- H3C Router Software Upgrade Guide-6W100
- 01-About software upgrade
- 02-Upgrade restrictions and guidelines
- 03-Upgrade workflow
- 04-Preparing for the upgrade
- 05-Upgrading the BootWare
- 06-Upgrading the startup software
- 07-Installing patches and features
- 08-Verifying the upgrade
- 09-Rolling back the running software images
- 10-Troubleshooting
- 11-Appendix A Downloading the upgrade file
- 12-Appendix B Software upgrade record form
- 13-Appendix C Acronyms
12-Appendix B Software upgrade record form | 35.88 KB |
Appendix B Upgrade record form
Site name |
Upgraded at |
Router model |
Router name |
Version before upgrade |
Version after upgrade |
Upgrade team members |
Team members from the site: Team members from H3C: |
Upgrade result |
Check items |
Result |
Unexpected situation handling |
Before the upgrade |
Check tools used to upgrade software. |
Identify the upgrade methods supported by the router. |
Check the upgrade environment. |
Check whether the router can be logged in. |
Prepare the required upgrade software images. |
View the current system software version. |
Check whether important data has been backed up. |
Check whether the storage medium has sufficient space to store the upgrade software images. |
During the upgrade |
Check the upgrade process. |
Check the TFTP or FTP server configuration. |
Check whether the software images have been downloaded successfully. |
Check the upgrade operation. |
(Optional.) Check the upgrade status of the standby MPU. |
After the upgrade |
Check the software version after the upgrade. |
Compare the memory usage and CPU usage before and after the upgrade to identify whether they are significantly different. |
Check whether services are running correctly. |
