20-Command
HomeSupportWirelessvAC1000 Virtual Access ControllerReference GuidesCommand ReferencesH3C vAC1000 Virtual Access Controller Command References(R5435P03)-6W10020-Command
20-Command
Title Size Downloads
20-Command-book.rar 6.72 MB
Table of Contents
Related Documents
book
book 6.72 MB
Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
A
aaa authorization
aaa authorization
aaa device-id
aaa nas-id profile
aaa session-id mode
aaa session-limit
aaa-fail nobinding enable
ac
ac discovery policy ipv6
access-control acl
access-limit
access-scan
accounting command
accounting default
accounting lan-access
accounting login
accounting portal
accounting ppp
accounting quota-out
accounting start-fail
accounting update-fail
accounting-level
accounting-level
accounting-merge enable
accounting-method
accounting-on enable
ack-flood action
ack-flood detect
ack-flood detect non-specific
ack-flood threshold
acl
acl copy
action cli
action reboot
action switchover
action syslog
activation-key
active-link keepalive-transmit-level
address
address
address range
address range
address-family ipv4
address-family ipv6
address-security cache
address-security enable
adjacency-factor
adjacency-factor radio-selection
adjacent-channel interference trap threshold
advantage-factor
agent-type
aging-time
ah authentication-algorithm
akm mode
akm mode sae
alias
a-mpdu
a-msdu
ani
antenna type
ap
ap name
ap radio
ap-channel-change
ap-classification rule
ap-flood
ap-impersonation
ap-license-synchronization enable
ap-model
ap-name
append
app-group
app-id (Facebook authentication server view)
app-id (QQ authentication server view)
app-id (WeChat authentication server view)
app-key (Facebook authentication server view)
app-key (QQ authentication server view)
app-key (WeChat authentication server view)
application statistics enable
apply ap-classification rule
apply classification policy
apply continue
apply continue
apply countermeasure policy
apply default-next-hop
apply default-output-interface
apply detect policy
apply ip-df
apply loadshare
apply loadshare
apply next-hop
apply next-hop
apply output-interface
apply precedence
apply precedence
apply signature policy
apply signature rule
app-secret
ap-rate-limit
ap-spoofing
ap-timer
archive configuration
archive configuration interval
archive configuration location
archive configuration max
arp active-ack enable
arp authorized enable
arp check enable
arp check log enable
arp detection enable
arp detection rule
arp detection trust
arp detection validate
arp fast-reply enable
arp filter binding
arp filter source
arp fixup
arp ip-conflict log prompt
arp max-learning-num
arp max-learning-number
arp scan
arp send-gratuitous-arp
arp source-mac
arp source-mac aging-time
arp source-mac exclude-mac
arp source-mac threshold
arp static
arp timer aging
arp valid-check enable
ascii
aspf apply policy
aspf policy
association-table-overflow
attack-defense apply policy
attack-defense local apply policy
attack-defense login reauthentication-delay
attack-defense policy
attack-defense signature log non-aggregate
attack-defense tcp fragment enable
attack-defense top-attack-statistics enable
attribute
attribute 15 check-mode
attribute 182 vendor-id 25506 vlan
attribute 25 car
attribute 30 format
attribute 30 mac-format
attribute 31 mac-format
attribute convert (RADIUS DAS view)
attribute convert (RADIUS scheme view)
attribute reject (RADIUS DAS view)
attribute reject (RADIUS scheme view)
attribute remanent-volume
attribute translate
attribute vendor-id 2011 version
attribute-map
authentication
authentication default
authentication ike
authentication lan-access
authentication login
authentication portal
authentication ppp
authentication super
authentication-method
authentication-mode
authentication-server
authentication-timeout
authentication-type
authorization command
authorization default
authorization ike
authorization lan-access
authorization login
authorization portal
authorization ppp
authorization-attribute (ISP domain view)
authorization-attribute (local user view/user group view)
authorization-server
auth-url
auto-channel european-gap enable
auto-execute command
B
backup startup-configuration
backup-ac
band-navigation
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth-based-sharing
bandwidth-guarantee
bandwidth-guarantee service-template
basic-service-ip-type
beacon ssid-hide
beacon-interval
bims-server
binary
bind-attribute
binding-retry
block mac-address
block-size
bonjour (AP view/AP group view)
bonjour (interface view)
bonjour activate service type
bonjour apply policy
bonjour global enable
bonjour policy
bonjour query
bonjour query interval
bonjour service type
bonjour service-mode
bonjour stop-m2u threshold
bootfile-name
boot-loader file
bridge-aggregation
broadcast-probe reply
bss transition-management enable
bss transition-management forced-disassociation
bye
bye
byod authorization
byod rule
byod rule-order
C
ca identifier
cac policy
calibrate-channel interference-threshold
calibrate-channel mode
calibrate-channel monitoring time-range
calibrate-channel pronto
calibrate-channel receive-service-traffic threshold
calibrate-channel self-decisive
calibrate-channel self-decisive sensitivity
calibrate-channel suppression
calibrate-channel track spectrum-analysis
calibrate-power min
calibrate-power mode
calibrate-power self-decisive
calibrate-power threshold
captive-bypass enable
car
cd
cd
cd
cdup
cdup
certificate domain
certificate domain
certificate request entity
certificate request from
certificate request mode
certificate request polling
certificate request url
certificate-chain-sending enable
channel
channel auto-select
channel band-width
channel holddown-time
channel-capability mode
channel-switch mode
channel-usage measure
channel-usage threshold
channel-usage-threshold
ciphersuite
cipher-suite
class ip-pool
class option-group
class pool
class range
classifier acl
classifier behavior
cli
client
client association-location
client behavior-local network-flow-forwarding enable
client cache aging-time
client dot11ac-only
client dot11ax-only
client dot11b-forbidden
client dot11n-only
client forwarding-location
client forwarding-policy enable
client forwarding-policy-name
client frame-format
client idle-timeout
client ip-cache aging-time
client ip-snooping http-learning enable
client ip-snooping ip-recover enable
client ipv4-snooping arp-learning enable
client ipv4-snooping dhcp-learning enable
client ipv4-snooping dhcp-learning timeout
client ipv6-snooping dhcpv6-learning enable
client ipv6-snooping nd-learning enable
client ipv6-snooping snmp-nd-report enable
client keep-alive
client keep-alive interval
client max-count
client max-count
client preferred-vlan authorized
client report-mandatory
client roaming-center
client smart-access enable
client url-redirect acl
client url-redirect enable
client vlan-alloc
client-association fast-learn enable
client-authentication
client-mac
client-online
client-proximity-sensor
client-proximity-sensor ap-timer
client-proximity-sensor ap-udp-server
client-proximity-sensor client-timer
client-proximity-sensor coordinates
client-proximity-sensor filter-list
client-proximity-sensor random-mac-report enable
client-proximity-sensor report-ac enable
client-proximity-sensor report-ac-interval
client-proximity-sensor report-ap enable
client-proximity-sensor report-oasis cache
client-proximity-sensor report-oasis client
client-proximity-sensor report-oasis disable
client-proximity-sensor report-oasis rssi-change-threshold
client-proximity-sensor rssi-change-threshold
client-proximity-sensor rssi-threshold
client-proximity-sensor rt-report enable
client-proximity-sensor server
client-proximity-sensor timezone-offset
client-proximity-sensor udp-server
client-rate-limit
client-rate-limit (radio view/AP group's radio view)
client-rate-limit (service template view)
client-rate-limit { disable | enable }
client-security aaa attribute ip-snooping-method
client-security accounting dual-stack separate enable
client-security accounting-delay time
client-security accounting-restart trigger ipv4
client-security accounting-start trigger
client-security accounting-update trigger
client-security authentication critical-vlan
client-security authentication fail-vlan
client-security authentication-location
client-security authentication-mode
client-security authorization trigger byod
client-security authorization-fail offline
client-security ignore-authentication
client-security ignore-authorization
client-security intrusion-protection action
client-security intrusion-protection enable
client-security intrusion-protection timer temporary-block
client-security intrusion-protection timer temporary-service-stop
client-spoofing
client-statistics-report
client-statistics-report smart-maintenance
client-timer
client-verify
clock datetime
clock protocol
clock summer-time
clock timezone
close
cloud-binding enable
cloud-management backup-server domain
cloud-management keepalive
cloud-management ping
cloud-management server domain
cloud-management server port
cloud-management unbinding-code
cloud-server url
co-channel interference trap threshold
codec-type
comeback-delay
command
command accounting
command authorization
commit
common-name
community read
company
config-exchange
configuration encrypt
configuration replace file
connection-limit
connection-limit apply
connection-limit apply global
continuous-mode
control-access
control-address
control-address enable
control-plane
control-plane management
copy
copy app-group
copyright-info enable
countermeasure adhoc
countermeasure attack all
countermeasure attack deauth-broadcast
countermeasure attack disassoc-broadcast
countermeasure attack honeypot-ap
countermeasure attack hotspot-attack
countermeasure attack ht-40-mhz-intolerance
countermeasure attack malformed-packet
countermeasure attack man-in-the-middle
countermeasure attack omerta
countermeasure attack power-save
countermeasure attack soft-ap
countermeasure attack unencrypted-trust-client
countermeasure attack weak-iv
countermeasure attack windows-bridge
countermeasure enhance
countermeasure external-ap
countermeasure mac-address
countermeasure misassociation-client
countermeasure misconfigured-ap
countermeasure packet-sending-interval
countermeasure potential-authorized-ap
countermeasure potential-external-ap
countermeasure potential-rogue-ap
countermeasure rogue-ap
countermeasure unauthorized-client
countermeasure uncategorized-ap
countermeasure uncategorized-client
country
cpu
crc-error-threshold
crl check enable
crl url
custom-antenna gain
customlog format
customlog format wlan
customlog host
customlog host source
customlog timestamp
D
dampening
data-fill
data-flow-format (HWTACACS scheme view)
data-flow-format (RADIUS scheme view)
data-size
data-tunnel encryption
deauthentication-broadcast
deauth-spoofing
debug
debugging
default
default
default
default
default
default ip-pool
default pool
default-logon-page
delay
delete
delete
delete
delete file
delete file
delete ipv6 static-routes all
delete static-routes all
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description (AP group view)
description (AP view)
description (application group view)
destination
destination ip
destination ipv6
destination port
detect
detect dissociate-client enable
detect policy
detect signature
dgaf enable
dh
dh
dhcp apply-policy
dhcp class
dhcp client dad enable
dhcp client dscp
dhcp client identifier
dhcp client-detect
dhcp dscp
dhcp enable
dhcp option-group
dhcp policy
dhcp relay check mac-address
dhcp relay check mac-address aging-time
dhcp relay client-information record
dhcp relay client-information refresh
dhcp relay client-information refresh enable
dhcp relay forward reply by-option82
dhcp relay gateway
dhcp relay information circuit-id
dhcp relay information enable
dhcp relay information remote-id
dhcp relay information strategy
dhcp relay release ip
dhcp relay source-address
dhcp select
dhcp server always-broadcast
dhcp server apply ip-pool
dhcp server bootp ignore
dhcp server bootp reply-rfc-1048
dhcp server database update interval
dhcp server database update now
dhcp server database update stop
dhcp server forbidden-ip
dhcp server ip-pool
dhcp server ping packets
dhcp server ping timeout
dhcp server relay information enable
dhcp server reply-exclude-option60
dhcp smart-relay enable
dhcp snooping binding database filename
dhcp snooping binding database update interval
dhcp snooping binding database update now
dhcp snooping binding record
dhcp snooping check mac-address
dhcp snooping check request-message
dhcp snooping deny
dhcp snooping enable
dhcp snooping information circuit-id
dhcp snooping information enable
dhcp snooping information remote-id
dhcp snooping information strategy
dhcp snooping log enable
dhcp snooping max-learning-num
dhcp snooping rate-limit
dhcp snooping trust
dhcpv6-follow-ipv6cp
diagnostic-logfile save
dir
dir
dir
disassociation-broadcast
disconnect
discovered-ap
discovery-response
disk
display | { begin | exclude | include }
display | by-linenum
display >
display >>
display acl
display alias
display app-group
display application
display application statistics
display application statistics top
display archive configuration
display arp
display arp detection
display arp detection statistics
display arp ip-address
display arp source-mac
display arp timer aging
display aspf all
display aspf interface
display aspf policy
display aspf session
display attack-defense flood statistics ip
display attack-defense flood statistics ipv6
display attack-defense policy
display attack-defense policy ip
display attack-defense policy ipv6
display attack-defense scan attacker ip
display attack-defense scan attacker ipv6
display attack-defense statistics interface
display attack-defense statistics local
display attack-defense top-attack-statistics
display bonjour active-service-type
display bonjour policy
display bonjour service
display boot-loader
display bootp client
display byod rule
display byod rule-order
display client-proximity-sensor device
display client-proximity-sensor sensor
display client-proximity-sensor statistics receive
display clock
display cloud-management state
display connection-limit
display connection-limit ipv6-stat-nodes
display connection-limit statistics
display connection-limit stat-nodes
display copyright
display counters
display counters rate
display cpu-usage
display cpu-usage configuration
display cpu-usage history
display crypto-engine
display crypto-engine statistics
display current-configuration
display current-configuration diff
display debugging
display default-configuration
display device
display dhcp client
display dhcp relay check mac-address
display dhcp relay client-information
display dhcp relay information
display dhcp relay server-address
display dhcp relay statistics
display dhcp server conflict
display dhcp server database
display dhcp server expired
display dhcp server free-ip
display dhcp server ip-in-use
display dhcp server pool
display dhcp server statistics
display dhcp snooping binding database
display dhcp snooping information
display dhcp snooping packet statistics
display dhcp snooping trust
display diagnostic-information
display diagnostic-logfile summary
display diff
display dns domain
display dns host
display dns server
display domain
display dot1x
display dot1x connection
display ethernet statistics
display exception context
display exception filepath
display fib
display ftp client source
display ftp-server
display ftp-user
display history-command
display history-command all
display hotkey
display hwtacacs scheme
display icmp statistics
display igmp-snooping
display igmp-snooping group
display igmp-snooping router-port
display igmp-snooping static-group
display igmp-snooping static-router-port
display igmp-snooping statistics
display ike proposal
display ike sa
display ike statistics
display ikev2 policy
display ikev2 profile
display ikev2 proposal
display ikev2 sa
display ikev2 statistics
display info-center
display interface
display interface
display interface inloopback
display interface loopback
display interface null
display interface range
display interface tunnel
display interface vlan-interface
display iot module
display ip http
display ip https
display ip interface
display ip interface brief
display ip policy-based-route
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
display ip pool
display ip routing-table
display ip routing-table acl
display ip routing-table ip-address
display ip routing-table protocol
display ip routing-table statistics
display ip routing-table summary
display ip source binding
display ip statistics
display ipsec { ipv6-policy | policy }
display ipsec { ipv6-policy-template | policy-template }
display ipsec profile
display ipsec sa
display ipsec statistics
display ipsec transform-set
display ipsec tunnel
display ipv6 dhcp client
display ipv6 dhcp client statistics
display ipv6 dhcp duid
display ipv6 dhcp option-group
display ipv6 dhcp pool
display ipv6 dhcp prefix-pool
display ipv6 dhcp relay server-address
display ipv6 dhcp relay statistics
display ipv6 dhcp server
display ipv6 dhcp server conflict
display ipv6 dhcp server database
display ipv6 dhcp server expired
display ipv6 dhcp server ip-in-use
display ipv6 dhcp server pd-in-use
display ipv6 dhcp server statistics
display ipv6 dns server
display ipv6 fib
display ipv6 icmp statistics
display ipv6 interface
display ipv6 interface prefix
display ipv6 l2-multicast ip
display ipv6 l2-multicast ip forwarding
display ipv6 l2-multicast mac
display ipv6 l2-multicast mac forwarding
display ipv6 nd snooping
display ipv6 nd snooping count
display ipv6 neighbors
display ipv6 neighbors count
display ipv6 pathmtu
display ipv6 policy-based-route
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
display ipv6 prefix
display ipv6 rawip
display ipv6 rawip verbose
display ipv6 rib attribute
display ipv6 rib nib
display ipv6 route-direct nib
display ipv6 route-static nib
display ipv6 route-static routing-table
display ipv6 routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 routing-table summary
display ipv6 source binding
display ipv6 statistics
display ipv6 tcp
display ipv6 tcp verbose
display ipv6 udp
display ipv6 udp verbose
display kernel deadloop
display kernel deadloop configuration
display kernel exception
display kernel reboot
display kernel starvation
display kernel starvation configuration
display l2-multicast ip
display l2-multicast ip forwarding
display l2-multicast mac
display l2-multicast mac forwarding
display ldap scheme
display license
display license device-id
display license feature
display line
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
display lldp local-information
display lldp neighbor-information
display lldp statistics
display lldp status
display lldp tlv-config
display local-guest waiting-approval
display local-proxy-arp
display local-user
display logbuffer
display logbuffer summary
display logfile summary
display mac-address
display mac-address aging-time
display mac-address mac-learning
display mac-address mac-move
display mac-authentication
display mac-authentication connection
display mac-forwarding cache ip
display mac-forwarding cache ip fragment
display mac-forwarding cache ipv6
display mac-forwarding statistics
display maintain cpu-usage history
display maintain memory-usage history
display memory
display memory-threshold
display mirroring-group
display mld-snooping
display mld-snooping group
display mld-snooping router-port
display mld-snooping static-group
display mld-snooping static-router-port
display mld-snooping statistics
display nat address-group
display nat alg
display nat all
display nat dns-map
display nat eim
display nat inbound
display nat log
display nat no-pat
display nat outbound
display nat outbound port-block-group
display nat port-block
display nat port-block-group
display nat port-block-usage
display nat server
display nat server-group
display nat session
display nat static
display nat statistics
display netconf service
display netconf session
display nqa history
display nqa reaction counters
display nqa result
display nqa server
display nqa statistics
display ntp-service ipv6 sessions
display ntp-service sessions
display ntp-service status
display ntp-service trace
display packet-capture status
display packet-drop
display packet-filter
display packet-filter verbose
display password-control
display password-control blacklist
display pki certificate access-control-policy
display pki certificate attribute-group
display pki certificate domain
display pki certificate renew-status
display pki certificate request-status
display pki crl domain
display port
display portal
display portal auth-error-record
display portal auth-fail-record
display portal captive-bypass statistics
display portal dns free-rule-host
display portal dns redirect-rule-host
display portal extend-auth-server
display portal local-binding mac-address
display portal logout-record
display portal mac-trigger user
display portal mac-trigger-server
display portal packet statistics
display portal permit-rule statistics
display portal redirect session
display portal redirect session-record
display portal redirect session-statistics
display portal redirect statistics
display portal roaming-center statistics packet
display portal rule
display portal safe-redirect statistics
display portal server
display portal user
display portal user count
display portal user dhcp-lease
display portal user dhcpv6-lease
display portal web-server
display port-mapping pre-defined
display port-mapping user-defined
display port-security
display port-security mac-address block
display port-security mac-address security
display ppp access-user
display ppp compression iphc
display pppoe-server session packet
display pppoe-server session summary
display pppoe-server throttled-mac
display pppoe-server va-pool
display process
display process cpu
display process log
display process memory
display process memory heap
display process memory heap address
display process memory heap size
display proxy-arp
display public-key local public
display public-key peer
display qos map-table
display qos policy
display qos policy control-plane
display qos policy control-plane management
display qos policy interface
display qos policy user-profile
display qos trust interface
display radius scheme
display radius statistics
display rawip
display rawip verbose
display rib attribute
display rib graceful-restart
display rib nib
display rmon alarm
display rmon event
display rmon eventlog
display rmon history
display rmon prialarm
display rmon statistics
display role
display role feature
display role feature-group
display route-direct nib
display route-static nib
display route-static routing-table
display rtm environment
display rtm policy
display saved-configuration
display scheduler job
display scheduler logfile
display scheduler reboot
display scheduler schedule
display security-logfile summary
display session aging-time application
display session aging-time state
display session relation-table
display session statistics
display session statistics ipv4
display session statistics ipv6
display session statistics multicast
display session table ipv4
display session table ipv6
display session table multicast ipv4
display session table multicast ipv6
display sftp client source
display snmp-agent community
display snmp-agent context
display snmp-agent group
display snmp-agent local-engineid
display snmp-agent mib-node
display snmp-agent mib-view
display snmp-agent remote
display snmp-agent statistics
display snmp-agent sys-info
display snmp-agent trap queue
display snmp-agent trap-list
display snmp-agent usm-user
display sntp ipv6 sessions
display sntp sessions
display ssh client source
display ssh server
display ssh user-information
display ssh2 algorithm
display ssl client-policy
display ssl server-policy
display startup
display system stable state
display tcp
display tcp statistics
display tcp verbose
display telnet client
display this
display time-range
display track
display traffic behavior
display traffic classifier
display udp
display udp statistics
display udp verbose
display user-group
display user-interface
display user-isolation statistics
display userlog export
display userlog host-group
display user-profile
display users
display version
display vlan
display vlan brief
display vlan-group
display wapi statistics
display wapi user
display web menu
display web users
display web-redirect rule
display wips sensor
display wips statistics
display wips virtual-security-domain countermeasure record
display wips virtual-security-domain device
display wlan ac-role
display wlan ap
display wlan ap address
display wlan ap all client-number
display wlan ap all feature capwap
display wlan ap all feature location-aware
display wlan ap all radio client-number
display wlan ap connection-record
display wlan ap continuous-mode
display wlan ap description
display wlan ap files
display wlan ap gps
display wlan ap group
display wlan ap online-time
display wlan ap radio
display wlan ap radio channel
display wlan ap radio type
display wlan ap reboot-log
display wlan ap region-code
display wlan ap running-configuration
display wlan ap statistics association-failure-record
display wlan ap statistics image-download
display wlan ap statistics online-record
display wlan ap statistics tunnel-down-record
display wlan ap tunnel latency
display wlan ap unauthenticated
display wlan ap-distribution
display wlan ap-distribution ap-name
display wlan ap-group
display wlan ap-group all client-number
display wlan ap-license-group
display wlan ap-model
display wlan blacklist
display wlan bss
display wlan client
display wlan client
display wlan client ipv6
display wlan client online-duration
display wlan client status
display wlan client-security block-mac
display wlan device role
display wlan forward statistics
display wlan forwarding-policy
display wlan hotspot uploaded-osu-icon
display wlan ipv6 multicast-optimization entry
display wlan license
display wlan load-balance group
display wlan load-balance status service-template
display wlan local-ac (on central ACs)
display wlan local-ac connection-record
display wlan local-ac files
display wlan local-ac model
display wlan local-ac online-time
display wlan measure-report
display wlan mesh-link ap
display wlan mesh-policy
display wlan mesh-profile
display wlan module firmware-upgrade history
display wlan module-information
display wlan multicast-optimization entry
display wlan nat-detect
display wlan private-psk cloud-password
display wlan private-psk cloud-password mac-binding
display wlan radio-load-balance status service-template
display wlan rfid-tracking radio
display wlan roaming-center history user
display wlan roaming-center statistics packet
display wlan roaming-center user
display wlan rrm baseline
display wlan rrm baseline apply-history
display wlan rrm-calibration-group
display wlan rrm-history ap
display wlan rrm-status ap
display wlan service-template
display wlan spectrum-analysis channel-quality
display wlan spectrum-analysis device
display wlan statistics accounting
display wlan statistics ap radio
display wlan statistics client
display wlan statistics connect-history
display wlan statistics global
display wlan statistics service template
display wlan statistics vip-client
display wlan virtual-ap client
display wlan whitelist
display wlan wmm
display wlan wt
distance
dns domain
dns domain
dns dscp
dns proxy enable
dns server
dns server
dns source-interface
dns spoofing
dns trust-interface
dns-flood action
dns-flood detect
dns-flood detect non-specific
dns-flood port
dns-flood threshold
dns-list
dns-server
domain
domain default enable
domain if-unknown
domain-name
domain-name
domain-name
dot11ac mandatory maximum-nss
dot11ac multicast-nss
dot11ac support maximum-nss
dot11ax mandatory maximum-nss
dot11ax multicast-nss
dot11ax support maximum-nss
dot11g protection
dot11n mandatory maximum-mcs
dot11n multicast-mcs
dot11n protection
dot11n support maximum-mcs
dot1p-priority (IGMP-snooping view)
dot1p-priority (MLD-snooping view)
dot1x
dot1x authentication-method
dot1x auth-fail vlan
dot1x critical vlan
dot1x domain
dot1x domain-delimiter
dot1x ead-assistant enable
dot1x ead-assistant free-ip
dot1x ead-assistant url
dot1x eap
dot1x eap-termination authentication-method
dot1x eap-termination eap-profile
dot1x guest-vlan
dot1x handshake
dot1x handshake enable
dot1x handshake reply enable
dot1x handshake secure
dot1x handshake secure enable
dot1x mandatory-domain
dot1x max-user
dot1x max-user
dot1x multicast-trigger
dot1x port-control
dot1x port-method
dot1x quiet-period
dot1x re-authenticate
dot1x re-authenticate enable
dot1x re-authenticate server-unreachable keep-online
dot1x retry
dot1x smarton
dot1x smarton password
dot1x smarton retry
dot1x smarton switchid
dot1x smarton timer supp-timeout
dot1x timer
download file
download file
dpd
dpd
drop-unknown (IGMP-snooping view)
drop-unknown (MLD-snooping view)
dtim
E
echo-count
echo-interval
echo-interval
edca auto
edca client (ac-be and ac-bk)
edca client (ac-vi and ac-vo)
edca radio
email
enable (IGMP-snooping view)
enable (MLD-snooping view)
enable log updown
enable snmp trap updown
encapsulation-mode
encryption
encryption-algorithm
enhanced-open enable
enhanced-open transition-mode service-template
entry-limit (IGMP-snooping view)
entry-limit (MLD-snooping view)
environment-monitor
escape-key
esn enable
esp authentication-algorithm
esp encryption-algorithm
event cli
event interface
event process
event snmp oid
event snmp-notification
event syslog
event track
exception filepath
exchange-mode
exclude-attribute (MAC binding server view)
exclude-attribute (portal authentication server view)
exempt acl
exit
exit()
expect { data | hex-data }
expect { failed-data | hex-failed-data }
expect ip
expect ipv6
expect status
expired
export oui
F
fail-permit enable
fail-permit template
fast-leave (IGMP-snooping view)
fast-leave (MLD-snooping view)
feature
fib lifetime
file prompt
filename
filter
fin-flood action
fin-flood detect
fin-flood detect non-specific
fin-flood threshold
firmware-upgrade
firmware-upgrade
fixdisk
flood association-request
flood authentication
flood beacon
flood block-ack
flood cts
flood deauthentication
flood disassociation
flood eap-failure
flood eapol-logoff
flood eapol-start
flood eap-success
flood null-data
flood probe-request
flood reassociation-request
flood rts
flow-interval
forbidden-ip
format
fqdn
fragment-size
fragment-threshold
frame-type
free ftp user
free ftp user-ip
free ftp user-ip ipv6
free line
free user-interface
free web users
free-traffic threshold
frequency
friendly-name
ft enable
ft method
ft reassociation-timeout
ftp
ftp client ipv6 source
ftp client source
ftp ipv6
ftp server acl
ftp server acl ipv6
ftp server acl-deny-log enable
ftp server dscp
ftp server enable
ftp server ipv6 dscp
ftp server ssl-server-policy
ftp timeout
full-name
G
gas-limit
gateway
gateway information report
gateway-list
gateway-list
gateway-list
get
get
gigabitethernet
global-ip-pool
gratuitous-arp mac-change retransmit
gratuitous-arp-learning enable
gratuitous-arp-sending enable
gre checksum
gre key
green-energy-management
group
group-filter
group-policy (IGMP-snooping view)
group-policy (MLD-snooping view)
gtk-rekey client-offline enable
gtk-rekey enable
gtk-rekey method
gunzip
gzip
H
header
help
help
hessid
hex-data-fill
history-command max-size
history-record enable
history-record keep-time
history-record number
honeypot-ap
host-aging-time (IGMP-snooping view)
host-aging-time (MLD-snooping view)
hostname
hotkey
hotspot-attack
hotspot-policy
ht-40mhz-intolerance
ht-greenfield
http method
http-flood action
http-flood detect
http-flood detect non-specific
http-flood port
http-flood threshold
hwtacacs nas-ip
hwtacacs scheme
hybrid-remote-ap
I
icmp-error drop
icmp-flood action
icmp-flood detect ip
icmp-flood detect non-specific
icmp-flood threshold
icmpv6-flood action
icmpv6-flood detect ipv6
icmpv6-flood detect non-specific
icmpv6-flood threshold
icon-file
identity
identity local
idle-timeout
if-match
if-match
if-match
if-match
if-match acl
if-match acl
if-match ip
if-match ipv6
if-match packet-length
if-match temp-pass
igmp-snooping
igmp-snooping dot1p-priority
igmp-snooping drop-unknown
igmp-snooping enable
igmp-snooping fast-leave
igmp-snooping general-query source-ip
igmp-snooping group-limit
igmp-snooping group-policy
igmp-snooping host-aging-time
igmp-snooping host-join
igmp-snooping last-member-query-interval
igmp-snooping leave source-ip
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping querier
igmp-snooping query-interval
igmp-snooping report source-ip
igmp-snooping router-aging-time
igmp-snooping router-port-deny
igmp-snooping special-query source-ip
igmp-snooping version
ignorelist
ike address-group
ike dpd
ike identity
ike invalid-spi-recovery enable
ike keepalive interval
ike keepalive timeout
ike keychain
ike limit
ike logging negotiation enable
ike nat-keepalive
ike profile
ike proposal
ike signature-identity from-certificate
ike-profile
ikev2 address-group
ikev2 cookie-challenge
ikev2 dpd
ikev2 ipv6-address-group
ikev2 keychain
ikev2 nat-keepalive
ikev2 policy
ikev2 profile
ikev2 proposal
ikev2-profile
import
import hotspot
import oui
include application
include-attribute h3c-dhcp-option
info-center diagnostic-logfile directory
info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
info-center diagnostic-logfile quota
info-center enable
info-center format
info-center logbuffer
info-center logbuffer size
info-center logfile directory
info-center logfile enable
info-center logfile frequency
info-center logfile size-quota
info-center logging suppress duplicates
info-center loghost
info-center loghost source
info-center security-logfile alarm-threshold
info-center security-logfile directory
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center source
info-center synchronous
info-center syslog min-age
info-center syslog trap buffersize
info-center timestamp
info-center timestamp loghost
info-center trace-logfile quota
inherit exclude service-template
init-ttl
inside ip
integrity
interface
interface bridge-aggregation
interface loopback
interface null
interface policy deny
interface range
interface range name
interface tunnel
interface wlan-mesh
inter-protocol fast-reroute
invalid-oui-classify illegal
iot auto-module
iot auto-module persistent
iot auto-module persistent all
iot engine port-redistribute
iot engine-address
iot location module
iot location rssi
iot module led-mode
iot module report-mode
iot packet length-field
iot report-format
iot report-mode
ip
ip
ip (MAC binding server view)
ip (portal authentication server view)
ip address
ip address
ip address bootp-alloc
ip address dhcp-alloc
ip address ppp-negotiate
ip forward-broadcast
ip host
ip http acl
ip http enable
ip http port
ip https acl
ip https certificate access-control-policy
ip https enable
ip https port
ip https ssl-server-policy
ip icmp error-interval
ip icmp source
ip load-sharing mode
ip local policy-based-route
ip mtu
ip pool
ip pool gateway
ip redirects enable
ip route-static
ip route-static default-preference
ip route-static fast-reroute auto
ip route-static-group
ip ttl-expires enable
ip unreachables enable
ip verify source
ip verify unknown-ip
ip-in-use threshold
ip-protocol
ipsec { ipv6-policy | policy } isakmp template
ipsec { ipv6-policy | policy } local-address
ipsec anti-replay check
ipsec anti-replay window
ipsec apply
ipsec decrypt-check enable
ipsec df-bit
ipsec fragmentation
ipsec global-df-bit
ipsec limit max-tunnel
ipsec logging negotiation enable
ipsec logging packet enable
ipsec profile
ipsec redundancy enable
ipsec sa global-duration
ipsec sa global-soft-duration buffer
ipsec sa idle-time
ipsec transform-set
ip-type
ipv6
ipv6 (MAC binding server view)
ipv6 (portal authentication server view)
ipv6 address
ipv6 address
ipv6 address anycast
ipv6 address auto
ipv6 address auto link-local
ipv6 address dhcp-alloc
ipv6 address eui-64
ipv6 address link-local
ipv6 address prefix-number
ipv6 dhcp apply-policy
ipv6 dhcp class
ipv6 dhcp client dscp
ipv6 dhcp client duid
ipv6 dhcp client pd
ipv6 dhcp client stateful
ipv6 dhcp client stateless enable
ipv6 dhcp dscp
ipv6 dhcp log enable
ipv6 dhcp policy
ipv6 dhcp pool
ipv6 dhcp relay gateway
ipv6 dhcp relay interface-id
ipv6 dhcp select
ipv6 dhcp server
ipv6 dhcp server apply pool
ipv6 dhcp server database filename
ipv6 dhcp server database update interval
ipv6 dhcp server database update now
ipv6 dhcp server database update stop
ipv6 dhcp server forbidden-address
ipv6 dhcp server forbidden-prefix
ipv6 dns dscp
ipv6 dns server
ipv6 dns spoofing
ipv6 extension-header drop enable
ipv6 hop-limit
ipv6 hoplimit-expires enable
ipv6 host
ipv6 icmpv6 error-interval
ipv6 icmpv6 source
ipv6 local policy-based-route
ipv6 mtu
ipv6 multicast-optimization enable
ipv6 nd autoconfig other-flag
ipv6 nd check log enable
ipv6 nd dad attempts
ipv6 nd mac-check enable
ipv6 nd ns retrans-timer
ipv6 nd nud reachable-time
ipv6 nd ra dns search-list
ipv6 nd ra dns search-list suppress
ipv6 nd ra dns server
ipv6 nd ra dns server suppress
ipv6 nd ra halt
ipv6 nd ra hop-limit unspecified
ipv6 nd ra interval
ipv6 nd ra invalid-delegated-prefix advertise enable
ipv6 nd ra no-advlinkmtu
ipv6 nd ra router-lifetime
ipv6 nd router-preference
ipv6 nd snooping enable global
ipv6 nd snooping enable link-local
ipv6 nd snooping glean source
ipv6 nd snooping max-learning-num
ipv6 neighbor
ipv6 neighbor stale-aging
ipv6 neighbors max-learning-num
ipv6 pathmtu
ipv6 pathmtu age
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
ipv6 prefer temporary-address
ipv6 prefix
ipv6 redirects enable
ipv6 route-static
ipv6 route-static default-preference
ipv6 temporary-address
ipv6 unreachables enable
ipv6 verify source
ita policy
ita-policy
J
job
jumboframe enable
jumboframe enable
K
keepalive
keepalive-interval
key
key (HWTACACS scheme view)
key (RADIUS scheme view)
keychain
keychain
key-derivation
L
last-listener-query-interval (MLD-snooping view)
last-member-query-interval (IGMP-snooping view)
lcd
ldap attribute-map
ldap scheme
ldap server
ldap-server
ldpc
led-mode
license activation-file install
license activation-file uninstall
license compress
limit
line
line class
link-aggregation global load-sharing mode
link-aggregation ignore vlan
link-aggregation mode
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
link-establish-threshold
link-hold-rssi
link-initiation enable
link-keepalive
link-maximum-number
link-saturation-rssi
lldp admin-status
lldp check-change-interval
lldp enable
lldp encapsulation snap
lldp fast-count
lldp global enable
lldp hold-multiplier
lldp ignore-pvid-inconsistency
lldp management-address
lldp management-address-format string
lldp max-credit
lldp mode
lldp notification med-topology-change enable
lldp notification remote-change enable
lldp source-mac vlan
lldp timer fast-interval
lldp timer notification-interval
lldp timer reinit-delay
lldp timer rx-timeout
lldp timer tx-interval
lldp tlv-enable
local ip
local-address
local-binding aging-time
local-binding enable
local-guest auto-delete enable
local-guest email format
local-guest email sender
local-guest email smtp-server
local-guest generate
local-guest manager-email
local-guest send-email
local-guest timer
local-identity
local-ip-address
locality
local-proxy-arp enable
local-proxy-nd enable
local-server log change-password-prompt
local-user
local-user-export class network guest
local-user-import class network guest
location (AP group view)
location (RRM holddown group view)
location (service template view)
lock
lock reauthentication
lock-key
logfile save
login failed-url
login success-url
login-dn
login-password
logon-page bind
logout-notify
long-retry threshold
ls
ls
lsr-path
M
mac-address
mac-address (AP group view)
mac-address (AP view)
mac-address (interface view)
mac-address (system view)
mac-address mac-learning enable
mac-address mac-learning priority
mac-address max-mac-count
mac-address max-mac-count enable-forwarding
mac-address notification mac-move
mac-address notification mac-move suppression (interface view)
mac-address notification mac-move suppression (system view)
mac-authentication
mac-authentication domain
mac-authentication fast-connect enable
mac-authentication guest-vlan
mac-authentication guest-vlan auth-period
mac-authentication max-user
mac-authentication re-authenticate server-unreachable keep-online
mac-authentication timer
mac-authentication timer auth-delay
mac-authentication user-name-format
mailbox
mail-domain-name
mail-protocol
maintain enable
maintain inactive-process restart enable
maintain monitor process
maintain process inactive-time
maintain process memory-threshold
malformed duplicated-ie
malformed fata-jack
malformed illegal-ibss-ess
malformed invalid-address-combination
malformed invalid-assoc-req
malformed invalid-auth
malformed invalid-deauth-code
malformed invalid-disassoc-code
malformed invalid-ht-ie
malformed invalid-ie-length
malformed invalid-pkt-length
malformed large-duration
malformed null-probe-resp
malformed overflow-eapol-key
malformed overflow-ssid
malformed redundant-ie
man-in-the-middle
manual-classify mac-address
map
map-configuration
match all (AP classification rule view)
match all (signature view)
match local (IKEv2 profile view)
match local address (IKE keychain view)
match local address (IKE profile view)
match local address (IKEv2 policy view)
match remote
match remote
max-failure
max-power
max-response-time (IGMP-snooping view)
max-response-time (MLD-snooping view)
md5sum
measure
measure-duration
measure-interval
member ip
memory
memory-threshold
memory-threshold usage
mesh peer-mac-address
mesh-id
mesh-interface
mesh-peer intra-ac-mpp enable
mesh-policy
mesh-port access vlan
mesh-port hybrid pvid
mesh-port hybrid vlan
mesh-port link-type
mesh-port trunk permit vlan
mesh-port trunk pvid
mesh-profile
mesh-profile enable
method
mimo
mirroring-group
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mkdir
mkdir
mkdir
mld-snooping
mld-snooping done source-ip
mld-snooping dot1p-priority
mld-snooping drop-unknown
mld-snooping enable
mld-snooping fast-leave
mld-snooping general-query source-ip
mld-snooping group-limit
mld-snooping group-policy
mld-snooping host-aging-time
mld-snooping host-join
mld-snooping last-listener-query-interval
mld-snooping max-response-time
mld-snooping overflow-replace
mld-snooping querier
mld-snooping query-interval
mld-snooping report source-ip
mld-snooping router-aging-time
mld-snooping router-port-deny
mld-snooping special-query source-ip
mld-snooping version
mode
module
module enable
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage threshold
monitor kernel deadloop enable
monitor kernel deadloop exclude-thread
monitor kernel deadloop time
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
monitor process
monitor thread
more
move
mtu
mtu
mu-txbf
N
nai
nai-realm
name
nas-id
nas-id
nas-id bind vlan
nas-ip (HWTACACS scheme view)
nas-ip (RADIUS scheme view)
nas-port-id
nas-port-type
nas-port-type
nas-port-type
nas-vlan
nat address-group
nat alg
nat dns-map
nat hairpin enable
nat icmp-error reply
nat inbound
nat inbound rule move
nat log alarm
nat log enable
nat log flow-active
nat log flow-begin
nat log flow-end
nat log port-block usage threshold
nat log port-block-assign
nat log port-block-withdraw
nat mapping-behavior endpoint-independent
nat outbound
nat outbound rule move
nat port-block global-share enable
nat server
nat server rule move
nat server-group
nat static enable
nat static inbound
nat static inbound net-to-net
nat static inbound rule move
nat static outbound
nat static outbound net-to-net
nat static outbound rule move
nat-keepalive
nbns-list
netbios-type
netconf capability specific-namespace
netconf idle-timeout
netconf log
netconf soap acl
netconf soap domain
netconf soap enable
netconf ssh acl
netconf ssh server enable
netconf ssh server port
network
network
network-type
newer
next-hop ip
next-hop ipv6
next-server
no-fragment enable
non-vip limit rate
nqa
nqa agent enable
nqa schedule
nqa server enable
nqa server tcp-connect
nqa server udp-echo
nqa template
ntp-service acl
ntp-service authentication enable
ntp-service authentication-keyid
ntp-service broadcast-client
ntp-service broadcast-server
ntp-service dscp
ntp-service enable
ntp-service inbound enable
ntp-service ipv6 acl
ntp-service ipv6 dscp
ntp-service ipv6 inbound enable
ntp-service ipv6 multicast-client
ntp-service ipv6 multicast-server
ntp-service ipv6 source
ntp-service ipv6 unicast-peer
ntp-service ipv6 unicast-server
ntp-service max-dynamic-sessions
ntp-service multicast-client
ntp-service multicast-server
ntp-service refclock-master
ntp-service reliable authentication-keyid
ntp-service source
ntp-service unicast-peer
ntp-service unicast-server
O
object
oid
omerta
open
operation (FTP operation view)
operation (HTTP operation view)
operation (HTTPS template view)
operator-name
option
option
option-group
organization
organization-unit
osu-provider
osu-ssid
oui
out interface
overflow-replace (IGMP-snooping view)
overflow-replace (MLD-snooping view)
P
packet-capture local ap
packet-capture local interface
packet-capture remote ap
packet-capture remote interface
packet-capture stop
packet-filter (interface view)
packet-filter (service template view)
packet-filter default deny
passive
password
password (device management user view)
password (network access user view)
password-control { aging | composition | history | length } enable
password-control aging
password-control alert-before-expire
password-control change-password first-login enable
password-control change-password weak-password enable
password-control complexity
password-control composition
password-control enable
password-control expired-user-login
password-control history
password-control length
password-control login idle-time
password-control login-attempt
password-control super aging
password-control super composition
password-control super length
password-control update-interval
pattern
peer
peer-public-key end
permit interface
permit vlan
permit-channel
pfs
phone
ping
ping ipv6
pkcs7-encryption-algorithm
pki abort-certificate-request
pki delete-certificate
pki domain
pki entity
pki export
pki import
pki request-certificate
pki retrieve-certificate
pki retrieve-crl
pki storage
pki validate-certificate
pki-domain (SSL client policy view)
pki-domain (SSL server policy view)
pmf
pmf association-comeback
pmf saquery retrycount
pmf saquery retrytimeout
poe port
poe wtu-port
policy-based-route
policy-name
port
port
port
port (MAC binding server view)
port (portal authentication server view)
port access vlan
port access vlan
port hybrid pvid
port hybrid pvid
port hybrid vlan
port hybrid vlan
port link-aggregation group
port link-mode
port link-type
port link-type
port trunk pvid
port trunk pvid
portal { bas-ip | bas-ipv6 }
portal { ipv4-max-user | ipv6-max-user }
portal accounting-separate enable
portal apply mac-trigger-server
portal apply web-server
portal auth-error-record enable
portal auth-error-record export
portal auth-error-record max
portal auth-fail-record enable
portal auth-fail-record export
portal auth-fail-record max
portal authorization strict-checking
portal captive-bypass optimize delay
portal client-gateway interface
portal client-traffic-report interval
portal cloud report interval
portal device-id
portal domain
portal dual-ip enable
portal dual-stack enable
portal dual-stack traffic-separate enable
portal enable (interface view)
portal enable (service template view)
portal extend-auth domain
portal fail-permit server
portal fail-permit web-server
portal forbidden-rule
portal free-all except destination
portal free-rule
portal free-rule description
portal free-rule destination
portal free-rule source
portal host-check enable
portal idle-cut dhcp-capture enable
portal ipv6 free-all except destination
portal ipv6 user-detect
portal local-web-server
portal logout-record enable
portal logout-record export
portal logout-record max
portal max-user
portal nas-id profile
portal nas-port-id format
portal nas-port-type
portal oauth user-sync interval
portal outbound-filter enable
portal packet log enable
portal redirect log enable
portal redirect max-session per-user
portal redirect-rule
portal refresh enable
portal roaming enable
portal safe-redirect default-action
portal safe-redirect enable
portal safe-redirect forbidden-file
portal safe-redirect forbidden-url
portal safe-redirect method
portal safe-redirect permit-url
portal safe-redirect user-agent
portal server
portal temp-pass enable
portal traffic-accounting disable
portal traffic-backup threshold
portal url-param source-address code-base64
portal user log enable
portal user-detect
portal user-dhcp-only
portal user-log traffic-separate
portal user-logoff after-client-offline enable
portal user-logoff ssid-switch enable
portal web-server
portal wifidog user-sync interval
portal-service enable
port-block
port-detect enable
port-isolate enable
port-mapping
port-mapping acl
port-mapping host
port-mapping subnet
port-range
port-security authorization ignore
port-security authorization-fail offline
port-security enable
port-security intrusion-mode
port-security mac-move permit
port-security max-mac-count
port-security nas-id-profile
port-security ntk-mode
port-security oui
port-security port-mode
port-security timer disableport
port-type switch
port-type switch
power holddown-time
power-capability mode
power-constraint mode
power-level default
power-lock
power-save
ppp account-statistics enable
ppp acfc local-request
ppp acfc remote-reject
ppp authentication-mode
ppp chap password
ppp chap user
ppp compression iphc enable
ppp compression iphc rtp-connections
ppp compression iphc tcp-connections
ppp ipcp dns
ppp ipcp dns admit-any
ppp ipcp dns request
ppp ipcp remote-address match
ppp ip-pool route
ppp lcp delay
ppp lcp echo mru verify
ppp pap local-user
ppp pfc local-request
ppp pfc remote-reject
ppp timer negotiate
pppoe-server access-delay
pppoe-server access-line-id bas-info
pppoe-server access-line-id circuit-id parse-mode
pppoe-server access-line-id circuit-id trans-format
pppoe-server access-line-id content
pppoe-server access-line-id remote-id trans-format
pppoe-server access-line-id trust
pppoe-server bind
pppoe-server session-limit
pppoe-server session-limit per-mac
pppoe-server session-limit per-vlan
pppoe-server session-limit total
pppoe-server tag ac-name
pppoe-server tag ppp-max-payload
pppoe-server tag service-name
pppoe-server throttle per-mac
pppoe-server virtual-template va-pool
preamble
prefer-cipher
prefix
prefix-pool
preshared-key
preshared-key
pre-shared-key
pre-shared-key
prf
primary accounting (HWTACACS scheme view)
primary accounting (RADIUS scheme view)
primary authentication (HWTACACS scheme view)
primary authentication (RADIUS scheme view)
primary authorization
priority
priority
priority (IKE keychain view)
priority (IKE profile view)
priority (IKEv2 policy view)
priority (IKEv2 profile view)
private-psk cloud enable
private-psk fail-permit enable
probe count
probe packet-interval
probe packet-number
probe packet-timeout
probe timeout
probe-request-interval
process core
prohibited-channel
proposal
proposal
protection-mode
protection-threshold
protocol
protocol inbound
protocol lifetime
protocol-version
provision
provision auto-recovery
provision auto-update
proxy-arp enable
proxy-nd enable
ptk-lifetime
ptk-rekey enable
public-key dsa
public-key ecdsa
public-key local create
public-key local destroy
public-key local export dsa
public-key local export ecdsa
public-key local export rsa
public-key peer
public-key peer import sshkey
public-key rsa
put
put
pwd
pwd
pwd
python
python filename
Q
qos apply policy (interface view)
qos apply policy (user profile view)
qos car any
qos map-table
qos policy
qos pre-classify
qos priority
qos priority
qos priority
qos trust
qos trust
qos trust
quick-association enable
R
radar-detect disable
radio
radio
radius attribute extended
radius dscp
radius dynamic-author server
radius nas-ip
radius scheme
radius session-control client
radius session-control enable
radius-server test-profile
random-mac-scan
rate
reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { owd-ds | owd-sd }
reaction checked-element icpif
reaction checked-element mos
reaction checked-element packet-loss
reaction checked-element probe-duration
reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail (for trigger)
reaction checked-element rtt
reaction trap
reaction trigger per-probe
reaction trigger probe-fail
reaction trigger probe-pass
reboot
redirect-url
redundancy replay-interval
reget
region-code (AP provision view/AP group provision view)
region-code (AP view/AP group view)
region-code (global configuration view)
region-code-ie
region-code-lock
remark dscp
remark local-precedence
remote address
remote address dhcp client-identifier
remote-address
remote-configuration
remote-configuration synchronize
remote-server
remote-server
remove
rename
rename
rename
repeat
report-aggregation (IGMP-snooping view)
report-aggregation (MLD-snooping view)
report-interval
report-interval
report-interval
request-method
reset
reset acl counter
reset application statistics
reset arp
reset arp detection statistics
reset aspf session
reset attack-defense policy flood
reset attack-defense statistics interface
reset attack-defense statistics local
reset attack-defense top-attack-statistics
reset bonjour service
reset client-proximity-sensor device
reset client-proximity-sensor statistics receive
reset connection-limit statistics
reset counters interface
reset counters interface loopback
reset counters interface null
reset counters interface tunnel
reset counters interface vlan-interface
reset crypto-engine statistics
reset dhcp relay client-information
reset dhcp relay statistics
reset dhcp server conflict
reset dhcp server expired
reset dhcp server ip-in-use
reset dhcp server statistics
reset dhcp snooping binding
reset dhcp snooping packet statistics
reset dns host
reset dot1x guest-vlan
reset dot1x statistics
reset ethernet statistics
reset exception context
reset hwtacacs statistics
reset igmp-snooping group
reset igmp-snooping router-port
reset igmp-snooping statistics
reset ike sa
reset ike statistics
reset ikev2 sa
reset ikev2 statistics
reset ip policy-based-route statistics
reset ip routing-table statistics protocol
reset ip statistics
reset ipsec sa
reset ipsec statistics
reset ipv6 dhcp client statistics
reset ipv6 dhcp relay statistics
reset ipv6 dhcp server conflict
reset ipv6 dhcp server expired
reset ipv6 dhcp server ip-in-use
reset ipv6 dhcp server pd-in-use
reset ipv6 dhcp server statistics
reset ipv6 nd snooping
reset ipv6 neighbors
reset ipv6 pathmtu
reset ipv6 policy-based-route statistics
reset ipv6 routing-table statistics protocol
reset ipv6 statistics
reset kernel deadloop
reset kernel exception
reset kernel reboot
reset kernel starvation
reset l2-multicast fast-forwarding cache
reset local-guest waiting-approval
reset logbuffer
reset mac-authentication guest-vlan
reset mac-authentication statistics
reset mac-forwarding statistics
reset mld-snooping group
reset mld-snooping router-port
reset mld-snooping statistics
reset nat count statistics
reset nat session
reset netconf service statistics
reset netconf session statistics
reset packet-drop interface
reset password-control blacklist
reset password-control history-record
reset portal auth-error-record
reset portal auth-fail-record
reset portal captive-bypass statistics
reset portal local-binding mac-address
reset portal logout-record
reset portal packet statistics
reset portal redirect session-record
reset portal redirect session-statistics
reset portal redirect statistics
reset portal roaming-center statistics packet
reset portal safe-redirect statistics
reset ppp access-user
reset ppp compression iphc
reset pppoe-server
reset radius statistics
reset recycle-bin
reset saved-configuration
reset scheduler logfile
reset session relation-table
reset session statistics
reset session statistics multicast
reset session table
reset session table ipv4
reset session table ipv6
reset session table multicast
reset session table multicast ipv4
reset session table multicast ipv6
reset tcp statistics
reset udp statistics
reset user-isolation statistics
reset userlog flow export
reset version-update-record
reset wapi statistics
reset wips embedded-oui
reset wips statistics
reset wips virtual-security-domain
reset wips virtual-security-domain countermeasure record
reset wlan ap
reset wlan ap connection-record
reset wlan ap provision
reset wlan ap reboot-log
reset wlan ap unauthenticated
reset wlan channel all
reset wlan client
reset wlan dynamic-blacklist
reset wlan forward statistics
reset wlan ipv6 multicast-optimization entry
reset wlan ipv6 multicast-optimization entry group
reset wlan local-ac
reset wlan multicast-optimization entry
reset wlan multicast-optimization entry group
reset wlan nat-detect
reset wlan roaming-center history user
reset wlan roaming-center statistics packet
reset wlan roaming-center user
reset wlan statistics ap radio
reset wlan statistics client
reset wlan statistics service-template
reset wlan tunnel latency ap
reset wlan wmm
resolve-target
resolve-type
resource-measure
resource-release { data-fill | hex-data-fill }
response-timeout
response-timeout
restart
restful http enable
restful https enable
restore factory-default
restore startup-configuration
retransmit-count
retransmit-count
retransmit-interval
retransmit-interval
retry
retry
retry
retry realtime-accounting
return
reverse-route dynamic
reverse-route preference
reverse-route tag
rfid-tracking aeroscout
rfid-tracking aeroscout aggregate-report interval
rfid-tracking aeroscout engine-address
rfid-tracking aeroscout engine-detection
rfid-tracking aeroscout report-mode
rfid-tracking aeroscout tag-multicast-address
rfid-tracking aeroscout timestamp
rfid-tracking aeroscout vendor-port
rfid-tracking ble
rfid-tracking ble advertisement
rfid-tracking ble advertisement { disable | enable }
rfid-tracking ble advertisement interval
rfid-tracking ble aging-time
rfid-tracking ble command-password
rfid-tracking ble engine-address
rfid-tracking ble real-time report
rfid-tracking ble real-time report prefix
rfid-tracking ble report
rfid-tracking ble report interval
rfid-tracking ble report-format
rfid-tracking ble report-mode
rfid-tracking ble vendor-port
rfid-tracking client rate-limit
rfid-tracking client rate-limit cir
rfid-tracking cupid
rfid-tracking cupid engine-address
rfid-tracking cupid report
rfid-tracking cupid report interval
rfid-tracking cupid report-format
rfid-tracking cupid report-mode
rfid-tracking cupid unassociated-measurement
rfid-tracking cupid unassociated-report
rfid-tracking cupid vendor-port
rfid-tracking dilution
rfid-tracking dilution factor
rfid-tracking fingerprint
rfid-tracking fingerprint engine-address
rfid-tracking fingerprint mu-report
rfid-tracking fingerprint raw-frame-report
rfid-tracking fingerprint report-format
rfid-tracking fingerprint report-mode
rfid-tracking fingerprint tag-multicast-address
rfid-tracking fingerprint vendor-port
rfid-tracking ignore ap-frame
rfid-tracking ignore beacon
rfid-tracking iot
rfid-tracking iot rssi threshold
rfid-tracking iot sampling interval
rfid-tracking iot sampling module
rfid-tracking keepalive
rfid-tracking mode
rfid-tracking radio
rfid-tracking rate-limit
rfid-tracking rate-limit cir
rfid-tracking rssi
rfid-tracking rssi threshold
rhelp
rib
rm-capability mode
rmdir
rmdir
rmdir
rmon alarm
rmon event
rmon history
rmon prialarm
rmon statistics
roam central-ac-auth enable
roam-enhance
roaming-center enable
roam-oi
role
role default-role enable
role feature-group
root-certificate fingerprint
route-option bypass-route
router-aging-time (IGMP-snooping view)
router-aging-time (MLD-snooping view)
rrm
rssi
rssi-threshold
rstatus
rst-flood action
rst-flood detect
rst-flood detect non-specific
rst-flood threshold
rtm cli-policy
rtm environment
rtm scheduler suspend
rtm tcl-policy
rule
rule
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
rule (Layer 2 ACL view)
rule (WLAN AP ACL view)
rule (WLAN client ACL view)
rule comment
running-time
S
sa duration
sa duration
sa duration
sa hex-key authentication
sa hex-key encryption
sa idle-time
sa soft-duration buffer
sa spi
sa string-key
sa trigger-mode
sacp anti-sticky
sacp ssid-hide channel-usage-threshold
save
save wlan ap provision
scan channel blacklist
scan channel whitelist
scan detect
scan idle-time
scan max-service-time
scan mode all
scan mode all interval
scan scan-time
scan work-channel-only
scan-only
scheduler job
scheduler logfile size
scheduler reboot at
scheduler reboot delay
scheduler schedule
scp
scp ipv6
scp ipv6 suite-b
scp server enable
scp suite-b
screen-length
screen-length disable
search-base-dn
search-scope
secondary accounting (HWTACACS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (HWTACACS scheme view)
secondary authentication (RADIUS scheme view)
secondary authorization
security
security acl
security-ie
security-logfile save
select sensor all
send
seq-number
serial-id
serial-id (AP group view)
serial-id (AP view)
serial-number
server-detect (portal authentication server view)
server-detect (portal Web server view)
server-detect url
server-register
server-timeout
server-type (MAC binding server view)
server-type (portal authentication server view/portal Web server view)
server-verify enable
service type
service vlan
service-template
service-template enable
service-type (ISP domain view)
service-type (local user view)
session
session log { bytes-active | packets-active }
session log enable
session log flow-begin
session log flow-end
session log time-active
session persistent acl
session state-machine mode loose
session statistics enable
session-time include-idle-time
set authentication password
sftp
sftp client ipv6 source
sftp client source
sftp ipv6
sftp ipv6 suite-b
sftp server enable
sftp server idle-timeout
sftp suite-b
sha256sum
shell
shop-id
short-gi
short-retry threshold
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown-interval
signature { large-icmp | large-icmpv6 } max-length
signature detect
signature level action
signature level detect
signature policy
signature rule
sip-server
smart-antenna
smart-antenna policy
smartrate-ethernet
snmp-agent
snmp-agent { inform | trap } source
snmp-agent calculate-password
snmp-agent community-map
snmp-agent context
snmp-agent group
snmp-agent log
snmp-agent mib-view
snmp-agent packet max-size
snmp-agent port
snmp-agent remote
snmp-agent sys-info contact
snmp-agent sys-info location
snmp-agent sys-info version
snmp-agent target-host
snmp-agent trap enable
snmp-agent trap enable ike
snmp-agent trap enable ipsec
snmp-agent trap enable ipv6 policy-based-route
snmp-agent trap enable mac-address
snmp-agent trap enable policy-based-route
snmp-agent trap enable port-security
snmp-agent trap enable radius
snmp-agent trap enable syslog
snmp-agent trap enable wlan ap
snmp-agent trap enable wlan capwap
snmp-agent trap enable wlan client
snmp-agent trap enable wlan client-audit
snmp-agent trap enable wlan load-balance
snmp-agent trap enable wlan location-aware
snmp-agent trap enable wlan rrm
snmp-agent trap enable wlan usersec
snmp-agent trap enable wsa
snmp-agent trap if-mib link extended
snmp-agent trap life
snmp-agent trap log
snmp-agent trap queue-size
snmp-agent usm-user { v1 | v2c }
snmp-agent usm-user v3
snmp-agent usm-user v3 user-role
sntp authentication enable
sntp authentication-keyid
sntp enable
sntp ipv6 unicast-server
sntp reliable authentication-keyid
sntp unicast-server
soft-ap
source
source
source interface (ICMP echo/UDP tracert operation view)
source ip
source ipv6
source port
spectrum-analysis
spectrum-analysis calibrate-channel sensitivity
spectrum-analysis trap channel-quality
spectrum-analysis trap channel-quality threshold
spectrum-analysis trap device
spectrum-analysis trap device enable
spectrum-management
sponsor-department
sponsor-email
sponsor-full-name
spoofing-attack blacklist
ssh client ipv6 source
ssh client source
ssh server acl
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
ssh server dscp
ssh server enable
ssh server ipv6 acl
ssh server ipv6 dscp
ssh server pki-domain
ssh server port
ssh server rekey-interval
ssh user
ssh2
ssh2 algorithm cipher
ssh2 algorithm key-exchange
ssh2 algorithm mac
ssh2 algorithm public-key
ssh2 ipv6
ssh2 ipv6 suite-b
ssh2 suite-b
ssid
ssid (AP classification rule view)
ssid (signature view)
ssid-length
ssl client-policy
ssl renegotiation disable
ssl server-policy
ssl version disable
ssl-client-policy
startup saved-configuration
state
state (ISP domain view)
state (local user view)
state primary
state secondary
static-bind
static-bind
statistics hold-time
statistics interval
statistics max-group
statistics-interval
statistics-interval fast-report
status
stbc
step
subject-dn
subscribe-required enable
super
super authentication-mode
super default role
super password
super use-login-username
su-txbf
svp map-ac
switchback (on central ACs)
syn-ack-flood action
syn-ack-flood detect
syn-ack-flood detect non-specific
syn-ack-flood threshold
syn-flood action
syn-flood detect
syn-flood detect non-specific
syn-flood threshold
sysname
system
T
tar create
tar extract
tar list
target-only
tclquit
tclsh
tcp mss
tcp path-mtu-discovery
tcp syn-check
tcp syn-cookie enable
tcp timer fin-timeout
tcp timer syn-timeout
tcp window
tcp-port
telnet
telnet client source
telnet ipv6
telnet server acl
telnet server acl-deny-log enable
telnet server dscp
telnet server enable
telnet server ipv6 acl
telnet server ipv6 dscp
telnet server ipv6 port
telnet server port
temporary address range
temporary-link enable
terminal debugging
terminal logging level
terminal monitor
terminal type
tfc enable
tftp
tftp client ipv6 source
tftp client source
tftp ipv6
tftp-server acl
tftp-server domain-name
tftp-server ip-address
tftp-server ipv6 acl
threshold percentage
threshold weight
threshold-learn apply
threshold-learn auto-apply enable
threshold-learn duration
threshold-learn enable
threshold-learn interval
threshold-learn mode
threshold-learn tolerance-value
time at
time once
time repeating
timer quiet (HWTACACS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (HWTACACS scheme view)
timer response-timeout (RADIUS scheme view)
time-range
timer-hold
timer-hold retry
tkip-cm-time
tolerance-level
tos
tracert
tracert ipv6
track interface
track interface physical
track interface protocol
track ip route reachability
track list boolean
track list threshold percentage
track list threshold weight
track nqa
traffic behavior
traffic classifier
traffic-quota-out
traffic-separate
transform-set
transmission-method
transport-protocol
trust mac-address
trust oui
trust ssid
ttl
tunnel dfbit enable
tunnel encryption
tunnel latency-detect
tunnel protection ipsec
tunnel tos
tunnel ttl
tx-power
type
type
type
U
udp-flood action
udp-flood detect
udp-flood detect non-specific
udp-flood threshold
undelete
unencrypted-authorized-ap
unknown-client
up-duration
uri
url
url
url-parameter
usage
usb
user
user-address-type
user-agent
user-group
user-interface
user-interface class
user-isolation enable
user-isolation permit-broadcast
user-isolation vlan enable
user-isolation vlan permit-bmc acl
user-isolation vlan permit-mac
userlog flow export host
userlog flow export load-balancing
userlog flow export source-ip
userlog flow export timestamp localtime
userlog flow export version
userlog flow syslog
userlog host-group
userlog host-group host flow
username
user-name-format (HWTACACS scheme view)
user-name-format (RADIUS scheme view)
user-parameters
user-password modify enable
user-profile
user-role
user-role
user-role
user-sync
V
valid class
validity-datetime
venue group
venue name
verbose
verify class
version
version
version (HTTP operation/HTTPS operation/HTTPS template view)
version (IGMP-snooping view)
version (MLD-snooping view)
version (SNMP DCA template view)
version disable
vip limit rate
vlan
vlan
vlan
vlan policy deny
vlan-group
vlan-list
W
wan-metrics
wapi authentication method
wapi authentication-server ip
wapi bk lifetime
wapi bk-rekey enable
wapi certificate domain
wapi domain
wapi enable
wapi msk-rekey client-offline enable
wapi msk-rekey enable
wapi msk-rekey method
wapi psk
wapi usk lifetime
wapi usk-rekey enable
weak-iv
web captcha
web https-authorization mode
web idle-timeout
web-redirect url
webui log enable
wep key
wep key-id
wep mode dynamic
windows-bridge
wips (radio view)
wips (system view)
wireless-bridge
wlan accounting-policy
wlan address-security
wlan ap
wlan ap-authentication
wlan ap-authentication acl
wlan ap-authentication domain
wlan ap-authentication enable
wlan ap-authentication import
wlan ap-authentication method
wlan ap-authentication permit-unauthenticated
wlan ap-certificate verification
wlan apdb
wlan apdb file
wlan ap-group
wlan ap-image-deploy
wlan apply accounting-policy
wlan association optimization
wlan authentication optimization
wlan auto-ap enable
wlan auto-ap fat-and-cloud enable
wlan auto-ap persistent
wlan auto-persistent enable
wlan band-navigation aging-time
wlan band-navigation balance access-denial
wlan band-navigation balance session
wlan band-navigation enable
wlan band-navigation rssi-threshold
wlan calibrate-channel pronto ap all
wlan calibrate-power pronto ap all
wlan capwap discovery-policy unicast
wlan capwap encryption
wlan channel-report disable
wlan channel-report interval
wlan client bss-load-ie enable
wlan client forwarding enable
wlan client forwarding-policy-name
wlan client ip-conflict-detection enable
wlan client reauthentication-period
wlan client-rate-limit
wlan client-security authentication clear-previous-connection
wlan description
wlan drs enable
wlan drs report-oasis
wlan drs report-oasis enable
wlan drs wired-statistics enable
wlan dynamic-blacklist active-on-ap
wlan dynamic-blacklist lifetime
wlan error-frame optimization
wlan execute module firmware-upgrade
wlan execute module led-flash
wlan execute module reset
wlan execute module restore-factory
wlan global-configuration
wlan hotspot osu-icon unload
wlan hotspot osu-icon upload
wlan hotspot-policy
wlan image-load filepath
wlan imc
wlan ipv6 multicast-optimization aging-time
wlan ipv6 multicast-optimization client entry-limit
wlan ipv6 multicast-optimization entry client-limit
wlan ipv6 multicast-optimization global entry-limit
wlan ipv6 multicast-optimization packet-rate-limit
wlan link-test
wlan load-balance access-denial
wlan load-balance enable
wlan load-balance mode bandwidth
wlan load-balance mode session
wlan load-balance mode traffic
wlan load-balance rssi-threshold
wlan local-ac
wlan location
wlan max-bandwidth
wlan mesh-policy
wlan mesh-profile
wlan multicast-optimization aging-time
wlan multicast-optimization client entry-limit
wlan multicast-optimization entry client-limit
wlan multicast-optimization global entry-limit
wlan multicast-optimization packet-rate-limit
wlan nas-port-id format
wlan nat-detect
wlan nat-detect countermeasure
wlan neighbor-report disable
wlan neighbor-report interval
wlan osu-provider
wlan password-failure-limit enable
wlan permit-ap-group
wlan permit-ssid
wlan radio
wlan radio continuous-service suppression
wlan radio continuous-service suppression-time
wlan radio-load-balance access-denial
wlan radio-load-balance enable
wlan radio-load-balance overload-5g ssid-hide
wlan radio-load-balance rssi-threshold
wlan re-group
wlan rename-ap
wlan retransmit-frame optimization
wlan roaming-center
wlan rrm baseline remove
wlan rrm baseline save
wlan rrm calibration-channel interval
wlan rrm calibration-power interval
wlan rrm hierarchy-calibration mode
wlan spectrum-analysis feature-db file
wlan static-blacklist mac-address
wlan timezone-sync enable
wlan tunnel-preempt
wlan vip-ap-group
wlan vip-client-group
wlan web-server api-path
wlan web-server host
wlan web-server max-client-entry
wlan whitelist mac-address
wlan-roaming-center ip
wlan-roaming-center port
wmm
wpa3
wt version
X
xml
Y
