- H3C Router Software Upgrade Guide-6W100
- 01-About software upgrade
- 02-Upgrade restrictions and guidelines
- 03-Upgrade workflow
- 04-Preparing for the upgrade
- 05-Upgrading the BootWare
- 06-Upgrading the startup software
- 07-Installing patches and features
- 08-Verifying the upgrade
- 09-Rolling back the running software images
- 10-Troubleshooting
- 11-Appendix A Downloading the upgrade file
- 12-Appendix B Software upgrade record form
- 13-Appendix C Acronyms
06-Upgrading the startup software | 119.75 KB |
Upgrading the startup software by using the boot loader method
Upgrading the startup software from the BootWare menu
Performing a compatible upgrade by using ISSU commands (distributed devices)
Performing a compatible upgrade by using ISSU commands (centralized devices)
Performing an incompatible upgrade by using ISSU commands (distributed devices)
Performing an incompatible upgrade by using ISSU commands (centralized devices)
You can upgrade the startup software by using the following methods:
· Upgrading the startup software by using the boot loader method
· Upgrading the startup software from the BootWare menu
· Performing a compatible upgrade by using ISSU commands (distributed devices)
· Performing a compatible upgrade by using ISSU commands (centralized devices)
· Performing an incompatible upgrade by using ISSU commands (distributed devices)
· Performing an incompatible upgrade by using ISSU commands (centralized devices)
Upgrade workflow
Table 1 Upgrade workflow
Upgrade procedure
See "Preparing for the upgrade."
Download the upgrade file from an PC to the router. For more information, see "Appendix A Downloading the upgrade file."
NOTE: · You can specify an .ipe file or a boot image file and a system image file in the boot-loader file command. This section uses an .ipe file as an example. · Available commands vary by router model. This section uses a CR16000-F router as an example. · The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices. |
# Specify an .ipe file as the main startup software file.
<Sysname> boot-loader file flash:/all.ipe all main
Verifying the file flash:/all.ipe on slot 1..............Done.
H3C CR16010H-F images in IPE:
boot.bin
system.bin
This command will set the main startup software images. Continue? [Y/N]:y
# Specify an .ipe file as the backup startup software file.
<Sysname> boot-loader file flash:/all2.ipe all backup
Verifying the file flash:/all2.ipe on slot 1..............Done.
boot.bin
system.bin
This command will set the backup startup software images. Continue? [Y/N]:y
Rebooting the router
# Reboot the router to complete the upgrade.
<Sysname> reboot
Start to check configuration with next startup configuration file, please wait.
........DONE!
Now rebooting, please wait...
Upgrade workflow
Table 2 Upgrade workflow
Upgrade procedure
# Return to the EXTENDED-BOOTWARE menu, and enter 0 in the EXTENDED-BOOTWARE menu to reboot the router.
NOTE: For a modular router that has an active MPU and a standby MPU, you must access the BootWare menus of them through the console port to upgrade their startup software. You also need to connect to the management Ethernet ports on both MPUs. |
NOTE: · Before performing an ISSU, you must use the display version comp-matrix command to identify the recommended ISSU methods. · In this section, the IRF fabric or cluster has two member devices, and each member device has two MPUs. · The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices. · The command output varies by device model. |
Upgrade workflow
Table 3 Upgrade workflow
Upgrade procedure
Identifying the recommended ISSU methods
# Display active software images.
<Sysname> display install active
Active packages on chassis 1 slot 0:
flash:/boot-t0001015.bin
flash:/system-t0001015.bin
flash:/feature-t0001015.bin
Active packages on chassis 1 slot 1:
Active packages on chassis 2 slot 0:
Active packages on chassis 2 slot 1:
# Identify the recommended ISSU methods.
<Sysname> display version comp-matrix file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin
Verifying the file flash:/boot-t0001016.bin on chassis 1 slot 0..................................Done.
Verifying the file flash:/system-t0001016.bin on chassis 1 slot 0..................................Done.
Verifying the file flash:/feature-t0001016.bin on chassis 1 slot 0..................................Done.
Identifying the upgrade methods....Done.
Chassis Slot Upgrade Way
1 0 Reboot
1 1 Reboot
2 0 Reboot
2 1 Reboot
The output shows that reboot upgrades are recommended.
# Upgrade the startup software on the subordinate member.
<Sysname> issu load file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin chassis 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:y
Copying file flash:/boot-t0001016.bin to chassis2#slot0#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to chassis2#slot0#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to chassis2#slot0#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on chassis 2 slot 0...Done.
Verifying the file flash:/system-t0001016.bin on chassis 2 slot 0............Done.
Verifying the file flash:/feature-t0001016.bin on chassis 2 slot 0...Done.
Copying file flash:/boot-t0001016.bin to chassis2#slot1#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to chassis2#slot1#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to chassis2#slot1#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on chassis 2 slot 1...Done.
Verifying the file flash:/system-t0001016.bin on chassis 2 slot 1............Done.
Verifying the file flash:/feature-t0001016.bin on chassis 2 slot 1...Done.
Identifying the upgrade methods….Done.
Running Version New Version
Test 0001015 Test 0001016
2 0 Reboot
2 1 Reboot
This operation might take several minutes, please wait...Done.
# Verify that the ISSU is in a stable state.
<Sysname> display issu state
ISSU state: Loaded
Compatibility: Compatible
Work state: Normal
Upgrade method: Chassis by chassis
Upgraded chassis:
chassis 2
Current upgrading chassis: None
Previous version list:
boot: 7.1.070, Test 0001015
system: 7.1.070, Test 0001015
feature: 7.1.070, Test 0001015
Previous software images:
Upgrade version list:
boot: 7.1.070, Test 0001016
system: 7.1.070, Test 0001016
feature: 7.1.070, Test 0001016
Upgrade software images:
The Loaded state is a stable state, which indicates that the system is waiting for a master/subordinate switchover. Chassis 2 has completed the upgrade, and chassis 1 has not.
# Perform a master/subordinate switchover.
<Sysname> issu run switchover
Chassis Slot Switchover Way
1 0 Master subordinate switchover
This operation might take several minutes, please wait.........
ISSU state: Switchover
Work state: Normal
Upgraded chassis:
chassis 2
The Switchover state is a stable state, which indicates that the system has completed the master/subordinate switchover and is waiting for a commit operation to upgrade chassis 1.
# Upgrade the startup software on the original master.
<Sysname> issu commit chassis 1
Copying file flash:/boot-t0001016.bin to chassis1#slot1#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to chassis1#slot1#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to chassis1#slot1#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on chassis 1 slot 1...Done.
Verifying the file flash:/system-t0001016.bin on chassis 1 slot 1...Done.
Verifying the file flash:/feature-t0001016.bin on chassis 1 slot 1...Done.
1 0 Reboot
1 1 Reboot
# Verify that the ISSU is finished.
ISSU state: Init
Compatibility: Unknown
Upgraded chassis: None
Current version list:
Current software images:
The ISSU state field displays Init, which indicates that the ISSU is finished.
# Verify that both members are running the new software images.
NOTE: · Before performing an ISSU, you must use the display version comp-matrix command to identify the recommended ISSU methods. · In this section, the IRF fabric has two member devices. · The command output varies by device model. |
Upgrade workflow
Table 4 Upgrade workflow
Upgrade procedure
Download the upgrade file from an PC to the router. For more information, "Appendix A Downloading the upgrade file."
Active packages on slot 1:
Active packages on slot 2:
Verifying the file flash:/boot-t0001016.bin on slot 1.......................Done.
Verifying the file flash:/system-t0001016.bin on slot 1................. .................Done.
Verifying the file flash:/feature-t0001016.bin on slot 1.................Done.
Slot Upgrade Way
1 Reboot
2 Reboot
<Sysname> issu load file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin slot 2
Copying file flash:/boot-t0001016.bin to slot2#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to slot2#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to slot2#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on slot 2...Done.
Verifying the file flash:/system-t0001016.bin on slot 2............Done.
Verifying the file flash:/feature-t0001016.bin on slot 2...Done.
Slot Upgrade Way
2 Reboot
ISSU state: Loaded
Work state: Normal
Upgrade method: Card by card
Upgraded slot:
slot 2
Current upgrading slot: None
The Loaded state is a stable state, which indicates that the system is waiting for a master/subordinate switchover. Slot 2 has completed the upgrade, and slot 1 has not.
Slot Switchover Way
1 Master subordinate switchover
Work state: Normal
Upgraded slot:
slot 2
The Switchover state is a stable state, which indicates that the system has completed the master/subordinate switchover and is waiting for a commit operation to upgrade slot 1.
<Sysname> issu commit slot 1
Slot Upgrade Way
1 Reboot
ISSU state: Init
Work state: Normal
Upgraded slot: None
NOTE: · Before performing an ISSU, you must use the display version comp-matrix command to identify the recommended ISSU methods. · In this section, the IRF fabric has two member devices, and each member device has two MPUs. · The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices. · The command output varies by device model. |
Upgrade workflow
Table 5 Upgrade workflow
Upgrade procedure
<Sysname> display version comp-matrix file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin
Verifying the file flash:/boot-t0001017.bin on chassis 1 slot 0..................................Done.
Verifying the file flash:/system-t0001017.bin on chassis 1 slot 0..................................Done.
Verifying the file flash:/feature-t0001017.bin on chassis 1 slot 0..................................Done.
Incompatible upgrade
The output shows that an incompatible upgrade is recommended.
<Sysname> issu load file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin chassis 2
Copying file flash:/boot-t0001017.bin to chassis2#slot0#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to chassis2#slot0#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to chassis2#slot0#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on chassis 2 slot 0...Done.
Verifying the file flash:/system-t0001017.bin on chassis 2 slot 0............Done.
Verifying the file flash:/feature-t0001017.bin on chassis 2 slot 0...Done.
Copying file flash:/boot-t0001017.bin to chassis2#slot1#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to chassis2#slot1#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to chassis2#slot1#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on chassis 2 slot 1...Done.
Verifying the file flash:/system-t0001017.bin on chassis 2 slot 1............Done.
Verifying the file flash:/feature-t0001017.bin on chassis 2 slot 1...Done.
Test 0001015 Test 0001017
2 0 Reboot
2 1 Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
ISSU state: Loaded
Compatibility: Incompatible
Work state: Normal
Upgraded chassis:
chassis 2
boot: 7.1.070, Test 0001017
system: 7.1.070, Test 0001017
feature: 7.1.070, Test 0001017
Copying file flash:/boot-t0001017.bin to chassis1#slot1#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to chassis1#slot1#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to chassis1#slot1#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on chassis 1 slot 1...Done.
Verifying the file flash:/system-t0001017.bin on chassis 1 slot 1............Done.
Verifying the file flash:/feature-t0001017.bin on chassis 1 slot 1...Done.
1 0 Reboot
1 1 Reboot
ISSU state: Init
Work state: Normal
Upgrade workflow
Table 6 Upgrade workflow
Upgrade procedure
Verifying the file flash:/boot-t0001017.bin on slot 1.......................Done.
Verifying the file flash:/system-t0001017.bin on slot 1................. .................Done.
Verifying the file flash:/feature-t0001017.bin on slot 1.................Done.
Incompatible upgrade.
<Sysname> issu load file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin slot 2
Copying file flash:/boot-t0001017.bin to slot2#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to slot2#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to slot2#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on slot 2...Done.
Verifying the file flash:/system-t0001017.bin on slot 2............Done.
Verifying the file flash:/feature-t0001017.bin on slot 2...Done.
Slot Upgrade Way
2 Reboot
ISSU state: Loaded
Work state: Normal
Upgraded slot:
slot 2
Slot Switchover Way
ISSU state: Init
Work state: Normal
Upgraded slot: None
