04-HH3C-DOT11-STATION-MIB | 155.43 KB |
hh3cDot11StationAuthenErrorTrap
hh3cDot11StationAuthorFailTrap
hh3cDot11StationAuthorSuccTrap
hh3cDot11StationDisconnectTrap
About this MIB
Use this MIB to manage client configuration and statistics.
MIB file name
hh3c-dot11-station.mib
Notifications
hh3cDot11StationMICErrorTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.1 |
A client detected a TKIP decryption MIC error. |
Informational |
Warning |
N/A (N/A) |
Off |
Notification triggers
This notification is triggered when a MIC error occurs.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable wlan usersec command.
OFF
CLI: Use the undo snmp-agent trap enable wlan usersec command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.3.1.2.1.1 (hh3cDot11CurrAPID) |
APID |
OCTET STRING |
OCTET STRING , (0..127) |
1.3.6.1.4.1.25506.2.75.3.1.2.1.2 (hh3cDot11CurrRadioID) |
Radio ID |
Integer32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.75.3.2.1.1 (hh3cDot11StationTrapBSSID) |
BSSID |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.1.1.1.12 (hh3cDot11StationSSIDName) |
SSID |
OCTET STRING |
OCTET STRING (0..32) |
1.3.6.1.4.1.25506.2.75.3.2.1.2 (hh3cDot11StationTrapStaMAC) |
Client MAC address. |
MacAddress |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.2 |
Client link authentication failed. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when an error occurs during the authentication negotiation process of 802.11 link establishment by a wireless client.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
APID |
OCTET STRING |
Radio ID |
Integer32 |
BSSID |
MacAddress |
SSID |
OCTET STRING |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.1.1.1.13 (hh3cDot11StationAuthenMode) |
Authentication mode. |
Hh3cDot11AuthenType |
1.3.6.1.4.1.25506.2.75.3.1.1.1.14 (hh3cDot11StationAKMMode) |
Key management mode. |
Hh3cDot11AKMType |
none(1),, psk(2),, dot1x(3),, ext(4) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.3 |
Client authorization failed. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when a client successfully establishes a wireless link but fails access authentication.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.3.1.1.1.3 (hh3cDot11StationUserName) |
Username for the client. |
OCTET STRING |
OCTET STRING, (0..255) |
MAC address of the client. |
MacAddress |
Radio ID |
Integer32 |
SSID |
OCTET STRING |
hh3cDot11StationAuthorFailCause (hh3cDot11StationAuthorFailCause) |
Reasons for client authorization failure. |
Hh3cDot11AuthorFailType |
1.3.6.1.4.1.25506.2.75.3.2.1.6 (hh3cDot11StationFailCauseDesc) |
Fault description for the client. |
OCTET STRING |
APID |
OCTET STRING |
1.3.6.1.4.1.25506.2.75.3.2.1.11 (hh3cDot11StationBSSID) |
BSSID to which the client is connected. |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.2.1.13 (hh3cDot11StationAuthMode) |
Client authentication mode. |
INTEGER |
1.3.6.1.4.1.25506.2.75.3.2.1.16 (hh3cDot11StationTrapAPMacAddress) |
AP's MAC address. |
MacAddress |
Recommended action
hh3cDot11StationAssocFailTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.4 |
Client association failed. |
Informational |
Warning |
N/A (N/A) |
Off |
This notification is triggered when a wireless client fails to establish a connection with an AP.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable wlan client command.
OFF
CLI: Use the undo snmp-agent trap enable wlan client command.
Object
OID (object name) |
Index |
Type |
Value range |
MacAddress |
Radio ID |
Integer32 |
ESS name. |
OCTET STRING |
1.3.6.1.4.1.25506.2.75.3.2.1.4 (hh3cDot11StationAssocFailCause) |
Reasons for client association failure. |
Hh3cDot11AssocFailType |
OCTET STRING |
To uniquely identify each AP, the relationship between hh3cDot11CurrAPID and the AP device will be static. |
OCTET STRING |
AP's MAC address. |
MacAddress |
MacAddress |
Recommended action
hh3cDot11StationDeAssocTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.5 |
A disassociation request was sent to a client. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when a system needs to transmit a disassociation packet to a wireless client.
System impact
N/A
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
OCTET STRING |
MAC address of the client where a MIC error occurred. |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.1.1.1.11 (hh3cDot11StationVlanId) |
VLAN ID associated with the client. |
Integer32 |
Each radio. |
Integer32 |
ESS name. |
OCTET STRING |
1.3.6.1.4.1.25506.2.75.3.2.1.7 (hh3cDot11StationSessionDuration) |
Duration of the client session. |
Unsigned32 |
OCTET STRING |
1.3.6.1.4.1.25506.2.75.3.2.1.10 (hh3cDot11StationAPName) |
Name of the AP to which the client is connected. |
OCTET STRING |
MacAddress |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.6 |
Client authorization succeeded. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when the system determines that the client has successfully connected to the WLAN network and completed link negotiation and access authentication.
System impact
N/A
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
OCTET STRING |
MacAddress |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.3 (hh3cDot11StationSessionStartTime) |
How long the client has been connected to the wireless network. |
DateAndTime |
Each radio. |
Integer32 |
ESS name. |
OCTET STRING |
OCTET STRING |
OCTET STRING |
MacAddress |
Recommended action
hh3cDot11StationRoamingTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.7 |
A client roamed to another AP. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when a client roams from one AP to another.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable wlan mobility command.
OFF
CLI: Use the undo snmp-agent trap enable wlan mobility command.
Object
OID (object name) |
Index |
Type |
Value range |
OCTET STRING |
OCTET STRING |
MacAddress |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.8 (hh3cDot11StationRoamingTime) |
Time when the client roamed to another AP. |
Unsigned32 |
Each radio. |
Integer32 |
ESS name. |
OCTET STRING |
1.3.6.1.4.1.25506.2.75.3.2.1.9 (hh3cDot11StationACIPAddress) |
IP address of the home AC for roaming clients. IP address of the foreign AC for roaming clients. |
IpAddress |
1.3.6.1.4.1.25506.2.75.3.2.1.14 (hh3cDot11StationACIPv6Add) |
IPv6 address of the home AC for roaming clients. IPv6 address of the foreign AC for roaming clients. |
OCTET STRING |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.8 |
A client went offline. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when the system detects that a client is no longer present after the client successfully registers to the system, regardless of how the client left the network.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
OCTET STRING |
MacAddress |
ESS name. |
OCTET STRING |
Unsigned32 |
Integer32 |
OCTET STRING |
Each radio. |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.12 (hh3cDot11StaDisconnectReason) |
Reasons for disconnection between the client and the AP. |
OCTET STRING |
MacAddress |
Recommended action
hh3cDot11UserDisconnectTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.9 |
A user went offline unexpectedly. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when a client times out. Set the idle-time to 60 seconds. For a PC, if it goes offline unexpectedly, it will be forcibly shut down. For a client other than a PC, a disassociation packet will be sent. If no username exists, the packet is empty.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
OCTET STRING |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.2.1.15 (hh3cDot11UserName) |
Username. |
OCTET STRING |
Recommended action
hh3cDot11StationAuditTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.11 |
Client behavior notification. |
Informational |
Warning |
N/A (N/A) |
Off |
This notification is triggered when a client comes online, goes offline, roams, or obtains an IP address.
System impact
N/A
Status control
ON
CLI: Use the snmp-agent trap enable wlan client-audit command.
OFF
CLI: Use the undo snmp-agent trap enable wlan client-audit command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.3.2.1.21 (hh3cDot11StationAuditTrapOpType) |
Client operation type. |
Unsigned32 |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.2.1.22 (hh3cDot11StationTrapStaIPAddress) |
IP address of the client. |
IpAddress |
AP's MAC address. |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.2.1.19 (hh3cDot11StationTrapAPIPAddress) |
AP's IP address. |
IpAddress |
1.3.6.1.4.1.25506.2.75.3.2.1.23 (hh3cDot11StationTrapRadioID) |
ID of each channel. |
Hh3cDot11RadioScopeType |
1.3.6.1.4.1.25506.2.75.3.2.1.24 (hh3cDot11StationTrapRadioMode) |
Radio type supported by the client. |
Hh3cDot11RadioType2 |
1.3.6.1.4.1.25506.2.75.3.2.1.25 (hh3cDot11StationTrapWlanID) |
WLAN ID of the BSS associated with the client. |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.26 (hh3cDot11StationTrapSSIDName) |
ESS name. |
Hh3cDot11SSIDStringType |
1.3.6.1.4.1.25506.2.75.3.2.1.27 (hh3cDot11StationTrapVlan) |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.28 (hh3cDot11StationTrapChannel) |
Current channel used by the client. |
Hh3cDot11ChannelScopeType |
1.3.6.1.4.1.25506.2.75.3.2.1.29 (hh3cDot11StationTrapRSSI) |
Strength of the received signal. The maximum value is defined by the chipset vendor. |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.20 (hh3cDot11StationTrapStartTime) |
Time when the device starts connecting to the client. |
Unsigned32 |
Unsigned32 |
1.3.6.1.4.1.25506.2.75.3.2.1.30 (hh3cDot11StationTrapRxFrameKbit) |
Number of data frames bits received from the client. |
Counter64 |
1.3.6.1.4.1.25506.2.75.3.2.1.31 (hh3cDot11StationTrapTxFrameKbit) |
Number of data frame bits sent to the client. |
Counter64 |
Recommended action
