H3C LSPM1FAN and LSPM1FANB Installation Manual-6W100
HomeSupportSwitchesH3C S5120 Switch SeriesInstall & UpgradeFan Tray ManualsH3C LSPM1FAN and LSPM1FANB Installation Manual-6W100
00-Preface
00-Preface 53.2 KB
Conventions
This section describes the conventions used in this documentation set.
Convention
 WARNING
 CAUTION
 IMPORTANT
NOTE
 TIP
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
Documentation feedback
We appreciate your comments.
