Title | Size | Downloads |
Command Index-book.pdf | 93.6 KB |
The command index includes all the commands supported on your S5500-SI series switches, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
access-limit |
Security Command Reference |
1-1 |
access-limit enable |
1-1 |
accounting |
ACL and QoS Command Reference |
2-7 |
accounting command |
1-2 |
accounting default |
1-3 |
accounting lan-access |
1-4 |
accounting login |
1-5 |
accounting optional |
1-6 |
accounting-on enable |
2-1 |
acl |
Fundamentals Command Reference |
2-1 |
acl |
1-1 |
acl copy |
1-2 |
acl ipv6 |
1-3 |
acl ipv6 copy |
1-4 |
acl ipv6 logging frequence |
1-5 |
acl ipv6 name |
1-5 |
acl logging frequence |
1-6 |
acl name |
1-6 |
activation-key |
2-1 |
active region-configuration |
Layer 2 - LAN Switching Command Reference |
7-1 |
add-member |
Network Management and Monitoring Command Reference |
8-14 |
administrator-address |
8-14 |
advantage-factor |
2-1 |
apply cost |
Layer 3 - IP Routing Command Reference |
6-1 |
apply ip-address next-hop |
6-6 |
apply ipv6 next-hop |
6-12 |
apply poe-profile |
4-1 |
apply poe-profile interface |
4-1 |
apply preference |
6-2 |
apply tag |
6-2 |
arp anti-attack active-ack enable |
16-8 |
arp anti-attack source-mac |
16-4 |
arp anti-attack source-mac aging-time |
16-5 |
arp anti-attack source-mac exclude-mac |
16-5 |
arp anti-attack source-mac threshold |
16-6 |
arp anti-attack valid-ack enable |
16-7 |
arp check enable |
Layer 3 - IP Services Command Reference |
1-1 |
arp detection enable |
16-9 |
arp detection mode |
16-9 |
arp detection static-bind |
16-10 |
arp detection trust |
16-11 |
arp detection validate |
16-11 |
arp max-learning-num |
1-2 |
arp rate-limit |
16-3 |
arp resolving-route enable |
16-1 |
arp source-suppression enable |
16-1 |
arp source-suppression limit |
16-2 |
arp static |
1-2 |
arp timer aging |
1-3 |
ascii |
3-6 |
attribute |
11-1 |
authentication default |
1-6 |
authentication lan-access |
1-7 |
authentication login |
1-8 |
authentication-mode |
2-3 |
authorization command |
1-9 |
authorization default |
1-10 |
authorization lan-access |
1-11 |
authorization login |
1-12 |
authorization-attribute |
1-13 |
auto-build |
8-15 |
auto-execute command |
2-4 |
backup startup-configuration |
6-1 |
binary |
3-7 |
bind-attribute |
1-14 |
black-list add-mac |
8-16 |
black-list delete-mac |
8-17 |
boot-loader |
7-1 |
bootrom |
7-1 |
bootrom-update security-check enable |
7-2 |
bpdu-drop any |
7-2 |
bpdu-tunnel dot1q |
8-1 |
bpdu-tunnel tunnel-dmac |
8-2 |
broadcast-suppression |
1-1 |
build |
8-17 |
bye |
3-7 |
bye |
13-2 |
ca identifier |
11-2 |
car |
2-8 |
cd |
3-7 |
cd |
5-1 |
cd |
13-2 |
cdup |
3-8 |
cdup |
13-3 |
certificate request entity |
11-2 |
certificate request from |
11-3 |
certificate request mode |
11-4 |
certificate request polling |
11-4 |
certificate request url |
11-5 |
cfd cc enable |
High Availability Command Reference |
2-1 |
cfd cc interval |
2-1 |
cfd enable |
2-2 |
cfd linktrace |
2-3 |
cfd linktrace auto-detection |
2-4 |
cfd loopback |
2-5 |
cfd ma |
2-6 |
cfd md |
2-7 |
cfd mep |
2-7 |
cfd mep enable |
2-8 |
cfd mip-rule |
2-8 |
cfd remote-mep |
2-10 |
cfd service-instance |
2-10 |
check region-configuration |
7-2 |
checkzero |
3-1 |
checkzero |
5-1 |
ciphersuite |
14-1 |
classifier behavior |
2-16 |
client-verify enable |
14-2 |
clock datetime |
8-1 |
clock summer-time one-off |
8-1 |
clock summer-time repeating |
8-2 |
clock timezone |
8-4 |
close |
3-9 |
close-mode wait |
14-2 |
cluster |
8-18 |
cluster enable |
8-19 |
cluster switch-to |
8-19 |
cluster-local-user |
8-20 |
cluster-mac |
8-21 |
cluster-mac syn-interval |
8-21 |
cluster-snmp-agent community |
8-22 |
cluster-snmp-agent group v3 |
8-23 |
cluster-snmp-agent mib-view included |
8-24 |
cluster-snmp-agent usm-user v3 |
8-25 |
codec-type |
2-1 |
command-alias enable |
1-1 |
command-alias mapping |
1-1 |
command-privilege level |
1-2 |
common-name |
11-6 |
control-vlan |
4-1 |
copy |
5-2 |
copyright-info enable |
2-5 |
country |
11-6 |
crl check |
11-7 |
crl update-period |
11-7 |
crl url |
11-8 |
cut connection |
1-16 |
databits |
2-6 |
data-fill |
2-2 |
data-flow-format (HWTACACS scheme view) |
3-1 |
data-flow-format (RADIUS scheme view) |
2-2 |
data-size |
2-3 |
debugging |
3-9 |
debugging |
1-8 |
default cost (RIP view) |
3-1 |
default cost (RIPng view) |
5-1 |
default-route |
3-2 |
delete |
3-11 |
delete |
5-2 |
delete |
13-3 |
delete ipv6 static-routes all |
4-1 |
delete static-routes all |
2-1 |
delete-member |
8-26 |
description |
1-2 |
description |
2-1 |
description |
5-1 |
description |
9-1 |
description |
1-7 |
description (any NQA test type view) |
2-4 |
destination ip |
2-4 |
destination port |
2-5 |
dhcp relay address-check |
4-1 |
dhcp relay information circuit-id format-type |
4-2 |
dhcp relay information circuit-id string |
4-2 |
dhcp relay information enable |
4-3 |
dhcp relay information format |
4-4 |
dhcp relay information remote-id format-type |
4-5 |
dhcp relay information remote-id string |
4-5 |
dhcp relay information strategy |
4-6 |
dhcp relay release ip |
4-7 |
dhcp relay security refresh enable |
4-8 |
dhcp relay security static |
4-7 |
dhcp relay security tracker |
4-9 |
dhcp relay server-detect |
4-9 |
dhcp relay server-group |
4-10 |
dhcp relay server-select |
4-11 |
dhcp select relay |
4-12 |
dhcp-snooping |
6-1 |
dhcp-snooping information circuit-id format-type |
6-2 |
dhcp-snooping information circuit-id string |
6-2 |
dhcp-snooping information enable |
6-3 |
dhcp-snooping information format |
6-4 |
dhcp-snooping information remote-id format-type |
6-4 |
dhcp-snooping information remote-id string |
6-5 |
dhcp-snooping information strategy |
6-6 |
dhcp-snooping trust |
6-7 |
dir |
3-11 |
dir |
5-3 |
dir |
13-4 |
disconnect |
3-12 |
display acl |
1-8 |
display acl ipv6 |
1-9 |
display acl resource |
1-10 |
display arp |
1-4 |
display arp anti-attack source-mac |
16-6 |
display arp detection |
16-12 |
display arp detection statistics |
16-12 |
display arp ip-address |
1-5 |
display arp source-suppression |
16-2 |
display arp timer aging |
1-6 |
display boot-loader |
7-3 |
display bootp client |
7-1 |
display brief interface |
1-3 |
display cfd linktrace-reply |
2-11 |
display cfd linktrace-reply auto-detection |
2-12 |
display cfd ma |
2-14 |
display cfd md |
2-15 |
display cfd mep |
2-16 |
display cfd mp |
2-18 |
display cfd remote-mep |
2-20 |
display cfd service-instance |
2-21 |
display cfd status |
2-22 |
display channel |
13-1 |
display clipboard |
1-3 |
display clock |
8-5 |
display cluster |
8-26 |
display cluster base-topology |
8-28 |
display cluster black-list |
8-30 |
display cluster candidates |
8-30 |
display cluster current-topology |
8-32 |
display cluster members |
8-34 |
display command-alias |
1-4 |
display connection |
1-16 |
display cpu-usage |
8-5 |
display cpu-usage history |
8-7 |
display current-configuration |
6-2 |
display debugging |
1-9 |
display default-configuration |
6-3 |
display device |
8-9 |
display device manuinfo |
8-10 |
display dhcp client |
5-1 |
display dhcp relay |
4-12 |
display dhcp relay information |
4-13 |
display dhcp relay security |
4-14 |
display dhcp relay security statistics |
4-15 |
display dhcp relay security tracker |
4-16 |
display dhcp relay server-group |
4-16 |
display dhcp relay statistics |
4-17 |
display dhcp-snooping |
6-7 |
display dhcp-snooping information |
6-8 |
display dhcp-snooping packet statistics |
6-9 |
display dhcp-snooping trust |
6-10 |
display diagnostic-information |
8-11 |
display dldp |
3-1 |
display dldp statistics |
3-3 |
display dns domain |
8-1 |
display dns dynamic-host |
8-2 |
display dns ipv6 dynamic-host |
11-1 |
display dns ipv6 server |
11-2 |
display dns server |
8-3 |
display domain |
1-18 |
display dot1x |
4-1 |
display environment |
8-11 |
display fan |
8-12 |
display fib |
9-1 |
display fib ip-address |
9-3 |
display ftp client configuration |
3-13 |
display ftp-server |
3-1 |
display ftp-user |
3-2 |
display garp statistics |
12-1 |
display garp timer |
12-2 |
display gvrp local-vlan |
12-2 |
display gvrp state |
12-3 |
display gvrp statistics |
12-4 |
display gvrp status |
12-5 |
display gvrp vlan-operation |
12-6 |
display habp |
9-1 |
display habp table |
9-1 |
display habp traffic |
9-2 |
display history-command |
1-4 |
display hotkey |
1-5 |
display hwtacacs |
3-1 |
display icmp statistics |
9-4 |
display igmp-snooping group |
IP Multicast Command Reference |
1-1 |
display igmp-snooping statistics |
1-2 |
display info-center |
13-2 |
display interface |
1-6 |
display interface loopback |
2-2 |
display interface null |
2-4 |
display interface vlan-interface |
9-2 |
display ip check source |
15-1 |
display ip host |
8-4 |
display ip http |
2-6 |
display ip https |
2-7 |
display ip interface |
3-1 |
display ip interface brief |
3-3 |
display ip ip-prefix |
6-7 |
display ip ipv6-prefix |
6-12 |
display ip routing-table |
1-1 |
display ip routing-table acl |
1-5 |
display ip routing-table ip-address |
1-7 |
display ip routing-table ip-prefix |
1-9 |
display ip routing-table protocol |
1-10 |
display ip routing-table statistics |
1-11 |
display ip socket |
9-5 |
display ip statistics |
9-8 |
display ip-subnet-vlan interface |
9-29 |
display ip-subnet-vlan vlan |
9-30 |
display ipv6 fib |
11-3 |
display ipv6 host |
11-4 |
display ipv6 interface |
11-5 |
display ipv6 neighbors |
11-9 |
display ipv6 neighbors count |
11-11 |
display ipv6 pathmtu |
11-11 |
display ipv6 routing-table |
1-12 |
display ipv6 routing-table acl |
1-13 |
display ipv6 routing-table ipv6-address |
1-14 |
display ipv6 routing-table ipv6-address1 ipv6-address2 |
1-15 |
display ipv6 routing-table ipv6-prefix |
1-16 |
display ipv6 routing-table protocol |
1-16 |
display ipv6 routing-table statistics |
1-17 |
display ipv6 routing-table verbose |
1-18 |
display ipv6 socket |
11-12 |
display ipv6 statistics |
11-14 |
display isolate-user-vlan |
10-1 |
display lacp system-id |
5-2 |
display link-aggregation load-sharing mode |
5-2 |
display link-aggregation member-port |
5-4 |
display link-aggregation summary |
5-7 |
display link-aggregation verbose |
5-8 |
display lldp local-information |
14-1 |
display lldp neighbor-information |
14-5 |
display lldp statistics |
14-9 |
display lldp status |
14-11 |
display lldp tlv-config |
14-13 |
display local-proxy-arp |
2-1 |
display local-user |
1-19 |
display logbuffer |
13-4 |
display logbuffer summary |
13-6 |
display loopback-detection |
1-10 |
display mac-address |
3-1 |
display mac-address aging-time |
3-2 |
display mac-authentication |
6-1 |
display mac-vlan |
9-19 |
display mac-vlan interface |
9-21 |
display memory |
8-13 |
display mib-style |
6-1 |
display mirroring-group |
10-1 |
display mld-snooping group |
3-1 |
display mld-snooping statistics |
3-2 |
display monitor-link group |
6-1 |
display multicast-vlan |
2-1 |
display multicast-vlan ipv6 |
4-1 |
display ndp |
8-1 |
display nqa history |
2-6 |
display nqa result |
2-7 |
display nqa server status |
2-37 |
display nqa statistics |
2-11 |
display ntdp |
8-7 |
display ntdp device-list |
8-8 |
display ntdp single-device mac-address |
8-9 |
display ntp-service sessions |
3-1 |
display ntp-service status |
3-6 |
display ntp-service trace |
3-7 |
display oam |
1-1 |
display oam configuration |
1-5 |
display oam critical-event |
1-6 |
display oam link-event |
1-7 |
display packet-drop interface |
1-11 |
display packet-drop summary |
1-12 |
display patch information |
7-3 |
display pki certificate |
11-9 |
display pki certificate access-control-policy |
11-10 |
display pki certificate attribute-group |
11-11 |
display pki crl domain |
11-12 |
display poe device |
4-2 |
display poe interface |
4-3 |
display poe interface power |
4-7 |
display poe pse |
4-8 |
display poe pse interface |
4-9 |
display poe pse interface power |
4-11 |
display poe-profile |
4-12 |
display poe-profile interface |
4-14 |
display port |
9-10 |
display port combo |
1-12 |
display port-group manual |
1-13 |
display port-isolate group |
6-1 |
display port-security |
7-1 |
display port-security mac-address block |
7-4 |
display port-security mac-address security |
7-5 |
display power |
8-13 |
display protocol-vlan interface |
9-24 |
display protocol-vlan vlan |
9-24 |
display proxy-arp |
2-1 |
display public-key local public |
10-1 |
display public-key peer |
10-2 |
display qos gts interface |
4-1 |
display qos lr interface |
4-3 |
display qos map-table |
3-1 |
display qos policy |
2-16 |
display qos policy global |
2-17 |
display qos policy interface |
2-19 |
display qos sp interface |
5-1 |
display qos trust interface |
3-4 |
display qos vlan-policy |
2-20 |
display qos wfq interface |
5-1 |
display qos wrr interface |
5-2 |
display radius scheme |
2-2 |
display radius statistics |
2-5 |
display reboot-type |
8-14 |
display rip |
3-3 |
display rip database |
3-5 |
display rip interface |
3-6 |
display rip route |
3-7 |
display ripng |
5-2 |
display ripng database |
5-3 |
display ripng interface |
5-4 |
display ripng route |
5-6 |
display rmon alarm |
7-1 |
display rmon event |
7-2 |
display rmon eventlog |
7-3 |
display rmon history |
7-4 |
display rmon prialarm |
7-7 |
display rmon statistics |
7-9 |
display route-policy |
6-3 |
display rps |
8-15 |
display rrpp brief |
4-2 |
display rrpp ring-group |
4-4 |
display rrpp statistics |
4-4 |
display rrpp verbose |
4-7 |
display saved-configuration |
6-3 |
display schedule job |
8-15 |
display schedule reboot |
8-16 |
display sflow |
12-1 |
display sftp client source |
13-5 |
display smart-link flush |
5-1 |
display smart-link group |
5-2 |
display snmp-agent community |
5-1 |
display snmp-agent group |
5-2 |
display snmp-agent local-engineid |
5-3 |
display snmp-agent mib-view |
5-4 |
display snmp-agent statistics |
5-5 |
display snmp-agent sys-info |
5-7 |
display snmp-agent trap queue |
5-8 |
display snmp-agent trap-list |
5-9 |
display snmp-agent usm-user |
5-9 |
display ssh client source |
12-8 |
display ssh server |
12-1 |
display ssh server-info |
12-9 |
display ssh user-information |
12-2 |
display ssl client-policy |
14-3 |
display ssl server-policy |
14-4 |
display stack |
9-1 |
display startup |
6-5 |
display stop-accounting-buffer |
2-8 |
3-3 |
display storm-constrain |
1-14 |
display stp |
7-3 |
display stp abnormal-port |
7-9 |
display stp down-port |
7-10 |
display stp history |
7-11 |
display stp region-configuration |
7-12 |
display stp root |
7-13 |
display stp tc |
7-14 |
display system-failure |
8-16 |
display tcp ipv6 statistics |
11-18 |
display tcp ipv6 status |
11-21 |
display tcp statistics |
9-9 |
display tcp status |
9-12 |
display telnet client configuration |
2-8 |
display tftp client configuration |
4-1 |
display this |
6-6 |
display time-range |
1-11 |
display track |
7-1 |
display traffic behavior |
2-9 |
display traffic classifier |
2-1 |
display transceiver |
8-21 |
display transceiver alarm |
8-17 |
display transceiver diagnosis |
8-20 |
display transceiver manuinfo |
8-23 |
display trapbuffer |
13-7 |
display udp ipv6 statistics |
11-22 |
display udp statistics |
9-13 |
display udp-helper server |
10-1 |
display user-bind |
15-2 |
display user-group |
1-21 |
display user-interface |
2-8 |
display user-profile |
8-1 |
display users |
2-10 |
display version |
8-24 |
display vlan |
9-3 |
display voice vlan oui |
11-1 |
display voice vlan state |
11-2 |
display web users |
2-11 |
dldp authentication-mode |
3-4 |
dldp delaydown-timer |
3-5 |
dldp enable |
3-5 |
dldp interval |
3-6 |
dldp reset |
3-7 |
dldp unidirectional-shutdown |
3-7 |
dldp work-mode |
3-8 |
dns domain |
8-4 |
dns proxy enable |
8-5 |
dns resolve |
8-6 |
dns server |
8-6 |
dns server ipv6 |
11-23 |
domain |
1-21 |
domain default enable |
1-22 |
domain ring |
4-10 |
dot1x |
4-4 |
dot1x authentication-method |
4-5 |
dot1x free-ip |
5-1 |
dot1x guest-vlan |
4-6 |
dot1x handshake |
4-8 |
dot1x handshake secure |
4-8 |
dot1x mandatory-domain |
4-9 |
dot1x max-user |
4-10 |
dot1x multicast-trigger |
4-11 |
dot1x port-control |
4-11 |
dot1x port-method |
4-12 |
dot1x quiet-period |
4-14 |
dot1x re-authenticate |
4-14 |
dot1x retry |
4-15 |
dot1x timer |
4-16 |
dot1x timer ead-timeout |
5-2 |
dot1x url |
5-2 |
duplex |
1-15 |
enable log updown |
13-8 |
enable snmp trap updown |
5-11 |
5-10 |
escape-key |
2-12 |
execute |
5-4 |
exit |
13-5 |
expiration-date |
1-23 |
fast-leave (IGMP-Snooping view) |
1-3 |
fast-leave (MLD-Snooping view) |
3-3 |
file prompt |
5-5 |
filename |
2-16 |
filter |
2-10 |
filter-policy export (RIP view) |
3-9 |
filter-policy export (RIPng view) |
5-7 |
filter-policy import (RIP view) |
3-10 |
filter-policy import (RIPng view) |
5-8 |
fixdisk |
5-6 |
flow-control |
2-13 |
flow-control |
1-16 |
flow-interval |
1-17 |
flush enable |
5-3 |
format |
5-6 |
fqdn |
11-13 |
free ftp user |
3-3 |
free user-interface |
2-14 |
free web-users |
2-14 |
frequency |
2-16 |
ftp |
3-13 |
ftp client source |
3-15 |
ftp ipv6 |
3-16 |
ftp server acl |
3-3 |
ftp server enable |
3-4 |
ftp timeout |
3-4 |
ftp update |
3-5 |
ftp-server |
8-36 |
garp timer hold |
12-6 |
garp timer join |
12-7 |
garp timer leave |
12-8 |
garp timer leaveall |
12-8 |
get |
3-16 |
get |
13-6 |
gratuitous-arp-learning enable |
1-8 |
gratuitous-arp-sending enable |
1-7 |
group |
1-24 |
group-member |
1-17 |
group-policy (IGMP-Snooping view) |
1-4 |
group-policy (MLD-Snooping view) |
3-4 |
gvrp |
12-9 |
gvrp registration |
12-10 |
habp enable |
9-3 |
habp server vlan |
9-3 |
habp timer |
9-4 |
handshake timeout |
14-5 |
header |
8-24 |
help |
13-6 |
history-command max-size |
2-15 |
history-records |
2-17 |
holdtime |
8-37 |
host-aging-time (IGMP-Snooping view) |
1-5 |
host-aging-time (MLD-Snooping view) |
3-5 |
host-route |
3-12 |
hotkey |
1-6 |
http-version |
2-18 |
hwtacacs nas-ip |
3-4 |
hwtacacs scheme |
3-5 |
idle-cut enable |
1-24 |
idle-timeout |
2-15 |
if-match |
2-2 |
if-match acl |
6-8 |
if-match cost |
6-4 |
if-match interface |
6-4 |
if-match ip |
6-9 |
if-match ip-prefix |
6-9 |
if-match ipv6 |
6-13 |
if-match tag |
6-5 |
igmp-snooping |
1-6 |
igmp-snooping drop-unknown |
1-6 |
igmp-snooping enable |
1-7 |
igmp-snooping fast-leave |
1-7 |
igmp-snooping general-query source-ip |
1-8 |
igmp-snooping group-limit |
1-9 |
igmp-snooping group-policy |
1-10 |
igmp-snooping host-aging-time |
1-11 |
igmp-snooping host-join |
1-12 |
igmp-snooping last-member-query-interval |
1-13 |
igmp-snooping max-response-time |
1-13 |
igmp-snooping overflow-replace |
1-14 |
igmp-snooping querier |
1-15 |
igmp-snooping query-interval |
1-15 |
igmp-snooping router-aging-time |
1-16 |
igmp-snooping source-deny |
1-17 |
igmp-snooping special-query source-ip |
1-17 |
igmp-snooping static-group |
1-18 |
igmp-snooping static-router-port |
1-19 |
igmp-snooping version |
1-20 |
import |
3-2 |
import-route |
5-9 |
import-route (RIP view) |
3-12 |
info-center channel name |
13-9 |
info-center console channel |
13-9 |
info-center enable |
13-10 |
info-center logbuffer |
13-11 |
info-center loghost |
13-11 |
info-center loghost source |
13-12 |
info-center monitor channel |
13-13 |
info-center snmp channel |
13-14 |
info-center source |
13-15 |
info-center synchronous |
13-17 |
info-center timestamp |
13-18 |
info-center timestamp loghost |
13-19 |
info-center trapbuffer |
13-20 |
instance |
7-15 |
interface |
1-18 |
interface bridge-aggregation |
5-11 |
2-5 |
interface null |
2-5 |
9-5 |
ip (PKI entity view) |
11-14 |
ip address |
9-6 |
ip address |
3-5 |
ip address bootp-alloc |
7-2 |
ip address dhcp-alloc |
5-3 |
ip check source |
15-3 |
ip forward-broadcast (interface view) |
9-14 |
ip forward-broadcast (system view) |
9-15 |
ip host |
8-7 |
ip http acl |
2-16 |
ip http enable |
2-17 |
ip http port |
2-17 |
ip https acl |
2-18 |
ip https certificate access-control-policy |
2-19 |
ip https enable |
2-19 |
ip https port |
2-20 |
ip https ssl-server-policy |
2-20 |
ip ip-prefix |
6-10 |
ip ipv6-prefix |
6-14 |
ip redirects enable |
9-15 |
ip route-static |
2-2 |
ip route-static default-preference |
2-3 |
ip ttl-expires enable |
9-16 |
ip unreachables enable |
9-16 |
ip-pool |
8-38 |
ip-subnet-vlan |
9-31 |
ipv6 |
11-24 |
ipv6 address |
11-24 |
ipv6 address auto link-local |
11-25 |
ipv6 address eui-64 |
11-26 |
ipv6 address link-local |
11-27 |
ipv6 hoplimit-expires enable |
11-27 |
ipv6 host |
11-28 |
ipv6 icmp-error |
11-29 |
ipv6 icmpv6 multicast-echo-reply enable |
11-29 |
ipv6 nd autoconfig managed-address-flag |
11-30 |
ipv6 nd autoconfig other-flag |
11-30 |
ipv6 nd dad attempts |
11-31 |
ipv6 nd hop-limit |
11-31 |
ipv6 nd ns retrans-timer |
11-32 |
ipv6 nd nud reachable-time |
11-33 |
ipv6 nd ra halt |
11-33 |
ipv6 nd ra interval |
11-34 |
ipv6 nd ra prefix |
11-35 |
ipv6 nd ra router-lifetime |
11-35 |
ipv6 neighbor |
11-36 |
ipv6 neighbors max-learning-num |
11-37 |
ipv6 pathmtu |
11-38 |
ipv6 pathmtu age |
11-38 |
ipv6 route-static |
4-2 |
isolate-user-vlan |
10-2 |
isolate-user-vlan enable |
10-4 |
jumboframe enable |
1-18 |
key (HWTACACS scheme view) |
3-5 |
key (RADIUS scheme view) |
2-9 |
lacp port-priority |
5-12 |
lacp system-priority |
5-13 |
last-listener-query-interval (MLD-Snooping view) |
3-6 |
last-member-query-interval (IGMP-Snooping view) |
1-20 |
lcd |
3-17 |
ldap-server |
11-14 |
5-13 |
link-aggregation mode |
5-15 |
link-delay |
1-19 |
lldp admin-status |
14-14 |
lldp check-change-interval |
14-15 |
lldp compliance admin-status cdp |
14-15 |
lldp compliance cdp |
14-16 |
lldp enable |
14-17 |
lldp encapsulation snap |
14-17 |
lldp fast-count |
14-18 |
lldp hold-multiplier |
14-18 |
lldp management-address-format string |
14-19 |
lldp management-address-tlv |
14-20 |
lldp notification remote-change enable |
14-20 |
lldp timer notification-interval |
14-21 |
lldp timer reinit-delay |
14-21 |
lldp timer tx-delay |
14-22 |
lldp timer tx-interval |
14-22 |
lldp tlv-enable |
14-23 |
locality |
11-15 |
local-proxy-arp enable |
2-2 |
local-user |
1-25 |
local-user password-display-mode |
1-26 |
lock |
2-21 |
logging-host |
8-38 |
loopback |
1-20 |
loopback-detection control enable |
1-21 |
loopback-detection enable |
1-21 |
loopback-detection interval-time |
1-22 |
loopback-detection per-vlan enable |
1-23 |
ls |
3-18 |
ls |
13-7 |
mac-address |
1-24 |
mac-address |
5-16 |
mac-address (Interface view) |
3-3 |
mac-address (system view) |
3-4 |
mac-address information enable (Ethernet interface view) |
4-1 |
mac-address information enable (system view) |
4-2 |
mac-address information interval |
4-2 |
mac-address information mode |
4-3 |
mac-address information queue-length |
4-3 |
mac-address max-mac-count (Interface view) |
3-5 |
mac-address station-move |
1-6 |
mac-address timer |
3-6 |
6-3 |
mac-authentication domain |
6-4 |
mac-authentication guest-vlan |
6-5 |
mac-authentication timer |
6-5 |
mac-authentication user-name-format |
6-6 |
mac-vlan enable |
9-21 |
mac-vlan mac-address |
9-22 |
management-vlan |
8-39 |
management-vlan synchronization enable |
8-40 |
max-response-time (IGMP-Snooping view) |
1-21 |
max-response-time (MLD-Snooping view) |
3-6 |
mdi |
1-24 |
mib-style |
6-1 |
mirroring-group |
10-2 |
mirroring-group mirroring-port |
10-3 |
mirroring-group monitor-egress |
10-3 |
mirroring-group monitor-port |
10-4 |
mirroring-group remote-probe vlan |
10-5 |
mirroring-port |
10-6 |
mirror-to cpu |
11-1 |
mirror-to interface |
11-2 |
mkdir |
3-19 |
mkdir |
5-7 |
mkdir |
13-7 |
mld-snooping |
3-7 |
mld-snooping enable |
3-7 |
mld-snooping fast-leave |
3-8 |
mld-snooping general-query source-ip |
3-9 |
mld-snooping group-limit |
3-10 |
mld-snooping group-policy |
3-11 |
mld-snooping host-aging-time |
3-12 |
mld-snooping host-join |
3-12 |
mld-snooping last-listener-query-interval |
3-14 |
mld-snooping max-response-time |
3-14 |
mld-snooping overflow-replace |
3-15 |
mld-snooping querier |
3-16 |
mld-snooping query-interval |
3-16 |
mld-snooping router-aging-time |
3-17 |
mld-snooping source-deny |
3-18 |
mld-snooping special-query source-ip |
3-18 |
mld-snooping static-group |
3-19 |
mld-snooping static-router-port |
3-20 |
mld-snooping version |
3-21 |
6-2 |
monitor-port |
10-7 |
more |
5-8 |
move |
5-8 |
multicast-suppression |
1-25 |
multicast-vlan |
2-2 |
4-2 |
name |
9-7 |
nas-ip (HWTACACS scheme view) |
3-6 |
nas-ip (RADIUS scheme view) |
2-10 |
ndp enable |
8-4 |
ndp timer aging |
8-5 |
ndp timer hello |
8-6 |
network |
3-13 |
next-hop |
2-18 |
nm-interface vlan-interface |
8-40 |
nqa |
2-19 |
nqa agent enable |
2-20 |
nqa agent max-concurrent |
2-20 |
nqa schedule |
2-21 |
nqa server enable |
2-38 |
nqa server tcp-connect |
2-38 |
nqa server udp-echo |
2-39 |
ntdp enable |
8-10 |
ntdp explore |
8-11 |
ntdp hop |
8-11 |
ntdp timer |
8-12 |
ntdp timer hop-delay |
8-12 |
ntdp timer port-delay |
8-13 |
ntp-service access |
3-8 |
ntp-service authentication enable |
3-9 |
ntp-service authentication-keyid |
3-10 |
ntp-service broadcast-client |
3-11 |
ntp-service broadcast-server |
3-12 |
ntp-service in-interface disable |
3-12 |
ntp-service max-dynamic-sessions |
3-13 |
ntp-service multicast-client |
3-14 |
ntp-service multicast-server |
3-14 |
ntp-service reliable authentication-keyid |
3-15 |
ntp-service source-interface |
3-16 |
ntp-service unicast-peer |
3-16 |
ntp-service unicast-server |
3-17 |
oam enable |
1-10 |
oam errored-frame period |
1-10 |
oam errored-frame threshold |
1-11 |
oam errored-frame-period period |
1-11 |
oam errored-frame-period threshold |
1-12 |
oam errored-frame-seconds period |
1-12 |
oam errored-frame-seconds threshold |
1-13 |
oam errored-symbol period |
1-14 |
oam errored-symbol threshold |
1-14 |
oam loopback |
1-15 |
oam mode |
1-15 |
open |
3-19 |
open ipv6 |
3-20 |
operation (FTP test type view) |
2-22 |
operation (HTTP test type view) |
2-22 |
operation interface |
2-23 |
organization |
11-15 |
organization-unit |
11-16 |
output-delay |
3-14 |
overflow-replace (IGMP-Snooping view) |
1-22 |
overflow-replace (MLD-Snooping view) |
3-22 |
packet-filter |
1-12 |
packet-filter ipv6 |
1-13 |
parity |
2-22 |
passive |
3-21 |
password |
1-26 |
password (FTP test type view) |
2-23 |
patch active |
7-4 |
patch deactive |
7-5 |
patch delete |
7-5 |
patch install |
7-6 |
patch load |
7-7 |
patch location |
7-7 |
patch run |
7-8 |
peer |
3-15 |
peer-public-key end |
10-3 |
ping |
1-1 |
ping ipv6 |
1-4 |
11-17 |
11-17 |
pki delete-certificate |
11-18 |
pki domain |
11-18 |
pki entity |
11-19 |
pki import-certificate |
11-19 |
pki request-certificate domain |
11-20 |
pki retrieval-certificate |
11-21 |
pki retrieval-crl domain |
11-21 |
pki validate-certificate |
11-22 |
pki-domain |
14-6 |
poe disconnect |
4-15 |
poe enable |
4-15 |
poe legacy enable |
4-16 |
poe max-power |
4-17 |
poe mode |
4-18 |
poe pd-description |
4-18 |
poe pd-policy priority |
4-19 |
poe priority |
4-19 |
poe update |
4-20 |
poe utilization-threshold |
4-21 |
poe-profile |
4-22 |
port |
9-11 |
port |
5-3 |
port |
6-2 |
port (IPv6 multicast VLAN view) |
4-2 |
port (multicast VLAN view) |
2-2 |
port access vlan |
9-11 |
port hybrid ip-subnet-vlan |
9-32 |
port hybrid protocol-vlan |
9-25 |
port hybrid pvid |
9-12 |
port hybrid vlan |
9-13 |
port link-aggregation group |
5-17 |
port link-type |
9-15 |
port monitor-link group |
6-3 |
port multicast-vlan |
2-3 |
port multicast-vlan ipv6 |
4-3 |
port smart-link group |
5-4 |
port trunk permit vlan |
9-16 |
port trunk pvid |
9-18 |
port-group manual |
1-26 |
port-isolate enable |
6-1 |
port-security authorization ignore |
7-6 |
port-security enable |
7-7 |
port-security intrusion-mode |
7-8 |
7-9 |
port-security max-mac-count |
7-10 |
port-security ntk-mode |
7-11 |
port-security oui |
7-11 |
port-security port-mode |
7-12 |
port-security timer disableport |
7-15 |
port-security trap |
7-16 |
preemption delay |
5-5 |
preemption mode |
5-6 |
prefer-cipher |
14-6 |
preference |
3-15 |
preference |
5-9 |
primary accounting (HWTACACS scheme view) |
3-7 |
primary accounting (RADIUS scheme view) |
2-10 |
primary authentication (HWTACACS scheme view) |
3-8 |
primary authentication (RADIUS scheme view) |
2-11 |
primary authorization |
3-8 |
probe count |
2-24 |
probe packet-interval |
2-25 |
probe packet-number |
2-25 |
probe packet-timeout |
2-26 |
probe timeout |
2-27 |
protected-vlan |
4-11 |
protected-vlan |
5-6 |
protocol inbound |
2-23 |
protocol-vlan |
9-27 |
proxy-arp enable |
2-2 |
public-key local create |
10-5 |
public-key local destroy |
10-6 |
public-key local export dsa |
10-7 |
public-key local export rsa |
10-8 |
public-key peer |
10-9 |
public-key peer import sshkey |
10-10 |
public-key-code begin |
10-4 |
public-key-code end |
10-5 |
put |
3-21 |
put |
13-8 |
pwd |
3-22 |
pwd |
5-9 |
pwd |
13-8 |
qinq enable |
13-2 |
qinq ethernet-type |
13-3 |
qinq vid |
13-4 |
qos apply policy (interface view, port group view) |
2-22 |
qos apply policy (user-profile view) |
2-22 |
qos apply policy global |
2-23 |
qos bandwidth queue |
5-3 |
qos gts |
4-2 |
qos lr |
4-3 |
qos map-table |
3-2 |
qos policy |
2-24 |
qos priority |
3-3 |
qos sp |
5-4 |
qos trust |
3-5 |
qos vlan-policy |
2-24 |
qos wfq |
5-5 |
qos wfq weight |
5-5 |
qos wrr |
5-6 |
qos wrr group |
5-7 |
quit |
1-8 |
quit |
3-22 |
quit |
13-9 |
radius client |
2-12 |
radius nas-ip |
2-13 |
radius scheme |
2-14 |
radius trap |
2-14 |
raw-vlan-id inbound |
13-1 |
reaction |
2-27 |
reaction trap |
2-28 |
reboot |
8-26 |
reboot member |
8-41 |
redirect |
2-11 |
region-name |
7-15 |
remark dot1p |
2-11 |
remark drop-precedence |
2-12 |
remark dscp |
2-12 |
remark ip-precedence |
2-14 |
remark local-precedence |
2-14 |
remotehelp |
3-23 |
remove |
13-9 |
rename |
5-9 |
rename |
13-10 |
report-aggregation (IGMP-Snooping view) |
1-22 |
report-aggregation (MLD-Snooping view) |
3-22 |
reset acl counter |
1-13 |
reset acl ipv6 counter |
1-14 |
reset arp |
1-7 |
reset arp detection statistics |
16-13 |
reset counters interface |
1-27 |
2-6 |
5-17 |
9-7 |
reset dhcp relay statistics |
4-19 |
reset dhcp-snooping |
6-10 |
reset dhcp-snooping packet statistics |
6-11 |
reset dldp statistics |
3-8 |
reset dns dynamic-host |
8-7 |
reset dns ipv6 dynamic-host |
11-39 |
reset dot1x statistics |
4-17 |
reset garp statistics |
12-10 |
reset hwtacacs statistics |
3-9 |
reset igmp-snooping group |
1-23 |
reset igmp-snooping statistics |
1-23 |
reset ip ip-prefix |
6-11 |
reset ip ipv6-prefix |
6-15 |
reset ip routing-table statistics protocol |
1-19 |
reset ip statistics |
9-17 |
reset ipv6 neighbors |
11-39 |
reset ipv6 pathmtu |
11-40 |
reset ipv6 routing-table statistics |
1-20 |
reset ipv6 statistics |
11-40 |
reset lacp statistics |
5-18 |
reset logbuffer |
13-21 |
reset mac-authentication statistics |
6-8 |
reset mld-snooping group |
3-23 |
reset mld-snooping statistics |
3-23 |
reset ndp statistics |
8-6 |
reset oam |
1-16 |
reset packet-drop interface |
1-27 |
reset qos policy global |
2-25 |
reset qos vlan-policy |
2-25 |
reset radius statistics |
2-15 |
reset recycle-bin |
5-10 |
reset rip statistics |
3-16 |
reset rrpp statistics |
4-12 |
reset saved-configuration |
6-7 |
reset smart-link statistics |
5-7 |
reset stop-accounting-buffer |
2-16 |
3-10 |
reset stp |
7-16 |
reset tcp ipv6 statistics |
11-41 |
reset tcp statistics |
9-17 |
reset trapbuffer |
13-21 |
reset udp ipv6 statistics |
11-41 |
reset udp statistics |
9-18 |
reset udp-helper packet |
10-1 |
reset unused porttag |
8-27 |
restore startup-configuration |
6-8 |
retry |
2-16 |
retry realtime-accounting |
2-17 |
retry stop-accounting (HWTACACS scheme view) |
3-10 |
retry stop-accounting (RADIUS scheme view) |
2-18 |
return |
1-8 |
revision-level |
7-17 |
ring |
4-13 |
ring enable |
4-15 |
rip |
3-16 |
rip authentication-mode |
3-17 |
rip default-route |
3-18 |
rip input |
3-19 |
rip metricin |
3-19 |
rip metricout |
3-20 |
rip mib-binding |
3-21 |
rip output |
3-22 |
rip poison-reverse |
3-22 |
rip split-horizon |
3-23 |
rip summary-address |
3-23 |
rip version |
3-24 |
ripng |
5-10 |
ripng default-route |
5-11 |
ripng enable |
5-12 |
ripng metricin |
5-12 |
ripng metricout |
5-13 |
ripng poison-reverse |
5-13 |
ripng split-horizon |
5-14 |
ripng summary-address |
5-15 |
rmdir |
3-25 |
rmdir |
5-12 |
rmdir |
13-10 |
rmon alarm |
7-11 |
rmon event |
7-13 |
rmon history |
7-14 |
rmon prialarm |
7-15 |
rmon statistics |
7-17 |
root-certificate fingerprint |
11-22 |
route-option bypass-route |
2-29 |
route-policy |
6-5 |
router-aging-time (IGMP-Snooping view) |
1-24 |
router-aging-time (MLD-Snooping view) |
3-24 |
rrpp domain |
4-16 |
rrpp enable |
4-16 |
rrpp ring-group |
4-17 |
rule (Ethernet frame header ACL view) |
1-15 |
rule (IPv4 advanced ACL view) |
1-16 |
rule (IPv4 basic ACL view) |
1-21 |
rule (IPv6 advanced ACL view) |
1-22 |
rule (IPv6 basic ACL view) |
1-26 |
rule (PKI CERT ACP view) |
11-23 |
rule comment |
1-27 |
save |
6-8 |
schedule job |
8-28 |
schedule reboot at |
8-29 |
schedule reboot delay |
8-31 |
screen-length |
2-23 |
screen-length disable |
1-9 |
secondary accounting (HWTACACS scheme view) |
3-11 |
secondary accounting (RADIUS scheme view) |
2-19 |
secondary authentication (HWTACACS scheme view) |
3-12 |
secondary authentication (RADIUS scheme view) |
2-20 |
secondary authorization |
3-12 |
security-policy-server |
2-21 |
self-service-url enable |
1-27 |
send |
2-24 |
server-type |
2-21 |
service-type |
1-28 |
session |
14-7 |
set authentication password |
2-25 |
sflow agent ip |
12-2 |
sflow collector ip |
12-3 |
sflow enable |
12-3 |
sflow interval |
12-4 |
sflow sampling-mode |
12-5 |
sflow sampling-rate |
12-5 |
sflow version |
12-6 |
sftp |
13-11 |
sftp client ipv6 source |
13-12 |
13-12 |
sftp ipv6 |
13-13 |
sftp server enable |
13-1 |
sftp server idle-timeout |
13-1 |
shell |
2-26 |
shutdown |
1-28 |
shutdown |
2-6 |
shutdown |
5-18 |
shutdown |
9-8 |
shutdown-interval |
8-32 |
silent-interface (RIP view) |
3-25 |
slave auto-update config |
6-10 |
smart-link flush enable |
5-8 |
smart-link group |
5-9 |
snmp-agent |
5-11 |
snmp-agent calculate-password |
5-12 |
5-13 |
snmp-agent group |
5-15 |
5-16 |
snmp-agent log |
5-17 |
5-17 |
snmp-agent packet max-size |
5-18 |
5-19 |
snmp-agent target-host |
5-20 |
snmp-agent trap enable |
5-21 |
snmp-agent trap if-mib link extended |
5-22 |
snmp-agent trap life |
5-23 |
snmp-agent trap queue-size |
5-24 |
snmp-agent trap source |
5-25 |
snmp-agent usm-user { v1 | v2c } |
5-25 |
5-27 |
snmp-host |
8-41 |
source interface |
2-30 |
source ip |
2-30 |
source port |
2-31 |
source-deny (IGMP-Snooping view) |
1-24 |
source-deny (MLD-Snooping view) |
3-24 |
speed |
2-26 |
speed |
1-29 |
speed auto |
1-29 |
ssh client authentication server |
12-9 |
ssh client first-time enable |
12-10 |
ssh client ipv6 source |
12-11 |
ssh client source |
12-11 |
ssh server authentication-retries |
12-3 |
ssh server authentication-timeout |
12-4 |
ssh server compatible-ssh1x enable |
12-5 |
ssh server enable |
12-5 |
ssh server rekey-interval |
12-6 |
ssh user |
12-7 |
ssh2 |
12-12 |
ssh2 ipv6 |
12-13 |
ssl client-policy |
14-8 |
ssl server-policy |
14-8 |
stack ip-pool |
9-3 |
stack role master |
9-3 |
stack stack-port |
9-4 |
stack switch-to |
9-5 |
startup bootrom-access enable |
8-33 |
startup saved-configuration |
6-10 |
state |
1-29 |
state |
2-22 |
state |
11-24 |
statistics hold-time |
2-32 |
statistics interval |
2-33 |
statistics max-group |
2-32 |
step |
1-28 |
stop-accounting-buffer enable (HWTACACS scheme view) |
3-13 |
stop-accounting-buffer enable (RADIUS scheme view) |
2-23 |
stopbits |
2-27 |
storm-constrain |
1-31 |
storm-constrain control |
1-32 |
storm-constrain enable log |
1-33 |
storm-constrain enable trap |
1-33 |
storm-constrain interval |
1-34 |
stp bpdu-protection |
7-17 |
stp bridge-diameter |
7-18 |
stp compliance |
7-19 |
stp config-digest-snooping |
7-19 |
stp cost |
7-20 |
stp edged-port |
7-21 |
stp enable |
7-22 |
stp loop-protection |
7-23 |
stp max-hops |
7-24 |
stp mcheck |
7-25 |
stp mode |
7-26 |
stp no-agreement-check |
7-26 |
stp pathcost-standard |
7-27 |
stp point-to-point |
7-29 |
stp port priority |
7-30 |
stp port-log |
7-30 |
stp priority |
7-31 |
7-32 |
stp root primary |
7-32 |
stp root secondary |
7-33 |
stp root-protection |
7-34 |
stp tc-protection |
7-35 |
stp tc-protection threshold |
7-35 |
stp timer forward-delay |
7-36 |
stp timer hello |
7-37 |
stp timer max-age |
7-37 |
stp timer-factor |
7-38 |
stp transmit-limit |
7-39 |
subvlan (IPv6 multicast VLAN view) |
4-4 |
subvlan (multicast VLAN view) |
2-4 |
summary |
3-26 |
super |
1-9 |
super password |
1-10 |
sysname |
8-33 |
system-failure |
8-34 |
system-view |
1-11 |
tcp ipv6 timer fin-timeout |
11-42 |
tcp ipv6 timer syn-timeout |
11-42 |
tcp ipv6 window |
11-43 |
tcp timer fin-timeout |
9-18 |
tcp timer syn-timeout |
9-19 |
tcp window |
9-19 |
telnet |
2-28 |
telnet client source |
2-30 |
telnet ipv6 |
2-29 |
telnet server enable |
2-30 |
terminal debugging |
13-22 |
terminal logging |
13-22 |
terminal monitor |
13-23 |
terminal trapping |
13-24 |
terminal type |
2-31 |
tftp |
4-2 |
tftp client source |
4-3 |
tftp ipv6 |
4-4 |
tftp-server |
8-42 |
tftp-server acl |
4-1 |
timer |
4-17 |
timer |
8-43 |
timer quiet (HWTACACS scheme view) |
3-14 |
timer quiet (RADIUS scheme view) |
2-24 |
timer realtime-accounting (HWTACACS scheme view) |
3-14 |
timer realtime-accounting (RADIUS scheme view) |
2-24 |
timer response-timeout (HWTACACS scheme view) |
3-15 |
timer response-timeout (RADIUS scheme view) |
2-25 |
time-range |
1-29 |
timers |
3-26 |
timers |
5-15 |
topology accept |
8-43 |
topology restore-from |
8-44 |
topology save-to |
8-45 |
tos |
2-34 |
tracert |
1-5 |
tracert ipv6 |
1-7 |
track nqa |
7-2 |
traffic behavior |
2-15 |
2-6 |
ttl |
2-34 |
type |
2-35 |
udp-helper enable |
10-2 |
udp-helper port |
10-2 |
udp-helper server |
10-3 |
undelete |
5-12 |
unicast-suppression |
1-35 |
url |
2-36 |
user |
3-26 |
user privilege level |
2-32 |
user-bind |
15-4 |
user-group |
1-30 |
user-interface |
2-31 |
username (FTP test type view) |
2-36 |
user-name-format (HWTACACS scheme view) |
3-16 |
user-name-format (RADIUS scheme view) |
2-26 |
user-profile |
8-2 |
user-profile enable |
8-2 |
validate-source-address |
3-27 |
verbose |
3-26 |
version |
3-28 |
version |
14-9 |
virtual-cable-test |
1-36 |
vlan |
9-8 |
vlan precedence |
9-23 |
vlan-mapping modulo |
7-40 |
voice vlan aging |
11-3 |
voice vlan enable |
11-4 |
voice vlan mac-address |
11-4 |
voice vlan mode auto |
11-6 |
voice vlan security enable |
11-6 |
