08-MPLS Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71008-MPLS Command Reference
04-MPLS L3VPN Commands
04-MPLS L3VPN Commands 280.97 KB
MPLS L3VPN commands 1
description (VPN instance view) 1
display bgp group vpnv4· 1
display bgp peer vpnv4· 3
display bgp routing-table ipv4 unicast inlabel 6
display bgp routing-table ipv4 unicast outlabel 7
display bgp routing-table vpnv4· 8
display bgp routing-table vpnv4 advertise-info· 12
display bgp routing-table vpnv4 as-path-acl 14
display bgp routing-table vpnv4 community-list 15
display bgp routing-table vpnv4 inlabel 16
display bgp routing-table vpnv4 outlabel 17
display bgp routing-table vpnv4 peer 18
display bgp routing-table vpnv4 statistics 20
display ip vpn-instance· 21
domain-id· 22
export route-policy· 23
ext-community-type· 24
import route-policy· 25
ip binding vpn-instance· 26
ip vpn-instance (system view) 27
ipv4-family (VPN instance view) 27
ipv4-family vpnv4· 28
nesting-vpn· 29
peer next-hop-invariable· 29
peer upe· 30
peer upe route-policy· 31
policy vpn-target 32
refresh bgp vpnv4· 32
reserve-vlan (VPN instance view) 33
reset bgp vpnv4· 34
route-distinguisher (VPN instance view) 35
route-tag· 36
routing-table limit 37
rr-filter 38
tnl-policy (VPN instance view/IPv4 VPN view/IPv6 VPN view) 39
vpn popgo· 40
vpn-instance-capability simple· 41
vpn-target (VPN instance view/IPv4 VPN view/IPv6 VPN view) 41
IPv6 MPLS L3VPN commands 1
display bgp group vpnv6· 1
display bgp peer vpnv6· 2
display bgp routing-table vpnv6· 6
display bgp routing-table vpnv6 advertise-info· 9
display bgp routing-table vpnv6 as-path-acl 10
display bgp routing-table vpnv6 community-list 11
display bgp routing-table vpnv6 inlabel 13
display bgp routing-table vpnv6 outlabel 14
display bgp routing-table vpnv6 peer 15
display bgp routing-table vpnv6 statistics 16
ipv6-family (VPN instance view) 17
ipv6-family vpnv6· 18
policy vpn-target 18
refresh bgp vpnv6· 19
reset bgp vpnv6· 20
rr-filter 20
Use description to configure a description for a VPN instance.
Use undo description to delete the description.
No description is configured for a VPN instance.
VPN instance view
Default command level
2: System level
text: Description for the VPN instance, a case-sensitive string of 1 to 79 characters.
# Configure a description of "This is vpn1" for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] description This is vpn1
Use display bgp group vpnv4 to display information about a specific BGP VPNv4 peer group or all BGP VPNv4 peer groups.
display bgp group vpnv4 [ vpn-instance vpn-instance-name ] [ group-name ]
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, this command displays BGP VPNv4 peer group information for the public network.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. If no peer group is specified, this command displays all peer groups.
# Display all BGP VPNv4 peer groups for the public network.
<Sysname> display bgp group vpnv4
 BGP peer group: group1
 Remote AS number: not specified
 Type: external
  Members:
  10.1.1.1
# Display information about the BGP VPNv4 peer group named group1.
<Sysname> display bgp group vpnv4 group1
 Remote AS: 600
 Type: external
 Maximum number of prefixes allowed: 4294967295
 Threshold: 75%
 Configured hold time: 180 seconds
 Keepalive time: 60 seconds
 Minimum time between advertisements: 30 seconds
 Peer preferred value: 0
 Routing policy configured:
 Members:
  2.2.2.2                600        0        0    0       0 00:00:05 Idle
BGP peer-group
Name of the BGP peer group.
Remote AS
AS number of the peer group.
Type of the BGP peer group:
·       External—EBGP peer group
·       Internal—IBGP peer group
Maximum number of routes that can be learned from the peer group.
Threshold
Warning threshold. When the percentage of received route prefixes to the maximum number of routes reaches this threshold, the device generates a prompt.
Configured hold time, in seconds.
Keepalive time
Keepalive interval, in seconds.
Peer Preferred Value
Preferred value for routes received from the peer.
Routing policy configured for the peer group.
Members
Peers in the peer group.
Peer
IPv6 address of the peer.
AS
MsgRcvd
Number of messages received.
MsgSent
Number of messages sent.
OutQ
Number of messages waiting to be sent to the peer.
PrefRcv
Number of prefixes received.
Up/Down
Duration of the BGP session in the current state.
State of the peer.
Use display bgp peer vpnv4 to display information about BGP VPNv4 peers.
display bgp peer vpnv4 [ vpn-instance vpn-instance-name ] [ group-name log-info | ip-address { log-info | verbose } | verbose ]
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, this command displays BGP VPNv4 peer information for the public network.
group-name: Displays peers in the specified peer group. The group name is a case-sensitive string of 1 to 47 characters.
ip-address: Specifies a BGP VPNv4 peer.
log-info: Displays log information.
verbose: Displays detailed information.
With no parameters specified, this command displays brief information about all BGP VPNv4 peers.
# Display brief information about BGP VPNv4 peers for the public network.
<Sysname> display bgp peer vpnv4
 BGP local router ID: 1.1.1.9
 Local AS number: 100
 Total number of peers: 2                  Peers in established state: 1
  3.3.3.9                100       50       51    0       2 00:37:19 Established
BGP Local router ID
Router ID of the local BGP router.
Local AS number
Local AS number
Number of peers in the state of established.
Peer
IP address of the peer.
AS
AS number of the peer.
MsgRcvd
MsgSent
OutQ
PrefRcv
Number of received prefixes.
Up/Down
State of the peer.
# Display detailed information about BGP VPNv4 peer 10.1.1.1.
<Sysname> display bgp peer vpnv4 10.1.1.1 verbose
         Peer: 10.1.1.1  Local: 192.168.1.136
         Type: EBGP link
         BGP version 4, remote router ID 192.168.1.135
         BGP current state: Established, Up for 00h01m25s
         BGP last state: OpenConfirm
         Port:  Local - 179      Remote - 1049
         Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Peer optional capabilities:
         Peer support BGP multi-protocol extended
         Peer support BGP route refresh capability
         Peer support BGP route AS4 capability
         Address family IPv4 Unicast: received
         Address family VPNv4: advertised and received
 Received: Total 4 messages, Update messages 1
 Sent: Total 17 messages, Update messages 1
 Threshold: 75%
 Optional capabilities:
 Connect-interface has been configured
 Peer Preferred Value: 0
 BFD: Enabled
Peer
Local
IP address of the local router.
BGP link type, IBGP link or EBGP link.
BGP version
BGP version of the peer.
remote router ID
Router ID of the peer.
BGP current state
Current state of the BGP session.
Up for
Duration since the peer is established.
BGP current event
Current event of the BGP session.
BGP last state
State that the BGP session was in before transitioning to the current state.
Port
Local and remote ports of the BGP session.
Configured
Settings of the local timers, including the active hold interval and keepalive interval.
Received
Received active hold interval.
Negotiated
Negotiated active hold interval and keepalive interval.
Optional capabilities of the peer.
Peer support bgp multi-protocol extended
The peer supports multiprotocol extension.
Peer support bgp route refresh capability
The peer supports route refresh capability.
Peer support bgp route AS4 capability
The peer supports 4-byte AS number capability.
IPv4 unicast family capability.
Received
Total number of received messages and the number of received update messages.
Sent
Total number of sent messages and the number of sent update messages.
Maximum number of routes that can be learned from the peer.
Threshold
Warning threshold. When the percentage of the number of the received route prefixes to the maximum number of routes supported reaches this threshold, the device generates a prompt.
Local optional capabilities.
Preferred value for the routes from the peer.
BFD
Indicates whether BFD is enabled for the peer.
# Display log information for the BGP VPNv4 peer 10.1.1.1.
<Sysname> display bgp peer vpnv4 10.1.1.1 log-info
 Peer: 10.1.1.1
     Date      Time    State Notification
                             Error/SubError
  21-Nov-2011 12:36:58 Up
  21-Nov-2011 12:22:29 Down  Send notification with error 6/6
                             Cease/Other Configuration Change
  21-Nov-2011 12:07:09 Up
Use display bgp routing-table ipv4 unicast inlabel to display incoming labels for BGP IPv4 unicast routes.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] inlabel
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, this command displays incoming labels for BGP IPv4 unicast routes on the public network.
The unicast keyword does not affect the command output.
# Display incoming labels for all BGP IPv4 unicast routes on the public network.
<Sysname> display bgp routing-table ipv4 inlabel
 Total number of routes: 1
 BGP local router ID is 3.3.3.9
     Network            NextHop         OutLabel        InLabel
  >  2.2.2.9/32         1.1.1.2         1151            1279
BGP Local router ID
Status
Route status codes. See Table 6.
Origin
Route origin codes. See Table 6.
In/Out Label
Incoming/outgoing label.
Use display bgp routing-table ipv4 unicast outlabel to display outgoing labels for BGP IPv4 unicast routes.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] outlabel
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, this command displays outgoing labels for BGP IPv4 unicast routes on the public network.
# Display outgoing labels for all BGP IPv4 unicast routes on the public network.
<Sysname> display bgp routing-table ipv4 outlabel
Table 5 Command output
BGP Local router ID
Status
Origin
OutLabel
Outgoing label.
Use display bgp routing-table vpnv4 to display BGP VPNv4 routing information.
display bgp routing-table vpnv4 [ route-distinguisher route-distinguisher ] [ network-address [ { mask | mask-length } [ longest-match ] ] ]
route-distinguisher route-distinguisher: Specifies an RD, a string of 3 to 21 characters in one of these formats:
·           16-bit AS number:32-bit user-defined number. For example, 101:3.
·           32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·           32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
network-address: Destination network address.
mask: Network mask, in dotted decimal notation.
mask-length: Length of the network mask, in the range of 0 to 32.
longest-match: Displays the longest matching BGP VPNv4 route.
If none of network-address, mask, and mask-length are specified, the command displays brief information about all BGP VPNv4 routes.
If network-address mask or network-address mask-length is specified, the command displays detailed information about the BGP VPNv4 route that exactly matches the specified address and mask.
If only network-address is specified, the command displays detailed information about the BGP VPNv4 route that exactly matches the specified address and the natural mask.
# Display brief information about all BGP VPNv4 routes.
<Sysname> display bgp routing-table vpnv4
 BGP local router ID is 1.1.1.9
 Total number of routes from all PEs: 2
 Route distinguisher: 100:1(vpn1)
 Total number of routes: 6
  >  10.1.1.0/24        10.1.1.2        0                     32768   ?
*  e                    10.1.1.1        0                     0       65410?
  >  10.1.1.2/32        127.0.0.1       0                     32768   ?
  >i 10.3.1.0/24        3.3.3.9         0          100        0       ?
  >e 192.168.1.0        10.1.1.1        0                     0       65410?
*  i                    3.3.3.9         0          100        0       65420?
 Route distinguisher: 200:1
 Total number of routes: 2
  >i 192.168.1.0        3.3.3.9         0          100        0       65420?
# Display brief information about BGP VPNv4 routes with RD 100:1..
<Sysname> display bgp routing-table vpnv4 route-distinguisher 100:1
Table 6 Command output
BGP Local router ID
Status codes
Route status codes:
·       * - valid—Valid route.
·       > - best—Common best route.
·       d – damped—Route damped for route flap.
·       h - history—History route.
·       i - internal—Internal route.
·       e - external—External route.
·       s - suppressed—Suppressed route.
·       S - Stale—Stale route.
Origin
Route origin:
·       i—IGP, originated in the AS. The origin of summary routes and routes advertised by the network command is IGP.
·       e—EGP, learned through EGP.
·       ?—Incomplete. The origin of routes redistributed from IGP protocols is Incomplete.
Total number of VPNv4 routes from all PEs.
Network
Network address.
NextHop
Address of the next hop.
MED
MED value.
LocPrf
Local preference value.
PrefVal
Preferred value.
Path/Ogn
AS_PATH and Origin attributes.
# Display detailed information about the BGP VPNv4 route destined for 10.3.1.0/24.
<Sysname> display bgp routing-table vpnv4 10.3.1.0 24
 Paths:   1 available, 1 best
 Relay nexthop   : 172.1.1.2
 Original nexthop: 3.3.3.9
 OutLabel        : 1279
 Ext-Community   : <RT: 111:1>
 AS-path         : (null)
 Origin          : incomplete
 State           : valid, internal, best,
 OutLabel        : 1279
 AS-path         : (null)
 Origin          : incomplete
# Display detailed information about the BGP VPNv4 route destined for 10.3.1.0/24 and with RD 100:1.
<Sysname> display bgp routing-table vpnv4 route-distinguisher 100:1 10.3.1.0 24
 OutLabel        : 1279
 AS-path         : (null)
 Origin          : incomplete
Table 7 Command output
Relay Nexthop
Recursive next hop. If no recursive next hop is found, "not resolved" is displayed.
Original nexthop
Original next hop. If the route is learned from a BGP update, it is the next hop in the update message.
Ext-Community
Extended community attribute.
Attribute value
BGP route attribute information:
·       MED—MED attribute.
·       Localpref—Local preference.
·       pref-val—Preferred value.
·       pre—Protocol preference.
Route status:
·       valid—Valid route.
·       internal—Internal route.
·       external—External route.
·       local—Locally generated route.
·       synchronize—Synchronized route.
·       best—Best route.
Use display bgp routing-table vpnv4 advertise-info to display advertisement information for BGP VPNv4 routes.
display bgp routing-table vpnv4 [ route-distinguisher route-distinguisher ] network-address [ mask | mask-length ] advertise-info
·           If the mask and mask-length arguments are not specified, the system ANDs the specified network address with the mask of each route. If the result matches the network address of the route, the command displays advertisement information for the route.
·           If the mask or mask-length argument is specified, the command displays advertisement information for the BGP VPNv4 route that exactly matches the specified address and mask.
# Display advertisement information for the BGP VPNv4 route destined to network 10.2.1.0/24.
<Sysname> display bgp routing-table vpnv4 10.1.1.0 24 advertise-info
 Paths:   1 best
 BGP routing table information of 10.1.1.0/24:
    3.3.3.9
 Inlabel         : 1279
Use display bgp routing-table vpnv4 as-path-acl to display BGP IPv4 unicast routes permitted by an AS path ACL.
display bgp routing-table vpnv4 [ route-distinguisher route-distinguisher ] as-path-acl as-path-acl-number
as-path-acl-number: Specifies an AS path ACL by its number in the range of 1 to 256.
# Display BGP VPNv4 routes permitted by AS path ACL 1.
<Sysname> display bgp routing-table vpnv4 as-path-acl 1
For command output, see Table 6.
ip as-path (Layer 3—IP Routing Configuration Guide)
Use display bgp routing-table vpnv4 community-list to display BGP VPNv4 routing information matching a specified BGP community list.
display bgp routing-table vpnv4 [ route-distinguisher route-distinguisher ] community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }
basic-community-list-number: Specifies a basic community list by its number in the range of 1 to 99.
comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters.
whole-match: Displays routes exactly matching the specified community list. Without this keyword, the command displays routes whose COMMUNITY attributes comprise the specified community list.
adv-community-list-number: Specifies an advanced community list by its number in the range of 100 to 199.
# Display BGP VPNv4 routing information matching BGP community list 100.
<Sysname> display bgp routing-table vpnv4 community-list 100
Use display bgp routing-table vpnv4 inlabel to display incoming labels for BGP VPNv4 routes.
# Display incoming labels for all BGP VPNv4 routes.
<Sysname> display bgp routing-table vpnv4 inlabel
  >  10.1.1.0/24        10.1.1.2        NULL            1279
  >e 192.168.1.0        10.1.1.1        NULL            1278
Table 8 Command output
BGP Local router ID
Status codes
Origin
Route origin. See Table 6.
Use display bgp routing-table vpnv4 outlabel to display ougoing labels for BGP VPNv4 routes.
# Display outgoing labels for all BGP VPNv4 routes.
<Sysname> display bgp routing-table vpnv4 outlabel
  >i 10.3.1.0/24        3.3.3.9         1279
*  i 192.168.1.0        3.3.3.9         1278
  >i 192.168.1.0        3.3.3.9         1278
Table 9 Command output
BGP Local router ID
Status
Origin
OutLabel
Outgoing label.
Use display bgp routing-table vpnv4 peer to display BGP VPNv4 routing information advertised to or received from a specified BGP peer.
display bgp routing-table vpnv4 [ vpn-instance vpn-instance-name ] peer ip-address { advertised-routes | received-routes } [ network-address [ mask | mask-length ] | statistics ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, the command displays BGP VPNv4 routing information advertised to or received from the specified BGP peer on the public network.
ip-address: Specifies a peer by its IP address.
advertised-routes: Displays routing information advertised to the specified peer.
received-routes: Displays routing information received from the specified peer.
network-address: Specifies the IP address of the destination network.
mask: Specifies the mask of the destination network, in dotted decimal notation.
mask-length: Specifies a mask length in the range of 0 to 32.
statistics: Displays route statistics.
If none of network-address, mask, and mask-length are specified, the command displays all BGP VPNv4 routing information advertised to or received from the specified BGP peer.
If the network-address argument is specified without mask or mask-length, the system ANDs the network address with the mask of a route. If the result matches the network address of the route, the command displays information about the route.
If network-address mask or network-address mask-length is specified, the command displays information about the route that exactly matches the specified address and mask (or mask length).
# Display all BGP VPNv4 routing information advertised to BGP peer 3.3.3.9 on the public network.
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 advertised-routes
     Network            NextHop         MED        LocPrf             Path/Ogn
  >  10.1.1.0/24        10.1.1.2        0                             ?
  >e 192.168.1.0        10.1.1.1        0                             65410?
# Display all BGP VPNv4 routing information received from BGP peer 3.3.3.9 on the public network.
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 received-routes
# Display statistics for BGP VPNv4 routes advertised to BGP peer 3.3.3.9 on the public network.
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 advertised-routes statistics
 Advertised routes total: 2
# Display statistics for BGP VPNv4 routes received from BGP peer 3.3.3.9 on the public network.
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 received-routes statistic
 Received routes total: 2
Table 10 Command output
Total number of routes advertised to the specified peer.
Total number of routes received from the specified peer.
Use display bgp routing-table vpnv4 statistics to display BGP VPNv4 route statistics.
# Display BGP VPNv4 route statistics for the public network.
<Sysname> display bgp routing-table vpnv4 statistics
Use display ip vpn-instance to display information about VPN instances.
display ip vpn-instance [ instance-name vpn-instance-name ]
instance-name vpn-instance-name: Displays information about the specified VPN instance. The vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, the command displays brief information about all VPN instances.
# Display brief information about all VPN instances.
<Sysname> display ip vpn-instance
  VPN-Instance Name               RD                     Create time
  abc                             1:1                    2011/05/18 10:48:17
Table 11 Command output
VPN-Instance Name
Name of the VPN instance.
RD
RD of the VPN instance.
Create Time
Time when the VPN instance was created.
# Display detailed information about VPN instance vpn1.
<Sysname> display ip vpn-instance instance-name vpn1
  VPN-Instance Name and ID : vpn1, 2
  Route Distinguisher : 100:1
  Description : vpn1
  Interfaces : GigabitEthernet3/0/2
  Ipv4-family:
   Export VPN Targets :
       2:2
   Import VPN Targets :
       3:3
   Export Route Policy : outpolicy
   Import Route Policy : inpolicy
   Tunnel Policy : tunnel1
   Maximum Routes Limit : 5000
  Ipv6-family:
       2:2
       3:3
domain-id
Use domain-id to configure an OSPF domain ID.
Use undo domain-id to restore the default.
undo domain-id [ domain-id ]
The OSPF domain ID is 0.
OSPF view
domain-id: OSPF domain ID, in one of these formats:
·           Integer, in the range of 0 to 4294967295. For example, 1.
·           Dotted decimal notation. For example, 0.0.0.1.
·           Dotted decimal notation:16-bit user-defined number in the range of 0 to 65535. For example, 0.0.0.1:512.
secondary: Specifies a secondary domain ID. Without this keyword, the command specifies a primary domain ID.
When you redistribute OSPF routes into BGP, BGP adds the configured OSPF domain ID to the redistributed BGP VPN routes as a BGP extended community attribute and advertises the routes to the BGP peer. When you redistribute the BGP VPN routes into OSPF on the BGP peer, OSPF uses the domain ID to determine whether the routes belong to the same OSPF routing domain. If yes and the routes are intra-area routes, OSPF advertises these routes in Summary LSAs (Type 3). If yes but the routes are not intra-area routes, OSPF advertises these routes in AS External LSAs (Type 5) or NSSA External LSAs (Type 7). If not, OSPF advertises these routes in Type 5 or Type 7 LSAs.
With no parameter specified, the undo domain-id command deletes all domain IDs.
# Configure an OSPF domain ID.
[Sysname] ospf 100
[Sysname-ospf-100] domain-id 234
export route-policy
Use export route-policy to apply an export routing policy for a VPN instance.
Use undo export route-policy to remove the application.
No export routing policy is applied for a VPN instance.
VPN instance view, IPv4 VPN view, IPv6 VPN view
route-policy: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
You can specify an export routing policy to filter advertised routes or modify their route attributes for the VPN instance.
An export routing policy specified in VPN instance view applies to both IPv4 VPN and IPv6 VPN.
An export routing policy specified in IPv4 VPN view or IPv6 VPN view applies to only IPv4 VPN or IPv6 VPN.
IPv4/IPv6 VPN prefers the export routing policy specified in IPv4/IPv6 VPN view over the one specified in VPN instance view.
# Apply export routing policy poly-1 for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] export route-policy poly-1
# Apply export routing policy poly-2 for IPv4 VPN vpn2.
[Sysname] ip vpn-instance vpn2
[Sysname-vpn-instance-vpn2] ipv4-family
[Sysname-vpn-ipv4-vpn2] export route-policy poly-2
# Apply export routing policy poly-3 for IPv6 VPN vpn3.
[Sysname] ip vpn-instance vpn3
[Sysname-vpn-instance-vpn3] ipv6-family
[Sysname-vpn-ipv6-vpn3] export route-policy poly-3
·           import route-policy
·           route-policy (Layer 3—IP Routing Configuration Guide)
ext-community-type
Use ext-community-type to configure the type code of an OSPF extended community attribute.
Use undo ext-community-type to restore the default.
undo ext-community-type { domain-id | router-id | route-type }
The type codes for domain ID, router ID, and route type are 0x0005, 0x0107, and 0x0306, respectively.
OSPF view
domain-id type-code1: Specifies the type code for domain ID. Valid values are 0x0005, 0x0105, 0x0205, and 0x8005.
router-id type-code2: Specifies the type code for router ID. Valid values are 0x0107 and 0x8001.
router-type type-code3: Specifies the type code for route type. Valid values are 0x0306 and 0x8000.
# Configure the type codes of domain ID, router ID, and route type as 0x8005, 0x8001, and 0x8000 for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] ext-community-type domain-id 8005
[Sysname-ospf-100] ext-community-type router-id 8001
[Sysname-ospf-100] ext-community-type route-type 8000
import route-policy
Use import route-policy to apply an import routing policy for a VPN instance.
Use undo import route-policy to remove the application.
All routes matching the import target attribute are accepted.
You can specify an import routing policy to filter received routes or modify their route attributes for the VPN instance.
An import routing policy specified in VPN instance view applies to both IPv4 VPN and IPv6 VPN.
An import routing policy specified in IPv4 VPN view or IPv6 VPN view applies to only the IPv4 VPN or IPv6 VPN.
IPv4/IPv6 VPN prefers the import routing policy specified in IPv4/IPv6 VPN view over the one specified in VPN instance view.
# Apply import routing policy poly-1 for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] import route-policy poly-1
# Apply import routing policy poly-2 for IPv4 VPN vpn2.
[Sysname-vpn-ipv4-vpn2] import route-policy poly-2
# Apply import routing policy poly-3 for IPv6 VPN vpn3.
[Sysname-vpn-ipv6-vpn3] import route-policy poly-3
·           export route-policy
Use ip binding vpn-instance to associate an interface with a VPN instance.
Use undo ip binding vpn-instance to remove the association.
undo ip binding vpn-instance vpn-instance-name
An interface is associated with no VPN instance and belongs to the public network.
Interface view
Use the command to associate the VPN instance with the interface connected to the CE.
This command or its undo form clears the IP address and routing protocol configuration on the interface. After executing this command or its undo form, use the display this command to view current configuration and re-configure the IP address and routing protocol on the interface.
The specified VPN instance must have been created by the ip vpn-instance command in system view.
To associate a new VPN instance with an interface, you must remove the previous association with the undo ip binding vpn-instance command and then use the ip binding vpn-instance command to associate the new VPN instance with the interface.
If you configure an IPv6 address for an interface associated with a VPN instance, the number of VPN instances that you can configure on the device decreases.
# Associate interface VLAN-interface 1 with VPN instance vpn1.
[Sysname-Vlan-interface1] ip binding vpn-instance vpn1
Use ip vpn-instance to create a VPN instance and enter VPN instance view.
Use undo ip vpn-instance to delete a VPN instance.
No VPN instance is created.
vpn-instance-name: Specifies the name of the VPN instance, a case-sensitive string of 1 to 31 characters.
# Create a VPN instance named vpn1.
route-distinguisher
Use ipv4-family in VPN instance view to enter IPv4 VPN view.
Use undo ipv4-family to remove all configurations from IPv4 VPN view.
ipv4-family
undo ipv4-family
VPN instance view
In IPv4 VPN view, you can configure IPv4 VPN parameters such as inbound and outbound routing policies.
# Enter IPv4 VPN view.
[Sysname-vpn-instance-vpn1] ipv4-family
[Sysname-vpn-ipv4-vpn1]
ipv4-family vpnv4
Use ipv4-family vpnv4 to enter BGP VPNv4 address family view or BGP-VPN VPNv4 address family view.
Use undo ipv4-family vpnv4 to remove all settings from BGP VPNv4 address family view or BGP-VPN VPNv4 address family view.
ipv4-family vpnv4
BGP view, BGP-VPN view
A VPNv4 address comprises an RD and an IPv4 prefix. VPNv4 routes comprise VPNv4 addresses.
For a PE to exchange BGP VPNv4 routes with a BGP peer, you must enable that peer by executing the peer enable command in BGP VPNv4 address family view or BGP-VPN VPNv4 address family view.
In BGP VPNv4 address family view, you can configure BGP VPNv4 route attributes, such as the preferred value, and whether to allow the local AS number to appear in the AS_PATH attribute of received route updates.
The settings in BGP VPNv4 address family view control VPNv4 route exchange between PEs.
The settings in BGP-VPN VPNv4 address family view control VPNv4 route exchange between provide PE and provider CE in nested MPLS L3VPN.
# Enter BGP-VPNv4 address family view.
[Sysname] bgp 100
[Sysname-bgp] ipv4-family vpnv4
[Sysname-bgp-vpnv4]
# Enter BGP-VPN VPNv4 address family view.
[Sysname] bgp 100
[Sysname-bgp] ip vpn-instance vpn1
[Sysname-bgp-vpn1] ipv4-family vpnv4
[Sysname-bgp-vpnv4-vpn1]
nesting-vpn
Use nesting-vpn to enable the nested VPN function.
Use undo nesting-vpn to disable the nested VPN function.
nesting-vpn
undo nesting-vpn
The nested VPN function is disabled.
To exchange VPNv4 routes with a peer in nested VPN, you must enable nested VPN and then execute the peer enable command to enable that peer in BGP VPNv4 view.
# Enable nested VPN.
[Sysname] bgp 10
[Sysname-bgp-vpnv4] nesting-vpn
Use peer next-hop-invariable to configure the device to not change the next hop of routes advertised to an EBGP peer or peer group.
Use undo peer next-hop-invariable to restore the default.
peer { group-name | ip-address } next-hop-invariable
undo peer { group-name | ip-address } next-hop-invariable
The device uses its address as the next hop of routes advertised to an EBGP peer or peer group.
On an RR in an inter-AS option C scenario, you must configure next-hop-invariable to not change the next hop of VPNv4 routes advertised to EBGP peers and RR clients.
This command is exclusive with the peer next-hop-local command.
# In BGP VPNv4 address family view, configure the device to not change the next hop of routes advertised to EBGP peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-vpnv4] peer 1.1.1.1 next-hop-invariable
peer next-hop-local (Layer 3—IP Routing Command Reference)
peer upe
Use peer upe to configure a BGP peer or peer group as a HoVPN UPE in BGP VPNv4 address family view.
Use undo peer upe to remove the configuration.
peer { group-name | ip-address } upe
undo peer { group-name | ip-address } upe
No BGP peer or peer group is configured as a UPE.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The specified peer group must have been created.
ip-address: Specifies a peer by its IP address. The specified peer must have been created.
A UPE is a special VPNv4 peer. It can accept one default route for each related VPN instance and routes permitted by the routing policy on the SPE. An SPE is a common VPN peer.
# Configure peer 1.1.1.1 as a UPE.
[Sysname] bgp 100
[Sysname-bgp-vpnv4] peer 1.1.1.1 upe
Use peer upe route-policy to advertise routes permitted by a routing policy to a UPE.
Use undo peer upe route-policy to restore the default.
peer { group-name | ip-address } upe route-policy route-policy-name export
undo peer { group-name | ip-address } upe route-policy route-policy-name export
No routes are advertised to any peer.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The specific peer group must have created.
ip-address: Specifies a peer by its IP address. The specific peer must have created.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
export: Applies the filtering policy to routes to be advertised.
This command must be used together with the peer upe command
# In BGP VPNv4 address family view, configure peer 1.1.1.1 as a UPE and advertise routes permitted by routing policy hope to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 as-number 200
[Sysname-bgp-vpnv4] peer 1.1.1.1 enable
[Sysname-bgp-vpnv4] peer 1.1.1.1 upe route-policy hope export
·           peer upe
policy vpn-target
Use policy vpn-target to enable route target filtering of received VPNv4 routes. Only VPNv4 routes whose route target attribute matches local import route target attribute are added to the routing table.
Use undo policy vpn-target to disable route target filtering, permitting all incoming VPNv4 routes.
policy vpn-target
The route target filtering function is enabled for received VPNv4 routes.
In an inter-AS option B scenario, an ASBR-PE must save all incoming VPNv4 routes and advertises those routes to the peer ASBR-PE. For this purpose, you must execute the undo policy vpn-target command on the ASBR-PE to disable route target filtering.
# In BGP VPNv4 address family view, disable route target filtering of received VPNv4 routes.
[Sysname] bgp 100
[Sysname-bgp-vpnv4] undo policy vpn-target
refresh bgp vpnv4
Use refresh bgp vpnv4 to soft reset BGP VPNv4 connections.
refresh bgp { ip-address | all | external | group group-name | internal } { export | import } vpnv4  [ vpn-instance vpn-instance-name ]
ip-address: Soft resets the BGP VPNv4 connection with the BGP peer identified by this IP address.
all: Soft resets all BGP VPNv4 connections.
external: Soft resets EBGP VPNv4 connections.
group group-name: Soft resets BGP VPNv4 connections with the BGP peer group identified by this name, a case-sensitive string of 1 to 47 characters.
internal: Soft resets IBGP VPNv4 connections.
export: Soft resets outbound EBGP VPNv4 connections.
import: Soft resets inbound EBGP VPNv6 connections.
vpn-instance vpn-instance-name: Soft resets BGP VPNv4 connections for the VPN instance specified by its name, a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, this command soft resets BGP VPNv4 connections for the public network.
Soft reset can update BGP VPNv4 routing information without breaking down BGP neighbor relationships.
You can apply a new route selection policy by executing this command. If you execute this command with the export keyword, BGP filters advertised routing information based on the new policy and sends the matching routes to the BGP peer. If you execute this command with the import keyword, BGP advertises a route-refresh message to the peer so the peer re-advertises its routing information. After receiving the routing information from the peer, BGP filters the routing information by using the new policy.
This command requires that both the local router and the peer support route refresh.
If the peer keep-all-routes command is configured, the refresh bgp vpnv4 import command does not take effect.
# Soft reset all inbound BGP VPNv4 connections for the public network.
<Sysname> refresh bgp all import vpnv4
·           peer capability-advertise route-refresh (Layer 3—IP Routing Command Reference)
·           peer keep-all-routes (Layer 3—IP Routing Command Reference)
Use reserve-vlan to specify a reserved VLAN for a VPN instance.
Use undo reserve-vlan to restore the default.
reserve-vlan vlan-id
undo reserve-vlan
No reserved VLAN is specified for a VPN instance.
VPN instance view
vlan-id: Specifies a reserved VLAN by its VLAN ID in the range of 1 to 4094.
The reserved VLAN of a VPN instance provides resources for the VPN instance to complete packet forwarding.
A common VLAN, including a default VLAN, a VLAN created by vlan, and a dynamically learned VLAN, cannot be specified as a reserved VLAN. After you specify a VLAN as the reserved VLAN of a VPN instance, the VLAN cannot be created by the vlan command, or dynamically learned.
Reserved VLANs specified for VPN instances must be different.
The reserved VLAN configuration takes effect only when the system is operating in standard mode. For more information about system operating modes, see Fundamentals Configuration Guide.
When the system is operating in standard mode, you must configure a reserved VLAN for a created VPN instance in the following cases:
·           The VPN instance is connected to no CEs.
·           There is no need to configure the multicast VPN function for the VPN instance.
·           There is no need to bind the VPN instance to an IP tunnel.
When the system is operating in standard mode, if a VPN instance is not configured with a reserved VLAN, you cannot configure URPF on the private network VLAN interface bound to the VPN instance.
# Specify VLAN 100 as the reserved VLAN of VPN instance vpn1.
[Sysname-vpn-instance-vpn1] reserve-vlan 100
vlan (Layer 2—LAN Switching Command Reference)
reset bgp vpnv4
Use reset bgp vpnv4 to reset BGP VPNv4 connections.
reset bgp { as-number | ip-address | all | external | group group-name | internal } vpnv4 [ vpn-instance vpn-instance-name ]
as-number: Resets BGP VPNv4 connections in the AS specified by its number in the range of 1 to 4294967295.
ip-address: Resets the BGP VPNv4 connection with the BGP peer identified by this IP address.
all: Resets all BGP VPNv4 connections.
external: Resets EBGP VPNv4 connections.
group group-name: Resets BGP VPNv4 connections with the BGP peer group identified by this name, a case-sensitive string of 1 to 47 characters.
internal: Resets IBGP VPNv4 connections.
vpn-instance vpn-instance-name: Resets BGP VPNv4 connections for the VPN instance identified by its name, a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, the command resets BGP VPNv4 connections for the public network.
This command tears down specified BGP neighbor relationships to update BGP VPNv4 routes with the new policy.
# Reset all BGP VPNv4 connections for the public network.
<Sysname> reset bgp all vpnv4
Use route-distinguisher to configure an RD for a VPN instance.
Use undo route-distinguisher to remove the RD of a VPN instance.
No RD is specified for a VPN instance.
VPN instance view
route-distinguisher: RD for the VPN instance, a string of 3 to 21 characters in one of these formats:
RDs enable VPNs to use the same address space. An RD and an IPv4 prefix comprise a unique VPN IPv4 prefix.
To change the RD of a VPN instance, you must delete the RD with the undo route-distinguisher command, and then use the route-distinguisher command to configure a new RD.
# Configure RD 22:1 for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] route-distinguisher 22:1
route-tag
Use route-tag to configure an external route tag for redistributed VPN routes.
Use undo route-tag to restore the default.
route-tag tag-value
undo route-tag
If the AS number is not greater than 65535, the first two octets of the default external route tag are 0xD000 and the last two octets is the local AS number. For example, if the local BGP AS number is 100, the default value of the external route tag is 3489661028. If the AS number is greater than 65535, the default external route tag is 0.
OSPF view
tag-value: External route tag for redistributed VPN routes, in the range of 0 to 4294967295.
If the PE-CE routing protocol is OSPF, the PE redistributes BGP VPNv4 routes received from the peer PE into the OSPF routing table, and advertises these routes to the locally connected CE through OSPF. If the routes are advertised to the CE in Type 5 or 7 LSAs, Type 5/7 LSAs must contain the external route tag. An external route tag can be configured by different commands and has different priorities. The following lists the commands used to configure the external route tag (in the descending order of tag priority):
·           import-route
·           route-tag
·           default tag
If the external route tag carried in a Type 5 or 7 LSA received by a PE is the same as the locally configured external route tag, the PE ignores the LSA in route calculation to avoid routing loops.
H3C recommends configuring the same external route tag for PEs in the same area.
An external route tag is not transferred in any BGP extended community attribute. It is only locally significant and takes effect only on the PEs that receive BGP routes and generate OSPF Type 5 or 7 LSAs.
You can configure the same external route tag for different OSPF processes.
# In OSPF process 100, set the external route tag for redistributed VPN routes to 100.
[Sysname] ospf 100
[Sysname-ospf-100] route-tag 100
import-route
routing-table limit
Use routing-table limit to limit the maximum number of routes in a VPN instance.
Use undo routing-table limit to restore the default.
The maximum number of routes depends on the system operating mode.
number: Specifies the maximum number of routes. The value range depends on the system operating mode. For more information about system operating modes, see Fundamentals Configuration Guide.
warn-threshold: Specifies a warning threshold, in the range of 1 to 100 in percentage. When the percentage of the number of existing routes to the maximum number of routes exceeds the specified threshold, the system gives an alarm message but still allows new routes. If routes in the VPN instance reach the maximum, no more routes are added.
simply-alert: Specifies that when routes exceeds the maximum number, the system still accepts routes but generates a system log message.
A limit configured in VPN instance view applies to both the IPv4 VPN and the IPv6 VPN.
A limit configured in IPv4 VPN view or IPv6 VPN view applies to only the IPv4 VPN or the IPv6 VPN.
IPv4/IPv6 VPN prefers the limit configured in IPv4/IPv6 VPN view over the limit configured in VPN instance view.
# Specify that VPN instance vpn1 supports up to 1000 routes, and when routes exceed the upper limit, can receive new routes but generates a system log message.
[Sysname-vpn-instance-vpn1] routing-table limit 1000 simply-alert
# Specify that the IPv4 VPN vpn2 supports up to 1000 routes, and when routes exceed the upper limit, can receive new routes but generates a system log message.
[Sysname-vpn-instance-vpn2] route-distinguisher 100:2
[Sysname-vpn-ipv4-vpn2] routing-table limit 1000 simply-alert
# Specify that the IPv6 VPN vpn3 supports up to 1000 routes, and when routes exceed the upper limit, can receive new routes but generates a system log message.
[Sysname-vpn-instance-vpn3] route-distinguisher 100:3
[Sysname-vpn-ipv4-vpn3] routing-table limit 1000 simply-alert
rr-filter
Use rr-filter to create an RR reflection policy so that only IBGP routes whose extended community attribute matches the specified extended community list are reflected.
Use undo rr-filter to restore the default.
rr-filter extended-community-number
undo rr-filter
An RR does not filter reflected routes.
extended-community-number: Specifies an extended community list by its number, in the range of 1 to 199.
By configuring different RR reflection policies on RRs in a cluster, you can implement load balancing among the RRs.
# In BGP VPNv4 address family view, configure the RR to only reflect VPNv4 routes with an extended community number of 10.
[Sysname] bgp 100
[Sysname-bgp-vpnv4] rr-filter 10
Use tnl-policy to associate a VPN instance with a tunnel policy.
Use undo tnl-policy to remove the association.
tnl-policy tunnel-policy-name
undo tnl-policy
No tunnel policy is associated with a VPN instance.
tunnel-policy-name: Specifies a tunnel policy by its name, a case-insensitive string of 1 to 19 characters.
The VPN instance uses the specified tunnel policy to select tunnels for traffic.
If a VPN instance is not associated with any tunnel policy or the associated tunnel policy is not configured, the VPN instance selects tunnels according to the default tunnel policy. The default tunnel policy selects only one tunnel in this order: LSP tunnel, GRE tunnel, CR-LSP tunnel.
A tunnel policy specified in VPN instance view is applicable to both the IPv4 VPN and the IPv6 VPN.
A tunnel policy specified in IPv4 VPN view or IPv6 VPN view is applicable to only the IPv4 VPN or IPv6 VPN.
IPv4/IPv6 VPN prefers the tunnel policy specified in IPv4/IPv6 VPN view over the tunnel policy specified in VPN instance view.
# Associate VPN instance vpn1 with tunnel policy po1.
[Sysname] tunnel-policy po1
[Sysname-tunnel-policy-po1] select-seq lsp load-balance-number 1
[Sysname-tunnel-policy-po1] quit
[Sysname-vpn-instance-vpn1] route-distinguisher 22:33
[Sysname-vpn-instance-vpn1] tnl-policy po1
# Associate the IPv4 VPN vpn2 with tunnel policy po1.
[Sysname-vpn-instance-vpn2] route-distinguisher 11:22
[Sysname-vpn-ipv4-vpn2] tnl-policy po1
[Sysname-vpn-ipv4-vpn2] quit
[Sysname-vpn-instance-vpn2] quit
# Associate the IPv6 VPN vpn3 with tunnel policy po1.
[Sysname-vpn-instance-vpn3] route-distinguisher 11:33
[Sysname-vpn-ipv6-vpn3] tnl-policy po1
tunnel-policy (MPLS Command Reference)
vpn popgo
Use vpn popgo to specify the VPN label processing mode as POPGO forwarding on an egress PE, which will pop the label for each packet and forward the packet out of the interface corresponding to the label.
Use undo vpn popgo to restore the default.
vpn popgo
undo vpn popgo
The VPN label processing mode is POP forwarding on an egress PE, which will pop the label for each packet and forward the packet through the FIB table.
BGP view
After you execute the vpn popgo command, the egress PE disconnects and reestablishes BGP sessions to re-learn VPN routes.
After the vpn popgo command is executed, the egress PE does not support load sharing among VPN BGP peers.
To add two switches to an IRF fabric, configure the same VPN label processing mode (POPGO by using vpn popgo or POP by using undo vpn popgo) for the two switches. Otherwise, the two switches cannot form an IRF fabric. For more information about IRF, see IRF Configuration Guide.
# Specify the VPN label processing mode on the egress PE as POPGO forwarding.
[Sysname] bgp 100
[Sysname-bgp] vpn popgo
# Specify the VPN label processing mode on the egress PE as POP forwarding.
[Sysname] bgp 100
[Sysname-bgp] undo vpn popgo
Use vpn-instance-capability simple to disable OSPF routing loop detection for a VPN instance.
Use undo vpn-instance-capability to restore the default.
OSPF routing loop detection is enabled for a VPN instance.
OSPF view
In an MCE network, you must disable OSPF routing loop detection for a VPN instance on the MCE. Otherwise, the MCE does not receive OSPF routes from the PE.
# Disable OSPF routing loop detection for VPN instance vpna.
[Sysname] ospf 100 vpn-instance vpna
[Sysname-ospf-100] vpn-instance-capability simple
Use vpn-target to configure route targets for a VPN instance.
Use undo vpn-target to remove the specified or all route targets of a VPN instance.
No route targets are configured for a VPN instance.
vpn-target&<1-8>: Specifies route targets. &<1-8> means that you can specify up to eight route targets.
A route target is a string of 3 to 21 characters in one of these formats:
·           32-bit AS number:16-bit user-defined number, where the AS number must not be less than 65536. For example, 65536:1.
both: Uses the specified route targets as both import targets and export targets. The both keyword is also used when you do not specify any of both, export-extcommunity, and import-extcommunity.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Removes all route targets.
MPLS L3VPN uses route targets to control the advertisement of VPN routing information. A PE adds the configured export targets into the route target attribute of routes advertised to a peer. The peer uses the local import targets to match the route targets of received routes. If a match is found, the peer adds the routes to the routing table of the VPN instance.
Route targets configured in VPN instance view are applicable to both the IPv4 VPN and the IPv6 VPN.
Route targets configured in IPv4 VPN view or IPv6 VPN view are applicable to only the IPv4 VPN or IPv6 VPN.
Route targets configured in IPv4 VPN view or IPv6 VPN view take precedence over those configured in VPN instance view. If you configure route targets in both IPv4 VPN view (or IPv6 VPN view) and VPN instance view, the IPv4 VPN or IPv6 VPN uses the route targets configured in IPv4 VPN view or IPv6 VPN view.
# Configure route targets for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] vpn-target 3:3 export-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 4:4 import-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 5:5 both
# Configure route targets for the IPv4 VPN vpn2.
[Sysname-vpn-ipv4-vpn2] vpn-target 3:3 export-extcommunity
[Sysname-vpn-ipv4-vpn2] vpn-target 4:4 import-extcommunity
[Sysname-vpn-ipv4-vpn2] vpn-target 5:5 both
# Configure route targets for the IPv6 VPN vpn3.
[Sysname-vpn-ipv6-vpn3] vpn-target 3:3 export-extcommunity
[Sysname-vpn-ipv6-vpn3] vpn-target 4:4 import-extcommunity
[Sysname-vpn-ipv6-vpn3] vpn-target 5:5 both
This chapter describes only IPv6 MPLS L3VPN-specific commands. For information about the commands available for both IPv4 MPLS L3VPN and IPv6 MPLS L3VPN, see "MPLS L3VPN commands."
Use display bgp group vpnv6 to display information about a specific BGP VPNv6 peer group or all BGP VPNv6 peer groups.
display bgp group vpnv6 [ group-name ]
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. If no peer group is specified, this command displays all BGP VPNv6 peer groups.
# Display all BGP VPNv6 peer groups for the public network.
<Sysname> display bgp group vpnv6
 Remote AS: 600
 Type: external
 Members:
  2.2.2.2
# Display information about the BGP VPNv6 peer group named group1.
<Sysname> display bgp group vpnv6 group1
 Remote AS: 600
 Type: external
 Threshold: 75%
 Members:
  2.2.2.2                600        0        0    0       0 00:00:22 Idle
Table 12 Command output
BGP peer-group
Remote AS
Threshold
Keepalive time
Members
Peer
AS
MsgRcvd
MsgSent
OutQ
PrefRcv
Up/Down
State of the peer.
Use display bgp peer vpnv6 to display information about BGP VPNv6 peers.
display bgp peer vpnv6 [ group-name log-info | ip-address { log-info | verbose } | verbose ]
group-name: Displays peers in the peer group specified by its name, a case-sensitive string of 1 to 47 characters.
ip-address: Specifies a BGP VPNv6 peer. If no peer is specified, the command displays all BGP VPNv6 peers.
verbose: Displays detailed information. If this keyword is not specified, the command displays brief information.
With no parameters specified, this command displays brief information about all BGP VPNv6 peers.
# Display brief information about all BGP VPNv6 peers for the public network.
<Sysname> display bgp peer vpnv6
 Local AS number: 300
 Total number of peers: 1                  Peers in established state: 1
  10.1.1.2               100        6        7    0       0 00:01:57 Established
Table 13 Command output
BGP Local router ID
Local AS number
Local AS number
Peer
AS
MsgRcvd
MsgSent
OutQ
PrefRcv
Up/Down
State of the peer.
# Display detailed information about BGP VPNv6 peer 10.1.1.2.
<Sysname> display bgp peer vpnv6 10.1.1.2 verbose
         Peer: 10.1.1.2  Local: 192.168.1.135
         Type: EBGP link
         BGP version 4, remote router ID 192.168.1.136
         BGP current state: Established, Up for 00h02m28s
         Port:  Local - 179      Remote - 63679
         Address family IPv4 Unicast: advertised
         Address family VPNv6: advertised and received
 Received: Total 6 messages, Update messages 2
 Sent: Total 7 messages, Update messages 2
 Threshold: 75%
 BFD: Enabled
Table 14 Command output
Peer
Local
BGP version
remote router ID
BGP current state
Up for
BGP current event
BGP last state
Port
Configured
Received
Negotiated
IPv4 unicast address family capability.
VPNv6 address family capability.
Received
Sent
Threshold
ORF advertise capability based on prefix (type 64):
Supports the ORF address prefix capability and the capability value is 64.
Local
Indicates whether the local device supports sending and receiving Route-refresh packets with ORF information. The value can be:
·       both—Supports sending and receiving Route-refresh messages with ORF information.
·       send—Supports sending Route-refresh messages with ORF information.
·       receive—Supports receiving Route-refresh messages with ORF information.
Negotiated
ORF capability negotiated by the local and remote peers. The value can be:
·       send—The local peer can send Route-refresh messages with ORF information and the remote peer can receive Route-refresh messages with ORF information.
·       receive—The local peer can receive Route-refresh messages with ORF information and the remote peer can send Route-refresh messages with ORF information.
This field is displayed only when the ORF capability negotiation is successful.
Indicates the source interface of TCP connections has been configured.
BFD
# Display log information for the BGP VPNv6 peer 10.1.1.2.
<Sysname> display bgp peer vpnv6 10.1.1.2 log-info
 Peer: 10.1.1.2
                             Error/SubError
  21-Nov-2011 13:22:25 Up
  21-Nov-2011 13:21:53 Down  Receive notification with error 6/6
  21-Nov-2011 12:39:37 Up
  21-Nov-2011 12:25:08 Down  Receive notification with error 6/6
  21-Nov-2011 12:09:48 Up
Use display bgp routing-table vpnv6 to display BGP VPNv6 routing information.
display bgp routing-table vpnv6 [ route-distinguisher route-distinguisher ] [ network-address prefix-length ]
network-address prefix-length: Displays the BGP VPNv6 route that exactly matches the specified network address and prefix length. The prefix length is in the range of 0 to 128. Without this parameter, the command displays all BGP VPNv6 routes.
# Display all BGP VPNv6 routes.
<Sysname> display bgp routing-table vpnv6
 Total number of routes from all PEs: 1
 Total number of routes: 4
  >  Network : 2001:1::                                 PrefixLen : 96
     NextHop : ::                                       LocPrf    :
     PrefVal : 32768                                    OutLabel  : NULL
     MED     : 0
     Path/Ogn: ?
*  e Network : 2001:1::                                 PrefixLen : 96
     NextHop : 2001:1::1                                LocPrf    :
     MED     : 0
     Path/Ogn: 65410?
  >  Network : 2001:1::2                                PrefixLen : 128
     NextHop : ::1                                      LocPrf    :
     MED     : 0
     Path/Ogn: ?
  >i Network : 2001:3::                                 PrefixLen : 96
     NextHop : ::FFFF:3.3.3.9                           LocPrf    : 100
     PrefVal : 0                                        OutLabel  : 1279
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
Table 15 Command output
BGP Local router ID
Status codes
Route status codes:
Origin
Route origin:
Total number of VPNv6 routes from all PEs.
Network
Network address.
PrefixLen
Prefix length
NextHop
LocPrf
PrefVal
Preferred value.
MED
MED value.
Path/Ogn
Use display bgp routing-table vpnv6 advertise-info to display advertisement information for BGP VPNv6 routes.
display bgp routing-table vpnv6 [ route-distinguisher route-distinguisher ] network-address [ mask | mask-length ] advertise-info
network-address prefix-length: Displays advertisement information for the BGP VPNv6 route that exactly matches the specified network address and prefix length. The prefix length is in the range of 0 to 128.
# Display advertisement information for the BGP VPNv6 route destined to network 2001:1::/96.
<Sysname> display bgp routing-table vpnv6 2001:1:: 96 advertise-info
 Paths:   1 best
 BGP routing table information of 2001:1::/96:
    3.3.3.9
 Inlabel         : 1279
Use display bgp routing-table vpnv6 as-path-acl to display BGP VPNv6 routes permitted by an AS path ACL.
display bgp routing-table vpnv6 [ route-distinguisher route-distinguisher ] as-path-acl as-path-acl-number
# Display BGP VPNv6 routes permitted by AS path ACL 1.
<Sysname> display bgp routing-table vpnv6 as-path-acl 1
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: 65410?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
For command output, see Table 15.
ip as-path (Layer 3—IP Routing Command Reference)
Use display bgp routing-table vpnv6 community-list to display BGP VPNv6 routing information matching a specified BGP community list.
display bgp routing-table vpnv6 [ route-distinguisher route-distinguisher ] community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }
# Display BGP VPNv6 routing information matching BGP community list 100.
<Sysname> display bgp routing-table vpnv6 community-list 100
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: 65410?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
display bgp routing-table vpnv6 inlabel
Use display bgp routing-table vpnv6 inlabel to display incoming labels for BGP VPNv6 routes.
# Display incoming labels for all BGP VPNv6 routes.
<Sysname> display bgp routing-table vpnv6 inlabel
     NextHop : ::                                       OutLabel  : NULL
     InLabel : 1279
Table 16 Command output
BGP Local router ID
Status codes
Origin
display bgp routing-table vpnv6 outlabel
Use display bgp routing-table vpnv6 outlabel to display ougoing labels for BGP VPNv6 unicast routes.
# Display outgoing labels for all BGP VPNv6 routes.
<Sysname> display bgp routing-table vpnv6 outlabel
     NextHop : ::FFFF:3.3.3.9                           OutLabel  : 1279
Table 17 Command output
BGP Local router ID
Status
Origin
OutLabel
Outgoing label.
display bgp routing-table vpnv6 peer
Use display bgp routing-table vpnv6 peer to display BGP VPNv6 routing information advertised to or received from a specified BGP peer.
display bgp routing-table vpnv6 peer ip-address { advertised-routes | received-routes } [ network-address prefix-length | statistics ]
# Display all BGP VPNv6 routing information advertised to BGP peer 3.3.3.9 on the public network.
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 advertised-routes
     MED     : 0                                        OutLabel  : NULL
     Path/Ogn: ?
# Display all BGP VPNv6 routing information received from BGP peer 3.3.3.9 on the public network.
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 received-routes
     MED     : 0
     Path/Ogn: ?
# Display statistics for BGP VPNv6 routes advertised to BGP peer 3.3.3.9 on the public network.
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 advertised-routes statistics
# Display statistics for BGP VPNv6 routes received from BGP peer 3.3.3.9 on the public network.
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 received-routes statistic
Table 18 Command output
display bgp routing-table vpnv6 statistics
Use display bgp routing-table vpnv6 statistics to display BGP VPNv6 route statistics.
# Display BGP VPNv6 route statistics for the public network.
<Sysname> display bgp routing-table vpnv6 statistics
ipv6-family (VPN instance view)
Use ipv6-family to enter IPv6 VPN view.
Use undo ipv6-family to remove all configurations from IPv6 VPN view.
ipv6-family
undo ipv6-family
VPN instance view
In IPv6 VPN view, you can configure IPv6 VPN parameters such as inbound and outbound routing policies.
# Enter IPv6 VPN view.
[Sysname-vpn-instance-vpn1] ipv6-family
[Sysname-vpn-ipv6-vpn1]
ipv4-family (VPN instance view)
ipv6-family vpnv6
Use ipv6-family vpnv6 to enter BGP VPNv6 address family view.
Use undo ipv6-family vpnv6 to remove all settings from BGP VPNv6 address family view.
ipv6-family vpnv6
BGP view
A VPNv6 address comprises an RD and an IPv6 prefix. In IPv6 MPLS L3VPNs, PEs exchange BGP VPNv6 routes.
For a PE to exchange BGP VPNv6 routes with a BGP peer, you must enable that peer by executing the peer enable command in BGP VPNv6 address family view.
In BGP VPNv6 address family view, you can configure BGP VPNv6 route attributes, such as the preferred value, and whether to allow the local AS number to appear in the AS_PATH attribute of received route updates.
# Enter BGP-VPNv6 address family view.
[Sysname] bgp 100
[Sysname-bgp] ipv6-family vpnv6
[Sysname-bgp-vpnv6]
policy vpn-target
Use policy vpn-target to enable route target filtering of received VPNv6 routes.
Use undo policy vpn-target to permit all VPNv6 routes.
policy vpn-target
The route target filtering function is enabled for received VPNv6 routes.
# In BGP VPNv6 address family view, disable route target filtering of received VPNv6 routes.
[Sysname] bgp 100
[Sysname-bgp-vpnv6] undo policy vpn-target
refresh bgp vpnv6
Use refresh bgp vpnv6 to soft reset BGP VPNv6 connections.
refresh bgp { ip-address | all | external | group group-name | internal } { export | import } vpnv6
ip-address: Soft resets the BGP VPNv6 connection with the BGP peer identified by this IP address.
all: Soft resets all BGP VPNv6 connections.
external: Soft resets EBGP VPNv6 connections.
group group-name: Soft resets BGP VPNv6 connections with the BGP peer group identified by this name, a case-sensitive string of 1 to 47 characters.
internal: Soft resets IBGP VPNv6 connections.
export: Soft resets outbound EBGP VPNv6 connections.
Soft reset can update BGP VPNv6 routing information without breaking down BGP neighbor relationships.
# Soft reset all inbound BGP VPNv6 connections.
<Sysname> refresh bgp all import vpnv6
reset bgp vpnv6
Use reset bgp vpnv6 to reset BGP VPNv6 connections.
reset bgp { as-number | ip-address | all | external | group group-name | internal } vpnv6
as-number: Resets BGP VPNv6 connections in the AS identified by this number in the range of 1 to 4294967295.
ip-address: Resets the BGP VPNv6 connection with the BGP peer identified by this IP address.
all: Resets all BGP VPNv6 connections.
external: Resets EBGP VPNv6 connections.
group group-name: Resets BGP VPNv6 connections with the BGP peer group identified by this name, a case-sensitive string of 1 to 47 characters.
internal: Resets IBGP VPNv6 connections.
# Reset all BGP VPNv6 connections to make new configurations take effect.
<Sysname> reset bgp vpnv6 all
rr-filter
undo rr-filter
# In BGP VPNv6 address family view, configure the RR to only reflect VPNv6 routes with an extended community number of 10.
[Sysname] bgp 100
[Sysname-bgp-vpnv6] rr-filter 10
