H3C S9500 Command Manual-Release2132[V2.03]-06 QoS ACL Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-06 QoS ACL Volume
01-QoS Commands
01-QoS Commands 297.29 KB
Table of Contents
Chapter 1 Traffic Shaping Configuration Commands. 1-1
1.1 Traffic Shaping Configuration Commands. 1-1
1.1.1 display qos gts interface. 1-1
1.1.2 qos gts. 1-2
Chapter 2 QoS Policy Configuration Commands. 2-1
2.1 Class Configuration Commands. 2-1
2.1.1 display traffic classifier user-defined. 2-1
2.1.2 if-match. 2-2
2.1.3 traffic classifier 2-6
2.2 Traffic Behavior Configuration Commands. 2-7
2.2.1 accounting. 2-7
2.2.2 car 2-8
2.2.3 display traffic behavior user-defined. 2-9
2.2.4 filter 2-10
2.2.5 nest 2-11
2.2.6 primap pre-defined. 2-12
2.2.7 primap pre-defined color 2-13
2.2.8 redirect 2-14
2.2.9 remark service-vlan-id. 2-16
2.2.10 remark dot1p. 2-16
2.2.11 remark drop-precedence. 2-17
2.2.12 remark dscp. 2-18
2.2.13 remark local-precedence. 2-19
2.2.14 traffic behavior 2-20
2.3 Policy Configuration Commands. 2-21
2.3.1 classifier behavior 2-21
2.3.2 display qos policy interface. 2-22
2.3.3 display qos policy user-defined. 2-23
2.3.4 qos apply policy. 2-25
2.3.5 qos policy. 2-26
Chapter 3 Hardware-based Congestion Management Configuration Commands. 3-1
3.1 SP Queuing Configuration Commands. 3-1
3.1.1 display qos sp interface. 3-1
3.1.2 qos sp. 3-2
3.2 WRR Queuing Configuration Commands. 3-2
3.2.1 display qos wrr interface. 3-2
3.2.2 qos wrr 3-4
3.2.3 qos wrr group. 3-4
Chapter 4 Priority Mapping Configuration Commands. 4-1
4.1 Priority Mapping Table Configuration Commands. 4-1
4.1.1 display qos map-table. 4-1
4.1.2 display qos map-table color 4-2
4.1.3 import 4-4
4.1.4 qos map-table. 4-5
4.1.5 qos map-table color 4-6
4.2 Port Priority Configuration Commands. 4-7
4.2.1 qos priority. 4-7
4.3 Port Priority Trust Mode Configuration Commands. 4-8
4.3.1 display qos trust interface. 4-8
4.3.2 qos trust dot1p. 4-9
Chapter 5 Congestion Avoidance Configuration Commands. 5-1
5.1 WRED Table Configuration Commands. 5-1
5.1.1 display qos wred interface. 5-1
5.1.2 display qos wred table. 5-2
5.1.3 qos wred apply. 5-3
5.1.4 qos wred queue table. 5-4
5.1.5 queue. 5-5
5.1.6 queue weighting-constant 5-6
Chapter 6 Aggregation CAR Configuration Commands. 6-1
6.1.1 car name. 6-1
6.1.2 display qos car name. 6-1
6.1.3 qos car aggregative. 6-2
6.1.4 reset qos car name. 6-4
Chapter 7 VLAN Policy Configuration Commands. 7-1
7.1 VLAN Policy Configuration Commands. 7-1
7.1.1 display qos vlan-policy. 7-1
7.1.2 qos vlan-policy. 7-2
7.1.3 reset qos vlan-policy. 7-3
Chapter 8 Traffic Mirroring Configuration Commands. 8-1
8.1 Traffic Mirroring Configuration Commands. 8-1
8.1.1 display qos policy user-defined. 8-1
8.1.2 display traffic behavior user-defined. 8-2
8.1.3 mirror-to cpu. 8-3
8.1.4 mirror-to interface. 8-4
Chapter 9 EACL Configuration Commands. 9-1
9.1 EACL Configuration Commands. 9-1
9.1.1 interface eacl 9-1
9.1.2 qos binding. 9-1
Chapter 10 Outbound Traffic Accounting Configuration Commands. 10-1
10.1 Outbound Traffic Accounting Configuration Commands. 10-1
10.1.1 display qos traffic-counter outbound. 10-1
10.1.2 qos traffic-counter outbound. 10-2
10.1.3 reset qos traffic-counter outbound. 10-4
View
Default Level
1: Monitor level
Use the display qos gts interface command to view parameter configuration and statistics information of generic traffic shaping (GTS) on an interface or all interfaces.
If no interface is specified, GTS configuration and statistics information of all interfaces is displayed.
# Display the GTS parameter configuration information and statistic information on all the interfaces.
Interface: Ten-GigabitEthernet6/1/1
 Rule(s): If-match any
 CIR 50000 (kbps), CBS 1600000 (byte)
 Rule(s): If-match queue 2
 CIR 40000 (kbps), CBS 2500000 (byte)
Table 1-1 Description on the fields of the display qos gts interface command
Filed
Interface name, consisting of interface type and interface number
Rule(s)
Matching rules
CIR
Committed information rate, in kbps
CBS
Committed burst size, that is, the depth of the token bucket holding burst traffic, in bytes
1.1.2  qos gts
qos gts { any | queue queue-number } cir committed-information-rate [ cbs committed-burst-size ]
undo qos gts { any | queue queue-number }
View
Ethernet interface view, port group view
Default Level
2: System level
any: Specifies to perform traffic shaping (TS) for all the IP data packets.
queue queue-number: Specifies to perform TS for data packets in a queue identified by the queue-number argument.
cir committed-information-rate: Committed information rate in kbps.
cbs committed-burst-size: Committed burst size in bytes, which must be a multiple of 4000. The default CBS is expressed in the formula MIN (cir × 62.5, 16000000), that is, the default CBS can be either CIR × 62.5 or 16000000, whichever is smaller.
&  Note:
If the cbs keyword is not specified in this command, the system calculates the CBS value using the formula MIN (cir × 62.5, 16000000). Because the CBS must be a multiple of 4000, the system tunes the calculation result of cir×62.5 automatically if the calculation result is not a multiple of 4000.
Use the qos gts command to set TS parameters for traffic of a particular class or all the traffic and start TS.
Use the undo qos gts command to cancel the TS parameters set for traffic of a particular class or all the traffics.
Use the qos gts any command to set TS parameters for all the traffics.
Use the qos gts queue command to set TS parameters for the traffic in a particular queue.
By default, a port is not configured with any TS parameter.
Related commands: acl.
&  Note:
CIR and CBS must satisfy the following formula: cbs >= cir × 62.5.
# Perform TS for all the packets on Ethernet 6/1/1. The normal traffic rate (that is, CIR) is 600 kbps, and CBS is 120000 bytes.
[Sysname] interface ethernet6/1/1
[Sysname-Ethernet6/1/1] qos gts any cir 600 cbs 120000
display traffic classifier user-defined [ tcl-name ]
View
Default Level
1: Monitor level
tcl-name: Class name.
Use the display traffic classifier user-defined command to display information about user-defined classes.
If the tcl-name argument is not specified, the information about all the user-defined classes is displayed.
# Display the information about user-defined classes.
User Defined Classifier Information:
 Classifier: USER1
  Operator: AND
  Rule(s) : if-match ip-precedence 5
 Classifier: database
  Operator: AND
  Rule(s) : if-match acl 3131
            if-match inbound-interface Ethernet4/1/1
Table 2-1 Description on the fields of the display traffic classifier user-defined command
Class type: user-defined
Classifier
Class name and the class content (of multiple types)
Operator
Logical relationship between classification rules
Rule
Classification rule
2.1.2  if-match
if-match match-criteria
undo if-match match-criteria
View
Class view
Default Level
2: System level
match-criteria: Match rules of a class. The values are as shown in Table 2-2:
Table 2-2 Values of match rules of a class
Value
acl [ ipv6 ] acl-number
Define ACL matching rules
The acl-number argument is the number of an ACL, which is in the range of 2000 to 5999 for IPv4 ACLs and in the range of 2000 to 3999 for IPv6 ACLs.
dscp dscp-list
Define DSCP matching rules
The dscp-list argument is the list of DSCP values and up to eight DSCP values can be input. The DSCP value is in the range 0 to 63.
destination-mac mac-address
Define destination MAC address matching rules
dot1p dot1p-id
Define dot1p matching rules
ip-precedence ip-precedence-list
Define IP precedence matching rules.
The ip-precedence-list argument is the list of ip-precedence values and up to eight ip precedence values can be input. The ip-precedence value is in the range of 0 to 7.
protocol protocol-name
Define protocol matching rules.
The protocol-name argument can be IP, IPv6 or bittorrent.
customer-vlan-id { vlan-id-list | vlan-id1 to vlan-id2 }
Define customer network VLAN ID matching rules.
The vlan-id-list argument is the list of VLAN IDs and up to eight VLAN IDs can be input. The vlan-id1 to vlan-id2 argument-keyword combination represents a VLAN ID range, where the vlan-id1 argument must be smaller than the vlan-id2 argument.
source-mac mac-address
Define source MAC address matching rules.
service-vlan-id { vlan-id-list | vlan-id1 to vlan-id2 }
Define service provider network VLAN ID matching rules.
mpls-exp exp-value
Define MPLS EXP field matching rules.
The EXP field value ranges from 0 to 7.
forward-level { bridge | route }
Define Layer-2/Layer-3 attribute matching rules, bridge for Layer-2 packets and route for Layer-3 packets.
ttl ttl-value
Define time to live (TTL) matching rules for IPv4 packets.
The value range for the ttl-value argument is 0 to 255.
Use the if-match command to define matching rules for packets.
Use the undo if-match command to delete the existing matching rules.
When defining the rules, take the following into consideration:
1)         Define ACL matching rules
l           If the ACL referenced in a class is not created, the matching rule cannot be applied to the hardware.
l           If the operator of a class is logical AND, only one if-match acl acl-number statement can be defined in the class. The acl-number argument ranges from 5000 to 5999.
2)         Define destination MAC address matching rules
l           The destination MAC address matching rules are only meaningful for the outbound policies on Ethernet ports.
l           For a class, you can configure multiple commands which cannot be overwritten.
3)         Define source MAC address matching rules
l           The source MAC address matching rules are only meaningful for the inbound policies on Ethernet ports.
4)         Define DSCP matching rules
l           For a class, you can configure multiple commands which cannot be overwritten. The DSCP values specified by them are automatically arranged in ascending order. Only when the specified DSCP values are identical with those in the rule (sequence may be different) can the command be deleted.
l           You may configure up to eight DSCP values in one command. If multiple DSCPs of the same value are specified, the system regards them as one. Relation between different DSCP values is “OR”.
5)         Define MPLS EXP field matching rules
The MPLS EXP field matching rules are only applicable to the ports on boards suffixed by C, CA, or CB.
If the class operator is set to and, the MPLS EXP field matching rules can be used in conjunction with only the following if-match commands:
l           if-match destination-mac
l           if-match service-vlan-id
l           if-match acl acl-number (with the acl-number argument in the range of 4000 to 4999) and the ACL rule can only be rule permit or rule permit dest-mac.
&  Note:
The DSCP value defined in the if-match dscp clause is used for matching IPv4 traffic in most cases. To use the clause to match IPv6 traffic, you need to define either the ip-match protocol ipv6 or if-match acl ipv6 clause in addition and adopt the AND operator in the class. In addition, you must ensure that the flow template applied to the port where the class is to be used contains the IPv6 DSCP field.
6)         Define IP precedence matching rules
l           When the command is configured, the IP precedence values are arranged automatically in ascending order.
l           You may configure up to eight IP precedence values in one command. If multiple IP precedences of the same value are specified, the system regards them as one. Relation between different IP precedence values is “OR”.
7)         Define customer network VLAN ID matching rules and service provider network VLAN ID matching rules
l           For a class, you can configure multiple commands which cannot be overwritten. When the command is configured, the vlan-id values are arranged automatically in ascending order. Only when the specified VLAN ID values are identical with those in the rule (sequence may be different) can the command be deleted.
l           You may configure multiple VLAN ID values in one command. If multiple VLAN IDs of the same value are specified, the system regards them as one. Relation between different VLAN IDs is “OR”.
8)         Define TTL matching rules for IPv4 packets
If the operator of the class is logical OR, a TTL matching rule for IPv4 packets cannot be configured together with any of the following statements in the class:
l           if-match protocol ipv6
l           if-match mpls-exp
l           if-match acl ipv6
Related commands: traffic classifier.
# Define a matching rule to match IP packets for class 1.
# Define a matching rule for class 1 to match packets with the destination MAC address 0050-BA27-BED3.
# Define a matching rule for class 2 to match packets with the source MAC address 0050-BA27-BED2.
[Sysname-classifier-class2] if-match source mac 0050-ba27-bed2
# Define a matching rule for class 1 to match IPv6 ACL 3101.
[Sysname-classifier-class1] if-match ipv6 acl 3101
# Define a matching rule for class 1 to match packets with IP precedence 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1 6
# Define a matching rule for class 1 to match packets with the customer VLAN ID 1, 6, or 9.
# Define a matching rule for class 1 to match Layer-2 packets.
[Sysname-classifier-class1] if-match forward-level bridge
# Define a matching rule for class 1 to match the IPv4 packets with TTL 1.
[Sysname-classifier-class1] if-match ttl 1
traffic classifier tcl-name [ operator { and | or } ]
undo traffic classifier tcl-name
View
Default Level
2: System level
and: Specifies the relationship between the rules in the class as logic AND (that is, the packet that matches all the rules belongs to this class).
or: Specifies the relationship between the rules in the class as logic OR (that is, the packet that matches any one of the rules belongs to this class).
Use the traffic classifier command to define a class and enter the class view.
Use the undo traffic classifier command to delete a class.
By default, the relationship between the rules in a class is logic AND.
Related commands: qos policy, qos apply policy, and classifier behavior.
# Define a class named class1.
2.2.1  accounting
accounting
undo accounting
View
Traffic behavior view
Default Level
2: System level
None
Use the accounting command to configure the accounting action for a traffic behavior.
Use the undo accounting command to cancel the accounting action configured for a traffic behavior.
Related commands: qos policy, traffic behavior, and classifier behavior.
# Configure the accounting action for the traffic behavior database.
[Sysname-behavior-database] accounting
2.2.2  car
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ red action ]
undo car
View
Default Level
2: System level
cbs committed-burst-size: Committed burst size in bytes, number of bits that can be sent at each interval. By default, the CBS is MAX (cir × 62.5, 1875), which means that the CBS could be either CIR × 62.5 or 1875, whichever is greater.
ebs excess-burst-size: Excessive burst size in bytes. It defaults to 0.
pir peak information rate: Peak information rate in kbps. It defaults to 0.
red action: Action to take on packets when the traffic rate neither conforms to the CIR nor conforms to the PIR. By default, the action of red is discard.
The action argument can be:
l           discard: Drops the packets.
l           pass: Allows the packets to pass through.
Use the car command to configure traffic policing for the current traffic behavior.
Use the undo car command to remove the traffic policing action from the traffic behavior.
The traffic policing action you configured can overwrite the previous traffic policing configuration of the traffic behavior, if any.
Related commands: qos policy, traffic behavior, classifier behavior.
&  Note:
CIR, CBS, EBS, and PIR must satisfy the following formulas:
l      cbs >= cir × 62.5
l      ebs >= pir × 50 ms
l      pir >= cir
# Configure traffic policing for traffic behavior database, setting CIR to 200 kbps, CBS to 50000 bytes, and action to dropping packets when the traffic rate exceeds 200 kbps.
[Sysname-behavior-database] car cir 200 cbs 50000 red discard
display traffic behavior user-defined [ behavior-name ]
View
Default Level
1: Monitor level
behavior-name: User-defined traffic behavior name. If it is not specified, the information of all the traffic behaviors is displayed.
Use the display traffic behavior command to display the information of the specific user-defined traffic behavior.
# Display information of all the user-defined traffic behaviors.
  User Defined Behavior Information:
    Behavior: test1
      Accounting Enable
      Committed Access Rate:
        CIR 20000 (kbps), CBS 300000 (byte), EBS 100 (byte), PIR 25000 (kbps)
        Red Action: discard
      Filter enable : permit
      Marking:
        Remark dot1p COS 2
    Behavior: test2
      Accounting Enable
        CIR 10000 (kbps), CBS 250000 (byte), EBS 100 (byte), PIR 25000 (kbps)
        Red Action: discard
      Filter enable : deny
      Marking:
        Remark dot1p COS 2
Table 2-3 Description on the fields of the display traffic behavior user-defined command
Behavior type: user-defined
Behavior
Behavior name and the behavior content (of multiple types)
Accounting enable
The accounting action is enabled for the traffic behavior
Information about rate limiting
Red Action
Action conducted to packets nonconforming to CIR
Filter enable
The traffic filtering action is configure for the traffic behavior
Marking
Information about priority marking
2.2.4  filter
filter { deny | permit }
undo filter
View
Default Level
2: System level
deny: Discards the packet.
permit: Transmits the packet.
Use the filter command to configure the traffic filtering action for a traffic behavior.
Use the undo filter command to cancel the traffic filtering action configured for a traffic behavior.
# Configure the traffic filtering action for the traffic behavior database.
2.2.5  nest
nest top-most vlan-id vlan-id-value
undo nest
View
Default Level
2: System level
vlan-id-value: VLAN ID of the outer VLAN tag.
Use the nest command to configure the action of creating an outer VLAN tag for a traffic behavior.
Use the undo nest command to cancel the action of creating an outer VLAN tag configured for the traffic behavior.
Note that:
l           A policy configured with the action of creating an outer VLAN tag can be applied to only the ingress direction of an interface.
l           If this command is executed multiple times, the new command overwrites the previous one.
# Configure the action of creating outer VLAN tag 657 for traffic behavior be1.
[Sysname-behavior-be1] nest top-most vlan-id 657
primap pre-defined { dscp-lp | dscp-dp | dscp-dot1p | dscp-dscp }
undo primap pre-defined { dscp-lp | dscp-dp | dscp-dot1p | dscp-dscp }
View
Default Level
2: System level
dscp-lp: DSCP-to-local-precedence mapping table.
dscp-dp: DSCP-to-drop-precedence mapping table.
dscp-dot1p: DSCP-to-802.1p-precedence mapping table.
dscp-dscp: DSCP-to-DSCP mapping table.
Use the primap pre-defined command to configure the action of obtaining other precedence values through the corresponding priority mapping table for a traffic behavior.
Use the undo primap pre-defined command to cancel the action.
&  Note:
All the priority mapping tables related to DSCP apply to EXP. That is, dsp-lp mappings are also used as exp-lp mappings; dscp-dscp mappings are also used as dscp-exp, exp-dscp, and exp-exp mappings. For MPLS packets, the priority mappings from EXP to other types of precedence apply; for non-MPLS packets, the priority mappings from DSCP to other types of precedence apply.
Related commands: display qos map-table.
# Obtain the local precedence values for packets through the DSCP-to-local-precedence mapping table.
[Sysname-behavior-behavior1] primap pre-defined dscp-dp
primap pre-defined color { dscp-dot1p | dscp-dp | dscp-dscp | dscp-lp | lp-dot1p | lp-dp | lp-dscp | lp-lp }
undo primap pre-defined color { dscp-dot1p | dscp-dp | dscp-dscp | dscp-lp | lp-dot1p | lp-dp | lp-dscp | lp-lp }
View
Default Level
2: System level
dscp-dscp: DSCP-to-DSCP-precedence mapping table.
lp-dot1p: Local-to-802.1p-precedence mapping table.
lp-dp: Local-to-drop-precedence mapping table.
lp-dscp: Local-to-DSCP-precedence mapping table.
lp-lp: Local-to-local-precedence mapping table.
Use the primap pre-defined color command to configure the action of precedence mapping based on the specified colored priority mapping table.
Use the undo primap pre-defined color command to remove the configured action.
&  Note:
l      All the priority mapping tables related to DSCP apply to EXP. That is, dsp-lp mappings are also used as exp-lp mappings; dscp-dscp mappings are also used as dscp-exp, exp-dscp, and exp-exp mappings. For MPLS packets, the priority mappings from EXP to other types of precedence apply; for non-MPLS packets, the priority mappings from DSCP to other types of precedence apply. For the description on the EXP field in MPLS packets, refer to the section talking about implementing QoS in an MPLS network in QoS Configuration.
l      A colored priority mapping table must be used in conjunction with the car command.
Related commands: display qos map-table color.
# Use the colored dscp-dp mapping table to obtain drop precedence values for packets.
[Sysname-behavior-behavior1] car cir 1600
[Sysname-behavior-behavior1] primap pre-defined color dscp-dp
2.2.8  redirect
redirect { cpu | interface interface-type interface-number | link-aggregation group group-id | next-hop { ipv4-add [ ipv4-add ] | ipv6-add [ interface-type interface-number ] [ ipv6-add [ interface-type interface-number ] ] } }
undo redirect
View
Default Level
2: System level
cpu: Redirects traffic to CPU.
interface: Redirects traffic to specified interface.
next-hop: Redirects traffic to the next hop.
link-aggregation: Redirects traffic to a link aggregation group.
ipv4-add: Next hop IPv4 address.
ipv6-add: Next hop IPv6 address. If the IPv6 address is a link-local address, specify an interface for the next hop IPv6 address; otherwise, you do not need to do so.
group group-id: Group number of an existing link aggregation group.
User the redirect command to configure the traffic redirecting action for a traffic behavior.
User the undo redirect command to cancel the traffic redirecting action configured for a traffic behavior.
  Caution:
l      When the traffic redirecting action is configured, if the outgoing interface to be redirected to is bound to an NAT virtual interface, packets sent from this outgoing interface are redirected to the L3+NAT card, thus resulting in traffic redirecting failure.
l      The policy routing function can be implemented through configuring the action of redirecting traffic to the next hop.
l      Two next hop addresses can be configured for the action of redirecting traffic to the next hop, with one address being the primary next hop address and the other being the secondary next hop address. The traffic is redirected to the primary next hop address if the primary next hop address exists; otherwise, the traffic is redirected to the secondary next hop address.
l      The device can only operate as follows: with the traffic redirected to the next hop address, if neither the primary next hop address nor the secondary next hop address exists, the device drops these packets.
# Configure the action of redirecting traffic to CPU for the traffic behavior database.
[Sysname-behavior-database] redirect cpu
remark service-vlan-id vlan-id-value
undo remark service-vlan-id
View
Default Level
2: System level
vlan-id-value: Service provider network VLAN ID of the packets.
Use the remark service-vlan-id command to configure the action of marking the service provider network VLAN ID of the packets for a traffic behavior.
Use the undo remark atm-clp command to cancel the action of marking the service provider network VLAN ID of the packets configured for a traffic behavior.
# Mark the packets with the service provider network VLAN ID 2.
[Sysname-behavior-database] remark service-vlan-id 2
2.2.10  remark dot1p
remark dot1p 8021p
undo remark dot1p
View
Default Level
2: System level
8021p: 802.1p priority value to be marked.
Use the remark dot1p command to configure the 802.1p priority value of the remarked packet.
Use the undo remark dot1p command to remove the 802.1p priority value from the remarked packet.
# Set the 802.1p priority value of the remarked packet to 2.
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence drop-precedence-value
undo remark drop-precedence
View
Default Level
2: System level
drop-precedence-value: Drop precedence value to be marked.
Use the remark drop-precedence command to configure the action of marking the drop precedence of packets.
Use the undo remark drop-precedence command to cancel the action of marking the drop precedence of packets.
# Mark the packets with drop precedence 2.
[Sysname-behavior-database] remark drop-precedence 2
2.2.12  remark dscp
remark dscp dscp-value
undo remark dscp
View
Default Level
2: System level
dscp-value: DSCP value, in the range of 0 to 63 (decimal), which can be any of these keywords as follows:
Table 2-4 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
Use the remark dscp command to set a remarked DSCP value for IP packets belonging to the class.
Use the undo remark dscp command to disable DSCP remark.
  Caution:
The remark dscp command applies to both DSCP and EXP. The EXP field is the low-order three bits in the dscp-value argument (binary). For the description on the EXP field in MPLS packets, refer to the part discussing implementing QoS in an MPLS network in QoS Configuration.
# Remark the DSCP of the IP packets belonging to the class to 6.
remark local-precedence local-precedence
undo remark local-precedence
View
Default Level
2: System level
local-precedence: Local precedence value to be marked.
Use the remark local-precedence command to configure the action of marking the local precedence of packets.
Use the undo remark local-precedence command to cancel the action of marking the local precedence of packets.
# Mark packets with the local precedence 2.
View
Default Level
2: System level
behavior-name: Behavior name.
Use the traffic behavior command to define a traffic behavior and enter the behavior view.
Use the undo traffic behavior command to delete a traffic behavior.
Related commands: qos policy, qos apply policy, classifier behavior.
# Define a traffic behavior named behavior1.
classifier tcl-name behavior behavior-name
undo classifier tcl-name
View
Policy view
Default Level
2: System level
tcl-name: Name of a class.
behavior–name: Name of a traffic behavior.
Use the classifier behavior command to specify the behavior for the class in the policy.
Use the undo classifier command to remove the application of the class in the policy.
Each class in the policy can only be associated with one behavior.
Related commands: qos policy.
# Specify the behavior test for the class database in the policy user1.
[Sysname] qos policy user1
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
View
Default Level
1: Monitor level
inbound: Inbound direction.
outbound: Outbound direction.
Use the display qos policy interface command to view the configuration and operating state about the policy on the specified interface.
# Display the configuration and operating state about the policy on Ethernet 4/1/1.
<Sysname> display qos policy interface ethernet 4/1/1
  Interface: Ethernet4/1/1
  Direction: Inbound
  Policy: test1
   Classifier: cl1
     Operator: AND
     Rule(s) : If-match acl 2345
     Behavior: be1
        CIR 10 (kbps), CBS 10000 (byte), EBS 0 (byte)
        Red Action: discard
        Green : 0(Bytes)
        Yellow: 0(Bytes)
        Red   : 0(Bytes)
Table 2-5 Description on the fields of the display qos policy interface command
Direction
Specifies the direction that the policy is applied to the interface.
Policy
Name of the policy applied to the interface
Classifier
Classification rules and corresponding configurations in the policy
Operator
Rule(s)
Classification rules of class
Behavior
Name and configuration information of the behavior. Refer to related command of behavior.
CIR
CBS
Committed burst size, i.e. the depth of the token bucket holding burst traffic, in bytes
EBS
Excess burst size, in bytes
Red
Traffic statistics information about red traffic
Green
Traffic statistics information about green traffic
Yellow
Traffic statistics information about yellow traffic
display qos policy user-defined [ policy-name [ classifier tcl-name ] ]
View
Default Level
1: Monitor level
policy-name: Policy name. If no policy is specified, the configurations of all user-defined policies are displayed.
tcl-name: Class name in the policy.
Use the display qos policy command to display the configurations of the specified or all classes and their associated behaviors in the specified or all user-defined policies.
# Display the configurations of all user-defined policies.
  User Defined QoS Policy Information:
  Policy: default
  Policy: user1
   Classifier: class1
     Behavior: test
      Accounting Enable
        Red Action: discard
      Marking:
        Remark dot1p COS 2
Table 2-6 Description on the fields of the display qos policy user-defined command
Policy
Policy name
Classifier
Class name. A policy may contain multiple classes, each corresponding to a behavior and multiple matching rules. For details, refer to the traffic classifier command.
Behavior
The behavior in the class. Each behavior can have multiple matching rules. For details, refer to the traffic behavior command.
Accounting enable
The traffic accounting action is configured for the traffic behavior.
Red Action
Action taken on red packets which are nonconforming to CIR
Filter enable
The traffic filtering action is configured for the traffic behavior.
Marking
undo qos apply policy { inbound | outbound }
View
Interface view, port group view, EACL service sub-interface view
Default Level
2: System level
Use the qos apply policy command to apply associated policy to the interface.
Use the undo qos apply policy command to delete the associated policy from the interface.
Note that:
l           To successfully apply the policy to the interface, you must make sure that the sum of bandwidth specified for the AF and EF classes in the policy is smaller than the available bandwidth of the interface. You can modify the available bandwidth of the current interface. If the sum of their bandwidth still exceeds that modified value, the policy will be deleted.
l           For a policy to be applied in the inbound direction, it cannot contain classes associated with traffic behaviors specified using gts.
l           Configured in interface view, the setting is effective on the current interface only; configured in port group view, the setting is effective on all the ports in the port group.
l           A policy can be applied only in the outbound direction in EACL service sub-interface view.
# Apply the policy USER1 in the outbound direction of Ethernet 1/1/1.
[Sysname] interface ethernet1/1/1
[Sysname-Ethernet1/1/1] qos apply policy USER1 outbound
2.3.5  qos policy
qos policy policy-name
undo qos policy policy-name
View
Default Level
2: System level
policy policy-name: Policy name.
Use the qos policy command to define a policy and enter policy view.
Use the undo qos policy command to delete a policy.
The policy cannot be deleted if it is applied on an interface. It is necessary to remove application of the policy on the current interface before deleting it via the undo qos policy command.
Related commands: classifier behavior, qos apply policy.
# Define a policy named user1 and enter policy view.
display qos sp interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
interface-type: Interface type.
interface-number: Interface number.
Use the display qos sp interface command to display the strict priority (SP) queuing configuration on an interface.
If no interface is specified, the SP queuing configuration information on all the interfaces is displayed.
Related commands: qos sp.
# Display the SP queuing configuration information on Ethernet 1/1/1/.
<Sysname> display qos sp interface ethernet 1/1/1
Output queue: Strict-priority queue
Table 3-1 Description on the fields of the display qos sp interface command
Output queue
Type of the current output queue
Adopt the SP queuing mechanism for queue scheduling
3.1.2  qos sp
qos sp
undo qos sp
View
Default Level
2: System level
None
Use the qos sp command to configure SP queuing on a port.
Use the undo qos sp command to restore the default queuing algorithm on the port.
Related commands: display qos sp interface.
# Adopt SP queuing for queue scheduling on Ethernet 6/1/1.
[Sysname-Ethernet6/1/1] qos sp
display qos wrr interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display qos wrr interface command to display the weighted round robin (WRR) queuing configuration on an interface.
If no interface is specified, the WRR queuing configuration on all the interfaces is displayed.
Related commands: qos wrr.
# Display the WRR queuing configuration information on Ethernet 6/1/1.
<Sysname> display qos wrr interface ethernet 6/1/1
Interface: Ethernet6/1/1
Output queue:   Weighted round robin queue
Queue ID    Group   Weight
0                2       100
1                1       1
2                1       1
3                1       1
4                1       1
5                1       1
6                1       1
7                1       1
Table 3-2 Description on the fields of the display qos wrr interface command
Interface name consisting of interface type and interface number.
Output queue
Queue ID
Queue ID
Group
ID of the group that the current queue belongs to
By default, all the queues belong to group 1.
Weight
Weight of a queue during queue scheduling
3.2.2  qos wrr
qos wrr
undo qos wrr
View
Default Level
2: System level
None
Use the qos wrr command to enable WRR queuing on a port.
Use the undo qos wrr command to disable WRR queuing on a port.
Before configuring WRR, make sure that you have used the qos wrr command to enable WRR queuing on a port.
# Enable WRR queuing on Ethernet 1/1/1.
[Sysname-Ethernet1/1/1] qos wrr
3.2.3  qos wrr group
qos wrr queue-id group { { 1 | 2 } weight schedule-value | sp }
undo qos wrr
View
Default Level
2: System level
queue-id: Queue ID, in the range of 0 to 7.
1 | 2 : Specifies the WRR priority group a queue belongs to. The group 1 keyword indicates that a queue belongs to WRR priority group 1, and the group 2 keyword indicates that a queue belongs to WRR priority group 2.
sp: Indicates that the queue belongs to WRR priority group 0 (that is, the SP queue).
weight: Indicates that the weight of a queue is calculated based on the queue length.
schedule-value: Scheduling weight value of a queue.
Use the qos wrr group command to configure or modify WRR queuing parameters.
Use the undo qos wrr command to restore the default queuing algorithm on the port.
Note that:
l           Before executing this command, enable WRR queuing on the port.
Related commands: display qos wrr interface.
# Enable the WRR queue scheduling algorithm on Ethernet 1/1/1, set the scheduling weight value of queue 0 to 100, and allocate queue 0 to group 1.
[Sysname-Ethernet1/1/1] qos wrr 0 group 1 weight 100
display qos map-table [ dot1p-dp | dot1p-lp | dot1p-rpr | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-exp | exp-lp | exp-rpr | ippre-rpr ]
View
Default Level
1: Monitor level
dot1p-dp: 802.1p-to-drop-precedence mapping table.
dot1p-lp: 802.1p-to-local-precedence mapping table.
dot1p-rpr: 802.1p-to-RPR-precedence mapping table.
dscp-exp: DSCP-to-EXP-precedence mapping table.
exp-dot1p: EXP-to-802.1p-precedence mapping table.
exp-dp: EXP-to-drop-precedence mapping table.
exp-exp: EXP-to-EXP-precedence mapping table.
exp-lp: EXP-to-local-precedence mapping table.
exp-rpr: EXP-to-RPR-precedence mapping table.
ippre-rpr: IP-precedence-to-RPR-precedence mapping table.
Use the display qos map-table command to display the configuration of a specific priority mapping table.
If the table type is not specified, the configuration information of all mapping tables is displayed.
Related commands: qos map-table.
# Display the configuration information of the 802.1p-precedence-to-drop-precedence mapping table.
<Sysname> display qos map-table dot1p-dp
MAP-TABLE NAME: dot1p-dp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    0
   1    :    0
   2    :    0
   3    :    0
   4    :    0
   5    :    0
   6    :    0
   7    :    0
Table 4-1 Description on the fields of the display qos map-table command
MAP-TABLE NAME
Name of the mapping table
TYPE
Type of the mapping table
IMPORT
Source precedence
EXPORT
Target precedence
display qos map-table color [ green | yellow | red ] [ dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-exp | exp-lp | lp-dot1p | lp-dp | lp-dscp | lp-exp | lp-lp ]
View
Default Level
1: Monitor level
green: Represents green packets.
yellow: Represents yellow packets.
red: Represents red packets.
dscp-dot1p: DSCP-to- 802.1p-precedence mapping table.
dscp-dp: DSCP-to- drop-precedence mapping table.
dscp-dscp: DSCP-to- DSCP-precedence mapping table.
dscp-exp DSCP-to- EXP-precedence mapping table.
dscp-lp: DSCP-to- local-precedence mapping table.
exp-dot1p: EXP-to- 802.1p-precedence mapping table.
exp-dp: EXP-to- drop-precedence mapping table.
exp-exp: EXP-to- EXP-precedence mapping table.
exp-lp: EXP-to- local-precedence mapping table.
lp-dot1p: Local-to- 802.1p-precedence mapping table.
lp-dp: Local-to- drop-precedence mapping table.
lp-dscp: Local-to- DSCP-precedence mapping table.
lp-exp: Local-to- EXP-precedence mapping table.
lp-lp: Local-to- local-precedence mapping table.
Use the display qos map-table color command to display the configuration of one or all colored priority mapping tables.
If no table is specified, the configurations of all the colored mapping tables is displayed. If no color is specified, the configuration of the mapping tables for all the colors is displayed.
# Display the configuration of the exp-lp mapping table for green packets.
<Sysname> display qos map-table color green exp-lp
MAP-TABLE NAME: exp-lp   TYPE: pre-define   COLOR: green
IMPORT  :  EXPORT
   0    :    0
   1    :    1
   2    :    2
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
Table 4-2 Description on the fields of the display qos map-table color command
MAP-TABLE NAME
Mapping table name
TYPE
Mapping table type
COLOR
Mapping table color
IMPORT
Source precedence
EXPORT
Target precedence
4.1.3  import
View
Priority mapping table view
Default Level
2: System level
import-value-list: Input parameters of a mapping table. Up to seven values can be input for a mapping table.
export-value: Output parameters of a mapping table.
all: Deletes all parameters in the mapping table.
Use the import command to configure the parameters in the specified priority mapping table to define a mapping rule or a group of mapping rules.
Use the undo import command to remove the values in the specified mapping entries and restore the default for the entries.
Related commands: display qos map-table, display qos map-table color.
# Configure the parameters in the dot1p-dp mapping table, with both 802.1p precedences 4 and 5 mapped to drop precedence 1.
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
4.1.4  qos map-table
qos map-table { dot1p-dp | dot1p-lp | dot1p-rpr | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-exp | exp-lp | exp-rpr | ippre-rpr }
View
Default Level
2: System level
dot1p-dp: 802.1p-precedence-to-drop-precedence mapping table.
dot1p-lp: 802.1p-precedence-to-local-precedence mapping table.
dot1p-rpr: 802.1p-precedence-to-RPR-precedence mapping table.
Use the qos map-table command to enter the specified priority mapping table view.
# Enter dot1p-dp mapping table view.
qos map-table color { green | yellow | red } { dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-exp | exp-lp | lp-dot1p | lp-dp | lp-dscp | lp-exp | lp-lp }
View
Default Level
2: System level
green: Green packets.
yellow: Yellow packets.
red: Red packets.
lp-exp: Local-to-EXP-precedence mapping table.
Use the qos map-table color command to enter the specified priority mapping table view.
# Enter green EXP-to-local-precedence mapping table view.
[Sysname] qos map-table color green exp-lp
[Sysname-maptbl-green-exp-lp]
4.2.1  qos priority
qos priority priority-value
undo qos priority
View
Default Level
2: System level
priority-value: Port priority value.
Use the qos priority command to configure the port priority of the current port.
Use the undo qos priority command to restore the default port priority of the current port.
The default priority of a port is 0.
Configured in Ethernet interface view, the setting is effective on the current port only; configured in port group view, the setting is effective on all the ports in the port group.
&  Note:
If the priority of a port is trusted, the device assigns a local precedence to each packet received on the port based on the port priority regardless of whether the packet carries a VLAN tag or not.
# Set the port priority of Ethernet 1/1/1 to 2.
[Sysname] interface ethernet 1/1/1
[Sysname-Ethernet1/1/1] qos priority 2
View
Default Level
1: Monitor level
Use the display qos trust interface command to display the information about the port priority trust mode of a port.
If no port is specified, the port priority trust mode information of all the ports is displayed.
# Display the information about the port priority trust mode of Ethernet 1/1/1/.
<Sysname> display qos trust interface ethernet 1/1/1
Interface: Ethernet1/1/1
Port priority trust information
Port priority :0
Port priority trust type :  dot1p
Table 4-3 Description on the fields of the display qos trust interface command
Port priority
Port priority
Port priority trust mode
qos trust dot1p
undo qos trust
View
Default Level
2: System level
None
Use the qos trust dot1p command to set to trust 802.1p precedence on a port.
Use the undo qos trust dot1p command to restore the default.
By default, port priority is trusted on Ethernet ports.
# Configure to trust the 802.1p precedence carried in packets on Ethernet 1/1/1.
[Sysname-Ethernet1/1/1] qos trust dot1p
View
Default Level
1: Monitor level
Use the display qos wred interface command to view weighed random early detection (WRED) configuration and statistics information of an interface.
If no interface is specified, WRED table configuration and statistics information of all interfaces is displayed.
# Display WRED table configuration and statistics information of Ethernet 1/1/1.
<Sysname> display qos wred interface ethernet 1/1/1
 Current WRED configuration:
 Applied WRED table name: table1
Table 5-1 Description on the fields of the display qos wred interface command
Current WRED configuration, that is, the applied WRED table
display qos wred table [ table-name ]
View
Default Level
1: Monitor level
table-name: Name of the WRED table to be displayed.
Use the display qos wred table command to display the configuration information about a specific WRED table.
If no WRED table name is specified, the configuration information about all the WRED tables is displayed.
# Display the configuration information about all the tables of the switch.
<Sysname> display qos wred table
Table Name: zhou
Table Type: Queue based WRED
QID:  gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent
 0    76    134     1    33     66     1    11     23     1      9
 1    85    143     1    37     75     1    13     27     1      9
 2    95    153     1    42     85     1    16     32     1      9
 3   104    162     1    47     94     1    18     37     1      9
 4   114    172     1    52    104     1    21     42     1      9
 5   124    182     1    57    114     1    23     47     1      9
 6   133    191     1    61    123     1    25     51     1      9
 7   143    201     1    66    133     1    28     56     1      9
Table Name: table1
 2    15     50   100    15     50   100    15     50   100      9
 3   104    162     1    47     94     1    18     37     1      3
Table 5-2 Description on the fields of the display qos wred table command
Table name
WRED table name
Table type
WRED table type
QID
Queue ID
gmin
Lower threshold for green packets
gmax
Upper threshold for green packets
gprob
Maximum drop probability for green packets
ymin
Lower threshold for yellow packets
ymax
Upper threshold for yellow packets
yprob
Maximum drop probability for yellow packets
rmin
Lower threshold for red packets
rmax
Upper threshold for red packets
rprob
Maximum drop probability for red packets
exponent
Exponent used for calculating average queue length
qos wred apply table-name
undo qos wred apply
View
Default Level
2: System level
table-name: Global WRED table name.
Use the qos wred apply command to apply a global WRED table to the current port or ports.
Use the undo qos wred apply command to restore the default drop mode (tail drop) and remove the WRED table application.
By default, a port adopts tail drop.
Related commands: display qos wred interface, display qos wred table, qos wred queue table.
Example
# Apply the queue-based WRED table queue-table1 to Ethernet 1/1/1.
[Sysname-Ethernet1/1/1] qos wred apply queue-table1
undo qos wred table table-name
View
Default Level
2: System level
table-name: WRED table name.
Use the qos wred queue table command to create a WRED table and enter WRED table view.
Use the undo qos wred table command to delete the global WRED table.
By default, no global WRED table exists.
A WRED table being used cannot be deleted.
Related commands: qos wred apply, display qos wred interface.
# Create a queue-based WRED table table1.
[Sysname] qos wred queue table table1
[Sysname-wred-table-table1]
5.1.5  queue
queue queue-value [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-value | all }
View
WRED table view
Default Level
2: System level
queue-value: Queue ID.
drop-level drop-level: Drop level. If the drop-level drop-level keyword-argument combination is not specified, the parameters configured subsequently apply to packets of all drop levels in the specific queue. If specified, the parameters apply to packets at the specific drop level.
low-limit low-limit: Lower threshold for the priority WRED table.
high-limit high-limit: Upper threshold for the priority WRED table.
discard-probability discard-prob: Denominator of drop probability. Each drop level has an independent drop probability denominator. The discard-prob argument is 1 for packets at drop level 0, 2 for packets at drop level 1, and 3 for packets at drop level 2.
Use the queue command to edit the content of the queue-based WRED table.
Use the undo queue command to restore the content of the WRED table to the default.
By default, a global queue-based WRED table has a set of applicable default parameters.
Related commands: qos wred queue table.
# Modify the drop parameter for packets of drop level 1 in queue 1 of the global queue-based WRED table queue-table1.
[Sysname-wred-table-queue-table1]
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 10
queue queue-value weighting-constant exponent
undo queue queue-value weighting-constant
View
WRED table view
Default Level
2: System level
exponent: Exponent used for calculating the average queue length. This argument defaults to 9.
Use the queue weighting-constant command to set the exponent used for calculating the average queue length for a queue-based WRED table.
Use the undo queue weighting-constant command to restore the default value.
# Set the exponent used for calculating the average queue length to 6 for the queue-based WRED table queue-table1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
6.1.1  car name
car name car-name
undo car
View
Default Level
2: System level
name car-name: Name of an aggregation CAR.
Use the car name car-name command to configure an aggregation CAR action for a traffic behavior.
Use the undo car command to remove the traffic policing action of a traffic behavior.
# Configure the aggregation CAR action aggcar-1 for the traffic behavior be1.
View
Default Level
1: Monitor level
Use the display qos car name command to display the configurations and statistics about the specific aggregation CAR. If no CAR is specified, the configuration and statistics about all aggregation CARs are displayed.
# Display the configuration information of aggregation CAR aggcar-1.
<Sysname> display qos car name aggcar-1
  Mode: aggregative
  CIR 100(kbps)  CBS: 10000(byte)  EBS: 100000(byte)
  Red Action: discard
  Green packet 2300(Bytes)
  Yellow packet 0(Bytes)
  Red packet 4500(Bytes)
Table 6-1 Description on the fields of the display qos car name command
Name of the traffic policing action
Mode: aggregative
Type of the traffic policing action
Traffic policing parameters
Red Action: discard
Action conducted to red packets
Green packet
Action conducted to green packets
Yellow packet
Traffic statistics about yellow packets
Red packet
Traffic statistics about red packets
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peek-information-rate ] [ red action ]
undo qos car car-name
View
Default Level
2: System level
aggregative: Specifies that the global CAR is aggregative. Only aggregation CAR is supported currently.
cir committed-information-rate: Committed information rate (CIR) in kbps.
cbs committed-burst-size: Committed burst size in bytes, that is, the burst traffic transmitted when the actual average rate is smaller than CIR. The default CBS value is expressed in the formula MAX (cir × 62.5, 1875), that is, the default CBS could be either CIR × 62.5 or 1875, whichever is greater.
ebs excess-burst-size: Excess burst size in bytes. The default is 0.
pir peak-information-rate: Peak information rate in kbps. The default is 0.
red action: Specifies the action conducted for red packets, which are packets that do not conform to CIR.
l           pass: Permits the packets to pass through.
Use the qos car aggregative command to configure an aggregation CAR.
Use the undo qos car aggregative command to cancel the aggregation CAR configuration.
An aggregation CAR takes effect after it is applied to an interface or it is referenced in a policy.
&  Note:
l      cbs ≥ cir × 62.5
l      ebs ≥ pir × 50 ms
l      pir ≥ cir
# Configure CAR parameters for an aggregation CAR, setting CIR to 200 kbps, CBS to 2000 bytes, and the action for red packets to discard.
[Sysname] qos car aggcar-1 aggregative cir 200 cbs 2000 red discard
View
Default Level
2: System level
car-name: Name of an aggregation CAR. If this argument is not specified, this command clears the statistics about all the aggregation CARs.
Use the reset qos car name command to clear the statistics about the specific aggregation CAR.
# Clear the statistics about the aggregation CAR aggcar-1.
<Sysname> reset qos car name aggcar-1
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ slot slot-id ]
View
Default Level
1: Monitor level
name policy-name: Specifies to display the information about the VLAN policy identified by the policy-name argument.
vlan vlan-id: Specifies to display VLAN policies applied to the VLAN identified by the vlan-id argument.
slot slot-id: Specifies to display the information about the VLAN policies applied to VLANs on the board residing in the specific slot. If this argument is not specified, the information about VLAN policies applied to the SRPU is displayed; if this argument is specified, the information about VLAN policies applied to the specific board is displayed.
Use the display qos vlan-policy command to display the information about a specific VLAN policy.
# Display the information about VLAN policy test.
<Sysname> display qos vlan-policy name test
Policy test
    Vlan 34: inbound (active)
    Vlan 38: inbound (active)
Table 7-1 Description on the fields of the display qos vlan-policy command
Policy test
Name of the QoS policy
Vlan 34
ID of the VLAN referencing the QoS policy
Inbound (active)
Apply the QoS policy to the incoming packets of the VLAN
The active field indicates that the VLAN policy is active.
undo qos vlan-policy vlan vlan-id-list { inbound | outbound }
View
Default Level
2: System level
vlan-id-list: VLAN ID list, which may be expressed in the form of vlan-id to vlan-id. The vlan-id argument is the ID of a VLAN. You can input multiple discontinuous VLAN IDs. For S9500 series routing switches, up to eight VLAN IDs can be input.
inbound: Applies the QoS policy to the incoming packets of the specific VLANs.
outbound: Applies the QoS policy to the outgoing packets of the specific VLANs. Currently, this keyword is used only for EACL.
Use the qos vlan-policy command to apply the QoS policy to the specific VLANs.
Use the undo qos vlan-policy command to cancel the QoS policy applied to the specific VLANs.
A QoS policy can be applied in the following two ways:
l           Port-based application: a QoS policy is applied to the incoming packets or outgoing packets of a port.
l           VLAN-based application: a QoS policy is applied to all the traffic of a VLAN.
A QoS policy applied to all the traffic of a VLAN is also known as a VLAN policy.
# Apply the VLAN policy test to the incoming packets of VLAN 200, VLAN 300, VLAN 400, VLAN 500, VLAN 600, VLAN 700, VLAN 800, and VLAN 900.
[Sysname] qos vlan-policy test vlan 200 300 400 500 600 700 800 900 inbound
reset qos vlan-policy [ vlan vlan-id ]
View
Default Level
2: System level
vlan-id: ID of a VLAN.
Use the reset qos vlan-policy command to clear the statistics information about the VLAN policies applied to a VLAN.
# Clear the statistics information about the VLAN policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
View
Default Level
1: Monitor level
tcl-name: Traffic classification rule name in a policy.
Use the display qos policy user-defined command to display the configuration information about a user-defined policy.
# Display the configuration information about the user-defined QoS policy test.
<Sysname> display qos policy user-defined test
  Policy: test
   Classifier: test
     Behavior: test
      Mirror enable:
        Mirror type: interface
        Mirror destination: Ethernet3/1/1
Table 8-1 Description on the fields of the display qos policy user-defined command
Policy
QoS policy name
Classifier
Behavior
Traffic behavior name
Mirror enable
Traffic mirroring is enabled
Mirror type
Traffic mirroring type
Mirror destination
Destination of traffic mirroring
View
Default Level
1: Monitor level
behavior-name: Traffic behavior name.
Use the display traffic behavior user-defined command to display the configuration information about a user-defined traffic behavior.
# Display the configuration information about the user-defined traffic behavior test.
<Sysname> display traffic behavior user-defined test
    Behavior: test
      Mirror enable:
Table 8-2 Description on the fields of the display traffic behavior user-defined command
Behavior
Mirror enable
Mirror type
Mirror destination
8.1.3  mirror-to cpu
mirror-to cpu
undo mirror-to cpu
View
Default Level
2: System level
cpu: Mirrors traffic to the CPU.
Use the mirror-to cpu command to configure the action of mirroring traffic to the CPU for a traffic behavior.
Use the undo mirror-to cpu command to cancel the action of mirroring traffic to the CPU for a traffic behavior.
By default, the action of mirroring traffic to the CPU is not configured for a traffic behavior.
In a traffic behavior, the action of mirroring traffic to a port is mutually exclusive with the action of mirroring traffic to the CPU.
# Configure the action of mirroring traffic to the CPU for the traffic behavior test.
[Sysname] traffic behavior test
[Sysname-behavior-test] mirror-to cpu
mirror-to interface interface-type interface-number
undo mirror-to interface interface-type interface-number
View
Default Level
2: System level
interface-type interface-number: Type and number of the destination interface of traffic mirroring.
Use the mirror-to interface command to configure the action of mirroring traffic to a specific port for a traffic behavior.
Use the undo mirror-to interface command to cancel the action of mirroring traffic to a specific port configured for a traffic behavior.
By default, the action of mirroring traffic to a specific port is not configured for a traffic behavior.
Note that:
l           In a traffic behavior, the action of mirroring traffic to a port is mutually exclusive with the action of mirroring traffic to the CPU.
l           If this command is executed multiple times, the new command overwrites the previous command.
# Configure the action of mirroring traffic to Ethernet 1/1/1 for the traffic behavior test.
[Sysname-behavior-test] mirror-to interface ethernet 1/1/1
interface eacl interface-number
View
Default Level
2: System level
Use the interface eacl command to enter EACL service subinterface view.
Currently, only the LSB1NAMB boards of S9500 series support EACL service subinterface view.
# Enter EACL service subinterface view.
[Sysname] interface eacl 8/0/1.1
9.1.2  qos binding
qos binding interface interface-type interface-number
undo qos binding
View
Default Level
2: System level
interface-type interface-number: Type and number of the interface to be bound to. Currently, only VLAN interfaces are available.
Use the qos binding command to bind an EACL service subinterface to a VLAN interface.
Use the undo qos binding command to cancel the binding.
An EACL service interface is bijective with a layer-3 interface, that is, an EACL service subinterface can be bound to only one layer-3 interface and a layer-3 interface can be bound to only one EACL service subinterface too.
# Bind EACL service subinterface EACL 8/0/1.1 to the VLAN-interface 100.
[Sysname-EACL8/0/1.1] qos binding interface vlan-interface 100
display qos traffic-counter outbound { counter0 | counter1 } slot slot-num
View
Default Level
1: Monitor level
counter0: Counter 0.
counter1: Counter 1.
slot-num: Number of the slot where a board resides.
Use the display qos traffic-counter command to display the outbound traffic statistics collected by the specified counter and the configuration of the counter.
# Display the statistics about outbound traffic for the board in slot 4.
<Sysname> display qos traffic-counter outbound counter0 slot 4
Slot 4 outbound counter0 mode:
  Interface: all
  VLAN: all
  Local precedence: all
  Drop priority: all
 The outgoing packets:
  Unicast: 0 packets
  Multicast: 0 packets
  Broadcast: 0 packets
  Bridge egress filtered packets: 0 packets
  TxQ filtered packets(Due to TxQ congestion): 0 packets
Table 10-1 Description on the fields of the display qos traffic-counter outbound command
Counter that is used for outbound traffic accounting, and the slot where the involved board is reside
Interfaces for which outbound traffic is counted
VLAN
VLANs for which outbound traffic is counted
Local precedence
Local precedence values of the counted packets
Drop priority
Drop precedence values of the counted packets
The number of outgoing packets
Unicast
The number of unicasts
Multicast
The number of multicasts
Broadcast
The number of broadcasts
The number of packets filtered in the egress direction of the bridge
TxQ filtered packets(Due to TxQ congestion )
The number of packets filtered out due to congestion in the transmit queue.
10.1.2  qos traffic-counter outbound
qos traffic-counter outbound { counter0 | counter1 } slot slot-num [ interface interface-type interface-number | vlan vlan-id | local-precedence lp-value | drop-priority dp-value ] *
undo qos traffic-counter outbound { counter0 | counter1 } slot slot-num
View
Default Level
2: System level
slot-num: Number of the slot where a board resides. The outbound traffic of the board is monitored.
interface-type interface-number: Type and number of the interface whose outbound traffic is monitored. Currently, Ethernet ports, POS interfaces, and RPR interfaces are supported.
vlan-id: ID of the VLAN whose outbound traffic is monitored.
lp-value: Local precedence value. The outbound traffic with the specified local precedence value is monitored.
dp-value: Drop precedence. The outbound traffic with the specified drop precedence value is monitored.
Use the qos traffic-counter outbound command to enable the outbound traffic accounting function and specify the type of outbound traffic.
Use the undo qos traffic-counter outbound command to disable the outbound traffic accounting function.
By default, the outbound traffic accounting function is disabled.
A board provides two counters for outbound traffic accounting. The monitored object can be an interface, a VLAN, a local precedence value, or a drop precedence value.
l           If no interface is specified, the outbound traffic of all the interfaces on the board is monitored.
l           If no VLAN is specified, the outbound traffic of all the VLANs is monitored.
l           If no local precedence value is specified, the outbound traffic is monitored regardless of the local precedence.
l           If no drop precedence value is specified, the outbound traffic is monitored regardless of the drop precedence.
&  Note:
l      After the qos traffic-counter outbound command is used to reset the monitored object for a board, the counter is rest automatically.
l      For the outbound traffic accounting function configured on XP4B, XP4CA, and D boards, the monitored object of the counter cannot be an interface.
# Enable counter 0 in slot 4 to collect statistics information about the outbound traffic of Ethernet 1/1/1.
[Sysname] qos traffic-counter outbound counter0 slot 4 interface ethernet1/1/1
10.1.3  reset qos traffic-counter outbound
reset qos traffic-counter outbound { counter0 | counter1 } slot slot-num
View
Default Level
2: System level
slot-num: Number of the slot where the board resides.
Use the reset qos traffic-counter outbound command to clear the outbound traffic statistics information collected by a counter.
# Clear the outbound traffic statistics information collected by counter 0 on the board in slot 4.
<Sysname> reset qos traffic-counter outbound counter0 slot 4
