H3C S9500 Command Manual-Release2132[V2.03]-07 Security Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-07 Security Volume
07-Portal Commands
07-Portal Commands 89.36 KB
Chapter 1  Portal Configuration Commands
1.1  Portal Configuration Commands
1.1.1  debugging portal
debugging portal { tcp | { acl | all | connection | server } interface interface-type interface-number }
undo debugging portal { tcp | { acl | all | connection | server } interface interface-type interface-number }
View
Default Level
1: Monitor level
tcp: Enables/disables debugging for portal TCP spoofing.
acl: Enables/disables debugging for portal ACLs.
all: Enables/disables debugging for portal connections, portal server, and portal ACLs.
connection: Enables/disables debugging for portal connections.
server: Enables/disables debugging for the portal server.
interface interface-type interface-number: Specifies the interface on which debugging is to be enabled. The S9500 series support only VLAN interfaces.
Use the debugging portal command to enable specific portal debugging.
Use the undo debugging portal command to disable specific portal debugging.
By default, portal debugging is disabled.
Table 1-1 Description on the fields of the debugging portal tcp command
Source
Source information tag
MAC
Source MAC address of the TCP connection
VLAN
VLAN of the source of the TCP connection
PortIndex
Port index of the source of the TCP connection
changed from STATUS_A to STATUS_B
Changed from STATUS_A to STATUS_B
Table 1-2 Description on the fields of the debugging portal acl command
Portal interface
Name of the interface with portal authentication enabled
Status
Portal operating state:
l      running: Port is running normally.
l      enable: Port is enabled.
l      disable: Portal is disabled.
Action
Types of matched ACL rules:
l      permit: Permits the packet is to pass.
l      redirect: Redirects the packet.
l      deny: Denies the packet.
NULL: No match is found.
Match rule
Matched ACL rule
Inbound interface
Bound interface
Static or dynamic ACL
Source
Source information of the matched ACL rule
IP
Source IP address of the matched ACL rule
Mask
Source mask of the matched ACL rule
Protocol
Protocol of the matched ACL rule
MAC
Source MAC address of the matched ACL rule
Source port of the matched ACL rule. If no Layer 2 interface is bound, the field is any for an interface with portal authentication enabled.
VLAN
Source VLAN ID of the matched ACL rule. This field is 0 for a routing interface with portal authentication enabled.
Destination
Destination information of the matched ACL rule
IP
Destination IP address of the matched ACL rule
Mask
Destination mask of the matched ACL rule
TCP Port
Destination port of the matched ACL rule
Context
Context sent by the driver module
Table 1-3 Description on the fields of the debugging portal connection command
Timer timer-name is started
The timer timer-name is started.
user index
User index
state
Current user state
IP
User IP address
Timer timer-name is stopped
The timer timer-name is stopped.
send message-name message to moduleA
The message message-name is sent to module A.
State stateA changing to stateB
User state changes from stateA to stateB
Recv portal message-name in state-name state
The message message-name is received in the state state-name.
[ACM]
Debugging information printed by the ACM module
Processing message-name
The message message-name is being processed.
recv 1 user index IP ip-address message-name from ACM
The message message-name is received from the ACM module, indicating the user with a user index of index and an IP address of ip-address is authenticated.
recv message-name from DRV
The message message-name is received from the driver.
Table 1-4 Description on the fields of the debugging portal server command
Portal socket receive packet length: packetlength
Length of the packet received through socket
Portal check packet OK
Checks whether the received packet is legal
Portal packet head
Portal packet header information
SN: serialNo
Packet serial number
Type: PacketType
Packet type
AttrNum: Number
Number of attributes of the packet
ErrCode: Number
Error code of the packet
UserIP: IP-Address
IP address of the access user
Portal packet attribute list
Attribute list of the packet
Portal raw packet
Packet format
Portal socket send packet length: packetlength
Length of the packet sent through socket
# Enable debugging for portal TCP spoofing on a device running portal.
<Sysname> debugging portal tcp
# Enable debugging for portal ACLs on a device running portal.
<Sysname> debugging portal acl interface Vlan-interface 100
# Enable debugging for portal connections, portal server, and portal ACLs on a device running portal.
<Sysname> debugging portal all interface Vlan-interface 100
# Enable debugging for portal connections on a device running portal.
<Sysname> debugging portal connection interface Vlan-interface 100
# Enable debugging for the portal server on a device running portal.
<Sysname> debugging portal server interface Vlan-interface 100
1.1.2  display portal acl
display portal acl { all | dynamic | static } interface interface-type interface-number
View
Default Level
1: Monitor level
all: Displays all access control lists (ACLs), including dynamic ACLs and static ACLs.
dynamic: Displays dynamic ACLs, namely, ACLs generated after a user passes portal authentication.
static: Displays static ACLs, namely, ACLs generated by related configurations.
interface interface-type interface-number: Displays the ACLs on the specified interface. Currently, only VLAN interfaces are supported.
Use the display portal acl command to display the ACLs on the specified interface.
# Display all ACLs on VLAN-interface 100.
<Sysname> display portal acl all interface Vlan-interface 100
Vlan-interface100 portal ACL rule:
 Rule 0
 Inbound interface = Vlan-interface100
 Type              = static
 Action            = permit
 Source:
    IP        = 10.10.10.0
    Mask      = 255.255.255.0
    MAC       = 0000-0000-0000
    Interface = any
    VLAN      = 100
 Destination:
    IP        = 192.168.0.111
    Mask      = 255.255.255.255
 Rule 1
 Inbound interface = all
 Type              = static
 Action            = permit
 Source:
    IP        = 10.10.10.0
    Interface = any
    VLAN      = 100
 Destination:
    IP        = 10.10.10.1
Table 1-5 Description on the fields of the display portal acl command
Rule
Sequence number of the generated ACL, which is numbered from 0 in ascending order
Inbound interface
Interface to which a portal ACL is bound
Type of a portal ACL
Action
Match action in a portal ACL
Source
Source information in a portal ACL
IP
Source IP address in a portal ACL
Mask
Subnet mask of the source IP address in a portal ACL
MAC
Source MAC address in a portal ACL
Source interface in a portal ACL
VLAN
Source VLAN in a portal ACL
Destination
Destination information in a portal ACL
IP
Destination IP address in a portal ACL
Mask
Subnet mask of the destination IP address in a portal ACL
1.1.3  display portal connection statistics
display portal connection statistics {all | interface interface-type interface-number }
View
Default Level
1: Monitor level
all: Displays portal connection statistics on all interfaces.
interface interface-type interface-number: Displays the portal connection statistics on the specified interface. Currently, only VLAN interfaces are supported.
Use the display portal connection statistics command to display the portal connection statistics on the specified interface or all interfaces.
# Display the portal connection statistics on Vlan-interface100.
<Sysname> display portal connection statistics interface Vlan-interface 100
 ---------------Interface: Vlan-interface100-----------------------
 User state statistics:
 State-Name                User-Num
 VOID                       0
 DISCOVERED                0
 WAIT_AUTHEN_ACK          0
 WAIT_AUTHOR_ACK          0
 WAIT_LOGIN_ACK           0
 WAIT_ACL_ACK              0
 WAIT_NEW_IP               0
 WAIT_USERIPCHANGE_ACK   0
 ONLINE                     1
 WAIT_LOGOUT_ACK          0
 WAIT_LEAVING_ACK         0
 Message statistics:
 Msg-Name                  Total         Err           Discard
 MSG_AUTHEN_ACK           3              0             0
 MSG_AUTHOR_ACK           3              0             0
 MSG_LOGIN_ACK            3              0             0
 MSG_LOGOUT_ACK           2              0             0
 MSG_LEAVING_ACK          0              0             0
 MSG_CUT_REQ               0              0             0
 MSG_AUTH_REQ              3              0             0
 MSG_LOGIN_REQ             3              0             0
 MSG_LOGOUT_REQ            2              0             0
 MSG_LEAVING_REQ           0              0             0
 MSG_ARPPKT                 0              0             0
 MSG_TMR_REQAUTH           1              0             0
 MSG_TMR_AUTHEN            0              0             0
 MSG_TMR_AUTHOR            0              0             0
 MSG_TMR_LOGIN             0              0             0
 MSG_TMR_LOGOUT            0              0             0
 MSG_TMR_LEAVING           0              0             0
 MSG_TMR_NEWIP             0              0             0
 MSG_TMR_USERIPCHANGE     0              0             0
 MSG_PORT_REMOVE           0              0             0
 MSG_VLAN_REMOVE           0              0             0
 MSG_IF_REMOVE             6              0             0
 MSG_L3IF_SHUT             0              0             0
 MSG_IP_REMOVE             0              0             0
 MSG_ALL_REMOVE            1              0             0
 MSG_IFIPADDR_CHANGE      0              0             0
 MSG_SOCKET_CHANGE        8              0             0.
Table 1-6 Description on the fields of the display portal connection statistics command
Statistics of portal users
State-Name
Name of a user state
User-Num
Number of users
VOID
Number of users in void state
DISCOVERED
Number of users in discovered state
WAIT_AUTHEN_ACK
Number of users in wait_authen_ack state
WAIT_AUTHOR_ACK
Number of users in wait_author_ack state
WAIT_LOGIN_ACK
Number of users in wait_login_ack state
WAIT_ACL_ACK
Number of users in wait_acl_ack state
WAIT_NEW_IP
Number of users in wait_new_ip state
Number of users wait_useripchange_ack state
ONLINE
Number of users in online state
WAIT_LOGOUT_ACK
Number of users in wait_logout_ack state
WAIT_LEAVING_ACK
Number of users in wait_leaving_ack state
Message statistics
Statistics of messages
Msg-Name
Name of a message
Total
Total number of messages
Err
Number of error messages
Discard
Number of discarded messages
MSG_AUTHEN_ACK
Authentication acknowledgment message
MSG_AUTHOR_ACK
Authorization acknowledgment message
MSG_LOGIN_ACK
Accounting acknowledgment message
MSG_LOGOUT_ACK
Accounting-stop acknowledgment message
MSG_LEAVING_ACK
Leaving acknowledgment message
MSG_CUT_REQ
Cut request message
MSG_AUTH_REQ
Authentication request message
MSG_LOGIN_REQ
Accounting request message
MSG_LOGOUT_REQ
Accounting-stop request message
MSG_LEAVING_REQ
Leaving request message
MSG_ARPPKT
ARP message
MSG_TMR_REQAUTH
Authentication request timeout message
MSG_TMR_AUTHEN
Authentication timeout message
MSG_TMR_AUTHOR
Authorization timeout message
MSG_TMR_LOGIN
Accounting-start timeout message
MSG_TMR_LOGOUT
Accounting-stop timeout message
MSG_TMR_LEAVING
Leaving timeout message
MSG_TMR_NEWIP
Public IP update timeout message
User IP change timeout message
MSG_PORT_REMOVE
Interface user removed message
MSG_VLAN_REMOVE
VLAN user removed message
MSG_IF_REMOVE
Interface remove message
MSG_L3IF_SHUT
Layer 3 interface shutdown message
MSG_IP_REMOVE
IP removed message
MSG_ALL_REMOVE
All users removed message
MSG_IFIPADDR_CHANGE
Interface IP address change message
MSG_SOCKET_CHANGE
Socket change message
1.1.4  display portal free-rule
display portal free-rule [ rule-number ]
View
Default Level
1: Monitor level
rule-number: Number of the authentication-free rule to be displayed.
Use the display portal free-rule command to display the information of a specified portal-authentication-free rule or all authentication-free rules.
If the rule-number argument is not specified, the information of all authentication-free rules will be displayed.
# Display the information of authentication-free rule 1.
<Sysname> display portal free-rule 1
 Rule-Number  1:
 Source:
   IP        = 2.2.2.0
   Interface = any
   Vlan      = 100
 Destination:
   IP        = 0.0.0.0
   Mask      = 0.0.0.0
Table 1-7 Description on the fields of the display portal free-rule command
Rule-Number
Number of an authentication-free rule
Source
Source information in an authentication-free rule
IP
Source IP address in an authentication-free rule
Mask
Subnet mask of the source IP address in an authentication-free rule
MAC
Source MAC address in an authentication-free rule
Source interface in an authentication-free rule
Vlan
Source VLAN in an authentication-free rule
Destination
Destination information in an authentication-free rule
IP
Destination IP address in an authentication-free rule
Mask
Subnet mask of the destination IP address in an authentication-free rule
1.1.5  display portal interface
display portal interface interface-type interface-number
View
Default Level
1: Monitor level
interface interface-type interface-number: Specifies an interface by interface type and interface number. Currently, only VLAN interfaces are supported.
Use the display portal interface command to display the portal configuration on the specified VLAN interface, including the referenced portal server, configured authentication mode, and configured service types.
# Display the portal configuration on VLAN-interface 100.
<Sysname> display portal interface Vlan-interface 100
 Interface portal configuration:
 Vlan-interface100: Portal running
 Portal server: servername
 Authentication type: Layer3
 Service type: Normal
 Authentication network:
 address = 0.0.0.0  mask = 0.0.0.0
Table 1-8 Description on the fields of the display portal interface command
Portal configuration on an interface
Vlan-interface100
Portal state on an interface
Portal server
Portal server applied to an interface
Authentication type
Authentication mode enabled on an interface
Service type
Type of service
Information of an portal authentication subnet
address
IP address of the portal authentication subnet
mask
Subnet mask of the IP address of the portal authentication subnet
1.1.6  display portal server
display portal server [ server-name ]
View
Default Level
1: Monitor level
server-name: Portal server name.
Use the display portal server command to display information about the specified portal server or all portal servers.
# Display the information of the portal server named aaa.
<Sysname> display portal server aaa
 Portal server:
  1)aaa:
    IP   = 192.168.0.111
    Key  = portal
    Port = 50100
URL  = http://192.168.0.111/portal
Table 1-9 Description on the fields of the display portal server command
1)
Number of the portal server
aaa
Name of the portal server
IP
IP address of the portal server
Key
Key for portal authentication
Port
Listening port on the portal server
URL
Address the packets are to be redirected to
1.1.7  display portal server statistics
display portal server statistics { all | interface interface-type interface-number }
View
Default Level
1: Monitor level
all: Displays portal server statistics on all interfaces.
interface interface-type interface-number: Displays portal server statistics on the specified interface. Currently, only VLAN interfaces are supported.
Use the display portal server statistics command to display portal server statistics on the specified interface or all interfaces, including the information of the packets from and to the portal server.
Note that when the all keyword is specified, the device will display the portal server statistics on each interface in turn, even if there is only one portal server.
# Display the portal server statistics on VLAN-interface 100.
<Sysname> display portal server statistics interface Vlan-interface 100
 Server name:  st
 Invalid packets: 0
 Pkt-Name                          Total   Discard  Checkerr
 REQ_CHALLENGE                       3        0        0
 ACK_CHALLENGE                       3        0        0
 REQ_AUTH                             3        0        0
 ACK_AUTH                             3        0        0
 REQ_LOGOUT                           1        0        0
 ACK_LOGOUT                           1        0        0
 AFF_ACK_AUTH                         3        0        0
 NTF_LOGOUT                           1        0        0
 REQ_INFO                              6        0        0
 ACK_INFO                              6        0        0
 NTF_USERDISCOVER                    0        0        0
 NTF_USERIPCHANGE                    0        0        0
 AFF_NTF_USERIPCHANGE               0         0        0
 ACK_NTF_LOGOUT                      1         0        0
Table 1-10 Description on the fields of the display portal server statistics command
Interface where the portal server resides on
Server name
Invalid packets
Number of invalid packets
Pkt-Name
Packet name
Total
Total number of packets
Discard
Number of discarded packets
Checkerr
Number of error packets
REQ_CHALLENGE
Challenge request message the portal server sends to the BAS
ACK_CHALLENGE
Challenge acknowledgment message the BAS sends to the portal server
REQ_AUTH
Authentication request message the portal server sends to the BAS
ACK_AUTH
Authentication acknowledgment message the BAS sends to the portal server
REQ_LOGOUT
Logout request message the portal server sends to the BAS
ACK_LOGOUT
Logout acknowledgment message the BAS sends to the portal server
AFF_ACK_AUTH
Affirmation message the portal server sends to the BAS after receiving an authentication success message
NTF_LOGOUT
Forced logout notification message the BAS sends to the portal server
REQ_INFO
Information request message
ACK_INFO
Information acknowledgment message
NTF_USERDISCOVER
User discovery notification message the portal server sends to the BAS
NTF_USERIPCHANGE
User IP change notification message the BAS sends to the portal server
User IP change success notification message the portal server sends to the BAS
ACK_NTF_LOGOUT
Forced logout acknowledgment message from the portal server
1.1.8  display portal tcp-cheat statistics
View
Default Level
1: Monitor level
None
Use the display portal tcp-cheat statistics command to display TCP spoofing statistics.
# Display all TCP spoofing statistics.
<Sysname> display portal tcp-cheat statistics
 TCP Cheat Statistic:
 Total Opens: 0
 Reset Connections: 0
 Current Opens: 0
 Packets Received: 0
 Packets Sent: 0
 Packets Retransmitted: 0
 Packets Dropped: 0
 HTTP Packets Sent: 0
 Connection State:
          SYN_RECVD: 0
          ESTABLISHED: 0
          CLOSE_WAIT: 0
          LAST_ACK: 0
          FIN_WAIT_1: 0
          FIN_WAIT_2: 0
          CLOSING: 0
Table 1-11 Description on fields of the display portal tcp-cheat statistics command
TCP Cheat Statistic
Total Opens
Total number of opened connections
Resets Connections
Number of the connections reset through RST packets
Current Opens
Number of active connections
Packets Received
Number of received packets
Packets Sent
Number of sent packets
Number of retransmitted packets
Packets Dropped
Number of dropped packets
HTTP Packets Sent
Number of sent HTTP packets
Connection State
State of a connection
ESTABLISHED
Number of connections in ESTABLISHED state
CLOSE_WAIT
Number of connections in CLOSE_WAIT state
LAST_ACK
Number of connections in LAST-ACK state
FIN_WAIT_1
Number of connections in FIN_WAIT_1 state
FIN_WAIT_2
Number of connections in FIN_WAIT_2 state
CLOSING
Number of connections in CLOSING state
1.1.9  display portal user
display portal user { all | interface interface-type interface-number }
View
Default Level
1: Monitor level
all: Displays user information on all interfaces with portal authentication enabled.
interface interface-type interface-number: Displays user information on the specified interface with portal enabled. Currently, only VLAN interfaces are supported.
Use the display portal user command to display the current user information on the specified interface or all interfaces with portal authentication enabled.
# Display user information on all interfaces with portal authentication enabled.
<Sysname> display portal user all
 Index:584
 State:ONLINE
 SubState:NONE
 MAC                IP                 Vlan   Interface
 0000-0000-0000   192.168.0.2      17      Vlan-interface17
 Total 1 user(s) matched, 1 listed.
Table 1-12 Description on the fields of the display portal user command
Index
Index of a portal user
Current state of a portal user
SubState
Current sub-state of a portal user
MAC
MAC address of a portal user
IP
IP address of a portal user
Vlan
VLAN where a portal user is
Interface to which a portal user is attached
Total number of portal users
&  Note:
The S9500 series support only Layer 3 portal authentication where portal user MAC address is not involved; therefore, all the entries the MAC column are displayed as 0000-0000-0000.
1.1.10  portal auth-network
portal auth-network network-address { mask-length | mask }
undo portal auth-network { network-address | all }
View
VLAN interface view
Default Level
2: System level
network-address: Authentication subnet address.
mask-length: Length of the subnet mask, in the range of 0 to 32.
mask: Subnet mask, in dotted decimal notation.
all: Specifies all authentication subnets.
Use the portal auth-network command to configure a portal authentication subnet.
Use the undo portal auth-network command to remove the configuration.
By default, the users in all the subnets are to be authenticated; that is, the portal authentication subnet is 0.0.0.0/0.
# Set the portal authentication subnet to 10.10.10.0/24.
[Sysname] interface Vlan-interface 100
[Sysname-Vlan-interface100] portal auth-network 10.10.10.0 24
1.1.11  portal delete-user
portal delete-user { ip-address | all | interface interface-type interface-number }
View
Default Level
2: System level
ip-address: IP address of a user.
all: Forces all users to log out.
Use the portal delete-user command to force the users attached to the access device to log out.
Related commands: display portal user.
# Force the user whose host IP address is 1.1.1.1 to log out.
[Sysname] portal delete-user 1.1.1.1
1.1.12  portal free-rule
portal free-rule rule-number { destination { any | ip { ip-address mask { mask-length | netmask } | any } } | source { any | [ interface interface-type interface-number | ip { ip-address mask { mask-length | netmask } | any } | vlan vlan-id ] * } } *
undo portal free-rule { rule-number | all }
View
Default Level
2: System level
rule-number: Number of an authentication-free rule, in the range of 0 to 31.
any: Specifies no limitation on the keyword which comes before the any keyword.
ip ip-address: Specifies an IP address in an authentication-free rule.
mask { mask-length | netmask }: Specifies the subnet mask of the IP address. The value of the mask-length argument is in the range 0 to 32, and the netmask argument is in dotted decimal notation.
interface interface-type interface-number: Specifies a source interface in an authentication-free rule. Currently, the S9500 series do not support this argument.
vlan vlan-id: Specifies a source VLAN ID in an authentication-free rule.
all: Specifies all authentication-free rules.
Use the portal free-rule command to configure a portal authentication-free rule, namely, to specify a source filtering condition or destination filtering condition.
Use the undo portal free-rule command to remove the authentication-free rule.
Note that there should be no repeated authentication-free rules. Otherwise, the device will prompt that the authentication-free rule already exists.
Related commands: display portal free-rule.
# Configure a portal authentication-free rule where the destination IP address is any address.
[Sysname] portal free-rule 15 source ip 10.10.10.0 mask 24 vlan 100 destination ip any
1.1.13  portal server
portal server server-name ip ip-address [ key key-string | port port-id | url url-string ] *
undo portal server server-name [ key | port | url ]
View
Default Level
2: System level
server-name: Name of the portal server, a case-sensitive string of 1 to 32 characters.
ip-address: IP address of the portal server.
key-string: Shared key required for communication with the portal server, a case-sensitive string of 1 to 16 characters.
port-id: Destination port ID used when the device sends a message to the portal server on its own, in the range 1 to 65534. The default is 50100.
url-string: Uniform resource locator (URL) to which HTTP packets are to be redirected, in the http://ip-address format. The default of ip-address is the IP address of the portal server.
Use the portal server command to configure a portal server.
Use the undo portal server command to delete the specified portal server or restore the default.
By default, no portal server is configured.
Note that if the specified portal server exists but there is no user on the interface, the specified portal server will be deleted if no parameter is specified when the undo portal server command is executed. Otherwise, the port and url parameters, if specified, will be restored to the default values.
Related commands: display portal server.
  Caution:
l      The parameters of a portal server are modifiable. If the portal feature is enabled on an interface, the portal server applied to the interface cannot be deleted. If there are users on this interface, the parameters of the portal server cannot be modified.
l      You must disable portal authentication on the interface before deleting the portal server applied to an interface in system view.
# Configure portal server pts, setting the IP address to 192.168.0.111, the key to portal, and the redirection URL to http://192.168.0.111/portal.
[Sysname] portal server servername ip 192.168.0.111 key portal url http://192.168.0.111/portal
1.1.14  portal server method
portal server server-name method layer3 [ service-type normal ]
undo portal
View
VLAN interface view
Default Level
2: System level
method: Authentication method.
layer3: Layer 3 authentication.
service-type: Specifies the type of service. The default service type is normal.
normal: Specifies normal portal server.
Use the portal server command to enable portal authentication on the interface, and specify the portal server to be referenced, authentication mode and service type.
Use the undo portal command to disable portal authentication on the interface.
By default, portal authentication is disabled.
Note that the specified portal server must exist.
# Enable portal authentication on VLAN-interface 100, setting the portal server to servername, the authentication mode to layer3, and the service type to normal.
[Sysname-Vlan-interface100] portal server servername method layer3 service-type normal
1.1.15  reset portal connection statistics
reset portal connection statistics { all | interface interface-type interface-number }
View
Default Level
1: Monitor level
all: Clears portal connection statistics on all interfaces.
interface interface-type interface-number: Clears the portal connection statistics on the specified interface. Currently, only VLAN interfaces are supported.
Use the reset portal connection statistics command to clear the portal connection statistics on the specified interface or all interfaces.
# Clear the portal connection statistics on VLAN-interface 100.
<Sysname> reset portal connection statistics interface Vlan-interface 100
1.1.16  reset portal server statistics
reset portal server statistics { all | interface interface-type interface-number }
View
Default Level
1: Monitor level
all: Clears the portal server statistics on all interfaces.
interface interface-type interface-number: Clears the portal server-related information on the specified interface. Currently, only VLAN interfaces are supported.
Use the reset portal server statistics command to clear the portal server statistics on the specified interface or all interfaces.
# Clear the portal server statistics on VLAN-interface 100.
<Sysname> reset portal server statistics interface Vlan-interface 100
1.1.17  reset portal tcp-cheat statistics
View
Default Level
1: Monitor level
None
Use the reset portal tcp-cheat statistics command to clear TCP spoofing statistics.
# Clear TCP spoofing statistics.
<Sysname> reset portal tcp-cheat statistics
