01-Probe命令
本章节下载: 01-Probe命令 (328.45 KB)
1.1.1 cellular-diag enable type filter
1.1.2 cellular-diag enable type virtual-com
1.2.2 debugging system internal adj4
1.3.1 debugging system internal arp event
1.3.2 debugging system internal arp features
1.3.3 debugging system internal arp notify
1.3.4 debugging system internal arp sync
1.3.5 debugging system internal fib prefix
1.3.6 debugging system internal fib vn
1.3.7 debugging system internal vlan
1.3.8 display fastforward session table
1.3.9 display hardware internal physical cellular
1.3.10 display system internal acl
1.3.11 display system internal adj4 entry
1.3.12 display system internal adj4 statistics
1.3.13 display system internal arp
1.3.14 display system internal arp ifcb
1.3.15 display system internal arp ip-address
1.3.16 display system internal arp machash
1.3.17 display system internal arp probe
1.3.18 display system internal arp rbhash
1.3.19 display system internal arp reload
1.3.20 display system internal arp rule
1.3.21 display system internal arp snooping
1.3.22 display system internal arp source-suppression cache
1.3.23 display system internal arp statistics
1.3.24 display system internal arp suppression xconnect-group verbose
1.3.25 display system internal arp vlan
1.3.26 display system internal aspf statistics
1.3.27 display system internal attack-defense scan stat-nodes ip
1.3.28 display system internal client-verify http redirect-node
1.1.1 display system internal control-plane statistics
1.3.29 display system internal dbm
1.3.30 display system internal ethernet character
1.3.31 display system internal ethernet controlblock
1.3.32 display system internal fib prefix
1.3.33 display system internal fib prefix entry-status
1.3.34 display system internal fib prefix ip
1.3.35 display system internal fib running-status
1.3.36 display system internal fib statistics
1.3.37 display system internal fib vn
1.3.38 display system internal fib vn entry-status
1.3.39 display system internal fib vn reference
1.3.40 display system internal ha service
1.3.41 display system internal ha service-group
1.3.42 display system internal ha statistics
1.3.43 display system internal ifmgr down
1.3.44 display system internal ifmgr entry
1.3.45 display system internal ifmgr event
1.3.46 display system internal ifmgr hotplug
1.3.47 display system internal ifmgr index
1.3.48 display system internal ifmgr list
1.3.49 display system internal ifmgr name
1.3.50 display system internal ifmgr type
1.3.51 display system internal ip address
1.3.52 display system internal ip fast-forwarding cache verbose
1.3.53 display system internal ip source binding
1.3.54 display system internal kernel memory dump
1.3.55 display system internal kernel memory pool
1.3.56 display system internal mac-address configuration
1.3.57 display system internal mac-address learned
1.3.58 display system internal mac-address protocol
1.3.59 display system internal mac-address statistics
1.3.60 display system internal mac-forwarding cache ip verbose
1.3.61 display system internal mac-forwarding controlblock
1.3.62 display system internal nat
1.3.63 display system internal object-group
1.3.64 display system internal object-policy
1.3.65 display system internal ppp statistics
1.3.66 display system internal pppoe-server statistics
1.3.67 display system internal rawip
1.3.68 display system internal rib event attribute
1.3.69 display system internal rib event policy
1.3.70 display system internal rib event prefix
1.3.71 display system internal rib event protocol
1.3.72 display system internal rib event statistics
1.3.73 display system internal rib ftn
1.3.74 display system internal rib ftn summary
1.3.75 display system internal rib log
1.3.76 display system internal rib memory
1.3.77 display system internal rib nib log
1.3.78 display system internal rib prefix
1.3.79 display system internal rib summary
1.3.80 display system internal route-direct interface
1.3.81 display system internal route-direct log
1.3.82 display system internal route-static nib log
1.3.83 display system internal startup cache
1.3.84 display system internal tcp
1.3.85 display system internal tcp port-info
1.3.86 display system internal udp
1.3.87 display system internal udp port-info
1.3.88 display system internal vlan
1.6.1 memory boundary-check enable
1.6.2 memory boundary-check scan
1.8.1 reset system internal adj4 statistics
1.8.2 reset system internal arp statistics
1.8.3 reset system internal aspf statistics
1.8.4 reset system internal control-plane statistics
1.8.5 reset system internal fib statistics
1.8.6 reset system internal mac-address statistics
1.8.7 reset system internal ppp statistics
1.8.8 reset system internal pppoe-server statistics
1.8.9 reset system internal rib log
1.8.10 reset system internal rib nib log
1.8.11 reset system internal rib summary
1.8.12 reset system internal route-direct log
1.8.13 reset system internal route-static nib log
本手册中的命令,仅供专业技术人员进行问题定位和调试所用,不建议用户使用。
cellular-diag enable type filter命令用来开启V7系统3G/4G离线诊断功能。
cellular-diag enable type filter filter-file-name { local file-url | remote tftp-server-address tftp-file-name } cellular interface-number
undo cellular-diag enable
probe视图
filter-file-name:指定过滤文件名。
file-url:指定输出文件名。
tftp-server-address:指定TFTP服务器地址。
tftp-file-name:指定TFTP服务器上保存的文件名。
interface-number:指定Cellular接口所占用的接口号。
cellular-diag enable type virtual-com命令用来开启V7系统3G/4G在线诊断功能。
cellular-diag enable type virtual-com port-number cellular interface-number
probe视图
port-number: 指定虚拟口编号,PC上的管理软件使用此端号访问模块。用十进制数表示,取值范围为1024~65535。
debugging ha命令用来打开HA各子模块的调试信息开关。
undo debugging ha命令用来关闭HA各子模块的调试信息开关。
debugging ha { all | config | fsm | policy | standby | sync }
undo debugging ha { all | config | fsm | policy | standby | sync }
HA各子模块的调试信息开关处于关闭状态。
all:HA所有模块的信息。
config:config子模块的信息。
fsm:FSM子模块的信息。
policy:policy子模块的信息。
standby:备份HA模块的信息。
sync:sync子模块的信息。
# 打开HA FSM子模块的调试开关。
debugging system internal adj4命令用来打开IPv4邻接表调试开关。
undo debugging system internal adj4命令用来关闭IPv4邻接表调试开关。
debugging system internal adj4 { hardware | bind | notify | entry }
undo debugging system internal adj4 { hardware | bind | notify | entry }
IPv4邻接表调试开关处于关闭状态。
probe视图
hardware:打开IPv4邻接表下驱动调试功能。
bind:打开VN/NHLFE表项绑定IPv4邻接表调试功能。
notify:打开IPv4邻接表项变化时,反刷VN和NHLFE表项调试功能。
entry:打开IPv4邻接表项更新时调试功能。
debugging system internal arp event命令用来打开ARP事件调试信息开关。
undo debugging system internal arp event命令用来关闭ARP事件调试信息开关。
ARP事件调试信息开关处于关闭状态。
Probe视图
debugging system internal arp features命令用来打开ARP子特性的调试信息开关。
undo debugging system internal arp features命令用来关闭ARP子特性的调试信息开关。
debugging system internal arp features { notify | packet }
undo debugging system internal arp features { notify | packet }
ARP子特性的调试信息开关处于关闭状态。
Probe视图
notify:表示ARP子特性的外部通知调试开关。
packet:表示ARP子特性报文调试开关。
debugging system internal arp notify命令用来打开ARP的外部通知调试信息开关。
undo debugging system internal arp notify命令用来关闭ARP的外部通知调试信息开关。
ARP的外部通知调试信息开关处于关闭状态。
Probe视图
debugging system internal arp sync命令用来打开ARP表项的同步调试开关。
undo debugging system internal arp sync命令用来关闭ARP表项的同步调试开关。
ARP表项的同步调试信息开关处于关闭状态。
Probe视图
debugging system internal fib 命令用来打开FIB调试信息开关。
undo debugging system internal fib命令用来关闭FIB调试信息开关。
debugging system internal fib prefix { all | message | hardware }
undo debugging system internal fib prefix { all | message | hardware }
FIB 调试信息开关处于关闭状态。
Probe视图
all:打开所有调试开关。
message:打开message调试开关,打印路由下发和板间同步的IPv4 FIB前缀消息。
hardware:打开hardware调试开关,打印下发驱动信息以及驱动返回的消息。
debugging system internal fib vn 命令用来打开VN调试信息开关。
undo debugging system internal fib vn命令用来关闭VN调试信息开关。
debugging system internal fib vn { all | message | hardware | bind | notify}
undo d debugging system internal fib vn { all | message | hardware | bind | notify }
VN 调试信息开关处于关闭状态。
Probe视图
all:打开所有调试开关。
message:打开message调试开关,显示路由下发和板间同步的vn消息。
hardware:打开hardware调试开关,显示下发驱动的信息以及驱动返回的信息。
bind:打开bind调试开关,显示前缀绑定vn,vn绑定adj/nhlfe的相关信息。
notify:打开notify调试开关,显示adj/nhlfe通知vn,以及vn通知前缀的信息。
debugging system internal vlan命令用来打开VLAN的调试开关。
undo debugging system internal vlan命令用来关闭VLAN的调试开关。
debugging system internal vlan { all | error | event | execution | hardware }
undo debugging system internal vlan { all | error | event | execution | hardware }
VLAN的调试开关处于关闭状态。
Probe视图
all:表示VLAN的所有调试信息开关。
error:表示VLAN的错误调试信息开关。
event:表示VLAN的事件调试信息开关。
execution:表示VLAN的执行调试信息开关。
hardware:表示VLAN的硬件调试信息开关。
display fastforward session table命令用来显示未经过安全业务处理的会话表项。目前,设备上的安全业务包括NAT、ASPF、连接数限制、APR。
Probe视图
ipv4:显示IPv4会话表项。
source-ip source-ip:显示指定源IP地址的会话表项。其中,source-ip表示发起方到响应方会话的源IP地址。
destination-ip destination-ip:显示指定目的IP地址的会话表项。其中,destination-ip表示发起方到响应方会话的目的IP地址。
verbose:显示详细的会话表项。不指定该参数表示显示会话表项的概要信息。
如果除ipv4外不指定任何参数,则显示所有未经过安全业务处理的IPv4会话表项。
display hardware internal physical cellular命令用来实现显示设备上已打开的诊断相关信息。
display hardware internal physical cellular interface-number diag_info
probe视图
display system internal acl命令用来显示ACL的配置和运行情况。
display system internal acl [ mac ] { acl-number | name acl-name }
Probe视图
mac:指定ACL类型为二层ACL。
acl-number:显示指定编号的ACL的配置和运行情况。acl-number表示ACL的编号,取值范围及其代表的ACL类型如下:
· 2000~2999:表示IPv4基本ACL。
· 3000~3999:表示IPv4高级ACL。
· 4000~4999:表示二层ACL。
name acl-name:显示指定名称的ACL的配置和运行情况。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。对于基本ACL或高级ACL,表示IPv4基本ACL或IPv4高级ACL的名称。
display system internal adj4 entry 命令用来显示指定IPv4邻接表项的详细信息。
display system internal adj4 entry ip-address interface interface-type interface-number
probe视图
ip-address:IPv4邻接表项中的IP地址。
interface interface-type interface-number:IPv4邻接表项所对应的三层接口类型和接口号。
display system internal adj4 statistics命令用来显示IPv4邻接表项的统计信息。
probe视图
display system internal arp命令用来显示对应设备或单板上学习到的ARP表项信息或表项个数。
display system internal arp { all | static | dynamic | multiport } [ count ]
Probe视图
all: 命令用来显示所有ARP表项信息或表项个数。
static: 用来显示静态ARP表项信息或表项个数。
dynamic: 用来显示动态ARP表项信息或表项个数。
multiport: 用来显示多端口ARP表项信息或表项个数。
count:用来显示ARP表项个数。
display system internal arp ifcb命令用来查看指定板上二层或三层接口ARP控制块信息
display system internal arp ifcb interface interface-type interface-number
Probe视图
interface interface-type interface-number :显示指定二层或三层接口上的ARP控制块信息,interface-type interface-number为接口类型和接口编号。
display system internal arp ip-address命令用来显示指定板上指定IP的ARP表项信息。
Probe视图
ip-address: 用来显示指定IP的ARP表项信息。
display system internal arp machash命令用来显示指定板上machash表项信息。
display system internal arp machash vlan vlan-id ip ip-address
Probe视图
vlan vlan-id: 显示指定VLAN上machash表项信息。vlan-id表示指定VLAN的id。
ip ip-address:显示指定IP上machash表项信息。ip-address表示指定IP的IP地址
display system internal arp probe命令用来显示指定板上ARP探测链表项。
Probe视图
display system internal arp rbhash命令用来显示指定板上rbhash表项信息。
display system internal arp rbhash vlan vlan-id ip ip-address
Probe视图
vlan vlan-id: 显示指定VLAN上rbhash表项信息。vlan-id表示指定VLAN的编号。
ip ip-address:显示指定IP上rbhash表项信息。
display system internal arp reload命令用来显示指定板上ARP重刷链表项。
Probe视图
display system internal arp rule命令用来显示ARP规则信息。
display system internal arp rule { all | interface interface-type interface-number [ ip-address ] }
Probe视图
all:显示所有ARP规则信息。
interface interface-type interface-number:显示指定接口的ARP规则信息,interface-type interface-number表示接口类型和接口编号。
ip-address:显示指定IP地址的ARP规则信息。
display system internal arp snooping命令用来在Probe视图显示ARP Snooping表项。
display system internal arp snooping [ vlan vlan-id ] [ count ]
display system internal arp snooping ip ip-address
Probe视图
vlan vlan-id:显示指定VLAN内的ARP Snooping表项。vlan-id的取值范围为1~4094。
count:显示当前ARP Snooping表项的数量。
ip ip-address:显示指定IP地址对应的ARP Snooping表项。
display system internal arp source-suppression cache命令用来显示指定板源抑制表项。
Probe视图
display system internal arp statistics命令用来显示指定板ARP统计信息。
Probe视图
display system internal arp suppression xconnect-group verbose命令用来显示ARP泛洪抑制表项的详细信息。
Probe视图
display system internal arp vlan命令用来显示指定VLAN的ARP表项信息或表项个数。
display system internal arp vlan vlan-id [ count ]
Probe视图
vlan vlan-id: 用来显示指定VLAN的ARP表项信息或表项个数。
count:用来显示ARP表项个数。
display system internal aspf statistics命令用来查看ASPF、报文过滤以及对象策略模块的丢包统计信息。
display system internal aspf statistics { interface | zone-pair } { ipv4 }
Probe视图
interface:查看接口上的ASPF丢包统计信息。
zone-pair:查看域间实例上的ASPF丢包统计信息。
ipv4: 查看IPv4报文的丢包统计信息。
display system internal attack-defense scan stat-nodes ip命令用来显示扫描攻击防范的IPv4统计节点信息。
Probe视图
source:显示基于源IP地址进行统计的扫描攻击统计节点。
destination:显示基于目的IP地址进行统计的扫描攻击统计节点。
ipv4-address:表示指定的源IPv4地址或目的IPv4地址,不能为广播地址、127.0.0.0/8网段地址、D类地址或E类地址。
interface interface-type interface-number:显示指定接口的扫描攻击统计节点,interface-type interface-number表示接口类型和接口编号。
local:显示本机上进行检测的扫描攻击统计节点。
count:显示符合指定条件的统计节点的个数。
display system internal client-verify http redirect-node命令用来显示HTTP客户端验证重定向节点信息。
display system internal client-verify http redirect-node { ip [ ipv4-address ] } [ count ]
Probe视图
ip ipv4-address:显示指定IPv4地址的重定向节点。
count:显示统计数据的个数。
display system internal control-plane statistics命令用来显示控制平面报文的统计信息。
Probe视图
display system internal dbm命令用来显示数据库信息。
display system internal dbm { all | name dbname [ key keyname ] }
Probe视图
all:表示所有数据库。
name dbname:指定数据库名。
key keyname:指定key的名称,在数据库中以key名称标识一项数据。
display system internal ethernet character命令用来显示以太网模块侦听的特征统计信息和详细信息。
display system internal ethernet character { global | interface interface-type interface-number }
Probe视图
global:显示全局的以太特征。全局特征表示对设备上所有报文进行匹配。
interface interface-type interface-number:表示接口类型和接口编号。
以太网模块主要实现链路层报文接收去封装和发送加封装等处理。上层应用模块需要侦听处理协议报文,指定侦听的范围(如指定接口上的报文或者设备上所有报文),侦听的协议报文具有指定的特征(如特殊的以太协议类型、特定的MAC等),并将这些特征下发给以太网模块,以太网模块在指定阶段(如收包MAC阶段/收包LLC阶段/发包三层口阶段等)会根据注册的特征库对报文进行匹配。匹配上了这些特征就交给这个阶段处理,不匹配就交给下一个阶段处理。
display system internal ethernet controlblock命令用来显示接口的控制块信息,它记录了链路层参数的值。
display system internal ethernet controlblock interface { interface-type interface-number }
Probe视图
display system internal fib prefix命令用来显示IPv4 FIB前缀基本信息。
display system internal fib prefix [ topology topo-name ]
Probe视图
topology topo-name:显示指定拓扑的IPv4 FIB前缀基本信息。topo-name表示拓扑名,为1~31个字符的字符串,区分大小写;取值为base时表示公网拓扑。如果未指定本参数,则显示公网的信息。
display system internal fib prefix entry-status命令用来显示下驱动失败或者待老化的IPv4 FIB表项信息。
display system internal fib prefix entry-status status
Probe视图
entry-status status:用于匹配FIB表项;取值范围为<A,F>,“A”表示需要被老化的IPv4 FIB表项信息,“F”表示下刷驱动失败的IPv4 FIB表项信息。
display system internal fib prefix ip命令用来显示IPv4 FIB前缀详细信息。
display system internal fib prefix ip [mask | mask-length ]
Probe视图
ip:显示指定IP地址的IPv4 FIB前缀详细信息。
mask:IP地址掩码。
mask-length:IP地址掩码长度,即掩码中连续“1”的个数。
display system internal fib running-status命令用来显示IPv4 FIB、VN全局信息。
Probe视图
display system internal fib statistics命令用来显示IPv4 FIB、VN表项操作的统计信息。
Probe视图
display system internal fib vn命令用来显示VN表项信息。
display system internal fib vn [ next-hop next-hop ]
display system internal fib vn { id id | index index }
Probe视图
id id:按指定VN ID显示VN表项详细信息。
index index:按指定VN索引显示VN表项详细信息。
next-hop next-hop:显示指定下一跳的VN表项基本信息,可以输入IPv4地址。
display system internal fib vn entry-status命令用来显示指定状态的VN表项基本信息。
display system internal fib vn entry-status status
Probe视图
entry-status status:按指定状态显示VN信息。取值范围为<A,F,R>,“A”表示待老化表项,“F”表示下驱动失败表项,“R”表示由于被关联而未删除的表项。
display system internal fib vn reference命令用来显示前缀关联VN的信息。
display system internal fib vn { id id | index index } reference
Probe视图
id id:按指定VN ID显示VN信息。
index index:按指定VN指针显示VN信息。
reference:显示关联该VN的前缀信息。
display system internal ha service命令用来显示某个业务进程的HA统计信息,包括业务注册的基本信息、各控制消息接收处理统计、各数据的发送统计和接收统计等。
display system internal ha service socket
Probe视图
socket:所要查询的业务进程的socket,可通过display system internal ha service-group sg-name查询。
display system internal ha service-group命令用来显示当前到HA模块注册的所有SG信息,包括SG的名称、SG的状态、SU的个数等信息。
display system internal ha service-group [ name [ instance ] ]
Probe视图
instance:SG实例的名称(如果有实例)。
display system internal ha statistics命令用来显示HA各子模块的统计信息。
display system internal ha statistics { submodule { fsm | service } | summary }
Probe视图
submodule:HA子模块的信息。
fsm:FSM子模块的信息。
service:service子模块的信息。
summary:全局统计信息。
display system internal ifmgr down命令用来显示已注册的down类型。
Probe视图
display system internal ifmgr entry命令用来显示指定接口的数据结构信息。
display system internal ifmgr entry { para | help }
Probe视图
para:指定显示时的参数。表示接口名或接口索引,格式为:1*接口索引,2*接口名。
help:显示命令参数的帮助信息,用于指导用户输入合法参数。
display system internal ifmgr event命令用来显示接口事件的注册信息,包括哪些模块注册了该事件,以及模块在哪些接口上注册了该事件。
display system internal ifmgr event { para | help }
Probe视图
para:指定显示时的参数。para为事件或接口类型,如果同时指定事件和接口类型,事件和接口中间需用“*”连接,格式为:event*type。
display system internal ifmgr hotplug命令用来显示板或子卡的热插拔信息。
display system internal ifmgr hotplug [ para | help ]
Probe视图
para:指定显示时的参数。para为槽位号或者槽位号和子槽位号(格式为slot-number*subslot-number),用于显示该板或子卡的热插拔信息。不指定该参数以及help参数时,显示所有板的热插拔信息;
display system internal ifmgr index命令用来显示接口索引节点的相关信息。
display system internal ifmgr index { para | help }
Probe视图
para:指定显示时的参数。为接口索引值的十进制形式。
display system internal ifmgr list命令用来显示接口树信息。
display system internal ifmgr list [ para | help ]
Probe视图
para:指定显示时的参数。para为接口类型对应的数值,该数值可通过help参数获取。
接口树用于管理设备上存在的接口。树上的节点对应接口,子节点对应接口下创建的子接口,每个节点的信息包括接口的名称和索引。
不指定para和help参数时,显示所有类型接口的接口树信息。
display system internal ifmgr name命令用来显示接口名字解析树信息。该树用于解析接口名字,以及命令行上输入接口名字时的帮助检查。
display system internal ifmgr name { para | help }
Probe视图
para:指定显示时的参数,为接口全名或简名。
display system internal ifmgr type命令用来按类型显示接口的信息。
display system internal ifmgr type { para | help }
Probe视图
para:指定显示时的参数。para为接口类型,为1~127个字符的字符串。
display system internal ip address命令用来显示地址详细信息
display system internal ip address [ interface interface-type interface-number ] [ ip-address ]
Probe视图
ip-address ip-address:显示指定IP地址。
interface interface-type interface-number:显示指定接口的IP地址,interface-type interface-number表示接口类型和接口编号。
display system internal ip fast-forwarding cache verbose命令用来显示IPv4快转表项的详细内容。
display system internal ip fast-forwarding cache [ ip-address ] verbose
probe视图
ip-address:显示指定IP地址的 IPv4 快转表详细信息。
display system internal ip source binding命令用来显示详细的IPv4绑定表项信息。
Probe视图
static:显示配置的静态绑定表项。
dhcp-relay:显示DHCP中继模块生成的动态绑定表项。
dhcp-server:显示DHCP服务器模块生成的动态绑定表项。
dhcp-snooping:显示DHCP Snooping模块生成的动态绑定表项。
ip-address ip-address:显示指定IPv4地址的绑定表项,ip-address表示绑定的IPv4地址。
mac-address mac-address:显示指定MAC地址的绑定表项,mac-address表示绑定的MAC地址,格式为H-H-H。
vlan vlan-id:显示指定VLAN的绑定表项,vlan-id表示绑定的VLAN ID,取值范围为1~4094。
interface interface-type interface-number:显示指定接口的绑定表项,interface-type interface-number表示绑定的接口类型和接口编号。
display system internal kernel memory dump命令用来查看指定内核内存地址的内容。
display system internal kernel memory dump address address-hex length memory-length
Probe视图
address address-hex:表示内存起始地址。
length memory-length:表示要查看的内存大小,取值范围为1~1024,单位为字节。
display system internal kernel memory pool命令用来显示内核态正在使用的内存池的统计信息。
display system internal kernel memory pool [ name name-string ]
display system internal kernel memory pool tag [ tag-value ]
display system internal kernel memory pool name name-string tag tag-value
Probe视图
name name-string:表示内存池的名字。
tag tag-value:指定内存池使用者的标识。
不指定name和tag参数时,显示系统内存池使用情况的概要信息。
仅指定name name-string时,显示指定内存池使用情况的概要信息;
仅指定tag时,显示所有内存池使用情况的概要信息,以tag为关键字进行显示;
仅指定tag tag-value时,显示指定tag使用的内存池概要信息;
指定name name-string tag tag-value时,显示指定tag和内存池中内存对象的使用信息。
display system internal mac-address configuration命令用来显示MAC地址表的配置信息。
display system internal mac-address configuration { blackhole | static } [ count ]
Probe视图
blackhole:显示黑洞MAC地址表项。
static:显示静态MAC地址表项。
count:显示MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)MAC地址表项的数量,而不显示MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的MAC地址表的具体内容。
display system internal mac-address learned命令用来显示动态MAC地址表项。
Probe视图
mac-address:显示指定MAC地址的动态MAC地址表项,mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
vlan vlan-id:显示指定VLAN的动态MAC地址表项。vlan-id的取值范围为1~4094。
interface interface-type interface-number:显示指定接口的动态MAC地址表项。interface-type interface-number为接口类型和接口编号。
count:显示动态MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)动态MAC地址表项的数量,而不显示动态MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的动态MAC地址表项的具体内容。
display system internal mac-address protocol命令用来显示指定协议或特性生成的MAC地址或VLAN接口的MAC地址。
display system internal mac-address protocol [ ead | vlan-interface ]
Probe视图
ead:显示EAD特性的MAC地址表项。
vlan-interface:显示VLAN接口的MAC地址表项。
display system internal mac-address statistics命令用来显示MAC地址表的统计信息。
Probe视图
display system internal mac-forwarding cache ip verbose命令用来显示IP快转表项的详细内容。
display system internal mac-forwarding cache ip [ ip-address ] verbose
probe视图
ip-address:显示指定IP地址的快速转发表信息。如果不指定ip-address,将显示所有快速转发表信息。
display system internal mac-forwarding controlblock命令用来显示二层转发的接口控制信息。
display system internal mac-forwarding controlblock interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的二层转发控制信息。其中,interface-type interface-number为指定接口类型和接口编号。
display system internal nat命令用来显示内核的NAT配置信息。
Probe视图
display system internal object-group命令用来显示对象组的配置和运行情况。
Probe视图
ip address:指定对象组类型为IP地址对象组。
port:指定对象组类型为端口对象组。
service:指定对象组类型为服务对象组。
default:指定默认对象组。
name object-group-name:指定对象组名称。object-group-name表示对象组的名称,为1~31个字符的字符串,不区分大小写。
display system internal object-policy命令用来显示指定对象策略的配置信息。
display system internal object-policy object-policy-name
Probe视图
object-policy-name表示对象策略的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。
display system internal ppp statistics命令用来显示PPP的统计信息。
display system internal ppp statistics { aggregation | all | interface-event }
Probe视图
aggregation:显示PPP的聚合处理统计信息。
all:显示PPP的所有统计信息。
interface-event:显示PPP的接口处理统计信息。
在主用设备和备用设备上都可以查询PPP的统计信息。
display system internal pppoe-server statistics命令用来显示PPPoE server的统计信息。
display system internal pppoe-server statistics aggregation
Probe视图
aggregation:显示PPPoE server的聚合处理统计信息。
在主用设备和备用设备上都可以查询PPPoE server的统计信息。
display system internal rawip命令用来显示设备上所有RawIP连接的摘要信息。
Probe视图
display system internal rib event attribute命令用来显示IPv4 RIB的路由属性事件信息。
Probe视图
display system internal rib event policy命令用来显示IPv4 RIB的路由策略事件信息。
Probe视图
display system internal rib notificaion prefix命令用来显示IPv4 RIB的路由前缀事件信息。
Probe视图
display system internal rib event protocol命令用来显示IPv4 RIB的协议事件信息。
Probe视图
display system internal rib event statistics用来显示IPv4 RIB的统计事件信息。
Probe视图
display system internal rib ftn命令用来显示FTN表项和统计计数信息。
display system internal rib ftn [ index ] [ statistics ]
Probe视图
index:显示指定FTN索引的FTN信息。index为FTN索引值,为十六进制数,最高位统一设置为1。如果未指定本参数,将显示所有FTN索引的FTN信息。
statistics:显示FTN统计计数信息。
display system internal rib ftn summary命令用来显示FTN的运行信息。
Probe视图
display system internal rib log命令用来显示RIB的日志信息。
display system internal rib log [ reverse ]
display system internal rib event log
Probe视图
rib:显示RIB的日志信息。
event:显示RIB路由变化通知的日志信息。
reverse:按时间新旧显示日志信息。
display system internal rib memory命令用来显示RIB的内存信息。
Probe视图
display system internal rib nib log命令用来显示系统内部NIB子模块运行状态的日志记录。
display system internal rib nib log [ reverse ]
Probe视图
nib:显示NIB子模块的运行状态。
display system internal rib prefix命令用来显示IPv4路由表前缀信息。
display system internal rib prefix ip-address mask-length
Probe视图
ip-address:指定IPv4目的地址。
mask-length:IP地址掩码,取值范围为0~32。
display system internal rib summary命令用来显示IPv4 RIB的统计信息。
Probe视图
display system internal route-direct interface命令用来显示IPv4地址接口的信息。
Probe视图
ip-address:接口IP地址,点分十进制,显示指定IP地址和掩码/掩码长度接口的信息。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
display system internal route-direct log命令用来显示直连路由日志信息。
display system internal route-direct { event | notify | nib } log [ reverse ]
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
display system internal route-static nib log命令用来显示静态路由NIB子模块日志信息。
display system internal route-static nib log [ reverse ]
Probe视图
display system internal startup cache命令用来显示设备本次启动时使用的二进制配置文件的路径,如flash:/startup.mdb。
Probe视图
用户执行save命令保存配置时,系统会自动生成一个字符串类型的配置文件和一个二进制类型的配置文件。
· 字符串类型的配置文件是一个文本文件,文件名后缀为“.cfg”,可以通过more命令查看该文件的内容。
· 二进制类型的配置文件是字符串类型的配置文件的二进制格式,文件名后缀为“.mdb”。在设备启动和运行时,系统软件能够解析该类配置文件,而用户却不能读取和编辑文件内容。
两个文件保存的配置相同,但格式不同。设备启动的时候,会优先使用二进制类型的配置文件,以便提高加载配置的速度。如果没有找到合适的二进制类型的配置文件,才使用字符串类型的配置文件。
当设备本次启动使用的是二进制类型的配置文件时,使用该命令会显示该二进制文件的路径;当设备本次启动使用的是字符串类型的配置文件时,使用该命令将显示None。
display system internal tcp命令用来显示设备上所有TCP连接的摘要信息。
Probe视图
display system internal tcp port-info命令用来显示TCP模块非保留端口的使用信息。
Probe视图
display system internal udp命令用来显示设备上所有UDP连接的摘要信息。
Probe视图
display system internal udp port-info命令用来显示UDP模块非保留端口的使用信息。
Probe视图
display system internal vlan命令用来查看VLAN模块相关的内部信息。
Probe视图
instance vlan-id:显示指定VLAN的VLAN模块信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
interface interface-type interface-number:显示指定端口的VLAN模块信息。interface-type interface-number为端口类型和端口编号。
summary:显示VLAN模块的摘要信息。
follow命令用来通过跟踪栈信息来调试指定的进程或者线程。
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ]
Probe视图
job job-id:任务ID,用于唯一标识一个进程,该ID不会随着进程的重启而改变,取值范围为1~2147483647。
process pid:进程ID,该ID可能会随着进程的重启而改变,取值范围为1~2147483647。
thread thread-id:线程ID,用于指定进程内某一指定线程,取值范围为1~2147483647。
delay seconds:指定每次跟踪操作的间隔时间,取值范围为0~255秒,缺省为5秒。
iteration count:指定跟踪调试的次数的次数,取值范围为1~255次,缺省为5次。
对于用户态进程,follow命令会分别显示当前进程的内核态堆栈和用户态堆栈信息,并以user stack/kernel stack提示符加以区分;对于内核态进程,则只显示内核态堆栈信息。
不指定thread参数时,默认显示指定进程内所有线程。
list命令用来查看系统目录(/proc/、/sys/、/var/)下的文件和子目录的相关信息,且文件路径中不能包含文件链接。
Probe视图
file-path:要查看的文件或目录的路径,区分大小写。
memory boundary-check enable命令用来开启内存越界检查功能。
undo memory boundary-check enable命令用来恢复缺省情况。
memory boundary-check enable job job-id
undo memory boundary-check enable job job-id
Probe视图
开启指定进程的内存越界检查功能后,该进程每次释放内存前都会进行内存越界检查,以便确保申请和释放操作的正确性。如果发生内存越界,将内存越界信息记录到内存文件中(所有进程的越界信息都会记录到一个文件中)。
memory boundary-check scan命令用来触发一次内存越界检查,并显示检查的结果。若有内存被写越界,则打印出该出错处地址往前偏移16字节,一共128字节的内存内容。
memory boundary-check scan job job-id
Probe视图
使用前必须使能内存越界检测功能,否则使用该命令检查,无效果。
执行该命令后,系统会从出错处地址往前偏移16字节,一共显示128字节的内存内容;当系统中存在多处内存越界时,只记录并显示地址最小的一条检查结果。
· memory boundary-check enable
probe命令用来从系统视图进入Probe视图。
在Probe视图下,用户可以通过命令查看系统的状态和信息,以便对系统故障进行诊断。
reset system internal adj4 statistics命令用来清除IPv4邻接表项的统计信息
probe视图
reset system internal arp statistics命令用来清除指定板上的ARP统计信息。
Probe视图
reset system internal aspf statistics命令用来清除ASPF、报文过滤以及对象策略模块的丢包统计信息。
reset system internal aspf statistics { interface | zone-pair } { ipv4 }
Probe视图
interface:清除接口上的ASPF丢包统计信息。
zone-pair:清除域间实例上的ASPF丢包统计信息。
ipv4:清除IPv4报文的丢包统计信息。
reset system internal control-plane statistics命令用来清除控制平面报文的统计信息
Probe视图
reset system internal fib statistics命令用来清除FIB统计信息。
Probe视图
reset system internal mac-address statistics命令用来清除MAC地址表的统计信息
Probe视图
reset system internal ppp statistics命令用来清除PPP的统计信息。
reset system internal ppp statistics { aggregation | all | interface-event }
Probe视图
aggregation:清除PPP的聚合处理统计信息。
all:清除PPP的所有统计信息。
interface-event:清除PPP的接口处理统计信息。
在主用设备和备用设备上都可以清除PPP的统计信息。
reset system internal pppoe-server statistics命令用来清除PPPoE server的统计信息。
reset system internal pppoe-server statistics aggregation
Probe视图
aggregation:清除PPPoE server的聚合处理统计信息。
在主用设备和备用设备上都可以清除PPPoE server的统计信息。
reset system internal rib log命令用来清除RIB相关的日志内容。
reset system internal rib [ event ] log
Probe视图
event:RIB路由变化相关的日志。
reset system internal rib nib log命令用来清除NIB子模块日志。
Probe视图
reset system internal rib summary命令用来清除IPv4 RIB的统计摘要信息。
Probe视图
reset system internal route-direct log命令用来清除直连路由日志。
reset system internal route-direct { event | notify | nib } log
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
reset system internal route-static nib log命令用来清除静态路由NIB子模块日志。
Probe视图
view命令用来查看系统目录(/proc/、/sys/、/var/)下的文件的内容。
Probe视图
file-path:要查看文件的路径,区分大小写。
执行该命令显示的文件路径中不能包含文件链接。文件链接类似于文件的快捷方式,文件链接指向另一个文件或目录。通过文件链接可以访问到其所指向的文件或目录。
