08-MPLS Configuration Guide
HomeSupportRoutersSR8800 SeriesConfigure & DeployConfiguration GuidesH3C SR8800 Configuration Guide-Release3347-6W10308-MPLS Configuration Guide
05-MPLS L3VPN Configuration
05-MPLS L3VPN Configuration 1.88 MB
Configuring MPLS L3VPN·· 1
MPLS L3VPN overview·· 1
MPLS L3VPN concepts 2
MPLS L3VPN packet forwarding· 4
MPLS L3VPN networking schemes 5
MPLS L3VPN routing information advertisement 8
Inter-AS VPN·· 9
Carrier’s carrier 12
Nested VPN·· 14
Multi-role host 16
HoVPN·· 16
OSPF VPN extension· 18
BGP AS number substitution· 21
Multi-VPN-instance CE· 22
MPLS L3VPN configuration task list 23
Configuring basic MPLS L3VPN·· 24
Configuration prerequisites 24
Configuring VPN instances 24
Configuring routing between PE and CE· 27
Configuring routing between PEs 33
Configuring routing features for BGP VPNv4 subaddress family· 33
Configuring inter-AS VPN·· 36
Configuration prerequisites 36
Configuring inter-AS option A·· 37
Configuring inter-AS option B· 37
Configuring inter-AS option C·· 38
Configuring nested VPN·· 40
Configuration prerequisites 40
Configuring multi-role host 41
Configuration prerequisites 41
Configuring and applying policy routing· 41
Configuring a static route· 42
Configuring HoVPN·· 42
Configuration prerequisites 42
Configuring an OSPF sham link· 43
Configuration prerequisites 43
Configuring a loopback interface· 43
Redistributing the loopback interface route and OSPF routes into BGP· 44
Creating a sham link· 44
Configuring routing on an MCE· 45
Configuration prerequisites 45
Configuring routing between MCE and VPN site· 45
Configuring routing between MCE and PE· 50
Specifying the VPN label processing mode· 54
Configuring BGP AS number substitution· 55
Configuration prerequisites 55
Configuration procedure· 55
Displaying and maintaining MPLS L3VPN·· 55
Resetting BGP connections 55
Displaying and maintaining MPLS L3VPN·· 56
MPLS L3VPN configuration examples 59
Configuring MPLS L3VPNs using EBGP between PE and CE· 59
Configuring MPLS L3VPNs using IBGP between PE and CE· 66
Configuring an MPLS L3VPN that uses a GRE tunnel 74
Configuring inter-AS option A·· 79
Configuring inter-AS option B· 84
Configuring inter-AS option C·· 89
Configuring carrier’s carrier 95
Configuring nested VPN·· 103
Configuring HoVPN·· 112
Configuring OSPF sham links 119
Configuring BGP AS number substitution· 124
Configuring IPv6 MPLS L3VPN·· 128
IPv6 MPLS L3VPN overview·· 128
IPv6 MPLS L3VPN packet forwarding· 129
IPv6 MPLS L3VPN routing information advertisement 129
IPv6 MPLS L3VPN networking schemes and functions 130
IPv6 MPLS L3VPN configuration task list 130
Configuring basic IPv6 MPLS L3VPN·· 130
Basic IPv6 MPLS L3VPN configuration task list 130
Configuration prerequisites 131
Configuring VPN instances 131
Configuring route related attributes for a VPN instance· 132
Configuring routing between PE and CE· 134
Configuring routing between PEs 137
Configuring routing features for the BGP-VPNv6 subaddress family· 138
Configuring inter-AS IPv6 VPN·· 139
Configuration prerequisites 139
Configuring inter-AS IPv6 VPN option A·· 140
Configuring inter-AS IPv6 VPN option C·· 140
Configuring routing on an MCE· 141
Configuration prerequisites 141
Configuring routing between MCE and VPN site· 141
Configuring routing between MCE and PE· 145
Displaying and maintaining IPv6 MPLS L3VPN·· 148
Resetting BGP connections 148
Displaying information about IPv6 MPLS L3VPN·· 148
IPv6 MPLS L3VPN configuration examples 150
Configuring IPv6 MPLS L3VPNs 150
Configuring inter-AS IPv6 VPN option A·· 157
Configuring inter-AS IPv6 VPN option C·· 162
Configuring carrier’s carrier 169
This chapter covers only introduction to and configuration of MPLS L3VPN. For information about MPLS basics, see the chapter “Configuring basic MPLS.” For information about BGP, see Layer 3—IP Routing Configuration Guide.
MPLS L3VPN overview
MPLS L3VPN is a PE-based L3VPN technology. It uses BGP to advertise VPN routes and uses MPLS to forward VPN packets over service provider backbones.
MPLS L3VPN provides flexible networking modes, excellent scalability, and convenient support for MPLS QoS and MPLS TE.
MPLS L3VPN comprises the following types of devices:
·           Customer edge (CE) device—A CE resides on a customer network and has one or more interfaces directly connected to service provider networks. It can be a router, a switch, or a host. It can neither “sense” the presence of any VPN nor does it need to support MPLS.
·           Provider edge (PE) device—A PE resides at the edge of a service provider network and connects one or more CEs. On an MPLS network, all VPN services are processed on the PEs.
·           Provider (P) device—A P device is a core device on a service provider network. It is not directly connected to any CE. It has only basic MPLS forwarding capability.
Figure 1 Network diagram for MPLS L3VPN model
CEs and PEs mark the boundary between the service providers and the customers.
A CE is usually a router. After a CE establishes adjacency with a directly connected PE, it advertises its VPN routes to the PE and learns remote VPN routes from the PE. A CE and a PE use BGP/IGP to exchange routing information. You can also configure static routes between them.
After a PE learns the VPN routing information of a CE, it uses BGP to exchange VPN routing information with other PEs. A PE maintains routing information about only VPNs that are directly connected, rather than all VPN routing information on the provider network.
A P router only maintains routes to PEs and does not deal with VPN routing information.
When VPN traffic travels over the MPLS backbone, the ingress PE functions as the ingress LSR, the egress PE functions as the egress LSR, and P routers function as the transit LSRs.
MPLS L3VPN concepts
Site
Sites are often mentioned in the VPN. A site has the following features:
·           A site is a group of IP systems with IP connectivity that does not rely on any service provider network to implement.
·           The classification of a site depends on the topology relationship of the devices, rather than the geographical positions, though the devices at a site are adjacent to each other geographically in most cases.
·           The devices at a site can belong to multiple VPNs.
·           A site is connected to a provider network through one or more CEs. A site can contain many CEs, but a CE can belong to only one site.
Sites connected to the same provider network can be classified into different sets by policies. Only the sites in the same set can access each other through the provider network. Such a set is called a VPN.
Address space overlapping
Each VPN independently manages the addresses that it uses. The assembly of such addresses for a VPN is called an address space.
The address spaces of VPNs may overlap. For example, if both VPN 1 and VPN 2 use the addresses on network segment 10.110.10.0/24, address space overlapping occurs.
VPN instance
In MPLS VPN, routes of different VPNs are identified by VPN instances.
A PE creates and maintains a VPN instance for each directly connected site. Each VPN instance contains the VPN membership and routing rules of the corresponding site. If a user at a site belongs to multiple VPNs at the same time, the VPN instance of the site contains information about all the VPNs.
For independence and security of VPN data, each VPN instance on a PE maintains a relatively independent routing table and a separate label forwarding information base (LFIB). VPN instance information includes the LFIB, the IP routing table, the interfaces bound to the VPN instance, and the administration information of the VPN instance. The administration information of a VPN instance includes the route distinguisher (RD), route filtering policy, and member interface list.
VPN-IPv4 address
Traditional BGP cannot process VPN routes which have overlapping address spaces. If, for example, both VPN 1 and VPN 2 use addresses on the segment 10.110.10.0/24 and each advertise a route to the segment, BGP selects only one of them, which results in loss of the other route.
PEs use MP-BGP to advertise VPN routes, and use VPN-IPv4 address family to solve the problem with traditional BGP.
A VPN-IPv4 address consists of 12 bytes. The first eight bytes represent the RD, followed by a 4-byte IPv4 address prefix, as shown in Figure 2.
Figure 2 VPN-IPv4 address structure
When a PE receives an ordinary IPv4 route from a CE, it must advertise the VPN route to the peer PE. The uniqueness of a VPN route is implemented by adding an RD to the route.
A service provider can independently assign RDs provided the assigned RDs are unique. Thus, a PE can advertise different routes to VPNs even if the VPNs are from different service providers and are using the same IPv4 address space.
Configure a distinct RD for each VPN instance on a PE, so that routes to the same CE use the same RD. The VPN-IPv4 address with an RD of 0 is in fact a globally unique IPv4 address.
By prefixing a distinct RD to a specific IPv4 address prefix, you get a globally unique VPN IPv4 address prefix.
An RD can be related to an autonomous system (AS) number, in which case it is the combination of the AS number and a discretionary number; or it can be related to an IP address, in which case it is the combination of the IP address and a discretionary number.
An RD can be in one of the following three formats distinguished by the Type field:
·           When the value of the Type field is 0, the Administrator subfield occupies two bytes, the Assigned number subfield occupies four bytes, and the RD format is 16-bit AS number:32-bit user-defined number. For example, 100:1.
·           When the value of the Type field is 1, the Administrator subfield occupies four bytes, the Assigned number subfield occupies two bytes, and the RD format is 32-bit IPv4 address:16-bit user-defined number. For example, 172.1.1.1:1.
·           When the value of the Type field is 2, the Administrator subfield occupies four bytes, the Assigned number subfield occupies two bytes, and the RD format is 32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
To guarantee global uniqueness for RDs, do not set the Administrator subfield to any private AS number or private IP address.
VPN target attributes
MPLS L3VPN uses the BGP extended community attributes called VPN target attributes, or route target attributes, to control the advertisement of VPN routing information.
A VPN instance on a PE supports two types of VPN target attributes:
·           Export target attribute: A local PE sets this type of VPN target attribute for VPN-IPv4 routes learned from directly connected sites before advertising them to other PEs.
·           Import target attribute: A PE checks the export target attribute of VPN-IPv4 routes advertised by other PEs. If the export target attribute matches the import target attribute of the VPN instance, the PE adds the routes to the VPN routing table.
In other words, VPN target attributes define which sites can receive VPN-IPv4 routes, and from which sites that a PE can receive routes.
Like RDs, VPN target attributes can be of three formats:
·           16-bit AS number:32-bit user-defined number. For example, 100:1.
·           32-bit IPv4 address:16-bit user-defined number. For example, 172.1.1.1:1.
·           32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
MP-BGP
Multiprotocol extensions for BGP-4 (MP-BGP) advertises VPN composition information and routes between PEs. It is backward compatible and supports both traditional IPv4 address family and other address families, such as VPN-IPv4 address family.
Using MP-BGP can guarantee that private routes of a VPN are advertised only in the VPN and implement communications between MPLS VPN members.
Routing policy
In addition to the import and export extended communities for controlling VPN route advertisement, you can also configure import and export routing policies to control the redistribution and advertisement of VPN routes more precisely.
An import routing policy can further filter the routes that can be advertised to a VPN instance by using the VPN target attribute of import target attribute. It can reject the routes selected by the communities in the import target attribute. An export routing policy can reject the routes selected by the communities in the export target attribute.
After a VPN instance is created, you can configure an import routing policy, an export routing policy, or both as needed.
Tunneling policy
A tunneling policy is used to select the tunnel for the packets of a specific VPN instance to use.
After a VPN instance is created, you can optionally configure a tunneling policy for the VPN instance. By default, only one tunnel is selected (no load balancing) in this order: LSP tunnel, CR-LSP tunnel. A tunneling policy takes effect only within the local AS.
For basic MPLS L3VPN applications in a single AS, VPN packets are forwarded with the following layers of labels:
·           Layer 1 labels—Outer labels, used for label switching inside the backbone. They indicate LSPs from the local PEs to the remote PEs. Based on layer 1 labels, VPN packets can be label switched along the LSPs to the remote PEs.
·           Layer 2 labels—Inner labels, used for forwarding packets from the remote PEs to the CEs. An inner label indicates to which site, or more precisely, to which CE the packet should be sent. A PE finds the interface for forwarding a packet according to the inner label.
If two sites (CEs) belong to the same VPN and are connected to the same PE, each CE only needs to know how to reach the other CE.
The following takes Figure 3 as an example to illustrate the VPN packet forwarding procedure.
Figure 3 VPN packet forwarding
1.      Site 1 sends an IP packet with the destination address of 1.1.1.2. CE 1 transmits the packet to PE 1.
2.      PE 1 searches VPN instance entries based on the inbound interface and destination address of the packet. Once finding a matching entry, PE 1 labels the packet with both inner and outer labels and forwards the packet out.
3.      The MPLS backbone transmits the packet to PE 2 by outer label. The outer label is removed from the packet at the penultimate hop.
4.      PE 2 searches VPN instance entries according to the inner label and destination address of the packet to determine the outbound interface and then forwards the packet out the interface to CE 2.
5.      CE 2 transmits the packet to the destination by IP forwarding.
In MPLS L3VPNs, VPN target attributes are used to control the advertisement and reception of VPN routes between sites. They work independently and can be configured with multiple values to support flexible VPN access control and implement multiple types of VPN networking schemes.
Basic VPN networking scheme
In the simplest case, all users in a VPN form a closed user group. They can forward traffic to each other but cannot communicate with any user outside the VPN.
For this networking scheme, the basic VPN networking scheme, you need to assign a VPN target to each VPN for identifying the export target attribute and import target attribute of the VPN. Moreover, this VPN target cannot be used by any other VPNs.
Figure 4 Network diagram for basic VPN networking scheme
In Figure 4, for example, the VPN target for VPN 1 is 100:1 on the PEs, while that for VPN 2 is 200:1. The two VPN 1 sites can communicate with each other, and the two VPN 2 sites can communicate with each other. However, the VPN 1 sites cannot communicate with the VPN 2 sites.
Hub and spoke networking scheme
For a VPN where a central access control device is required and all users must communicate with each other through the access control device, the hub and spoke networking scheme can be used to implement the monitoring and filtering of user communications.
This networking scheme requires two VPN targets: one for the hub and the other for the spoke.
The VPN target setting rules for VPN instances of all sites on PEs are as follows:
·           On spoke PEs (that is, the PEs connected with spoke sites), set the export target attribute to Spoke and the import target attribute to Hub.
·           On the hub PE (that is, the PE connected to the hub site), specify two interfaces or subinterfaces, one for receiving routes from spoke PEs, and the other for advertising routes to spoke PEs. Set the import target attribute of the VPN instance for the former to Spoke, and the export target attribute of the VPN instance for the latter to Hub.
Figure 5 Network diagram for hub and spoke networking scheme
In Figure 5, the spoke sites communicate with each other through the hub site. The arrows in the figure indicate the advertising path of routes from Site 2 to Site 1:
·           The hub PE can receive all the VPN-IPv4 routes advertised by spoke PEs.
·           All spoke PEs can receive the VPN-IPv4 routes advertised by the hub PE.
·           The hub PE advertises the routes learned from a spoke PE to the other spoke PEs. Thus, the spoke sites can communicate with each other through the hub site.
·           The import target attribute of any spoke PE is distinct from the export VPN targets of the other spoke PEs. Therefore, any two spoke PEs can neither directly advertise VPN-IPv4 routes to each other nor directly access each other.
Extranet networking scheme
The extranet networking scheme can be used when some resources in a VPN are to be accessed by users that are not in the VPN.
In this kind of networking scheme, if a VPN needs to access a shared site, the export target attribute and the import target attribute of the VPN must be contained respectively in the import target attribute and the export target attribute of the VPN instance of the shared site.
Figure 6 Network diagram for extranet networking scheme
In Figure 6, VPN 1 and VPN 2 can access Site 3 of VPN 1.
·           PE 3 can receive the VPN-IPv4 routes advertised by PE 1 and PE 2.
·           PE 1 and PE 2 can receive the VPN-IPv4 routes advertised by PE 3.
·           Based on the above, Site 1 and Site 3 of VPN 1 can communicate with each other, and Site 2 of VPN 2 and Site 3 of VPN 1 can communicate with each other.
PE 3 advertises neither the VPN-IPv4 routes received from PE 1 to PE 2, nor the VPN-IPv4 routes received from PE 2 to PE 1 (that is, routes learned from an IBGP neighbor will not be advertised to any other IBGP neighbor). Therefore, Site 1 of VPN 1 and Site 2 of VPN 2 cannot communicate with each other.
In basic MPLS L3VPN networking, the advertisement of VPN routing information involves CEs and PEs. A P router maintains only the routes of the backbone and does not need to know any VPN routing information. A PE maintains only the routing information of the VPNs directly connected to it, rather than that of all VPNs. Therefore, MPLS L3VPN has excellent scalability.
The VPN routing information of a local CE is advertised in three phases:
1.      Advertised from the local CE to the ingress PE.
2.      Advertised from the ingress PE to the egress PE.
3.      Advertised from the egress PE to the remote CE.
Then, a route is available between the local CE and the remote CE, and the VPN routing information can be advertised on the backbone.
The following describes these phases in detail.
Routing information exchange from the local CE to the ingress PE
After establishing an adjacency with the directly connected PE, a CE advertises its VPN routing information to the PE.
The route between the CE and the PE can be a static route, RIP route, OSPF route, IS-IS route, EBGP route, or IBGP route. No matter which routing protocol is used, the CE always advertises standard IPv4 routes to the PE.
Routing information exchange from the ingress PE to the egress PE
After learning the VPN routing information from the CE, the ingress PE adds RDs and VPN targets for these standard IPv4 routes to create VPN-IPv4 routes, save them to the routing table of the VPN instance that is created for the CE, and then trigger MPLS to assign VPN labels for them.
Then, the ingress PE advertises the VPN-IPv4 routes to the egress PE through MP-BGP.
Finally, the egress PE compares the export target attribute of the VPN-IPv4 routes with the import target attribute that it maintains for the VPN instance and determines whether to add the routes to the routing table of the VPN instance.
PEs use IGP to ensure the connectivity between them.
Routing information exchange from the egress PE to the remote CE
A remote CE can learn VPN routes from the egress PE in a number of ways. The routes can be static routes, RIP routes, OSPF routes, IS-IS routes, EBGP routes, and IBGP routes. The exchange of routing information between the egress PE and the remote CE is the same as that between the local CE and the ingress PE.
Inter-AS VPN
In some networking scenarios, multiple sites of a VPN may be connected to multiple ISPs in different ASs, or to multiple ASs of an ISP. Such an application is called inter-AS VPN.
RFC 2547bis presents the following inter-AS VPN solutions:
·           VRF-to-VRF—ASBRs manage VPN routes between them through subinterfaces. This solution is also called inter-AS option A.
·           EBGP redistribution of labeled VPN-IPv4 routes—ASBRs advertise labeled VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option B.
·           Multihop EBGP redistribution of labeled VPN-IPv4 routes—PEs advertise labeled VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option C.
Inter-AS option A
In this solution, PEs of two ASs are directly connected and each PE is also the ASBR of its AS.
The PEs acting as ASBRs are connected through multiple subinterfaces. Each of them treats the other as a CE of its own and advertises IPv4 routes through conventional EBGP. Within an AS, packets are forwarded using two-level label forwarding as VPN packets. Between ASBRs, conventional IP forwarding is used.
Ideally, each inter-AS has a pair of subinterfaces to exchange VPN routing information.
Figure 7 Network diagram for inter-AS option A
This kind of solution is easy to carry out because no special configuration is required on the PEs acting as the ASBRs.
However, it has limited scalability because the PEs acting as the ASBRs have to manage all the VPN routes and create VPN instances on a per-VPN basis. This leads to excessive VPN-IPv4 routes on the PEs. Moreover, the requirement to create a separate subinterface for each VPN also calls for higher performance of the PEs.
Inter-AS option B
In this kind of solution, two ASBRs use MP-EBGP to exchange labeled VPN-IPv4 routes that they have obtained from the PEs in their respective ASs.
As shown in Figure 8, the routes are advertised through the following steps:
1.      PEs in AS 100 advertise labeled VPN-IPv4 routes to the ASBR PE of AS 100 or the route reflector (RR) for the ASBR PE through MP-IBGP.
2.      The ASBR PE advertises labeled VPN-IPv4 routes to the ASBR PE of AS 200 through MP-EBGP.
3.      The ASBR PE of AS 200 advertises labeled VPN-IPv4 routes to PEs in AS 200 or to the RR for the PEs through MP-IBGP.
The ASBRs must perform the special processing on the labeled VPN-IPv4 routes, also called ASBR extension method.
Figure 8 Network diagram for inter-AS option B
In terms of scalability, inter-AS option B is better than option A.
When adopting MP-EBGP method, note the following issues:
·           ASBRs perform no VPN target filtering on VPN-IPv4 routes that they receive from each other. Therefore, the ISPs in different ASs that exchange VPN-IPv4 routes need to agree on the route exchange.
·           VPN-IPv4 routes are exchanged only between VPN peers. A VPN user can exchange VPN-IPv4 routes neither with the public network nor with MP-EBGP peers with whom it has not reached agreement on the route exchange.
Inter-AS option C
The inter-AS option A and B solutions can satisfy the needs for inter-AS VPNs. However, they require that the ASBRs maintain and advertise VPN-IPv4 routes. When every AS needs to exchange a great amount of VPN routes, the ASBRs may become bottlenecks hindering network extension.
One way to solve the above problem is to make PEs directly exchange VPN-IPv4 routes without the participation of ASBRs:
·           Two ASBRs advertise labeled IPv4 routes to PEs in their respective ASs through MP-IBGP.
·           The ASBRs neither maintain VPN-IPv4 routes nor advertise VPN-IPv4 routes to each other.
·           An ASBR maintains labeled IPv4 routes of the PEs in the AS and advertises them to the peers in the other ASs. The ASBR of another AS also advertises labeled IPv4 routes. Thus, an LSP is established between the ingress PE and egress PE.
·           Between PEs of different ASs, Multi-hop EBGP connections are established to exchange VPN-IPv4 routes.
Figure 9 Network diagram for inter-AS option C
To improve the scalability, you can specify an RR in each AS, making it maintain all VPN-IPv4 routes and exchange VPN-IPv4 routes with PEs in the AS. The RRs in two ASs establish an inter-AS VPNv4 connection to advertise VPN-IPv4 routes, as shown in Figure 10.
Figure 10 Network diagram for inter-AS option C using RRs
Carrier’s carrier
Introduction to carrier's carrier
It is possible that a customer of the MPLS L3VPN service provider is also a service provider. In this case, the MPLS L3VPN service provider is called the provider carrier or the Level 1 carrier, while the customer is called the customer carrier or the Level 2 carrier. This networking model is referred to as carrier’s carrier. In this model, the Level 2 service provider serves as a CE of the Level 1 service provider.
For good scalability, the Level 1 carrier does not redistribute the routes of the customer network connected to a Level 2 carrier; it only redistributes the routes for delivering packets between different sites of the Level 2 carrier. Routes of the customer networks connected to a Level 2 carrier are exchanged through the BGP session established between the routers of the Level 2 carrier. This can greatly reduce the number of routes maintained by the Level 1 carrier network.
Implementation of carrier’s carrier
Compared with the common MPLS L3VPN, the carrier’s carrier is different because of the way in which a CE of a Level 1 carrier, that is, a Level 2 carrier, accesses a PE of the Level 1 carrier:
·           If the PE and the CE are in a same AS, you need to configure IGP and LDP between them.
·           If the PE and the CE are not in the same AS, you need to configure MP-EBGP to label the routes exchanged between them.
In either case, you need to enable MPLS on the CE of the Level 1 carrier. Moreover, the CE holds the VPN routes of the Level 2 carrier, but it does not advertise the routes to the PE of the Level 1 carrier; it only exchanges the routes with other PEs of the Level 2 carrier.
A Level 2 carrier can be an ordinary ISP or an MPLS L3VPN service provider.
When the Level 2 carrier is an ordinary ISP, its PEs run IGP to communicate with the CEs, rather than MPLS. As shown in Figure 11, PE 3 and PE 4 exchange VPN routes of the Level 2 carrier through IBGP sessions.
Figure 11 Scenario where the Level 2 carrier is an ISP
When the Level 2 carrier is an MPLS L3VPN service provider, its PEs need to run IGP and LDP to communicate with CEs. As shown in Figure 12, PE 3 and PE 4 exchange VPN routes of the Level 2 carrier through MP-IBGP sessions.
Figure 12 Scenario where the Level 2 carrier is an MPLS L3VPN service provider
CAUTION
CAUTION:
If equal cost routes exist between the Level 1 carrier and the Level 2 carrier, H3C recommends establishing equal cost LSPs between them.
Nested VPN
Background
In an MPLS L3VPN network, generally a service provider runs an MPLS L3VPN backbone and provides VPN services through PEs. Different sites of a VPN customer are connected to the PEs through CEs to implement communication. In this scenario, a customer’s networks are ordinary IP networks and cannot be further divided into sub-VPNs.
However, in actual applications, customer networks can be dramatically different in form and complexity, and a customer network may need to use VPNs to further group its users. The traditional solution to this request is to implement internal VPN configuration on the service provider’s PEs. This solution is easy to deploy, but it increases the network operation cost and brings issues on management and security because:
·           The number of VPNs that PEs must support will increase sharply.
·           Any modification of an internal VPN must be done through the service provider.
The nested VPN technology offers a better solution. It exchanges VPNv4 routes between PEs and CEs of the ISP MPLS L3VPN and allows a customer to manage its own internal VPNs. Figure 13 depicts a nested VPN network. On the service provider’s MPLS VPN network, there is a customer VPN named VPN A. The customer VPN contains two sub-VPNs, VPN A-1 and VPN A-2. The service provider PEs treat the customer’s network as a common VPN user and do not join any sub-VPNs. The customer’s CE devices (CE 1, CE 2, CE 7 and CE 8) exchange VPNv4 routes that carry the sub-VPN routing information with the service provider PEs, implementing the propagation of the sub-VPN routing information throughout the customer network.
Figure 13 Network diagram for nested VPN
Propagation of routing information
In a nested VPN network, routing information is propagated in the following process:
1.      A provider PE and its CEs exchange VPNv4 routes, which carry information about users’ internal VPNs.
2.      After receiving a VPNv4 route, a provider PE keeps the user’s internal VPN information, and appends the user’s MPLS VPN attributes on the service provider network. That is, it replaces the RD of the VPNv4 route with the RD of the user’s MPLS VPN on the service provider network and adds the export route-target (ERT) attribute of the user’s MPLS VPN on the service provider network to the extended community attribute list of the route. The internal VPN information of the user is maintained on the provider PE.
3.      The provider PE advertises VPNv4 routes which carry the comprehensive VPN information to the other PEs of the service provider.
4.      After another provider PE receives the VPNv4 routes, it matches the VPNv4 routes based on its local VPNs. Each local VPN accepts routes of its own and advertises them to its connected sub-VPN CEs (such as CE 3 and CE 4, or CE 5 and CE 6 in Figure 13). If a CE is connected to a provider PE through an IPv4 connection, the PE advertises IPv4 routes to the CE. If a CE is connected to a provider PE through a VPNv4 connection (a user MPLS VPN network), the PE advertises VPNv4 routes to the CE.
Benefits
The nested VPN technology features the following main benefits:
·           Support for VPN aggregation. It can aggregate a customer’s internal VPNs into one VPN on the service provider’s MPLS VPN network.
·           Support for both symmetric networking and asymmetric networking. Sites of the same VPN can have the same number or different numbers of internal VPNs.
·           Support for multiple levels of nesting of internal VPNs.
Nested VPN is flexible and easy to implement and can reduce the cost because a customer only needs to pay for one MPLS VPN to have multiple internal VPNs connected. Nested VPN provides diversified VPN networking methods for a customer, and allows for multi-level hierarchical access control over the internal VPNs.
Multi-role host
The VPN attributes of the packets forwarded from a CE to a PE depend on the VPN instance bound to the inbound interface. Therefore, all CEs whose packets are forwarded through the same inbound interface of a PE must belong to the same VPN.
In a real networking environment, however, a CE may need to access multiple VPNs through a single physical interface. In this case, you can set multiple logical interfaces to satisfy the requirement. But this needs extra configurations and brings limitations to the application.
Using multi-role host, you can configure policy routing on the PE to allow packets from the CE to access multiple VPNs.
To allow information from other VPNs to reach the CE from the PE, you must configure static routes on other VPNs that take the interface connected to the CE as the next hop.
All IP addresses associated with the PE must be unique to implement the multi-role host feature.
In practice, H3C recommends centralizing the addresses of each VPN to improve the forwarding efficiency.
HoVPN
Why HoVPN?
In MPLS L3VPN solutions, PEs are the key devices. They provide the following functions:
·           User access. This means that the PEs must have a large amount of interfaces.
·           VPN route managing and advertising, and user packet processing. These require that a PE must have a large-capacity memory and high forwarding capability.
Most of the current network schemes use the typical hierarchical architecture. For example, the MAN architecture contains typically three layers, namely, the core layer, distribution layer, and access layer. From the core layer to the access layer, the performance requirements on the devices decrease while the network expands.
MPLS L3VPN, on the contrary, is a plane model where performance requirements are the same for all PEs. If a certain PE has limited performance or scalability, the performance or scalability of the whole network is influenced.
Due to the specified difference, you are faced with the scalability problem when deploying PEs at any of the three layers. Therefore, the plane model is not applicable to the large-scale VPN deployment.
To solve the scalability problem of the plane model, MPLS L3VPN must transition to the hierarchical model.
In MPLS L3VPN, hierarchy of VPN (HoVPN) was proposed to meet that requirement. With HoVPN, the PE functions can be distributed among multiple PEs, which take different roles for the same functions and form a hierarchical architecture.
As in the typical hierarchical network model, HoVPN has different requirements on the devices at different layers of the hierarchy.
Implementation of HoVPN
Figure 14 Basic architecture of HoVPN
As shown in Figure 14, devices directly connected to CEs are called underlayer PEs (UPEs) or user-end PEs, whereas devices that are connected with UPEs and are in the internal network are called superstratum PEs (SPE) or service provider-end PEs.
The hierarchical PE consists of multiple UPEs and SPEs, which function together as a traditional PE.
With the HoVPN solution, PE functions are implemented hierarchically. Hence, the solution is also called hierarchy of PE (HoPE).
UPEs and SPEs play different roles:
·           A UPE allows user access. It maintains the routes of the VPN sites that are directly connected with it, It does not maintain the routes of the remote sites in the VPN, or only maintains their summary routes. A UPE assigns inner labels to the routes of its directly connected sites, and advertises the labels to the SPE along with VPN routes through MP-BGP.
·           An SPE manages and advertises VPN routes. It maintains all the routes of the VPNs connected through UPEs, including the routes of both the local and remote sites. An SPE advertises routes along with labels to UPEs, including the default routes of VPN instances or summary routes and the routes permitted by the routing policy. By using routing policies, you can control which nodes in a VPN can communicate with each other.
Different roles mean different requirements:
·           An SPE is required to have large-capacity routing table, high forwarding performance, and fewer interface resources.
·           A UPE is required to have small-capacity routing table, low forwarding performance, but higher access capability.
HoVPN takes full use of both the high performance of SPEs and the high access capability of UPEs.
The concepts of SPE and UPE are relative. In the hierarchical PE architecture, a PE may be the SPE of its underlayer PEs and a UPE of its SPE at the same time.
The HoPE and common PEs can coexist in an MPLS network.
SPE-UPE
The MP-BGP running between SPE and UPE can be either MP-IBGP or MP-EBGP. Which one to use depends on whether the UPE and SPE belong to a same AS.
With MP-IBGP, in order to advertise routes between IBGP peers, the SPE acts as the RR and advertises routes from IBGP peer UPE to IBGP peer SPE. However, it does not act as the RR of the other PEs.
Recursion and extension of HoVPN
HoVPN supports HoPE recursion:
·           A HoPE can act as a UPE to form a new HoPE with an SPE.
·           A HoPE can act as an SPE to form a new HoPE with multiple UPEs.
·           HoVPN supports multi-level recursion.
With recursion of HoPEs, a VPN can be extended infinitely in theory.
Figure 15 Recursion of HoPEs
Figure 15 shows a three-level HoPE. The PE in the middle is called the middle-level PE (MPE). MP-BGP runs between SPE and MPE, as well as between MPE and UPE.
The term of MPE does not really exist in a HoVPN model. It is used here just for the convenience of description.
MP-BGP advertises all the VPN routes of the UPEs to the SPEs, and advertises the default routes of the VPN instance of the SPEs or the VPN routes permitted by the routing policies to the UPEs.
The SPE maintains the VPN routes of all sites in the HoVPN. Each UPE maintains only VPN routes of its directly connected sites. The number of routes maintained by the MPE is between SPE and UPE.
OSPF VPN extension
This section focuses on the OSPF VPN extension. For more information about OSPF, see Layer 3—IP Routing Configuration Guide.
OSPF for VPNs on a PE
OSPF is a prevalent IGP protocol. It often runs between PE and CE to simplify CE configuration and management because the CEs only need to support OSPF. In addition, if the customers require MPLS L3VPN services through conventional OSPF backbone, using OSPF between PE and CE can simplify the transition.
For OSPF to run between CE and PE, the PE must support multiple OSPF processes. Each OSPF process must correspond to a VPN instance and have its own interface and routing table.
The following describes details of OSPF configuration between PE and CE.
·           Configuration of OSPF areas between PE and CE
The OSPF area between a PE and a CE can be either a non-backbone area or a backbone area.
In the OSPF VPN extension application, the MPLS VPN backbone is considered the backbone area (area 0). The area 0 of each VPN site must be connected to the MPLS VPN backbone because OSPF requires that the backbone area be contiguous.
If a VPN site contains an OSPF area 0, the connected PE must be connected to the backbone area of the VPN site through area 0. You can configure a logical connection by using a virtual link.
·           BGP/OSPF interaction
PEs advertise VPN routes to each other through BGP and to CEs through OSPF.
Conventional OSPF considers two sites to be in different ASs even if they belong to the same VPN. Therefore, the routes that one site learns are advertised to the other as external routes. This results in more OSPF traffic and network management problems.
The extended OSPF protocol supports multiple instances to address the previous problems. Properly configured, OSPF sites are considered directly connected, and PEs can exchange OSPF routing information as they are using dedicated lines. This improves network management and makes OSPF applications more effective.
As shown in Figure 16, PE 1 and PE 2 are connected through the MPLS backbone; CE 11, CE 21, and CE 22 belong to VPN 1. Assumes that CE 11, CE 21, and CE 22 belong to the same OSPF domain. PEs advertise VPN 1 routes in the following procedure:
a.    PE 1 redistributes OSPF routes from CE 11 into BGP.
b.    PE 1 advertises the VPN routes to PE 2 through BGP.
c.     PE 2 redistributes the BGP VPN routes into OSPF and advertises them to CE 21 and CE 22.
Figure 16 Application of OSPF in VPN
With the standard BGP/OSPF interaction, PE 2 advertises the BGP VPN routes to CE 21 and CE 22 through Type 5 LSAs (ASE LSAs). However, CE 11, CE 21, and CE 22 belong to the same OSPF domain, and the route advertisement between them should use Type 3 LSAs (inter-AS routes).
To solve the problem, the PE uses an extended BGP/OSPF interaction process called BGP/OSPF interoperability to advertise routes from one site to another, differentiating the routes from real AS-External routes. The process requires that extended BGP community attributes carry the information for identifying the OSPF attributes.
Each OSPF domain must have a configurable domain ID. H3C recommends that you configure the same domain ID or adopt the default ID for all OSPF processes of the same VPN, so the system can know that all VPN routes with the same domain ID are from the same VPN.
·           Routing loop detection
If OSPF runs between CEs and PEs and a VPN site is connected to multiple PEs, when a PE advertises the BGP VPN routes learned from MPLS/BGP to the VPN site through LSAs, the LSAs may be received by another PE, resulting in a routing loop.
To avoid routing loops, when creating Type 3 LSAs, the PE always sets the flag bit DN for BGP VPN routes learned from MPLS/BGP, regardless of whether the PE and the CEs are connected through the OSPF backbone. When performing route calculation, the OSPF process of the PE ignores the Type 3 LSAs whose DN bit is set.
If the PE needs to advertise to a CE the routes from other OSPF domains, it must indicate that it is the ASBR, and advertise the routes using Type 5 LSAs.
Sham link
Generally, BGP peers carry routing information on the MPLS VPN backbone through the BGP extended community attributes. The OSPF that runs on the remote PE can use the information to create Type 3 summary LSAs to be transmitted to the CEs. As shown in Figure 17, both site 1 and site 2 belong to VPN 1 and OSPF area1. They are connected to different PEs, PE 1 and PE 2. There is an intra-area OSPF link called backdoor link between them. In this case, the route connecting the two sites through PEs is an inter-area route. It is not preferred by OSPF because its preference is lower than that of the intra-area route across the backdoor link.
Figure 17 Network diagram for sham link
To solve the problem, you can establish a sham link between the two PEs so that the routes between them over the MPLS VPN backbone become an intra-area route.
The sham link acts as an intra-area point-to-point link and is advertised through the Type 1 LSA. You can select a route between the sham link and backdoor link by adjusting the metric.
The sham link is considered the link between the two VPN instances with one endpoint address in each VPN instance. The endpoint address is a loopback interface address with a 32-bit mask in the VPN address space on the PE. Different sham links of the same OSPF process can share an endpoint address, but that of different OSPF processes cannot.
BGP advertises the endpoint addresses of sham links as VPN-IPv4 addresses. A route across the sham link cannot be redistributed into BGP as a VPN-IPv4 route.
A sham link can be configured in any area. You need to configure it manually. In addition, the local VPN instance must have a route to the destination of the sham link.
When configuring an OSPF sham link, redistribute OSPF VPN routes to BGP, but do not redistribute BGP routes to OSPF to avoid route loops.
Since BGP detects routing loops by AS number, if EBGP runs between PEs and CEs, you must assign different AS numbers to geographically different sites to ensure correct transmission of the routing information.
The BGP AS number substitution function allows physically dispersed CEs to use the same AS number. The function is a BGP outbound policy and functions on routes to be advertised.
With the BGP AS number substitution function, when a PE advertises a route to a CE of the specified peer, if an AS number identical to that of the CE exist in the AS_PATH of the route, it will be replaced with that of the PE.
After you enable the BGP AS number substitution function, the PE re-advertises all routing information to the connected CEs in the peer group, performing BGP AS number substitution based on the above principle.
Figure 18 Application of BGP AS number substitution
In Figure 18, both CE 1 and CE 2 use the AS number of 800. AS number substitution is enabled on PE 2 for CE 2. Before advertising updates received from CE 1 to CE 2, PE 2 finds that an AS number in the AS_PATH is the same as that of CE 2 and hence substitutes its own AS number 100 for the AS number. In this way, CE 2 can normally receive the routing information from CE 1.
AS number substitution also applies to a PE connecting multiple CEs through different interfaces, such as PE 2 in Figure 18, which connects CE 2 and CE 3.
For a multi-homed CE, that is, a CE connected with multiple PEs, the BGP AS number substitution function must be used in combination with the site-of-origin (SOO) function. Otherwise, routing loops may appear.
Background
BGP/MPLS VPN transmits private network data through MPLS tunnels over the public network. However, the traditional MPLS L3VPN architecture requires that each VPN instance exclusively use a CE to connect with a PE, as shown in Figure 1.
For better services and higher security, a private network is usually divided into multiple VPNs to isolate services. To meet these requirements, you can configure a CE for each VPN, which, apparently, will increase users’ device expense and maintenance costs. Or, you can configure multiple VPNs to use the same CE and the same routing table, which cannot ensure the data security.
Using the Multi-VPN-Instance CE (MCE) function, you can remove the contradiction of low cost and high security in multi-VPN networks. MCE allows you to bind each VPN to a VLAN interface. The MCE creates and maintains a separate routing table for each VPN. This separates the forwarding paths of packets of different VPNs and, in conjunction with the PE, can correctly advertise the routes of each VPN to the peer PE, ensuring the normal transmission of VPN packets over the public network.
How MCE works
The following uses Figure 19 to describe how an MCE maintains the routing entries for multiple VPNs and exchanges VPN routes with PEs.
Figure 19 Network diagram for the MCE function
Establish a tunnel between the two sites of each VPN.
Create a routing table for VPN 1 and VPN 2 respectively on the MCE device, and bind VLAN-interface 2 to VPN 1 and VLAN-interface 3 to VPN 2. When receiving a route, the MCE device can determine the source of the routing information according to the number of the receiving interface, and adds it to the corresponding routing table.
You must also bind PE 1’s interfaces/subinterfaces connected to the MCE to the VPNs in the same way. The MCE connects to PE 1 through a trunk link, which permits packets of VLAN 2 and VLAN 3 with VLAN tags carried. In this way, PE 1 can determine the VPN a received packet belongs to according to the VLAN tag of the packet and sends the packet through the corresponding tunnel.
You can configure static routes, RIP, OSPF, IS-IS, EBGP, or IBGP between MCE and VPN site and between MCE and PE.
To implement dynamic IP assignment for DHCP clients in private networks, you can configure DHCP server or DHCP relay agent on the MCE. The IP address spaces for different private networks cannot overlap.
Complete the following tasks to configure MPLS L3VPN:
Remarks
By configuring basic MPLS L3VPN, you can construct simple VPN networks over an MPLS backbone.
To deploy special MPLS L3VPN networks, such as inter-AS VPN, nested VPN, and multi-role host, you also need to perform some specific configurations in addition to the basic MPLS L3VPN configuration.
Configuring HoVPN
The key task in MPLS L3VPN configuration is to manage the advertisement of VPN routes on the MPLS backbone, including PE-CE route exchange and PE-PE route exchange.
Complete the following tasks to configure basic MPLS L3VPN:
Remarks
Creating a VPN instance
Required
Associating a VPN instance with an interface
Required
Optional
Configuring a tunneling policy for a VPN instance
Optional
Configuring an LDP instance
Optional
Required
Required
Optional
Before you configure basic MPLS L3VPN, complete the following tasks:
·           Configure an IGP for the MPLS backbone (on the PEs and Ps) to achieve IP connectivity
·           Configure basic MPLS for the MPLS backbone
·           Configure MPLS LDP for the MPLS backbone so that LDP LSPs can be established
By configuring VPN instances on a PE, you can isolate not only VPN routes from public network routes, but also routes of a VPN from those of another VPN. This feature allows VPN instances to be used in networking scenarios besides MPLS L3VPNs.
All VPN instance configurations are performed on PEs or MCEs.
A VPN instance is associated with a site. It is a collection of the VPN membership and routing rules of its associated site. A VPN instance does not necessarily correspond to one VPN.
A VPN instance takes effect only after you configure an RD for it.
You can configure a description for a VPN instance to record its related information, such as its relationship with a certain VPN.
To create and configure a VPN instance:
Step
Remarks
1.     Enter system view.
N/A
2.     Create a VPN instance and enter VPN instance view.
N/A
3.     Configure an RD for the VPN instance.
N/A
4.     Configure a description for the VPN instance.
Optional
After creating and configuring a VPN instance, you need to associate the VPN instance with the interface for connecting the CE. Any LDP-capable interface can be associated with a VPN instance. For information about LDP-capable interfaces, see the chapter “Configuring basic MPLS.”
To associate a VPN instance with an interface:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Associate a VPN instance with the interface.
No VPN instance is associated with an interface by default.
The ip binding vpn-instance command clears the IP address of the interface on which it is configured. Be sure to re-configure an IP address for the interface after configuring the command.
The control process of VPN route advertisement is as follows:
·           When a VPN route learned from a CE gets redistributed into BGP, BGP associates it with a VPN target extended community attribute list, which is usually the export target attribute of the VPN instance associated with the CE.
·           The VPN instance determines which routes it can accept and redistribute according to the import-extcommunity in the VPN target.
·           The VPN instance determines how to change the VPN targets attributes for routes to be advertised according to the export-extcommunity in the VPN target.
To configure route related attributes for a VPN instance:
Step
Remarks
N/A
2.     Enter VPN instance view.
N/A
3.     Enter IPv4 VPN view.
ipv4-family
Optional.
4.     Configure VPN targets.
N/A
5.     Set the maximum number of routes allowed.
Optional.
6.     Apply an import routing policy.
Optional.
By default, all routes matching the import target attribute are accepted.
7.     Apply an export routing policy.
Optional.
By default, routes to be advertised are not filtered.
·       Route related attributes configured in VPN instance view are applicable to both IPv4 VPNs and IPv6 VPNs.
·       You can configure route related attributes for IPv4 VPNs in both VPN instance view and IPv4 VPN view. Those configured in IPv4 VPN view take precedence.
·       A single vpn-target command can configure up to eight VPN targets. You can configure up to 64 VPN targets for a VPN instance.
·       You can define the maximum number of routes for a VPN instance to support, preventing too many routes from being redistributed into the PE.
·       Create a routing policy before associating it with a VPN instance. Otherwise, the router cannot filter the routes to be received and advertised.
To configure a tunneling policy for a VPN instance:
Step
Remarks
N/A
2.     Create a tunneling policy and enter tunneling policy view.
tunnel-policy tunnel-policy-name
N/A
3.     Specify the tunnel selection preference order and the number of tunnels for load balancing.
tunnel select-seq { cr-lsp | lsp } * load-balance-number number
4.     Return to system view.
N/A
5.     Enter VPN instance view.
N/A
6.     Enter IPv4 VPN view.
ipv4-family
Optional.
7.     Apply the tunnel policy to the VPN instance.
tnl-policy tunnel-policy-name
·       If you specify more than one tunnel type and the number of tunnels of a type is less than the specified number of tunnels for load balancing, tunnels of different types may be used.
·       When you configure the tunnel selection preference order by using the tunnel select-seq command, a tunnel type closer to the select-seq keyword has a higher priority. For example, with the tunnel select-seq lsp cr-lsp load-balance-number 1 command configured, VPN uses a CR-LSP tunnel when no LSP exists. After an LSP is created, the VPN uses the LSP tunnel instead.
·       A tunneling policy configured in VPN instance view is applicable to both IPv4 VPNs and IPv6 VPNs.
·       You can configure a tunneling policy for IPv4 VPNs in both VPN instance view and IPv4 VPN view. A tunneling policy configured in IPv4 VPN view takes precedence.
·       Create a tunneling policy before associating it with a VPN instance. Otherwise, the default tunneling policy is used. The default tunneling policy selects only one tunnel (no load balancing) in this order: LSP tunnel, CR-LSP tunnel.
LDP instances are for carrier’s carrier networking applications.
This task is to configure the LDP capability for an existing VPN instance, create an LDP instance for the VPN instance, and configure LDP parameters for the LDP instance.
To configure an LDP instance:
Step
Remarks
N/A
2.     Enable LDP for a VPN instance, create an LDP instance, and enter MPLS LDP VPN instance view.
mpls ldp vpn-instance vpn-instance-name
Disabled by default
3.     Configure LDP parameters except LDP GR for the instance.
For configuration information, see the chapter “Configuring basic MPLS.”
Optional
·       Except the command for LDP GR, all commands available in MPLS LDP view can be configured in MPLS LDP VPN instance view. For more information about MPLS LDP, see the chapter “Configuring basic MPLS.”
·       Configurations in MPLS LDP VPN instance view affect only the LDP-enabled interface bound to the VPN instance, while configurations in MPLS LDP view do not affect interfaces bound to VPN instances. When configuring the transport address of an LDP instance, you need to use the IP address of the interface bound to the VPN instance.
·       By default, LDP adjacencies on a private network are established by using addresses of the LDP-enabled interfaces, while those on the public network are established by using the LDP LSR ID.
You can configure static routing, RIP, OSPF, IS-IS, EBGP, or IBGP between PE and CE.
Before you configure routing between PE and CE, complete the following tasks:
·           Assigning an IP address to the CE-PE interface of the CE.
·           Assigning an IP address to the PE-CE interface of the PE.
Configuring static routing between PE and CE
To configure static routing between PE and CE:
Step
Remarks
N/A
2.     Configure a static route for a VPN instance.
·       ip route-static dest-address { mask | mask-length } { gateway-address | interface-type interface-number [ gateway-address ] | vpn-instance d-vpn-instance-name gateway-address } [ preference preference-value ] [ tag tag-value ] [ description description-text ]
·       ip route-static vpn-instance s-vpn-instance-name&<1-5> dest-address { mask | mask-length } { gateway-address [ public ] | interface-type interface-number [ gateway-address ] | vpn-instance d-vpn-instance-name gateway-address } [ preference preference-value ] [ tag tag-value ] [ description description-text ]
Use either command.
Perform this configuration on PEs. On CEs, configure normal static routes.
For information about static routing, see Layer 3—IP Routing Configuration Guide.
Configuring RIP between PE and CE
A RIP process belongs to the public network or a single VPN instance. If you create a RIP process without binding it to a VPN instance, the process belongs to the public network.
To configure RIP between PE and CE:
Step
Remarks
N/A
2.     Create a RIP process for a VPN instance and enter RIP view.
rip [ process-id ] vpn-instance vpn-instance-name
Perform this configuration on PEs. On CEs, create a normal RIP process.
3.     Enable RIP on the interface attached to the specified network.
network network-address
By default, RIP is disabled on an interface.
For more information about RIP, see Layer 3IP Routing Configuration Guide.
Configuring OSPF between PE and CE
An OSPF process that is bound to a VPN instance does not use the public network router ID configured in system view. Therefore, you need to specify the router ID when starting a process or to configure the IP address for at least one interface of the VPN instance.
An OSPF process belongs to the public network or a single VPN instance. If you create an OSPF process without binding it to a VPN instance, the process belongs to the public network.
To configure OSPF between PE and CE:
Step
Remarks
N/A
2.     Create an OSPF process for a VPN instance and enter the OSPF view.
ospf [ process-id | router-id router-id | vpn-instance vpn-instance-name ] *
Perform the configurations on PEs. On CEs, create a normal OSPF process.
3.     Configure the OSPF domain ID.
Optional.
0 by default.
4.     Configure the type codes of OSPF extended community attributes.
Optional.
The defaults are as follows:
0x0005 for Domain ID,
0x0107 for Router ID, and
0x0306 for Route Type.
5.     Create an OSPF area and enter area view.
area area-id
By default, no OSPF area is created.
6.     Enable OSPF on the interface attached to the specified network in the area.
By default, an interface neither belongs to any area nor runs OSPF.
Deleting a VPN instance also deletes all the associated OSPF processes.
An OSPF process can be configured with only one domain ID. Domain IDs of different OSPF processes are independent of each other.
All OSPF processes of a VPN must be configured with the same domain ID for routes to be correctly advertised, while OSPF processes on PEs in different VPNs can be configured with domain IDs as desired.
The domain ID of an OSPF process is included in the routes generated by the process. When an OSPF route is redistributed into BGP, the OSPF domain ID is included in the BGP VPN route and delivered as a BGP extended community attribute.
·       After configuring an OSPF process for a VPN instance, you must enable OSPF. The configuration procedure is the same as that for a normal OSPF process.
·       For more information about OSPF, see Layer 3—IP Routing Configuration Guide.
·       After you configure the domain-id domain-id [ secondary ] command, the configuration will not take effect until you execute the reset ospf command.
Configuring IS-IS between PE and CE
An IS-IS process belongs to the public network or a single VPN instance. If you create an IS-IS process without binding it to a VPN instance, the process belongs to the public network.
To configure IS-IS between PE and CE:
Step
Remarks
N/A
2.     Create an IS-IS process for a VPN instance and enter IS-IS view.
isis [ process-id ] vpn-instance vpn-instance-name
N/A
3.     Configure a network entity title for the IS-IS process.
network-entity net
Not configured by default
N/A
5.     Enter interface view.
N/A
6.     Enable the IS-IS process on the interface.
isis enable [ process-id ]
Disabled by default
For more information about IS-IS, see Layer 3—IP Routing Configuration Guide.
Configuring PE-CE route exchange through EBGP
1.      Configurations on a PE
To configure EBGP between PE and CE:
Step
Remarks
N/A
2.     Enable BGP and enter BGP view.
bgp as-number
N/A
3.     Enter BGP VPN instance view.
ipv4-family vpn-instance vpn-instance-name
N/A
4.     Configure the CE as the VPN EBGP peer.
peer { group-name | ip-address } as-number as-number
N/A
5.     Redistribute the routes of the local CEs.
import-route protocol [ process-id ] [ med med-value | route-policy route-policy-name ] *
A PE needs to redistribute the routes of the local CEs into its VPN routing table so that it can advertise them to the peer PE.
6.     Configure BGP to filter routes to be advertised.
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ direct | isis process-id | ospf process-id | rip process-id | static ]
Optional.
By default, BGP does not filter routes to be advertised.
7.     Configure BGP to filter received routes.
filter-policy { acl-number | ip-prefix ip-prefix-name } import
Optional.
By default, BGP does not filter received routes.
8.     Allow the local AS number to appear in the AS_PATH attribute of a received route and set the maximum number of repetitions.
peer { group-name | ip-address } allow-as-loop [ number ]
Optional.
For the hub and spoke networking scheme
Normally, BGP detects routing loops by AS number. In the hub and spoke networking scheme, however, with EBGP running between PE and CE, the routing information the PE advertises to a CE carries the number of the AS where the PE resides. Therefore, the route updates that the PE receives from the CE also include the number of the AS where the PE resides. This causes the PE unable to receive the route updates. In this case, routing loops must be allowed.
2.      Configurations on a CE
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure the PE as the EBGP peer.
N/A
4.     Configure the route redistribution and advertisement behavior.
Optional.
A CE needs to advertise its routes to the connected PE so that the PE can advertise them to the peer CE.
·       Exchange of BGP routes for a VPN instance is the same as that of ordinary BGP routes.
·       The BGP configuration task in BGP-VPN instance view is the same as that in BGP view. For more information, see Layer 3—IP Routing Configuration Guide.
·       For information about BGP peer and peer group configuration, see Layer 3—IP Routing Configuration Guide. This chapter does not differentiate between peer and peer group.
Configuring IBGP between PE and CE
IBGP can be used between PE and CE devices in only common MPLS L3VPN networking. In Extranet, inter-AS VPN, carrier’s carrier, nested VPN, and HoVPN networking, you cannot use IBGP between PE and CE devices.
1.      Configurations a PE
To configure IBGP between PE and CE:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure the CE as the VPN IBGP peer.
N/A
5.     Configure the system to be the RR and specify the CE as the client of the RR.
peer { group-name | ip-address } reflect-client
Optional.
By default, no RR or RR client is configured.
6.     Enable route reflection between clients.
reflect between-clients
Optional.
Enabled by default.
7.     Configure the cluster ID for the RR.
Optional.
Router ID of an RR in the cluster by default.
8.     Configure BGP to filter routes to be advertised.
Optional.
9.     Configure BGP to filter received routes.
Optional.
·       By default, a PE does not advertise routes learned from IBGP peer CEs to IBGP peers, including VPNv4 IBGP peers. Only when you configure an IBGP peer CE as a client of the RR, does the PE advertise routes learned from it to other IBGP peers.
·       You can execute the reflect between-clients command and the reflector cluster-id command in multiple views, such as BGP-VPN instance view and BGP-VPNv4 subaddress family view. The two commands take effect for only the RR in the view where they are executed. For RRs in other views, they do not take effect.
·       Configuring an RR does not change the next hop of a route. To change the next hop of a route, configure an inbound policy on the receiving side of the route.
2.      Configurations a CE
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure the PE as the IBGP peer.
N/A
Optional.
·       Exchange of BGP routes of a VPN instance is the same as that of ordinary BGP routes.
·       The BGP configuration task in BGP VPN instance view is the same as that in BGP view. For more information, see Layer 3—IP Routing Configuration Guide.
·       For information about BGP peer and BGP peer group configuration, see Layer 3—IP Routing Configuration Guide. This chapter does not differentiate between peer and peer group.
Configuring routing between PEs
To configure routing between PEs:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure the remote PE as the peer.
N/A
4.     Specify the source interface for route updates.
peer { group-name | ip-address } connect-interface interface-type interface-number
By default, BGP uses the source interface of the optimal route update packet.
5.     Enter BGP-VPNv4 subaddress family view.
ipv4-family vpnv4
N/A
6.     Enable the exchange of BGP-VPNv4 routing information with the specified peer.
peer { group-name | ip-address } enable
By default, BGP peers exchange IPv4 routing information only.
Configuring routing features for BGP VPNv4 subaddress family
With BGP VPNv4 subaddress family, there are a variety of routing features that are the same as those for BGP IPv4 unicast routing. You can select any of the features as required.
Configuring common routing features for all types of subaddress families
For VPN applications, BGP address families include BGP VPN-IPv4 address family, BGP-L2VPN address family, and VPLS address family. Every command in the following table has the same function on BGP routes for each type of the address families and only takes effect for the BGP routes in the address family view where the command is executed.
To configure common routing features for all types of subaddress families:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
peer ip-address as-number as-number
N/A
4.     Specify the interface for TCP connection.
peer ip-address connect-interface interface-type interface-number
N/A
5.     Enter address family view.
·       ipv4-family vpnv4
·       l2vpn-family
·       vpls-family
Use one of the commands as needed.
6.     Allow the local AS number to appear in the AS_PATH attribute of a received route and set the maximum number of repetitions.
Optional.
7.     Enable a peer or peer group for an address family and enable the exchange of BGP routing information of the address family.
By default, only IPv4 routing information is exchanged between BGP peers.
8.     Add a peer into an existing peer group.
peer ip-address group group-name
Optional.
9.     Configure the system to use the local address as the next hop of a route to be advertised to a specific peer or peer group.
peer { group-name | ip-address } next-hop-local
Optional.
By default, the system uses the local address as the next hop of a route to be advertised to an EBGP peer. In the inter-AS option C solution, you need to configure the peer { group-name | ip-address } next-hop-invariable command on the RR for multi-hop EBGP neighbors and reflector clients to make sure that the next hop of a VPN route will not be changed.
10.   Configure the system to be the RR and set a peer or peer group as the client of the RR.
Optional.
11.   Enable the Outbound Route Filtering (ORF) capability for a BGP peer/peer group.
peer { group-name | ip-address } capability-advertise orf ip-prefix { both | receive | send }
Optional.
By default, the ORF capability is disabled on a BGP peer or peer group.
12.   Enable VPN target filtering for received VPNv4 routes.
policy vpn-target
Optional.
Enabled by default.
13.   Enable route reflection between clients.
Optional.
Enabled by default.
14.   Specify the cluster ID of the RR.
Optional.
15.   Create an RR reflection policy.
rr-filter extended-community-list-number
Optional.
For information about BGP-L2VPN address family and VPLS address family, see MPLS Command Reference.
Configuring specific routing features for BGP-VPNv4 subaddress family
To configure specific routing features for BGP-VPNv4 subaddress family:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
N/A
ipv4-family vpnv4
N/A
6.     Set the default value of the local preference.
Optional.
100 by default.
7.     Set the default value for the system MED.
default med med-value
Optional.
By default, the default value of the system MED is 0.
8.     Filter all or certain types of routes to be advertised.
Optional.
9.     Filter received routes.
Optional.
10.   Advertise community attributes to a peer or peer group.
peer { group-name | ip-address } advertise-community
Optional.
By default, no community attributes are advertised to any peer or peer group.
11.   Filter routes received from or to be advertised to a peer or peer group based on an AS_PATH list.
peer { group-name | ip-address } as-path-acl as-path-filter-number { import | export }
Optional.
By default, no AS filtering list is applied to a peer or peer group.
12.   Advertise a default route destined for a VPN instance to a peer or peer group.
peer { group-name | ip-address } default-route-advertise vpn-instance vpn-instance-name
Optional.
By default, no default route is advertised to a peer or peer group.
13.   Apply a filtering policy to a peer or peer group.
peer { group-name | ip-address } filter-policy acl-number { export | import }
Optional.
By default, no filtering policy is applied to a peer or peer group.
14.   Apply a route filtering policy based on IP prefix list to a peer or peer group.
peer { group-name | ip-address } ip-prefix prefix-name { export | import }
Optional.
By default, no route filtering policy based on IP prefix list is applied to a peer or peer group.
15.   Specify not to change the next hop of a route when advertising it to an EBGP peer.
Optional.
By default, a device uses its address as the next hop when advertising a route to its EBGP peer.
16.   Specify the preference value for the routes received from the peer/peer group.
peer { group-name | ip-address } preferred-value value
Optional.
0 by default.
17.   Make BGP updates to be sent carry no private AS numbers.
peer { group-name | ip-address } public-as-only
Optional.
By default, a BGP update carries private AS numbers.
18.   Apply a routing policy to a peer or peer group.
peer { group-name | ip-address } route-policy route-policy-name { export | import }
Optional.
By default, no routing policy is applied to a peer or peer group.
For information about BGP routing, see Layer 3—IP Routing Configuration Guide.
Configuring inter-AS VPN
If the MPLS backbone on which the VPN routes rely spans multiple ASs, you need to configure inter-AS VPN.
Three inter-AS VPN solutions are available. You can choose them as required.
Configuration prerequisites
Before you configure inter-AS VPN, complete the following tasks:
·           Configure an IGP for the MPLS backbones in each AS to implement IP connectivity of the backbones in the AS
·           Configure basic MPLS capabilities for the MPLS backbones of each AS
·           Configure MPLS LDP for the MPLS backbones so that LDP LSPs can be established
·           Configure basic MPLS L3VPN for each AS
When configuring basic MPLS L3VPN for each AS, specific configurations may be required on PEs or ASBR PEs. This depends on the inter-AS VPN solution selected.
Configuring inter-AS option A
Inter-AS option A applies to scenarios where the number of VPNs and that of VPN routes on the PEs are relatively small. It is simple to implement.
To configure inter-AS option A, you only need to:
·           Configure basic MPLS L3VPN on each AS.
·           Configure each ASBR-PE, taking the peer ASBR-PE as its CE.
In other words, configure VPN instances on PEs and ASBR PEs respectively. The VPN instances on PEs are used to allow CEs to access the network, and those on ASBR PEs are used to access the peer ASBR PEs.
For more information, see “Configuring basic MPLS L3VPN.”
In the inter-AS option A solution, for the same VPN, the VPN targets configured on the PEs must match those configured on the ASBR-PEs in the same AS to make sure that VPN routes sent by the PEs (or ASBR-PEs) can be received by the ASBR-PEs (or PEs). VPN targets configured on the PEs in different ASs do not have such requirements.
Configuring inter-AS option B
To configure inter-AS option B on ASBR PEs:
Step
Remarks
N/A
2.     Enter interface view for the interface connecting to the remote ASBR-PE.
N/A
3.     Configure the IP address of the interface.
ip address ip-address { mask | mask-length }
N/A
N/A
5.     Enter BGP view.
bgp as-number
N/A
6.     Enter BGP-VPNv4 subaddress family view.
ipv4-family vpnv4
N/A
7.     Disable VPN target filtering for VPNv4 routes.
undo policy vpn-target
By default, PE performs VPN target filtering of the received VPNv4 routes.
The routes surviving the filtering will be added to the routing table, and the others are discarded.
In the inter-AS option B solution, the ASBR PEs need to maintain all VPNv4 routing information and advertise the information to peer ASBR PEs. In this case, the ASBR PEs must receive all VPNv4 routing information without performing VPN target filtering.
In the inter-AS option B solution, for the same VPN, the VPN targets for the VPN instances on the PEs in different ASs must match.
For inter-AS option B, two configuration methods are available:
·       Do not change the next hop on an ASBR. With this method, you still need to configure MPLS LDP between ASBRs.
·       Change the next hop on an ASBR. With this method, MPLS LDP is not required between ASBRs.
The router supports only the second method. Therefore, MP-EBGP routes will get their next hops changed by default before being redistributed to MP-IBGP. However, normal EBGP routes to be advertised to IBGP do not have their next hops changed by default. To change the next hop to a local address, use the peer { ip-address | group-name } next-hop-local command. For information about the command, see Layer 3—IP Routing Configuration Guide.
Configuring inter-AS option C
Configuring the PEs
You need to establish ordinary IBGP peer relationship between PEs and ASBR PEs in an AS and MP-EBGP peer relationship between PEs of different ASs.
The PEs and ASBR PEs in an AS must be able to exchange labeled IPv4 routes.
To configure a PE for inter-AS option C:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure the ASBR PE in the same AS as the IBGP peer.
N/A
4.     Enable the PE to exchange labeled IPv4 routes with the ASBR PE in the same AS.
peer { group-name | ip-address } label-route-capability
By default, the device does not advertise labeled routes to the IPv4 peer/peer group.
5.     Configure the PE of another AS as the EBGP peer.
N/A
ipv4-family vpnv4
N/A
7.     Enable the PE to exchange BGP VPNv4 routing information with the EBGP peer.
N/A
8.     Configure the PE not to change the next hop of a route when advertising it to the EBGP peer.
Optional.
Required only when RRs are used to advertise VPNv4 routes, where the next hop of a route advertised between RRs cannot be changed.
Configuring the ASBR PEs
In the inter-AS option C solution, an inter-AS LSP is required, and the routes advertised between the relevant PEs and ASBRs must carry MPLS label information.
An ASBR-PE establishes common IBGP peer relationship with PEs in the same AS, and common EBGP peer relationship with the peer ASBR PE. All of them exchange labeled IPv4 routes.
The public routes carrying MPLS labels are advertised through MP-BGP. According to RFC 3107 “Carrying Label Information in BGP-4”, the label mapping information for a particular route is piggybacked in the same BGP update message that is used to distribute the route itself. This capability is implemented through BGP extended attributes and requires that the BGP peers can handle labeled IPv4 routes.
To configure an ASBR PE for inter-AS option C:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure each PE in the same AS as the IBGP peer.
N/A
4.     Enable the ASBR PE to exchange labeled IPv4 routes with the PEs in the same AS.
5.     Configure the ASBR PE to change the next hop to itself when advertising routes to PEs in the same AS.
By default, a BGP speaker does not use its address as the next hop when advertising a route to its IBGP peer/peer group.
6.     Configure the remote ASBR PE as the EBGP peer.
N/A
7.     Enable the ASBR PE to exchange labeled IPv4 routes with the peer ASBR PE.
By default, the device does not advertise labeled routes to the IPv4 peer.
8.     Apply a routing policy to the routes advertised by peer ASBR PE.
peer { group-name | ip-address } route-policy route-policy-name export
Configuring the routing policy
After you configure and apply a routing policy on an ASBR PE, it:
·           Assigns MPLS labels to the routes received from the PEs in the same AS before advertising them to the peer ASBR PE.
·           Assigns new MPLS labels to the labeled IPv4 routes to be advertised to the PEs in the same AS.
Which IPv4 routes are to be assigned with MPLS labels depends on the routing policy. Only routes that satisfy the criteria are assigned with labels. All the other routes are still common IPv4 routes.
To configure a routing policy for inter-AS option C on an ASBR PE:
Step
Remarks
N/A
2.     Enter routing policy view.
route-policy policy-name permit node seq-number
N/A
3.     Configure the device to match IPv4 routes with labels.
if-match mpls-label
N/A
4.     Configure the device to assign labels to IPv4 routes.
apply mpls-label
By default, an IPv4 route does not carry any label.
For information about routing policy configuration, see Layer 3—IP Routing Configuration Guide.
Configuring nested VPN
For a network with many VPNs, if you want to implement layered management of VPNs and to conceal the deployment of internal VPNs, nested VPN is a good solution. By using nested VPN, you can implement layered management of internal VPNs easily with a low cost and simple management operation.
Configure the basic MPLS L3VPN capability (see “Configuring basic MPLS L3VPN”).
To configure nested VPN:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure a CE peer or peer group.
peer { group-name | peer-address } as-number number
N/A
5.     Return to BGP view.
N/A
ipv4-family vpnv4
N/A
7.     Enable nested VPN.
nesting-vpn
Disabled by default.
8.     Activate a nested VPN peer or peer group, and enable the BGP-VPNv4 route exchange capability.
peer { group-name | peer-address } vpn-instance vpn-instance-name enable
By default, only IPv4 routes and no BGP-VPNv4 routes can be exchanged between nested VPN peers/peer groups.
9.     Add a peer to the nested VPN peer group.
peer peer-address vpn-instance vpn-instance-name group group-name
Optional.
By default, a peer is not in any nested VPN peer group.
10.   Apply a routing policy to routes received from a nested VPN peer or peer group.
peer { group-name | peer-address } vpn-instance vpn-instance-name route-policy route-policy-name import
Optional.
By default, no routing policy is applied to routes received from a nested VPN peer or peer group.
·       The address ranges for sub-VPNs of a VPN cannot overlap.
·       Do not give nested VPN peers addresses that public network peers use.
·       Before specifying a nested VPN peer or peer group, be sure to configure the corresponding CE peer or peer group in BGP VPN instance view.
·       Nested VPN does not support multi-hop EBGP networking. A service provider PE and its peer must use the addresses of the directly connected interfaces to establish neighbor relationship.
·       Nested VPN does not allow a sub-VPN of a customer VPN and another backbone VPN to import routes from each other for mutual communication. If they need to communicate, you must configure route exchange between the customer VPN and that backbone VPN. For example, an ISP has backbone VPNs VPN A and VPN B. VPN A has a sub-VPN VPN A-1. If VPN A-1 and VPN B need to communicate, you must configure route exchange between VPN A and VPN B instead of that between VPN A-1 and VPN B.
Configuring multi-role host
To allow a CE to access multiple VPNs, you need to configure the multi-role host feature on the PE.
All configurations for the multi-role host feature are on the PE connecting that CE.
For more information about policy routing, see Layer 3—IP Routing Configuration Guide.
Before you configure the multi-role host feature, complete the following tasks:
·           Create VPN instances for the VPNs
Configuring and applying policy routing
To configure and apply policy routing:
Step
2.     Create a policy and enter policy routing view.
policy-based-route policy-name { deny | permit } node node-number
3.     Specify the VPN instances for forwarding packets.
apply access-vpn vpn-instance vpn-instance-name&<1-6>
5.     Enter the view of the interface connecting a CE.
6.     Apply policy routing to the interface.
ip policy-based-route policy-name
Configuring a static route
For configuration steps, see “Configuring routing between PE and CE.”
You can configure a private network static route on a PE, specifying the egress of another private network or public network as the egress of the static route. Thus, packets from the multi-role host for accessing a certain VPN can return based on the routing table that does not belong to the VPN.
Configuring HoVPN
For hierarchical VPNs, you can adopt HoVPN to reduce the performance requirements for PEs.
Complete the basic MPLS L3VPN configuration.
Configuring HoVPN
To configure HoVPN:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enter BGP-VPNv4 subaddress family view.
ipv4-family vpnv4
N/A
4.     Enable the exchange of BGP-VPNv4 routing information with a peer.
N/A
5.     Specify a BGP peer or peer group as the UPE.
peer { group-name | ip-address } upe
N/A
6.     Advertise a default VPN route or routes permitted by a routing policy to the UPE.
·       To advertise a default VPN route:
·       To advertise routes permitted by a routing policy:
peer
{ group-name | ip-address } upe route-policy route-policy-name export
Configure either command as needed.
By default, BGP does not advertise default routes to a VPNv4 peer.
With the peer default-route-advertise vpn-instance command configured, the SPE always advertises a default route using the local address as the next hop address to the UPE, regardless of whether the default route is present in the local routing table or not.
·       The default routes of a VPN instance can be advertised to only a BGP peer or peer group that is UPE.
·       Do not configure both the peer default-route-advertise vpn-instance command and the peer upe route-policy command at the same time.
·       Do not connect an SPE to a CE directly. If an SPE must be directly connected to a CE, the VPN instance on the SPE and that on the UPE must be configured with different RDs.
Configuring an OSPF sham link
The sham link is considered an OSPF intra-area route. It is used to make sure that the VPN traffic is transmitted over the backbone instead of the backdoor link between two CEs.
The source and destination addresses of the sham link must be loopback interface addresses with 32-bit masks. Besides, the loopback interfaces must be bound to the VPN instances and be advertised through BGP.
Before you configure an OSPF sham link, complete the following tasks:
·           Configure basic MPLS L3VPN (OSPF is used between PEs and CEs)
·           Configure OSPF in the LAN where CEs reside
Configuring a loopback interface
To configure a loopback interface:
Step
Remarks
N/A
2.     Create a loopback interface and enter loopback interface view.
interface loopback interface-number
N/A
3.     Bind the loopback interface to a VPN instance.
By default, an interface is associated with no VPN instance.
4.     Configure the address of the loopback interface.
N/A
Redistributing the loopback interface route and OSPF routes into BGP
To redistribute the loopback interface route and OSPF routes into BGP:
Step
2.     Enter BGP view.
bgp as-number
4.     Redistribute direct routes into BGP (to redistribute the loopback interface route into BGP).
import-route direct [ med med-value | route-policy route-policy-name ] *
5.     Redistribute OSPF VPN routes.
import-route ospf [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
Creating a sham link
To create a sham link:
Step
Remarks
N/A
2.     Enter OSPF view.
N/A
3.     Configure the route tag.
route-tag tag-value
N/A
4.     Enter OSPF area view.
area area-id
N/A
5.     Configure a sham link.
sham-link source-ip-address destination-ip-address [ cost cost | dead dead-interval | hello hello-interval | retransmit retrans-interval | trans-delay delay | simple [ cipher | plain ] password | { md5 | hmac-md5 } key-id [ cipher | plain ] password ]*
By default, no sham link is configured.
·       If you start OSPF but do not configure the router ID, the system will automatically elect one. However, the same election rules produce the same router ID. Therefore, H3C recommends that you configure the router ID when starting an OSPF process. For the election rules, see Layer 3—IP Routing Configuration Guide.
·       If you configure multiple OSPF VPN instances but do not configure the route tag, the system will automatically create one based on the AS number configured. If you do not configure BGP, the tag will be 0. However, the same calculation rule produces the same tag, and hence the same tag will be created for multiple OSPF VPN instances on the same PE or PEs with the same AS number. Therefore, H3C recommends configuring different tags for different OSPF VPN instance.
Configuring routing on an MCE
MCE implements service isolation through route isolation. MCE routing configuration includes:
·           MCE-VPN site routing configuration
·           MCE-PE routing configuration
On the PE in an MCE network environment, disable routing loop detection to avoid route loss during route calculation and disable route redistribution between routing protocols to save system resources.
Before you configure routing on an MCE, complete the following tasks:
·           Configure VPN instances, and bind the VPN instances with the interfaces connected to the VPN sites and those connected to the PE.
·           Configure the link layer and network layer protocols on related interfaces to ensure IP connectivity.
Configuring routing between MCE and VPN site
Configuring static routing betweem MCE and VPN site
An MCE can reach a VPN site through a static route. Static routing on a traditional CE is globally effective and thus does not support address overlapping among VPNs. An MCE supports binding a static route with a VPN instance, so that the static routes of different VPN instances can be isolated from each other.
To configure static routing between MCE and VPN site:
Step
Remarks
N/A
·       ip route-static vpn-instance s-vpn-instance-name&<1-6> dest-address { mask | mask-length } { gateway-address [ public ] | interface-type interface-number [ gateway-address ] | vpn-instance d-vpn-instance-name gateway-address } [ preference preference-value ] [ tag tag-value ] [ description description-text ]
Use either command.
Perform this configuration on the MCE. On a VPN site, configure a normal static route.
3.     Configure the default precedence for static routes.
ip route-static default-preference default-preference-value
Optional.
60 by default.
Configuring RIP between MCE and VPN site
A RIP process belongs to the public network or a single VPN instance. If you create a RIP process without binding it to a VPN instance, the process belongs to the public network. By configuring RIP-to-VPN bindings on a CE, you allow routes of different VPNs to be exchanged between the CE and the sites through different RIP processes, ensuring the separation and security of VPN routes.
To configure route exchange through RIP:
Step
Remarks
N/A
Perform this configuration on the MCE. On a VPN site, create a normal RIP process.
4.     Redistribute remote site routes advertised by the PE.
import-route protocol [ process-id ] [ allow-ibgp ] [ cost cost | route-policy route-policy-name | tag tag ] *
By default, no route of any other protocol is redistributed into RIP.
5.     Configure the default cost value for the redistributed routes.
default cost value
Optional.
0 by default.
For more information about RIP, see Layer 3—IP Routing Configuration Guide.
Configuring OSPF between MCE and VPN site
By configuring OSPF process-to-VPN instance bindings on a MCE, you allow routes of different VPNs to be exchanged between the MCE and the sites through different OSPF processes, ensuring the separation and security of VPN routes.
To configure route exchange through OSPF:
Step
Remarks
N/A
2.     Create an OSPF process for a VPN instance and enter OSPF view.
Perform this configuration on the MCE. On a VPN site, create a normal OSPF process.
3.     Enable the multi-VPN-instance function of OSPF.
vpn-instance-capability simple
4.     Configure the OSPF domain ID.
Optional.
0 by default.
Perform this configuration on the MCE. On a VPN site, perform the common OSPF configuration.
5.     Redistribute remote site routes advertised by the PE.
import-route protocol [ process-id | allow-ibgp ] [ cost cost | type type | tag tag | route-policy route-policy-name ] *
By default, no route of any other protocol is redistributed into OSPF.
6.     Create an OSPF area and enter OSPF area view.
area area-id
7.     Enable OSPF on the interface attached to the specified network in the area.
·       An OSPF process that is bound with a VPN instance does not use the public network router ID configured in system view. Therefore, you need to configure a router ID when starting the OSPF process. All OSPF processes for the same VPN must be configured with the same OSPF domain ID to ensure correct route advertisement.
·       An OSPF process can belong to only one VPN instance, but one VPN instance can use multiple OSPF processes to advertise the VPN routes.
·       After you configure an OSPF process for a VPN instance, you need to enable OSPF. The configuration procedure is the same as that for a normal OSPF process. For more OSPF configuration information, see Layer 3—IP Routing Configuration Guide.
Configuring IS-IS between MCE and VPN site
By configuring IS-IS process-to-VPN instance bindings on a MCE, you allow routes of different VPNs to be exchanged between the MCE and the sites through different IS-IS processes, ensuring the separation and security of VPN routes.
To configure route exchange through IS-IS:
Step
Remarks
N/A
Perform this configuration on the MCE. On a VPN site, configure a normal IS-IS process.
3.     Configure a network entity title.
network-entity net
Not configured by default.
import-route { isis [ process-id ] | ospf [ process-id ] | rip [ process-id ] | bgp [ allow-ibgp ] | direct | static } [ cost cost | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
Optional.
By default, IS-IS does not redistribute routes of any other protocol.
If you do not specify the route level in the command, the command will redistribute routes to the level-2 routing table by default.
5.     Return to system view.
N/A
6.     Enter interface view.
N/A
7.     Enable the IS-IS process on the interface.
Configuring EBGP between MCE and VPN site
To use EBGP for exchanging routing information between an MCE and VPN sites, you must configure a BGP peer for each VPN instance on the MCE, and redistribute the IGP routes of each VPN instance on the VPN sites.
You also can configure filtering policies to filter the received and sent routes.
1.      Configurations on the MCE
To configure the MCE:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enter BGP-VPN instance view.
N/A
4.     Configure an EBGP peer.
N/A
5.     Allow the local AS number to appear in the AS_PATH attribute of a received route, and configure the maximum number of times that such case is allowed to appear.
Optional.
6.     Redistribute remote site routes advertised by the PE.
import-route protocol [ process-id | all-processes ] [ med med-value | route-policy route-policy-name ] *
By default, no routes of any other protocol are redistributed to BGP.
7.     Configure a filtering policy to filter the routes to be advertised.
Optional.
By default, BGP does not filter the routes to be advertised.
8.     Configure a filtering policy to filter received routes.
Optional.
By default, BGP does not filter the received routes.
·       Normally, BGP checks routing loops by examining AS numbers. If EBGP is used between the MCE and a site, when the MCE advertises its routing information with its AS number to the site and then receives routing update information from the site, the route update message will carry the AS number of the MCE, making the MCE unable to receive this route update message. In this case, to enable the MCE to receive route updates normally, configure the MCE to allow routing loops.
·       In standard BGP/OSPF route redistribution, when a route is redistributed into OSPF from BGP on the MCE, the route’s original OSPF attribute cannot be restored, making the route unable to be distinguished from routes redistributed from other domains. To distinguish routes of different OSPF domains, you need to enable a route to carry the OSPF domain ID when the route is redistributed from OSPF into BGP on the peer PE. Thus, the domain ID of an OSPF process is carried in a route generated by the process. When the OSPF route is redistributed into BGP, the domain ID is added to the BGP VPN route and is transmitted over the network as the extended community attribute of BGP.
·       After you configure a BGP VPN instance, the BGP route exchange in the VPN instance is the same as the common BGP’s. For more information about BGP configuration, see Layer 3—IP Routing Configuration Guide.
2.      Configurations on a VPN site
To configure the VPN site:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure the MCE as the EBGP peer.
N/A
4.     Redistribute the IGP routes of the VPN.
Optional.
A VPN site must advertise the VPN network addresses it can reach to the connected MCE.
Configuring IBGP beween MCE and VPN site
If IBGP is used for exchanging routing information between an MCE and VPN sites, you must configure a BGP peer for each VPN instance respectively, and redistribute the IGP routes of each VPN instance on the VPN sites.
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure an IBGP peer.
N/A
5.     Configure the system to be the RR and specify the peer as the client of the RR.
Optional.
Optional.
Optional.
When a CE is configured as an IBGP peer, the MCE does not advertise the BGP routes learned from this CE to other IBGP peers, including VPNv4 peers. Only when you configure a CE as a client of the RR (the MCE), does the MCE advertise routes learned from it to other IBGP peers.
2.      Configurations on the VPN site
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure the MCE as the IBGP peer.
N/A
Optional.
Configuring routing between MCE and PE
MCE-PE routing configuration includes these tasks:
·           Bind the MCE-PE interfaces to VPN instances
·           Perform route configurations
·           Redistribute VPN routes into the routing protocol running between the MCE and the PE.
Configurations in this section are made on the MCE. Configurations on the PE are similar to those on the PE in common MPLS L3VPN network solutions (see “Configuring routing between PE and CE”).
Configuring static routing between MCE and PE
To configure static routing between MCE and PE:
Step
Remarks
N/A
Use either command.
Optional.
60 by default.
Configuring RIP between MCE and PE
To configure RIP between MCE and PE:
Step
Remarks
N/A
N/A
4.     Redistribute the VPN routes.
By default, no route of any other routing protocol is redistributed into RIP.
default cost value
Optional.
0 by default.
Configuring OSPF between MCE and PE
To configure OSPF between MCE and PE:
Step
Remarks
N/A
N/A
Optional.
0 by default.
5.     Redistribute the VPN routes.
By default, no route of any other routing protocol is redistributed into OSPF.
6.     Configure a filtering policy to filter the redistributed routes.
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] ]
Optional.
By default, redistributed routes are not filtered.
7.     Configure the default parameters for redistributed routes (cost, route number, tag, and type).
default { cost cost | limit limit | tag tag | type type } *
Optional.
The default cost is 1, the default maximum number of routes redistributed per time is 1000, the default tag is 1, and default type of redistributed routes is Type-2.
8.     Create an OSPF area and enter OSPF area view.
area area-id
9.     Enable OSPF on the interface attached to the specified network in the area.
Configuring IS-IS between MCE and PE
To configure IS-IS between MCE and PE:
Step
Remarks
N/A
N/A
network-entity net
Optional.
By default, IS-IS does not redistribute routes of any other routing protocol.
5.     Configure a filtering policy to filter the redistributed routes.
filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } export [ isis process-id | ospf process-id | rip process-id | bgp | direct | static ]
Optional.
By default, IS-IS does not filter redistributed routes.
6.     Return to system view.
N/A
7.     Enter interface view.
N/A
8.     Enable the IS-IS process on the interface.
Configuring EBGP between MCE and PE
To configure EBGP between MCE and PE:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure the PE as the EBGP peer.
N/A
5.     Redistribute the VPN routes of the VPN site.
By default, no route redistribution is configured.
6.     Configure a filtering policy to filter the routes to be advertised.
Optional.
7.     Configure a filtering policy to filter the received routes.
Optional.
BGP runs within a VPN in the same way as it runs within a public network. For more information about BGP, see Layer 3—IP Routing Configuration Guide.
Configuring IBGP between MCE and PE
To configure IBGP between MCE and PE:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Configure the PE as the IBGP peer.
N/A
Optional.
Optional.
Specifying the VPN label processing mode
The VPN label processing mode of an egress PE can be either POPGO or POP:
·           POPGO forwarding: Pop the label, and then search for the outbound interface according to the label and forward the packet out the interface.
·           POP forwarding: Pop the label, and then search the FIB to find the outbound interface and forward the packet out the interface.
To specify the VPN label processing mode on an egress PE:
Step
Remarks
N/A
2.     Specify the VPN label processing mode as POPGO forwarding.
vpn popgo
POP forwarding by default
Before executing the vpn popgo command on the router, you need to save the current configuration and then reboot the router as prompted. After the command is executed successfully, the router does not inform you of the result. You can use the display vpn label operation command to view the current VPN label processing mode.
Configuring BGP AS number substitution
Before you configure BGP AS number substitution, complete the following tasks:
·           Ensure CEs at different sites to have the same AS number
Configuration procedure
When CEs at different sites have the same AS number, configure the BGP AS number substitution function to avoid route loss.
With the BGP AS number substitution function, when a PE advertises a route to a CE of the specified peer, if an AS number identical to that of the CE exist in the AS_PATH of the route, it will be replaced with that of the PE before the route is advertised.
To configure the BGP AS number substitution function:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Enable the BGP AS number substitution function.
peer { ip-address | group-name } substitute-as
Disabled by default
For information about the peer { ip-address | group-name } substitute-as command, see Layer 3—IP Routing Command Reference.
Displaying and maintaining MPLS L3VPN
Resetting BGP connections
When BGP configuration changes, you can use the soft reset function or reset BGP connections to make new configurations take effect. Soft reset requires that BGP peers have route refreshment capability (supporting Route-Refresh messages).
Step
Remarks
1.     Perform a soft reset of the BGP connections in a specific VPN instance.
refresh bgp vpn-instance vpn-instance-name  { ip-address | all | external | group group-name } { export | import }
Available in user view
2.     Perform a soft reset of the BGP VPNv4 connections.
refresh bgp vpnv4 { ip-address | all | external | group group-name | internal } { export | import }
3.     Reset BGP connections of a VPN instance.
reset bgp vpn-instance vpn-instance-name { as-number | ip-address | all | external | group group-name }
4.     Reset BGP VPNv4 connections.
reset bgp vpnv4 { as-number | ip-address | all | external | internal | group group-name }
Remarks
Display information about the routing table associated with a VPN instance.
display ip routing-table vpn-instance vpn-instance-name [ verbose ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Display information about a specific or all VPN instances.
display ip vpn-instance [ instance-name vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display information about the FIB of a VPN instance.
display fib vpn-instance vpn-instance-name [ acl acl-number | ip-prefix ip-prefix-name ] [ | { begin | exclude | include } regular-expression ]
Display information about the FIB of a VPN instance that matches the specified destination IP address.
display fib vpn-instance vpn-instance-name ip-address [ mask | mask-length ] [ | { begin | exclude | include } regular-expression ]
Display information about labeled routes in the BGP routing table.
display bgp vpnv4 { all | vpn-instance vpn-instance-name } routing-table label [ | { begin | exclude | include } regular-expression ]
Display information about a specific or all BGP VPNv4 peer group.
display bgp vpnv4 { all | vpn-instance vpn-instance-name } group [ group-name ] [ | { begin | exclude | include } regular-expression ]
Display information about BGP VPNv4 routes redistributed into a specific or all VPN instances.
display bgp vpnv4 { all | vpn-instance vpn-instance-name } network [ | { begin | exclude | include } regular-expression ]
Display BGP VPNv4 AS path information.
display bgp vpnv4 { all | vpn-instance vpn-instance-name } paths [ as-regular-expression | { | { begin | exclude | include } regular-expression } ]
Display information about BGP VPNv4 peers.
display bgp vpnv4 all peer [ ip-address verbose | verbose ] [ | { begin | exclude | include } regular-expression ]
display bgp vpnv4 vpn-instance vpn-instance-name peer [ group-name log-info | ip-address { log-info | verbose } | verbose ] [ | { begin | exclude | include } regular-expression ]
Display the IP prefix information of the ORF packets received from the specified BGP peer.
display bgp vpnv4 { all | vpn-instance vpn-instance-name } peer ip-address received ip-prefix [ | { begin | exclude | include } regular-expression ]
Display all BGP VPNv4 routing information.
display bgp vpnv4 all routing-table [ [ network-address [ { mask | mask-length } [ longer-prefixes ] ] | as-path-acl as-path-acl-number | cidr | community [ aa:nn ]&<1-13> [ no-advertise | no-export | no-export-subconfed ] * [ whole-match ] | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }&<1-16> | different-origin-as | peer ip-address { advertised-routes | received-routes } [ statistic ] | statistic ] [ | { begin | exclude | include } regular-expression ] | regular-expression as-regular-expression ]
Display the BGP VPNv4 routing information of a specific RD.
display bgp vpnv4 route-distinguisher route-distinguisher routing-table [ [ network-address [ mask | mask-length ] | as-path-acl as-path-acl-number | cidr | community [ aa:nn ]&<1-13> [ no-advertise | no-export | no-export-subconfed ] * [ whole-match ] | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }&<1-16> | different-origin-as ] [ | { begin | exclude | include } regular-expression ] | regular-expression as-regular-expression ]
Display the BGP VPNv4 routing information of a specific VPN instance.
display bgp vpnv4 vpn-instance vpn-instance-name routing-table [ [ network-address [ { mask | mask-length } [ longer-prefixes ] ] | as-path-acl as-path-acl-number | cidr | community [ aa:nn ]&<1-13> [ no-advertise | no-export | no-export-subconfed ] * [ whole-match ] | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }&<1-16> | dampened | dampening parameter | different-origin-as | flap-info [ network-address  [ { mask | mask-length } [ longer-match ] ] | as-path-acl as-path-acl-number ] | peer ip-address { advertised-routes | received-routes } | statistic ] [ | { begin | exclude | include } regular-expression ] | [ flap-info ] regular-expression as-regular-expression ]
Display information about OSPF sham links.
display ospf [ process-id ] sham-link [ area area-id ] [ | { begin | exclude | include } regular-expression ]
Display information about a specific or all tunnel policies.
display tunnel-policy { all | policy-name tunnel-policy-name } [ | { begin | exclude | include } regular-expression ]
Display the VPN label processing mode on an egress PE.
display vpn label operation [ | { begin | exclude | include } regular-expression ]
Display information about the specified LDP instance.
display mpls ldp vpn-instance vpn-instance-name [ | { begin | exclude | include } regular-expression ]
Clear the route flap dampening information of a VPN instance.
reset bgp vpn-instance vpn-instance-name dampening [ network-address [ mask | mask-length ]
Clear route flap history information about a BGP peer of a VPN instance.
reset bgp vpn-instance vpn-instance-name ip-address flap-info
reset bgp vpn-instance vpn-instance-name flap-info [ ip-address [ mask | mask-length ] | as-path-acl as-path-acl-number | regexp as-path-regexp ]
For commands to display information about a routing table, see Layer 3—IP Routing Command Reference.
MPLS L3VPN configuration examples
Configuring MPLS L3VPNs using EBGP between PE and CE
Network requirements
·           CE 1 and CE 3 belong to VPN 1, while CE 2 and CE 4 belong to VPN 2.
·           VPN 1 uses VPN target attributes 111:1, while VPN 2 uses VPN target attributes 222:2. Users of different VPNs cannot access each other.
·           EBGP is used to exchange VPN routing information between CE and PE.
·           PEs use OSPF to communicate with each other and use MP-IBGP to exchange VPN routing information.
Figure 20 Network diagram
Device
IP address
Device
IP address
CE 1
GE4/1/1
10.1.1.1/24
P
Loop0
2.2.2.9/32
PE 1
Loop0
1.1.1.9/32
POS2/1/1
172.1.1.2/24
GE4/1/1
10.1.1.2/24
POS2/1/2
172.2.1.1/24
GE4/1/2
10.2.1.2/24
PE 2
Loop0
3.3.3.9/32
POS2/1/1
172.1.1.1/24
GE4/1/1
10.3.1.2/24
CE 2
GE4/1/1
10.2.1.1/24
GE4/1/2
10.4.1.2/24
CE 3
GE4/1/1
10.3.1.1/24
POS2/1/1
172.2.1.2/24
CE 4
GE4/1/1
10.4.1.1/24
1.      Configure an IGP on the MPLS backbone to implement IP connectivity within the backbone.
# Configure PE 1.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] interface pos 2/1/1
[PE1-POS2/1/1] ip address 172.1.1.1 24
[PE1-POS2/1/1] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Configure the P device.
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface pos 2/1/1
[P-POS2/1/1] clock master
[P-POS2/1/1] ip address 172.1.1.2 24
[P-POS2/1/1] quit
[P] interface pos 2/1/2
[P-POS2/1/2] clock master
[P-POS2/1/2] ip address 172.2.1.1 24
[P-POS2/1/2] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# Configure PE 2.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
[PE2] interface pos 2/1/1
[PE2-POS2/1/1] ip address 172.2.1.2 24
[PE2-POS2/1/1] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
After you complete the configurations, OSPF adjacencies are established between PE 1, P, and PE 2. Issue the display ospf peer verbose command. The output shows that the adjacency status is Full. Issue the display ip routing-table command. The output shows that the PEs have learned the routes to the loopback interfaces of each other. The following takes PE 1 as an example:
[PE1] display ip routing-table
Routing Tables: Public
         Destinations : 8        Routes : 8
Destination/Mask  Proto  Pre  Cost     NextHop         Interface
1.1.1.9/32        Direct 0    0        127.0.0.1       InLoop0
2.2.2.9/32        OSPF   10   1        172.1.1.2       POS2/1/1
3.3.3.9/32        OSPF   10   2        172.1.1.2       POS2/1/1
127.0.0.0/8       Direct 0    0        127.0.0.1       InLoop0
127.0.0.1/32      Direct 0    0        127.0.0.1       InLoop0
172.1.1.0/24      Direct 0    0        172.1.1.1       POS2/1/1
172.1.1.1/32      Direct 0    0        127.0.0.1       InLoop0
172.2.1.0/24      OSPF   10   1        172.1.1.2       POS2/1/1
[PE1] display ospf peer verbose
          OSPF Process 1 with Router ID 1.1.1.9
                  Neighbors
Area 0.0.0.0 interface 172.1.1.1(POS5/1/1)'s neighbors
 Router ID: 2.2.2.9          Address: 172.1.1.2        GR State: Normal
   State: Full  Mode:Nbr is  Master  Priority: 1
   DR: 172.1.1.1  BDR: 172.1.1.2  MTU: 0
   Dead timer due in 38  sec
   Neighbor is up for 00:02:44
   Neighbor state change count: 5
2.      Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs.
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls
[PE1-mpls] lsp-trigger all
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1-POS2/1/1] mpls
[PE1-POS2/1/1] mpls ldp
[PE1-POS2/1/1] quit
[P] mpls lsr-id 2.2.2.9
[P] mpls
[P-mpls] lsp-trigger all
[P-mpls] quit
[P] mpls ldp
[P-mpls-ldp] quit
[P-POS2/1/1] mpls
[P-POS2/1/1] mpls ldp
[P-POS2/1/1] quit
[P-POS2/1/2] mpls
[P-POS2/1/2] mpls ldp
[P-POS2/1/2] quit
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls
[PE2-mpls] lsp-trigger all
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2-POS2/1/1] mpls
[PE2-POS2/1/1] mpls ldp
[PE2-POS2/1/1] quit
After you complete the configurations, LDP sessions are established between PE 1, P, and PE 2. Issue the display mpls ldp session command. The output shows that the session status is Operational. Issue the display mpls ldp lsp command. The output shows that the LSPs established by LDP. The following takes PE 1 as an example:
[PE1] display mpls ldp session
               LDP Session(s) in Public Network
 Peer-ID         Status        LAM  SsnRole  FT   MD5  KA-Sent/Rcv
 2.2.2.9:0       Operational   DU   Passive  Off  Off  5/5
 LAM : Label Advertisement Mode         FT  : Fault Tolerance
[PE1] display mpls ldp lsp
                              LDP LSP Information
 SN  DestAddress/Mask   In/OutLabel  Next-Hop     In/Out-Interface
 1   1.1.1.9/32         3/NULL       127.0.0.1     -------/InLoop0
 2   2.2.2.9/32         NULL/3       172.1.1.2     -------/POS2/1/1
 3   3.3.3.9/32         NULL/1024    172.1.1.2     -------/POS2/1/1
 A '*' before an LSP means the LSP is not established
 A '*' before a Label means the USCB or DSCB is stale
3.      Configure VPN instances on PEs to allow CEs to access.
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 100:2
[PE1-vpn-instance-vpn2] vpn-target 222:2
[PE1-vpn-instance-vpn2] quit
[PE1] interface GigabitEthernet 4/1/1
[PE1-GigabitEthernet4/1/1] ip binding vpn-instance vpn1
[PE1-GigabitEthernet4/1/1] ip address 10.1.1.2 24
[PE1-GigabitEthernet4/1/1] quit
[PE1] interface GigabitEthernet4/1/2
[PE1-GigabitEthernet4/1/2] ip binding vpn-instance vpn2
[PE1-GigabitEthernet4/1/2] ip address 10.2.1.2 24
[PE1-GigabitEthernet4/1/2] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
[PE2] ip vpn-instance vpn2
[PE2-vpn-instance-vpn2] route-distinguisher 200:2
[PE2-vpn-instance-vpn2] vpn-target 222:2
[PE2-vpn-instance-vpn2] quit
[PE2] interface GigabitEthernet 4/1/1
[PE2-GigabitEthernet4/1/1] ip binding vpn-instance vpn1
[PE2-GigabitEthernet4/1/1] ip address 10.3.1.2 24
[PE2-GigabitEthernet4/1/1] quit
[PE2] interface GigabitEthernet 4/1/2
[PE2-GigabitEthernet4/1/2] ip binding vpn-instance vpn2
[PE2-GigabitEthernet4/1/2] ip address 10.4.1.2 24
[PE2-GigabitEthernet4/1/2] quit
# Configure IP addresses for the CEs as required in Figure 20. (Details not shown)
After completing the configurations, issue the display ip vpn-instance command on the PEs to view the configuration of the VPN instance. Use the ping command to test connectivity between the PEs and their attached CEs. The PEs can ping their attached CEs. The following takes PE 1 and CE 1 as an example:
[PE1] display ip vpn-instance
  Total VPN-Instances configured : 2
  VPN-Instance Name               RD                     Create time
  vpn1                            100:1                  2009/01/22 13:02:21
  vpn2                            100:2                  2009/01/22 13:02:40
 [PE1] ping -vpn-instance vpn1 10.1.1.1
  PING 10.1.1.1: 56  data bytes, press CTRL_C to break
    Reply from 10.1.1.1: bytes=56 Sequence=1 ttl=255 time=56 ms
    Reply from 10.1.1.1: bytes=56 Sequence=2 ttl=255 time=4 ms
    Reply from 10.1.1.1: bytes=56 Sequence=3 ttl=255 time=4 ms
    Reply from 10.1.1.1: bytes=56 Sequence=4 ttl=255 time=52 ms
    Reply from 10.1.1.1: bytes=56 Sequence=5 ttl=255 time=3 ms
  --- 10.1.1.1 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 3/23/56 ms
4.      Establish EBGP peer relationships between PEs and CEs to allow VPN routes to be redistributed
# Configure CE 1.
<CE1> system-view
[CE1] bgp 65410
[CE1-bgp] peer 10.1.1.2 as-number 100
[CE1-bgp] import-route direct
[CE1-bgp] quit
The configurations for the other three CEs (CE 2 through CE 4) are similar to those for CE 1. (Details not shown)
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp] ipv4-family vpn-instance vpn1
[PE1-bgp-vpn1] peer 10.1.1.1 as-number 65410
[PE1-bgp-vpn1] import-route direct
[PE1-bgp-vpn1] quit
[PE1-bgp] ipv4-family vpn-instance vpn2
[PE1-bgp-vpn2] peer 10.2.1.1 as-number 65420
[PE1-bgp-vpn2] import-route direct
[PE1-bgp-vpn2] quit
[PE1-bgp] quit
The configurations for PE 2 are similar to those for PE 1. (Details not shown)
After completing the configuration, issue the display bgp vpnv4 vpn-instance peer command on the PEs. The output shows that BGP peer relationship has been established between the PEs and CEs, and has reached the Established state. The following takes PE 1 and CE 1 as an example:
[PE1] display bgp vpnv4 vpn-instance vpn1 peer
 BGP local router ID : 1.1.1.9
 Local AS number : 100
 Total number of peers : 1            Peers in established state : 1
  Peer       AS   MsgRcvd MsgSent OutQ  PrefRcv   Up/Down    State
  10.1.1.1   65410 11      9       0     1         00:06:37   Established
5.      Configure an MP-IBGP peer relationship between PEs
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp] peer 3.3.3.9 as-number 100
[PE1-bgp] peer 3.3.3.9 connect-interface loopback 0
[PE1-bgp] ipv4-family vpnv4
[PE1-bgp-af-vpnv4] peer 3.3.3.9 enable
[PE1-bgp-af-vpnv4] quit
[PE1-bgp] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp] peer 1.1.1.9 as-number 100
[PE2-bgp] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp] ipv4-family vpnv4
[PE2-bgp-af-vpnv4] peer 1.1.1.9 enable
[PE2-bgp-af-vpnv4] quit
[PE2-bgp] quit
After completing the configuration, issue the display bgp peer command or the display bgp vpnv4 all peer command on the PEs. The output shows that BGP peer relationship has been established between the PEs, and has reached the Established state.
[PE1] display bgp peer
  3.3.3.9     100        2        6     0         0   00:00:12 Established
6.      Verify your configurations
Issue the display ip routing-table vpn-instance command on the PEs. The output shows the routes to the CEs. The following takes PE 1 as an example:
[PE1] display ip routing-table vpn-instance vpn1
Routing Tables: vpn1
         Destinations : 5        Routes : 5
10.1.1.0/24         Direct 0    0            10.1.1.2        GE4/1/1
10.1.1.2/32         Direct 0    0            127.0.0.1       InLoop0
10.3.1.0/24         BGP    255  0            3.3.3.9         NULL0
[PE1] display ip routing-table vpn-instance vpn2
10.2.1.0/24         Direct 0    0            10.2.1.2        GE4/1/2
10.2.1.2/32         Direct 0    0            127.0.0.1       InLoop0
10.4.1.0/24         BGP    255  0            3.3.3.9         NULL0
CEs of the same VPN can ping each other, whereas those of different VPNs can not. For example, CE 1 can ping CE 3 (10.3.1.1), but cannot ping CE 4 (10.4.1.1):
[CE1] ping 10.3.1.1
  PING 10.3.1.1: 56  data bytes, press CTRL_C to break
    Reply from 10.3.1.1: bytes=56 Sequence=1 ttl=253 time=72 ms
    Reply from 10.3.1.1: bytes=56 Sequence=2 ttl=253 time=34 ms
    Reply from 10.3.1.1: bytes=56 Sequence=3 ttl=253 time=50 ms
    Reply from 10.3.1.1: bytes=56 Sequence=4 ttl=253 time=50 ms
    Reply from 10.3.1.1: bytes=56 Sequence=5 ttl=253 time=34 ms
  --- 10.3.1.1 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 34/48/72 ms
[CE1] ping 10.4.1.1
  PING 10.4.1.1: 56  data bytes, press CTRL_C to break
    Request time out
    Request time out
    Request time out
    Request time out
    Request time out
  --- 10.4.1.1 ping statistics ---
    0 packet(s) received
    100.00% packet loss
Configuring MPLS L3VPNs using IBGP between PE and CE
·           CE 1 and CE 3 belong to VPN 1. CE 2 and CE 4 belong to VPN 2.
·           VPN 1 uses VPN target attribute 111:1. VPN 2 uses VPN target attribute 222:2. Users of different VPNs cannot access each other.
·           IBGP is used to exchange VPN routing information between CE and PE.
Figure 21 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
1.1.1.9/32
PE 2
Loop0
3.3.3.9/32
GE3/1/1
10.1.1.2/24
GE3/1/1
10.3.1.2/24
GE3/1/2
10.2.1.2/24
GE3/1/2
10.4.1.2/24
POS5/1/1
172.1.1.1/24
POS5/1/1
172.2.1.2/24
CE 1
Loop0
4.4.4.9/32
P
Loop0
2.2.2.9/32
GE3/1/1
10.1.1.1/24
POS5/1/1
172.1.1.2/24
CE 2
Loop0
5.5.5.9/32
POS5/1/2
172.2.1.1/24
GE3/1/1
10.2.1.1/24
CE 4
Loop0
7.7.7.9/32
CE 3
Loop0
6.6.6.9/32
GE3/1/1
10.4.1.1/24
GE3/1/1
10.3.1.1/24
1.      Configure an IGP on the MPLS backbone to ensure IP connectivity within the backbone.
# Configure PE 1.
<PE1> system-view
[PE1] interface pos 5/1/1
[PE1-POS5/1/1] ip address 172.1.1.1 24
[PE1-POS5/1/1] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure the P router.
<P> system-view
[P-LoopBack0] quit
[P] interface pos 5/1/1
[P-POS5/1/1] ip address 172.1.1.2 24
[P-POS5/1/1] quit
[P] interface pos 5/1/2
[P-POS5/1/2] ip address 172.2.1.1 24
[P-POS5/1/2] quit
[P] ospf
[P-ospf-1] area 0
# Configure PE 2.
<PE2> system-view
[PE2] interface pos 5/1/1
[PE2-POS5/1/1] ip address 172.2.1.2 24
[PE2-POS5/1/1] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
After you complete the configurations, P establishes an OSPF adjacency with PE 1 and PE 2 respectively. Issue the display ospf peer command. The output shows that the adjacency status is Full. Issue the display ip routing-table command. The output shows that the PEs have learned the routes to the loopback interfaces of each other. Take PE 1 as an example:
2.2.2.9/32        OSPF   10   1        172.1.1.2       POS5/1/1
3.3.3.9/32        OSPF   10   2        172.1.1.2       POS5/1/1
172.1.1.0/24      Direct 0    0        172.1.1.1       POS5/1/1
172.2.1.0/24      OSPF   10   1        172.1.1.2       POS5/1/1
                  Neighbors
# Configure PE 1.
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1-POS5/1/1] mpls
[PE1-POS5/1/1] mpls ldp
[PE1-POS5/1/1] quit
[P] mpls
[P-mpls] quit
[P] mpls ldp
[P-mpls-ldp] quit
[P-POS5/1/1] mpls
[P-POS5/1/1] mpls ldp
[P-POS5/1/1] quit
[P-POS5/1/2] mpls
[P-POS5/1/2] mpls ldp
[P-POS5/1/2] quit
# Configure PE 2.
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2-POS5/1/1] mpls
[PE2-POS5/1/1] mpls ldp
[PE2-POS5/1/1] quit
After you complete the configurations, P establishes an LDP session with PE 1 and PE 2 respectively. Issue the display mpls ldp session command. The output shows that the session status is Operational. Issue the display mpls ldp lsp command. The output shows the LSPs established by LDP. Take PE 1 as an example:
                              LDP LSP Information
 2   2.2.2.9/32         NULL/3       172.1.1.2     -------/POS5/1/1
 3   3.3.3.9/32         NULL/1024    172.1.1.2     -------/POS5/1/1
# Configure PE 1.
[PE1] interface GigabitEthernet 3/1/1
[PE1-GigabitEthernet3/1/1] ip binding vpn-instance vpn1
[PE1-GigabitEthernet3/1/1] ip address 10.1.1.2 24
[PE1-GigabitEthernet3/1/1] quit
[PE1] interface GigabitEthernet 3/1/2
[PE1-GigabitEthernet3/1/2] ip binding vpn-instance vpn2
[PE1-GigabitEthernet3/1/2 ip address 10.2.1.2 24
[PE1-GigabitEthernet3/1/2] quit
# Configure PE 2.
[PE2] interface GigabitEthernet 3/1/1
[PE2-GigabitEthernet3/1/1] ip binding vpn-instance vpn1
[PE2-GigabitEthernet3/1/1] ip address 10.3.1.2 24
[PE2-GigabitEthernet3/1/1] quit
[PE2] interface GigabitEthernet 3/1/2
[PE2-GigabitEthernet3/1/2] ip binding vpn-instance vpn2
[PE2-GigabitEthernet3/1/2] ip address 10.4.1.2 24
[PE2-GigabitEthernet3/1/2 quit
# Configure IP addresses for the CEs as per Figure 21. (Details not shown)
After completing the configurations, issue the display ip vpn-instance command on the PEs to view the configuration of the VPN instances. Use the ping command to test connectivity between the PEs and their attached CEs. The PEs can ping their attached CEs. Take PE 1 and CE 1 as examples:
    0.00% packet loss
4.      Establish IBGP peer relationships between PEs and CEs to redistribute VPN routes, and configure routing policies to change the next hop of the routes.
# On CE 1, configure PE 1 as the IBGP peer, and configure a routing policy for the routes received from PE 1, changing the next hop address of the routes to the IP address of PE 1.
<CE1> system-view
[CE1] route-policy ce-ibgp permit node 0
[CE1-route-policy] apply ip-address next-hop 10.1.1.2
[CE1-route-policy] quit
[CE1] bgp 100
[CE1-bgp] peer 10.1.1.2 route-policy ce-ibgp import
[CE1-bgp] quit
# On PE 1, configure the CE 1 and CE 2 as its IBGP peers, and configure PE 1 as the route reflector.
[PE1] bgp 100
[PE1-bgp-vpn1] peer 10.1.1.1 as-number 100
[PE1-bgp-vpn1] peer 10.1.1.1 reflect-client
[PE1-bgp-vpn1] quit
[PE1-bgp-vpn2] peer 10.2.1.1 as-number 100
[PE1-bgp-vpn2] peer 10.2.1.1 reflect-client
[PE1-bgp-vpn2] quit
[PE1-bgp] quit
Issue the display bgp vpnv4 vpn-instance peer command on the PEs. The output shows that BGP peer relationships have been established between the PEs and CEs, and have reached the Established state. Take the BGP peer relationship between PE 1 and CE 1 as an example:
  10.1.1.1               100       26       21    0       2 00:11:08 Established
# On PE 1, configure PE 2 as the MP-IBGP peer, and configure a routing policy for the routes received from PE 2, changing the next hop address of the routes as the loopback interface address of PE 2.
[PE1] route-policy pe-ibgp permit node 0
[PE1-route-policy] apply ip-address next-hop 3.3.3.9
[PE1-route-policy] quit
[PE1] bgp 100
[PE1-bgp-af-vpnv4] peer 3.3.3.9 route-policy pe-ibgp import
[PE1-bgp] quit
# On PE 2, configure PE 1 as the MP-IBGP peer, and configure a routing policy for the routes received from PE 1, changing the next hop address of the routes as the loopback interface address of PE 1.
[PE2] route-policy pe-ibgp permit node 0
[PE2-route-policy] apply ip-address next-hop 1.1.1.9
[PE2-route-policy] quit
[PE2] bgp 100
[PE2-bgp-af-vpnv4] peer 1.1.1.9 route-policy pe-ibgp import
[PE2-bgp] quit
Issue the display bgp peer command or the display bgp vpnv4 all peer command on the PEs. The output shows that a BGP peer relationship has been established between the PEs, and has reached the Established state. Take PE 1 as an example.
Issue the display ip routing-table vpn-instance command on the PEs. The output shows the routes to the peer CEs. Take PE 1 as an example:
         Destinations : 7        Routes : 7
4.4.4.9/32          BGP    255  0            10.1.1.1        GE3/1/1
6.6.6.9/32          BGP    255  0            3.3.3.9         NULL0
10.1.1.0/24         Direct 0    0            10.1.1.2        GE3/1/1
Routing Tables: vpn2
5.5.5.9/32          BGP    255  0            10.2.1.1        GE3/1/2
7.7.7.9/32          BGP    255  0            3.3.3.9         NULL0
10.2.1.0/24         Direct 0    0            10.2.1.2        GE3/1/2
CEs of the same VPN can ping each other, whereas those of different VPNs can not. For example, CE 1 can ping CE 3 (6.6.6.9), but cannot ping CE 4 (7.7.7.9):
[CE1] ping 6.6.6.9
  PING 6.6.6.9: 56  data bytes, press CTRL_C to break
    Reply from 6.6.6.9: bytes=56 Sequence=1 ttl=253 time=72 ms
    Reply from 6.6.6.9: bytes=56 Sequence=2 ttl=253 time=34 ms
    Reply from 6.6.6.9: bytes=56 Sequence=3 ttl=253 time=50 ms
    Reply from 6.6.6.9: bytes=56 Sequence=4 ttl=253 time=50 ms
    Reply from 6.6.6.9: bytes=56 Sequence=5 ttl=253 time=34 ms
  --- 6.6.6.9 ping statistics ---
    0.00% packet loss
[CE1] ping 7.7.7.9
  PING 7.7.7.9: 56  data bytes, press CTRL_C to break
    Request time out
    Request time out
    Request time out
    Request time out
    Request time out
  --- 7.7.7.9 ping statistics ---
    100.00% packet loss
Configuring an MPLS L3VPN that uses a GRE tunnel
·           CE 1 and CE 2 belong to VPN 1. The PEs support MPLS. The P router does not support MPLS and provides only IP functions.
·           On the backbone, use a GRE tunnel to encapsulate and forward VPN packets to implement MPLS L3VPN.
Configure tunneling policies on the PEs and specify the tunnel type for VPN traffic as GRE.
Figure 22 Network diagram
Device
IP address
Device
IP address
CE 1
GE3/1/1
10.1.1.1/24
P
POS5/1/1
172.1.1.2/24
PE 1
Loop0
1.1.1.9/32
POS5/1/2
172.2.1.1/24
GE3/1/1
10.1.1.2/24
PE 2
Loop0
2.2.2.9/32
POS5/1/2
172.1.1.1/24
GE3/1/1
10.2.1.2/24
Tunnel0
20.1.1.1/24
POS5/1/1
172.2.1.2/24
CE 2
GE3/1/1
10.2.1.1/24
Tunnel0
20.1.1.2/24
1.      Configure an IGP (such as OSPF) on the MPLS backbone to ensure IP connectivity within the backbone.
After you complete the configurations, OSPF adjacencies are established between PE 1, P, and PE 2. Issue the display ospf peer command. The output shows that the adjacency status is Full. Issue the display ip routing-table command. The output shows that the PEs have learned the loopback route of each other.
2.      Enable basic MPLS on the PEs
# Configure PE 1.
<PE1> system-view
[PE1] mpls
[PE1-mpls] quit
# Configure PE 2.
<PE2> system-view
[PE2] mpls lsr-id 2.2.2.9
[PE2] mpls
[PE2-mpls] quit
3.      Configure VPN instances on PEs to allow CEs to access, and apply tunneling policies to the VPN instances, using a GRE tunnel for VPN packet forwarding
# Configure PE 1.
[PE1] tunnel-policy gre1
[PE1-tunnel-policy-gre1] tunnel select-seq gre load-balance-number 1
[PE1-tunnel-policy-gre1] quit
[PE1-vpn-instance-vpn1] vpn-target 100:1 both
[PE1-vpn-instance-vpn1] tnl-policy gre1
# Configure PE 2.
[PE2] tunnel-policy gre1
[PE2-tunnel-policy-gre1] tunnel select-seq gre load-balance-number 1
[PE2-tunnel-policy-gre1] quit
[PE2-vpn-instance-vpn1] route-distinguisher 100:2
[PE2-vpn-instance-vpn1] vpn-target 100:1 both
[PE2-vpn-instance-vpn1] tnl-policy gre1
[PE2-GigabitEthernet3/1/1] ip address 10.2.1.2 24
# Configure CE 1.
<CE1> system-view
[CE1] interface GigabitEthernet 3/1/1
[CE1-GigabitEthernet3/1/1] ip address 10.1.1.1 24
[CE1-GigabitEthernet3/1/1] quit
# Configure CE 2.
<CE2> system-view
[CE2] interface GigabitEthernet 3/1/1
[CE2-GigabitEthernet3/1/1] ip address 10.2.1.1 24
[CE2-GigabitEthernet3/1/1] quit
After completing the configurations, issue the display ip vpn-instance command on the PEs to view the configuration of the VPN instance. Use the ping command to test connectivity between the PEs and their attached CEs. The PEs can ping their attached CEs. The following takes PE 1 as an example:
  VPN-Instance Name      RD          Create Time
  vpn1                  100:1        2006/08/13 09:32:45
    Reply from 10.1.1.1: bytes=56 Sequence=1 ttl=255 time=27 ms
    Reply from 10.1.1.1: bytes=56 Sequence=2 ttl=255 time=33 ms
    Reply from 10.1.1.1: bytes=56 Sequence=3 ttl=255 time=7 ms
    Reply from 10.1.1.1: bytes=56 Sequence=4 ttl=255 time=29 ms
    Reply from 10.1.1.1: bytes=56 Sequence=5 ttl=255 time=9 ms
    0.00% packet loss
    round-trip min/avg/max = 7/21/33 ms
# Configure CE 1.
[CE1] bgp 65410
[CE1-bgp] quit
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-vpn1] peer 10.1.1.1 next-hop-local
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
The configurations for CE 2 are similar to those for CE 1 and the configurations for PE 2 are similar to those for PE 1. (Details not shown)
After completing the configuration, issue the display bgp vpnv4 vpn-instance peer command on the PEs. The output shows that BGP peer relationship has been established between PE and CE, and has reached the Established state.
  10.1.1.1   65410      5        5     0        1   00:02:03 Established
5.      Configure an MP-IBGP peers between PEs
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp] peer 2.2.2.9 as-number 100
[PE1-bgp] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-af-vpnv4] peer 2.2.2.9 enable
[PE1-bgp] quit
[PE1] display bgp vpnv4 all peer
  2.2.2.9     100        3        3     0        1   00:00:34 Established
6.      Configure a GRE tunnel
# Configure PE 1.
[PE1] interface tunnel 0
[PE1-Tunnel0] tunnel-protocol gre
[PE1-Tunnel0] source loopback 0
[PE1-Tunnel0] destination 2.2.2.9
[PE1-Tunnel0] ip address 20.1.1.1 24
[PE1-Tunnel0] mpls
[PE1-Tunnel0] quit
# Configure PE 2.
[PE2] interface tunnel 0
[PE2-Tunnel0] tunnel-protocol gre
[PE2-Tunnel0] source loopback 0
[PE2-Tunnel0] destination 1.1.1.9
[PE2-Tunnel0] ip address 20.1.1.2 24
[PE2-Tunnel0] mpls
[PE2-Tunnel0] quit
7.      Verify your configurations
After you complete the configurations, the CEs can learn the interface routes from each other.
The following takes CE 1 as an example:
[CE1] display ip routing-table
10.1.1.0/24         Direct 0    0       10.1.1.1      GE3/1/1
10.1.1.1/32         Direct 0    0       127.0.0.1     InLoop0
10.2.1.0/24         BGP    255  0       10.1.1.2      GE3/1/1
         Destinations : 11       Routes : 11
2.2.2.9/32          OSPF   10   3125    172.1.1.2     POS5/1/2
10.2.1.0/24         Static 60   0       20.1.1.1      Tunnel0
20.1.1.0/24         Direct 0    0       20.1.1.1      Tunnel0
20.1.1.1/32         Direct 0    0       127.0.0.1     InLoop0
172.1.1.0/24        Direct 0    0       172.1.1.1     POS5/1/2
172.1.1.2/32        Direct 0    0       172.1.1.2     POS5/1/2
172.2.1.0/24        OSPF   10   3124    172.1.1.2     POS5/1/2
         Destinations : 3        Routes : 3
10.2.1.0/24         BGP    255  0       2.2.2.9       NULL0
The CEs can ping each other.
[CE1] ping 10.2.1.1
  PING 10.2.1.1: 56  data bytes, press CTRL_C to break
    Reply from 10.2.1.1: bytes=56 Sequence=1 ttl=253 time=41 ms
    Reply from 10.2.1.1: bytes=56 Sequence=2 ttl=253 time=69 ms
    Reply from 10.2.1.1: bytes=56 Sequence=3 ttl=253 time=68 ms
    Reply from 10.2.1.1: bytes=56 Sequence=4 ttl=253 time=68 ms
    Reply from 10.2.1.1: bytes=56 Sequence=5 ttl=253 time=67 ms
  --- 10.2.1.1 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 41/62/69 ms
·           CE 1 and CE 2 belong to the same VPN. CE 1 accesses the network through PE 1 in AS 100 and CE 2 accesses the network through PE 2 in AS 200.
·           Inter-AS MPLS L3VPN is implemented using option A. That is, the VRF-to-VRF method is used to manage VPN routes.
·           The MPLS backbone in each AS runs OSPF.
Figure 23 Network diagram
Device
IP address
Device
IP address
CE 1
GE4/1/1
10.1.1.1/24
CE 2
GE4/1/1
10.2.1.1/24
PE 1
Loop0
1.1.1.9/32
PE 2
Loop0
4.4.4.9/32
GE4/1/2
10.1.1.2/24
GE4/1/2
10.2.1.2/24
POS2/1/1
172.1.1.1/24
POS2/1/1
162.1.1.1/24
ASBR-PE1
Loop0
2.2.2.9/32
ASBR-PE2
Loop0
3.3.3.9/32
POS2/1/1
172.1.1.2/24
POS2/1/1
162.1.1.2/24
POS2/1/2
192.1.1.1/24
POS2/1/2
192.1.1.2/24
1.      Configure an IGP (such as OSPF) on the MPLS backbone to ensure IP connectivity in the backbone. (Details not shown)
The 32-bit loopback interface address used as the LSR ID needs to be advertised by OSPF.
After you complete the configurations, each ASBR PE and the PE in the same AS can establish OSPF adjacencies. Issue the display ospf peer verbose command. The output shows that the adjacencies reach the Full state, and that PEs can learn the routes to the loopback interfaces of each other.
Each ASBR PE and the PE in the same AS can ping each other.
# Configure basic MPLS on PE 1 and enable MPLS LDP on the interface connected to ASBR PE 1.
<PE1> system-view
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1] interface pos2/1/1
[PE1-POS2/1/1] mpls
[PE1-POS2/1/1] quit
# Configure basic MPLS on ASBR PE 1 and enable MPLS LDP on the interface connected to PE 1.
<ASBR-PE1> system-view
[ASBR-PE1] mpls lsr-id 2.2.2.9
[ASBR-PE1] mpls
[ASBR-PE1-mpls] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-mpls-ldp] quit
[ASBR-PE1] interface pos2/1/1
[ASBR-PE1-POS2/1/1] clock master
[ASBR-PE1-POS2/1/1] mpls
[ASBR-PE1-POS2/1/1] mpls ldp
[ASBR-PE1-POS2/1/1] quit
# Configure basic MPLS on ASBR PE 2 and enable MPLS LDP on the interface connected to PE 2.
<ASBR-PE2> system-view
[ASBR-PE2] mpls lsr-id 3.3.3.9
[ASBR-PE2] mpls
[ASBR-PE2-mpls] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-mpls-ldp] quit
[ASBR-PE2] interface pos2/1/1
[ASBR-PE2-POS2/1/1] clock master
[ASBR-PE2-POS2/1/1] mpls
[ASBR-PE2-POS2/1/1] mpls ldp
[ASBR-PE2-POS2/1/1] quit
# Configure basic MPLS on PE 2 and enable MPLS LDP on the interface connected to ASBR PE 2.
<PE2> system-view
[PE2] mpls lsr-id 4.4.4.9
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2] interface pos2/1/1
[PE2-POS2/1/1] mpls
[PE2-POS2/1/1] quit
After you complete the configurations, each PE and the ASBR PE in the same AS can establish neighbor relationship. Issue the display mpls ldp session command on the devices. The output shows that the session status is Operational.
3.      Configure VPN instances on PEs to allow CEs to access the network
For the same VPN, the VPN targets for the VPN instance on the PE must match those for the VPN instance on the ASBR-PE in the same AS. This is not required for PEs in different ASs.
# Configure CE 1.
<CE1> system-view
[CE1] interface GigabitEthernet 4/1/1
[CE1-GigabitEthernet4/1/1] ip address 10.1.1.1 24
[CE1-GigabitEthernet4/1/1] quit
# Configure PE 1.
[PE1] interface GigabitEthernet 4/1/2
[PE1-GigabitEthernet4/1/2] ip binding vpn-instance vpn1
[PE1-GigabitEthernet4/1/2] ip address 10.1.1.2 24
# Configure CE 2.
<CE2> system-view
[CE2] interface GigabitEthernet 4/1/1
[CE2-GigabitEthernet4/1/1] ip address 10.2.1.1 24
[CE2-GigabitEthernet4/1/1] quit
# Configure PE 2.
[PE2-vpn-instance-vpn1] route-distinguisher 200:2
[PE2-GigabitEthernet4/1/2] ip binding vpn-instance vpn1
[PE2-GigabitEthernet4/1/2] ip address 10.2.1.2 24
# Configure ASBR PE 1, creating a VPN instance and binding the instance to the interface connected to ASBR PE 2. ASBR PE 1 considers ASBR PE 2 its CE.
[ASBR-PE1] ip vpn-instance vpn1
[ASBR-PE1-vpn-vpn1] route-distinguisher 100:1
[ASBR-PE1-vpn-vpn1] vpn-target 100:1 both
[ASBR-PE1-vpn-vpn1] quit
[ASBR-PE1] interface POS 2/1/2
[ASBR-PE1-POS2/1/2] clock master
[ASBR-PE1-POS2/1/2] ip binding vpn-instance vpn1
[ASBR-PE1-POS2/1/2] ip address 192.1.1.1 24
[ASBR-PE1-POS2/1/2] quit
# Configure ASBR PE 2, creating a VPN instance and binding the instance to the interface connected to ASBR PE 1. ASBR PE 2 considers ASBR PE 1 its CE.
[ASBR-PE2] ip vpn-instance vpn1
[ASBR-PE2-vpn-vpn1] route-distinguisher 200:1
[ASBR-PE2-vpn-vpn1] vpn-target 100:1 both
[ASBR-PE2-vpn-vpn1] quit
[ASBR-PE2] interface POS 2/1/2
[ASBR-PE2-POS2/1/2] ip binding vpn-instance vpn1
[ASBR-PE2-POS2/1/2] ip address 192.1.1.2 24
[ASBR-PE2-POS2/1/2] quit
After completing the configurations, view the VPN instance configurations by issuing the display ip vpn-instance command.
The PEs can ping their attached CEs and the ASBR PEs can ping each other.
# Configure CE 1.
[CE1] bgp 65001
[CE1-bgp] quit
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-vpn1] peer 10.1.1.1 as-number 65001
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
# Configure CE 2.
[CE2] bgp 65002
[CE2-bgp] peer 10.2.1.2 as-number 200
[CE2-bgp] import-route direct
[CE2-bgp] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp] ipv4-family vpn-instance vpn1
[PE2-bgp-vpn1] peer 10.2.1.1 as-number 65002
[PE2-bgp-vpn1] import-route direct
[PE2-bgp-vpn1] quit
[PE2-bgp] quit
5.      Establish an MP-IBGP peer relationship between each PE and the ASBR-PE in the same AS and an EBGP peer relationship between the ASBR PEs
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-af-vpnv4] peer 2.2.2.9 next-hop-local
[PE1-bgp] quit
# Configure ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp] ipv4-family vpn-instance vpn1
[ASBR-PE1-bgp-vpn1] peer 192.1.1.2 as-number 200
[ASBR-PE1-bgp-vpn1] quit
[ASBR-PE1-bgp] peer 1.1.1.9 as-number 100
[ASBR-PE1-bgp] peer 1.1.1.9 connect-interface loopback 0
[ASBR-PE1-bgp] ipv4-family vpnv4
[ASBR-PE1-bgp-af-vpnv4] peer 1.1.1.9 enable
[ASBR-PE1-bgp-af-vpnv4] peer 1.1.1.9 next-hop-local
[ASBR-PE1-bgp-af-vpnv4] quit
[ASBR-PE1-bgp] quit
# Configure ASBR-PE 2.
[ASBR-PE2] bgp 200
[ASBR-PE2-bgp] ipv4-family vpn-instance vpn1
[ASBR-PE2-bgp-vpn1] peer 192.1.1.1 as-number 100
[ASBR-PE2-bgp-vpn1] quit
[ASBR-PE2-bgp] peer 4.4.4.9 as-number 200
[ASBR-PE2-bgp] peer 4.4.4.9 connect-interface loopback 0
[ASBR-PE2-bgp] ipv4-family vpnv4
[ASBR-PE2-bgp-af-vpnv4] peer 4.4.4.9 enable
[ASBR-PE2-bgp-af-vpnv4] peer 4.4.4.9 next-hop-local
[ASBR-PE2-bgp-af-vpnv4] quit
[ASBR-PE2-bgp] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp] peer 3.3.3.9 as-number 200
[PE2-bgp] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-af-vpnv4] peer 3.3.3.9 enable
[PE2-bgp-af-vpnv4] peer 3.3.3.9 next-hop-local
[PE2-bgp] quit
After you complete the configurations, the CEs can learn the interface routes from each other and ping each other.
Configuring inter-AS option B
·           Site 1 and Site 2 belong to the same VPN. CE 1 of Site 1 accesses the network through PE 1 in AS 100 and CE 2 of Site 2 accesses the network through PE 2 in AS 600.
·           PEs in the same AS run IS-IS.
·           PE 1 and ASBR-PE 1 exchange labeled IPv4 routes by MP-IBGP.
·           PE 2 and ASBR-PE 2 exchange labeled IPv4 routes by MP-IBGP.
·           ASBR-PE 1 and ASBR-PE 2 exchange labeled IPv4 routes by MP-EBGP.
·           ASBRs do not perform VPN target filtering of received VPN-IPv4 routes.
Figure 24 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
GE4/1/1
30.0.0.1/8
GE4/1/1
20.0.0.1/8
POS2/1/1
1.1.1.2/8
POS2/1/1
9.1.1.2/8
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
POS2/1/1
1.1.1.1/8
POS2/1/1
9.1.1.1/8
POS2/1/2
11.0.0.2/8
POS2/1/2
11.0.0.1/8
1.      Configure PE 1
# Start IS-IS on PE 1.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] network-entity 10.1111.1111.1111.1111.00
[PE1-isis-1] quit
# Configure LSR ID, enable MPLS and LDP.
[PE1] mpls lsr-id 2.2.2.9
[PE1] mpls
[PE1-mpls] label advertise non-null
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
# Configure interface POS 2/1/1, and start IS-IS and enable MPLS and LDP on the interface.
[PE1] interface POS 2/1/1
[PE1-POS2/1/1] ip address 1.1.1.2 255.0.0.0
[PE1-POS2/1/1] isis enable 1
[PE1-POS2/1/1] mpls
[PE1-POS2/1/1] quit
# Configure interface Loopback 0 and start IS-IS on it.
[PE1-LoopBack0] ip address 2.2.2.9 32
[PE1-LoopBack0] isis enable 1
# Create VPN instance vpn1 and configure the RD and VPN target attributes.
# Bind the interface connected with CE 1 to the created VPN instance.
[PE1-GigabitEthernet4/1/1] ip address 30.0.0.1 8
# Start BGP on PE 1.
[PE1] bgp 100
# Configure IBGP peer 3.3.3.9 as a VPNv4 peer.
# Redistribute direct routes to the VPN routing table of vpn1.
[PE1] bgp 100
[PE1-bgp-vpn1] quit
2.      Configure ASBR-PE 1
# Start IS-IS on ASBR-PE 1.
[ASBR-PE1] isis 1
[ASBR-PE1-isis-1] network-entity 10.2222.2222.2222.2222.00
[ASBR-PE1-isis-1] quit
[ASBR-PE1] mpls
[ASBR-PE1-mpls] label advertise non-null
[ASBR-PE1] mpls ldp
[ASBR-PE1] interface POS 2/1/1
[ASBR-PE1-POS2/1/1] ip address 1.1.1.1 255.0.0.0
[ASBR-PE1-POS2/1/1] isis enable 1
# Configure interface POS 2/1/2 and enable MPLS.
[ASBR-PE1-POS2/1/2] ip address 11.0.0.2 255.0.0.0
[ASBR-PE1-POS2/1/2] mpls
[ASBR-PE1-LoopBack0] ip address 3.3.3.9 32
[ASBR-PE1-LoopBack0] isis enable 1
[ASBR-PE1-LoopBack0] quit
# Start BGP on ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp] peer 2.2.2.9 as-number 100
[ASBR-PE1-bgp] peer 2.2.2.9 connect-interface loopback 0
[ASBR-PE1-bgp] peer 11.0.0.1 as-number 600
# Specify not to filter the received VPNv4 routes using the import target attribute.
[ASBR-PE1-bgp-af-vpnv4] undo policy vpn-target
# Configure both IBGP peer 2.2.2.0 and EBGP peer 11.0.0.1 as VPNv4 peers.
[ASBR-PE1-bgp-af-vpnv4] peer 11.0.0.1 enable
[ASBR-PE1-bgp-af-vpnv4] peer 2.2.2.9 enable
3.      Configure ASBR-PE 2
# Start IS-IS on ASBR-PE 2.
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] network-entity 10.222.222.222.222.00
[ASBR-PE2-isis-1] quit
[ASBR-PE2] mpls
[ASBR-PE2-mpls] label advertise non-null
[ASBR-PE2] mpls ldp
[ASBR-PE2] interface POS 2/1/1
[ASBR-PE2-POS2/1/1] ip address 9.1.1.1 255.0.0.0
[ASBR-PE2-POS2/1/1] isis enable 1
[ASBR-PE2-POS2/1/2] ip address 11.0.0.1 255.0.0.0
[ASBR-PE2-POS2/1/2] mpls
[ASBR-PE2] interface loopback 0
[ASBR-PE2-LoopBack0] ip address 4.4.4.9 32
[ASBR-PE2-LoopBack0] isis enable 1
[ASBR-PE2-LoopBack0] quit
# Start BGP on ASBR-PE 2.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp] peer 11.0.0.2 as-number 100
[ASBR-PE2-bgp] peer 5.5.5.9 as-number 600
[ASBR-PE2-bgp] peer 5.5.5.9 connect-interface loopback 0
[ASBR-PE2-bgp-af-vpnv4] undo policy vpn-target
# Configure both IBGP peer 5.5.5.9 and EBGP peer 11.0.0.2 as VPNv4 peers.
[ASBR-PE2-bgp-af-vpnv4] peer 11.0.0.2 enable
[ASBR-PE2-bgp-af-vpnv4] peer 5.5.5.9 enable
[ASBR-PE2-bgp] quit
4.      Configure PE 2
# Start IS-IS on PE 2.
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] network-entity 10.1111.1111.1111.1111.00
[PE2-isis-1] quit
[PE2] mpls lsr-id 5.5.5.9
[PE2] mpls
[PE2-mpls] label advertise non-null
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2] interface POS 2/1/1
[PE2-POS2/1/1] ip address 9.1.1.2 255.0.0.0
[PE2-POS2/1/1] isis enable 1
[PE2-POS2/1/1] mpls
[PE2-POS2/1/1] quit
[PE2-LoopBack0] ip address 5.5.5.9 32
[PE2-LoopBack0] isis enable 1
[PE2-vpn-instance-vpn1] route-distinguisher 12:12
[PE2-GigabitEthernet4/1/1] ip address 20.0.0.1 8
# Start BGP on PE 2.
[PE2] bgp 600
# Configure IBGP peer 4.4.4.9 as a VPNv4 peer.
[PE2-bgp] peer 4.4.4.9 as-number 600
[PE2-bgp] peer 4.4.4.9 connect-interface loopback 0
[PE2-bgp-af-vpnv4] peer 4.4.4.9 enable
[PE2-bgp-vpn1] quit
[PE2-bgp] quit
5.      Verify your configurations
# After you complete the configurations, ping PE 1 from PE 2. The ping operation is successful.
[PE2] ping –vpn-instance vpn1 30.0.0.1
# Ping PE 2 from PE 1. The ping operation is successful.
[PE1] ping –vpn-instance vpn1 20.0.0.1
Configuring inter-AS option C
·           Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100 and Site 2 accesses the network through PE 2 in AS 600.
·           PE 1 and PE 2 are MP-EBGP peers.
·           ASBR-PE 1 and ASBR-PE 2 use their respective routing policies and label the routes received from each other.
·           ASBR-PE 1 and ASBR-PE 2 use MP-EBGP to exchange labeled IPv4 routes.
Figure 25 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
Loop1
30.0.0.2
Loop1
20.0.0.2
POS4/1/1
1.1.1.2/8
POS4/1/1
9.1.1.2/8
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
POS4/1/1
1.1.1.1/8
POS4/1/1
9.1.1.1/8
POS4/1/2
11.0.0.2/8
POS4/1/2
11.0.0.1/8
1.      Configure PE 1
# Run IS-IS on PE 1.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] quit
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
# Configure interface POS 4/1/1, and start IS-IS and enable MPLS and LDP on the interface.
[PE1] interface POS 4/1/1
[PE1-POS4/1/1] ip address 1.1.1.2 255.0.0.0
[PE1-POS4/1/1] isis enable 1
[PE1-POS4/1/1] mpls
[PE1-POS4/1/1] mpls ldp
[PE1-POS4/1/1] quit
# Configure interface Loopback 1 and bind the interface to VPN instance vpn1.
[PE1] interface loopback 1
[PE1-LoopBack1] ip binding vpn-instance vpn1
[PE1-LoopBack1] ip address 30.0.0.1 32
[PE1-LoopBack1] quit
[PE1] bgp 100
# Configure the capability to advertise labeled routes to IBGP peer 3.3.3.9 and to receive labeled routes from the peer.
[PE1-bgp] peer 3.3.3.9 label-route-capability
# Configure the maximum hop count from PE 1 to EBGP peer 5.5.5.9 as 10.
[PE1-bgp] peer 5.5.5.9 as-number 600
[PE1-bgp] peer 5.5.5.9 connect-interface loopback 0
[PE1-bgp] peer 5.5.5.9 ebgp-max-hop 10
# Configure peer 5.5.5.9 as a VPNv4 peer.
[PE1-bgp-af-vpnv4] peer 5.5.5.9 enable
# Redistribute direct routes to the routing table of vpn1.
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
[ASBR-PE1] isis 1
[ASBR-PE1] mpls
[ASBR-PE1] mpls ldp
[ASBR-PE1] interface POS 4/1/1
[ASBR-PE1-POS4/1/1] clock master
[ASBR-PE1-POS4/1/1] ip address 1.1.1.1 255.0.0.0
[ASBR-PE1-POS4/1/1] isis enable 1
[ASBR-PE1-POS4/1/1] mpls
[ASBR-PE1-POS4/1/1] mpls ldp
[ASBR-PE1-POS4/1/1] quit
# Configure interface POS 4/1/2 and enable MPLS on it.
[ASBR-PE1] interface POS 4/1/2
[ASBR-PE1-POS4/1/2] clock master
[ASBR-PE1-POS4/1/2] ip address 11.0.0.2 255.0.0.0
[ASBR-PE1-POS4/1/2] mpls
[ASBR-PE1-POS4/1/2] quit
# Create routing policies.
[ASBR-PE1] route-policy policy1 permit node 1
[ASBR-PE1-route-policy1] apply mpls-label
[ASBR-PE1-route-policy1] quit
[ASBR-PE1] route-policy policy2 permit node 1
[ASBR-PE1-route-policy2] if-match mpls-label
[ASBR-PE1-route-policy2] apply mpls-label
[ASBR-PE1-route-policy2] quit
# Start BGP on ASBR-PE 1 and redistribute routes from IS-IS process 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp] import-route isis 1
# Use routing policy policy2 to filter routes advertised to IBGP peer 2.2.2.9.
[ASBR-PE1-bgp] peer 2.2.2.9 route-policy policy2 export
# Configure the capability to advertise labeled routes to IBGP peer 2.2.2.9 and to receive labeled routes from the peer.
[ASBR-PE1-bgp] peer 2.2.2.9 label-route-capability
# Use routing policy policy1 to filter routes advertised to EBGP peer 11.0.0.1.
[ASBR-PE1-bgp] peer 11.0.0.1 route-policy policy1 export
# Configure the capability to advertise labeled routes to EBGP peer 11.0.0.1 and to receive labeled routes from the peer.
[ASBR-PE1-bgp] peer 11.0.0.1 label-route-capability
[ASBR-PE1-bgp] quit
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] network-entity 10.2222.2222.2222.2222.00
[ASBR-PE2] mpls
[ASBR-PE2] mpls ldp
[ASBR-PE2] interface POS 4/1/1
[ASBR-PE2-POS4/1/1] clock master
[ASBR-PE2-POS4/1/1] ip address 9.1.1.1 255.0.0.0
[ASBR-PE2-POS4/1/1] isis enable 1
[ASBR-PE2-POS4/1/1] mpls
[ASBR-PE2-POS4/1/1] mpls ldp
[ASBR-PE2-POS4/1/1] quit
[ASBR-PE2] interface POS 4/1/2
[ASBR-PE2-POS4/1/2] ip address 11.0.0.1 255.0.0.0
[ASBR-PE2-POS4/1/2] mpls
[ASBR-PE2-POS4/1/2] quit
[ASBR-PE2] route-policy policy1 permit node 1
[ASBR-PE2-route-policy1] apply mpls-label
[ASBR-PE2-route-policy1] quit
[ASBR-PE2] route-policy policy2 permit node 1
[ASBR-PE2-route-policy2] if-match mpls-label
[ASBR-PE2-route-policy2] apply mpls-label
[ASBR-PE2-route-policy2] quit
# Start BGP on ASBR-PE 2 and redistribute routes from IS-IS process 1.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp] import-route isis 1
# Configure the capability to advertise labeled routes to IBGP peer 5.5.5.9 and to receive labeled routes from the peer.
[ASBR-PE2-bgp] peer 5.5.5.9 label-route-capability
# Use routing policy policy2 to filter routes advertised to IBGP peer 5.5.5.9.
[ASBR-PE2-bgp] peer 5.5.5.9 route-policy policy2 export
# Use routing policy policy1 to filter routes advertised to EBGP peer 11.0.0.2.
[ASBR-PE2-bgp] peer 11.0.0.2 route-policy policy1 export
# Configure the capability to advertise labeled routes to EBGP peer 11.0.0.2 and to receive labeled routes from the peer.
[ASBR-PE2-bgp] peer 11.0.0.2 label-route-capability
[ASBR-PE2-bgp] quit
4.      Configure PE 2
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2] interface POS 4/1/1
[PE2-POS4/1/1] ip address 9.1.1.2 255.0.0.0
[PE2-POS4/1/1] isis enable 1
[PE2-POS4/1/1] mpls
[PE2-POS4/1/1] mpls ldp
[PE2-POS4/1/1] quit
[PE2-vpn-instance-vpn1] route-distinguisher 11:11
[PE2] interface loopback 1
[PE2-LoopBack1] ip binding vpn-instance vpn1
[PE2-LoopBack1] ip address 20.0.0.1 32
[PE2-LoopBack1] quit
[PE2] bgp 600
# Configure the capability to advertise labeled routes to IBGP peer 4.4.4.9 and to receive labeled routes from the peer.
[PE2-bgp] peer 4.4.4.9 label-route-capability
# Configure the maximum hop count from PE 2 to EBGP peer 2.2.2.9 as 10.
[PE2-bgp] peer 2.2.2.9 as-number 100
[PE2-bgp] peer 2.2.2.9 connect-interface loopback 0
[PE2-bgp] peer 2.2.2.9 ebgp-max-hop 10
# Configure peer 2.2.2.9 as a VPNv4 peer.
[PE2-bgp-af-vpnv4] peer 2.2.2.9 enable
[PE2-bgp-vpn1] quit
[PE2-bgp] quit
After you complete the configurations, PE 1 and PE 2 can ping each other:
Configuring carrier’s carrier
Configure carrier’s carrier for the scenario shown in Figure 26. In this scenario:
·           PE 1 and PE 2 are the provider carrier’s PE routers. They provide VPN services for the customer carrier.
·           CE 1 and CE 2 are the customer carrier’s routers. They are connected to the provider carrier’s backbone as CE routers.
·           PE 3 and PE 4 are the customer carrier’s PE routers. They provide MPLS L3VPN services for the end customers.
·           CE 3 and CE 4 are customers of the customer carrier.
The key to carrier’s carrier deployment is to configure exchange of two kinds of routes:
·           Exchange of the customer carrier’s internal routes on the provider carrier’s backbone.
·           Exchange of the end customers’ VPN routes between PE 3 and PE 4, the PEs of the customer carrier. In this process, an MP-IBGP peer relationship must be established between PE 3 and PE 4.
Figure 26 Network diagram
Device
IP address
Device
IP address
CE 3
GE4/1/1
100.1.1.1/24
CE 4
GE4/1/1
120.1.1.1/24
PE 3
Loop0
1.1.1.9/32
PE 4
Loop0
6.6.6.9/32
GE4/1/1
100.1.1.2/24
GE4/1/1
120.1.1.2/24
POS2/1/2
10.1.1.1/24
POS2/1/2
20.1.1.2/24
CE 1
Loop0
2.2.2.9/32
CE 2
Loop0
5.5.5.9/32
POS2/1/1
10.1.1.2/24
POS2/1/1
21.1.1.2/24
POS2/1/2
11.1.1.1/24
POS2/1/2
20.1.1.1/24
PE 1
Loop0
3.3.3.9/32
PE 2
Loop0
4.4.4.9/32
POS2/1/1
11.1.1.2/24
POS2/1/1
30.1.1.2/24
POS2/1/2
30.1.1.1/24
POS2/1/2
21.1.1.1/24
1.      Configure MPLS L3VPN on the provider carrier backbone: start IS-IS as the IGP, enable LDP between PE 1 and PE 2, and establish an MP-IBGP peer relationship between the PEs
# Configure PE 1.
<PE1> system-view
[PE1-LoopBack0] ip address 3.3.3.9 32
[PE1] mpls lsr-id 3.3.3.9
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE1-isis-1] quit
[PE1] interface POS 2/1/2
[PE1-POS2/1/2] ip address 30.1.1.1 24
[PE1-POS2/1/2] isis enable 1
[PE1-POS2/1/2] mpls
[PE1-POS2/1/2] mpls ldp
[PE1-POS2/1/2] mpls ldp transport-address interface
[PE1-POS2/1/2] quit
[PE1] bgp 100
[PE1-bgp] peer 4.4.4.9 as-number 100
[PE1-bgp] peer 4.4.4.9 connect-interface loopback 0
[PE1-bgp-af-vpnv4] peer 4.4.4.9 enable
[PE1-bgp] quit
After completing the configurations, issue the display mpls ldp session command on PE 1 or PE 2; the output shows that the LDP session has been successfully established. Issue the display bgp peer command; the output shows that the BGP peer relationship has been established and has reached the Established state. Issue the display isis peer command; the output shows that the IS-IS neighbor relationship has been set up. Take PE 1 as an example:
 4.4.4.9:0      Operational   DU   Active   Off  Off  378/378
 BGP local router ID : 3.3.3.9
  4.4.4.9      100      162      145     0        0  02:12:47 Established
[PE1] display isis peer
                          Peer information for ISIS(1)
  System Id    Interface   Circuit Id    State HoldTime Type   PRI
0000.0000.0005 POS2/1/2           001       Up   29s      L1L2   --
2.      Configure the customer carrier network: start IS-IS as the IGP and enable LDP between PE 3 and CE 1, and between PE 4 and CE 2 respectively
# Configure PE 3.
<PE3> system-view
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 1.1.1.9 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 1.1.1.9
[PE3] mpls
[PE3-mpls] quit
[PE3] mpls ldp
[PE3-mpls-ldp] quit
[PE3] isis 2
[PE3-isis-2] network-entity 10.0000.0000.0000.0001.00
[PE3-isis-2] quit
[PE3-LoopBack0] isis enable 2
[PE3] interface POS 2/1/2
[PE3-POS2/1/2] ip address 10.1.1.1 24
[PE3-POS2/1/2] isis enable 2
[PE3-POS2/1/2] mpls
[PE3-POS2/1/2] mpls ldp
[PE3-POS2/1/2] mpls ldp transport-address interface
[PE3-POS2/1/2] quit
# Configure CE 1.
<CE1> system-view
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 2.2.2.9 32
[CE1-LoopBack0] quit
[CE1] mpls lsr-id 2.2.2.9
[CE1] mpls
[CE1-mpls] quit
[CE1] mpls ldp
[CE1-mpls-ldp] quit
[CE1] isis 2
[CE1-isis-2] network-entity 10.0000.0000.0000.0002.00
[CE1-isis-2] quit
[CE1-LoopBack0] isis enable 2
[CE1] interface pos2/1/1
[CE1-POS2/1/1] ip address 10.1.1.2 24
[CE1-POS2/1/1] isis enable 2
[CE1-POS2/1/1] mpls
[CE1-POS2/1/1] mpls ldp
[CE1-POS2/1/1] mpls ldp transport-address interface
[CE1-POS2/1/1] quit
After you complete the configurations, PE 3 and CE 1 can establish an LDP session and IS-IS neighbor relationship between them.
The configurations for PE 4 and CE 2 are similar to those for PE 3 and CE 1. (Details not shown)
3.      Perform configuration to allow CEs of the customer carrier to access PEs of the provider carrier, and redistribute IS-IS routes to BGP and BGP routes to IS-IS on the PEs.
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 200:1
[PE1] mpls ldp vpn-instance vpn1
[PE1-mpls-ldp-vpn-instance-vpn1] quit
[PE1] isis 2 vpn-instance vpn1
[PE1-isis-2] network-entity 10.0000.0000.0000.0003.00
[PE1-isis-2] import-route bgp allow-ibgp
[PE1-isis-2] quit
[PE1-POS2/1/1] ip binding vpn-instance vpn1
[PE1-POS2/1/1] ip address 11.1.1.2 24
[PE1-POS2/1/1] isis enable 2
[PE1-POS2/1/1] mpls
[PE1-POS2/1/1] mpls ldp transport-address interface
[PE1-POS2/1/1] quit
[PE1] bgp 100
[PE1-bgp-vpn1] import isis 2
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
# Configure CE 1.
[CE1] interface POS 2/1/2
[CE1-POS2/1/2] ip address 11.1.1.1 24
[CE1-POS2/1/2] isis enable 2
[CE1-POS2/1/2] mpls
[CE1-POS2/1/2] mpls ldp
[CE1-POS2/1/2] mpls ldp transport-address interface
[CE1-POS2/1/2] quit
After you complete the configurations, PE 1 and CE 1 can establish an LDP session and IS-IS neighbor relationship between them.
The configurations for PE 2 and CE 2 are similar to those for PE 1 and CE 1. (Details not shown)
4.      Perform configuration to connect CEs of the end customers to the PEs of the customer carrier.
# Configure CE 3.
<CE3> system-view
[CE3] interface GigabitEthernet 4/1/1
[CE3-GigabitEthernet4/1/1] ip address 100.1.1.1 24
[CE3-GigabitEthernet4/1/1] quit
[CE3] bgp 65410
[CE3-bgp] peer 100.1.1.2 as-number 100
[CE3-bgp] import-route direct
[CE3-bgp] quit
# Configure PE 3.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 100:1
[PE3-vpn-instance-vpn1] vpn-target 1:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface GigabitEthernet 4/1/1
[PE3-GigabitEthernet4/1/1] ip binding vpn-instance vpn1
[PE3-GigabitEthernet4/1/1] ip address 100.1.1.2 24
[PE3-GigabitEthernet4/1/1] quit
[PE3] bgp 100
[PE3-bgp] ipv4-family vpn-instance vpn1
[PE3-bgp-vpn1] peer 100.1.1.1 as-number 65410
[PE3-bgp-vpn1] import-route direct
[PE3-bgp-vpn1] quit
[PE3-bgp] quit
The configurations for PE 4 and CE 4 are similar to those for PE 3 and CE 3. (Details not shown)
5.      Configure an MP-IBGP peer relationship between the PEs of the customer carrier to exchange the VPN routes of the end customers
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp] peer 6.6.6.9 as-number 100
[PE3-bgp] peer 6.6.6.9 connect-interface loopback 0
[PE3-bgp] ipv4-family vpnv4
[PE3-bgp-af-vpnv4] peer 6.6.6.9 enable
[PE3-bgp-af-vpnv4] quit
[PE3-bgp] quit
The configurations for PE 4 are similar to those for PE 3. (Details not shown)
After completing all the configurations, issue the display ip routing-table command on PE 1 and PE 2. The output shows that only routes of the provider carrier network are present in the public network routing table of PE 1 and PE 2. Take PE 1 as an example:
3.3.3.9/32          Direct 0    0       127.0.0.1    InLoop0
4.4.4.9/32          ISIS   15   10      30.1.1.2     POS2/1/2
30.1.1.0/24         Direct 0    0       30.1.1.1     POS2/1/2
30.1.1.1/32         Direct 0    0       127.0.0.1    InLoop0
30.1.1.2/32         Direct 0    0       30.1.1.2     POS2/1/2
Issue the display ip routing-table vpn-instance command on PE 1 and PE 2. The output shows that the internal routes of the customer carrier network are present in the VPN routing tables, but the VPN routes that the customer carrier maintains are not. Take PE 1 as an example:
1.1.1.9/32          ISIS   15   20      11.1.1.1      POS2/1/1
2.2.2.9/32          ISIS   15   10      11.1.1.1      POS2/1/1
5.5.5.9/32          BGP    255  0       4.4.4.9       NULL0
6.6.6.9/32          BGP    255  0       4.4.4.9       NULL0
10.1.1.0/24         ISIS   15   20      11.1.1.1      POS2/1/1
11.1.1.0/24         Direct 0    0       11.1.1.1      POS2/1/1
11.1.1.1/32         Direct 0    0       127.0.0.1     InLoop0
11.1.1.2/32         Direct 0    0       11.1.1.2      POS2/1/1
20.1.1.0/24         BGP    255  0       4.4.4.9       NULL0
21.1.1.0/24         BGP    255  0       4.4.4.9       NULL0
21.1.1.2/32         BGP    255  0       4.4.4.9       NULL0
Issue the display ip routing-table command on CE 1 and CE 2. The output shows that the internal routes of the customer carrier network are present in the public network routing tables, but the VPN routes that the customer carrier maintains are not. Take CE 1 as an example:
         Destinations : 16       Routes : 16
1.1.1.9/32          ISIS   15   10     10.1.1.2        POS2/1/1
2.2.2.9/32          Direct 0    0      127.0.0.1       InLoop0
5.5.5.9/32          ISIS   15   74     11.1.1.2        POS2/1/2
6.6.6.9/32          ISIS   15   74     11.1.1.2        POS2/1/2
10.1.1.0/24         Direct 0    0      10.1.1.2        POS2/1/1
10.1.1.1/32         Direct 0    0      10.1.1.1        POS2/1/1
11.1.1.0/24         Direct 0    0      11.1.1.1        POS2/1/2
11.1.1.2/32         Direct 0    0      11.1.1.2        POS2/1/2
20.1.1.0/24         ISIS   15   74     11.1.1.2        POS2/1/2
21.1.1.0/24         ISIS   15   74     11.1.1.2        POS2/1/2
21.1.1.2/32         ISIS   15   74     11.1.1.2        POS2/1/2
Issue the display ip routing-table command on PE 3 and PE 4. The output shows that the internal routes of the customer carrier network are present in the public network routing tables. Take PE 3 as an example:
[PE3] display ip routing-table
2.2.2.9/32          ISIS   15   10     10.1.1.2        POS2/1/2
5.5.5.9/32          ISIS   15   84     10.1.1.2        POS2/1/2
6.6.6.9/32          ISIS   15   84     10.1.1.2        POS2/1/2
10.1.1.0/24         Direct 0    0      10.1.1.1        POS2/1/2
10.1.1.2/32         Direct 0    0      10.1.1.2        POS2/1/2
11.1.1.0/24         ISIS   15   20     10.1.1.2        POS2/1/2
20.1.1.0/24         ISIS   15   84     10.1.1.2        POS2/1/2
21.1.1.0/24         ISIS   15   84     10.1.1.2        POS2/1/2
21.1.1.2/32         ISIS   15   84     10.1.1.2        POS2/1/2
Issue the display ip routing-table vpn-instance command on PE 3 and PE 4. The output shows that the routes of the remote VPN customers are present in the VPN routing tables. Take PE 3 as an example:
[PE3] display ip routing-table vpn-instance vpn1
100.1.1.0/24        Direct 0    0       100.1.1.2      GE4/1/1
100.1.1.2/32        Direct 0    0       127.0.0.1      InLoop0
120.1.1.0/24        BGP    255  0       6.6.6.9        NULL0
PE 3 and PE 4 can ping each other:
[PE3] ping 20.1.1.2
  PING 20.1.1.2: 56  data bytes, press CTRL_C to break
    Reply from 20.1.1.2: bytes=56 Sequence=1 ttl=252 time=127 ms
    Reply from 20.1.1.2: bytes=56 Sequence=2 ttl=252 time=97 ms
    Reply from 20.1.1.2: bytes=56 Sequence=3 ttl=252 time=83 ms
    Reply from 20.1.1.2: bytes=56 Sequence=4 ttl=252 time=70 ms
    Reply from 20.1.1.2: bytes=56 Sequence=5 ttl=252 time=60 ms
  --- 20.1.1.2 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 60/87/127 ms
CE 3 and CE 4 can ping each other:
[CE3] ping 120.1.1.1
  PING 120.1.1.1: 56  data bytes, press CTRL_C to break
    Reply from 120.1.1.1: bytes=56 Sequence=1 ttl=252 time=102 ms
    Reply from 120.1.1.1: bytes=56 Sequence=2 ttl=252 time=69 ms
    Reply from 120.1.1.1: bytes=56 Sequence=3 ttl=252 time=105 ms
    Reply from 120.1.1.1: bytes=56 Sequence=4 ttl=252 time=88 ms
    Reply from 120.1.1.1: bytes=56 Sequence=5 ttl=252 time=87 ms
  --- 120.1.1.1 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 69/90/105 ms
Configuring nested VPN
The service provider provides nested VPN services for users, as shown in Figure 27, where:
·           PE 1 and PE 2 are PE devices on the service provider backbone. Both of them support the nested VPN function.
·           CE 1 and CE 2 are connected to the service provider backbone. Both of them support VPNv4 routes.
·           PE 3 and PE 4 are PE devices of the customer VPN. Both of them support MPLS L3VPN.
·           CE 3 through CE 6 are CE devices of sub-VPNs for the customer VPN.
The key of nested VPN configuration is to understand the processing of routes of sub-VPNs on the service provider PEs, which is described as follows:
·           When receiving a VPNv4 route from a CE (CE 1 or CE 2 in this example), a service provider PE replaces the RD of the VPNv4 route with the RD of the MPLS VPN on the service provider network where the CE resides, adds the export target attribute of the MPLS VPN on the service provider network to the extended community attribute list, and then forwards the VPNv4 route as usual.
·           To implement exchange of sub-VPN routes between customer PEs and service provider PEs, MP-EBGP peers should be established between service provider PEs and customer CEs.
Figure 27 Network diagram
Device
IP address
Device
IP address
CE 1
Loop0
2.2.2.9/32
CE 2
Loop0
5.5.5.9/32
POS5/1/1
10.1.1.2/24
POS5/1/1
21.1.1.2/24
POS5/1/2
11.1.1.1/24
POS5/1/2
20.1.1.1/24
CE 3
GE3/1/1
100.1.1.1/24
CE 4
GE3/1/1
120.1.1.1/24
CE 5
GE3/1/1
110.1.1.1/24
CE 6
GE3/1/1
130.1.1.1/24
PE 1
Loop0
3.3.3.9/32
PE 2
Loop0
4.4.4.9/32
POS5/1/1
11.1.1.2/24
POS5/1/1
30.1.1.2/24
POS5/1/2
30.1.1.1/24
POS5/1/2
21.1.1.1/24
PE 3
Loop0
1.1.1.9/32
PE 4
Loop0
6.6.6.9/32
GE3/1/1
100.1.1.2/24
GE3/1/1
120.1.1.2/24
GE3/1/2
110.1.1.2/24
GE3/1/2
130.1.1.2/24
POS5/1/2
10.1.1.1/24
POS5/1/2
20.1.1.2/24
Configuration procedure
1.      Configure MPLS L3VPN on the service provider backbone, using IS-IS as the IGP protocol, and enabling LDP and establishing MP-IBGP peer relationship between PE 1 and PE 2.
# Configure PE 1.
<PE1> system-view
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] interface pos 5/1/2
[PE1-POS5/1/2] ip address 30.1.1.1 24
[PE1-POS5/1/2] isis enable 1
[PE1-POS5/1/2] mpls
[PE1-POS5/1/2] mpls ldp
[PE1-POS5/1/2] mpls ldp transport-address interface
[PE1-POS5/1/2] quit
[PE1] bgp 100
[PE1-bgp] quit
Configurations on PE 2 are similar to those on PE 1, and are thus omitted here.
After completing the configurations, execute commands display mpls ldp session, display bgp peer and display isis peer respectively on either PE 1 or PE 2. The output shows that the LDP session is established, the BGP peer relationship is established and in Established state, and the IS-IS neighbor relationship is established and up.
The following takes PE 1 for illustration.
0000.0000.0005 POS5/1/1           001       Up   29s      L1L2   --
2.      Configure the customer VPN, using IS-IS as the IGP protocol and enabling LDP between PE 3 and CE 1, and between PE 4 and CE 2.
# Configure PE 3.
<PE3> system-view
[PE3] mpls
[PE3-mpls] quit
[PE3] mpls ldp
[PE3-mpls-ldp] quit
[PE3] isis 2
[PE3-isis-2] quit
[PE3] interface pos 5/1/2
[PE3-POS5/1/2] ip address 10.1.1.1 24
[PE3-POS5/1/2] isis enable 2
[PE3-POS5/1/2] mpls
[PE3-POS5/1/2] mpls ldp
[PE3-POS5/1/2] quit
# Configure CE 1.
<CE1> system-view
[CE1] mpls
[CE1-mpls] quit
[CE1] mpls ldp
[CE1-mpls-ldp] quit
[CE1] isis 2
[CE1-isis-2] quit
[CE1] interface pos 5/1/1
[CE1-POS5/1/1] ip address 10.1.1.2 24
[CE1-POS5/1/1] isis enable 2
[CE1-POS5/1/1] mpls
[CE1-POS5/1/1] mpls ldp
[CE1-POS5/1/1] quit
After the configurations, LDP and IS-IS neighbor relationship can be established between PE 3 and CE 1.
Configurations on PE 4 and CE 2 are similar to those on PE 3 and CE 1 respectively, and are thus omitted here.
3.      Connect CE 1 and CE 2 to service provider PEs.
# Configure PE 1.
[PE1-POS5/1/1] ip binding vpn-instance vpn1
[PE1-POS5/1/1] ip address 11.1.1.2 24
[PE1-POS5/1/1] mpls
[PE1-POS5/1/1] quit
[PE1] bgp 100
[PE1-bgp-vpn1] peer 11.1.1.1 as-number 200
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
# Configure CE 1.
[CE1] interface pos 5/1/2
[CE1-POS5/1/2] ip address 11.1.1.1 24
[CE1-POS5/1/2] mpls
[CE1-POS5/1/2] quit
[CE1] bgp 200
[CE1-bgp] peer 11.1.1.2 as-number 100
[CE1-bgp] import isis 2
[CE1-bgp] quit
Configurations on PE 2 and CE 2 are similar to those on PE 1 and CE 1 respectively, and are thus omitted here.
4.      Connect sub-VPN CEs to the customer VPN PEs.
# Configure CE 3.
<CE3> system-view
[CE3] interface GigabitEthernet 3/1/1
[CE3-GigabitEthernet3/1/1] ip address 100.1.1.1 24
[CE3-GigabitEthernet3/1/1] quit
[CE3] bgp 65410
[CE3-bgp] peer 100.1.1.2 as-number 200
[CE3-bgp] quit
# Configure CE 5.
<CE5> system-view
[CE5] interface GigabitEthernet 3/1/1
[CE5-GigabitEthernet3/1/1] ip address 110.1.1.1 24
[CE5-GigabitEthernet3/1/1] quit
[CE5] bgp 65411
[CE5-bgp] peer 110.1.1.2 as-number 200
[CE5-bgp] import-route direct
[CE5-bgp] quit
# Configure PE 3.
[PE3] ip vpn-instance SUB_VPN1
[PE3-vpn-instance-SUB_VPN1] route-distinguisher 100:1
[PE3-vpn-instance-SUB_VPN1] vpn-target 2:1
[PE3-vpn-instance-SUB_VPN1] quit
[PE3] interface GigabitEthernet 3/1/1
[PE3-GigabitEthernet3/1/1] ip binding vpn-instance SUB_VPN1
[PE3-GigabitEthernet3/1/1] ip address 100.1.1.2 24
[PE3-GigabitEthernet3/1/1] quit
[PE3] ip vpn-instance SUB_VPN2
[PE3-vpn-instance-SUB_VPN2] route-distinguisher 101:1
[PE3-vpn-instance-SUB_VPN2] vpn-target 2:2
[PE3-vpn-instance-SUB_VPN2] quit
[PE3] interface GigabitEthernet 3/1/2
[PE3-GigabitEthernet3/1/2] ip binding vpn-instance SUB_VPN2
[PE3-GigabitEthernet3/1/2] ip address 110.1.1.2 24
[PE3-GigabitEthernet3/1/2] quit
[PE3] bgp 100
[PE3-bgp] ipv4-family vpn-instance SUB_VPN1
[PE3-bgp-SUB_VPN1] peer 100.1.1.1 as-number 65410
[PE3-bgp-SUB_VPN1] import-route direct
[PE3-bgp-SUB_VPN1] quit
[PE3-bgp] ipv4-family vpn-instance SUB_VPN2
[PE3-bgp-SUB_VPN2] peer 110.1.1.1 as-number 65411
[PE3-bgp-SUB_VPN2] import-route direct
[PE3-bgp-SUB_VPN2] quit
[PE3-bgp] quit
Configurations on PE 4, CE 4 and CE 6 are similar to those on PE 3, CE 3 and CE 5 respectively, and are thus omitted here.
5.      Establish MP-EBGP peer relationship between service provider PEs and their CEs to exchange user VPNv4 routes.
# Configure PE 1, enabling nested VPN.
[PE1] bgp 100
[PE1-bgp-af-vpnv4] nesting-vpn
[PE1-bgp-af-vpnv4] peer 11.1.1.1 vpn-instance vpn1 enable
[PE1-bgp] quit
# Configure CE 1, enabling VPNv4 capability and establishing VPNv4 neighbor relationship between CE 1 and PE 1.
[CE1] bgp 200
[CE1-bgp] ipv4-family vpnv4
[CE1-bgp-af-vpnv4] peer 11.1.1.2 enable
# Allow the local AS number to appear in the AS-PATH attribute of the routes received.
[CE1-bgp-af-vpnv4] peer 11.1.1.2 allow-as-loop 2
# Receive all VPNv4 routes.
[CE1-bgp-af-vpnv4] undo policy vpn-target
[CE1-bgp-af-vpnv4] quit
[CE1-bgp] quit
6.      Establish MP-IBGP peer relationship between sub-VPN PEs and CEs of the customer VPN to exchange VPNv4 routes of sub-VPNs.
# Configure PE 3.
[PE3] bgp 200
[PE3-bgp] peer 2.2.2.9 as-number 200
[PE3-bgp] peer 2.2.2.9 connect-interface loopback 0
[PE3-bgp-af-vpnv4] peer 2.2.2.9 enable
[PE3-bgp-af-vpnv4] peer 2.2.2.9 allow-as-loop 2
[PE3-bgp] quit
# Configure CE 1.
[CE1] bgp 200
[CE1-bgp] peer 1.1.1.9 as-number 200
[CE1-bgp] peer 1.1.1.9 connect-interface loopback 0
[CE1-bgp-af-vpnv4] peer 1.1.1.9 enable
[CE1-bgp] quit
7.      Verify the configurations.
After completing all the configurations, execute the display ip routing-table command on PE 1 and PE 2 to verify that the public routing tables contain only routes on the service provider network. The following takes PE 1 for illustration.
4.4.4.9/32          ISIS   15   10           30.1.1.2        POS5/1/2
30.1.1.0/24         Direct 0    0            30.1.1.1        POS5/1/2
30.1.1.2/32         Direct 0    0            30.1.1.2        POS5/1/2
Execute the display ip routing-table vpn-instance command on PE 1 and PE 2 to verify that the VPN routing tables contain sub-VPN routes. The following takes PE 1 for illustration.
         Destinations : 9        Routes : 9
11.1.1.0/24         Direct 0    0            11.1.1.1        POS5/1/1
11.1.1.2/32         Direct 0    0            11.1.1.2        POS5/1/1
100.1.1.0/24        BGP    255  0            11.1.1.1        NULL0
110.1.1.0/24        BGP    255  0            11.1.1.1        NULL0
120.1.1.0/24        BGP    255  0            4.4.4.9         NULL0
130.1.1.0/24        BGP    255  0            4.4.4.9         NULL0
Execute the display bgp vpnv4 all routing-table command on CE 1 and CE 2 to verify that the VPNv4 routing tables on the customer VPN contain internal sub-VPN routes. The following takes CE 1 for illustration.
[CE1] display bgp vpnv4 all routing-table
BGP Local router ID is 11.11.11.11
 Status codes: * - valid, ^ - VPN best, > - best, d - damped,
               h - history,  i - internal, s - suppressed, S - Stale
               Origin : i - IGP, e - EGP, ? - incomplete
 Total number of routes from all PE: 4
Route Distinguisher: 100:1
    Network            NextHop         In/Out Label     MED        LocPrf
*>  100.1.1.0/24       1.1.1.9         1024/1024
Route Distinguisher: 101:1
*^  100.1.1.0/24       1.1.1.9         1024/1024
* > 110.1.1.0/24       1.1.1.9         1025/1025
 Route Distinguisher: 200:1
* > 120.1.1.0/24       11.1.1.2        1026/1027
Route Distinguisher: 201:1
* > 130.1.1.0/24       11.1.1.2        1027/1028
Execute the display ip routing-table vpn-instance SUB_VPN1 command on PE 3 and PE 4 to verify that the VPN routing tables contain routes sent by provider PEs to sub-VPNs. The following takes PE 3 for illustration.
[PE3] display ip routing-table vpn-instance SUB_VPN1
Routing Tables: SUB_VPN1
100.1.1.0/24        Direct 0    0            100.1.1.2       GE3/1/1
120.1.1.0/24        BGP    255  0            2.2.2.9         NULL0
Execute the display ip routing-table command on CE 3 and CE 4 to verify that the routing tables contain routes of remote sub-VPNs. The following takes CE 3 for illustration.
[CE3] display ip routing-table
100.1.1.0/24        Direct 0    0            100.1.1.1       GE3/1/1
100.1.1.1/32        Direct 0    0            127.0.0.1       InLoop0
120.1.1.0/24        BGP    255  0            100.1.1.2       GE3/1/1
Execute the display ip routing-table command on CE 5 and CE 6 to verify that the routing tables contain routes of remote sub-VPNs. The following takes CE5 for illustration.
[CE5] display ip routing-table
Routing Tables: Public
110.1.1.0/24        Direct 0    0            110.1.1.1       GE3/1/1
110.1.1.1/32        Direct 0    0            127.0.0.1       InLoop0
130.1.1.0/24        BGP    255  0            110.1.1.2       GE3/1/1
CE 3 and CE 4 can ping each other successfully.
    0.00% packet loss
CE 5 and CE 6 can ping each other successfully.
[CE5] ping 130.1.1.1
  PING 130.1.1.1: 56  data bytes, press CTRL_C to break
    Reply from 130.1.1.1: bytes=56 Sequence=1 ttl=252 time=102 ms
    Reply from 130.1.1.1: bytes=56 Sequence=2 ttl=252 time=69 ms
    Reply from 130.1.1.1: bytes=56 Sequence=3 ttl=252 time=105 ms
    Reply from 130.1.1.1: bytes=56 Sequence=4 ttl=252 time=88 ms
    Reply from 130.1.1.1: bytes=56 Sequence=5 ttl=252 time=87 ms
  --- 130.1.1.1 ping statistics ---
    0.00% packet loss
CE 3 and CE 6 cannot ping each other.
[CE3] ping 130.1.1.1
    Request time out
    Request time out
    Request time out
    Request time out
    Request time out
    100.00% packet loss
Configuring HoVPN
Network requirements
There are two levels of networks, the backbone and the MPLS VPN networks, as shown in Figure 28.
·           SPEs act as PEs to allow MPLS VPNs to access the backbone.
·           UPEs act as PEs of the MPLS VPNs to allow end users to access the VPNs.
·           Performance requirements for the UPEs are lower than those for the SPEs.
·           SPEs advertise routes permitted by the routing policies to UPEs, permitting CE 1 and CE 3 in VPN 1 to communicate with each other and forbidding CE 2 and CE 4 in VPN 2 to communicate with each other.
Figure 28 Network diagram
Device
IP address
Device
IP address
CE 1
GE4/1/1
10.2.1.1/24
CE 3
GE4/1/1
10.1.1.1/24
CE 2
GE4/1/1
10.4.1.1/24
CE 4
GE4/1/1
10.3.1.1/24
UPE 1
Loop0
1.1.1.9/32
UPE 2
Loop0
4.4.4.9/32
GE4/1/1
10.2.1.2/24
GE4/1/1
172.2.1.1/24
GE4/1/2
10.4.1.2/24
GE4/1/2
10.1.1.2/24
GE4/1/3
172.1.1.1/24
GE4/1/3
10.3.1.2/24
SPE 1
Loop0
2.2.2.9/32
SPE 2
Loop0
3.3.3.9/32
GE4/1/1
172.1.1.2/24
GE4/1/1
180.1.1.2/24
GE4/1/2
180.1.1.1/24
GE4/1/2
172.2.1.2/24
1.      Configure UPE 1
# Configure basic MPLS and MPLS LDP to establish LDP LSPs.
<UPE1> system-view
[UPE1] interface loopback 0
[UPE1-LoopBack0] ip address 1.1.1.9 32
[UPE1-LoopBack0] quit
[UPE1] mpls lsr-id 1.1.1.9
[UPE1] mpls
[UPE1-mpls] quit
[UPE1] mpls ldp
[UPE1-mpls-ldp] quit
[UPE1] interface GigabitEthernet 4/1/3
[UPE1-GigabitEthernet4/1/3] ip address 172.1.1.1 24
[UPE1-GigabitEthernet4/1/3] mpls
[UPE1-GigabitEthernet4/1/3] mpls ldp
[UPE1-GigabitEthernet4/1/3] quit
# Configure the IGP protocol, OSPF, for example.
[UPE1] ospf
[UPE1-ospf-1] area 0
[UPE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[UPE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[UPE1-ospf-1-area-0.0.0.0] quit
[UPE1-ospf-1] quit
# Configure VPN instances vpn1 and vpn2, allowing CE 1 and CE 2 to access UPE 1.
[UPE1] ip vpn-instance vpn1
[UPE1-vpn-instance-vpn1] route-distinguisher 100:1
[UPE1-vpn-instance-vpn1] vpn-target 100:1 both
[UPE1-vpn-instance-vpn1] quit
[UPE1] ip vpn-instance vpn2
[UPE1-vpn-instance-vpn2] route-distinguisher 100:2
[UPE1-vpn-instance-vpn2] vpn-target 100:2 both
[UPE1-vpn-instance-vpn2] quit
[UPE1] interface GigabitEthernet 4/1/1
[UPE1-GigabitEthernet4/1/1] ip binding vpn-instance vpn1
[UPE1-GigabitEthernet4/1/1] ip address 10.2.1.2 24
[UPE1-GigabitEthernet4/1/1] quit
[UPE1] interface GigabitEthernet 4/1/2
[UPE1-GigabitEthernet4/1/2] ip binding vpn-instance vpn2
[UPE1-GigabitEthernet4/1/2] ip address 10.4.1.2 24
[UPE1-GigabitEthernet4/1/2] quit
# Configure UPE 1 to establish MP-IBGP peer relationship with SPE 1 and to inject VPN routes.
[UPE1] bgp 100
[UPE1-bgp] peer 2.2.2.9 as-number 100
[UPE1-bgp] peer 2.2.2.9 connect-interface loopback 0
[UPE1-bgp] ipv4-family vpnv4
[UPE1-bgp-af-vpnv4] peer 2.2.2.9 enable
[UPE1-bgp-af-vpnv4] quit
[UPE1-bgp] ipv4-family vpn-instance vpn1
[UPE1-bgp-vpn1] peer 10.2.1.1 as-number 65410
[UPE1-bgp-vpn1] import-route direct
[UPE1-bgp-vpn1] quit
[UPE1-bgp] ipv4-family vpn-instance vpn2
[UPE1-bgp-vpn1] peer 10.4.1.1 as-number 65420
[UPE1-bgp] quit
2.      Configure CE 1
<CE1> system-view
[CE1-GigabitEthernet4/1/1] ip address 10.2.1.1 255.255.255.0
[CE1] bgp 65410
[CE1-bgp] peer 10.2.1.2 as-number 100
[CE1] quit
3.      Configure CE 2
<CE2> system-view
[CE2-GigabitEthernet4/1/1] ip address 10.4.1.1 255.255.255.0
[CE2] bgp 65420
[CE2-bgp] peer 10.4.1.2 as-number 100
[CE2] quit
4.      Configure UPE 2
<UPE2> system-view
[UPE2] interface loopback 0
[UPE2-LoopBack0] ip address 4.4.4.9 32
[UPE2-LoopBack0] quit
[UPE2] mpls lsr-id 4.4.4.9
[UPE2] mpls
[UPE2-mpls] quit
[UPE2] mpls ldp
[UPE2-mpls-ldp] quit
[UPE2] interface GigabitEthernet 4/1/1
[UPE2-GigabitEthernet4/1/1] ip address 172.2.1.1 24
[UPE2-GigabitEthernet4/1/1] mpls
[UPE2-GigabitEthernet4/1/1] mpls ldp
[UPE2-GigabitEthernet4/1/1] quit
[UPE2] ospf
[UPE2-ospf-1] area 0
[UPE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[UPE2-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[UPE2-ospf-1-area-0.0.0.0] quit
[UPE2-ospf-1] quit
# Configure VPN instances vpn1 and vpn2, allowing CE 3 and CE 4 to access UPE 2.
[UPE2] ip vpn-instance vpn1
[UPE2-vpn-instance-vpn1] route-distinguisher 300:1
[UPE2-vpn-instance-vpn1] vpn-target 100:1 both
[UPE2-vpn-instance-vpn1] quit
[UPE2] ip vpn-instance vpn2
[UPE2-vpn-instance-vpn2] route-distinguisher 400:2
[UPE2-vpn-instance-vpn2] vpn-target 100:2 both
[UPE2-vpn-instance-vpn2] quit
[UPE2] interface GigabitEthernet 4/1/2
[UPE2-GigabitEthernet4/1/2] ip binding vpn-instance vpn1
[UPE2-GigabitEthernet4/1/2] ip address 10.1.1.2 24
[UPE2-GigabitEthernet4/1/2] quit
[UPE2] interface GigabitEthernet 4/1/3
[UPE2-GigabitEthernet4/1/3] ip binding vpn-instance vpn2
[UPE2-GigabitEthernet4/1/3] ip address 10.3.1.2 24
[UPE2-GigabitEthernet4/1/3] quit
# Configure UPE 2 to establish MP-IBGP peer relationship with SPE 2 and to inject VPN routes.
[UPE2] bgp 100
[UPE2-bgp] peer 3.3.3.9 as-number 100
[UPE2-bgp] peer 3.3.3.9 connect-interface loopback 0
[UPE2-bgp] ipv4-family vpnv4
[UPE2-bgp-af-vpnv4] peer 3.3.3.9 enable
[UPE2-bgp-af-vpnv4] quit
[UPE2-bgp] ipv4-family vpn-instance vpn1
[UPE2-bgp-vpn1] peer 10.1.1.1 as-number 65430
[UPE2-bgp-vpn1] import-route direct
[UPE2-bgp-vpn1] quit
[UPE2-bgp] ipv4-family vpn-instance vpn2
[UPE2-bgp-vpn1] peer 10.3.1.1 as-number 65440
[UPE2-bgp] quit
5.      Configure CE 3
<CE3> system-view
[CE3-GigabitEthernet4/1/1] ip address 10.1.1.1 255.255.255.0
[CE3] bgp 65430
[CE3-bgp] peer 10.1.1.2 as-number 100
[CE3] quit
6.      Configure CE 4
<CE4> system-view
[CE4] interface GigabitEthernet 4/1/1
[CE4-GigabitEthernet4/1/1] ip address 10.3.1.1 255.255.255.0
[CE4-GigabitEthernet4/1/1] quit
[CE4] bgp 65440
[CE4-bgp] peer 10.3.1.2 as-number 100
[CE4-bgp] import-route direct
[CE4] quit
7.      Configure SPE 1
<SPE1> system-view
[SPE1] interface loopback 0
[SPE1-LoopBack0] ip address 2.2.2.9 32
[SPE1-LoopBack0] quit
[SPE1] mpls lsr-id 2.2.2.9
[SPE1] mpls
[SPE1-mpls] quit
[SPE1] mpls ldp
[SPE1-mpls-ldp] quit
[SPE1] interface GigabitEthernet 4/1/1
[SPE1-GigabitEthernet4/1/1] ip address 172.1.1.2 24
[SPE1-GigabitEthernet4/1/1] mpls
[SPE1-GigabitEthernet4/1/1] mpls ldp
[SPE1-GigabitEthernet4/1/1] quit
[SPE1] interface GigabitEthernet 4/1/2
[SPE1-GigabitEthernet4/1/2] ip address 180.1.1.1 24
[SPE1-GigabitEthernet4/1/2] mpls
[SPE1-GigabitEthernet4/1/2] mpls ldp
[SPE1-GigabitEthernet4/1/2] quit
[SPE1] ospf
[SPE1-ospf-1] area 0
[SPE1-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[SPE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] quit
[SPE1-ospf-1] quit
# Configure VPN instances vpn1 and vpn2.
[SPE1] ip vpn-instance vpn1
[SPE1-vpn-instance-vpn1] route-distinguisher 500:1
[SPE1-vpn-instance-vpn1 ] vpn-target 100:1 both
[SPE1-vpn-instance-vpn1] quit
[SPE1] ip vpn-instance vpn2
[SPE1-vpn-instance-vpn2] route-distinguisher 700:1
[SPE1-vpn-instance-vpn2] vpn-target 100:2 both
[SPE1-vpn-instance-vpn2] quit
# Configure SPE 1 to establish MP-IBGP peer relationship with UPE 1 and to inject VPN routes, and specify UPE 1.
[SPE1] bgp 100
[SPE1-bgp] peer 1.1.1.9 as-number 100
[SPE1-bgp] peer 1.1.1.9 connect-interface loopback 0
[SPE1-bgp] peer 1.1.1.9 next-hop-local
[SPE1-bgp] peer 3.3.3.9 as-number 100
[SPE1-bgp] peer 3.3.3.9 connect-interface loopback 0
[SPE1-bgp] ipv4-family vpnv4
[SPE1-bgp-af-vpnv4] peer 3.3.3.9 enable
[SPE1-bgp-af-vpnv4] peer 1.1.1.9 enable
[SPE1-bgp-af-vpnv4] peer 1.1.1.9 upe
[SPE1-bgp-af-vpnv4] quit
[SPE1-bgp]ipv4-family vpn-instance vpn1
[SPE1-bgp-vpn1] quit
[SPE1-bgp]ipv4-family vpn-instance vpn2
[SPE1-bgp-vpn2] quit
[SPE1-bgp] quit
# Configure SPE 1 to advertise to UPE 1 the routes permitted by a routing policy, that is, the routes of CE 3.
[SPE1] ip ip-prefix hope index 10 permit 10.1.1.1 24
[SPE1] route-policy hope permit node 0
[SPE1-route-policy] if-match ip-prefix hope
[SPE1-route-policy] quit
[SPE1] bgp 100
[SPE1-bgp-af-vpnv4] peer 1.1.1.9 upe route-policy hope export
8.      Configure SPE 2
<SPE2> system-view
[SPE2] interface loopback 0
[SPE2-LoopBack0] ip address 3.3.3.9 32
[SPE2-LoopBack0] quit
[SPE2] mpls lsr-id 3.3.3.9
[SPE2] mpls
[SPE2-mpls] quit
[SPE2] mpls ldp
[SPE2-mpls-ldp] quit
[SPE2] interface GigabitEthernet 4/1/1
[SPE2-GigabitEthernet4/1/1] ip address 180.1.1.2 24
[SPE2-GigabitEthernet4/1/1] mpls
[SPE2-GigabitEthernet4/1/1] mpls ldp
[SPE2-GigabitEthernet4/1/1] quit
[SPE2] interface GigabitEthernet 4/1/2
[SPE2-GigabitEthernet4/1/2] ip address 172.2.1.2 24
[SPE2-GigabitEthernet4/1/2] mpls
[SPE2-GigabitEthernet4/1/2] mpls ldp
[SPE2-GigabitEthernet4/1/2] quit
[SPE2] ospf
[SPE2-ospf-1] area 0
[SPE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[SPE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] quit
[SPE2-ospf-1] quit
[SPE2] ip vpn-instance vpn1
[SPE2-vpn-instance-vpn1] route-distinguisher 600:1
[SPE2-vpn-instance-vpn1 ] vpn-target 100:1 both
[SPE2-vpn-instance-vpn1] quit
[SPE2] ip vpn-instance vpn2
[SPE2-vpn-instance-vpn2] route-distinguisher 800:1
[SPE2-vpn-instance-vpn2] vpn-target 100:2 both
[SPE2-vpn-instance-vpn2] quit
# Configure SPE 2 to establish MP-IBGP peer relationship with UPE 2 and to inject VPN routes, and specify UPE 2.
[SPE2] bgp 100
[SPE2-bgp] peer 4.4.4.9 as-number 100
[SPE2-bgp] peer 4.4.4.9 connect-interface loopback 0
[SPE2-bgp] peer 4.4.4.9 next-hop-local
[SPE2-bgp] peer 2.2.2.9 as-number 100
[SPE2-bgp] peer 2.2.2.9 connect-interface loopback 0
[SPE2-bgp] ipv4-family vpnv4
[SPE2-bgp-af-vpnv4] peer 2.2.2.9 enable
[SPE2-bgp-af-vpnv4] peer 4.4.4.9 enable
[SPE2-bgp-af-vpnv4] peer 4.4.4.9 upe
[SPE2-bgp-af-vpnv4] quit
[SPE2-bgp]ipv4-family vpn-instance vpn1
[SPE2-bgp-vpn1] quit
[SPE2-bgp]ipv4-family vpn-instance vpn2
[SPE2-bgp-vpn2] quit
[SPE2-bgp] quit
# Configure SPE 2 to advertise to UPE 2 the routes permitted by a routing policy, that is, the routes of CE 1.
[SPE2] ip ip-prefix hope index 10 permit 10.2.1.1 24
[SPE2] route-policy hope permit node 0
[SPE2-route-policy] if-match ip-prefix hope
[SPE2-route-policy] quit
[SPE2] bgp 100
[SPE2-bgp-af-vpnv4] peer 4.4.4.9 upe route-policy hope export
Configuring OSPF sham links
·           CE 1 and CE 2 belong to VPN 1 and are respectively connected to PE 1 and PE 2.
·           CE 1 and CE 2 are in the same OSPF area.
·           VPN traffic between CE 1 and CE 2 is required to be forwarded through the MPLS backbone, instead of any route in the OSPF area.
Figure 29 Network diagram
Device
IP address
Device
IP address
CE 1
GE4/1/1
100.1.1.1/24
CE 2
GE4/1/1
120.1.1.1/24
POS2/1/2
20.1.1.1/24
POS2/1/2
30.1.1.2/24
PE 1
Loop0
1.1.1.9/32
PE 2
Loop0
2.2.2.9/32
Loop1
3.3.3.3/32
Loop1
5.5.5.5/32
GE4/1/1
100.1.1.2/24
GE4/1/1
120.1.1.2/24
POS2/1/2
10.1.1.1/24
POS2/1/1
10.1.1.2/24
Router A
POS2/1/1
30.1.1.1/24
POS2/1/2
20.1.1.2/24
1.      Configure OSPF on the customer networks
Configure conventional OSPF on CE 1, Router A, and CE 2 to advertise segment addresses of the interfaces as shown in Figure 29. (Details not shown)
After completing the configurations, CE 1 and CE 2 can learn the OSPF route to the GigabitEthernet interface of each other. The following takes CE 1 as an example:
<CE1> display ip routing-table
Destination/Mask  Proto  Pre  Cost     NextHop         Interface
20.1.1.0/24       Direct 0    0        20.1.1.1        POS2/1/2
20.1.1.2/32       Direct 0    0        20.1.1.2        POS2/1/2
30.1.1.0/24       OSPF   10   3124     20.1.1.2        POS2/1/2
100.1.1.0/24      Direct 0    0        100.1.1.1       GE4/1/1
120.1.1.0/24      OSPF   10   3125     20.1.1.2        POS2/1/2
2.      Configure MPLS L3VPN on the backbone
# Configure basic MPLS and MPLS LDP on PE 1 to establish LDP LSPs.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1-POS2/1/2] ip address 10.1.1.1 24
[PE1-POS2/1/2] mpls
[PE1-POS2/1/2] quit
# Configure PE 1 to take PE 2 as the MP-IBGP peer.
[PE1] bgp 100
[PE1-bgp] ipv4-family vpnv4
[PE1-bgp-af-vpnv4] quit
[PE1-bgp] quit
# Configure OSPF on PE 1.
[PE1]ospf 1
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure basic MPLS and MPLS LDP on PE 2 to establish LDP LSPs.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2-LoopBack0] quit
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2] interface POS 2/1/2
[PE2-POS2/1/2] ip address 10.1.1.2 24
[PE2-POS2/1/2] mpls
[PE2-POS2/1/2] mpls ldp
[PE2-POS2/1/2] quit
# Configure PE 2 to take PE 1 as the MP-IBGP peer.
[PE2] bgp 100
[PE2-bgp] peer 1.1.1.9 as-number 100
[PE2-bgp] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp] ipv4-family vpnv4
[PE2-bgp-af-vpnv4] peer 1.1.1.9 enable
[PE2-bgp-af-vpnv4] quit
[PE2-bgp] quit
# Configure OSPF on PE 2.
[PE2] ospf 1
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE2-ospf-1] quit
3.      Configure PEs to allow CEs to access the network
# Configure PE 1 to allow CE 1 to access the network.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] quit
[PE1] interface GigabitEthernet 4/1/1
[PE1-GigabitEthernet4/1/1] ip binding vpn-instance vpn1
[PE1-GigabitEthernet4/1/1] ip address 100.1.1.2 24
[PE1-GigabitEthernet4/1/1] quit
[PE1] ospf 100 vpn-instance vpn1
[PE1-ospf-100] domain-id 10
[PE1-ospf-100] area 1
[PE1-ospf-100-area-0.0.0.1] network 100.1.1.0 0.0.0.255
[PE1-ospf-100-area-0.0.0.1] quit
[PE1-ospf-100] quit
[PE1] bgp 100
[PE1-bgp] ipv4-family vpn-instance vpn1
[PE1-bgp-vpn1] import-route ospf 100
[PE1-bgp-vpn1] import-route direct
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
# Configure PE 2 to allow CE 2 to access the network.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] quit
[PE2] interface GigabitEthernet 4/1/1
[PE2-GigabitEthernet4/1/1] ip binding vpn-instance vpn1
[PE2-GigabitEthernet4/1/1] ip address 120.1.1.2 24
[PE2-GigabitEthernet4/1/1] quit
[PE2] ospf 100 vpn-instance vpn1
[PE2-ospf-100] domain-id 10
[PE2-ospf-100] area 1
[PE2-ospf-100-area-0.0.0.1] network 120.1.1.0 0.0.0.255
[PE2-ospf-100-area-0.0.0.1] quit
[PE2-ospf-100] quit
[PE2] bgp 100
[PE2-bgp-vpn1] import-route ospf 100
[PE2-bgp-vpn1] quit
[PE2-bgp] quit
After completing the configurations, issue the display ip routing-table vpn-instance command on the PEs. You can see that the path to the peer CE is along the OSPF route across the customer networks, instead of the BGP route across the backbone. Take PE 1 as an example:
[PE1] display ip routing-table vpn-instance vpn1
Routing Tables: vpn1
         Destinations : 5        Routes : 5
20.1.1.0/24       OSPF   10   1563     100.1.1.1     GE4/1/1
30.1.1.0/24       OSPF   10   3125     100.1.1.1     GE4/1/1
120.1.1.0/24      OSPF   10   3126     100.1.1.1     GE4/1/1
4.      Configure a sham link
# Configure PE 1.
[PE1-LoopBack1] ip address 3.3.3.3 32
[PE1] ospf 100
[PE1-ospf-100-area-0.0.0.1] sham-link 3.3.3.3 5.5.5.5 cost 10
[PE1-ospf-100] quit
# Configure PE 2.
[PE2-LoopBack1] ip address 5.5.5.5 32
[PE2] ospf 100
[PE2-ospf-100-area-0.0.0.1] sham-link 5.5.5.5 3.3.3.3 cost 10
[PE2-ospf-100] quit
After completing the configurations, issue the display ip routing-table vpn-instance command again on the PEs. You can see that the path to the peer CE is now along the BGP route across the backbone, and that a route to the sham link destination address is present. Take PE 1 as an example:
         Destinations : 6        Routes : 6
3.3.3.3/32        Direct 0    0        127.0.0.1      InLoop0
5.5.5.5/32        BGP    255  0        2.2.2.9        NULL0
Issue the display ip routing-table command on the CEs. You can see that the cost of the OSPF route to the peer CE is now 10 (the cost configured for the sham link), and that the next hop is now the GigabitEthernet interface connected to the PE. This means that VPN traffic to the peer will be forwarded over the backbone. Take CE 1 as an example:
20.1.1.0/24       Direct 0    0         20.1.1.1       POS2/1/1
20.1.1.2/32       Direct 0    0         20.1.1.2       POS2/1/1
30.1.1.0/24       OSPF   10   1574      100.1.1.2      GE4/1/1
120.1.1.0/24      OSPF   10   12        100.1.1.2      GE4/1/1
Issue the display ospf sham-link command on the PEs. You can see the established sham link. Take PE 1 as an example:
[PE1] display ospf sham-link
          OSPF Process 100 with Router ID 100.1.1.2
 Sham Link:
 Area            NeighborId      Source-IP       Destination-IP  State Cost
 0.0.0.1         120.1.1.2       3.3.3.3         5.5.5.5         P-2-P 10
Issue the display ospf sham-link area command. You can see that the peer state is Full:
[PE1] display ospf sham-link area 1
  Sham-Link: 3.3.3.3 --> 5.5.5.5
  Neighbor ID: 120.1.1.2     Neighbour State: Full
  Area: 0.0.0.1
  Cost: 10  State: P-2-P  Type: Sham
Configuring BGP AS number substitution
As shown in Figure 30, CE 1 and CE 2 belong to VPN 1 and are connected to PE 1 and PE 2 respectively. In addition, they use the same AS number 600.
Figure 30 Configure BGP AS number substitution
Device
IP address
Device
IP address
CE 1
GE4/1/1
10.1.1.1/24
P
Loop0
2.2.2.9/32
GE4/1/2
100.1.1.1/24
GE4/1/1
20.1.1.2/24
PE 1
Loop0
1.1.1.9/32
GE4/1/2
30.1.1.1/24
GE4/1/1
10.1.1.2/24
PE 2
Loop0
3.3.3.9/32
GE4/1/2
20.1.1.1/24
GE4/1/1
10.2.1.2/24
CE 2
GE4/1/1
10.2.1.1/24
GE4/1/2
30.1.1.2/24
GE4/1/2
200.1.1.1/24
1.      Configure basic MPLS L3VPN
·           Configure OSPF on the MPLS backbone to allow the PEs and P device to learn the routes of the loopback interfaces from each other.
·           Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs.
·           Establish MP-IBGP peer relationship between the PEs to advertise VPN IPv4 routes.
·           Configure the VPN instance of VPN 1 on PE 2 to allow CE 2 to access the network.
·           Configure the VPN instance of VPN 1 on PE 1 to allow CE 1 to access the network.
·           Configure BGP between PE 1 and CE 1, and between PE 2 and CE 2 to inject routes of CEs into PEs.
After completing the configurations, issue the display ip routing-table command on CE 2. You can see that CE 2 has learned the route to network segment 10.1.1.0/24, where the interface used by CE 1 to access PE 1 resides; but has not learned the route to the VPN (100.1.1.0/24) behind CE 1. The situation on CE 1 is similar.
<CE2> display ip routing-table
         Destinations : 8        Routes : 8
10.1.1.0/24         BGP    255  0          10.2.1.2        GE4/1/1
10.1.1.1/32         BGP    255  0          10.2.1.2        GE4/1/1
10.2.1.0/24         Direct 0    0          10.2.1.1        GE4/1/1
10.2.1.1/32         Direct 0    0          127.0.0.1       InLoop0
10.2.1.2/32         Direct 0    0          10.2.1.2        GE4/1/1
200.1.1.0/24        Direct 0    0          200.1.1.1       InLoop0
200.1.1.1/32        Direct 0    0          127.0.0.1       InLoop0
Issue the display ip routing-table vpn-instance command on the PEs. You can see the route to the VPN behind the peer CE. Take PE 2 as an example:
<PE2> display ip routing-table vpn-instance vpn1
         Destinations : 7        Routes : 7
10.1.1.0/24         BGP    255  0          1.1.1.9         NULL0
10.1.1.1/32         BGP    255  0          1.1.1.9         NULL0
10.2.1.0/24         Direct 0    0          10.2.1.2        GE4/1/1
10.2.1.1/32         Direct 0    0          10.2.1.1        GE4/1/1
10.2.1.2/32         Direct 0    0          127.0.0.1       InLoop0
100.1.1.1/32        BGP    255  0          1.1.1.9         NULL0
200.1.1.1/32        BGP    255  0          10.2.1.1        GE4/1/1
Enable BGP update packet debugging on PE 2. You can see that PE 2 advertises the route to 100.1.1.1/32, and the AS_PATH is 100 600.
<PE2> terminal monitor
<PE2> terminal debugging
<PE2> debugging bgp update vpn-instance vpn1 verbose
<PE2> refresh bgp vpn-instance vpn1 all export
*0.4402392 PE2 RM/7/RMDEBUG:
         BGP.vpn1: Send UPDATE to 10.2.1.1 for following destinations :
         Origin    : Incomplete
         AS Path   : 100 600
         Next Hop  : 10.2.1.2
         100.1.1.1/32,
Issue the display bgp routing-table peer received-routes command on CE 2. You can see that CE 2 did not receive the route to 100.1.1.1/32.
<CE2> display bgp routing-table peer 10.2.1.2 received-routes
 Total Number of Routes: 4
 BGP Local router ID is 10.2.1.1
 Status codes: * - valid, ^ - VPNv4 best, > - best, d - damped,
      Network          NextHop        MED     LocPrf    PrefVal Path/Ogn
 *>   10.1.1.0/24      10.2.1.2                           0      100?
 *>   10.1.1.1/32      10.2.1.2                           0      100?
 *    10.2.1.0/24      10.2.1.2        0                  0      100?
 *    10.2.1.1/32      10.2.1.2        0                  0      100?
2.      Configure BGP AS number substitution
# Configure BGP AS number substitution on PE 2.
<PE2> system-view
[PE2] bgp 100
[PE2-bgp-vpn1] peer 10.2.1.1 substitute-as
[PE2-bgp-vpn1] quit
[PE2-bgp] quit
The output shows that among the routes advertised by PE 2 to CE 2, the AS_PATH of 100.1.1.1/32 has changed from 100 600 to 100 100:
*0.13498737 PE2 RM/7/RMDEBUG:
         Origin    : Incomplete
         AS Path   : 100 100
         Next Hop  : 10.2.1.2
         100.1.1.1/32
Display again the routing information that CE 2 receives and the routing table:
 Total Number of Routes: 5
 *>   100.1.1.1/32     10.2.1.2                           0      100 100?
110.1.1.0/24         BGP    255  0          10.2.1.2        GE4/1/1
100.1.1.1/32        BGP    255  0          10.2.1.2        GE4/1/1
After configuring BGP AS substitution on PE 1 too, the GigabitEthernet interfaces of CE 1 and CE 2 can ping each other:
<CE1> ping –a 100.1.1.1 200.1.1.1
  PING 200.1.1.1: 56  data bytes, press CTRL_C to break
    Reply from 200.1.1.1: bytes=56 Sequence=1 ttl=253 time=109 ms
    Reply from 200.1.1.1: bytes=56 Sequence=2 ttl=253 time=67 ms
    Reply from 200.1.1.1: bytes=56 Sequence=3 ttl=253 time=66 ms
    Reply from 200.1.1.1: bytes=56 Sequence=4 ttl=253 time=85 ms
    Reply from 200.1.1.1: bytes=56 Sequence=5 ttl=253 time=70 ms
  --- 200.1.1.1 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 66/79/109 ms
IPv6 MPLS L3VPN overview
MPLS L3VPN applies to the IPv4 environment. It uses BGP to advertise IPv4 VPN routes and uses MPLS to forward IPv4 VPN packets on the service provider backbone.
IPv6 MPLS L3VPN functions similarly. It uses BGP to advertise IPv6 VPN routes and uses MPLS to forward IPv6 VPN packets on the service provider backbone.
Figure 31 shows the typical IPv6 MPLS L3VPN model. At present, the service provider backbone in the IPv6 MPLS L3VPN model is an IPv4 network. IPv6 runs inside the VPNs and between CEs and PEs. Therefore, PEs must support both IPv4 and IPv6. The PE-CE interfaces of a PE run IPv6 and the PE-P interface of a PE runs IPv4.
Figure 31 Network diagram for the IPv6 MPLS L3VPN model
IPv6 MPLS L3VPN packet forwarding
Figure 32 IPv6 MPLS L3VPN packet forwarding diagram
As shown in Figure 32, the IPv6 MPLS L3VPN packet forwarding procedure is as follows:
1.      The PC at Site 1 sends an IPv6 packet destined for 2001:2::1, the PC at Site 2. CE 1 transmits the packet to PE 1.
2.      Based on the inbound interface and destination address of the packet, PE 1 searches the routing table of the VPN instance. Finding a matching entry, PE 1 labels the packet with both inner and outer labels and forwards the packet out.
3.      The MPLS backbone transmits the packet to PE 2 by outer label. The outer label is removed from the packet at the penultimate hop.
4.      According to the inner label and destination address of the packet, PE 2 searches the routing table of the VPN instance to determine the outbound interface and then forwards the packet out the interface to CE 2.
5.      CE 2 forwards the packet to the destination by IPv6 forwarding.
IPv6 MPLS L3VPN routing information advertisement
The IPv6 VPN routing information of a local CE is advertised to a remote peer PE in three steps:
1.      From the local CE to the ingress PE.
2.      From the ingress PE to the egress PE.
3.      From the egress PE to the remote peer CE.
Then, a route is available from the local CE to the remote CE.
Routing information exchange from the local CE to the ingress PE
After establishing an adjacency with the directly connected PE, a CE advertises its IPv6 VPN routes to the PE.
The routes between a CE and a PE can be static routes, RIPng routes, OSPFv3 routes, IPv6 IS-IS routes, or EBGP routes. No matter which routing protocol is used, the CE always advertises standard IPv6 routes to the PE.
Routing information exchange from the ingress PE to the egress PE
After learning the IPv6 VPN routes from the CE, the ingress PE adds RDs and VPN targets for these standard IPv6 routes to create VPN-IPv6 routes, saves them to the routing table of the VPN instance created for the CE, and then triggers MPLS to assign VPN labels for them.
Then, the ingress PE advertises the VPN-IPv6 routes to the egress PE through MP-BGP.
Finally, the egress PE compares the export target attributes of the VPN-IPv6 routes with the import target attributes that it maintains for the VPN instance and, if they are the same, adds the routes to the routing table of the VPN instance.
The PEs use an IGP to ensure the connectivity between them.
Routing information exchange from the egress PE to the remote CE
The exchange of routing information between the egress PE and the remote CE is the same as that between the local CE and the ingress PE.
IPv6 MPLS L3VPN networking schemes and functions
At present, IPv6 MPLS L3VPN supports the following networking schemes and functions:
·           Basic VPN networking
·           Inter-AS VPN option A
·           Inter-AS VPN option C
·           Carrier’s carrier
·           Multi-VPN-instance CE
IPv6 MPLS L3VPN configuration task list
Complete the following tasks to configure IPv6 MPLS L3VPN:
Remarks
Configuring basic IPv6 MPLS L3VPN
By configuring basic IPv6 MPLS L3VPN, you can construct simple IPv6 VPN networks over an MPLS backbone.
To deploy special IPv6 MPLS L3VPN networks, such as inter-AS VPN, you also need to perform some specific configurations in addition to the basic IPv6 MPLS L3VPN configuration. For more information, see the related sections.
Configuring inter-AS IPv6 VPN
Configuring routing on an MCE
Basic IPv6 MPLS L3VPN configuration task list
The key task in IPv6 MPLS L3VPN configuration is to manage the advertisement of IPv6 VPN routes on the MPLS backbone, including PE-CE route exchange and PE-PE route exchange.
Complete the following tasks to configure basic IPv6 MPLS L3VPN:
Remarks
Configuring VPN instances
Creating a VPN instance
Required
Associating a VPN instance with an interface
Required
Configuring route related attributes for a VPN instance
Optional
Configuring a tunneling policy for a VPN instance
Optional
Configuring an LDP instance
Optional
Configuring routing between PE and CE
Required
Configuring routing between PEs
Required
Configuring routing features for the BGP-VPNv6 subaddress family
Optional
Configuration prerequisites
Before configuring basic IPv6 MPLS L3VPN, complete these tasks:
·           Configuring an IGP for the MPLS backbone (on the PEs and Ps) to achieve IP connectivity
·           Configuring basic MPLS for the MPLS backbone
·           Configuring MPLS LDP for the MPLS backbone so that LDP LSPs can be established
By configuring VPN instances on a PE, you isolate not only VPN routes from public network routes, but also routes of a VPN from those of another VPN. This feature allows VPN instances to be used in networking scenarios besides MPLS L3VPNs.
All VPN instance configurations are performed on PEs or MCEs.
A VPN instance is associated with a site. It is a collection of the VPN membership and routing rules of its associated site. A VPN instance does not necessarily correspond to one VPN.
A VPN instance takes effect only after you configure an RD for it.
You can configure a description for a VPN instance to record its related information, such as its relationship with a certain VPN.
To create and configure a VPN instance:
Step
Remarks
1.     Enter system view.
N/A
2.     Create a VPN instance and enter VPN instance view.
Required
3.     Configure an RD for the VPN instance.
Required
4.     Configure a description for the VPN instance.
Optional
After creating and configuring a VPN instance, you need to associate the VPN instance with the interface for connecting the CE. Any LDP-capable interface can be associated with a VPN instance. For information about LDP-capable interfaces, see the chapter “Configuring basic MPLS.”
To associate a VPN instance with an interface:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Associate a VPN instance with the interface.
No VPN instance is associated with an interface by default.
The ip binding vpn-instance command clears the IP address of the interface on which it is configured. Be sure to re-configure an IP address for the interface after configuring the command.
The control process of VPN route advertisement is as follows:
·           When a VPN route learned from a CE gets redistributed into BGP, BGP associates it with a VPN target extended community attribute list, which is usually the export target attribute of the VPN instance associated with the CE.
·           The VPN instance determines which routes it can accept and redistribute according to the import-extcommunity in the VPN target.
·           The VPN instance determines how to change the VPN targets attributes for routes to be advertised according to the export-extcommunity in the VPN target.
To configure route related attributes for a VPN instance:
Step
Remarks
N/A
2.     Enter VPN instance view.
N/A
3.     Enter IPv6 VPN view.
ipv6-family
Optional
4.     Configure VPN targets.
Required
5.     Set the maximum number of routes supported.
Optional
6.     Apply an import routing policy.
Optional
By default, all routes matching the import target attribute are accepted.
7.     Apply an export routing policy.
Optional
By default, routes to be advertised are not filtered.
·       Route related attributes configured in VPN instance view are applicable to both IPv4 VPNs and IPv6 VPNs.
·       You can configure route related attributes for IPv6 VPNs in both VPN instance view and IPv6 VPN view. Those configured in IPv6 VPN view take precedence.
·       A single vpn-target command can configure up to eight VPN targets. You can configure up to 64 VPN targets for a VPN instance.
·       You can define the maximum number of routes for a VPN instance to support, preventing too many routes from being redistributed into the PE.
·       Create a routing policy before associating it with a VPN instance. Otherwise, the device cannot filter the routes to be received and advertised.
To configure a tunneling policy for a VPN instance:
Step
Remarks
N/A
2.     Create a tunneling policy and enter tunneling policy view.
tunnel-policy tunnel-policy-name
Required
3.     Specify the tunnel selection preference order and the number of tunnels for load balancing.
tunnel select-seq { cr-lsp | lsp } * load-balance-number number
By default, only one tunnel is selected (no load balancing) in this order: LSP tunnel, CR-LSP tunnel.
4.     Return to system view.
N/A
5.     Enter VPN instance view.
Required
6.     Enter IPv6 VPN view.
ipv6-family
Optional
7.     Apply the tunneling policy to the VPN instance.
tnl-policy tunnel-policy-name
·       When you configure tunnel selection preference order by using the tunnel select-seq command, a tunnel type closer to the select-seq keyword has a higher priority. For example, with the tunnel select-seq lsp cr-lsp load-balance-number 1 command configured, VPN uses a CR-LSP tunnel when no LSP exists. After an LSP is created, the VPN uses the LSP tunnel instead.
·       If you specify more than one tunnel type and the number of tunnels of a type is less than the specified number of tunnels for load balancing, tunnels of different types may be used.
·       A tunneling policy configured in VPN instance view is applicable to both IPv4 VPNs and IPv6 VPNs.
·       You can configure a tunneling policy for IPv6 VPNs in both VPN instance view and IPv6 VPN view. A tunneling policy configured in IPv6 VPN view takes precedence.
·       Create a tunneling policy before associating it with a VPN instance. Otherwise, the default tunneling policy is used.
LDP instances are for carrier’s carrier networking applications.
This task is to enable LDP for an existing VPN instance, create an LDP instance for the VPN instance, and configure LDP parameters for the LDP instance.
For LDP instance configuration information, see the chapter “Configuring MPLS L3VPN.”
You can configure static routing, RIPng, OSPFv3, IPv6 IS-IS, or EBGP between PE and CE.
Before you configure routing between PE and CE, complete the following tasks:
·           Assign an IPv6 address to the CE-PE interface of the CE
·           Assign an IPv6 address to the PE-CE interface of the PE
Configuring static routing between PE and CE
To configure PE-CE route exchange through static routes:
Step
Remarks
N/A
2.     Configure static routes for a VPN instanceN/A.
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name nexthop-address } [ preference preference-value ]
Required
Use either command
Perform this configuration on PEs. On CEs, configure normal static routes.
ipv6 route-static vpn-instance s-vpn-instance-name&<1-6> ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | nexthop-address [ public ] | vpn-instance d-vpn-instance-name nexthop-address } [ preference preference-value ]
For information about IPv6 static routing, see Layer 3—IP Routing Configuration Guide.
Configuring RIPng between PE and CE
A RIPng process belongs to the public network or a single VPN instance. If you create a RIPng process without binding it to a VPN instance, the process belongs to the public network.
To configure RIPng between PE and CE:
Step
Remarks
N/A
2.     Create a RIPng process for a VPN instance and enter RIPng view.
ripng [ process-id ] vpn-instance vpn-instance-name
Perform this configuration on PEs. On CEs, create a normal RIPng process.
3.     Return to system view.
N/A
4.     Enter interface view.
N/A
5.     Enable RIPng on the interface.
ripng process-id enable
By default, RIPng is disabled on an interface.
For more information about RIPng, see Layer 3—IP Routing Configuration Guide.
Configuring OSPFv3 between PE and CE
An OSPFv3 process belongs to the public network or a single VPN instance. If you create an OSPF process without binding it to a VPN instance, the process belongs to the public network.
To configure OSPFv3 between PE and CE:
Step
Remarks
N/A
2.     Create an OSPFv3 process for a VPN instance and enter the OSPFv3 view.
ospfv3 [ process-id ] vpn-instance vpn-instance-name
Perform this configuration on PEs. On CEs, create a normal OSPF process.
3.     Set the router ID.
router-id router-id
Required
N/A
5.     Enter interface view.
N/A
6.     Enable OSPFv3 on the interface.
ospfv3 process-id area area-id [ instance instance-id ]
By default, OSPFv3 is disabled on an interface.
·       Deleting a VPN instance will delete all related OSPFv3 processes at the same time.
·       For more information about OSPFv3, see Layer 3—IP Routing Configuration Guide.
Configuring IPv6 IS-IS between PE and CE
An IPv6 IS-IS process belongs to the public network or a single VPN instance. If you create an IPv6 IS-IS process without binding it to a VPN instance, the process belongs to the public network.
To configure IPv6 IS-IS between PE and CE:
Step
Remarks
N/A
2.     Create an IPv6 IS-IS process for a VPN instance and enter IS-IS view.
isis [ process-id ] vpn-instance vpn-instance-name
Perform this configuration on PEs. On CEs, create a normal IPv6 IS-IS process.
3.     Configure a network entity title for the IS-IS process.
network-entity net
Not configured by default
4.     Enable the IPv6 capacity for the IS-IS process.
ipv6 enable
Disabled by default
5.     Return to system view.
N/A
6.     Enter interface view.
N/A
7.     Enable the IPv6 capacity for the IS-IS process on the interface.
isis ipv6 enable [ process-id ]
Disabled by default
For more information about IPv6 IS-IS, see Layer 3—IP Routing Configuration Guide.
Configuring EBGP between PE and CE
1.      Configurations on a PE
To configure EBGP between PE and CE:
Step
Remarks
N/A
2.     Enable BGP and enter BGP view.
bgp as-number
N/A
3.     Enter IPv6 BGP-VPN instance view.
ipv6-family vpn-instance vpn-instance-name
Required
4.     Configure the CE as the VPN EBGP peer.
Required
5.     Redistribute the routes of the local CEs.
import-route protocol [ process-id ] [ med med-value | route-policy route-policy-name ] *
A PE needs to redistribute the routes of the local CEs into its VPN routing table so that it can advertise them to the peer PE.
6.     Configure a filtering policy to filter the routes to be advertised.
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ direct | isisv6 process-id | ripng process-id | static ]
Optional
By default, BGP does not filter routes to be advertised.
7.     Configure a filtering policy to filter received routes.
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import
Optional
By default, the PE does not filter received routes.
2.      Configurations on a CE
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enter IPv6 BGP subaddress family view.
ipv6-family
Required
4.     Configure the PE as the EBGP peer.
Required
5.     Configure route redistribution and advertisement.
Optional
A CE needs to advertise its VPN routes to the connected PE so that the PE can advertise them to the peer CE.
·       After an IPv6 BGP-VPN instance is configured, exchange of BGP routes for the VPN instance is the same as exchange of ordinary BGP routes.
·       The configuration commands available in IPv6 BGP-VPN instance view are the same as those in IPv6 BGP subaddress family view. For more configuration commands in the two views, see Layer 3—IP Routing Configuration Guide.
To configure routing between PEs:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
Required
3.     Configure the remote PE as the peer.
peer ip-address as-number as-number
Required
4.     Specify the source interface for route update packets.
peer { group-name | ip-address } connect-interface interface-type interface-number
By default, BGP uses the outbound interface of the best route to the BGP peer.
5.     Enter BGP-VPNv6 subaddress family view.
ipv6-family vpnv6
Required
6.     Enable the exchange of BGP-VPNv6 routing information with the specified peer.
peer ip-address enable
By default, BGP peers exchange only IPv4 routing information.
A variety of routing features for the BGP-VPNv6 subaddress family are the same as those for BGP IPv6 unicast routing. You can select any of the features as required.
To configure routing features for the BGP-VPNv6 subaddress family:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
Required
4.     Specify the interface for TCP connections.
peer ip-address connect-interface interface-type interface-number
Required
ipv6-family vpnv6
N/A
6.     Set the default value of the local preference.
Optional
100 by default
7.     Set the default value for the system MED.
default med med-value
Optional
By default, the default value of the system MED is 0.
8.     Configure a filtering policy to filter routes to be advertised.
Optional
By default, the PE does not filter routes to be advertised.
9.     Configure a filtering policy to filter received routes.
Optional
10.   Apply a filtering policy for the peer.
peer ip-address filter-policy acl6-number { export | import }
Optional
By default, no filtering policy is applied for a peer.
11.   Apply an IPv6-prefix list for the peer to filter received/advertised routes.
peer ip-address ipv6-prefix prefix-name { export | import }
Optional
By default, no IPv6 prefix list is applied for a peer.
12.   Specify the preference value for the routes received from the peer.
peer ip-address preferred-value value
Optional
0 by default
13.   Configure BGP updates to the peer to not carry private AS numbers.
peer ip-address public-as-only
Optional
By default, a BGP update carries private AS numbers.
14.   Apply a routing policy for the peer.
peer ip-address route-policy route-policy-name { export | import }
Optional
By default, no routing policy is applied for a peer.
15.   Enable VPN target filtering for received BGP-VPNv6 subaddress family routes.
policy vpn-target
Optional
Enabled by default
16.   Configure the local PE as the route reflector and specify the peer as the client.
peer ip-address reflect-client
Optional
No route reflector or client is configured by default.
17.   Enable route reflection between clients.
reflect between-clients
Optional
Enabled by default
18.   Configure a cluster ID for the route reflector.
Optional
By default, a route reflector uses its router ID as the cluster ID.
19.   Create an RR reflection policy.
rr-filter extended-community-list-number
Optional
For information about IPv6 BGP routing features, see Layer 3—IP Routing Configuration Guide.
If the MPLS backbone that carries the IPv6 VPN routes spans multiple ASs, you need to configure inter-AS IPv6 VPN.
There are three inter-AS VPN solutions (for more information, see the chapter “Configuring MPLS L3VPN”). IPv6 MPLS L3VPN supports only inter-AS VPN option A and option C.
Before configuring inter-AS IPv6 VPN, complete these tasks:
·           Configuring an IGP for the MPLS backbone in each AS to implement IP connectivity
·           Configuring basic MPLS capabilities for the MPLS backbone of each AS
·           Configuring MPLS LDP for the MPLS backbones so that LDP LSPs can be established
The following sections describe inter-AS IPv6 VPN option A and option C. Select one according to your networking scenario.
Configuring inter-AS IPv6 VPN option A
Inter-AS IPv6 VPN option A applies to scenarios where the number of VPNs and that of VPN routes on the PEs are relatively small. It is easy to implement.
To configure inter-AS IPv6 option A, you need to:
·           Perform basic IPv6 MPLS L3VPN configuration on each AS.
·           Configure each ASBR, taking the peer ASBR PE as its CE. In other words, configure VPN instances on both PEs and ASBR PEs. The VPN instances on PEs allow CEs to access the network, while those on ASBR PEs are for access of the peer ASBR PEs.
For configuration information, see the chapter “Configuring basic IPv6 MPLS L3VPN.”
In the inter-AS IPv6 VPN option A solution, for the same IPv6 VPN, the VPN targets configured on the PEs must match those configured on the ASBR-PEs in the same AS to make sure that VPN routes sent by the PEs (or ASBR-PEs) can be received by the ASBR-PEs (or PEs). VPN targets configured on the PEs in different ASs do not have such requirements.
Configuring inter-AS IPv6 VPN option C
Configuring the PEs
You need to establish ordinary IBGP peer relationships between PEs and ASBR PEs in an AS and MP-EBGP peer relationships between PEs in different ASs.
The PEs and ASBR PEs in an AS must be able to exchange labeled routes.
To configure a PE for inter-AS IPv6 VPN option C:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure the ASBR PE in the same AS as the IBGP peer.
peer { group-name | ip-address } as-number as-number
Required
4.     Enable the PE to exchange labeled routes with the ASBR PE in the same AS.
peer { group-name | ip-address } label-route-capability
By default, the PE does not advertise labeled routes to the IPv4 peer/peer group.
5.     Configure the PE of another AS as the EBGP peer.
Required
6.     Enter BGP-VPNv6 subaddress family view.
ipv6-family vpnv6
N/A
7.     Enable the PE to exchange BGP VPNv6 routing information with the EBGP peer.
Required
Configuring the ASBR PEs
In the inter-AS IPv6 VPN option C solution, an inter-AS LSP is required, and the routes advertised between the relevant PEs and ASBRs must carry MPLS label information. The configuration is the same as that in the Inter-AS IPv4 VPN option C solution (see the chapter “Configuring MPLS L3VPN”).
Configuring the routing policy
After you configure and apply a routing policy on an ASBR PE, it:
·           Assigns MPLS labels to routes received from the PEs in the same AS before advertising them to the peer ASBR PE.
·           Assigns new MPLS labels to the labeled routes to be advertised to the PEs in the same AS.
An MCE implements service isolation through route isolation. MCE routing configuration includes:
·           MCE-VPN site routing configuration
·           MCE-PE routing configuration
On the PE in an MCE network environment, disable routing loop detection to avoid route loss during route calculation and disable route redistribution between routing protocols to save system resources.
Before you configure routing on an MCE, complete the following tasks:
·           On the MCE, configure VPN instances, and bind the VPN instances with the interfaces connected to the VPN sites and those connected to the PE.
·           Configure the link layer and network layer protocols on related interfaces to ensure IP connectivity.
Configuring routing between MCE and VPN site
Configuring static routing between MCE and VPN site
An MCE can reach a VPN site through a static route. Static routing on a traditional CE is globally effective and thus does not support address overlapping among VPNs. An MCE supports binding a static route with an IPv6 VPN instance, so that the static routes of different IPv6 VPN instances can be isolated from each other.
To configure static routing between MCE and VPN site:
Step
Remarks
N/A
2.     Configure IPv6 static routes for an IPv6 VPN instanceN/A.
Required
Use either command.
Perform this configuration on the MCE. On a VPN site, configure normal static routes.
3.     Configure the default precedence for IPv6 static routes.
ipv6 route-static default-preference default-preference-value
Optional
60 by default
Configuring RIPng between MCE and VPN site
A RIPng process belongs to the public network or a single IPv6 VPN instance. If you create a RIPng process without binding it to an IPv6 VPN instance, the process belongs to the public network. By configuring RIPng process-to-IPv6 VPN instance bindings on a MCE, you allow routes of different VPNs to be exchanged between the MCE and the sites through different RIPng processes, ensuring the separation and security of IPv6 VPN routes.
To configure RIPng between MCE and VPN site:
Step
Remarks
N/A
Perform this configuration on the MCE. On a VPN site, configure normal RIPng.
3.     Redistribute remote site routes advertised by the PE.
import-route protocol [ process-id ] [ allow-ibgp ] [ cost cost | route-policy route-policy-name ] *
By default, no route of any other routing protocol is redistributed into RIPng.
4.     Configure the default cost value for the redistributed routes.
default cost value
Optional
0 by default
N/A
N/A
7.     Enable RIPng on the interface.
Disabled by default
Configuring OSPFv3 between MCE and VPN site
An OSPFv3 process belongs to the public network or a single IPv6 VPN instance. If you create an OSPFv3 process without binding it to an IPv6 VPN instance, the process belongs to the public network.
By configuring OSPFv3 process-to-IPv6 VPN instance bindings on a MCE, you allow routes of different IPv6 VPNs to be exchanged between the MCE and the sites through different OSPFv3 processes, ensuring the separation and security of IPv6 VPN routes.
To configure OSPFv3 between MCE and VPN site:
Step
Remarks
N/A
2.     Create an OSPFv3 process for a VPN instance and enter OSPFv3 view.
Perform this configuration on the MCE. On a VPN site, configure normal OSPFv3.
router-id router-id
Required
4.     Redistribute remote site routes advertised by the PE..
import-route protocol [ process-id | allow-ibgp ] [ cost value | route-policy route-policy-name | type type ] *
By default, no route of any other routing protocol is redistributed into OSPFv3.
N/A
N/A
7.     Enable OSPFv3 on the interface.
Configuring IPv6 IS-IS between MCE and VPN site
An IPv6 IS-IS process belongs to the public network or a single IPv6 VPN instance. If you create an IPv6 IS-IS process without binding it to an IPv6 VPN instance, the process belongs to the public network.
By configuring IPv6 IS-IS process-to-IPv6 VPN instance bindings on a MCE, you allow routes of different IPv6 VPNs to be exchanged between the MCE and the sites through different IPv6 IS-IS processes, ensuring the separation and security of IPv6 VPN routes.
To configure IPv6 IS-IS between MCE and VPN site:
Step
Remarks
N/A
Perform this configuration on the MCE. On a VPN site, configure normal IPv6 IS-IS.
network-entity net
4.     Enable the IPv6 capacity for the IPv6 IS-IS process.
ipv6 enable
Disabled by default
5.     Redistribute remote site routes advertised by the PE.
ipv6 import-route protocol [ process-id ] [ allow-ibgp ] [ cost cost | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
Optional
By default, no routes from any other routing protocol are redistributed to IPv6 IS-IS.
If you do not specify the route level in the command, redistributed routes are added to the level-2 routing table by default.
6.     Return to system view.
N/A
7.     Enter interface view.
N/A
8.     Enable the IPv6 IS-IS process on the interface.
Disabled by default
Configuring EBGP between MCE and VPN site
To use EBGP for exchanging routing information between an MCE and IPv6 VPN sites, you must configure a BGP peer for each IPv6 VPN instance on the MCE, and redistribute the IGP routes of each VPN instance on the IPv6 VPN sites.
If EBGP is used for route exchange, you also can configure filtering policies to filter the received routes and the routes to be advertised.
1.     Configurations on the MCE
To configure EBGP between MCE and VPN site:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
Required
4.     Specify an IPv6 BGP peer in an AS.
Required
import-route protocol [ process-id [ med med-value | route-policy route-policy-name ] * ]
By default, No route redistribution is configured.
filter-policy { acl6-number | ipv6-prefix ip-prefix-name } export [ direct | isisv6 process-id | ripng process-id | static ]
Optional
By default, the MCE does not filter the routes to be advertised.
7.     Configure a filtering policy to filter the received routes.
filter-policy { acl6-number | ipv6-prefix ip-prefix-name } import
Optional
By default, the MCE does not filter the received routes.
After you configure an IPv6 BGP VPN instance, the IPv6 BGP route exchange for the IPv6 VPN instance is the same with the normal IPv6 BGP VPN route exchange. For more information about IPv6 BGP, see Layer 3—IP Routing Configuration Guide.
2.     Configurations on a VPN site
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enter IPv6 address family view.
ipv6-family
N/A
4.     Configure the MCE as the EBGP peer.
Required
5.     Redistribute the IGP routes of the VPN.
Optional
By default, no route redistribution is configured.
A VPN site must advertise the IPv6 VPN network addresses it can reach to the connected MCE.
Configuring routing between MCE and PE
MCE-PE routing configuration includes these tasks:
·           Bind the MCE-PE interfaces to IPv6 VPN instances
·           Perform routing configurations
·           Redistribute IPv6 VPN routes into the routing protocol running between the MCE and the PE.
Configurations in this section are configured on the MCE. Configurations on the PE are similar to those on the PE in common IPv6 MPLS L3VPN network solutions (see “Configuring routing between PE and CE”).
Configuring IPv6 static routing between MCE and PE
To configure static routing between MCE and PE:
Step
Remarks
N/A
2.     Configure static routes for an IPv6 VPN instanceN/A.
Required
User either command.
3.     Configure the default precedence for static routes.
Optional
60 by default
Configuring RIPng between MCE and PE
To configure RIPng between MCE and PE:
Step
Remarks
N/A
2.     Create a RIPng process for an IPv6 VPN instance and enter RIPng view.
Required
3.     Redistribute the VPN routes.
default cost value
Optional
0 by default
N/A
N/A
7.     Enable the RIPng process on the interface.
Disabled by default.
Configuring OSPFv3 between MCE and PE
To configure OSPFv3 between MCE and PE:
Step
Remarks
N/A
2.     Create an OSPFv3 process for an IPv6 VPN instance and enter OSPFv3 view.
Required
router-id router-id
Required
4.     Redistribute the VPN routes.
5.     Configure a filtering policy to filter the redistributed routes.
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ bgp4+ | direct | isisv6 process-id | ospfv3 process-id | ripng process-id | static ]
Optional
By default, redistributed routes are not filtered.
N/A
N/A
8.     Enable the OSPFv3 process on the interface.
Configuring IPv6 IS-IS between MCE and PE
To configure IPv6 IS-IS between MCE and PE:
Step
Remarks
N/A
2.     Create an IS-IS process for an IPv6 VPN instance and enter IS-IS view.
Required
3.     Configure a network entity title.
network-entity net
Not configured by default.
ipv6 enable
5.     Redistribute the VPN routes.
Optional
By default, IS-IS does not redistribute routes of any other routing protocol.
If you do not specify the route level in the command, the command will redistribute routes to the level-2 routing table by default.
6.     Configure a filtering policy to filter the redistributed routes.
ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
Optional
By default, IPv6 IS-IS does not filter redistributed routes.
7.     Return to system view.
N/A
8.     Enter interface view.
N/A
9.     Enable IPv6 for the IS-IS process on the interface.
Configuring EBGP between MCE and PE
To configure EBGP between MCE and PE:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
Required
Required
Optional
By default, BGP does not filter the routes to be advertised.
Optional
By default, BGP does not filter the received routes.
IPv6 BGP runs within a VPN in the same way as it runs within a public network. For more information about IPv6 BGP, see Layer 3—IP Routing Configuration Guide.
Displaying and maintaining IPv6 MPLS L3VPN
Resetting BGP connections
When BGP configuration changes, use the soft reset function or reset BGP connections to make the changes take effect. Soft reset requires that BGP peers have the route refreshment capability, which means supporting Route-Refresh messages.
Step
Remarks
1.     Soft reset the IPv6 BGP connections of a VPN instance.
refresh bgp ipv6 vpn-instance vpn-instance-name { ipv6-address | all | external } { export | import }
Available in user view
2.     Soft reset the BGP VPNv6 connections.
refresh bgp vpnv6 { ip-address | all | external | internal } { export | import }
3.     Reset the IPv6 BGP connections of a VPN instance.
reset bgp ipv6 vpn-instance vpn-instance-name { as-number | ipv6-address | all | external }
4.     Reset BGP VPNv6 connections.
reset bgp vpnv6 { as-number | ip-address | all | external | internal }
Displaying information about IPv6 MPLS L3VPN
Remarks
Display information about the IPv6 routing table associated with a VPN instance.
display ipv6 routing-table vpn-instance vpn-instance-name [ verbose ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Display information about a specific VPN instance or all VPN instances.
display ip vpn-instance [ instance-name vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display information about the IPv6 FIB of a VPN instance.
display ipv6 fib vpn-instance vpn-instance-name [ acl6 acl6-number | ipv6-prefix ipv6-prefix-name ] [ | { begin | exclude | include } regular-expression ]
Display a VPN instance’s FIB entries that match the specified destination IPv6 address.
display ipv6 fib vpn-instance vpn-instance-name ipv6-address [ prefix-length ] [ | { begin | exclude | include } regular-expression ]
Display information about BGP VPNv6 peers established between PEs.
display bgp vpnv6 all peer [ ipv4-address verbose | verbose ] [ | { begin | exclude | include } regular-expression ]
Display information about IPv6 BGP peers established between the PE and CE in a VPN instance.
display bgp vpnv6 vpn-instance vpn-instance-name peer [ ipv6-address verbose | verbose ] [ | { begin | exclude | include } regular-expression ]
Display all BGP VPNv6 routing information.
display bgp vpnv6 all routing-table [ network-address prefix-length [ longer-prefixes ] | peer ip-address { advertised-routes | received-routes } [ statistic ] | statistic ] [ | { begin | exclude | include } regular-expression ]
Display the BGP VPNv6 routing information of an RD.
display bgp vpnv6 route-distinguisher route-distinguisher routing-table [ network-address prefix-length ] [ | { begin | exclude | include } regular-expression ]
Display the BGP VPNv6 routing information of a VPN instance.
display bgp vpnv6 vpn-instance vpn-instance-name routing-table [ network-address prefix-length [ longer-prefixes ] | peer ipv6-address { advertised-routes | received-routes } ] [ | { begin | exclude | include } regular-expression ]
For commands that display information about a routing table, see Layer 3—IP Routing Command Reference.
IPv6 MPLS L3VPN configuration examples
Configuring IPv6 MPLS L3VPNs
·           CE 1 and CE 3 belong to VPN 1. CE 2 and CE 4 belong to VPN 2.
·           VPN 1 uses VPN target attributes 111:1. VPN 2 uses VPN target attributes 222:2. Users of different VPNs cannot access each other.
·           EBGP is used to exchange VPN routing information between CEs and PEs.
·           PEs use OSPF to communicate with each other and use MP-IBGP to exchange VPN routing information.
Figure 33 Network diagram
Device
IP address
Device
IP address
CE 1
GE4/1/1
2001:1::1/96
P
Loop0
2.2.2.9/32
PE 1
Loop0
1.1.1.9/32
POS2/1/1
172.1.1.2/24
GE4/1/1
2001:1::2/96
POS2/1/2
172.2.1.1/24
GE4/1/2
2001:2::2/96
PE 2
Loop0
3.3.3.9/32
POS2/1/1
172.1.1.1/24
GE4/1/1
2001:3::2/96
CE 2
GE4/1/1
2001:2::1/96
GE4/1/2
2001:4::2/24
CE 3
GE4/1/1
2001:3::1/96
POS2/1/1
172.2.1.2/24
CE 4
GE4/1/1
2001:4::1/96
Configuration procedure
1.      Configure OSPF on the MPLS backbone to achieve IP connectivity among the PEs and the P router.
# Configure PE 1.
<PE1> system-view
[PE1] interface pos2/1/1
[PE1-POS2/1/1] ip address 172.1.1.1 24
[PE1-POS2/1/1] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure the P router.
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface pos2/1/1
[P-POS2/1/1] ip address 172.1.1.2 24
[P-POS2/1/1] quit
[P] interface POS 2/1/2
[P-POS2/1/2] ip address 172.2.1.1 24
[P-POS2/1/2] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# Configure PE 2.
<PE2> system-view
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2] interface pos2/1/1
[PE2-POS2/1/1] ip address 172.2.1.2 24
[PE2-POS2/1/1] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
After you complete the configurations, OSPF adjacencies are established between PE 1, P, and PE 2. Issue the display ospf peer command. The output shows that the adjacency is in Full state. Issue the display ip routing-table command. The output shows that the PEs have learned the routes to the loopback interfaces of each other. The following takes PE 1 as an example:
         Destinations : 9        Routes : 9
1.1.1.9/32        Direct 0    0        127.0.0.1       InLoop0
2.2.2.9/32        OSPF   10   1        172.1.1.2       POS2/1/1
3.3.3.9/32        OSPF   10   2        172.1.1.2       POS2/1/1
172.1.1.0/24      Direct 0    0        172.1.1.1       POS2/1/1
172.1.1.1/32      Direct 0    0        127.0.0.1       InLoop0
172.1.1.2/32      Direct 0    0        172.1.1.2       POS2/1/1
172.2.1.0/24      OSPF   10   1        172.1.1.2       POS2/1/1
[PE1] display ospf peer verbose
          OSPF Process 1 with Router ID 1.1.1.9
                  Neighbors
 Area 0.0.0.0 interface 172.1.1.1(POS2/1/1)'s neighbors
 Router ID: 172.1.1.2        Address: 172.1.1.2        GR State: Normal
   State: Full  Mode:Nbr is  Master  Priority: 1
   DR: None   BDR: None   MTU: 1500
   Dead timer due in 38  sec
   Neighbor is up for 00:02:44
   Neighbor state change count: 5
2.      Configure basic MPLS and enable MPLS LDP on the MPLS backbone to establish LDP LSPs.
# Configure PE 1.
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1-POS2/1/1] mpls
[PE1-POS2/1/1] mpls ldp
[PE1-POS2/1/1] quit
[P] mpls lsr-id 2.2.2.9
[P] mpls
[P-mpls] quit
[P] mpls ldp
[P-mpls-ldp] quit
[P-POS2/1/1] mpls
[P-POS2/1/1] mpls ldp
[P-POS2/1/1] quit
[P-POS2/1/2] mpls
[P-POS2/1/2] mpls ldp
[P-POS2/1/2] quit
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2-POS2/1/1] mpls
[PE2-POS2/1/1] mpls ldp
[PE2-POS2/1/1] quit
After you complete the configurations, LDP sessions are established between PE 1, P, and PE 2. Issue the display mpls ldp session command. The output shows that the session status is Operational. Issue the display mpls ldp lsp command. The output shows the LSPs established by LDP. The following takes PE 1 as an example:
[PE1] display mpls ldp session
               LDP Session(s) in Public Network
 Peer-ID         Status        LAM  SsnRole  FT   MD5  KA-Sent/Rcv
 2.2.2.9:0       Operational   DU   Passive  Off  Off  5/5
 LAM : Label Advertisement Mode         FT  : Fault Tolerance
[PE1] display mpls ldp lsp
                              LDP LSP Information
 SN  DestAddress/Mask   In/OutLabel  Next-Hop     In/Out-Interface
 1   1.1.1.9/32         3/NULL       127.0.0.1     POS2/1/1/InLoop0
 2   2.2.2.9/32         NULL/3       172.1.1.2     -------/POS2/1/1
 3   3.3.3.9/32         NULL/1024    172.1.1.2     -------/POS2/1/1
 A '*' before an LSP means the LSP is not established
 A '*' before a Label means the USCB or DSCB is stale
3.      Configure IPv6 VPN instances on the PEs to allow the CEs to access.
# Configure PE 1.
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 100:2
[PE1-vpn-instance-vpn2] vpn-target 222:2
[PE1-vpn-instance-vpn2] quit
[PE1-GigabitEthernet4/1/1] ipv6 address 2001:1::2 96
[PE1] interface GigabitEthernet 4/1/2
[PE1-GigabitEthernet4/1/2] ip binding vpn-instance vpn2
[PE1-GigabitEthernet4/1/2] ipv6 address 2001:2::2 96
[PE1-GigabitEthernet4/1/2] quit
# Configure PE 2.
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2] ip vpn-instance vpn2
[PE2-vpn-instance-vpn2] route-distinguisher 200:2
[PE2-vpn-instance-vpn2] vpn-target 222:2
[PE2-vpn-instance-vpn2] quit
[PE2-GigabitEthernet4/1/1] ipv6 address 2001:3::2 96
[PE2] interface GigabitEthernet 4/1/2
[PE2-GigabitEthernet4/1/2] ip binding vpn-instance vpn2
[PE2-GigabitEthernet4/1/2] ipv6 address 2001:4::2 24
[PE2-GigabitEthernet4/1/2] quit
# Configure IP addresses for the CEs as required in Figure 33. (Details not shown)
After completing the configurations, issue the display ip vpn-instance command on the PEs to view information about the VPN instances. Use the ping command to test connectivity between the PEs and their attached CEs. The PEs can ping their attached CEs. The following takes PE 1 and CE 1 as an example:
[PE1] display ip vpn-instance
  Total VPN-Instances configured : 2
  VPN-Instance Name      RD          Create Time
  vpn1                  100:1        2006/08/13 09:32:45
  vpn2                  100:2        2006/08/13 09:42:59
[PE1] ping ipv6 -vpn-instance vpn1 2001:1::1
  PING 2001:1::1 : 56  data bytes, press CTRL_C to break
    Reply from 2001:1::1
    bytes=56 Sequence=1 hop limit=64  time = 1 ms
    bytes=56 Sequence=2 hop limit=64  time = 1 ms
    bytes=56 Sequence=3 hop limit=64  time = 1 ms
    bytes=56 Sequence=4 hop limit=64  time = 1 ms
    bytes=56 Sequence=5 hop limit=64  time = 1 ms
  --- 2001:1::1 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 1/1/1 ms
4.      Establish EBGP peer relationships between the PEs and CEs to allow them to exchange VPN routes.
# Configure CE 1.
<CE1> system-view
[CE1] bgp 65410
[CE1-bgp] ipv6-family
[CE1-bgp-af-ipv6] peer 2001:1::2 as-number 100
[CE1-bgp-af-ipv6] import-route direct
[CE1-bgp-af-ipv6] quit
The configurations for the CE 2 through CE 4 are similar. (Details not shown)
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp] ipv6-family vpn-instance vpn1
[PE1-bgp-ipv6-vpn1] peer 2001:1::1 as-number 65410
[PE1-bgp-ipv6-vpn1] import-route direct
[PE1-bgp-ipv6-vpn1] quit
[PE1-bgp] ipv6-family vpn-instance vpn2
[PE1-bgp-ipv6-vpn2] peer 2001:2::1 as-number 65420
[PE1-bgp-ipv6-vpn2] import-route direct
[PE1-bgp-ipv6-vpn2] quit
[PE1-bgp] quit
The configurations for PE 2 are similar to those for PE 1. (Details not shown)
After completing the configurations, issue the display bgp vpnv6 vpn-instance peer command on the PEs. BGP peer relationships have been established between the PEs and CEs, and have reached Established state. The following takes the PE 1-CE 1 BGP peer relationship as an example:
[PE1] display bgp vpnv6 vpn-instance vpn1 peer
 BGP local router ID : 1.1.1.9
 Local AS number : 100
 Total number of peers : 1            Peers in established state : 1
  Peer               AS   MsgRcvd MsgSent OutQ  PrefRcv   Up/Down    State
  2001:1::1         65410 11      9       0     1         00:06:37   Established
5.      Configure an MP-IBGP peer relationship between the PEs.
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp] peer 3.3.3.9 as-number 100
[PE1-bgp] peer 3.3.3.9 connect-interface loopback 0
[PE1-bgp] ipv6-family vpnv6
[PE1-bgp-af-vpnv6] peer 3.3.3.9 enable
[PE1-bgp-af-vpnv6] quit
[PE1-bgp] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp] ipv6-family vpnv6
[PE2-bgp-af-vpnv6] peer 1.1.1.9 enable
[PE2-bgp-af-vpnv6] quit
[PE2-bgp] quit
After completing the configurations, issue the display bgp peer command or the display bgp vpnv6 all peer command on the PEs. You can see a BGP peer relationship has been established between the PEs, and has reached Established state.
[PE1] display bgp peer
  3.3.3.9     100        2        6     0         0   00:00:12 Established
6.      Verify your configurations
# Issue the display ipv6 routing-table vpn-instance command on the PEs. The output shows the routes to the CEs. The following takes PE 1 as an example:
[PE1] display ipv6 routing-table vpn-instance vpn1
Routing Table :
         Destinations : 3        Routes : 3
Destination: 2001:1::/96                              Protocol  : Direct
NextHop    : 2001:1::2                                Preference: 0
Interface  : GE4/1/1                                  Cost      : 0
Destination: 2001:1::2/128                            Protocol  : Direct
NextHop    : ::1                                      Preference: 0
Interface  : InLoop0                                  Cost      : 0
Destination: 2001:2::/96                              Protocol  : BGP4+
NextHop    : ::FFFF:303:309                           Preference: 0
Interface  : NULL0                                    Cost      : 0
[PE1] display ipv6 routing-table vpn-instance vpn2
Routing Table :
Destination: 2001:3::/96                              Protocol  : Direct
NextHop    : 2001:3::2                                Preference: 0
Interface  : GE4/1/2                                  Cost      : 0
Destination: 2001:3::2/128                            Protocol  : Direct
Destination: 2001:4::/96                              Protocol  : BGP4+
# From each CE, ping other CEs. CEs of the same VPN can ping each other, whereas those of different VPNs should not. For example, CE 1 can ping CE 3 (2001:3::1), but cannot ping CE 4 (2001:4::1):
[CE1] ping ipv6 2001:3::1
  PING 2001:3::1 : 56  data bytes, press CTRL_C to break
    Reply from 2001:3::1
  --- 2001:3::1 ping statistics ---
    0.00% packet loss
[CE1] ping ipv6 2001:4::1
  PING 2001:4::1 : 56  data bytes, press CTRL_C to break
    Request time out
    Request time out
    Request time out
    Request time out
    Request time out
  --- 2001:4::1 ping statistics ---
    0 packet(s) received
    100.00% packet loss
    round-trip min/avg/max = 0/0/0 ms
Network requirements
·           CE 1 and CE 2 belong to the same VPN. CE 1 accesses the network through PE 1 in AS 100 and CE 2 accesses the network through PE 2 in AS 200.
·           An inter-AS IPv6 MPLS L3VPN is implemented using option A. That is, the VRF-to-VRF method is used to manage VPN routes.
·           The MPLS backbone in each AS runs OSPF.
Figure 34 Network diagram
Device
IP address
Device
IP address
CE 1
GE4/1/1
2001:1::1/96
CE 2
GE4/1/1
2001:2::1/96
PE 1
Loop0
1.1.1.9/32
PE 2
Loop0
4.4.4.9/32
GE4/1/1
2001:1::2/96
GE4/1/1
2001:2::2/96
POS2/1/1
172.1.1.2/24
POS2/1/1
162.1.1.2/24
ASBR-PE1
Loop0
2.2.2.9/32
ASBR-PE2
Loop0
3.3.3.9/32
POS2/1/1
172.1.1.1/24
POS2/1/1
162.1.1.1/24
POS2/1/2
2002:1::1/96
POS2/1/2
2002:1::2/96
1.      Configure an IGP (such as OSPF) on each MPLS backbone to ensure IP connectivity within the backbone. (Details not shown)
Be sure to advertise the route to the 32-bit loopback interface address of each router through OSPF. The loopback interface address of a router is to be used as the router’s LSR ID.
After you complete the configurations, each ASBR PE and the PE in the same AS can establish an OSPF adjacency. Issue the display ospf peer command and ping command; the output shows that the adjacencies are in Full state, and that the PE and ASBR PE in the same AS have learned the routes to the loopback interfaces of each other and can ping each other.
2.      Configure basic MPLS and enable MPLS LDP on each MPLS backbone to establish LDP LSPs.
# Configure basic MPLS on PE 1 and enable MPLS LDP for both PE 1 and the interface connected to ASBR-PE 1.
<PE1> system-view
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1-POS2/1/1] mpls
[PE1-POS2/1/1] quit
# Configure basic MPLS on ASBR-PE 1 and enable MPLS LDP for both ASBR-PE 1 and the interface connected to PE 1.
<ASBR-PE1> system-view
[ASBR-PE1] mpls lsr-id 2.2.2.9
[ASBR-PE1] mpls
[ASBR-PE1-mpls] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-mpls-ldp] quit
[ASBR-PE1] interface pos2/1/1
[ASBR-PE1-POS2/1/1] mpls
[ASBR-PE1-POS2/1/1] mpls ldp
[ASBR-PE1-POS2/1/1] quit
# Configure basic MPLS on ASBR-PE 2 and enable MPLS LDP for both ASBR-PE 2 and the interface connected to PE 2.
<ASBR-PE2> system-view
[ASBR-PE2] mpls lsr-id 3.3.3.9
[ASBR-PE2] mpls
[ASBR-PE2-mpls] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-mpls-ldp] quit
[ASBR-PE2] interface pos2/1/1
[ASBR-PE2-POS2/1/1] mpls
[ASBR-PE2-POS2/1/1] mpls ldp
[ASBR-PE2-POS2/1/1] quit
# Configure basic MPLS on PE 2 and enable MPLS LDP for both PE 2 and the interface connected to ASBR-PE 2.
<PE2> system-view
[PE2] mpls lsr-id 4.4.4.9
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2-POS2/1/1] mpls
[PE2-POS2/1/1] quit
After you complete the configurations, each PE and the ASBR PE in the same AS can establish the LDP neighbor relationship. Issue the display mpls ldp session command on the routers. The output shows that the session status is Operational.
3.      Configure a VPN instance on the PEs to allow the CEs to access
For the same VPN, the VPN targets for the VPN instance on the PE must match those for the VPN instance on the ASBR-PE in the same AS. This is not required for PEs in different ASs.
# Configure CE 1.
<CE1> system-view
[CE1] interface GigabitEthernet 4/1/1
[CE1-GigabitEthernet4/1/1] ipv6 address 2001:1::1 96
[CE1-GigabitEthernet4/1/1] quit
# Configure PE 1.
[PE1-vpn-instance-vpn1] vpn-target 100:1 both
# Configure CE 2.
<CE2> system-view
[CE2] interface GigabitEthernet 4/1/1
[CE2-GigabitEthernet4/1/1] ipv6 address 2001:2::1 96
[CE2-GigabitEthernet4/1/1] quit
# Configure PE 2.
[PE2-vpn-instance-vpn1] route-distinguisher 200:2
[PE2-vpn-instance-vpn1] vpn-target 100:1 both
[PE2-GigabitEthernet4/1/1] ipv6 address 2001:2::2 96
# Configure ASBR-PE 1, creating a VPN instance and binding the VPN instance to the interface connected to ASBR-PE 2 (ASBR-PE 1 considers ASBR-PE 2 its attached CE).
[ASBR-PE1] ip vpn-instance vpn1
[ASBR-PE1-vpn-vpn1] route-distinguisher 100:1
[ASBR-PE1-vpn-vpn1] vpn-target 100:1 both
[ASBR-PE1-vpn-vpn1] quit
[ASBR-PE1] interface POS 2/1/2
[ASBR-PE1-POS2/1/2] ip binding vpn-instance vpn1
[ASBR-PE1-POS2/1/2] ipv6 address 2002:1::1 96
[ASBR-PE1-POS2/1/2] quit
# Configure ASBR-PE 2, creating a VPN instance and binding the VPN instance to the interface connected to ASBR-PE 1 (ASBR-PE 2 considers ASBR-PE 1 its attached CE).
[ASBR-PE2] ip vpn-instance vpn1
[ASBR-PE2-vpn-vpn1] route-distinguisher 200:1
[ASBR-PE2-vpn-vpn1] vpn-target 100:1 both
[ASBR-PE2-vpn-vpn1] quit
[ASBR-PE2] interface POS 2/1/2
[ASBR-PE2-POS2/1/2] ip binding vpn-instance vpn1
[ASBR-PE2-POS2/1/2] ipv6 address 2002:1::2 96
[ASBR-PE2-POS2/1/2] quit
After completing the configurations, you can view the VPN instance information by issuing the display ip vpn-instance command.
Each PE can ping its attached CE, and ASBR-PE 1 and ASBR-PE 2 can ping each other.
4.      Establish EBGP peer relationships between PEs and CEs to allow them to exchange VPN routes.
# Configure CE 1.
[CE1] bgp 65001
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-ipv6-vpn1] peer 2001:1::1 as-number 65001
[PE1-bgp] quit
# Configure CE 2.
[CE2] bgp 65002
[CE2-bgp-af-ipv6] peer 2001:2::2 as-number 200
[CE2-bgp-af-ipv6] import-route direct
[CE2-bgp-af-ipv6] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp] ipv6-family vpn-instance vpn1
[PE2-bgp-ipv6-vpn1] peer 2001:2::1 as-number 65002
[PE2-bgp-ipv6-vpn1] import-route direct
[PE2-bgp-ipv6-vpn1] quit
[PE2-bgp] quit
5.      Establish an IBGP peer relationship between each PE and the ASBR PE in the same AS and an EBGP peer relationship between the ASBR PEs
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp] peer 2.2.2.9 as-number 100
[PE1-bgp] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-af-vpnv6] peer 2.2.2.9 enable
[PE1-bgp] quit
# Configure ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp] ipv6-family vpn-instance vpn1
[ASBR-PE1-bgp-ipv6-vpn1] peer 2002:1::2 as-number 200
[ASBR-PE1-bgp-ipv6-vpn1] quit
[ASBR-PE1-bgp] peer 1.1.1.9 as-number 100
[ASBR-PE1-bgp] peer 1.1.1.9 connect-interface loopback 0
[ASBR-PE1-bgp] ipv6-family vpnv6
[ASBR-PE1-bgp-af-vpnv6] peer 1.1.1.9 enable
[ASBR-PE1-bgp-af-vpnv6] quit
[ASBR-PE1-bgp] quit
# Configure ASBR-PE 2.
[ASBR-PE2] bgp 200
[ASBR-PE2-bgp] ipv6-family vpn-instance vpn1
[ASBR-PE2-bgp-ipv6-vpn1] peer 2002:1::1 as-number 100
[ASBR-PE2-bgp-ipv6-vpn1] quit
[ASBR-PE2-bgp] peer 4.4.4.9 as-number 200
[ASBR-PE2-bgp] peer 4.4.4.9 connect-interface loopback 0
[ASBR-PE2-bgp] ipv6-family vpnv6
[ASBR-PE2-bgp-af-vpnv6] peer 4.4.4.9 enable
[ASBR-PE2-bgp-af-vpnv6] quit
[ASBR-PE2-bgp] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp] peer 3.3.3.9 as-number 200
[PE2-bgp] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-af-vpnv6] peer 3.3.3.9 enable
[PE2-bgp] quit
After you complete the configurations, display the routing table and use the ping command. The CEs have learned the route to each other and can ping each other.
·           Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100 and Site 2 accesses the network through PE 2 in AS 600.
·           PEs in the same AS run IS-IS.
·           PE 1 and ASBR-PE 1 exchange labeled IPv4 routes by MP-IBGP.
·           PE 2 and ASBR-PE 2 exchange labeled IPv4 routes by MP-IBGP.
·           PE 1 and PE 2 are MP-EBGP peers.
·           ASBR-PE 1 and ASBR-PE 2 use their respective routing policies and label the routes received from each other.
·           ASBR-PE 1 and ASBR-PE 2 use MP-EBGP to exchange labeled IPv4 routes.
Figure 35 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
2.2.2.9/32
PE 2
Loop0
5.5.5.9/32
Loop1
2001:1::1/128
Loop1
2001:1::2/128
POS4/1/1
1.1.1.2/8
POS4/1/1
9.1.1.2/8
ASBR-PE 1
Loop0
3.3.3.9/32
ASBR-PE 2
Loop0
4.4.4.9/32
POS4/1/1
1.1.1.1/8
POS4/1/1
9.1.1.1/8
POS4/1/2
11.0.0.2/8
POS4/1/2
11.0.0.1/8
1.      Configure PE 1
# Configure IS-IS on PE 1.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] network-entity 10.111.111.111.111.00
[PE1-isis-1] quit
# Configure an LSR ID, and enable MPLS and LDP.
[PE1] mpls lsr-id 2.2.2.9
[PE1] mpls
[PE1-mpls] label advertise non-null
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
# Configure interface POS 4/1/1, and start IS-IS and enable MPLS and LDP on the interface.
[PE1] interface POS 4/1/1
[PE1-POS4/1/1] ip address 1.1.1.2 255.0.0.0
[PE1-POS4/1/1] isis enable 1
[PE1-POS4/1/1] mpls
[PE1-POS4/1/1] mpls ldp
[PE1-POS4/1/1] quit
# Configure interface Loopback 0 and start IS-IS on it.
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 2.2.2.9 32
[PE1-LoopBack0] isis enable 1
[PE1-LoopBack0] quit
# Create VPN instance vpn1, and configure the RD and VPN target attributes for it.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] quit
# Configure interface Loopback 1 and bind the interface to VPN instance vpn1.
[PE1] interface loopback 1
[PE1-LoopBack1] ip binding vpn-instance vpn1
[PE1-LoopBack1] ipv6 address 2001:1::1 128
[PE1-LoopBack1] quit
# Start BGP on PE 1.
[PE1] bgp 100
# Configure the capability to advertise labeled routes to and receive labeled routes from IBGP peer 3.3.3.9.
[PE1-bgp] peer 3.3.3.9 label-route-capability
# Configure the maximum hop count from PE 1 to EBGP peer 5.5.5.9 as 10.
[PE1-bgp] peer 5.5.5.9 as-number 600
[PE1-bgp] peer 5.5.5.9 connect-interface loopback 0
[PE1-bgp] peer 5.5.5.9 ebgp-max-hop 10
# Configure peer 5.5.5.9 as a VPNv6 peer.
[PE1-bgp-af-vpnv6] peer 5.5.5.9 enable
# Redistribute direct routes to the routing table of vpn1.
[PE1-bgp] quit
2.      Configure ASBR-PE 1
# Start IS-IS on ASBR-PE 1.
[ASBR-PE1] isis 1
[ASBR-PE1-isis-1] network-entity 10.222.222.222.222.00
[ASBR-PE1-isis-1] quit
[ASBR-PE1] mpls
[ASBR-PE1-mpls] label advertise non-null
[ASBR-PE1] mpls ldp
[ASBR-PE1] interface POS 4/1/1
[ASBR-PE1-POS4/1/1] ip address 1.1.1.1 255.0.0.0
[ASBR-PE1-POS4/1/1] isis enable 1
[ASBR-PE1-POS4/1/1] mpls
[ASBR-PE1-POS4/1/1] mpls ldp
[ASBR-PE1-POS4/1/1] quit
# Configure interface POS 4/1/2 and enable MPLS on it.
[ASBR-PE1] interface POS 4/1/2
[ASBR-PE1-POS4/1/2] ip address 11.0.0.2 255.0.0.0
[ASBR-PE1-POS4/1/2] mpls
[ASBR-PE1-POS4/1/2] quit
[ASBR-PE1-LoopBack0] ip address 3.3.3.9 32
[ASBR-PE1-LoopBack0] isis enable 1
[ASBR-PE1-LoopBack0] quit
# Create routing policies.
[ASBR-PE1] route-policy policy1 permit node 1
[ASBR-PE1-route-policy1] apply mpls-label
[ASBR-PE1-route-policy1] quit
[ASBR-PE1] route-policy policy2 permit node 1
[ASBR-PE1-route-policy2] if-match mpls-label
[ASBR-PE1-route-policy2] apply mpls-label
[ASBR-PE1-route-policy2] quit
# Start BGP on ASBR-PE 1 and redistribute routes from IS-IS process 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp] import-route isis 1
# Apply routing policy policy2 to filter routes advertised to IBGP peer 2.2.2.9.
[ASBR-PE1-bgp] peer 2.2.2.9 as-number 100
[ASBR-PE1-bgp] peer 2.2.2.9 route-policy policy2 export
# Configure the capability to advertise labeled routes to and receive labeled routes from IBGP peer 2.2.2.9.
[ASBR-PE1-bgp] peer 2.2.2.9 connect-interface loopback 0
[ASBR-PE1-bgp] peer 2.2.2.9 label-route-capability
# Apply routing policy policy1 to filter routes advertised to EBGP peer 11.0.0.1.
[ASBR-PE1-bgp] peer 11.0.0.1 as-number 600
[ASBR-PE1-bgp] peer 11.0.0.1 route-policy policy1 export
# Configure the capability to advertise labeled routes to and receive labeled routes from EBGP peer 11.0.0.1.
[ASBR-PE1-bgp] peer 11.0.0.1 label-route-capability
[ASBR-PE1-bgp] quit
3.      Configure ASBR-PE 2
# Start IS-IS on ASBR-PE 2.
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] network-entity 10.222.222.222.222.00
[ASBR-PE2-isis-1] quit
[ASBR-PE2] mpls
[ASBR-PE2-mpls] label advertise non-null
[ASBR-PE2] mpls ldp
[ASBR-PE2] interface POS 4/1/1
[ASBR-PE2-POS4/1/1] ip address 9.1.1.1 255.0.0.0
[ASBR-PE2-POS4/1/1] isis enable 1
[ASBR-PE2-POS4/1/1] mpls
[ASBR-PE2-POS4/1/1] mpls ldp
[ASBR-PE2-POS4/1/1] quit
[ASBR-PE2] interface loopback 0
[ASBR-PE2-LoopBack0] ip address 4.4.4.9 32
[ASBR-PE2-LoopBack0] isis enable 1
[ASBR-PE2-LoopBack0] quit
[ASBR-PE2] interface POS 4/1/2
[ASBR-PE2-POS4/1/2] ip address 11.0.0.1 255.0.0.0
[ASBR-PE2-POS4/1/2] mpls
[ASBR-PE2-POS4/1/2] quit
[ASBR-PE2] route-policy policy1 permit node 1
[ASBR-PE2-route-policy1] apply mpls-label
[ASBR-PE2-route-policy1] quit
[ASBR-PE2] route-policy policy2 permit node 1
[ASBR-PE2-route-policy2] if-match mpls-label
[ASBR-PE2-route-policy2] apply mpls-label
[ASBR-PE2-route-policy2] quit
# Start BGP on ASBR-PE 2 and redistribute routes from IS-IS process 1.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp] import-route isis 1
# Configure the capability to advertise labeled routes to and receive labeled routes from IBGP peer 5.5.5.9.
[ASBR-PE2-bgp] peer 5.5.5.9 as-number 600
[ASBR-PE2-bgp] peer 5.5.5.9 connect-interface loopback 0
[ASBR-PE2-bgp] peer 5.5.5.9 label-route-capability
# Apply routing policy policy2 to filter routes advertised to IBGP peer 5.5.5.9.
[ASBR-PE2-bgp] peer 5.5.5.9 route-policy policy2 export
# Apply routing policy policy1 to filter routes advertised to EBGP peer 11.0.0.2.
[ASBR-PE2-bgp] peer 11.0.0.2 as-number 100
[ASBR-PE2-bgp] peer 11.0.0.2 route-policy policy1 export
# Configure the capability to advertise labeled routes to and receive labeled routes from EBGP peer 11.0.0.2.
[ASBR-PE2-bgp] peer 11.0.0.2 label-route-capability
[ASBR-PE2-bgp] quit
4.      Configure PE 2
# Start IS-IS on PE 2.
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] network-entity 10.111.111.111.111.00
[PE2-isis-1] quit
[PE2] mpls lsr-id 5.5.5.9
[PE2] mpls
[PE2-mpls] label advertise non-null
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2] interface POS 4/1/1
[PE2-POS4/1/1] ip address 9.1.1.2 255.0.0.0
[PE2-POS4/1/1] isis enable 1
[PE2-POS4/1/1] mpls
[PE2-POS4/1/1] mpls ldp
[PE2-POS4/1/1] quit
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 5.5.5.9 32
[PE2-LoopBack0] isis enable 1
[PE2-LoopBack0] quit
# Create VPN instance vpn1 and configure the RD and VPN target attributes for it.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 11:11
[PE2-vpn-instance-vpn1] quit
[PE2] interface loopback 1
[PE2-LoopBack1] ip binding vpn-instance vpn1
[PE2-LoopBack1] ipv6 address 2001:1::2 128
[PE2-LoopBack1] quit
# Start BGP.
[PE2] bgp 600
# Configure the capability to advertise labeled routes to and receive labeled routes from IBGP peer 4.4.4.9.
[PE2-bgp] peer 4.4.4.9 as-number 600
[PE2-bgp] peer 4.4.4.9 connect-interface loopback 0
[PE2-bgp] peer 4.4.4.9 label-route-capability
# Configure the maximum hop count from PE 2 to EBGP peer 2.2.2.9 as 10.
[PE2-bgp] peer 2.2.2.9 as-number 100
[PE2-bgp] peer 2.2.2.9 connect-interface loopback 0
[PE2-bgp] peer 2.2.2.9 ebgp-max-hop 10
# Configure peer 2.2.2.9 as a VPNv6 peer.
[PE2-bgp-af-vpnv6] peer 2.2.2.9 enable
[PE2-bgp] quit
5.      Verify your configurations
# From each PE, ping the other PE. PE 1 and PE 2 can ping each other:
[PE2] ping ipv6 –vpn-instance vpn1 2001:1::1
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
[PE1] ping ipv6 –vpn-instance vpn1 2001:1::2
  PING 2001:1::2 : 56  data bytes, press CTRL_C to break
    Reply from 2001:1::2
  --- 2001:1::2 ping statistics ---
    0.00% packet loss
Configuring carrier’s carrier
Configure carrier’s carrier for the scenario shown in Figure 36. .In this scenario:
·           PE 1 and PE 2 are the provider carrier’s PE routers. They provide VPN services to the customer carrier.
·           CE 1 and CE 2 are the customer carrier’s routers. They are connected to the provider carrier’s backbone as CE routers.
·           PE 3 and PE 4 are the customer carrier’s PE routers. They provide IPv6 MPLS L3VPN services to end customers.
·           CE 3 and CE 4 are customers of the customer carrier.
The key to the carrier’s carrier deployment is to configure exchange of two kinds of routes:
·           Exchange of the customer carrier’s internal routes on the provider carrier’s backbone.
·           Exchange of the end customers’ internal routes between PE 3 and PE 4, the PEs of the customer carrier. In this process, an MP-IBGP peer relationship must be established between PE 3 and PE 4.
Figure 36 Network diagram
Device
IP address
Device
IP address
CE 3
GE4/1/1
2001:1::1/96
CE 4
GE4/1/1
2001:2::1/96
PE 3
Loop0
1.1.1.9/32
PE 4
Loop0
6.6.6.9/32
GE4/1/1
2001:1::2/96
GE4/1/1
2001:2::2/96
POS2/1/2
10.1.1.1/24
POS2/1/2
20.1.1.2/24
CE 1
Loop0
2.2.2.9/32
CE 2
Loop0
5.5.5.9/32
POS2/1/1
10.1.1.2/24
POS2/1/1
21.1.1.2/24
POS2/1/2
11.1.1.1/24
POS2/1/2
20.1.1.1/24
PE 1
Loop0
3.3.3.9/32
PE 2
Loop0
4.4.4.9/32
POS2/1/1
11.1.1.2/24
POS2/1/1
30.1.1.2/24
POS2/1/2
30.1.1.1/24
POS2/1/2
21.1.1.1/24
1.      Configure MPLS L3VPN on the provider carrier backbone: start IS-IS as the IGP, enable LDP on PE 1 and PE 2, and establish an MP-IBGP peer relationship between the PEs.
# Configure PE 1.
<PE1> system-view
[PE1-LoopBack0] ip address 3.3.3.9 32
[PE1] mpls lsr-id 3.3.3.9
[PE1] mpls
[PE1-mpls] quit
[PE1] mpls ldp
[PE1-mpls-ldp] quit
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE1-isis-1] quit
[PE1] interface POS 2/1/2
[PE1-POS2/1/2] ip address 30.1.1.1 24
[PE1-POS2/1/2] isis enable 1
[PE1-POS2/1/2] mpls
[PE1-POS2/1/2] mpls ldp
[PE1-POS2/1/2] mpls ldp transport-address interface
[PE1-POS2/1/2] quit
[PE1] bgp 100
[PE1-bgp] peer 4.4.4.9 as-number 100
[PE1-bgp] peer 4.4.4.9 connect-interface loopback 0
[PE1-bgp] ipv4-family vpnv4
[PE1-bgp-af-vpnv4] peer 4.4.4.9 enable
[PE1-bgp-af-vpnv4] quit
[PE1-bgp] quit
After completing the configurations, issue the display mpls ldp session command on PE 1 or PE 2; the output shows that the LDP session has been established successfully. Issue the display bgp peer command; the output shows that the BGP peer relationship has been established and has reached the Established state. Issue the display isis peer command; the output shows that an IS-IS neighbor relationship has been set up. Take PE 1 as an example:
 4.4.4.9:0      Operational   DU   Active   Off  Off  378/378
 BGP local router ID : 3.3.3.9
  4.4.4.9       100      162      145     0        0  02:12:47 Established
[PE1] display isis peer
                          Peer information for ISIS(1)
  System Id    Interface   Circuit Id      State HoldTime Type   PRI
0000.0000.0005 POS2/1/2           001       Up   29s      L1L2   --
2.      Configure the customer carrier network: start IS-IS as the IGP, and enable LDP between PE 3 and CE 1, and between PE 4 and CE 2.
# Configure PE 3.
<PE3> system-view
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 1.1.1.9 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 1.1.1.9
[PE3] mpls
[PE3-mpls] quit
[PE3] mpls ldp
[PE3-mpls-ldp] quit
[PE3] isis 2
[PE3-isis-2] network-entity 10.0000.0000.0000.0001.00
[PE3-isis-2] quit
[PE3-LoopBack0] isis enable 2
[PE3] interface POS 2/1/2
[PE3-POS2/1/2] ip address 10.1.1.1 24
[PE3-POS2/1/2] isis enable 2
[PE3-POS2/1/2] mpls
[PE3-POS2/1/2] mpls ldp
[PE3-POS2/1/2] mpls ldp transport-address interface
[PE3-POS2/1/2] quit
# Configure CE 1.
<CE1> system-view
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 2.2.2.9 32
[CE1-LoopBack0] quit
[CE1] mpls lsr-id 2.2.2.9
[CE1] mpls
[CE1-mpls] quit
[CE1] mpls ldp
[CE1-mpls-ldp] quit
[CE1] isis 2
[CE1-isis-2] network-entity 10.0000.0000.0000.0002.00
[CE1-isis-2] quit
[CE1-LoopBack0] isis enable 2
[CE1] interface POS2/1/1
[CE1-POS2/1/1] ip address 10.1.1.2 24
[CE1-POS2/1/1] isis enable 2
[CE1-POS2/1/1] mpls
[CE1-POS2/1/1] mpls ldp
[CE1-POS2/1/1] mpls ldp transport-address interface
[CE1-POS2/1/1] quit
After you complete the configurations, PE 3 and CE 1 can establish an LDP session and IS-IS neighbor relationship between them.
The configurations for PE 4 and CE 2 are similar to those for PE 3 and CE 1. (Details not shown)
3.      Connect the customer carrier to the provider carrier.
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 200:1
[PE1] mpls ldp vpn-instance vpn1
[PE1-mpls-ldp-vpn-instance-vpn1] quit
[PE1] isis 2 vpn-instance vpn1
[PE1-isis-2] network-entity 10.0000.0000.0000.0003.00
[PE1-isis-2] import-route bgp allow-ibgp
[PE1-isis-2] quit
[PE1-POS2/1/1] ip binding vpn-instance vpn1
[PE1-POS2/1/1] ip address 11.1.1.2 24
[PE1-POS2/1/1] isis enable 2
[PE1-POS2/1/1] mpls
[PE1-POS2/1/1] mpls ldp transport-address interface
[PE1-POS2/1/1] quit
[PE1] bgp 100
[PE1-bgp] ipv4-family vpn-instance vpn1
[PE1-bgp-vpn1] import isis 2
[PE1-bgp-vpn1] quit
[PE1-bgp] quit
# Configure CE 1.
[CE1] interface POS 2/1/2
[CE1-POS2/1/2] ip address 11.1.1.1 24
[CE1-POS2/1/2] isis enable 2
[CE1-POS2/1/2] mpls
[CE1-POS2/1/2] mpls ldp
[CE1-POS2/1/2] mpls ldp transport-address interface
[CE1-POS2/1/2] quit
After you complete the configurations, PE 1 and CE 1 can establish an LDP session and IS-IS neighbor relationship between them.
The configurations for PE 2 and CE 2 are similar to those for PE 1 and CE 1. (Details not shown)
4.      Connect end customers to the customer carrier.
# Configure CE 3.
<CE3> system-view
[CE3] interface GigabitEthernet 4/1/1
[CE3-GigabitEthernet4/1/1] ipv6 address 2001:1::1 96
[CE3-GigabitEthernet4/1/1] quit
[CE3] bgp 65410
[CE3-bgp] ipv6-family
[CE3-bgp] peer 2001:1::2 as-number 100
[CE3-bgp] import-route direct
[CE3-bgp] quit
# Configure PE 3.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 100:1
[PE3-vpn-instance-vpn1] vpn-target 1:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface GigabitEthernet 4/1/1
[PE3-GigabitEthernet4/1/1] ip binding vpn-instance vpn1
[PE3-GigabitEthernet4/1/1] ipv6 address 2001:1::2 96
[PE3-GigabitEthernet4/1/1] quit
[PE3] bgp 100
[PE3-bgp] ipv6-family vpn-instance vpn1
[PE3-bgp-ipv6-vpn1] peer 2001:1::1 as-number 65410
[PE3-bgp-ipv6-vpn1] import-route direct
[PE3-bgp-ipv6-vpn1] quit
[PE3-bgp] quit
The configurations for PE 4 and CE 4 are similar to those for PE 3 and CE 3. (Details not shown)
5.      Configure an MP-IBGP peer relationship between the PEs of the customer carrier to exchange the VPN routes of the end customers.
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp] peer 6.6.6.9 as-number 100
[PE3-bgp] peer 6.6.6.9 connect-interface loopback 0
[PE3-bgp] ipv6-family vpnv6
[PE3-bgp-af-vpnv6] peer 6.6.6.9 enable
[PE3-bgp-af-vpnv6] quit
[PE3-bgp] quit
The configurations for PE 4 are similar to those for PE 3. (Details not shown)
# Issue the display ip routing-table command on PE 1 and PE 2. The output shows that only routes of the provider carrier network are present in the public network routing table of PE 1 and PE 2. Take PE 1 as an example:
[PE1] display ip routing-table
Routing Tables: Public
         Destinations : 7        Routes : 7
Destination/Mask    Proto  Pre  Cost    NextHop      Interface
3.3.3.9/32          Direct 0    0       127.0.0.1    InLoop0
4.4.4.9/32          ISIS   15   10      30.1.1.2     POS2/1/2
30.1.1.0/24         Direct 0    0       30.1.1.1     POS2/1/2
30.1.1.1/32         Direct 0    0       127.0.0.1    InLoop0
30.1.1.2/32         Direct 0    0       30.1.1.2     POS2/1/2
127.0.0.0/8         Direct 0    0       127.0.0.1    InLoop0
127.0.0.1/32        Direct 0    0       127.0.0.1    InLoop0
# Issue the display ip routing-table vpn-instance command on PE 1 and PE 2. The output shows that the internal routes of the customer carrier network are present in the VPN routing tables. Take PE 1 as an example:
[PE1] display ip routing-table vpn-instance vpn1
Routing Tables: vpn1
         Destinations : 11        Routes : 11
1.1.1.9/32          ISIS   15   20      11.1.1.1      POS2/1/1
2.2.2.9/32          ISIS   15   10      11.1.1.1      POS2/1/1
5.5.5.9/32          BGP    255  0       4.4.4.9       NULL0
6.6.6.9/32          BGP    255  0       4.4.4.9       NULL0
10.1.1.0/24         ISIS   15   20      11.1.1.1      POS2/1/1
11.1.1.0/24         Direct 0    0       11.1.1.1      POS2/1/1
11.1.1.1/32         Direct 0    0       127.0.0.1     InLoop0
11.1.1.2/32         Direct 0    0       11.1.1.2      POS2/1/1
20.1.1.0/24         BGP    255  0       4.4.4.9       NULL0
21.1.1.0/24         BGP    255  0       4.4.4.9       NULL0
21.1.1.2/32         BGP    255  0       4.4.4.9       NULL0
# Issue the display ipv6 routing-table vpn-instance command on PE 1 and PE 2. The output shows that their VPN routing tables do not contain the VPN routes that the customer carrier maintains.
Issue the display ip routing-table command on CE 1 and CE 2. The output shows that the internal routes of the customer carrier network are present in the public network routing tables. Take CE 1 as an example:
[CE1] display ip routing-table
         Destinations : 16       Routes : 16
1.1.1.9/32          ISIS   15   10     10.1.1.2        POS2/1/1
2.2.2.9/32          Direct 0    0      127.0.0.1       InLoop0
5.5.5.9/32          ISIS   15   74     11.1.1.2        POS2/1/2
6.6.6.9/32          ISIS   15   74     11.1.1.2        POS2/1/2
10.1.1.0/24         Direct 0    0      10.1.1.2        POS2/1/1
10.1.1.1/32         Direct 0    0      10.1.1.1        POS2/1/1
10.1.1.2/32         Direct 0    0      127.0.0.1       InLoop0
11.1.1.0/24         Direct 0    0      11.1.1.1        POS2/1/2
11.1.1.2/32         Direct 0    0      11.1.1.2        POS2/1/2
20.1.1.0/24         ISIS   15   74     11.1.1.2        POS2/1/2
21.1.1.0/24         ISIS   15   74     11.1.1.2        POS2/1/2
21.1.1.2/32         ISIS   15   74     11.1.1.2        POS2/1/2
# Issue the display ipv6 routing-table vpn-instance command on CE 1 and CE 2. The output shows that the VPN routing tables do not contain the VPN routes that the customer carrier maintains.
# Issue the display ip routing-table command on PE 3 and PE 4. The output shows that the internal routes of the customer carrier network are present in the public network routing tables. Take PE 3 as an example:
[PE3] display ip routing-table
2.2.2.9/32          ISIS   15   10     10.1.1.2        POS2/1/2
5.5.5.9/32          ISIS   15   84     10.1.1.2        POS2/1/2
6.6.6.9/32          ISIS   15   84     10.1.1.2        POS2/1/2
10.1.1.0/24         Direct 0    0      10.1.1.1        POS2/1/2
10.1.1.1/32         Direct 0    0      127.0.0.1       InLoop0
10.1.1.2/32         Direct 0    0      10.1.1.2        POS2/1/2
11.1.1.0/24         ISIS   15   20     10.1.1.2        POS2/1/2
20.1.1.0/24         ISIS   15   84     10.1.1.2        POS2/1/2
21.1.1.0/24         ISIS   15   84     10.1.1.2        POS2/1/2
21.1.1.2/32         ISIS   15   84     10.1.1.2        POS2/1/2
# Ping PE 3 from PE 4 and ping PE 4 from PE 3. PE 3 and PE 4 can ping each other:
[PE3] ping 20.1.1.2
  PING 20.1.1.2: 56  data bytes, press CTRL_C to break
    Reply from 20.1.1.2: bytes=56 Sequence=1 ttl=252 time=127 ms
    Reply from 20.1.1.2: bytes=56 Sequence=2 ttl=252 time=97 ms
    Reply from 20.1.1.2: bytes=56 Sequence=3 ttl=252 time=83 ms
    Reply from 20.1.1.2: bytes=56 Sequence=4 ttl=252 time=70 ms
    Reply from 20.1.1.2: bytes=56 Sequence=5 ttl=252 time=60 ms
  --- 20.1.1.2 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 60/87/127 ms
CE 3 and CE 4 can ping each other:
[CE3] ping ipv6 2001:2::1
  PING 2001:2::1 : 56  data bytes, press CTRL_C to break
    Reply from 2001:2::1
  --- 2001:2::1 ping statistics ---
    0.00% packet loss
