MAC地址表故障处理手册
MAC地址表故障处理手册
1 MAC地址表故障处理
1.1  源MAC地址攻击导致端口流量瞬断故障处理
1.1.1  故障描述
如图1-1所示,Switch下接DSLAM(Digital Subscriber Line Access Multiplexer,数字用户线接入复用器),Switch上接BAS(Broadband Access Server,宽带接入服务器),由BAS终结用户的拨号PPPoE报文。在Switch上配置灵活QinQ功能,对应的用户侧VLAN为824,网络侧VLAN为1003。BAS上作为网关的MAC地址为0090-1aa0-d47a。
故障现象为:DSLAM下挂用户不定时大规模掉线。出现问题时,发现端口Ethernet3/0/4的流量急剧下降。大约5分钟左右,端口Ethernet3/0/4的流量开始慢慢回升,证明此时大规模掉线已经结束,DSLAM下挂用户又在逐步恢复连接,网络在逐步恢复正常状态。
图1-1 源MAC地址攻击导致端口流量瞬断故障处理组网图
1.1.2  故障处理步骤
(1)      检查接口信息
执行display interface命令显示端口Ethernet3/0/4的相关信息:
<Switch> display interface ethernet 3/0/4
 Ethernet3/0/4 current state: UP
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e200-8048
 Description: Ethernet3/0/4 Interface
 Loopback is not set
 Media type is twisted pair, port hardware type is 100_BASE_TX
 100Mbps-speed mode, full-duplex mode
 Flow-control is not enabled
 The Maximum Frame Length is 9022
 Broadcast MAX-ratio: 100%
 Unicast MAX-ratio: 100%
 Multicast MAX-ratio: 100%
 Allow jumbo frame to pass
 PVID: 100
 Mdi type: auto
 Port link-type: trunk
  VLAN passing  : 824
  VLAN permitted: 824
  Trunk port encapsulation: IEEE 802.1q
 Port priority: 0
 Last clearing of counters:  Never
 Peak value of input: 4 bytes/sec, at 2012-04-26 12:07:48
 Peak value of output: 81 bytes/sec, at 2012-04-26 12:09:24
 Last 300 seconds input:  1 packets/sec 147 bytes/sec
 Last 300 seconds output:  1 packets/sec 179 bytes/sec
 Input (total):  271 packets, 12250 bytes
          0 unicasts, 150 broadcasts, 121 multicasts, 0 pauses
 Input (normal):  271 packets, 12250 bytes
          0 CRC, 0 frame, - overruns, 0 aborts
          - ignored, - parity errors
 Output (total): 1522 packets, 183608303 bytes
          0 unicasts, 13 broadcasts, 860 multicasts, 0 pauses
 Output (normal): 1522 packets, - bytes
 Output: 0 output errors, - underruns, 1 buffer failures
          0 lost carrier, - no carrier
可以看到, 端口在故障时只有组播和广播报文的记数。
(2)      原因分析
从现象上看,Switch的端口Ethernet3/0/4的入方向报文计数在故障时只有组播和广播报文,基本上可以确定:由于某种原因,导致从Switch的端口Ethernet3/0/4进来的单播报文被全部丢弃了。DSLAM下挂用户正常通信的流量以单播报文为主,这种丢弃行为导致用户下线,然后重新认证,所以端口流量大大减小。
因此从报文被丢弃的原因着手分析问题。这种报文丢弃特征和“源端口返回报文”丢弃很吻合,也就是说很可能端口收到了目的MAC地址和本端口学习到的目的MAC地址一致的报文。正常工作状态下,BAS的MAC地址(也就是从Switch的端口Ethernet3/0/4上来的PPPoE单播流量的目的MAC地址)只会学习到Switch的端口GigabitEthernet2/0/1上的VLAN 1003,不会学习到用户侧端口,除非网络中有环路或者其他原因。
下面是正常情况下Switch的MAC地址表信息:
<Switch> display mac-address
MAC ADDR       VLAN ID  STATE          PORT INDEX               AGING TIME(s)
0090-1aa0-d47a 1003     Learned        GE2/0/1                  AGING
0090-1aa0-d47a 1101     Learned        GE2/0/1                  AGING
0090-1aa0-d47a 1201     Learned        GE2/0/1                  AGING
0090-1aa0-d47a 4093     Learned        GE2/0/1                  AGING
再看看出故障时学习到Switch的端口Ethernet3/0/4的MAC地址:
<Switch> display mac-address interface ethernet 3/0/4
0090-1aa0-d47a 824      Learned        Eth3/0/4                 AGING
这个MAC地址是BAS的MAC地址,却学习到了用户侧Switch的端口Ethernet3/0/4的VLAN 824。这时,从Switch的端口Ethernet3/0/4上来的PPPoE正常业务报文的目的MAC地址正是这个MAC地址,结果被作为源端口返回报文全部丢弃。
重新检视故障前后的定位信息,发现了这样的规律:大规模掉线时(端口大量丢包),BAS的MAC地址学习到了Switch的端口Ethernet3/0/4,而在业务流量逐渐恢复到正常的期间,这个MAC地址被老化掉了。
因为DSLAM和Switch是直连,中间没有其他交换机导致环路,网络拓扑一直处于稳定状态,因此可以得出结论:DSLAM下挂用户通过仿冒网关MAC地址的方法对Switch进行攻击,导致该DSLAM下面用户大规模掉线。从用户的攻击心理看,攻击大多数是为了获取更大的带宽,把其他用户踢下线,让网络系统重新来一次初始化,攻击者会明显感觉网速比以前要快了。
(3)      解决故障
在Switch的上行口GigabitEthernet2/0/1配置一个用户侧VLAN 824的静态网关MAC地址,这样网关MAC地址就永远不会学习到Switch的端口Ethernet3/0/4了,攻击者仿冒MAC地址的攻击也就不起作用了,方法如下:
# 把端口GigabitEthernet2/0/1加入到VLAN 824。
<Switch> system-view
[Switch] interface gigabitethernet 2/0/1
[Switch-GigabitEthernet2/0/1] port link-type trunk
[Switch-GigabitEthernet2/0/1] port trunk permit vlan 824
[Switch-GigabitEthernet2/0/1] quit
# 在端口GigabitEthernet2/0/1的VLAN 824设置一个网关静态MAC地址。
[Switch] mac-address static 0090-1aa0-d47a interface gigabitethernet 2/0/1 vlan 824
配置了静态MAC地址后,DSLAM下挂的用户运行很稳定,再未出现掉线的情况。
·       在使能灵活QinQ的情况下,为了防止用户进行源MAC地址攻击,建议在设备的上行口配置网关的静态MAC地址。
·       在有多个上行口的情况下,在任意一个上行口配置该静态MAC地址即可。
1.2  故障诊断命令
display interface
显示以太网接口的相关信息
display mac-address
显示MAC地址表信息
附件下载
