07-MPLS命令参考
04-MPLS L2VPN命令
本章节下载: 04-MPLS L2VPN命令  (454.01 KB)
04-MPLS L2VPN命令
1 MPLS L2VPN
1.1 MPLS L2VPN配置命令
1.1.1 ac interface
1.1.2 address-family l2vpn
1.1.3 auto-discovery
1.1.4 backup-peer
1.1.5 ccc
1.1.6 cem class-attach
1.1.7 cem clock recover
1.1.8 cem clock transmit differential
1.1.9 cem signaling cas
1.1.10 cem-class
1.1.11 connection
1.1.12 connection remote-site-id
1.1.13 control-word enable
1.1.14 crc
1.1.15 default
1.1.16 description (CEM interface view)
1.1.17 description (cross-connect group view)
1.1.18 display bgp l2vpn signaling
1.1.19 display interface circuit-emulation
1.1.20 display l2vpn bgp
1.1.21 display l2vpn forwarding
1.1.22 display l2vpn ldp
1.1.23 display l2vpn pw
1.1.24 display l2vpn pw-class
1.1.25 display l2vpn service-instance
1.1.26 display l2vpn xconnect-group
1.1.27 encapsulation
1.1.28 idle-code
1.1.29 interface circuit-emulation
1.1.30 jitter-buffer
1.1.31 l2vpn enable
1.1.32 l2vpn reflector
1.1.33 l2vpn switchover
1.1.34 mtu
1.1.35 payload
1.1.36 peer
1.1.37 peer signaling
1.1.38 policy vpn-target
1.1.39 protection dual-receive
1.1.40 pw-class (cross-connect auto-discovery view)
1.1.41 pw-class (system view)
1.1.42 pw-type
1.1.43 reset counters interface
1.1.44 reset l2vpn statistics pw
1.1.45 revertive
1.1.46 route-distinguisher
1.1.47 rr-filter
1.1.48 rtp-header enable
1.1.49 sequencing
1.1.50 service-instance
1.1.51 shutdown (CEM interface view)
1.1.52 shutdown (cross-connect group view)
1.1.53 site
1.1.54 snmp-agent trap enable l2vpn
1.1.55 statistics enable (cross-connect PW view)
1.1.56 tunnel-policy (auto-discovery cross-connect view)
1.1.57 vpn-target
1.1.58 xconnect-group
1 MPLS L2VPN
1.1  MPLS L2VPN配置命令
1.1.1  ac interface
ac interface命令用来指定交叉连接关联的接口或以太网服务实例。
undo ac interface命令用来取消接口或以太网服务实例与交叉连接的关联。
ac interface interface-type interface-number { service-instance instance-id } [ access-mode { ethernet | vlan } ]
undo ac interface interface-type interface-number { service-instance instance-id }
交叉连接未关联接口或以太网服务实例。
交叉连接视图/自动发现交叉连接视图
interface-type interface-number:指定与交叉连接关联的接口信息。interface-type interface-number为接口类型和接口编号。
service-instance instance-id:指定以太网服务实例。instance-id为以太网服务实例编号,取值范围为1~4096。
access-mode:指定接入模式。当关联交叉连接的AC为以太网服务实例时,可以指定本参数,接入模式缺省为VLAN;当AC为三层接口或三层子接口时,不可以指定本参数。
ethernet:指定接入模式为Ethernet。
vlan:指定接入模式为VLAN。
在交叉连接视图/自动发现交叉连接视图下执行本命令后,从关联接口接收到的所有报文或符合指定以太网服务实例报文匹配规则的报文,将通过与该交叉连接关联的PW或另一条AC转发。
接入模式是PE对从CE收到的以太网帧携带的外层VLAN Tag的理解方式,以及PE向CE发送以太网帧的方式。接入模式分为两种:
·     VLAN接入模式:CE发送给PE的以太网帧头需要带有一个VLAN Tag,该Tag被称为P-Tag,即服务提供商网络为了区分用户而添加的“服务定界符”。PE发送以太网帧给CE时,也需要携带P-Tag。
·     Ethernet接入模式:CE发送给PE的以太网帧头中如果带有VLAN Tag,则该Tag被称为U-Tag,即用户网络的内部VLAN Tag,对于PE设备没有意义。PE发送以太网帧给CE时,不需要携带P-Tag。
执行本命令关联以太网服务实例前,必须通过encapsulation命令为指定的以太网服务实例配置报文匹配规则。
# 接口GigabitEthernet1/0/1下采用以太网服务实例200来匹配外层VLAN Tag为200的报文,在交叉连接组vpn1的交叉连接actopw中关联该以太网服务实例。
[Sysname-GigabitEthernet1/0/1] service-instance 200
[Sysname-GigabitEthernet1/0/1-srv200] encapsulation s-vid 200
[Sysname-GigabitEthernet1/0/1-srv200] quit
[Sysname] xconnect-group vpn1
[Sysname-xcg-vpn1] connection actopw
[Sysname-xcg-vpn1-actopw] ac interface gigabitethernet 1/0/1 service-instance 200
# 接口GigabitEthernet1/0/1下采用以太网服务实例200来匹配外层VLAN Tag为200的报文,在交叉连接组vpwsbgp的自动发现交叉连接视图下关联该以太网服务实例。
[Sysname] xconnect-group vpwsbgp
[Sysname-xcg-vpwsbgp] auto-discovery bgp
[Sysname-xcg-vpwsbgp-auto] site 1 range 10 default-offset 0
[Sysname-xcg-vpwsbgp-auto-1] connection remote-site-id 2
[Sysname-xcg-vpwsbgp-auto-1-2] ac interface gigabitethernet 1/0/1 service-instance 200
·     connection
·     display l2vpn interface
·     display l2vpn service-instance
·     encapsulation
·     pw-type
address-family l2vpn命令用来创建BGP L2VPN地址族,并进入BGP L2VPN地址族视图。如果BGP L2VPN地址族已经存在,则直接进入BGP L2VPN地址族视图。
undo address-family l2vpn命令用来删除BGP L2VPN地址族及BGP L2VPN地址族视图下的所有配置。
不存在BGP L2VPN地址族。
BGP实例视图
在MPLS L2VPN组网中,要想建立BGP PW,需要在PE设备的BGP L2VPN地址族视图下通过peer enable命令使能BGP对等体,以便PE与该对等体交换L2VPN信息。
# 在BGP实例default下,创建BGP L2VPN地址族,并进入BGP L2VPN地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn
[Sysname-bgp-default-l2vpn]
# 在BGP实例abc下,创建BGP L2VPN地址族,并进入BGP L2VPN地址族视图。
[Sysname] bgp 100 instance  abc
[Sysname-bgp-abc] address-family l2vpn
[Sysname-bgp-abc-l2vpn]
auto-discovery命令用来指定交叉连接组采用BGP方式自动发现邻居、建立PW,并进入交叉连接组自动发现视图。
undo auto-discovery命令用来恢复缺省情况。
auto-discovery bgp
undo auto-discovery
交叉连接组不会采用BGP方式自动发现邻居并建立PW。
交叉连接组视图
bgp:指定交叉连接组采用BGP方式自动发现邻居并建立PW。
执行本命令进入交叉连接组自动发现视图后,在该视图下可以配置BGP信令协议的相关参数,如本端站点、远端站点、Route Target属性等,以便PE设备通过BGP信令协议自动发现远端PE设备,并建立连接两端站点的PW。
# 指定名为bbb的交叉连接组使用BGP方式自动发现邻居、建立PW,并进入交叉连接组自动发现视图。
[Sysname] xconnect-group bbb
[Sysname-xcg-bbb] auto-discovery bgp
[Sysname-xcg-bbb-auto]
·     display l2vpn pw
·     display l2vpn xconnect-group
1.1.4  backup-peer
backup-peer命令用来配置交叉连接的备份PW,并进入交叉连接备份PW视图。如果指定的备份PW已经存在,则直接进入交叉连接备份PW视图。
undo backup-peer命令用来恢复缺省情况。
backup-peer ip-address pw-id pw-id [ in-label label-value out-label label-value ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
undo backup-peer ip-address pw-id pw-id
不存在交叉连接的备份PW。
交叉连接PW视图
ip-address:指定备份PW远端PE的LSR ID。
pw-id pw-id:指定备份PW的PW ID。pw-id为PW ID,取值范围为1~4294967295。
in-label label-value:指定备份PW的入标签。label-value为入标签值,取值范围为16~1023。
out-label label-value:指定备份PW的出标签。label-value为出标签值,取值范围为16~1048575。
pw-class class-name:指定备份PW引用的PW模板。class-name表示PW模板名,为1~19个字符的字符串,区分大小写。PW模板中可以配置PW的数据封装类型、是否使用控制字等。如果不指定本参数,则PW数据封装类型由接口的链路类型决定,对于不强制要求使用控制字的PW数据封装类型,不支持控制字功能。
tunnel-policy tunnel-policy-name:指定备份PW的隧道选择策略。tunnel-policy-name表示隧道策略名,为1~19个字符的字符串,区分大小写。如果不指定本参数,则使用缺省的隧道选择策略。
备份PW作为主PW的备份,可以为主PW提供冗余保护。当主PW出现故障时,设备将通过主PW对应的备份PW转发流量。
配置备份的静态PW时,必须指定in-label和out-label参数;配置备份的LDP PW时,无需指定此参数。
配置备份PW时指定的远端PE的LSR ID和PW ID,不能与已经存在的VPLS PW、交叉连接PW的LSR ID和PW ID同时相同。
PW冗余保护功能和多段PW功能互斥。即,如果在交叉连接视图下通过重复执行peer命令配置了两条PW,则在交叉连接PW视图下不能执行backup-peer命令配置备份PW;反之亦然。
如果为静态PW指定的入标签与已经存在的静态LSP/静态CRLSP的入标签相同,则会导致标签冲突,静态PW不可用。即使修改静态LSP/静态CRLSP的入标签,静态PW仍不可用,需要手工删除该静态PW并重新配置。
# 为交叉连接组vpn2内的交叉连接pw2pw配置主备静态PW:主PW的远端PE地址为6.6.6.6,PW ID为100;备份PW的远端PE地址为7.7.7.7,PW ID为200。
[Sysname] xconnect-group vpn2
[Sysname-xcg-vpn2] connection pw2pw
[Sysname-xcg-vpn2-pw2pw] peer 6.6.6.6 pw-id 100 in-label 16 out-label 17
[Sysname-xcg-vpn2-pw2pw-6.6.6.6-100] backup-peer 7.7.7.7 pw-id 200 in-label 18 out-label 19
[Sysname-xcg-vpn2-pw2pw-6.6.6.6-100-backup]
·     display l2vpn ldp
·     display l2vpn pw
·     peer
1.1.5  ccc
ccc命令用来创建一条CCC(Circuit Cross Connect,电路交叉连接)远程连接。
undo ccc命令用来恢复缺省情况。
ccc in-label in-label-value out-label out-label-value { nexthop nexthop | out-interface interface-type interface-number } [ pw-class class-name ]
undo ccc
不存在CCC远程连接。
交叉连接视图
in-label in-label-value:指定CCC远程连接的入标签。in-label-value为入标签值,取值范围为16~1023。
out-label out-label-value:指定CCC远程连接的出标签。out-label-value为出标签值,取值范围为16~1048575。
nexthop nexthop:指定CCC远程连接的下一跳IP地址。
out-interface interface-type interface-number:指定CCC远程连接的出接口。interface-type interface-number为接口类型和接口编号。
pw-class class-name:指定CCC远程连接引用的PW模板。class-name表示PW模板名,为1~19个字符的字符串,区分大小写。PW模板中可以配置PW的数据封装类型、是否使用控制字等。如果不指定本参数,则PW数据封装类型由接口的链路类型决定,对于不强制要求使用控制字的PW数据封装类型,不支持控制字功能。
CCC远程连接是通过在PE设备上手工指定入标签和出标签而建立的一条静态连接。CCC远程连接不需要公网隧道来承载,它通过在PE之间的P设备上配置两条方向相反的静态LSP,来实现报文跨越公网传送。通过CCC远程连接转发二层用户报文时,只需为用户报文封装一层标签。
建立CCC远程连接时,需要在本地PE和远端PE上均执行本命令创建CCC远程连接。如果两端PE之间存在P设备,则还需要在P设备上配置两条方向相反的静态LSP。配置时,需要确保为某一台设备指定的出标签必须与为其下一跳指定的入标签相同。
在交叉连接视图下建立CCC远程连接后,还需在该视图下执行ac interface命令指定关联的接口或以太网服务实例,以实现从关联接口接收到的所有报文或符合指定以太网服务实例报文匹配规则的报文,通过建立的CCC远程连接转发。
只有出接口连接的链路是点到点链路时,才能够使用out-interface参数指定出接口。如果出接口连接的链路不是点到点链路,如出接口类型为VLAN接口,则必须使用nexthop参数指定下一跳IP地址。
创建CCC远程连接时,需要保证两端PE上CCC远程连接的封装类型、控制字功能等配置保持一致,否则可能会导致报文转发失败。
# 在交叉连接视图下创建一条CCC远程连接:下一跳为10.1.1.1,入标签为100,出标签为200,引用的PW模板为pwc1。
[Sysname-xcg-bbb] connection ccc1
[Sysname-xcg-bbb-ccc1] ccc in-label 100 out-label 200 nexthop 10.1.1.1 pw-class pwc1
·     ac interface
·     display l2vpn pw
cem class-attach命令用来在接口上引用电路仿真类。
undo cem class-attach命令用来恢复缺省情况。
cem class-attach cem-class-name
设备各款型对于本节所描述的命令及参数的支持情况有所不同,详细差异信息如下:
型号
RA10
cem class-attach
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
接口未引用任何电路仿真类。
电路仿真接口视图
cem-class-name:电路仿真类的名称,为1~19个字符的字符串,不区分大小写。
在电路仿真接口上引用电路仿真类后,该接口上TDM电路仿真业务采用的参数值为该电路仿真类下配置的值。
# 在E1控制器通道化出来的Circuit-Emulation2/3/0:0上引用电路仿真类satop。
[Sysname] controller e1 2/3/0
[Sysname-E1 2/3/0] cem-set 0 timeslot-list 1-5
[Sysname-E1 2/3/0] quit
[Sysname] interface circuit-emulation 2/3/0:0
[Sysname-Circuit-Emulation2/3/0:0] cem class-attach satop
cem clock recover命令用来配置电路仿真时钟恢复方式。
undo cem clock recover命令用来恢复缺省情况。
cem clock recover { adaptive | differential }
型号
RA10
cem clock recover
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
不进行时钟恢复。
电路仿真接口视图
adaptive:Adaptive Clock Recovery,自适应时钟恢复方式。
differential:Differential Clock Recovery,差分时钟恢复方式。
TDM电路采用时分复用技术,有严格的系统时钟同步要求,以传送实时同步业务。而分组交换网是基于统计复用的分组交换技术,接收端与发送端没有严格的时钟同步要求。所以,当采用分组网来传输TDM业务时,出口PE需进行时钟恢复,时钟恢复方式有以下两种:
·     ACR(Adaptive Clock Recovery,自适应时钟恢复):出口PE根据报文的到达速率和Jitter buffer的填充水平进行时钟恢复。此方式在入口PE和出口PE没有相同的时钟源时使用。
·     DCR(Differential Clock Recovery,差分时钟恢复):出口PE根据报文的RTP头中的差分时间戳信息进行时钟恢复。此方式在当出口PE和入口PE具有相同的时钟源时使用。
# 配置电路仿真时钟恢复方式为自适应时钟恢复方式。
[Sysname-Circuit-Emulation2/3/0:0] cem clock recover adaptive
cem clock transmit differential命令用来配置采用差分方式传送时间戳。
undo cem clock transmit differential命令用来恢复缺省情况。
型号
RA10
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
采用绝对方式传送时间戳。
电路仿真接口视图
时间戳的传送方式有两种:
·     绝对模式:入口PE采用从用户侧TDM电路恢复出的时钟来设置RTP头的时间戳。
·     差分模式:PW连接的两台PE设备访问同一个高质量同步时钟源,时钟传送的发送方采用TDM时钟与高质量同步时钟源的差值来设置RTP头的时间戳。
# 配置采用差分方式传送时间戳。
[Sysname-Circuit-Emulation2/3/0:0] cem clock transmit differential
cem signaling cas命令用来配置电路仿真接口上使用的信令类型为CAS(Channel-associated signaling,随路信令)。
undo cem signaling cas命令用来恢复缺省情况。
cem signaling cas
型号
RA10
cem signaling cas
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
电路仿真接口未使用CAS信令类型。
电路仿真接口视图
当对CAS的DS0(数字信号0)业务进行CESoPSN方式的电路仿真时,需通过本命令配置电路仿真接口上使用的信令类型为CAS。
# 配置电路仿真接口上使用的信令类型为随路信令。
[Sysname-Circuit-Emulation2/3/0] cem signaling cas
1.1.10  cem-class
cem-class命令用来创建一个电路仿真类,并进入电路仿真类视图。如果指定的电路仿真类已经存在,则直接进入电路仿真类视图。
undo cem-class命令用来删除指定的电路仿真类。
cem-class cem-class-name
undo cem-class cem-class-name
型号
RA10
cem-class
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
不存在电路仿真类。
通过本命令创建电路仿真类,并进入电路仿真类视图后,可在该视图下指定电路仿真的一组参数或属性,如Jitter-buffer的大小、每个分组净载荷的大小及分组丢失时的填充字符。
当多个TDM电路仿真业务采用相同的一组参数时,通过CEM(Circuit Emulation,电路仿真)类可以简化配置。
# 创建名为satop的电路仿真类,并进入电路仿真类视图。
[Sysname] cem-class satop
[Sysname-cem-satop]
1.1.11  connection
connection命令用来创建一条交叉连接,并进入交叉连接视图。如果指定的交叉连接已经存在,则直接进入交叉连接视图。
undo connection命令用来删除指定的交叉连接。
connection connection-name
undo connection connection-name
不存在L2VPN交叉连接。
交叉连接组视图
connection-name:交叉连接的名称,为1~20个字符的字符串,不能包含字符“-”,区分大小写。
L2VPN的交叉连接为点到点连接。
在交叉连接视图下,可以进行如下配置:
·     执行一次ac interface命令和一次peer命令将AC和PW关联,以实现从指定AC接收到的报文通过指定的PW转发、从指定PW上接收到的报文转发给指定AC。
·     执行两次ac interface命令将两条AC关联,以实现报文在两个AC之间进行本地交换。
·     执行两次peer命令将两条PW关联,以实现多段PW功能。
·     执行一次ac interface命令和一次ccc命令将AC和CCC远程连接关联,以实现从指定AC接收到的报文通过指定的CCC远程连接转发、从指定CCC远程连接上接收到的报文将转发给指定AC。
# 为交叉连接组vpn1创建名为ac2pw的交叉连接,并进入交叉连接视图。
[Sysname-xcg-vpn1] connection ac2pw
[Sysname-xcg-vpn1-ac2pw]
connection remote-site-id命令用来创建交叉连接,并进入自动发现交叉连接视图。如果指定的交叉连接已经存在,则直接进入自动发现交叉连接视图。
undo connection remote-site-id命令用来删除指定的交叉连接。
connection remote-site-id remote-site-id
undo connection remote-site-id remote-site-id
不存在交叉连接。
站点视图
remote-site-id:远端站点的ID。取值范围为0~250。
执行本命令后,设备将会在创建交叉连接的同时,采用BGP方式在当前站点和指定的远端站点之间建立一条PW,该PW与该交叉连接关联。
自动发现交叉连接视图下,可以执行ac interface命令将交叉连接与指定的AC关联,以实现从指定AC接收到的报文通过与该交叉连接关联的PW转发、从该PW上接收到的报文将转发给指定AC。
# 在站点视图下创建交叉连接,同时创建连接本地站点1和远端站点3的BGP PW,并进入自动发现交叉连接视图。
[Sysname-xcg-bbb-auto] site 1 range 10
[Sysname-xcg-bbb-auto-1] connection remote-site-id 3
[Sysname-xcg-bbb-auto-1-3]
control-word enable命令用来开启控制字功能。
undo control-word enable命令用来关闭控制字功能。
control-word enable
控制字功能处于关闭状态。
PW模板视图
控制字字段位于MPLS标签栈和二层数据之间,用来携带额外的二层数据帧的控制信息,如序列号等。控制字具有如下功能:
·     避免报文乱序:在多路径转发的情况下,报文有可能产生乱序,此时可以通过控制字的序列号字段对报文进行排序重组。
·     传送特定二层数据帧的标记:如帧中继的FECN(Forward Explicit Congestion Notification,前向显式拥塞通知)比特和BECN(Backward Explicit Congestion Notification,后向显式拥塞通知)比特等。
·     传送TDM电路的OAM相关标记:如LOS(Loss of Signal,信号丢失)和AIS(Alarm Indication Signal,告警指示信号)等。
·     指示净载荷长度:如果PW上传送报文的净载荷长度小于64字节,则需要对报文进行填充,以避免报文发送失败。此时,通过控制字的载荷长度字段可以确定原始载荷的长度,以便从填充后的报文中正确获取原始的报文载荷。
对于某些PW数据封装类型(如帧中继DLCI类型、ATM AAL5 SDU VCC类型),PW上传递的报文必须携带控制字字段,不能通过配置来控制;对于某些PW数据封装类型(如Ethernet、VLAN),控制字字段是可选的,可以通过配置来决定是否携带控制字。
本命令用来配置对于控制字字段可选的PW数据封装类型,本端是否支持携带控制字字段。报文实际是否携带控制字字段,由两端的配置共同决定:如果两端PE上都使能了控制字功能,则报文中携带控制字字段;否则,报文中不携带控制字字段。
# 使能PW模板pw100的控制字功能。
[Sysname] pw-class pw100
[Sysname-pw-pw100] control-word enable
·     display l2vpn pw-class
1.1.14  crc
crc命令用来配置电路仿真接口的CRC校验模式。
undo crc命令用来恢复缺省情况。
crc { 16 | 32 | none }
undo crc
型号
RA10
crc
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
电路仿真接口使用16位CRC校验。
电路仿真接口视图
16:电路仿真接口使用16位CRC校验。
32:电路仿真接口使用32位CRC校验。
none:电路仿真接口不进行CRC校验。
# 配置电路仿真接口Circuit-Emulation2/3/0:0使用32位CRC校验。
[Sysname-Circuit-Emulation2/3/0:0] crc 32
1.1.15  default
default命令用来恢复当前电路仿真接口的缺省配置。
default
型号
RA10
default
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
电路仿真接口视图
# 将电路仿真接口Circuit-Emulation2/3/0:0恢复为缺省配置。
[Sysname-Circuit-Emulation2/3/0:0] default
description命令用来设置当前接口的描述信息。
undo description命令用来恢复缺省情况。
型号
RA10
description
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
接口的描述信息为“接口名 Interface”,比如:Circuit-Emulation2/3/0:0 Interface。
电路仿真接口视图
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
# 配置电路仿真接口Circuit-Emulation2/3/0:0的描述信息为“router-interface”。
[Sysname-Circuit-Emulation2/3/0:0] description router-interface
description命令用来配置交叉连接组的描述信息。
未配置交叉连接组的描述信息。
交叉连接组视图
text:交叉连接组的描述信息,为1~80个字符的字符串,区分大小写。
# 配置名为vpn2的交叉连接组的描述信息为“vpws for vpn2”。
[Sysname-xcg-vpn2] description vpws for vpn2
display bgp l2vpn signaling命令用来显示BGP协议的MPLS L2VPN标签块信息。
display bgp [ instance instance-name ] l2vpn signaling [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ site-id site-id [ label-offset label-offset [ advertise-info ] ] ] | statistics ]
peer ip-address:显示向指定对等体发布或者从指定对等体收到的BGP协议的MPLS L2VPN标签块信息。ip-address表示对等体的IP地址。
advertised:显示向指定对等体发布的BGP协议的MPLS L2VPN标签块信息。
received:显示从指定对等体接收到的BGP协议的MPLS L2VPN标签块信息。
statistics:显示BGP协议的MPLS L2VPN标签块的统计信息。
route-distinguisher route-distinguisher:显示指定路由标识符的BGP协议MPLS L2VPN标签块信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
site-id site-id:显示为指定站点分配的BGP协议的MPLS L2VPN标签块信息。site-id为站点编号,取值范围为0~65535。
label-offset label-offset:显示标签块偏移量为指定值的BGP协议MPLS L2VPN标签块信息。label-offset为标签块偏移量,取值范围为0~65535。
advertise-info:显示BGP协议MPLS L2VPN标签块的通告信息。
执行本命令时,如果未指定任何参数,则显示所有BGP协议MPLS L2VPN标签块的简要信息。
# 显示BGP实例default内所有BGP协议MPLS L2VPN标签块的简要信息。
<Sysname> display bgp l2vpn signaling
 BGP local router ID is 192.168.1.135
 Total number of label blocks: 2
 Route distinguisher: 2:2
     Site ID  LB offset  LB range  LB base    Nexthop
* >  1        0          10        1034       0.0.0.0
* >i 2        0          10        1162       192.3.3.3
表1-1 display bgp l2vpn signaling命令简要显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     s - suppressed:聚合抑制路由
·     S - Stale:过期路由
·     i - internal:内部路由
·     e - external:外部路由
Origin
标签块信息的来源,取值包括:
·     i – IGP:表示产生于本AS内
·     e – EGP:表示是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
·     ? – incomplete:表示来源无法确定
所有标签块信息的总数
Route distinguisher
路由标识符
路由标识符为指定值的标签块信息的数目
Site ID
站点编号
LB offset
标签块偏移量
LB range
标签块大小
LB base
标签块的初始标签值
Nexthop
下一跳地址
# 显示BGP实例default内路由标识符为2:2、为站点2分配的、标签块偏移量为0的BGP协议MPLS L2VPN标签块的详细信息。
<Sysname> display bgp l2vpn signaling route-distinguisher 2:2 site-id 2 label-offset 0
 Local AS number: 100
 Total number of label blocks: 1
 Paths:   1 available, 1 best
 Original nexthop: 192.3.3.3
 Ext-Community   : <RT: 2:2>, <L2VPN info: MTU 1500, Encap type VLAN>
 AS-path         : (null)
 Origin          : igp
 Attribute value : localpref 100, pref-val 0
 Site ID         : 2
 LB offset       : 0
 LB base         : 1162
 LB range        : 10
 State           : valid, internal, best
 CSV             : 0x01000ABFFF
表1-2 display bgp l2vpn signaling命令详细显示信息描述表
BGP local router ID
BGP本地路由器ID
Local AS number
本地自治系统号
Route distinguisher
路由标识符
路由标识符为指定值的标签块信息的总数
Paths
标签块信息的数目:
·     available:有效可达信息条数
·     best:最佳可达信息条数
From
发布该信息的BGP对等体的IP地址
Original nexthop
原始下一跳地址,如果是从BGP更新消息中获得的标签块信息,则该地址为接收到的消息中的下一跳IP地址
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     L2VPN info:L2VPN相关信息,包括MTU值、封装类型(Encap type)
AS-path
AS路径属性,记录了此标签块信息经过的所有AS,可以避免环路的出现
Origin
标签块信息的起源代码,取值包括:
·     igp:表示可达信息来源于AS内部
·     egp:表示可达信息通过EGP学习
·     incomplete:表示可达信息的来源无法确定
Attribute value
标签块信息的属性值,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:首选值
·     pre:协议优先级
Site ID
站点编号
LB offset
标签块偏移量
LB base
标签块的初始标签值
LB range
标签块大小
标签块信息的当前状态,取值包括:
·     valid:有效信息
·     internal:内部信息
·     external:外部信息
·     local:本地产生信息
·     best:最佳信息
CSV
接入链路状态
# 显示BGP实例default内指定MPLS L2VPN标签块的通告信息。
<Sysname> display bgp l2vpn signaling route-distinguisher 2:2 site-id 1 label-offset 0 advertise-info
 Paths:   1 best
 Site ID         : 1
 LB offset       : 0
 LB base         : 1034
 LB range        : 10
 CSV             : 0x01000ADFFF
    192.3.3.3
表1-3 display bgp l2vpn signaling adveritse-info命令显示信息描述表
BGP local router ID
BGP本地路由器ID
Local AS number
本地自治系统号
Route distinguisher
路由标识符
路由标识符为指定值的标签块信息总数
Paths
标签块信息的数目:
·     best:最佳可达信息条数
Site ID
站点编号
LB offset
标签块偏移量
LB base
标签块的初始标签值
LB range
标签块大小
CSV
接入链路状态
该信息已经向哪些对等体发送,以及对等体的数目
display interface circuit-emulation命令用来显示电路仿真接口的相关信息。
display interface [ circuit-emulation [ interface-number ] ] [ brief [ description | down ] ]
型号
RA10
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
interface-number:显示指定电路仿真接口的信息。
description:显示用户配置的接口的全部描述信息。如果某接口的描述信息超过27个字符,不指定该参数时,只显示描述信息中的前27个字符,超出部分不显示;指定该参数时,可以显示全部描述信息。
如果不指定circuit-emulation参数,将显示设备支持的所有接口的相关信息。
如果指定circuit-emulation参数,不指定interface-number参数,将显示所有已创建的电路仿真接口的相关信息。
# 显示电路仿真接口Circuit-Emulation2/3/0:0的详细信息。
<Sysname> display interface circuit-emulation 2/3/0:0
Circuit-Emulation 2/3/0:0
Current state: UP
Line protocol state: UP
Description: Circuit-Emulation2/3/0:0 Interface
Bandwidth: 64kbps
Maximum transmit unit: 0
Clock recovery: ACR
Clock state: init
Input:
  Discarded: 0           Malformed: 0
  Reordered: 0           Lost: 0
  OutOfSeqDroped: 0      Stray: 0
  Lbit: 0                Rbit: 0
  JitBufOverrun: 0       JitBufUnderrun: 0
  Lops: 0                SentToTdm: 0
Output:
  Lbit: 0                Rbit: 0
表1-4 display interface circuit-emulation命令显示信息描述表
Current state
电路仿真接口当前的物理状态和管理状态,取值包括:
·     Administratively DOWN:表示该电路仿真接口已经通过shutdown命令被关闭,即管理状态为关闭
·     DOWN:表示该电路仿真接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     UP:该电路仿真接口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态,取值包括:
·     UP:表示数据链路层协议状态为开启
·     DOWN:表示数据链路层协议状态为关闭
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口当前不能处理IP报文
最近一次使用reset counters interface命令清除接口下的统计信息的时间。如果从设备启动一直未执行reset counters interface命令清除过该接口下的统计信息,则显示Never
Clock recover
电路仿真时钟恢复方式,取值包括:
·     ACR:表示配置了自适应时钟恢复方式
·     DCR:表示配置了差分时钟恢复方式
·     NONE:表示没有时钟恢复方式
ClockState
配置电路仿真时钟恢复方式后,时钟恢复的状态:
·     unknown:表示时钟恢复处于未知状态
·     N/A:表示时钟恢复处于不可用状态
·     init:表示时钟恢复处于初始化状态
·     hold-over:表示时钟恢复处于保持状态
·     learning:表示时钟恢复处于学习状态
·     locked:表示时钟恢复处于锁定状态
Input
电路仿真接口输入方向统计信息:
·     Discarded:表示被丢弃的报文计数
·     Malformed:表示畸形的报文计数
·     Reordered:表示重排序的报文计数
·     Lost:表示丢失的报文计数
·     OutOfSeqDroped:表示失序但无法重排序的报文计数
·     Stray:表示迷失或者失去连接的报文计数
·     Lbit:表示接收到本地失步故障的报文计数
·     Rbit:表示接收到远端接收故障的报文计数
·     JitBufOverrun:表示Jitter-buffer缓存Overrun的报文计数
·     JitBufUnderrun:表示Jitter-buffer缓存Underrun的报文计数
·     Lops:表示从正常状态转变到报文同步丢失状态的报文计数
·     SentToTdm:表示主动发送往TDM侧的报文计数
Output
·     Lbit:表示发送本地失步故障的报文计数
·     Rbit:表示发送远端接收故障的报文计数
# 显示电路仿真接口Circuit-Emulation2/3/0:0的概要信息。
<Sysname> display interface circuit-emulation 2/3/0:0 brief
Speed: (a) – auto
CEM2/3/0:0           DOWN --      --     --   --
# 显示当前物理状态为down的电路仿真接口的信息以及down的原因。
<Sysname> display interface circuit-emulation brief down
CEM2/3/0:0           DOWN Not connected
表1-5 display interface circuit-emulation brief命令显示信息描述表
Brief information on interface in bridge mode:
二层接口的概要信息
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口
Speed: (a) - auto
如果某接口的Speed属性值为“(a)”,则表示该接口的速率是通过自动协商获取的
如果某接口的Duplex属性值为“(a)”或者“A”,则表示该接口的Duplex属性是通过自动协商获取的;取值为“H”则表示为半双工;取值为“F”则表示为全双工
接口的链路类型,取值包括:
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
接口名称缩写
Link
接口物理连接状态,取值可能为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     ADM:表示接口被手工关闭了,需要执行undo shutdown命令才能打开接口
·     Stby:表示该接口是一个备份接口
Speed
接口的速率,单位为bps
Duplex
接口的双工模式,取值为:
·     A:表示双工模式由自动协商结果决定
·     F:表示全双工
·     F(a):表示自由协商的结果为全双工
·     H:表示半双工
·     H(a):表示自由协商的结果为半双工
链路类型,取值为:
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
PVID
接口所在的缺省VLAN ID
Cause
接口物理连接状态为down的原因,取值为Administratively时表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态;取值为Not connected时表示没有物理连接(可能没有插网线或者网线故障)
display l2vpn bgp命令用来显示MPLS L2VPN的标签块信息。
display l2vpn bgp [ local | peer ip-address ] [ xconnect-group group-name ] [ verbose ]
local:只显示本地分配的标签块信息。
peer ip-address:显示从指定远端PE接收到的标签块信息。ip-address为远端PE的地址。
xconnect-group group-name:显示指定交叉连接组内的标签块信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有交叉连接组的标签块信息。
verbose:显示详细信息。如果不指定本参数,则显示简要信息。
执行本命令时指定了peer ip-address参数,如果存在与从远端PE接收到的标签块匹配的本地标签块,即接收到的标签块信息中携带的远端Site ID满足条件:本地标签块LO<=远端Site ID<=本地标签块LO+LR-1,则同时显示远端标签块和匹配的本地标签块信息;否则,只显示从远端PE接收到的标签块信息。
执行本命令时,如果未指定peer ip-address和local参数,则显示从所有远端PE接收到的标签块信息。如果存在与远端标签块匹配的本地标签块,则同时显示本地标签块信息。
# 显示从所有远端PE接收到的标签块的简要信息。
<Sysname> display l2vpn bgp
Total number of BGP PWs: 1, 1 up, 0 down
Xconnect-group Name: vpnb, Site ID:1
Rmt Site   Offset  RD                    Nexthop          In/Out Label     State
2          0       2:2                   192.3.3.3        1036/1163        Up
表1-6 display l2vpn bgp命令显示信息描述表
BGP PW的总数,及处于up和down状态的BGP PW数目
Xconnect-group Name
交叉连接组名称
Site ID
本端Site标识符
Rmt Site
远端Site标识符
Offset
远端标签块的偏移量
RD
路由标识符
Nexthop
远端PE地址
In/Out Label
PW的入标签和出标签值
PW状态,取值包括Up、Down
# 显示从所有远端PE接收到的标签块的详细信息。
<Sysname> display l2vpn bgp verbose
 Remote Site ID     : 2
 Offset             : 0
 RD                 : 2:2
 PW State           : Up
 Encapsulation      : VLAN
 MTU                : 1500
 Nexthop            : 192.3.3.3
 Local VC Label     : 1036
 Remote VC Label    : 1163
 Link ID            : 1
 Local Label Block  : 1034/10/0
 Remote Label Block : 1162/10/0
 Export Route Target: 2:2
表1-7 display l2vpn bgp verbose命令显示信息描述表
Xconnect-group Name
交叉连接组名称
Site ID
本端Site标识符
Remote Site ID
远端Site标识符
Offset
远端标签块的偏移量
RD
路由标识符
PW State
PW状态,取值包括Up、Down
Encapsulation
PW数据封装类型
MTU
PW协商后的最大传输单元,单位为字节
Nexthop
远端PE地址
Local VC Label
PW的入标签
Remote VC Label
PW的出标签
Link ID
PW在交叉连接内的链路标识符
Local Label Block
本端的标签块信息,包括标签块的初始标签值/标签块大小/标签块的偏移量
Remote Label Block
从远端收到的标签块信息,包括标签块的初始标签值/标签块大小/标签块的偏移量
Export Route Target
从远端收到的标签块对应的Route Target属性
# 显示所有本地分配的标签块的简要信息。
<Sysname> display l2vpn bgp local
Site   Offset  Range  Label Base    RD
1      0       10     1034          2:2
表1-8 display l2vpn bgp local命令显示信息描述表
Xconnect-group Name
交叉连接组名称
Site
本端Site标识符
Offset
为该Site分配的标签块的偏移量
Range
为该Site分配的标签块大小
Label Base
为该Site分配的标签块的初始标签值
RD
标签块对应的路由标识符,如果未配置,则显示为“-”
# 显示所有本地分配的标签块的详细信息。
<Sysname> display l2vpn bgp local verbose
 Site ID            : 1
 Offset             : 0
 RD                 : 2:2
 Range              : 10
 Label Base         : 1034
 Link ID            : 1
表1-9 display l2vpn bgp local verbose命令显示信息描述表
Xconnect-group Name
交叉连接组名称
Site ID
本端Site标识符
Offset
为该Site分配的标签块的偏移量
RD
Range
为该Site分配的标签块大小
Label Base
为该Site分配的标签块的初始标签值
Link ID
标签块对应的Link ID序列值,即基于该标签块建立的PW的Link ID值
对于MPLS L2VPN来说,由于每个交叉连接下只能创建一条BGP PW,因此Link ID固定为1
·     display l2vpn pw
display l2vpn forwarding命令用来显示交叉连接的转发信息。
display l2vpn forwarding { ac | pw } [ xconnect-group group-name ] [ slot slot-number ] [ verbose ]
ac:显示AC的转发信息。
pw:显示PW的转发信息。
xconnect-group group-name:显示指定交叉连接组的转发信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有交叉连接组的转发信息。
slot slot-number:显示指定单板上的交叉连接转发信息。slot-number表示单板所在的槽位号。对于RA100路由器指的是设备本身,对于RA200路由器指的是设备上的主控板。
# 显示所有交叉连接组的AC转发简要信息。
<Sysname> display l2vpn forwarding ac
Total number of cross-connections: 2
Total number of ACs: 2
AC                               Xconnect-group Name              Link ID
GE1/0/5 srv1                     vpn1                            0
GE1/0/6 srv2                     vpn2                            0
表1-10 display l2vpn forwarding ac命令显示信息描述表
所有交叉连接组或指定交叉连接组下交叉连接的总数,包括未关联AC的交叉连接
Total number of ACs
所有交叉连接组或指定交叉连接组下AC的总数
AC
接入电路,取值为:二层接口名称和以太网服务实例:在交叉连接视图下关联以太网服务实例时,AC取值为此方式
Xconnect-group Name
AC所属交叉连接组的名称
Link ID
AC在交叉连接内的链路标识符
# 显示所有交叉连接组的AC转发详细信息。
<Sysname> display l2vpn forwarding ac verbose
Xconnect-group: vpws1
 Connection: actopw
  Interface: GE1/0/1
    Link ID      : 1
    Access Mode  : Ethernet
 Connection: actoac
  Interface: GE1/0/2
    Link ID      : 0
  Interface: GE1/0/3
    Link ID      : 1
    Reflector    :
      IP Address   : 100.1.1.4
      MAC Address  : 8850-fc51-5cee
      Src Port     : 200
      Dst Port     : 201
      State        : Succeeded
表1-11 display l2vpn forwarding ac verbose命令显示信息描述表
Xconnect-group Name
交叉连接组名称
Connection
交叉连接名称
接入接口
Service Instance
以太网服务实例,AC为二层接口的以太网服务实例时才显示该字段
Link ID
AC在交叉连接内的链路标识符
Access Mode
AC接入模式,取值包括:
·     VLAN:VLAN模式
·     Ethernet:Ethernet模式
Encapsulation
以太网服务实例的报文匹配规则,AC为二层接口的以太网服务实例时才显示该字段
Reflector
报文反射信息
IP Address
待反射报文的目的IP地址
MAC Address
待反射报文的目的MAC地址
Src Port
待反射报文的源UDP端口号
Dst Port
待反射报文的目的UDP端口号
报文反射下发驱动的状态,取值包括:
·     Succeeded:表示报文反射成功下发驱动
·     Reloading:表示报文反射正在重新下发驱动
·     Failed:表示报文反射下发驱动失败
# 显示所有交叉连接组的PW转发简要信息。
<Sysname> display l2vpn forwarding pw
Total number of cross-connections: 1
Total number of PWs: 2, 2 up, 0 blocked, 0 down
Xconnect-group Name             In/Out Label    NID        Link ID    State
vpn1                            1279/1151       1025       0          Up
vpn1                            1278/1151       1027       1          Up
表1-12 display l2vpn forwarding pw命令显示信息描述表
所有交叉连接组或指定交叉连接组下交叉连接的总数,包括未配置PW的交叉连接
Total number of PWs
所有交叉连接组或指定交叉连接组下PW总数,以及处于up、blocked、down状态的PW数目
Xconnect-group Name
PW所属交叉连接组的名称
In/Out Label
PW的入标签和出标签
NID
承载PW的隧道对应的NHLFE表项索引
·     存在等价隧道时,一个PW会对应多个NID
·     如果不存在隧道,显示为None
Link ID
PW在交叉连接内的链路标识符
PW的状态,取值包括Up、Down、Blocked和BFD Defect
其中,Blocked为存在主备PW的情况下,当前未转发流量、起到备份作用的PW的状态;BFD Defect为BFD检测到PW存在缺陷的状态
# 显示所有交叉连接组的PW转发详细信息。
<Sysname> display l2vpn forwarding pw verbose
Xconnect-group Name: vpn1
 Connection: ldp
  Link ID: 0
    PW Type         : VLAN                  PW State : Up
    In Label        : 1279                  Out Label: 1151
    MTU             : 1500
    PW Attributes   : Main
    VCCV CC         : Router-Alert
    VCCV BFD        : Fault Detection with BFD
    Tunnel Group ID : 0x60000000
    Tunnel NHLFE IDs: 1025
  Link ID: 1
    In Label        : 1278                  Out Label: 1151
    MTU             : 1500
    Tunnel Group ID : 0x160000001
    Tunnel NHLFE IDs: 1027
表1-13 display l2vpn forwarding pw verbose命令显示信息描述表
Xconnect-group Name
交叉连接组名称
Connection
交叉连接名称
Link ID
PW在交叉连接内的链路标识符
PW Type
PW数据封装类型
PW State
In Label
PW的入标签
Out Label
PW的出标签
MTU
PW协商后的最大传输单元
PW Attributes
PW的属性,取值包括
·     Main:主PW
·     Backup:备份PW
VCCV CC
检测PW的VCCV控制通道类型,取值包括:
·     Control-Word:控制字类型
·     Router-Alert:MPLS路由器告警标签类型
·     TTL:TTL超时类型
取值为“-”表示未指定VCCV控制通道类型
VCCV BFD
检测PW的BFD报文的封装方式,取值包括:
·     Fault Detection with BFD:BFD报文的封装方式为IP/UDP Encapsulation (with IP/UDP Headers)
·     Fault Detection with Raw-BFD:BFD报文的封装方式为PW-ACH Encapsulation (without IP/UDP Headers),即封装在VCCV控制通道内的BFD控制报文不携带IP和UDP头
取值为“-”表示未使用BFD检测PW的连通性
Tunnel Group ID
承载PW的隧道组ID
Tunnel NHLFE IDs
承载PW的隧道对应的NHLFE表项索引列表
存在等价隧道时,一个PW会对应多个索引值
如果不存在隧道,显示为None
display l2vpn ldp命令用来显示LDP协议通告的PW标签相关信息。
display l2vpn ldp [ peer ip-address [ pw-id pw-id ] | xconnect-group group-name ] [ verbose ]
peer ip-address:显示指定远端PE通过LDP通告的PW标签相关信息。ip-address为远端PE的LSR ID。如果未指定本参数,则显示所有远端PE通过LDP通告的PW标签相关信息。
pw-id pw-id:显示指定PW的PW标签相关信息。pw-id为PW的PW ID,取值范围为1~4294967295。如果指定了peer ip-address参数,未指定本参数,则显示指定远端PE通过LDP通告的所有PW标签相关信息。
xconnect-group group-name:显示指定交叉连接组内LDP协议通告的PW标签相关信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有交叉连接组内LDP协议通告的PW标签相关信息。
# 显示LDP协议通告的所有PW标签的简要信息。
<Sysname> display l2vpn ldp
Total number of LDP PWs: 5, 4 up, 1 down
Peer            PW ID/VPLS ID         In/Out Label    State Owner
192.3.3.3       1001                  775125/775126   Up    vpws1
192.3.3.3       1003                  775117/775122   Up    vpws3
192.3.3.3       1004                  775120/775120   Up    vpws4
192.4.4.4       1000                  775116/unknown  Down  vpws5
表1-14 display l2vpn ldp命令显示信息描述表
LDP PW的总数,及处于up和down状态的LDP PW数目
Peer
PW远端PE的IP地址
PW ID/VPLS ID
对于FEC 128方式,为PW标识符PW ID;对于FEC 129方式,为用来标识PE所属VPLS实例的VPLS ID
只有VPLS支持FEC 129方式
In/Out Label
PW的入标签和出标签
PW状态,取值包括:
·     Up:PW处于up状态
·     Down:PW处于down状态
Owner
PW所属交叉连接组的名称
# 显示LDP协议通告的所有PW标签的详细信息。
<Sysname> display l2vpn ldp verbose
Peer: 192.2.2.2        PW ID: 1000
  Xconnect-group: vpn1
  Connection    : ldp
  PW State      : Up
  PW Status Communication: Notification method
  PW ID FEC (Local/Remote):
    PW Type     : VLAN/VLAN
    Group ID    : 0/0
    Label       : 1151/1279
    Control Word: Disabled/Disabled
    VCCV CC Type: -/-
    VCCV CV Type: -/-
    MTU         : 1500/1500
    PW Status   : PW forwarding/PW forwarding
Peer: 192.3.3.3        PW ID: 1
  Xconnect-group: x1
  Connection    : c1
  PW State      : Up
    PW Type     : TDM-CESoPSN-Basic/TDM-CESoPSN-Basic
    Group ID    : 0/0
    Label       : 710127/710127
    Control Word: Enabled/Enabled
    VCCV CV Type: LSP Ping/LSP Ping
    VCCV CC Type: -/-
    Bit Rate    : 10/10
    Payload     : 80/80
    RTP Header  : Enabled/Enabled
    Timestamping: Differential/Differential
    Frequency   : 0/0
表1-15 display l2vpn ldp verbose命令显示信息描述表
Peer
PW远端PE的IP地址
PW ID
PW标识符
Xconnect-group
PW所属交叉连接组的名称
Connection
PW所属交叉连接的名称
PW State
PW状态,取值包括Up和Down
PW状态通知方式:
·     Notification method:通过Notification消息通知PW状态
·     Label withdraw method:标签回收方式,即只有PW连接的AC状态为up时才会为该PW分配PW标签,AC状态变为down时回收该PW的PW 标签
本地向远端PE通告的PW ID FEC相关信息/远端PE通告给本地的PW ID FEC相关信息
PW Type
PW数据封装类型
Group ID
PW的Group标识符
Label
PW标签
Control Word
是否使能控制字功能,取值包括
·     Enabled:PW使能了控制字功能
·     Disabled:PW未使能控制字功能
VCCV CC Type
支持的VCCV CC(Control Channel,控制通道)类型,取值包括:
·     TTL:TTL超时类型
VCCV(Virtual Circuit Connectivity Verification,虚电路连通性验证)的详细介绍,请参见“MPLS配置指导”中的“MPLS OAM”
VCCV CV Type
支持的VCCV CV(Connectivity Verification,连通性验证)类型,取值包括:
·     LSP Ping:采用MPLS ping检测PW的连通性
·     BFD:采用BFD检测PW的连通性,BFD报文的封装方式为IP/UDP Encapsulation (with IP/UDP Headers)
·     Raw-BFD:采用BFD检测PW的连通性,BFD报文的封装方式为PW-ACH Encapsulation (without IP/UDP Headers),即封装在VCCV控制通道内的BFD控制报文不携带IP和UDP头
取值为“-”表示不对PW进行VCCV CV检测
MTU
交叉连接的最大传输单元
Bit Rate
TDM接口比特率,取值与电路仿真接口的电路类型有关(单位:64Kbit/s):
·     SAToP的E1口:32
·     SAToP的T1口:24
·     CESoPSN的E1或T1接口:时隙数
Payload
TDM接口的负载大小,单位为字节或帧数,与执行payload命令时指定的单位一致
RTP Header
是否使能RTP头,取值包括:
·     Enabled:使能RTP头
·     Disabled:未使能RTP头
Timestamping
RTP头上时间戳的传送方式,取值包括:
·     Differential:差分时钟模式
·     Absolute:绝对时钟模式
Frequency
RTP头上打时间戳的时钟频率
PW Status
PW状态,取值包括:
·     PW forwarding:PW可以转发报文
·     PW not forwarding:PW不可以转发报文
·     AC receive fault:AC接收方向失效
·     AC transmit fault:AC发送方向失效
·     PW receive fault:PW接收方向失效
·     PW transmit fault:PW发送方向失效
display l2vpn pw命令用来显示L2VPN的PW信息。
display l2vpn pw [ xconnect-group group-name ] [ protocol { bgp | ldp | static } ] [ verbose ]
xconnect-group group-name:显示指定交叉连接组内L2VPN的PW信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有交叉连接组内L2VPN的PW信息。
protocol:显示采用指定信令协议建立的PW的信息。如果未指定本参数,则显示所有协议产生的PW信息。
bgp:显示采用BGP作为PW信令协议建立的PW的信息,即BGP PW信息。
ldp:显示采用LDP作为PW信令协议建立的PW的信息,即LDP PW信息。
static:显示采用静态方式建立的PW的信息,即静态PW信息,包括CCC远程连接信息。
开启PW统计功能后,可使用display l2vpn pw verbose命令查看PW的报文统计信息。
# 显示L2VPN所有PW的简要信息。
<Sysname> display l2vpn pw
Flags: M - main, B - backup, H - hub link, S - spoke link, N - no split horizon
2 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
Xconnect-group Name: ldp
Peer            PW ID/Rmt Site    In/Out Label    Proto   Flag  Link ID  State
192.3.3.3       500               1299/1299       LDP     M     0        Up
192.3.3.3       2                 1036/1163       BGP     M     1        Up
表1-16 display l2vpn pw命令显示信息描述表
Flags
PW属性标记的取值
Total number of PWs
PW的总数,及处于up、blocked、down、defect、idle和duplicate状态的PW数目
Xconnect-group Name
交叉连接组名称
Peer
PW远端PE的IP地址
PW ID/Rmt Site
如果是静态PW或LDP PW,则为PW标识符PW ID;如果是BGP PW,则为远端Site标识符Rmt Site
In/Out Label
PW的入标签和出标签
Proto
建立PW使用的信令协议,取值包括LDP、Static和BGP
Flag
PW属性标记,取值包括:
·     M:Main,主PW
·     B:Backup,备份PW
Link ID
PW在交叉连接内的链路标识符
PW状态,取值包括:
·     Up:表示该PW可用
·     Down:表示该PW不可用
·     Blocked:表示存在主备PW的情况下,该PW当前未转发流量、起到备份作用
·     Defect:表示BFD检测到该PW存在缺陷
·     Idle:表示该PW的入标签不可用
·     Dup:表示该静态PW的入标签与静态LSP或静态CRLSP的入标签相同
# 显示L2VPN所有PW的详细信息。
<Sysname> display l2vpn pw verbose
 Connection Name: ldp
  Peer: 192.3.3.3        PW ID: 500
    Signaling Protocol  : LDP
    Link ID             : 0          PW State : Up
    In Label            : 1299       Out Label: 1299
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x800000160000000
    Tunnel NHLFE IDs    : 1026
    Input statistics    :
      Octets   : 10600
      Packets  : 100
      Errors   : 0
      Discards : 0
    Output statistics   :
      Octets   : 12600
      Packets  : 100
      Errors   : 0
      Discards : 0
 Connection of auto-discovery: Site 1
  Peer: 192.3.3.3        Remote Site: 2
    Signaling Protocol  : BGP
    Link ID             : 1          PW State : Up
    In Label            : 1036       Out Label: 1163
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
表1-17 display l2vpn pw verbose命令显示信息描述表
Xconnect-group Name
PW所属的交叉连接组名称
Connection Name
PW所属的交叉连接名称,采用LDP或静态方式建立PW时,显示此信息
Peer
PW远端PE的IP地址
PW ID
PW标识符
Signaling Protocol
Link ID
PW在交叉连接内的链路标识符
PW State
PW状态,取值包括:
·     Up:表示该PW可用
·     Down:表示该PW不可用
·     Idle:表示该PW的入标签不可用
·     Duplicate:表示该静态PW的入标签与静态LSP或静态CRLSP的入标签相同
In Label
PW入标签
Out Label
PW出标签
Wait to Restore Time
回切等待时间,单位为秒。如果配置不回切,则显示为Infinite
只会在主备PW同时存在的情况下显示,并且只在主PW上显示
Remaining Time
回切等待的剩余时间,单位为秒。回切等待定时器启动时,才会显示该字段
MTU
PW协商后的最大传输单元
PW Attributes
PW的属性,取值包括:
·     Main:主PW
·     Backup:备份PW
VCCV CC
·     TTL:TTL超时类型
VCCV BFD
Tunnel Group ID
承载PW的隧道组ID
Tunnel NHLFE IDs
如果不存在隧道,显示为None
通过BGP方式建立的PW
Site
本端Site标识符
Remote site
远端Site标识符
Input statistics
入方向的PW转发统计信息,包括入方向接收的字节数(Octets)、接收的报文数(Packets)、接收的错误报文数(Errors)和丢弃的报文数(Discards)
 Output statistics
出方向的PW转发统计信息,包括出方向发送的字节数(Octets)、发送的报文数(Packets)、发送的错误报文数(Errors)和丢弃的报文数(Discards)
·     statistics enable
display l2vpn pw-class命令用来显示PW模板的信息。
display l2vpn pw-class [ class-name ] [ verbose ]
class-name:显示指定PW模板的信息。class-name表示PW模板的名称,为1~19个字符的字符串,区分大小写。如果不指定本参数,则显示所有PW模板的信息。
# 显示所有PW模板的信息。
<Sysname> display l2vpn pw-class
Total number of PW classes: 2
PW Class Name       PW Type              Control Word   VCCV CC        VCCV BFD
pw1                 Ethernet             Enabled        Control-Word   Raw-BFD
pw2                 VLAN                 Disabled       Router-Alert   BFD
表1-18 display l2vpn pw-class命令显示信息描述表
PW模板的总数
PW Class Name
PW模板的名称
PW Type
PW数据封装类型,取值包括Ethernet、VLAN、TDM-CESoPSN-Basic和TDM-SAToP-E1
Control Word
是否使能控制字功能,取值包括Enabled和Disabled
VCCV CC
·     TTL:TTL超时类型
VCCV BFD
·     BFD:BFD报文的封装方式为IP/UDP Encapsulation (with IP/UDP Headers)
·     Raw-BFD:BFD报文的封装方式为PW-ACH Encapsulation (without IP/UDP Headers),即封装在VCCV控制通道内的BFD控制报文不携带IP和UDP头
# 显示所有PW模板的详细信息。
<Sysname> display l2vpn pw-class verbose
PW Class Name : pw1
  PW Type     : Ethernet
  VCCV CC     : Control-Word
  VCCV BFD    : Raw-BFD
  Sequencing  : Both
PW Class Name : pw2
  PW Type     : VLAN
  VCCV BFD    : BFD
  Sequencing  : -
表1-19 display l2vpn pw-class verbose命令显示信息描述表
PW Class Name
PW模板的名称
PW Type
Control Word
VCCV CC
·     TTL:TTL超时类型
VCCV BFD
Sequencing
PW的排序处理,取值为Both。取值为“-”时表示未配置PW的排序处理,即不对PW上传输的报文进行排序
·     pw-class
display l2vpn service-instance命令用来显示以太网服务实例的信息。
interface interface-type interface-number:显示指定二层以太网接口或二层聚合接口上的以太网服务实例信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有二层以太网接口和二层聚合接口上的以太网服务实例信息。
service-instance instance-id:显示指定以太网服务实例的信息。instance-id为以太网服务实例的ID,取值范围为1~4096。如果指定了interface interface-type interface-number参数,未指定本参数,则显示指定二层以太网接口或二层聚合接口上所有以太网服务实例的信息。
# 显示所有以太网服务实例的简要信息。
<Sysname> display l2vpn service-instance
Total number of service-instances: 5, 5 up, 0 down
Total number of ACs: 4, 4 up, 0 down
Interface                SrvID Owner                           LinkID State Type
GE1/0/3                  1     vpws1                           1      Up    VPWS
GE1/0/3                  2     vpws2                           1      Up    VPWS
GE1/0/3                  3     vpws3                           1      Up    VPWS
GE1/0/3                  4     vpws4                           1      Up    VPWS
GE1/0/3                  5                                            Up
表1-20 display l2vpn service-instance命令显示信息描述表
以太网服务实例的总数,及处于up和down状态的以太网服务实例数目
Total number of ACs
AC的总数,及处于up和down状态的AC数目
二层以太网接口或二层聚合接口名称
SrvID
以太网服务实例的ID
Owner
交叉连接组名称,如果以太网服务实例尚未关联交叉连接,则该字段显示为空
LinkID
以太网服务实例对应AC在交叉连接内的链路标识符
以太网服务实例的状态,取值包括Up和Down
以太网服务实例所属的L2VPN类型,在MPLS L2VPN中取值为VPWS
# 显示二层以太网接口GigabitEthernet1/0/1上所有以太网服务实例的详细信息。
<Sysname> display l2vpn service-instance interface gigabitethernet 1/0/1 verbose
Interface: GE1/0/1
  Service Instance: 1
    Encapsulation : s-vid 1 to 16
    Connection    : actopw
    Link ID       : 1
    State         : Up
    Statistics    : Enabled
    Input Statistics:
      Octets   :0
      Packets  :0
    Output Statistics:
      Octets   :0
      Packets  :0
  Service Instance: 2
    Encapsulation : s-vid 1001 to 1002 1015 to 1016
                    only-tagged
    Xconnect-group: vpws2
    Connection    : pwtopw
    Link ID       : 1
    State         : Up
    Input Statistics:
      Octets   :0
      Packets  :0
    Output Statistics:
      Octets   :0
      Packets  :0
  Service Instance: 3
    Encapsulation : s-vid 2000
                    c-vid 1001 to 1002 1015 to 1016
    Xconnect-group: vpws3
    AD Connection : Site 1, Remote Site 2
    Link ID       : 1
    State         : Up
    Input Statistics:
      Octets   :0
      Packets  :0
    Output Statistics:
      Octets   :0
      Packets  :0
表1-21 display l2vpn service-instance verbose命令显示信息描述表
二层以太网接口或二层聚合接口
Service Instance
以太网服务实例ID
Encapsulation
以太网服务实例的报文匹配规则,如果未配置报文匹配规则,则不显示本字段
Xconnect-group
以太网服务实例所属的交叉连接组的名称
Connection
与以太网服务实例关联的交叉连接的名称
AD Connection
与以太网服务实例关联的自动发现交叉连接,由本端Site标识符(Site)和远端Site标识符(Remote Site)来标识
Link ID
Statistics
是否使能以太网服务实例的统计功能,取值包括:
·     Enabled:使能统计功能
·     Disabled:关闭统计功能
Input Statistics
以太网服务实例入方向报文的统计信息,包括接收的字节数(Octets)、接收的报文数(Packets)
Output Statistics
以太网服务实例出方向报文的统计信息,包括发送的字节数(Octets)、发送的报文数(Packets)
·     service-instance
display l2vpn xconnect-group命令用来显示交叉连接组的信息。
display l2vpn xconnect-group [ name group-name ] [ verbose ]
name group-name:显示指定交叉连接组的信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有交叉连接组的信息。
verbose:显示交叉连接组的详细信息。如果不指定本参数,则显示交叉连接组的简要信息。
# 显示所有交叉连接组的简要信息。
<Sysname> display l2vpn xconnect-group
Total number of cross-connections: 3, 0 up, 3 down, 0 admin down
Xconnect-group Name             Connection ID   MTU    State
abc                             0               1500   Down
vpn1                            2               1500   Down
vpn2                            1               1500   Down
表1-22 display l2vpn xconnect-group命令显示信息描述表
所有交叉连接组或指定交叉连接组下交叉连接的总数,以及处于up、down、admin down状态的交叉连接数目
Xconnect-group Name
交叉连接组名称
Connection ID
交叉连接索引
MTU
交叉连接的最大传输单元
交叉连接组的状态,取值包括:
·     Up:up状态
·     Down:down状态
·     Admin down:通过shutdown命令手工关闭的交叉连接组
# 显示所有交叉连接组的详细信息。
<Sysname> display l2vpn xconnect-group verbose
 Connection of auto-discovery: Site 1, Remote Site 2
  Connection ID    : 0
  State            : Up
  MTU              : 1500
  BGP PWs:
    Peer            Remote Site      Link ID    State
    192.3.3.3       2                1          Up
  ACs:
    AC                               Link ID    State
    GE1/0/4                          0          Up
表1-23 display l2vpn xconnect-group verbose命令显示信息描述表
Xconnect-group Name
交叉连接组名称
交叉连接组的描述信息,如果不配置,则此行不显示
Connection Name
交叉连接名称
自动发现交叉连接
Site
本端Site标识符
Remote site
远端Site标识符
Connection ID
交叉连接索引
交叉连接组的状态,取值包括
·     Up:up状态
·     Down:down状态
·     Administratively down:通过shutdown命令手工关闭交叉连接组
MTU
交叉连接的最大传输单元
LDP PWs
LDP PW相关信息
Static PWs
静态PW相关信息
BGP PWs
BGP PW相关信息
Peer
PW远端PE的IP地址
PW ID
PW标识符
Link ID
PW在交叉连接内的链路标识符
PW的状态,取值包括Up、Down、Blocked和Defect
ACs
AC相关信息
AC
接入电路,取值有如下两种:
·     三层接口名称:在交叉连接视图下关联三层接口时,AC取值为此方式
·     二层接口名称和以太网服务实例:在交叉连接视图下关联以太网服务实例时,AC取值为此方式
Link ID
AC在交叉连接组内的链路ID
AC的状态,取值包括Up和Down
·     xconnect-group
encapsulation命令用来配置以太网服务实例的报文匹配规则。
undo encapsulation命令用来恢复缺省情况。
encapsulation s-vid { vlan-id | vlan-id-list } [ only-tagged ]
encapsulation { default | tagged | untagged }
undo encapsulation
未配置报文匹配规则。
以太网服务实例视图
s-vid { vlan-id | vlan-id-list }:匹配外层VLAN标签(Service VLAN ID)为指定值的报文。
·     vlan-id表示VLAN的编号,取值范围为1~4094。
·     vlan-id-list为VLAN列表,表示一个或多个VLAN的编号。表示方式为vlan-id-list = { vlan-id [ to vlan-id ] }&<1-8>。其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-8>表示前面的参数最多可以输入8次。
only-tagged:表示只匹配携带VLAN标签的报文。当匹配的VLAN为缺省VLAN时,如果未指定本关键字,则会同时匹配所携带VLAN标签为缺省VLAN的报文和未携带VLAN标签的报文;如果指定了本参数,则只匹配所携带VLAN标签为缺省VLAN的报文。
default:表示缺省的报文匹配规则。同一个以太网接口下最多只能有一个服务实例采用缺省的报文匹配规则。如果接口下同时存在一个采用缺省报文匹配规则的服务实例和多个采用其他报文匹配规则的服务实例,则未与任何其他报文匹配规则匹配的报文将匹配缺省报文匹配规则;如果接口下只存在一个采用缺省报文匹配规则的服务实例,则该接口上的所有报文都匹配缺省报文匹配规则。
untagged:表示匹配未携带VLAN标签的报文。
当同一个接口下配置的不同以太网服务实例的报文匹配规则出现重叠时,如何匹配报文与设备的型号有关,请以设备的实际情况为准。
不能通过重复执行本命令修改报文匹配规则。如需修改报文匹配规则,请先通过undo encapsulation命令删除报文匹配规则,再执行encapsulation命令。
删除以太网服务实例下的报文匹配规则后,会自动取消以太网服务实例与交叉连接的关联。
内层VLAN标签和外层VLAN标签的介绍请参见“二层技术-以太网交换配置指导”中的“QinQ”。
# 在二层以太网接口GigabitEthernet1/0/1的以太网服务实例1上配置如下报文匹配规则:匹配外层VLAN标签为111的报文。
[Sysname-GigabitEthernet1/0/1] service-instance 1
[Sysname-GigabitEthernet1/0/1-srv1] encapsulation s-vid 111
1.1.28  idle-code
idle-code命令用来配置出口PE检测到特定电路仿真接口的电路仿真分组丢失时,向TDM线路发送的空闲码。
undo idle-code命令用来恢复缺省情况。
idle-code bit-pattern
undo idle-code
型号
RA10
idle-code
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
出口PE检测到特定电路仿真接口的电路仿真分组丢失时,向TDM线路发送的空闲码为FF。
电路仿真类视图
bit-pattern:空闲码。十六进制形式,取值范围为00~FF。
出口PE以恒定的速率向TDM线路发送TDM帧。当出口PE检测到电路仿真分组丢失时,每个丢失的电路仿真分组的净载荷必须用等量的替代数据来代替。出口PE使用配置的空闲码作为替代数据。
# 配置电路仿真类satop的电路仿真分组丢失时,向TDM线路发送的空闲码为C2。
[Sysname-cem-satop] idle-code c2
interface circuit-emulation命令用来进入电路仿真接口视图。
interface circuit-emulation { interface-number:0 | interface-number:set-number }
型号
RA10
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
interface-number:CE1/PRI接口或CT1/PRI接口的编号。详细信息请参见“接口管理”中的“WAN接口”。
set-number:该接口上时隙捆绑形成的电路仿真组编号,取值范围为0~30。详细信息请参见“接口管理”中的“WAN接口”。
interface circuit-emulation interface-number:0命令用于在SAToP模式时进入电路仿真接口视图。
interface circuit-emulation interface-number:set-number命令用于在CESoPSN模式时进入电路仿真接口视图。
# 进入电路仿真接口Circuit-Emulation2/3/0:0接口视图。
[Sysname] interface circuit-emulation2/3/0:0
jitter-buffer命令用来配置电路仿真类的Jitter-buffer的大小。
undo jitter-buffer命令用来恢复缺省情况。
jitter-buffer buffer-size
undo jitter-buffer
型号
RA10
jitter-buffer
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
Jitter-buffer的大小与引用此电路仿真类的电路仿真接口的电路类型有关,不区分SAToP或CESoPSN。具体取值如下:
E1—16ms、T1—16ms、E3—5ms、T3—5ms。
电路仿真类视图
buffer-size:Jitter-buffer的大小,取值范围1~500,单位为毫秒。
由于出口PE必须以恒定速率向TDM电路发送数据,而PSN网络中分组的时延抖动一般较大。因此,需要通过出口PE上的Jitter-buffer缓存TDM电路仿真分组的净载荷,从而平滑PSN网络传送导致的时延抖动。缓存后再以恒定速率向TDM接口发送。
Jitter buffer越小,抗抖动能力越弱;Jitter buffer越大,抗抖动能力越强,但在数据流重建的时候会引入较大的传送延时。过大或过小的Jitter buffer都不利于业务的高质量传输,请根据实际情况合理选择Jitter buffer的大小。
# 配置电路仿真类satop的Jitter-buffer大小为100毫秒。
[Sysname-cem-satop] jitter-buffer 100
1.1.31  l2vpn enable
l2vpn enable命令用来开启L2VPN功能。
undo l2vpn enable命令用来关闭L2VPN功能。
l2vpn enable
undo l2vpn enable
L2VPN功能处于关闭状态。
只有开启L2VPN功能后,才能进行L2VPN的相关配置。
# 开启L2VPN功能。
[Sysname] l2vpn enable
l2vpn reflector命令用来开启L2VPN的报文反射功能。
undo l2vpn reflector命令用来关闭L2VPN的报文反射功能。
l2vpn reflector interface { interface-name | interface-type interface-number } { service-instance instance-id } ip ip-address [ mac mac-address ] [ source-port source-port ] [ destination-port destination-port ]
undo l2vpn reflector interface { interface-name | interface-type interface-number } { service-instance instance-id }
L2VPN的报文反射功能处于关闭状态。
interface:指定关联的AC侧接口。
interface-name:AC侧接口的名称。
interface-type interface-number:AC侧接口类型和接口编号。
service-instance instance-id:指定关联的以太网服务实例,instance-id为以太网服务实例编号,取值范围为1~4096。
ip ip-address:指定待反射报文的目的IP地址,为点分十进制格式,不能为本设备连接CE的接口IP地址。
mac mac-address:指定待反射报文的目的MAC地址,如果不指定本参数,则表示interface-name或者interface-type interface-number指定的接口的MAC地址。不支持组播MAC地址和全0的MAC地址。
source-port source-port:指定待反射报文的UDP源端口号,取值范围为1~65535,缺省值为49184。
destination-port destination-port:指定待反射报文的UDP目的端口号,取值范围为1~65535,缺省值为7。
开启L2VPN的报文反射功能后,可在设备上生成对应的ARP泛洪抑制表项,用于代答对指定IP地址的ARP请求。同时在AC绑定的交叉连接下开启ARP泛洪抑制功能后,可反射对指定PW的检测报文。
待反射报文的IP地址需本地唯一,即每个以太网服务实例或三层接口关联的反射报文的IP地址不能相同。
每个以太网服务实例或三层接口只能关联一个待反射报文的IP地址和MAC地址。多次执行本命令为同一个以太网服务实例或三层接口关联不同的待反射报文IP地址和MAC地址时,最后一次执行的命令生效。
在设备上多次执行本命令最多可生成8条不同的ARP泛洪抑制表项。
开启L2VPN的报文反射功能时,需同时在AC绑定的交叉连接下开启ARP泛洪抑制功能。
# 开启L2VPN的报文反射功能:AC侧接口为GigabitEthernet1/0/1,关联的以太网实例为1,反射报文的目的IP地址为1.0.0.1。
[Sysname] l2vpn reflector interface gigabitethernet 1/0/1 service-instance 1 ip 1.0.0.1
·     display l2vpn forwarding
l2vpn switchover命令用来将指定PW的流量手工倒换到它的冗余备份PW上。
l2vpn switchover peer ip-address pw-id pw-id
peer ip-address:指定PW远端PE的LSR ID。
pw-id pw-id:指定PW的PW ID。pw-id为PW的PW ID,取值范围为1~4294967295。
PW远端PE的LSR ID地址和PW ID唯一标识了一条PW。如果该PW存在对应的可用主PW或备份PW,则执行本命令后,通过该PW转发的流量将倒换到另一条可用的主PW或备份PW上转发;如果不存在对应的可用主PW和备份PW,则不进行流量倒换。
本命令是PW保护倒换的手工倒换命令,用来方便管理员对网络流量进行管理。
# 远端PE地址为3.3.3.3、PW ID为100的PW存在备份PW,将该PW上的流量手工倒换到它的备份PW上转发。
<Sysname> l2vpn switchover peer 3.3.3.3 pw-id 100
1.1.34  mtu
mtu命令用来配置PW的MTU(Maximum Transmission Unit,最大传输单元)值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
型号
RA10
mtu
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
PW的MTU值为1500字节。
交叉连接视图/交叉连接组自动发现视图
在交叉连接视图/交叉连接组自动发现视图下执行本命令后,该视图下建立的所有PW的MTU值均为本命令配置的值。
PW上发送报文的MTU值为包括控制字、PW标签和网络层报文在内的报文的最大长度。
如果采用LDP信令协议建立PW,则要求PW两端的PE上为PW配置相同的MTU值。否则,PW无法up。
# 在交叉连接组vpn1的交叉连接ac2pw下,配置PW的MTU值为1400字节。
[Sysname-xcg-vpn1-ac2pw] mtu 1400
# 在交叉连接组自动发现视图下,配置PW的MTU值为1400字节。
[Sysname-xcg-bbb-auto] mtu 1400
1.1.35  payload
payload命令用来配置电路仿真类中每个分组的净载荷大小。
undo payload命令用来恢复缺省情况。
payload { size | frame frame-number }
undo payload
型号
RA10
payload
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
SAToP模式下,净载荷的大小与电路仿真接口的电路类型有关,具体取值如下:
E1—256字节、T1—192字节、E3—1024字节、T3—1024字节。
CESoPSN模式下,净载荷的大小与电路仿真接口的时隙数有关。净载荷大小(L字节)、时隙数(N)、分组化延迟(D毫秒)有如下关系:
L = 8 * N * D。
缺省载荷如下:
·     N=1时,D为8毫秒,相应的净载荷大小为64字节;
·     2<=N<=4时,D为4毫秒,相应的净载荷大小为32*N字节;
·     N>=5时,D为1毫秒,相应的净载荷大小为8*N字节。
电路仿真类视图
frame frame-number:每个分组中净载荷的帧数,取值为8、16或24。
通过配置分组的净载荷大小,可控制在PW上传输的分组报文的大小。
# 配置电路仿真类satop中每个分组的净载荷大小为512字节。
[Sysname-cem-satop] payload 512
1.1.36  peer
peer命令用来配置交叉连接的PW,并进入交叉连接PW视图。如果指定的PW已经存在,则直接进入交叉连接PW视图。
undo peer命令用来删除指定的PW。
undo peer ip-address pw-id pw-id
不存在交叉连接的PW。
交叉连接视图
pw-id pw-id:指定PW的PW ID。pw-id为PW ID,取值范围为1~4294967295。
in-label label-value:指定PW的入标签。label-value为入标签值,取值范围为16~1023。
out-label label-value:指定PW的出标签。label-value为出标签值,取值范围为16~1048575。
pw-class class-name:指定PW引用的PW模板。class-name表示PW模板名,为1~19个字符的字符串,区分大小写。PW模板中可以配置PW的数据封装类型、是否使用控制字等。如果不指定本参数,则PW数据封装类型由接口的链路类型决定,对于不强制要求使用控制字的PW数据封装类型,不支持控制字功能。
tunnel-policy tunnel-policy-name:指定PW的隧道选择策略。tunnel-policy-name表示隧道策略名,为1~19个字符的字符串,区分大小写。如果不指定本参数,则使用缺省的隧道选择策略。
创建静态PW时,必须指定in-label和out-label参数;静态PW已经存在,进入交叉连接PW视图时,无需指定in-label和out-label参数。
执行本命令时,如果未指定in-label和out-label参数,且尚未创建静态PW,则表示采用LDP信令协议建立PW。
PW ID是一对PE之间PW的标识,本端和远端PE上为同一PW指定的PW ID必须相同。
在本端PE上,远端PE的LSR ID和PW ID唯一标识一条PW。配置PW时指定的远端PE的LSR ID和PW ID,不能与已经存在的VPLS PW、交叉连接PW的LSR ID和PW ID同时相同。
PW冗余保护功能和多段PW功能互斥。即,如果在交叉连接视图下通过重复执行peer命令配置了两条PW,则不能在交叉连接PW视图下执行backup-peer命令配置备份PW;反之亦然。
# 为交叉连接组vpn1内的交叉连接pw2pw配置一条LDP PW:远端PE的地址为4.4.4.4,PW ID为200,并进入交叉连接PW视图。
[Sysname-xcg-vpn1] connection pw2pw
[Sysname-xcg-vpn1-pw2pw] peer 4.4.4.4 pw-id 200
[Sysname-xcg-vpn1-pw2pw-4.4.4.4-200]
# 为交叉连接组vpn1内的交叉连接pw2pw配置一条静态PW:远端PE的地址为5.5.5.5,PW ID为200,入标签为100,出标签为200,并进入交叉连接PW视图。
[Sysname-xcg-vpn1-pw2pw] peer 5.5.5.5 pw-id 200 in-label 100 out-label 200
[Sysname-xcg-vpn1-pw2pw-5.5.5.5-200]
·     display l2vpn ldp
·     display l2vpn pw
·     pw-class
peer signaling命令用来开启本地路由器与指定对等体/对等体组交换MPLS L2VPN标签块信息的能力。
undo peer signaling命令用来禁止本地路由器与指定对等体/对等体组交换MPLS L2VPN标签块信息。
peer { group-name | ip-address [ mask-length ] } signaling [ non-standard ]
undo peer { group-name | ip-address [ mask-length ] } signaling
本地路由器具有与BGP L2VPN对等体/对等体组交换标签块信息的能力,并且采用RFC 4761中定义的MP_REACH_NLRI格式交换标签块信息。
BGP L2VPN地址族视图
ip-address:对等体的IP地址。指定的对等体必须已经创建。
non-standard:指定采用draft-kompella-ppvpn-l2vpn-03草案中定义的MP_REACH_NLRI格式交换标签块信息。如果不指定本参数,则采用RFC 4761中定义的MP_REACH_NLRI格式交换标签块信息。请根据对等体支持的MP_REACH_NLRI格式类型,选择是否指定本参数。
建立BGP PW时,PE设备需要通过MP-BGP协议来交换标签块信息。
在BGP L2VPN地址族视图下执行peer enable命令后,本地路由器即具有与指定对等体/对等体组采用RFC 4761中定义的MP_REACH_NLRI格式交换标签块信息的能力。如需禁止该能力或该对等体不支持交换标签块信息,则执行undo peer signaling命令。
# 在BGP实例default的BGP L2VPN地址族视图下,开启本地路由器与对等体3.3.3.9交换MPLS L2VPN标签块信息的能力,并指定采用draft-kompella-ppvpn-l2vpn-03草案中定义的MP_REACH_NLRI格式交换标签块信息。
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] peer 3.3.3.9 signaling non-standard
# 在BGP实例abc的BGP L2VPN地址族视图下,开启本地路由器与对等体3.3.3.9交换MPLS L2VPN标签块信息的能力,并指定采用draft-kompella-ppvpn-l2vpn-03草案中定义的MP_REACH_NLRI格式交换标签块信息。
[Sysname-bgp-abc-l2vpn] peer 3.3.3.9 signaling non-standard
·     display bgp l2vpn signaling
policy vpn-target命令用来开启BGP L2VPN信息的VPN-Target过滤功能。
undo policy vpn-target命令用来关闭BGP L2VPN信息的VPN-Target过滤功能。
policy vpn-target
BGP L2VPN信息的VPN-Target过滤功能处于开启状态。
BGP L2VPN地址族视图
开启BGP L2VPN信息的VPN-Target过滤功能后,设备只将Export Route Target属性与本地Import Route Target属性匹配的BGP L2VPN信息加入到BGP L2VPN信息表。
在跨域VPN-OptionB组网中,ASBR-PE需要保存所有BGP L2VPN信息(即标签块信息),以通告给远端ASBR-PE。这种情况下,ASBR-PE上需执行undo policy vpn-target命令接收所有的BGP L2VPN信息,不对它们进行VPN-Target过滤。
跨域VPN-OptionB的详细介绍,请参见“MPLS配置指导”中的“MPLS L3VPN”。
# 在BGP实例default的BGP L2VPN地址族视图下,关闭BGP L2VPN信息的VPN-Target过滤功能。
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] undo policy vpn-target
# 在BGP实例abc的BGP L2VPN地址族视图下,关闭BGP L2VPN信息的VPN-Target过滤功能。
[Sysname-bgp-abc-l2vpn] undo policy vpn-target
protection dual-receive命令用来配置PW冗余保护的双收功能,即主PW和备份PW都能接收报文,主备PW工作在单发双收模式。
undo protection dual-receive命令用来恢复缺省情况。
未配置PW冗余保护的双收功能,即配置PW冗余保护时,仅主PW能发送和接收报文,备份PW不能发送和接收报文。
交叉连接视图
# 为交叉连接组vpn1内的交叉连接ac2pw配置PW冗余保护的双收功能。
[Sysname-xcg-vpn1-ac2pw] protection dual-receive
pw-class命令用来指定引用的PW模板。
undo pw-class命令用来恢复缺省情况。
pw-class class-name
undo pw-class
未引用PW模板。
交叉连接组自动发现视图
class-name:PW模板名,为1~19个字符的字符串,区分大小写。
在交叉连接组自动发现视图下执行本命令指定引用的PW模板后,该PW模板将应用于该视图下建立的所有PW。
# 在交叉连接组自动发现视图下,指定引用的PW模板为pw100。
[Sysname-pw-pw100] quit
[Sysname-xcg-bbb-auto] pw-class pw100
·     control-word enable
·     pw-class
·     pw-type
pw-class命令用来创建PW模板,并进入PW模板视图。如果指定的PW模板已经存在,则直接进入PW模板视图。
undo pw-class命令用来删除指定的PW模板。
pw-class class-name
undo pw-class class-name
不存在PW模板。
通过本命令创建PW模板,并进入PW模板视图后,可以在PW模板视图下指定PW的属性,如PW的数据封装类型、是否使用控制字。具有相同属性的PW可以通过引用相同的PW模板,实现对PW属性的配置,从而简化配置。
# 创建PW模板pw100,并进入PW模板视图。
[Sysname-pw-pw100]
·     pw-type
1.1.42  pw-type
pw-type命令用来配置PW数据封装类型。
undo pw-type命令用来恢复缺省情况。
pw-type { ethernet | tdm-cesopsn-basic | tdm-satop-e1 | vlan }
undo pw-type
PW数据封装类型为VLAN。
PW模板视图
ethernet:PW数据封装类型为Ethernet。
tdm-cesopsn-basic:PW数据封装类型为TDM-CESoPSN-Basic。
型号
参数
RA10
tdm-cesopsn-basic
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
tdm-satop-e1:PW数据封装类型为TDM-SAToP-E1。
型号
参数
RA10
tdm-cesopsn-basic
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
vlan:PW数据封装类型为VLAN。
Ethernet数据封装类型下,PW上传输的帧不能携带P-Tag。对于CE侧的报文,如果PE从CE收到带有P-Tag的报文,则将其去除后再添加PW标签和公网隧道标签转发;如果从CE收到不带P-Tag的报文,则直接添加PW标签和公网隧道标签后转发。对于PE发送给CE的报文,如果ac interface命令配置的接入模式为VLAN,则添加P-Tag后转发给CE;如果配置的接入模式为Ethernet,则不添加P-Tag,直接转发给CE;无论ac interface命令配置的接入模式为VLAN还是Ethernet,均不允许重写或去除已经存在的任何Tag。
VLAN数据封装类型下,PW上传输的帧必须携带P-Tag。对于CE侧的报文,PE从CE收到带有P-Tag的报文后,如果远端PE不要求Ingress改写P-Tag,则保留P-Tag,如果远端PE要求Ingress改写P-Tag,则将P-Tag改写为远端PE期望的VLAN Tag(Tag可能是值为0的空Tag),再添加PW标签和公网隧道标签后转发;从CE收到不带P-Tag的报文后,如果远端PE不要求Ingress改写P-Tag,则添加值为0的空P-Tag,如果远端PE要求Ingress改写P-Tag,则添加一个远端PE期望的VLAN Tag(Tag可能是值为0的空Tag)后,再添加PW标签和公网隧道标签后转发。对于PE发送给CE的报文,如果ac interface命令配置的接入模式为VLAN,转发给CE时重写或保留P-Tag;如果配置的接入模式为Ethernet,则去除P-Tag后转发给CE。
TDM-CESoPSN-Basic数据封装类型以结构化的方式在PW上传送E1电路数据。
TDM-SAToP-E1数据封装类型以非结构化方式在PW上透明地传送E1电路数据,且所有电路时隙都通过一条PW传送。
# 配置PW数据封装类型为Ethernet。
[Sysname-pw-pw100] pw-type ethernet
·     ac interface
reset counters interface命令用来清除接口的统计信息。
reset counters interface [ circuit-emulation [ interface-number ] ]
型号
RA10
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
circuit-emulation:清除电路仿真接口的统计信息。
interface-number:电路仿真接口的编号。
如果不指定circuit-emulation和interface-number,则清除所有接口的统计信息;
如果指定circuit-emulation而不指定interface-number,则清除所有电路仿真接口的统计信息;
如果同时指定circuit-emulation和interface-number,则清除指定电路仿真接口的统计信息。
# 清除接口Circuit-Emulation2/3/0:0的统计信息。
<Sysname> reset counters interface circuit-emulation 2/3/0:0
·     display interface circuit-emulation
reset l2vpn statistics pw命令用来清除指定PW的报文统计信息。
reset l2vpn statistics pw [ xconnect-group group-name [ connection connection-name ] ]
xconnect-group group-name:清除指定交叉连接组内的PW报文统计信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果不指定该参数,则清除所有PW的统计信息。
connection connection-name:清除指定PW的统计信息。connection-name为交叉连接组内交叉连接的名称,为1~20个字符的字符串,区分大小写。如果不指定该参数,则清除指定交叉连接组内的所有PW统计信息。
当PW存在备PW时,会同时清除主PW和备PW的报文统计信息。
# 清除本设备上所有PW报文统计信息。
<Sysname> reset l2vpn statistics pw
·     statistics enable
1.1.45  revertive
revertive命令用来配置PW冗余保护倒换的回切模式,以及回切等待时间。
undo revertive命令用来恢复缺省情况。
revertive { wtr wtr-time | never }
undo revertive { wtr | never }
回切模式为可回切,回切等待时间为0,即主PW恢复后,流量会立即从备份PW回切到主PW。
交叉连接视图
wtr wtr-time:指定回切模式为可回切,并指定回切等待时间(wait-to-restore time),即主PW恢复后,等待wtr-time时间后,才将流量从备份PW回切到主PW。wtr-time取值范围为0~3600,单位为秒。
never:指定回切模式为不回切。
# 配置交叉连接组vpn1内交叉连接ac2pw的回切模式为可回切,并指定回切等待时间为120秒。
[Sysname-xcg-vpn1-ac2pw] revertive wtr 120
·     display l2vpn pw
route-distinguisher命令用来为当前交叉连接组的BGP方式配置RD(Route Distinguisher,路由标识符)。
undo route-distinguisher命令用来恢复缺省情况。
未指定交叉连接组BGP方式的RD。
交叉连接组自动发现视图
route-distinguisher:路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
在MPLS L2VPN中,RD用来区分不同VPN内编号相同的站点。PE在通过BGP发布其连接的站点信息时,在Site ID前增加RD,通过RD和Site ID来唯一标识网络中的一个站点。
不能为不同交叉连接组的BGP方式配置相同的RD。
不能通过重复执行本命令修改RD值。如需修改RD值,请先通过undo route-distinguisher命令删除RD值,再执行route-distinguisher命令。
# 配置交叉连接组bbb的BGP方式的RD为22:2。
[Sysname-xcg-bbb-auto] route-distinguisher 22:2
1.1.47  rr-filter
rr-filter命令用来创建路由反射器的反射策略。
undo rr-filter命令用来恢复缺省情况。
rr-filter extended-community-list-number
undo rr-filter
路由反射器不会对反射的L2VPN信息进行过滤。
BGP L2VPN地址族视图
extended-community-list-number:路由反射器支持的扩展团体属性号,取值范围1~199。
执行本命令后,路由反射器将根据扩展团体属性列表对接收的L2VPN信息进行过滤:只有接收的BGP L2VPN信息通过扩展团体属性列表过滤时,路由反射器才会反射该L2VPN信息。
当一个集群中存在多个路由反射器时,通过在不同的路由反射器上配置不同的反射策略,可以实现路由反射器之间的负载分担。
扩展团体属性列表的详细介绍,请参见“三层技术-IP路由配置指导”中的“路由策略”。
# 在BGP实例default的BGP L2VPN地址族视图下,配置路由反射器只反射通过扩展团体属性列表10过滤的BGP L2VPN信息。
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] rr-filter 10
# 在BGP实例abc的BGP L2VPN地址族视图下,配置路由反射器只反射通过扩展团体属性列表10过滤的BGP L2VPN信息。
[Sysname-bgp-abc-l2vpn] rr-filter 10
·     ip extcommunity-list(三层技术-IP路由命令参考/路由策略)
rtp-header enable命令用来配置电路仿真类中的报文携带RTP头。
undo rtp-header enable命令用来恢复缺省情况。
rtp-header enable
型号
RA10
rtp-header enable
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
电路仿真类的报文不携带RTP头。
电路仿真类视图
通常情况下,电路仿真类中的报文不携带RTP头。当时钟恢复方式为差分恢复方式时,出口PE需根据分组的RTP头中的差分时间戳信息进行时钟恢复,必须通过本命令配置电路仿真类中的报文携带RTP头。
# 配置电路仿真类satop中的分组携带RTP头。
[Sysname-cem-satop] rtp-header enable
1.1.49  sequencing
sequencing命令用来配置对PW上传送的报文进行排序处理。
undo sequencing命令用来恢复缺省情况。
sequencing both
undo sequencing both
PW上传送的报文不进行排序处理。
PW模板视图
both:PW收发两个方向都要进行排序处理。
在分组交换中,当转发负载比较重或者网络中有多条传送路径进行负载分担时,报文的传送可能会发生乱序,此时需要对传送的分组进行排序处理,即在发送端为每一个在PW上传送的分组添加一个序列号,接收端根据序列号进行重新排序。
本命令的配置不与对端协商,如果本地开启排序处理功能,则PW上传送的分组携带序列号,且对从PW上收到的分组进行排序处理。如果本端未开启排序处理功能,当收到的分组携带序列号时,则忽略该序列号,不对分组进行排序处理。
# 配置对引用PW模板aaa的PW上传送的报文进行排序处理。
[Sysname] pw-class aaa
[Sysname-pwc-aaa] sequencing both
service-instance命令用来创建以太网服务实例,并进入以太网服务实例视图。如果指定的以太网服务实例已经存在,则直接进入以太网服务实例视图。
undo service-instance命令用来删除指定的以太网服务实例。
undo service-instance instance-id
不存在以太网服务实例。
二层以太网接口视图/二层聚合接口视图
instance-id:以太网服务实例的编号,取值范围为1~4096。
# 在二层以太网接口GigabitEthernet1/0/1上创建以太网服务实例1,并进入以太网服务实例1的视图。
shutdown命令用来关闭电路仿真接口。
undo shutdown命令用来打开电路仿真接口。
shutdown
型号
RA10
shutdown
不支持
RA10-E
支持
RA100
不支持
RA200
不支持
电路仿真接口处于打开状态。
电路仿真接口视图
# 关闭电路仿真接口Circuit-Emulation2/3/0:0。
[Sysname-Circuit-Emulation2/3/0:0] shutdown
shutdown命令用来关闭当前的交叉连接组。
undo shutdown命令用来开启当前的交叉连接组。
shutdown
交叉连接组处于开启状态。
交叉连接组视图
关闭交叉连接组后,该交叉连接组下所有交叉连接将不能提供L2VPN服务。
关闭交叉连接组功能通常用于暂时禁用L2VPN服务,但还需要再次启用该L2VPN服务的场景。关闭交叉连接组后,该交叉连接组所有已存在的配置保持不变。在关闭状态下还可以对交叉连接组进行配置。交叉连接组再次被开启后,基于最新的配置提供L2VPN服务。
# 关闭名为vpn2的交叉连接组。
[Sysname-xcg-vpn2] shutdown
1.1.53  site
site命令用来创建本地站点,并进入站点视图。如果指定的本地站点已经存在,则直接进入站点视图。
undo site命令用来删除指定的本地站点。
site site-id [ range range-value ] [ default-offset defalut-offset ]
undo site site-id
不存在本地站点。
交叉连接组自动发现视图
site-id:本地站点的ID。取值范围为0~250。
range range-value:指定VPN内最多包含的站点数目。range-value取值范围为2~site-id的最大值+1,缺省值为10。
default-offset defalut-offset:指定VPN中站点的起始编号。defalut-offset为起始编号,取值为0或1,缺省值为0。取值为0时,表示VPN内的站点从0开始编号;取值为1时,表示VPN内的站点从1开始编号。
range range-value和default-offset default-offset参数决定了PE为当前站点分配的标签块:
·     第一次执行site命令时指定range-value为range1,则分配第一个标签块,其LR为range1,LO为default-offset。
·     再次执行site命令时将range-value增加为range2(大于range1),则分配第二个标签块,LR为range2-range1,LO为range1+default-offset。以此类推。
例如,在PE上先后执行如下命令,则PE分配三个标签块,分别为:LB1/0/10、LB2/10/12、LB3/22/14。其中,LB1、LB2、LB3为PE自动选取的标签值。
site 1 range 22
site 1 range 36
在同一个交叉连接组下,可以创建ID不同的多个本地站点。
允许在site-id和defalut-offset不改变的情况下,通过重复执行site命令来增大此站点的range值,但不允许减小range值。如需减小range值,请先通过undo site命令删除本地站点,再执行site命令。建议根据对VPN规模发展的预计,把range range-value设置得比实际需要大一些。这样当以后对VPN进行扩容,增加VPN中的站点数目时,就可以尽量少的修改配置。
不能通过重复执行本命令修改VPN中站点的起始编号。如需修改,请先通过undo site命令删除本地站点,再执行site命令。
# 在名为bbb的交叉连接组下创建本地站点1,指定VPN内最多包含的站点数目为30,站点的起始编号为0,并进入站点视图。
[Sysname-xcg-bbb-auto] site 1 range 30 default-offset 0
·     display l2vpn pw
snmp-agent trap enable l2vpn命令用来开启L2VPN告警功能。
undo snmp-agent trap enable l2vpn命令用来关闭L2VPN告警功能。
snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] *
undo snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] *
L2VPN告警功能处于关闭状态。
pw-up-down:开启PW的up-down状态变化告警。
pw-delete:开启PW删除告警。
pw-switch:开启主备PW切换告警。
开启L2VPN告警功能后,当PW的up-down状态发生变化、PW删除或主备PW切换时会产生告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
执行本命令时,如果未指定任何参数,则表示开启或关闭L2VPN的所有告警功能。
# 开启PW的up-down状态变化告警功能。
[Sysname] snmp-agent trap enable l2vpn pw-up-down
·     display snmp-agent trap-list(网络管理和监控命令参考/SNMP)
statistics enable命令用来开启指定PW的统计功能。
undo statistics enable命令用来关闭指定PW的统计功能。
statistics enable
通过命令行创建的PW的报文统计功能处于关闭状态;通过MIB创建的PW的报文统计功能处于开启状态。
交叉连接PW视图
备PW是否开启统计功能与其主PW保持一致,不需要单独开启或关闭备PW的统计功能。
# 开启指定PW的报文统计功能。
[Sysname-xcg-vpws] connection ldp
[Sysname-xcg-vpws-ldp] peer 5.5.5.5 pw-id 120
[Sysname-xcg-vpws-ldp-5.5.5.5-120] statistics enable
·     reset l2vpn statistics pw
·     display l2vpn pw
tunnel-policy命令用来指定引用的隧道策略。
undo tunnel-policy命令用来恢复缺省情况。
undo tunnel-policy
未引用隧道策略。
自动发现交叉连接视图
tunnel-policy-name:隧道策略名称,为1~19个字符的字符串,区分大小写。
在自动发现交叉连接视图下执行本命令指定引用的隧道策略后,与该交叉连接关联的PW将引用该隧道策略,即根据指定的隧道策略选择承载PW的公网隧道。
如果未引用隧道策略或者引用的隧道策略尚未配置,则PW根据缺省选择策略来选择公网隧道。缺省选择策略为按照LSP隧道->GRE隧道->CR-LSP隧道的优先级顺序选择隧道,负载分担的隧道数目为1。
# 在自动发现交叉连接视图下,指定引用的隧道策略为policy1。
[Sysname] tunnel-policy policy1
[Sysname-tunnel-policy-policy1] quit
[Sysname-xcg-bbb-auto] site 2 range 10 default-offset 0
[Sysname-xcg-bbb-auto-2] connection remote-site-id 3
[Sysname-xcg-bbb-auto-2-3] tunnel-policy policy1
1.1.57  vpn-target
vpn-target命令用来为当前交叉连接组的BGP方式配置Route Target属性。
undo vpn-target命令用来删除指定的Route Target属性。
undo vpn-target { vpn-target&<1-8> | all } [ both | export-extcommunity | import-extcommunity ]
未指定交叉连接组BGP方式的Route Target属性。
交叉连接组自动发现视图
vpn-target&<1-8>:Route Target属性值,为3~21个字符的字符串。&<1-8>表示前面的参数最多可以输入8次。Route Target有三种格式:
both:指定配置的Route Target值同时作为Import Target和Export Target。未指定both、export-extcommunity和import-extcommunity中的任何一个参数时,缺省值为both。
export-extcommunity:指定配置的Route Target值为Export Target。
import-extcommunity:指定配置的Route Target值为Import Target。
all:所有Route Target值。
Route Target用来控制BGP L2VPN信息(即标签块信息)的发布。本地PE在通过BGP的Update消息将L2VPN信息(如本地Site ID、RD、标签块等)发送给远端PE时,将Update消息中携带的VPN target属性设置为Export target。远端PE接收到BGP L2VPN信息后,将该信息中携带的Export Target属性与本地配置的Import Target进行比较,如果二者中存在相同的值,则接收该信息。
# 为交叉连接组bbb的BGP方式配置Import Target为10:1 100:1 1000:1,Export Target为20:1 200:1 2000:1。
[Sysname-xcg-bbb-auto] vpn-target 10:1 100:1 1000:1 import-extcommunity
[Sysname-xcg-bbb-auto] vpn-target 20:1 200:1 2000:1 export-extcommunity
1.1.58  xconnect-group
xconnect-group命令用来创建一个L2VPN交叉连接组,并进入交叉连接组视图。如果指定的交叉连接组已经存在,则直接进入交叉连接组视图。
undo xconnect-group命令用来删除指定的交叉连接组。
undo xconnect-group group-name
不存在交叉连接组。
group-name:交叉连接组的名称,为1~31个字符的字符串,不能包含字符“-”,区分大小写。
在同一个交叉连接组下,可以同时使用不同的方式(LDP、BGP、静态方式)建立多条PW。
# 创建名为vpn1的交叉连接组,并进入交叉连接组视图。
[Sysname-xcg-vpn1]
