00-Preface | 100.97 KB |
Preface
This document describes hardware information and specifications for H3C SR6604 and SR6608 routers. It contains the following sections:
· Chassis views and technical specifications.
· Removable components.
· LEDs.
· Slot arrangement and interface numbering.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
