H3C SR6600 SPE-FWM-200 Card Manual-6PW101
HomeSupportRoutersH3C SR6600 Router SeriesInstall & UpgradeCard Module ManualsH3C SR6600 SPE-FWM-200 Card Manual-6PW101
Download Book
1  Card identifier
The card identifier SPE-FWM-200 is at the right corner of the front panel.
2  Introduction
The SPE-FWM-200 card provides one console port, one CF card interface, two USB interfaces, two 10/100/1000BASE-T Ethernet copper interfaces, and two Gigabit Combo interfaces.
You can use a GE port or combo interface to provide the following functions:
·     In-band management.
·     Outgoing interface for log messages.
·     Failover interface for stateful failover.
3  Specifications
Figure 1 Front panel
(1) CF card eject button
(2) CF card slot (CF CARD)
(3) CF LED (CF)
(4) Console port (CONSOLE)
(5) USB interface 1 (reserved)
(6) USB interface 0 (reserved)
(7) Management Ethernet interface 1 (10/100/1000BASE-T)
(8) Management Ethernet interface 0 (10/100/1000BASE-T)
(9) Management Ethernet interface 1 LED (LINK)
(10) Management Ethernet interface 1 LED (ACT)
(11) Management Ethernet interface 0 LED (LINK)
(12) Management Ethernet interface 0 LED (ACT)
(13) Management interface 3 (Electrical port of combo interface 10/100/1000BASE-T)
(14) Management interface 2 (Electrical port of combo interface 10/100/1000BASE-T)
(15) Management interface 3 (Optical port of combo interface 1000BASE-X)
(16) Management interface 2 (Optical port of combo interface 1000BASE-X)
(17) Management interface 3 LED (LINK)
(18) Management interface 3 LED (ACT)
(19) Management interface 2 LED (LINK)
(20) Management interface 2 LED (ACT)
(21) RUN LED (RUN)
(22) Ejector lever
(23) Captive screw
Table 1  Card specifications
Item
Specification
CF card
One CF card slot, 256MB by default for the external CF card
256 MB, 512 MB, or 1 GB for an optional external CF card
Dimensions (H × W × D)
45 × 399 × 412 mm (1.77 × 15.71 × 16.22 in)
Power consumption
75W~101W
Weight
3.7 kg (8.16 lb)
Hot swapping
Supported
Ports
·     1 console port
·     2 USB ports (reserved for future use)
·     2 pairs of combo ports, each pair containing the following ports:
? 1 x 10/100/1000BASE-T copper port
? 1 x 1000BASE-X SFP fiber port
You can use the combo enable { copper | fiber } command to activate either of the ports in a pair. By default, the copper combo port is activated.
Ambient temperature
·     Operating: 0°C to 45°C (32°F to 113°F)
·     Not operating: –40°C to +70°C (–40°F to +158°F)
Ambient relative humidity
·     Operating: 10% to 95%, noncondensing
·     Non-operating: 5% to 95%, noncondensing
Compatible device models
H3C SR6600 routers
System software version
See the release notes that come with the card.
Table 2 Console port specifications
Item
Specification
Connector
RJ-45
Interface standard
RS-232
Transmission baud rate
9600 bps (default) to 115200 bps
Transmission medium
Asynchronous serial cable
Transmission distance
≤15 m (49.21 ft)
Services
·     Provides connection to an ASCII terminal.
·     Provides connection to the serial port of a local or remote PC (through a pair of modems) that is running a terminal emulation program.
·     Supports command line interface (CLI).
Table 3 10/100/1000BASE-T copper port specifications
Item
Specification
Connector
RJ-45
Interface standard
802.3, 802.3u, and 802.3ab
Interface type
MDI/MDIX autosensing
Supported cable
Category-5 (or above) twisted pair cable
100 m (328.08 ft)
Operating mode
·     10 Mbps, half/full duplex
·     100 Mbps, half/full duplex
·     1000 Mbps, full duplex
Table 4 1000BASE-X fiber port specifications
Item
Specification
Transceiver module
SFP
Connector
LC
Interface standard
Operating mode
Table 5 1000BASE-X SFP port specifications
Gigabit SFP module
Central wavelength
Connector
Cable specifications
Maximum transmission distance
SFP-GE-SX-MM850-A
850 nm
LC
62.5/125μm multi-mode optical fiber
0.55 km (0.34 miles)
SFP-GE-LX-SM1310-A
1310 nm
LC
9/125 μm single-mode optical fiber
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310 nm
LC
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550 nm
LC
40 km (24.86 miles)
SFP-GE-LH70-SM1550
1550 nm
LC
70 km (43.5 miles)
SFP-GE-LH100-SM1550
1550 nm
LC
100 km (62.14 miles)
4  LEDs
The card provides LEDs to show the operating status of the card and interfaces.
Table 6 LED description
LED
Status
CF card(CF)
Off
The CF card is not present or cannot be identified.
Steady green
The CF card is present and has passed the power on self test (POST).
Flashing green
The system is reading the CF card data. Do not unplug the CF card.
GE/Combo copper port
(LINK/ACT)
Off
No link is present on the port.
Steady green
A link is present on the port.
Flashing yellow
The port is sending or receiving data.
System LED(RUN)
Off
No power is input, or the card is faulty.
Steady green
The system is not operating correctly.
Flashing green (1 Hz)
The system has started up and is operating correctly.
Flashing green (8 Hz)
The system is loading the software or is not ready.
5  Installing and removing the card
CAUTION
CAUTION:
·     Wear a well-grounded ESD wrist strap or ESD gloves before you install or remove the card.
·     Do not touch the components on the PCB.
5.1  Installing the card
1.     Locate the slot where you will install the SPE-FWM-200, and remove the blank panel from the position. This manual describes installing the SPE-FWM-200 to slot 2.
2.     Push the module with the components facing upward into the slot along the guide rails until the positioning hole of the module is seated onto the positioning pin on the backplane. Push the ejector levers inward to lock the module in place.
3.     Fasten the captive screws on the module with a Philips screwdriver.
Figure 2 Installing the card
5.2  Removing the card
1.     Use a Phillips screwdriver to loosen the captive screws at both sides of the card.
2.     Pull the ejector levers at both sides of the card outward to separate it from the backplane, and then pull the card along the guide rails to remove it from the chassis.
3.     Place the card on an anti-static workbench with the surface-mounted components up. You can also put it in an anti-static bag.
4.     If you are not going to install a new card, install a filler panel to prevent dust and ensure good ventilation in the router.
6  Logging in to the card
The card uses an independent operating system. Before you can configure the card, you must log in to the card by using one of the following methods:
·     Log in from the router's CLI through the oap connect command.
·     Log in through the card's Web interface, console port, Telnet, or SSH.
H3C recommends that you log in to the card from the router's CLI the first time you access the card. This section includes a procedure for logging in from the router's CLI. For more information about other login methods, see H3C SecBlade II Firewall Cards Configuration Guide.
To log in to the card from the router's CLI, perform the following task in user view:
Remarks
Log in to the card through OAP.
·     In standalone mode:
oap connect
slot slot-number
·     In IRF mode:
oap connect chassis chassis-number slot slot-number
To return to the CLI interface of the router, press Ctrl+K.
7  Software upgrade
The card uses independent BootWare and system software images. You must upgrade the card software separately from the router software. To ensure a successful card upgrade, H3C recommends that you upgrade the card through the card's console port or management Ethernet port. For more information about software upgrade of the card, see the release notes that come with the card.
8  Obtaining documentation
To access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com:
1.     Go to http://www.h3c.com/Technical_Documents, or click Technical Support & Documents > Technical Documents on the top navigation bar at http://www.h3c.com.
2.     Click Security Products > H3C SecBlade Module to choose the desired product category and model.
Copyright © 2014 Hangzhou H3C Technologies Co., Ltd.
