H3C S9500 Operation Manual-Release1648[v1.24]-07 Security Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release1648[v1.24]-07 Security Volume
01-Protocol Port Security Configuration
01-Protocol Port Security Configuration 27.1 KB
Chapter 1  Protocol Port Security Configuration
When performing protocol port security configuration, go to these sections for information you are interested in:
l           Introduction to Protocol Port Security
l           Configuring Protocol Port Security
1.1  Introduction to Protocol Port Security
The protocol port security function is short for TCP, UDP protocol port shutdown check function. If a protocol is not enabled, this function can drop the packet on the interface board whose destination IP is the virtual interface IP of the switch, so that it reduces the unnecessary communications between the boards and the CPU operation of the SRPU, and enhances the anti-interference ability of the switch to the packet.
1.2  Configuring Protocol Port Security
1.2.1  Setting the State of Protocol Port
Perform the following configuration in system view to set the status of protocol ports:
Operation
Enable the protocol port security function
ip portsafe enable
Disable the protocol port security function
undo ip portsafe enable
By default, the protocol port security function is enabled.
Following table lists the protocols that can be checked.
Table 1-1 State of the protocol port
Protocol
Port
Default State
IGMP/IGSP
PROTOCOL:2
Close
OSPF
PROTOCOL:89
Close
PIM
PROTOCOL:123
Close
SSH
TCP:22
Close
TELNET
TCP:23
Close
HTTP
TCP:80
Open
BGP
TCP:179
Close
MPLS LDP
TCP:646
Close
DHCP
UDP:67,68
Close
NTP
UDP:123
Close
SNMP-AGENT
UDP:161
Close
RIP
UDP:520
Close
MPLS LDP
UDP:646
Close
RADIUS CLIENT
UDP:1812
Close
RADIUS LOCAL SERVER
UDP:1645,1646
Open
PORTAL SERVER
UDP:2000
Close
1.2.2  Setting the State of HTTP Protocol Port
Perform the following configurations in system view to set the status of HTTP protocol port:
Operation
Shutdown the port of HTTP protocol
ip http shutdown
Open the port of HTTP protocol
undo ip http shutdown
By default, the port 80 of HTTP protocol is enabled.
