00-About the Configuration Guides
HomeSupportSwitchesS6812 & S6813 SeriesConfigure & DeployConfiguration GuidesH3C S6812 & S6813 Switch Series Configuration Guide-R6615Pxx-6W10000-About the Configuration Guides
Table of Contents
Related Documents
book
book 103.42 MB
About the H3C S6812 & S6813 switch series configuration guides
The configuration guides are applicable to the following switches and software versions:
Hardware
Software versions
H3C S6812 switch series
Release 6615P03 and later
H3C S6813 switch series
The guides describe the software features and their configuration procedures and provide configuration examples to help you apply the software features to different network scenarios.
Configuration guide
Content
Fundamentals Configuration Guide
Describes how to use the command line interface of the switch, log in to and set up the switch, and use the basic management functions. This guide includes:
·     CLI
·     RBAC
·     Login management
·     FTP and TFTP
·     File system management
·     Configuration file management
·     Software upgrade
·     ISSU
·     Device management
·     Tcl
·     Python
·     Automatic configuration
Virtual Technologies Configuration Guide
Describes the Intelligent Resilient Framework (IRF) technology, which provides data center class availability and scalability.
IRF creates a fabric from multiple switches. The switches that form the IRF fabric work in 1:N redundancy and appear as one unit in the network. IRF improves management efficiency and streamlines network topologies. It is suitable for highly reliable enterprise networks and data centers.
Layer 2—LAN Switching Configuration Guide
Covers Layer 2 technologies and features used on a LAN switched network, such as VLAN technology, port isolation, and spanning tree. You can use these features to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN and so on. This guide includes:
·     Ethernet interface
·     Loopback, null, and inloopback interfaces
·     Bulk interface configuration
·     MAC address table and MAC Information
·     Ethernet link aggregation
·     DRNI
·     Port isolation
·     VLAN
·     MVRP
·     QinQ
·     VLAN mapping
·     Loop detection
·     Spanning tree
·     LLDP
·     L2PT
·     PPP
·     Service loopback group
Layer 3—IP Services Configuration Guide
Describes how to configure ARP, IP addressing, IP performance optimization, IP forwarding basics, IPv6 basics, DHCP, DNS, UDP helper, and DHCPv6. This guide includes:
·     ARP
·     IP addressing
·     DHCP
·     DNS
·     mDNS relay
·     IP forwarding basics
·     Fast forwarding
·     Adjacency table
·     IRDP
·     IP performance optimization
·     UDP helper
·     Basic IPv6 settings
·     DHCPv6
·     IPv6 fast forwarding
·     Tunneling
·     GRE
·     HTTP redirect
Layer 3—IP Routing Configuration Guide
Covers the routing technologies for IPv4 and IPv6 networks of different sizes, route filtering. This guide includes:
·     Basic IP routing
·     Static routing
·     RIP
·     OSPF
·     IS-IS
·     BGP
·     Policy-based routing
·     IPv6 static routing
·     RIPng
·     OSPFv3
·     IPv6 policy-based routing
·     Routing policy
IP Multicast Configuration Guide
Covers Layer 2 and Layer 3 multicast protocols. This guide includes:
·     Multicast overview
·     IGMP snooping
·     PIM snooping
·     Multicast VLAN
·     Multicast routing and forwarding
·     IGMP
·     PIM
·     MSDP
·     MLD snooping
·     IPv6 PIM snooping
·     IPv6 multicast VLAN
·     IPv6 multicast routing and forwarding
·     MLD
·     IPv6 PIM
MPLS Configuration Guide
Describes the application scenarios, fundamentals, and configuration of MPLS. This configuration guide includes:
·     SR-MPLS
·     Basic MPLS
·     Static LSP
·     LDP
·     MPLS L3VPN
·     MPLS L2VPN
·     VPLS
·     MPLS OAM
·     MCE
ACL and QoS Configuration Guide
Describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. You can use ACLs to help other function modules (such as QoS and IP routing) classify or filter traffic. This configuration guide includes:
·     ACL
·     QoS
·     Data buffer
·     Time range
·     QCN
Security Configuration Guide
Covers security features. The major security features available on the switch include: identity authentication, secure management, and attack protection. This guide includes:
·     AAA
·     802.1X
·     MAC authentication
·     Portal authentication
·     Web authentication
·     Triple authentication
·     Port security
·     User profile
·     Password control
·     Keychain
·     Public key management
·     PKI
·     IPsec, IKE, and IKEv2
·     SSH
·     SSL
·     Attack detection and prevention
·     TCP attack prevention
·     IP source guard
·     ARP attack protection
·     ND attack defense
·     uRPF
·     SAVI
·     SAVA
·     Crypto engine
·     MFF
·     FIPS
·     802.1X client
·     Microsegmentation configuration
High Availability Configuration Guide
Describes high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This guide includes:
·     Ethernet OAM
·     CFD
·     DLDP
·     RRPP
·     ERPS
·     Smart Link
·     Monitor Link
·     VRRP
·     BFD
·     Track
·     Process placement
Network Management and Monitoring Configuration Guide
Describes features that help you manage and monitor your network, for example, manage system events, and test network connectivity. This guide includes:
·     System maintenance and debugging
·     NQA
·     iNQA
·     NTP
·     PTP
·     Network synchronization
·     SNMP
·     RMON
·     Event MIB
·     NETCONF
·     Ansible
·     Puppet
·     Chef
·     CWMP
·     EAA
·     Process monitoring and maintenance
·     Mirroring
·     sFlow
·     Information center
·     Packet capture
·     VCF fabric
·     eMDI
·     Service quality analysis (SQA)
Telemetry Configuration Guide
Describes the application scenarios, fundamentals, and configuration of gRPC.
OpenFlow Configuration Guide
Describes the application scenarios, fundamentals, and configuration of OpenFlow.
VXLAN Configuration Guide
Describes the application scenarios, fundamentals, and configuration of VXLAN.
EVPN Configuration Guide
Describes the application scenarios, fundamentals, and configuration of EVPN. This guide includes:
·     EVPN overview
·     EVPN VXLAN
·     EVPN VPWS
·     EVPN-DCI
Service Chain Configuration Guide
Describes the application scenarios and fundamentals of service chains.
Acronyms
Lists the significant acronyms in the configuration guides.
  • Become a Partner
  • Partner Resources
