H3C S7500E Series Ethernet Switches Operation Manual(Release 6100 series V1.01)
HomeSupportSwitchesH3C S7500E Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E Series Ethernet Switches Operation Manual(Release 6100 series V1.01)
Title Size Downloads
30-SSH Configuration.pdf 732.99 KB
30-SSH Configuration 732.99 KB
Table of Contents
Chapter 1 SSH Configuration. 1-1
1.1 SSH Overview. 1-1
1.1.1 Algorithm and Key. 1-1
1.1.2 Asymmetric Key Algorithm.. 1-2
1.1.3 SSH Operating Process. 1-2
1.2 Configuring the Device as an SSH Server 1-5
1.2.1 SSH Server Configuration Task List 1-5
1.2.2 Enabling SSH Server 1-6
1.2.3 Configuring the User Interfaces for SSH Clients. 1-6
1.2.4 Configuring RSA Keys. 1-7
1.2.5 Configuring a Client Public Key. 1-8
1.2.6 Configuring an SSH User 1-9
1.2.7 Setting the SSH Management Parameters. 1-10
1.3 Configuring the Device as an SSH Client 1-11
1.3.1 SSH Client Configuration Task List 1-11
1.3.2 Specifying a Source IP address/Interface for SSH Client 1-12
1.3.3 Configuring First-time Authentication. 1-12
1.3.4 Establishing a Connection Between SSH Client and Server 1-13
1.4 Displaying and Maintaining SSH. 1-14
1.5 SSH Server Configuration Examples. 1-15
1.5.1 When Using Password Authentication. 1-15
1.5.2 When Using Publickey Authentication. 1-17
1.6 SSH Client Configuration Examples. 1-23
1.6.1 When Using Password Authentication. 1-23
1.6.2 When Using Publickey Authentication. 1-26
Chapter 2 SFTP Service. 2-1
2.1 SFTP Overview. 2-1
2.2 Configuring an SFTP Server 2-1
2.2.1 Configuration Prerequisites. 2-1
2.2.2 Enabling the SFTP Server 2-1
2.2.3 Configuring the SFTP Connection Idle Timeout Period. 2-2
2.3 Configuring an SFTP Client 2-2
2.3.1 Specifying a Source IP Address/Interface for SFTP Client 2-2
2.3.2 Establishing a Connection to the SFTP Server 2-3
2.3.3 Working with the SFTP Directories. 2-3
2.3.4 Working with SFTP Files. 2-4
2.3.5 Displaying Help Information. 2-5
2.3.6 Terminating the Connection to the Remote SFTP Server 2-6
2.4 SFTP Configuration Example. 2-6
When configuring SSH, go to these sections for information you are interested in:
l           SSH Overview
l           Configuring the Device as an SSH Server
l           Configuring the Device as an SSH Client
l           Displaying and Maintaining SSH
l           SSH Server Configuration Examples
l           SSH Client Configuration Examples
1.1  SSH Overview
Secure Shell (SSH) offers an approach to securely logging into a remote device. By encryption and strong authentication, it protects devices against attacks such as IP spoofing and plain text password interception.
The device can not only work as an SSH server to support connections with SSH clients, but also work as an SSH client to allow users to establish SSH connections with a remote device acting as the SSH server.
&  Note:
Currently, when acting as an SSH server, the device supports two SSH versions: SSH2 and SSH1. When acting as an SSH client, the device supports SSH2 only.
Algorithm is a set of transformation rules for encryption and decryption. Information without being encrypted is known as plain text, while information that is encrypted is known as cipher text. Encryption and decryption are performed using a string of characters called a key, which controls the transformation between plain text and cipher text, for example, changing the plain text into cipher text or cipher text into plain text.
Figure 1-1 Encryption and decryption
Key-based algorithm is usually classified into symmetric key algorithm and asymmetric key algorithm.
Asymmetric key algorithm means that a key pair exists at both ends. The key pair consists of a private key and a public key. The public key is effective for both ends, while the private key is effective only for the local end.
Asymmetric key algorithm encrypts data using the public key and decrypts the data using the private key, thus ensuring data security.
You can also use the asymmetric key algorithm for digital signature. For example, user 1 adds his signature to the data using the private key, and then sends the data to user 2. User 2 verifies the signature using the public key of user 1. If the signature is correct, this means that the data originates from user 1.
The Revest-Shamir-Adleman Algorithm (RSA) is an asymmetric key algorithm. It can be used for data encryption and signature.
The session establishment between an SSH client and the SSH server involves the following five stages:
Table 1-1 Stages in establishing a session between the SSH client and the server
Stages
Version negotiation
SSH1 and SSH2 are supported. The two parties negotiate a version to use.
Key and algorithm negotiation
SSH supports multiple algorithms. The two parties negotiate an algorithm for communication.
Authentication
The SSH server authenticates the client in response to the client’s authentication request.
Session request
This client sends a session request to the server.
Interactive session
The client and the server start to communicate with each other.
I. Version negotiation
l           The server opens port 22 to listen to connection requests from clients.
l           The client sends a TCP connection request to the server. After the TCP connection is established, the server sends the first packet to the client, which includes a version identification string in the format of “SSH-<primary protocol version number>.<secondary protocol version number>-<software version number>”. The primary and secondary protocol version numbers constitute the protocol version number, while the software version number is used for debugging.
l           The client receives and resolves the packet. If the protocol version of the server is lower but supportable, the client uses the protocol version of the server; otherwise, the client uses its own protocol version.
l           The client sends to the server a packet that contains the number of the protocol version it decides to use. The server compares the version carried in the packet with that of its own to determine whether it can cooperate with the client.
l           If the negotiation is successful, the server and the client proceed with key and algorithm negotiation; otherwise, the server breaks the TCP connection.
&  Note:
All the packets involved in the above steps are transferred in plain text.
II. Key and algorithm negotiation
l           The server and the client send key algorithm negotiation packets to each other, which include the supported public key algorithm list, encryption algorithm list, MAC algorithm list, and compression algorithm list.
l           Based on the received algorithm negotiation packets, the server and the client figure out the algorithms to be used.
l           The server and the client use the DH key exchange algorithm and parameters such as the host key pair to generate the session key and session ID.
Through the above steps, the server and the client get the same session key, which is to be used to encrypt and decrypt data exchanged between the server and the client later. The server and the client use session ID in the authentication stage.
  Caution:
Before the negotiation, the RSA key pair must have been generated on the server. It will be used for generating the session key.
III. Authentication
l           The client sends to the server an authentication request, which includes the username, authentication method and information related to the authentication method (the password in the case of password authentication).
l           The server authenticates the client. If the authentication fails, the server informs the client by sending a message, which includes a list of available methods for re-authentication.
l           The client selects a method from the list to initiate another authentication.
l           The above process repeats until the authentication succeeds or the authentication times timeout and the session is torn down.
SSH provides two authentication methods: password authentication and publickey authentication.
In password authentication:
l           The client encrypts the username and password, encapsulates them into a password authentication request, and sends the request to the server.
l           Upon receiving the request, the server decrypts the username and password, compares them against those it maintains, and then informs the client of the authentication result.
In publickey authentication:
l           The server authenticates clients using digital signatures. Currently, the device uses RSA to implement digital signature. The client sends to the server a public authentication request containing its user name, public key and algorithm. The server validates the public key. If the public key is invalid, the authentication fails; otherwise, the server generates a digital signature to authenticate the client, and then sends back a message to inform the success or failure of the authentication.
&  Note:
Besides password authentication and publickey authentication, SSH2.0 provides another two authentication methods:
l      password-publickey: Performs both password authentication and publickey authentication of the client. A client running SSH1 client only needs to pass either type of the two, while a client running SSH2 client must pass both of them to login.
l      any: Performs either password authentication or publickey authentication. The client tries publickey authentication first.
IV. Session request
After passing authentication, the client sends a session request to the server, while the server listens to and processes the request from the client. If the client passes authentication, the server sends back to the client an SSH_SMSG_SUCCESS packet and goes on to the interactive session stage with the client. Otherwise, the server sends back to the client an SSH_SMSG_FAILURE packet, indicating that the processing fails or it cannot resolve the request.
V. Interactive session
In this stage, the server and the client exchanges data in this way:
l           The client encrypts and sends the command to be executed to the server.
l           The server decrypts and executes the command, and then encrypts and sends the result to the client.
l           The client decrypts and displays the result on the terminal.
&  Note:
l      During interactive session, the client can send the commands to be performed by pasting the text, which must be within 2000 bytes. It is recommended that the text pasted be commands in the same view; otherwise, the server may not be able to perform the commands.
l      If the text exceeds 2000 bytes, you can upload the configuration file to the server and use the configuration file to restart the server so that the server executes the commands.
Complete the following tasks to configure an SSH server:
Remarks
Enabling SSH Server
Required
Required
Creating the RSA key pair
Required
Exporting the RSA key pair
Optional
Destroying the RSA key pair
Optional
Required for publickey authentication users and optional for password authentication users
Optional
Optional
Follow these steps to enable SSH server:
To do…
Use the command…
Remarks
Enter system view
Enable the SSH server function
ssh server enable
Required
Disabled by default
An SSH client accesses the device through a VTY user interface. Therefore, you need to configure the user interfaces for SSH clients to allow SSH login. Note that the configuration takes effect at the next login.
Follow these steps to configure the protocols for the current user interface to support:
To do…
Use the command…
Remarks
Enter system view
Enter user interface view of one or more user interfaces
user-interface vty number [ ending-number ]
Required
Set the login authentication method to scheme
authentication-mode scheme [ command-authorization ]
Required
By default, the authentication mode is password.
Specify the protocols for the user interfaces to support
Optional
All protocols are supported by default.
  Caution:
l      For detailed information about the authentication-mode and protocol inbound commands, refer to Login Commands.
l      If you configure a user interface to support SSH, be sure to configure the corresponding authentication method with the authentication-mode scheme command.
l      For a user interface configured to support SSH, you cannot configure the authentication-mode password command and the authentication-mode none command.
I. Creating the RSA key pair
For successful SSH login, you must create the RSA key pair first.
Follow these steps to create an RSA key pair:
To do…
Use the command…
Remarks
Enter system view
Create the local RSA key pair
public-key local create rsa
Required
By default, there is no RSA key pair.
  Caution:
l      Configuration of the rsa local-key-pair create command can survive a reboot. You only need to configure it once.
l      The length of an RSA server/host key is in the range 512 to 2048 bits. With SSH2, however, some clients require that the keys generated by the server must not be less than 768 bits.
II. Exporting the RSA key pair
You can display or export the local RSA host key for setting the host key on the remote end.
Follow these steps to display or export an RSA host key:
To do…
Use the command…
Remarks
Enter system view
Display the local RSA host key on the screen in a specified format, or export it to a specified file
public-key local export rsa { openssh | ssh1 | ssh2  } [ filename ]
Required
III. Destroying the RSA key pair
Follow these steps to destroy an RSA key pair:
To do…
Use the command…
Remarks
Enter system view
Destroy the local RSA key pair
public-key local destroy rsa
Required
&  Note:
This configuration task is only necessary for SSH users using publickey authentication.
For an SSH user that uses publickey authentication to login, the server must be configured with the client RSA host public key in advance, and the corresponding private key for the client must be specified on the client.
You can manually configure or import the publickey public key from a public key file. In the former case, you can manually copy the client’s public key configuration to the server. In the latter case, the system automatically converts the public key to a string coded using the PKCS standard. Before importing the public key, you must upload the public key file (in binary) to the server through FTP or TFTP.
  Caution:
l      When the device functions as the SSH server, you cannot use Secure CRT 4.07 to upload the client public key to the server.
l      You can configure at most 20 client pubic keys on an SSH server.
I. Configuring a client public key manually
Follow these steps to configure the client public key manually:
To do…
Use the command…
Remarks
Enter system view
System-view
Enter public key view
public-key peer keyname
Enter public key code view
public-key-code begin
Configure a client public key
Enter the content of the public key
Required
The content must be a hexadecimal string that is generated randomly by the SSH-supported client software and coded compliant to PKCS. Spaces and carriage returns are allowed between characters.
Return from public key code view to public key view
public-key-code end
When you exit public key code view, the system automatically saves the public key.
Return from public key view to system view
peer-public-key end
II. Importing a client public key from a public key file
Follow these steps to import a public key from a public key file:
To do…
Use the command…
Remarks
Enter system view
Import the public key from a public key file
public-key peer keyname import sshkey filename
Required
This configuration allows you to create an SSH user and specify the service type and authentication method.
Follow these steps to configure an SSH user:
To do…
Use the command…
Remarks
Enter system view
Create an SSH user, and specify the service type and authentication method
For stelnet users
ssh user username service-type stelnet authentication-type { password | { any | password-publickey | publickey } assign publickey keyname }
Required
Use either command.
For all users or sftp users
ssh user username service-type { all | sftp } authentication-type { password | { any | password-publickey | publickey } assign publickey keyname work-directory directory-name }
  Caution:
l      After passing AAA authentication, an AAA user without SSH user account still can log on to the server using password authentication and Stelnet or SFTP service.
l      An SSH server supports up to 1024 SSH users.
l      The service type of an SSH user can be Stelnet or SFTP. stelnet, or the secure Telnet protocol, refers to the traditional SSH service. For information about stelnet, refer to SSH Overview. sftp represents the secure FTP protocol. For information about sftp, refer to SFTP Overview.
l      For successful login through SFTP, you must set the user service type to sftp or all.
l      You can set the service type of an SSH user to stelnet or all if the user does not need SFTP service.
l      As SSH1 does not support service type sftp, if the client uses SSH1 to log in to the server, you must set the service type to stelnet or all on the server. Otherwise, the client will fail to log in successfully.
l      The working folder of an SFTP user is subject to the user authentication method. For a user using only password authentication, the working folder is the AAA authorized one. For a user using only publickey authentication  or using both the publickey and password authentication methods, the working folder is the one set by using the ssh user command.
l      The configured authentication method takes effect when the user logs in next time.
&  Note:
For users using publickey authentication:
l      You must configure on the device the corresponding username and public keys.
l      After login, the commands available for a user are determined by the user privilege level, which is configured with the user privilege level command on the user interface. By default, the command privilege level is 0.
For users using password authentication:
l      You can configure the accounting information either on the device or on the remote authentication server (such as RADIUS authentication server).
l      After login, the commands available to a user are determined by AAA authorization.
SSH management includes:
l           Enabling the SSH server to be compatible with SSH1
l           Setting the server key pair update interval, applicable to users using SSH1 client.
l           Setting the SSH user authentication timeout period
l           Setting the maximum number of SSH authentication attempts
Setting the above parameters can help avoid malicious guess at and cracking of the keys and usernames, securing your SSH connections.
Follow these steps to set the SSH management parameters:
To do…
Use the command…
Remarks
Enter system view
Enable the SSH server to work with SSH1.x clients
ssh server compatible-ssh1x enable
Optional
By default, the SSH server can work with SSH1.x clients.
Set the RSA server key pair update interval
ssh server rekey-interval hours
Optional
0 by default, that is, the RSA server key pair is not updated.
Set the SSH user authentication timeout period
Optional
60 seconds by default
Set the maximum number of SSH authentication attempts
ssh server authentication-retries times
Optional
3 by default
&  Note:
Authentication will fail if the number of authentication attempts (including both publickey and password authentication) exceeds that specified in the ssh server authentication-retries command.
Complete the following tasks to configure an SSH client:
Remarks
Optional
Optional
Required
This configuration task allows you to specify a source IP address or interface for the client to access the SSH server, improving service manageability.
To do…
Use the command…
Remarks
Enter system view
Specify a source IP address or interface for the SSH client
Specify a source IPv4 address or interface for the SSH client
ssh client source { ip ip-address | interface interface-type interface-number }
Required
By default, the address of the interface decided by the routing is used to access the SSH server
Specify a source IPv6 address or interface for the SSH client
ssh client ipv6 source { ipv6 ipv6-address | interface interface-type interface-number }
When the device connects to the SSH server as an SSH client, you can configure whether the device supports first-time authentication.
l           With first-time authentication, when an SSH client not configured with the server host public key accesses the server for the first time, the user can continue accessing the server, and save the host public key on the client for use in subsequent authentications.
l           Without first-time authentication, a client not configured with the server host public key will be denied of access to the server. To access the server, a user must configure in advance the server host public key locally and specify the public key name for authentication.
I. Enable the device to support first-time authentication
Follow these steps to enable the device to support first-time authentication:
To do...
Use the command…
Remarks
Enter system view
ssh client first-time enable
Optional
By default, first-time authentication is supported on a client.
II. Disable first-time authentication
For successful authentication of an SSH client not supporting first-time authentication, the server host public key must be configured on the client and the public key name must be specified.
Follow these steps to disable first-time authentication:
To do...
Use the command…
Remarks
Enter system view
Disable first-time authentication support
undo ssh client first-time
Optional
Configure the server public key
Refer to 1.2.5  Configuring a Client Public Key
Required
The method of configuring server public key on the client is similar to that of configuring client public key on the server.
Specify the host public key name of the server
ssh client authentication server server assign publickey keyname
Required
Follow these steps to establish the connection between the SSH client and the server:
To do...
Use the command…
Remarks
Establish a connection between the SSH client and the server, and specify the preferred key exchange algorithm, encryption algorithms, and HMAC algorithms for them
Establish a connection between the SSH client and the IPv4 server, and specify the preferred key exchange algorithm, encryption algorithms, and HMAC algorithms for them
ssh2 server [ port-number ] [ prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
Required
Use either command in user view.
Establish a connection between the SSH client and the IPv6 server, and specify the preferred key exchange algorithm, encryption algorithms, and HMAC algorithms for them
ssh2 ipv6 server [ port-number ] [ prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
To do…
Use the command…
Remarks
Display information about the public keys of the local key pair
display public-key local rsa public
Available in any view
display public-key peer [ brief | name publickey-name ]
Display the source IP address or interface currently set for the SFTP client
display sftp client source
Display the source IP address or interface currently set for the SSH client
display ssh client source
Display the status information or session information of an SSH server
display ssh server { status | session }
Display the mappings between host public keys and SSH servers saved on a client
display ssh server-info
Display information about a specified or all SSH users on the SSH server
I. Network requirements
l           The host (SSH client) and the switch (SSH server) are directly connected through the Ethernet interfaces.
l           The host runs SSH client software to securely log on to the switch for configuration.
l           Password authentication is used.
II. Network diagram
Figure 1-2 SSH server configuration (using password authentication)
III. Configuration procedure
Configure the SSH server
# Generate an RSA key pair and enable SSH server.
<Switch> system-view
[Switch] public-key local create rsa
[Switch] ssh server enable
# Configure an IP address for VLAN-interface 1, which the SSH client will use as the destination for SSH connection.
[Switch] interface vlan-interface 1
[Switch-Vlan-interface1] ip address 192.168.1.40 255.255.255.0
[Switch-Vlan-interface1] quit
# Set the authentication mode for the user interface to AAA.
[Switch] user-interface vty 0 4
[Switch-ui-vty0-4] authentication-mode scheme
# Enable the user interface to support SSH.
[Switch-ui-vty0-4] protocol inbound ssh
[Switch-ui-vty0-4] quit
# Create local user “client001”, and set the user command privilege level to 3.
[Switch] local-user client001
[Switch-luser-client001] password simple aabbcc
[Switch-luser-client001] service-type ssh level 3
[Switch-luser-client001] quit
# Specify the service type for user client001 as Stelnet, and the authentication method as password.
[Switch] ssh user client001 service-type stelnet authentication-type password
Configure the SSH client
&  Note:
There are a variety of SSH client software, such as PuTTY, OpenSSH, and so on. The following is an example of configuring SSH client using PuTT v0.58.
# Establish a connection with the SSH server
Launch PuTTY.exe to enter the following interface. In the Host Name (or IP address) text box, enter the IP address of the server.
Figure 1-3 SSH client configuration interface
From the window shown in Figure 1-3, click Open. If the connection is normal, you will be prompted to enter the username client001 and password aabbcc. .
l           Publickey authentication is used, the algorithm is RSA.
II. Network diagram
Figure 1-4 SSH server configuration (using publickey authentication)
1)         Configure the SSH server
# Set the user command privilege level to 3.
[Switch-ui-vty0-4] user privilege level 3
&  Note:
Before performing the following tasks, you must generate an RSA key pair (using the client software) on the client, save the public key in a file named key.pub, and then upload the file to the SSH server through FTP or TFTP. For details, refer to Configuring the SSH Client.
# Import the client’s public key from file key.pub.
[Switch] public-key peer Switch001 import sshkey key.pub
# Specify the authentication type for user client002 as publickey, and assign the public key Switch001 for the user.
[Switch] ssh user client002 service-type stelnet authentication-type publickey assign publickey Switch001
2)         Configure the SSH client
# Generate an RSA key pair.
Run PuTTYGen.exe, choose SSH-2 RSA and click Generate.
Figure 1-5 Generate a client key pair (1)
While generating the key pair, you must move the mouse continuously and keep the mouse off the green process bar shown in Figure 1-6. Otherwise, the process bar stops moving and the key pair generating process is stopped.
Figure 1-6 Generate a client key pair (2)
After the key pair is generated, click Save public key to save the key in a file by entering a file name (key.pub in this case).
Figure 1-7 Generate a client key pair (3)
Likewise, to save the private key, click Save private key. A warning window pops up to prompt you whether to save the private key without any protection. Click Yes and enter the name of the file for saving the key (“private” in this case).
Figure 1-8 Generate a client key (4)
&  Note:
After generating a key pair on a client, you need to transmit the saved public key file to the server through FTP or TFTP and have the configuration on the server done before continuing configuration of the client.
# Specify the private key file and establish a connection with the SSH server
Launch PuTTY.exe to enter the following interface. In the Host Name (or IP address) text box, enter the IP address of the server (192.168.1.40).
Figure 1-9 SSH client configuration interface (1)
Select Connection/SSH/Auth. The following window appears. Click Browse… to bring up the file selection window, navigate to the private key file and click OK.
Figure 1-10 SSH client configuration interface (2)
From the window shown in Figure 1-10, click Open. If the connection is normal, you will be prompted to enter the username client002 to enter the configuration interface.
l           As shown in Figure 1-11, Switch A (the SSH client) needs to log on to Switch B (the SSH server) through the SSH protocol.
l           The username of the SSH client is client001 and the password is aabbcc. Password authentication is required.
II. Network diagram
Figure 1-11 SSH client configuration (using password authentication)
# Create an RSA key pair and enable the SSH server.
[SwitchB] public-key local create rsa
[SwitchB] ssh server enable
# Create an IP address for VLAN-interface 1, which the SSH client will use as the destination for SSH connection.
[SwitchB] interface vlan-interface 1
[SwitchB-Vlan-interface1] ip address 10.165.87.136 255.255.255.0
[SwitchB-Vlan-interface1] quit
[SwitchB] user-interface vty 0 4
[SwitchB-ui-vty0-4] authentication-mode scheme
[SwitchB-ui-vty0-4] protocol inbound ssh
[SwitchB-ui-vty0-4] quit
# Create local user client001.
[SwitchB] local-user client001
[SwitchB-luser-client001] password simple aabbcc
[SwitchB-luser-client001] service-type ssh level 3
[SwitchB-luser-client001] quit
[SwitchB] ssh user client001 service-type stelnet authentication-type password
# Configure an IP address for VLAN-interface 1.
[SwitchA-Vlan-interface1] ip address 10.165.87.137 255.255.255.0
# Disable first-time authentication.
[SwitchA] undo ssh client first-time
# Configure the host public key of the SSH server.
[SwitchA] public-key peer key1
[SwitchA-pkey-public-key] public-key-code begin
[SwitchA-pkey-key-code]308201B73082012C06072A8648CE3804013082011F0281810
0D757262C4584C44C211F18BD96E5F0
[SwitchA-pkey-key-code]61C4F0A423F7FE6B6B85B34CEF72CE14A0D3A5222FE08CECE
65BE6C265854889DC1EDBD13EC8B274
[SwitchA-pkey-key-code]DA9F75BA26CCB987723602787E922BA84421F22C3C89CB9B0
6FD60FE01941DDD77FE6B12893DA76E
[SwitchA-pkey-key-code]EBC1D128D97F0678D7722B5341C8506F358214B16A2FAC4B3
68950387811C7DA33021500C773218C
[SwitchA-pkey-key-code]737EC8EE993B4F2DED30F48EDACE915F0281810082269009E
14EC474BAF2932E69D3B1F18517AD95
[SwitchA-pkey-key-code]94184CCDFCEAE96EC4D5EF93133E84B47093C52B20CD35D02
492B3959EC6499625BC4FA5082E22C5
[SwitchA-pkey-key-code]B374E16DD00132CE71B020217091AC717B612391C76C1FB2E
88317C1BD8171D41ECB83E210C03CC9
[SwitchA-pkey-key-code]B32E810561C21621C73D6DAAC028F4B1585DA7F42519718CC
9B09EEF0381840002818000AF995917
[SwitchA-pkey-key-code]E1E570A3F6B1C2411948B3B4FFA256699B3BF871221CC9C5D
F257523777D033BEE77FC378145F2AD
[SwitchA-pkey-key-code]D716D7DB9FCABB4ADBF6FB4FDB0CA25C761B308EF53009F71
01F7C62621216D5A572C379A32AC290
[SwitchA-pkey-key-code]E55B394A217DA38B65B77F0185C8DB8095522D1EF044B465E
8716261214A5A3B493E866991113B2D
[SwitchA-pkey-key-code]485348
[SwitchA-pkey-key-code] public-key-code end
[SwitchA-pkey-public-key] peer-public-key end
# Specify the host public key for the SSH server (10.165.87.136) as key1.
[SwitchA] ssh client authentication server 10.165.87.136 assign publickey key1
[SwitchA] quit
# Establish an SSH connection to server 10.165.87.136.
<SwitchA> ssh2 10.165.87.136
Username: client001
Trying 10.165.87.136
Press CTRL+K to abort
Connected to 10.165.87.136...
Enter password:
* Copyright (c) 2004-2007 Hangzhou H3C Tech. Co., Ltd. All rights reserved.*
<SwitchB>
l           As shown in Figure 1-12, Switch A (the SSH client) needs to log on to Switch B (the SSH server) through SSH protocol.
l           Publickey authentication is used; the algorithm is RSA.
II. Network diagram
Figure 1-12 SSH client configuration (using publickey authentication)
[SwitchB-ui-vty0-4] user privilege level 3
&  Note:
# Import the remote public key from the file key.pub.
[SwitchB] public-key peer Switch001 import sshkey key.pub
[SwitchB] ssh user client002 service-type stelnet authentication-type publickey assign publickey Switch001
1)         Configure the SSH client
[SwitchA] public-key local create rsa
# Export the RSA public key to the file key.pub.
[SwitchA] public-key local export rsa ssh2 key.pub
[SwitchA] quit
&  Note:
# Establish an SSH connection to the server (10.165.87.136).
Username: client002
Trying 10.165.87.136 ...
Connected to 10.165.87.136 ...
The Server is not authenticated. Continue? [Y/N]:y
Do you want to save the server public key? [Y/N]:n
<SwitchB>
When configuring SFTP, go to these sections for information you are interested in:
l           SFTP Overview
l           Configuring an SFTP Server
l           Configuring an SFTP Client
l           SFTP Configuration Example
2.1  SFTP Overview
The secure file transfer protocol (SFTP) is a new feature in SSH 2.0.
SFTP uses the SSH connection to provide secure data transfer. The device can serve as the SFTP server, allowing a remote user to login to the SFTP server for secure file management and transfer. The device can also server as an SFTP client, enabling a user to login from the device to a remote device for secure file transfer.
l           You have configured the SSH server. For the detailed configuration procedure, refer to Configuring the Device as an SSH Server.
l           You have used the ssh user service-type command to set the service type of SSH users to sftp or all. For configuration procedure, refer to Configuring an SSH User.
This configuration task is to enable the SFTP service so that a client can login to the SFTP server through SFTP.
Follow these steps to enable the SFTP server:
To do…
Use the command…
Remarks
Enter system view
Enable the SFTP server
sftp server enable
Required
Disabled by default
&  Note:
When the device functions as the SFTP server, only one client can access the SFTP server at a time. If the SFTP client uses WinSCP, a file on the server cannot be modified directly; it can only be downloaded to a local place, modified, and then uploaded to the server.
Once the idle period of an SFTP connection exceeds the specified threshold, the system automatically tears the connection down, so that a user cannot occupy a connection for nothing.
Follow these steps to configure the SFTP connection idle timeout period:
To do…
Use the command…
Remarks
Enter system view
Configure the SFTP connection idle timeout period
Optional
10 minutes by default
You can configure a client to use only a specified source IP address or interface to access the SFTP server, thus enhancing the service manageability.
Follow these steps to specify a source IP address or interface for the SFTP client:
To do…
Use the command…
Remarks
Enter system view
Specify a source IP address or interface for the SFTP client
Specify a source IPv4 address or interface for the SFTP client
sftp client source { ip ip-address | interface interface-type interface-number }
Required
Use either command.
By default, an SFTP client uses the interface address specified by the route of the device to access the SFTP server.
Specify a source IPv6 address or interface for the SFTP client
sftp client ipv6 source { ipv6 ipv6-address | interface interface-type interface-number }
This configuration task is to enable the SFTP client to establish a connection with the remote SFTP server and enter SFTP client view.
Follow these steps to enable the SFTP client:
To do…
Use the command…
Remarks
Establish a connection to the remote SFTP server and enter SFTP client view
Establish a connection to the remote IPv4 SFTP server and enter SFTP client view
sftp server [ port-number ] [ prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
Required
Establish a connection to the remote IPv6 SFTP server and enter SFTP client view
sftp ipv6 server [ port-number ] [ prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
SFTP directory operations include:
l           Changing or displaying the current working directory
l           Displaying files under a specified directory or the directory information
l           Changing the name of a specified directory on the server
l           Creating or deleting a directory
Follow these steps to work with the SFTP directories:
To do…
Use the command…
Remarks
sftp [ ipv6 ] server [ port-number ] [ prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
Required
Execute the command in user view.
Change the working directory of the remote SFTP server
cd [ remote-path ]
Optional
Return to the upper-level directory
cdup
Optional
Display the current working directory of the remote SFTP server
pwd
Optional
Display files under a specified directory
Optional
The dir command functions as the ls command.
Change the name of a specified directory on the SFTP server
rename oldname newname
Optional
Create a new directory on the remote SFTP server
mkdir remote-path
Optional
Delete a directory from the SFTP server
rmdir remote-path&<1-10>
Optional
SFTP file operations include:
l           Changing the name of a file
l           Downloading a file
l           Uploading a file
l           Displaying a list of the files
l           Deleting a file
Follow these steps to work with SFTP files:
To do…
Use the command…
Remarks
Required
Change the name of a specified file on the SFTP server
rename old-name new-name
Optional
Download a file from the remote server and save it locally
Optional
Upload a local file to the remote SFTP server
Optional
Display the files under a specified directory
Optional
Delete a file from the SFTP server
delete remote-file&<1-10>
Optional
The delete command functions as the remove command.
remove remote-file&<1-10>
This configuration task is to display a list of all commands or the help information of an SFTP client command, such as the command format and parameters.
Follow these steps to display a list of all commands or the help information of an SFTP client command:
To do…
Use the command…
Remarks
Required
Display a list of all commands or the help information of an SFTP client command
help [ all | command-name ]
Required
Follow these steps to terminate the connection to the remote SFTP server:
To do…
Use the command…
Remarks
Required
Terminate the connection to the remote SFTP server and return to user view
bye
Required
Use any of the commands.
These three commands function in the same way.
exit
As shown in Figure 2-1, an SSH connection is established between Switch A and Switch B. Switch A, as an SFTP client, uses the username client001 and password aabbcc to login to Switch B for file management and file transfer.
II. Network diagram
Figure 2-1 Network diagram for SFTP configuration
Configure the SFTP server (Switch B)
# Configure an IP address for VLAN-interface 1, which the SSH client uses as the destination for SSH connection.
[SwitchB] interface Vlan-interface 1
[SwitchB-Vlan-interface1] ip address 192.168.0.1 255.255.255.0
# Set the authentication method on the user interface to AAA.
# Set the user interface to support SSH.
# Set the SSH authentication method to password, service type to SFTP.
[SwitchB] ssh user client001 service-type sftp authentication-type password
&  Note:
If you set the SSH authentication method to publickey, you need to configure the host public key of SwitchA. For the specific configuration, refer to When Using Publickey Authentication.
# Enable the SFTP server.
[SwitchB] sftp server enable
Configure the SFTP client (Switch A)
[SwitchA-Vlan-interface1] ip address 192.168.0.2 255.255.255.0
[SwitchA] quit
# Establish a connection to the remote SFTP server and enter SFTP client view.
<SwitchA> sftp 192.168.0.1
Input Username: client001
Trying 192.168.0.1 ...
Connected to 192.168.0.1 ...
Do you want to save the server public key? [Y/N]:y
Enter password:
sftp-client>
# Display files under the current directory of the server, delete the file named z, and check if the file is deleted successfully.
sftp-client> dir
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey1
drwxrwxrwx   1 noone    nogroup         0 Sep 01 06:22 new
-rwxrwxrwx   1 noone    nogroup       225 Sep 01 06:55 pub
-rwxrwxrwx   1 noone    nogroup         0 Sep 01 08:00 z
sftp-client> delete z
The following File will be deleted:
/z
Are you sure to delete it? [Y/N]:y
This operation may take a long time.Please wait...
File successfully Removed
sftp-client> dir
# Add a directory named new1 and check if it is created successfully.
sftp-client> mkdir new1
New directory created
sftp-client> dir
drwxrwxrwx   1 noone    nogroup         0 Sep 02 06:30 new1
# Rename directory new1 to new2 and check if the directory is renamed successfully.
sftp-client> rename new1 new2
File successfully renamed
sftp-client> dir
drwxrwxrwx   1 noone    nogroup         0 Sep 02 06:33 new2
# Download the file pubkey2 from the server and change the name to public.
sftp-client> get pubkey2 public
Remote  file:/pubkey2 --->  Local file: public
Downloading file successfully ended
# Upload the local file pu to the server, save it as puk, and check if the file is uploaded successfully.
sftp-client> put pu puk
Local file:pu --->  Remote file: /puk
Uploading file successfully ended
sftp-client> dir
-rwxrwxrwx   1 noone    nogroup       283 Sep 02 06:35 pub
-rwxrwxrwx   1 noone    nogroup       283 Sep 02 06:36 puk
sftp-client>
# Terminate the connection to the remote SFTP server.
sftp-client> quit
Bye
<SwitchA>
