04-会话管理命令
本章节下载: 04-会话管理命令 (225.95 KB)
1.1.1 display session aging-time application
1.1.2 display session aging-time state
1.1.3 display session relation-table
1.1.4 display session statistics
1.1.5 display session statistics multicast
1.1.6 display session table ipv4
1.1.7 display session table ipv6
1.1.8 display session table multicast ipv4
1.1.9 display session table multicast ipv6
1.1.10 reset session relation-table
1.1.11 reset session statistics
1.1.12 reset session statistics multicast
1.1.14 reset session table ipv4
1.1.15 reset session table ipv6
1.1.16 reset session table multicast
1.1.17 reset session table multicast ipv4
1.1.18 reset session table multicast ipv6
1.1.19 session aging-time application
1.1.20 session aging-time state
1.1.21 session log bytes-active
1.1.23 session log packets-active
1.1.24 session log time-active
1.1.26 session statistic enable
display session aging-time application命令用来显示应用层协议的会话老化时间。
# 显示当前各应用层协议的会话老化时间。
<Sysname> display session aging-time application
Application Aging Time(s)
DNS 1
FTP 3600
GTP 60
H225 3600
H245 3600
RAS 300
RTSP 3600
SIP 300
TFTP 60
ILS 3600
MGCP 60
NBT 3600
PPTP 3600
RSH 60
SCCP 3600
SQLNET 600
XDMCP 3600
表1-1 display session aging-time application命令显示信息描述表
Application |
应用层协议类型 |
Aging Time(s) |
会话老化时间,单位为秒 |
· application aging-time
display session aging-time state命令用来显示各协议状态的会话老化时间。
# 显示当前各协议状态的会话老化时间。
<Sysname> display session aging-time state
State Aging Time(s)
SYN 10
TCP-EST 3600
FIN 10
UDP-OPEN 10
UDP-READY 30
ICMP-REQUEST 30
ICMP-REPLY 10
RAWIP-OPEN 30
RAWIP-READY 60
UDPLITE-OPEN 30
UDPLITE-READY 60
DCCP-REQUEST 30
DCCP-EST 3600
DCCP-CLOSEREQ 30
SCTP-INIT 30
SCTP-EST 3600
SCTP-SHUTDOWN 30
ICMPV6-REQUEST 60
ICMPV6-REPLY 30
表1-2 display session aging-time state命令显示信息描述表
State |
各协议的状态类型 |
Aging Time(s) |
会话老化时间,单位为秒 |
· session aging-time state
display session relation-table命令用来显示关联表项信息。
独立运行模式:
display session relation-table { ipv4 | ipv6 } [ slot slot-number ]
IRF模式:
display session relation-table { ipv4 | ipv6 } [ chassis chassis-number slot slot-number ]
ipv4:显示IPv4关联表项。
ipv6:显示IPv6关联表项。
slot slot-number:显示指定单板上的关联表项信息,slot-number表示单板所在槽位号。不指定该参数时,显示所有单板上的关联表项信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的关联表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,显示所有成员设备的所有单板上的关联表项信息。(IRF模式)
# 显示所有的IPv4关联表项。(独立运行模式)
<Sysname> display session relation-table ipv4
Slot 1:
Source IP/port: 192.168.1.100/-
Destination IP/port: 192.168.2.100/99
VPN instance/VLAN ID/VLL ID: 1/-/-
Protocol: TCP(6) TTL: 1234s App: FTP-DATA
Source IP/port: -/-
Destination IP/port: 192.168.2.200/1212
VPN instance/VLAN ID/VLL ID: -/-/-
Protocol: TCP(6) TTL: 3100s App: H225
Total entries found: 2
# 显示所有的IPv6关联表项。(独立运行模式)
<Sysname> display session relation-table ipv6
Slot 1:
Source IP: 2011::0002
Destination IP/port: 2011::0008/1212
Protocol: TCP(6) TTL: 567s App: FTP-DATA
Total entries found: 1
# 显示所有的IPv4关联表项。(IRF模式)
Slot 1 in chassis 1:
Source IP/port: -/-
# 显示所有的IPv6关联表项。(IRF模式)
表1-3 display session relation-table命令显示信息描述表
Source IP/port |
会话的源IP地址和端口号。如果未指定则显示“-/-” IPv6会话无源端口号字段 |
Destination IP/port |
会话的目的IP地址/端口号 |
VPN instance/VLAN ID/VLL ID |
关联表项所属的MPLS L3VPN/二层转发时会话所属的VLAN ID/二层转发时会话所属的INLINE。未指定的参数则显示为“-” |
Protocol |
传输层协议类型 |
TTL |
关联表的剩余存活时间,单位为秒 |
App |
应用层协议类型 |
Total entries found |
当前查找到的关联表总数 |
display session statistics命令用来显示单播会话统计信息。
独立运行模式:
display session statistics [ summary ] [ slot slot-number ]
IRF模式:
display session statistics [ summary ] [ chassis chassis-number slot slot-number ]
summary:显示会话单播统计信息的概要信息。不指定该参数时,显示单播会话统计信息的详细信息。
slot slot-number:显示指定单板上的单播会话统计信息,slot-number表示单板所在槽位号。不指定该参数时,显示所有单板上的单播会话统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的单播会话统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,显示所有成员设备的所有单板上的单播会话统计信息。(IRF模式)
# 显示所有单播会话统计信息的详细信息。
<Sysname> display session statistics
Current sessions: 3
TCP sessions: 0
UDP sessions: 0
ICMP sessions: 3
ICMPv6 sessions: 0
UDP-Lite sessions: 0
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
History average sessions per second:
Past hour: 1
Past 24 hours: 0
Past 30 days: 0
History average session establishment rate:
Past 24 hours: 0/s
Past 30 days: 0/s
Current relation-table entries: 0
Session establishment rate: 0/s
TCP: 0/s
UDP: 0/s
ICMP: 0/s
ICMPv6: 0/s
UDP-Lite: 0/s
SCTP: 0/s
DCCP: 0/s
RAWIP: 0/s
Received TCP : 0 packets 0 bytes
Received UDP : 118 packets 13568 bytes
Received ICMP : 105 packets 8652 bytes
Received ICMPv6 : 0 packets 0 bytes
Received UDP-Lite : 0 packets 0 bytes
Received SCTP : 0 packets 0 bytes
Received DCCP : 0 packets 0 bytes
Received RAWIP : 0 packets 0 bytes
表1-4 display session statistics命令显示信息描述表
Current sessions |
系统当前的单播总会话数 |
TCP sessions |
系统当前的TCP单播会话数,以及各协议状态下的会话数 |
UDP sessions |
系统当前的UDP单播会话数,以及各协议状态下的会话数 |
ICMP sessions |
系统当前的ICMP单播会话数,以及各协议状态下的会话数 |
ICMPv6 sessions |
系统当前的ICMPv6单播会话数,以及各协议状态下的会话数 |
UDP-Lite sessions |
系统当前的UDP-Lite单播会话数,以及各协议状态下的会话数 |
SCTP sessions |
系统当前的SCTP单播会话数,以及各协议状态下的会话数 |
DCCP sessions |
系统当前的DCCP单播会话数,以及各协议状态下的会话数 |
RAWIP sessions |
系统当前的Raw IP单播会话数,以及各协议状态下的会话数 |
History average sessions per second |
单播会话数的历史统计信息,以当前时间为基准 |
Past hour |
最近一小时内每秒钟系统单播会话数目的平均值 |
Past 24 hours |
最近一天内每秒钟系统单播会话数目的平均值 |
Past 30 days |
最近三十天内每秒钟系统单播会话数目的平均值 |
History average session establishment rate |
新建单播会话速率的历史统计信息,以当前时间为基准 |
Past hour |
最近一小时内系统新建单播会话速率的平均值 |
Past 24 hours |
最近一天内系统新建单播会话速率的平均值 |
Past 30 days |
最近三十天内系统新建单播会话速率的平均值 |
Current relation-table entries |
总关联表项个数 |
Session establishment rate |
系统创建单播会话的速率,以及创建各协议会话的速率 |
Received TCP |
系统当前收到的TCP报文数、报文字节数 |
Received UDP |
系统当前收到的UDP报文数、报文字节数 |
Received ICMP |
系统当前收到的ICMP报文数、报文字节数 |
Received ICMPv6 |
系统当前收到的ICMPv6报文数、报文字节数 |
Received UDP-Lite |
系统当前收到的UDP-Lite报文数、报文字节数 |
Received SCTP |
系统当前收到的SCTP报文数、报文字节数 |
Received DCCP |
系统当前收到的DCCP报文数、报文字节数 |
Received RAWIP |
系统当前收到的Raw IP报文数、报文字节数 |
# 显示单播会话统计信息的概要信息。(独立运行模式)
<Sysname> display session statistics summary
Slot Sessions TCP UDP Rate TCP rate UDP rate
1 3 0 0 0/s 0/s 0/s
表1-5 display session statistics summary命令显示信息描述表
Sessions |
系统当前的单播总会话数 |
TCP |
系统当前的TCP单播会话数 |
UDP |
系统当前的UDP单播会话数 |
Rate |
系统创建单播会话的速率 |
TCP rate |
系统创建TCP单播会话的速率 |
UDP rate |
系统创建UDP单播会话的速率 |
display session statistic multicast命令用来显示组播会话统计信息。
独立运行模式:
display session statistics multicast [ slot slot-number ]
IRF模式:
display session statistics multicast [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板上的组播会话统计信息,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有单板上的组播会话统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的组播会话统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有成员设备的所有单板上的组播会话统计信息。(IRF模式)
# 显示组播会话统计信息。(独立运行模式)
<Sysname> display session statistics multicast
Slot 1:
Current sessions: 0
Received: 0 packets 0 bytes
Sent : 0 packets 0 bytes
Slot 2:
Current sessions: 0
表1-6 display session statistics multicast命令显示信息描述表
Current sessions |
系统当前为业务流量创建的组播会话数 |
系统创建组播会话的速率 |
Received |
系统当前收到的组播报文数、报文字节数 |
Sent |
系统当前发出的组播报文数、报文字节数 |
display session table ipv4命令用来显示IPv4单播会话表项信息。
独立运行模式:
display session table ipv4 [ slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ]
IRF模式:
display session table ipv4 [ chassis chassis-number slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ]
slot slot-number:显示指定单板上的IPv4单播会话表项,slot-number表示单板所在槽位号。不指定该参数时,显示所有单板上的IPv4单播会话表项。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的IPv4单播会话表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,显示所有成员设备的所有单板上的IPv4单播会话表项。(IRF模式)
source-ip start-source-ip [ end-source-ip ]:显示指定源IP地址的单播会话表项。其中,start-source-ip表示发起方到响应方会话的起始源IPv4地址,end-source-ip表示发起方到响应方会话的结束源IPv4地址。
destination-ip start-destination-ip [ end-destination-ip ]:显示指定目的IPv4地址的单播会话表项。其中,start-destination-ip表示发起方到响应方会话的起始目的IPv4地址,end-destination-ip表示发起方到响应方会话的结束目的IPv4地址。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv4单播会话表项。其中,IPv4传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的IPv4单播会话表项。其中,source-port表示发起方到响应方会话的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的IPv4单播会话表项。其中,destination-port表示发起方到响应方会话的目的端口号,取值为0~65535。
verbose:显示IPv4单播会话表项的详细信息。不指定该参数时,显示IPv4单播会话表项的概要信息。
如果不指定任何参数,则显示所有的IPv4单播会话表项。
# 显示所有的IPv4单播会话表项的概要信息。(独立运行模式)
<Sysname> display session table ipv4
Slot 1:
Initiator:
Source IP/port: 192.168.1.18/1877
Destination IP/port: 192.168.1.55/22
Protocol: TCP(6)
Inbound interface: GigabitEthernet1/0/1
Initiator:
Source IP/port: 192.168.1.18/1792
Destination IP/port: 192.168.1.55/2048
Protocol: ICMP(1)
Total sessions found: 2
# 显示所有的IPv4单播会话表项的详细信息。(独立运行模式)
<Sysname> display session table ipv4 verbose
Slot 1:
Initiator:
Protocol: TCP(6)
Responder:
Source IP/port: 192.168.1.55/22
Destination IP/port: 192.168.1.18/1877
Protocol: TCP(6)
Inbound interface: GigabitEthernet1/0/2
State: TCP_SYN_SENT
Application: SSH
Start time: 2011-07-29 19:12:36 TTL: 28s
Initiator->Responder: 1 packets 48 bytes
Responder->Initiator: 0 packets 0 bytes
Initiator:
Protocol: ICMP(1)
Responder:
Source IP/port: 192.168.1.55/1792
Destination IP/port: 192.168.1.18/0
Protocol: ICMP(1)
State: ICMP_REQUEST
Application: OTHER
Start time: 2011-07-29 19:12:33 TTL: 55s
Initiator->Responder: 1 packets 60 bytes
# 显示所有的IPv4单播会话表项的详细信息。(IRF模式)
Initiator:
Protocol: TCP(6)
Responder:
Protocol: TCP(6)
State: TCP_SYN_SENT
Application: SSH
Initiator:
Protocol: ICMP(1)
Responder:
Protocol: ICMP(1)
State: ICMP_REQUEST
Application: OTHER
表1-7 display session table命令显示信息描述表
Initiator |
发起方到响应方的连接对应的单播会话信息 |
Responder |
响应方到发起方的连接对应的单播会话信息 |
Source IP/port |
源IP地址/端口号 |
目的IP地址/端口号 |
单播会话所属的MPLS L3VPN/二层转发时单播会话所属的VLAN ID/二层转发时单播会话所属的INLINE。未指定的参数则显示为“-” |
Protocol |
传输层协议类型,取值包括:DCCP、ICMP、ICMPv6、Raw IP、SCTP、TCP、UDP、UDP-Lite 括号中的数字表示协议号 |
Inbound interface |
报文的入接口 |
State |
单播会话状态 |
Application |
应用层协议类型,取值包括:FTP、DNS等,OTHER表示未知协议类型,其对应的端口为非知名端口 |
Start time |
单播会话创建时间 |
TTL |
单播会话剩余存活时间,单位为秒 |
Initiator->Responder |
发起方到响应方的报文数、报文字节数 |
Responder->Initiator |
响应方到发起方的报文数、报文字节数 |
Total sessions found |
当前查找到的单播会话表项总数 |
display session table ipv6命令用来显示IPv6单播会话表项信息。
独立运行模式:
display session table ipv6 [ slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ]
IRF模式:
display session table ipv6 [ chassis chassis-number slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ]
slot slot-number:显示指定单板上的IPv6单播会话表项,slot-number表示单板所在槽位号。不指定该参数时,显示所有单板上的IPv6单播会话表项。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的IPv6单播会话表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,显示所有成员设备的所有单板上的IPv6单播会话表项。(IRF模式)
source-ip start-source-ip [ end-source-ip ]:显示指定源IPv6地址的单播会话表项。其中,start-source-ip表示发起方到响应方会话的起始源IPv6地址,end-source-ip表示发起方到响应方会话的结束源IPv6地址。
destination-ip start-destination-ip [ end-destination-ip ]:显示指定目的IPv6地址的单播会话表项。其中,start-destination-ip表示发起方到响应方会话的起始目的IPv6地址,end-destination-ip表示发起方到响应方会话的结束目的IPv6地址。
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv6单播会话表项。其中,IPv6传输层协议类型可包括:DCCP、ICMPv6、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的IPv6单播会话表项。其中,source-port表示发起方到响应方IPv6会话的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的IPv6单播会话表项。其中,destination-port表示发起方到响应方IPv6单播会话的目的端口号,取值为0~65535。
verbose:显示IPv6单播会话表项的详细信息。不指定该参数时,显示IPv6单播会话表项的概要信息。
如果不指定任何参数,则显示所有的IPv6单播会话表项。
# 显示所有的IPv6单播会话表项的概要信息。(独立运行模式)
<Sysname> display session table ipv6
Slot 1:
Initiator:
Source IP/port: 2011::2/58473
Destination IP/port: 2011::8/32768
Protocol: IPV6-ICMP(58)
Total sessions found: 1
# 显示所有的IPv6单播会话表项的详细信息。(独立运行模式)
<Sysname> display session table ipv6 verbose
Slot 1:
Initiator:
Responder:
Source IP/port: 2011::8/58473
Destination IP/port: 2011::2/33024
State: ICMPV6_REQUEST
Application: OTHER
Start time: 2011-07-29 19:23:41 TTL: 55s
Initiator->Responder: 1 packets 104 bytes
# 显示所有的IPv6单播会话表项的概要信息。(IRF模式)
Initiator:
# 显示所有的IPv6单播会话表项的详细信息。(IRF模式)
Initiator:
Responder:
Application: OTHER
表1-8 display session table命令显示信息描述表
Initiator |
Responder |
Source IP/port |
源IP地址/端口号 |
目的IP地址/端口号 |
Protocol |
Inbound interface |
报文的入接口 |
State |
单播会话状态 |
Application |
Start time |
单播会话创建时间 |
TTL |
单播会话剩余存活时间,单位为秒 |
发起方到响应方的报文数、报文字节数 |
响应方到发起方的报文数、报文字节数 |
当前查找到的单播会话表项总数 |
display session table multicast ipv4命令用来显示IPv4组播会话表项信息。
独立运行模式:
display session table multicast ipv4 [ slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ]
IRF模式:
display session table multicast ipv4 [ chassis chassis-number slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ]
slot slot-number:显示指定单板上的IPv4组播会话表项,slot-number表示单板所在槽位号。不指定该参数时,显示所有单板上的IPv4组播会话表项。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的IPv4组播会话表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,显示所有成员设备的所有单板上的IPv4组播会话表项。(IRF模式)
source-ip start-source-ip [ end-source-ip ]:显示指定源IP地址的组播会话表项。其中,start-source-ip表示发起方到响应方组播会话的起始源IPv4地址,end-source-ip表示发起方到响应方组播会话的结束源IPv4地址。
destination-ip start-destination-ip [ end-destination-ip ]:显示指定目的IPv4地址的组播会话表项。其中,start-destination-ip表示发起方到响应方组播会话的起始目的IPv4地址,end-destination-ip表示发起方到响应方组播会话的结束目的IPv4地址。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv4组播会话表项。其中,IPv4传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的IPv4组播会话表项。其中,source-port表示发起方到响应方组播会话的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的IPv4组播会话表项。其中,destination-port表示发起方到响应方组播会话的目的端口号,取值为0~65535。
verbose:显示IPv4组播会话表项的详细信息。不指定该参数时,显示IPv4组播会话表项的概要信息。
如果不指定任何参数,则显示所有的IPv4组播会话表项。
# 显示所有的IPv4组播会话表项的概要信息。(独立运行模式)
<Sysname> display session table multicast ipv4
Slot 1:
Total sessions found: 0
Slot 2:
Inbound initiator:
Source IP/port: 3.3.3.4/1609
Destination IP/port: 232.0.0.1/1025
Protocol: UDP(17)
Outbound interface list:
GigabitEthernet1/0/3
Total sessions found: 3
# 显示所有的IPv4组播会话表项的详细信息。(独立运行模式)
<Sysname> display session table multicast ipv4 verbose
Slot 1:
Slot 2:
Inbound initiator:
Protocol: UDP(17)
Inbound responder:
Source IP/port: 232.0.0.1/1025
Destination IP/port: 3.3.3.4/1609
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 15:59:22 TTL: 18s
Initiator->Responder: 1 packets 84 bytes
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
Outbound interface: GigabitEthernet1/0/2
State: UDP_OPEN
Application: OTHER
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
Outbound interface: GigabitEthernet1/0/3
State: UDP_OPEN
Application: OTHER
表1-9 display session table multicast ipv4命令显示信息描述表
Inbound initiator |
入接口上发起方到响应方的连接对应的组播会话信息 |
Inbound responder |
入接口上响应方到发起方的连接对应的组播会话信息 |
Outbound initiator |
出接口上发起方到响应方的连接对应的组播会话信息 |
Outbound responder |
出接口上响应方到发起方的连接对应的组播会话信息 |
Source IP/port |
源IP地址/端口号 |
目的IP地址/端口号 |
组播会话所属的MPLS L3VPN/二层转发时会话所属的VLAN ID/二层转发时会话所属的INLINE。未指定的参数则显示为“-” |
Protocol |
传输层协议类型,取值包括:DCCP、ICMP、Raw IP、SCTP、TCP、UDP、UDP-Lite,括号中的数字表示协议号 |
State |
组播会话状态 |
Application |
Start time |
组播会话创建时间 |
TTL |
组播会话剩余存活时间,单位为秒 |
Inbound interface |
发起方到响应方首报文的入接口 |
Outbound interface |
发起方到响应方首报文的出接口 |
Outbound interface list |
发起方到响应方首报文的出接口列表 |
发起方到响应方的报文数、报文字节数 |
当前查找到的组播会话表项总数 |
display session table multicast ipv6命令用来显示IPv6组播会话表项信息。
独立运行模式:
display session table multicast ipv6 [ slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ]
IRF模式:
display session table multicast ipv6 [ chassis chassis-number slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ]
slot slot-number:显示指定单板上的IPv6组播会话表项,slot-number表示单板所在槽位号。不指定该参数时,显示所有单板上的IPv6组播会话表项。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的IPv6组播会话表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,显示所有成员设备的所有单板上的IPv6组播会话表项。(IRF模式)
source-ip start-source-ip [ end-source-ip ]:显示指定源IPv6地址的组播会话表项。其中,start-source-ip表示发起方到响应方组播会话的起始源IPv6地址,end-source-ip表示发起方到响应方组播会话的结束源IPv6地址。
destination-ip start-destination-ip [ end-destination-ip ]:显示指定目的IPv6地址的组播会话表项。其中,start-destination-ip表示发起方到响应方组播会话的起始目的IPv6地址,end-destination-ip表示发起方到响应方组播会话的结束目的IPv6地址。
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv6组播会话表项。其中,IPv6传输层协议类型可包括:DCCP、ICMPv6、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的IPv6组播会话表项。其中,source-port表示发起方到响应方IPv6组播会话的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的IPv6组播会话表项。其中,destination-port表示发起方到响应方IPv6组播会话的目的端口号,取值为0~65535。
verbose:显示IPv6组播会话表项的详细信息。不指定该参数时,显示IPv6组播会话表项的概要信息。
如果不指定任何参数,则显示所有的IPv6组播会话表项。
# 显示所有的IPv6组播会话表项的概要信息。(独立运行模式)
<Sysname> display session table multicast ipv6
Slot 1:
Slot 2:
Inbound initiator:
Source IP/port: 3::4/1617
Destination IP/port: FF0E::1/1025
Protocol: UDP(17)
# 显示所有的IPv6组播会话表项的详细信息。(独立运行模式)
<Sysname> display session table multicast ipv6 verbose
Slot 1:
Slot 2:
Inbound initiator:
Protocol: UDP(17)
Inbound responder:
Source IP/port: FF0E::1/1025
Destination IP/port: 3::4/1617
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 16:10:58 TTL: 23s
Initiator->Responder: 5 packets 520 bytes
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
表1-10 display session table multicast ipv6命令显示信息描述表
Inbound initiator |
Inbound responder |
Source IP/port |
源IP地址/端口号 |
目的IP地址/端口号 |
Protocol |
传输层协议类型,取值包括:DCCP、ICMPv6、Raw IP、SCTP、TCP、UDP、UDP-Lite,括号中的数字表示协议号 |
State |
组播会话状态 |
Application |
Start time |
组播会话创建时间 |
TTL |
组播会话剩余存活时间,单位为秒 |
Inbound interface |
发起方到响应方首报文的入接口 |
发起方到响应方首报文的出接口 |
发起方到响应方首报文的出接口列表 |
发起方到响应方的报文数、报文字节数 |
当前查找到的组播会话表项总数 |
reset session relation-table命令用来删除关联表项。
独立运行模式:
reset session relation-table [ ipv4 | ipv6 ] [ slot slot-number ]
IRF模式:
reset session relation-table [ ipv4 | ipv6 ] [ chassis chassis-number slot slot-number ]
ipv4:删除IPv4关联表项。
ipv6:删除IPv6关联表项。
slot slot-number:删除指定单板上的关联表项,slot-number表示单板所在槽位号。不指定该参数时,删除所有单板上的关联表项。(独立运行模式)
chassis chassis-number slot slot-number:删除指定成员设备上指定单板的关联表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,删除所有成员设备的所有单板上的关联表项。(IRF模式)
如果不指定ipv4和ipv6,则删除所有的IPv4和IPv6关联表项。
# 删除所有的IPv4关联表项。
<Sysname> reset session relation-table ipv4
· display session relation-table
reset session statistics命令用来清除单播会话统计信息。
独立运行模式:
reset session statistics [ slot slot-number ]
IRF模式:
reset session statistics [ chassis chassis-number slot slot-number ]
slot slot-number:清除指定单板的上单播会话统计信息,slot-number表示单板所在槽位号。不指定该参数时,清除所有单板上的单播会话统计信息。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备的指定单板上的单播会话统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,清除所有成员设备的所有单板上的单播会话统计信息。(IRF模式)
# 清除所有的单播会话统计信息。
<Sysname> reset session statistics
· display session statistics
reset session statistics multicast命令用来清除组播会话统计信息。
独立运行模式:
reset session statistics multicast [ slot slot-number ]
IRF模式:
reset session statistics multicast [ chassis chassis-number slot slot-number ]
slot slot-number:清除指定单板的上组播会话统计信息,slot-number表示单板所在槽位号。不指定该参数时,清除所有单板上的组播会话统计信息。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备的指定单板上的组播会话统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,清除所有成员设备的所有单板上的组播会话统计信息。(IRF模式)
# 清除所有的组播会话统计信息。
<Sysname> reset session statistics multicast
· display session statistics multicast
reset session table命令用来删除所有单播会话表项,包括IPv4和IPv6单播会话表项。
独立运行模式:
reset session table [ slot slot-number ]
IRF模式:
reset session table [ chassis chassis-number slot slot-number ]
slot slot-number:删除指定单板上的所有单播会话表项,slot-number表示单板所在槽位号。不指定该参数时,删除所有单板上的所有单播会话表项。(独立运行模式)
chassis chassis-number slot slot-number:删除指定成员设备的指定单板上的所有单播会话表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,删除所有成员设备的所有单板上的所有单播会话表项。(IRF模式)
# 删除所有单播会话表项。
<Sysname> reset session table
reset session table ipv4命令用来删除IPv4单播会话表项。
独立运行模式:
reset session table ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
IRF模式:
reset session table ipv4 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
slot slot-number:删除指定单板上的IPv4单播会话表项,slot-number表示单板所在槽位号。不指定该参数时,删除所有单板上的IPv4单播会话表项。(独立运行模式)
chassis chassis-number slot slot-number:删除指定成员设备的指定单板上的IPv4单播会话表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,删除所有成员设备的所有单板上的IPv4单播会话表项。(IRF模式)
source-ip source-ip:删除指定源IP地址的IPv4单播会话表项。其中,source-ip表示发起方到响应方会话的源IPv4地址。
destination-ip destination-ip:删除指定目的IP地址的IPv4单播会话表项。其中,destination-ip表示发起方到响应方会话的目的IPv4地址。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:删除指定协议类型的单播会话表项。其中,IPv4传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:删除指定源端口号的IPv4单播会话表项。其中,source-port表示发起方到响应方会话的源端口号,取值为0~65535。
destination-port destination-port:删除指定目的端口号的IPv4单播会话表项。其中,destination-port表示发起方到响应方会话的目的端口号,取值为0~65535。
vpn-instance vpn-instance-name:删除指定VPN实例的IPv4单播会话表项。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。不指定该参数时,删除公网中的IPv4单播会话表项。
如果不指定任何参数,则删除所有公网中的IPv4单播会话表项。
# 删除所有IPv4单播会话表项。
<Sysname> reset session table ipv4
# 删除所有发起方源IP地址为10.10.10.10的IPv4单播会话表项。
<Sysname> reset session table ipv4 source-ip 10.10.10.10
· display session table ipv4
reset session table ipv6命令用来删除IPv6单播会话表项。
独立运行模式:
reset session table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
IRF模式:
reset session table ipv6 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
slot slot-number:删除指定单板上的IPv6单播会话表项,slot-number表示单板所在槽位号。不指定该参数时,删除所有单板上的IPv6单播会话表项。(独立运行模式)
chassis chassis-number slot slot-number:删除指定成员设备的指定单板上的IPv6单播会话表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,删除所有成员设备的所有单板上的IPv6单播会话表项。(IRF模式)
source-ip source-ip:删除指定源IP地址的IPv6单播会话表项。其中,source-ip表示发起方到响应方会话的源IPv6地址。
destination-ip destination-ip:删除指定目的IP地址的IPv6单播会话表项。其中,destination-ip表示发起方到响应方会话的目的IPv6地址。
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }:删除指定协议类型的IPv6单播会话表项。其中,IPv6传输层协议类型可包括:DCCP、ICMPv6、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:删除指定源端口号的IPv6单播会话表项。其中,source-port表示发起方到响应方会话的源端口号,取值为0~65535。
destination-port destination-port:删除指定目的端口号的IPv6单播会话表项。其中,destination-port表示发起方到响应方会话的目的端口号,取值为0~65535。
vpn-instance vpn-instance-name:删除指定VPN实例的IPv6单播会话表项。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。不指定该参数时,删除公网中的IPv6单播会话表项。
如果不指定任何参数,则删除所有公网中的IPv6单播会话表项。
# 删除所有IPv6单播会话表项。
<Sysname> reset session table ipv6
# 删除所有发起方源IP地址为2011::0002的IPv6单播会话表项。
<Sysname> reset session table ipv6 source-ip 2011::0002
· display session table ipv6
reset session table multicast命令用来删除所有组播会话表项,包括IPv4和IPv6组播会话表项。
独立运行模式:
reset session table multicast [ slot slot-number ]
IRF模式:
reset session table multicast [ chassis chassis-number slot slot-number ]
slot slot-number:删除指定单板上的所有组播会话表项,slot-number表示单板所在槽位号。不指定该参数时,删除所有单板上的所有组播会话表项。(独立运行模式)
chassis chassis-number slot slot-number:删除指定成员设备的指定单板上的所有组播会话表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,删除所有成员设备的所有单板上的所有组播会话表项。(IRF模式)
# 删除所有组播会话表项。
<Sysname> reset session table multicast
· display session table multicast ipv4
· display session table multicast ipv6
reset session table multicast ipv4命令用来删除IPv4组播会话表项。
独立运行模式:
reset session table multicast ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
IRF模式:
reset session table multicast ipv4 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
slot slot-number:删除指定单板上的IPv4组播会话表项,slot-number表示单板所在槽位号。不指定该参数时,删除所有单板上的IPv4组播会话表项。(独立运行模式)
chassis chassis-number slot slot-number:删除指定成员设备的指定单板上的IPv4组播会话表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,删除所有成员设备的所有单板上的IPv4组播会话表项。(IRF模式)
source-ip source-ip:删除指定源IP地址的IPv4组播会话表项。其中,source-ip表示发起方到响应方组播会话的源IPv4地址。
destination-ip destination-ip:删除指定目的IP地址的IPv4组播会话表项。其中,destination-ip表示发起方到响应方组播会话的目的IPv4地址。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:删除指定协议类型的组播会话表项。其中,IPv4传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:删除指定源端口号的IPv4组播会话表项。其中,source-port表示发起方到响应方组播会话的源端口号,取值为0~65535。
destination-port destination-port:删除指定目的端口号的IPv4组播会话表项。其中,destination-port表示发起方到响应方组播会话的目的端口号,取值为0~65535。
vpn-instance vpn-instance-name:删除指定VPN实例的IPv4组播会话表项。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。不指定该参数时,删除公网中的IPv4组播会话表项。
如果不指定任何参数,则删除所有公网中的IPv4组播会话表项。
# 删除所有IPv4组播会话表项。
<Sysname> reset session table multicast ipv4
# 删除所有发起方源IP地址为10.10.10.10的IPv4组播会话表项。
<Sysname> reset session table multicast ipv4 source-ip 10.10.10.10
reset session table multicast ipv6命令用来删除IPv6组播会话表项。
独立运行模式:
reset session table multicast ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
IRF模式:
reset session table multicast ipv6 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
slot slot-number:删除指定单板上的IPv6组播会话表项,slot-number表示单板所在槽位号。不指定该参数时,删除所有单板上的IPv6组播会话表项。(独立运行模式)
chassis chassis-number slot slot-number:删除指定成员设备的指定单板上的IPv6组播会话表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,删除所有成员设备的所有单板上的IPv6组播会话表项。(IRF模式)
source-ip source-ip:删除指定源IP地址的IPv6组播会话表项。其中,source-ip表示发起方到响应方组播会话的源IPv6地址。
destination-ip destination-ip:删除指定目的IP地址的IPv6组播会话表项。其中,destination-ip表示发起方到响应方组播会话的目的IPv6地址。
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }:删除指定协议类型的IPv6组播会话表项。其中,IPv6传输层协议类型可包括:DCCP、ICMPv6、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:删除指定源端口号的IPv6组播会话表项。其中,source-port表示发起方到响应方组播会话的源端口号,取值为0~65535。
destination-port destination-port:删除指定目的端口号的IPv6组播会话表项。其中,destination-port表示发起方到响应方组播会话的目的端口号,取值为0~65535。
vpn-instance vpn-instance-name:删除指定VPN实例的IPv6组播会话表项。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。不指定该参数时,删除公网中的IPv6组播会话表项。
如果不指定任何参数,则删除所有公网中的IPv6组播会话表项。
# 删除所有IPv6组播会话表项。
<Sysname> reset session table multicast ipv6
# 删除所有发起方源IP地址为2011::0002的IPv6组播会话表项。
<Sysname> reset session table multicast ipv6 source-ip 2011::0002
session aging-time application命令用来设置应用层协议的会话老化时间。
undo session aging-time application命令用来恢复缺省情况。如果不指定应用层协议类型,则将所有应用层协议的会话老化时间都恢复为缺省情况。
session aging-time application { dns | ftp | gtp | h225 | h245 | ils | mgcp | nbt | pptp | ras | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp } time-value
undo session aging-time application [ dns | ftp | gtp | h225 | h245 | ras | rtsp | sip | tftp ]
各应用层协议的会话老化时间为:
· dns:1秒
· ftp:3600秒
· gtp:60秒
· h225:3600秒
· h245:3600秒
· ils:3600秒
· mgcp:60秒
· nbt:3600秒
· pptp:3600秒
· ras:300秒
· rsh:60秒
· rtsp:3600秒
· sccp:3600秒
· sip:300秒
· sqlnet:600秒
· tftp:60秒
· xdmcp:3600秒
dns:表示DNS协议的会话老化时间。
ftp:表示FTP协议的会话老化时间。
gtp:表示GTP(GPRS Tunneling Protocol,GPRS隧道协议)协议的会话老化时间。
h225:表示H.225协议的会话老化时间。
h245:表示H.245协议的会话老化时间。
ils:表示ILS(Internet Locator Service,互联网定位服务)协议的会话老化时间。
mgcp:表示MGCP(Media Gateway Control Protocol,媒体网关控制协议)协议的会话老化时间。
nbt:表示NBT(NetBIOS over TCP/IP,基于TCP/IP的网络基本输入输出系统)协议的会话老化时间。
pptp:表示PPTP(Point-to-Point Tunneling Protocol,点到点隧道协议)协议的会话老化时间。
ras:表示RAS协议的会话老化时间。
rsh:表示RSH(Remote Shell,远程外壳)协议的会话老化时间。
rtsp:表示RTSP(Real Time Streaming Protocol,实时流协议)协议的会话老化时间。
sccp:表示SCCP(Skinny Client Control Protocol,瘦小客户端控制协议)协议的会话老化时间。
sip:表示SIP协议的会话老化时间。
sqlnet:表示SQLNET协议的会话老化时间。
tftp:表示TFTP协议的会话老化时间。
xdmcp:表示XDMCP(X Display Manager Control Protocol,X显示监控)协议的会话老化时间。
time-value:指定的老化时间,取值范围为5~100000,单位为秒。如果指定应用层协议为dns,则此参数的取值范围为1~100000。
应用层协议的会话老化时间仅在会话进入稳态时生效(TCP会话的稳态为TCP-EST,UDP会话的稳态为UDP-READY)。
会话进入稳态后,如果该会话属于本命令中指定的一种应用层协议,则此会话的老化时间为指定的应用层协议老化时间;否则为传输层协议状态的老化时间(由session aging-time state命令配置)。
对TCP会话来说,如果会话符合长连接会话的规则,那么该会话稳态的老化时间为长连接老化时间(由session persistent acl命令配置)。
# 设置FTP协议的会话老化时间为1800秒。
[Sysname] session aging-time application ftp 1800
· display session aging-time application
· session persistent acl
session aging-time state命令用来设置各协议状态的会话老化时间。
undo session aging-time state命令用来恢复缺省情况,如果不指定任何参数,则将所有协议状态的会话老化时间都恢复为缺省情况。
session aging-time state { fin | icmp-reply | icmp-request | rawip-open | rawip-ready | syn | tcp-est | udp-open | udp-ready } time-value
undo session aging-time state [ fin | icmp-reply | icmp-request | rawip-open | rawip-ready | syn | tcp-est | udp-open | udp-ready ]
各协议状态的会话老化时间为:
· fin:30秒
· icmp-reply:30秒
· icmp-request:60秒
· rawip-open:30秒
· rawip-ready:60秒
· syn:30秒
· tcp-est:3600秒
· udp-open:30秒
· udp-ready:60秒
fin:表示TCP协议FIN-WAIT状态的会话老化时间。
icmp-reply:表示ICMP协议REPLY状态的会话老化时间。
icmp-request:表示ICMP协议REQUEST状态的会话老化时间。
rawip-open:表示RAWIP-OPEN状态的会话老化时间。
rawip-ready:表示RAWIP-READY状态的会话老化时间。
syn:表示TCP协议SYN-SENT和SYN-RCV状态的会话老化时间。
tcp-est:表示TCP协议ESTABLISHED状态的会话老化时间。
udp-open:表示UDP协议OPEN状态的会话老化时间。
udp-ready:表示UDP协议READY状态的会话老化时间。
会话进入稳态后,如果该会话属于session aging-time application命令中指定的一种应用层协议,则此会话的老化时间为指定的应用层协议老化时间;否则为四层协议状态的老化时间(由session aging-time state命令配置)。
# 设置TCP协议SYN-SENT和SYN-RCV状态的老化时间为60秒。
[Sysname] session aging-time state syn 60
· display session aging-time state
· session aging-time application
session log bytes-active命令用来配置输出会话日志的字节数流量阈值。
undo session log bytes-active命令用来恢复缺省情况。
session log bytes-active bytes-value
不依据字节数流量阈值发送会话日志。
bytes-value:表示发送会话日志的字节数阈值,取值范围为1~1000,单位为兆字节。
如果设置的字节数阈值为n,则一个会话每传输n兆个字节整数倍时,设备就输出一次相应的会话日志。
同时配置了时间阈值和流量阈值的情况下,只要有一个阈值到达,就会输出相应的会话日志,并将所有的阈值统计信息清零。
同时只能有一种流量阈值有效,以最后一次配置的阈值类型为准,例如,先配置报文数阈值再配置字节数阈值,则当前有效的阈值是字节数阈值,只会输出达到字节数阈值的会话日志。
# 设置输出会话日志的字节数流量阈值为10兆字节。
[Sysname] session log bytes-active 10
· session log enable
· session log time-active
session log enable命令用来开启会话日志功能。
undo session log enable命令用来关闭会话日志功能。
session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
undo session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
会话日志功能处于关闭状态。
ipv4:表示IPv4会话日志。
ipv6:表示IPv6会话日志。
acl acl-number:对与指定ACL相匹配的会话输出会话日志,其中acl-number表示ACL的编号,取值范围为2000~3999。如果不指定ACL,则表示允许输出经过接口的所有IPv4或IPv6会话的日志。
inbound:指定输出入方向的会话日志。
outbound:指定输出出方向的会话日志。
可配置仅输出单方向的会话日志,也可以配置输出双向的会话日志。每个方向上最多可以配置一个IPv4 ACL规则和一个IPv6 ACL规则。
在未指定相关阈值(流量阈值、时间阈值)的情况下,若会话日志功能处于开启状态,则仅在会话表创建和删除的时候分别输出一次会话日志。
# 在GigabitEthernet1/0/1接口下开启会话日志功能,指定输出此接口入方向上的所有IPv4会话日志。
[Sysname-GigabitEthernet1/0/1] session log enable ipv4 inbound
# 在GigabitEthernet1/0/2接口下开启会话日志功能,指定输出此接口出方向上匹配ACL 2050的IPv4会话日志。
[Sysname-GigabitEthernet1/0/2] session log enable ipv4 acl 2050 outbound
# 在GigabitEthernet1/0/3接口下开启会话日志功能,指定输出此接口出方向上匹配ACL 2050的IPv6会话日志。
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] session log enable ipv6 acl 2050 outbound
· session log bytes-active
· session log packets-active
session log packets-active命令用来配置输出会话日志的报文数流量阈值。
undo session log packets-active命令用来恢复缺省情况。
session log packets-active packets-value
不依据报文数流量阈值发送会话日志。
packets-value:表示发送会话日志的报文数阈值,取值范围为1~1000,单位为兆包。
如果设置的报文数阈值为n,则一个会话每收发n兆个报文,设备就输出一次相应的会话日志。
# 设置输出会话日志的流量阈值为10兆报文数。
[Sysname] session log packets-active 10
session log time-active命令用来配置输出会话日志的时间阈值。
undo session log time-active用来恢复缺省情况。
session log time-active time-value
不依据时间阈值发送会话日志。
time-value:表示发送会话日志的时间阈值,取值范围为10~120,单位为分钟,只能为10的整数倍。
如果设置的时间阈值为n,则每经过n分钟,设备就输出一次相应的会话日志。
# 设置输出会话日志的时间阈值为50分钟。
<Sysname> system
[Sysname] session log time-active 50
session persistent acl命令用来配置长连接会话规则。
undo session persistent acl命令用来恢复缺省情况。
session persistent acl [ ipv6 ] acl-number [ aging-time time-value ]
undo session persistent acl [ ipv6 ]
无长连接会话规则。
ipv6:指定IPv6 ACL。如果没有指定本参数,则表示IPv4 ACL。
acl-number:ACL的编号,取值范围为2000~3999。
aging-time time-value:长连接会话的老化时间。其中,time-value表示指定的老化时间,取值范围为0~360,单位为小时,缺省值为24。0表示永不老化。
长连接老化时间仅在TCP会话进入稳态(TCP-EST状态)时生效。在TCP会话处于稳态时,长连接老化时间具有最高的优先级,其次为应用层协议老化时间,最后为协议状态老化时间。
对于设置为永不老化的长连接会话,不会因为没有报文命中而被老化删除,只有当会话的发起方或响应方主动发起关闭连接请求或管理员使用reset session table命令手动删除该会话时,才会被删除。
长连接会话的配置仅影响后续生成的会话,对于已经生效的会话不产生作用。
# 配置符合ACL 2000规则的IPv4会话为长连接,老化时间为72小时。
[Sysname] session persistent acl 2000 aging-time 72
# 配置符合ACL 3000规则的IPv6会话为长连接,老化时间为100小时。
[Sysname] session persistent acl ipv6 3000 aging-time 100
session statistics enable命令用来开启会话统计功能。
undo session statistics enable命令用来关闭会话统计功能。
会话统计功能处于关闭状态。
开启会话统计功能之后,设备将对收到和发送的基于会话的业务报文数目和报文字节数进行统计,基于会话的报文统计信息可以通过display session table命令查看,基于报文类型的报文统计信息可以通过display session statistics命令查看。
# 开启会话统计功能。
[Sysname] session statistics enable
