H3C S5120-SI Series Ethernet Switches Command Reference-Release 1101-6W105
HomeSupportSwitchesH3C S5120 Switch SeriesReference GuidesCommand ReferencesH3C S5120-SI Series Ethernet Switches Command Reference-Release 1101-6W105
25-Public Key Commands
25-Public Key Commands 50.92 KB
Public Key Configuration Commands
display public-key local public
display public-key local { dsa | rsa } public
View
Default Level
1: Monitor level
dsa: DSA key pair.
rsa: RSA key pair.
Use the display public-key local public command to display the public key information of the local key pairs.
Related commands: public-key local create.
# Display the public key information of the local RSA key pairs.
<Sysname> display public-key local rsa public
Time of Key pair created: 19:59:16  2007/10/25
Key name: HOST_KEY
Key type: RSA Encryption Key
Key code:
30819F300D06092A864886F70D010101050003818D0030818902818100BC4C392A97734A633BA0F1DB01F84EB51228EC86ADE1DBA597E0D9066FDC4F04776CEA3610D2578341F5D049143656F1287502C06D39D39F28F0F5CBA630DA8CD1C16ECE8A7A65282F2407E8757E7937DCCDB5DB620CD1F471401B7117139702348444A2D8900497A87B8D5F13D61C4DEFA3D14A7DC07624791FC1D226F62DF3020301
0001
Time of Key pair created: 19:59:17  2007/10/25
Key name: SERVER_KEY
Key code:
307C300D06092A864886F70D0101010500036B003068026100C51AF7CA926962284A4654B2AACC7B2AE12B2B1EABFAC1CDA97E42C3C10D7A70D1012BF23ADE5AC4E7AAB132CFB6453B27E054BFAA0A85E113FBDE751EE0ECEF659529E857CF8C211E2A03FD8F10C5BEC162B2989ABB5D299D1E4E27A13C7DD10203010001
# Display the public key information of the local DSA key pair.
<Sysname> display public-key local dsa public
Time of Key pair created: 20:00:16  2007/10/25
Key name: HOST_KEY
Key type: DSA Encryption Key
Key code:
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
A4C79054
Table 1-1 display public-key local public command output description
Time at which the local key pair is created
Key name
Key name, which can be:
l      HOST_KEY: Host public key.
l      SERVER_KEY: Server public key. This value is available only for RSA key pairs.
Key type
Key type, which can be:
l      RSA Encryption Key: RSA key pair.
l      DSA Encryption Key: DSA key pair.
Key code
Key data
display public-key peer
display public-key peer [ brief | name publickey-name ]
View
Default Level
1: Monitor level
brief: Displays brief information about all the host public keys of peers.
name publickey-name: Displays information about a peer's host public key. publickey-name specifies a host public key by its name, which is a case-sensitive string of 1 to 64 characters.
Use the display public-key peer command to display information about the specified or all locally saved public keys of peers.
With neither the brief keyword nor the name publickey-name combination specified, the command displays detailed information about all locally saved public keys of peers.
You can use the public-key peer command or the public-key peer import sshkey command to get a local copy of the public keys of a peer.
Related commands: public-key peer, public-key peer import sshkey.
# Display detailed information about the peer host public key named idrsa.
<Sysname> display public-key peer name idrsa
  Key name  : idrsa
  Key type  : RSA
  Key module: 1024
Key Code:
30819D300D06092A864886F70D010101050003818B00308187028181009C46A8710216CEC0C01C7CE136BA76C79AA6040E79F9E305E453998C7ADE8276069410803D5974F708496947AB39B3F39C5CE56C95B6AB7442D56393BF241F99A639DD02D9E29B1F5C1FD05CC1C44FBD6CFFB58BE6F035FAA2C596B27D1231D159846B7CB9A7757C5800FADA9FD72F65672F4A549EE99F63095E11BD37789955020123
# Display brief information about all locally saved public keys of the peers.
<Sysname> display public-key peer brief
Type  Module  Name
RSA   1024    idrsa
DSA   1024    10.1.1.1
peer-public-key end
peer-public-key end
View
Public key view
Default Level
2: System level
None
Use the peer-public-key end command to return from public key view to system view.
Related commands: public-key peer.
# Exit public key view.
[Sysname] public-key peer key1
[Sysname-pkey-public-key] peer-public-key end
[Sysname]
public-key-code begin
View
Public key view
Default Level
2: System level
None
Use the public-key-code begin command to enter public key code view.
After entering public key code view, input the key data in the correct format. Spaces and carriage returns are allowed between characters.
You can input the key data displayed with the display public-key local public command to make sure the format requirements are met.
You can configure the RSA server public key of the peer. However, the public key configured cannot be used for identity authentication in SSH applications, which use the RSA host public key. For more information about SSH, see SSH2.0 Configuration.
# Enter public key code view and input the key.
[Sysname-pkey-public-key] public-key-code begin
[Sysname-pkey-key-code]30819F300D06092A864886F70D010101050003818D0030818902818100C0EC8014F82515F6335A0A
[Sysname-pkey-key-code]EF8F999C01EC94E5760A079BD73E4F4D97F3500EDB308C29481B77E719D1643135877E13B1C531B4
[Sysname-pkey-key-code]FF1877A5E2E7B1FA4710DB0744F66F6600EEFE166F1B854E2371D5B952ADF6B80EB5F52698FCF3D6
[Sysname-pkey-key-code]1F0C2EAAD9813ECB16C5C7DC09812D4EE3E9A0B074276FFD4AF2050BD4A9B1DDE675AC30CB020301
[Sysname-pkey-key-code]0001
public-key-code end
public-key-code end
View
Public key code view
Default Level
2: System level
None
Use the public-key-code end command to return from public key code view to public key view and to save the configured public key.
The system verifies the key before saving it. If the key is not in the correct format, the system discards the key and displays an error message. If the key is valid, the system saves the key.
Related commands: public-key peer, public-key-code begin.
# Exit public key code view and save the configured public key.
[Sysname-pkey-key-code] public-key-code end
public-key local create { dsa | rsa }
View
Default Level
2: System level
dsa: DSA key pair.
rsa: RSA key pair.
Use the public-key local create command to create local key pair(s).
Note that:
l          When using this command to create DSA or RSA key pairs, you will be prompted to provide the length of the key modulus. The modulus length is in the range 512 to 2048 bits, and defaults to 1024 bits. If the type of key pair already exists, the system will ask you whether you want to overwrite it.
l          The local key pairs created with the public-key local create command are saved automatically and can survive a reboot.
Related commands: public-key local destroy, display public-key local public.
# Create local RSA key pairs.
[Sysname] public-key local create rsa
NOTES: If the key modulus is greater than 512,
It will take a few minutes.
Press CTRL+C to abort.
Input the bits of the modulus[default = 1024]:
Generating Keys...
# Create a local DSA key pair.
[Sysname] public-key local create dsa
Generating Keys...
public-key local destroy { dsa | rsa }
View
Default Level
2: System level
dsa: DSA key pair.
rsa: RSA key pair.
Use the public-key local destroy command to destroy the local key pair(s).
# Destroy the local RSA key pairs.
[Sysname] public-key local destroy rsa
Warning: Confirm to destroy these keys? [Y/N]:y
# Destroy the local DSA key pair.
[Sysname] public-key local destroy dsa
Warning: Confirm to destroy these keys? [Y/N] :y
public-key local export dsa
public-key local export dsa { openssh | ssh2 } [ filename ]
View
Default Level
1: Monitor level
openssh: Uses the format of OpenSSH.
ssh2: Uses the format of SSH2.0.
filename: Name of the file for storing the local public key. For detailed information about file name, see File System Management.
Use the public-key local export dsa command to display the local DSA public key on the screen or export it to a specified file.
If you do not specify the filename argument, the command displays the local DSA public key on the screen; otherwise, the command exports the local DSA public key to the specified file and saves the file.
SSH2.0 and OpenSSH are two different public key formats for different requirements.
Related commands: public-key local create, public-key local destroy.
# Export the local DSA public key in OpenSSH format to a file named key.pub.
[Sysname] public-key local export dsa openssh key.pub
# Display the local DSA public key in SSH2.0 format.
[Sysname] public-key local export dsa ssh2
---- BEGIN SSH2 PUBLIC KEY ----
Comment: "dsa-key-20070625"
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
---- END SSH2 PUBLIC KEY ----
# Display the local DSA public key in OpenSSH format.
ssh-dss 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 dsa-key
public-key local export rsa
public-key local export rsa { openssh | ssh1 | ssh2 } [ filename ]
View
Default Level
1: Monitor level
ssh1: Uses the format of SSH1.5.
filename: Name of the file for storing the public key. For detailed information about file name, see File System Management.
Use the public-key local export rsa command to display the local RSA public key on the screen or export them to a specified file.
If you do not specify the filename argument, the command displays the local RSA public key on the screen; otherwise, the command exports the local RSA public key to the specified file and saves the file.
SSH1, SSH2.0 and OpenSSH are three different public key formats for different requirements.
# Export the local RSA public key in OpenSSH format to a file named key.pub.
[Sysname] public-key local export rsa openssh key.pub
# Display the local RSA public key in SSH2.0 format.
[Sysname] public-key local export rsa ssh2
Comment: "rsa-key-20070625"
AAAAB3NzaC1yc2EAAAADAQABAAAAgQDAo0dVYR1S5f30eLKGNKuqb5HU3M0TTSaGlER2GmcRI2sgSegbo1x6ut5NIc5+jJxuRCU4+gMc76iS8d+2d50FqIweEkHHkSG/ddgXt/iAZ6cY81bdu/CKxGiQlkUpbw4vSv+X5KeE7j+o0MpOpzh3W768/+u1riz+1LcwVTs51Q==
# Display the local RSA public key in OpenSSH format.
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQDAo0dVYR1S5f30eLKGNKuqb5HU3M0TTSaGlER2GmcRI2sgSegbo1x6ut5NIc5+jJxuRCU4+gMc76iS8d+2d50FqIweEkHHkSG/ddgXt/iAZ6cY81bdu/CKxGiQlkUpbw4vSv+X5KeE7j+o0MpOpzh3W768/+u1riz+1LcwVTs51Q== rsa-key
public-key peer
public-key peer keyname
undo public-key peer keyname
View
Default Level
2: System level
keyname: Host public key name of the peer, a case-sensitive string of 1 to 64 characters.
Use the public-key peer command to specify a name for a peer's host public key and enter public key view.
Use the undo public-key peer command to remove a peer’s host public key.
After entering public key view, you can configure the public key of the peer with the public-key-code begin and public-key-code end commands. This operation requires that you obtain the hexadecimal public key from the peer beforehand.
Related commands: public-key-code begin, public-key-code end, display public-key peer.
# Specify the name for the peer's host public key as key1 and enter public key view.
public-key peer keyname import sshkey filename
View
Default Level
2: System level
keyname: Public key name, a case-sensitive string of 1 to 64 characters.
filename: Name of the file that saves a peer's public key. For detailed information about file name, see File System Management.
Use the public-key peer import sshkey command to import the public key of a peer from the public key file.
Use the undo public-key peer command to remove a configured peer public key.
After execution of this command, the system automatically transforms the public key in SSH1, SSH2.0 or OpenSSH format to PKCS format, and imports the peer public key. This operation requires that you get a copy of the public key file from the peer through FTP or TFTP in advance.
Related commands: display public-key peer.
# Import the peer host public key named key2 from the public key file key.pub.
[Sysname] public-key peer key2 import sshkey key.pub
