欢迎user
手册下载
H3C SecPath NS-C100-QG4A1 interface module
The module identifier NS-C100-QG4A1 is in the upper right corner of the front panel.
The NS-C100-QG4A1 interface module provides four 40G fiber ports.
Figure 1 Front panel
(1) 40G fiber ports |
(2) Ejector lever |
(3) 40G fiber port LEDs |
(4) Captive screw |
Table 1 Module specifications
Item |
Specification |
Dimensions (H × W × D) |
37.4 × 174 × 192 mm (1.47 × 6.85 × 7.56 in) |
Power consumption |
4 W to 15 W |
Net weight |
0.76 kg (1.68 lb) |
Hot swapping |
Not supported |
Ports |
4 × 40GBASE-R QSFP+ ports |
Connector type |
· LC · MPO |
Available transceiver modules |
See Table 2. |
Compatible devices and slots |
· M9000-AI-E4 multiservice security gateway (slots 2/3 and 2/4) · T9000-E4 IPS (slots 2/3 and 2/4) |
The 40GBASE-R QSFP+ ports support QSFP+ transceiver modules in Table 2.
Table 2 QSFP+ transceiver modules available for the 40GBASE-R QSFP+ ports
Module |
Central wavelength |
Connector type |
Cable specifications |
Modal bandwidth |
Maximum transmission distance |
QSFP-40G-SR4-MM850 |
850 nm |
MPO |
50/125 µm, MMF |
2000 MHz*km |
100 m (328.08 ft) |
QSFP-40G-LR4-WDM1300 |
1310 nm |
LC |
9/125 µm, SMF |
N/A |
10 km (6.21 miles) |
QSFP-40G-CSR4-MM850 |
850 nm |
MPO |
50/125 µm, MMF |
2000 (MHz*km) |
300 m (984.25 ft) |
QSFP-40G-BIDI-SR-MM850 |
850 nm |
LC |
50/125 µm, MMF |
2000 (MHz*km) |
100 m (328.08 ft) |
4700 (MHz*km) |
150 m (492.13 ft) |
QSFP-40G-LR4L-WDM1300 |
1310 nm |
LC |
9/125 µm, SMF |
N/A |
2 km (1.24 miles) |
QSFP-40G-ER4-WDM1300 |
1310 nm |
LC |
9/125 µm, SMF |
N/A |
40 km (24.86 miles) |
QSFP-40G-BIDI-WDM850 |
850 nm |
LC |
50/125 µm, MMF |
2000 (MHz*km) |
240 m (787.40 ft) |
4700 (MHz*km) |
350 m (1148.29 ft) |
The module provides a LED for each 40G fiber port to indicate their operating status.
Table 3 40G fiber port LED description
Status |
Flashing |
The port is sending or receiving data. |
On |
A link is present on the port. |
Off |
No link is present on the port. |
For information about installing the module, see the installation guide for the device.
Copyright © 2024 New H3C Technologies Co., Ltd.
