03-Interface Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71003-Interface Command Reference
02-Loopback and null interface commands
02-Loopback and null interface commands 96.46 KB
default
Use default to restore the default settings for a loopback or null interface.
default
Loopback interface view, null interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command before using it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for interface loopback 1.
[Sysname] interface loopback 1
[Sysname-LoopBack1] default
description
Use description to set a description for an interface.
The description of a loopback or null interface is the interface name plus Interface (for example, LoopBack1 Interface).
text: Specifies an interface description, a string of 1 to 80 characters.
Configure a description for an interface for easy identification and management purposes.
You can use the display interface command to view the configured description.
# Set the description to for RouterID for interface loopback 1.
[Sysname-LoopBack1] description for RouterID
display interface loopback
Use display interface loopback to display information about the specified or all existing loopback interfaces.
display interface [ loopback [ interface-number ] ] [ brief [ description ] ]
interface-number: Specifies a loopback interface by its number, which can be the number of any existing loopback interface. If you do not specify this argument, the command displays information about all existing loopback interfaces on the device.
description: Displays the full description of the specified interface. When the keyword is not specified, only the first 27 characters of an interface description are displayed if the interface description is longer than 27 characters. When the keyword is specified, all characters of the interface description are displayed.
This command is supported only after a loopback interface is created.
If the loopback keyword is not specified, the command displays information about all interfaces of the device.
If the loopback keyword is specified but the interface-number argument is not specified, the command displays information about all existing loopback interfaces.
# Display detailed information about interface loopback 0.
<Sysname> display interface loopback 0
LoopBack0 current state: UP
Line protocol current state: UP (spoofing)
Description: LoopBack0 Interface
The Maximum Transmit Unit is 1536
Internet protocol processing : disabled
Physical is Loopback
Last clearing of counters:  Never
    Last 300 seconds input:  0 bytes/sec, 0 bits/sec, 0 packets/sec
    Last 300 seconds output:  0 bytes/sec, 0 bits/sec, 0 packets/sec
    0 packets input, 0 bytes, 0 drops
    0 packets output, 0 bytes, 0 drops
current state
State of the loopback interface:
·       UPThe loopback interface can receive and transmit packets.
·       Administratively DOWN—The interface was manually shut down by using the shutdown command.
State of the data link layer protocol. If the link layer protocol state of an interface is shown as UP but its link is an on-demand link or not present at all, its protocol attribute includes the spoofing flag.
Description string of the interface.
MTU of the interface.
Internet protocol processing: disabled
Indicates that the interface cannot process Layer 3 packets (displayed when the interface is not configured with an IP address).
Internet Address is 1.1.1.1/32 Primary
Primary IP address of the interface (displayed when the interface is configured with a primary IP address).
The physical type of the interface is loopback.
Time when statistics on the logical interface were last cleared by using the reset counters interface command.
If the statistics of the interface have never been cleared by using the reset counters interface command since the device started, this field displays Never.
Average input rate during the last 300 seconds (displayed when the interface supports traffic statistics collection):
·       packets/secAverage number of packets received per second.
·       bytes/secAverage number of bytes received per second.
·       bits/secAverage number of bits received per second.
Average output rate over the last 300 seconds (displayed when the interface supports traffic statistics collection):
·       packets/secAverage number of packets sent per second.
·       bytes/secAverage number of bytes sent per second.
·       bits/secAverage number of bits sent per second.
Amount of incoming traffic in packets and in bytes, and the total number of dropped incoming packets (displayed when the interface supports traffic statistics collection).
Total number and size (in bytes) of output packets of the interface and the number of dropped packets (displayed when the interface supports traffic statistics collection).
# Display brief information about all loopback interfaces.
<Sysname> display interface loopback brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Loop1                UP   UP(s)    --              aaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about all existing loopback interfaces, including the full description of each loopback interface.
<Sysname> display interface loopback brief description
Loop1                UP   UP(s)    --              aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Brief information about loopback interfaces.
·       ADM—The interface has been shut down by the network administrator. To recover its physical layer state, run the undo shutdown command.
·       Stby—The interface is a standby interface.
Protocol: (s) – spoofing
If the network layer protocol of an interface is UP but its link is an on-demand link or not present at all, this field displays UP (s), where s represents the spoofing flag. This attribute is typical of interface Null 0 and loopback interfaces.
Interface name.
Link
Physical link state of the interface:
·       UP—The link is up.
·       DOWN—The link is physically down.
·       ADM—The link has been administratively shut down. To recover its physical state, run the undo shutdown command.
Protocol
Protocol connection state of the interface:
·       UP.
·       DOWN.
·       UP(s)—The link of the interface is an on-demand link or not present at all.
Interface description configured by using the description command. If the description keyword is not specified in the display interface brief command, the Description field is of up to 27 characters. If the  description keyword is specified in the display interface brief command, the field displays the full interface description.
·           interface loopback
·           reset counters interface loopback
display interface null
Use display interface null to display information about the null interface.
display interface [ null [ 0 ] ] [ brief [ description ] ]
0: Specifies interface Null 0.
The device has only one null interface (Null 0). The null interface number is fixed at 0.
If the null keyword is not specified, the command displays information about all interfaces of the device.
If the null keyword is specified but the 0 keyword is not specified, the command displays information about interface Null 0, because the device has only one null interface Null 0.
# Display detailed information about interface Null 0.
<Sysname> display interface null 0
NULL0 current state: UP
Description:  NULL0 Interface
The Maximum Transmit Unit is 1500
Physical is NULL DEV
# Display brief information about interface Null 0.
<Sysname> display interface null 0 brief
NULL0                UP   UP(s)    --              aaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about interface Null 0 including the full description of the null interface.
<Sysname> display interface null 0 brief description
NULL0                UP   UP(s)    --              aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
For the command output, see Table 1 and Table 2.
·           interface null
·           reset counters interface null
interface loopback
Use interface loopback to create a loopback interface and enter loopback interface view.
Use undo interface loopback to remove a loopback interface.
interface loopback interface-number
undo interface loopback interface-number
No loopback interface exists.
interface-number: Specifies a loopback interface by its number, which is in the range of 0 to 1023.
The physical layer state and link layer protocols of a loopback interface are always up unless the loopback interface is manually shut down. You can establish a connection to a loopback interface to prevent the connection from being affected by the physical state of the interface and to improve the reliability of the connection. For example, you can configure a loopback interface as the source interface for establishing an FTP connection or use the loopback interface address as the Router ID in BGP.
# Create interface loopback1.
[Sysname-LoopBack1]
interface null
Use interface null to enter null interface view.
interface null 0
A device has only one null interface (Null 0), which cannot be created or deleted.
0: Specifies interface Null 0. The null interface number is fixed at 0.
# Enter Null 0 interface view.
[Sysname] interface null 0
[Sysname-NULL0]
Use reset counters interface loopback to clear the statistics on the specified or all loopback interfaces.
reset counters interface loopback [ interface-number ]
interface-number: Specifies a loopback interface by its number, which can be the number of any existing loopback interface. If you do not specify the interface-number argument, the command clears the statistics on all loopback interfaces.
To determine whether a loopback interface works correctly within a period by collecting the traffic statistics within that period, first use the reset counters interface [ loopback [ interface-number ] ] command to clear the statistics, and then have the interface automatically collect the statistics.
This command is available only if at least one loopback interface has been created.
# Clear the statistics on loopback interface Loopback 1.
<Sysname> reset counters interface loopback 1
Use reset counters interface null to clear the statistics on the null interface.
reset counters interface [ null [ 0 ] ]
0: Specifies the number of the null interface, which is fixed at 0.
To determine whether the null interface works correctly within a period by collecting the traffic statistics within that period, first use the reset counters interface [ null [ 0 ] ] command to clear the statistics, and then have the interface automatically collect the statistics.
# Clear the statistics on interface Null 0.
<Sysname> reset counters interface null 0
shutdown
Use shutdown to shut down a loopback interface.
Use undo shutdown to bring up a loopback interface.
shutdown
A loopback interface is up.
Use the shutdown command with caution, because the command disconnects the connection of the interface and disables the interface from communicating.
# Shut down interface loopback 1.
[Sysname-LoopBack1] shutdown
