- H3C Router Software Upgrade Guide-6W100
- 01-About software upgrade
- 02-Upgrade restrictions and guidelines
- 03-Upgrade workflow
- 04-Preparing for the upgrade
- 05-Upgrading the BootWare
- 06-Upgrading the startup software
- 07-Installing patches and features
- 08-Verifying the upgrade
- 09-Rolling back the running software images
- 10-Troubleshooting
- 11-Appendix A Downloading the upgrade file
- 12-Appendix B Software upgrade record form
- 13-Appendix C Acronyms
07-Installing patches and features | 79.21 KB |
Installing features on a single-MPU device (distributed devices in standalone mode)
Installing features on a dual-MPU device (distributed devices in standalone mode)
Installing features (distributed devices in IRF mode/CR19000)
Installing features (centralized devices)
This chapter describes how to install patches and features.
· Installing features on a single-MPU device (distributed devices in standalone mode)
· Installing features on a dual-MPU device (distributed devices in standalone mode)
· Installing features (distributed devices in IRF mode/CR19000)
· Installing features (centralized devices)
Installing patches
Installation workflow
Figure 1 Installation workflow
Installation procedure
See "Preparing for the upgrade."
Downloading the image file
Download the image file from an PC to the router. For more information, see "Appendix A Downloading the upgrade file."
Installing a patch
NOTE: The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices. |
# Install a patch.
<Sysname> install activate patch flash:/patch1.bin all
# Commit the software change.
<Sysname> install commit
NOTE: · The install commit command enables the installed patch to take effect after the device or a card reboots. · You need to re-install the patch after the software is upgraded and then rolled back to original version. |
Uninstalling a patch
# Display active patch images.
<Sysname> display install active
# Uninstall a patch.
<Sysname> install deactivate patch flash:/patch1.bin all
NOTE: The install commit command enables the uninstalled patch to not take effect after the device or a card reboots. |
Figure 2 Installation workflow
Download the upgrade file from an PC to the router. For more information, see "Appendix A Downloading the upgrade file."
Decompressing the .ipe file
If the image file for installing a feature is in an .ipe file, decompress the .ipe file.
<Sysname> install add flash:/feature1.ipe flash:/
Installing a feature
# Install a feature image on the MPU.
<Sysname> install activate feature flash:/feature1.bin slot0
NOTE: · The install commit command enables the installed feature images to take effect after the device or a card reboots. · You need to re-install the feature images after the software is upgraded and then rolled back to original version. |
Uninstalling a feature image
# Uninstall the feature image on the MPU.
<Sysname> install deactivate feature flash:/feature1.bin slot0
NOTE: The install commit command enables the uninstalled feature images to not take effect after the device or a card reboots. |
Figure 3 Installation workflow
# Install a feature image on the active MPU.
# Install a feature image on the standby MPU.
<Sysname> install activate feature flash:/feature1.bin slot1
# Uninstall the feature image on the standby MPU.
<Sysname> install deactivate feature flash:/feature1.bin slot1
# Uninstall the feature image on the active MPU.
NOTE: · To uninstall a feature image, you must begin with the standby MPU. · The install commit command enables the uninstalled feature images to not take effect after the device or a card reboots. |
NOTE: · In this section, the IRF fabric or cluster has two member devices, and each member device has two MPUs. · The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices. |
Figure 4 Installation workflow
# Install a feature image on all MPUs in the IRF fabric or cluster.
<Sysname> install activate feature flash:/feature1.bin chassis 1 slot0
<Sysname> install activate feature flash:/feature1.bin chassis 1 slot1
<Sysname> install activate feature flash:/feature1.bin chassis 2 slot0
<Sysname> install activate feature flash:/feature1.bin chassis 2 slot1
# Uninstall the feature image from all standby MPUs.
<Sysname> install deactivate feature flash:/feature1.bin chassis 1 slot1
<Sysname> install deactivate feature flash:/feature1.bin chassis 2 slot1
<Sysname> install deactivate feature flash:/feature1.bin chassis 2 slot0
# Uninstall the feature image from the active MPU.
NOTE: · To uninstall a feature image, you must begin with the standby MPUs. · The install commit command enables the uninstalled feature images to not take effect after the device or a card reboots. |
Figure 5 Installation workflow
# Install a feature image.
NOTE: · The install commit command enables the installed feature images to take effect after the device reboots. · You need to re-install the feature images after the software is upgraded and then rolled back to original version. |
# Uninstall a feature image.
NOTE: The install commit command enables the uninstalled feature images to not take effect after the device reboots. |
