H3C S9500 Operation Manual-Release2132[V2.03]-02 IP Services Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release2132[V2.03]-02 IP Services Volume
07-IPv6 Basics Configuration
07-IPv6 Basics Configuration 239.89 KB
Chapter 1  IPv6 Basics Configuration
When configuring IPv6 basics, go to these sections for information you are interested in:
l           IPv6 Overview
l           IPv6 Basics Configuration Task List
l           Configuring Basic IPv6 Functions
l           Configuring IPv6 NDP
l           Configuring PMTU Discovery
l           Configuring IPv6 TCP Properties
l           Configuring IPv6 FIB-Based Forwarding
l           Configuring Capacity and Update Period of Token Bucket
l           Configuring IPv6 DNS
l           Displaying and Maintaining IPv6 Basics Configuration
l           IPv6 Configuration Examples
l           Troubleshooting IPv6 Basics Configuration
&  Note:
The term “router” in this document refers to a router in a generic sense or an Ethernet switch running routing protocols.
1.1  IPv6 Overview
Internet protocol version 6 (IPv6), also called IP next generation (IPng), was designed by the Internet Engineering Task Force (IETF) as the successor to Internet protocol version 4 (IPv4). The significant difference between IPv6 and IPv4 is that IPv6 increases the IP address size from 32 bits to 128 bits. This section covers the following:
l           IPv6 Features
l           Introduction to IPv6 Address
l           Introduction to IPv6 Neighbor Discovery Protocol
l           IPv6 PMTU Discovery
l           Introduction to IPv6 DNS
l           Protocols and Standards
1.1.1  IPv6 Features
I. Header format simplification
IPv6 cuts down some IPv4 header fields or move them to the IPv6 extension headers to reduce the length of the basic IPv6 header. IPv6 uses the basic header with a fixed length, thus making IPv6 packet handling simple and improving the forwarding efficiency. Although the IPv6 address size is four times the IPv4 address size, the basic IPv6 header size is 40 bytes and is only twice the IPv4 header size (excluding the Options field).
Figure 1-1 Comparison between IPv4 packet header format and basic IPv6 packet header format
II. Adequate address space
The source and destination IPv6 addresses are both 128 bits (16 bytes) long. IPv6 can provide 3.4 x 1038 addresses to completely meet the requirements of hierarchical address division as well as allocation of public and private addresses.
III. Hierarchical address structure
IPv6 adopts the hierarchical address structure to quicken route search and reduce the system source occupied by the IPv6 routing table by means of route aggregation.
IV. Automatic address configuration
To simplify the host configuration, IPv6 supports stateful and stateless address configuration.
l           Stateful address configuration means that a host acquires an IPv6 address and related information from a server (for example, DHCP server).
l           Stateless address configuration means that a host automatically configures an IPv6 address and related information on basis of its own link-layer address and the prefix information advertised by the router.
In addition, a host can generate a link-local address on basis of its own link-layer address and the default prefix (FE80::/10) to communicate with other hosts on the link.
V. Built-in security
IPv6 uses IPSec as its standard extension header to provide end-to-end security. This feature provides a standard for network security solutions and improves the interoperability between different IPv6 applications.
VI. QoS support
The Flow Label field in the IPv6 header allows the device to label packets in a flow and provide special handling for these packets.
VII. Enhanced neighbor discovery mechanism
The IPv6 neighbor discovery protocol is implemented through a group of Internet Control Message Protocol version 6 (ICMPv6) messages that manages the information exchange between neighbor nodes on the same link. The group of ICMPv6 messages takes the place of address resolution protocol (ARP) message, Internet control message protocol version 4 (ICMPv4) router discovery message, and ICMPv4 redirection message to provide a series of other functions.
VIII. Flexible extension headers
IPv6 cancels the Options field in IPv4 packets but introduces multiple extension headers. In this way, IPv6 enhances the flexibility greatly to provide scalability for IP while improving the handling efficiency. The Options field in IPv4 packets contains 40 bytes at most, while the size of IPv6 extension headers is restricted by that of IPv6 packets.
1.1.2  Introduction to IPv6 Address
I. IPv6 address format
An IPv6 address is represented as a series of 16-bit hexadecimals, separated by colons. An IPv6 address is divided into eight groups, and the 16 bits of each group are represented by four hexadecimal numbers which are separated by colons, for example, 2001:0000:130F:0000:0000:09C0:876A:130B.
To simplify the representation of IPv6 addresses, zeros in IPv6 addresses can be handled as follows:
l           Leading zeros in each group can be removed. For example, the above-mentioned address can be represented in shorter format as 2001:0:130F:0:0:9C0:876A:130B.
l           If an IPv6 address contains two or more consecutive groups of zeros, they can be replaced by the double-colon :: option. For example, the above-mentioned address can be represented in the shortest format as 2001:0:130F::9C0:876A:130B.
  Caution:
The double-colon :: option can be used only once in an IPv6 address. Otherwise, the device is unable to determine how many zeros double-colons represent when converting them to zeros to restore a 128-bit IPv6 address.
An IPv6 address consists of two parts: address prefix and interface ID. The address prefix and the interface ID are respectively equivalent to the network ID and the host ID in an IPv4 address.
An IPv6 address prefix is written in IPv6-address/prefix-length notation, where IPv6-address is an IPv6 address in any of the notations and prefix-length is a decimal number indicating how many bits from the utmost left of an IPv6 address are the address prefix.
II. IPv6 address classification
IPv6 addresses fall into three types: unicast address, multicast address, and anycast address.
l           Unicast address: An identifier for a single interface, similar to an IPv4 unicast address. A packet sent to a unicast address is delivered to the interface identified by that address.
l           Multicast address: An identifier for a set of interfaces (typically belonging to different nodes), similar to an IPv4 multicast address. A packet sent to a multicast address is delivered to all interfaces identified by that address.
l           Anycast address: An identifier for a set of interfaces (typically belonging to different nodes). A packet sent to an anycast address is delivered to one of the interfaces identified by that address (the nearest one, according to the routing protocols’ measure of distance).
&  Note:
There are no broadcast addresses in IPv6. Their function is superseded by multicast addresses.
The type of an IPv6 address is designated by the first several bits called format prefix. Table 1-1 lists the mappings between address types and format prefixes.
Table 1-1 Mapping between address types and format prefixes
Format prefix (binary)
IPv6 prefix ID
Unicast address
Unassigned address
00...0  (128 bits)
::/128
Loopback address
00...1  (128 bits)
::1/128
Link-local address
1111111010
FE80::/10
Site-local address
1111111011
FEC0::/10
Global unicast address
other forms
Multicast address
11111111
FF00::/8
Anycast address
Anycast addresses are taken from unicast address space and are not syntactically distinguishable from unicast addresses.
III. Unicast address
There are several forms of unicast address assignment in IPv6, including global unicast address, link-local address, and site-local address.
l           The global unicast address, equivalent to an IPv4 public address, is provided for network service providers. This type of address allows efficient route prefix aggregation to restrict the number of global routing entries.
l           The link-local address is used for communication between link-local nodes in neighbor discovery and stateless autoconfiguration. Routers must not forward any packets with link-local source or destination addresses to other links.
l           IPv6 unicast site-local addresses are similar to private IPv4 addresses. Routers must not forward any packets with site-local source or destination addresses outside of the site (equivalent to a private network).
l           Loopback address: The unicast address 0:0:0:0:0:0:0:1 (represented in the shortest format as ::1) is called the loopback address and may never be assigned to any physical interface. Like the loopback address in IPv4, it may be used by a node to send an IPv6 packet to itself.
l           Unassigned address: The unicast address "::” is called the unassigned address and may not be assigned to any node. Before acquiring a valid IPv6 address, a node may fill this address in the source address field of an IPv6 packet, but may not use it as a destination IPv6 address.
IV. Multicast address
IPv6 multicast addresses listed in Table 1-2 are reserved for special purpose.
Table 1-2 Reserved IPv6 multicast addresses
Address
Application
FF01::1
Node-local scope all-nodes multicast address
FF02::1
Link-local scope all-nodes multicast address
FF01::2
Node-local scope all-routers multicast address
FF02::2
Link-local scope all-routers multicast address
FF05::2
Site-local scope all-routers multicast address
Besides, there is another type of multicast address: solicited-node address. A solicited-node multicast address is used to acquire the link-layer addresses of neighbor nodes on the same link and is also used for duplicate address detection (DAD). Each IPv6 unicast or anycast address has one corresponding solicited-node address. The format of a solicited-node multicast address is as follows:
FF02:0:0:0:0:1:FFXX:XXXX
Where, FF02:0:0:0:0:1 FF is permanent and consists of 104 bits, and XX:XXXX is the last 24 bits of an IPv6 unicast or anycast address.
V. Interface identifier in IEEE EUI-64 format
Interface identifiers in IPv6 unicast addresses are used to identify interfaces on a link and they are required to be unique on that link. Interface identifiers in IPv6 unicast addresses are currently required to be 64 bits long. An interface identifier in IEEE EUI-64 format is derived from the link-layer address of that interface. Interface identifiers in IPv6 addresses are 64 bits long, while MAC addresses are 48 bits long. Therefore, the hexadecimal number FFFE needs to be inserted in the middle of MAC addresses (behind the 24 high-order bits). To ensure the interface identifier obtained from a MAC address is unique, it is necessary to set the universal/local (U/L) bit (the seventh high-order bit) to “1”. Thus, an interface identifier in IEEE EUI-64 format is obtained.
Figure 1-2 Convert a MAC address into an EUI-64 interface identifier
1.1.3  Introduction to IPv6 Neighbor Discovery Protocol
IPv6 neighbor discovery protocol (NDP) uses five types of ICMPv6 messages to implement the following functions:
l           Address resolution
l           Neighbor reachability detection
l           Duplicate address detection
l           Router/prefix discovery and address autoconfiguration
l           Redirection
Table 1-3 lists the types and functions of ICMPv6 messages used by the NDP.
Table 1-3 Types and functions of ICMPv6 messages
ICMPv6 message
Number
Function
Neighbor solicitation (NS) message
135
Used to acquire the link-layer address of a neighbor
Used to verify whether the neighbor is reachable
Used to perform a duplicate address detection
Neighbor advertisement (NA) message
136
Used to respond to an NS message
When the link layer changes, the local node initiates an NA message to notify neighbor nodes of the node information change.
Router solicitation (RS) message
133
After started, a node sends an RS message to request the router for an address prefix and other configuration information for the purpose of autoconfiguration.
Router advertisement (RA) message
134
Used to respond to an RS message
With the RA message suppression disabled, the router regularly sends an RA message containing information such as prefix information options and flag bits.
Redirect message
137
When a certain condition is satisfied, the default gateway sends a redirect message to the source host so that the host can reselect a correct next hop router to forward packets.
135
Used to verify whether a neighbor is reachable
Used to perform duplicate address detection
136
When the link layer changes, the local node sends an NA message to notify neighbor nodes of the node change.
133
After started, a node sends an RS message to request the router for an address prefix and other configuration information used for autoconfiguration.
134
Redirect message
137
When certain conditions are satisfied, the default gateway sends a redirect message to the source host so that the host can reselect a correct next hop router to forward packets.
The NDP mainly provides the following functions:
I. Address resolution
Similar to the ARP function in IPv4, a node acquires the link-layer addresses of neighbor nodes on the same link through NS and NA messages. Figure 1-3 shows how node A acquires the link-layer address of node B.
Figure 1-3 Address resolution
The address resolution procedure is as follows:
1)         Node A multicasts an NS message. The source address of the NS message is the IPv6 address of the sending interface of node A and the destination address is the solicited-node multicast address of node B. The NS message contains the link-layer address of node A.
2)         After receiving the NS message, node B judges whether the destination address of the packet is its solicited-node multicast address. If yes, node B learns the link-layer address of node A, and then unicasts an NA message containing its link-layer address.
3)         Node A acquires the link-layer address of node B from the NA message. After that, node A and node B can communicate.
II. Neighbor reachability detection
After node A acquires the link-layer address of its neighbor node B, node A can verify whether node B is reachable according to NS and NA messages.
1)         Node A sends an NS message whose destination address is the IPv6 address of node B.
2)         If node A receives an NA message from node B, node A considers that node B is reachable. Otherwise, node B is unreachable.
III. Duplicate address detection
After node A acquires an IPv6 address, it will perform duplicate address detection (DAD) to determine whether the address is being used by other nodes (similar to the gratuitous ARP function of IPv4). DAD is accomplished through NS and NA messages. Figure 1-3 shows the DAD procedure.
Figure 1-4 Duplicate address detection
The DAD procedure is as follows:
1)         Node A sends an NS message whose source address is the unassigned address :: and destination address is the corresponding solicited-node multicast address of the IPv6 address to be detected. The NS message contains the IPv6 address.
2)         If node B uses this IPv6 address, node B returns an NA message. The NA message contains the IPv6 address of node B.
3)         Node A learns that the IPv6 address is being used by node B after receiving the NA message from node B. Otherwise, node B is not using the IPv6 address and node A can use it.
IV. Router/prefix discovery and address autoconfiguration
Router/prefix discovery means that a node locates the neighboring routers, and learns the prefix of the network where the host is located, and other configuration parameters from the received RA message.
Stateless address autoconfiguration means that a node automatically configures an IPv6 address according to the information obtained through router/prefix discovery.
The router/prefix discovery is implemented through RS and RA messages. The router/prefix discovery procedure is as follows:
1)         After started, a node sends an RS message to request the router for the address prefix and other configuration information for the purpose of autoconfiguration.
2)         The router returns an RA message containing information such as address prefix and flag bits. (The router also regularly sends an RA message.)
3)         The node automatically configures an IPv6 address and other information for its interface according to the address prefix and other configuration parameters in the RA message.
V. Redirection
When a host is started, its routing table may contain only the default route to the gateway. When certain conditions are satisfied, the gateway sends an ICMPv6 redirect message to the source host so that the host can select a better next hop to forward packets (similar to the ICMP redirection function in IPv4).
The gateway will send an IPv6 ICMP redirect message when the following conditions are satisfied:
l           The receiving interface is the forwarding interface.
l           The selected route itself is not created or modified by an IPv6 ICMP redirect message.
l           The selected route is not the default route.
l           The forwarded IPv6 packet does not contain any routing header.
1.1.4  IPv6 PMTU Discovery
The links that a packet passes from the source to the destination may have different MTUs. In IPv6, when the packet size exceeds the link MTU, the packet will be fragmented at the source end so as to reduce the processing pressure of the forwarding device and utilize network resources rationally.
The path MTU (PMTU) discovery mechanism is to find the minimum MTU of all links in the path from the source to the destination. Figure 1-5 shows the working procedure of the PMTU discovery.
Figure 1-5 Working procedure of the PMTU discovery
The working procedure of the PMTU discovery is as follows:
1)         The source host uses its MTU to fragment packets and then sends them to the destination host.
2)         If the MTU supported by the forwarding interface is less than the packet size, the forwarding device will discard the packet and return an ICMPv6 error packet containing the interface MTU to the source host.
3)         After receiving the ICMPv6 error packet, the source host uses the returned MTU to fragment the packet again and then sends it.
4)         Step 2 to step 3 are repeated until the destination host receives the packet. In this way, the minimum MTU of all links in the path from the source host to the destination host is determined.
1.1.5  Introduction to IPv6 DNS
In the IPv6 network, a domain name system (DNS) supporting IPv6 converts domain names into IPv6 addresses, instead of IPv4 addresses.
However, just like an IPv4 DNS, an IPv6 DNS also covers static domain name resolution and dynamic domain name resolution. The function and implementation of these two types of domain name resolution are the same as those of an IPv4 DNS. For details, refer to DNS Configuration.
Usually, the DNS server connecting IPv4 and IPv6 networks not only contain A records (IPv4 addresses), but also AAAA records (IPv6 addresses). The DNS server can convert domain names into IPv4 addresses or IPv6 addresses. In this way, the DNS server implements the functions of both IPv6 DNS and IPv4 DNS.
1.1.6  Protocols and Standards
Protocols and standards related to IPv6 include:
l           RFC 1881: IPv6 Address Allocation Management
l           RFC 1887: An Architecture for IPv6 Unicast Address Allocation
l           RFC 1981: Path MTU Discovery for IP version 6
l           RFC 2375: IPv6 Multicast Address Assignments
l           RFC 2460: Internet Protocol, Version 6 (IPv6) Specification.
l           RFC 2461: Neighbor Discovery for IP Version 6 (IPv6)
l           RFC 2462: IPv6 Stateless Address Autoconfiguration
l           RFC 2463: Internet Control Message Protocol (ICMPv6) for the Internet Protocol Version 6 (IPv6) Specification
l           RFC 2464: Transmission of IPv6 Packets over Ethernet Networks
l           RFC 2526: Reserved IPv6 Subnet Anycast Addresses
l           RFC 3307: Allocation Guidelines for IPv6 Multicast Addresses
l           RFC 3513: Internet Protocol Version 6 (IPv6) Addressing Architecture
l           RFC 3596: DNS Extensions to Support IP Version 6
1.2  IPv6 Basics Configuration Task List
Complete the following tasks to perform IPv6 basics configuration:
Remarks
Required
Optional
Optional
Optional
Optional
Optional
Optional
1.3  Configuring Basic IPv6 Functions
1.3.1  Enabling the IPv6 Packet Forwarding Function
Before IPv6-related configurations, you must enable the IPv6 packet forwarding function. Otherwise, an interface cannot forward IPv6 packets even if an IPv6 address is configured, resulting in communication failures in the IPv6 network.
Follow these steps to enable the IPv6 packet forwarding function:
To do...
Use the command...
Remarks
Enter system view
Enable the IPv6 packet forwarding function
ipv6
Required
Disabled by default.
1.3.2  Configuring an IPv6 Unicast Address
IPv6 site-local addresses and global unicast addresses can be configured in either of the following ways:
l           EUI-64 format: When the EUI-64 format is adopted to form IPv6 addresses, the IPv6 address prefix of an interface is the configured prefix and the interface identifier is derived from the link-layer address of the interface.
l           Manual configuration: IPv6 site-local addresses or global unicast addresses are configured manually.
IPv6 link-local addresses can be configured in either of the following ways:
l           Automatic generation: The device automatically generates a link-local address for an interface according to the link-local address prefix (FE80::/10) and the link-layer address of the interface.
l           Manual assignment: IPv6 link-local addresses can be assigned manually.
Follow these steps to configure an IPv6 unicast address:
To do...
Use the command...
Remarks
Enter system view
Enter interface view
Configure an IPv6 global unicast address or site-local address
Manually assign an IPv6 address
Use either command
By default, no site-local address or global unicast address is configured for an interface.
Adopt the EUI-64 format to form an IPv6 address
ipv6 address ipv6-address/prefix-length eui-64
Configure an IPv6 link-local address
Automatically generate a link-local address
ipv6 address auto link-local
Optional
By default, after an IPv6 site-local address or global unicast address is configured for an interface, a link-local address will be generated automatically.
Manually assign a link-local address for an interface
&  Note:
l      After an IPv6 site-local address or global unicast address is configured for an interface, a link-local address will be generated automatically. The automatically generated link-local address is the same as the one generated by using the ipv6 address auto link-local command. If a link-local address is manually assigned to an interface, this link-local address takes effect. If the manually assigned link-local address is removed, the automatically generated link-local address takes effect.
l      The manual assignment takes precedence over the automatic generation. That is, if you first adopt the automatic generation and then the manual assignment, the manually assigned link-local address will overwrite the automatically generated one. If you first adopt the manual assignment and then the automatic generation, the automatically generated link-local address will not take effect and the link-local address of an interface is still the manually assigned one. After you delete the manually assigned address, the automatically generated link-local address is validated.
l      The undo ipv6 address auto link-local command can be used only after the ipv6 address auto link-local command is executed. However, if an IPv6 site-local address or global unicast address is already configured for an interface, the interface still has a link-local address because the system automatically generates one for the interface. If no IPv6 site-local address or global unicast address is configured, the interface has no link-local address.
1.4  Configuring IPv6 NDP
1.4.1  Configuring a Static Neighbor Entry
The IPv6 address of a neighbor node can be resolved into a link-layer address dynamically through NS and NA messages or statically through a static neighbor entry.
The device uniquely identifies a static neighbor entry according to the IPv6 address and the layer 3 interface ID. Currently, there are two configuration methods:
l           Configure an IPv6 address and link-layer address for a layer 3 interface.
l           Configure an IPv6 address and link-layer address for a port in a VLAN.
Follow these steps to configure a static neighbor entry:
To do...
Use the command...
Remarks
Enter system view
Configure a static neighbor entry
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number }
Required
  Caution:
You can adopt either of the following two methods to configure a static neighbor entry for a VLAN interface.
l      After a static neighbor entry is configured by using the first method, the device needs to resolve the corresponding layer 2 port information of the VLAN interface.
l      If you adopt the second method to configure a static neighbor entry, you should ensure that the corresponding VLAN interface exists and that the layer 2 port specified by port-type port-number belongs to the VLAN specified by vlan-id. After a static neighbor entry is configured, the device relates the VLAN interface to an IPv6 address to uniquely identify a static neighbor entry.
1.4.2  Configuring the Maximum Number of Neighbors Dynamically Learned
The device can dynamically acquire the link-layer address of a neighbor node through NS and NA messages and add it into the neighbor table. Too large a neighbor table may reduce the forwarding performance of the device. You can restrict the size of the neighbor table by setting the maximum number of neighbors that an interface can dynamically learn. When the number of dynamically learned neighbors reaches the threshold, the interface will stop learning neighbor information.
Follow these steps to configure the maximum number of neighbors dynamically learned:
To do…
Use the command…
Remarks
Enter system view
Configure the maximum number of neighbors dynamically learned on an interface
ipv6 neighbors max-learning-num number
Optional
1024 by default.
1.4.3  Configuring Parameters Related to an RA Message
You can configure whether the interface sends an RA message, the interval for sending RA messages, and parameters in RA messages. After receiving an RA message, a host can use these parameters to perform corresponding operations. Table 1-4 lists the configurable parameters in an RA message and their descriptions.
Table 1-4 Parameters in an RA message and their descriptions
Cur hop limit
When sending an IPv6 packet, a host uses the value of this parameter to fill the Cur Hop Limit field in IPv6 headers. Meanwhile, the value of this parameter is equal to the value of the Cur Hop Limit field in response messages of the device.
Prefix information options
After receiving the prefix information advertised by the device, the hosts on the same link can perform stateless autoconfiguration operations.
M flag
This field determines whether hosts use the stateful autoconfiguration to acquire IPv6 addresses.
If the M flag is set to 1, hosts use the stateful autoconfiguration to acquire IPv6 addresses. Otherwise, hosts use the stateless autoconfiguration to acquire IPv6 addresses, that is, hosts configure IPv6 addresses according to their own link-layer addresses and the prefix information issued by the router.
O flag
This field determines whether hosts use the stateful autoconfiguration to acquire information other than IPv6 addresses.
If the O flag is set to 1, hosts use the stateful autoconfiguration (for example, DHCP server) to acquire information other than IPv6 addresses. Otherwise, hosts use the stateless autoconfiguration to acquire information other than IPv6 addresses.
Router lifetime
This field is used to set the lifetime of the router that sends RA messages to serve as the default router of hosts. According to the router lifetime in the received RA messages, hosts determine whether the router sending RA messages can serve as the default router of hosts.
Retrans timer
If the device fails to receive a response message within the specified time after sending an NS message, the device will retransmit it.
Reachable time
After the neighbor reachability detection shows that a neighbor is reachable, the device considers the neighbor is reachable within the reachable time. If the device needs to send a packet to a neighbor after the reachable time expires, the device will again confirm whether the neighbor is reachable.
&  Note:
The values of the Retrans Timer field and the Reachable Time field configured for an interface are sent to hosts via RA messages. Furthermore, this interface sends NS messages at intervals of Retrans Timer and considers a neighbor reachable within the time of Reachable Time.
Follow these steps to configure parameters related to an RA message:
To do…
Use the command…
Remarks
Enter system view
Configure the current hop limit
ipv6 nd hop-limit value
Optional
64 by default.
Disable the RA message suppression
undo ipv6 nd ra halt
Optional
By default, RA messages are suppressed.
Configure the maximum and minimum intervals for sending RA messages
ipv6 nd ra interval max-interval-value min-interval-value
Optional
By default, the maximum interval for sending RA messages is 600 seconds, and the minimum interval is 200 seconds.
The device sends RA messages at intervals of a random value between the maximum interval and the minimum interval.
The minimum interval should be less than or equal to 0.75 times the maximum interval.
Configure the prefix information options in RA messages
ipv6 nd ra prefix { ipv6-address prefix-length | ipv6-address/prefix-length } valid-lifetime preferred-lifetime [ no-autoconfig [ off-link ]*
Optional
By default, no prefix information is configured in RA messages and the IPv6 address of the interface sending RA messages is used as the prefix information.
Set the M flag bit to 1
Optional
By default, the M flag bit is set to 0, that is, hosts acquire IPv6 addresses through stateless autoconfiguration.
Set the O flag bit to 1.
ipv6 nd autoconfig other-flag
Optional
By default, the O flag bit is set to 0, that is, hosts acquire other information through stateless autoconfiguration.
Configure the router lifetime in RA messages
ipv6 nd ra router-lifetime value
Optional
1,800 seconds by default.
Set the retrans timer
Optional
By default, the local interface sends NS messages at intervals of 1,000 milliseconds and the Retrans Timer field in RA messages sent by the local interface is equal to 0.
Set the reachable time
ipv6 nd nud reachable-time value
Optional
By default, the neighbor reachable time on the local interface is 30,000 milliseconds and the Reachable Timer field in RA messages is 0.
  Caution:
The maximum interval for sending RA messages should be less than or equal to the router lifetime in RA messages.
1.4.4  Configuring the Number of Attempts to Send an NS Message for DAD
An interface sends a neighbor solicitation (NS) message for DAD after acquiring an IPv6 address. If the interface does not receive a response within a specified time (determined by the ipv6 nd ns retrans-timer command), it continues to send an NS message. If it still does not receive a response after the number of attempts to send an NS message reaches the maximum, the acquired address is considered available.
Follow these steps to configure the attempts to send an NS message for DAD:
To do…
Use the command…
Remarks
Enter system view
Configure the number of attempts to send an NS message for DAD
ipv6 nd dad attempts value
Optional
1 by default. When the value argument is set to 0, DAD is disabled.
1.5  Configuring PMTU Discovery
1.5.1  Configuring the Interface MTU
IPv6 routing devices do not support packet fragmentation. After an IPv6 routing device receives an IPv6 packet, if the packet size is greater than the MTU of the forwarding interface, the device will discard the packet. Meanwhile, the device sends the MTU to the source host through an ICMPv6 packet — Packet Too Big message. The source host fragments the packet according to the MTU and resends it. To reduce the extra flow overhead resulting from packets being discarded, a proper interface MTU should be configured according to the actual networking environment.
Follow these steps to configure the interface MTU:
To do…
Use the command…
Remarks
Enter system view
Configure the interface MTU
ipv6 mtu mtu-size
Optional
1.5.2  Configuring a Static PMTU for a Specified IPv6 Address
You can configure a static PMTU for a specified destination IPv6 address. When a source host sends packets through an interface, it compares the interface MTU with the static PMTU of the specified destination IPv6 address. If the packet size is larger than the smaller one between the two values, the host fragments the packet according to the smaller value.
Follow these steps to configure a static PMTU for a specified address:
To do…
Use the command…
Remarks
Enter system view
Configure a static PMTU for a specified IPv6 address
ipv6 pathmtu ipv6-address [ value ]
Required
By default, no static PMTU is configured.
1.5.3  Configuring the Aging Time for PMTU
After the MTU of the path from the source host to the destination host is dynamically determined (refer to section 1.1.4  IPv6 PMTU Discovery”), the source host sends subsequent packets to the destination host on basis of this MTU. After the aging time expires, the dynamically determined PMTU is removed and the source host re-determines an MTU to send packets through the PMTU mechanism.
The aging time is invalid for static PMTU.
Follow these steps to configure the aging time for PMTU:
To do…
Use the command…
Remarks
Enter system view
Configure aging time for PMTU
ipv6 pathmtu age age-time
Optional
10 minutes by default.
1.6  Configuring IPv6 TCP Properties
The IPv6 TCP properties you can configure include:
l           synwait timer: When a SYN packet is sent, the synwait timer is triggered. If no response packet is received before the synwait timer expires, the IPv6 TCP connection establishment fails.
l           finwait timer: When the IPv6 TCP connection status is FIN_WAIT_2, the finwait timer is triggered. If no packet is received before the finwait timer expires, the IPv6 TCP connection is terminated. If a FIN packet is received, the IPv6 TCP connection status becomes TIME_WAIT. If other packets are received, the finwait timer is reset from the last received packet and the connection is terminated after the finwait timer expires.
l           Size of the IPv6 TCP sending/receiving buffer.
Follow these steps to configure IPv6 TCP properties:
To do…
Use the command…
Remarks
Enter system view
Set the finwait timer of IPv6 TCP packets
tcp ipv6 timer fin-timeout wait-time
Optional
675 seconds by default
Set the synwait timer of IPv6 TCP packets
tcp ipv6 timer syn-timeout wait-time
Optional
Set the size of the IPv6 TCP sending/receiving buffer
tcp ipv6 window size
Optional
8 KB by default
1.7  Configuring IPv6 FIB-Based Forwarding
With the caching function of IPv6 FIB enabled, the device searches the FIB cache when forwarding packets, thus reducing the time in searching IP packets and improving the forwarding efficiency.
In the load sharing mode of IPv6 FIB, the device can decide how to select an equal cost multi-path (ECMP) route to forward packets. Currently, two load sharing modes are supported:
l           Load sharing based on the HASH algorithm: A certain algorithm based on the source IPv6 address and destination IPv6 address is adopted to select an ECMP route to forward packets.
l           Load sharing based on polling: Each ECMP route is used in turn to forward packets.
Follow these steps to configure the IPv6 FIB-based forwarding:
To do…
Use the command…
Remarks
Enter system view
Enable the caching function of IPv6 FIB
ipv6 fibcache { slot-number | all }
Required
Disabled by default
Configure the IPv6 FIB load sharing mode
Configure the load sharing based on the HASH algorithm
ipv6 fib-loadbalance-type hash-based
Optional
By default, the load sharing based on polling is adopted, that is, each ECMP route is used in turn to forward packets.
Configure the load sharing based on polling
undo ipv6 fib-loadbalance-type hash-based
1.8  Configuring Capacity and Update Period of Token Bucket
If too many ICMPv6 error packets are sent within a short time in a network, network congestion may occur. To avoid network congestion, you can control the maximum number of ICMPv6 error packets sent within a specified time, currently by adopting the token bucket algorithm.
You can set the capacity of a token bucket, namely, the number of tokens in the bucket. In addition, you can set the update period of the token bucket, namely, the interval for updating the number of tokens in the token bucket to the configured capacity. One token allows one ICMPv6 error packet to be sent. Each time an ICMPv6 error packet is sent, the number of tokens in a token bucket decreases by 1. If the number of ICMPv6 error packets successively sent exceeds the capacity of the token bucket, subsequent ICMPv6 error packets cannot be sent out until the number of tokens in the token bucket is updated and new tokens are added to the bucket.
Follow these steps to configure the capacity and update period of the token bucket:
To do…
Use the command…
Remarks
Enter system view
Configure the capacity and update period of the token bucket
ipv6 icmp-error { bucket bucket-size | ratelimit interval } *
Optional
By default, the capacity of a token bucket is 10 and the update period is 100 milliseconds. That is, at most 10 IPv6 ICMP error packets can be sent within these 100 milliseconds.
The update period “0” indicates that the number of ICMPv6 error packets sent is not restricted.
1.9  Configuring IPv6 DNS
1.9.1  Configuring Static IPv6 DNS
Configuring static IPv6 domain name resolution is to establish the mapping between a host name and an IPv6 address. When using such applications as Telnet, you can directly input a host name and the system will resolve the host name into an IPv6 address. Each host name can correspond to only one IPv6 address.
Follow these steps to configure a host name and the corresponding IPv6 address:
To do…
Use the command…
Remarks
Enter system view
Configure a host name and the corresponding IPv6 address
ipv6 host hostname ipv6-address
Required
1.9.2  Configuring Dynamic IPv6 DNS
If you want to use the dynamic domain name function, you can use the following command to enable the dynamic domain name resolution function. In addition, you should configure a DNS server so that a query request message can be sent to the correct server for resolution. The system can support at most six DNS servers.
You can configure a DNS suffix so that you only need to enter some fields of a domain name and the system can automatically add the preset suffix for address resolution. The system can support at most 10 DNS suffixes.
Follow these steps to configure dynamic IPv6 DNS:
To do…
Use the command…
Remarks
Enter system view
Enable the dynamic domain name resolution function
dns resolve
Required
Configure an IPv6 DNS server
dns server ipv6 ipv6-address [ interface-type interface-number ]
Required
If the IPv6 address of the DNS server is a link-local address, you need to specify a value for interface-type and interface-number.
Configure the DNS suffix.
dns domain domain-name
Required
By default, no DN suffix is configured, that is, the domain name is resolved according to the input information.
&  Note:
The dns resolve and dns domain commands are the same as those of IPv4 DNS. For details about the commands, refer to DNS Commands.
1.10  Displaying and Maintaining IPv6 Basics Configuration
To do…
Use the command…
Remarks
Display DNS suffix information
display dns domain [ dynamic ]
Available in any view
Display IPv6 dynamic domain name cache information
display dns ipv6 dynamic-host
Display DNS server information
display dns server [ dynamic ]
Display the IPv6 FIB entries
display ipv6 fib [ slot-number ] [ ipv6-address ]
Display the total number of routes in the IPv6 FIB cache
display ipv6 fibcache slot-number
Display the mappings between host names and IPv6 addresses in the static DNS database.
display ipv6 host
Display the IPv6 information of an interface
display ipv6 interface [ interface-type interface-number | brief ]
Display neighbor information
display ipv6 neighbors { { ipv6-address | all | dynamic | static } [ slot slot-number ] | interface interface-type interface-number | vlan vlan-id } [ | { begin | exclude | include } regular-expression ]
Display the total number of neighbor entries satisfying the specified conditions
Display the PMTU information of an IPv6 address
display ipv6 pathmtu { ipv6-address | all | dynamic | static }
Display information related to a specified socket
display ipv6 socket [ socktype socket-type ] [ task-id socket-id ] [ slot slot-number ]
Display the IPv6 TCP connection statistics
display tcp ipv6 statistics
Display the IPv6 TCP connection status
display tcp ipv6 status
Display the IPv6 UDP connection statistics
display udp ipv6 statistics
Clear IPv6 dynamic domain name cache information
reset dns ipv6 dynamic-host
Available in user view
Clear FIB entries from the cache
reset ipv6 fibcache { slot-number | all }
Clear IPv6 neighbor information
Clear the corresponding PMTU
reset ipv6 pathmtu { all | static | dynamic}
Clear the statistics of IPv6 packets
Clear all IPv6 TCP connection statistics
reset tcp ipv6 statistics
Clear the statistics of all IPv6 UDP packets
reset udp ipv6 statistics
&  Note:
The display dns domain and display dns server commands are the same as those of IPv4 DNS. For details about the commands, refer to DNS Commands.
1.11  IPv6 Configuration Examples
I. Network requirements
Switch A and Switch B are directly connected through two Ethernet ports that belong to VLAN 2. Different types of IPv6 addresses are configured for VLAN-interface 2 respectively on Switch A and Switch B to verify the connectivity between two switches. The IPv6 prefix in the EUI-64 format is 2001::/64, the global unicast address of Switch A is 3001::1/64, and the global unicast address of Switch B is 3001::2/64.
II. Network diagram
Figure 1-6 Network diagram for IPv6 address configuration
III. Configuration procedure
l           Configure Switch A
# Enable the IPv6 packet forwarding function.
[SwitchA] ipv6
# Configure the interface VLAN-interface 2 to automatically generate a link-local address.
[SwitchA-Vlan-interface2] ipv6 address auto link-local
# Configure an EUI-64 address for the interface VLAN-interface 2.
[SwitchA-Vlan-interface2] ipv6 address 2001::/64 eui-64
# Configure a global unicast address for the interface VLAN-interface 2.
[SwitchA-Vlan-interface2] ipv6 address 3001::1/64
l           Configure Switch B
[SwitchB] ipv6
[SwitchB-Vlan-interface2] ipv6 address auto link-local
[SwitchB-Vlan-interface2] ipv6 address 2001::/64 eui-64
# Configure a global unicast address for VLAN-interface 2.
[SwitchB-Vlan-interface2] ipv6 address 3001::2/64
IV. Verification
# Display the IPv6 information of the interface on Switch A.
[SwitchA-Vlan-interface2] display ipv6 interface vlan-interface 2
Vlan-interface2 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::20F:E2FF:FE49:8048
  Global unicast address(es):
    2001::20F:E2FF:FE49:8048, subnet is 2001::/64
    3001::1, subnet is 3001::/64
  Joined group address(es):
    FF02::1:FF00:1
    FF02::1:FF49:8048
    FF02::2
    FF02::1
  MTU is 1500 bytes
# Display the IPv6 information of the interface on Switch B.
[SwitchB-Vlan-interface2] display ipv6 interface vlan-interface 2
IPv6 is enabled, link-local address is FE80::20F:E2FF:FE00:1
    2001::20F:E2FF:FE00:1, subnet is 2001::/64
    3001::2, subnet is 3001::/64
    FF02::1:FF00:2
    FF02::1:FF00:1
    FF02::2
    FF02::1
  MTU is 1500 bytes
# From Switch A, ping the link-local address, EUI-64 address, and global unicast address of Switch B, respectively. If the configurations are correct, the three types of IPv6 addresses above can be pinged.
  Caution:
When you ping a link-local address, you should use the “–i” parameter to specify an interface for the link-local address.
[SwitchA-Vlan-interface2] ping ipv6 FE80::20F:E2FF:FE00:1 -i vlan-interface2
  PING FE80::20F:E2FF:FE00:1 : 56  data bytes, press CTRL_C to break
    Reply from FE80::20F:E2FF:FE00:1
    bytes=56 Sequence=1 hop limit=255  time = 80 ms
    bytes=56 Sequence=2 hop limit=255  time = 60 ms
    bytes=56 Sequence=3 hop limit=255  time = 60 ms
    bytes=56 Sequence=4 hop limit=255  time = 70 ms
    bytes=56 Sequence=5 hop limit=255  time = 60 ms
  --- FE80::20F:E2FF:FE00:1 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 60/66/80 ms
[SwitchA-Vlan-interface2] ping ipv6 2001::20F:E2FF:FE00:1
  PING 2001::20F:E2FF:FE00:1 : 56  data bytes, press CTRL_C to break
    Reply from 2001::20F:E2FF:FE00:1
    bytes=56 Sequence=1 hop limit=255  time = 40 ms
    bytes=56 Sequence=2 hop limit=255  time = 70 ms
    bytes=56 Sequence=4 hop limit=255  time = 60 ms
  --- 2001::20F:E2FF:FE00:1 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 40/58/70 ms
[SwitchA-Vlan-interface2] ping ipv6 3001::2
  PING 3001::2 : 56  data bytes, press CTRL_C to break
    Reply from 3001::2
    bytes=56 Sequence=1 hop limit=255  time = 50 ms
    Reply from 3001::2
    Reply from 3001::2
    Reply from 3001::2
    Reply from 3001::2
  --- 3001::2 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 50/60/70 ms
1.12  Troubleshooting IPv6 Basics Configuration
I. Symptom:
The peer IPv6 address cannot be pinged.
II. Solution:
l           Carry out the display current-configuration command in any view or the display this command in system view to check that the IPv6 packet forwarding function is enabled.
l           Carry out the display ipv6 interface command in any view to check that the IPv6 address of the interface is correct and that the interface is up.
l           Carry out the debugging ipv6 packet command in user view to enable the debugging for IPv6 packets and make judgment according to the debugging information.
