08-ACl和QoS命令参考
02-QoS命令
本章节下载: 02-QoS命令  (421.72 KB)
02-QoS命令
1 QoS策略
1.1 定义类的命令
1.1.1 display traffic classifier
1.1.2 if-match
1.1.3 traffic classifier
1.2 定义流行为的命令
1.2.1 accounting
1.2.2 car
1.2.3 display traffic behavior
1.2.4 filter
1.2.5 nest top-most
1.2.6 redirect
1.2.7 remark customer-vlan-id
1.2.8 remark dot1p
1.2.9 remark drop-precedence
1.2.10 remark dscp
1.2.11 remark ip-precedence
1.2.12 remark local-precedence
1.2.13 remark qos-local-id
1.2.14 remark service-vlan-id
1.2.15 traffic behavior
1.3 定义和应用QoS策略的命令
1.3.1 classifier behavior
1.3.2 control-plane
1.3.3 control-plane management
1.3.4 display qos policy
1.3.5 display qos policy control-plane
1.3.6 display qos policy control-plane management
1.3.7 display qos policy control-plane management pre-defined
1.3.8 display qos policy control-plane pre-defined
1.3.9 display qos policy global
1.3.10 display qos policy interface
1.3.11 qos apply policy (interface view,control plane view, control plane management view)
1.3.12 qos apply policy global
1.3.13 qos policy
1.3.14 reset qos policy control-plane
1.3.15 reset qos policy control-plane management
1.3.16 reset qos policy global
2 优先级映射
2.1 优先级映射表配置命令
2.1.1 display qos map-table
2.1.2 display qos map-table interface
2.1.3 display qos map-table name
2.1.4 import (flexible priority map view)
2.1.5 import (priority map view)
2.1.6 qos apply map-table name
2.1.7 qos map-table
2.1.8 qos map-table name
2.2 端口优先级信任模式配置命令
2.2.1 display qos trust interface
2.2.2 qos trust
3 流量整形和限速
3.1 流量整形配置命令
3.1.1 display qos gts interface
3.1.2 qos gts
3.2 限速配置命令
3.2.1 display qos lr
3.2.2 qos lr
4 硬件实现拥塞管理
4.1 严格优先级队列配置命令
4.1.1 display qos queue sp interface
4.1.2 qos sp
4.2 加权轮询队列配置命令
4.2.1 display qos queue wrr interface
4.2.2 qos wrr
4.2.3 qos wrr { byte-count | weight }
4.2.4 qos wrr group sp
4.3 加权公平队列配置命令
4.3.1 display qos queue wfq interface
4.3.2 qos bandwidth queue
4.3.3 qos wfq
4.3.4 qos wfq { byte-count | weight }
4.3.5 qos wfq group sp
5 全局CAR
5.1 全局CAR配置命令
5.1.1 car name
5.1.2 display qos car name
5.1.3 qos car
5.1.4 reset qos car name
1 QoS策略
说明: 注意
本文中的单板及slot参数,对于RA10/RA10-E/RA100路由器指的是设备本身,对于RA200路由器指的是设备上的主控板。
1.1  定义类的命令
display traffic classifier命令用来显示类的配置信息。
user-defined:用户定义类。
classifier-name:类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有类的配置信息。
slot slot-number:显示指定单板的流分类的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主用主控板的类的配置信息。
# 显示用户定义类的配置信息。
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match not protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
表1-1 display traffic classifier命令显示信息描述表
用户自定义类的信息
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
1.1.2  if-match
if-match命令用来定义匹配数据包的规则。
undo if-match命令用来删除配置的匹配数据包的规则。
if-match [ not ] match-criteria
undo if-match [ not ] match-criteria
未定义匹配数据包的规则。
类视图
not:不匹配该规则。
表1-2 类的匹配规则取值
取值
acl [ ipv6 | mac ] { acl-number | name acl-name }
定义匹配ACL的规则
acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~3999,IPv6 ACL序号的取值范围是2000~3999,二层ACL序号的取值范围是4000~4999
acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all
any
定义匹配所有数据包的规则
control-plane protocol protocol-name&<1-8>
定义匹配控制平面或者管理口控制平面协议的规则,protocol-name&<1-8>为系统预定义匹配协议报文类型名称的列表,具体如表1-3所示,&<1-8>表示前面的参数最多可以输入8次。
control-plane protocol-group protocol-group-name
定义匹配控制平面或者管理口控制平面协议组的规则,protocol-group-name取值为critical、exception、important、management、monitor、normal、redirect
customer-dot1p dot1p-value&<1-8>
定义匹配内层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
customer-vlan-id vlan-id-list
定义匹配内层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-id、vlan-id1、vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
destination-mac mac-address
定义匹配目的MAC地址的规则
dscp dscp-value&<1-8>
定义匹配DSCP的规则,dscp-value&<1-8>为DSCP取值的列表,DSCP的取值范围为0~63,&<1-8>表示前面的参数最多可以输入8次;也可以输入关键字,具体如表1-5所示
ip-precedence ip-precedence-value&<1-8>
定义匹配IP优先级的规则,ip-precedence-value&<1-8>为IP优先级的列表,IP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
定义匹配协议的规则,protocol-name取值为arp、ip、ipv6
qos-local-id local-id-value
定义匹配QoS本地ID值的规则,local-id-value为QoS本地ID,取值范围为1~4095
service-dot1p dot1p-value&<1-8>
定义匹配外层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
service-vlan-id vlan-id-list
定义匹配外层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-id、vlan-id1、vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
source-mac mac-address
定义匹配源MAC地址的规则
表1-3 系统预定义匹配协议报文类型名称的列表
报文类型
default
其他协议
arp
ARP协议
arp-snooping
ARP Snooping协议
bgp
BGP协议
bgp4+
IPv6 BGP
bpdu-tunnel
BPDU Tunnel协议
cdp
CDP协议
cfd
CFD协议
dhcp
DHCP协议
dhcp-snooping
DHCP Snooping协议
dhcpv6
IPv6 DHCP协议
dldp
DLDP协议
dot1x
802.1p 协议
gmrp
GMRP协议
mvrp
MVRP协议(包含GVRP协议)
http
HTTP协议
https
HTTPS协议
icmp
ICMP协议
icmpv6
IPv6 ICMP协议
igmp
IGMP协议
igmp-snooping
IGMP Snooping协议
irdp
IRDP协议
isis
IS-IS协议
lacp
LACP协议
ldp
LDP协议
ldp6
IPv6 LDP协议
lldp
LLDP协议
mld
MLD协议
msdp
MSDP协议
ntp
NTP协议
oam
OAM协议
ospf-multicast
OSPF组播
ospf-unicast
OSPF单播
ospf3-multicast
OSPFv3组播
ospf3-unicast
OSPFv3单播
pim-multicast
PIM组播
pim-unicast
PIM单播
pim6-multicast
IPv6 PIM组播
pim6-unicast
IPv6 PIM单播
portal
PORTAL协议
pppoe-negotiation
PPPoE协商
pvst
PVST协议
radius
RADIUS协议
rip
RIP协议
ripng
RIPng协议
rrpp
RRPP协议
rsvp
RSVP协议
smart-link
Smart Link协议
snmp
SNMP协议
stp
STP协议
tacacs
TACACS协议
udld
UDLD协议
udp-helper
UDP中继转发
vrrp
VRRP协议
vrrp6
IPv6 VRRP协议
vtp
VLAN中继协议
ip-option
带选项字段的IPv4报文
ipv6-option
带选项字段的IPv6报文
ssh
SSH协议
telnet
TELNET协议
ftp
FTP协议
tftp
TFTP协议
bfd
BFD协议
ttl-expires
TTL超时
hoplimit-expires
Hop Limit超时
在定义匹配ACL的规则时,请注意:
·     如果类中引用的ACL不存在,则不能在硬件中下发。
·     一个类下可配置多条匹配命令,各个配置之间互相不覆盖。
·     对同一个类,允许通过ACL名称和序号的方式分别引用一次同一个ACL。
·     当if-match中引用的ACL规则的动作为deny时,直接忽略ACL规则的动作,以流行为中定义的动作为准,报文匹配只使用ACL中的分类域。
在定义匹配目的MAC地址的规则时,请注意:
·     匹配目的MAC地址规则只对以太网接口有意义。
在定义匹配源MAC地址的规则时,请注意:
·     匹配源MAC地址规则只对以太网接口有意义。
在定义匹配DSCP的规则时,请注意:
·     一条命令可以配置多个DSCP值,最多可指定8个;如果指定了多个相同的DSCP值,系统默认为一个;多个不同的DSCP值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配DSCP的规则时,指定的所有DSCP值必须与该规则中定义的完全相同才会删除,顺序可不一样。
在定义匹配内层VLAN Tag和外层VLAN Tag 802.1p优先级的规则时,请注意:
·     一条命令可以配置多个802.1p优先级值,最多可指定8个;如果指定了多个相同的802.1p优先级值,系统默认为一个;多个不同的802.1p优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配802.1p优先级的规则时,指定的所有802.1p优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
在定义匹配IP优先级的规则时,请注意:
·     一条命令可以配置多个IP优先级值,最多可指定8个;如果指定了多个相同的IP优先级值,系统默认为一个;多个不同的IP优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配IP优先级的规则时,指定的所有IP优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
在定义匹配内层VLAN Tag和外层VLAN Tag VLAN ID的规则时,请注意:
·     一条命令可以配置多个VLAN ID值,如果指定了多个相同的VLAN ID值,系统默认为一个;多个不同的VLAN ID值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配VLAN ID的规则时,指定的所有VLAN ID值必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     若只携带单层VLAN Tag,可以用外层VLAN Tag的VLAN ID规则来匹配。
在定义匹配预定义的上送控制平面或者管理口控制平面报文类型的规则时,请注意:
·     一条命令可以配置多个protocol,如果指定了多个相同的protocol,系统默认为一个;多个不同的protocol是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配protocol的规则时,指定的所有protocol必须与该规则中定义的完全相同才会删除,顺序可不一样。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的802.1p优先级为3。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的802.1p优先级为5。
[Sysname-classifier-class1] if-match service-dot1p 5
# 定义类匹配ACL3101。
# 定义类匹配ACL flow。
# 定义类匹配IPv6 ACL3101。
# 定义类匹配IPv6 ACL flow。
# 定义匹配所有数据包的规则。
# 定义类class1的匹配规则为:匹配DSCP值为1或6或9的报文。
[Sysname-classifier-class1] if-match dscp 1 6 9
# 定义类class1的匹配规则为:匹配IP优先级值为1或6的报文。
[Sysname-classifier-class1] if-match ip-precedence 1 6
# 定义类匹配IP协议的报文。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的VLAN ID值为1或6或9的报文。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的VLAN ID值为2或7或10的报文。
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# 定义类class1匹配qos-local-id 3。
[Sysname-classifier-class1] if-match qos-local-id 3
[Sysname-classifier-class1] if-match control-plane protocol arp
# 在流分类class1中配置匹配上送控制平面或管理口控制平面的normal协议组报文。
traffic classifier命令用来创建一个类,并进入类视图。如果指定的类已经存在,则直接进入类视图。
undo traffic classifier命令用来删除一个类。
不存在类。
operator:指定各规则之间的逻辑运算符。缺省情况为and。
# 定义一个名为class1的类。
·     display traffic classifier
1.2  定义流行为的命令
1.2.1  accounting
accounting命令用来配置流量统计动作。
undo accounting命令用来恢复缺省情况。
accounting { byte | packet }
undo accounting
未配置流量统计动作。
流行为视图
byte:表示报文基于字节进行统计。
packet:表示报文基于包进行统计。
如果流行为视图下配置了accounting命令,则指定该流行为的QoS策略不支持在全局下应用。
# 为流行为配置流量统计动作,基于字节进行统计。
[Sysname-behavior-database] accounting byte
1.2.2  car
car命令用来配置流量监管动作。
undo car命令用来恢复缺省情况。
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
未配置流量监管动作。
流行为视图
cir committed-information-rate:承诺信息速率。流量的平均速率,单位为kbps。取值范围为8~160000000,取值必须为8的倍数。
cbs committee-burst-size:承诺突发尺寸,单位为byte。取值范围为512~256000000,取值必须为512的倍数。
ebs excess-burst-size:超出突发尺寸,单位为byte。取值范围为0~256000000,取值必须为512的倍数。
pir peak-information-rate:峰值速率,单位为kbps。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。取值范围为8~160000000,取值必须为8的倍数。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass。
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard。
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass。
action:对数据包采取的动作,有以下几种(CAR支持的动作与设备相关,请以设备的实际情况为准):
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dot1p-pass new-cos:设置新的802.1P报文的优先级值,并允许数据包通过,取值范围为0~7。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63。
·     remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。
·     remark-mpls-exp-pass new-exp:设置新的MPLS报文的EXP标志位的值,并允许数据包通过,取值范围为0~7。
接口上应用的策略中使用car时,可以应用到接口报文的接收或者发送方向。
在同一个流行为中多次执行本命令,最后一次执行的命令生效。
# 为流行为配置流量监管。报文正常流速为800kbps,承诺突发尺寸为51200bytes,速率大于200kbps时,报文DSCP值改为0并发送。
[Sysname-behavior-database] car cir 800 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
display traffic behavior命令用来显示流行为的配置信息。
user-defined:用户定义行为。
behavior-name:行为名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有流行为的配置信息。
slot slot-number:显示指定单板的流行为的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的流行为的配置信息。
# 显示用户定义行为的配置信息。
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
      Primap pre-defined table: dscp-dp
      Assured Forwarding:
        Bandwidth 30 (kbps)
        Discard Method: Tail
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Marking:
        Remark mpls-exp 4
      Redirecting:
        Redirect to the CPU
      Mirroring:
        Mirror to the VLAN: VLAN 1000
      Expedited Forwarding:
        Bandwidth 50 (kbps) CBS 1250 (Bytes)
    Behavior: 3 (ID 102)
      -none-
表1-4 display traffic behavior命令显示信息描述表
用户自定义流行为的信息
Behavior
行为的名称及其内容,内容可以有多种类型
Marking
标记相关信息
Remark dscp
重新标记报文的DSCP优先级值
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
EBS
超出突发尺寸,单位为byte
Green action
对绿色报文的动作
Red action
对红色报文的动作
Yellow action
对黄色报文的动作
预定义映射表相关信息。对于映射表的描述可以参考2.1  优先级映射表配置命令
Primap color-map-dp
根据报文颜色标记丢弃优先级的映射表
Primap pre-defined color table
预定义带颜色映射表相关信息。对于带颜色映射表的描述可以参考2.1  优先级映射表配置命令
Assured Forwarding
确保转发(AF队列)的相关信息
Bandwidth
队列的带宽
Discard Method
丢弃方式
Accounting enable
流量统计动作
Filter enable
流量过滤动作
Remark mpls-exp
重新标记报文的EXP优先级值
Redirecting
流量重定向相关信息
Mirroring
流量镜像相关信息
加速转发(EF队列)相关信息
none
表示未配置其他流行为
Flow based Weighted Fair Queue
基于流的加权公平队列相关信息
Max number of hashed queues
加权公平队列的长度
Exponential Weight
计算平均队列长度的指数
Pre
报文的IP优先级
Low
队列下限
High
队列上限
Dis-prob
计算丢弃概率时的分母
1.2.4  filter
filter命令用来配置流量过滤动作。
undo filter命令用来恢复缺省情况。
filter { deny | permit }
undo filter
未配置流量过滤动作。
流行为视图
deny:丢弃数据包。
permit:允许数据包通过。
# 为流行为配置丢弃数据包的过滤动作。
1.2.5  nest top-most
nest top-most命令用来配置添加VLAN Tag的动作。
undo nest top-most命令用来恢复缺省情况。
nest top-most vlan vlan-id
undo nest top-most
未配置添加VLAN Tag的动作。
流行为视图
vlan vlan-id:添加的VLAN ID,取值范围为1~4094。
引用了添加VLAN Tag动作的QoS策略只能应用到接口的入方向上。
# 在流行为b1上配置如下动作:添加VLAN ID为123的VLAN Tag。
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
1.2.6  redirect
redirect命令用来为流行为配置流量重定向动作。
undo redirect命令用来恢复缺省情况。
redirect { cpu | interface interface-type interface-number }
undo redirect { cpu | interface interface-type interface-number }
未配置流量重定向动作。
流行为视图
cpu:重定向到CPU。
interface:重定向到指定的接口。
interface-type interface-number:指定接口类型和接口编号(对于重定向到二层聚合接口来说,接口类型是bridge-aggregation)。
# 为流行为配置流量重定向动作,重定向到CPU。
[Sysname-behavior-database] redirect cpu
# 为流行为配置流量重定向动作,重定向到接口GigabitEthernet1/0/1。
[Sysname-behavior-database] redirect interface gigabitethernet1/0/1
·     classifier behavior
·     qos policy
·     traffic behavior
remark customer-vlan-id命令用来重标记报文的CVLAN。
undo remark customer-vlan-id命令用来恢复缺省情况。
未配置重新标记报文的动作。
流行为视图
vlan-id:表示重标记报文内层VLAN(CVLAN)的编号,取值范围为1~4094。
# 在流行为b1上配置重标记报文的CVLAN为VLAN 111。
[Sysname-behavior-b1] remark customer-vlan-id 111
1.2.8  remark dot1p
remark dot1p命令用来配置重新标记报文的802.1p优先级的动作或内外层标签802.1p优先级复制动作。
undo remark dot1p命令用来取消标记报文的802.1p优先级或内外层标签802.1p优先级复制动作。
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
未配置重新标记报文802.1p优先级以及内外层标签802.1p优先级复制动作。
流行为视图
green:对绿色报文进行重标记。
red:对红色报文进行重标记。
yellow:对黄色报文进行重标记。
dot1p-value:802.1p优先级,取值范围为0~7。
customer-dot1p-trust:QoS策略应用到端口后,将内层VLAN tag的802.1p优先级复制为外层VLAN tag的802.1p优先级。
命令remark dot1p dot1p-value和remark dot1p customer-dot1p-trust是覆盖关系。
如果报文只携带一层VLAN tag,则配置remark dot1p customer-dot1p-trust不会生效。
# 重新标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
# 配置内外层标签优先级复制功能。
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
remark drop-precedence命令用来重新标记报文的丢弃优先级。
undo remark drop-precedence命令用来恢复缺省情况。
remark drop-precedence drop-precedence-value
未配置重新标记报文的动作。
流行为视图
drop-precedence-value:丢弃优先级,取值范围为0~2。
应用该动作的流行为只能应用在入方向。
# 重新标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
1.2.10  remark dscp
remark dscp命令用来重新标记报文的DSCP值。
undo remark dscp命令用来取消标记报文的DSCP值。
undo remark [ green | red | yellow ] dscp
未配置重新标记报文DSCP值的动作。
流行为视图
green:对绿色报文进行重标记。
red:对红色报文进行重标记。
yellow:对黄色报文进行重标记。
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-5所示。
表1-5 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
# 重新标记报文的DSCP值为6。
remark ip-precedence命令用来重新标记报文的IP优先级。
undo remark ip-precedence命令用来取消标记报文的IP优先级。
remark ip-precedence ip-precedence-value
未配置重新标记报文IP优先级的动作。
流行为视图
ip-precedence-value:IP优先级,取值范围为0~7。
# 重新标记报文的IP优先级值为6。
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence命令用来重新标记报文的本地优先级。
undo remark local-precedence命令用来取消标记报文的本地优先级。
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
未配置重新标记报文本地优先级的动作。
流行为视图
green:对绿色报文进行重标记。
red:对红色报文进行重标记。
yellow:对黄色报文进行重标记。
local-precedence-value:本地优先级,取值范围为0~7。
# 重新标记报文的本地优先级值为2。
remark qos-local-id命令用来重新标记报文的QoS本地ID值。
undo remark qos-local-id命令用来恢复缺省情况。
remark qos-local-id local-id-value
未配置重新标记报文的QoS本地ID值的动作。
流行为视图
local-id-value:QoS本地ID值,取值范围为1~4095。
一般情况下,在QoS策略的入方向对报文的QoS本地ID值进行标记,在QoS策略的出方向根据标记的QoS本地ID值对报文进行分类以及指定相应的流行为,两者要结合使用。
# 重新标记报文的QoS本地ID值为2。
[Sysname-behavior-database] remark qos-local-id 2
remark service-vlan-id命令用来重标记报文的SVLAN。
undo remark service-vlan-id命令用来恢复缺省情况。
未配置重新标记报文的SVLAN的动作。
流行为视图
vlan-id:表示重标记报文外层VLAN(SVLAN)的编号,取值范围为1~4094。
# 在流行为b1上配置重标记报文的SVLAN为VLAN 222。
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior命令用来创建一个流行为,并进入流行为视图。如果指定的流行为已经存在,则直接进入流行为视图。
undo traffic behavior命令用来删除一个流行为。
不存在流行为。
behavior-name:流行为名,为1~31个字符的字符串,区分大小写。
# 定义一个名为behavior1的流行为。
[Sysname-behavior-behavior1]
·     display traffic behavior
1.3  定义和应用QoS策略的命令
classifier behavior命令用来为类指定流行为。
undo classifier命令用来取消为类指定的流行为。
classifier classifier-name behavior behavior-name [ mode dcbx | insert-before before-classifier-name ] *
没有为类指定流行为。
QoS策略视图
mode dcbx:表示该流分类与流行为的关联模式为DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议)模式。有关DCBX的介绍,请参见“二层技术-以太网交换配置指导”中的“LLDP”。
insert-before before-classifier-name:表示将配置的类插入到QoS策略中已存在的指定类之前。before-classifier-name表示QoS策略中已存在的类名,为1~31个字符的字符串,区分大小写。不指定该参数时,表示新配置的类与流行为配对将添加到QoS策略最后。
QoS策略下每个类只能与一个流行为关联。
如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
如果undo命令指定的类为系统预定义类default-class,表示恢复default-class对应的流行为为系统预定义流行为be,而不是取消对应的流行为。
如果配置了mode参数,对于类和流行为的配置会存在一些特殊限制,请以设备的实际情况为准。
# 在QoS策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
# 在QoS策略user1中为类database指定流行为test,并将该类插入到策略中已存在的类class-a前。
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
·     qos policy
1.3.2  control-plane
control-plane命令用来进入控制平面视图。
slot slot-number:指定单板。slot-number表示单板所在的槽位号。
# 进入3号板控制平面视图。
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
control-plane management命令用来进入管理口控制平面视图。
# 进入管理口控制平面视图。
[Sysname] control-plane management
[Sysname-cp-management]
display qos policy命令用来显示QoS策略的配置信息。
user-defined:用户定义QoS策略。
policy-name:QoS策略名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有用户定义策略的配置信息。
classifier classifier-name:QoS策略中的类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示策略中所有类相关的配置信息。
slot slot-number:显示指定单板的QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的QoS策略的配置信息。
# 显示用户定义QoS策略的配置信息。
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
     Behavior: 2
      Marking:
        Remark mpls-exp 4
     Behavior: 3
表1-6 display qos policy命令显示信息描述表
用户自定义QoS策略的信息
Policy
QoS策略名
其它显示信息解释请参见表1-1和表1-4。
display qos policy control-plane命令用来显示控制平面应用QoS策略的信息。
slot slot-number:显示指定单板的控制平面应用QoS策略的信息,slot-number表示单板所在的槽位号。
# 显示应用到控制平面的QoS策略信息。
<Sysname> display qos policy control-plane
Control plane
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Yellow packets: 0 (Packets) 0 (Bytes)
        Red packets   : 0 (Packets) 0 (Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark mpls-exp 4
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-7 display qos policy control-plane命令显示信息描述表
Direction
对进入控制平面(Inbound)的报文应用QoS策略
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-6。
display qos policy control-plane management命令用于显示管理口控制平面应用的QoS策略信息。
# 显示对进入管理口控制平面的报文应用的QoS策略信息。
<Sysname> display qos policy control-plane management
Control plane management
  Direction: Inbound
  Policy: a
   Classifier: default-class
     Matched : 0 (Packets) 0 (Bytes)
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: a
     Matched : 3 (Packets) 180 (Bytes)
     Operator: OR
     Rule(s) :
      If-match control-plane protocol arp
      If-match control-plane protocol rip
      If-match control-plane protocol-group critical
      If-match acl 3001
      If-match control-plane protocol bgp
      If-match control-plane protocol bgp4+
      If-match control-plane protocol ftp
      If-match control-plane protocol http https icmp icmp6 ripng snmp
     Behavior: a
        CIR 128 (kbps), CBS 5120 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Green packets : 3 (Packets) 180 (Bytes)
表1-8 display qos policy control-plane management命令显示信息描述表
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-6。
display qos policy control-plane management pre-defined命令用来显示系统预定义的管理口控制平面应用QoS策略的信息。
# 显示系统预定义的管理口控制平面应用QoS策略的信息。
<Sysname> display qos policy control-plane management pre-defined
Pre-defined control plane policy management
  Protocol          Priority   Bandwidth (kbps)   Group
  Default           N/A        100000             N/A
  ARP               N/A        128                normal
  BGP               N/A        256                critical
  BGPv6             N/A        256                critical
  HTTP              N/A        512                management
  HTTPS             N/A        512                management
  ICMP              N/A        128                monitor
  ICMPv6            N/A        128                monitor
  OSPF Multicast    N/A        256                critical
  OSPF Unicast      N/A        256                critical
  OSPFv3 Multicast  N/A        256                critical
  OSFPv3 Unicast    N/A        256                critical
  RIP               N/A        1024               critical
  RIPng             N/A        256                critical
  SNMP              N/A        512                management
  SSH               N/A        512                management
  TELNET            N/A        512                management
  FTP               N/A        512                management
  TFTP              N/A        512                management
表1-9 display qos policy control-plane management pre-defined命令显示信息描述表
预定义管理口控制平面策略内容
Protocol
系统预定义协议报文类型
Priority
优先级
Bandwidth
带宽
Group
协议组
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面应用QoS策略的信息。
slot slot-number:显示指定单板的系统预定义的控制平面策略信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有在位单板的系统预定义的控制平面应用QoS策略的信息。
# 显示3号板系统预定义的控制平面应用QoS策略的信息。
<Sysname> display qos policy control-plane pre-defined slot 3
Pre-defined control plane policy slot 3
  ARP               1          1000
  ARP Snooping      2          2000
  BGP               3          3000
  BGPv6             4          4000
  BPDU Tunnel       5          5000
  CDP               6          6000
  CFD               7          7000
  DHCP              0          8000
  DHCP Snooping     1          9000
  DHCPv6            2          10000
表1-10 display qos policy control-plane pre-defined命令显示信息描述表
预定义控制平面策略内容
Protocol
系统预定义协议报文类型
Priority
优先级
Bandwidth
带宽
display qos policy global命令用来显示基于全局应用QoS策略的信息。
inbound:显示对全局接收到的报文应用QoS策略的信息。
outbound:显示对全局发送的报文应用QoS策略的信息。
slot slot-number:显示指定单板的基于全局应用QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上基于全局应用QoS策略的信息,不显示各单板的信息。
如果未指定显示方向,则同时显示出入两个方向基于全局应用QoS策略的信息。
# 显示基于全局应用QoS策略的信息。
<Sysname> display qos policy global inbound
  Direction: Inbound
  Type     : Extension
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark mpls-exp 4
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-11 display qos policy global命令显示信息描述表
Direction
对接收到(Inbound)/发送(Outbound)的报文应用QoS策略
策略的应用类型,与应用策略的命令对应。应用时没有指定类型时,显示信息中也没有此字段。取值有:
·     Enhancement:增强型
·     Extension:扩展型
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
display qos policy interface命令用来显示接口上QoS策略的配置信息和运行情况。
display qos policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的配置信息和运行情况。
slot slot-number:显示指定单板上指定接口的QoS策略的配置信息和运行情况。slot-number表示单板所在的槽位号。只有当接口为VLAN接口、聚合接口等类型时才支持此参数。
inbound:显示对接口接收到的报文应用QoS策略的信息。
outbound:显示对接口发送的报文应用QoS策略的信息。
如果未指定显示方向,则同时显示出入两个方向接口上应用QoS策略的配置信息和运行情况。
# 显示对接口GigabitEthernet1/0/1接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark mpls-exp 4
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# 显示所有接口上QoS策略的接口的配置信息和运行情况。
Interface: GigabitEthernet5/0/1
  Direction: Inbound
  Type     : Enhancement
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: GigabitEthernet5/0/10
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 0 (Bytes)
        Green action  : pass
Interface: GigabitEthernet5/0/17
  Direction: Inbound
  Policy: b
   Classifier: b
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        CIR 200 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Green packets : 0(Packets)
  Direction: Inbound
  Type     : Enhancement
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Green action  : pass
表1-12 display qos policy interface命令显示信息描述表
Direction
Policy应用在接口的方向
·     Enhancement:增强型
·     Extension:扩展型
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
qos apply policy命令用来在接口、控制平面或管理口控制平面上应用QoS策略。
undo qos apply policy命令用来取消接口、控制平面或管理口控制平面上应用的QoS策略。
qos apply policy policy-name inbound | outbound }
undo qos apply policy policy-name inbound | outbound }
未应用QoS策略。
接口视图/控制平面视图/管理口控制平面视图
policy-name:策略名,为1~31个字符的字符串,区分大小写。
inbound:对接口或控制平面或管理口控制平面接收到的报文应用QoS策略。
outbound:对接口发送的报文应用QoS策略。
策略在接口上应用的规则如下:
·     在应用策略时,如果策略中为确保转发和加速转发的类指定的带宽之和超过接口允许的可用带宽,则在该接口不可应用。如果对接口修改了可用带宽,此时如果策略中为确保转发和加速转发的类指定的带宽之和超过接口允许的可用带宽,则将策略删除。
·     入方向的策略与类关联的行为不允许有GTS配置。
# 将策略USER1应用到接口GigabitEthernet1/0/1的入方向上。
[Sysname-GigabitEthernet1/1] qos apply policy USER1 inbound
# 对进入3号槽控制平面的报文应用策略aaa。
[Sysname-cp-slot3] qos apply policy aaa inbound
# 对进入管理口控制平面的报文应用策略bbb。
[Sysname-cp-management] qos apply policy bbb inbound
qos apply policy global命令用来全局应用QoS策略。
undo qos apply policy global命令用来取消全局应用的QoS策略。
undo qos apply policy policy-name global { inbound | outbound }
未在全局应用QoS策略。
inbound:对设备所有端口接收到的流量应用QoS策略。
outbound:对设备所有端口发送的流量应用QoS策略。
全局应用的QoS策略对全部流量生效。
# 将名为user1的策略应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
1.3.13  qos policy
qos policy命令用来创建一个策略,并进入策略视图。如果指定的策略已经存在,则直接进入策略视图。
undo qos policy命令用来删除一个策略。
qos policy policy-name
undo qos policy policy-name
不存在策略。
如果该策略已经被应用,则不允许删除该策略,需要先在应用的位置上取消对该策略的应用,然后再使用undo qos policy命令删除该策略。
# 定义一个名为user1的策略。
·     qos apply policy
·     qos apply policy global
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
reset qos policy control-plane slot slot-number [ cpu cpu-number ]
slot slot-number:清除指定单板的基于控制平面应用QoS策略的统计信息,slot-number表示单板所在的槽位号。
# 清除应用到3号板控制平面的QoS策略统计信息。
<Sysname> reset qos policy control-plane slot 3
reset qos policy control-plane management命令用来清除管理口控制平面QoS策略的统计信息。
# 清除管理口控制平面QoS策略的统计信息。
<Sysname> reset qos policy control-plane management
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
inbound:清除全局接收到的报文应用QoS策略的统计信息。
outbound:清除全局发送的报文应用QoS策略的统计信息。
如果不指定方向,则同时清除出入两个方向全局应用的QoS策略的统计信息。
# 清除全局入方向应用的QoS策略的统计信息。
<Sysname> reset qos policy global inbound
2 优先级映射
2.1  优先级映射表配置命令
display qos map-table命令用来显示指定优先级映射表配置情况。
display qos map-table [ dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | exp-dot1p ]
表2-1 优先级映射表
优先级映射
dot1p-dp
802.1p优先级到丢弃优先级映射表
dot1p-exp
802.1p优先级到EXP映射表
dot1p-lp
802.1p优先级到本地优先级映射表
dscp-dot1p
DSCP到802.1p优先级映射表
dscp-dp
DSCP到丢弃优先级映射表
dscp-dscp
DSCP到DSCP映射表
exp-dot1p
EXP到802.1p优先级映射表
如果未指定表的类型,将显示所有映射表的配置情况。
如果未指定任何参数,即display qos map-table命令将显示所有映射表(以及带颜色映射表)的配置情况。
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-2 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名称
TYPE
映射表的类型
IMPORT
映射表的输入值
EXPORT
映射表的输出值
display qos map-table interface命令用来显示接口上应用的灵活优先级映射表。
display qos map-table interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。如果未指定该参数,则显示所有接口上应用的灵活优先级映射表。
如果未指定方向,将显示接口所有方向应用的灵活优先级映射表。
# 显示接口GigabitEthernet1/0/1应用的灵活优先级映射表。
<Sysname> display qos map-table interface gigabitethernet 1/0/1
  Direction: Inbound
  Map table name: user1
表2-3 display qos map-table interface命令显示信息描述表
接口名,由接口类型和接口编号构成
Direction
对进入接口(inbound)的报文应用灵活优先级映射表
Map table name
灵活优先级映射表的名称
·     display qos map-table name
·     qos map-table name
display qos map-table name命令用来显示灵活优先级映射表的配置情况。
display qos map-table name [ map-table-name ]
map-table-name:灵活优先级映射表的名称,为1~31个字符的字符串,区分大小写。如果未指定该参数,则显示所有灵活优先级映射表的配置情况。
# 显示名为user1的灵活优先级映射表的配置情况。
<Sysname> display qos map-table name user1
Map table name: user1   Item: 3
 Type             dot1p-lp  Import     Export
                                5        1
                                6        1
                                7        1
表2-4 display qos map-table name命令显示信息描述表
Map table name
灵活优先级映射表的名称
Item
优先级映射关系的项数
优先级映射关系的类型
Import
优先级映射关系的输入值
Export
优先级映射关系的输出值
·     display qos map-table interface
import命令用来配置灵活优先级映射关系。
undo import命令用来删除指定的灵活优先级映射关系。
{ dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | exp-dot1p } import import-value-list export export-value
灵活优先级映射表视图
灵活优先级映射表中不存在优先级映射关系。
import-value-list:输入值列表。
export-value:输出值。
其它参数请参见表2-1。
对于同一个映射关系,多次执行本命令时,如果输入值相同,则最后一次执行的命令生效。
# 定义名为user1的灵活优先级映射表,在该灵活优先级映射表视图下配置dot1p-lp优先级到本地优先级的映射关系,与dot1p-lp优先级2相对的本地优先级为4。
[Sysname] qos map-table name user1
[Sysname-flexmaptbl-user1] dot1p-lp import 2 export 4
import命令用来配置指定优先级映射表的映射关系。
undo import命令用来删除配置的优先级映射表的映射关系,恢复其为缺省的映射关系。
优先级映射表的映射关系请参见配置指导中的附录 B。
优先级映射表视图
export-value:输出值。
all:删除配置地该映射表的所有映射关系,恢复其为缺省的映射关系。
如果在优先级映射表视图下配置了指定优先级映射表的映射关系,但在某个接口上应用了灵活优先级映射表,此时通过该接口的报文将根据灵活优先级映射表的映射关系分配或修改报文的优先级。
# 配置802.1p优先级到丢弃优先级映射表的映射关系,与802.1p优先级4、5相对应的丢弃优先级为1。
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
·     display qos map-table color
qos apply map-table name命令用来在接口上应用一个灵活优先级映射表。
undo qos apply map-table name命令用来取消接口上应用的灵活优先级映射表。
qos apply map-table name map-table-name
undo qos apply map-table name map-table-name
接口上未应用灵活优先级映射表。
map-table-name:灵活优先级映射表的名称,为1~31个字符的字符串,区分大小写,且指定的灵活优先级映射表必须已经存在。
配置该命令时,指定的灵活优先级映射表必须已经存在。
未指定接口方向时,表示入方向。接口的一个方向只允许应用一个灵活优先级映射表。
# 在接口GigabitEthernet1/0/1上应用名为user1的灵活优先级映射表。
[Sysname-GigabitEthernet1/0/1] qos apply map-table name user1
2.1.7  qos map-table
qos map-table { dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | exp-dot1p }
其它参数请参见表2-1。
# 进入802.1p优先级到丢弃优先级映射表视图。
[Sysname-maptbl-in-dot1p-dp]
[Sysname-maptbl-out-dot1p-dp]
·     import
qos map-table name命令用来创建灵活优先级映射表,并进入灵活优先级映射表视图。如果指定的灵活优先级映射表已经存在,则直接进入灵活优先级映射表视图。
undo qos map-table name命令用来删除一个灵活优先级映射表。
qos map-table name map-table-name
undo qos map-table name map-table-name
不存在灵活优先级映射表。
已经应用到接口上的灵活优先级映射表不允许直接删除。如果需要删除,请先在接口视图下通过执行undo qos apply map-table name命令取消应用,回到系统视图后,再执行undo qos map-table name命令删除该灵活优先级映射表。
# 创建一个名为user1的灵活优先级映射表,并进入该灵活优先级映射表视图。
[Sysname-map-tbl-user1]
·     qos apply map-table name
2.2  端口优先级信任模式配置命令
display qos trust interface命令用来显示当前配置的端口优先级信任模式信息和端口优先级的信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的端口优先级信任模式信息。
# 显示当前配置的端口优先级信任模式信息(支持一种类型端口优先级的设备)。
<Sysname> display qos trust interface gigabitethernet 1/0/1
 Port priority information
  Port priority:4
  Port priority trust type: dscp
表2-5 display qos trust interface命令显示信息描述表(支持一种类型端口优先级的设备)
接口名,由接口类型和接口编号构成
端口优先级信任信息
Port priority
端口优先级
端口优先级信任类型,取值为:
·     dot1p:802.1p优先级
·     dscp:DSCP优先级
2.2.2  qos trust
qos trust命令用来配置端口优先级信任模式。
undo qos trust命令用来恢复缺省情况。
qos trust { dot1p | dscp }
undo qos trust
端口以802.1p优先级进行优先级映射。
# 在接口GigabitEthernet1/0/1上配置优先级信任模式为信任报文自带的802.1p优先级。
[Sysname-GigabitEthernet1/0/1] qos trust dot1p
·     display qos trust interface
3 流量整形和限速
3.1  流量整形配置命令
display qos gts interface命令用来显示接口的流量整形配置情况和统计信息。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的流量整形配置情况和统计信息。
# 显示所有接口的流量整形配置情况和统计信息。
 Rule: If-match acl 2001
  CIR 200 (kbps), CBS 51200 (Bytes), PIR 51200 (kbps), EBS 0 (Bytes)
  Queue Length: 100 (Packets)
  Queue Size: 70 (Packets)
  Passed   : 0 (Packets) 0 (Bytes)
  Discarded: 0 (Packets) 0 (Bytes)
  Delayed  : 0 (Packets) 0 (Bytes)
  CIR 50 (%), CBS 600 (ms), EBS 0 (ms)
表3-1 display qos gts命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成
Rule
匹配规则
CIR
承诺信息速率,当采用绝对值形式输入时,单位为kbps
CBS
承诺突发尺寸,当采用绝对值形式输入时,单位为byte
EBS
超出突发尺寸,当采用绝对值形式输入时,单位为byte
PIR
峰值速率,当采用绝对值形式输入时,单位为kbps
Queue Length
缓冲队列能够容纳的数据包的个数
Queue Size
当前缓冲区中数据包的数目
Passed
已经通过的数据包数目和字节数
Discarded
被丢弃的数据包数目和字节数
Delayed
被延迟发送的数据包数目和字节数
3.1.2  qos gts
qos gts命令用来在接口上配置流量整形。
undo qos gts命令用来取消接口上流量整形的配置。
undo qos gts queue queue-id
接口上未配置流量整形。
queue queue-id:对队列queue上的数据包进行流量整形,queue-id为匹配的队列号,取值范围为0~7。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为8~1048576,取值必须为8的倍数。
cbs committed-burst-size:承诺突发尺寸,单位为byte。取值范围为512~16777216,取值必须为512的倍数。
# 在接口GigabitEthernet1/0/1上对报文进行流量整形。正常流速为200kbps,突发流量为1024bytes。
[Sysname-GigabitEthernet1/0/1] qos gts queue 1 cir 200 cbs 1024
3.2  限速配置命令
display qos lr命令用来显示接口或PW上的限速配置情况和统计信息。
display qos lr { interface [ interface-type interface-number ] | l2vpn-pw [ peer ip-address pw-id pw-id ] }
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的限速配置情况和运行统计信息。
peer ip-address pw-id pw-id:显示指定PW上的限速配置情况和运行统计信息。ip-address为PW远端PE的LSR ID。pw-id为PW的PW ID,取值范围为1~4294967295。如果未指定本参数,将显示所有PW上的限速配置情况和运行统计信息。
# 显示所有接口的接口限速配置情况和统计信息。
 Direction: Inbound
  CIR 2000 (kbps), CBS 20480 (Bytes), EBS 0 (Bytes)
  Passed   : 1000 (Packets) 1000 (Bytes)
  Discarded: 1000 (Packets) 1000 (Bytes)
  Delayed  : 1000 (Packets) 1000 (Bytes)
  Active shaping: No
 Direction: Outbound
  Active shaping: No
# 显示所有PW上的限速配置情况和统计信息。
<Sysname> display qos lr l2vpn-pw
L2VPN-PW: peer 1.2.3.4, pw-id 1
  Direction: Outbound
   CIR 1024 (kbps), CBS 64000 (Bytes), EBS 0 (Bytes)
   Active shaping: No
表3-2 display qos lr命令显示信息描述表
L2VPN-PW
显示指定PW的信息,PW通过远端PE地址和PW ID唯一标识
Direction
方向,可以是Inbound、Outbound
CIR
CBS
EBS
Passed
已经通过的数据包数目和字节数
Discarded
被丢弃的数据包数目和字节数
Delayed
被延迟发送的数据包数目和字节数
Active shaping
当前限速配置是否被激活,Yes表示激活,No表示未激活
3.2.2  qos lr
qos lr命令用来配置限速。
undo qos lr命令用来取消配置的限速。
undo qos lr { inbound | outbound }
未配置限速。
接口视图/交叉连接PW视图/VSI LDP PW视图/VSI静态PW视图
inbound:对接收的数据流进行限速。
outbound:对发送的数据流进行限速。
cbs committed-burst-size:承诺突发尺寸,单位为bytes。取值范围为512~16777216,取值必须为512的倍数。
# 对接口GigabitEthernet1/0/1上出方向的报文进行限速。正常流速为200kbps,突发流量为51200bytes,以后速率小于等于200kbps时正常发送,速率大于200kbps时,将进行限速。
[Sysname-GigabitEthernet1/0/1] qos lr outbound cir 200 cbs 51200
4 硬件实现拥塞管理
4.1  严格优先级队列配置命令
display qos queue sp interface命令用来显示接口的SP(Strict Priority,严格优先级)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的SP队列配置情况。
# 显示GigabitEthernet1/0/1的严格优先级队列配置情况。
<Sysname> display qos queue sp interface gigabitethernet 1/0/1
 Output queue: Strict Priority queuing
表4-1 display qos queue sp interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
4.1.2  qos sp
qos sp命令用来在接口上配置严格优先队列。
undo qos sp命令用来恢复缺省情况。
qos sp
undo qos sp
接口上使用WRR队列。
# 在接口GigabitEthernet1/0/1上应用SP模式的队列调度。
[Sysname-GigabitEthernet1/0/1] qos sp
·     display qos queue sp interface
4.2  加权轮询队列配置命令
display qos queue wrr interface命令用来显示接口的WRR(Weighted Round Robin,加权轮询)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WRR队列配置情况。
# 显示接口GigabitEthernet1/0/1的WRR队列配置情况。
<Sysname> display qos queue wrr interface gigabitethernet 1/0/1
 Output queue: Weighted Round Robin queuing
 Queue ID        Queue    name      Group           Weight
 0               be              1               1
 1               af1             1               1
 2               af2             1               1
 3               af3             1               1
 4               af4             1               1
 5               ef              1               1
 6               cs6             1               1
 7               cs7             sp              N/A
表4-2 display qos queue wrr interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
Queue ID
队列号
Queue name
队列名称
Group
分组号,说明队列属于哪一个分组,缺省情况下,队列所属的分组号为1
Byte count
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算,N/A表示该队列采用SP调度算法
Weight
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算, N/A表示该队列采用SP调度算法
4.2.2  qos wrr
qos wrr命令用来在接口上开启WRR队列,并指明当前WRR队列调度权重的计算方式。
undo qos wrr命令用来恢复缺省情况。
undo qos wrr { byte-count | weight }
接口上使用WRR队列。
byte-count:表示按照每次轮询可发送的字节数进行计算。
weight:表示按照每次轮询可发送的报文个数进行计算。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行WRR配置。
# 在接口GigabitEthernet1/0/1上开启WRR队列,并按照每次轮询可发送的报文个数进行计算。
[Sysname-GigabitEthernet1/0/1] qos wrr weight
# 在接口GigabitEthernet1/1上开启WRR队列,并按照每次轮询可发送的字节数进行计算。
[Sysname] interface gigabitethernet 1/1
[Sysname-GigabitEthernet1/0/1] qos wrr byte-count
·     display qos queue wrr interface
qos wrr { byte-count | weight }命令用来配置WRR队列或修改WRR队列的参数。
undo qos wrr命令用来取消WRR队列调度参数的配置。
qos wrr queue-id group { 1 { byte-count | weight } schedule-value | sp }
undo qos wrr queue-id
WRR队列属于group 1,按照byte-count进行计算。。
queue-id:队列序号。取值范围为0~7。
group 1:表示该队列属于哪个WRR优先组,缺省为group 1。
schedule-value:配置队列的调度权重,缺省的调度权重值如下表所示。
sp:严格优先级调度算法。
表4-3 queue-id数字和关键字对应表
队列序号
缺省的调度权重值
0
1
1
2
2
3
3
4
4
5
5
9
6
13
7
15
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行本配置。
queue-id除了支持数字外,还支持直接输入关键字,具体情况请参见表4-4。
表4-4 queue-id数字和关键字对应表
queue-id数字
queue-id关键字
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
# 在接口GigabitEthernet1/0/1上应用WRR队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10,分组为1。
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group 1 byte-count 10
·     qos wrr
qos wrr group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wrr group sp命令用来取消将队列加入SP组。
qos wrr queue-id group sp
接口上使用WRR队列,属于WRR优先组1。
本命令需要在端口队列为WRR调度模式下使用。
SP组与普通WRR优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WRR优先组。
# 在接口GigabitEthernet1/0/1上应用WRR队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group sp
·     qos wrr
4.3  加权公平队列配置命令
display qos queue wfq interface命令用来显示接口的WFQ配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WFQ配置情况。
# 显示接口GigabitEthernet1/1的加权公平队列配置情况。
<Sysname> display qos queue wfq interface gigabitethernet 1/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID        Queue name      Group           Byte count      Min Bandwidth
 0               be              1               1               64
 1               af1             1               1               64
 2               af2             1               1               64
 3               af3             1               1               64
 4               af4             1               1               64
 5               ef              1               1               64
 6               cs6             1               1               64
 7               cs7             1               1               64
表4-5 display qos queue wfq interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
Queue ID
队列号
Queue name
队列名称
Group
Byte-count
Weight
Min-Bandwidth
队列的最小保证带宽值
qos bandwidth queue命令用来配置端口队列的最小带宽保证。
undo qos bandwidth queue命令用来恢复缺省情况。
undo qos bandwidth queue queue-id
WFQ队列的最小保证带宽值为64kbps。
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。取值范围为8~1000000。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行本配置。
# 在接口GigabitEthernet1/0/1上配置队列0的最小保证带宽值为100kbps。
[Sysname-GigabitEthernet1/0/1] qos wfq weight
[Sysname-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
·     qos wfq
4.3.3  qos wfq
qos wfq命令用来在接口上开启WFQ队列,并指明当前WFQ队列调度权重的计算方式。
undo qos wfq命令用来恢复缺省情况。
undo qos wfq { byte-count | weight }
接口上使用WRR队列。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行WFQ配置。
# 在接口GigabitEthernet1/0/1上开启WFQ队列,并按照每次轮询可发送的报文个数进行计算。
# 在接口GigabitEthernet1/0/1上开启WFQ队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-GigabitEthernet1/0/1] qos wfq byte-count
·     display qos queue wfq interface
qos wfq { byte-count | weight }命令用来配置WFQ队列或修改WFQ队列的参数。
undo qos wfq命令用来取消WFQ队列调度参数的配置。
qos wfq queue-id group 1 { byte-count | weight } schedule-value
undo qos wfq queue-id
WFQ队列属于group 1。
group 1:表示该队列属于哪个WFQ优先组,缺省为group 1。
schedule-value:配置队列的调度权重,缺省的调度权重值为1。
# 在接口GigabitEthernet1/0/1上应用WFQ队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10,分组为1。
[Sysname-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 10
·     qos bandwidth queue
·     qos wfq
qos wfq group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wfq group sp命令用来取消将队列加入SP组。
qos wfq queue-id group sp
接口上使能WFQ队列后,WFQ队列都属于group 1。
queue-id:队列序号。不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
本命令需要在端口队列为WFQ调度模式下使用。
SP组与普通WFQ优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WFQ优先组。
# 在接口GigabitEthernet1/0/1上应用WFQ队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-GigabitEthernet1/0/1] qos wfq 0 group sp
·     qos wfq
5 全局CAR
5.1  全局CAR配置命令
5.1.1  car name
car name命令用来配置全局CAR动作。
undo car用来恢复缺省情况。
car name car-name
undo car
未配置全局CAR动作。
流行为视图
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
hierarchy-car-name:分层CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。本参数的支持情况和设备的型号有关,请以设备的实际情况为准。
# 配置流行为be1的聚合CAR动作为aggcar-1。
·     display qos car name
·     display traffic behavior user-defined
display qos car name命令用来显示全局CAR的配置和统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。显示指定全局CAR的配置和统计信息。如果未指定本参数,将显示所有全局CAR的配置和统计信息。
# 显示全局CAR的配置和统计信息。
<Sysname> display qos car name
  Mode: aggregative
   CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
   Green action  : pass
  Slot 0:
   Green packets : 0 (Packets), 0 (Bytes)
   Yellow packets: 0 (Packets), 0 (Bytes)
   Red packets   : 0 (Packets), 0 (Bytes)
表5-1 display qos car name命令显示信息描述表
Name
全局CAR的名称
Mode
全局CAR的类型
·     aggregative:聚合CAR
CIR  CBS  PIR  EBS
流量监管流量的参数配置
Green action
对绿色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Yellow action
对黄色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Red action
对红色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
5.1.3  qos car
qos car命令用来配置聚合CAR或分层CAR。
undo qos car命令用来取消聚合CAR或分层CAR的配置。
qos car car-name aggregative  cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative  cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
未配置聚合CAR。
aggregative:该全局CAR为聚合模式。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为8~160000000,且取值必须为8的倍数。
cbs committed-burst-size:承诺突发尺寸,即实际平均速率在承诺速率以内时的突发流量,单位为byte。取值范围为512~256000000,且取值必须为512的倍数。
ebs excess-burst-size:过度突发尺寸,单位为byte。取值范围为0~256000000,且取值必须为512的倍数。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为8~160000000,且取值必须为8的倍数。
action:对数据包采取的动作,有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63;用文字表示时,可以选取af11、af12、af13、af21、af22、af23、af31、af32、af33、af41、af42、af43、cs1、cs2、cs3、cs4、cs5、cs6、cs7、default、ef。
聚合CAR配置需要在接口上应用或在策略中引用后才能生效。
# 配置聚合CAR采取的CAR参数取值,cir取值为200,cbs取值为2048,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 200 cbs 2048 red discard
reset qos car name命令用来清除全局CAR的统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。清除指定全局CAR的统计信息。如果未指定本参数,将清除所有全局CAR的统计信息。
# 清除全局CAR aggcar-1的统计信息。
<Sysname> reset qos car name aggcar-1
