07-Layer 3 - IP Routing Configuration Guide
HomeSupportSwitchesS9500E SeriesConfigure & DeployConfiguration GuidesH3C S9500E Configuration Guide-Release1728-6W17007-Layer 3 - IP Routing Configuration Guide
02-Static Routing Configuration
02-Static Routing Configuration 219 KB
Introduction to static routes
Static routes are manually configured. If a network’s topology is simple, you only need to configure static routes for the network to work properly.
Static routes cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually.
Configuring a static route
Configuration prerequisites
Before you configure a static route, complete the following tasks:
·           Configure the physical parameters for related interfaces.
·           Configure the link-layer attributes for related interfaces.
·           Configure the IP addresses for related interfaces.
Configuration procedure
To configure a static route:
Step
Remarks
1.     Enter system view.
N/A
2.     Configure a static route.
·       Approach 1:
ip route-static
dest-address { mask | mask-length } { next-hop-address [ track track-entry-number ] | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address [ track track-entry-number ] } [ preference preference-value ] [ tag tag-value ] [ permanent ] [ description description-text ]
·       Approach 2:
ip route-static vpn-instance s-vpn-instance-name&<1-6> dest-address { mask | mask-length } { next-hop-address [ public ] [ track track-entry-number ] | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address track track-entry-number } [ preference preference-value ] [ tag tag-value ] [ permanent ] [ description description-text ]
Use either approach.
By default, no static route is configured.
3.     Configure the default preference for static routes.
ip route-static default-preference default-preference-value
Optional.
60 by default.
4.     Remove all static routes.
delete [ vpn-instance vpn-instance-name ] static-routes all
Optional.
·       If you specify the next hop address of a static route and configure it as the IP address of a local interface, the static route does not take effect.
·       Associating track with static routing helps you determine the validity of static routes by monitoring the reachability of the next hops. For more information about track, see High Availability Configuration Guide.
·       Use the undo ip route-static command to delete one static route; use the delete static-routes all command to delete all static routes, including the default route.
Configuring BFD for static routes
Bidirectional forwarding detection (BFD) provides a general-purpose, standard, medium-, and protocol-independent fast failure detection mechanism. It can uniformly and quickly detect the failures of the bidirectional forwarding paths between two routers for protocols, such as routing protocols and Multiprotocol Label Switching (MPLS). For more information about BFD, see High Availability Configuration Guide.
BFD control packet mode
To use BFD control packets for bidirectional detection between two devices, enable BFD control packet mode for each device’s static route destined to the peer.
To configure a static route and enable BFD control packet mode for it, specify an outbound interface and a direct next hop, or specify an indirect next hop and a specific BFD packet source address for the static route.
To configure a static route with BFD control packet mode enabled (direct next hop):
Step
Remarks
N/A
2.     Configure a static route and enable BFD control packet mode for it.
·       Approach 1:
ip route-static dest-address { mask | mask-length } interface-type interface-number next-hop-address bfd control-packet [ preference preference-value ] [ tag tag-value ] [ description description-text ]
·       Approach 2:
ip route-static vpn-instance s-vpn-instance-name&<1-6> dest-address { mask | mask-length } interface-type interface-number next-hop-address bfd control-packet [ preference preference-value ] [ tag tag-value ] [ description description-text ]
To configure a static route with BFD control packet mode enabled (indirect next hop):
Step
Remarks
N/A
·       Approach 1:
ip route-static dest-address { mask | mask-length } next-hop-address bfd control-packet bfd-source ip-address [ preference preference-value ] [ tag tag-value ] [ description description-text ]
·       Approach 2:
ip route-static vpn-instance s-vpn-instance-name&<1-6> dest-address { mask | mask-length } next-hop-address bfd control-packet bfd-source ip-address [ preference preference-value ] [ tag tag-value ] [ description description-text ]
BFD echo packet mode
With BFD echo packet mode enabled for a static route, the local switch sends BFD echo packets to the peer, which loops it back to test the link.
To configure BFD echo packet mode for static routes:
Step
Remarks
N/A
2.     Configure the source address of echo packets.
bfd echo-source-ip ip-address
Not configured by default.
For more information about this command, see High Availability Command Reference.
3.     Enable BFD echo packet mode for static routes.
·       Approach 1:
ip route-static dest-address { mask | mask-length } interface-type interface-number next-hop-address bfd echo-packet [ preference preference-value ] [ tag tag-value ] [ description description-text ]
·       Approach 2:
ip route-static vpn-instance s-vpn-instance-name&<1-6> dest-address { mask | mask-length } interface-type interface-number next-hop-address bfd echo-packet [ preference preference-value ] [ tag tag-value ] [ description description-text ]
CAUTION
CAUTION:
·       If route flaps occur, enabling BFD could worsen them.
·       Do not use BFD for a static route with the outbound interface in spoofing state.
·       BFD can be used for static routes with direct next hops rather than indirect next hops.
·       A BFD session is established at only one end when the echo mode is used.
·       For the echo and control mode, the switch currently does not support BFD detection on tunnel interfaces.
Configuring static route FRR
When a link or a router fails, the packets on the path are discarded, and a routing loop occurs. To avoid such problems, you can enable static route fast reroute (FRR).
Figure 1 Network diagram
As shown in Figure 1, upon a link failure, FRR designates a backup next hop by using a routing policy for routes matching the specified criteria. Packets are directed to the backup next hop to avoid traffic interruption.
Create a routing policy to be referenced by FRR and use the apply fast-reroute backup-interface command to specify a backup next hop in a routing policy. For more information about the command and routing policy configurations, see the chapter “Configuring routing policy.”
To configure static route FRR:
Step
Remarks
N/A
1.     Configure the source address of BFD echo packets.
2.     Configure static route FRR.
ip route-static [ vpn-instance vpn-instance-name ] fast-reroute route-policy route-policy-name
·       Static route FRR takes effect only for static routes that have both the outbound interface and next hop specified.
·       Do not use static route FRR and BFD (for static route) at the same time.
Displaying and maintaining static routes
Remarks
View information of static routes.
display ip routing-table protocol static [ inactive | verbose ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Delete all static routes.
Available in system view
For more information about this command, see Layer 3IP Routing Command Reference.
Static route configuration examples
By default, Ethernet, VLAN, and aggregate interfaces are down. Before configuring these interfaces, bring them up by using the undo shutdown command.
Basic static route configuration example
Network requirements
Configure static routes in Figure 2 to achieve interconnections between any two hosts.
Figure 2 Network diagram
1.      Configure IP addresses for interfaces. (Details not shown)
2.      Configure static routes:
# Configure a default route on Switch A.
[SwitchA] ip route-static 0.0.0.0 0.0.0.0 1.1.4.2
# Configure two static routes on Switch B.
[SwitchB] ip route-static 1.1.2.0 255.255.255.0 1.1.4.1
[SwitchB] ip route-static 1.1.3.0 255.255.255.0 1.1.5.6
# Configure a default route on Switch C.
[SwitchC] ip route-static 0.0.0.0 0.0.0.0 1.1.5.5
3.      Configure the hosts:
The default gateways for the three hosts A, B, and C are 1.1.2.3, 1.1.6.1, and 1.1.3.1 respectively. (Details not shown)
4.      Verify the configuration:
# Display the IP routing table of Switch A.
Routing Tables: Public
         Destinations : 7       Routes : 7
0.0.0.0/0           Static 60   0            1.1.4.2         Vlan500
1.1.2.0/24          Direct 0    0            1.1.2.3         Vlan300
1.1.2.3/32          Direct 0    0            127.0.0.1       InLoop0
1.1.4.0/30          Direct 0    0            1.1.4.1         Vlan500
1.1.4.1/32          Direct 0    0            127.0.0.1       InLoop0
# Display the IP routing table of Switch B.
[SwitchB] display ip routing-table
         Destinations : 10       Routes : 10
1.1.2.0/24          Static 60   0            1.1.4.1         Vlan500
1.1.3.0/24          Static 60   0            1.1.5.6         Vlan600
1.1.4.0/30          Direct 0    0            1.1.4.2         Vlan500
1.1.4.2/32          Direct 0    0            127.0.0.1       InLoop0
1.1.5.0/30          Direct 0    0            1.1.5.5         Vlan600
1.1.5.5/32          Direct 0    0            127.0.0.1       InLoop0
1.1.6.0/24          Direct 0    0            1.1.6.1         Vlan100
1.1.6.1/32          Direct 0    0            127.0.0.1       InLoop0
# Use the ping command on Host B to check reachability to Host A (Windows XP runs on the two hosts).
C:\Documents and Settings\Administrator>ping 1.1.2.2
Pinging 1.1.2.2 with 32 bytes of data:
Reply from 1.1.2.2: bytes=32 time=1ms TTL=126
Ping statistics for 1.1.2.2:
# Use the tracert command on Host B to check reachability to Host A.
C:\Documents and Settings\Administrator>tracert 1.1.2.2
Tracing route to 1.1.2.2 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  1.1.6.1
  2    <1 ms    <1 ms    <1 ms  1.1.4.1
  3     1 ms    <1 ms    <1 ms  1.1.2.2
Trace complete.
BFD for static routes configuration example (direct next hop)
In Figure 3, configure a static route to subnet 120.1.1.0/24 on Switch A and configure a static route to subnet 121.1.1.0/24 on Switch B. Enable BFD for both routes so that when the link between Switch A and Switch B through the Layer 2 switch fails, BFD can detect the failure immediately and Switch A and Switch B can communicate through Switch C.
Figure 3 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int10
12.1.1.1/24
Switch B
Vlan-int10
12.1.1.2/24
Vlan-int11
10.1.1.102/24
Vlan-int13
13.1.1.1/24
Switch C
Vlan-int11
10.1.1.100/24
Vlan-int13
13.1.1.2/24
1.      Configure IP addresses for the interfaces. (Details not shown)
2.      Configure static routes and BFD:
# Configure static routes on Switch A and enable BFD control packet mode for the static route through the Layer 2 switch.
[SwitchA] interface vlan-interface10
[SwitchA-vlan-interface10] bfd min-transmit-interval 500
[SwitchA-vlan-interface10] bfd min-receive-interval 500
[SwitchA-vlan-interface10] bfd detect-multiplier 9
[SwitchA-vlan-interface10] quit
[SwitchA] ip route-static 120.1.1.0 24 vlan-interface 10 12.1.1.2 bfd control-packet
[SwitchA] ip route-static 120.1.1.0 24 vlan-interface 11 10.1.1.100 preference 65
[SwitchA] quit
# Configure static routes on Switch B and enable BFD control packet mode for the static route through the Layer 2 switch.
[SwitchB] interface vlan-interface10
[SwitchB-vlan-interface10] bfd min-transmit-interval 500
[SwitchB-vlan-interface10] bfd min-receive-interval 500
[SwitchB-vlan-interface10] bfd detect-multiplier 9
[SwitchB-vlan-interface10]] quit
[SwitchB] ip route-static 121.1.1.0 24 vlan-interface 10 12.1.1.1 bfd control-packet
[SwitchB] ip route-static 121.1.1.0 24 vlan-interface 13 13.1.1.2 preference 65
[SwitchB] quit
3.      Verify the configuration:
The following operations are performed on Switch A. The operations on Switch B are similar.
# Display the BFD session information.
<SwitchA> display bfd session
 Total Session Num: 1            Init Mode: Active
 Session Working Under Ctrl Mode:
 LD/RD         SourceAddr      DestAddr        State Holdtime Interface
 4/7           12.1.1.1        12.1.1.2        Up    2000ms   Vlan10
# Display the static route information. The static route to Switch B through the Layer 2 switch is displayed in the output.
<SwitchA> display ip routing-table protocol static
Public Routing Table : Static
Summary Count : 2
Static Routing table Status : <Active>
Summary Count : 1
120.1.1.0/24        Static 60   0            12.1.1.2        Vlan10
Direct Routing table Status : <Inactive>
Summary Count : 1
120.1.1.0/24        Static 65   0            10.1.1.100      Vlan11
# Enable BFD debugging. When the link between Switch A and Layer 2 switch fails, Switch A can detect the failure.
<SwitchA> debugging bfd event
<SwitchA> debugging bfd scm
<SwitchA> terminal debugging
%Jul 27 10:18:18:672 2007 SwitchA BFD/4/LOG:Sess[12.1.1.1/12.1.1.2, Vlan10,Ctrl], Sta: UP->DOWN, Diag: 1
*Jul 27 10:18:18:672 2007 SwitchA BFD/7/EVENT:Send sess-down Msg, [Src:12.1.1.1,Dst:12.1.1.2, Vlan10,Ctrl], instance:0, protocol:STATIC
*Jul 27 10:18:19:172 2007 SwitchA BFD/7/EVENT:Receive Delete-sess, [Src:12.1.1.1,Dst:12.1.1.2, Vlan10,Ctrl], Direct, Instance:0x0, Proto:STATIC
*Jul 27 10:18:19:172 2007 SwitchA BFD/7/EVENT:Notify driver to stop receiving bf
# Display the static route information on Switch A again. Switch A communicates with Switch B over the static route passing Switch C now.
Summary Count : 2
Summary Count : 1
Static Routing table Status : <Inactive>
Summary Count : 1
BFD for static routes configuration example (indirect next hop)
In Figure 4, Switch A has a route to interface Loopback1 (2.2.2.9/32) on Switch B, with outbound interface VLAN-interface 10. Switch B has a route to interface Loopback1 (1.1.1.9/32) on Switch A, with outbound interface VLAN-interface 12. Switch D has a route to 1.1.1.9/32, with outbound interface VLAN-interface 10, and a route to 2.2.2.9/32, with outbound interface VLAN-interface 12.
Configure a static route to subnet 120.1.1.0/24 on Switch A and configure a static route to subnet 121.1.1.0/24 on Switch B. Enable BFD for both routes so that when the link between Switch A and Switch B through Switch D fails, BFD can detect the failure immediately and Switch A and Switch B can communicate through Switch C.
Figure 4 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int10
12.1.1.1/24
Switch B
Vlan-int12
11.1.1.1/24
Vlan-int11
10.1.1.102/24
Vlan-int13
13.1.1.1/24
Loop1
1.1.1.9/32
Loop1
2.2.2.9/32
Switch C
Vlan-int11
10.1.1.100/24
Switch D
Vlan-int10
12.1.1.2/24
Vlan-int13
13.1.1.2/24
Vlan-int12
11.1.1.2/24
# Configure static routes on Switch A and enable BFD control packet mode for the static route through Switch D.
[SwitchA] interface loopback 1
[SwitchA-LoopBack1] bfd min-transmit-interval 500
[SwitchA-LoopBack1] bfd min-receive-interval 500
[SwitchA-LoopBack1] bfd detect-multiplier 9
[SwitchA-LoopBack1] quit
[SwitchA] ip route-static 120.1.1.0 24 2.2.2.9 bfd control-packet bfd-source 1.1.1.9
[SwitchA] quit
# Configure static routes on Switch B and enable BFD control packet mode for the static route through Switch D.
[SwitchB] interface loopback 1
[SwitchB-LoopBack1] bfd min-transmit-interval 500
[SwitchB-LoopBack1] bfd min-receive-interval 500
[SwitchB-LoopBack1] bfd detect-multiplier 9
[SwitchB-LoopBack1] quit
[SwitchB] ip route-static 121.1.1.0 24 1.1.1.9 bfd control-packet bfd-source 2.2.2.9
[SwitchB] quit
The following operations are performed on Switch A. The operations on Switch B are similar and are not shown.
Total session number: 1   Up session number: 0   Init mode: Active
 IPv4 session working under Ctrl mode:
 4/7           1.1.1.9         2.2.2.9         Up    2000ms   Loop1
# Display the static route information. The static route to Switch B through Switch D is displayed in the output.
Summary Count : 2
Summary Count : 1
120.1.1.0/24        Static 60   0            2.2.2.9         Vlan10
Summary Count : 1
# Enable BFD debugging. When the link between Switch A and Switch D fails, Switch A can detect the failure.
%Oct 10 10:18:18:672 2010 SwitchA BFD/4/LOG:Sess[1.1.1.9/2.2.2.9, Loop1,Ctrl], Sta: UP->DOWN, Diag: 1
* Oct 10 10:18:18:672 2010 SwitchA BFD/7/EVENT:Send sess-down Msg, [Src:1.1.1.9,Dst:2.2.2.9, Loop1,Ctrl], instance:0, protocol:STATIC
Summary Count : 2
Summary Count : 1
Summary Count : 1
Static route FRR configuration example
Figure 5 shows that Switch S, Switch A, and Switch D are interconnected through static routes. Configure static route FRR so that when Link A between Switch S and Switch D fails, traffic can be switched to Link B immediately.
Figure 5 Network diagram
1.      Configure IP addresses for the interfaces on each switch. (Details not shown)
Configure static routes on Switch S, Switch A, and Switch D so that Switch S can reach Loopback 0 on Switch D and Switch D can reach Loopback 0 on Switch S.
# Configure a static route on Switch S.
<SwitchS> system-view
[SwitchS] ip route-static 4.4.4.4 32 vlan-interface 200 13.13.13.2
[SwitchS] ip route-static 4.4.4.4 32 vlan-interface 100 12.12.12.2 preference 65
# Configure a static route on Switch D.
<SwitchD> system-view
[SwitchD] ip route-static 1.1.1.1 32 vlan-interface 200 13.13.13.1
[SwitchD] ip route-static 1.1.1.1 32 vlan-interface 101 24.24.24.2 preference 65
# Configure a static route on Switch A.
[SwitchA] ip route-static 4.4.4.4 32 vlan-interface 101 24.24.24.4
[SwitchA] ip route-static 1.1.1.1 32 vlan-interface 100 12.12.12.1
3.      Configure static route FRR:
# Configure Switch S.
[SwitchS] bfd echo-source-ip 1.1.1.1
[SwitchS] ip ip-prefix abc index 10 permit 4.4.4.4 32
[SwitchS] route-policy frr permit node 10
[SwitchS-route-policy] if-match ip-prefix abc
[SwitchS-route-policy] apply fast-reroute backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
[SwitchS-route-policy] quit
[SwitchS] ip route-static fast-reroute route-policy frr
# Configure Switch D.
[SwitchD] bfd echo-source-ip 4.4.4.4
[SwitchD] ip ip-prefix abc index 10 permit 1.1.1.1 32
[SwitchD-route-policy] if-match ip-prefix abc
[SwitchD-route-policy] apply fast-reroute backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
[SwitchD-route-policy] quit
[SwitchD] ip route-static fast-reroute route-policy frr
# Display route 4.4.4.4/32 on Switch S to view the backup next hop information.
[SwitchS] display ip routing-table 4.4.4.4 verbose
Routing Table : Public
Summary Count : 2
  Destination: 4.4.4.4/32
     Protocol: Static          Process ID: 0
   Preference: 60                    Cost: 0
 IpPrecedence:                    QosLcID:
      NextHop: 13.13.13.2       Interface: vlan 200
    BkNextHop: 12.12.12.2     BkInterface: vlan 100
  RelyNextHop: 0.0.0.0          Neighbor : 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
  BKTunnel ID: 0x0                BKLabel: NULL
        State: Active Adv             Age: 00h01m27s
          Tag: 0
   Preference: 100                      Cost: 0
    BkNextHop: 0.0.0.0          BkInterface:
          Tag: 0
# Display route 1.1.1.1/32 on Switch D to view the backup next hop information.
[SwitchD] display ip routing-table 1.1.1.1 verbose
Summary Count : 2
  Destination: 1.1.1.1/32
      NextHop: 13.13.13.1       Interface: vlan 200
    BkNextHop: 24.24.24.2     BkInterface: vlan 101
          Tag: 0
          Tag: 0
Introduction to default routes
A default route is used to forward packets that match no entry in the routing table.
Without a default route, a packet that does not match any routing entries is discarded and an Internet Control Message Protocol (ICMP) destination-unreachable packet is sent to the source.
Default route can be configured in either of the following ways:
·           The network administrator can configure a default route with both destination and mask being 0.0.0.0. For more information, see the chapter “Configuring static routing.”
·           Some dynamic routing protocols, such as Open Shortest Path First (OSPF), Routing Information Protocol (RIP), and Intermediate System-to-Intermediate System (IS-IS), can generate a default route. For example, an upstream router running OSPF can generate a default route and advertise it to other routers, which install the default route with the next hop being the upstream router. For more information, see configuration guides of relevant routing protocols.
