02-4G Modem管理命令
本章节下载: 02-4G Modem管理命令 (237.85 KB)
1.1.4 display controller cellular
1.1.11 pin verification enable
1.1.17 reset counters controller cellular
1.1.23 display interface eth-channel
1.1.26 ip address cellular-alloc
1.1.29 reset counters interface
controller cellular命令用来进入Cellular接口视图。
controller cellular cellular-number
cellular-number:Cellular接口的编号。
# 进入接口Cellular2/0的视图。
[Sysname] controller cellular 2/0
[Sysname-Cellular 2/0]
description命令用来设置当前接口的描述信息。
undo description命令用来恢复缺省情况。
接口的描述信息为“该接口的接口名 Interface”,比如:Cellular2/0 Interface。
Cellular接口视图
text:接口描述信息,为1~255个字符的字符串,区分大小写。
# 设置接口Cellular2/0的描述信息为“Cellular-intf”。
[Sysname-Cellular2/0] description Cellular-intf
display cellular命令用来显示4G Modem的呼叫连接信息。
display cellular [ interface-number ]
interface-number:显示指定Cellular接口的4G Modem呼叫连接信息。如果不指定本参数,则显示所有在位Modem对应Cellular接口的4G Modem呼叫连接信息。
对于不同厂家生产的4G Modem,此命令显示的内容和格式可能略有区别。
# 显示4G Modem的呼叫连接信息(LTE网络)。
<Sysname> display cellular 0/0
Cellular0/0:
Hardware Information:
Model: MC7750
Manufacturer: Sierra Wireless, Incorporated
Modem Firmware Version: SWI9600M_03.05.10.06
Hardware Version: 10
International Mobile Equipment Identity (IMEI): 990000560327506
Modem Status: Online
Profile Information:
Profile index: 1
PDP Type: IPv4
Header Compression: Off
Data Compression: Off
Access Point Name (APN): vzwinternet
Network Information:
Current Service Status: Service available
Current Roaming Status: Roaming
Current Data Bearer Technology: Unknown
Network Selection Mode: Manual
Mobile Country Code (MCC): 460
Mobile Network Code (MNC): 00
Location Area Code (LAC): 4318
Cell ID: 25381
Radio Information:
Technology Preference: LTE only
Technology Selected: LTE
LTE related info:
Current RSSI: -79 dBm
Current RSRQ: -9 dB
Current RSRP: -106 dBm
Current SNR: 5 dB
Tx Power: -3276 dBm
Modem Security Information:
PIN Verification: Disabled
PIN Status: Ready
SIM Status: OK
ICCID: 89860113811003195000
表1-1 display cellular命令显示信息描述表(LTE网络)
Modem名称 |
Modem的软件版本号 |
Modem的硬件版本号 |
Modem的IMEI串号 |
Modem的状态: · Online:Modem处于上电状态 · Offline:Modem处于下电状态或省电模式,Cellular接口功能不可用 |
Modem的参数模板信息 |
Modem的参数模板索引 |
PDP类型,只有Profile 1 = Active时,才显示该信息: · IPv4:PDP协议类型为IPv4 · PPP:PDP协议类型为PPP透传 |
PDP头压缩模式: · On:使能PDP头压缩 · Off:禁止PDP头压缩 |
PDP数据压缩模式: · On:使能PDP数据压缩 · Off:禁止PDP数据压缩 |
Modem的服务状态: · Limited:服务受限,Cellular接口功能不可用 · Service available:提供有效服务 · Emergency:提供有限制服务,Cellular接口功能不可用 · No service:无法提供服务,Cellular接口功能不可用 · Low power:处于省电模式,Cellular接口功能不可用 |
· Roaming:漫游状态 · Home:本地状态 |
· Manual:手动选择 · Automatic:自动选择 |
· AUTO:自动选择连接网络 · GSM only:仅连接GSM网络 · GSM precedence:优先连接GSM网络 · WCDMA only:仅连接WCDMA网络 · WCDMA precedence:优先连接WCDMA网络 · TD-SCDMA only:仅连接TD-SCDMA网络 · TD-SCDMA precedence:优先连接TD-SCDMA网络 · EVDO:仅连接CDMA-EVDO网络 · 1x RTT:仅连接CDMA-1x RTT网络 · 1xRTT/EVDO HYBRID:同时连接CDMA-EVDO和CDMA-1x RTT网络 · LTE only:仅连接LTE网络 |
· GSM:连接GSM网络 · WCDMA:连接WCDMA网络 · TD-SCDMA:连接TD-SCDMA网络 · EVDO:连接CDMA-EVDO网络 · 1x RTT:连接CDMA-1x RTT网络 · 1xRTT/EVDO HYBRID:同时连接CDMA-EVDO和CDMA-1x RTT网络 · LTE:连接LTE网络 |
LTE网络相关信息 |
· 信号质量的取值范围为-110dBm~-51dBm · Unknown:无信号,Cellular接口功能不可用 |
Modem安全信息 |
PIN认证状态: · Disabled:未使能PIN认证 · Enabled:使能了PIN认证 · Unknown:当前PIN码状态未知 |
· Ready:SIM卡状态正常 · PIN Requirement:SIM卡有PIN认证请求,需要用户配置pin verify命令 · PUK Requirement:SIM卡有PUK认真请求,需要用户配置pin unlock命令 |
SIM卡状态: · OK:SIM卡状态正常 · Network Reject:SIM卡被拒绝接入网络,Cellular接口功能不可用 · Not Inserted:未插入SIM卡,Cellular接口功能不可用 · Not Initialized:当前SIM卡状态未知 |
ICCID |
SIM卡ID号,仅当SIM卡状态为正常时显示 |
· pin verification enable
display controller cellular命令用来显示Cellular接口的相关信息。
display controller [ cellular [ interface-number ] ]
interface-number:Cellular接口的编号。
· 如果不指定cellular参数,将显示设备支持的所有接口的相关信息;
· 如果指定cellular参数,不指定interface-number参数,将显示所有已创建的Cellular接口的相关信息。
# 显示接口Cellular2/0的相关信息。
<Sysname> display controller cellular 2/0
Cellular2/0
Current state: UP
Description: Cellular2/0 Interface
Modem status: Present
DM port status: Disabled
Capability:
1 Control channel, 1 PPP channel
Control channel 0 traffic statistics:
TX: 0 packets, 0 errors
RX: 0 packets, 0 errors
PPP channel 0 traffic statistics:
表1-2 display controller cellular命令显示信息描述表
Cellular2/0 |
· Administratively DOWN:表示该接口已经通过shutdown命令被关闭,即管理状态为关闭 · DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障) · UP:该接口的管理状态和物理状态均为开启 |
Cellular接口的描述信息 |
USB 4G Modem模块的在位状态: · Present:表示在位 · Absent:表示不在位 |
DM功能的状态: · Enabled:表示DM功能处于打开状态 · Disabled:表示DM功能处于关闭状态 |
Cellular接口支持的通道类型及数量: · 1 Control channel:支持1个控制通道 · 1 PPP channel:支持1个异步串口子通道 · 1 ETH channel:支持1个以太网子通道 |
Control channel的报文收发统计信息: |
PPP channel的报文收发统计信息: |
ETH channel的报文收发统计信息: |
· reset counters controller cellular
dm-port open命令用来打开4G Modem的DM功能。
undo dm-port open命令用来关闭4G Modem的DM功能。
本命令的缺省情况与4G Modem设备的型号有关,请以设备的实际情况为准。
Cellular接口视图
本命令用于在4G Modem上打开或关闭DM功能。
DM(Diagnostic and Monitoring,诊断和监控),指某些类型的4G Modem支持通过4G Modem上的调试信息输出接口输出调试信息功能,用于连接第三方的调试工具(如高通QXDM软件)进行诊断和监控。
# 打开4G Modem的DM功能。
[Sysname-Cellular2/0] dm-port open
mode命令用来选择网络连接方式。
Cellular接口视图
1xrtt:设置4G Modem只选择CDMA-1x RTT网络。
auto:设置4G Modem自动选择网络。
evdo:设置4G Modem只选择CDMA-EVDO网络。
gsm:设置4G Modem只选择GSM网络。
gsm-preference:设置4G Modem优先选择GSM网络。
hybrid:设置4G Modem同时选择CDMA-EVDO和CDMA-1x RTT网络。
lte:设置4G Modem只选择LTE网络。
td:设置4G Modem只选择TD-SCDMA网络。
td-preference:设置4G Modem优先选择TD-SCDMA网络。
wcdma:设置4G Modem只选择WCDMA网络。
wcdma-preference:设置4G Modem优先选择WCDMA网络。
本命令用于在4G Modem上选择网络连接方式。
本命令中各参数的支持情况与4G Modem设备的型号有关,请以设备的实际情况为准。
# 设置4G Modem只选择LTE网络。
[Sysname-Cellular2/0] mode lte
modem reboot命令用来手动重启4G Modem。
Cellular接口视图
4G Modem在运行过程中能够自动检测异常,并实施自动重启。如果无法自动重启,用户可以通过本命令手动重启4G Modem。
# 手动重启4G Modem。
[Sysname-Cellular2/0] modem reboot
modem response命令用来配置系统向4G Modem下发配置指令后,等待其回复的时间间隔,以及4G Modem连续不响应系统配置指令(配置指令失败或配置指令响应超时)次数的阈值,达到系统配置的阈值后,自动重启4G Modem。
undo modem response命令用来恢复缺省情况。
modem response timer time auto-recovery threshold
系统等待4G Modem回复的时间间隔为10秒, 4G Modem连续不响应系统配置指令次数的阈值为3次。
Cellular接口视图
timer time:系统向4G Modem下发配置指令后,等待其回复的时间间隔。若在该时间内系统没收到4G Modem的回复,则认为4G Modem不响应系统配置指令。time的取值范围为1~300,单位为秒。
auto-recovery threshold: 4G Modem连续不响应系统配置指令次数的阈值,达到阈值后系统自动重启4G Modem。取值范围为0~10。当threshold配置为0时,关闭自动重启功能。
4G无线网络的不稳定运行或应用环境变化可能导致4G Modem功能故障,无法自动拨号并连接网络。设备提供自动重启4G Modem功能,尽可能减少需要用户手工重启4G Modem的情况。
开启自动重启4G Modem功能后,如果连续多次下发配置指令失败或配置指令响应超时,系统将自动重启4G Modem。为避免因配置错误引起的多次拨号失败,而导致的反复自动重启4G Modem的情况,系统仅在上次自动重启4G Modem后有过至少一次拨号成功记录,并且多次发配置指令失败或配置指令响应超时的情况下才会自动重启4G Modem。
# 配置系统向4G Modem下发配置指令时,等待其回复的时间间隔为20秒,配置4G Modem模块连续4次不响应系统配置指令,则自动重启。
[Sysname-Cellular2/0] modem response timer 20 auto-recovery 4
pin modify命令用来修改SIM/UIM卡的PIN码,修改后的PIN码保存在SIM/UIM卡上。
pin modify current-pin new-pin
Cellular接口视图
current-pin:插在4G Modem上的SIM/UIM卡的PIN码,由4~8位数字组成。
new-pin:用户重新设置的PIN码,由4~8位数字组成。
本命令用于在4G Modem上修改SIM/UIM卡的PIN码。
· 如果开启了4G Modem的PIN码认证功能,修改PIN码后,需要配置pin verify命令以保持和修改后的PIN码一致。
· 如果连续多次修改PIN码失败,会导致SIM/UIM卡被锁。
· 如果SIM/UIM卡被锁,必须先通过pin unlock命令来解锁。
· 部分4G Modem必须在启用PIN码认证,并且PIN码认证通过后才可以修改PIN码。
# 修改SIM/UIM卡的PIN码。
[Sysname-Cellular2/0] pin modify 1234 4321
PIN will be changed to “4321”. Continue? [Y/N]:y
PIN has been changed successfully.
pin unlock命令用来对4G Modem上的SIM/UIM卡进行PIN码解锁。
Cellular接口视图
puk:插在4G Modem上的SIM/UIM卡的PUK码,由网络提供商提供,由4~8位数字组成。
new-pin:用户重新设置的PIN码,由4~8位数字组成。重新设置的PIN码保存在SIM/UIM卡上。
本命令用于在4G Modem上对SIM/UIM卡进行PIN码解锁。下列情况可能导致SIM/UIM卡PIN码被锁住:
· 连续多次修改PIN码失败。
· 连续多次开启或关闭4G Modem的PIN码认证功能失败。
· 连续多次PIN码认证失败。
如果PIN码被锁住,需要用户使用PUK码将PIN码解锁,否则4G Modem的数据通信功能不可用。
· 如果开启了4G Modem的PIN码认证功能,解锁PIN码后,需要配置pin verify命令以保持和重新设置的PIN码一致。
· 如果连续多次解锁失败,可能会导致SIM/UIM卡被永久锁定,无法使用。
· 如果SIM/UIM卡被永久锁定,请联系SIM/UIM卡的运营商为SIM/UIM卡解锁。
# 使用PUK码解锁PIN码。
[Sysname-Cellular2/0] pin unlock 87654321 1234
PIN will be unlocked and changed to “1234”. Continue? [Y/N]:y
PIN has been unlocked and changed successfully.
pin verification enable命令用来开启4G Modem的PIN码认证功能。
undo pin verification enable命令用来关闭4G Modem的PIN码认证功能。
pin verification enable [ pin ]
undo pin verification enable [ pin ]
Cellular接口视图
本命令用于在4G Modem上开启或关闭PIN码认证功能。
· 如果开启了4G Modem的PIN码认证功能,当4G Modem插入或4G Modem重启时,会使用pin verify命令配置的PIN码进行认证,否则4G Modem的数据通信功能不可用。重启4G Modem的途径包括:重启设备、使用modem reboot命令重启4G Modem。
· 如果关闭了4G Modem的PIN码认证功能,不需要进行PIN码认证就可以进行4G Modem数据通信。
如果开启了4G Modem的PIN码认证功能,需要通过pin verify命令将PIN码保存在设备上,在需要认证时,自动完成PIN码认证。
· 开启或关闭4G Modem的PIN码认证功能时,可能要求输入当前的PIN码。该要求与4G Modem设备的型号有关,请以设备的实际情况为准。如果连续多次开启或关闭4G Modem的PIN码认证功能失败,可能会导致SIM/UIM卡被锁。如果SIM/UIM卡被锁,可以通过pin unlock命令来解锁。
· 部分4G Modem在启用PIN码认证功能后,必须PIN码认证通过后才可以关闭PIN码认证功能。
# 开启PIN码认证功能。
[Sysname-Cellular2/0] pin verification enable 1234
pin verify命令用来配置4G Modem进行认证的PIN码。
undo pin verify命令用来恢复缺省情况。
pin verify { cipher ciphered-pin | simple pin }
未配置4G Modem进行认证的PIN码。
Cellular接口视图
cipher:表示以密文形式输入密码。
ciphered-pin:插在4G Modem上的SIM/UIM卡的密文PIN码,由37~41个字符的字符串组成。
simple:表示以明文形式输入密码。
pin:插在4G Modem上的SIM/UIM卡的明文PIN码,由4~8位数字组成。
开启了4G Modem的PIN码认证功能后,当4G Modem插入或重启时,需要通过pin verify命令输入PIN码进行认证,如果输入的PIN码正确,则PIN码认证通过,否则,PIN码认证失败。如果连续多次PIN码认证失败,可能会导致SIM/UIM卡被锁。如果SIM/UIM卡被锁,可以通过pin unlock命令来解锁。
用户可以在需要PIN码认证时配置pin verify命令,也可以提前配置pin verify命令,只要配置一次pin verify命令,PIN码就会保存在设备上,在需要认证时,自动完成PIN码认证。
# 配置4G Modem进行认证的PIN码。
[Sysname-Cellular2/0] pin verify simple 1234
plmn search命令用来搜索移动网络。
Cellular接口视图
本命令用于触发4G Modem搜索移动网络。
搜索移动网络需要等待几分钟,完成搜索后,命令行会给出提示,显示搜索到的移动网络。
4G Modem使用时,需要在PLMN(Public Land Mobile Network,公共陆地移动网络)进行选择接入的移动网络。如果用户需要手工指定接入的移动网络,则需要先搜索移动网络,获取当前区域内有信号的移动网络列表。
# 搜索移动网络。
[Sysname-Cellular2/0] plmn search
PLMN search done.
Available PLMNs:
PLMN No. MCC MNC Status Type
01 460 00 Current GSM
02 460 01 Forbidden GSM
表1-3 plmn search命令显示信息描述表
· 00、02、07:表示移动 · 01:表示联通 · 03:表示电信 |
· Current:表示当前正在使用的网络 · Available:表示网络可达 · Forbidden:表示网络被禁止使用 |
plmn select命令用来配置选择移动网络的方式。
plmn select { auto | manual mcc mnc }
Cellular接口视图
auto:表示自动选择PLMN(Public Land Mobile Network,公共地带移动网络)。
manual:表示人工指定PLMN。
mcc:MCC(Mobile Country Code,移动国家编码),取值范围为0~65535。
mnc:MNC(Mobile Network Code,移动网络编码),取值范围为0~65535。
本命令用于在4G Modem上配置选择移动网络的方式。
当配置选择移动网络的方式为人工指定时,需要先通过plmn search命令搜索移动网络。
# 配置选择移动网络的方式为人工指定。
[Sysname-Cellular2/0] plmn select manual 460 00
profile create命令用来创建4G Modem的参数模板。
Cellular接口视图
profile-number: 4G Modem的参数模板编号。不同型号的4G Modem设备支持的取值范围不同,请以设备的实际情况为准。
dynamic:由运营商根据接入用户动态分配接入点。
static apn:指定的由运营商提供的接入点名称,为1~100个字符的字符串,是否大小写敏感和运营商有关。
authentication-mode:认证方式。
none:不认证。
chap:认证方式为CHAP。
pap:认证方式为PAP。
user username:认证用户名,由运营商提供。为1~32个字符的字符串,区分大小写。
password password:认证密码,由运营商提供。为1~32个字符的字符串,区分大小写。
本命令用于在4G Modem上创建参数模板。
参数模板可以配置接入点和认证方式, 4G Modem会根据配置的接入点和认证方式,来和对应的服务商进行认证:
· 当选用None方式时,不需要输入用户名和密码。
· 当选用CHAP或PAP方式时,需要根据运营商的要求,选择配置用户名和密码,其中username字段是必选的,而password字段是可选的。
# 创建4G Modem的参数模板1,指定的接入点名称为cmnet,认证方式采用PAP。
[Sysname-Cellular2/0] profile create 1 static cmnet authentication-mode pap user abc password abc
profile main命令用来配置4G Modem拨号使用的主备参数模板。
undo profile main命令用来恢复缺省情况。
profile main main-profile-number backup backup-profile-number
4G Modem使用参数模板1进行拨号。
Cellular接口视图
main-profile-numbe:主参数模板索引。不同型号的4G Modem设备支持的取值范围不同,请以设备的实际情况为准。
backup backup-profile-number:备份参数模板索引。不同型号的4G Modem设备支持的取值范围不同,请以设备的实际情况为准。
配置profile main命令后, 4G Modem每次拨号都优先选择主参数模板,如果主参数模板拨号失败,将使用备份参数模板进行拨号。无论备份参数模板拨号是否成功,下次拨号时都使用主参数模板拨号。
· 本命令的配置会在下次拨号时生效,不会影响当前的拨号结果。
# 配置4G Modem拨号使用主参数模板1,备份参数模板2。
[Sysname-Cellular2/0] profile main 1 backup 2
reset counters controller cellular命令用来清除Cellular接口的统计信息。
reset counters controller cellular [ interface-number ]
· 如果不指定interface-number,则清除所有Cellular接口的统计信息;
· 如果指定interface-number,则清除指定Cellular接口的统计信息。
# 清除接口Cellular2/0的统计信息。
<Sysname> reset counters controller cellular 2/0
sendat命令用来手工向4G Modem发送配置指令。
Cellular接口视图
at-string:配置指令字符串,为1~300个字符的字符串。该字符串的内容格式不同产品有所区别,可能是AT指令(“+++”和“A/”以及任意以AT开头的字符串,AT指令的详细解释请参见“二层技术-广域网接入命令参考/Modem管理”中的命令sendat),也可能是CNS格式的报文(样例请参见表1-4)。
表1-4 CNS格式报文举例
控制CNS心跳检测开关 · n = 00000500000000000000,打开CNS心跳检测开关 · n = 00000800000000000000,关闭CNS心跳检测开关 |
sendat命令不检查配置指令的合法性,直接将用户输入的字符串送至4G Modem(遇到小写字母自动转化为大写字母)。
· sendat命令一次只能配置一条配置指令。
· 通过配置指令配置4G Modem后, 4G Modem的工作状态会被改变,有可能导致4G Modem的状态混乱从而影响到拨号等基本功能。请在专业人员的指导下慎重使用此功能。
# 向4G Modem发送拨号指令,呼叫号码169。
[Sysname-Cellular2/0] sendat ATD169
# 向4G Modem发送打开CNS心跳检测开关的指令。
[Sysname-Cellular2/0] sendat cns00000500000000000000
shutdown命令用来关闭Cellular接口。
undo shutdown命令用来打开Cellular接口。
Cellular接口处于打开状态。
Cellular接口视图
# 关闭接口Cellular2/0。
[Sysname] interface cellular 2/0
[Sysname-Cellular2/0] shutdown
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
接口的期望带宽=接口的波特率÷1000(kbit/s)。
bandwidth-value:表示接口的期望带宽,取值范围为1~400000000,单位为kbit/s。
# 设置以太网通道接口Eth-channel2/0:0的期望带宽为1000kbit/s。
[Sysname] interface eth-channel 2/0:0
[Sysname-Eth-channel2/0:0] bandwidth 1000
default命令用来恢复当前接口的缺省配置。
# 将以太网通道接口Eth-channel2/0:0恢复为缺省配置。
[Sysname-Eth-channel2/0:0] default
接口的描述信息为“该接口的接口名 Interface”,比如“Echannel2/0:0 Interface”。
修改后的描述信息会在display interface显示的接口信息中体现。
# 设置以太网通道接口Eth-channel2/0:0的描述信息为“Echannel-interface”。
[Sysname-Eth-channel2/0:0] description Echannel-interface
display interface eth-channel命令用来显示以太网通道接口的相关信息。
display interface [ eth-channel [ channel-id ] ] [ brief [ description | down ] ]
channel-id:以太网通道接口的编号。
· 如果不指定eth-channel参数,将显示设备支持的所有接口的相关信息;
· 如果指定eth-channel参数,不指定channel-id参数,将显示所有已通道化的以太网通道接口的相关信息。
# 显示以太网通道接口Eth-channel2/0:0的详细信息。
<Sysname> display interface eth-channel 2/0:0
Echannel2/0:0
Current state: DOWN
Line protocol state: DOWN
Description: Echannel2/0:0 Interface
Bandwidth: 100000kbps
Maximum Transmit Unit: 1500
Internet protocol processing: disabled
IP Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 000c-2963-b75d
Transfer time: 00:00:00
Last 300 seconds input rate 0.00 bytes/sec, 0.00 packets/sec
Last 300 seconds output rate 0.00 bytes/sec, 0.00 packets/sec
Input: 0 packets, 0 bytes, 0 buffers
Output:0 packets, 0 bytes
# 显示以太网通道接口Eth-channel2/0:0的概要信息。
<Sysname> display interface eth-channel 2/0:0 brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface Link Protocol Main IP Description
Echannel2/0:0 UP UP(s) 192.168.80.239
# 显示当前物理状态为down的以太网通道接口的信息以及down的原因。
<Sysname> display interface eth-channel brief down
Interface Link Cause
Echannel2/0:0 ADM Administratively
表1-5 display interface eth-channel命令显示信息描述表
· UP:表示数据链路层协议状态为开启 · DOWN:表示数据链路层协议状态为关闭 · UP(spoofing):表示该接口的数据链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立 |
接口的IP地址,此IP地址由运营商自动分配 |
IP Packet Frame Type,Hardware Address |
IP报文发送帧格式,硬件地址 |
输出队列的紧急队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数。 |
输出队列的协议队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数。 |
输出队列的先进先出队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数。该显示信息与用户的配置有关,当配置为CBQ、WFQ等队列时则显示为CBQ/WFQ等队列的消息数。 |
接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过) |
最近一次使用reset counters interface命令清除接口下的统计信息的时间。如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never |
最近300秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的包数 |
最近300秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的包数 |
三层模式下(route)接口的概要信息,即三层接口的概要信息 |
· 如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态 · 如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口 |
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的 |
· UP:表示接口物理上是连通的 · DOWN:表示接口物理上不通 · ADM:表示接口被手工关闭了,需要执行undo shutdown命令才能打开接口 · Stby:表示该接口是一个备份接口 |
· UP:表示接口的数据链路层是连通的 · DOWN:表示接口的数据链路层不通 · UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的 |
接口主IP地址 |
用户通过description命令给接口配置的描述信息。使用display interface brief命令,不指定description参数时,该字段最多显示27个字符;指定description参数时,可显示配置的全部描述信息 |
接口物理连接状态为down的原因,取值为Administratively时表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态 |
eth-channel命令用来将Cellular接口通道化出以太网通道接口。
undo eth-channel命令用来将Cellular接口通道化出的以太网通道接口删除。
undo eth-channel channel-number
Cellular接口视图
channel-number:通道化出的以太网通道接口编号。不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
Cellular接口在配置该命令后通道化出一个以太网通道接口,接口名是eth-channel cellular-number:channel-number。
# 将接口Cellular2/0通道化出一个以太网通道接口。
[Sysname-Cellular2/0] eth-channel 0
interface eth-channel命令用来进入以太网通道接口视图。
interface eth-channel interface-number
interface-number:以太网通道接口的编号。
# 进入以太网通道接口Eth-channel2/0:0的视图。
ip address cellular-alloc命令用来配置接口通过Modem私有协议获取IP地址。
undo ip address cellular-alloc命令用来恢复缺省情况。
接口不通过Modem私有协议获取IP地址。
ip address cellular-alloc与ip address dhcp-alloc命令用于设置接口以何种方式从Modem获取接口IP地址,Modem的IP地址由运营商自动分配。
其中,ip address cellular-alloc命令是配置接口采用Modem私有协议获取IP地址,而ip address dhcp-alloc命令是配置接口采用标准DHCP协议获取IP地址。
# 为接口Cellular2/0创建以太网通道接口,并采用Modem私有协议获取运营商自动分配的IP地址。
[Sysname-Cellular2/0] quit
[Sysname-Eth-channel2/0:0] ip address cellular-alloc
lte band命令用来配置选择LTE模块所工作的频段。
undo lte band命令用来恢复缺省情况。
lte band band-number
undo lte band
Cellular接口视图
band-number:该模块所支持的LTE频段,不同模块所支持频段不同,以命令行提示信息为准。
此命令现在只有Sierra的MC7354和MC7304,龙尚的U8300C和U8300W等4G模块支持。
#为接口Cellular1/0配置选择3频段。
[Sysname] controller cellular 1/0
[Sysname-Controller-Cellular1/0]lte band 3
mtu命令用来配置接口的MTU(Maximum Transmission Unit,最大传输单元)值。
undo mtu命令用来恢复缺省情况。
接口的MTU值为1500字节。
# 配置以太网通道接口Eth-channel2/0:0的MTU值为1430字节。
[Sysname-Eth-channel2/0:0] mtu 1430
reset counters interface命令用来清除以太网通道接口的统计信息。
reset counters interface [ eth-channel [ channel-id ] ]
eth-channel:清除以太网通道接口的统计信息。
· 如果不指定eth-channel和channel-id,则清除所有接口的统计信息;
· 如果指定eth-channel而不指定channel-id,则清除所有以太网通道接口的统计信息;
· 如果同时指定eth-channel和channel-id,则清除指定以太网通道接口的统计信息。
# 清除以太网通道接口Eth-channel2/0:0的统计信息。
<Sysname> reset counters interface eth-channel 2/0:0
shutdown命令用来关闭以太网通道接口。
undo shutdown命令用来打开以太网通道接口。
# 关闭以太网通道接口Eth-channel2/0:0。
[Sysname-Eth-channel2/0:0] shutdown
