| 00-1Cover | 118.39 KB |
H |
User Manual |
Hangzhou H
Manual Version: 6W104-20100304 Product Version: R1111
( WX5002 / LS R2105 ( WX5004 / WX5002V2 / LSWM1WCM10 ) R3109 ( WX3000 series / LSWM1WCM20) R2113 ( WX6000 series ) |
Copyright © 2008-2010, Hangzhou
H
H
All Rights Reserved
No part of this manual may be reproduced or
transmitted in any form or by any means without prior written consent of
Hangzhou H
Trademarks
H
, Aolynk,
, H3Care,
TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
About This Manual
Organization
H
Conventions
The manual uses the following conventions:
Command conventions
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> |
The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
A line starting with the # sign is comments. |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
Means a complementary description. |
Related Documentation
In addition
to this manual, each H
Manual |
H |
Introduces the installation process, startup, hardware and software maintenance of WX5002 series access controllers. |
H |
Introduces the installation process, startup, hardware and software maintenance of a WX5002V2 access controller. |
H |
Introduces the installation process, startup, hardware and software maintenance of a WX5004 access controller. |
H |
Introduces the installation process, startup, hardware and software maintenance of a WX6103 access controller. |
H |
Introduces the installation process, startup, hardware and software maintenance of WX3024 and WX3010 unified switches. |
H |
Introduces installation process, startup,
hardware and software maintenance of an LS |
H |
hardware and software maintenance of an LSQM1WCMB0
access controller module used on the H |
H |
hardware and software maintenance of an LSBM1WCM |
H |
Introduces installation and removal
processes and upgrade of an LSRM1WCM |
H |
Introduces software and hardware features,
installation and removal processes, upgrade, and login of an LSWM1WCM20 card used on the H |
H |
Introduces
software and hardware features, installation and removal processes, upgrade,
and login of an LSWM1WCM10 card used on the
H |
H |
Provides a guide to the operation of H |
H |
Elaborates on the operation commands for
H |
H |
Provides a guide to the operation on WX3000 series unified switches switching engines. It covers configurations of CLI, login, VLAN, GVRP, basic port configurations, MAC address table management, MSTP, 802.1x, AAA, ACL, QoS, SNMP, RMON, NTP, and SSH. |
H |
Elaborates on the operation commands for WX3000 series unified switches switching engines. It covers the operation commands for CLI, login, VLAN, GVRP, basic port configurations, MAC address table management, MSTP, 802.1x, AAA, ACL, QoS, SNMP, RMON, NTP, and SSH. |
H |
Introduces the Web-based management function of the WX series access controllers. |
Obtaining Documentation and Technical Support
To obtain up-to-date documentation and
technical support, go to http://www.h
At http://www.h
Documentation
Go to the following columns for different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies, as well as solutions.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation, configuration, and maintenance.
[Technical Support & Document > Software Download]: Provides the documentation released with the software version.
Technical Support
customer_service@h
http://www.h
At http://www.h3cnetworks.com
Documentation
1) Select Drivers & Downloads in the Support area.
2) Select Documentation for Type of File and select Product Category.
Technical Support
Register Your Product
Warranty and other service benefits start from the date of purchase, so it is important to register your product quickly to ensure you get full use of the warranty and other service benefits available to you.
Warranty and other service benefits are enabled through product registration. Register your product at http://www.h3cnetworks.com, go to Support, Product Registration. Support services are based on accounts that you create or have authorization to access. First time users must apply for a user name and password that provides access to a number of eSupport features including Product Registration, Repair Services, and Service Request. If you have trouble registering your product, please contact 3Com Global Services for assistance.
Purchase Value-Added Services
To enhance response times or extend warranty benefits, contact 3Com or your authorized reseller. Value-added services like ExpressSM and GuardianSM can include 24x7 telephone technical support, software upgrades, onsite assistance or advance hardware replacement. Experienced engineers are available to manage your installation with minimal disruption to your network. Expert assessment and implementation services are offered to fill resource gaps and ensure the success of your networking projects. More information on 3Com maintenance and Professional Services is available at http://www.h3cnetworks.com.
Contact your authorized reseller or 3Com for a complete list of the value-added services available in your area.
Troubleshoot Online
You will find support tools posted on the
web site at http://www.h3cnetworks.com/ under Support, Knowledgebase.
The Knowledgebase helps you troubleshoot H
Access Software Downloads
Software Updates are the bug fix / maintenance releases for the version of software initially purchased with the product. In order to access these Software Updates you must first register your product on the web site at http://www.h3cnetworks.com, go to Support, Product Registration.
First time users will need to apply for a user name and password. A link to software downloads can be found at http://www.h3cnetworks.com, under Support, Drivers and downloads.
Software Upgrades are the software releases that follow the software version included with your original product. In order to access upgrades and related documentation you must first purchase a service contract from 3Com or your reseller.
Telephone Technical Support and Repair
To enable telephone support and other service benefits, you must first register your product at http://www.h3cnetworks.com/
When you contact 3Com for assistance, please have the following information ready:
l Product model name, part number, and serial number
l Proof of purchase, if you have not pre-registered your product
l A list of system hardware and software, including revision level
l Diagnostic error messages
l Details about recent configuration changes, if applicable
To send a product directly to 3Com for repair, you must first obtain a return authorization number (RMA). Products sent to 3Com, without authorization numbers clearly marked on the outside of the package, will be returned to the sender unopened, at the sender’s expense. If your product is registered and under warranty, you can obtain an RMA number online at http://www.h3cnetworks.com under support, Repair & Replacement Request. First time users will need to apply for a user name and password.
Contact Us
3Com offers telephone, e-mail and internet access to technical support and repair services. To access these services for your region, use the appropriate telephone number, URL or e-mail address.
Find a current directory of contact information posted on the web site at http://www.h3cnetworks.com under Support, Technical Support Contact.
Documentation Feedback
We appreciate your comments.
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
