H3C S9500 Command Manual-Release2132[V2.03]-07 Security Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-07 Security Volume
06-SSH2.0 Commands
06-SSH2.0 Commands 186.1 KB
Table of Contents
Chapter 1 SSH2.0 Configuration Commands. 1-1
1.1 SSH2.0 Configuration Commands. 1-1
1.1.1 debugging ssh client 1-1
1.1.2 debugging ssh server 1-5
1.1.3 display rsa local-key-pair public. 1-13
1.1.4 display rsa peer-public-key. 1-15
1.1.5 display sftp client source. 1-16
1.1.6 display ssh client source. 1-17
1.1.7 display ssh server 1-18
1.1.8 display ssh server-info. 1-19
1.1.9 display ssh user-information. 1-20
1.1.10 peer-public-key end. 1-21
1.1.11 protocol inbound. 1-22
1.1.12 public-key-code begin. 1-23
1.1.13 public-key-code end. 1-23
1.1.14 rsa local-key-pair create. 1-24
1.1.15 rsa local-key-pair destroy. 1-25
1.1.16 rsa local-key-pair export 1-26
1.1.17 rsa peer-public-key. 1-27
1.1.18 rsa peer-public-key import sshkey. 1-28
1.1.19 sftp. 1-29
1.1.20 sftp client ipv6 source. 1-30
1.1.21 sftp client source. 1-31
1.1.22 sftp ipv6. 1-31
1.1.23 sftp server enable. 1-33
1.1.24 sftp server idle-timeout 1-33
1.1.25 ssh client authentication server 1-34
1.1.26 ssh client first-time enable. 1-35
1.1.27 ssh client ipv6 source. 1-36
1.1.28 ssh client source. 1-36
1.1.29 ssh server authentication-retries. 1-37
1.1.30 ssh server authentication-timeout 1-38
1.1.31 ssh server compatible-ssh1x enable. 1-39
1.1.32 ssh server enable. 1-39
1.1.33 ssh server rekey-interval 1-40
1.1.34 ssh user assign rsa-key. 1-41
1.1.35 ssh user authentication-type. 1-41
1.1.36 ssh user service-type. 1-43
1.1.37 ssh user work-directory. 1-44
1.1.38 ssh2. 1-45
1.1.39 ssh2 ipv6. 1-46
1.2 SFTP Configuration Commands. 1-47
1.2.1 bye. 1-47
1.2.2 cd. 1-48
1.2.3 cdup. 1-49
1.2.4 delete. 1-49
1.2.5 dir 1-50
1.2.6 exit 1-51
1.2.7 get 1-51
1.2.8 help. 1-52
1.2.9 ls. 1-53
1.2.10 mkdir 1-54
1.2.11 put 1-54
1.2.12 pwd. 1-55
1.2.13 quit 1-55
1.2.14 remove. 1-56
1.2.15 rename. 1-57
1.2.16 rmdir 1-57
debugging ssh client { all | error | event | message }
undo debugging ssh client { all | error | event | message }
View
Default Level
1: Monitor level
all: Enables all types of debugging.
error: Enables error debugging.
event: Enables event debugging.
message: Enables message debugging.
Use the debugging ssh client command to enable debugging for SSH clients and to debug a user interface separately.
Use the undo debugging ssh client command to disable debugging for SSH clients.
Be default, debugging is disabled for SSH clients.
Table 1-1 Description on the fields of the debugging ssh client event command
ProcessSession:
Session processing
InEncrypt:key-algorithm
Incoming encryption algorithm information
OutEncrypt: key-algorithm
Outgoing encryption algorithm information
InMac:mac-algorithm
Incoming MAC algorithm information
OutMac: mac-algorithm
Outgoing MAC algorithm information
KeyType:key-type
Key type
Process Kex Init:
Initialize algorithm negotiation
Connect Socket:
Socket connection
FSM from fsm1 to fsm2
The state of the state machines is changed from Connected to version negotiation.
Read Buffer
Read the buffer of the client
Client_SUB1_FSM from fsm1 to fsm2
On the client, the state of the Sub1 state machine is changed.
Table 1-2 Description on the fields of the debugging ssh client message command
STELC:
Stelnet client
Client Data Flow Control:
Flow control on the client
Send Disconnect:
Send the Disconnect information
Window Adjust:
The channel window on the client is adjusted.
AuthReq:
Send an authentication request
ServiceReq:
Service request
NewKey:
The client is in newkey state.
GEX Init:
Initialize the GEX algorithm
GEX Request:
GEX request
Send GEX Request:
Send a GEX request
Send GRP Init:
Send a GEX initialization message
SendKexInit:
Send a KEX initialization message
Client_SendVersionString:
The client sends a version character string.
SFTPC:
SFTP client
SFTPC CUSTOM CLOSED
Customer Closed message
Table 1-3 Description on the fields of the debugging ssh client error command
ProcessSession Error:
Session processing error
Error:
Error message
GEX Init Error:
An error occurs to initialization of the GEX algorithm.
GRP Init Error:
An error occurs to initialization of the GRP algorithm.
Process Kex Init Error:
Key exchange error
VersionString Received Error:
An error occurs to the received version string.
DoClose:
An error occurs when the file is closed.
Process RealPath Error:
An error occurs when a relative path is converted to an absolute path.
Connect Socket Error:
Error of Socket connection
# Enable event debugging on the SSH client. The IP address of the SSH client is 10.1.1.1. The user (username: client; password: aabbcc) logs into the SSH server with the IP address of 10.1.1.2 from the SSH client.
<Sysname> debugging ssh client event
[Sysname] ssh2 10.1.1.2
Username: client
Trying 10.1.1.2 ...
Press CTRL+K to abort
Connected to 10.1.1.2 ...
*Oct 12 09:21:00:252 2006 Sysname SSH/7/Client_EVENT: FSM from SSH_Main_Connect to SSH_Main_VersionMatch
// The client performs version negotiation with the server.
*Oct 12 09:21:00:254 2006 Sysname SSH/7/Client_EVENT: FSM from SSH_Main_Connect to SSH2_Main_KEX_Init
*Oct 12 09:21:00:478 2006 Sysname SSH/7/Client_EVENT: Read Buffer:
  Receive Packet(len=284).
// Receive a 284-byte packet.
*Oct 12 09:21:00:478 2006 Sysname SSH/7/Client_EVENT: Process Kex Init:
  InEncrypt:aes128-cbc, OutEncrypt:aes128-cbc
  InMac:hmac-sha1-96, OutMac:hmac-sha1-96
  KeyType:KEX_DH_GEX_SHA1
// Perform algorithm negotiation.
*Oct 12 09:21:00:479 2006 Sysname SSH/7/Client_EVENT: FSM from SSH2_Main_KEX_Init to SSH2_Main_KEX_GEX_Request
*Oct 12 09:21:00:889 2006 Sysname SSH/7/Client_EVENT: Read Buffer:
  Receive Packet(len=276).
*Oct 12 09:21:00:889 2006 Sysname SSH/7/Client_EVENT: FSM from SSH2_Main_KEX_GEX_Request to SSH2_Main_KEX_GEX_Init
// Negotiate about the GEX algorithm.
*Oct 12 09:21:01:441 2006 Sysname SSH/7/Client_EVENT: Read Buffer:
  Receive Packet(len=572).
*Oct 12 09:21:01:441 2006 Sysname SSH/7/Client_EVENT: FSM from SSH2_Main_KEX_GEX_Init to SSH2_Main_KEX_NewKey
// Update the key.
*Oct 12 09:21:01:539 2006 Sysname SSH/7/Client_EVENT: Read Buffer:
  Receive Packet(len=12).
*Oct 12 09:21:01:540 2006 Sysname SSH/7/Client_EVENT: FSM from SSH2_Main_KEX_NewKey to SSH2_Main_Authentication
// Authenticate the user.
*Oct 12 09:21:01:640 2006 Sysname SSH/7/Client_EVENT: Read Buffer:
  Receive Packet(len=28).
*Oct 12 09:21:01:641 2006 Sysname SSH/7/Client_EVENT: Client_SUB1_FSM from SSH2_Sub1_Service_Req to SSH2_Sub1_Auth_Req
Enter password:
// Prompt the user to enter a password.
*Oct 12 09:21:01:739 2006 Sysname SSH/7/Client_EVENT: Read Buffer:
*Oct 12 09:21:09:841 2006 Sysname SSH/7/Client_EVENT: Read Buffer:
*Oct 12 09:21:09:842 2006 Sysname SSH/7/Client_EVENT: Client_SUB1_FSM from SSH2_Sub1_Auth_Req to SSH2_Sub1_Service_Req
// Service request.
*Oct 12 09:21:09:843 2006 Sysname SSH/7/Client_EVENT: FSM from SSH2_Main_Authentication to SSH2_Main_Channel
// Channel request.
*Oct 12 09:21:09:941 2006 Sysname SSH/7/Client_EVENT: Read Buffer:
*Oct 12 09:21:09:942 2006 Sysname SSH/7/Client_EVENT: FSM from SSH2_Main_Channel to SSH2_Main_Pty
// Send a channel request of PTY type.
*Oct 12 09:21:10:42 2006 Sysname SSH/7/Client_EVENT: Read Buffer:
*Oct 12 09:21:10:42 2006 Sysname SSH/7/Client_EVENT: FSM from SSH2_Main_Pty to SSH2_Main_Shell
// Send a channel request of Shell type.
*Oct 12 09:21:10:141 2006 Sysname SSH/7/Client_EVENT: Read Buffer:
*Oct 12 09:21:10:142 2006 Sysname SSH/7/Client_EVENT: FSM from SSH2_Main_Shell to SSH2_Main_Session
Establish a session.
debugging ssh server { all | vty vty-num { all | error | event | message } }
undo debugging ssh server { all | vty vty-num { all | error | event | message } }
View
Default Level
1: Monitor level
all: Enables debugging for all SSH channels.
vty-num: SSH channel to be debugged. Its value depends on the number of VTY user view, and ranges from 0 to 4.
Use the debugging ssh server command to enable debugging for SSH servers and to debug a user interface separately.
Use the undo debugging ssh server command to disable debugging for SSH servers.
Be default, debugging is disabled for SSH servers.
Table 1-4 Description on the fields of the debugging ssh server vty error command
VTY[vty-num]
Current user interface
STELS Data Error:
Data resolution error
Read Buffer Error:
An error occurs when the buffer is read.
Read Buffer:
Read the buffer
CRC WRONG:
An error occurs during the CRC.
READ LENGTH WRONG:
An error occurs when the length is read.
Accept Error:
Accept error of the Socket
ProcessAuthentication Error:
Error of authentication
ProcessSub1Password Error:
Error of the password
ProcessSessionKey Error:
Error of the session key
Received unexpected packet:
Receive an unexpected packet
Session Key Store Error:
Error of key storage
Unsupported Cookie_type:
Unsupported cookie type
Unsupported Cipher_type:
Unsupported Cipher type
SSH1 VersionMatch Error:
Error of version match
Verify UserName Error:
Error of the username
Process RsaChallenge Error:
Error of RSA processing
Receive error msgtype:
Receive an erroneous message type
Process Auth Sign Error:
An error occurs to the digital signature authentication on the server.
Process AuthPK Error:
An error occurs to authentication of the public key on the server.
Process Password Error:
Error of the authenticated password
User Auth Init Error:
Fail to initialize the authentication on the server
Service Auth Error:
The request for ID authentication fails.
NewKey Error:
An error occurs to the processing of the newkey state machine on the server.
GEX_Reply Error:
An error occurs to the reply of the GEX public key.
GEX_Group Error:
An error occurs to the processing of the key exchange algorithm.
GRP Reply Error:
An error occurs to the reply of the GRP public key.
Server Key Init Error:
An error occurs to the initialization of algorithm negotiation.
Rename Error:
An error occurs when the file is renamed.
SFTPS Opendir:
An error occurs when the SFTP server opens a directory.
SFTPS Open Error:
An error occurs when the file is opened.
SFTPS Process Error:
An error occurs when the SFTP server processes a message.
Table 1-5 Description on the fields of the debugging ssh server vty event command
VTY[vty-num]
Accept:
Accept event of the Socket
Send Version To CLient:
Send version information to the client
Succeed to send version string: version-string
Send the version string successfully
Socket:soketid
ID of the current Socket
LineIndex:lineindex
Index to the current line resource
IP:ipaddress
IP address of the login user
FSM Change: From fsm1 to fsm2
The state of the state machine is changed.
Read:
Read event of the Socket
Read Buffer:
Read the buffer on the server
Receive Packet(len=length)
Receive a packet with the length specified by length
Server Key Init:
Initialize the server key on the server
InMac:mac-algorithm
KeyType:key-type
Key type
SUB1_FSM Change: From sub1_fsm1 to sub1_fsm2
The state of the Sub1 state machine is changed.
SUB2_Auth_FSM from sub2_fsm1 to sub2_fsm2
The state of the Sub2 state machine is changed.
UserAuthInit:
Initialize user authentication
Get user name:user-name!
Username of the client
Sub2Password:
Password authentication
User: user-name
Username
PasswordLen:length
Password length
LOGIN Succeed:
Successful login
LOGIN Failed:
Login failure
Channel Request:
Channel request on the client
Received channel request:request-type
Type of the received channel request message
STELS Start Shell:
Start the Shell
SFTPS_TaskQuit:
The SFTP task quits.
SFTPS Requeset SubSystem:
SFTP subsystem requests
Receive message:
Received message from the SFTP client
Successful to create task: Id=taskid
Create an SFTP task successfully
SFTP Server Init:
Initialize SFTP version negotiation
SFTPS Open:
Open the file
SFTPS Close:
Close the file
SFTPS Read:
Read the file
SFTPS Write:
Write data into the file
SFTPS Opendir:
Open the directory
Readdir:
Read the directory
SFTPS Remove:
Remove the file
SFTPS Mkdir:
Create a directory
SFTPS Rmdir:
Delete a directory
SFTPS RealPath:
Convert a relative path is into an absolute path
SFTPS Rename:
Rename the file
SFTPS SetStat:
Set file attributes
Window Adjust:
Adjust the sliding window
Verify UserName:
Verify the username
UserNameDazzle:
Dazzle the username
Session Key Store:
Store the session key
Table 1-6 Description on the fields of the debugging ssh server vty message command
VTY[vty-num]
Send Message:
Send a message to the client
SSH_VERSION_SEND from SocketID socketid
The server sends version information.
VersionReseived:
Receive the version of the client
Received VersionString[len=length]: version-string
Received version string and its length
SendKexInit:
Send the key negotiation information on the server
Read Buffer:
Received Message[Type=type-number]:message-type
Type of the received message
GEX_Group:
GEX key exchange algorithm
GEX Reply:
The server replies to the GEX key exchange algorithm.
Service Auth:
Authentication service
Authentication Failure:
Authentication failure
Authentication Success:
Authentication is successful.
Process Channel:
Process the channel message
STELS Request PTY:
PTY request from the Stelnet client
SSH Channel:
SSH channel message
STELS Start Shell:
Start the Shell
Process Session:
Process the session message
STELS Data:
Process the data message
SFTPS Trans:
Send a packet to the client
Data Flow Control:
Flow control on the SFTP server
SFTPS Send Data:
Send data
SFTPS Send Handle:
Send a handle message
SFTPS Send Status:
Send a status message
SFTPS Send Names:
Send a filename
SFTPS Send Attrs:
Send file attributes
Send Disconnect:
Send a Disconnect message
# Enable event debugging for the SSH server on the user interface VTY 1. The IP address of the SSH client is 10.1.1.1. The user (username: client; password: aabbcc) logs into the SSH server with the IP address of 10.1.1.2 from the SSH client.
<Sysname> debugging ssh server vty 1 event
*Oct 12 09:32:58:462 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Accept:
Socket:6 LineIndex:83,IP:10.1.1.1
// The user logs in from VTY 1, and creates a socket on the server.
*Oct 12 09:32:58:463 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Accept:
SSH user comes from 10.1.1.1, and current FSM is SSH_Main_Connect
// The user logs in from a client with the IP address of 10.1.1.1. A TCP connection has been established.
*Oct 12 09:32:58:463 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Send Version To CLient:
Successful to send version string: SSH-1.99-CMW-3.4
// Send version information to the client.
*Oct 12 09:32:58:464 2006 Sysname SSH/7/Server_EVENT: VTY[1]:FSM Change:
  From SSH_Main_Connect to SSH_Main_VersionMatch.
*Oct 12 09:32:58:467 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read:
  Process user [] from 10.1.1.1.
// Process user data from the IP address of 10.1.1.1.
*Oct 12 09:32:58:467 2006 Sysname SSH/7/Server_EVENT: VTY[1]:FSM Change:
  From SSH_Main_VersionMatch to SSH_Main_SSHProcess.
*Oct 12 09:32:58:564 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read:
*Oct 12 09:32:58:565 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read Buffer:
*Oct 12 09:32:58:566 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Server Key Init:
// Initialize the key on the server.
*Oct 12 09:32:58:566 2006 Sysname SSH/7/Server_EVENT: VTY[1]:SUB1_FSM Change:
  From SSH_Sub1_KEX_Init to SSH_Sub1_KEX_GEX_Group.
*Oct 12 09:32:58:943 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read:
*Oct 12 09:32:58:944 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read Buffer:
  Receive Packet(len=20).
*Oct 12 09:32:58:944 2006 Sysname SSH/7/Server_EVENT: VTY[1]:SUB1_FSM Change:
  From SSH_Sub1_KEX_GEX_Group to SSH_Sub1_KEX_GEX_Reply.
*Oct 12 09:32:58:955 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read:
*Oct 12 09:32:59:263 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read Buffer:
  Receive Packet(len=268).
*Oct 12 09:32:59:263 2006 Sysname SSH/7/Server_EVENT: VTY[1]:SUB1_FSM Change:
  From SSH_Sub1_KEX_GEX_Reply to SSH_Sub1_KEX_NewKey.
// Update the key.
*Oct 12 09:32:59:507 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read:
*Oct 12 09:32:59:508 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read Buffer:
*Oct 12 09:32:59:509 2006 Sysname SSH/7/Server_EVENT: VTY[1]:SUB1_FSM Change:
  From SSH_Sub1_KEX_NewKey to SSH_Sub1_Authentication.
*Oct 12 09:32:59:605 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read:
*Oct 12 09:32:59:606 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read Buffer:
*Oct 12 09:32:59:607 2006 Sysname SSH/7/Server_EVENT: VTY[1]:SUB2_Auth_FSM
  from SSH_Sub2_Service_Acc to SSH_Sub2_Auth_Init
// Initialize user authentication.
*Oct 12 09:32:59:707 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read:
*Oct 12 09:32:59:707 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read Buffer:
  Receive Packet(len=44).
*Oct 12 09:32:59:708 2006 Sysname SSH/7/Server_EVENT: VTY[1]:UserAuthInit:
  Get user name: client!
// The login user is named "client”.
*Oct 12 09:32:59:709 2006 Sysname SSH/7/Server_EVENT: VTY[1]:UserAuthInit:
  Current AuthType is SSH_AUTH_PASSWORD
// The authentication mode is "password”.
*Oct 12 09:33:01:585 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read:
  Process user [client] from 10.1.1.1.
*Oct 12 09:33:01:585 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read Buffer:
  Receive Packet(len=60).
*Oct 12 09:33:01:586 2006 Sysname SSH/7/Server_EVENT: VTY[1]:UserAuthInit:
*Oct 12 09:33:01:587 2006 Sysname SSH/7/Server_EVENT: VTY[1]:SUB2_Auth_FSM
  from SSH_Sub2_Auth_Init to SSH_Sub2_Auth_Password
*Oct 12 09:33:01:587 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Sub2Password:
  User:client  PasswordLen: 6
// The password of the "client“ user is 6 in length.
*Oct 12 09:33:01:613 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Sub2Password: SSH user client succeeded to login from 10.1.1.1 on VTY1.
*Oct 12 09:33:01:614 2006 Sysname SSH/7/Server_EVENT: VTY[1]:LOGIN Succeed:
   SSH user client succeeded to login from 10.1.1.1(000f-e200-0001) on VTY1.
// Succeed in authenticating the “client” user.
*Oct 12 09:33:01:615 2006 Sysname SSH/7/Server_EVENT: VTY[1]:SUB2_Auth_FSM
  from SSH_Sub2_Auth_Password to SSH_Sub2_Auth_Init
// The Sub2 state machine returns to the authentication initialization state.
*Oct 12 09:33:01:615 2006 Sysname SSH/7/Server_EVENT: VTY[1]:SUB1_FSM Change:
  From SSH_Sub1_Authentication to SSH_Sub1_Channel.
// Channel request.
*Oct 12 09:33:01:696 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read:
*Oct 12 09:33:01:697 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read Buffer:
*Oct 12 09:33:01:697 2006 Sysname SSH/7/Server_EVENT: VTY[1]:SUB1_FSM Change:
  From SSH_Sub1_Channel to SSH_Sub1_Session.
// Establish a session.
*Oct 12 09:33:01:796 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read:
*Oct 12 09:33:01:797 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read Buffer:
*Oct 12 09:33:01:797 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Channel Request:
  Received channel request: pty-req
// Receive a channel request of pty-req type.
*Oct 12 09:33:01:798 2006 Sysname SSH/7/Server_EVENT: VTY[1]:STELS Requeset PTY:
  Successful to send SSH2_MSG_CHANNEL_SUCCESS(99) from 10.1.1.2 to 10.1.1.1
// Send an SSH2_MSG_CHANNEL_SUCCESS message successfully.
*Oct 12 09:33:01:897 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read:
*Oct 12 09:33:01:898 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Read Buffer:
*Oct 12 09:33:01:898 2006 Sysname SSH/7/Server_EVENT: VTY[1]:Channel Request:
  Received channel request: shell
// Receive a channel request of shell type.
*Oct 12 09:33:01:899 2006 Sysname SSH/7/Server_EVENT: VTY[1]:STELS Start Shell:
  Send SSH2_MSG_CHANNEL_SUCCESS(99) from 10.1.1.2 to 10.1.1.1
%Oct 12 09:33:02:01 2006 Sysname SHELL/4/LOGIN: client login from 10.1.1.1
// The “client” user logs into the server from a client with the IP address of 10.1.1.1.
View
Default Level
1: Monitor level
None
Use the display rsa local-key-pair public command to display the public key information of the host key pair on the server and of server key pair. If no key is generated, the system prompts that no key is found.
Related commands: rsa local-key-pair create.
# Display the public key information of the host key pair on the server and of the server key pair.
<Sysname> display rsa local-key-pair public
Time of Key pair created: 13:41:21  2004/11/12
Key name: Sysname_Host
Key type: RSA encryption Key
Key code:
3047
  0240
    C30B0C1E 1AC2A028 984B7801 9583105D 78E69F6C
    62561976 95E3B92B 7D9EC59C 150AE9CC 92E7CEF7
    F025D3E0 C15408F5 4C9F4945 308A2DCF 1BA59D60
    53DB5825
  0203
    010001
Time of Key pair created: 13:41:25  2004/11/12
Key name: Sysname_Server
Key code:
3067
  0260
    E0DC0229 0525E04D AE3B8998 C56A18A1 997A609B
    043B9302 F843715B FC727A3D 4A503B32 333DFD46
    D95F4BD7 5AF63BBF 99100F9E EEAE4B3E DC6FBE42
    1757F88D 1F7A098F 2C3FFFDF 8E2DA17D 991111ED
    C318E857 6D40D224 4114AD15 A42068B9
  0203
    010001
Table 1-7 Description on the fields of the display rsa local-key-pair public command
Time when the key pair is created
Key name
Key name
Key type
Key type, for example, RSA encryption Key
Key code
Key data
display rsa peer-public-key [ brief | name keyname ]
View
Default Level
1: Monitor level
brief: Displays brief information about all remote public keys.
name keyname: Specifies a key by its name, a string of 1 to 64 characters.
Use the display rsa peer-public-key command to displays remote RSA public keys.
If no parameters are specified, the system displays detailed information about all public keys.
# Display detailed information about all public keys.
<Sysname> display rsa peer-public-key
    Key name: aa
    Key address:
Key Code:
308186
  028180
    6B494EC4 EBD23DEE 1375C2B5 AB892F69 F2529D09 5B559E26 26011A1F C58AA5E3
    60258B01 26494D0E 7221BB98 1C844CCD 8F0F8AEA 4AA1CD5B 9C3C5EF5 3093319F
    6F3AEA80 351E5E8D 29F1511C D4AC08B4 3FDF5B7B E30A4E47 6FF75B9A 63BE5E94
    E9C344B7 F0EC9D53 AE54E0A3 0567184A 2E80BEC3 89A2DAFA 83C18591 5B29EAA1
  0201
    25
Table 1-8 Description on the fields of the display rsa peer-public-key command
Key name
Key name
Key address
Key address
Key code
Key data
# Display brief information about all remote public keys.
<Sysname>display rsa peer-public-key brief
Address         Bits   Name
                1023   aaa
Table 1-9 Description on the fields of the display rsa peer-public-key brief command
Address
Remote address
Bits
Number of bits of the remote public key
Name
Name of the remote public key
View
Default Level
1: Monitor level
None
Use the display sftp client source command to display the source IP address or source interface currently set for the SFTP client.
If neither source IP address nor source interface is specified for the SFTP client, you will be notified of the fact.
Related commands: sftp client source.
# Display the source IP address of the SFTP client.
<Sysname> display sftp client source
The source IP address you specified is 192.168.0.1
View
Default Level
1: Monitor level
None
Use the display ssh client source command to display the source IP address or source interface currently set for the SSH client.
If neither source IP address nor source interface is specified for the SSH client, you will be notified of the fact.
Related commands: ssh client source.
# Display the source IP address of the SSH client.
<Sysname> display ssh client source
View
Default Level
1: Monitor level
session: Displays the session information of the SSH server.
status: Displays the status information of the SSH server.
Use the display ssh server command on an SSH server to display SSH server status information or session information.
Related commands: ssh server authentication-retries, ssh server rekey-interval, ssh server authentication-timeout, ssh server enable, and ssh server compatible-ssh1x enable.
# Display the SSH server status information.
<Sysname> display ssh server status
 SSH Server: Disable
 SSH version : 1.99
 SSH authentication-timeout : 60 second(s)
 SSH server key generating interval : 0 hour(s)
 SSH Authentication retries : 3 time(s)
 SFTP Server: Disable
 SFTP Server Idle-Timeout: 10 minute(s)
Table 1-10 Description on fields of the display ssh server status command
SSH Server
Whether the SSH server function is enabled
SSH version
SSH protocol version
Authentication timeout period
SSH server key pair update interval
Maximum number of SSH authentication attempts
SFTP Server
Whether the SFTP server function is enabled
SFTP connection idle timeout period
# Display the SSH server session information.
<Sysname> display ssh server session
 Conn   Ver   Encry    State         Retry    SerType  Username
 VTY 0  2.0   3DES      Established   0        SFTP     client001
Table 1-11 Description on fields of the display ssh server session command
Conn
VTY interface used by the user
Ver
SSH server protocol version
Encry
Encryption algorithm used by SSH
Status of the session, including: Init, Ver-exchange, Keys-exchange, Auth-request, Serv-request, Established, Disconnected
Retry
Number of authentication attempts
SerType
Service type (SFTP, Stelnet)
Username
Name of a user during login
View
Default Level
1: Monitor level
None
Use the display ssh server-info command on a client to display mappings between SSH servers and their host public keys saved on the client.
When an SSH client needs to authenticate the SSH server, it uses the locally saved public key of the server for the authentication. If the authentication fails, you can use this command to check the public key of the server saved on the client.
Related commands: ssh client authentication server.
# Display the mappings between host public keys and SSH servers saved on the client.
<Sysname> display ssh server-info
Server Name(IP)                 Server public key name
______________________________________________________
192.168.0.1                      abc_key01
192.168.0.2                      abc_key02
Table 1-12 Descriptions on fields of the display ssh server-info command
Server Name(IP)
Name or IP address of the server
Name of the host public key of the server
View
Default Level
1: Monitor level
username: SSH username, a string of 1 to 80 characters.
Use the display ssh user-information command on an SSH server to display information about a specified or all SSH users.
With the username argument not specified, the command displays information about all users.
Related commands: ssh user assign rsa-key, ssh user authentication-type, ssh user service-type.
# Display information about all SSH users.
<Sysname> display ssh user-information
 Total ssh users : 2
 Username            Authentication-type  User-public-key-name  Service-type
 yemx                 password               putty                    stelnet|sftp
 test              rsa                  null                   sftp
Table 1-13 Description on fields of the display ssh user-information command
Username
Name of the user
Authentication-type
Authentication type
Public key of the user
Service-type
Service type
peer-public-key end
View
Public key view
Default Level
2: System level
None
Use the peer-public-key end command to return from public key view to system view.
Related commands: rsa peer-public-key.
# Exit public key view.
[Sysname] rsa peer-public-key Sysname003
[Sysname-rsa-public-key] peer-public-key end
[Sysname]
View
VTY user interface view
Default Level
2: System level
all: Supports all of the three protocols: Telnet and SSH.
ssh: Supports SSH only.
telnet: Supports Telnet only.
Use the protocol inbound command to enable the current user interface to support Telnet, and SSH.
By default, a user interface supports all of the three protocols: Telnet, PAD, and SSH.
The configuration of this command takes effect at next login.
If you configure the current user interface to support SSH, be sure to configure the authentication-mode scheme command.
Related commands: user-interface vty in User Interface Commands of System Volume.
&  Note:
This command is not supported in Console user interface view or AUX user interface view.
# Enable VTYs 0 to 4 to support SSH only.
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] authentication-mode scheme
[Sysname-ui-vty0-4] protocol inbound ssh
View
Public key view
Default Level
2: System level
None
Use the public-key-code begin command to enter RSA key code view.
After entering public key code view, you can input the key data. It must be a hexadecimal string that has not been converted and in the distinguished encoding rules (DER) encoding format. Spaces and carriage returns are allowed between characters.
Related commands: rsa peer-public-key, public-key-code end.
# Enter public key code view to input the key.
[Sysname-rsa-public-key] public-key-code begin
[Sysname-rsa-key-code] 30818602 818078C4 32AD7864 BB0137AA 516284BB 3F55F0E3
[Sysname-rsa-key-code] F6DD9FC2 4A570215 68D2B3F7 5188A1C3 2B2D40BE D47A08FA
[Sysname-rsa-key-code] CF41AF4E 8CCC2ED0 C5F9D1C5 22FC0625 BA54BCB3 D1CBB500
[Sysname-rsa-key-code] A177E917 642BE3B5 C683B0EB 1EC041F0 08EF60B7 8B6ED628
[Sysname-rsa-key-code] 9830ED46 0BA21FDB F55E7C81 5D1A2045 54BFC853 5358E5CF
[Sysname-rsa-key-code] 7D7DDF25 03C44C00 E2F49539 5C4B0201 25
public-key-code end
View
RSA key code view
Default Level
2: System level
None
Use the public-key-code end command to return from public key code view to public key view.
The system verifies the key before saving it. If the key contains illegal characters, the system displays an error message, indicating that an illegal character is entered, and discards the key.
Related commands: rsa peer-public-key, public-key-code begin.
# Exit RSA key code view.
[Sysname-rsa-key-code] public-key-code end
View
Default Level
2: System level
None
Use the rsa local-key-pair create command to generate RSA host key pairs and server key pairs.
Note that:
l           After you enter this command, the system prompts you to enter the number of bits of the key pair. For a host key pair and server key pair, the minimum length is 512 bits, and the maximum length is 2,048 bits. If a key pair already exists, you need to decide whether to modify it.
l           You only need to execute this command once. You do not need to execute it again after the device is restarted.
Related commands: rsa local-key-pair destroy and display rsa local-key-pair public.
# Generate a host key pair and server key pair.
[Sysname] rsa local-key-pair create
NOTES: If the key modulus is greater than 512,
       It will take a few minutes.
Input the bits in the modulus[default = 1024]:
Generating keys...
Done!
View
Default Level
2: System level
None
Use the rsa local-key-pair destroy command to destroy RSA host key pairs and server key pairs.
After entering this command, you need to decide whether to destroy RSA host key pairs and server key pairs.
# Destroy an RSA host key pair and server key pair.
[Sysname] rsa local-key-pair destroy
The local-key-pair will be destroyed.
Confirm to destroy these keys? [Y/N]:y
..........Done!
rsa local-key-pair export { ssh1 | ssh2 | openssh } [ filename ]
View
Default Level
2: System level
ssh1: An RSA host public key is in the format of “SSH1”.
ssh2: An RSA host public key is in the format of “SSH2”.
openssh: An RSA host public key is in the format of “OpenSSH”.
filename: Name of the exported RSA host public key file. If a host public key filename is denoted in the format of “filename”, filename is a string of 1 to 91 characters. If a host public key filename is denoted in the format of “directory + filename”, filename is a string of 1 to 136 characters (the filename consists of a maximum of 91 characters).
Use the rsa local-key-pair export command to display RSA host public keys in the screen in a specified format or to export RSA host public keys to a specified file.
If no filename is specified, the system displays RSA host public keys in the screen. Otherwise, the system exports and saves RSA host public keys to the specified file.
SSH1, SSH2 and OpenSSH indicate three different types of public key file formats.
Related commands: rsa local-key-pair create and rsa local-key-pair destroy.
# Export RSA host public keys in the format of “OpenSSH”.
<Sysname> rsa local-key-pair export OpenSSH myOpenSSH
The file of public key is successfully generated.
# Display RSA host public keys in the format of “SSH2”.
<Sysname> rsa local-key-pair export SSH2
Host public key for SSH2 format code:
---- BEGIN SSH2 PUBLIC KEY ----
AAAAB3NzaC1yc2EAAAADAQABAAAAgQCusCaLG/BIkVdFQT7pND+ETtHZGnOclMuK
9zxdbzcjcAdWIZY4Hwu/AOGbn7Sj2NJZNeqUzFrYNeOjD1cGqO5NkgLvy+2lAUSW
+L9usdsIk67fiF63Msu3i9HcqyA0mUuToNjQUZoltU1kbqFK7zE1CCZAt7+55rWk
SqcCGqFBsw==
---- END SSH2 PUBLIC KEY ----
[Sysname]
# Display RSA host public keys in the format of “OpenSSH”.
Public key code for pasting into OpenSSH authorized_keys file :
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQCusCaLG/BIkVdFQT7pND+ETtHZGnOclMuK9zxdbzcj
cAdWIZY4Hwu/AOGbn7Sj2NJZNeqUzFrYNeOjD1cGqO5NkgLvy+2lAUSW+L9usdsIk67fiF63Msu3i9HcqyA0mUuToNjQUZoltU1kbqFK7zE1CCZAt7+55rWkSqcCGqFBsw== rsa-key
rsa peer-public-key keyname
undo rsa peer-public-key keyname
View
Default Level
2: System level
keyname: Name of a public key, a string of 1 to 64 characters.
Use the rsa peer-public-key command to enter public key view.
Use the undo rsa peer public-key command to delete the configured remote public keys.
In public key view, you can configure remote public keys using the public-key-code begin and public-key-code end commands together. You need to first obtain the remotely generated hexadecimal public keys.
Related commands: public-key-code begin and public-key-code end.
# Enter public key view (the public key is named “abc123”).
[Sysname] rsa peer-public-key abc123
[Sysname-pkeyrsa-public-key]
rsa peer-public-key keyname import sshkey filename
View
Default Level
2: System level
filename: Name of a public key file, a string of 1 to 136 characters.
Use the rsa peer-public-key import sshkey command to import remote public keys from a public key file.
After you execute this command, the system automatically converts the generated public key files (support SSH1, SSH2, and OpenSSH formats) into PKCS codes, and configures remote public keys. The remote public key file of the RSA key must be FTPed/TFTPed to the local device in advance.
# Import the remote public key named “abc456” from the public file “pub2”.
[Sysname] rsa peer-public-key abc456 import sshkey pub2
1.1.19  sftp
sftp { host-ip | host-name } [ port-number ] [ prefer_ctos_cipher { 3des | aes128 | des } | prefer_ctos_hmac { md5 | md5_96 | sha1 | sha1_96 } | prefer_kex { dh_exchange_group | dh_group1 } | prefer_stoc_cipher { 3des | aes128 | des } | prefer_stoc_hmac { md5 | md5_96 | sha1 | sha1_96 } ] *
View
Default Level
3: Manage level
host-ip: IPv4 address of the server.
host-name: Server name, a string of 1 to 20 characters.
port-number: Port number of the server, in the range 0 to 65535. The default is 22.
prefer_ctos_cipher: Preferred encryption algorithm from client to server, defaulted to aes128.
l           3des: Encryption algorithm 3des_cbc.
l           aes128: Encryption algorithm aes128_cbc.
l           des: Encryption algorithm des_cbc.
prefer_ctos_hmac: Preferred HMAC algorithm from client to server, defaulted to sha1.
l           md5: HMAC algorithm hmac-md5.
l           md5_96: HMAC algorithm hmac-md5-96.
l           sha1: HMAC algorithm hmac-sha1.
l           sha1_96: HMAC algorithm hmac-sha1-96.
prefer_kex: Preferred key exchange algorithm, defaulted to dh_group1.
l           dh_exchange_group: Key exchange algorithm diffie-hellman-group-exchange-sha1.
l           dh_group1: Key exchange algorithm diffie-hellman-group1-sha1.
prefer_stoc_cipher: Preferred algorithm from server to client, defaulted to aes128.
prefer_stoc_hmac: Preferred HMAC algorithm from server to client, defaulted to sha1.
Use the sftp command to establish a connection to a remote IPv4 SFTP server and enter SFTP client view.
# Connect to SFTP server 10.1.1.2.
[Sysname] sftp 10.1.1.2
Input Username:
sftp client ipv6 source { ipv6 ipv6-address | interface interface-type interface-number }
undo sftp client ipv6 source
View
Default Level
3: Manage level
ipv6 ipv6-address: Specifies a source IPv6 address.
interface interface-type interface-number: Specifies a source interface by its type and number.
Use the sftp client ipv6 source command to specify the source IPv6 address or source interface for an SFTP client.
Use the undo sftp client ipv6 source command to remove the configuration.
By default, the client uses the interface address specified by the route of the device to access the SFTP server.
If the specified interface does not exist, the system prompts failure.
Related commands: display sftp client source.
# Specify the source IPv6 address of the SFTP client as 2:2::2:2.
[Sysname] sftp client ipv6 source ipv6 2:2::2:2
sftp client source { ip ip-address | interface interface-type interface-number }
undo sftp client source
View
Default Level
3: Manage level
ip ip-address: Specifies a source IPv4 address.
Use the sftp client source command to specify the source IPv4 address or interface of an SFTP client.
Use the undo sftp source-interface command to remove the configuration.
By default, a client uses the IP address or interface specified by the route to access the SFTP server.
# Specify the source IP address of the SFTP client as 192.168.0.1.
[Sysname] sftp client source ip 192.168.0.1
1.1.22  sftp ipv6
sftp ipv6 { ipv6-address | host-name } [ port-number ] [ prefer_ctos_cipher { 3des | aes128 | des } | prefer_ctos_hmac { md5 | md5_96 | sha1 | sha1_96 } | prefer_kex { dh_exchange_group | dh_group1 } | prefer_stoc_cipher { 3des | aes128 | des } | prefer_stoc_hmac { md5 | md5_96 | sha1 | sha1_96 } ] *
View
Default Level
3: Manage level
ipv6-address: IPv6 address of the server.
host-name: Server name, a string of 1 to 46 characters.
prefer_stoc_cipher: Preferred encryption algorithm from server to client, defaulted to aes128.
Use the sftp ipv6 command to establish a connection to a remote IPv6 SFTP server and enter SFTP client view.
# Connect to server 2:5::8:9.
[Sysname] sftp ipv6 2:5::8:9
Input Username:
sftp server enable
undo sftp server enable
View
Default Level
2: System level
None
Use the sftp server enable command to enable SFTP server.
Use the undo sftp server enable command to disable SFTP server.
By default, SFTP server is disabled.
Related commands: display ssh server.
# Enable SFTP server.
[Sysname] sftp server enable
undo sftp server idle-timeout
View
Default Level
2: System level
time-out-value: Timeout period in minutes. It ranges from 1 to 35,791.
Use the sftp server idle-timeout command to set the idle timeout period for SFTP user connections.
Use the undo sftp server idle-timeout command to restore the default.
By default, the idle timeout period is 10 minutes.
# Set the idle timeout period for SFTP user connections to 500 minutes.
[Sysname] sftp server idle-timeout 500
ssh client authentication server { server-ip | server-name } assign rsa-key keyname
undo ssh client authentication server { server-ip | server-name } assign rsa-key
View
Default Level
2: System level
server-ip: IP address of the server, a string of 1 to 80 characters.
server-name: Server name, a string of 1 to 64 characters.
keyname: Name of the host public key on the server.
Use the ssh client authentication server command to configure the host public key of the server so that the client can determine whether the server is trustworthy.
Use the undo ssh authentication server command to remove the configuration.
By default, the host public key of the server is not configured, and when logging into the server, the client uses the IP address or host name used for login as the public key name.
# Configure the public key of the server with the IP address of 192.168.0.1 to be abc.
[Sysname] ssh client authentication server 192.168.0.1 assign rsa-key abc
undo ssh client first-time
View
Default Level
2: System level
None
Use the ssh client first-time enable command to enable the first authentication function.
Use the undo ssh client first-time command to disable the function.
By default, the function is enabled.
When an SSH client tries to access a server whose public host key it does not know for the first time, the first authentication function enables it to access the server and obtain and save the public host key of the server. When the client accesses the server later, it can use the locally saved public host key of the server to authenticate the server.
With the first authentication function disabled, an SSH client cannot access any server whose public host key it does not know. In this case, you must configure the public host key of the server to be accessed and specify the public key name on the client at first.
# Enable the first authentication function.
[Sysname] ssh client first-time enable
ssh client ipv6 source { ipv6 ipv6-address | interface interface-type interface-number }
undo ssh client ipv6 source
View
Default Level
3: Manage level
Use the ssh client ipv6 source command to specify the source IPv6 address or source interface for the SSH client.
Use the undo ssh client ipv6 source command to remove the configuration.
By default, the client uses the source address specified by the route of the device to access the SSH server.
# Specify the source IPv6 address as 2:2::2:2 for the SSH client.
[Sysname] ssh client ipv6 source ipv6 2:2::2:2
ssh client source { ip ip-address | interface interface-type interface-number }
undo ssh client source
View
Default Level
3: Manage level
Use the ssh client source command to specify the source IPv4 address or source interface of the SSH client.
Use the undo ssh client source command to remove the configuration.
By default, an SSH client uses the IP address or interface specified by the route to access the SSH server.
Related commands: display ssh client source.
# Specify the source IPv4 address of the SSH client as 192.168.0.1.
[Sysname] ssh client source ip 192.168.0.1
ssh server authentication-retries times
undo ssh server authentication-retries
View
Default Level
2: System level
times: Maximum number of authentication attempts, in the range 1 to 5.
Use the ssh server authentication-retries command to set the maximum number of SSH connection authentication attempts, which takes effect at next login.
Use the undo ssh server authentication-retries command to restore the default.
By default, the maximum number of SSH connection authentication attempts is 3.
Note that the threshold specified by using the ssh server authentication-retries command takes into account both RSA authentication attempts and password authentication attempts.
# Set the maximum number of SSH connection authentication attempts to four.
[Sysname] ssh server authentication-retries 4
undo ssh server authentication-timeout
View
Default Level
2: System level
time-out-value: Authentication timeout period in seconds, in the range 1 to.
Use the ssh server authentication-timeout command to set the SSH user authentication timeout period on the SSH server.
Use the undo ssh server authentication-timeout command to restore the default.
By default, the authentication timeout period is 60 seconds.
# Set the SSH user authentication timeout period to 10 seconds.
[Sysname] ssh server authentication-timeout 10
undo ssh server compatible-ssh1x
View
Default Level
2: System level
None
Use the ssh server compatible-ssh1x command to enable the SSH server to work with SSH1.x clients.
Use the undo ssh server compatible-ssh1x command to disable the SSH server from working with SSH1.x clients.
By default, the SSH server can work with SSH1.x clients.
This configuration takes effect at next login.
# Enable the SSH server to work with SSH1.x clients.
[Sysname] ssh server compatible-ssh1x enable
ssh server enable
undo ssh server enable
View
Default Level
2: System level
None
Use the ssh server enable command to enable SSH server.
Use the undo ssh server enable command to disable SSH server.
By default, SSH server is disabled.
# Enable SSH server.
[Sysname] ssh server enable
ssh server rekey-interval hours
undo ssh server rekey-interval
View
Default Level
2: System level
hours: Server key pair update interval in hours, in the range 1 to 24.
Use the ssh server rekey-interval command to set the interval for updating the server key pair.
Use the undo ssh server rekey-interval command to restore the default.
By default, the update interval of the server key pair is 0, that is, the server key pair is not updated.
# Set the server key pair update interval to three hours.
[Sysname] ssh server rekey-interval 3
ssh user username assign rsa-key keyname
undo ssh user username assign rsa-key
View
Default Level
2: System level
keyname: Name of an existing client public key, a string of 1 to 64 characters.
Use the ssh user assign rsa-key command to assign an existing public key to the specified SSH user.
Use the undo ssh user assign rsa-key command to remove the mapping between a user and its public key.
Note that:
l           The system creates an SSH user while you configure the ssh user assign rsa-key command. By default, the authentication mode is RSA, and the service type is stelnet. Use the undo ssh user username command to delete SSH users.
l           If you configure the ssh user assign rsa-key command for a user with a public key, the new public key overwrites the old one.
l           The new public key takes effect when the user logs in next time.
Related commands: display ssh user-information.
# Assign  key named “key1” to the user named “aaa”.
[Sysname] ssh user aaa assign rsa-key key1
ssh user username authentication-type { password | rsa | password-publickey | all }
undo ssh user username authentication-type
View
Default Level
2: System level
username: Name of the SSH user, a string of 1 to 80 characters.
password: Sets the authentication mode of the user to “password” forcibly.
rsa: Sets the authentication mode of the user to “RSA” forcibly.
password-publickey: Sets the authentication mode of the user to “RSA” plus “password” forcibly.
all: Sets the authentication mode to either “password” or “RSA”. Clients will attempt to log in through RSA first.
&  Note:
For the authentication mode specified by password-publickey:
l      SSH1 users can log in successfully if passing one kind of authentication.
l      SSH2 users cannot log in successfully unless passing both kinds of authentication.
Use the ssh user authentication-type command to specify an authentication mode for a specific user. Use the undo ssh user authentication-type command to restore the default authentication mode.
By default, the system specifies the authentication mode as “RSA”.
Note that:
l           This command is used to specify an optional authentication mode for user login on the server. In practice, users can adopt an authentication mode on a client at their discretion.
l           The system creates an SSH user while you configure the ssh user authentication-type command. The default service type is “stelnet”. Use the undo ssh user command to delete SSH users.
l           A newly configured authentication mode will take effect when users log in next time.
l           If a user uses the RSA authentication mode, this user and its public key must be configured on a switch. If a user uses the password authentication mode, its account information can be configured on a switch or remote authentication server (for example, a RADIUS authentication server).
# Specify the authentication mode of the user named “aaa” as a password.
[Sysname] ssh user aaa authentication-type password
ssh user username service-type { stelnet | sftp | all }
undo ssh user username service-type
View
Default Level
2: System level
stelnet: The service type is secure Telnet.
sftp: The service type is Secure FTP.
all: Two service types including Stelnet and SFTP.
Use the ssh user service-type command to specify a service type for a specific user. Use the undo ssh user service-type command to restore the default service type.
By default, the service type is Stelnet.
The system creates an SSH user while you configure the ssh user service-type command. The default service type is “RSA”. Use the undo ssh user command to delete SSH users.
# Specify the service type as SFTP for the user named “aaa”.
[Sysname] ssh user aaa service-type sftp
ssh user username work-directory directory-name
undo ssh user username work-directory
View
Default Level
2: System level
directory-name: Working folder of the SSH user, a string of 1 to 135 characters.
Use the ssh user work-directory command to specify the working folder for an SSH user.
Use the undo ssh user work-directory command to remove the working folder configuration for a user.
Executing the ssh user work-directory command will also create an SSH user. To remove an SSH user, use the undo ssh user command.
Note that:
l           You need to use this command to specify a working folder for each user whose authentication mode is publickey and service type is SFTP.
l           If a user uses publickey and password authentication at the same time, the working folder specified by the ssh user work-directory command takes priority.
# Specify working folder flash:/ for user aaa.
[Sysname] ssh user aaa work-directory flash:/
1.1.38  ssh2
ssh2 { host-ip | host-name } [ port-number ] [ prefer_ctos_cipher { 3des | aes128 | des } | prefer_ctos_hmac { md5 | md5_96 | sha1 | sha1_96 } | prefer_kex { dh_exchange_group | dh_group1 } | prefer_stoc_cipher { 3des | aes128 | des } | prefer_stoc_hmac { md5 | md5_96 | sha1 | sha1_96 } ] *
View
Default Level
0: Visit level
Use the ssh2 command to establish a connection to an SSH server, and specify the preferred key exchange algorithm, encryption algorithms, and HMAC algorithms of the client and the server.
# Login to remote SSH2 server 10.214.50.51, setting the algorithms as follows:
l           Preferred key exchange algorithm: DH_exchange_group
l           Preferred encryption algorithm from server to client: AES128
l           Preferred HMAC algorithm from client to server: MD5
l           Preferred HMAC algorithm from server to client: SHA1-96.
[Sysname] ssh2 10.214.50.51 prefer_kex dh_exchange_group prefer_stoc_cipher aes128 prefer_ctos_hmac md5 prefer_stoc_hmac sha1_96
1.1.39  ssh2 ipv6
ssh2 ipv6 { ipv6-address | host-name } [ port-number ] [ prefer_ctos_cipher { 3des | aes128 | des } | prefer_ctos_hmac { md5 | md5_96 | sha1 | sha1_96 } | prefer_kex { dh_exchange_group | dh_group1 } | prefer_stoc_cipher { 3des | aes128 | des } | prefer_stoc_hmac { md5 | md5_96 | sha1 | sha1_96 } ] *
View
Default Level
0: Visit level
prefer_kex: Preferred key exchange algorithm, default to dh_group1.
Use the ssh2 ipv6 command to establish a connection to an IPv6 SSH server and specify the preferred key exchange algorithm, encryption algorithms, and HMAC algorithms of the client and the server.
# Login to remote SSH2 server 2000::1, setting the algorithms as follows:
[Sysname] ssh2 ipv6 2000::1 prefer_kex dh_exchange_group prefer_stoc_cipher aes128 prefer_ctos_hmac md5 prefer_stoc_hmac sha1_96
1.2.1  bye
bye
View
SFTP client view
Default Level
3: Manage level
None
Use the bye command to terminate the connection with a remote SFTP server and return to user view.
This command functions as the exit and quit commands.
# Terminate the connection with the remote SFTP server.
sftp-client> bye
Bye
<Sysname>
1.2.2  cd
cd [ remote-path ]
View
SFTP client view
Default Level
3: Manage level
remote-path: Name of a path on the server.
Use the cd command to change the working path on a remote SFTP server. With the argument not specified, the command displays the current working path.
&  Note:
l      You can use the cd .. command to return to the upper-level directory.
l      You can use the cd / command to return to the root directory of the system.
# Change the working path to new1.
sftp-client> cd new1
Current Directory is:
/new1
1.2.3  cdup
cdup
View
SFTP client view
Default Level
3: Manage level
None
Use the cdup command to return to the upper-level directory.
# From the current working directory /new1, return to the upper-level directory.
sftp-client> cdup
1.2.4  delete
delete remote-file&<1-10>
View
SFTP client view
Default Level
3: Manage level
remote-file&<1-10>: Name of a file on the server. &<1-10> means that you can provide up to 10 filenames, which are separated by space.
Use the delete command to delete a specified file from a server.
This command functions as the remove command.
# Delete file temp.c from the server.
sftp-client> delete temp.c
The following files will be deleted:
/temp.c
Are you sure to delete it? [Y/N]:y
This operation may take a long time.Please wait...
File successfully Removed
1.2.5  dir
View
SFTP client view
Default Level
3: Manage level
-a: Displays the filenames or the folder names of the specified directory.
-l: Displays in list form detailed information of the files and folder of the specified directory
remote-path: Name of the directory to be queried.
Use the dir command to display file and folder information under a specified directory.
With the –a and –l keyword not specified, the command displays detailed information of files and folder under the specified directory in a list form.
With the remote-path not specified, the command displays the file and folder information of the current working directory.
This command functions as the ls command.
# Display in a list form detailed file and folder information under the current working directory.
sftp-client> dir
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey1
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:28 pub1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:24 new1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:18 new2
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:30 pub2
1.2.6  exit
exit
View
SFTP client view
Default Level
3: Manage level
None
Use the exit command to terminate the connection with a remote SFTP server and return to user view.
This command functions as the bye and quit commands.
sftp-client> exit
Bye
<Sysname>
1.2.7  get
View
SFTP client view
Default Level
3: Manage level
remote-file: Name of a file on the remote SFTP server.
local-file: Name for the local file.
Use the get command to download a file from a remote SFTP server and save it locally.
If you do not specify the local-file argument, the file will be saved locally with the same name as that on the remote SFTP server.
# Download file temp1.c and save it as temp.c locally.
sftp-client> get temp1.c temp.c
Remote  file:/temp1.c --->  Local file: temp.c
Downloading file successfully ended
1.2.8  help
help [ all | command-name ]
View
SFTP client view
Default Level
3: Manage level
all: Displays a list of all commands.
command-name: Name of a command.
Use the help command to display a list of all commands or the help information of an SFTP client command.
With neither the argument nor the keyword specified, the command displays a list of all commands.
# Display the help information of the get command.
sftp-client> help get
get remote-path [local-path]  Download file
Default local-path is the same with remote-path
1.2.9  ls
View
SFTP client view
Default Level
3: Manage level
Use the ls command to display file and folder information under a specified directory.
This command functions as the dir command.
sftp-client> ls
1.2.10  mkdir
mkdir remote-path
View
SFTP client view
Default Level
3: Manage level
remote-path: Name for the directory on a remote SFTP server.
Use the mkdir command to create a directory on a remote SFTP server.
# Create a directory named test on the remote SFTP server.
sftp-client> mkdir test
New directory created
1.2.11  put
View
SFTP client view
Default Level
3: Manage level
local-file: Name of a local file.
remote-file: Name for the file on a remote SFTP server.
Use the put command to upload a local file to a remote SFTP server.
If you do not specify the remote-file argument, the file will be saved remotely with the same name as the local one.
# Upload local file temp.c to the remote SFTP server and save it as temp1.c.
sftp-client> put temp.c temp1.c
Local file:temp.c --->  Remote file: /temp1.c
Uploading file successfully ended
1.2.12  pwd
pwd
View
SFTP client view
Default Level
3: Manage level
None
Use the pwd command to display the current working directory of a remote SFTP server.
# Display the current working directory of the remote SFTP server.
sftp-client> pwd
1.2.13  quit
View
SFTP client view
Default Level
3: Manage level
None
Use the quit command to terminate the connection with a remote SFTP server and return to user view.
This command functions as the bye and exit commands.
sftp-client> quit
Bye
<Sysname>
1.2.14  remove
remove remote-file&<1-10>
View
SFTP client view
Default Level
3: Manage level
remote-file&<1-10>: Name of a file on an SFTP server. &<1-10> means that you can provide up to 10 filenames, which are separated by space.
Use the remove command to delete a specified file from a remote server.
This command functions as the delete command.
sftp-client> remove temp.c
/temp.c
1.2.15  rename
rename oldname newname
View
SFTP client view
Default Level
3: Manage level
oldname: Original file name or directory name.
newname: New file name or directory name.
Use the rename command to change the name of a specified file or directory on an SFTP server.
# Change the name of a file on the SFTP server from temp1.c to temp2.c.
sftp-client> rename temp1.c temp2.c
File successfully renamed
1.2.16  rmdir
rmdir remote-path&<1-10>
View
SFTP client view
Default Level
3: Manage level
remote-path&<1-10>: Name of the directory on the remote SFTP server. &<1-10> means that you can specify up to 10 directory names that are separated by space.
Use the rmdir command to delete a specified directory from an SFTP server.
# On the SFTP server, delete directory temp1 in the current directory.
sftp-client> rmdir temp1
Directory successfully removed
