02-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesS9820 SeriesConfigure & DeployConfiguration GuidesH3C S9820-8C Switch Configuration Guides-Release 6715-6W10002-Layer 2—LAN Switching Configuration Guide
16-Cut-through Layer 2 forwarding configuration
Configuring cut-through Layer 2 forwarding
About cut-through Layer 2 forwarding
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame and enhances forwarding performance.
Restrictions and guidelines for cut-through Layer 2 forwarding configuration
With cut-through forwarding, the device forwards CRC-error frames because it starts forwarding frames before their CRC field is received.
The cut-through forwarding does not take effect for traffic from multiple ingress ports to the same destination port or traffic from one ingress port to multiple destination ports.
2.     Enable cut-through forwarding.
cut-through enable
By default, cut-through forwarding is disabled.
