03-Interface Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71003-Interface Command Reference
01-Ethernet interface commands
01-Ethernet interface commands 191.76 KB
·           A switch operating in standard mode does not support Layer 3 Ethernet interfaces, Layer 3 Ethernet subinterfaces, Layer 3 aggregate interfaces, or Layer 3 aggregate subinterfaces. For more information about the system operating mode commands, see Fundamentals Command Reference.
·           When enhanced IRF is enabled on a switch operating in IRF mode, you cannot create Layer 3 Ethernet interfaces, Layer 3 Ethernet subinterfaces, Layer 3 aggregate interfaces, or Layer 3 aggregate subinterfaces on the switch. For more information about IRF, see IRF Configuration Guide.
Common Ethernet interface commands
default
Use default to restore the default settings for an Ethernet interface or subinterface.
default
Ethernet interface view, Ethernet subinterface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for interface GigabitEthernet 3/0/1.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] default
# Restore the default settings for Layer 3 subinterface GigabitEthernet 3/0/1.1.
[Sysname] interface GigabitEthernet 3/0/1.1
[Sysname-GigabitEthernet3/0/1.1] default
description
Use description to change the description of an interface.
The description of an interface is the interface name plus Interface (for example, GigabitEthernet3/0/1 Interface).
text: Specifies the interface description, a case-sensitive string of 1 to 80 characters.
# Change the description of interface GigabitEthernet 3/0/1 to lanswitch-interface.
[Sysname-GigabitEthernet3/0/1] description lanswitch-interface
# Change the description of Ethernet subinterface GigabitEthernet 3/0/1.1 to l2-subinterface3/0/1.1.
[Sysname-GigabitEthernet3/0/1.1] description l2-subinterface3/0/1.1
display counters
Use display counters to display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
interface-number.subnumber: Specifies a subinterface number, where interface-number is a main interface (which must be a Layer 3 Ethernet interface) number, and subnumber is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
This command displays traffic statistics within a statistics polling interval specified by the flow-interval command.
To clear the Ethernet interface traffic statistics, use the reset counters interface command. For more information, see "reset counters interface."
If no interface type is specified, this command displays traffic statistics for all interfaces that have traffic counters.
If an interface type is specified but no interface number or subinterface number is specified, this command displays traffic statistics for all interfaces of the specified type.
If an interface type and an interface number or subinterface number are specified, this command displays traffic statistics of the specified interface or subinterface.
# Display inbound traffic statistics for all GigabitEthernet interfaces.
<Sysname> display counters inbound interface GigabitEthernet
Interface            Total (pkts)    Broadcast (pkts)    Multicast (pkts)  Err (pkts)
GE3/0/1                       100                100                  0              0
GE3/0/2                         0                  0                  0              0
GE3/0/3                  Overflow           Overflow           Overflow       Overflow
GE3/0/4                         0                  0                  0              0
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
Abbreviated interface name.
Total (pkts)
Total number of packets received or sent through the interface.
Broadcast (pkts)
Total number of broadcast packets received or sent through the interface.
Multicast (pkts)
Total number of multicast packets received or sent through the interface.
Err (pkts)
Total number of error packets received or sent through the interface.
The command displays Overflow if any of the following cases applies:
·       The data length of an Err field value is greater than 7 decimal digits.
·       The data length of a non-Err field value is greater than 14 decimal digits.
--: Not supported
The statistical item is not supported.
·           flow-interval
·           reset counters interface
display counters rate
Use display counters rate to display traffic rate statistics of interfaces in up state over the last statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
The statistics cover only interfaces in up state.
If an interface type is specified, the command displays traffic rate statistics for all up interfaces of the specified type over the last statistics polling interval.
If no interface type is specified, the command displays traffic rate statistics for all up interfaces that have traffic counters over the last statistics polling interval.
If an interface which is always down over the last statistics polling interval is specified, the system prompts that the interface does not support the command.
You can use the flow-interval command to set the statistics polling interval.
# Display the inbound traffic rate statistics for all GigabitEthernet interfaces.
<Sysname> display counters rate inbound interface gigabitethernet
Interface               Total (pps)       Broadcast (pps)       Multicast (pps)
GE3/0/1                         200                   100                   100
GE3/0/2                         300                   200                   100
GE3/0/3                         300                   200                   100
 Overflow: More than 14 digits.
       --: Not supported.
Total (pkts/sec)
Average rate (in pps) of receiving or sending packets during the statistics polling interval.
Broadcast (pkts/sec)
Average rate (in pps) of receiving or sending broadcast packets during the statistics polling interval.
Multicast (pkts/sec)
Average rate (in pps) of receiving or sending multicast packets during the statistics polling interval.
Overflow: more than 14 decimal digits
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits.
--: not supported
·           flow-interval
display interface
Use display interface to display Ethernet interface information.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ]
If no interface type is specified, this command displays information about all interfaces.
If an interface type is specified but no interface number or subinterface number is specified, this command displays information about all interfaces of that type.
If both the interface type and interface number are specified, this command displays information about the specified interface.
# Display information about Layer 3 interface GigabitEthernet 3/0/1.
<Sysname> display interface GigabitEthernet 3/0/1
GigabitEthernet3/0/1 current state: DOWN
Line protocol current state: DOWN
Description: GigabitEthernet3/0/1 Interface
The Maximum Transmit Unit is 100, Hold timer is 10(sec)
Internet protocol processing: disabled
IP Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 0001-0001-0001
IPV6 Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 0001-0001-0001
Media type is twisted pair, Port hardware type is 1000_BASE_T
Port priority: 2
 Loopback is not set
 Unknown-speed mode, Unknown-duplex mode
 Last 300 seconds input:  0 packets/sec 0 bytes/sec  0
 Last 300 seconds output: 0 packets/sec 0 bytes/sec  0
 Input  (total): 0 packets, 0 bytes
          0 broadcasts, 0 multicasts, - pauses
 Input  (normal): 0 packets, 0 bytes
          0 broadcasts, 0 multicasts, 0 pauses
 Input: 0 input errors, 0 runts, 0 giants, 0 throttles
          - ignored, - parity errors
 Output  (total): 0 packets, 0 bytes
 Output  (normal): 0 packets, 0 bytes
          - lost carrier, - no carrier
 Peak value of input: 0 bytes/sec, at 2011-12-23 09:05:58
 Peak value of output: 0 bytes/sec, at 2011-12-23 09:05:58
State of the interface:
·       Administratively DOWN—The Ethernet interface was shut down with the shutdown command. The interface is administratively down.
·       DOWN—The Ethernet interface is administratively up but physically down (possibly because no physical link is present or the link has failed).
·       UP—The Ethernet interface is both administratively and physically up.
Link layer state of the interface. The state is determined through parameter negotiation on the link layer.
Hold timer is
Link-up or link-down event suppression interval.
Indicates that the interface cannot process IP packets.
Media type
Physical media type of the interface:
·       twisted pair
·       optical fiber
Loopback is set internal
An internal loopback test is running on the Ethernet interface.
Loopback is not set
No loopback test is running on the Ethernet interface.
Unknown-speed mode
The speed of the interface is unknown, because the speed negotiation fails or the interface is not physically connected.
Unknown-duplex mode
The duplex mode of the interface is unknown, because the duplex mode negotiation fails or the interface is not physically connected.
Last 300 seconds input rate
Average input rate over the last 300 seconds in Bps, bps, and pps.
Last 300 seconds output rate
Average output rate over the last 300 seconds in Bps, bps, and pps.
Input (total):
Input (normal):
Input:
Output (total):
Output (normal):
Output:
Statistics about input/output packets and errors. For more information, see Table 4.
A hyphen (-) indicates that the statistical item is not supported.
Peak value of input
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred.
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred.
# Display detailed information about Layer 2 interface GigabitEthernet 3/0/1.
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000c-2963-b767
Loopback is not set
1000Mbps-speed mode, full-duplex mode
Flow-control is not enabled
The Maximum Frame Length is 9216
Allow jumbo frame to pass
Broadcast MAX-ratio: 100%
Multicast MAX-ratio: 100%
Unicast MAX-ratio: 100%
PVID: 1
Mdi type: automdix
Port link-type: access
 Tagged Vlan:   none
 UnTagged Vlan: 1
Port priority: 2
 Peak value of input: 0 bytes/sec, at 2000-01-01 00:00:00
 Peak value of output: 0 bytes/sec, at 2000-01-01 00:00:00
 Last 300 seconds input:  0 packets/sec 0 bytes/sec 0%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec 0%
          0 unicasts, 0 broadcasts, 0 multicasts, - pauses
State of the Ethernet interface:
Ethernet framing format. PKTFMT_ETHNT_2 indicates that the frames are encapsulated in Ethernet II framing format.
Hardware address
MAC address of the interface.
Loopback is not set
Media type
·       twisted pair
·       optical fiber
10Mbps-speed mode
The interface is operating at 10 Mbps.
100Mbps-speed mode
The interface is operating at 100 Mbps.
1000Mbps-speed mode
The interface is operating at 1000 Mbps.
Unknown-speed mode
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected.
half-duplex mode
The interface is operating in half duplex mode.
full-duplex mode
The interface is operating in full duplex mode.
unknown-duplex mode
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected.
The interface is configured with the speed auto command.
Link speed type is force link
The interface is configured with a specific speed, for example, 10 Mbps or 100 Mbps, by using the speed command.
The interface is configured with the duplex auto command.
link duplex type is force link
The interface is configured with a specific duplex mode, for example, half or full, by using the duplex command.
Flow control is not enabled on the interface.
Maximum Ethernet frame length allowed on the interface.
The interface allows jumbo frames to pass through.
Broadcast MAX-
Broadcast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Multicast MAX-
Multicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Unicast MAX-
Unicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
PVID
Port VLAN ID (PVID) of the Ethernet interface.
Mdi type
Cable type (depending on your configuration):
·       automidx.
·       mdi.
·       mdix.
Port link-type
Link type of the interface (depending on your configuration):
·       access.
·       trunk.
·       hybrid.
Tagged VLAN ID
VLANs for which the interface sends packets without removing VLAN tags.
Untagged VLAN ID
VLANs for which the interface sends packets after removing VLAN tags.
Port priority
Priority of the interface.
Time when the reset counters interface command was last used to clear statistics on the interface. Never indicates that the reset counters interface command was never used since the device was started.
Peak value of input
Last 300 seconds input:  0 packets/sec 0 bytes/sec -%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec -%
Average rate of inbound and outbound traffic in the last 300 seconds, in pps and Bps, and the ratio of the actual rate to the maximum interface rate.
Input(total):  0 packets, 0 bytes
Inbound traffic statistics (in packets and bytes) for the interface. All inbound normal and abnormal packets and normal pause frames were counted.
Number of inbound unicast packets, number of inbound broadcasts, number of inbound multicasts, and number of inbound pause frames.
Input(normal):  0 packets, 0 bytes
Inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
Number of inbound normal unicast packets, number of inbound normal broadcasts, number of inbound normal multicasts, and number of inbound normal pause frames.
input errors
Number of inbound packets with errors.
runts
Number of inbound frames shorter than 64 bytes, in correct format, and containing valid CRCs.
giants
Number of inbound frames larger than the maximum frame length supported on the interface.
·       For an Ethernet interface that does not permit jumbo frames, giants refer to frames larger than 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags).
·       For an Ethernet interface that permits jumbo frames, giants refer to frames larger than the maximum length of Ethernet frames that are allowed to pass through, which is configured when you configure jumbo frame support on the interface.
throttles
Number of times the port is shut down due to buffer or CPU overload.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·       Fragment frames—CRC error frames shorter than 64 bytes. The length can be an integral or non-integral value.
·       Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length). For an Ethernet interface that does not permit jumbo frames, jabber frames refer to CRC error frames greater than 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags). For an Ethernet interface that permits jumbo frames, jabber frames refer to CRC error frames greater than the maximum length of Ethernet frames that are allowed to pass through the interface (which is configured when you configure jumbo frame support on the interface).
·       Symbol error frames—Frames that contained at least one undefined symbol.
·       Unknown operation code frames—Non-pause MAC control frames.
·       Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receive buffer of the port ran low.
parity errors
Total number of frames with parity errors.
Output(total): 0 packets, 0 bytes
Outbound traffic statistics (in packets and bytes) for the interface. All outbound normal and abnormal packets and normal pause frames were counted.
Number of outbound unicast packets, number of outbound broadcasts, number of outbound multicasts, and number of outbound pause frames.
Output(normal): 0 packets, 0 bytes
Outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
Number of outbound normal unicast packets, number of outbound normal broadcasts, number of outbound normal multicasts, and number of outbound normal pause frames.
output errors
Number of outbound packets with errors.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmit buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
display interface brief
Use display interface brief to display brief Ethernet interface information.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] brief [ description ]
description: Displays the full description of the specified interface. If the keyword is not specified, the command displays at most the first 27 characters of the interface description. If the keyword is specified, the command displays all characters of the interface description.
# Display brief information about all interfaces.
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
GE3/0/1              UP   UP       10.1.1.2        Link to CoreRouter
GE3/0/2              Stby DOWN     --
Loop0                UP   UP(s)    2.2.2.9
NULL0                UP   UP(s)    --
Vlan1                UP   DOWN     --
Vlan999              UP   UP       192.168.1.42
The brief information of interface(s) under bridge mode:
Speed or Duplex: (a)/A - auto; H - half; F - full
GE3/0/2              DOWN auto    A      A    1
GE3/0/3              UP   100M(a) F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaa
GE3/0/4              DOWN auto    A      A    1
GE3/0/5              DOWN auto    A      A    1
GE3/0/6              UP   100M(a) F(a)   A    1
GE3/0/7              DOWN auto    A      A    1
GE3/0/8              UP   100M(a) F(a)   A    1
GE3/0/9              UP   100M(a) F(a)   A    999
# Display brief information about interface GigabitEthernet 3/0/3, including the full description of the interface.
<Sysname> display interface brief  GigabitEthernet 3/0/3 description
GE3/0/3              UP   100M(a) F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Table 5 Command output
Brief information about Layer 3 interfaces.
·       ADM—The interface has been shut down by the network administrator. To recover its physical layer state, run the undo shutdown command.
·       Stby—The interface is a standby interface.
Protocol: (s) – spoofing
If the network layer protocol of an interface is UP, but its link is an on-demand link or not present at all, this field displays UP (s), where s represents the spoofing flag. This attribute is typical of interface Null 0 and loopback interfaces.
Interface name.
Link
Physical link state of the interface:
·       UP—The link is up.
·       DOWN—The link is physically down.
·       ADM—The link has been administratively shut down. To recover its physical state, run the undo shutdown command.
Protocol
Protocol connection state of the interface:
·       UP.
·       DOWN.
·       UP(s)—The link of the interface is an on-demand link or not present at all.
Interface description configured by using the description command. If the description keyword is not specified in the display interface brief command, the Description field displays at most 27 characters. If the description keyword is specified in the display interface brief command, the field displays the full interface description.
Brief information about Layer 2 interfaces.
Speed or Duplex: (a)/A - auto; H - half; F – full
If the speed of an interface is automatically negotiated, its speed attribute includes the auto negotiation flag, indicated by the letter a in parentheses.
If the duplex mode of an interface is automatically negotiated, its duplex mode attribute includes the following options:
·       (a)/A—Auto negotiation.
·       H—Half negotiation.
·       F—Full negotiation.
Type: A - access; T - trunk; H – hybrid
Link type options for Ethernet interfaces.
Speed
Interface rate, in bps.
Duplex
Duplex mode of the interface:
·       A—Autonegotiation.
·       F—Full duplex.
·       F(a)—Autonegotiated full duplex.
·       H—Half duplex.
·       H(a)—Autonegotiated half duplex.
Link type of the interface:
·       A—Access.
·       H—Hybrid.
·       T—Trunk.
PVID
Port VLAN ID.
Cause
Causes for the physical state of an interface to be DOWN.
·       Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
·       Administratively DOWN—The port was shut down with the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
display packet-drop
Use display packet-drop to display information about packets dropped on an interface or multiple interfaces.
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
interface-type: Specifies an interface type. If you do not specify an interface type, this command displays information about dropped packets on all the interfaces on the device.
interface-number: Specifies an interface number. If you specify an interface type only, this command displays information about dropped packets on the specified type of interfaces.
summary: Displays the summary of dropped packets on all interfaces.
# Display information about dropped packets on GigabitEthernet 3/0/1.
<Sysname> display packet-drop interface GigabitEthernet 3/0/1
GigabitEthernet3/0/1:
Packets dropped due to full GBP or insufficient bandwidth: 301
Packets dropped due to Fast Filter Processor FFP: 261
Packets dropped due to STP non-forwarding state: 321
Packets dropped due to rate-limit: 143
Packets dropped due to broadcast-suppression: 301
Packets dropped due to unicast-suppression: 215
Packets dropped due to multicast-suppression: 241
Packets dropped due to Tx packet aging: 246
# Display the summary of dropped packets on all interfaces.
<Sysname> display packet-drop summary
All interfaces:
  Packets dropped due to FFP: 261
Table 6 Command output
Packets that are dropped because the buffer is used up or the bandwidth is insufficient.
Packets that are filtered out.
Packets that are dropped because STP is in the non-forwarding state.
Packets that are dropped due to the rate limit set on the device.
Packets that are dropped due to broadcast suppression.
Packets that are dropped due to unknown unicast suppression.
Packets that are dropped due to multicast suppression.
Outbound packets that are timed out.
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default duplex mode of the Ethernet interface.
duplex { auto | full | half }
undo duplex
A 10-GE interface operates in full duplex mode, and all other types of Ethernet interfaces operate in autonegotiation mode.
auto: Configures the interface to autonegotiate the duplex mode with the peer.
full: Configures the interface to operate in full duplex mode, so that the interface can receive and transmit packets at the same time.
half: Configures the interface to operate in half duplex mode, so that the interface can only receive or only transmit packets at one time. Fiber ports do not support the keyword.
# Configure interface GigabitEthernet 3/0/1 to operate in full duplex mode.
[Sysname-GigabitEthernet3/0/1] duplex full
flag sdh
Use flag sdh to set the value for the overhead byte J0 or J1 in SDH frames when the 10-GE interface operates in WAN mode.
Use undo flag sdh to restore the default value of the J0 or J1 byte.
flag { j0 | j1 } sdh value
undo flag { j0 | j1 } sdh
The J0 and J1 bytes are padded with 0s.
Ten-GigabitEthernet interface view
j0: Specifies the Path Trace byte in the Regenerator Section Overhead.
j1: Specifies the Path Trace byte in the High-Order Path Overhead.
value: Specifies the value for the J0 or J1 byte, a string of 1 to 15 characters.
This command is effective only when the 10-GE interface is operating in WAN mode.
# Set the value of the J0 byte in SDH frames to Sysname on interface Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] port-mode wan
[Sysname-Ten-GigabitEthernet3/0/1] flag j0 sdh Sysname
port-mode
flow-control
Use flow-control to enable TxRx mode generic flow control on an Ethernet interface.
Use undo flow-control to disable generic flow control on the Ethernet interface.
flow-control
undo flow-control
Generic flow control is disabled on an Ethernet interface.
To implement flow control on a link, enable the generic flow control function at both ends of the link.
TxRx mode generic flow control enables an Ethernet interface to receive common pause frames from its peer, and send common pause frames to notify its peer of congestions.
With the flow-control command configured, an interface can both send and receive flow control frames:
·           When congested, the interface sends a flow control frame to its peer.
·           Upon receiving a flow control frame from the peer, the interface suspends sending packets.
# Enable TxRx mode generic flow control on the interface GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] flow-control
flow-interval
Use flow-interval to set the interface statistics polling interval.
Use undo flow-interval to restore the default interval.
flow-interval interval
undo flow-interval
The interface statistics polling interval is 300 seconds.
interval: Sets the statistics polling interval, in seconds. The interval is in the range of 5 to 300 and must be a multiple of 5.
# Set the statistics polling interval to 100 seconds on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] flow-interval 100
interface
Use interface to enter interface or subinterface view. With the interface-number.subnumber argument specified, if the subinterface identified by the argument does not exist, this command creates the subinterface first, and then enters subinterface view.
# Enter GigabitEthernet 3/0/1 interface view.
# Create Ethernet subinterface GigabitEthernet 3/0/1.1 and enter GigabitEthernet 3/0/1.1 subinterface view.
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
jumboframe enable [ value ]
The device allows jumbo frames within 9216 bytes to pass through.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view
value: Sets the maximum length of Ethernet frames that are allowed to pass through. The value range for the argument is 1552 to 9216. On LST1XP16LEB1 and LST1XP16LEC1 cards, the value range for the argument is 1552 to 8168.
If you set the value argument multiple times, the most recent configuration takes effect.
# Enable jumbo frames to pass through GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] jumboframe enable
link-delay
Use link-delay to set the physical state change suppression interval on an Ethernet interface.
Use undo link-delay to restore the default.
link-delay delay-time [ mode { up | updown } ]
undo link-delay
The physical state change suppression interval is one second.
delay-time: Sets the physical state change suppression interval (in seconds) on the Ethernet interface. The value range for the argument is 0 to 30, however, only 0 to 10 is supported. A value of 0 indicates that physical state changes are not suppressed.
mode up: Suppresses the link-up events. The keyword is not supported in the current software version. The keyword is reserved for future support.
mode updown: Suppresses both the link-up and link-down events.
With the link-delay delay-time command configured:
·           When the interface comes down, the link-down event is not reported to the CPU unless the interface is still down when the suppression interval (delay-time) expires.
·           When the interface goes up, the link-up event is immediately reported.
With the link-delay delay-time mode up command configured:
·           When the interface goes up, the link-up event is not reported to the CPU unless the interface is still up when the suppression interval (delay-time) expires.
·           When the interface comes down, the link-down event is immediately reported.
With the link-delay delay-time mode updown command configured, when the interface comes down or goes up, the link-down or link-up event is not reported to the CPU unless the interface is still down or up when the suppression interval (delay-time) expires.
On a port, if you configure the link-delay command multiple times, the most recent configuration takes effect.
Do not configure this command on a port with MSTP enabled.
The link-delay delay-time command and the link-delay delay-time mode up command are not supported.
# Set the physical state change suppression interval to 8 seconds on interface GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] link-delay 8
loopback
Use loopback to perform a loopback test on an Ethernet interface.
Use undo loopback to cancel a loopback test on an Ethernet interface.
undo loopback
Loopback test is disabled on an interface.
external: Performs an external loopback test on the Ethernet interface. The keyword is not supported in the current software version. The keyword is reserved for future support.
internal: Performs an internal loopback test on the Ethernet interface.
If an Ethernet interface does not work normally, you can perform a loopback test on it to identify the problem.
An Ethernet interface in a loopback test does not forward data traffic.
On a physically down interface (displayed as in DOWN state), you can only perform an internal loopback test, and an external loopback test will fail. On an administratively shut down interface (displayed as in ADM or Administratively DOWN state), you cannot perform an internal or external loopback test.
The speed, duplex, mdi, and shutdown commands are not available during a loopback test.
During a loopback test, the Ethernet interface operates in full duplex mode. When the loopback test is complete, the port returns to its duplex setting.
# Perform an internal loopback test on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] loopback internal
port link-mode
Use port link-mode to change the link mode of an Ethernet interface.
Use undo port link-mode to restore the default.
undo port link-mode
An Ethernet interface operates in Layer 2 mode.
bridge: Specifies the Layer 2 mode.
route: Specifies the Layer 3 mode.
Depending on the layers where the device processes packets received on interfaces, Ethernet interfaces can operate as Layer 2 Ethernet interfaces (in bridge mode) or as Layer 3 Ethernet interfaces (in route mode).
After you change the link mode of an Ethernet interface, all the settings (except the shutdown status) of the Ethernet interface are restored to their defaults under the new link mode. For more information about shutting down or bringing up an interface, see "shutdown."
The command is available on only switches operating in non-standard mode. By default, a switch operates in standard mode. For more information about the system operating modes, see Fundamentals Configuration Guide.
The following Ethernet interfaces do not support switching the operating mode: aggregation group member ports, reflector port of a remote source mirroring group, and Ethernet interfaces of a switch operating in IRF mode and with enhanced IRF enabled. For more information about reflector ports, see Network Management and Monitoring Configuration Guide. For more information about enhanced IRF, see IRF Configuration Guide.
# Configure GigabitEthernet 3/0/1 to operate in Layer 3 mode.
[Sysname-GigabitEthernet3/0/1] port link-mode route
port-mode
Use port-mode to configure a 10-GE interface to operate in LAN or WAN mode.
Use undo port-mode to restore the default.
port-mode { lan | wan }
undo port-mode
A 10-GE interface operates in LAN mode.
lan: Configures the interface to operate in LAN mode. A port operating in this mode transmits Ethernet packets and connects an Ethernet network.
wan: Configures the interface to operate in WAN mode. A port operating in this mode transmits SDH packets and connects an SDH network. In addition, it supports point-to-point links only.
# Configure the interface Ten-GigabitEthernet 3/0/1 to operate in WAN mode.
[Sysname] interface ten-gigabitethernet3/0/1
Use reset counters interface to clear the Ethernet interface or subinterface statistics.
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
interface-number.subnumber: Specifies a subinterface number, where interface-number is a main interface (which must be a Layer 3 Ethernet interface) number; subnumber is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
Before collecting traffic statistics for a specific period of time on an interface, clear the old statistics first.
If no interface type is specified, this command clears statistics for all interfaces.
If only the interface type is specified, this command clears statistics for all interfaces of that type.
If both the interface type and the interface or subinterface number are specified, this command clears statistics for the specified interface or subinterface.
# Clear the statistics of GigabitEthernet 3/0/1.
<Sysname> reset counters interface GigabitEthernet 3/0/1
·           display interface
·           display counters interface
·           display counters rate interface
reset packet-drop interface
Use reset packet-drop interface to clear the dropped packet statistics on an interface or multiple interfaces.
reset packet-drop interface [ interface-type [ interface-number ] ]
interface-type: Specify an interface type. If you do not specify an interface type, this command clears dropped packet statistics on all the interfaces on the device.
interface-number: Specify an interface number. If you do not specify this argument, this command clears dropped packet statistics on all interfaces of the specified type.
# Clear dropped packet statistics on GigabitEthernet 3/0/1.
<Sysname> reset packet-drop interface GigabitEthernet 3/0/1
# Clear dropped packet statistics on all interfaces.
display packet-drop
shutdown
Use shutdown to shut down an Ethernet interface or subinterface.
Use undo shutdown to bring up an Ethernet interface or subinterface.
shutdown
Ethernet interfaces are down, and Ethernet subinterfaces are up.
You might need to shut down and then bring up an Ethernet interface to make some interface configurations take effect.
# Shut down and then bring up GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] shutdown
[Sysname-GigabitEthernet3/0/1] undo shutdown
# Shut down and then bring up Layer 3 Ethernet subinterface GigabitEthernet 3/0/1.1.
[Sysname-GigabitEthernet3/0/1.1] shutdown
[Sysname-GigabitEthernet3/0/1.1] undo shutdown
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 10 | 100 | 1000 | 10000 | auto }
undo speed
The speed of an Ethernet interface is autonegotiated.
10: Sets the interface speed to 10 Mbps.
100: Sets the interface speed to 100 Mbps.
1000: Sets the interface speed to 1000 Mbps.
10000: Sets the interface speed to 10000 Mbps.
auto: Enables the interface to negotiate a speed with its peer.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface.
For a fiber port, use the speed command to set its speed to match the rate of a transceiver module.
A fiber port does not support the 10 and 100 keyword of the command.
A 10-GE interface does not support the command.
# Configure GigabitEthernet 3/0/1 to autonegotiate the speed.
[Sysname-GigabitEthernet3/0/1] speed auto
Layer 2 Ethernet interface/subinterface commands
Use broadcast-suppression to enable broadcast suppression and set the broadcast suppression threshold.
Use undo broadcast-suppression to restore the default.
Ethernet interfaces do not suppress broadcast traffic.
ratio: Sets the broadcast suppression threshold as a percentage of the maximum interface rate. The value range for the argument is 0 to 100. The smaller the percentage, the less broadcast traffic is allowed to pass through. The argument is always 100. As a result, you cannot suppression broadcast traffic by using the argument.
pps max-pps: Specifies the maximum number of broadcast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 1 to 1.4881 × the maximum interface rate. For example, the value range for the argument is 1 to 1488100 on a GE interface.
kbps max-kbps: Specifies the maximum number of kilobits of broadcast traffic that the Ethernet interface can forward per second. The value range for the argument (in kbps) is 1 to the maximum interface rate.
You can use the broadcast storm suppression function to limit the size of broadcast traffic on an interface. When the broadcast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
When you configure the suppression threshold in pps or kbps, the device converts the configured value into a multiple of a certain step (6400 for pps and 50 for kbps) supported by the chip. As a result, the actual suppression threshold may be different from the configured one. To determine the suppression threshold that takes effect, see the prompts on the device.
# Set the broadcast suppression threshold to 10000 kbps on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] broadcast-suppression kbps 10000
·           multicast-suppression
·           unicast-suppression
mdix-mode
IMPORTANT
IMPORTANT:
Fiber ports do not support this command.
Use mdix-mode to configure the Medium Dependent Interface Cross-Over (MDIX) mode of an Ethernet interface.
Use undo mdix-mode to restore the default.
mdix-mode { automidx | mdi| mdix }
undo mdix-mode
Ethernet interfaces operate in automdix mode.
automidx: Specifies that the interface negotiates pin roles with its peer.
mdi: Specifies that pins 1 and 2 are transmit pins and pins 3 and 6 are receive pins.
mdix: Specifies that pins 1 and 2 are receive pins and pins 3 and 6 are transmit pins.
# Set GigabitEthernet 3/0/1 to operate in MDI mode.
[Sysname-GigabitEthernet3/0/1] mdix-mode mdi
Use multicast-suppression to enable multicast storm suppression and set the multicast storm suppression threshold.
Use undo multicast-suppression to restore the default.
Ethernet interfaces do not suppress multicast traffic.
Layer 2 Ethernet interface view, Layer 2 Ethernet subinterface view
ratio: Sets the multicast suppression threshold as a percentage of the maximum interface rate. The value range for the argument (in percentage) is 0 to 100. The smaller the percentage, the less multicast traffic is allowed to pass through. The argument is always 100. As a result, you cannot suppression multicast traffic by using the argument.
pps max-pps: Specifies the maximum number of multicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 1 to 1.4881 × the maximum interface rate. For example, the value range for the argument is 1 to 1488100 on a GE interface.
kbps max-kbps: Specifies the maximum number of kilobits of multicast traffic that the Ethernet interface can forward per second. The value range for the argument (in kbps) is 1 to the maximum interface rate.
You can use the multicast storm suppression function to limit the size of multicast traffic on an interface. When the multicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
# Set the multicast storm suppression threshold to 10000 kbps on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] multicast-suppression kbps 10000
·           broadcast-suppression
port up-mode
Use port up-mode to forcibly bring up a fiber GE or 10-GE port.
Use undo port up-mode to restore the default.
port up-mode
undo port up-mode
You can use this command to forcibly bring up a fiber Ethernet port, and enable the port to forward packets unidirectionally over a single link. In this way, transmission links are well utilized.
After you forcibly bring up an Ethernet fiber port, the fiber port stays physically up regardless of whether or not an optical module or fiber connections are present for the port.
Only 10-GE fiber ports operating in LAN mode and GE fiber ports support this command. Copper ports and combo interfaces do not support this command.
To configure this command on a port, make sure the port is operating in bridge mode.
The port up-mode command is mutually exclusive with any of the shutdown, speed, duplex, and loopback commands.
The fiber port cannot properly forward traffic if you install a transceiver module, 100/1000-Mbps transceiver module, or 100-Mbps transceiver module into the port and configure the port up-mode command. To solve the problem, use the undo port up-mode command on the fiber port.
# Forcibly bring up the fiber port GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] port up-mode
unicast-suppression
Use unicast-suppression to enable unicast storm suppression and set the unicast storm suppression threshold.
Use undo unicast-suppression to restore the default.
Ethernet interfaces do not suppress unicast traffic.
ratio: Sets the unicast suppression threshold as a percentage of the maximum interface rate. The value range for the argument (in percentage) is 0 to 100. The smaller the percentage, the less unicast traffic is allowed to pass through. The argument is always 100. As a result, you cannot suppression unicast traffic by using the argument.
pps max-pps: Specifies the maximum number of unicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 1 to 1.4881 × the maximum interface rate. For example, the value range for the argument is 1 to 1488100 on a GE interface.
kbps max-kbps: Specifies the maximum number of kilobits of unicast traffic that the Ethernet interface can forward per second. The value range for the argument (in kbps) is 1 to the maximum interface rate.
You can use the unicast storm suppression function to limit the size of unicast traffic on an interface. When the unicast traffic on the interface exceeds this threshold, the system discards packets until the unicast traffic drops below this threshold.
# Set the unicast storm suppression threshold to 10000 kbps on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] unicast-suppression kbps 10000
Layer 3 Ethernet interface or subinterface commands
mtu
Use mtu to set the MTU for an Ethernet interface or subinterface.
mtu size
undo mtu
The MTU of an Ethernet interface or subinterface is 1500 bytes.
Layer 3 Ethernet interface view, Layer 3 Ethernet subinterface view
size: Sets the maximum transmission unit (MTU) in bytes, which is in the range of 64 to 9198.
Do not modify the MTU in general cases.
# Set the MTU to 1430 bytes for Layer 3 Ethernet interface GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] mtu 1430
# Set the MTU to 1400 bytes for Layer 3 Ethernet subinterface GigabitEthernet 3/0/1.1.
[Sysname-GigabitEthernet3/0/1.1] mtu 1430
