ACL and QoS Command Reference
HomeSupportSwitchesH3C S5500 Switch SeriesReference GuidesCommand ReferencesH3C S5500-SI Series Ethernet Switches Command References-Release 2202-V1.03ACL and QoS Command Reference
Download Book
Title Size Downloads
ACL and QoS Command Reference-book.pdf 447.66 KB
Click the link on the right to download the complete book.
Preface
The H3C S5500-SI documentation set includes 9 command references, which describe the commands and command syntax options for the S5500-SI Release 2202.
The ACL and QoS Command Reference describes ACL and QoS configuration commands. It covers the commands for creating ACLs, using ACLs for packet filtering, configuring QoS policies, and configuring common QoS techniques, such as traffic policing, traffic shaping, and congestion management.
This preface includes:
l          Audience
l          Document Organization
l          Conventions
l          About the H3C S5500-SI Documentation Set
l          Obtaining Documentation
l          Documentation Feedback
Audience
This documentation set is intended for:
l          Network planners
l          Field technical support and servicing engineers
l          Network administrators working with the S5500-SI series
The ACL and QoS Command Reference comprises these parts:
ACL Configuration Commands
QoS Policy Configuration Commands
Priority Mapping Configuration Commands
GTS and Line Rate Configuration Commands
Congestion Management Configuration Commands
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none.
&<1-n>
Symbols
Convention
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means a complementary description.
The H3C S5500-SI documentation set also includes:
Category
Documents
Purposes
Product description and specifications
Marketing brochures
Describe product specifications and benefits.
Technology white papers
Provide an in-depth description of software features and technologies.
RPS User Manual
Describes the appearances, features, and specifications of the RPS units available for the products.
RPS Ordering Information for H3C Low-End Ethernet Switches
Provides the RPS and switch compatibility matrix and RPS cable specifications.
H3C Low End Series Ethernet Switches Pluggable Modules Manual
Describes the models, appearances, and specifications of the pluggable modules available for the products.
Interface Card User Manual
Describes the appearance and specifications of the interface card.
Hardware installation
H3C S5500-SI Quick Start
Provides regulatory information and the safety instructions that must be followed during installation.
Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration.
S5500-SI Series Ethernet Switches Installation Manual
Provides a complete guide to hardware installation and hardware specifications.
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide
Guides you through installing SFP/SFP+/XFP transceiver modules.
Describes how to install the interface card.
Software configuration
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Operations and maintenance
H3C Series Ethernet Switches Login Password Recovery Manual
Tells how to find the lost password or recover the password when the login password is lost.
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
We appreciate your comments.
