- H3C Router Software Upgrade Guide-6W100
- 01-About software upgrade
- 02-Upgrade restrictions and guidelines
- 03-Upgrade workflow
- 04-Preparing for the upgrade
- 05-Upgrading the BootWare
- 06-Upgrading the startup software
- 07-Installing patches and features
- 08-Verifying the upgrade
- 09-Rolling back the running software images
- 10-Troubleshooting
- 11-Appendix A Downloading the upgrade file
- 12-Appendix B Software upgrade record form
- 13-Appendix C Acronyms
11-Appendix A Downloading the upgrade file | 76.89 KB |
Using FTP to download upgrade file
Downloading software images at the CLI
Downloading software images from the BootWare menu
Using TFTP to download software images
The router can function as the TFTP client, FTP client, or FTP server. For more information about FTP and TFTP, see the FTP and TFTP configuration in the fundamentals configuration guide.
This section uses the router as an FTP client to download files from an FTP server.
NOTE: The BootWare menu varies by router model and BootWare version. This section uses a CF16000-F router as an example. |
1. Set up an upgrade environment as described in "Preparing for the upgrade."
2. Run the FTP server program on a PC (its IP address is 192.168.0.23), and set the working directory, FTP username, and password. Store the upgrade file on the working directory of the FTP server.
3. Make sure the PC and the router can reach each other.
4. Log in to the router, and access the root directory of the storage medium for the startup software images.
<Sysname> cd cfa0:/
<Sysname>
NOTE: If the storage medium to which the startup software images are downloaded is not the specified storage medium, access the root directory of the storage medium of startup software images before downloading the software images. |
5. Download the upgrade file (newest.ipe in this example) to the storage medium on the router.
# Log in to the FTP server.
<Sysname> ftp 192.168.0.23
Connected to 192.168.0.23 (192.168.0.23).
User (192.168.0.23:(none)):username
Password:
230 Logged in successfully
Remote system type is MSDOS.
ftp>
# Set the file transfer mode to binary.
ftp> binary
200 Type is Image (Binary)
# Download the upgrade file newest.ipe to the root directory of the storage medium.
ftp> get newest.ipe
227 Entering Passive Mode (192,168,0,23,7,100)
150 "C:\ newest.ipe " file ready to send (385 bytes) in in IMAGE / Binary mode
226 Transfer finished successfully.
74948608 bytes received in 35.974 seconds (896.00 kbyte/s)
ftp> bye
221 Windows FTP Server (WFTPD, by Texas Imperial Software) says goodbye
# Verify that the upgrade file has been in the root directory of the storage medium.
<Sysname> dir
# Use the MD5 algorithm to calculate the digest of the file, and compare it with the MD5 digest on the H3C website to verify file integrity.
<Sysname> md5sum newest.ipe
MD5 digest:
4f22b6190d151a167105df61c35f0917
3. Run the terminal emulation program on the PC, and power on the router. Press Ctrl+B at prompt to access the EXTENDED-BOOTWARE menu.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Skip Authentication for Console Login |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
4. (Optional.) Set the default storage medium.
IMPORTANT: If the storage medium storing the upgrade file is not the default storage medium, set it as the default storage medium. |
# Enter 9 to access the storage device submenu.
==============================<DEVICE CONTROL>==============================
|<1> Display All Available Nonvolatile Storage Device(s) |
|<2> Set The Operating Device |
|<3> Set The Default Boot Device |
|<0> Exit To Main Menu |
Enter your choice(0-3):
# Enter 2 to set the storage medium for storing the upgrade file.
Please set the operating device:
|Note:the operating device is cfa0 |
|NO. Device Name File System Total Size Available Space |
|1 flash JFFS2 262144KB 224937KB |
|2 cfa0 FAT 2044256KB 1173684KB |
|0 Exit |
Enter your choice(0-2):
# Enter 2 to set the CF card as the storage medium for storing the upgrade file.
# Enter 3 to set the default storage medium.
Please set the default device:
|Note:the default device is cfa0 |
|0 Exit |
# Enter 2 to set the CF card as the default storage medium.
# Enter 0 to exit the storage device submenu.
5. Download and upgrade the BootWare.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
# Enter 3 to access the Ethernet submenu.
==========================<Enter Ethernet SubMenu>==========================
|<1> Download Image Program To SDRAM And Run |
|<2> Update Main Image File |
|<3> Update Backup Image File |
|<4> Download Files(*.*) |
|<5> Modify Ethernet Parameter |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-5):
# Enter 5 to configure the network settings.
==========================<ETHERNET PARAMETER SET>==========================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :ftp
Load File Name :newest.ipe
Target File Name :newest.ipe
Server IP Address :192.168.0.23
Local IP Address :192.168.0.105
Subnet Mask :255.255.255.0
Gateway IP Address :0.0.0.0
FTP User Name :xxx
FTP User Password :***
Table 1 Network parameter fields and shortcut keys
'.' = Clear field |
Press a dot (.) and then press Enter to clear the setting for a field. |
'-' = Go to previous field |
Press a hyphen (-) and then press Enter to return to the previous field. |
Ctrl+D = Quit |
Press Ctrl+D to exit the ETHERNET PARAMETER SET menu. |
Protocol (FTP or TFTP) |
Set the file transfer protocol to FTP or TFTP. |
Load File Name |
Set the name of the file to be downloaded. |
Target File Name |
Set a file name for saving the file on the router. The target file name must have the same extension as the source file. By default, the target file name is the same as the source file name. |
Server IP Address |
Set the IP address of the FTP or TFTP server. |
Local IP Address |
Set the IP address of the Ethernet interface that connects to the TFTP server. |
Subnet Mask |
Set the IP address mask. |
Gateway IP Address |
Set a gateway IP address if the router is on a different network than the server. |
After you finish setting the FTP parameters, the system returns to the Ethernet submenu. Choose option 2 to 3. For example, enter 2 to upgrade the main startup software images.
Loading.....................................................................
.........................Done!
31911744 bytes downloaded!
Image file BOOT.bin is self-decompressing... Saving file cfa0:/ BOOT.bin ..............................................Done.
Image file SYSTEM.bin is self-decompressing...Saving file cfa0:/ SYSTEM.bin .................................. ..Done.
# Enter 0 in the Ethernet submenu to return to the EXTENDED-BOOTWARE menu.
# Enter 0 to reboot the router.
2. Run the TFTP server program on a PC (its IP address is 192.168.0.23), and set the working directory, TFTP username, and password. Store the upgrade file on the working directory of the TFTP server.
<Sysname> cd cfa0:/
<Sysname>
NOTE: If the storage medium to which the startup software images are downloaded is not the specified storage medium, access the root directory of the storage medium of startup software images before downloading software images. |
<Sysname> tftp 192.168.0.23 get newest.ipe
Press CTRL+C to abort.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 13.9M 100 13.9M 0 0 1206k 0 0:00:11 0:00:11 --:--:-- 1206k
Writing file...Done.
<Sysname> dir
MD5 digest:
2. Run the TFTP server program on a PC (its IP address is 192.168.0.23), set the working directory, TFTP username, and password. Store the upgrade file on the working directory of the TFTP server.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
4. (Optional.) Set the default storage medium for downloading the upgrade file.
|0 Exit |
|0 Exit |
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-5)::
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :tftp
Load File Name :test.bin
:newest.ipe
Target File Name :test.bin
:newest.ipe
Table 2 Network parameter fields and shortcut keys
'.' = Clear field |
Ctrl+D = Quit |
Load File Name |
Target File Name |
Server IP Address |
Local IP Address |
Subnet Mask |
