- 04-Layer 3 - IP Services Configuration Examples
- 01-H3C_S7500E-X_DHCP_Snooping_Configuration_Examples
- 02-H3C_S7500E-X_GRE_with_OSPF_Configuration_Examples
- 03-H3C_S7500E-X_IPv6_over_IPv4_GRE_Tunnel_Configuration_Examples
- 04-H3C_S7500E-X_IPv6_over_IPv4_Manual_Tunneling_with_OSPFv3_Configuration_Examples
- 05-H3C_S7500E-X_ISATAP_Tunnel_and_6to4_Tunnel_Configuration_Examples
- 06-H3C_S7500E-X_IP_Unnumbered_Configuration_Examples
- 07-H3C_S7500E-X_Cross-Subnet_Dynamic_IP_Address_Allocation_Configuration_Examples
07-H3C_S7500E-X_Cross-Subnet_Dynamic_IP_Address_Allocation_Configuration_Examples | 104.25 KB |
H3C S7500E-X Cross-Subnet Dynamic IP Address Allocation Configuration Examples
Copyright © 2015 Hangzhou H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
Example: Configuring cross-subnet dynamic IP address allocation
Introduction
This document provides examples for configuring cross-subnet dynamic IP address allocation.
This document assumes that you have basic knowledge of DHCP.
Network requirements
As shown inFigure 1, a company's branches are on a different subnet from the headquarters. Device A acts as the gateway of the headquarters and Device B acts as the gateway for the branches.
Configure DHCP server on Device A to meet the following requirements:
· The hosts at the headquarters obtain IP addresses in the range of 10.1.1.2 to 10.1.1.100.
· The hosts at branch 1 obtain IP addresses in the range of 10.1.3.2 to 10.1.3.48. The hosts at branch 2 obtain IP addresses in the range of 10.1.3.49 to 10.1.3.100.
· The hosts at the headquarters and branches obtain the DNS server address, the TFTP server address, the domain name suffix, and the gateway address through DHCP.
Configure DHCP relay agent on Device B to meet the following requirements:
· The hosts at the branches obtain IP addresses and other configuration parameters from the DHCP server.
· The hosts at the branches cannot access the network by using manually configured IP addresses.
· The hosts at each branch obtain IP addresses from the address range assigned to the branch.
IP address |
Device |
IP address |
Device A |
Vlan-int3 |
10.1.1.1/24 |
Device B |
Vlan-int3 |
10.1.3.1/24 |
Vlan-int2 |
10.1.2.1/24 |
Vlan-int2 |
10.1.2.2/24 |
Requirements analysis
To meet the network requirements, you must perform the following tasks:
· Exclude the IP addresses of the DNS server and TFTP server from dynamic address allocation to prevent them from being assigned to hosts.
· To prevent the hosts at the branches from using manually configured IP addresses to access the network, perform the following tasks:
¡ Enable the DHCP relay agent to record client information in DHCP relay entries.
¡ Enable IP source guard to filter incoming packets based on the DHCP relay entries.
· To make sure the hosts in each branch obtain IP addresses from the address range assigned to the branch, perform the following tasks:
¡ Configure Option 82 on the DHCP relay agent.
¡ Create DHCP user classes for the branches and configure match rules based on Option 82 to match the branches on the DHCP server.
Software version used
This configuration example was created and verified on S7500EX-CMW710-R7168.
To ensure correct DHCP address allocation by using Option 82, you must perform Option 82 configuration on both the DHCP server and the DHCP relay agent.
Configuration procedures
Configuring Device A
# Assign interface GigabitEthernet 1/0/2 to VLAN 2.
[DeviceA] vlan 2
[DeviceA-vlan2] port GigabitEthernet 1/0/2
[DeviceA-vlan2] quit
# Assign an IP address to VLAN-interface 2.
[DeviceA] interface Vlan-interface 2
[DeviceA-Vlan-interface2] ip address 10.1.2.1 24
[DeviceA-Vlan-interface2] quit
# Assign interface GigabitEthernet 1/0/1 to VLAN 3.
[DeviceA] vlan 3
[DeviceA-vlan3] port GigabitEthernet 1/0/1
[DeviceA-vlan3] quit
# Assign an IP address to VLAN-interface 3.
[DeviceA] interface Vlan-interface 3
[DeviceA-Vlan-interface3] ip address 10.1.1.1 24
[DeviceA-Vlan-interface3] quit
# Enable DHCP.
[DeviceA] dhcp enable
# Enable DHCP server on VLAN-interface 2.
[DeviceA] interface vlan-interface 2
[DeviceA-Vlan-interface2] dhcp select server
# Enable DHCP server on VLAN-interface 3.
[DeviceA] interface vlan-interface 3
[DeviceA-Vlan-interface3] dhcp select server
# Create DHCP address pool 1.
[DeviceA] dhcp server ip-pool 1
# Specify the subnet and address range for dynamic address allocation.
[DeviceA-dhcp-pool-1] network 10.1.1.0 mask 255.255.255.0
[DeviceA-dhcp-pool-1] address range 10.1.1.2 10.1.1.100
# Specify the DNS server address, TFTP server address, domain name suffix, and gateway address to be assigned to clients.
[DeviceA-dhcp-pool-1] dns-list 10.1.1.3
[DeviceA-dhcp-pool-1] tftp-server ip-address 10.1.1.4
[DeviceA-dhcp-pool-1] domain-name com
[DeviceA-dhcp-pool-1] gateway-list 10.1.1.1
# Exclude the IP addresses of the DNS server and TFTP server from dynamic address allocation.
[DeviceA-dhcp-pool-1] forbidden-ip 10.1.1.3 10.1.1.4
[DeviceA-dhcp-pool-1] quit
# Apply the DHCP address pool to VLAN-interface 3.
[DeviceA-Vlan-interface3] dhcp server apply ip-pool 1
# Create DHCP user class aa for the hosts at branch 1. Configure match rule 1 to match DHCP requests in which the fifth and sixth bytes of Option 82 are 0x0001. The string 0x0001 indicates that the clients are connected to interface GigabitEthernet 1/0/1.
[DeviceA] dhcp class aa
[DeviceA-dhcp-class-aa] if-match rule 1 option 82 hex 0001 offset 4 length 2
[DeviceA-dhcp-class-aa] quit
# Create DHCP user class bb for the hosts at branch 2. Configure match rule 1 to match DHCP requests in which the fifth and sixth bytes of Option 82 are 0x0003. The string 0x0003 indicates that the clients are connected to interface GigabitEthernet 1/0/3.
[DeviceA] dhcp class bb
[DeviceA-dhcp-class-bb] if-match rule 1 option 82 hex 0003 offset 4 length 2
[DeviceA-dhcp-class-bb] quit
# Create DHCP address pool 2.
[DeviceA] dhcp server ip-pool 2
# Specify the subnet for dynamic address allocation.
[DeviceA-dhcp-pool-2] network 10.1.3.0 mask 255.255.255.0
# Specify address range 10.1.3.2 to 10.1.3.48 for DHCP user class aa.
[DeviceA-dhcp-pool-2] class aa range 10.1.3.2 10.1.3.48
# Specify address range 10.1.3.49 to 10.1.3.100 for DHCP user class bb.
[DeviceA-dhcp-pool-2] class bb range 10.1.3.49 10.1.3.100
[DeviceA-dhcp-pool-2] tftp-server ip-address 10.1.1.4
[DeviceA-dhcp-pool-2] dns-list 10.1.1.3
[DeviceA-dhcp-pool-2] domain-name com
[DeviceA-dhcp-pool-2] gateway-list 10.1.3.1
[DeviceA-dhcp-pool-2] quit
# Apply the DHCP address pool to VLAN-interface 2.
[DeviceA-Vlan-interface2] dhcp server apply ip-pool 2
# Configure a static route to subnet 10.1.3.0/24.
[DeviceA] ip route-static 10.1.3.0 24 10.1.2.2
Configuring Device B
[DeviceB] vlan 2
[DeviceB-vlan2] port GigabitEthernet 1/0/2
[DeviceB-vlan2] quit
[DeviceB] interface Vlan-interface 2
[DeviceB-Vlan-interface2] ip address 10.1.2.2 24
[DeviceB-Vlan-interface2] quit
# Assign interfaces GigabitEthernet 1/0/1 and GigabitEthernet 1/0/3 to VLAN 3.
[DeviceB] vlan 3
[DeviceB-vlan3] port GigabitEthernet 1/0/1
[DeviceB-vlan3] port GigabitEthernet 1/0/3
[DeviceB-vlan3] quit
[DeviceB] interface Vlan-interface 3
[DeviceB-Vlan-interface3] ip address 10.1.3.1 24
[DeviceB-Vlan-interface3] quit
# Enable DHCP.
[DeviceB] dhcp enable
# Enable DHCP relay agent on VLAN-interface 3.
[DeviceB] interface vlan-interface 3
[DeviceB-Vlan-interface3] dhcp select relay
# Specify the IP address of the DHCP server.
[DeviceB-Vlan-interface3] dhcp relay server-address 10.1.2.1
# Enable the DHCP relay agent to support Option 82.
[DeviceB-Vlan-interface3] dhcp relay information enable
# Enable recording of client information in DHCP relay entries.
[DeviceB] dhcp relay client-information record
# Enable IPv4 source guard on VLAN-interface 3 to filter incoming packets by source IPv4 addresses and source MAC addresses.
[DeviceB-Vlan-interface3] ip verify source ip-address mac-address
# Configure a static route to subnet 10.1.1.0/24.
[DeviceB] ip route-static 10.1.1.0 24 10.1.2.1
# Verify that the IP address 10.1.3.3 has been assigned to a client.
<DeviceA> display dhcp server ip-in-use ip 10.1.3.3
IP address Client identifier/ Lease expiration Type
Hardware address
10.1.3.3 0033-6365-352e-6136- Jan 2 00:34:02 2011 Auto(C)
6466-2e65-3133-392d-
5465-6e2d-4769-6761-
6269-7445-7468-6572-
6e65-7431-2f30-2f35-
31
# Verify that the hosts at each branch can obtain IP addresses from the address range assigned to the branch. This example uses a host at branch 2.
C:\Documents and Settings\aa>ipconfig
Windows IP Configuration
Ethernet adapter aa:
Connection-specific DNS Suffix . : domain-name com
IP Address. . . . . . . . . . . . : 10.1.3.3
Subnet Mask . . . . . . . . . . . : 255.255.255.0
IP Address. . . . . . . . . . . . : fe80::20f:3dff:fe80:2b38%4
Default Gateway . . . . . . . . . : 10.1.3.1
# Manually assign IP address 10.1.3.87 to a host at branch 2, and verify that the host cannot access the TFTP server. (Details not shown.)
Configuration files
· Device A:
dhcp enable
vlan 2 to 3
dhcp class aa
dhcp class bb
dns-list 10.1.1.3
domain-name com
forbidden-ip 10.1.1.4
dns-list 10.1.1.3
domain-name com
interface Vlan-interface2
ip address 10.1.2.1 255.255.255.0
interface Vlan-interface3
port link-mode bridge
port access vlan 3
port access vlan 2
· Device B:
dhcp enable
vlan 2 to 3
ip address 10.1.2.2 255.255.255.0
ip address 10.1.3.1 255.255.255.0
dhcp select relay
port access vlan 3
port access vlan 2
port access vlan 3
Related documentation
· H3C S7500E-X Switch Series Layer 3—IP Services Configuration Guide-Release 7168
· H3C S7500E-X Switch Series Layer 3—IP Services Command Reference-Release 7168
