H3C S9500 Command Manual-Release2132[V2.03]-06 QoS ACL Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-06 QoS ACL Volume
02-ACL Commands
02-ACL Commands 138.06 KB
Chapter 1  ACL Configuration Commands
1.1  Common Configuration Commands
1.1.1  display time-range
display time-range { time-name | all }
View
Default Level
1: Monitor level
time-name: Name of a time range.
all: All existing time ranges.
Use the display time-range command to display the configuration and state of a specified or all time ranges.
A time range is active if the system time falls into its range, and if otherwise, inactive.
If the specified time range does not exist, no information will be displayed.
# Display the configuration and state of time range trname.
[Sysname] display time-range trname
Current time is 10:45:15 4/14/2005 Thursday
Time-range : trname ( Inactive )
from 08:00 12/1/2007 to 23:59 12/31/2100
Table 1-1 Description on the fields of the display time-range command
Current time
Current system time
Time-range
The configuration and state of time range, such as time range name, its activated state, and start time and ending time.
1.1.2  time-range
time-range time-name { start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 }
undo time-range time-name [ start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 ]
View
Default Level
2: System level
time-name: Time range name comprising 1 to 32 characters. It is case insensitive and must start with an English letter. To avoid confusion, this name cannot be all.
start-time: Start time of a periodic time range, in hh:mm format as 24-hour time, where hh is hours and mm is minutes. Its value ranges from 00:00 to 23:59.
end-time: End time of the periodic time range, in hh:mm format as 24-hour time, where hh is hours and mm is minutes. Its value ranges from 00:00 to 24:00. The end time must be greater than the start time.
days: Indicates on which day or days of the week the periodic time range is valid. You may specify multiple values, in words or in digits, separated by spaces, for this argument, but make sure that they do not overlap. These values can take one of the following forms:
l           A digit in the range 0 to 6, respectively for Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, and Saturday.
l           Week in words, that is, Mon, Tue, Wed, Thu, Fri, Sat, or Sun.
l           working-day for Monday through Friday.
l           off-day for Saturday and Sunday.
l           daily for seven days of a week.
from time1 date1: Indicates the start time and date of an absolute time range. The time1 argument specifies the time of the day in hh:mm format as 24-hour time, where hh is hours and mm is minutes. Its value ranges from 00:00 to 23:59. The date1 argument specifies a date in MM/DD/YYYY or YYYY/MM/DD format, where MM is the month of the year in the range 1 to 12, DD is the day of the month in the range 1 to 31, and YYYY is the year in the usual Gregorian calendar in the range 1970 to 2100. If not specified, the start time is the earliest time available from the system, namely, 01/01/1970 00:00:00 AM.
to time2 date2: Indicates the end time and date of the absolute time range. The format of the time2 argument is the same as that of the time1 argument, but its value ranges from 00:00 to 24:00. The end time must be greater than the start time. If not specified, the end time is the maximum time available from the system, namely, 12/31/2100 24:00:00 PM. The format and value range of the date2 argument are the same as those of the date1 argument.
Use the time-range command to create a time range.
Use the undo time-range command to remove a time range.
You may create a maximum of 256 time ranges.
A time range can be one of the following:
l           Periodic time range created using the time-range time-name start-time to end-time days command. A time range thus created recurs periodically on the day or days of the week.
l           Absolute time range created using the time-range time-name { from time1 date1 [ to time2 date2 ] | to time2 date2 } command. Unlike a periodic time range, a time range thus created does not recur.
l           Compound time range created using the time-range time-name start-time to end-time days { from time1 date1 [ to time2 date2 ] | to time2 date2 } command. A time range thus created recurs on the day or days of the week only within the specified period. For example, to create a time range that is active from 12:00 to 14:00 on Wednesdays between January 1, 2004 00:00 and December 31, 2004 23:59, you may use the time-range test 12:00 to 14:00 wednesday from 00:00 01/01/2004 to 23:59 12/31/2004 command.
l           By default, up to 256 time ranges are available.
You may create individual time ranges identified with the same name. They are regarded as one time range whose active period is the result of ORing periodic ones, ORing absolute ones, and ANDing periodic and absolute ones.
# Create an absolute time range named test, setting it to become active from 00:00 on January 1, 2003.
[Sysname] time-range test from 0:0 2003/1/1
# Create a compound time range named test, setting it to be active between 8:00 to 18:00 during working days.
[Sysname] time-range test 8:00 to 18:00 working-day
# Create a periodic time range named test, setting it to be active between 14:00 and 18:00 on Saturday and Sunday.
[Sysname] time-range test 14:00 to 18:00 off-day
1.2  IPv4 ACL Configuration Commands
1.2.1  acl
acl number acl-number [ match-order { auto | config } ]
undo acl { all | number acl-number }
View
Default Level
2: System level
number: Defines a numbered access control list (ACL).
acl-number: IPv4 ACL number in the range 2000 to 5999, where:
l           2000 to 2999 for basic IPv4 ACLs
l           3000 to 3999 for advanced IPv4 ACLs
l           4000 to 4999 for Ethernet frame header ACLs
l           5000 to 5999 for user-defined ACLs
match-order: Sets the order in which ACL rules are matched. This keyword is not available for user-defined IPv4 ACLs.
l           auto: Performs depth-first match.
l           config: Performs matching against rules in the order in which they are configured.
all: All IPv4 ACLs.
Use the acl command to enter IPv4 ACL view. If the ACL does not exist, it is created first.
Use the undo acl command to remove a specified or all IPv4 ACLs.
By default, the match order is config.
Note that:
l           The match order for user-defined ACLs can only be config.
l           You can also use this command to modify the match order of an existing IPv4 ACL but only when it is empty.
# Create IPv4 ACL 2000.
[Sysname] acl number 2000
[Sysname-acl-basic-2000]
1.2.2  description (for IPv4)
View
Basic IPv4 ACL view, advanced IPv4 ACL view, Ethernet frame header ACL view, user-defined ACL view
Default Level
2: System level
text: ACL description, a case-sensitive string of 1 to 127 characters.
Use the description command to create an IPv4 ACL description to describe the purpose of the ACL for example.
Use the undo description command to remove the ACL description.
By default, an IPv4 ACL has no description.
# Define the description of IPv4 ACL 2000.
[Sysname-acl-basic-2000] description This acl is used in eth 0
# Define the description of IPv4 ACL 3000.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] description This acl is used in eth 0
# Define the description of IPv4 ACL 4000.
[Sysname] acl number 4000
[Sysname-acl-ethernetframe-4000] description This acl is used in eth 0
# Define the description of IPv4 ACL 5000.
[Sysname] acl number 5000
[Sysname-acl-user-5000] description This acl is used in eth 0
1.2.3  display acl
display acl { acl-number | all }
View
Default Level
1: Monitor level
all: All IPv4 ACLs.
Use the display acl command to display information about the specified or all IPv4 ACLs.
This command displays ACL rules in the order in which the system compares a packet against them.
# Display information about ACL 2001.
<Sysname> display acl 2001
Basic ACL  2001, named flow, 1 rules,
this is first
ACL's step is 5
 rule 22 permit fragment time-range aaa
 rule 22 comment THIS RULE IS USED IN VLAN2(Inactive)
Table 1-2 Description on the fields of the display acl command
Basic ACL  2001
The displayed information is about the basic IPv4 ACL 2001.
1 rules
The ACL contains one rule.
this is first
Description of the IPv4 ACL
ACL’s step is 5
The rules in this ACL are numbered in the step of 5.
rule xx
Configuration information of IPv4 ACL XX
rule xx comment
Description of IPv4 ACL XX
Active/Inactive
Indicates whether the ACL is active
1.2.4  reset acl counter
reset acl counter { acl-number | all }
View
Default Level
2: System level
acl-number: IPv4 ACL number in the range 2000 to 4999, where:
all: All IPv4 ACLs with ACL numbers falling in the range 2000 to 4999.
Use the reset acl counter command to clear statistics about specified or all IPv4 ACLs except for user-defined ACLs.
# Clear statistics about IPv4 ACL 2001.
1.2.5  rule (in basic ACL view)
rule [ rule-id ] { deny | permit } [ fragment | logging | source { sour-addr sour-wildcard | any } | time-range time-name | vpn-instance vpn-instance-name ] *
undo rule rule-id [ fragment | logging | source | time-range | vpn-instance ] *
View
Basic ACL view
Default Level
2: System level
rule-id: ACL rule number in the range 0 to 65534.
deny: Defines a deny statement to drop matched packets.
permit: Defines a permit statement to allow matched packets to pass.
fragment: Indicates that the rule applies only to non-first fragments. Without this keyword, the rule applies to both fragments and non-fragments
logging: Specifies to log matched packets.
source { sour-addr sour-wildcard | any }: Specifies a source address. The sour-addr sour-wildcard argument specifies a source IP address in dotted decimal notation. Setting the wildcard to a zero indicates a host address. The any keyword indicates any source IP address.
time-range time-name: Specifies the time range in which the rule takes effect. If the specified time range does not exist, the rule will not take effect.
vpn-instance vpn-instance-name: Specifies a VPN instance. The vpn-instance-name argument is a case-insensitive string of 1 to 31 characters.
Use the rule command to create an IPv4 ACL rule or modify the rule if it has existed.
Use the undo rule command to remove an IPv4 ACL rule or parameters from the rule.
With the undo rule command, if no optional parameters are specified, the entire ACL rule is removed; otherwise, only the involved information is removed.
Note that:
l           You will fail to create or modify a rule if its permit/deny statement is exactly the same as another rule. In addition, if the ACL match order is set to auto rather than config, you cannot modify ACL rules.
l           You may use the display acl command to verify rules configured in an ACL. If the match order for this ACL is auto, rules are displayed in the depth-first match order rather than by rule number.
# Create a rule to deny packets with the source IP address 1.1.1.1.
[Sysname-acl-basic-2000] rule deny source 1.1.1.1 0
1.2.6  rule (in advanced ACL view)
rule [ rule-id ] { deny | permit } protocol [ destination { dest-addr dest-wildcard | any } | destination-port operator port1 [ port2 ] | dscp dscp | established | fragment | icmp-type { icmp-type icmp-code | icmp-message } | logging | precedence precedence | reflective | source { sour-addr sour-wildcard | any } | source-port operator port1 [ port2 ] | time-range time-name | tos tos | vpn-instance vpn-instance-name ] *
undo rule rule-id [ destination | destination-port | dscp | fragment | icmp-type | logging | precedence | reflective | source | source-port | time-range | tos | vpn-instance ] *
View
Advanced ACL view
Default Level
2: System level
protocol: Protocol carried by IP. It can be a number in the range 0 to 255, or in words, gre (47), icmp (1), igmp (2), ip, ipinip (4), ospf (89), tcp (6), udp (17).
Table 1-3 Parameters for advanced IPv4 ACL rules
Parameter
Function
Specifies a destination address.
The dest-addr dest-wildcard argument specifies a destination IP address in dotted decimal notation. Setting the dest-wildcard to a zero indicates a host address. The any keyword indicates any destination IP address.
Specifies an IP precedence value.
The precedence argument can be a number in the range 0 to 7, or in words, routine, priority, immediate, flash, flash-override, critical, internet, or network.
tos tos
Specifies a ToS preference.
The tos argument can be a number in the range 0 to 15, or in words, max-reliability (2), max-throughput (4), min-delay (8), min-monetary-cost (1), or normal (0).
dscp dscp
Specifies a DSCP priority.
The dscp argument can be a number in the range 0 to 63, or in words, af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
logging
This function requires that the module using the ACL supports logging.
reflective
Specifies the rule to be reflective.
A rule with the reflective keyword can be defined only for TCP, UDP, or ICMP packets and its statement can only be permit.
fragment
With this keyword not provided, the rule is effective to both non-fragments and fragments.
Specifies the time range in which the rule can take effect.
If the protocol argument is set to tcp or udp, you may define the parameters in the following table.
Table 1-4 TCP/UDP-specific parameters for advanced IPv4 ACL rules
Parameter
Function
Defines a UDP or TCP source port against which UDP or TCP packets are matched.
The operator argument can be lt (lower than), gt (greater than), eq (equal to), neq (not equal to), and range (inclusive range).
port1, port2: TCP or UDP port number, represented by a number in the range 0 to 65535. TCP port number can be represented in words as follows:
chargen (19), bgp (179), cmd (514), daytime (13), discard (9), domain (53), echo (7), exec (512), finger (79), ftp (21), ftp-data (20), gopher (70), hostname (101), irc (194), klogin (543), kshell (544), login (513), lpd (515), nntp (119), pop2 (109), pop3 (110), smtp (25), sunrpc (111), tacacs (49), talk (517), telnet (23), time (37), uucp (540), whois (43), or www (80).
UDP port number can be represented in words as follows: biff (512), bootpc (68), bootps (67), discard (9), dns (53), dnsix (90), echo (7), mobilip-ag (434), mobilip-mn (435), nameserver (42), netbios-dgm (138), netbios-ns (137), netbios-ssn (139), ntp (123), rip (520), snmp (161), snmptrap (162), sunrpc (111), syslog (514), tacacs-ds (65), talk (517), tftp (69), time (37), who (513), xdmcp (177).
Defines a UDP or TCP destination port against which UDP or TCP packets are matched.
established
Defines the rule for TCP connection packets.
A keyword specific to TCP. With this keyword, the rule matches TCP connection packets with the ACK or RST flag.
If the protocol argument is set to icmp, you may define the parameters in the following table.
Table 1-5 Parameters for advanced IPv4 ACL rules
Parameter
Function
Specifies the ICMP message type and code.
The icmp-type argument ranges from 0 to 255.
The icmp-code argument ranges from 0 to 255.
The icmp-message argument specifies a message name.
The following table provides the ICMP messages that you can specify in advanced IPv4 ACL rules.
Table 1-6 ICMP messages and their codes
ICMP message
Code
echo
8
0
echo-reply
0
0
fragmentneed-DFset
3
4
host-redirect
5
1
host-tos-redirect
5
3
host-unreachable
3
1
information-reply
16
0
information-request
15
0
net-redirect
5
0
net-tos-redirect
5
2
net-unreachable
3
0
parameter-problem
12
0
port-unreachable
3
3
protocol-unreachable
3
2
reassembly-timeout
11
1
source-quench
4
0
source-route-failed
3
5
timestamp-reply
14
0
timestamp-request
13
0
ttl-exceeded
11
0
Use the rule command to define or modify an advanced IPv4 ACL rule. If the rule does not exist, it is created first.
Use the undo rule command to remove an ACL rule or parameters from the rule.
Note that:
l           You may use the display acl command to verify rules configured in an ACL. If the match order for this ACL is auto, rules are displayed in the depth-first order rather than by rule number.
# Define a rule to permit the TCP packets to pass with the destination port 80 sent from 129.9.0.0 to 202.38.160.0.
[Sysname] acl number 3101
[Sysname-acl-adv-3101] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq 80
1.2.7  rule (in Ethernet frame header ACL view)
rule [ rule-id ] { deny | permit } [ cos vlan-pri | dest-mac dest-addr dest-mask | lsap lsap-code lsap-wildcard | source-mac sour-addr source-mask | time-range time-name | type type-code type-wildcard ] *
undo rule rule-id
View
Default Level
2: System level
cos vlan-pri: Defines a 802.1p priority. The vlan-pri argument takes a value in the range 0 to 7; or its equivalent in words, best-effort, background, spare, excellent-effort, controlled-load, video, voice, or network-management.
dest-mac dest-addr dest-mask: Specifies a destination MAC address range. The dest-addr and dest-mask arguments indicate a destination MAC address and mask in xxxx-xxxx-xxxx format.
lsap lsap-code lsap-wildcard: Defines the DSAP and SSAP fields in the LLC encapsulation. The lsap-code argument is a 16-bit hexadecimal number indicating frame encapsulation. The lsap-wildcard argument is a 16-bit hexadecimal number indicating the wildcard of the LSAP code.
source-mac sour-addr source-mask: Specifies a source MAC address range. The sour-addr and sour-mask arguments indicate a source MAC address and mask in xxxx-xxxx-xxxx format.
time-range time-name: Specifies the time range in which the rule can take effect. If the specified time range does not exist, the rule will not take effect.
type type-code type-wildcard: Defines a link layer protocol. The type-code argument is a 16-bit hexadecimal number indicating frame type. It is corresponding to the type-code field in Ethernet_II and Ethernet_SNAP frames. The type-wildcard argument is a 16-bit hexadecimal number indicating the wildcard.
Use the rule command to create an Ethernet frame header ACL rule or modify the rule if it has existed.
Use the undo rule command to remove an Ethernet frame header ACL rule.
Note that:
  Caution:
l      When you define an Ethernet frame header ACL, do not set the type-code argument to 0x0800, 0x86DD, 0x8847, 0x8848, or 0x8100.
l      For the default flow template to be used, the destination mask corresponding to the type keyword must be 0xFFFF.
# Create a rule to deny packets with the 802.1p priority of 3.
[Sysname-acl-ethernetframe-4000] rule deny cos 3
1.2.8  rule (in user-defined ACL view)
rule [ rule-id ] { deny | permit } [ { { ipv4 | ipv6 | l2 | l4 | l5 } rule-string rule-mask offset }&<1-8> ] [ time-range time-name ]
undo rule rule-id
View
User-defined ACL view
Default Level
2: System level
ipv4: Sets the offset from the beginning of the IPv4 header.
ipv6: Sets the offset from the beginning of the IPv6 header.
l2: Sets the offset from the beginning of the Layer 2 frame header.
l4: Sets the offset from the beginning of the Layer 4 header.
l5: Sets the offset from the beginning of the Layer 5 header.
rule-string: Defines a match pattern in hexadecimal format. Its length must be a multiple of two.
rule-mask: Defines a match pattern mask in hexadecimal format. Its length must be the same as that of the match pattern.
offset: The offset in bytes at which the match operation begins.
&<1-8>: Indicates that up to eight match patterns can be defined in the rule.
Use the rule command to create a user-defined IPv4 ACL rule.
Use the undo rule command to remove a user-defined IPv4 ACL rule.
Note that you will fail to create a user-defined ACL rule if its permit/deny statement is exactly the same as another rule.
# Create user-defined ACL 5500, permitting any packet with the 13th and 14th bytes starting from the Layer 2 header being 0x0806 (that is, ARP packets).
[Sysname] acl number 5500
[Sysname-acl-user-5500] rule 0 permit l2 0806 ffff 12
1.2.9  rule comment (for IPv4)
rule rule-id comment text
undo rule rule-id comment
View
Default Level
2: System level
rule-id: IPv4 ACL rule number in the range 0 to 65534.
text: IPv4 ACL rule description, a case-sensitive string of 1 to 127 characters.
Use the rule comment command to create or modify an ACL rule description, for example to describe the purpose of the ACL rule or the parameters it contains.
You will fail to do that if the specified rule does not exist.
Use the undo rule comment command to remove the ACL rule description.
By default, no rule description is created.
# Create a rule in ACL 2000 and define the rule description.
[Sysname-acl-basic-2000] rule 0 deny source 1.1.1.1 0
[Sysname-acl-basic-2000] rule 0 comment This rule is used in eth 1
# Create a rule in ACL 3000 and define the rule description.
[Sysname-acl-adv-3000] rule 0 permit ip source 1.1.1.1 0
[Sysname-acl-adv-3000] rule 0 comment This rule is used in eth 1
# Create a rule in ACL 4000 and define the rule description.
[Sysname-acl-ethernetframe-4000] rule 0 deny cos 3
[Sysname-acl-ethernetframe-4000] rule 0 comment This rule is used in eth 1
# Create a rule in ACL 5000 and define the rule description.
[Sysname-acl-user-5000] rule 0 permit l2 14 20 10
[Sysname-acl-user-5000] rule 0 comment This rule is used in eth 1
1.2.10  step (for IPv4)
step step-value
undo step
View
Default Level
2: System level
step-value: IPv4 ACL rule numbering step, in the range 1 to 20.
Use the step command to set a rule numbering step.
Use the undo step command to restore the default.
By default, rule numbering step is five.
When defining rules in an IPv4 ACL, you do not necessarily assign them numbers. The system can do this automatically in steps. For example, if the default step applies, rules you created are automatically numbered 0, 5, 10, 15, and so on. One benefit of rule numbering step is that it allows you to insert new rules between existing ones as needed. For example, after creating four rules numbered 0, 5, 10, 15 in an ACL configured with the step of five, you can still insert a rule numbered 1.
Any step change can result in renumbering. For example, after you change the step in the above example from five to two, the rules are renumbered 0, 2, 4, 6, and 8.
Note that even if the current step is the default, performing the undo step command can still result in rule renumbering. Suppose that ACL 3001 adopts the default numbering step and contains two rules numbered 0 and 5. After you insert rule 1 and rule 3, the rules are numbered 0, 1, 3, and 5. If you perform the undo step command, they will be renumbered 0, 5, 10, and 15.
# Set the rule numbering step to 2 for IPv4 ACL 3101.
[Sysname-acl-basic-3101] step 2
1.3  IPv6 ACL Configuration Commands
1.3.1  acl ipv6
acl ipv6 number acl6-number [ match-order { auto | config } ]
undo acl ipv6 { all | number acl6-number }
View
Default Level
2: System level
acl6-number: IPv6 ACL number. It is a value in one of the following ranges:
l           2000 to 2999 for basic IPv6 ACLs
l           3000 to 3999 for advanced IPv6 ACLs
all: All IPv6 ACLs.
Use the acl ipv6 command to enter IPv6 ACL view. If the ACL does not exist, it is created first.
Use the undo acl ipv6 command to remove a specified or all IPv6 ACLs.
You can also use this command to modify the match order of an existing IPv6 ACL but only when it is empty.
# Create ACL 2000.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000]
1.3.2  description (for IPv6)
View
Basic IPv6 ACL view, advanced IPv6 ACL view
Default Level
2: System level
Use the description command to create an IPv6 ACL description, to describe the purpose of the ACL for example.
Use the undo description command to remove the IPv6 ACL description.
By default, an IPv6 ACL has no description.
# Create a description for IPv6 ACL 2000.
[Sysname-acl6-basic-2000] description This acl is used in vlan2
# Create a description for IPv6 ACL 3000.
[Sysname-acl6-adv-3000] description This acl is used in vlan2
1.3.3  display acl ipv6
display acl ipv6 { acl6-number | all }
View
Default Level
1: Monitor level
all: All IPv6 ACLs.
Use the display acl ipv6 command to display information about the specified or all IPv6 ACLs.
The output will be displayed in matching order.
# Display information about IPv6 ACL 2001.
<Sysname> display acl ipv6 2001
Basic IPv6 ACL  2001, 1 rule,
this is first
 ACL's step is 5
 rule 22 comment This rule is used in vlan2(Active)
Table 1-7 Description on the fields of the display acl ipv6 command
Basic IPv6 ACL  2001
The displayed information is about the basic IPv6 ACL 2001.
1 rule
this is first
Description of the IPv6 ACL
ACL's step is 5
rule xx
Configuration information of IPv6 ACL XX
rule xx comment
Description of IPv6 ACL XX
Active/Inactive
Indicates whether the ACL is active.
1.3.4  reset acl ipv6 counter
reset acl ipv6 counter { acl6-number | all }
View
Default Level
2: System level
all: All IPv6 ACLs.
Use the reset acl ipv6 counter command to clear statistics about specified or all basic and advanced IPv6 ACLs.
# Clear the statistics about IPv6 ACL 2001.
<Sysname> reset acl ipv6 counter 2001
1.3.5  rule (in basic IPv6 ACL view)
rule [ rule-id ] { deny | permit } [ fragment | logging | source { ipv6-address prefix-length | ipv6-address/prefix-length | any } | time-range time-name ] *
undo rule rule-id [ fragment | logging | source | time-range ] *
View
Basic IPv6 ACL view
Default Level
2: System level
rule-id: IPv6 ACL rule number in the range 0 to 65534.
fragment: Indicates that the rule applies only to non-first fragments. The rule applies to both fragments and non-fragments without this keyword.
source { ipv6-address prefix-length | ipv6-address/prefix-length | any }: Specifies a source address. The ipv6-address and prefix-length arguments specify a source IPv6 address, and its address prefix length in the range 1 to 128. The any keyword indicates any IPv6 source address.
Use the rule command to create an IPv6 ACL rule or modify the rule if it has existed.
Use the undo rule command to remove an IPv6 ACL rule or parameters from the rule.
Note that:
l           You may use the display acl ipv6 command to verify rules configured in an ACL. If the match order for this IPv6 ACL is auto, rules are displayed in the depth-first match order rather than by rule number.
# Create rules in IPv6 ACL 2000.
[Sysname-acl6-basic-2000] rule permit source 2030:5060::9050/64
[Sysname-acl6-basic-2000] rule 8 deny source fe80:5060::8050/96
1.3.6  rule (in advanced IPv6 ACL view)
rule [ rule-id ] { deny | permit } protocol [ destination { dest dest-prefix | dest/dest-prefix | any } | destination-port operator port1 [ port2 ] | dscp dscp | fragment | icmpv6-type { icmpv6-type icmpv6-code | icmpv6-message } | logging | source { source source-prefix | source/source-prefix | any } | source-port operator port1 [ port2 ] | time-range time-name ] *
undo rule rule-id [ destination | destination-port | dscp | fragment | icmpv6-type | logging | source | source-port | time-range ] *
View
Advanced IPv6 ACL view
Default Level
2: System level
protocol: Protocol carried on IPv6. It can be a number in the range 0 to 255, or in words, gre (47), icmpv6 (58), ipv6, ipv6-ah (51), ipv6-esp (50),  ospf (89), tcp (6), udp (17).
Table 1-8 Match criteria and other rule information for advanced IPv6 ACL rules
Parameter
Function
Specifies a source IPv6 address.
The source and source-prefix arguments specify an IPv6 source address and its prefix length in the range 1 to 128.
Specifies a destination IPv6 address.
The dest and dest-prefix arguments specify a destination IPv6 address, and its prefix length in the range 1 to 128.
The any keyword indicates any IPv6 destination address.
dscp dscp
Specifies a DSCP preference
logging
fragment
Table 1-9 TCP/UDP-specific match criteria for advanced IPv6 ACL rules
Parameter
Function
Defines the source port in the UDP/TCP packet.
The operator argument can be lt (lower than), gt (greater than), eq (equal to), or range (inclusive range).
The port1 and port2 arguments each specify a TCP or UDP port, represented by a number in the range 0 to 65535. TCP port number can be represented in words as follows:
Defines the destination port in the UDP/TCP packet.
If the protocol argument is set to ICMPv6, you may define the parameters in the following table.
Table 1-10 ICMPv6-specific match criteria for advanced IPv6 ACL rules
Parameter
Function
Specifies the ICMPv6 message type and code
The icmpv6-type argument ranges from 0 to 255.
The icmpv6-code argument ranges from 0 to 255.
The icmpv6-message argument specifies a message name.
The following table provides the ICMPv6 messages that you can specify in advanced IPv6 ACL rules.
Table 1-11 Available ICMPv6 messages
ICMPv6 message
Code
redirect
137
0
echo-request
128
0
echo-reply
129
0
err-Header-field
4
0
frag-time-exceeded
3
1
hop-limit-exceeded
3
0
host-admin-prohib
1
1
host-unreachable
1
3
neighbor-advertisement
136
0
neighbor-solicitation
135
0
network-unreachable
1
0
packet-too-big
2
0
port-unreachable
1
4
router-advertisement
134
0
router-solicitation
133
0
unknown-ipv6-opt
4
2
unknown-next-hdr
4
1
Note that:
l           You may use the display acl ipv6 command to verify rules configured in an IPv6 ACL. If the match order for this IPv6 ACL is auto, rules are displayed in the depth-first match order rather than by rule number.
# Create a rule in IPv6 ACL 3000, permitting the TCP packets with the source address 2030:5060::9050/64 to pass.
[Sysname-acl6-adv-3000] rule permit tcp source 2030:5060::9050/64
1.3.7  rule comment (for IPv6)
View
Default Level
2: System level
text: IPv6 ACL rule description, a case-sensitive string of 1 to 127 characters.
Use the rule comment command to create or modify a description for an existing IPv6 ACL rule, for example to describe the purpose of the ACL rule or its attributes.
Use the undo rule comment command to remove the IPv6 ACL rule description.
# Define a rule in IPv6 ACL 2000 and create a description for the rule.
[Sysname-acl6-basic-2000] rule 0 permit source 2030:5060::9050/64
[Sysname-acl6-basic-2000] rule 0 comment This rule is used in eth 1
# Define a rule in IPv6 ACL 3000 and create a description for the rule.
[Sysname-acl6-adv-3000] rule 0 permit tcp source 2030:5060::9050/64
[Sysname-acl6-adv-3000] rule 0 comment This rule is used in eth 1
1.3.8  step (for IPv6)
step step-value
undo step
View
Default Level
2: System level
step-value: The step in which the rules in the IPv6 ACL is numbered. By default, it is in the range 1 to 20 at the step of 5.
Use the step command to set a rule numbering step for the IPv6 ACL.
When defining rules in an IPv6 ACL, you do not necessarily assign them numbers. The system can do this automatically in steps. For example, if the default step applies, rules you created are numbered 0, 5, 10, 15, and so on automatically.
One benefit of rule numbering step is that it allows you to insert new rules between existing ones as needed. For example, after creating four rules numbered 0, 5, 10, 15 in an ACL configured with the step of 5, you can still insert a rule numbered 1.
Any step change can result in renumbering. For example, after you change the step in the above example from 5 to 2, the rules are renumbered 0, 2, 4, 6, and 8.
Note that even if the current step is the default, performing the undo step command can still result in rule renumbering. Suppose that IPv6 ACL 3001 adopts the default numbering step and contains two rules numbered 0 and 5. After you insert rule 1 and rule 3, the rules are numbered 0, 1, 3, and 5. If you perform the undo step command, they will be renumbered 0, 5, 10, and 15.
# Set the rule numbering step to 2 for IPv6 ACL 2000.
[Sysname-acl6-basic-2000] step 2
# Set the rule numbering step to 2 for IPv6 ACL 3000.
[Sysname-acl6-adv-3000] step 2
Chapter 2  Flow Template Configuration Commands
2.1  Flow Template Configuration Commands
2.1.1  display flow-template user-defined
display flow-template user-defined [ flow-template-name ]
View
Default Level
1: Monitor level
flow-template-name: Name of a user-defined flow template.
Use the display flow-template user-defined command to display the configuration of the specified or all user-defined flow templates.
# Display the configuration of all user-defined flow templates.
<Sysname> display flow-template user-defined
user-defined flow template: basic
 name:f1, index:1, total reference counts:1
 fields: ip-protocol fragments ip-precedence
user-defined flow template: extend
 name:f2, index:2, total reference counts:0
 fields: start 22 33 l2 55 66
 name:f3, index:3, total reference counts:1
 fields: tos
Table 2-1 Description on the fields of display flow-template user-defined
Type of the user-defined flow template: basic or extend
name
Name of the user-defined flow template
index
Index of the user-defined flow template
Total number of the times that the user-defined flow template is referenced.
fields
Fields included in the user-defined flow template
2.1.2  display flow-template interface
display flow-template interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display flow-template interface command to display information about the user-defined flow template applied to the specified interface or all the interfaces.
# Display information about the user-defined flow templates applied to all interfaces.
<Sysname> display flow-template interface
Interface: Ethernet1/1/1
Table 2-2 Description on the fields of display flow-template interface
Interface where the user-defined flow template is referenced
name
index
Reference count for the user-defined flow templates
fields
2.1.3  flow-template
flow-template flow-template-name
undo flow-template
View
Ethernet interface view, port group view
Default Level
2: System level
Use the flow-template command to reference a flow template on an Ethernet interface or port group.
Use the undo flow-template command to remove the reference.
Note that:
l           The specified user-defined flow template must exist.
l           You can reference only one user-defined flow template on an interface.
# Reference user-defined flow template f1 on Ethernet 1/1/1.
[Sysname] interface ethernet 1/1/1
[Sysname-Ethernet1/1/1] flow-template f1
# Remove the referenced flow template on Ethernet 1/1/1.
[Sysname-Ethernet1/1/1] undo flow-template
# Reference user-defined flow template f1 on port group 1.
[Sysname] link-aggregation group 1 mode manual
[Sysname] interface ethernet 1/1/2
[Sysname-Ethernet1/1/2] port link-aggregation group 1
[Sysname-Ethernet1/1/2] interface ethernet 1/1/3
[Sysname-Ethernet1/1/3] port link-aggregation group 1
[Sysname-Ethernet1/1/3] quit
[Sysname] port-group aggregation 1
[Sysname-port-group-aggregation-1] flow-template f1
2.1.4  flow-template basic
flow-template flow-template-name basic { customer-vlan-id | dip | dipv6 | dmac | dport | dscp | ethernet-protocol | fragments | icmp-code | icmp-type | icmpv6-code | icmpv6-type | ip-precdence | ip-protocol | ip-ttl | ipv6-dscp | ipv6-fragment | ipv6-protocol | mpls-exp | service-cos | service-vlan-id | sip | sipv6 | smac | sport | tcp-flag | tos } *
undo flow-template { all | name flow-template-name }
View
Default Level
2: System level
flow-template-name: Name of a user-defined flow template, a case-insensitive string of 1 to 31 characters.
customer-vlan-id: Customer VLAN ID.
dip: Destination IP address.
dipv6: Destination IPv6 address.
dmac: Destination MAC address.
dport: Destination Layer 4 port.
dscp: Differentiated service code point (DSCP) field in the IP header.
ethernet-protocol: Protocol type field in the Ethernet frame header.
fragments: Fragments field in the IP header.
icmp-code: ICMP code field.
icmp-type: ICMP type field.
icmpv6-code: IPv6 code field.
Icmpv6-type: IPv6 type field.
ip-precedence: Precedence field in the IP header.
ip-protocol: Protocol type field in the IP header.
ip-ttl: TTL value of the IPv4 packet.
ipv6-dscp: DSCP field in the IPv6 header.
ipv6-fragments: IPv6 fragments flag.
ipv6-protocol: Protocol type in the IPv6 header.
mpls-exp: EXP field in the MPLS label.
service-cos: Specifies the service provider 802.1p COS field.
service-vlan-id: Service provider VLAN ID.
sip: Source IP address.
sipv6: Source IPv6 address.
smac: Source MAC address.
sport: Source Layer 4 port.
tcp-flag: Flags field.
tos: ToS field.
all: All user-defined flow templates.
Use the flow-template basic command to create a basic user-defined flow template.
Use the undo flow-template command to remove the specified or all user-defined flow templates.
When removing templates, make sure that they are not referenced on interfaces. Otherwise, your removing attempt will fail.
# Create a basic user-defined flow template.
[Sysname] flow-template f1 basic dip smac ip-protocol tcp-flag
2.1.5  flow-template extend
flow-template flow-template-name extend { ipv4 offset-max-value length-max-value | ipv6 offset-max-value length-max-value | l2 offset-max-value length-max-value | l4 offset-max-value length-max-value | l5 offset-max-value length-max-value } *
View
Default Level
2: System level
offset-max-value: The maximum offset relative to the referential location.
length-max-value: The maximum comparing length.
all: Specifies to remove all user-defined flow templates.
Use the flow-template extend command to create an extended user-defined flow template.
# Create an extended user-defined flow template.
[Sysname] flow-template f2 extend l2 3 10 ipv4 5 8
