- H3C Router Software Upgrade Guide-6W100
- 01-About software upgrade
- 02-Upgrade restrictions and guidelines
- 03-Upgrade workflow
- 04-Preparing for the upgrade
- 05-Upgrading the BootWare
- 06-Upgrading the startup software
- 07-Installing patches and features
- 08-Verifying the upgrade
- 09-Rolling back the running software images
- 10-Troubleshooting
- 11-Appendix A Downloading the upgrade file
- 12-Appendix B Software upgrade record form
- 13-Appendix C Acronyms
00-Preface | 101.04 KB |
Preface
H3C Router Software Upgrade Guide guides you through the upgrade of your routers. The guide contains the following sections:
· Upgrade restrictions and guidelines
· Upgrading the startup software
· Installing patches and features
· Rolling back the running software images
· Downloading the upgrade file
· Software upgrade record form
· Acronyms
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
