- 00-Preface.htm
- 02-802.1X configuration
- 04-Portal configuration
- 06-Triple authentication configuration
- 08-User profile configuration
- 10-Keychain configuration
- 12-PKI configuration
- 14-SSH configuration
- 16-TCP attack prevention configuration
- 18-ARP attack protection configuration
- 20-SAVI configuration
- 22-Crypto engine configuration
- 24-802.1X client configuration
22-Crypto engine configuration |
Configuring crypto engines
About crypto engines
Crypto engines encrypt and decrypt data for service modules.
The device supports only one software crypto engine, which is a set of software encryption algorithms. The software crypto engine is always enabled.
When a service module requires data encryption/decryption, it sends the desired data to the crypto engine. After the crypto engine completes data encryption/decryption, it sends the data back to the service module.
Display and maintenance commands for crypto engines
Task |
Command |
Display crypto engine information. |
display crypto-engine |
Display crypto engine statistics. |
display crypto-engine statistics [ engine-id engine-id slot slot-number ] |
Clear crypto engine statistics. |
reset crypto-engine statistics [ engine-id engine-id slot slot-number ] |
