06-WLAN Access Command Reference
HomeSupportWirelessvAC1000 Virtual Access ControllerReference GuidesCommand ReferencesH3C vAC1000 Virtual Access Controller Command References(R5435P03)-6W10006-WLAN Access Command Reference
01-WLAN access commands
01-WLAN access commands 351.99 KB
WLAN access commands· 1
access-control acl 1
accounting-level 2
beacon ssid-hide· 3
broadcast-probe reply· 3
classifier acl 4
client association-location· 5
client behavior-local network-flow-forwarding enable· 5
client cache aging-time· 6
client forwarding-location· 7
client forwarding-policy enable· 7
client forwarding-policy-name· 8
client frame-format 9
client idle-timeout 9
client keep-alive· 10
client keep-alive interval 11
client max-count 12
client preferred-vlan authorized· 13
client report-mandatory· 13
client smart-access enable· 14
client vlan-alloc· 14
client-mac· 15
client-statistics-report 16
client-statistics-report smart-maintenance· 17
customlog format wlan· 18
description· 19
display wlan ap all client-number 19
display wlan ap all radio client-number 20
display wlan ap-group all client-number 20
display wlan blacklist 21
display wlan bss· 22
display wlan client 23
display wlan client ipv6· 29
display wlan client online-duration· 30
display wlan client status· 31
display wlan forwarding-policy· 33
display wlan service-template· 34
display wlan statistics client 39
display wlan statistics connect-history· 40
display wlan statistics service template· 41
display wlan statistics vip-client 42
display wlan whitelist 43
inherit exclude service-template· 43
nas-id· 44
nas-port-id· 45
nas-port-type· 46
nas-vlan· 47
non-vip limit rate· 48
quick-association enable· 49
report-interval 49
reset wlan client 50
reset wlan dynamic-blacklist 51
reset wlan statistics client 51
reset wlan statistics service-template· 52
roam-enhance· 52
service-template· 53
service-template enable· 54
snmp-agent trap enable wlan client 55
snmp-agent trap enable wlan client-audit 55
ssid· 56
unknown-client 56
vip limit rate· 57
vlan· 58
wlan accounting-policy· 59
wlan apply accounting-policy· 60
wlan association optimization· 60
wlan client bss-load-ie enable· 61
wlan client forwarding enable· 62
wlan client forwarding-policy-name· 62
wlan client reauthentication-period· 63
wlan dynamic-blacklist active-on-ap· 64
wlan dynamic-blacklist lifetime· 65
wlan forwarding-policy· 65
wlan imc· 66
wlan link-test 66
wlan nas-port-id format 68
wlan permit-ap-group· 69
wlan permit-ssid· 70
wlan service-template· 71
wlan static-blacklist mac-address· 71
wlan vip-client-group· 72
wlan web-server api-path· 72
wlan web-server host 73
wlan web-server max-client-entry· 74
wlan whitelist mac-address· 74
access-control acl
Use access-control acl to specify an ACL for ACL-based access control.
Use undo access-control acl to restore the default.
access-control acl acl-number
No ACL is specified.
AP view
Service template view
acl-number: Specifies the number of a Layer 2 ACL, in the range of 4000 to 4999.
This feature controls client access by using the specified ACL rules. When the device receives an association request, it performs the following actions:
·     Allows the client to access the WLAN if the MAC address of the client matches the MAC address attribute or MAC address OUI attribute in a rule and the rule action is permit. If multiple clients match the OUI attribute, all these clients are allowed to access the WLAN.
·     Denies the client's access to the WLAN if no match is found or the matched rule has a deny statement.
When you configure this feature, follow these restrictions and guidelines:
·     If the specified ACL contains a deny statement, configure a permit statement for the ACL to permit all clients. If you do not do so, no clients can come online.
·     ACL-based access control configuration takes precedence over whitelist and blacklist configuration.
·     You can specify only one ACL. If you execute this command multiple times, the most recent configuration takes effect.
·     The configuration in AP view takes precedence over the configuration in service template view.
# Create ACL 4000 and create ACL rules to permit the client with MAC address 000e-35b2-000e and clients with the specified OUI. Specify ACL 4000 for service template service1.
[Sysname] acl mac 4000
[Sysname-acl-mac-4000] rule 0 permit source-mac 000e-35b2-000e ffff-ffff-ffff
[Sysname-acl-mac-4000] rule 1 permit source-mac 000e-35b2-000f ffff-ff00-0000
[Sysname-acl-mac-4000] rule 2 deny
[Sysname-acl-mac-4000] quit
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] access-control acl 4000
# Create ACL 4000 and create ACL rules to permit the client with MAC address 000e-35b2-000e and clients with the specified OUI. Specify ACL 4000 for AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] access-control acl 4000
accounting-level
Use accounting-level to specify a traffic level for ACL-based accounting.
Use undo accounting-level to remove the accounting configuration for a traffic level.
accounting-level level acl { acl-number | ipv6 ipv6-acl-number }
undo accounting-level level
No traffic levels are specified for ACL-based accounting.
Accounting policy view
level: Specifies the traffic level in the range of 1 to 8.
acl-number: Specifies an IPv4 ACL number in the range of 3000 to 3999.
ipv6 ipv6-acl-number: Specifies an IPv6 ACL number in the range of 3000 to 3999.
An accounting policy takes effect on matching packets no matter whether the ACL action is deny or permit.
# Specify the traffic level as 1 for packets matching ACL 3000 in accounting policy view of policy abc.
[Sysname] wlan accounting-policy abc
[Sysname-wlan-acctpolicy-abc] accounting-level 1 acl 3000
beacon ssid-hide
Use beacon ssid-hide to disable advertising of the Service Set Identifier (SSID) in beacon frames.
Use undo beacon ssid-hide to restore the default.
beacon ssid-hide
The SSID is advertised in beacon frames.
This command disables a radio from carrying SSIDs in the beacon frames and responding to probe requests after the specified service template is bound to the radio.
# Disable advertising the SSID in beacon frames.
[Sysname-wlan-st-service1] beacon ssid-hide
Use broadcast-probe reply enable to enable an AP to respond to broadcast probe requests.
Use broadcast-probe reply disable to disable an AP from responding to broadcast probe requests.
Use undo broadcast-probe reply to restore the default.
broadcast-probe reply { disable | enable }
In AP view, an AP uses the configuration in AP group view.
In AP group view, an AP responds to broadcast probe requests.
AP view
AP group view
Broadcast probe requests do not carry an SSID. Upon receiving a broadcast probe request, an AP responds with a probe response that carries service information for the AP. To ensure that clients that send unicast probe requests can associate with the AP, disable the AP from responding to broadcast probe requests.
The configuration in AP view takes precedence over the configuration in AP group view.
# Disable AP ap1 from responding to broadcast probe requests.
[Sysname-wlan-ap-ap1] broadcast-probe reply disable
# Disable APs in AP group group1 from responding to broadcast probe requests.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] broadcast-probe reply disable
classifier acl
Use classifier acl to configure a forwarding rule for a forwarding policy.
Use undo classifier acl to remove a forwarding rule.
classifier acl { acl-number | ipv6 ipv6-acl-number } behavior { local | remote }
undo classifier acl { acl-number | ipv6 ipv6-acl-number }
No forwarding rules are configured.
Forwarding policy view
acl-number: Specifies an IPv4 or Layer 2 ACL number in the range of 2000 to 4999.
ipv6 ipv6-acl-number: Specifies an IPv6 ACL number in the range of 2000 to 3999.
behavior: Specifies a forwarding mode for traffic that matches the specified ACL.
local: Specifies the local forwarding mode.
remote: Specifies the centralized forwarding mode.
Actions defined in ACL rules do not take effect in wireless packet forwarding. All matched packets are forwarded based on the forwarding mode.
A forwarding rule takes effect immediately after it is created. You can configure a maximum of 1000 forwarding rules for a forwarding policy.
# Configure a forwarding rule to locally forward packets that match ACL 2000.
<sysname> system-view
[sysname] wlan forwarding-policy abc
[sysname-wlan-fp-abc] classifier acl 2000 behavior local
Use client association-location to enable client association at the AC or APs.
Use undo client association-location to restore the default.
client association-location { ac | ap }
Client association is performed at the AC.
ac: Enables client association at the AC.
ap: Enables client association at APs.
Make sure the service template is disabled before you execute this command.
# Enable client association at the AC.
[Sysname-wlan-st-service1] client association-location ac
Use client behavior-local network-flow-forwarding enable to enable APs to forward client traffic to the external network when local forwarding is enabled.
Use undo client behavior-local network-flow-forwarding enable to disable APs from forwarding client traffic to the external network when local forwarding is enabled.
APs drop client packets destined to the external network when local forwarding is enabled.
WLAN forwarding policy view
When local forwarding is enabled, APs drop client packets destined to the external network. This feature enables an AP to replace the destination MAC address of a client packet destined to the external network with the AP's MAC address. Through NAT, the packet's source IP address is converted to an IP address in the same network segment as the AP. This enables APs to forward client traffic to an external network correctly.
This feature is available only on APs that support NAT.
# Enable APs to forward client packets destined to the external network when local forwarding is enabled.
[Sysname] wlan forwarding-policy abc
[Sysname-wlan-fp-abc] client behavior-local network-flow-forwarding enable
Use client cache aging-time to set the aging time for the cache of clients.
Use undo client cache aging-time to restore the default.
client cache aging-time aging-time
The aging time for the cache of clients is 180 seconds.
aging-time: Specifies the aging time for the cache of clients, in the range of 0 to 86400 seconds.
If you set the aging time to 0 seconds, the AC clears the client cache immediately when the clients go offline.
# Set the aging time for the cache of clients to 100 seconds.
[Sysname-wlan-st-service1] client cache aging-time 100
Use client forwarding-location to specify the client data traffic forwarder.
Use undo client forwarding-location to restore the default.
client forwarding-location { ac | ap [ vlan { start-vlan [ to end-vlan ] } ] }
The AC forwards client data traffic.
ac: Enables the AC to forward client data traffic.
ap: Enables APs to forward client data traffic.
vlan start-vlan to end-vlan: Specifies a VLAN ID range. The value range for the start-vlan and end-vlan arguments is 1 to 4094. If you do not specify this option, APs forward client data traffic from all VLANs.
If APs forward client data traffic, you can specify a VLAN or a VLAN range for the APs to forward client data traffic from the specified VLANs. The AC forwards data traffic from other VLANs.
Make sure client traffic forwarding is enabled when the AC is configured as the client traffic forwarder.
# Configure APs to forward client data traffic from all VLANs.
[Sysname-wlan-st-service1] user-forward location ap
Use client forwarding-policy enable to enable policy-based forwarding for a service template.
Use undo client forwarding-policy enable to disable policy-based forwarding for a service template.
Policy-based forwarding is disabled for a service template.
Enable policy-based forwarding for a service template for the following forwarding policies to take effect:
·     The forwarding policy applied to the service template.
·     The forwarding policy applied to a user profile that uses the service template.
# Enable policy-based forwarding for service template service1.
[Sysname-wlan-st-service1] client forwarding-policy enable
client-security authentication-location
Use client forwarding-policy-name to apply a forwarding policy to a service template.
Use undo client forwarding-policy-name to restore the default.
client forwarding-policy-name policy-name
No forwarding policy is applied to a service template.
policy-name: Specifies a forwarding policy by its name, a case-insensitive string of 1 to 31 characters.
For the forwarding policy to take effect, you must enable policy-based forwarding and specify the AC to perform client authentication for the service template.
Make sure the AC and its associated APs are in different network segments.
# Apply forwarding policy strategy to service template service1.
[Sysname-wlan-st-service1] client forwarding-policy-name strategy
client frame-format
Use client frame-format to set the client data frame format.
Use undo client frame-format to restore the default.
client frame-format { dot3 | dot11 }
Client data frames are encapsulated in 802.3 format.
dot3: Specifies the 802.3 format.
dot11: Specifies the 802.11 format.
This command takes effect only in centralized forwarding mode.
# Configure the client data frames to be encapsulated in 802.11 format.
[Sysname-wlan-st-service1] client frame-format dot11
client idle-timeout
Use client idle-timeout to set the client idle timeout timer.
Use undo client idle-timeout to restore the default.
client idle-timeout timeout
In AP group view, the client idle timeout timer is 3600 seconds.
AP view
AP group view
timeout: Specifies the client idle timeout timer in the range of 60 to 86400 seconds.
If an online client does not send any frames to the associated AP before the client idle timeout timer expires, the AP logs off the client.
# Set the client idle timeout timer to 2000 seconds for AP ap1.
[Sysname-wlan-ap-ap1] client idle-timeout 2000
# Set the client idle timeout timer to 2000 seconds for AP group group1.
[Sysname-wlan-ap-group-group1] client idle-timeout 2000
client keep-alive
Use client keep-alive enable to enable client keepalive.
Use client keep-alive disable to disable client keepalive.
Use undo client keep-alive to restore the default.
client keep-alive { disable | enable }
In AP group view, client keepalive is disabled.
AP view
AP group view
disable: Disables client keepalive.
enable: Enables client keepalive.
This feature enables an AP to send keepalive packets to clients at the client keepalive interval to determine whether the clients are online. If the AP does not receive any replies from a client within three keepalive intervals, it logs off the client.
# Enable client keepalive for AP ap1.
[Sysname-wlan-ap-ap1] client keep-alive enable
# Enable client keepalive for AP group group1.
[Sysname-wlan-ap-group-group1] client keep-alive enable
Use client keep-alive interval to set the client keepalive interval.
Use undo client keep-alive interval to restore the default.
client keep-alive interval interval
In AP group view, the client keepalive interval is 300 seconds.
AP view
AP group view
interval: Specifies the client keepalive interval in the range of 3 to 1800 seconds.
Enable client keepalive before you execute this command.
As a best practice to avoid client instability caused by a short keepalive interval, set the interval to be longer than 10 seconds.
# Set the keepalive interval to 20 seconds for AP ap1.
[Sysname-wlan-ap-ap1] client keep-alive interval 20
# Set the keepalive interval to 20 seconds for AP group group1.
[Sysname-wlan-ap-group-group1] client keep-alive interval 20
client max-count
Use client max-count to set the maximum number of associated clients for a service template.
Use undo client max-count to restore the default.
client max-count max-number
The number of associated clients for a service template is not limited.
max-number: Specifies the maximum number of clients in the range of 1 to 512.
With this feature configured, new clients cannot access the WLAN from a radio and the SSID is hidden when the maximum number is reached on the radio.
# Set the maximum number of associated clients to 38 for service template service1.
[Sysname-wlan-st-service1] client max-count 38
beacon ssid-hide
Use client preferred-vlan authorized to configure clients to prefer the authorization VLAN after roaming.
Use undo client preferred-vlan authorized to configure client VLANs to remain unchanged after client roaming.
Clients prefer the authorization VLAN after roaming.
This feature takes effect only on 802.1X and MAC authentication clients.
Typically, the VLAN of a client remains unchanged after client roaming. However, if the client triggers a security alert configured on IMC after roams to another AP, the issued authorization VLAN for user isolation takes effect.
# Configure clients to prefer the authorization VLAN after roaming.
[Sysname-wlan-st-service1] client preferred-vlan authorized
Use client report-mandatory to allow locally authenticated clients to come online after successful client information reporting.
Use undo client report-mandatory to allow locally authenticated clients to come online immediately after successful local authentication.
Locally authenticated clients come online after successful client information reporting.
By default, an AP reports information about locally authenticated clients that pass authentication to the AC, and the AC creates client entries and informs the AP to get the clients online. If the CAPWAP tunnel between the AC and the AP operates incorrectly, clients might fail to come online and perform reauthentication repeatedly. To avoid this problem, you can allow clients to come online immediately after successful local authentication so that the AP can forward client traffic when the AC cannot be reached. The AP synchronizes client information to the AC when the tunnel recovers.
# Allow locally authenticated clients to come online immediately after successful local authentication.
[Sysname-wlan-st-service1] undo client report-mandatory
Use client smart-access enable to enable smart client access.
Use undo client smart-access enable to restore the default.
Smart client access is disabled.
This feature enables H3C wireless clients to access the WLAN automatically when the AKM mode is set to PSK or when the radio is bound to an empty service template.
# Enable smart client access.
[Sysname-wlan-st-service1] client smart-access enable
client vlan-alloc
Use client vlan-alloc to set the VLAN allocation method for clients.
Use undo client vlan-alloc to restore the default.
client vlan-alloc { dynamic | static | static-compatible }
The VLAN allocation method for clients is dynamic.
dynamic: Specifies dynamic VLAN allocation.
static: Specifies static VLAN allocation.
static-compatible: Specifies compatible static VLAN allocation.
When a client comes online for the first time, the associated AP assigns a random VLAN to it. When the client comes online again, the VLAN assigned to the client depends on the allocation method.
·     Static allocation—The client inherits the VLAN that has been assigned to it. If the IP address lease has not expired, the client will use the same IP address. This method helps save IP addresses.
·     Dynamic allocation—The radio re-assigns a VLAN to the client. This method balances clients in all VLANs.
·     Compatible static allocation—The client inherits the VLAN that has been assigned to it when roaming between Comware 5 and Comware 7 ACs.
# Set the VLAN allocation method for clients to dynamic.
[Sysname-wlan-st-service1] client vlan-alloc dynamic
service-template
client-mac
Use client-mac to add a client to the VIP client group.
Use undo ap-name to remove a client from the VIP client group.
client-mac mac-address [ level level ]
undo client-mac mac-address
No clients exist in the VIP client group.
VIP client group view
mac-address: Specifies a client by its MAC address. The MAC address must be in the H-H-H format, where 0s at the beginning of each H (16-bit hexadecimal digit) can be omitted.
level level: Specifies the VIP client level. The value is 1 or 2. By default, the client level is 1.
You can add both online and offline clients to the VIP client group.
You can add a maximum of 64 client MAC addresses.
Level 1 clients have a higher transmission and access priority than level 2 clients. The system does not rate limit level 1 clients.
When the maximum number of associated clients is reached on a radio and a new client attempts to come online, the system performs the following tasks:
·     If the new client is a non-VIP client, the system rejects the client's association request.
·     If the new client is a VIP client, the system logs off a non-VIP client or a VIP client of a lower level for the new client to come online.
¡     If non-VIP clients are online, the system logs off a non-VIP client.
¡     If no non-VIP client is online, the system logs off a level 2 VIP client.
¡     If all the online clients are level 1 VIP clients, the system rejects the client's association request.
# Add a client with MAC address a0cc-2bca-a305 to the VIP client group.
[Sysname] wlan vip-client-group
[Sysname-wlan vip-client-group] client-mac a0cc-2bca-a305
Use client-statistics-report enable to enable client statistics reporting.
Use client-statistics-report disable to disable client statistics reporting.
Use undo client-statistics-report to restore the default.
client-statistics-report { disable | enable [ interval interval ] }
In AP group view, client statistics reporting is enabled.
AP view
AP group view
interval interval: Specifies the interval at which client statistics are reported, in the range of 2 to 120 seconds. The interval is 50 seconds by default.
This feature enables an AP to report client statistics to the AC at the specified intervals for client entry update. The AC informs the AP to log off a client if the client's information does not exist in the saved entries.
To avoid frequent client re-association, disable this feature when the network is in a bad condition.
# Enable client statistics reporting and set the reporting interval to 20 seconds for AP ap1.
[Sysname-wlan-ap-ap1] client-statistics-report enable interval 20
# Enable client statistics reporting and set the reporting interval to 20 seconds for AP group group1.
[Sysname-wlan-ap-group-group1] client-statistics-report enable interval 20
Use client-statistics-report smart-maintenance enable to enable client O&M statistics reporting.
Use client-statistics-report smart-maintenance disable to disable client O&M statistics reporting.
Use undo client-statistics-report smart-maintenance to restore the default.
client-statistics-report smart-maintenance { disable | enable }
In AP group view, client O&M statistics reporting is enabled.
AP view
AP group view
This feature enables an AP to report client O&M statistics to the AC at the interval specified by the client-statistics-report command. Then, the AC will report the statistics to the Oasis platform.
As a best practice, disable this feature when the network is in a bad condition.
VIP client functions might require client O&M statistics. If you configure VIP clients, enable client O&M statistics reporting.
# Enable client O&M statistics reporting for AP ap1.
[Sysname-wlan-ap-ap1] client-statistics-report smart-maintenance enable
# Enable client O&M statistics reporting for AP group group1.
[Sysname-wlan-ap-group-group1] client-statistics-report smart-maintenance enable
Use customlog format wlan to enable the device to generate client logs in the specified format.
Use undo customlog format wlan to restore the default.
customlog format wlan { normal | sangfor }
The device generates client logs only in H3C format.
normal: Specifies normal format.
sangfor: Specifies sangfor format.
By default, the device generates client logs only in H3C format that logs AP name, radio ID, client MAC address, SSID, BSSID, and client online status.
You can configure the device to generate client logs in one of the following formats:
·     Normal—Logs AP MAC address, AP name, client IP address, client MAC address, SSID, and BSSID.
·     Sangfor—Logs AP MAC address, client IP address, and client MAC address.
This feature does not affect the generation of client logs in H3C format.
# Enable the device to generate client logs in sangfor format.
[Sysname] customlog format wlan sangfor
description
Use description to configure a description for a service template.
No description is configured for a service template.
text: Specifies a description, a case-sensitive string of 1 to 64 characters.
# Configure a description for service template service1.
[Sysname-wlan-st-service1] description wlanst
Use display wlan ap all client-number to display the number of online clients at the 2.4 GHz band and the 5 GHz band.
# Display the number of online clients at both the 2.4 GHz and 5 GHz bands.
<System> display wlan ap all client-number
AP name           Clients           2.4GHz            5GHz
ap1               2                 2                 0
Clients
Total number of online clients.
2.4GHz
Number of online clients at the 2.4 GHz band.
5GHz
Number of online clients at the 5 GHz band.
Use display wlan ap all radio client-number to display the number of online clients and channel information for each radio.
# Display the number of online clients and channel information for each radio.
<Sysname> display wlan ap all radio client-number
AP name                    RID     Channel     Clients
ap1                        1       44          12
ap1                        2       11          4
Use display wlan ap-group all client-number to display the number of online clients in each radio group.
# Display the number of online clients in each radio group.
<Sysname> display wlan ap-group all client-number
AP group name                    Group ID    Clients     2.4GHz      5GHz
default-group                    1           150         100         50
1                                2           250         50          200
2.4GHz
Number of clients at the 2.4 GHz band.
5GHz
Number of clients at the 5 GHz band.
Use display wlan blacklist to display blacklist entries.
display wlan blacklist { dynamic | static }
dynamic: Specifies the dynamic blacklist.
static: Specifies the static blacklist.
# Display static blacklist entries.
<Sysname> display wlan blacklist static
Total number of clients: 3
 MAC addresses:
  000e-35b2-000e
  0019-5b8e-b709
  001c-f0bf-9c92
# Display dynamic blacklist entries.
<Sysname> display wlan blacklist dynamic
MAC address     APID  Lifetime (s)  Duration (hh:mm:ss)
000f-e2cc-0001  1     300           00:02:11
000f-e2cc-0002  2     300           00:01:17
000f-e2cc-0003  3     300           00:02:08
MAC address
Client MAC address.
APID
ID of the AP that detects the rogue client.
Lifetime (s)
Lifetime of the entry in seconds.
Duration (hh:mm:ss)
Duration for the entry since the entry was added to the dynamic blacklist.
display wlan bss
Use display wlan bss to display basic service set (BSS) information.
display wlan bss { all | ap ap-name | bssid bssid } [ verbose ]
all: Displays all BSSs.
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
bssid bssid: Specifies a BSS by its ID. The value is a 48-bit hexadecimal number in the format of H-H-H.
verbose: Displays detailed client information. If you do not specify this keyword, the command displays brief client information.
# Display brief information about all BSSs.
<Sysname> display wlan bss all
Total number of BSSs: 4
AP name                   RID  SSID                            BSSID
ap1                       1    SSID1                           001c-f08f-f804
ap1                       2    SSID1                           001c-f08f-f806
ap2                       1    SSID1                           001c-f0bf-9c92
ap2                       2    SSID1                           001c-f0bf-9c94
# Display detailed information about the BSS with ID 001c-f08f-f804.
<Sysname> display wlan bss bssid 001c-f08f-f804 verbose
AP name                       : ap1
BSSID                         : 001c-f08f-f804
Radio ID                      : 1
Service template name         : servcie1
SSID                          : SSID1
VLAN ID                       : 1
AKM mode                      : Not configured
User authentication mode      : Bypass
AKM mode
AKM mode:
·     802.1X.
·     PSK.
·     Not configured.
User authentication mode:
·     Bypass—No client authentication.
·     MAC.
·     802.1X.
·     OUI.
display wlan client
Use display wlan client to display client information.
display wlan client [ ap ap-name [ radio radio-id ] | mac-address mac-address | service-template service-template-name | frequency-band { 2.4 | 5 } | vlan vlan-id ] [ verbose ]
ap ap-name: Displays information about clients that are connected to the specified AP. The AP name is a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio radio-id: Displays information about clients that are connected to the specified radio. The value range for the radio-id argument varies by device model. If you do not specify this option, the command displays information about all clients that are connected to the specified AP.
mac-address mac-address: Specifies a client by its MAC address.
service-template service-template-name: Displays information about clients that are associated with the specified service template. The service template name is a case-insensitive string of 1 to 63 characters.
frequency-band: Displays information about clients working on the specified band.
2.4: Specifies the 2.4 GHz band.
5: Specifies the 5 GHz band.
vlan vlan-id: Displays information about clients in the specified VLAN. The VLAN ID is in the range of 1 to 4094.
# Display brief information about all clients.
<Sysname> display wlan client
MAC address    Username         AP name       RID   IP address          VLAN
000f-e265-6400 N/A                  ap1                   1 1.1.1.1         100
000f-e265-6401 user                 ap2                   1 3.0.0.3         200
84db-ac14-dd08 N/A                  ap1                   1 5.5.5.3         1
Table 5 Command output
MAC address
Client MAC address.
Username
Client username:
·     The field displays the client username if the client uses 802.1X or MAC authentication.
·     The field displays N/A if the client does not use 802.1X or MAC authentication.
If the client uses portal authentication, this field does not display the portal username of the client.
AP name
Name of the AP that the client is associated with.
R
ID of the radio that the client is associated with.
IP address
IPv4 address of the client.
VLAN ID
ID of the VLAN to which the client belongs.
# Display detailed information about the client with MAC address 000f-e265-6400.
<Sysname> display wlan client mac-address 000f-e265-6400 verbose
Total number of clients: 1
MAC address                        : 000f-e265-6400
IPv4 address                       : 10.1.1.114
IPv6 address                       : 2001::1234:5678:0102:0304
Username                           : N/A
AID                                : 1
AP ID                              : 1
AP name                            : ap1
Radio ID                           : 1
SSID                               : office
BSSID                              : 0026-3e08-1150
VLAN ID                            : 3
Sleep count                        : 3
Wireless mode                      : 802.11gn
Channel bandwidth                  : 20MHz
20/40 BSS Coexistence Management   : Not supported
SM power save                      : Enabled
Short GI for 20MHz                 : Supported
Short GI for 40MHz                 : Supported
Short GI for 80MHz                 : Supported
Short GI for 160/80+80MHz          : Not supported
STBC RX capability                 : Not supported
STBC TX capability                 : Not supported
LDPC RX capability                 : Not supported
SU beamformee capability           : Not supported
MU beamformee capability           : Not supported
Beamformee STS capability          : N/A
Block Ack                          : TID 0 In
Supported VHT-MCS set              : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
                                     NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
Supported HT MCS set               : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15
Supported rates                    : 1, 2, 5.5, 6, 9, 11,
                                     12, 18, 24, 36, 48, 54 Mbps
QoS mode                           : WMM
Listen interval                    : 10
RSSI                               : 62
Rx/Tx rate                         : 130/195 Mpbs
Speed                              : N/A
Authentication method              : Open system
Security mode                      : PRE-RSNA
Cipher suite                       : N/A
WPA3 status                        : Disabled
Authorization ACL ID               : 3001(Not effective)
Authorization user profile         : N/A
Authorization CAR                  :
  Average input rate               : 102400 bps
  Average output rate              : 102400 bps
Roam status                        : N/A
Key derivation                     : SHA1
PMF status                         : Enabled
Forwarding policy name             : Not configured
Online time                        : 0days 0hours 1minutes 13seconds
FT status                          : Inactive
BTM status                         : Disabled
Table 6 Command output
MAC address
Client MAC address.
IPv4 address
Client IPv4 address.
IPv6 address
Client IPv6 address.
Username
Client username:
AID
Association ID.
AP ID
ID of the AP that the client is associated with.
AP name
Radio ID
SSID
SSID with which the client is associated.
VLAN ID
Sleep count
Client sleep times.
Wireless mode
Wireless mode:
·     802.11a.
·     802.11b.
·     802.11g.
·     802.11gn.
·     802.11an.
·     802.11ac.
·     802.11ax.
Channel bandwidth
Channel bandwidth:
·     20 MHz.
·     40 MHz.
·     80 MHz.
·     160 MHz.
Whether the client supports 20/40MHz channel bandwidth coexistence.
SM Power Save
SM Power Save status:
·     Enabled—Only one antenna of a client operates in active state, and others operate in sleep state to save power.
·     Disabled.
Short GI for 20MHz
Whether the client supports short GI when its channel bandwidth is 20 MHz:
·     Supported.
·     Not supported.
Short GI for 40MHz
Whether the client supports short GI when its channel bandwidth is 40 MHz:
·     Supported.
·     Not supported.
Short GI for 80MHz
Whether the client supports short GI when its channel bandwidth is 80 MHz:
·     Supported.
·     Not supported.
Whether the client supports short GI when its channel bandwidth is 160 MHz or 80 + 80 MHz:
·     Supported.
·     Not supported.
STBC Rx Capability
Client STBC receive capability;
·     Not Supported.
·     Supported.
STBC Tx Capability
Client STBC transmission capability:
·     Not Supported.
·     Supported.
LDPC Rx capability
Client LDPC receive capability;
·     Not Supported.
·     Supported.
Client SU beamformee capability:
·     Not Supported.
·     Supported.
Client MU beamformee capability:
·     Not Supported.
·     Supported.
Supported spatial stream quantity if the client is a beamformee receiver, in the range of 0 to 7 (the maximum spatial stream quantity specified by the MIMO mode minus one). This field displays N/A if the client cannot act as a beamformee receiver.
Number of Sounding Dimensions
Supported spatial stream quantity if the client is a beamformee transmitter, in the range of 0 to 7 (the maximum spatial stream quantity specified by the MIMO mode minus one). This field displays N/A if the client cannot act as a beamformee transmitter.
Block Ack
Negotiation result of Block ACK with TID:
·     TID 0 In—Sends Block ACK for inbound traffic.
·     TID 0 Out—Sends Block ACK for outbound traffic.
·     TID 0 Both—Sends Block ACK for both inbound and outbound traffic.
·     N/A—Does not send Block ACK for both inbound and outbound traffic.
VHT-MCS supported by the client.
2.4G 40MHz Channel bandwidth
Client support for 2.4G 40 MHz channel bandwidth:
·     Not Supported.
·     Supported.
5G 40And80MHz  Channel bandwidth
Client support for 5G 40 MHz and 80 MHz channel bandwidth:
·     Not Supported.
·     Supported.
5G 160MHz  Channel bandwidth
Client support for 5G 160 MHz channel bandwidth:
·     Not Supported.
·     Supported.
5G 8080MHz  Channel bandwidth
Client support for 5G 80+80 MHz channel bandwidth:
·     Not Supported.
·     Supported.
OFDMA random access RUs
Support for OFDMA random selection of RUs.
·     Not Supported.
·     Supported.
Supported HE80MHz-MCS set
Supported 80 MHz HE-MCS sets.
Supported HE160MHz-MCS set
Supported 160 MHz HE-MCS sets.
Supported HE 8080MHz-MCS set
Supported 80+80 MHz HE-MCS sets.
QoS mode
QoS mode:
·     N/A—WMM is not supported.
·     WMM—WMM is supported.
WMM information negotiation is carried out between an AP and a client that both support WMM.
Listen interval
Interval at which the client wakes up to listen for beacon frames. It is counted by beacon interval.
RSSI
Received signal strength indication. This value indicates the client signal strength detected by the AP.
Rx/Tx rate
Sending and receiving rates of data, management, and control frames.
Speed
Sending and receiving rates in the past 2 minutes in Kbps, rounded to three decimal places.
This field displays N/A if both the sending and receiving rates are 0.
Authentication method:
·     Open system.
·     Shared key.
·     SAE.
Security mode
Security mode:
·     RSN—Beacons and probe responses carry RSN IE.
·     WPA—Beacons and probe responses carry WPA IE.
·     PRE-RSNA—Beacons and probe responses do not carry RSN IE or WPA IE.
AKM mode
AKM mode:
·     802.1X.
·     PSK.
·     OWE.
·     Not configured.
Cipher suite
Cipher suite:
·     N/A.
·     WEP40.
·     WEP104.
·     WEP128.
·     CCMP.
·     TKIP.
·     GCMP.
·     MAC.
·     802.1X.
·     OUI.
WPA3 status
WPA3 status:
·     Disabled.
·     Enabled.
·     N/A.
Authorized ACL number:
·     This field displays the ACL number if the authorized ACL takes effect.
·     This field displays ACL number(Not effective) if the authorized ACL does not take effect.
·     This field displays N/A if the authentication server is configured without any authorized ACL.
Name of the authorized user profile:
·     This field displays the authorized user profile name if the authorized user profile takes effect.
·     This field displays authorized user profile name + Not effective if the authorized user profile does not take effect.
·     This field displays N/A if the authentication server is configured without any authorized user profile.
Authorization CAR
Authorization CAR:
·     Average input rate—Average uplink rate in bps.
·     Average output rate—Average downlink rate in bps.
·     N/A—This field displays N/A if the authentication server is not configured with authorization CAR for users.
Roam status
Roam status:
·     Roaming in progress.
·     Inter-AC roam.
·     Inter-MA roam.
·     Intra-AC roam.
·     Intra-MA roam.
·     This field displays N/A if the client stays in one BSS after coming online.
Key derivation
Key derivation type:
·     SHA1—Uses the HMAC-SHA1 hash algorithm.
·     SHA256—Uses the HMAC-SHA256 hash algorithm.
·     SHA384—Uses the HMAC-SHA384 hash algorithm.
·     N/A—No key derivation algorithm is involved for the authentication type.
PMF status
PMF status:
·     Enabled—Management frame protection is enabled.
·     Disabled—Management frame protection is disabled.
·     N/A—Management frame protection is not involved.
WLAN forwarding policy name:
·     Not configured.
·     Policy-name.
Online time
Client online duration.
FT status
Fast BSS transition (FT) status:
·     Active—FT is enabled.
·     Inactive—FT is disabled.
BTM status
BSS transition management (BTM) status:
·     Disabled.
·     Enabled.
Use display wlan client ipv6 to display information about client IPv6 addresses.
# Display brief status information about the specified client.
<Sysname> display wlan client ipv6
MAC address    AP name               IPv6 address                            VLAN
84db-ac14-dd08 ap1                   1::2:0:0:3                              300
Table 7 Command output
MAC address
Client MAC address.
IPv6 address
Use display wlan client online-duration to display client online duration.
display wlan client online-duration [ ap ap-name ] [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief information about client online duration.
<Sysname> display wlan client online-duration
Total number of online clients: 2
MAC address            IPv4 address    Online duration
a4c1-5b79-fa5b-1d62    192.168.11.123  0days 0hours 2minutes 23seconds
22d3-c5b7-a4b5-96fa    192.168.11.234  0days 0hours 5minutes 34seconds
Table 8 Command output
MAC address
Client MAC address.
IPv4 address
Online duration
Use display wlan client status to display client status information.
display wlan client status [ mac-address mac-address ] [ verbose ]
mac-address mac-address: Specifies a client by its MAC address in the format of H-H-H. If you do not specify this option, the command displays status information about all clients.
verbose: Displays detailed client status information. If you do not specify this keyword, the command displays brief client status information.
<Sysname> display wlan client status mac-address 001c-f08f-f804
MAC address     RSSI  Rx/Tx rate    Speed(bps)   Discard  AP name          RID
001c-f08f-f804  0     39M/117M      N/A          0.00     ap2              2
# Display brief status information about all clients.
Total number of clients: 2
000b-c002-9d09   65    39M/117M      N/A          0.00%    ap2              2
000f-e265-6401   62    130M/195M     N/A          0.00%    ap1              1
Table 9 Command output
MAC address
Client MAC address.
RSSI
RSSI of the client.
Rx/Tx rate
Rates at which the client receives and sends data, management packets, and control packets.
Speed(bps)
Rates at which the client receives and sends packets in the past 2 minutes, rounded to one decimal place.
If a rate is smaller than 1 Mbps, the value is displayed in Kbps. If a rate equals 1 Mbps or is larger than 1 Mbps, the value is displayed in Mbps. If a rate equals 1 Gbps or is larger than 1 Gbps, the value is displayed in Gbps.
Discard
Ratio of packets discarded by the client.
AP name
Name of the AP with which the client is associated.
RID
ID of the radio with which the client is associated.
# Display detailed status information about the specified client.
<Sysname> display wlan client status mac-address 001c-f08f-f804 verbose
MAC address                       : 001c-f08f-f804
AP name                           : ap2
Radio ID                          : 2
RSSI                              : 0
Rx/Tx rate                        : 39/117 Mbps
Received:
 Retransmitted packets            : 84
 Retransmitted packet ratio       : 64.12 %
Sent:
 Retransmitted packets            : 0
 Retransmitted packet ratio       : 0.00 %
Discarded:
 Discarded packets                : 0
 Discarded packet ratio           : 0.00 %
Table 10 Command output
MAC address
Client MAC address.
AP name
Radio ID
RSSI
RSSI of the client.
Rx/Tx rate
Received
Received packet statistics:
·     Retransmitted packets.
·     Retransmitted packet ratio.
Sent
Sent packet statistics:
Discarded
Discarded packet statistics:
·     Discarded packets.
·     Discarded packet ratio.
Use display wlan forwarding-policy to display WLAN forwarding policy information.
display wlan forwarding-policy [ policy-name ]
Parameter
policy-name: Specifies a WLAN forwarding policy by its name, a case-insensitive string of 1 to 31 characters. If you do not specify this argument, the command displays information about all WLAN forwarding policies.
# Display information about all WLAN forwarding policies.
<Sysname> display wlan forwarding-policy
Total number of forwarding policies: 2
Forwarding policy name: fwd1
 Classifier ACL 2000: Local
 Classifier ACL 2004: Local
 Classifier IPv6 ACL 2001: Remote
 Classifier IPv6 ACL 2002: Remote
Forwarding policy name: fwd2
 Classifier ACL 4021: Local
 Classifier IPv6 ACL 2000: Remote
 Classifier IPv6 ACL 3024: Remote
Table 11 Command output
Classifier ACL number
IPv4 packet forwarding mode:
·     Local—Local forwarding.
·     Remote—Centralized forwarding.
Classifier IPv6 ACL number
IPv6 packet forwarding mode:
Use display wlan service-template to display service template information.
display wlan service-template [ service-template-name ] [ verbose ]
service-template-name: Specifies a service template by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command displays information about all service templates.
verbose: Displays detailed service template information.
# Display brief information about all service templates.
[Sysname] display wlan service-template
Total number of service templates: 2
Service template name           SSID                                    Status
1                               2333                                    Enabled
2                               3222                                    Enabled
# Display detailed information about all service templates.
<Sysname> display wlan service-template verbose
Service template name                            : service1
Description                                      : Not configured
SSID                                             : wuxianfuwu
SSID-hide                                        : Disabled
User-isolation                                   : Disabled
Service template status                          : Disabled
Maximum clients per BSS                          : 64
Frame format                                     : Dot3
Seamless roam status                             : Disabled
Seamless roam RSSI threshold                     : 50
Seamless roam RSSI gap                           : 20
VLAN ID                                          : 1
AKM mode                                         : PSK
Security IE                                      : RSN
Cipher suite                                     : CCMP
WEP key ID                                       : 1
TKIP countermeasure time                         : 100 sec
PTK lifetime                                     : 43200 sec
PTK rekey                                        : Enabled
GTK rekey                                        : Enabled
GTK rekey method                                 : Time-based
GTK rekey time                                   : 86400 sec
GTK rekey client-offline                         : Enabled
PPSK                                             : Disabled
PPSK Fail Permit                                 : Disabled
Enhance-open status                              : Enabled
Enhanced-open transition-mode service-template   : N/A
Intrusion protection                             : Disabled
Intrusion protection mode                        : Temporary-block
Temporary block time                             : 180 sec
Temporary service stop time                      : 20 sec
Fail VLAN ID                                     : 1
802.1X handshake                                 : Enabled
802.1X handshake secure                          : Disabled
802.1X domain                                    : my-domain
MAC-auth domain                                  : Not configured
Max 802.1X users per BSS                         : 4096
Max MAC-auth users per BSS                       : 4096
802.1X re-authenticate                           : Enabled
Authorization fail mode                          : Online
Accounting fail mode                             : Online
Authorization                                    : Permitted
PMF status                                       : Optional
Hotspot policy number                            : Not configured
Forwarding policy status                         : Disabled
Forwarder                                        : AP
FT status                                        : Disabled
QoS trust                                        : Port
QoS priority                                     : 0
Table 12 Command output
SSID
SSID of the service template.
SSID-hide
Whether the SSID is hidden in beacons:
·     Disabled.
·     Enabled.
User-isolation
Use isolation:
·     Disabled.
·     Enabled.
Service template status:
·     Disabled.
·     Enabled.
Maximum number of clients that the BSS supports.
Frame format
Client data frame encapsulation format:
·     Dot3—802.3 format.
·     Dot11—802.11 format.
Seamless roaming status:
·     Disabled.
·     Enabled.
Seamless roaming RSSI threshold.
Seamless roaming RSSI gap.
VLAN ID
ID of the VLAN to which clients belong after they come online through the service template.
AKM mode
AKM mode:
·     802.1X.
·     PSK.
Security IE
Security IE:
·     RSN.
·     WPA.
Cipher suite
Cipher suite:
·     WEP40.
·     WEP104.
·     WEP128.
·     TKIP.
·     CCMP.
·     GCMP.
TKIP countermeasure time. The value 0 indicates no countermeasures are taken.
PTK rekey
PTK rekey status:
·     Enabled.
·     Disabled.
GTK rekey
GTK rekey status:
·     Enabled.
·     Disabled.
GTK rekey method
GTK rekey method:
·     Time-based.
·     Packet-based.
GTK rekey time
GTK rekey interval.
GTK rekey packets
Number of packets that can be transmitted before the GTK is refreshed.
Client-off GTK rekey status:
·     Enabled.
·     Disabled.
WPA3 status
WPA3 security mode:
·     Disabled.
·     Mandatory.
·     Optional.
PPSK
PPSK status:
·     Disabled.
·     Enabled.
PPSK Fail Permit
PPSK fail-permit status:
·     Disabled.
·     Enabled.
Enhance-open status
Enhanced open system authentication status:
·     Disabled.
·     Enabled.
Recommended service template in transition mode.
This field displays N/A if no recommended service template is specified in transition mode.
Authentication mode:
·     Bypass—No authentication.
·     MAC.
·     MAC-or-802.1X—MAC authentication is performed first. If MAC authentication fails, 802.1X authentication is performed.
·     802.1X.
·     802.1X-or-MAC—802.1X authentication is performed first. If 802.1X authentication fails, MAC authentication is performed.
·     OUI-or-802.1X—OUI authentication is performed first. If OUI authentication fails, 802.1X authentication is performed.
·     MAC-and-802.1X—MAC authentication is performed first. If MAC authentication succeeds, 802.1X authentication is performed.
Intrusion protection status:
·     Enabled.
·     Disabled.
Intrusion protection mode:
·     Temporary-block—Temporarily adds intruders to the block list.
·     Service-stop—Stops all services provided by the BSS that receives illegal packets until it resets.
·     Temporary-service-stop—Temporarily stops the access service provided by the BSS that receives illegal packets.
Temporary block time in seconds.
Temporary service stop time in seconds.
Fail VLAN ID
ID of the VLAN to which clients are added if they cannot pass the authentication when the authentication server can be reached. This field displays Not configured if the fail VLAN ID is not configured.
Critical VLAN ID
ID of the VLAN to which clients are added if they cannot pass the authentication because the authentication server cannot be reached. This field displays Not configured if the critical VLAN ID is not configured.
802.1X handshake
802.1X handshake status:
·     Enabled.
·     Disabled.
Secure 802.1X handshake status:
·     Enabled.
·     Disabled.
802.1X domain
802.1X authentication domain. This field displays Not configured if the domain is not configured.
MAC-auth domain
MAC authentication domain. This field displays Not configured if the domain is not configured.
Maximum number of supported 802.1X users in a BSS.
Maximum number of supported users that pass the MAC authentication in a BSS.
802.1X reauthentication status:
·     Enabled.
·     Disabled.
Authorization fail mode:
·     Offline—Clients are logged off when authorization fails.
·     Online—Clients are not logged off when authorization fails.
Accounting fail mode:
·     Offline—Clients are logged off when accounting fails.
·     Online—Clients are not logged off when accounting fails.
Authorization
Authorization information:
·     Permitted—Applies the authorization information issued by the RADIUS server or the local device.
·     Ignored—Ignores the authorization information issued by the RADIUS server or the local device.
Key derivation
·     SHA1-AND-SHA256—Uses the HMAC SHA1 and SHA256 hash algorithm.
PMF status
PMF status:
·     Optional—Management frame protection in optional mode is enabled.
·     Mandatory—Management frame protection in mandatory mode is enabled.
Hotspot 2.0 policy number.
WLAN forwarding policy status:
·     Disabled.
·     Enabled.
Forward policy name
·     Not configured—No WLAN forwarding policy is configured.
·     policy-name.
Forwarder
Client traffic forwarder:
·     AC—AC in a non-AC hierarchical network and local AC in an AC hierarchical network.
·     AP.
·     Central AC.
FT status
FT status:
·     Disabled.
·     Enabled.
FT method
FT method:
·     over-the-air.
·     over-the-ds.
FT reassociation deadline
FT reassociation timeout timer in seconds.
QoS trust
QoS priority trust mode:
·     Port—Port priority trust mode.
·     Dot11e—802.11e priority trust mode.
QoS priority
Port priority in the range of 0 to 7.
BTM status
BSS Transition Management (BTM) status:
·     Disabled.
·     Enabled.
Use display wlan statistics client to display client statistics.
display wlan statistics client [ mac-address mac-address ]
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays statistics for all clients.
# Display statistics for all clients.
<Sysname> display wlan statistics client
MAC address                : 0014-6c8a-43ff
AP name                    : ap1
Radio ID                   : 1
SSID                       : office
BSSID                      : 000f-e2ff-7700
RSSI                       : 31
Sent frames:
  Back ground              : 0/0 (frames/bytes)
  Best effort              : 9/1230 (frames/bytes)
  Video                    : 0/0 (frames/bytes)
  Voice                    : 2/76 (frames/bytes)
Received frames:
  Best effort              : 18/2437 (frames/bytes)
  Voice                    : 7/468 (frames/bytes)
Discarded frames:
  Best effort              : 0/0 (frames/bytes)
  Voice                    : 5/389 (frames/bytes)
Table 13 Command output
SSID
MAC address
Client MAC address.
Back ground
AC-BK queue.
Best effort
AC-BE queue.
Video
AC-VI queue.
Voice
AC-VO queue.
Use display wlan statistics connect-history to display client connection history.
display wlan statistics connect-history { ap { all | name ap-name } | service-template service-template-name }
ap: Specifies APs.
all: Specifies all APs.
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
service-template service-template-name: Specifies a service template by its name.
# Display the connection history for service template 1.
<Sysname> display wlan statistics connect-history service-template 1
AP name                     : ap1
Radio ID                    : 1
Associations                : 132
Association failures        : 3
Reassociations              : 30
Rejections                  : 12
Abnormal disassociations    : 2
Current associations        : 57
# Display the connection history for AP ap1.
<Sysname> display wlan statistics connect-history ap name ap1
AP name                       : ap1
Associations                  : 1
Reassociations                : 0
Failures                      : 0
Rejections                    : 0
Abnormal disassociations      : 0
Current associations          : 1
Use display wlan statistics service-template to display service template statistics.
display wlan statistics service-template service-template-name
# Display statistics for service template 1.
<Sysname> display wlan statistics service-template 1
AP name                       : ap1
Radio ID                      : 1
Received:
  Frame count                 : 1713
  Frame bytes                 : 487061
  Data frame count            : 1683
  Data frame bytes            : 485761
  Association request count   : 2
Sent:
  Frame count                 : 62113
  Frame bytes                 : 25142076
  Data frame count            : 55978
  Data frame bytes            : 22626600
  Association response count  : 2
Use display wlan statistics vip-client to display VIP client statistics that an AP reports to the AC.
display wlan statistics vip-client [ mac-address mac-address ] [ history-record ]
history-record: Displays the history records for the VIP client. If you do not specify this keyword, the most recent statistics about the VIP client are displayed.
A maximum of 300 history records can be displayed for a VIP client.
# Display VIP client statistics that an AP reports to the AC.
<Sysname> display wlan statistics vip-client mac-address 1234-4321-1234
Total number of configured VIP clients: 1
Total number of online VIP clients: 1
MAC address                     : 1234-4321-1234
Data reporting time             : 2018-8-15 12:20:15
AP name                         : ap1
Radio ID                        : 1
SSID                            : val-problem
Rx/Tx rate                      : 114.2/120.2 Mbps
Rx/Tx traffic                   : 16584/901021 Bytes
RSSI                            : 33
Clients on radio                : 5
Channel utilization             : 20%
Packet loss rate                : 0.25%
Packet error rate               : 0.01%
Retransmission rate             : 1.29%
Delay                           : 5us
Table 14 Command output
MAC address
MAC address of the VIP client.
Data reporting time
Time at which the AP reported VIP client statistics to the AC.
AP name
Name of the AP associated with the VIP client.
Radio ID
ID of the radio associated with the VIP client.
SSID
SSID associated with the VIP client.
Rx/Tx rate
Rx/Tx rate for packets from the VIP client, including data, management, and control packets.
Rx/Tx traffic
Traffic received and sent by the VIP client within the report interval, in Bytes.
RSSI
RSSI of the VIP client.
Clients on radio
Number of clients associated with the radio.
Delay
AP-to-VIP client packet sending delay in microseconds.
client-mac
Use display wlan whitelist to display whitelist entries.
# Display whitelist entries.
<Sysname> display wlan whitelist
 MAC addresses:
  000e-35b2-000e
  0019-5b8e-b709
  001c-f0bf-9c92
Use inherit exclude service-template to configure an AP to not inherit the specified service template from the AP group to which it belongs.
Use undo inherit exclude service-template to restore the default.
inherit exclude service-template service-template-name
undo inherit exclude service-template service-template-name
An AP inherits the service template bound to an AP group.
Radio view
# Configure AP ap1 to not inherit service template st from an AP group.
[Sysname-ap-ap1] radio 1
[Sysname-ap-ap1-radio-1] inherit exclude service-template st
nas-id
Use nas-id to set the network access server identifier (NAS ID).
nas-id nas-id
undo nas-id
In AP view, an AP uses the configuration in AP group view. If no configuration exists in AP group view, the AP uses the configuration in global configuration view.
In AP group view, an AP uses the configuration in global configuration view.
In global configuration view, no NAS ID is specified.
AP view
AP group view
Global configuration view
nas-id: Specifies a NAS ID, a case-sensitive string of 1 to 63 characters.
After coming online, a client sends a RADIUS request that carries the NAS ID to the RADIUS server to indicate its network access server.
The priorities for the configuration in AP view, AP group view, and global configuration view are in descending order. You can also set the NAS ID when binding a service template to a radio. If you have specified a NAS ID when binding a service template to a radio, the AP uses the NAS ID specified for the service template.
# Set the NAS ID to abc123 for AP ap1.
[Sysname] wlan ap ap1 model WA4320i-AGN
[Sysname-wlan-ap-ap1] nas-id abc123
# Set the NAS ID to abc123 for AP group group1.
[Sysname-wlan-ap-group-group1] nas-id abc123
# Set the global NAS ID to abc123.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] nas-id abc123
nas-port-id
Use nas-port-id to set the network access server port identifier (NAS port ID).
Use the undo nas-port-id to restore the default.
nas-port-id nas-port-id
undo nas-port-id
In AP view, an AP uses the configuration in AP group view. If no NAS ID is specified in AP group view, the AP uses the configuration in global configuration view.
In global configuration view, no NAS port ID is specified.
AP view
AP group view
nas-port-id: Specifies a NAS port ID, a case-sensitive string of 1 to 63 characters.
After coming online, a client sends a RADIUS request that carries the NAS port ID to the RADIUS server to indicate its network access server.
The priorities for the configuration in AP view, AP group view, and global configuration view are in descending order. You can also set the NAS port ID when binding a service template to a radio. If you have specified a NAS port ID when binding a service template to a radio, the AP uses the NAS port ID specified for the service template.
# Set the NAS port ID to abcd1234 for AP ap1.
[Sysname-wlan-ap-ap1] nas-port-id abcd1234
# Set the NAS port ID to abcd1234 for AP group group1.
[Sysname-wlan-ap-group-group1] nas-port-id abcd1234
# Set the global NAS port ID to abcd1234.
[Sysname-wlan-global-configuration] nas-port-id abcd1234
nas-port-type
Use nas-port-type to set the NAS port type attribute in RADIUS requests.
Use the undo nas-port-type to restore the default.
nas-port-type value
undo nas-port-type
The NAS port type is Wireless-IEEE 802.11.
value: Specifies a NAS port type by its code value in the range of 0 to 255. Table 15 lists the most commonly used NAS port types and their code values.
Table 15 Common NAS port types and their code values
NAS port type
Code value
Async
0
Sync
1
ISDN Sync
2
ISDN Async V.120
3
ISDN Async V.110
4
Virtual
5
PIAFS
6
HDLC Clear Channel
7
X.25
8
X.75
9
G.3 Fax
10
SDSL
11
ADSL-CAP
12
ADSL-DMT
13
IDSL
14
Ethernet
15
xDSL
16
Cable
17
Wireless-Other
18
19
You can execute this command to set the NAS port type attribute in RADIUS requests for 802.11X and MAC-authenticated clients.
# Set the NAS port type in RADIUS requests to 15 (Ethernet).
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] nas-port-type 15
nas-vlan
Use nas-vlan to set the network access server VLAN identifier (NAS VLAN ID) and enable the AC to encapsulate the VLAN ID in RADIUS requests.
Use undo nas-vlan to restore the default.
nas-vlan vlan-id
undo nas-vlan
No NAS VLAN ID is set. Authentication requests sent to the RADIUS server do not contain the NAS VLAN ID field.
AP view
vlan-id: Specifies a NAS VLAN ID in the range of 1 to 4096.
When the NAS VLAN ID is set, the AC encapsulates the VLAN ID in RADIUS requests sent to the RADIUS server to indicate clients' network access server.
Set the NAS VLAN ID when a third-party Security Accounting Management (SAM) server is used as the RADIUS server.
# Set the NAS VLAN ID to 1234 for the AP ap1.
[Sysname-wlan-ap-ap1] nas-vlan 1234
non-vip limit rate
Use non-vip limit rate to configure non-VIP client rate limit.
Use undo non-vip limit rate to remove the configuration.
non-vip limit rate { inbound | outbound } [ mode { dynamic [ min min-cir ] [ max max-cir ] | static } ] cir cir
undo non-vip limit rate { inbound | outbound } cir
Non-VIP client rate limit is not configured.
inbound: Limits the rate of incoming traffic.
outbound: Limits the rate of outgoing traffic.
dynamic: Specifies the dynamic rate limit mode. In this mode, the limited rate for each client is the total CIR divided by the number of clients.
min min-cir: Specifies the minimum CIR for a client, in the range of 16 to 1700000 kbps.
max max-cir: Specifies the maximum CIR for a client, in the range of 16 to 1700000 kbps. The maximum CIR must be larger than the minimum CIR.
static: Specifies the static rate limit mode. In this mode, the limited rate for each client is a fixed value.
cir cir: Specifies the CIR in Kbps. The value range for the cir argument is 16 to 1700000.
With non-VIP client rate limit configured, all non-VIP clients associated with a radio are rate limited when the radio has associated VIP clients. When all VIP clients associated with the radio go offline or if the radio does not have associated VIP clients, non-VIP clients are not rate limited.
If dynamic rate limit is configured, the limited rate for a client is the total limited rate divided by the number of clients. If the value is smaller than the minimum CIR, the minimum CIR takes effect. If the value is larger than the maximum CIR, the maximum CIR takes effect.
If both radio-based client rate limit and non-VIP client rate limit are configured, VIP clients are not rate limited and rate limit takes effect for non-VIP clients as follows:
·     If the configured rate limit modes are different, the non-VIP rate limit configuration takes effect.
·     If the configured rate limit modes are the same:
¡     In static mode, the rate of the non-VIP clients takes the smaller value.
¡     In dynamic mode, the non-VIP rate limit configuration takes effect.
You can rate limit both inbound and outbound traffic.
# Configure non-VIP client rate limit in VIP client group view: enable static rate limit and set the CIR to 500 Kbps for incoming traffic, and enable dynamic rate limit and set the CIR to 100 Kbps for outgoing traffic.
[Sysname-wlan vip-client-group] non-vip limit rate inbound mode static cir 500
[Sysname-wlan vip-client-group] non-vip limit rate outbound mode dynamic cir 100
client-rate-limit (radio view/AP group radio view)
quick-association enable
Use quick-association to enable quick association.
Use undo quick-association to disable quick association.
undo quick-association enable
Quick association is disabled.
Service template view
This command disables APs from performing load balancing or band navigation on clients associated with the specified service template.
# Enable quick association for service template service1.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1]quick-association enable
report-interval
Use report-interval to set the interval at which an AP reports VIP client statistics to the AC.
Use undo report-interval to restore the default.
report-interval interval
An AP reports VIP client statistics to the AC at intervals of 50 seconds.
interval: Specifies the interval at which an AP reports VIP client statistics to the AC, in the range of 10 to 120 seconds.
The AC sends VIP client statistics to the Oasis platform every five minutes.
# Set the interval at which an AP reports VIP client statistics to the AC to 36 seconds.
[Sysname-wlan vip-client-group] report-interval 36
reset wlan client
Use reset wlan client to log off a client or all clients.
reset wlan client { all | mac-address mac-address }
View
all: Specifies all clients.
# Log off all clients.
<Sysname> reset wlan client all
display wlan client
reset wlan dynamic-blacklist
Use reset wlan dynamic-blacklist to remove the specified client or all clients from the dynamic blacklist.
reset wlan dynamic-blacklist [ mac-address mac-address ]
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command removes all clients from the dynamic blacklist.
# Remove all clients from the dynamic blacklist.
<Sysname> reset wlan dynamic-blacklist
# Remove the specified client from the dynamic blacklist.
<Sysname> reset wlan dynamic-blacklist mac-address b8ca-32a2-df69
reset wlan statistics client
Use reset wlan statistics client to clear client statistics.
reset wlan statistics client { all | mac-address mac-address }
View
# Clear statistics about all clients.
<Sysname> reset wlan statistics client all
reset wlan statistics service-template
Use reset wlan statistics service-template to clear service template statistics.
reset wlan statistics service-template service-template-name
View
# Clear statistics about service template service1.
<Sysname> reset wlan statistics service-template service1
roam-enhance
Use roam-enhance to enable roaming enhancement.
Use undo roam-enhance to disable roaming enhancement.
roam-enhance ssid ssid
undo roam-enhance
In radio view, the configuration in an AP group's radio view is used.
In an AP group's radio view, roaming enhancement is disabled.
Radio view
ssid: Specifies an SSID for roaming enhancement, a case-sensitive string of 1 to 32 characters.
You can enable this feature only on the 2.4G radio. If you perform this task multiple times, the most recent configuration takes effect.
Bind the 5G radio to a minimum of one service template that uses the SSID specified for roaming enhancement for the 2.4G radio.
You can bind a maximum of five service templates using the specified SSID to the 5G radio.
To avoid packet loss, do not configure the 5G radio as a scanning radio.
The 5G radio cannot operate in a radar channel. As a best practice, manually specify a non-radar channel, enable auto channel selection, or configure the channel scanning whitelist or blacklist for the 5G radio.
# Enable roaming enhancement for AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] radio 2
[Sysname-wlan-ap-ap1-radio-2] roam-enhance ssid agv
# Enable roaming enhancement for APs in AP group group1.
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN] radio 2
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-2] roam-enhance ssid agv
service-template
Use service-template to bind a service template to a radio.
Use undo service-template to unbind a service template from a radio.
service-template service-template-name [ vlan vlan-id1 | vlan-group vlan-group-name ] [ ssid-hide ] [ nas-port-id nas-port-id ] [ nas-id nas-id ]
undo service-template service-template-name
In radio view, an AP uses the configuration in AP group view.
In an AP group's radio view, no service template is bound to a radio.
Radio view
vlan vlan-id1: Specifies a VLAN ID in the range of 1 to 4094.
vlan-group vlan-group-name: Specifies a VLAN group name, a case-insensitive string of 1 to 31 characters. If you do not specify this option, the radio uses the VLAN configured for the service template. For more information about configuring VLAN groups, see VLAN commands in Network Connectivity Command Reference.
ssid-hide: Hides SSIDs in beacon frames.
nas-port-id nas-port-id: Specifies a NAS port ID, a case-insensitive string of 1 to 63 characters that do not contain spaces.
nas-id nas-id: Specifies a NAS ID, a case-insensitive string of 1 to 63 characters that do not contain spaces.
Before you bind a service template to a radio or a radio interface, you must create the service template.
If you specify a non-existent VLAN, the AC creates the VLAN when a client comes online.
The VLAN ID or VLAN group configured using this command takes precedence over the VLAN ID configured for a service template.
The configuration in radio view takes precedence over the configuration in an AP group's radio view.
# Bind service template service1 to radio 1 and specify VLAN group vg1 for the radio.
[Sysname-ap-ap1-radio-1] service-template service1 vlan-group vg1
# Bind service template service1 to radio 1 and specify VLAN group vg1 for the radios in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] service-template service1 vlan-group vg1
service-template enable
Use service-template enable to enable a service template.
Use undo service-template enable to disable a service template.
A service template is disabled.
If the number of BSSs on a device exceeds the limit, you cannot enable a new service template.
# Enable service template service1.
[Sysname-wlan-st-service1] service-template enable
snmp-agent trap enable wlan client
Use snmp-agent trap enable wlan client to enable SNMP notification for client access.
Use undo snmp-agent trap enable wlan client to disable SNMP notification for client access.
SNMP notification is disabled for client access.
When this feature is enabled, the device sends a client status change notification to an NMS every time the status of a client changes. For the notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notification for client access.
[Sysname] snmp-agent trap enable wlan client
snmp-agent trap enable wlan client-audit
Use snmp-agent trap enable wlan client-audit to enable SNMP notification for client audit.
Use undo snmp-agent trap enable wlan client-audit to disable SNMP notification for client audit.
SNMP notification is disabled for client audit.
When this feature is enabled, the device sends a client status change notification to an NMS when a client comes online, goes offline, roams to another AP, or obtains an IP address. For the notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notification for client audit.
[Sysname] snmp-agent trap enable wlan client-audit
ssid
Use ssid to set an SSID for a service template.
Use undo ssid to restore the default.
ssid ssid-name
undo ssid
No SSID is configured for a service template.
ssid-name: Specifies an SSID name, a case-sensitive string of 1 to 32 characters.
Disable the service template before you execute this command.
# Set the SSID to lynn for service template service1.
[Sysname-wlan-st-service1] ssid lynn
unknown-client
Use unknown-client to set the way that an AP processes traffic from unknown clients.
Use undo unknown-client to restore the default.
unknown-client { deauthenticate | drop }
undo unknown-client
An AP drops packets from unknown clients and deauthenticates these clients.
deauthenticate: Drops packets from unknown clients and deauthenticates these clients.
drop: Drops packets from unknown clients.
# Configure APs that use service template example to drop packets from unknown clients but not deauthenticate these clients.
[Sysname] wlan service-template example
[Sysname-wlan-st-example] unknown-client drop
vip limit rate
Use vip limit rate to enable VIP client rate limit.
Use undo vip limit rate to disable VIP client rate limit.
vip limit rate level level { inbound | outbound } mode { dynamic [ min min-cir ] [ max max-cir ] | static } cir cir
undo vip limit rate level level { inbound | outbound }
VIP client rate limit is disabled.
level level: Specifies the VIP client level. Only 2 is available.
min min-cir: Specifies the minimum CIR for each client, in the range of 16 to 1700000 Kbps. If you do not specify this option, the command does not limit the minimum total CIR.
max max-cir: Specifies the maximum CIR for each client, in the range of 16 to 1700000 Kbps. The maximum CIR must be larger than the minimum CIR. If you do not specify this option, the command does not limit the maximum total CIR.
cir cir: Specifies the CIR in Kbps. The value range for the cir argument is 16 to 1700000 Kbps.
If a large number of VIP clients are online, you can perform this task to rate limit VIP clients to guarantee bandwidth for each client and ensure good user experience.
If you specify both the minimum and maximum CIRs for dynamic rate limit, the feature operates as follows:
·     If the specified CIR divided by the total number of clients is smaller than the minimum CIR, the minimum CIR takes effect for each client.
·     If the specified CIR divided by the total number of clients is larger than the maximum CIR, the maximum CIR takes effect for each client.
·     If the specified CIR divided by the total number of clients is between the minimum and maximum CIRs, the specified CIR divided by the total number of clients takes effect for each client.
You can execute this command multiple times to limit the rates of both the incoming and outgoing traffic.
If you configure both VIP client rate limit and radio-based client rate limit, the configuration that takes effect depends on the rate limit modes (static or dynamic):
·     If different rate limit modes are configured, VIP client rate limit takes effect.
·     If the static mode is configured, the smaller CIR takes effect.
·     If the dynamic mode is configured, VIP client rate limit takes effect.
# Configure static VIP client rate limit: set the CIR to 500 Kbps for incoming traffic and set the CIR to 100 Kbps for outgoing traffic.
[Sysname-vip-client-group] vip limit rate level 2 inbound mode static cir 500
[Sysname-vip-client-group] vip limit rate level 2 outbound mode static cir 100
vlan
Use vlan to assign clients coming online through a service template to the specified VLAN.
Use undo vlan to restore the default.
vlan vlan-id
undo vlan
Clients are assigned to VLAN 1 after coming online through a service template.
vlan-id: Specifies a VLAN by its VLAN ID, in the range of 1 to 4094. If the specified VLAN does not exist, this command creates the VLAN when clients come online.
# Assign clients coming online through service template service1 to VLAN 2.
[Sysname-wlan-st-service1] vlan 2
wlan accounting-policy
Use wlan accounting-policy to create an accounting policy and enter its view or enter the view of an existing accounting policy.
Use undo wlan accounting-policy to delete an accounting policy.
wlan accounting-policy policy-name
undo wlan accounting-policy policy-name
No accounting policies exist.
policy-name: Specifies the policy name, a case-insensitive string of 1 to 31 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), and hyphens (-).
For the accounting server to perform differentiated accounting on different client traffic, specify multiple traffic levels for an accounting policy.
# Create accounting policy abc and enter its view.
[Sysname] wlan accounting-policy abc
[Sysname-wlan-acctpolicy-abc]
accounting-level
wlan apply accounting-policy
Use wlan apply accounting-policy to apply an accounting policy to a user profile.
Use undo wlan apply accounting-policy to restore the default.
wlan apply accounting-policy policy-name
No accounting policy is applied to a user profile.
User profile view
This feature enables APs to perform client traffic accounting based on the accounting policy applied to the user profile. Upon client association, the authentication server deploys the user profile bound to the client account to the client authenticator (AC or AP). If the AC is the authenticator, it deploys the user profile to the AP.
If no accounting policy is applied to a user profile, the system performs AAA accounting.
Accounting policy changes, including deletion, for a user profile do not affect online clients.
# Apply accounting policy abc to user profile 123.
[Sysname] user-profile 123
[Sysname-user-profile-123] wlan apply accounting-policy abc
wlan association optimization
Use wlan association optimization to set the index for optimizing client association ratios.
Use undo wlan association optimization to restore the default.
wlan association optimization value
The index is 0. The device does not optimize client association ratios.
value: Specifies the index for optimizing client association ratios, in the range of 900 to 1000. The smaller the index is, the smaller the calculated association success ratio will be and the larger the calculated congestion ratio and abnormal disassociation ratio will be.
This feature enables the device to recalculate the client association success ratio, association congestion ratio, and abnormal disassociation ratio by using the specified index to get smaller ratio values.
The client association success ratio is the number of successful client associations divided by the total number of client association attempts. The client association congestion ratio is the number of failed client associations caused by AP overloading divided by the total number of client association attempts. The client abnormal disassociation ratio is the number of abnormal disassociations divided by the sum of successful associations and online clients.
# Set the index for optimizing client association ratios to 950.
[Sysname] wlan association optimization 950
wlan client bss-load-ie enable
Use wlan client bss-load-ie enable to enable beacon frames and probe responses to carry BSS Load IEs.
Use undo wlan client bss-load-ie enable to disable beacon frames and probe responses from carrying BSS Load IEs.
wlan client bss-load-ie enable [ update-interval interval ]
Beacon frames and probe responses do not carry BSS Load IEs.
update-interval interval: Specifies the BSS Load IE update interval, in the range of 5 to 30 seconds. By default, the interval is 15 seconds.
This feature enables beacon frames and probe responses to carry BSS Load IEs. A BSS Load IE contains information such as associated client quantity, channel usage, and remaining available media time.
As a best practice, enable this feature in Hotspot 2.0 networks or networks where client roaming is required. This helps clients identify the optimal WLAN.
# Enable beacon frames and probe responses to carry BSS Load IEs.
[Sysname] wlan client bss-load-ie enable
wlan client forwarding enable
Use wlan client forwarding enable to enable client traffic forwarding.
Use undo wlan client forwarding enable to disable client traffic forwarding.
Client traffic forwarding is enabled.
You must enable this feature if you configure the AC as the client traffic forwarder.
In an AC hierarchical network, disable this feature on the central AC and enable this feature on local ACs if the client traffic forwarder is the AC. This guarantees central AC's management performance in case a local AC is down.
For more information about AC hierarchy, see WLAN Advanced Features Configuration Guide.
# Disable client traffic forwarding.
[Sysname] undo wlan client forwarding enable
client forwarding-location
wlan client forwarding-policy-name
Use wlan client forwarding-policy-name to apply a forwarding policy to a user profile.
Use undo wlan client forwarding-policy-name to restore the default.
wlan client forwarding-policy-name policy-name
No forwarding policy is applied to a user profile.
User profile view
policy-name: Specifies a forwarding policy name, a case-insensitive string of 1 to 31 characters.
For the AC to perform policy-based forwarding for clients that use a user profile, apply a forwarding policy to the user profile. After a client passes authentication, the authentication server sends the user profile name specified for the client to the AC. The AC will forward traffic of the client based on the forwarding policy applied to the user profile.
For the forwarding policy applied to a user profile to take effect, perform the following tasks for the service template that the user profile uses:
·     Enable policy-based forwarding.
·     Specify the AC to perform client authentication.
If you modify or delete the applied forwarding policy, the change takes effect when the client comes online again.
The AC preferentially uses the forwarding policy applied to a user profile to direct client traffic forwarding. If the user profile of a client does not have a forwarding policy applied, the AC uses the forwarding policy applied to the service template.
Make sure the AC and its associated APs are in different network segments.
# Apply forwarding policy policyname to user profile profilename.
[Sysname] user-profile profilename
[Sysname-user-profile-profilename] wlan client forward-policy-name policyname
client forwarding-policy enable
client-security authentication-location
wlan client reauthentication-period
Use wlan client reauthentication-period to set the idle period before client reauthentication.
Use undo wlan client reauthentication-period to restore the default.
wlan client reauthentication-period [ period-value ]
The idle period is 10 seconds.
period-value: Specifies the idle period in the range of 1 to 3600 seconds.
When URL redirection for WLAN MAC authentication is enabled, an AP redirects clients whose information is not recorded on the RADIUS server to the specified URL for Web authentication. Clients passing Web authentication are logged off and must perform MAC reauthentication to come online. However, MAC reauthentication fails if the IP addresses assigned to the clients have not expired.
Perform this task to add these clients to the dynamic blacklist for the specified idle period after they pass Web authentication to reduce reauthentication failures.
# Set the idle period before client reauthentication to 100 seconds.
[Sysname] wlan client reauthentication-period 100
wlan dynamic-blacklist active-on-ap
Use wlan dynamic-blacklist active-on-ap to configure the dynamic blacklist to take effect on APs.
Use undo wlan dynamic-blacklist active-on-ap to configure the dynamic blacklist to take effect on the AC.
The dynamic blacklist takes effect on APs.
If you configure the dynamic blacklist to take effect on the AC, all APs connected to the AC will reject the client in the dynamic blacklist. If you configure the dynamic blacklist to take effect on APs, the AP associated with the client in the dynamic blacklist will reject the client, but the client can still associate with other APs connected to the AC. As a best practice, configure the dynamic blacklist to take effect on the AC in high-density environments.
# Configure the dynamic blacklist to take effect on the AC.
[Sysname] undo wlan dynamic-blacklist active-on-ap
wlan dynamic-blacklist lifetime
Use wlan dynamic-blacklist lifetime to set the aging time for dynamic blacklist entries.
Use undo wlan dynamic-blacklist lifetime to restore the default.
wlan dynamic-blacklist lifetime lifetime
The aging time is 300 seconds for dynamic blacklist entries.
lifetime: Specifies the aging time in the range of 1 to 3600 seconds.
The configured aging time takes effect only on entries added to the dynamic blacklist after this command is executed.
The aging time for dynamic blacklist entries only applies to rogue client entries.
# Set the aging time for dynamic blacklist entries to 3600 seconds.
[Sysname] wlan dynamic-blacklist lifetime 3600
Use wlan forwarding-policy to create a forwarding policy and enter its view, or enter the view of an existing forwarding policy.
Use undo wlan forwarding-policy to delete a forwarding policy.
wlan forwarding-policy policy-name
undo wlan forwarding-policy policy-name
No forwarding policies are created.
Actions defined in ACL rules do not take effect in wireless packet forwarding. All matched packets are forwarded based on the forwarding mode.
You can create a maximum of 1000 forwarding policies.
# Create forwarding policy abc and enter its view.
[Sysname] wlan forwarding-policy abc
[Sysname-wlan-fp-abc]
wlan imc
Use wlan imc to specify an IMC server by its IP address and port number.
Use undo wlan imc to restore the default.
wlan imc ip ip-address port port-number
undo wlan imc
No IMC server is specified.
ip ip-address: Specifies an IMC server by its IP address.
port port-number: Specifies an IMC server by its port number in the range of 1025 to 65535.
This feature enables the system to report association and disassociation events of APs, clients, and portal users to an IMC server, allowing you to view the statistics from the IMC platform.
# Specify an IMC server.
[Sysname] wlan imc ip 1.1.1.1 port 65535
wlan link-test
Use wlan link-test to test wireless link quality.
wlan link-test mac-address
mac-address: Specifies the client MAC address in the H-H-H format.
Wireless link quality detection enables an AP to test the quality of the link to a wireless client. The AP sends empty data frames to the client at each supported rate. Then it calculates link quality information such as RSSI, packet retransmissions, and RTT based on the responses from the client.
The timeout timer for wireless link quality detection is 10 seconds. If wireless link detection is not completed within the timeout timer, test results cannot be obtained.
# Test the quality of the wireless link to the client with MAC address 60a4-4cda-eff0.
<Sysname> wlan link-test 60a4-4cda-eff0
Testing link to 60a4-4cda-eff0. Press CTRL + C to break.
                              Link Status
MAC address: 60a4-4cda-eff0
VHT-MCS  Rate(Mbps)  Tx packets  Rx packets  RSSI   Retries RTT(ms)
NSS = 1
 0       32.5        5           5           54     0       0
 1       65          5           5           51     0       0
 2       97.5        5           5           49     0       0
 3       130         5           5           47     0       0
 4       195         5           5           45     0       0
 5       260         5           5           45     0       0
 6       292.5       5           5           44     0       0
 7       325         5           5           44     0       0
 8       390         5           5           44     0       0
 9       433.3       5           5           43     0       0
NSS = 2
 0       65          5           5           44     0       0
 1       130         5           5           44     0       0
 2       195         5           5           44     0       0
 3       260         5           5           44     0       0
 4       390         5           5           44     0       0
 5       520         5           5           44     0       0
 6       585         5           5           43     0       0
 7       650         5           5           43     0       0
 8       780         5           5           43     0       0
 9       866.7       5           5           43     0       0
<Sysname> wlan link-test 784f-43b6-077c
Testing link to 784f-43b6-077c. Press CTRL + C to break.
                              Link Status
MAC address: 784f-43b6-077c
0       6.5         5           5           54     0        0
1       13          5           5           51     0        0
2       19.5        5           5           49     0        0
3       26          5           5           47     0        0
4       39          5           5           45     0        0
5       52          5           5           45     0        0
6       58.5        5           5           44     0        0
7       72.2        5           5           44     0        0
8       13          5           5           44     0        0
9       26          5           5           43     0        0
10       39         5           5           44     0        0
11       52         5           5           44     0        0
12       78         5           5           44     0        0
13       104        5           5           44     0        0
14       117        5           5           44     0        0
15       144.4      5           5           44     11       0
Table 16 Command output
No./MCS/VHT-MCS
·     No.—Rate number for link quality test on 802.11a, 802.11b, or 802.11g clients.
·     MCS—MCS index for link quality test on 802.11n clients.
·     VHT-MCS—VHT-MCS index for link quality test on 802.11ac clients.
Rate(Mbps)
Rate at which the AP sends wireless link quality detection frames.
Tx packets
Number of wireless link quality detection frames sent by the AP.
Rx packets
Number of responses received by the AP.
RSSI
RSSI of the client detected by the AP.
Retries
Number of wireless link quality retransmission frames sent by the AP.
RTT(ms)
Round trip time for link quality test frames from the AP to the client.
NSS
Number of spatial streams for link quality test on 802.11n or 802.11ac clients.
wlan nas-port-id format
Use wlan nas-port-id format to set the format of NAS port IDs for wireless clients.
Use undo wlan nas-port-id format to restore the default.
wlan nas-port-id format { 2 | 4 }
Clients use format 2 to generate NAS port IDs.
2: Specifies the SlotID00IfNOVlanID format.
·     SlotID—Slot ID for client access, a string of two characters.
·     IfNO—Interface number for client access, a string of three characters.
·     VlanID—VLAN ID for client access, a string of nine characters.
4: Specifies the slot=**;subslot=**;port=**;vlanid=**;vlanid2=** format. The vlanid2 field is available only for clients accessing the WLAN through an interface configured with VLAN termination.
802.1X and MAC-authenticated clients provide NAS port IDs in the specified format in RADIUS packets.
If a NAS port ID has been specified by using the nas-port-id command, clients use the specified NAS port ID.
# Set the NAS port ID format to format 4.
[Sysname] wlan nas-port-id format 4
nas-port-id
wlan permit-ap-group
Use wlan permit-ap-group to specify a permitted AP group for client association.
Use undo permit-ap-group to delete a permitted AP group.
wlan permit-ap-group ap-group-name
undo wlan permit-ap-group [ ap-group-name ]
No permitted AP group is specified for client association.
User profile view
ap-group-name: Specifies an AP group by its name, a case-insensitive string of 1 to 31 characters.
If no permitted AP group is specified for client association, client access is not restricted.
If you specify a permitted AP group for client association, clients can only associate with APs in the AP group.
The undo form of the command deletes all permitted AP groups if you do not specify the ap-group-name argument.
# Specify AP group group1 as the permitted AP group for client association.
[Sysname] user-profile profile1
[Sysname-user-profile-profile1] wlan permit-ap-group group1
wlan permit-ssid
Use wlan permit-ssid to specify a permitted SSID for client association.
Use undo permit-ssid to delete a permitted SSID.
wlan permit-ssid ssid-name
undo wlan permit-ssid [ ssid-name ]
No permitted SSID is specified for client association.
User profile view
ssid-name: Specifies an SSID by its name, a case-sensitive string of 1 to 32 characters.
If no permitted SSID is specified for client association, client association is not restricted.
If you specify a permitted SSID for client association, clients can only associate with WLANs through the SSID.
The undo form of the command deletes all permitted SSIDs if you do not specify the ssid-name argument.
# Specify SSID ssid1 as the permitted SSID for client access.
[Sysname-user-profile- profile1] wlan permit-ssid ssid1
Use wlan service-template to create a service template and enter its view, or enter the view of an existing service template.
Use undo wlan service-template to delete a service template.
wlan service-template service-template-name
undo wlan service-template service-template-name
No service template exists.
You cannot delete a service template that has been bound to a radio.
# Create service template service1 and enter its view.
wlan static-blacklist mac-address
Use wlan static-blacklist mac-address to add a client to the static blacklist.
Use undo wlan static-blacklist mac-address to remove a client from the static blacklist.
wlan static-blacklist mac-address mac-address
undo wlan static-blacklist [ mac-address mac-address ]
No clients exist in the static blacklist.
If you add an online client to the static blacklist, the command logs off the client.
You cannot add a client to both the whitelist and the static blacklist.
The undo form of the command removes all clients from the static blacklist if you do not specify the mac-address mac-address option.
Do not add multicast or broadcast MAC addresses to the static blacklist.
# Add MAC address 001c-f0bf-9c92 to the static blacklist.
[Sysname] wlan static-blacklist mac-address 001c-f0bf-9c92
display wlan blacklist
Use wlan vip-client-group to create the VIP client group and enter its view or enter the view of the existing VIP client group.
Use undo wlan vip-client-group to delete the VIP client group.
No VIP client group exists.
You can view information about online clients in the VIP client group from the Oasis platform.
# Create the VIP client group.
[Sysname] wlan vip-client-group
wlan web-server api-path
Use wlan web-server api-path to specify the path of the Web server to which client information is reported.
Use undo wlan web-server api-path to restore the default.
wlan web-server api-path path
The path of the Web server is not specified.
path: Specifies a path, a case-sensitive string of 1 to 256 characters.
The Web server accepts client information only when the server's host name, port number, and path are specified.
# Specify the path of the Web server as /wlan/dev-cfg.
[Sysname] wlan web-server api-path /wlan/dev-cfg
wlan web-server host
wlan web-server max-client-entry
Use wlan web-server host to specify the host name and port number of the Web server to which client information is reported.
Use undo wlan web-server host to restore the default.
wlan web-server host host-name port port-number
The host name and port number of the Web server are not specified.
host host-name: Specifies a host name, a case-insensitive string of 3 to 127 characters that can contain letters, digits, hyphens (-), underscores (_), and dots (.).
port port-number: Specifies a port number in the range of 1 to 65534.
Client information changes are reported to the Web server in real time.
# Specify the host name and port number of the Web server as www.abc.com and 668, respectively.
[Sysname] wlan web-server host www.abc.com port 668
Use wlan web-server max-client-entry to set the maximum number of client entries that can be reported at a time.
Use undo wlan web-server max-client-entry to restore the default.
wlan web-server max-client-entry number
A maximum of ten client entries can be reported at a time.
number: Specifies a maximum number of client entries that can be reported at a time, in the range of 1 to 25.
# Set the maximum of client entries that can be reported at a time to 12.
[Sysname] wlan web-server max-client-entry 12
wlan whitelist mac-address
Use wlan whitelist mac-address to add a client to the whitelist.
Use undo wlan whitelist mac-address to remove a client from the whitelist.
wlan whitelist mac-address mac-address
undo wlan whitelist [ mac-address mac-address ]
No clients exist in the whitelist.
When you add the first client to the whitelist, the system asks you whether to disconnect all online clients. Enter Y at the prompt to configure the whitelist.
If you remove an online client from the whitelist, the command logs off the client. If you remove all clients from the whitelist, online clients will not be logged off.
The undo form of the command removes all clients from the whitelist if you do not specify the mac-address mac-address option.
Do not add multicast or broadcast MAC addresses to the whitelist.
# Add MAC address 001c-f0bf-9c92 to the whitelist.
[Sysname] wlan whitelist mac-address 001c-f0bf-9c92
This command will disconnect all clients. Continue? [Y/N]:
