book
本章节下载 (565.92 KB)
H3C SOHO Switch System Log Messages
Abstract: This document describes the system log messages.
Copyright © 2017 New H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of New H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
sysname (host name or IP address)
DLDP_UNIDIRECTION_AUTO_ENHANCE
DLDP_UNIDIRECTION_AUTO_DISABLE
DLDP_UNIDIRECTION_AUTO_LOOPBACK
DLDP_UNIDIRECTION_AUTO_LINKDOWN
DLDP_UNIDIRECTION_MAN_LOOPBACK
DLDP_UNIDIRECTION_MAN_LINKDOWN
ETHOAM_CONNECTION_FAIL_UNSATISF
ETHOAM_CONNECTION_FAIL_TIMEOUT
ETHOAM_ENTER_LOOPBACK_CONTROLLED
ETHOAM_QUIT_LOOPBACK_CONTROLLED
ETHOAM_ENTER_LOOPBACK_CONTROLLIN
ETHOAM_QUIT_LOOPBACK_CONTROLLING
ETHOAM_LOOPBACK_EXIT_ERROR_STATU
ETHOAM_LOCAL_ERROR_FRAME_PERIOD
ETHOAM_REMOTE_ERROR_FRAME_PERIOD
ETHOAM_LOCAL_ERROR_FRAME_SECOND
ETHOAM_REMOTE_ERROR_FRAME_SECOND
FLT_SET_POLICY_NOTSUPPORT_FAIL
FLT6_SET_POLICY_NOTSUPPORT_FAIL
LAGG_INACTIVE_RESOURCE_INSUFFICIE
During the operation of a device, the log module in the host software records every event of the device and generates system log information.
With system log information, network administrators can monitor device running status, analyze network status, find network or security problems, and take corresponding actions against them.
You can display the system log information through the console port or by telnetting. The device can save logs or output them to the log server.
According to the syslog protocol, the system transmits logs through UDP port 514. Any UDP packet on port 514 is considered as a log message, which uses the following format.
<PRI>timestamp sysname %%vvmodule/level/digest: source content
1 2 3 4 5 6 7 8 9 10
Table 1 Description of a log message
Number |
1 |
Priority |
2 |
Timestamp |
3 |
Host name |
4 |
Manufacturer |
5 |
Version |
6 |
Module name |
7 |
Severity level |
8 |
Message summary |
9 |
Message creator |
10 |
Message content |
The system messages sent to log hosts are log messages.
The priority is calculated using the formula: facility*8+severity, in which facility is the logging facility name and can be configured when you set the log host parameters. The facility ranges from local0 to local7 (16 to 23 in decimal integers) and defaults to local7. It is mainly used to mark different log sources on the log host, query and filter the logs of the corresponding log source. Severity ranges from 0 to 7. Table 2 details the value and meaning associated with each severity.
Note that the priority field takes effect only when the information has been sent to the log host.
Severity |
Severity value |
Emergency |
0 |
The system is unusable. |
Alert |
1 |
Action must be taken immediately. |
Critical |
2 |
Critical conditions |
Error |
3 |
Error conditions |
Warning |
4 |
Warning conditions |
Notice |
5 |
Normal but significant conditions |
Informational |
6 |
Informational messages |
Debug |
7 |
Debug-level messages |
Time stamp records the time when system information is generated to allow users to check and identify system events. The time stamp of the system information sent from the information center to the log host is with a precision of milliseconds. The time stamp format of the system information sent to the log host is configured with the info-center timestamp loghost command, and that of the system information sent to the other destinations is configured with the info-center timestamp command. For the detailed description of the time stamp parameters, see the following table:
Table 3 Description on the time stamp parameters
Time stamp parameter |
Example |
boot |
System up time (that is, the duration for this operation of the device), in the format of xxxxxx.yyyyyy. xxxxxx represents the higher 32 bits, and yyyyyy represents the lower 32 bits. System information sent to all destinations except log host supports this parameter. |
%0.16406399 Sysname IFNET/3/LINK_UPDOWN: Ethernet0/6 link status is DOWN. 0.16406399 is a time stamp in the boot format. |
date |
Current date and time of the system, in the format of Mmm dd hh:mm:ss:sss yyyy. System information sent to all destinations supports this parameter. |
%Aug 19 16:11:03:288 2009 Sysname IFNET/3/LINK_UPDOWN: Ethernet0/6 link status is UP. Aug 19 16:11:03:288 2009 is a time stamp in the date format. |
iso |
Time stamp format stipulated in ISO 8601 Only the system information sent to a log host supports this parameter. |
<187>2009-09-21T15:32:55 Sysname %%10 IFNET/3/LINK_UPDOWN(l): Ethernet0/6 link status is DOWN. 2009-09-21T15:32:55 is a time stamp in the iso format. |
none |
No time stamp is included. System information sent to all destinations supports this parameter. |
% Sysname IFNET/3/LINK_UPDOWN: Ethernet0/6 link status is DOWN. No time stamp is included. |
no-year-date |
Current date and time of the system, with year information excluded. Only the system information sent to a log host supports this parameter. |
<187>Aug 19 16:120:38 Sysname %%10 IFNET/3/LINK_UPDOWN(l): Ethernet0/6 link status is DOWN. Aug 19 16:120:38 is a time stamp in the no-year-date format. |
· If the system information is sent to a log host in the format of UNICOM, and the info-center loghost source command is configured, or vpn-instance vpn-instance-name is provided in the info-center loghost command, the field is displayed as the IP address of the device that generates the system information.
· In other cases (when the system information is sent to a log host in the format of H3C, or sent to other destinations), the field is displayed as the name of the device that generates the system information, namely, the system name of the device. You can use the sysname command to modify the system name. For more information, see the Fundamentals Command Reference.
This field indicates that system information is generated by a H3C device. It is displayed only when the system information is sent to a log host in the format of H3C.
This field is a version identifier of syslog, with a value of 10. It is displayed only when the output destination is log host.
This field represents the name of the module that generates system information. You can enter the info-center source? command in system view to view the module list
System information can be divided into eight levels based on its severity, from 0 to 7. See Table 2for definition and description of these severity levels. The levels of system information generated by modules are predefined by developers, so you cannot change the system information levels. However, with the info-center source command, you can configure to output information of the specified level and not to output information lower than the specified level.
The digest field is a string of up to 32 characters, outlining the system information.
For system information destined to the log host:
· If the character string ends with (l), the information is log information
· If the character string ends with (t), the information is trap information
· If the character string ends with (d), the information is debugging information
For system information destined to other destinations:
· If the time stamp starts with a %, the information is log information
· If the time stamp starts with a #, the information is trap information
· If the time stamp starts with a *, the information is debugging information
This field indicates the source of the information.This field is optional and is displayed only when the system information is sent to a log host in the format of H3C.
This field provides the content of the system information.
For example:
%@354%Feb 15 19:03:21:985 2011 H3C CFGMAN/5/CFGMAN_EXIT: Exit from configuration mode.
The information shows that this log is generated on Feb. 15 19: 03:21 2011, and is sent by module CFGMAN, the host name is H3C, severity level is 5, and the content of the log is exit from configure mode.
Table 4 Module list
Module Name |
Full spelling |
ADDR |
IPv4 address management |
ADDR6 |
IPv6 address management |
ACL |
Access Control List |
ACFPC |
Application Control Forwarding Protocol Client |
ARP |
Address Resolution Protocol |
ASPF |
Application Specific Packet Filter |
BFD |
Bidirectional Forwarding Detection |
BGP |
Border Gateway Protocol |
BLS |
Blacklist |
CFD |
Connectivity Fault Detection |
CFGMAN |
Configuration Management |
CFM |
Configuration File Management |
CLST |
Cluster |
CLKM |
Clock Management |
CMD |
Command |
CSPF |
Constraint Shortest Path First |
DAR |
Deeper Application Recognition |
DEVM |
Device Management |
DHBK |
Double Hot Backup |
DHCPC |
Dynamic Host Configuration Protocol Client |
DHCPR |
Dynamic Host Configuration Protocol Relay |
DHCPRULE |
Dynamic Host Configuration Protocol Rule |
DHCPS |
Dynamic Host Configuration Protocol Server |
DHCPSP6 |
DHCPv6 Snooping |
DLDP |
Device Link Detection Protocol |
DOT1X |
DOT1X |
DPATTACK |
Data Plane Attack defense |
DPBRIDGE |
Data Plane Bridge |
DPCNNLMT |
Data Plane Connection limit |
DPPBR |
Data Plane Policy Based Route |
DPPBR6 |
Data Plane Policy Based Route IPv6 |
DPURPF |
Data Plane Unicast Reverse Path Forwarding |
DPVFR |
Data Plane Virtual Fragment Reassembly |
ETHOAM |
Ethernet Operation, Administration and Maintenance |
FLT6 |
Filter of IPv6 |
FILTER |
Filter of IPv4 |
FTP Daemon |
File Transfer Protocol Daemon |
HA |
High Availability |
HOSTTRAF |
Host traffic |
IC |
Information Center |
IFNET |
Interface Net Management |
IKE |
Internet Key Exchange |
IPCIM |
IP Client Information Management |
IPSEC |
IP Security |
IPV6PP |
Internet Protocol Version 6 Packet Process Management |
ISIS |
Intermediate System-to-Intermediate System |
L2V |
Layer 2 Virtual Private Network |
L3VPN |
Layer 3 Virtual Private Network |
LAGG |
Link Aggregation |
LDP |
Label Distribution Protocol |
LICS |
License |
LLDP |
Link Layer Discovery Protocol |
LPDETECT |
Loop Detect |
LPDT |
Loopback Detection |
LS |
Local Server |
LSPM |
LSP Management |
LSPV |
LSP Verification |
LWPC |
Light Weight Access Point Protocol client |
LWPS |
Light Weight Access Point Protocol server |
MAC |
Media Access Control |
MAD |
Multi-Active Detection |
MD |
Multicast domain |
MEM |
Memory Management |
MFF |
MAC-Forced Forwarding |
MFW |
MPLS Forwarding |
MPLS OAM |
MPLS Operation Administration and Maintenance |
MSDP |
Multicast Source Discovery Protocol |
MSTP |
Multiple Spanning Tree Protocol |
MTLK |
Monitor Link |
NAT |
Network Address Translation |
ND |
Neighbor Discovery |
NTP |
Network Time Protocol |
OPTMOD |
Optical Module |
OSPF |
Open Shortest Path First |
OSPFv3 |
Open Shortest Path First Version 3 |
PBR |
PBR6 |
PIM |
Protocol Independent Multicast |
PKEY |
Public Key |
PKI |
Public Key Infrastructure |
PORTAL |
PORTAL |
PORTSEC |
PORTSEC |
PPPOEC |
Point to Point Protocol Over Ethernet Client |
PS |
Protection Switch |
QINQ |
802.1Q IN 802.1Q |
QOS |
Quality of Service |
RDS |
RADIUS |
RIP |
Routing Information Protocol |
RIPNG |
Routing Information Protocol Next Generation |
RM |
Routing Management |
RMON |
Remote Monitor |
RPR |
Resilient Packet Ring |
RRPP |
Rapid Ring Protect Protocol |
RSVP |
Resource Reservation Protocol |
SC |
Service Control |
SHELL |
Shell |
SLBG |
Service Loopback Group |
SMLK |
Smart Link |
SNMP |
Simple Network Management Protocol |
SOCKET |
SOCKET |
SSH |
Secure Shell |
STM |
Stack Topology Management |
SVPN |
Virtual Private Network based on Security Socket Layer |
TNLM |
Tunnel Management |
URPF |
USERLOG |
User Log |
UTM |
Unified Threat Management |
VFR |
VFS |
Virtual File System |
VRRP |
Virtual Router Redundancy Protocol |
WIDS |
WLAN Intrusion Detection system |
WMAC |
WLAN MAC |
WMESH |
WLAN Mesh |
WROAM |
WLAN Roaming |
WEBOPT |
Web Operation APPCTL is short for Application Control LDBL is short for Load Balance LS is short for Local User IC is short for Information Center |
Support for the following modules depends on the device model.
Module Name |
Supported Device |
Not Supported Device |
RIP |
S2100,S3110, S5000PV2-EI,S5110,S5110-D, S5110-SI,IE4100,IE4300 |
S1850,S2600,S3110-SI |
OSPF |
S2100,S3110 |
S1850,S2600,S3110-SI,S5000PV2-EI, S5110, S5110-D,S5110-SI,IE4100,IE4300, |
QINQ |
S2100,S3110, S5000PV2-EI, S5110,S5110-D,S5110-SI,IE4100,IE4300 |
S1850,S2600,S3110-SI, |
This section contains the entire system log messages related to ADDR.
Message text |
-TaskId=[ULONG]-TaskName=[STRING]-BoardId=[ULONG]-IPAddr=[IPADDR]-IfName=[STRING]; Failed to add or delete IP address to or from driver. |
Variable fields |
$1: Task ID. $2: Task name. $3: Board ID. $4: IP address. $5: Interface name. |
Severity level |
3 |
Example |
ADDR/3/ADDR_SETDRIVER_FAIL: -TaskId=1-TaskName=IP-BoardId=1-IPAddr=1.1.1.1-IfName=GigabitEthernet1/0/1; Failed to add or delete IP address to or from driver. |
Explanation |
Failed to add or delete IP address to/from driver. |
Recommended action |
No action is required. |
This section contains the entire system log messages related to ADDR6.
Message text |
IPv6 address [STRING] add error on [STRING] slot [ULONG]. |
Variable fields |
$1: IPv6 address. $2: Chassis number. $3: Slot number. |
Severity level |
4 |
Example |
ADDR6/4/ADDR6_ADD_ADDR_FAIL: IPv6 address 2::2 add error on slot 3. |
Explanation |
IPv6 address add error on IO board. |
This section contains the entire system log messages related to ACL.
Message text |
Error occurred in ACL [ULONG] for not enough resource. |
Variable fields |
$1: The acl group ID. |
Severity level |
3 |
Example |
ACL/3/ACL_NOT_ENOUGH_RES:Error occurred in ACL 3000 for not enough resource. |
Explanation |
There is no enough resource for the synchronization of acl group to driver. |
Delete the acl group. |
Message text |
Error occurred in ACL [ULONG]. |
Variable fields |
Severity level |
3 |
Example |
ACL/3/ ACL_OTHER_ERROR:Error occurred in ACL 3000. |
Explanation |
Other error occurred when synchronization acl to driver. |
Message text |
Error occurred in ACL [ULONG] rule [ULONG] for not enough resource. |
Variable fields |
$1: The acl group ID. $2: The acl rule ID. |
Severity level |
3 |
Example |
ACL/3/ACL_RULE_NOT_ENOUGH_RES: Error occurred in ACL 3000 rule 100 for not enough resource. |
Explanation |
There is no enough resource for the synchronization of acl rule to driver. |
Delete the acl rule. |
Message text |
Error occurred in ACL [ULONG] rule [ULONG]. |
Variable fields |
Severity level |
3 |
Example |
ACL/3/ACL_RULE_OTHER_ERROR: Error occurred in ACL 3000 RULE 100. |
Explanation |
Other error occurred when synchronization acl rule to driver. |
Message text |
Error occurred in ACL IPv6 [ULONG] for not enough resource. |
Variable fields |
Severity level |
3 |
Example |
ACL/3/ACL_IPV6_NOT_ENOUGH_RES:Error occurred in ACL IPv6 3000 for not enough resource. |
Explanation |
Message text |
Error occurred in ACL IPv6 [ULONG]. |
Variable fields |
Severity level |
3 |
Example |
ACL/3/ACL_IPV6_OTHER_ERROR: Error occurred in ACL IPv6 3000. |
Explanation |
Message text |
Error occurred in ACL IPv6 [ULONG] rule [ULONG] for not enough resource. |
Variable fields |
Severity level |
3 |
Example |
ACL/3/ACL_IPV6_RULE_NOT_ENOUGH_RES: Error occurred in ACL IPv6 3000 rule 100 for not enough resource. |
Explanation |
Message text |
Error occurred in ACL IPv6 [ULONG] rule [ULONG]. |
Variable fields |
Severity level |
3 |
Example |
ACL/3/ACL_IPV6_RULE_OTHER_ERROR: Error occurred in ACL IPv6 3000 RULE 100. |
Explanation |
This section contains the entire system log messages related to ARP.
Message text |
Duplicate address [IPADDR] on interface [STRING], sourced from [STRING]. |
Variable fields |
$1: IP address. $2: Interface name. $3: MAC Address. |
Severity level |
5 |
Example |
ARP/5/ARP_DUPIFIP: Duplicate address 1.1.1.1 on interface Vlan-interface1, sourced from 0015-E944-A947. |
Explanation |
The ARP checks the duplicate address. |
Modify the IP address configuration. |
Message text |
ARP Detection Warning: Failed to enable ARP detection on driver. |
Variable fields |
Severity level |
3 |
Example |
ARP/3/ARP_DETECTION_SETDRIVER_FAIL: ARP Detection Warning: Failed to enable ARP detection on driver. |
Explanation |
The driver failed to set ARP detection. |
Message text |
An attack from MAC [STRING] was detected on interface [STRING]. |
Variable fields |
$1: MAC address. $2: Interface name. |
Severity level |
6 |
Example |
ARP/6/ARP_SRC_MAC_FOUND_ATTACK: An attack from MAC 0000-5E14-0E00 was detected on interface Ethernet1/0/1. |
Explanation |
An attack was detected by source MAC address based ARP attack detection. |
Check the host with the source MAC address. |
Message text |
The maximum number of multiport ARP entries has been reached. |
Variable fields |
NA |
Severity level |
5 |
Example |
ARP/5/ARP_MULTIPORT_FULL: The maximum number of multiport ARP entries has been reached. |
Explanation |
Delete a multiport ARP entry. |
This section contains all the system log messages related to CFD.
Message text |
CFD is now enabled on the device. |
Variable fields |
Severity level |
2 |
Example |
CFD/2/CFD_ENABLE: CFD is now enabled on the device. |
Explanation |
CFD is enabled. |
Message text |
CFD is now disabled on the device. |
Variable fields |
Severity level |
2 |
Example |
CFD/2/CFD_DISABLE: CFD is now disabled on the device. |
Explanation |
CFD is disabled. |
Message text |
MEP [string] in SI [string] received a cross-connect CCM. It’s SrcMAC is [string], SeqNum is 0x[string], RMEP is [string], MdName is [string], MaName is [string]. |
Variable fields |
$1: Service instance ID $2: Local MEP ID $3: Source MAC address $4: Sequence Number $5: Remote MEP ID $6 MD name $7 MA name |
Severity level |
3 |
Example |
CFD/3/CFD_CROSS_CCM: MEP 1 in SI 1 received a cross-connect CCM. It’s SrcMAC is 000f-e200-0001, SeqNum is 0x3254, RMEP is 2, MdName is md1, MaName is ma1. |
Explanation |
A MEP received a cross-connect CCM. |
Check the links and the MA name configuration. |
Message text |
MEP [string] in SI [string] received an error CCM. It’s SrcMAC is [string], SeqNum is 0x[string], RMEP is [string], MdName is [string], MaName is [string]. |
Variable fields |
Severity level |
3 |
Example |
CFD/3/CFD_ERROR_CCM: MEP 1 in SI 1 received an error CCM. It’s SrcMAC is 000f-e200-0001, SeqNum is 0x3254, RMEP is 5, MdName is md1, MaName is ma1. |
Explanation |
A MEP received an error CCM. |
Check the CCM configuration. |
Message text |
MEP [string] in SI [string] failed to receive CCMs from RMEP [string]. |
Variable fields |
$1: Local MEP ID $2: Service instance ID $3: Remote MEP ID |
Severity level |
4 |
Example |
CFD/4/CFD_LOST_CCM: MEP 1 in SI 1 failed to receive CCMs from RMEP 2. |
Explanation |
A MEP failed to receive CCMs within 3.5 sending periods. |
Check the link and the configuration of the remote MEP. |
Message text |
MEP [string] in SI [string] received CCMs from RMEP [string]. |
Variable fields |
Severity level |
4 |
Example |
CFD/4/CFD_RECEIVE_CCM: MEP 1 in SI 1 received CCMs from RMEP 2. |
Explanation |
A MEP received CCMs from a remote MEP. |
This section contains the entire system log messages related to CFGMAN.
-EventIndex=[INTEGER]-CommandSource=[INTEGER]-ConfigSource=[INTEGER]-ConfigDestination=[INTEGER]; Configuration is changed. |
Variable fields |
$1: Event index $2: Command source $3: Configuration source $5: Configuration destination |
Severity level |
5 |
Example |
CFGMAN/5/CFGMAN_CFGCHANGED: -EventIndex=13-CommandSource=1-ConfigSource=3-ConfigDestination=2; Configuration is changed. |
Explanation |
Running-configuration is changed. |
Please save current configuration if necessary. |
Message text |
-OptType=[INTEGER]-OptTime=[TIMETICK]-OptState=[INTEGER]-OptEndTime=[TIMETICK]; Configuration is copied. |
Variable fields |
$1: Operation type $2: Operation time $3: Operation state $4: End time of operation |
Severity level |
5 |
Example |
CFGMAN/5/CFGMAN_CFGCOPY: -OptType=6-OptTime=12-OptState=2-OptEndTime=10682324; Configuration is copied. |
Explanation |
Configuration was copied or saved by SNMP. |
This section contains the entire system log messages related to CFM.
Message text |
Failed to save configuration! |
Variable fields |
N/A |
Severity level |
3 |
Example |
CFM/3/CFM_SAVECONFIG_FAILED: Failed to save configuration! |
Explanation |
Save configuration failed for some reasons. Save configuration failed for some reasons. |
Check reasons,for example: is device space enough; Is configuration file is opened and so on. |
Message text |
Configuration is saved successfully. |
Variable fields |
N/A |
Severity level |
5 |
Example |
CFM/5/CFM_SAVECONFIG_SUCCESSFULLY: Configuration is saved successfully. |
Explanation |
Save configuration successfully. Save configuration successfully. |
This section contains the entire system log messages related to CLST.
Message text |
[IPADDR] is assigned by the cluster. |
Variable fields |
$1: Member’s IP address assigned by administrator device. |
Severity level |
6 |
Example |
CLST/5/CLST_SET_IP_ADDR: 10.0.0.2 is assigned by the cluster. |
Explanation |
A member device has been assigned a private IP address, so it can communicate with the administrator device and network management device. When a member joins the cluster. |
Message text |
[STRING] is specified by the cluster. |
Variable fields |
$1: Some system command, for example info-center loghost 10.0.0.1. |
Severity level |
6 |
Example |
CLST/6/CLST_CMD_CFG: info-center loghost 10.0.0.1 is specified by the cluster. |
Explanation |
The command has been configured on the member device. When a member joins the cluster. |
Message text |
hostnamePrefix [STRING] is specified by the cluster. |
Variable fields |
$1: Hostname prefix used by cluster to specify the sysname of the device. |
Severity level |
6 |
Example |
CLST/6/CLST_SET_HOST_NAME_PREFIX: hostnamePrefix aaa_1 is specified by the cluster. |
Explanation |
A hostname prefix is used by the cluster to specify the sysname. |
Message text |
Failed to enable NAT and the member device cannot communicate with the network administrator device. |
Variable fields |
Severity level |
4 |
Example |
CLST/4/CLST_SET_NAT_FAILED: Failed to enable NAT and the member device cannot communicate with the network administrator device. |
Explanation |
The administrator device failed to enable NAT and the reason may be memory shortage. |
Message text |
Device [STRING] failed to modify MVLAN because [STRING]. |
Variable fields |
$1: MAC address of the member device. $2: The reason, for example, the member device cannot create a new VLAN. |
Severity level |
4 |
Example |
CLST/4/CLST_CHANGE_MVLAN_FAILED: Device 00E0-FC00-9912 failed to modify MVLAN because it failed to create a management VLAN. |
Explanation |
A member device cannot modify the management VLAN. |
Check the configuration of the member device. |
Message text |
Device [STRING] failed to add some port to the management VLAN. |
Variable fields |
$1: MAC address of the member device. |
Severity level |
4 |
Example |
CLST/4/CLST_ADDPORT_MVLAN_FAILED: Device 000F-E25D-F27B failed to add some port to the management VLAN. |
Explanation |
A member device failed to add some port to the management VLAN. |
Message text |
Member [STRING] has joined cluster [STRING]. |
Variable fields |
$1: Member device number. $2: Cluster name. |
Severity level |
5 |
Example |
CLST/5/CLST_MEMBER_JOIN_CLUSTER: Member 000F-E25D-F27B has joined cluster aaa. |
Explanation |
A member has joined cluster. (On administrator device) |
Message text |
Member [STRING] in the cluster was deleted. |
Variable fields |
$1: Member device number. |
Severity level |
5 |
Example |
CLST/5/CLST_MEMBER_DELETED_CLUSTER: Member 000F-E25D-F27B in the cluster was deleted. |
Explanation |
A member has been deleted from the cluster. (On administrator device) |
Message text |
Member [STRING] has joined the cluster again. |
Variable fields |
Severity level |
5 |
Example |
CLST/5/CLST_MEMBER_REJOIN_CLUSTER: Member 00E0-FC00-3620 has rejoined the cluster again. |
Explanation |
When handshake exchange error occurred between the administrator and the member device. The member device can join the cluster again when it can exchange hand-shake packets with the administrator device. (On administrator device) |
Message text |
Member [STRING] in the cluster was down. |
Variable fields |
Severity level |
4 |
Example |
CLST/4/CLST_MEMBER_DOWN: Member 00E0-FC00-3620 in the cluster was down. |
Explanation |
If the administrator device does not receive the member’s hand-shake packet for sometime, the administrator device will consider the member device is down. (On administrator device) |
Check if the communication between the administrator device and the member device fails or the administrator device is down. |
Message text |
A device [STRING] has joined cluster [STRING]. |
Variable fields |
$1: MAC address $2: Cluster name. |
Severity level |
5 |
Example |
CLST/5/CLST_DEVICE_JOIN_CLUSTER: A device 000f -e200-0004 has joined cluster ttt. |
Explanation |
A member was added into the cluster. (On member device) |
Message text |
A device was deleted from cluster [STRING]. |
Variable fields |
$1: Cluster name. |
Severity level |
5 |
Example |
CLST/5/CLST_DEVICE_DELETED_CLUSTER: A switch was deleted from cluster aaa. |
Explanation |
A member was deleted from the cluster. (On member device) |
Message text |
Cluster administrator was down. |
Variable fields |
Severity level |
4 |
Example |
CLST/4/CLST_ADMINISTRATOR_DOWN: Cluster administrator was down. |
Explanation |
When a member hasn’t received the administrator‘s hand-shake packet for sometime. The member will consider the administrator is down. (On member device) |
Check if the communication between the administrator and the member fails or the administrator device is down. |
Message text |
A device has joined the cluster again. |
Variable fields |
Severity level |
5 |
Example |
CLST/5/CLST_DEVICE_REJOIN_CLUSTER: A device has joined the cluster again. |
Explanation |
When handshake exchange error occurred between the administrator and the member device. The member device can join the cluster again when it can exchange hand-shake packets with the administrator device. (On member device) |
Message text |
Info-center loghost used by cluster not configured. |
Variable fields |
Severity level |
5 |
Example |
CLST/5/CLST_LOG_HOST_NOT_CFG: Info-center loghost used by cluster was not configured. |
Explanation |
The info-center loghost command is not configured on the administrator device. |
Configure the info-center loghost command on the management device. |
Message text |
Member [ULONG] has executed the [STRING] configuration successfully. |
Variable fields |
$1: Member ID. $2: A configuration, for example SNMP read-community. |
Severity level |
5 |
Example |
CLST/5/CLST_SYN_COM_SUC: Member 1 has executed the read-community configuration successfully. |
Explanation |
Configuration has been performed successfully on the member. |
Message text |
Member [STRING] failed to configure the [STRING] command. |
Variable fields |
Severity level |
4 |
Example |
CLST/4/CLST_SYN_COM_FAL: Member 1 failed to configure the read-community command. |
Explanation |
A member device failed to perform a configuration. |
Check the member device’s configuration and memory usage. |
This section contains the entire system log messages related to CLKM.
Message text |
Traced reference change alarm, no reference traced now. |
Variable fields |
N/A |
Severity level |
4 |
Example |
CLKM/4/CLKM_NOREFERENCE: Traced reference change alarm, no reference traced now. |
Explanation |
no reference are traced now on the device. |
Check the device and repair the fault. |
Message text |
Traced reference change alarm, current traced reference is [ULONG]. |
Variable fields |
$1: Number of references. |
Severity level |
6 |
Example |
CLKM/6/CLKM_REFERENCE_CHANGE: Traced reference change alarm, current traced reference is 15. |
Explanation |
current traced reference changes. |
Message text |
Reference [ULONG] is recovered. |
Variable fields |
Severity level |
6 |
Example |
CLKM/6/CLKM_REFERENCE_RECOVER: Reference 5 is recovered. |
Explanation |
The specified reference is recovered. |
Message text |
Reference [ULONG] is lost. |
Variable fields |
Severity level |
5 |
Example |
CLKM/5/CLKM_REFERENCE_LOST: Reference 5 is lost. |
Explanation |
The specified reference is lost. |
Message text |
All references are lost. |
Variable fields |
N/A |
Severity level |
4 |
Example |
CLKM/4/CLKM_REFERENCE_ALLLOST: All references are lost. |
Explanation |
All references are lost in the device. |
Message text |
[STRING] alarm, current state is [STRING]. |
Variable fields |
$1: Alarm type. $2: Current state. |
Severity level |
4 |
Example |
CLKM/4/CLKM_ALARM: SSM level alarm, current state is SSM_PRC on reference 5. CLKM/4/CLKM_ALARM: SSM out level alarm, current state is SSM_SETS. CLKM/4/CLKM_ALARM: Phase lock alarm, current state is hold judge. CLKM/4/CLKM_ALARM: Osc state alarm, current state is warm-up. CLKM/4/CLKM_ALARM: CLKM SRAM self-test alarm, current state is fault. CLKM/4/CLKM_ALARM: CLKM 38Mhz signal self-test alarm, current state is fault. CLKM/4/CLKM_ALARM: CLKM PLL tru050 self-test alarm, current state is fault. CLKM/4/CLKM_ALARM: CLKM PLL 88915 self-test alarm, current state is fault. CLKM/4/CLKM_ALARM: OSC self-test alarm, current state is fault. CLKM/4/CLKM_ALARM: CLKM I2C bus self-test alarm, current state is fault. CLKM/4/CLKM_ALARM: CLKM EPLD self-test alarm, current state is fault. CLKM/4/CLKM_ALARM: CLKM HDLC self-test alarm, current state is fault. CLKM/4/CLKM_ALARM: CLKM E1a self-test alarm, current state is fault. CLKM/4/CLKM_ALARM: CLKM E1b self-test alarm, current state is fault. |
Explanation |
The state of clock management system changes. |
This section contains the entire system log messages related to DEVM.
Message text |
Fan [INTEGER] recovered. |
Variable fields |
$1: The fan ID |
Severity level |
5 |
Example |
DEVM/5/FAN_RECOVERED: Fan 2 recovered. |
Explanation |
The fan state changes from failed or absent to OK. |
Message text |
Fan [INTEGER] failed. |
Variable fields |
$1: The fan ID |
Severity level |
2 |
Example |
DEVM/2/FAN_FAILED: Fan 2 failed. |
Explanation |
The fan failed to run. |
Check the fan and repair it. |
This section contains the entire system log messages related to DHCPC.
Message text |
IP address request failed on interface [STRING] because an IP address on the same network segment is being used on the device. |
Variable fields |
$1: Name of DHCP client interface from which the DHCP packets are received. |
Severity level |
4 |
Example |
DHCPC/4/DHCPC_REQIPFAILED_NETCONFLICT: IP address request failed on interface VLAN-interface1 because an IP address on the same network segment is being used on the device. |
Explanation |
The same network segment IP address was detected on the device. |
Check the IP address configuration on the device. |
This section contains the entire system log messages related to DHCPR.
Message text |
DHCP Relay information: DHCP Relay interface = [STRING], server IP (detected by DHCP Relay) = [IPADDR]. |
Variable fields |
$1: Name of the interface where the packet is received. $2: Server IP address. |
Severity level |
5 |
Example |
DHCPR/5/DHCPR_DETECT_SERVER: DHCP Relay information: DHCP Relay interface = Ethernet1/0/1, server IP (detected by DHCP Relay) = 1.1.1.1. |
Explanation |
A DHCP server was detected by the relay device. |
Check whether the DHCP server is legal. |
This section contains the entire system log messages related to DHCPRULE.
Message text |
DHCP failed to apply a rule to driver because [STRING] on interface [STRING]. |
Variable fields |
$1: The reason. $2: The interface name. |
Severity level |
4 |
Example |
DHCPRULE/4/DHCPRULE_SET_DRIVER_FAIL: DHCP failed to apply a rule to driver because there is no enough resource for new rules on interface Ethernet1/0/1. |
Explanation |
DHCP failed to apply a rule to driver. |
This section contains all the system log messages related to DLDP.
Message text |
Packets failed to pass the DLDP authentication because of unmatched [STRING]. |
Variable fields |
$1: Packet field |
Severity level |
3 |
Example |
DLDP/3/DLDP_AUTHENTICATION_FAIL: Packets failed to pass the DLDP authentication because of unmatched INTERVAL. |
Explanation |
Packets failed to pass the DLDP authentication. |
Check authentication-related configurations. |
Message text |
DLDP detects a unidirectional link on port [STRING]. The transceiver has malfunction in the Tx direction or cross-connected links exist between the local device and its neighbor. The shutdown mode is AUTO. DLDP shuts down the port. |
Variable fields |
$1: Port name |
Severity level |
3 |
Example |
DLDP/3/DLDP_UNIDIRECTION_AUTO: DLDP detects a unidirectional link on port GigabitEthernet 1/0/25. The transceiver has malfunction in the Tx direction or cross-connected links exist between the local device and its neighbor. The shutdown mode is AUTO. DLDP shuts down the port. |
Explanation |
DLDP detects a unidirectional link and shuts down the port automatically. |
Check the unidirectional link. |
Message text |
DLDP detects a unidirectional link on port [STRING]. The transceiver has malfunction in the Tx direction or cross-connected links exist between the local device and its neighbor. The shutdown mode is MANUAL. The port needs to be shut down by the user. |
Variable fields |
$1: Port name |
Severity level |
3 |
Example |
DLDP/3/DLDP_UNIDIRECTION_MAN: DLDP detects a unidirectional link on port GigabitEthernet 1/0/25. The transceiver has malfunction in the Tx direction or cross-connected links exist between the local device and its neighbor. The shutdown mode is MANUAL. The port needs to be shut down by the user. |
Explanation |
DLDP detects a unidirectional link and suggests that the port should be shut down. |
Shut down the port and check the unidirectional link. |
Message text |
In enhanced DLDP mode, port [STRING] cannot detect its aged-out neighbor. The transceiver has malfunction in the Tx direction or cross-connected links exist between the local device and its neighbor. The shutdown mode is AUTO. DLDP shuts down the port. |
Variable fields |
$1: Port name |
Severity level |
3 |
Example |
DLDP/3/DLDP_UNIDIRECTION_AUTO_ENHANCE: In enhanced DLDP mode, port GigabitEthernet 1/0/25 cannot detect its aged-out neighbor. The transceiver has malfunction in the Tx direction or cross-connected links exist between the local device and its neighbor. The shutdown mode is AUTO. DLDP shuts down the port. |
Explanation |
In enhanced mode, DLDP detects a unidirectional link and shuts down the port automatically. |
Message text |
In enhanced DLDP mode, port [STRING] cannot detect its aged-out neighbor. The transceiver has malfunction in the Tx direction or cross-connected links exist between the local device and its neighbor. The shutdown mode is MANUAL. The port needs to be shut down by the user. |
Variable fields |
$1: Port name |
Severity level |
3 |
Example |
DLDP/3/ DLDP_UNIDIRECTION_MAN_ENHANCE: In enhanced DLDP mode, port GigabitEthernet 1/0/25 cannot detect its aged-out neighbor. The transceiver has malfunction in the Tx direction or cross-connected links exist between the local device and its neighbor. The shutdown mode is MANUAL. The port needs to be shut down by the user. |
Explanation |
In enhanced mode, DLDP detects a unidirectional link and suggests that the port should be shutdown. |
Message text |
DLDP detects a unidirectional link on port [STRING]. The local port has received disable packets. The shutdown mode is AUTO. DLDP shuts down the port. |
Variable fields |
$1: Port name |
Severity level |
3 |
Example |
DLDP/3/DLDP_UNIDIRECTION_AUTO_DISABLE: DLDP detects a unidirectional link on port GigabitEthernet1/0/25. The local port has received disable packets. The shutdown mode is AUTO. DLDP shuts down the port. |
Explanation |
DLDP detects a unidirectional link because DLDP received disable packets in AUTO shutdown mode. |
Check the neighbour port and the unidirctional link. |
Message text |
DLDP detects a unidirectional link on port [STRING]. The local port has received looped back packets. The shutdown mode is AUTO. DLDP shuts down the port. |
Variable fields |
$1: Port name |
Severity level |
3 |
Example |
DLDP/3/DLDP_UNIDIRECTION_AUTO_LOOPBACK: DLDP detects a unidirectional link on port GigabitEthernet1/0/25. The local port has received looped back packets. The shutdown mode is AUTO. DLDP shuts down the port. |
Explanation |
DLDP detects a unidirectional link because DLDP received looped back packets in AUTO shutdown mode. |
Check the loopback link and the unidirectional link. |
Message text |
DLDP detects a unidirectional link on port [STRING]. The local port has received linkdown packets. The shutdown mode is AUTO. DLDP shuts down the port. |
Variable fields |
$1: Port name |
Severity level |
3 |
Example |
DLDP/3/DLDP_UNIDIRECTION_AUTO_LINKDOWN: DLDP detects a unidirectional link on port GigabitEthernet1/0/25. The local port has received linkdown packets. The shutdown mode is AUTO. DLDP shuts down the port. |
Explanation |
DLDP detects a unidirectional link because DLDP received linkdown packets in AUTO shutdown mode. |
Message text |
DLDP detects a unidirectional link on port [STRING]. The local port has received disable packets. The shutdown mode is MANUAL. The port needs to be shut down by the user. |
Variable fields |
$1: Port name |
Severity level |
3 |
Example |
DLDP/3/DLDP_UNIDIRECTION_MAN_DISABLE: DLDP detects a unidirectional link on port GigabitEthernet1/0/25. The local port has received disable packets. The shutdown mode is MANUAL. The port needs to be shut down by the user. |
Explanation |
DLDP detects a unidirectional link because DLDP received disable packets in MANUAL shutdown mode. |
Shut down the port, and check the neighbour port and the unidirctional link. |
Message text |
DLDP detects a unidirectional link on port [STRING]. The local port has received looped back packets. The shutdown mode is MANUAL. The port needs to be shut down by the user. |
Variable fields |
$1: Port name |
Severity level |
3 |
Example |
DLDP/3/DLDP_UNIDIRECTION_MAN_LOOPBACK: DLDP detects a unidirectional link on port GigabitEthernet1/0/25. The local port has received looped back packets. The shutdown mode is MANUAL. The port needs to be shut down by the user. |
Explanation |
DLDP detects a unidirectional link because DLDP received looped back packets in MANUAL shutdown mode. |
Shut down the port, and check the loopback link and the unidirctional link. |
Message text |
DLDP detects a unidirectional link on port [STRING]. The local port has received linkdown packets. The shutdown mode is MANUAL. The port needs to be shut down by the user. |
Variable fields |
$1: Port name |
Severity level |
3 |
Example |
DLDP/3/DLDP_UNIDIRECTION_MAN_LINKDOWN: DLDP detects a unidirectional link on port GigabitEthernet1/0/25. The local port has received linkdown packets. The shutdown mode is MANUAL. The port needs to be shut down by the user. |
Explanation |
DLDP detects a unidirectional link because DLDP received linkdown packets in MANUAL shutdown mode. |
This section contains the entire system log messages related to DOT1X.
Message text |
-IfName=[STRING]-UserName=[STRING]; DOT1X authentication failed. |
Variable fields |
$1: Interface type and number $2: Username |
Severity level |
6 |
Example |
DOT1X/6/DOT1X_AUTH_FAILURE: -IfName=Ethernet1/0/1-UserName=test; DOT1X authentication failed. |
Explanation |
A user failed the authentication. This may result from incorrect username or password, or incorrect configuration on the user client, access device, or authentication server. |
Check the relevant configuration. |
Message text |
-IfName=[STRING]-UserName=[STRING]; SmartOn authentication failed because [STRING] |
Variable fields |
$1: Interface type and number $2: Username $3: Failure reason. |
Severity level |
6 |
Example |
DOT1X/6/DOT1X_SMARTON_FAILURE: -IfName=Ethernet1/0/1-UserName=test; SmartOn authentication failed because the switch ID is mismatched. |
Explanation |
A SmartOn user authentication failure. This may result from mismatched switch ID or password. |
Message text |
-IfName=[STRING]-UserName=[STRING]; [STRING] |
Variable fields |
$1: Interface type and number $2: Username $3: ACL rule assignment failure. Possible reasons include: “The specified ACL does not exist.” “Failed to delete the specified ACL.” “This type of ACL is not supported.” “Hardware resource is not enough.” “ACL contains a source MAC address that is different from the MAC address of the user.” “Failed to assign the specified ACL.” |
Severity level |
5 |
Example |
DOT1X/5/DOT1X_SOP_ACL_FAILURE: -IfName=Ethernet1/0/1-UserName=test; This type of ACL is not supported. |
Explanation |
ACL rule assignment failure. |
This section contains the entire system log messages related to DPBRIDGE.
Message text |
MAC address table is full. |
Variable fields |
N/A |
Severity level |
5 |
Example |
DPBRIDGE/5/DPBRIDGE_MACFULL: MAC address table is full. |
Explanation |
The MAC address table is full. |
Check the MAC address table. |
This section contains the entire system log messages related to CNNLMT.
Message text |
-srcIPAddr=[STRING]-srcIPMask=[ULONG]-srcVPNID=[STRING]-dstIPAddr=[STRING]-dstIPMask=[ULONG]-dstVPNID=[STRING]- protocol=[STRING]-MaxConnectionNum=[ULONG]; Number of connections reached the upper limit. |
Variable fields |
$1: Source IP address $2: Source IP address mask $3: source VPN ID $4: destination IP address $5: destination IP address mask $6: destination VPN ID $7: protocol of connection $8: Maximum connection number |
Severity level |
6 |
Example |
DPCONLMT/6/CONNLMT_REACH_UPPERLIMIT: -srcIPAddr=5.5.5.6-srcIPMask=24-srcVPNID=None-dstIPAddr=6.6.6.6-dstIPMask=24-dstVPNID=None-protocol=HTTP-MaxConnectionNum=1024; Number of connections reached the upper limit. |
Explanation |
This section contains the entire system log messages related to DPPBR.
Message text |
Failed to refresh data plane because [STRING]. |
Variable fields |
$1: The reason, for example, there is not enough memory. |
Severity level |
4 |
Example |
DPPBR/4/DPPBR_FAILED_REFRESH: Failed to refresh data plane because the memory is not enough. |
Explanation |
Failed to refresh data plane. |
Check the configuration and the resource usage. |
This section contains the entire system log messages related to DPPBR6.
Message text |
No enough resource when [STRING]. |
Variable fields |
$1: What operation failed, for example allocating memory for a policy. |
Severity level |
4 |
Example |
DPPBR6/4/DPPBR6_FAILED_REFRESH: No enough resource when allocating memory for a node. |
Explanation |
PBR6 failed to refresh data plane. |
This section contains all the system log messages related to ETHOAM.
Message text |
Ethernet OAM is now enabled on port [string]. |
Variable fields |
$1: Port name |
Severity level |
2 |
Example |
ETHOAM/2/ETHOAM_ENABLE: Ethernet OAM is now enabled on port GigabitEthernet 1/0/25. |
Explanation |
Ethernet OAM is successfully enabled on a port. |
Message text |
Ethernet OAM is now disabled on port [string]. |
Variable fields |
$1: Port name |
Severity level |
2 |
Example |
ETHOAM/2/ETHOAM_DISABLE: Ethernet OAM is now disabled on port GigabitEthernet 1/0/25. |
Explanation |
Ethernet OAM is successfully disabled on a port. |
Message text |
An OAM connection is established on port [string]. |
Variable fields |
$1: Port name |
Severity level |
3 |
Example |
ETHOAM/3/ETHOAM_CONNECTION_SUCCEED: An Ethernet OAM connection is established on port Ethernet 1/0/1. |
Explanation |
An OAM connection has been established between two ports. |
Message text |
Port [string] failed to establish an OAM connection .because the peer is not satisfied with the capacity of the local port. |
Variable fields |
$1: Port name |
Severity level |
3 |
Example |
ETHOAM/3/ETHOAM_CONNECTION_FAIL_UNSATISF: Port Ethernet 1/0/1 because the peer is not satisfied with the capacity of the local port. |
Explanation |
OAM connection is not successfully established between two ports because the peer is not satisfied with the capacity of the local port. |
Message text |
Port [string] removed the OAM connection because it failed to receive information OAMPDU. |
Variable fields |
$1: Port name |
Severity level |
5 |
Example |
ETHOAM/5/ETHOAM_CONNECTION_FAIL_TIMEOUT: Port Ethernet 1/0/1 removed the OAM connection because it failed to receive information OAMPDU. |
Explanation |
When an OAM entity fails to receive OAMPDUs in five seconds, it removes the OAM connection. |
Check the link status or the OAM enable status on the peer. |
Message text |
The OAM connection on port [string] failed because the port link is down. |
Variable fields |
$1: Port name |
Severity level |
5 |
Example |
ETHOAM/5/ETHOAM_CONNECTION_FAIL_DOWN: The OAM connection on port Ethernet 1/0/1 failed because the port link is down. |
Explanation |
When the port link transits from up to down, the OAM connection will be disconnected. |
Message text |
The local OAM entity enters remote loopback as controlled DTE on OAM Port [string]. |
Variable fields |
$1: Port name |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_ENTER_LOOPBACK_CONTROLLED: The local OAM entity enters remote loopback as controlled DTE on OAM port Ethernet 1/0/1. |
Explanation |
After you run the “oam loopback” command on the remote OAM entity, the local OAM entity enters remote loopback as controlled DTE. |
Message text |
The local OAM entity quits remote loopback as controlled DTE on OAM Port [string]. |
Variable fields |
$1: Port name |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_QUIT_LOOPBACK_CONTROLLED: The local OAM entity quits remote loopback as controlled DTE on OAM Port Ethernet 1/0/1. |
Explanation |
After you run the “undo oam loopback” command on the remote OAM entity, the local OAM entity quits remote loopback as controlled DTE. |
Message text |
The local OAM entity enters remote loopback as controlling DTE on OAM Port [string]. |
Variable fields |
$1: Port name |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_ENTER_LOOPBACK_CONTROLLIN: The local OAM entity enters remote loopback as controlling DTE on OAM Port Ethernet 1/0/1. |
Explanation |
After you run the “oam loopback” command on the local OAM entity, the remote OAM entity enters remote loopback as controlling DTE. |
Message text |
The local OAM entity quits remote loopback as controlling DTE on OAM Port [string]. |
Variable fields |
$1: Port name |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_QUIT_LOOPBACK_CONTROLLING: The local OAM entity enters remote loopback as controlling DTE on OAM Port Ethernet1/0/1. |
Explanation |
After you run the “undo oam loopback” command on the local OAM entity, the local OAM entity quits remote loopback as controlling DTE. |
Message text |
OAM Port [string] quits remote loopback. |
Variable fields |
$1: Port name |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_LOOPBACK_EXIT: OAM Port Ethernet 1/0/1 quits remote loopback. |
Explanation |
When the link is down or the OAM entity working as controlled DTE is disabled, the local OAM entity quits remote loopback. |
Message text |
OAM Port [string] quits remote loopback due to incorrect multiplexer or parser status. |
Variable fields |
$1: Port name |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_LOOPBACK_EXIT_ERROR_STATU: OAM port Ethernet 1/0/1 quits remote loopback due to incorrect multiplexer or parser status. |
Explanation |
The OAM entity quits remote loopback due to incorrect multiplexer or parser status. |
Disable and then re-enable the OAM protocol on the OAM entity. |
A local link fault event has occurred on [string]. |
Variable fields |
$1: Name of a port on the local device |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOCAL_LINK_FAULT: A local link fault event has occurred on GigabitEthernet 1/0/25. |
Explanation |
A link fault event occurred on a local port. Disconnect the receiver fiber of a local port. |
Re-connect the receiver fiber of the local port. |
A remote link fault event has occurred on [string]. |
Variable fields |
$1: Name of a port on a remote device |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_REMOTE_LINK_FAULT: A remote link fault event has occurred on GigabitEthernet 1/0/25. |
Explanation |
A link fault event occurred on a remote port. |
Re-connect the receiver fiber of the remote port. |
Message text |
An errored frame event has occurred on local port [string]. |
Variable fields |
$1: Port name |
Severity level |
5 |
Example |
ETHOAM/5/ETHOAM_LOCAL_ERROR_FRAME: An errored frame event has occurred on local port GigabitEthernet 1/0/25. |
Explanation |
An errored frame event occurred on a local port. |
Check the link. |
Message text |
An errored frame event has occurred on the peer of [string]. |
Variable fields |
$1: Port name |
Severity level |
5 |
Example |
ETHOAM/5/ ETHOAM_REMOTE_ERROR_FRAME: An errored frame event has occurred on the peer of port GigabitEthernet 1/0/25. |
Explanation |
An errored frame event occurred on a remote port. |
Check the link. |
Message text |
An errored frame period event has occurred on local port [string]. |
Variable fields |
$1: Port name |
Severity level |
5 |
Example |
ETHOAM/5/ETHOAM_LOCAL_ERROR_FRAME_PERIOD: An errored frame period event has occurred on local port GigabitEthernet 1/0/25. |
Explanation |
An errored frame period event occurred on a local port. |
Check the link. |
Message text |
An errored frame period event has occurred on remote port [string]. |
Variable fields |
$1: Port name |
Severity level |
5 |
Example |
ETHOAM/5/ETHOAM_REMOTE_ERROR_FRAME_PERIOD: An errored frame period event has occurred on the peer of port GigabitEthernet 1/0/25. |
Explanation |
Check the link. |
Message text |
An errored frame seconds summary event has occurred on local port [string]. |
Variable fields |
$1: Port name |
Severity level |
5 |
Example |
ETHOAM/5/ETHOAM_LOCAL_ERROR_FRAME_SECOND: An errored frame seconds summary event has occurred on local port GigabitEthernet 1/0/25. |
Explanation |
An errored frame seconds summary event occurred on a local port. |
Check the link. |
Message text |
An errored frame seconds summary event has occurred on the peer of port [string]. |
Variable fields |
$1: Port name |
Severity level |
5 |
Example |
ETHOAM/5/ETHOAM_REMOTE_ERROR_FRAME_SECOND: An errored frame seconds summary event has occurred on the peer of port GigabitEthernet 1/0/25. |
Explanation |
An errored frame seconds summary event occurred on a remote port. |
Check the link. |
Message text |
A dying gasp event has occurred on the peer of port [string]. |
Variable fields |
$1: Port name |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_REMOTE_DYING_GASP: A dying gasp event has occurred on the peer of port GigabitEthernet 1/0/25. |
Explanation |
A dying gasp event occurred on a remote port. |
Don’t use this link until it returns to a normal condition. |
Message text |
A critical event has occurred on the peer of port [string]. |
Variable fields |
$1: Port name |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_REMOTE_CRITICAL: A critical event has occurred on the peer of GigabitEthernet 1/0/25. |
Explanation |
A critical event occurred on a remote port. |
Message text |
OAM port [string] cannot enter remote loopback due to insufficient resources. |
Variable fields |
$1: Port name |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOOPBACK_NO_RESOURCE: OAM port GigabitEthernet 1/0/25 cannot enter remote loopback due to insufficient resources. |
Explanation |
When you try to enable remote loopback on the OAM port, there are not enough resources to complete the operation. |
Release the resources, and run the “oam loopback” command again. |
Message text |
OAM port [STRING] cannot enter remote loopback because the operation is not supported. |
Variable fields |
$1: Port name |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOOPBACK_NOT_SUPPORT: OAM port Ethernet 1/0/1 cannot enter remote loopback because the operation is not supported. |
Explanation |
The operation of enabling remote loopback on the OAM port is not supported. |
Message text |
A local dying gasp event has occurred on [string]. |
Variable fields |
$1: Port name |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOCAL_DYING_GASP: A local dying gasp event has occurred on GigabitEthernet 1/0/25. |
Explanation |
A dying gasp event occurred on a local port. |
This section contains the entire system log messages related to Filter.
Message text |
Driver failed to apply the filter policy to or refresh the filter policy on interface [STRING].Not supported. |
Variable fields |
$1: Interface type and number |
Severity level |
5 |
Example |
FILTER/5/FLT_SET_POLICY_NOTSUPPORT_FAIL: Failed to apply the filter policy to or refresh the filter policy on interface Ethernet1/0/1.Not supported. |
Explanation |
N/A |
Check the configure of FILTER. |
Message text |
Driver failed to apply the filter policy to or refresh the filter policy on interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
FILTER/5/FLT_DRV_SET_POLICY_FAIL: Driver failed to apply the filter policy to or refresh the filter policy on interface Ethernet1/0/1. |
Explanation |
N/A N/A |
Message text |
Driver failed to delete the filter policy on interface [STRING]. |
Variable fields |
Severity level |
5 |
Example |
FILTER/5/FLT_DRV_DEL_POLICY_FAIL: Driver failed to delete the filter policy on interface Ethernet1/0/1. |
Explanation |
N/A |
This section contains the entire system log messages related to FLT6.
Message text |
Failed to apply the filter policy to or refresh the filter policy on interface [STRING].Not supported. |
Variable fields |
Severity level |
5 |
Example |
FLT6/5/FLT6_SET_POLICY_NOTSUPPORT_FAIL: Failed to apply the filter policy to or refresh the filter policy on interface Ethernet1/0/1.Not supported. |
Explanation |
N/A |
Check the configure of FLT6. |
This section contains the entire system log messages related to FTP Daemon.
Message text |
User [STRING] ([IPADDR]) has logged in successfully. |
Variable fields |
$1: User name. $2: Source IP address of the FTP client. |
Severity level |
5 |
Example |
FTPD/5/FTPD_LOGIN: User ftpuser (192.168.0.99) has logged in successfully. |
Explanation |
An FTP user has logged in successfully. |
Message text |
User [STRING]([IPADDR]) logged out. |
Variable fields |
$1: User name. $2: Source IP address of FTP client. |
Severity level |
5 |
Example |
FTPD/5/FTPD_LOGOUT: User ftpuser (192.168.0.99) logged out. |
Explanation |
An FTP user has logged out. |
Message text |
User [STRING] ([IPADDR]) failed to log in. |
Variable fields |
Severity level |
5 |
Example |
FTPD/5/FTPD_LOGIN_FAILED: User ftpuser (192.168.0.99) failed to log in. |
Explanation |
An FTP user failed to log in. |
Message text |
User [STRING] ([IPADDR]) request: [STRING]. |
Variable fields |
$1: User name. $2: Source IP address of FTP client. $3: Request command of FTP client. |
Severity level |
6 |
Example |
FTPD/6/FTPD_REQUEST: User ftpuser (192.168.0.99) request: PORT 192,168,0,99,18,162. |
Explanation |
An FTP client sent a request to the server. |
Message text |
FTP server has sent [ULONG] bytes to client [STRING] ([IPADDR]). |
Variable fields |
$1: File length transferred. $2: User name. $3: Source IP address of FTP client. |
Severity level |
5 |
Example |
FTPD/5/FTPD_SEND: FTP server has sent 16045 bytes to client ftpuser (192.168.0.99). |
Explanation |
An FTP client has gotten a file successfully. |
Message text |
FTP server has received [ULONG] bytes from client [STRING] ([IPADDR]). |
Variable fields |
Severity level |
5 |
Example |
FTPD/5/FTPD_RECEIVE: FTP server has received 16045 bytes from client ftpuser (192.168.0.99). |
Explanation |
An FTP client has put a file successfully. |
Message text |
FTP server completed in writing a file. |
Variable fields |
N/A |
Severity level |
5 |
Example |
FTPD/5/FTPD_WRITE_FINISHED: FTP server completed in writing a file. |
Explanation |
A file was written to the file system successfully. |
Message text |
User [STRING] ([IPADDR]) failed to put a file. |
Variable fields |
Severity level |
5 |
Example |
FTPD/5/FTPD_TRANSFER_FAILED: User ftpuser (192.168.0.99) failed to put a file. |
Explanation |
The FTP client failed to put a file to the FTP server. |
Check network connection. |
Message text |
FTP server failed to write a file. |
Variable fields |
N/A |
Severity level |
4 |
Example |
FTPD/4/FTPD_WRITE_FAILED: FTP server failed to write a file. |
Explanation |
Failed to write a file to the file system. |
Check the file system. |
This section contains the entire system log messages related to SNMP.
Message text |
System restarted --\r\n[STRING] Software. |
Variable fields |
$1: Software name. |
Severity level |
6 |
Example |
IC/6/SYS_RESTART: System restarted --\r\nComware Software. |
Explanation |
System started and ready to send syslog. |
This section contains the entire system log messages related to IFNET.
Message text |
Line protocol on the interface [STRING] is [STRING]. |
Variable fields |
$1: The name of interface. $2: The status of line protocol. |
Severity level |
5 |
Example |
IFNET/5/LINEPROTO_UPDOWN: Line protocol on the interface Vlan-interface1is DOWN. |
Explanation |
The status of line protocol has been changed on an interface. |
Message text |
Protocol [STRING] on the interface [STRING] is [STRING]. |
Variable fields |
$1: The name of protocol. $2: The name of interface. $3: The status of protocol. |
Severity level |
5 |
Example |
IFNET/5/PROTOCOL_UPDOWN: Protocol IPX on the interface Vlan-interface1 is UP |
Explanation |
The status of protocol has been changed on an interface. |
Message text |
[STRING]: link status is [STRING]. |
Variable fields |
$1: The name of interface. $2: The link status |
Severity level |
3 |
Example |
IFNET/3/LINK_UPDOWN: Ethernet1/0/1 link status is DOWN. |
Explanation |
The link status has been changed on an interface. |
This section contains the entire system log messages related to LAGG.
Message text |
Member port [STRING] of aggregation group [STRING] becomes INACTIVE because the current number of active ports has reached the upper limit. |
Variable fields |
$1: Port name $2: Link aggregation group type and ID |
Severity level |
5 |
Example |
LAGG/5/LAGG_INACTIVE_UPPER_LIMIT: Member port GigabitEthernet1/0/25 of aggregation group BAGG1 becomes INACTIVE because the current number of active ports has reached the upper limit. |
Explanation |
The status of some member port(s) in an aggregation group becomes inactive because the number of current active ports has reached the upper limit. |
Message text |
Member port [STRING] of aggregation group [STRING] becomes INACTIVE because all aggregation resources are already in-use. |
Variable fields |
Severity level |
5 |
Example |
LAGG/5/LAGG_INACTIVE_RESOURCE_INSUFFICIE: Member port GigabitEthernet1/0/25 of aggregation group BAGG1 becomes INACTIVE because all aggregation resources are already in-use. |
Explanation |
The status of some member port(s) in an aggregation group becomes inactive because all aggregation resources are already in-use. |
Message text |
Member port [STRING] of aggregation group [STRING] becomes INACTIVE because the port's configuration is improper for being attached. |
Variable fields |
Severity level |
5 |
Example |
LAGG/5/LAGG_INACTIVE_CONFIGURATION: Member port GigabitEthernet1/0/25 of aggregation group BAGG1 becomes INACTIVE because the port's configuration is improper for being attached. |
Explanation |
The status of some member port(s) in an aggregation group becomes inactive because the configuration of the port(s) is improper for being attached. |
Modify the configuration of the member port(s) to be consistent with that of the aggregation interface. |
Message text |
Member port [STRING] of aggregation group [STRING] becomes INACTIVE because the port's partner is improper for being attached. |
Variable fields |
Severity level |
5 |
Example |
LAGG/5/LAGG_INACTIVE_PARTNER: Member port GigabitEthernet1/0/25 of aggregation group BAGG1 becomes INACTIVE because the port's partner is improper for being attached. |
Explanation |
Status of some member port(s) in an aggregation group becomes inactive because the port's partner is improper for being attached. |
Change the status of the partner to active. |
Message text |
Member port [STRING] of aggregation group [STRING] becomes INACTIVE because the number of current active ports has not reached the lower limit. |
Variable fields |
Severity level |
5 |
Example |
LAGG/5/LAGG_INACTIVE_LOWER_LIMIT: Member port GigabitEthernet1/0/25 of aggregation group BAGG1 becomes INACTIVE because the number of current active ports has not reached the lower limit. |
Explanation |
Status of some member port(s) in an aggregation group becomes inactive because the number of current active ports has not reached the lower limit according to the aggregation interface’s configuration. |
Make more member ports to be active. |
Message text |
Member port [STRING] of aggregation group [STRING] becomes INACTIVE because the port's physical state (down) is improper for being attached. |
Variable fields |
Severity level |
5 |
Example |
LAGG/5/LAGG_INACTIVE_PHYSTATE: Member port Ethernet1/0/1 of aggregation group BAGG1 becomes INACTIVE because the port's physical state (down) is improper for being attached. |
Explanation |
The status of a member port in an aggregation group becomes inactive because the port's physical state (down) is improper for being attached. |
Change the physical state of the port to up. |
Message text |
Member port Ethernet1/0/1 of aggregation group BAGG1 becomes INACTIVE because the port's hardware restriction is improper for being attached. |
Variable fields |
Severity level |
5 |
Example |
LAGG/5/LAGG_INACTIVE_HARDWARE_VALUE: Member port Ethernet1/0/1 of aggregation group BAGG1 becomes INACTIVE because the port's hardware restriction is improper for being attached. |
Explanation |
The status of a member port in an aggregation group becomes inactive because the port's hardware restriction is improper for being attached. |
Message text |
Member port Ethernet1/0/1 of aggregation group BAGG1 becomes INACTIVE because the port's speed is improper for being attached. |
Variable fields |
Severity level |
5 |
Example |
LAGG/5/LAGG_INACTIVE_SPEED: Member port Ethernet1/0/1 of aggregation group BAGG1 becomes INACTIVE because the port's speed is improper for being attached. |
Explanation |
The status of a member port in an aggregation group becomes inactive because the port's speed is improper for being attached. |
Modify the speed of the member port(s) to be consistent with that of the active port(s). |
Message text |
Member port Ethernet1/0/1 of aggregation group BAGG1 becomes INACTIVE because the port's duplex mode is improper for being attached. |
Variable fields |
Severity level |
5 |
Example |
LAGG/5/LAGG_INACTIVE_DUPLEX: Member port Ethernet1/0/1 of aggregation group BAGG1 becomes INACTIVE because the port's duplex mode is improper for being attached. |
Explanation |
The status of a member port in an aggregation group becomes inactive because the port's duplex mode is improper for being attached. |
Modify the duplex mode of the member port(s) to be consistent with that of the active port(s). |
This section contains all the system log messages related to LLDP.
Message text |
New neighbor created on Port [STRING] (IfIndex [ULONG]), Chassis ID is [STRING], Port ID is [STRING]. |
Variable fields |
$1: Port name $2: Port ifIndex $3: The neighbor’s chassis ID $4: The neighbor’s port ID |
Severity level |
6 |
Example |
LLDP/6/LLDP_CREATE_NEIGHBOR: New neighbor created on Port 1 (IfIndex 587599), Chassis ID is 00-E0-10-6C-C3-E3, Port ID is Ethernet 1/0/1. |
Explanation |
The port discovers a new neighbor. |
Message text |
Neighbor deleted on Port [STRING] (IfIndex [ULONG]), Chassis ID is [STRING], Port ID is [STRING]. |
Variable fields |
Severity level |
6 |
Example |
LLDP/6/LLDP_DELETE_NEIGHBOR: Neighbor deleted on Port 1 (IfIndex 587599), Chassis ID is 00-E0-10-6C-C3-E3, Port ID is Ethernet 1/0/1. |
Explanation |
A neighbor is shut down. |
Message text |
Neighbor aged out on Port [STRING] (IfIndex [ULONG]), Chassis ID is [STRING], Port ID is [STRING]. |
Variable fields |
Severity level |
5 |
Example |
LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Neighbor age out on Port 1 (IfIndex 587599), Chassis ID is 00-E0-10-6C-C3-E3, Port ID is Ethernet 1/0/1. |
Explanation |
A neighbor had aged out. |
Check the link status or the receive/transmit status of LLDP on the peer. |
Message text |
The number of neighbors maintained by the port [STRING] (IfIndex [ULONG]) has reached [ULONG], and no more neighbors can be added. |
Variable fields |
$1: Port name $2: Port ifIndex $3: The maximum number of neighbors a port can maintain |
Severity level |
5 |
Example |
LLDP/5/LLDP_REACH_NEIGHBOR_LIMIT: The number of neighbors maintained by port 1 (IfIndex 587599) has reached 16, and no more neighbors can be added. |
Explanation |
The port received too many LLDP messages. |
Message text |
The number of neighbors maintained by port [STRING] (IfIndex [ULONG]) is less than [ULONG], and new neighbors can be added. |
Variable fields |
$1: Port name $2: Port ifIndex $3: The max number of neighbor that a port can maintain. |
Severity level |
6 |
Example |
LLDP/6/LLDP_LESS_THAN_NEIGHBOR_LIMIT: The number of neighbors maintained by port 1 (IfIndex 587599) is less than 16, and new neighbors can be added. |
Explanation |
The port has not received too many LLDP messages. |
This section contains the entire system log messages related to LPDETECT.
Message text |
Loopback exists on [STRING] and this interface is blocked. |
Variable fields |
$1: Interface name. |
Severity level |
5 |
Example |
LPDETECT/5/LPDETECT_BLOCK: Loopback exists on Ethernet1/0/1 and this interface is blocked. |
Explanation |
Loopback exists on the interface and this interface is blocked. |
Eliminate the loopback on the interface. |
Message text |
Loopback exists on [STRING] and this interface is shut down. |
Variable fields |
Severity level |
5 |
Example |
LPDETECT/5/LPDETECT_SHUTDOWN: Loopback exists on Ethernet1/0/1 and this interface is shut down. |
Explanation |
Loopback exists on the interface and this interface is shut down. |
Message text |
Loopback exists on [STRING]. |
Variable fields |
Loopback exists on the interface |
Severity level |
5 |
Example |
LPDETECT/5/LPDETECT_LOOPBACKED: Loopback exists on Ethernet1/0/1. |
Explanation |
Loopback exists on the interface. |
Message text |
Loopback on [STRING] recovered. |
Variable fields |
Severity level |
5 |
Example |
LPDETECT/5/LPDETECT_RECOVERED: Loopback on Ethernet1/0/1 recovered. |
Explanation |
Loopback on the interface is eliminated. |
This section contains the entire system log messages related to LS.
Message text |
-AccessType=[STRING]-UserName=[STRING]; Authentication is failed. [STRING] |
Variable fields |
$1:AccessType $2:Username $3: Reason of failure: “User not found.” “Password verified failed.” “User not active.” “User expired.” “Access type mismatch.” “Binding attribute is failed.” |
Severity level |
5 |
Example |
LS/5/LS_AUTHEN_FAILURE: - AccessType=Login -UserName=cwf@system;Authentication is failed. User not found. |
Explanation |
A user’s authentication request is rejected by local. |
Message text |
-AccessType=[STRING]-UserName=[STRING]; Authorization is failed. [STRING] |
Variable fields |
$1:AccessType $2:Username $3: Reason of failure: “User not found.” “User not active.” “Privilege level mistach.” |
Severity level |
5 |
Example |
LS/5/LS_AUTHOR_FAILURE: - AccessType=Login-UserName=cwf@system;Authorizaton is failed. User not found. |
Explanation |
A user’s authorization request is rejected by local. |
Message text |
-AccessType=[STRING]-UserName=[STRING]; Accounting is failed. [STRING] |
Variable fields |
$1:AccessType $2:Username $3: Reason of failure: “User not active.” “Concurrent access limitation.” |
Severity level |
5 |
Example |
LS/5/LS_AUTHOR_FAILURE: - AccessType=Login -UserName=cwf@system;Accounting is failed. Concurrent access limitation. |
Explanation |
This section contains the entire system log messages related to MAC.
Message text |
Variable fields |
N/A |
Severity level |
5 |
Example |
MAC/5/MAC_TABLE_FULL: MAC address table is full. |
Explanation |
Message text |
-Action=[STRING]-MacAddr=[STRING]-VlanID=[ULONG]-MACType=[ULONG]-IfName=[STRING]; MAC address table changed. |
Variable fields |
$1: Added or Deleted. $2: MAC address. $3: Vlan ID. $4: MAC address type. $5: Interface name. |
Severity level |
6 |
Example |
MAC/6/MAC_INFORMATION:-Action=Added-MacAddr=0000-0000-0001-VlanID=2-MACType=4-IfName=GigabitEthernet1/0/25; MAC address table changed. |
Explanation |
The MAC address table has changed. |
Message text |
MAC address table exceeded maximum number [ULONG]. |
Variable fields |
$1: Max MAC address number. |
Severity level |
5 |
Example |
MAC/5/MAC_TABLE_FULL_GLOBAL: MAC address table exceeded maximum number 2. |
Explanation |
The global MAC address table exceeded maximum number. |
Message text |
MAC address table exceeded maximum number [ULONG] on interface [STRING]. |
Variable fields |
$1: Max MAC address number. $2: Interface name. |
Severity level |
5 |
Example |
MAC/5/MAC_TABLE_FULL_PORT: MAC address table exceeded maximum number 2 on interface GigabitEthernet1/0/25. |
Explanation |
MAC address table on interface exceeded maximum number. |
Message text |
MAC address table exceeded maximum number [ULONG] on Vlan [ULONG]. |
Variable fields |
$1: Max MAC address number. $2: Vlan ID. |
Severity level |
5 |
Example |
MAC/5/MAC_TABLE_FULL_VLAN: MAC address table exceeded maximum number 2 on Vlan 2. |
Explanation |
MAC address table on Vlan exceeded maximum number. |
This section contains all system log messages related to MFW.
Message text |
Failed to download information to driver, cause: [STRING]. |
Variable fields |
$1: the reason for downloading to driver failure, include: invalid configuration parameter; configuration entry already exists; configuration is not supported; no enough system resource; configuration parameter is out of range; hardware resource is not ready; no enough hardware resource. |
Severity level |
3 |
Example |
MFW/3/MFW_DRV_DOWN: Failed to download information to driver, cause: invalid configuration parameter. |
Explanation |
Failed to download information to driver. |
Notify operator to check configuration and network. |
This section contains all the system log messages related to MSTP.
Message text |
STP is now enabled on the device. |
Variable fields |
N/A |
Severity level |
6 |
Example |
MSTP/6/MSTP_ENABLE: STP is now enabled on the device. |
Explanation |
STP is enabled. |
Message text |
STP is now disabled on the device. |
Variable fields |
N/A |
Severity level |
6 |
Example |
MSTP/6/MSTP_DISABLE: STP is now disabled on the device. |
Explanation |
STP is disabled. |
Message text |
[STRING] [ULONG]'s port [STRING] has been set to forwarding state. |
Variable fields |
$1: “Instance” or “VLAN” $2: Instance ID or VLAN ID $3: Interface name |
Severity level |
6 |
Example |
MSTP/6/MSTP_FORWARDING: Instance 0's port Ethernet 1/0/2 has been set to forwarding state. MSTP/6/MSTP_FORWARDING: VLAN 10's port Ethernet 1/0/2 has been set to forwarding state. |
Explanation |
A certain port of the instance or VLAN is in forwarding state. MSTP calculates the state of the ports within the instance. |
Message text |
[STRING] [ULONG]'s port [STRING] has been set to discarding state. |
Variable fields |
Severity level |
6 |
Example |
MSTP/6/MSTP_DISCARDING: Instance 0's port Ethernet 1/0/2 has been set to discarding state. MSTP/6/MSTP_DISCARDING: VLAN 10's port Ethernet 1/0/2 has been set to discarding state. |
Explanation |
A certain port of the instance or VLAN is in discarding state. |
Message text |
The current switch is no longer the root of [STRING] [ULONG]. |
Variable fields |
$1: “instance” or “VLAN” $2: Instance ID or VLAN ID |
Severity level |
5 |
Example |
MSTP/5/MSTP_NOT_ROOT: The current switch is no longer the root of instance 0. MSTP/5/MSTP_NOT_ROOT: The current switch is no longer the root of VLAN 10. |
Explanation |
The current switch is not the root of an instance or a VLAN. |
Check the bridge priority configuration and possible attacks from other devices. |
Message text |
BPDU-Protection port [STRING] received BPDUs. |
Variable fields |
$1: Interface name |
Severity level |
4 |
Example |
MSTP/4/MSTP_BPDU_PROTECTION: BPDU-Protection port Ethernet 1/0/4 received BPDUs. |
Explanation |
A BPDU-Protection port received BPDUs. |
Check whether the downstream devices are terminals and check for possible attacks from other devices. |
Message text |
[STRING] [ULONG]'s ROOT-Protection port [STRING] received superior BPDUs. |
Variable fields |
Severity level |
4 |
Example |
MSTP/4/MSTP_ROOT_PROTECTION: Instance 0's ROOT-Protection port Ethernet 1/0/2 received superior BPDUs. MSTP/4/MSTP_ROOT_PROTECTION: VLAN 10's ROOT-Protection port Ethernet 1/0/2 received superior BPDUs. |
Explanation |
A ROOT-Protection port received superior BPDUs. |
Recommended action |
Message text |
[STRING] [ULONG]'s LOOP-Protection port [STRING] failed to receive configuration BPDUs. |
Variable fields |
Severity level |
4 |
Example |
MSTP/4/MSTP_LOOP_PROTECTION: Instance 0's LOOP-Protection port Ethernet 1/0/2 failed to receive configuration BPDUs. MSTP/4/MSTP_LOOP_PROTECTION: VLAN 10's LOOP-Protection port Ethernet 1/0/2 failed to receive configuration BPDUs. |
Explanation |
A LOOP-Protection port failed to receive configuration BPDUs. |
Check the STP status of the upstream device and possible attacks from other devices. |
Message text |
Port [STRING] received MSTP BPDUs of different formats continually. Shut it down in order to prevent broadcast. |
Variable fields |
Severity level |
4 |
Example |
MSTP/4/MSTP_BPDU_FORMAT_ERROR: Port Ethernet 1/0/1 received MSTP BPDUs of different formats continually. Shut it down in order to prevent broadcast. |
Explanation |
A port received MSTP BPDUs of different formats continually. |
Check the MSTP format configuration of other devices. |
Message text |
Port [STRING] received MSTP BPDUs of a different format than the configured one. Please change your MSTP BPDU format configuration. |
Variable fields |
Severity level |
4 |
Example |
MSTP/4/MSTP_BPDU_FORMAT_CONFIG_ERROR: Port Ethernet 1/0/1 received MSTP BPDUs of a different format than the configured one. Please change your MSTP BPDU format configuration. |
Explanation |
A port received MSTP BPDUs of a different format than the configured one. |
Check the MSTP BPDU format configuration of the current device. |
Message text |
Port [STRING] received MSTP BPDUs of the same format as the configured one. |
Variable fields |
Severity level |
5 |
Example |
MSTP/5/MSTP_BPDU_FORMAT_CONFIG_RIGHT: Port Ethernet 1/0/1 received MSTP BPDUs of the same format as the configured one. |
Explanation |
A port received MSTP BPDUs of the same format as the configured one. |
No action is required. |
Message text |
[STRING] [ULONG]'s port [STRING] received no BPDU within the rcvdInfoWhile interval. Information of the port aged out. |
Variable fields |
Severity level |
5 |
Example |
MSTP/5/MSTP_BPDU_RECEIVE_EXPIRY: Instance 0's port GigabitEthernet 1/0/25 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out. |
Explanation |
When a non-designated port received no BPDU within the rcvdInfoWhile interval, information of the port ages out. |
Message text |
[STRING] [ULONG]'s port [STRING] was notified of a topology change. |
Variable fields |
Severity level |
6 |
Example |
MSTP/6/MSTP_NOTIFIED_TC: Instance 0's port GigabitEthernet 1/0/25 was notified of a topology change. |
Explanation |
The instance or VLAN to which the port belongs has a topology change. |
Check whether the topology change is normal. |
Message text |
[STRING] [ULONG]'s port [STRING] detected a topology change. |
Variable fields |
Severity level |
6 |
Example |
MSTP/6/MSTP_DETECTED_TC: Instance 0's port GigabitEthernet 1/0/25 detected a topology change. |
Explanation |
The MSTP instance or VLAN to which the port belongs has a topology change. |
Message text |
[STRING] [ULONG]'s port [STRING] received BPDUs from an access port. Inconsistent port type. |
Variable fields |
$1: “VLAN” $2: VLAN ID $3: Interface name |
Severity level |
6 |
Example |
MSTP/6/MSTP_PORT_TYPE_PROTECTION: VLAN 10's port GigabitEthernet 1/0/25 received BPDU from an access port. Inconsistent port type. |
Explanation |
An access port received a PVST PDU. |
Check that port type configuration is correct. |
Message text |
[STRING] [ULONG]'s port [STRING] received BPDUs with inconsistent peer VLAN ID [STRING]. Inconsistent local VLAN. |
Variable fields |
$1: “VLAN” $2: VLAN ID $3: Interface name $4: VLAN ID |
Severity level |
6 |
Example |
MSTP/6/MSTP_PVID_PROTECTION: VLAN 10's port GigabitEthernet 1/0/25 received BPDUs with inconsistent peer VLAN ID 20. Inconsistent local VLAN. |
Explanation |
A non-access port received a PVST PDU with an inconsistent peer VLAN ID. |
Check that port PVID configuration is correct. |
Message text |
[STRING] [ULONG]'s port [STRING] consistency restored. |
Variable fields |
Severity level |
6 |
Example |
MSTP/6/MSTP_PVID_PROTECTION: VLAN 10's port GigabitEthernet 1/0/25 consistency restored. |
Explanation |
Port type or PVID protection is invalid. |
This section contains the entire system log messages related to ND.
Message text |
[STRING] is not consistent. |
Variable fields |
$1: Type of configuration. |
Severity level |
5 |
Example |
ND/5/ND_CONFIG_CONFLICT: PREFIX VALID TIME is not consistent. |
Explanation |
Configurations on the two routers are different. |
Check device’s configuration. |
Message text |
Duplicated address: [STRING] on interface [STRING]. |
Variable fields |
$1: Address that is to be assigned to an interface. $2: Name of the interface. |
Severity level |
5 |
Example |
ND/5/ND_DUPADDR: Duplicated address: 33::8 on interface Vlan-interface9. |
Explanation |
The address that was to be assigned to the interfaces is already used by another device. |
Assign a different address to the interface. |
Message text |
Preferred lifetime is greater than the valid lifetime of prefix [STRING]. |
Variable fields |
$1: IPv6 prefix. |
Severity level |
5 |
Example |
ND/5/ND_LIFETIME_ERROR: Preferred lifetime is greater than the valid lifetime of prefix 10::. |
Explanation |
The preferred lifetime is greater than the valid lifetime of the prefix information of RA received when address autoconfiguration is enabled. |
Message text |
IPv6 address [STRING] conflicts with route [STRING]. |
Variable fields |
$1: IPv6 address. $2: If "on VPN instance instance-name" is displayed, the log indicates there is a route conflict in the specified VPN. Typically, this field is not displayed because IPv6 does not support VPN. |
Severity level |
6 |
Example |
ND/5/ND_ROUTECONFLICT: IPv6 address 100::1 conflicts with route. |
Explanation |
The driver returned route conflict when an ND entry was added to the driver. |
Message text |
Failed to add a rule because [STRING] on interface [STRING]. |
Variable fields |
Severity level |
4 |
Example |
ND/4/ND_SETRULE_FAILED: Failed to add a rule because no enough resource on interface GigabitEthernet1/0/25. |
Explanation |
Failed to add a rule to driver. |
This section contains the entire system log messages related to NTP.
Message text |
System Leap Indicator changed from [ULONG] to [ULONG] after clock update. |
Variable fields |
$1: Original Leap Indicator. $2: Current Leap Indicator. |
Severity level |
5 |
Example |
NTP/5/NTP_CHANGE_LEAP: System Leap Indicator changed from 00 to 01 after clock update. |
Explanation |
NTP Leap Indicator is a two-bit code warning of an impending leap second to be inserted in the NTP timescale. The bits are set before 23:59 on the day of insertion and reset after 00:00 on the following day. This causes the number of seconds (rolloverinterval) in the day of insertion to be increased or decreased by one. |
Message text |
System stratum changed from [ULONG] to [ULONG] after clock update. |
Variable fields |
$1: Original stratum. $2: Current stratum. |
Severity level |
5 |
Example |
NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 6 to 5 after clock update. |
Explanation |
System stratum has changed. |
Message text |
System synchronization source lost. |
Variable fields |
N/A |
Severity level |
5 |
Example |
NTP/5/NTP_SOURCE_LOST: System synchronization source lost. |
Explanation |
Check NTP server and network connection. |
Message text |
Too many peers. |
Variable fields |
N/A |
Severity level |
6 |
Example |
NTP/5/NTP_TOO_MANY_PEERS: Too many peers. |
Explanation |
The maximum number of NTP associations has been reached. |
This section contains the entire system log messages related to OPTMOD.
Message text |
[STRING]: The transceiver is absent. |
Variable fields |
$1: A port name |
Severity level |
4 |
Example |
OPTMOD/4/MODULE_OUT: GigabitEthernet1/0/26: The transceiver is absent. |
Explanation |
The transceiver is plugged out. |
Message text |
[STRING]: The transceiver is [STRING]. |
Variable fields |
$1: A port name $2: The type string of the module. |
Severity level |
4 |
Example |
OPTMOD/4/MODULE_IN: GigabitEthernet1/0/25: The transceiver is 1000_BASE_T_AN_SFP. |
Explanation |
The transceiver is plugged in, it’s type is 1000_BASE_BX_U_SFP. |
This section contains the entire system log messages related to OSPF.
Message text |
OSPF [ULONG] [STRING] route limit reached. |
Variable fields |
$1:OSPF Process ID $2:Route Type (intra area ,inter area or AS external) |
Severity level |
4 |
Example |
OSPF/4/OSPF_RT_LMT: OSPF 1 AS External route limit reached. |
Explanation |
OSPF routes reach limit. |
Please check OSPF routes and modify OSPF configuration to make routes under the limit. |
Message text |
OSPF [ULONG] New router ID elected, please restart OSPF if you want to make the new router ID take effect. |
Variable fields |
$1: OSPF Process ID |
Severity level |
5 |
Example |
OSPF/5/OSPF_RTRID_CHG: OSPF 1 New router ID elected, please restart OSPF if you want to make the new router ID take effect. |
Explanation |
When OSPF Router ID is changed, user must restart OSPF manually in order to make the new Router ID take effect. |
Please use “reset ospf process” command to make the new Router ID take effect. |
Message text |
OSPF [ULONG] Neighbor [STRING] ([STRING]) from [STRING] to [STRING] |
Variable fields |
$1:OSPF Process ID $2:Neighbor IP Address $3:Interface Name $4:Old Neighbor State $5:New Neighbor State |
Severity level |
5 |
Example |
OSPF/5/OSPF_NBR_CHG: OSPF 1 Neighbor 2.2.2.2 (Vlan-interface100) from Full to Down. |
Explanation |
An important neighbor state change event occurs. |
When neighbor state change from Full to other state, please check OSPF configuration and network status. |
Message text |
OSPF [ULONG] Router ID changed, re-configure Vlink on peer |
Variable fields |
Severity level |
5 |
Example |
OSPF/5/OSPF_VLINKID_CHG:OSPF 1 Router ID changed, re-configure Vlink on peer |
Explanation |
When new OSPF Router ID takes effect, user should check and modify Vlink configuration on peer router according to new Router ID. |
Please check and modify Vlink configuration on peer router according to new Router ID. |
Message text |
OSPF [ULONG] Last neighbor down event: Router ID: [STRING] Local address: [STRING] Remote address: [STRING] Reason: [STRING] |
Variable fields |
$1:OSPF Process ID $2:Router ID $3:Local IP Address $4:Neighbor IP Address $5:Reason |
Severity level |
6 |
Example |
OSPF/6/OSPF_LAST_NBR_DOWN: OSPF 1 Last neighbor down event: Router ID: 2.2.2.2 Local address: 10.1.1.1 Remote address: 10.1.1.2 Reason: Dead Interval timer expired. |
Explanation |
Record last OSPF neighbor down event. |
Please check the reason of last OSPF neighbor down event. |
This section contains the entire system log messages related to PING.
Message text |
PING/6/PING_LOG: [IPADDR] ping statistics: [ULONG] packet(s) transmitted; [ULONG] packet(s) received; [ULONG] duplicates; Somebody's printing up packets; packet loss: [ULONG]%; round-trip min/avg/max = [ULONG]/[ULONG]/[ULONG] ms. |
Variable fields |
$1: IP address. $2: packet(s) transmitted number. $3: packet(s) received number. $4: packet(s) duplicates number $5: The percentage of lost packet. $6: minimal time cost by round-trip. $7: average time cost by round-trip. $8: maximal time cost by round-trip. |
Severity level |
6 |
Example |
PING/6/PING_LOG: 192.168.0.115 ping statistics: 5 packet(s) transmitted; 5 packet(s) received; packet loss: 0.00%; round-trip min/avg/max = 1/5/24 ms. |
Explanation |
The result of the ping. |
If there is no packet received, please check wether the interface is down which causes missing of its route in the routing table, or the destination can be reached, |
This section contains the entire system log messages related to IPv6 PING.
Message text |
PING6/6/PING6_LOG: [IPv6ADDR] ping statistics: [ULONG] packet(s) transmitted; [ULONG] packet(s) received; [ULONG] duplicates; Somebody's printing up packets; packet loss: [ULONG]%; round-trip min/avg/max = [ULONG]/[ULONG]/[ULONG] ms. |
Variable fields |
$1: IPv6 address. $2: packet(s) transmitted number. $3: packet(s) received number. $4: packet(s) duplicates number $5: The percentage of lost packet. $6: minimal time cost by round-trip. $7: average time cost by round-trip. $8: maximal time cost by round-trip. |
Severity level |
6 |
Example |
PING6/6/PING6_LOG: 2000::2 ping statistics: 5 packet(s) transmitted; 5 packet(s) received; packet loss: 0.00%; round-trip min/avg/max = 1/8/38 ms. |
Explanation |
The result of the IPv6 ping. |
This section contains the entire system log messages related to PKEY.
Message text |
Failed to backup the host key pair. |
Variable fields |
N/A |
Severity level |
4 |
Example |
PKEY/4/PKEY_HOST_KEY_BACKUP_FAIL: Failed to backup the host key pair. |
Explanation |
Check the status of the device, such as the CPU usage, memory usage, and storage. |
Message text |
Failed to backup the server key pair. |
Variable fields |
N/A |
Severity level |
4 |
Example |
PKEY/4/PKEY_SERVER_KEY_BACKUP_FAIL: Failed to backup the server key pair. |
Explanation |
Message text |
Exported public key to file successfully. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKEY/6/ PKEY_EXPORT_PKEY_SUCC: Exported public key to file successfully. |
Explanation |
Exported the public key to a file successfully. |
Message text |
Failed to export public key to file. |
Variable fields |
N/A |
Severity level |
4 |
Example |
PKEY/4/PKEY_EXPORT_PKEY_FAIL: Failed to export public key to file. |
Explanation |
Failed to export the public key to a file. |
Check if there is something wrong with the Flash or CF card. |
Message text |
Created the host key pair successfully. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKEY/6/PKEY_CREATE_HOST_KEY_SUCC: Created the host key pair successfully. |
Explanation |
Message text |
Created server key pair successfully. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKEY/6/PKEY_CREATE_SERVER_KEY_SUCC: Created server key pair successfully. |
Explanation |
Created the server key pair successfully. |
Message text |
Failed to create the key pair(s). |
Variable fields |
N/A |
Severity level |
4 |
Example |
PKEY/4/PKEY_CREATE_LOCAL_KEY_FAIL: Failed to create the key pair(s). |
Explanation |
Create encryption key failure. |
Message text |
Destroyed the host key pair successfully. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKEY/6/PKEY_DESTORY_HOST_KEY_SUCC: Destroyed the host key pair successfully. |
Explanation |
Message text |
Destroyed the server key pair successfully. |
Variable fields |
N/A |
Severity level |
6 |
Example |
PKEY/6/PKEY_DESTORY_SERVER_KEY_SUCC: Destroyed the server key pair successfully. |
Explanation |
Message text |
Failed to destroy the key pair(s). |
Variable fields |
N/A |
Severity level |
4 |
Example |
PKEY/4/PKEY_DESTORY_LOCAL_KEY_FAIL: Failed to destroy the key pair(s). |
Explanation |
Destroy encryption key failure. |
This section contains the entire system log messages related to POE.
Message text |
PSE [ULONG]: PSE power supply failed because of fan failure. |
Variable fields |
$1: PSE index |
Severity level |
4 |
Example |
POE/4/PSE_STATUS: PSE 1: PSE power supply failed because of fan failure. |
Explanation |
Clear fan failure. |
Message text |
PSE [ULONG]: PSE power supply recovered because fan failure was cleared. |
Variable fields |
$1: PSE index |
Severity level |
4 |
Example |
POE/4/PSE_STATUS: PSE 1: PSE power supply recovered because fan failure was cleared. |
Explanation |
Message text |
PSE [ULONG]: Upgrade for PSE firmware is proceeding. |
Variable fields |
$1: PSE index. |
Severity level |
4 |
Example |
POE/4/PSE_STATUS: PSE 1: Upgrade for PSE firmware is proceeding. |
Explanation |
PSE firmware was being upgraded. |
Message text |
PSE [ULONG]: PSE firmware upgraded successfully. |
Variable fields |
$1: PSE index |
Severity level |
4 |
Example |
POE/4/PSE_STATUS: PSE 1: PSE firmware upgraded successfully. |
Explanation |
PSE firmware was upgraded successfully from the CLI. |
Message text |
PSE [ULONG]: The device will automatically reboot since the PSE firmware upgraded successfully. |
Variable fields |
$1: PSE index |
Severity level |
4 |
Example |
POE/4/PSE_STATUS: PSE 1: The device will automatically reboot since the PSE firmware upgraded successfully. |
Explanation |
PSE firmware was automatically upgraded. |
Message text |
PSE [ULONG]: Failed to upgrade PSE firmware. |
Variable fields |
$1: PSE index |
Severity level |
4 |
Example |
POE/4/PSE_STATUS: PSE 1: Failed to upgrade PSE firmware. |
Explanation |
PSE firmware failed to be upgraded. |
Try to upgrade PSE firmware again. |
Message text |
PSE [ULONG]: Failed to upgrade PSE firmware and PSE will not operate correctly. |
Variable fields |
$1: PSE index |
Severity level |
4 |
Example |
POE/4/PSE_STATUS: PSE 1: Failed to upgrade PSE firmware and PSE will not operate correctly. |
Explanation |
This section contains the entire system log messages related to PORTSEC.
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANId=[INTEGER]; A new MAC address learned. |
Variable fields |
$1: Interface type and number $2: MAC address $3: VLAN ID |
Severity level |
6 |
Example |
PORTSEC/6/PORTSEC_LEARNED_MACADDR: -IfName=Ethernet1/0/1-MACAddr=00:11:43:C5:4B:23-VLANId=1; A new MAC address learned. |
Explanation |
A new MAC address has been learned. |
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANId=-[INTEGER]-IfStatus=[STRING]; Intrusion detected. |
Variable fields |
$1: Interface type and number $2: MAC address $3: VLAN ID $4: Interface status, up or down |
Severity level |
5 |
Example |
PORTSEC/5/PORTSEC_VIOLATION: -IfName=Ethernet1/0/1-MAC Addr=00:11:43:C5:4B:23-VLANId=1-IfStatus=Up; Intrusion detected. |
Explanation |
An intrusion was detected. |
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANId=[INTEGER]-UserName=[STRING]; The user failed the 802.1X authentication. |
Variable fields |
$1: Interface type and number $2: MAC address $3: VLAN ID $4: Username |
Severity level |
6 |
Example |
PORTSEC/6/PORTSEC_DOT1X_LOGIN_FAILURE: -IfName=Ethernet1/0/1-MACAddr=00:11:43:C5:4B:23-VLANId=1-UserName=test; The user failed the 802.1X authentication. |
Explanation |
Message text |
IfName=[STRING]-MACAddr=[STRING]-VLANId=[INTEGER]-UserName=[STRING]; The user passed 802.1X authentication and got online successfully. |
Variable fields |
Severity level |
6 |
Example |
PORTSEC/6/PORTSEC_DOT1X_LOGIN_SUCC: -IfName=Ethernet1/0/1-MACAddr=00:11:43:C5:4B:23-VLANId=1-UserName=test; The user passed 802.1X authentication and got online successfully. |
Explanation |
A user passed 802.1X authentication and got online successfully. |
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANId=[INTEGER]-UserName=[STRING]-ErrCode=[INTEGER]; Session of the 802.1X user was terminated. |
Variable fields |
$1: Interface type and number $2: MAC address $3: VLAN ID $4: Username $5: Error code |
Severity level |
6 |
Example |
PORTSEC/6/PORTSEC_DOT1X_LOGOFF: -IfName=Ethernet1/0/1-MACAddr=00:11:43:C5:4B:23-VLANId=1-UserName=test-ErrCode=34; Session of the 802.1X user was terminated. |
Explanation |
The 802.1x user logged off or got kicked out. |
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANId=[INTEGER]-UserName=[STRING]-UserNameFormat=[STRING]; The user failed the MAC address authentication. |
Variable fields |
$1: Interface type and number $2: MAC address $3: VLAN ID $4: Username $5: Username format, fixed or MAC address |
Severity level |
6 |
Example |
PORTSEC/6/PORTSEC_MACAUTH_LOGIN_FAILURE: -IfName=Ethernet1/0/1 0/0-MACAddr=00:11:43:C5:4B:23-VLANId=1-UserName=test-UserNameFormat=fixed; The user failed the MAC address authentication. |
Explanation |
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANId=[INTEGER]-UserName=[STRING]-UserNameFormat=[STRING]; The user passed MAC address authentication and got online successfully. |
Variable fields |
Severity level |
6 |
Example |
PORTSEC/6/PORTSEC_MACAUTH_LOGIN_SUCC: -IfName=Ethernet1/0/1-MACAddr=00:11:43:C5:4B:23-VLANId=1-UserName=test-UserNameFormat=fixed; The user passed MAC address authentication and got online successfully. |
Explanation |
A user passed MAC address authentication and got online successfully. |
Message text |
-IfName=[STRING]-MACAddr=[STRING]-VLANId=[INTEGER]-UserName=[STRING]-UserNameFormat=[STRING]; Session of the MAC-AUTH user was terminated. |
Variable fields |
$1: Interface type and number $2: MAC address $3: VLAN ID $4: User name $5: Username format, fixed or MAC address |
Severity level |
6 |
Example |
PORTSEC/6/PORTSEC_MACAUTH_LOGOFF: -IfName=Ethernet1/0/1-MACAddr=00:11:43:C5:4B:23-VLANId=1-UserName=test-UserNameFormat=fixed; Session of the MAC-AUTH user was terminated. |
Explanation |
The MAC-AUTH user logged off or got kicked out. |
This section contains all the system log messages related to QINQ.
Message text |
Failed to configure the Ethernet type on interface [STRING] because of insufficient resources. Please manually cancel the configuration. |
Variable fields |
$1: interface name |
Severity level |
4 |
Example |
QINQ/4/QINQ_ETHERNETTYPE_NORESOURCE: Failed to configure the Ethernet type on interface GigabitEthernet 1/0/25 because of insufficient resources. Please manually cancel the configuration. |
Explanation |
The system displays error information for activating the configuration of Ethernet type. |
Manually cancel the configuration of Ethernet type. |
Message text |
Failed to configure the outer VLAN tag to be added for packets on interface [STRING] because of insufficient resources. Please manually cancel the configuration. |
Variable fields |
Severity level |
4 |
Example |
QINQ/4/QINQ_OUTERVLANTAG_NORESOURCE: Failed to configure the outer VLAN tag to be added for packets on interface GigabitEthernet 1/0/25 because of insufficient resources. Please manually cancel the configuration. |
Explanation |
The system displays error information for activating the configuration of outer VLAN tag. |
Manually cancel the configuration of outer VLAN tag. |
This section contains the entire system log messages related to QOS.
Message text |
Classifier-behavior [STRING] in policy [STRING] applied on interface [STRING] failed. Reason: [STRING] |
Variable fields |
$1: The classifier-behavior name. $2: The policy name. $3: The port name. $4: The failed reason. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYIF_CBFAIL: Classifier-behavior b in policy b applied on interface Ethernet1/0/1 failed. Reason: No actions in behavior. |
Explanation |
Error info for applying policy on interface. |
Message text |
Classifier-behavior [STRING] in policy [STRING] applied globally failed. Reason: [STRING] |
Variable fields |
$1: The classifier-behavior name. $2: The policy name. $3: The failed reason. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYGLOBAL_CBFAIL: Slot=3; Classifier-behavior b in policy b applied globally failed. Reason: No actions in behavior. |
Explanation |
Error info for applying policy globally. |
Message text |
Applying classifier-behavior [STRING] in policy [STRING] to the control plane of slot [ULONG] failed. Reason: [STRING] |
Variable fields |
$1: The classifier-behavior name. $2: The policy name. $3: The slot number. $4: The failed reason. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYCOPP_CBFAIL: Slot=3; Applying classifier-behavior d in policy b to the control plane of slot 3 failed. Reason: No actions in behavior. |
Explanation |
Error info for applying a policy to a control plane. |
Message text |
Applying or refreshing QoS policy [STRING] to interface [STRING] failed. Reason: [STRING] |
Variable fields |
$1: The policy name. $2: The port name. $3: The failed reason. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYIF_FAIL: Slot=3; Applying or refreshing QoS policy b to interface Ethernet1/0/1 failed. Reason: Not supported by hardware. |
Explanation |
Error info for applying a policy to an interface. |
Message text |
Applying QoS policy [STRING] globally failed. Reason: [STRING] |
Variable fields |
$1: The policy name. $2: The failed reason. |
Severity level |
4 |
Example |
QOS/4/ QOS_POLICY_APPLYGLOBAL_FAIL: Slot=3; Applying or refreshing QoS policy b globally failed. Reason: Not supported by hardware. |
Explanation |
Error info for applying a policy globally. |
Message text |
Applying or refreshing QoS policy [STRING] to the control plane of slot [ULONG] failed. Reason: [STRING] |
Variable fields |
$1: The policy name. $2: The slot number. $3: The failed reason. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYCOPP_FAIL: Slot=3; Applying or refreshing QoS policy b to the control plane of slot 3 failed. Reason: Not supported by hardware. |
Explanation |
Message text |
Failed to apply QoS policy [STRING] in the [STRING] direction of user profile [STRING]! |
Variable fields |
$1: Policy name $2: Direction: inbound or outbound $3: User profile name |
Severity level |
5 |
Example |
QOS/5/FAILED_TO_APPLY_QOS_PROFILE: Failed to apply QoS policy policy1 in the inbound direction of user profile user1! |
Explanation |
User profile failed to apply qos policy. |
Message text |
Failed to check QoS policy [STRING] in the [STRING] direction of user profile [STRING]! |
Variable fields |
Severity level |
5 |
Example |
QOS/5/FAILED_TO_CHECK_QOS_PROFILE: Failed to check QoS policy policy1 in the inbound direction of user profile user1! |
Explanation |
User profile failed to check qos policy. |
Message text |
Error occurred in policy [STRING] classifier [STRING] for not support. |
Variable fields |
$1: The policy name. $2: The classifier name. |
Severity level |
3 |
Example |
QOS/3/QOS_POLICY_NOTSUPPORT: Error occurred in policy pp classifier cc for not support. |
Explanation |
The synchronization of policy-class to hardware is not supported. |
Delete the policy-class. |
Message text |
Error occurred in policy [STRING] classifier [STRING] for not enough resource. |
Variable fields |
Severity level |
3 |
Example |
QOS/3/QOS_POLICY_NO_ENOUGH_RESOURCE: Error occurred in policy pp classifier cc for not enough resource. |
Explanation |
There is not enough resource for the synchronization of policy-class to hardware. |
Message text |
Error occurred in policy [STRING] classifier [STRING]. |
Variable fields |
Severity level |
3 |
Example |
QOS/3/QOS_POLICY_COMMON_ERROR: Error occurred in policy pp classifier cc. |
Explanation |
Other error occurred in the synchronization of policy-class to hardware. |
This section contains the entire system log messages related to RDS.
Message text |
-IfName=[STRING]-VLANId=[ULONG]-MACAddr=[STRING]-IPAddr=[STRING]-IPv6Addr=[STRING]-UserName=[STRING]; User failed to get online. [STRING] |
Variable fields |
$1: Interface type and number $2: VLAN ID $3: MAC address $4: IP address $5: IPv6 address $6: Username $7:Authentication failure. Possible reasons include: “Failed to send the accounting packet.” "Failed to create the accounting packet." "Unsupported RADIUS attributes." |
Severity level |
5 |
Example |
RDS/5/RDS_FAILURE: -IfName=Ethernet1/0/1-VLANId=1-MACAddr=00:11:43:C5:4B:23-IPAddr=192.168.0.1-IPv6Addr=2002::1-UserName=test@system; User failed to get online. Failed to send the accounting packet. |
Explanation |
A user failed to get online. |
Message text |
-IfName=[STRING]-VLANId=[ULONG]-MACAddr=[STRING]-IPAddr=[STRING]-IPv6Addr=[STRING]-UserName=[STRING]; User got online successfully. |
Variable fields |
$1: Interface type and number $2: VLAN ID $3: MAC address $4: IP address $5: IPv6 address $6: Username |
Severity level |
6 |
Example |
RDS/6/RDS_SUCC: -IfName=Ethernet1/0/1-VLANId=1-MACAddr=00:11:43:C5:4B:23-IPAddr=192.168.0.1-IPv6Addr=2002::1-UserName=test@system; User got online successfully. |
Explanation |
A user got online successfully. |
Message text |
RIP [ULONG] Route limit reached |
Variable fields |
$1: Process ID |
Severity level |
4 |
Example |
RIP/4/RIP_RT_LMT: RIP 1 Route limit reached. |
Explanation |
RIP routes reach limit. |
Please check RIP routes and modify RIP configuration to make routes under the limit. |
This section contains the entire system log messages related to RMON.
Message text |
[STRING] table is added a valid row with index [ULONG] by [STRING]. |
Variable fields |
$1: The name of table. $2: An index that uniquely identifies an entry in the table. $3: The owner of the entry. |
Severity level |
6 |
Example |
RMON/6/RMON_ADDINFO: Alarm table is added a valid row with index 15 by user. |
Explanation |
A new entry has been added into alarm table or event table successfully. |
This section contains the entire system log messages related to SC.
Message text |
-AAAType=[STRING]-AAAScheme=[STRING]-Service=[STRING]-UserName=[STRING]; AAA launched. |
Variable fields |
$1: AAA type $2: AAA Scheme $3: Service $4: Username |
Severity level |
6 |
Example |
SC/6/SC_AAA_LAUNCH: -AAAType=AUTHEN-AAAScheme= radius-scheme cams-Service=login-UserName=cwf@system; AAA launched. |
Explanation |
A user start a AAA request. A user start a AAA request. |
Message text |
AAAType=[STRING]-AAAScheme=[STRING]-Service=[STRING]-UserName=[STRING]; AAA is successful. |
Variable fields |
Severity level |
6 |
Example |
SC/6/SC_AAA_SUCCESS: -AAAType=AUTHOR-AAAScheme= radius-scheme cams-Service=login-UserName=cwf@system; AAA is successful. |
Explanation |
A AAA request is accepted. A user ‘s AAA request is accepted. |
Message text |
-AAAType=[STRING]-AAAScheme=[STRING]-Service=[STRING]-UserName=[STRING]; AAA is failed. [STRING] |
Variable fields |
$1: AAA type, may be authentication, authorization or accouting $2: AAA Scheme, may be radius-scheme, hwtacacs-scheme, local or none $3: Service, may be login, super or command. $4: Username $5: Reason of failure, may be: “Common.” “No response.” |
Severity level |
5 |
Example |
SC/5/SC_AAA_FAILURE: -AAAType=ACCOUNT-AAAScheme= radius-scheme cams-Service=login-UserName=cwf@system; AAA is failed. No respon se. |
Explanation |
A user’s AAA request is rejected for no response from server, or for other common reasons such as user name or password error. |
This section contains the entire system log messages related to SHELL.
Message text |
[STRING] logged in from [STRING]. |
Variable fields |
$1: The name of users. $2: The type of users. |
Severity level |
5 |
Example |
SHELL/5/SHELL_LOGIN: Console logged in from con0. |
Explanation |
A user login successfully. |
Message text |
[STRING] logged out from [STRING]. |
Variable fields |
Severity level |
5 |
Example |
SHELL/5/SHELL_LOGOUT: Console logged out from con0. |
Explanation |
A user quitted from system. |
Message text |
-Task=[STRING]-IPAddr=[STRING]-User=[STRING]; Command is [STRING] |
Variable fields |
$1: Task name, if there isn’t task name, ‘***’ instead. $2: IP address, if there isn’t IP address, ‘**’ instead. $3: User name, if there isn’t user name, ‘**’ instead. $4: Command string. |
Severity level |
6 |
Example |
SHELL/6/SHELL_CMD: -Task=co0-IPAddr=**-User=**; Command is display this |
Explanation |
Record command string. |
Message text |
[STRING] failed to log in [STRING]. |
Variable fields |
$1: the user name $2: from IP (MAC) on VTY index. |
Severity level |
5 |
Example |
SHELL/5/SHELL_LOGINFAIL: TELNET user failed to log in from 12.130.2.19(000f-e239-1f97) on VTY0. |
Explanation |
This is a common print info and output the parameter info. |
Message text |
-seqNO=[ULONG]-srcIP=[STRING]-op=GET-node=[STRING]-value=[STRING]; The agent received a message. |
Variable fields |
$1: The sequence number of snmp operation log $2: The source IP address of the NMS. $3: The operation type of the NMS $4: The MIB object name and OID $5: The value field of the response packet |
Severity level |
6 |
Example |
SNMP/6/SNMP_GET: -seqNO=1-srcIP=192.168.28.28-op=GET-node=sysLocation(1.3.6.1.2.1.1.6.0)-value=; The agent received a message. |
Explanation |
Record the information about the SNMP get request packet. |
Message text |
-seqNO=[ULONG]-srcIP=[STRING]-op=SET-errorIndex=[ULONG]-errorStatus=[STRING]-node=[STRING]-value=[STRING]; The agent received a message. |
Variable fields |
$1: The sequence number of snmp operation log $2: The source IP address of the NMS. $3: The operation type of the NMS $4: The error index of the set operation $5: The error status of the set operation $6: The MIB object name and OID $7: The value field of the response packet |
Severity level |
6 |
Example |
SNMP/6/SNMP_SET: -seqNO=3-srcIP=192.168.28.28-op=SET-errorIndex=0-errorStatus=noError-node=sysLocation(1.3.6.1.2.1.1.6.0)-value=Hangzhou China; The agent received a message. |
Explanation |
Record the information about set request and response packet |
This section contains the entire system log messages related to SSH.
Message text |
[STRING] user [STRING] (IP: [STRING]) logged in successfully. |
Variable fields |
$1: User service type. $2: Username. $3: IP address of the SSH client. |
Severity level |
6 |
Example |
SSH/6/SSH_LOGIN: STEL user user1 (IP: 1.1.1.1) logged in successfully. |
Explanation |
The SSH user logged in successfully. |
Message text |
[STRING] user [STRING] (IP: [STRING]) logged out. |
Variable fields |
Severity level |
6 |
Example |
SSH/6/SSH_LOGOUT: STEL user user1 (IP: 1.1.1.1) logged out. |
Explanation |
The SSH user logged out. |
Message text |
[STRING] user [STRING] (IP: [STRING]) logged out because the SSH client closed the connection. |
Variable fields |
Severity level |
6 |
Example |
SSH/6/SSH_CONNECTION_CLOSE: STEL user user1 (IP: 1.1.1.1) logged out because the SSH client closed the connection. |
Explanation |
The SSH client closed the connection and the disconnection logged out the user. |
Message text |
[STRING] user [STRING] (IP: [STRING]) failed to log in because of authentication timeout. |
Variable fields |
Severity level |
6 |
Example |
SSH/6/SSH_AUTH_TIMEOUT: SSH user user1 (IP: 1.1.1.1) failed to log in because of authentication timeout. |
Explanation |
The SSH user initiated a login request, but the authentication timed out. This caused the login failure. |
Message text |
Received SFTP user [STRING] (IP: [STRING]) request: [STRING]. |
Variable fields |
$1: Username. $2: IP address of the SSH client. $3: Requested operation. |
Severity level |
5 |
Example |
SSH/5/SSH_SFTP_OPER: Received SFTP user user1 (IP: 1.1.1.1) request: Read file flash:/logfile.txt. |
Explanation |
An SFTP user request was received. |
This section contains the entire system log messages related to USERLOG.
Message text |
\r\n-protType(1001)=[STRING]-insideIPAddr(1003)=[STRING]-insidePortNum(1004)=[INTEGER]-insideNatIPAddr(1005)=[STRING]-insideNatPortNum(1006)=[INTEGER]-destIPAddr(1019)=[STRING]-destPortNum(1020)=[INTEGER]-beginTime_e(1013)=[STRING]-endTime_e(1014)=[STRING]-Operator(1112)=[STRING] |
Variable fields |
$1: IP protocol type; $2: Source IP address; $3: Source port number; $4: Source NAT IP address; $5: Source NAT port number; $6: Destination IP address; $7: Destination port number; $8: The time at which NAT session is created; $9: The time at which NAT session is deleted; $10: Session Operator; |
Severity level |
6 |
Example |
USERLOG/6/USERLOG_NAT: -protType(1001)=ICMP-insideIPAddr(1003)=192.168.0.67-insidePortNum(1004)=512-insideNatIPAddr(1005)=169.254.0.67-insideNatPortNum(1006)=12289-destIPAddr(1019)=169.254.0.90-destPortNum(1020)=512-beginTime_e(1013)=04022009111607-endTime_e(1014)=04022009111709-Operator(1112)=(1)Normal over |
Explanation |
A NAT log is outputted by the way of syslog. |
Message text |
\r\n-protType(1001)=[STRING]-srcIPAddr(1017)=[STRING]-srcPortNum(1018)=[INTEGER]-destIPAddr(1019)=[STRING]-destPortNum(1020)=[INTEGER]-beginTime_e(1013)=[STRING]-endTime_e(1014)=[STRING]-Operator(1112)=[STRING] |
Variable fields |
$1: IP protocol type; $2: Source IP address; $3: Source port number; $4: Destination IP address; $5: Destination port number; $6: The time at which a flow session is created; $7: The time at which a flow session is deleted; $8: Session Operator; |
Severity level |
6 |
Example |
USERLOG/6/USERLOG_FLOW: -protType(1001)=UDP-srcIPAddr(1017)=192.168.0.90-srcPortNum(1018)=20202-destIPAddr(1019)=1.1.1.1-destPortNum(1020)=9029-beginTime_e(1013)=04262000133545-endTime_e(1014)=04262000133545-Operator(1112)=(8)Data flow created |
Explanation |
A flow log is outputted by the way of syslog |
Message text |
\r\n-protType(1001)=[STRING]-insideIPAddr(1003)=[STRING]-insidePortNum(1004)=[INTEGER]-insideNatIPAddr(1005)=[STRING]-insideNatPortNum(1006)=[INTEGER]-outsideIPAddr(1007)=[STRING]-outsidePortNum(1008)=[INTEGER]-outsideNatIPAddr(1009)=[STRING]-outsideNatPortAddr(1010)=[INTEGER]-InTotalPkg(1106)=[INTEGER]-InTotalByte(1107)=[INTEGER]-OutTotalPkg(1108)=[INTEGER]-OutTotalByte(1109)=[INTEGER]-SrcVPNNAME(1080)=[STRING]-DesVPNNAME(1081)=[STRING]-beginTime_e(1013)=[STRING]-endTime_e(1014)=[STRING]-Operator(1112)=[STRING] |
Variable fields |
$1: IP protocol type; $2: Source IP address; $3: Source port number; $4: Source NAT IP address; $5: Source NAT port; $6 : Destination IP address; $7 : Destination port number; $8: Destination NAT IP address; $9: Destination NAT port number; $10: Received packets; $11: Received bytes; $12: Send packets; $13: Send bytes; $14: Source VPN name; $15: Destination VPN name; $16: The time at which a flow session is created; $17: The time at which a flow session is deleted; $18: Session Operator; |
Severity level |
6 |
Example |
USERLOG/6/USERLOG_FLOW:-protType(1001)=UDP-insideIPAddr(1003)=192.168.0.90-insidePortNum(1004)=20202-insideNatIPAddr(1005)=192.168.0.90-insideNatPortNum(1006)=20202-outsideIPAddr(1007)=1.1.1.1-outsidePortNum(1008)=9029-outsideNatIPAddr(1009)=1.1.1.1-outsideNatPortAddr(1010)=9029-InTotalPkg(1106)=0-InTotalByte(1107)=0-OutTotalPkg(1108)=1-OutTotalByte(1109)=440-SrcVPNNAME(1080)=none-DesVPNNAME(1081)=none-beginTime_e(1013)=04262000134247-endTime_e(1014)=04262000134247-Operator(1112)=(8)Data flow created. |
Explanation |
