09-Radio Resources Management Command Reference
HomeSupportWirelessvAC1000 Virtual Access ControllerReference GuidesCommand ReferencesH3C vAC1000 Virtual Access Controller Command References(R5435P03)-6W10009-Radio Resources Management Command Reference
07-WLAN radio resource measurement commands
07-WLAN radio resource measurement commands 73.10 KB
display wlan measure-report
Use display wlan measure-report to display measurement reports for clients.
display wlan measure-report ap ap-name radio radio-id [ client mac-address mac-address ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio radio-id: Specifies a radio by its number.
client mac-address mac-address: Specifies a client by its MAC address. If you do not specify a client, this command displays measurement reports for all clients.
# Display measurement reports for clients associated with radio 2 of AP ap1.
<Sysname> display wlan measure-report ap ap1 radio 2
Total number of clients: 1
Client MAC address                               : 0aef-e760-3587
Link measurement:
  Link margin                                    : 2 dBm
  RCPI                                           : -85 dBm
  RSNI                                           : 53 dBm
Noise histogram:
  Antenna ID                                     : 3
  ANPI                                           : -56 dBm
  IPI0 to IPI10 density                          : 5 12 16 13 8 5 5 15 17 1 3
Spectrum measurement:
  Transmit power                                 : 20 dBm
  BSS                                            : Detected
  OFDM preamble                                  : Detected
  Radar                                          : Detected
  Unidentified signal                            : Undetected
  CCA busy fraction                              : 60
  RPI0 to RPI7 density                           : 3 7 11 19 15 23 15 7
Frame report entry:
  BSSID                                          : a072-2351-e253
  PHY type                                       : fhss
  Average RCPI                                   : -10 dBm
  Last RSNI                                      : 2 dBm
  Last RCPI                                      : -20 dBm
  Frames                                         : 1
Dot11BSSAverageAccessDelay group:
  Average access delay                           : 32 ms
  BestEffort average access delay                : 1 ms
  Background average access delay                : 1 ms
  Video average access delay                     : 1 ms
  Voice average access delay                     : 1 ms
  Clients                                        : 32
  Channel utilization rate                       : 11
Transmit stream:
  Traffic ID                                     : 0
  Sent MSDUs                                     : 60
  Discarded MSDUs                                : 5
  Failed MSDUs                                   : 3
  MSDUs resent multiple times                    : 3
  Lost QoS CF-Polls                              : 2
  Average queue delay                            : 2 ms
  Average transmit delay                         : 1 ms
  Bin0 range                                     : 0 to 10 ms
  Bin0 to Bin5                                   : 5 10 10 5 10 10
Link margin
Gap between the received RSSI and the lowest available RSSI.
RCPI
Received Channel Power Indicator.
RSNI
Received Signal to Noise Indicator.
ANPI
Average Noise Power Indicator during the measurement.
Percentage of time for different IPI ranges to the total measurement period.
IPIn represents an IPI range. The value for n is in the range of 1 to 10:
·     0: IPI <= –92 dBm.
·     1: –92 dBm < IPI <= –89 dBm.
·     2: –89 dBm < IPI <= –86 dBm.
·     3: –86 dBm < IPI <= –83 dBm.
·     4: –83 dBm < IPI <= –80 dBm.
·     5: –80 dBm < IPI <= –75 dBm
·     6: –75 dBm < IPI <= –70 dBm.
·     7: –70 dBm < IPI <= –65 dBm.
·     8: –65 dBm < IPI <= –60 dBm.
·     9: –60 dBm < IPI <= –55 dBm.
·     10: –55 dBm < IPI.
Transmit power
Transmission power of the client.
BSS
Whether the client has detected wireless packets from other BSSs.
OFDM preamble
Whether the client has detected OFDM preambles.
Radar
Whether the client has detected radar signals.
Unidentified signal
Whether the client has detected unknown signals.
CCA busy fraction
CCA utilization is expressed as a percentage of time that the channel is busy (during the measurement period).
Percentage of time that each RPI was used during the measurement period.
RPIn represents a RPI range. The value for n is in the range of 1 to 7:
·     0: RPI <= –87 dBm.
·     1: –87 dBm < RPI <= –82 dBm.
·     2: –82 dBm < RPI <= –77 dBm.
·     3: –77 dBm < RPI <= –72 dBm.
·     4: –72 dBm < RPI <= –67 dBm.
·     5: –67 dBm < RPI <= –62 dBm.
·     6: –62 dBm < RPI <= –57 dBm.
·     7: –57 dBm < RPI.
PHY type
Physical media type:
·     fhss.
·     dsss.
·     irbaseband.
·     ofdm.
·     hrdsss.
·     erp.
Frames
Number of frames from the same MAC address and BSSID during the measurement.
Bin0 range
Value range for Bin0.
Bin0 to Bin5
Number of successfully sent MSDUs for each average delay range.
Binx represents an average delay range. The value for x is in the range of 0 to 5:
·     Bin0: Delay< 10 ms.
·     Bin1: 10 ms <= Delay < 20 ms.
·     Bin2: 20 ms <= Delay < 40 ms.
·     Bin3: 40 ms <= Delay < 80 ms.
·     Bin4: 80 ms <= Delay < 160 ms.
·     Bin5: 160 ms <= Delay.
measure
Use measure enable to enable the specified measurement feature or all measurement features.
Use measure disable to disable the specified measurement feature or all measurement features.
Use undo measure to restore the default.
measure { all | link | neighbor | radio | spectrum | tpc } { disable | enable }
undo measure
In radio view, an AP uses the configuration in AP group view.
In an AP group's radio view, measurement is disabled.
Radio view
all: Specifies all measurement features.
link: Specifies link measurement. Link measurement measures RCPI, RSNI, and link redundancy for the requested link.
neighbor: Specifies neighbor measurement. Neighbor measurement measures the channel and BSSID of neighbor APs.
radio: Specifies radio measurement. Radio measurement measures channel load, noise histogram, beacons, frames, station statistics, locations, and transmit streams.
spectrum: Specifies spectrum measurement, which includes basic measurement, Clear Channel Assessment (CCA) measurement, and Receive Power Indication (RPI) measurement.
tpc: Specifies TPC measurement. TPC measurement measures link redundancy and transmission power for clients.
You must enable radio resource measurement if you enable link, neighbor, or radio measurement.
You must enable spectrum management if you enable spectrum or TPC measurement. For more information about spectrum management, see Radio Resources Management Configuration Guide.
The spectrum and tpc keywords are available only for 5 GHz radios.
# Enable spectrum measurement for AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] measure spectrum enable
# Enable spectrum measurement for AP group apgroup1.
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] measure spectrum enable
measure-duration
measure-interval
resource-measure
spectrum-management
measure-duration
Use measure-duration to set the measurement duration.
Use undo measure-duration to restore the default.
measure-duration time
In an AP group's radio view, the measurement duration is 500 TUs.
Radio view
time: Specifies the measurement duration in the range of 1 to 10000 TUs. One TU is equal to 1024 microseconds.
When measurement is enabled on an AP, the AP adds the measurement duration in the measurement requests sent to clients.
# Set the measurement duration to 512 TUs for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] measure-duration 512
# Set the measurement duration to 512 TUs for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] measure-duration 512
measure
measure-interval
measure-interval
Use measure-interval to set the measurement interval for an AP to send measurement requests to clients.
Use undo measure-interval to restore the default.
measure-interval interval
In an AP group's radio view, the measurement interval is 30 seconds.
Radio view
interval: Specifies the measurement interval in the range of 10 to 60 seconds.
# Set the measurement interval to 35 seconds for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] measure-interval 35
# Set the measurement interval to 35 seconds for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] measure-interval 35
measure
measure-duration
resource-measure
Use resource-measure enable to enable radio resource measurement.
Use resource-measure disable to disable radio resource measurement.
Use undo resource-measure to restore the default.
resource-measure { disable | enable }
In an AP group's radio view, radio resource measurement is disabled.
Radio view
When radio measurement is enabled on an AP, the AP sets the Radio Measurement field to 1 in beacons, probe responses, association responses, or reassociation responses. It notifies the clients that they can send measurement requests. These frames also carry measurement capabilities of the AP to inform clients of measurement types that the AP supports.
The AP periodically sends Measurement Pilot frames to help clients fast discover the AP. Measurement Pilot frames are sent more frequently than beacons and carry less information.
# Enable radio resource measurement for AP ap1.
[Sysname-wlan-ap-ap1] radio 2
[Sysname-wlan-ap-ap1-radio-2] resource-measure enable
# Enable radio resource measurement for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] resource-measure enable
rm-capability mode
Use rm-capability mode to set the match mode for client radio resource measurement capabilities.
Use undo rm-capability mode to restore the default.
rm-capability mode { all | none | partial }
In an AP group's radio view, the match mode is none for client radio resource measurement capabilities.
Radio view
all: Specifies the all mode. A client is allowed to associate with an AP only when all its radio resource measurement capabilities match the AP's radio resource measurement capabilities.
none: Specifies the none mode. The AP does not check client radio resource measurement capabilities.
partial: Specifies the partial mode. A client is allowed to associate with an AP as long as one of its radio resource measurement capabilities matches any of the AP's radio resource measurement capabilities.
The configuration takes effect only when radio resource measurement is enabled.
# Set the match mode to partial for client radio resource measurement capabilities for AP ap1.
[Sysname-wlan-ap-ap1-radio-2] rm-capability mode partial
# Set the match mode to partial for client radio resource measurement capabilities for AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] rm-capability mode partial
resource-measure
