16-Security Command Reference
HomeSupportWirelessvAC1000 Virtual Access ControllerReference GuidesCommand ReferencesH3C vAC1000 Virtual Access Controller Command References(R5435P03)-6W10016-Security Command Reference
04-ASPF commands
04-ASPF commands 78.19 KB
ASPF commands
aspf apply policy
Use aspf apply policy to apply an ASPF policy to an interface.
Use undo aspf apply policy to remove an ASPF policy application from an interface.
aspf apply policy aspf-policy-number { inbound | outbound }
undo aspf apply policy aspf-policy-number { inbound | outbound }
No ASPF policy is applied to an interface.
Interface view
aspf-policy-number: Specifies an ASPF policy number. The value range for this argument is 1 to 256.
inbound: Applies the ASPF policy to incoming packets.
outbound: Applies the ASPF policy to outgoing packets.
To inspect the traffic through an interface, you must apply a configured ASPF policy to that interface.
Make sure a connection initiation packet and the response packet pass through the same interface, because an ASPF stores and maintains the application layer protocol status based on interfaces.
You can apply an ASPF policy to both the inbound and outbound directions of an interface.
# Apply ASPF policy 1 to the outbound direction of VLAN-interface 100.
[Sysname-Vlan-interface100] aspf apply policy 1 outbound
aspf policy
display aspf all
display aspf interface
aspf policy
Use aspf policy to create an ASPF policy and enter its view, or enter the view of an existing ASPF policy.
Use undo aspf policy to remove an ASPF policy.
aspf policy aspf-policy-number
undo aspf policy aspf-policy-number
No ASPF policies exist.
aspf-policy-number: Assigns a number to the ASPF policy. The value range for this argument is 1 to 256.
# Create ASPF policy 1 and enter its view.
[Sysname] aspf policy 1
[Sysname-aspf-policy-1]
display aspf all
display aspf policy
detect
Use detect to configure ASPF inspection for an application layer protocol.
Use undo detect to restore the default.
detect { ftp | h323 | sccp | sip | gtp | ils | mgcp | nbt | pptp | rsh | rtsp | sqlnet | tftp | xdmcp }
undo detect { ftp | gtp | h323 | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
ASPF inspects only transport layer protocols and application protocol FTP.
ASPF policy view
ftp: Specifies FTP, an application layer protocol.
gtp: Specifies GPRS Tunneling Protocol (GTP), an application layer protocol.
h323: Specifies H.323 protocol stack, application layer protocols.
ils: Specifies Internet Locator Service (ILS), an application layer protocol.
mgcp: Specifies Media Gateway Control Protocol (MGCP), an application layer protocol.
nbt: Specifies NetBIOS over TCP/IP (NBT), an application layer protocol.
pptp: Specifies Point-to-Point Tunneling Protocol (PPTP), an application layer protocol.
rsh: Specifies Remote Shell (RSH), an application layer protocol.
rtsp: Specifies Real Time Streaming Protocol (RTSP), an application layer protocol.
sccp: Specifies Skinny Client Control Protocol (SCCP), an application layer protocol.
sip: Specifies Session Initiation Protocol (SIP), an application layer protocol.
sqlnet: Specifies SQLNET, an application layer protocol.
tftp: Specifies TFTP, an application layer protocol.
xdmcp: Specifies X Display Manager Control Protocol (XDMCP), an application layer protocol.
This command is required to ensure successful data connections for multichannel protocols.
Application protocols supported by this command (except TFTP) are multichannel protocols.
Repeat the detect command to configure ASPF inspection for multiple application protocols.
ASPF inspection for transport layer protocols is always enabled and is not configurable. The supported transport layer protocols include TCP, UDP, UDP-Lite, SCTP, Raw IP, ICMP, ICMPv6, and DCCP.
This command configures ASPF inspection for application protocols.
# Configure ASPF inspection for FTP packets.
[Sysname-aspf-policy-1] detect ftp
display aspf policy
display aspf all
Use display aspf all to display the configuration of all ASPF policies and their applications.
display aspf all
# Display the configuration of all ASPF policies and their applications.
<Sysname> display aspf all
ASPF policy configuration:
  Policy default:
    ICMP error message check: Disabled
    Inspected protocol
      FTP
  Policy number: 1
    TCP SYN packet check: Disabled
    Inspected protocol
      FTP
Interface configuration:
  GigabitEthernet1/0
    Inbound policy : 1
    Outbound policy: none
Policy default
Predefined ASPF policy.
Whether ICMP error message check is enabled.
Whether TCP SYN check is enabled.
Inspected protocol
Protocols to be inspected by ASPF.
Interfaces where ASPF policy is applied.
Inbound policy
Inbound ASPF policy number.
Outbound policy
Outbound ASPF policy number.
aspf apply policy
aspf policy
display aspf policy
Use display aspf interface to display ASPF policy application on interfaces.
# Display ASPF policy application on interfaces.
<Sysname> display aspf interface
  Vlan-interface 100
    Inbound policy : 1
Inbound policy
Outbound policy
aspf apply policy
aspf policy
display aspf policy
Use display aspf policy to display the configuration of an ASPF policy.
display aspf policy { aspf-policy-number | default }
aspf-policy-number: Specifies the number of an ASPF policy. The value range for this argument is 1 to 256.
default: Specifies the predefined ASPF policy.
# Display the configuration of ASPF policy 1.
<Sysname> display aspf policy 1
  Policy number: 1
    TCP SYN packet check: Enabled
Inspected protocol
aspf policy
display aspf session
Use display aspf session to display ASPF sessions.
display aspf session [ ipv4 | ipv6 ] [ verbose ]
ipv4: Displays IPv4 ASPF sessions.
ipv6: Displays IPv6 ASPF sessions.
verbose: Displays detailed information about ASPF sessions. If you do not specify this keyword, the command displays the brief information about ASPF sessions.
If you do not specify the ipv4 keyword or the ipv6 keyword, this command displays all ASPF sessions on the device.
# Display brief information about IPv4 ASPF sessions.
<Sysname> display aspf session ipv4
Initiator:
  Source      IP/port: 192.168.1.18/1877
  Destination IP/port: 192.168.1.55/22
  DS-Lite tunnel peer: -
  Protocol: TCP(6)
  Inbound interface: Vlan-interface 100
Initiator:
  Source      IP/port: 192.168.1.18/1792
  Destination IP/port: 192.168.1.55/2048
  Protocol: ICMP(1)
Total sessions found: 2
# Display detailed information about IPv4 ASPF sessions.
<Sysname> display aspf session ipv4 verbose
Initiator:
  Protocol: TCP(6)
Responder:
  Source       IP/port: 192.168.1.55/22
  Destination IP/port: 192.168.1.18/1877
  Protocol: TCP(6)
  Inbound interface: Vlan-interface 101
State: TCP_SYN_SENT
Application: SSH
Start time: 2011-07-29 19:12:36  TTL: 28s
Initiator->Responder:         1 packets         48 bytes
Responder->Initiator:         0 packets          0 bytes
Initiator:
  Protocol: ICMP(1)
Responder:
  Source      IP/port: 192.168.1.55/1792
  Destination IP/port: 192.168.1.18/0
  Protocol: ICMP(1)
State: ICMP_REQUEST
Application: OTHER
Start time: 2011-07-29 19:12:33  TTL: 55s
Initiator->Responder:          1 packets         60 bytes
Initiator
Session information from initiator to responder.
Responder
Session information from responder to initiator.
Source IP/port
Source IP address and port number.
Destination IP/port
Destination IP address and port number.
DS-Lite tunnel peer
IP address of the DS-Lite tunnel peer.
If the session is not tunneled by DS-Lite, this field displays a hyphen (-).
VPN-instance/VLAN ID/Inline ID
·     VPN-instance—MPLS L3VPN instance where the session is initiated. This field is not supported in the current software version.
·     VLAN ID—VLAN to which the session belongs during Layer 2 forwarding.
·     Inline ID—Inline to which the session belongs during Layer 2 forwarding.
If no MPLS L3VPN instance, VLAN ID, or Inline ID is specified, a hyphen (-) is displayed for each field.
Protocol
Transport layer protocols, including DCCP, ICMP, ICMPv6, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
Number in parentheses represents the protocol number.
Protocol status of the session.
Application
Application layer protocol, including FTP.
If it is an unknown protocol identified by an unknown port, this field displays OTHER.
Start time
Establishment time of the session.
TTL
Remaining lifetime of the session, in seconds.
Number of packets and bytes from initiator to responder.
Number of packets and bytes from responder to initiator.
reset aspf session
icmp-error drop
Use icmp-error drop to enable ICMP error message check and drop faked messages.
Use undo icmp-error drop to disable ICMP error message check.
icmp-error drop
ICMP error message check is disabled.
ASPF policy view
An ICMP error message carries information about the corresponding connection. ICMP error message check verifies the information. If the information does not match the connection, ASPF drops the message.
# Enable ICMP error message check for ASPF policy 1.
[Sysname-aspf-policy-1] icmp-error drop
aspf policy
display aspf policy
reset aspf session
Use reset aspf session to clear ASPF session statistics.
reset aspf session [ ipv4 | ipv6 ]
ipv4: Clears IPv4 ASPF session statistics.
ipv6: Clears IPv6 ASPF session statistics.
If you do not specify the ipv4 keyword or the ipv6 keyword, this command clears all ASPF session statistics.
# Clear all ASPF session statistics.
<Sysname> reset aspf session
tcp syn-check
Use tcp syn-check to enable TCP SYN check.
Use undo tcp syn-check to disable TCP SYN check.
tcp syn-check
undo tcp syn-check
TCP SYN check is disabled.
ASPF policy view
TCP SYN check checks the first packet to establish a TCP connection whether it is a SYN packet. If the first packet is not a SYN packet, ASPF drops the packet.
When a router attached to the network is started up, it can receive a non-SYN packet of an existing TCP connection for the first time. If you do not want to interrupt the existing TCP connection, you can disable the TCP SYN check. Then, the router allows the non-SYN packet that is the first packet to establish a TCP connection to pass. After the network topology becomes steady, you can enable TCP SYN check again.
# Enable TCP SYN check for ASPF policy 1.
[Sysname-aspf-policy-1] tcp syn-check
aspf policy
