H3C WX Series Access Controllers User Manual-6W104
HomeSupportWirelessH3C WX3000 Series Unified SwitchesConfigure & DeployUser ManualsH3C WX Series Access Controllers User Manual-6W104
03-Compatibility Matrices
03-Compatibility Matrices 401.34 KB
Support of the H3C WX series access controllers for features and commands may vary by device model.
l          The H3C WX series access controller products include H3C access controllers, access controller modules, and H3C WX series unified switches' access controller engines. Support of the H3C WX series access controllers for features and commands may vary by device model. Refer to Feature Matrices and Command Matrices for details.
l          The WX3000 series includes the WX3024, WX3010, and WX3008 unified switches.
l          The WX5000 series includes the WX5002 and WX5004 access controllers, and the LS8M1WCMA0, LSWM1WCM10, and LSWM1WCM20 access controller modules.
l          The WX6000 series includes the WX6103 access controllers, and the LSQM1WCMB0, LSBM1WCM2A0, and LSRM1WCM2A1 access controller modules.
l          The models listed in this manual are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
Access Controller Module and Ethernet Switch Compatibility Matrix
For switches supporting IRF (for example, the S5800 series), if one of the IRF members has an access controller module installed, the access controller module can manage all fit APs connected to all the IRF members.
Table 1-1 Access controller module and Ethernet switch compatibility matrix
Ethernet switch model
LSWM1WCM20
S5800 series:
S5800-60C-PWR/S5800-32F/S5800-56C/S5800-32C/S5800-32C-PWR/S5800-56C-PWR
LSWM1WCM10
S5800 series:
S5800-60C-PWR
S5820 series:
S5820-28C
LS8M1WCMA0
S7500 series:
S7502/S7503/S7506/S7506R
LSQM1WCMB0
S7500E series:
S7502E/S7503E-S/S7503E/S7506E-S/S7506E/S7506E-V/S7510E
LSBM1WCM2A0
S9500 series:
S9512/S9508/S9508V/S9505
LSRM1WCM2A1
S9500E series:
S9505E/S9508E-V/S9512E
Typical Network Scenarios
AC Networking
As shown in the following figure, AC is connected to Switch (Layer 2 or Layer 3), which can be connected to APs directly or connected to APs over a network, and Clients can be connected to the network through the APs to implement WLAN user access.
Figure 1-1 AC networking
Access Controller Module Networking
As shown in the following figure, installed with an access controller module, Switch (Layer 2 or Layer 3) can be connected to APs directly or connected to APs over a network, and Clients can be connected to the network through the APs to implement WLAN user access.
Figure 1-2 Access controller module networking
Unified Switch Networking
As shown in the following figure, Unified switch can be connected to APs directly or connected to APs over a network, and Clients can be connected to the network through the APs to implement WLAN user access.
Figure 1-3 Unified switch networking diagram
Feature Matrix for the WX5000 Series
The LS8M1WCMA0, LSWM1WCM10, and LSWM1WCM20 on the WX5000 series adopt the OAP architecture. Installed on the expansion slots of switches, they work as OAP cards to exchange data and status and control information with the switches through their internal service interfaces. You are not recommended to configure services such as QoS rate limiting and 802.1X authentication on GE interfaces on the LS8M1WCMA0, XGE 1/0/1 on the LSWM1WCM10, and the logical interface BAGG1 aggregated by GE 1/0/1 and GE 1/0/2 on the LSWM1WCM20.
Table 2-1 Feature matrix for the WX5000 series
Volume
Module
Feature
WX5002
WX5002V2
LS8M1WCMA0
WX5004
LSWM1WCM10
LSWM1WCM20
Login
Login configuration
AUX user interface
Supported
Not supported
Supported
Not supported
Supported
Supported
Console user interface
Not supported
Supported
Not supported
Supported
Not supported
Not supported
VTY user interface
Supported
Supported
Supported
Supported
Supported
Supported
Telnet
Supported
Supported
Supported
Supported
Supported
Supported
Web-based NMS
Supported
Supported
Supported
Supported
Supported
Supported
NMS
Supported
Supported
Supported
Supported
Supported
Supported
Access controller module basic configuration
Not supported
Not supported
Supported
Not supported
Supported
Supported
Access
Ethernet interface configuration
Combo port configuration
Supported
Supported
Not supported
Supported
Not supported
Not supported
Shutting down an Ethernet interface
Supported
Supported
Supported
Supported
Supported.
However, you are not recommended to use the shutdown command on internal interfaces; otherwise, the normal operation of the device will be affected.
Supported.
Configuring flow control on an Ethernet interface
Supported
Supported
Supported
Supported
Not supported
Not supported
Configuring loopback detection on an Ethernet interface
Supported on GE interfaces only
Internal loopback testing supported on GE interfaces only
Internal loopback testing supported on XGE interfaces only
Link aggregation configuration
Link aggregation
Supported
Supported
Not supported
Supported
Not supported
Supported
Port mirroring configuration
Port mirroring
Remote port mirroring and cross-board mirroring not supported
Not supported
Not supported
Not supported
Layer 2 forwarding configuration
Layer 2 forwarding
Supported
Not supported
Supported
Supported
Not supported
Not supported
STP
STP
Not supported
Supported
Not supported
Supported
Not supported
Not supported
IP services
DNS configuration
IPv6 DNS configuration
Supported
Supported
Supported
Supported
Supported
Supported
IP performance optimization configuration
Configuring ICMP to send error packets
Supported
Not supported
Not supported
Not supported
Not supported
Not supported
IPv6 basics configuration
Supported
Supported
Supported
Supported
Supported
Supported
IPv6 application configuration
Supported
Supported
Supported
Supported
Supported
Supported
Adjacency table configuration
Displaying and maintaining adjacency table
Not supported
Supported
Not supported
Supported
Supported
Supported
Dual stack configuration
Supported
Supported
Supported
Supported
Supported
Supported
IP routing
IP routing basics configuration
IPv6 features
Supported
Supported
Supported
Supported
Supported
Supported
IPv6 static routing configuration
Supported
Supported
Supported
Supported
Supported
Supported
IP multicast
MLD snooping configuration
MLD snooping
Supported
Supported
Supported
Supported
Supported
Supported
IPv6 multicast VLAN configuration
IPv6 multicast VLAN
Supported
Supported
Supported
Supported
Supported
Supported
QoS
QoS
Configuring line rate
Supported
Supported
Supported
Not supported
Supported
Supported
Configuring CAR applicable to all traffic of online users
Not supported
Supported
Not supported
Supported
Supported
Supported
Congestion management
Supported
Supported
Supported
Not supported
Supported
Supported
Security
AAA
Specifying the device ID to be used in stateful failover mode
Not supported
Supported
Not supported
Supported
Supported
Not supported
Security
Portal configuration
Configuring Layer 3 portal authentication
Not supported
Supported
Not supported
Supported
Supported
Supported
Specifying the portal group to which the portal service backup interface belongs
Not supported
Supported
Not supported
Supported
Supported
Not supported
Not supported
Supported
Not supported
Supported
Supported
Not supported
Specifying the backup source IP address for RADIUS packets to be sent
Not supported
Supported
Not supported
Supported
Supported
Not supported
ACL configuration
IPv6 ACL
Supported
Supported
Supported
Supported
Supported
Supported
SSH2.0 configuration
Specifying a source IPv6 address or interface for an SSH client
Supported
Supported
Supported
Supported
Supported
Supported
Establishing a connection between an SSH client and an IPv6 SSH server
Supported
Supported
Supported
Supported
Supported
Supported
Specifying a source IPv6 address or interface for an SFTP client
Supported
Supported
Supported
Supported
Supported
Supported
Establishing a connection between an SFTP client and an IPv6 SFTP server
Supported
Supported
Supported
Supported
Supported
Supported
IPv6 SFTP client
Supported
Supported
Supported
Supported
Supported
Supported
Security protection configuration
Management protocol packets supported
Telnet, SNMP, and web management packets whose destination IP address is the local host
ICMP, IEC, Telnet, and SNMP packets whose destination IP address is the local host
Other protocol packets supported
11MAC/ 8
02.1X/AR
P/DHCP/
HWTACA
S/ICMP/I
GMP/ML
D/LWAP
P/ND/NT
P/PIM/R
ADIUS
Data packets: all packets except the above packets.
UDP/ TC
P/ 802.1X
/ DHCP/ I
GMP/ NT
P/ ARP/L
WAPP/ L
ooPback/
PPPoE/ I
ACTP/ A
CSEI/ WA
PI/ STP/ L
WAPP_D
ATA/ Default
11MAC/ 8
02.1X/ AR
P/ DHCP/
HWTACA
S/ ICMP/ I
GMP/ ML
D/ LWAP
P/ ND/ NT
P/ PIM
/ RADIUS
UDP/ TC
P/ 802.1X
/ DHCP/ I
GMP/ NT
P/ ARP/ L
WAPP/ L
ooPback/
PPPoE/ I
ACTP/ A
CSEI/ WA
PI/ STP/ L
WAPP_D
ATA/ Def
ault
UDP/ TC
P/ 802.1X
/ DHCP/ I
GMP/ NT
P/ ARP/ L
WAPP/ L
ooPback/
PPPoE/ I
ACTP/ A
CSEI/ WA
PI/ STP/ L
WAPP_D
ATA/ Def
ault
UDP/ TC
P/ 802.1X
/ DHCP/ I
GMP/ NT
P/ ARP/ L
WAPP/ L
ooPback/
PPPoE/ I
ACTP/ A
CSEI/ WA
PI/ STP/ L
WAPP_D
ATA/ Def
ault
Enabling attack prevention for protocols
Not supported
Supported
Not supported
Supported
Supported
Supported
Configuring rate limits for a protocol
Not supported
Supported
Not supported
Supported
Supported
Supported
WAPI configuration
WAPI
Not supported
Supported
Not supported
Supported
Supported
Supported
System
Device management configuration
Storage media supported
Flash
CF
Flash
CF
CF
Flash
License
l      The WX5002 supports 32 concurrent APs by default, and can be extended to support 64 concurrent APs.
l      Not supported on the WX5002-128
The WX5002V2 supports 32 concurrent APs by default, and can be extended to support 64 concurrent APs.
Not supported
The new WX5004 supports 64 concurrent APs by default, and can be extended to support 256 concurrent APs.
The LSWM1WCM10 supports 64 concurrent APs by default, and can be extended to support 256 concurrent APs.
The LSWM1WCM20 supports 32 concurrent APs by default, and can be extended to support 128 concurrent APs.
File system management configuration
Configuration file encryption
Not supported
Not supported
Not supported
Not supported
Not supported
Supported
Information center configuration
Logfile
Not supported
Not supported
Not supported
Supported
Supported
Not supported
User interface configuration
User interface type
Console user interface not supported
AUX user interface not supported
Supported
OAA
OAA configuration
OAP module configuration
Not supported
Supported
Not supported
Supported
Not supported
Not supported
ACSEI server configuration
Not supported
Supported
Not supported
Supported
Not supported
Not supported
ACSEI client configuration
Not supported
Supported
Supported
Supported
Supported
Supported
WLAN
WLAN services configuration
Hot AC backup
Not supported
Not supported
Not supported
Supported
Supported
Not supported
Feature Matrix for the WX6000 Series
The switch interface module on the WX6103, and the LSQM1WCMB0, LSBM1WCM2A0, and LSRM1WCM2A1 access controller modules on the WX6000 series adopt the OAP architecture. Installed on the expansion slots of switches, they work as OAP cards to exchange data and status and control information with the switches through their internal service interfaces. The XGE interfaces on the switch interface module on the WX6103, and the LSQM1WCMB0, LSBM1WCM2A0, and LSWM1WCM10 access controller modules are internal interfaces. Therefore, you are not recommended to configure services such as QoS rate limiting and 802.1X authentication on them.
Table 2-2 Feature matrix for the WX6000 series
Volume
Module
Feature
WX6103
LSQM1WCMB0
LSBM1WCM2A0
LSRM1WCM2A1
Login
Login configuration
AUX user interface
Not supported
Not supported
Not supported
Supported
Supported
Supported
Supported
Supported
VTY user interface
Supported
Supported
Supported
Supported
Telnet
Supported
Supported
Supported (IPv6 telnet not supported)
Supported
Web-based NMS
Supported
Supported
Supported
Supported
NMS
Supported
Supported
Supported
Supported
Not supported
Supported
Supported
Supported
Access
The MPU does not support the Combo port.
Not supported
Not supported
Not supported
Supported
Supported
Supported
Supported
Loopback detection on an Ethernet interface
Not supported
Not supported
Not supported
Not supported
Link aggregation
Not supported
Not supported
Not supported
Not supported
Port mirroring
Not supported
Not supported
Not supported
Not supported
Layer 2 forwarding
Not supported
Not supported
Not supported
Not supported
STP
STP
Not supported
Not supported
Not supported
Not supported
IP services
DNS configuration
Supported
Supported
Not supported
Supported
Not supported
Not supported
Not supported
Not supported
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Not supported
Supported
IP routing
IPv6-related displaying and maintaining commands
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
IP multicast
MLD snooping
Supported
Supported
Not supported
Not supported
IPv6 multicast VLAN
Supported
Supported
Not supported
Not supported
QoS
QoS
Not supported
Not supported
Not supported
Not supported
Supported
Supported
Supported
Supported
Not supported
Not supported
Not supported
Not supported
Security
AAA configuration
Supported
Supported
Supported
Supported
Security
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
ACL configuration
IPv6 ACL
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
IPv6 SFTP client
Supported
Supported
Not supported
Supported
UDP/ TCP/ 80
2.1X/ DHCP/ I
GMP/ NTP/ A
RP/ LWAPP/
LooPback/ P
PPoE/ IACTP
/ ACSEI/ WAP
I/ STP/ LWAP
P_DATA/ Def
ault
UDP/ TCP/ 80
2.1X/ DHCP/ I
GMP/ NTP/ A
RP/ LWAPP/
LooPback/ P
PPoE/ IACTP
/ ACSEI/ WAP
I/ STP/ LWAP
P_DATA/ Def
ault
UDP/ TCP/ 80
2.1X/ DHCP/ I
GMP/ NTP/ A
RP/ LWAPP/
LooPback/ P
PPoE/ IACTP
/ ACSEI/ WAP
I/ STP/ LWAP
P_DATA/ Def
ault
UDP/ TCP/ 80
2.1X/ DHCP/ I
GMP/ NTP/ A
RP/ LWAPP/
LooPback/ P
PPoE/ IACTP
/ ACSEI/ WAP
I/ STP/ LWAP
P_DATA/ Def
ault
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
WAPI configuration
WAPI
Supported
Supported
Supported
Supported
System
CF and USB
CF and USB
CF and USB
CF and USB
License
128 APs at most by default, and can be extended to 640 APs.
Not supported
Not supported
Not supported
Not supported
Logfile
Supported
Not supported
Not supported
Not supported
User interface type
OAA
OAA configuration
Supported
Not supported
Not supported
Not supported
Supported
Not supported
Not supported
Not supported
Supported
Supported
Supported
Supported
WLAN
Hot AC backup
Supported
Supported
Supported
Supported
Feature Matrix for the WX3000 Series
The access controller engine and switching engine on the WX3000 series adopt the OAP architecture. The switching engine is integrated on the access controller engine as an OAP card. You actually log in to the access controller engine when you log in to the device by default. GE 1/0/1 interfaces on the WX3024, WX3010 and WX3008 are used to exchange data, status and control information with GE1/0/29 (WX3024), GE1/0/11 (WX3010) or GE1/0/9 (WX3008) on the switching engine. Therefore, you are not recommended to configure services such as QoS rate limiting and 802.1X authentication on these interfaces.
Table 2-3 Feature matrix for the WX3000 series
Volume
Module
Feature
WX3024
WX3010
WX3008
Login
Login configuration
AUX user interface
Supported
Supported
Supported
Not supported
Not supported
Not supported
VTY user interface
Supported
Supported
Supported
Telnet
Web-based NMS
Supported
Supported
Supported
NMS
Supported
Supported
Supported
Not supported
Not supported
Not supported
Access
Not supported
Not supported
Not supported
Not supported on GE1/0/1 of the access controller engine and GE1/0/29 on the switching engine
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Layer 2 forwarding
Not supported
Not supported
Not supported
STP
STP
Not supported
Not supported
Not supported
IP services
DNS configuration
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Displaying and maintaining an adjacency table
Supported
Supported
Supported
Not supported
Not supported
Not supported
IP routing
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
IP multicast
MLS snooping
Not supported
Not supported
Not supported
IPv6 multicast VLAN
Not supported
Not supported
Not supported
QoS
QoS
Not supported
Not supported
Not supported
Supported
Supported
Supported
Not supported
Not supported
Not supported
Security
AAA configuration
Not supported
Not supported
Not supported
Security
Supported
Supported
Supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
ACL configuration
IPv6 ACL
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
IPv6 SFTP client
Not supported
Not supported
Not supported
UDP/ TCP/ 802.
1X/ DHCP/ IGM
P/ NTP/ ARP/ LW
APP/ LooPback/
PPPoE/ IACTP/
ACSEI/ WAPI/ S
TP/ LWAPP_DA
TA/ Default
UDP/ TCP/ 802.
1X/ DHCP/ IGM
P/ NTP/ ARP/ LW
APP/ LooPback/
PPPoE/ IACTP/
ACSEI/ WAPI/ S
TP/ LWAPP_DA
TA/ Default
UDP/ TCP/ 802.
1X/ DHCP/ IGM
P/ NTP/ ARP/ LW
APP/ LooPback/
PPPoE/ IACTP/
ACSEI/ WAPI/ S
TP/ LWAPP_DA
TA/ Default
Supported
Supported
Supported
Supported
Supported
Supported
WAPI configuration
WAPI
Supported
Not supported
Not supported
System
Flash
Flash
Flash
License
24 APs at most by default, and can be extended to 48 APs.
12 APs at most by default, and can be extended to 24 APs.
Not supported
Supported
Supported
Supported
Logfile
Not supported
Not supported
Not supported
User interface type
OAA
OAA configuration
Supported
Supported
Supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
WLAN
Hot AC backup
Not supported
Not supported
Not supported
Command Matrix for the WX5000 Series
Table 3-1 Command matrix for the WX5000 series
Volume
Module
WX5002
WX5002V2
LS8M1WCMA0
WX5004
LSWM1WCM10
LSWM1WCM20
Login
Login commands
acl
Supported only by the VTY user interface
activation-key
Not supported by the VTY user interface
auto-execute command
databits
display user-interface
AUX and VTY user interfaces are supported.
When number is an absolute index, the value ranges from 0 to 5.
Console and VTY user interfaces are supported.
When number is an absolute index, the value ranges from 0 to 6.
free user-interface
parity
protocol inbound
send
speed
stopbits
undo shell
user-interface
Access
Ethernet interface commands
duplex
Supported
Supported
Supported
Supported
Not supported
Not supported
display loopback-detection
Supported
Supported
Supported
Supported
Supported
Not supported
flow-control
Supported
Supported
Supported
Supported
Not supported
Not supported
jumboframe enable
value ranges from 1600 to 9216 bytes and defaults to 1600 bytes.
value ranges from 1600 to 4096 bytes and defaults to 1600 bytes.
loopback
Supported
Supported
Supported
Supported
Only internal is supported.
loopback-detection control enable
Supported
Supported
Supported
Supported
Not supported
Not supported
loopback-detection enable
Supported
Supported
Supported
Supported
Not supported
Not supported
loopback-detection interval-time
Supported
Supported
Supported
Supported
Not supported
Not supported
shutdown
Supported
Supported
Supported
Supported
Not supported
Not supported
speed
Supported
Supported
Not supported
Supported
Not supported
Not supported
Link aggregation commands
All commands in the link aggregation commands manual
Supported
Supported
Not supported
Not supported
Not supported
Not supported
Port mirroring commands
All commands in the port mirroring commands manual
Supported
Supported
Not supported
Supported
Not supported
Not supported
PPP commands
pppoe-server max-sessions local-mac
number ranges from 1 to 2048.
number ranges from 1 to 4096.
pppoe-server max-sessions total
number ranges from 1 to 2048 and defaults to 1024.
number ranges from 1 to 4096 and defaults to 4096.
number ranges from 1 to 65535 and defaults to 4096.
VLAN commands
interface vlan-interface
The maximum value is 64.
The maximum value is 512.
WLAN interface commands
display interface wlan-ess
interface-number ranges from 0 to 127.
interface-number ranges from 0 to 1023.
interface wlan-ess
Layer 2 forwarding commands
All commands in the Layer 2 commands manual
Supported
Not supported
Supported
Supported
Not supported
Not supported
MSTP commands
All commands in the MSTP commands manual
Not supported
Supported
Not supported
Supported
Not supported
Not supported
IP services
ARP commands
arp max-learning-num
number ranges from 0 to 2048.
number ranges from 0 to 4096.
number ranges from 0 to 8192.
DNS commands
All commands in IPv6 DNS configuration commands
Supported
Supported
Supported
Supported
Supported
Supported
IP performance optimization commands
ip redirects enable
Supported
Not supported
Not supported
Not supported
Not supported
Not supported
ip ttl-expires enable
Supported
Not supported
Not supported
Not supported
Not supported
Not supported
ip unreachables enable
Supported
Not supported
Not supported
Not supported
Not supported
Not supported
IPv6 basics commands
All commands in IPv6 basics commands manual
Supported
Supported
Supported
Supported
Supported
Supported
ipv6 neighbors max-learning-num
number ranges from 1 to 256 and defaults to 256.
number ranges from 1 to 1024 and defaults to 1024.
IPv6 application commands
All commands in IPv6 application commands manual
Supported
Supported
Supported
Supported
Supported
Supported
Adjacency table commands
display adjacent-table
Not supported
Supported
Not supported
Supported
Supported
Supported
IP routing
IP routing basics commands
display ipv6 routing-table
Supported
Supported
Supported
Supported
Supported
Supported
display ipv6 routing-table ipv6-address
Supported
Supported
Supported
Supported
Supported
Supported
display ipv6 routing-table ipv6-address1 ipv6-address2
Supported
Supported
Supported
Supported
Supported
Supported
display ipv6 routing-table protocol
Supported
Supported
Supported
Supported
Supported
Supported
display ipv6 routing-table statistics
Supported
Supported
Supported
Supported
Supported
Supported
display ipv6 routing-table verbose
Supported
Supported
Supported
Supported
Supported
Supported
reset ipv6 routing-table statistics
Supported
Supported
Supported
Supported
Supported
Supported
IPv6 static routing commands
All commands in IPv6 static routing commands manual
Supported
Supported
Supported
Supported
Supported
Supported
IP multicast
Multicast VLAN commands
port multicast-vlan
Layer 2 aggregate interface view supported
Layer 2 aggregate interface view not supported
IGMP snooping commands
igmp-snooping fast-leave
igmp-snooping group-limit
igmp-snooping static-group
igmp-snooping static-router-port vlan
MLD snooping commands
Supported
Supported
Supported
Supported
Supported
Supported
IPv6 multicast VLAN commands
Supported
Supported
Supported
Supported
Supported
Supported
port multicast-vlan ipv6
QoS
QoS
car
pir peak-information-rate not supported
green action not supported
remark-lp-pass new-local-precedence not supported
display qos lr interface
Supported
Supported
Supported
Not supported
Supported
Supported
display qos map-table
dscp-lp not supported
Supported
Supported
Supported
Supported
if-match
Supported
classifier tcl-name not supported
inbound-interface interface-type interface-number not supported
local-precedence local-precedence-list not supported
rtp start-port start-port-number end-port end-port-number not supported
Supported
qos car
Not supported
Supported
Not supported
Supported
Supported
Supported
qos map-table
Supported
Supported
Supported
Supported
qos lr
Supported
[ ebs excess-burst-size ] not supported
Supported
Not supported
redirect
Not supported
Supported
Not supported
Supported
Supported
Supported
Congestion management configuration commands
Supported
Supported
Supported
Not supported
Supported
Supported
Security
802.1X commands
dot1x max-user
user-number ranges from 1 to 2048.
user-number ranges from 1 to 4096.
AAA commands
nas device-id device-id
Not supported
Supported
Not supported
Supported
Supported
Not supported
MAC authentication commands
mac-authentication max-user user-number
user-number ranges from 1 to 1024 and defaults to 1024.
user-number ranges from 1 to 4096 and defaults to 4096.
user-number ranges from 1 to 2048 and defaults to 2048.
Portal commands
ACL commands
portal server server-name method { direct | layer3 | redhcp }
layer3 not supported
layer3 supported
layer3 supported
layer3 supported
layer3 supported
portal backup-group group-id
Not supported
Supported
Not supported
Supported
Supported
Not supported
Not supported
Supported
Not supported
Supported
Supported
Not supported
radius nas-backup-ip ip-address
Not supported
Supported
Not supported
Supported
Supported
Not supported
radius scheme radius-scheme-name
Not supported
Supported
Not supported
Supported
Supported
Not supported
portal max-user max-number
max-number ranges from 1 to 2048.
max-number ranges from 1 to 4096.
acl ipv6
Supported
Supported
Supported
Supported
Supported
Supported
acl ipv6 copy
Supported
Supported
Supported
Supported
Supported
Supported
acl ipv6 name
Supported
Supported
Supported
Supported
Supported
Supported
description (for IPv6)
Supported
Supported
Supported
Supported
Supported
Supported
display acl ipv6
Supported
Supported
Supported
Supported
Supported
Supported
reset acl ipv6 counter
Supported
Supported
Supported
Supported
Supported
Supported
rule (basic IPv6 ACL view)
Supported
Supported
Supported
Supported
Supported
Supported
rule (advanced IPv6 ACL view)
Supported
Supported
Supported
Supported
Supported
Supported
rule comment (for IPv6)
Supported
Supported
Supported
Supported
Supported
Supported
step (for IPv6)
Supported
Supported
Supported
Supported
Supported
Supported
SSH2.0 commands
ssh client ipv6 source
Supported
Supported
Supported
Supported
Supported
Supported
ssh2 ipv6
Supported
Supported
Supported
Supported
Supported
Supported
sftp client ipv6 source
Supported
Supported
Supported
Supported
Supported
Supported
sftp ipv6
Supported
Supported
Supported
Supported
Supported
Supported
Security protection commands
anti-attack protocol enable
Not supported
Supported
Not supported
Supported
Supported
Supported
anti-attack protocol threshold
Not supported
Supported
Not supported
Supported
Supported
Supported
display anti-attack { 11mac | admin | all | arp | data | dhcp | dot1x | hwtacas | icmp | igmp | lwapp |  nd | ntp | pim | radius }
Supported
Not supported
Supported
Not supported
Not supported
Not supported
display anti-attack { protocol protocol | all }
Not supported
Supported
Not supported
Supported
Supported
Supported
WAPI commands
display wapi statistics
Not supported
Supported
Not supported
Supported
Supported
Supported
display wapi user
Not supported
Supported
Not supported
Supported
Supported
Supported
reset wapi statistics
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi authentication method
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi authentication mode
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi authentication-server ip
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi bk lifetime
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi bk rekey enable
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi certificate domain
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi certificate format
Not supported
Supported
Not supported
Supported
gbw not supported
gbw not supported
wapi mandatory-domain
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi msk-rekey client-offline enable
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi msk-rekey enable
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi msk-rekey method
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi psk { pass-phrase
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi usk lifetime
Not supported
Supported
Not supported
Supported
Supported
Supported
wapi usk rekey enable
Not supported
Supported
Not supported
Supported
Supported
Supported
System
Device management commands
display device
cf-card, usb, subslot subslot-number not supported
usb not supported
usb not supported
usb and subslot subslot-number not supported
display fan
fan-id takes the value of 1 or 2.
fan-id ranges from 1 to 5.
Not supported
Not supported
display power
power-id takes the value of 1 or 2.
Not supported
Not supported
display rps
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
license append
Supported
Supported
Supported
Supported
Supported
temperature-limit
By default, lower-value is 5, and upper-value is 60
By default, lower-value is 0, and upper-value is 90
Not supported
By default, lower-value is 0, and upper-value is 60
File system management configuration commands
configuration encrypt
Not supported
Not supported
Not supported
Not supported
Not supported
Supported
ftp ipv6
Supported
Supported
Supported
Supported
Supported
Supported
mount
Not supported
Not supported
Not supported
Supported
Not supported
Not supported
open ipv6
Not supported
Not supported
Not supported
Supported
Not supported
Not supported
tftp ipv6
Supported
Supported
Supported
Supported
Supported
Supported
umount
Not supported
Not supported
Not supported
Supported
Not supported
Not supported
System maintenance and debugging commands
ping ipv6
Supported
Supported
Supported
Supported
Supported
Supported
tracert ipv6
Supported
Supported
Supported
Supported
Supported
Supported
Basic system configuration commands
configure-user count
number ranges from 1 to 6.
number ranges from 1 to 7.
Information center commands
display logfile buffer
Not supported
Supported
Not supported
Supported
Supported
Not supported
display logfile summary
Not supported
Supported
Not supported
Supported
Supported
Not supported
info-center logfile enable
Not supported
Supported
Not supported
Supported
Supported
Not supported
info-center logfile frequency
Not supported
Supported
Not supported
Supported
Supported
Not supported
info-center logfile size-quota
Not supported
Supported
Not supported
Supported
Supported
Not supported
info-center logfile switch-directory
Not supported
Supported
Not supported
Supported
Supported
Not supported
logfile save
Not supported
Supported
Not supported
Supported
Supported
Not supported
MAC address table management commands
mac-address max-mac-count
count ranges from 0 to 4096.
count ranges from 0 to 8192.
Telnet configuration commands
telnet ipv6
Supported
Supported
Supported
Supported
Supported
Supported
OAA
OAA commands
mcms connect
Not supported
Not supported
Not supported
Not supported
Supported on the device side of the access controller module
mcms reboot
Not supported
Not supported
Not supported
Not supported
Supported
Supported
oap connect slot
Not supported
Supported
Not supported
Supported
Not supported
Not supported
oap management-ip
Not supported
Supported
Not supported
Supported
Not supported
Not supported
oap reboot slot
Not supported
Supported
Not supported
Supported
Not supported
Not supported
ACSEI server configuration commands
Not supported
Supported
Not supported
Supported
Not supported
Not supported
ACSEI client configuration commands
Not supported
Supported
Supported
Supported
Supported
Supported
WLAN
WLAN services commands
All commands for hot AC backup
Not supported
Supported
Not supported
Supported
Not supported
Supported
bind wlan-ess
interface-index ranges from 0 to 127.
interface-index ranges from 0 to 1023.
display wlan ap-group
group-id ranges from 1 to 128.
group-id ranges from 1 to 32.
group-id ranges from 1 to 64.
hot-backup hellointerval
Not supported
hellointerval ranges from 100 to 2000 milliseconds, and defaults to 100 milliseconds.
Not supported
Not supported
wlan ap-group
wlan permit-ap-group
wlan service-template
wapi not supported
Supported
wapi not supported
Supported
wapi not supported
Supported
WLAN roaming commands
display wlan client
Supported
Supported
Supported
Supported
Supported
Supported
display wlan mobility-group
Supported
Supported
Supported
Supported
Supported
Supported
member
Supported
Supported
Supported
Supported
Supported
Supported
mobility-tunnel
Supported
Supported
Supported
Supported
Supported
Supported
undo member
Supported
Supported
Supported
Supported
Supported
Supported
source
Supported
Supported
Supported
Supported
Supported
Supported
Command Matrix for the WX6000 Series
Table 3-2 Command matrix for the WX6000 series
Volume
Module
WX6103
LSQM1WCMB0
LSBM1WCM2A0
LSRM1WCM2A1
Login
Login commands
acl
activation-key
databits
AUX, console and VTY user interfaces are supported.
When number is an absolute index, the value ranges from 0 to 12.
free user-interface
parity
protocol inbound
send
speed
stopbits
undo shell
user-interface
Access
duplex
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
flow-control
Supported
Supported
Supported
Supported
jumboframe enable
loopback
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
shutdown
Supported
Supported
Supported
Supported
speed
Supported
Not supported
Supported
Not supported
All commands
Not supported
Not supported
Not supported
Not supported
All commands
Not supported
Not supported
Not supported
Not supported
PPP commands
number ranges from 1 to 20480.
VLAN commands
The maximum value is 1024.
interface wlan-ess
All commands
Not supported
Not supported
Not supported
Not supported
MSTP commands
All commands
Not supported
Not supported
Not supported
Not supported
IP services
ARP commands
number ranges from 0 to 24576.
DNS commands
All commands for IPv6 DNS configuration
Supported
Supported
Not supported
Supported
ip redirects enable
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
All commands
Supported
Supported
Not supported
Supported
All commands
Supported
Supported
Not supported
Supported
Supported
Supported
Supported
Supported
IP routing
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
All commands
Supported
Supported
Not supported
Supported
IP multicast
port multicast-vlan
Supported
Supported
Not supported
Not supported
Supported
Supported
Not supported
Not supported
QoS
QoS commands
car
Not supported
Not supported
Not supported
Not supported
Supported
Supported
Supported
Supported
if-match
qos car
Supported
Supported
Supported
Supported
qos lr
Not supported
Not supported
Not supported
Not supported
qos map-table
Supported
Supported
Supported
Supported
redirect
Supported
Supported
Supported
Supported
Not supported
Not supported
Not supported
Not supported
Security
802.1X commands
dot1x max-user
user-number ranges from 1 to 20480.
AAA commands
Supported
Supported
Supported
Supported
Portal commands
layer3 supported
layer3 supported
layer3 supported
layer3 supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
max-number ranges from 1 to 20480.
ACL commands
acl ipv6
Supported
Supported
Supported
Supported
acl ipv6 copy
Supported
Supported
Supported
Supported
acl ipv6 name
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
display acl ipv6
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
step (for IPv6)
Supported
Supported
Supported
Supported
SSH2.0 commands
Supported
Supported
Not supported
Supported
ssh2 ipv6
Supported
Supported
Not supported
Supported
Supported
Supported
Not supported
Supported
sftp ipv6
Supported
Supported
Not supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Not supported
Not supported
Not supported
Not supported
Supported
Supported
Supported
Supported
WAPI commands
Supported
Supported
Supported
Supported
display wapi user
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
wapi bk lifetime
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
gbw not supported
gbw not supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
wapi usk lifetim
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
System
display device
Supported
Supported
Supported
Supported
display fan
fan-id can only be 1.
display power
display rps
Not supported
Not supported
Not supported
Not supported
license append
Supported
Supported
Supported
Supported
temperature-limit
By default, lower-value is 0, and upper-value is 86
Not supported
Not supported
Not supported
Not supported
ftp ipv6
Supported
Supported
Not supported
Supported
mount
Supported
Supported
Supported
Supported
open ipv6
Supported
Supported
Supported
Supported
tftp ipv6
Supported
Supported
Not supported
Supported
umount
Supported
Supported
Supported
Supported
ping ipv6
Supported
Supported
Not supported
Supported
tracert ipv6
Supported
Supported
Not supported
Supported
number ranges from 1 to 13.
Supported
Not supported
Not supported
Not supported
Supported
Not supported
Not supported
Not supported
Supported
Not supported
Not supported
Not supported
Supported
Not supported
Not supported
Not supported
Supported
Not supported
Not supported
Not supported
Supported
Not supported
Not supported
Not supported
logfile save
Supported
Not supported
Not supported
Not supported
count ranges from 0 to 24576.
telnet ipv6
Supported
Supported
Not supported
Supported
OAA
OAA commands
mcms connect
Not supported
Not supported
Not supported
Not supported
mcms reboot
Not supported
Not supported
Not supported
Not supported
oap connect slot
Supported
Not supported
Not supported
Not supported
oap management-ip
Supported
Not supported
Not supported
Not supported
oap reboot slot
Supported
Not supported
Not supported
Not supported
Supported
Not supported
Not supported
Not supported
Supported
Supported
Supported
Supported
WLAN
WLAN service commands
Supported
Supported
Supported
Supported
bind wlan-ess
group-id ranges from 1 to 640.
hellointerval ranges from 30 to 2000 milliseconds, and defaults to 30 milliseconds.
wlan ap-group
Supported
Supported
Supported
Supported
display wlan client
Supported
Supported
member ipv6 ipv6-address not supported
Supported
Supported
Supported
Supported
member
Supported
Supported
Supported
mobility-tunnel
Supported
Supported
iactp6 not supported
Supported
undo member
Supported
Supported
undo member ipv6 ipv6-address not supported
Supported
source
Supported
Supported
Supported
Command Matrix for the WX3000 Series
Table 3-3 Command matrix for the WX3000 series
Volume
Module
WX3024
WX3010
WX3008
Login
Login commands
acl
activation-key
databits
free user-interface
parity
protocol inbound
send
speed
stopbits
undo shell
user-interface
Access
duplex
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
flow-control
Not supported
Not supported
Not supported
jumboframe enable
value ranges from 1600 to 4086 bytes and defaults to 1600 bytes.
loopback
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
shutdown
Not supported on GE1/0/1 of the access controller engine and GE1/0/11 on the switching engine
Not supported on GE1/0/1 of the access controller engine and GE1/0/9 on the switching engine
speed
Not supported
Not supported
Not supported
All commands
Not supported
Not supported
Not supported
All commands
Not supported
Not supported
Not supported
PPP commands
number ranges from 1 to 1024.
VLAN commands
The maximum value is 32.
interface-number ranges from 0 to 63.
interface wlan-ess
All commands
Not supported
Not supported
Not supported
MSTP commands
All commands
Not supported
Not supported
Not supported
IP services
ARP commands
DNS commands
Not supported
Not supported
Not supported
ip redirects enable
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
All commands
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
All commands
Not supported
Not supported
Not supported
Supported
Supported
Supported
IP routing
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
All commands
Not supported
Not supported
Not supported
IP multicast
port multicast-vlan
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
QoS
QoS commands
car
Supported
Supported
Supported
Not supported
Not supported
Not supported
if-match
IPv6 ACL not supported
qos car
Supported
Supported
Supported
qos lr
Not supported
Not supported
Not supported
qos map-table
Supported
Supported
Supported
redirect
Supported
Supported
Supported
Not supported
Not supported
Not supported
Security
802.1X commands
dot1x max-user
AAA commands
Not supported
Not supported
Not supported
Portal commands
layer3 supported
layer3 supported
layer3 supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
ACL commands
acl ipv6
Not supported
Not supported
Not supported
acl ipv6 copy
Not supported
Not supported
Not supported
acl ipv6 name
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
display acl ipv6
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
step (for IPv6)
Not supported
Not supported
Not supported
SSH2.0 commands
Not supported
Not supported
Not supported
ssh2 ipv6
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
sftp ipv6
Not supported
Not supported
Not supported
Supported
Supported
Supported
Supported
Supported
Supported
Not supported
Not supported
Not supported
Supported
Supported
Supported
WAPI commands
Supported
Not supported
Not supported
display wapi user
Supported
Not supported
Not supported
Supported
Not supported
Not supported
Supported
Not supported
Not supported
Supported
Not supported
Not supported
Supported
Not supported
Not supported
wapi bk lifetime
Supported
Not supported
Not supported
Supported
Not supported
Not supported
Supported
Not supported
Not supported
Supported
Not supported
Not supported
Supported
Not supported
Not supported
Supported
Not supported
Not supported
Supported
Not supported
Not supported
Supported
Not supported
Not supported
Supported
Not supported
Not supported
wapi usk lifetim
Supported
Not supported
Not supported
Supported
Not supported
Not supported
System
display device
cf-card and usb not supported
display fan
fan-id ranges from 1 to 3.
display power
power-id can only be 1.
display rps
Supported
Not supported
Not supported
license append
Supported
Supported
Supported
temperature-limit
By default, lower-value is 4, and upper-value is 79.
By default, lower-value is 0, and upper-value is 63.
Supported
Supported
Supported
ftp ipv6
Not supported
Not supported
Not supported
mount
Not supported
Not supported
Not supported
open ipv6
Not supported
Not supported
Not supported
tftp ipv6
Not supported
Not supported
Not supported
umount
Not supported
Not supported
Not supported
ping ipv6
Not supported
Not supported
Not supported
tracert ipv6
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
logfile save
Not supported
Not supported
Not supported
count ranges from 0 to 2048.
telnet ipv6
Not supported
Not supported
Not supported
OAA
OAA commands
mcms connect
Not supported
Not supported
Not supported
mcms reboot
Not supported
Not supported
Not supported
oap connect slot
Supported
Supported
Supported
oap management-ip
Supported
Supported
Supported
oap reboot slot
Supported
Supported
Supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
WLAN
Not supported
Not supported
Not supported
bind wlan-ess
interface-index ranges from 0 to 63.
group-id ranges from 1 to 12.
Not supported
Not supported
Not supported
wlan ap-group
wapi not supported
wlan service-template not supported
wapi not supported
display wlan client
member
mobility-tunnel
undo member
undo member ipv6 /ipv6-address not supported
source
