Layer 2 - LAN Switching Configuration Guide
HomeSupportWirelessWA2200 Series WLAN Access PointsConfigure & DeployConfiguration GuidesH3C WA Series WLAN Access Points Configuration Guide-6W100Layer 2 - LAN Switching Configuration Guide
02-Ethernet Interface Configuration
02-Ethernet Interface Configuration 77.48 KB
l          The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l          Support of the H3C WA series WLAN access points (APs) for features may vary by AP model. For more information, see Feature Matrix.
l          The interface types and the number of interfaces vary by AP model.
This chapter includes these sections:
l          General Ethernet Interface Configuration
l          Configuring a Layer 2 Ethernet Interface
l          Displaying and Maintaining an Ethernet Interface
Layer-2 Ethernet interfaces are physical interfaces operating at the data link layer, processing Layer-2 protocols, and implementing Layer-2 fast forwarding. This document describes Layer-2 Ethernet interface attributes and configuration on the AP.
Configuring Basic Settings of an Ethernet Interface
You can set an Ethernet interface to operate in one of the following duplex modes:
l          Full-duplex mode (full). Interfaces operating in this mode can send and receive packets simultaneously.
l          Half-duplex mode (half). Interfaces operating in this mode cannot send and receive packets simultaneously.
l          Auto-negotiation mode (auto). Interfaces operating in this mode negotiate a duplex mode with their peers.
Similarly, you can set the speed of an Ethernet interface or enable it to automatically negotiate a speed with its peer by using the speed auto command.
Follow these steps to configure the basic settings of an Ethernet interface:
To do…
Use the command…
Remarks
Enter system view
Enter Ethernet interface view
Change the description of the interface
Optional
By default, the description of an interface is the interface name followed by character string Interface. For example, Ethernet1/0/1 Interface.
Set the duplex mode
duplex { auto | full | half }
Optional
auto by default.
Optical interfaces do not support the half keyword.
Set the port speed
speed { 10 | 100 | 1000 | auto }
Optional
auto by default.
l      Optical interfaces do not support the 10 or 100 keyword.
l       Support for the 1000 keyword varies with AP models.
Shut down the Ethernet interface
shutdown
Optional
By default, an Ethernet interface is in the up state.
To bring up an Ethernet interface, use the undo shutdown command.
Configuring Flow Control on an Ethernet Interface
You can avoid packet drops on a link by enabling flow control at both ends of the link. When traffic congestion occurs at the receiving end, the receiving end sends a Pause frame to ask the sending end to suspend sending packets. In this way, flow control helps avoid packet drops.
Follow these steps to enable flow control on an Ethernet interface:
To do…
Use the command…
Remarks
Enter system view
Enable flow control
flow-control
Required
Disabled by default
Configuring Loopback Testing on an Ethernet Interface
If an Ethernet interface does not work normally, you can enable loopback testing on it to identify the problem. There are two types of loopback testing:
l          Internal loopback testing, which tests all on-chip functions related to the Ethernet interfaces.
l          External loopback testing, which tests the hardware of Ethernet interfaces. To perform external loopback testing on an Ethernet interface, connect a loopback plug to the Ethernet interface. The AC sends test packets out the interface, which are expected to loop over the plug and back to the interface. If the interface fails to receive any test packet, the hardware of the interface is faulty.
Ethernet interfaces cannot forward data packets during loopback testing.
Follow these steps to enable loopback testing on an Ethernet interface:
To do…
Use the command…
Remarks
Enter system view
Enable loopback testing
Optional
Disabled by default.
l          On an interface that is physically down, you can perform only internal loopback testing. On an interface administratively shut down, you can perform neither internal nor external loopback testing.
l          The speed, duplex, and shutdown commands are unavailable during loopback testing.
l          During loopback testing, an Ethernet interface works in full duplex mode. When you disable loopback testing, the duplex setting of the interface restores.
Layer 2 Ethernet Interface Configuration Task List
Complete these tasks to configure a Layer 2 Ethernet interface:
Remarks
Configuring Storm Suppression
Optional
Applicable to Layer 2 Ethernet interfaces
Setting the Interface Statistics Polling Interval
Optional
Enabling Loopback Detection on an Ethernet Interface
Optional
You can use the storm suppression function to limit the size of a particular type of traffic (currently broadcast, multicast and unknown unicast traffic) on Ethernet interfaces in Ethernet interface view. When the broadcast, multicast, or unknown unicast traffic on the interface exceeds the threshold, the system discards packets until the traffic drops below the threshold.
Follow these steps to set storm suppression thresholds on an Ethernet interface:
To do…
Use the command…
Remarks
Enter system view
Settings made in Ethernet interface view take effect on the current interface only.
Set the broadcast storm suppression threshold
broadcast-suppression { ratio | pps max-pps }
Optional
By default, broadcast traffic is not suppressed.
Set the multicast storm suppression threshold
multicast-suppression { ratio | pps max-pps }
Optional
By default, multicast traffic is not suppressed.
Set the unknown unicast storm suppression threshold
unicast-suppression { ratio | pps max-pps }
Optional
By default, unknown unicast traffic is not suppressed.
Follow these steps to set the interface statistics polling interval:
To do…
Use the command…
Remarks
Enter system view
Set the interface statistics polling interval
flow-interval interval
Optional
The default interface statistics polling interval is 300 seconds
In system view, you configure a statistics polling interval for all interfaces.
If an interface receives a packet that it sent out, a loop has occurred. Loops may cause broadcast storms, which degrade network performance. You can enable loopback detection to detect loops on an interface and, if the interface supports the loopback-detection action command, configure the protective action to take on the interface when a loop is detected, for example, to shut down the interface. Depending on whether a protective action is configured, the AP takes the actions in Table 1-1 to alleviate the impact of the loop condition.
Table 1-1 Actions taken upon detection of a loop condition
Port type
Actions
No protective action configured
A protective action configured
Access port
l      Place the interface in controlled mode. The interface discards all incoming packets, but still forwards outgoing traffic.
l      Generate traps.
l      Delete all MAC address entries of the interface.
l      Perform the configured protective action.
l      Generate traps and log messages.
Hybrid or trunk port
l      Generate traps.
l      If loopback detection control is enabled, set the interface in controlled mode. The interface discards all incoming packets, but still forwards outgoing packets.
l      Create traps and log messages.
l      If loopback detection control is enabled, take the configured protective action on the interface.
Follow these steps to configure loopback detection:
To do…
Use the command…
Remarks
Enter system view
Enable global loopback detection
loopback-detection enable
Required
Disabled by default
Set the loopback detection interval
loopback-detection interval-time time
Optional
30 seconds by default
Enable loopback detection control on a trunk or hybrid port
loopback-detection control enable
Optional
Disabled by default
l          To use loopback detection on an Ethernet interface, you must enable the function both globally and on the interface.
l          To disable loopback detection on all interfaces, run the undo loopback-detection enable command in system view.
l          To enable a hybrid or trunk port to take the administratively specified protective action, you must perform the loopback-detection control enable command on the port.
To do…
Use the command…
Remarks
Display the current state of an interface and the related information
display interface [ interface-type [ interface-number | interface-number.subnumber ] ]
Available in any view
Display the summary information of an interface
display brief interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ | { begin | exclude | include } regular-expression ]
Clear the statistics of an interface
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
Available in user view
Display the information about the loopback function
display loopback-detection
