01-基础配置命令参考
09-设备管理命令
本章节下载 09-设备管理命令  (754.5 KB)
09-设备管理命令
  录
1 设备管理
1.1 设备管理配置命令
1.1.1 accelerate
1.1.2 board-offline
1.1.3 clock datetime
1.1.4 clock protocol
1.1.5 clock summer-time
1.1.6 clock timezone
1.1.7 command
1.1.8 copyright-info enable
1.1.9 display alarm
1.1.10 display clock
1.1.11 display copyright
1.1.12 display cpu-usage
1.1.13 display cpu-usage configuration
1.1.14 display cpu-usage history
1.1.15 display device
1.1.16 display device manuinfo
1.1.17 display device manuinfo chassis-only
1.1.18 display device manuinfo fan
1.1.19 display device manuinfo power
1.1.20 display device manuinfo power-monitor
1.1.21 display diagnostic-information
1.1.22 display environment
1.1.23 display fabric utilization
1.1.24 display fan
1.1.25 display fan auto-control-mode
1.1.26 display hardware-failure-detection
1.1.27 display hardware-failure-protection
1.1.28 display memory
1.1.29 display memory-threshold
1.1.30 display power-supply
1.1.31 display scheduler job
1.1.32 display scheduler logfile
1.1.33 display scheduler reboot
1.1.34 display scheduler schedule
1.1.35 display system-working-mode
1.1.36 display transceiver alarm
1.1.37 display transceiver diagnosis
1.1.38 display transceiver interface
1.1.39 display transceiver manuinfo
1.1.40 display version
1.1.41 fan auto-control-mode
1.1.42 forward-path-detection enable
1.1.43 hardware-failure-detection
1.1.44 hardware-failure-protection aggregation
1.1.45 hardware-failure-protection auto-down
1.1.46 header
1.1.47 job
1.1.48 memory-threshold
1.1.49 monitor cpu-usage enable
1.1.50 monitor cpu-usage interval
1.1.51 power-supply off
1.1.52 power-supply on
1.1.53 power-supply led-blink
1.1.54 power-supply module new-id
1.1.55 power-supply policy enable
1.1.56 power-supply policy redundant
1.1.57 reboot
1.1.58 restore factory-default
1.1.59 reset scheduler logfile
1.1.60 scheduler job
1.1.61 scheduler logfile size
1.1.62 scheduler reboot at
1.1.63 scheduler reboot delay
1.1.64 scheduler schedule
1.1.65 shutdown-interval
1.1.66 sysname
1.1.67 system-working-mode
1.1.68 temperature-limit
1.1.69 time at
1.1.70 time once
1.1.71 time repeating
1.1.72 transceiver phony-alarm-disable
1.1.73 usb disable
1 设备管理
·     本文中的“EF类单板”指的是丝印后缀为EF的单板,如CR-SPC-GT48LEFRBRC类单板含义类似。
·     设备支持两种运行模式:独立运行模式和IRF模式,缺省情况下为独立运行模式。有关IRF模式的介绍,请参见“虚拟化技术配置指导”中的“IRF”。
1.1  设备管理配置命令
1.1.1  accelerate
accelerate命令用来开启指定单板的加速转发功能。
undo accelerate命令用来关闭指定单板的加速转发功能。
独立运行模式:
accelerate slot slot-number
undo accelerate slot slot-number
IRF模式:
accelerate chassis chassis-number slot slot-number
undo accelerate chassis chassis-number slot slot-number
单板的加速转发功能处于关闭状态。
slot slot-number:开启指定单板的加速转发功能,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:开启指定成员设备上指定单板的加速转发功能。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
在某些特殊情况下,需要使用该命令开启指定单板的加速转发功能,以提升单板的转发性能。但如果同时开启多块单板的加速转发功能,会给交换网板带来较大的突发流量,可能导致丢包。建议您必须在H3C工程师指导下谨慎使用该功能,不要自行配置。
配置本功能需同时满足以下条件:
·     设备型号为:CR16008-AC、CR16008-DC、CR16018-AC、CR16018-DC。
·     所配置的单板为:RB、RC类接口板(RC类接口板中,CR-SPC-CP4RC接口板的加速转发功能默认始终开启,不能通过本命令配置)。其他单板不支持本功能。
·     系统工作模式不为grand模式。
需要注意的是,执行该命令后,需使用reboot命令重启单板,配置才能生效。
# 开启3号单板的加速转发功能。(独立运行模式)
[Sysname] accelerate slot 3
Forwarding acceleration configured. Please reboot the card to place it into effect.
# 开启成员设备1上3号单板的加速转发功能。(IRF模式)
[Sysname] accelerate chassis 1 slot 3
·     reboot
·     system-working-mode
1.1.2  board-offline
board-offline命令用来从系统中隔离指定单板。
undo board-offline命令用来恢复缺省情况。
独立运行模式:
board-offline slot slot-number
undo board-offline slot slot-number
IRF模式:
board-offline chassis chassis-number slot slot-number
undo board-offline chassis chassis-number slot slot-number
缺省情况下,单板没有从系统中隔离。
slot slot-number:单板的槽位号。
chassis chassis-number slot slot-number:从系统中隔离指定成员设备上指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板的槽位号。
配置此命令后,单板上的转发业务将中断,但不影响系统整体运行和其他单板的业务,从而使用户能够方便地对被隔离单板进行现场诊断或逻辑升级。
配置此命令时,需要注意的是:
·     独立运行模式下,主用主控板不能从系统中被隔离。IRF模式下,每台成员设备上的本地主用主控板不能被隔离。有关本地主用主控板的详细介绍,请参见“虚拟化技术配置指导”中的“IRF”。
·     独立运行模式下,当设备上仅剩一块交换网板工作时,该交换网板不能从系统中被隔离。IRF模式下,每台成员设备上都至少要有一块正常工作的交换网板不能被隔离。
·     配置某块网板的隔离功能后,如果该网板不需要再使用,请及时拔出该网板;如果该网板需要继续使用,请使用undo board-offline命令对该网板取消隔离。
·     请不要对处于隔离状态的单板进行配置操作,否则该配置可能无法生效。
提示
·     用户可以通过display device命令查询单板是否处于被隔离的状态。
·     建议用户拔出处于工作状态的交换网板之前,配置该交换网板处于隔离状态,减轻对系统运行的影响。
# 从系统中隔离位于3号槽的单板。
[Sysname] board-offline slot 3
Caution: This command is only for diagnostic purpose which will cause board normal service unusable. Continue? [Y/N]:y
Config successfully
clock datetime命令用来设置设备的UTC(Coordinated Universal Time,国际协调时间)时间。
clock datetime time date
time:设置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。比如将time参数设置为0表示零点。
date:设置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
命令行配置的系统时间由配置的UTC时间、本地时区和夏令时运算之后联合决定,通过display clock命令可以查看。
为了保证与其它设备协调工作,为了更好的监控和维护设备,请将系统时间配置准确。用户可使用该命令来配置系统时间,或者通过NTP、PTP协议获取系统时间。
# 设置设备的UTC时间为2015年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2015
# 设置设备的UTC时间为2015年1月1日8时10分。
<Sysname> clock datetime 8:10 2015/1/1
·     clock protocol
·     clock summer-time
·     clock timezone
·     display clock
clock protocol命令用来配置获取系统时间的方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | ntp mdc mdc-id }
undo clock protocol
通过的NTP协议获取系统时间。
none:表示通过本地时钟源获取系统时间。配置该参数后,用户可通过clock datetimeclock timezoneclock summer-time命令修改系统时间。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取系统时间。配置该参数后,用户不能通过命令行修改系统时间,需要配置NTP的相关参数才能获取到时钟。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
mdc mdc-id:表示时钟的来源MDC编号。该参数取值只能为1。
这个共用时钟源可以是:
·     本地时钟源,设备上的晶体振荡器产生的时钟信号。
·     络时钟源,通过协议从其它网络设备上获取的时钟信号。
多次使用该命令配置不同的系统时间获取方式时,新配置将覆盖旧配置。
# 配置通过本地时钟源获取系统时间。
[Sysname] clock protocol none
clock summer-time命令用来设置夏令时。
undo clock summer-time命令用来恢复缺省情况。
没有配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
·     直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
·     分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:JanuaryFebruaryMarchAprilMayJuneJulyAugustSeptemberOctoberNovemberDecember;然后输入开始的星期,用当月的第几个星期表示,取值如下:firstsecondthirdfourthfifthlast;最后输入起始日,取值为SundayMondayTuesdayWednesdayThursdayFridaySaturday
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
·     直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。
命令行配置的系统时间由配置的UTC时间、本地时区和夏令时运算之后联合决定,通过display clock命令可以查看。为了保证与其它设备协调工作,为了更好的监控和维护设备,请将所有网络设备的夏令时配置保持一致。
# 设置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
·     clock datetime
·     clock protocol
·     clock timezone
·     display clock
clock timezone命令用来对本地时区进行设置。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
本地时区采用UTC时区。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。
命令行配置的系统时间由配置的UTC时间、本地时区和夏令时运算之后联合决定,通过display clock命令可以查看。为了保证与其它设备协调工作,为了更好的监控和维护设备,请将所有网络设备的时区和当地地理时区保持一致。
# 设置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
·     clock datetime
·     clock protocol
·     clock summer-time
·     display clock
1.1.7  command
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
需要注意的是,通过command指定的命令行必须是设备上可成功执行的命令行,不包括telnetftpssh2monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
# 为Job(假设名称为backupconfig)分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
·     scheduler job
copyright-info enable命令用来使能显示版权信息。
undo copyright-info enable命令用来禁止显示版权信息。
显示版权信息处于使能状态。
# 使能显示版权信息。
[Sysname] copyright-info enable
·     使用Telnet方式登录设备,会显示如下信息:
* Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                               *
* no decompiling or reverse-engineering shall be allowed.                  *
<Sysname>
·     如果当前已经使用Console口登录设备了,再退出用户视图重新登录,会显示如下信息:
User interface con0 is available.
Press ENTER to get started.
# 禁止显示版权信息。
[Sysname] undo copyright-info enable
<Sysname>
1.1.9  display alarm
display alarm命令用来显示设备的告警信息。
独立运行模式:
display alarm [ slot slot-number ]
IRF模式:
display alarm [ chassis chassis-number slot slot-number ]
【缺省级别】
slot slot-number:显示指定单板的告警信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的告警信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
# 显示设备的告警信息。(独立运行模式)
<Sysname> display alarm
Slot  Level    Info
2     ERROR    Fan 2 is absent.
5     ERROR    Power 2 is absent.
6     ERROR    The board in slot 6 is faulty.
8     WARNING  The temperature of sensor 3 exceeds the lower limit.
表1-1 display alarm命令显示信息描述表
Slot
产生告警的单板所在的槽位号(如果显示为“-”,则表示产生告警的元件位于机框上)
Level
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO
Info
告警的详细信息
Fan n is absent.
风扇n当前不在位
Power n is absent.
电源n当前不在位
faulty
单板处于faulty状态(该单板可能正在启动,或者当前处于故障状态)
The temperature of sensor n exceeds the lower limit.
传感器n的温度低于低温门限
The temperature of sensor n exceeds the upper limit.
传感器n的温度高于高温门限
# 显示设备当前告警信息。(IRF模式)
Chassis  Slot  Level    Info
1        6     ERROR    Fan 2 is absent.
1        6     ERROR    Power 2 is absent.
1        6     ERROR    The board in slot 10 is faulty.
2        3     WARNING  The temperature of sensor 3 exceeds the lower limit.
表1-2 display alarm命令显示信息描述表(IRF模式)
Chassis
告警设备的成员编号
Slot
告警单板所在的槽位号
Level
Info
告警的详细信息
Fan n is absent.
风扇n当前不在位
Power n is absent.
电源n当前不在位
The board in slot n is faulty.
n号槽位上的单板处于faulty状态(该单板可能正在启动,或者当前处于故障状态)
传感器n的温度低于低温门限
传感器n的温度高于高温门限
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
# 没有配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00 UTC Fri 03/16/2015
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00 Z5 Fri 03/16/2015
·     clock datetime
·     clock timezone
·     clock summer-time
display copyright命令用来显示系统软件和硬件的详细版权信息。
display copyright
【缺省级别】
通过查看版权信息,可以获知系统当前使用软件和硬件版本的版权信息、版权的参照标准、版权证书等相关信息。
# 显示详细的软件版权信息。
<Sysname> display copyright
display cpu-usage命令用来显示CPU利用率的统计信息。
独立运行模式:
display cpu-usage [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
display cpu-usage [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示指定单板的CPU利用率的统计信息。slot-number表示单板所在的槽位号。不指定该参数时,显示的是所有单板的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板的CPU利用率的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。不指定该参数时,表示默认CPU。
该命令用于显示最近5秒钟、最近1分钟、最近5分钟CPU利用率的平均值。
# 显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage
Slot 0 CPU 0 CPU usage:
       1% in last 5 seconds
       0% in last 1 minute
       0% in last 5 minutes
Slot 1 CPU 0 CPU usage:
       1% in last 1 minute
       1% in last 5 minutes
# 显示所有单板CPU利用率统计信息。(IRF模式)
Chassis 1 Slot 0 CPU 0 CPU usage:
       9% in last 5 seconds
       8% in last 1 minute
       8% in last 5 minutes
Chassis 1 Slot 1 CPU 0 CPU usage:
       5% in last 5 seconds
       4% in last 1 minute
       4% in last 5 minutes
Chassis 2 Slot 0 CPU 0 CPU usage:
       6% in last 5 seconds
       6% in last 1 minute
       6% in last 5 minutes
Chassis 2 Slot 1 CPU 0 CPU usage:
       6% in last 1 minute
表1-3 display cpu-usage命令显示信息描述表
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率。该字段显示的是最近一个5秒统计周期内CPU的平均利用率
1% in last 1 minute
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU的平均利用率
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU的平均利用率
Slot x CPU y CPU usage
x号单板上y号CPU的CPU利用率信息(独立运行模式)
Chassis x Slot y CPU z CPU usage
x号成员设备y号单板上z号CPU的CPU利用率信息(IRF模式)
display cpu-usage configuration命令用来显示CPU利用率历史信息记录功能相关配置。
独立运行模式:
IRF模式:
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,显示的是主用主控板上的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。不指定该参数时,显示的是全局主用主控板上的相应信息。(IRF模式)
cpu cpu-number:表示CPU的编号。不指定该参数时,表示默认CPU。
# 显示CPU利用率历史信息记录功能相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
·     monitor cpu-usage enable
·     monitor cpu-usage interval
display cpu-usage history命令用来以图表方式显示CPU利用率历史信息。
独立运行模式:
IRF模式:
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id:显示指定进程的CPU利用率的历史信息,job-id表示进程的编号。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控命令参考”中的“系统维护与调试”。
slot slot-number:显示指定单板的CPU利用率的历史信息。slot-number表示单板所在的槽位号。不指定该参数时,显示的是主用主控板主CPU的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的CPU利用率的历史信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示IRF中的全局主用主控板主CPU的相应信息。(IRF模式)
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。不指定该参数时,表示默认CPU。
启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
·     纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
·     横坐标表示时间,时间越靠左表示距离当前时间越近。
·     用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示整个系统的主CPU利用率的历史记录。
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明整个系统(用“SYSTEM”表示)在最近60分钟内主CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
# 以图表方式显示编号为1的进程的主CPU利用率的历史记录。
<Sysname> display cpu-usage history job 1
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|
 10%|
  5%|                   #
                      cpu-usage (CPU 0) last 60 minutes (scmd)
以上显示信息表明编号为1的进程(进程名为scmd,如果进程名带有“[]”标识则表示它是内核线程)在最近60分钟内主CPU的利用率情况:20分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备信息。
独立运行模式:
display device [ cf-card | flash] [ slot slot-number | verbose ]
IRF模式:
display device [ cf-card | flash] [ chassis chassis-number [ slot slot-number ] | verbose ]
cf-card:显示CF卡的信息。
flash:显示flash的信息。
chassis chassis-number:显示指定成员设备的详细信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
slot slot-number:显示指定单板的信息。slot-number表示单板所在的槽位号。(独立运行模式)
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息。
不带cf-cardflash参数时,显示的是设备上所有单板的信息。
# 显示设备信息。(独立运行模式)
<Sysname> display device
Slot No.   Brd Type        Brd Status   Software Version
 0         CR-MRP-I        Standby      CR16000-CMW710-R7174
 1         CR-MRP-I        Master       CR16000-CMW710-R7174
 2         NONE            Absent       NONE
 3         NONE            Absent       NONE
 4         NONE            Absent       NONE
 5         CR-SPC-GT48LEF  Normal       CR16000-CMW710-R7174
 6         NONE            Absent       NONE
 7         NONE            Absent       NONE
 8         NONE            Absent       NONE
 9         NONE            Absent       NONE
 10        NONE            Absent       NONE
 11        NONE            Absent       NONE
 12        CR-SF08C        Normal       CR16000-CMW710-R7174
 13        CR-SF08C        Normal       CR16000-CMW710-R7174
 14        CR-SF08C        Normal       CR16000-CMW710-R7174
 15        CR-SF08C        Normal       CR16000-CMW710-R7174
 16        CR-SF08C        Normal       CR16000-CMW710-R7174
 17        CR-SF08C        Normal       CR16000-CMW710-R7174
 18        CR-SF08C        Normal       CR16000-CMW710-R7174
以上显示信息表明,该独立运行模式上有两块主控板,一块接口板,7块交换网板。其中插在0号槽位的是备用主控板,插在1号槽位的是主用主控板,插在5号槽位的是接口板,插在12号到18号槽位的是交换网板。
表1-4 display device命令显示信息描述表(独立运行模式)
Slot No.
单板的槽位号
Brd Type
单板类型
Brd Status
单板状态:
·     Standby:表示该板是备用主控板
·     Master:表示该板是主用主控板
·     Absent:表示该槽位没有插入单板
·     Fault:表示该槽位单板正处于启动过程中或者该槽位单板出错,不能正常启动;对于网板,也可能是处于被隔离状态
·     Normal:表示该槽位单板是接口板并处于正常工作状态
·     Off:表示该槽位的单板没有上电
·     Illegal:表示当前软件版本不支持该单板,单板无法正常使用
·     Offline:表示该槽位单板处于被隔离状态
Software Version
当前单板上运行的软件版本:
·     显示软件版本:应与设备软件版本一致
·     NONE:表示该槽位没有单板
·     Mismatched:表示当前软件版本不支持该单板,无法正常加载软件
# 显示IRF中各成员设备的设备信息。(IRF模式)
 1/0       CR-MRP-I        Standby      CR16000-CMW710-R7174
 1/1       CR-MRP-I        Master       CR16000-CMW710-R7174
 1/2       NONE            Absent       NONE
 1/3       NONE            Absent       NONE
 1/4       NONE            Absent       NONE
 1/5       CR-SPC-GT48LEF  Normal       CR16000-CMW710-R7174
 1/6       NONE            Absent       NONE
 1/7       NONE            Absent       NONE
 1/8       NONE            Absent       NONE
 1/9       NONE            Absent       NONE
 1/10      NONE            Absent       NONE
 1/11      NONE            Absent       NONE
 1/12      CR-SF08C        Normal       CR16000-CMW710-R7174
 1/13      CR-SF08C        Normal       CR16000-CMW710-R7174
 1/14      CR-SF08C        Normal       CR16000-CMW710-R7174
 1/15      CR-SF08C        Normal       CR16000-CMW710-R7174
 1/16      CR-SF08C        Normal       CR16000-CMW710-R7174
 1/17      CR-SF08C        Normal       CR16000-CMW710-R7174
 1/18      CR-SF08C        Normal       CR16000-CMW710-R7174
以上显示信息表明,该IRF中包含一台成员设备,成员编号为1。同时还显示了该成员设备的单板信息。从单板状态可以看出,成员设备1的1号单板为整个IRF的主用主控板,成员设备1的主控板(0号槽位)为整个IRF的备用主控板。
表1-5 display device命令显示信息描述表(IRF模式)
Slot No.
设备在IRF中的成员编号和成员设备上单板所在的槽位号
Brd Type
单板类型
单板的当前状态:
·     Absent:单板不在位
·     Master:单板为全局主用主控板(即整个IRF的主用主控板)
·     Standby:单板为全局备用主控板(即整个IRF的备用主控板)
·     Normal:单板为接口板,并且状态正常
·     Fault:单板状态异常
·     Off:表示该槽位的单板没有上电
Software Version
当前单板上运行的软件版本:
·     显示软件版本:应与设备软件版本一致
·     NONE:表示该槽位没有单板
# 显示5号接口板的信息。(独立运行模式)
<Sysname> display device slot 5
Status   : Normal
Type     : CR-SPC-GT48LEF
Software : CR16000-CMW710-R7174
PCB      : Ver.A
Board Cpu:
  Number of Cpld: 2
  Cpld 0:
    SoftWare  : 001C
  Cpld 1:
    SoftWare  : 001C
CpuCard
  Type      : LSR1CPA
  PCB       : Ver.C
  Number of Cpld: 1
  Cpld 0:
    SoftWare  : 001
  BootRom   : 2.12
  Base Boot  : 2.10
Mbus card
  Type      : LSR1MBCB
  Software  : 115
  PCB       : Ver.B
Chip 0:
  Learning Mode : IVL
Chip 1:
  Learning Mode : IVL
Chip 2:
  Learning Mode : IVL
Chip 3:
  Learning Mode : IVL
表1-6 display device命令显示信息描述表(独立运行模式)
Status
单板状态:
·     Master:表示该板是主用主控板
·     Off:表示该槽位的单板没有上电
单板类型
Software
当前单板上运行的软件版本
PCB
单板的PCB版本号
Board Cpu
底板CPU的信息
Number of Cpld
复杂可编程逻辑器件的个数
Cpld 0
0号复杂可编程逻辑器件
SoftWare
软件版本
CpuCard
CPU扣板信息
CPU扣板类型
PCB
PCB版本号
Number of Cpld
复杂可编程逻辑器件的个数
Cpld 0
0号复杂可编程逻辑器件
SoftWare
软件版本
BootRom
BootRom扩展段软件版本
Base Boot
BootRom基本段软件版本
Mbus card
Mbus扣板信息
Mbus扣板类型
Software
软件版本
PCB
PCB版本号
Chip 0
0号芯片的信息
Learning Mode
MAC学习方式:
IVL:Independent VLAN Learning,以VLAN为单位创造独立的MAC地址表
display device manuinfo命令用来显示设备的电子标签信息。
独立运行模式:
IRF模式:
display device manuinfo [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number:显示指定成员设备的电子标签信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
slot slot-number:显示指定单板的电子标签信息。slot-number表示单板所在的槽位号。不输入该
参数时,显示所有单板的相应信息。
电子标签信息也可以称为永久配置数据或档案信息等,在单板或者设备的调测(调试、测试)过程中被写入到设备的存储器件中,包括单板的名称、生产序列号、MAC地址、制造商等信息。本命令显示的是设备的部分电子标签信息。
# 显示设备的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo
Chassis self
DEVICE_NAME          : CR16004AC
DEVICE_SERIAL_NUMBER : 210235A0F5X122000016
MANUFACTURING_DATE   : 2012-03-03
VENDOR_NAME          : H3C
 Slot 1
DEVICE_NAME          : CR-MRP-I
DEVICE_SERIAL_NUMBER : 210231A9680112000022
MAC_ADDRESS          : B8AF-6730-3200
MANUFACTURING_DATE   : 2012-02-04
VENDOR_NAME          : H3C
 Slot 6
DEVICE_NAME          : CR-SPC-GT48LEF
DEVICE_SERIAL_NUMBER : 210231A85L0123456789
MAC_ADDRESS          : NONE
MANUFACTURING_DATE   : 2011-12-08
VENDOR_NAME          : H3C
Fan 1
DEVICE_NAME          : LSTM3FANH
DEVICE_SERIAL_NUMBER : 210231A0J1N121000039
MANUFACTURING_DATE   : 2012-02-07
VENDOR_NAME          : H3C
Power 3
DEVICE_NAME          : NONE
DEVICE_SERIAL_NUMBER : 21023122222222222222
MANUFACTURING_DATE   : NONE
VENDOR_NAME          : NONE
PowerMonitor 1
DEVICE_NAME          : LSTM2PMUA
DEVICE_SERIAL_NUMBER : 210212A031X122000021
MAC_ADDRESS          : NONE
MANUFACTURING_DATE   : 2012-02-13
VENDOR_NAME          : H3C
# 显示设备的电子标签信息。(IRF模式)
Chassis 1
Chassis self
VENDOR_NAME          : H3C
 Slot 1:
MAC_ADDRESS          : 3822-D645-EC00
MANUFACTURING_DATE   : 2011-02-24
VENDOR_NAME          : H3C
 Slot 6
MAC_ADDRESS          : NONE
VENDOR_NAME          : H3C
Fan 1
VENDOR_NAME          : H3C
Power 3
DEVICE_NAME          : NONE
VENDOR_NAME          : NONE
PowerMonitor 1
MAC_ADDRESS          : NONE
VENDOR_NAME          : H3C
表1-7 display device manuinfo命令信息显示描述表
Chassis 1 Slot 0
成员设备1上0号单板的相关信息
DEVICE_NAME
设备名称
设备序列号
MAC_ADDRESS
设备出厂MAC地址
MANUFACTURING_DATE
设备调测日期
VENDOR_NAME
制造商名称
display device manuinfo chassis-only命令用来显示指定机框背板的电子标签信息。
独立运行模式:
IRF模式:
display device manuinfo chassis chassis-number chassis-only
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
# 显示机框背板的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo chassis-only
Chassis self
VENDOR_NAME          : H3C
# 显示成员设备1上机框背板的电子标签信息。(IRF模式)
<Sysname> display device manuinfo chassis 1 chassis-only
 Chassis 1:
Chassis self
VENDOR_NAME          : H3C
display device manuinfo fan命令用来显示指定风扇的电子标签信息。
独立运行模式:
display device manuinfo fan fan-id
IRF模式:
display device manuinfo chassis chassis-number fan fan-id
fan-id:表示设备上风扇的ID编号,取值范围为1~2。
# 显示风扇2的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo fan 2
Fan 2:
DEVICE_SERIAL_NUMBER : 210235A36L1234567890
MANUFACTURING_DATE   : 2010-01-20
VENDOR_NAME          : H3C
# 显示成员设备1上风扇2的电子标签信息。(IRF模式)
<Sysname> display device manuinfo chassis 1 fan 2
 Chassis 1:
 Fan 2:
DEVICE_SERIAL_NUMBER   : 210235A36L1234567891
VENDOR_NAME            : H3C
display device manuinfo power命令用来显示指定电源的电子标签信息。
独立运行模式:
display device manuinfo power power-id
IRF模式:
display device manuinfo chassis chassis-number power power-id
power-id:表示设备上电源的ID编号,CR16018设备上取值范围为1~12,其他型号设备上取值范围为1~6。
# 显示电源2的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo power 2
Power 2:
DEVICE_NAME          : power
VENDOR_NAME          : H3C
# 显示成员设备1上电源2的电子标签信息。(IRF模式)
<Sysname> display device manuinfo chassis 1 power 2
 Chassis 1:
Power 2:
DEVICE_NAME            : power2
VENDOR_NAME            : H3C
display device manuinfo power-monitor命令用来显示指定电源监控模块的电子标签信息。
独立运行模式:
display device manuinfo power-monitor pmu-id
IRF模式:
display device manuinfo chassis chassis-number power-monitor pmu-id
power-monitor pmu-id:表示设备上电源监控模块的编号。对于只有一个电源框的设备(如CR16008),pmu-id取值为1;对于有2个电源框的设备(如CR16018),上方第一个电源框的电源监控模块编号为1,第二个电源框的电源监控模块编号为2。
电源监控模块是设备上的硬件,它用于对设备上的电源模块进行监控。
# 显示电源监控模块2的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo power-monitor 2
PowerMonitor 2:
DEVICE_NAME          : PMU
DEVICE_SERIAL_NUMBER : 210231A36L1234567890
MAC_ADDRESS          : NONE
VENDOR_NAME          : H3C
# 显示成员设备1上电源监控模块2的电子标签信息。(IRF模式)
<Sysname> display device manuinfo chassis 1 power-monitor 2
 Chassis 2:
PowerMonitor 2:
DEVICE_NAME            : PMU2
DEVICE_SERIAL_NUMBER   : 210231A36L1234567891
MAC_ADDRESS            : NONE
VENDOR_NAME            : H3C
display diagnostic-information命令用来显示系统当前多个功能模块运行的统计信息。
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ]
hardware:收集硬件相关诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个功能模块的运行信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,显示系统当前多个功能模块运行的统计信息。
该命令不支持“|”、“>”和“>>”参数,执行该命令后,用户可以选择直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,保存到指定文件时会同时收集设备上的core文件,因为诊断信息较多,core文件较大,系统会自动将该文件压缩后保存,默认文件名组成为diag_sysname_年月日-时分秒,文件名后缀为“.tar.gz”。
# 显示系统当前各个功能模块运行的统计信息。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_sysname_20150705-112153.tar.gz]:t
est.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
display environment命令用来显示设备上温度传感器的温度信息,包括当前温度和设定的温度告警门限。
独立运行模式:
IRF模式:
display environment [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number:显示IRF中指定成员设备上温度传感器的温度信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
slot slot-number:显示设备中指定单板上的温度传感器的温度信息。slot-number表示单板所在的槽位号。
·     不指定slot参数时,显示的是设备上所有温度传感器的温度信息。(独立运行模式)
·     不指定chassis参数时,显示的是IRF中所有温度传感器的温度信息;指定chassis但不指定slot时,显示的是指定成员设备上所有温度传感器的温度信息。(IRF模式)
# 显示设备上所有温度传感器的温度信息。(独立运行模式)
<Sysname> display environment
System temperature information (degree centigrade):
Slot  Sensor    Temperature  LowerLimit  WarningLimit  AlarmLimit ShutdownLimit
   1  inflow  1       30         -10           55           80          N/A
   1  outflow 1       34          -5           60           85          N/A
   1  hotspot 1       34          -5           60           85          N/A
   2  inflow  1       35         -10           60           85          N/A
   2  outflow 1       40           0           60           85          N/A
   2  hotspot 1       38          -5           60           80          N/A
   6  inflow  1       39          -5           60           80          N/A
   6  outflow 1       39         -10           60           95          N/A
   6  hotspot 1       47           0           65           95          N/A
   8  inflow  1       36          -5           60           80          N/A
   8  outflow 1       41         -10           60           95          N/A
   8  hotspot 1       45           0           65           95          N/A
# 显示IRF中所有温度传感器的温度信息。(IRF模式)
 1/1  inflow  1       30         -10           55           80          N/A
 1/1  outflow 1       34          -5           60           85          N/A
 1/1  hotspot 1       34          -5           60           85          N/A
 1/2  inflow  1       35         -10           60           85          N/A
 1/2  outflow 1       40           0           60           85          N/A
 1/2  hotspot 1       38          -5           60           80          N/A
 1/6  inflow  1       39          -5           60           80          N/A
 1/6  outflow 1       39         -10           60           95          N/A
 1/6  hotspot 1       47           0           65           95          N/A
 1/8  inflow  1       36          -5           60           80          N/A
 1/8  outflow 1       41         -10           60           95          N/A
 1/8  hotspot 1       45           0           65           95          N/A
表1-8 display environment命令显示信息描述表
System Temperature information (degree centigrade)
系统温度信息(单位为摄氏度)
sensor
温度传感器
·     hotspot:表示热点温度传感器
·     inflow:表示入风口温度传感器
·     outflow:表示出风口温度传感器
Slot
当显示数字时表示指定槽位单板上温度传感器的温度信息;当显示Vent时表示位于机框、风扇框上的温度传感器的温度信息(独立运行模式)
Slot
当显示chassis-number/slot-number时表示指定成员设备指定单板上温度传感器的温度信息;当显示chassis-number/Vent时表示指定成员设备上位于机框、风扇框上的温度传感器的温度信息(IRF模式)
Temperature
当前温度
LowerLimit
低温告警门限
WarningLimit
一般级(Warning)高温告警门限
AlarmLimit
严重级(Alarm)高温告警门限
ShutdownLimit
关断级(Shutdown)高温告警门限,当温度传感器的温度大于该门限时,设备会自动关闭
display fabric utilization命令用来显示设备接口板上交换芯片的通道利用率信息。
独立运行模式:
display fabric utilization [ slot slot-number ]
IRF模式:
display fabric utilization [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板上交换芯片的通道利用率信息。slot-number表示单板所在的槽位号。不指定该参数时,表示所有单板。(独立运行模式)。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的通道利用率信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板在成员设备上的槽位号。不指定该参数时,表示所有IRF中的所有单板。(IRF模式)
# 显示2号接口板上交换芯片的通道信息。(独立运行模式)
<System> display fabric utilization slot 2
                    Input                         Output
Chs Slot Chan Speed Uitl Peak                     Uitl Peak
0    2    0     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2    1     1G    0%   0% 14:18:03 2023/07/05   0%   0% 14:18:03 2023/07/05
0    2    2     1G    0%   0% 16:44:59 2023/07/05   0%   0% 16:44:59 2023/07/05
0    2    3     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2    4     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2    5     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2    6     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2    7     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2    8     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2    9     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   10     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   11     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   12     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   13     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   14     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   15     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   16     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   17     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   18     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   19     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   20     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   21     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   22     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   23     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   24     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   25     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   26     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   27     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   28     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   29     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   30     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   31     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   32     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   33     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   34     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   35     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   36     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   37     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   38     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   39     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   40     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   41     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   42     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   43     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   44     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   45     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   46     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
0    2   47     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
# 显示2号成员设备2号接口板上交换芯片的通道信息。(IRF模式)
<System> display fabric utilization chassis 2 slot 2
                    Input                         Output
2    2    0     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2    1     1G    0%   0% 14:18:03 2023/07/05   0%   0% 14:18:03 2023/07/05
2    2    2     1G    0%   0% 16:44:59 2023/07/05   0%   0% 16:44:59 2023/07/05
2    2    3     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2    4     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2    5     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2    6     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2    7     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2    8     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2    9     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   10     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   11     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   12     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   13     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   14     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   15     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   16     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   17     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   18     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   19     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   20     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   21     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   22     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   23     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   24     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   25     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   26     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   27     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   28     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   29     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   30     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   31     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   32     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   33     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   34     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   35     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   36     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   37     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   38     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   39     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   40     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   41     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   42     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   43     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   44     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   45     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   46     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
2    2   47     1G    0%   0% 11:39:10 2023/07/05   0%   0% 11:39:10 2023/07/05
表1-9 display fabric utilization命令显示信息描述表
Chs
取值为0,无实际意义(独立运行模式)
Chassis的缩写,为设备在IRF中的成员编号(IRF模式)
Slot
接口板所在的槽位号
Chan
Channel的缩写,通道号
Speed
通道的速率
Input
入方向的统计数据
Output
出方向的统计数据
Uitl
通道利用率
Peak
通道利用率峰值以及峰值发生的时间
1.1.24  display fan
display fan命令用来显示设备风扇的工作状态。
独立运行模式:
display fan [ verbose ]
IRF模式:
display fan [ chassis chassis-number ] [ verbose ]
chassis chassis-number:显示指定成员设备上风扇的状态信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备上的所有风扇。(IRF模式)
verbose:显示设备内置风扇的详细信息。不指定该参数时,显示设备内置风扇的简要信息。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
Fan-tray state on chassis 0:
Fan-tray 1    state: Normal
# 显示设备上所有风扇的详细信息。
<Sysname>display fan verbose
Fan-tray verbose state on chassis 0:
Fan-tray 1:
Software version: 204
Hardware version: Ver.A
Fan number: 8
Temperature: 33 ℃
High temperature alarm threshold: 60 ℃
Low speed alarm threshold: 30 %
Fan  Status      Speed(%)
 1   normal      50 %
 2   normal      50 %
 3   normal      50 %
 4   normal      50 %
 5   normal      50 %
 6   normal      50 %
 7   normal      45 %
 8   normal      45 %
 Type: FCU
 Current Ver: 204
 Boot Ver: 100
 Low-Area Ver: 204
 High-Area Ver: 203
 Current-Area: Low
表1-10 display fan命令显示信息描述表
Fan-tray 1:
以下信息为1号风扇框上风扇的详细状态
Software version:
软件版本
Hardware version
风扇监控板硬件版本
Fan number:
风扇数量
Temperature:
设备温度
设备温度告警门限
风扇低速告警门限
Fan
风扇编号
Status
风扇状态
Speed(rpm)
风扇转速
display fan auto-control-mode命令用来显示设备当前风扇的工作模式。
独立运行模式:
IRF模式:
display fan auto-control-mode chassis chassis-number
# 显示设备当前风扇的工作模式。
<Sysname> display fan auto-control-mode
Current fan auto-control mode: silence-mode
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息。
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息,包括各种故障对应的修复操作,以及系统中每个单板最近十次故障修复的历史信息(如果是连续相同的操作,只会记录其中最后一次)。
硬件故障检测和修复的历史信息保存在主用主控板上,即使某个槽位单板已拔出或者更换过,只要在主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。
# 查看设备的硬件故障检测和故障修复信息。
<Sysname> display hardware-failure-detection
Current level:
    chip       : isolate
    board      : isolate
    forwarding : warning
--------------------------Slot  0 executed records:-----------------------------
                 There is no record.
--------------------------Slot  0 trapped records:-----------------------------
                 There is no record.
表1-11 display hardware-failure-detection命令显示信息描述表
Current level
当前故障检测对应的修复操作级别
chip       :
器件类级别
board      :
单板类级别
forwarding :
转发类级别
Slot  n executed records:
对应主控板n上记录的各个单板的历史操作记录
display hardware-failure-protection命令用来显示设备上硬件故障保护的配置情况。
display hardware-failure-protection [ aggregation | port { auto-down | interface-type interface-number } ]
aggregation:显示聚合组的硬件故障保护配置情况。
port:显示端口硬件故障保护的配置情况。
auto-down:显示已配置端口硬件故障保护的端口列表。
interface-type interface-number:显示指定端口上硬件故障保护的配置情况。
如果不带参数,则显示设备上所有硬件故障保护的配置情况,包括是否配置了针对聚合组的硬件故障保护和所有配置了端口硬件故障保护的端口列表。
# 查看设备上所有硬件故障保护的配置情况。
<Sysname> display hardware-failure-protection
Aggregation: on
Port: ge3/0/1     ge3/0/2
# 查看配置了端口硬件故障保护的端口列表。
<Sysname> display hardware-failure-protection port auto-down
# 查看端口GE3/0/2是否配置了硬件故障保护。
<Sysname> display hardware-failure-protection port GigabitEthernet 3/0/2
Auto-down is NOT allowed while hardware-failure happened.
表1-12 display hardware-failure-protection命令显示信息描述表
Aggregation
显示是否配置了针对聚合组的硬件故障保护功能
Port:
显示配置了端口硬件故障保护的端口列表
display memory命令用来显示内存使用情况。
独立运行模式:
display memory [ slot slot-number ]
IRF模式:
display memory [ chassis chassis-number slot slot-number ]
slot slot-number:表示单板所在的槽位号,不指定时显示当前所有单板的内存使用情况。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板,不指定时显示当前所有单板的内存使用情况。(IRF模式)
# 显示设备的内存使用情况。(独立运行模式)
<Sysname> display memory
The statistics about memory is measured in KB:
Slot 0:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:        507980    154896    353084         0       488     54488       69.5%
-/+ Buffers/Cache:     99920    408060
Swap:           0         0         0
# 显示设备的内存使用情况。(IRF模式)
Chassis 1 Slot 0:
Swap:           0         0         0
表1-13 display memory命令显示信息描述表
系统内存使用情况,以下统计信息均以KB为单位
Slot
单板所在的槽位号(独立运行模式)
Chassis x Slot x
单板所在的槽位号(IRF模式)
Mem
内存使用信息
Total
系统可分配的物理内存的大小
设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小
Used
整个系统已用的物理内存大小
Free
整个系统可用的物理内存大小
Shared
多个进程共享的物理内存总额
Buffers
已使用的文件缓冲区的大小
Cached
高速缓冲寄存器已使用的内存大小
FreeRatio
整个系统物理内存的空闲率
-/+ Buffers/Cache
-/+ Buffers/Cache:Used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小
-/+ Buffers/Cache:Free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小
Swap
交换分区的使用信息
display memory-threshold命令用来显示内存告警门限相关信息。
独立运行模式:
display memory-threshold [ slot slot-number ]
IRF模式:
display memory-threshold [ chassis chassis-number slot slot-number ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。不指定该参数时,表示全局主用主控板。(IRF模式)
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold:
     Minor: 64M
     Severe: 48M
     Critical: 32M
     Normal: 96M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 2015-5-15 09:21:35.546
    Latest notification: 2015-5-15 09:21:35.546
    Total number of notifications sent: 1
 [Enter minor low-memory state]
    First notification at: 2015-5-15 09:07:05.941
    Latest notification at: 2015-5-15 09:07:05.941
 [Back to minor low-memory state]
    First notification at: 0.0
    Latest notification at: 0.0
    Total number of notifications sent: 0
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
表1-14 display memory-threshold命令显示信息描述表
         Minor:
         Severe:
         Critical:
         Normal:
当前内存门限阈值:
·     Minor:一级告警门限,单位为MB
·     Severe:二级告警门限,单位为MB
·     Critical:三级告警门限,单位为MB
·     Normal:恢复到正常状态的阈值,单位为MB
系统当前内存使用状态:
·     Normal:正常状态
·     Minor:一级告警门限状态
·     Severe:二级告警门限状态
·     Critical:三级告警门限状态
Event statistics:
门限事件统计信息,事件分为:
·     Back to normal state:内存恢复到正常状态
·     Enter minor low-memory state:进入一级告警门限状态
·     Back to minor low-memory state:恢复到一级告警门限状态
·     Enter severe low-memory state:进入二级告警门限状态
·     Back to severe low-memory state:恢复到二级告警门限状态
·     Enter critical low-memory state:进入三级告警门限状态
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
Total number of notification send
事件发生的总次数
display power-supply命令用来显示设备电源的信息。
独立运行模式:
display power-supply [ verbose ]
IRF模式:
display power-supply [ chassis chassis-number ] [ verbose ]
chassis chassis-number:显示指定成员设备上电源的信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
verbose:显示电源的详细信息。不指定该参数时,显示电源的简要信息。
通过指定verbose关键字,可以查看电源管理功能的配置情况和系统功率信息,包括:
·     System power-supply policy:电源管理功能是否使能;
·     System power-module redundant(configured):通过命令行配置的冗余电源模块数;
·     System power usable:系统可用功率。系统可用功率 = 电源模块的额定功率X系统电源模块数-系统实际冗余功率;
·     System power redundant(actual):系统实际冗余功率。该值只能取电源模块额定功率的整数倍;
¡     如果系统剩余功率>=电源模块额定功率×配置的冗余电源模块数,则系统实际冗余功率显示值为电源模块额定功率×配置的冗余电源模块数
¡     如果系统剩余功率<电源模块额定功率×配置的冗余电源模块数,则系统实际冗余功率显示值为系统剩余功率向下取整。比如:电源模块的额定功率为2000W,配置的冗余电源模块数为3,系统剩余功率小于2000W时,此处显示为0;2000W<=系统剩余功率<4000W时,此处显示为2000W。
·     System power allocated:系统已分配的功率。系统已分配功率=系统配置的所有硬件模块(包括单板、风扇等)的最大功率之和;
·     System power available:系统可用的剩余功率,系统可用的剩余功率 = 系统可用功率-系统已分配功率;
·     System power used(current):系统实时功耗。通常小于系统已分配的功率;
·     当System power redundant(actual)显示值<配置的冗余电源模块数×电源模块额定功率时,说明冗余功率已经启用,您可以考虑增加电源模块以保持期望的冗余功率。
# 显示电源详细信息。
<Sysname> display power-supply verbose
Power info on chassis 0:
System power-supply policy: enable
System power-module redundant(configured): 1
System power usable: 4000 Watts
System power redundant(actual): 0 Watts
System power allocated: 3585 Watts
System power available: 415 Watts
System power used(current): 419.73 Watts
System power monitoring unit 1:
        Software version: 200
Type        In/Out  Rated-Vol(V)  Existing  Usable  Redundant(actual)
PSE9000-A   AC/DC   220(default)  2         2       0
DC output voltage information:
Tray Value(V)  Upper-Threshold(V)  Lower-Threshold(V)  Status
  1  49.97     52.00               48.00               Normal
DC output current information:
Total current(A): 8.40
Branch   Value(A)
 1/1       3.80
 1/2       4.60
 1/3       N/A
 1/4       N/A
 1/5       N/A
 1/6       N/A
 1/7       N/A
 1/8       N/A
PSU Status:
ID  Status  Input-Err   Output-Err High-Temperature Fan-Err Closed Current-Limit
1/1  Normal
1/2  Normal
1/2                     Low-vol                                     Y
1/3  Absent
1/4  Absent
1/5  Absent
1/6  Absent
1/7  Absent
1/8  Absent
Input-Err:
        *Over-vol: Input voltage is higher than the upper threshold.
Output-Err:
        *Over-vol: Output voltage is not between the lower and upper thresholds.
        *Low-vol:  Output voltage is lower than bus voltage. Output from others might be high.
PSU status might be incorrect. Please contact technical support.
Line-card power status:
Slot  Board-Type       Watts  Status
 2    None             --     Absent
 3    None             --     Absent
 4    CR-SPC-GP48LEF   195    On
 5    None             --     Absent
 6    None             --     Absent
 7    None             --     Absent
 8    None             --     Absent
 9    None             --     Absent
PMU 1: normal
    Protocol: 21
    Type: LST1PMUB
    Vendor: H3C
    Current Ver: 200
    Boot Ver: 205
    Low-Area Ver: 200
    High-Area Ver: Unknown
    Current-Area: Low
    PCB Ver: Ver.A
    Backplane PCB Ver: Ver.A
    Backplane Type: LST19KA2PSB
    PMU Temperature: 29 ℃
    PSU Count: 2
    PSU Actual Output: 50V
     ID     Temperature Fan 0 Speed Fan 1 Speed Actual Current
    Run1     41          141         140         4
    Run2     41          138         138         5
      ID    Inp-Vol RatedPower Type             Hardware         SN
    Info1  220     2000       CP2000AC54PE     1:18             12CS39016731
    Info2  220     2000       CP2000AC54PE     1:18             12CS39016230
display scheduler job命令用来查看Job的配置信息,包括Job的名称和分配的命令。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示已执行的Job的日志信息,包括Job的名称、对应的Schedule的名称、执行时间以及执行结果。
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang GigabitEthernet 3/0/1 to GigabitEthernet 3/0/3
[Sysname-if-range]shutdown
表1-15 display scheduler logfile命令显示信息描述表
Logfile Size
Schedule日志文件的大小,单位为字节
Job name
Job的名称
Schedule name
Schedule的名称
Execution time
开始执行Job的时间
Completion time
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息)
Job output
Job中的命令执行时的输出信息
·     reset scheduler logfile
display scheduler reboot命令用来查看定时重启功能的相关配置。
# 查看定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2011 (in 1 hours and 39 minutes).
·     scheduler reboot at
·     scheduler reboot delay
display scheduler schedule命令用来查看Schedule的相关信息。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 查看所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2015
Last execution time  : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts     : 1
shutdown                                          Successful
表1-16 display scheduler schedule命令显示信息描述表
Schedule name
Schedule的名称
Schedule type
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息
Start time
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Last execution time
Schedule上一开始执行的时间
·     如果没有为Schedule配置执行时间,则不会显示该信息
·     如果还没有执行,则显示Yet to be executed
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Execution counts
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息
Job name
Schedule下关联的Job的名称
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看)
·     Successful:表示执行成功
·     Failed:表示执行失败
·     Waiting:表示正在等待被执行
·     In process:表示正在执行
·     -NA-:表示还没有到执行时间
display system-working-mode命令用来显示当前的系统工作模式。
# 显示当前的系统工作模式。
<Sysname> display system-working-mode
The current system working mode is standard.
The next system working mode is advance.
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见表1-17。如果没有故障,则显示为None。
表1-17 display transceiver alarm命令输出信息描述表
SFP/SPF+
RX loss of signal
接收信号丢失
RX power high
接收光功率高告警
RX power low
接收光功率低告警
TX fault
发送错误
TX bias high
偏置电流高告警
TX bias low
偏置电流低告警
TX power high
发送光功率高告警
TX power low
发送光功率低告警
Temp high
温度高告警
Temp low
温度低告警
Voltage high
电压高告警
Voltage low
电压低告警
Transceiver info I/O error
模块信息读写错误
Transceiver info checksum error
模块信息校验和错误
Transceiver type and port configuration mismatch
模块类型和端口配置不匹配
Transceiver type not supported by port hardware
端口不支持该模块类型
XFP
RX loss of signal
接收信号丢失
RX not ready
接收状态未就绪
RX CDR loss of lock
RX CDR时钟失锁
RX power high
接收光功率高告警
RX power low
接收光功率低告警
TX not ready
发送状态未就绪
TX fault
发送错误
TX CDR loss of lock
TX CDR时钟失锁
TX bias high
偏置电流高告警
TX bias low
偏置电流低告警
TX power high
发送光功率高告警
TX power low
发送光功率低告警
Module not ready
模块状态未就绪
APD supply fault
APD(Avalanche Photo Diode,雪崩光电二极管)错误
TEC fault
TEC(Thermoelectric Cooler,热点冷却器)错误
Wavelength unlocked
光信号波长失锁
Temp high
温度高告警
Temp low
温度低告警
Voltage high
电压高告警
Voltage low
电压低告警
模块信息读写错误
模块信息校验错误
模块类型和端口配置不匹配
端口不支持该模块类型
# 显示接口GigabitEthernet3/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface gigabitethernet 3/0/1
GigabitEthernet3/0/1 transceiver current alarm information:
  RX loss of signal
  RX power low
表1-18 display transceiver alarm显示信息描述表
接口光模块当前故障告警信息
RX loss of signal
接收信号丢失
RX power low
接收光功率低告警
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet3/0/2上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface gigabitethernet 3/0/2
GigabitEthernet3/0/2 transceiver diagnostic information:
    Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
36        3.31        6.13      -35.64          -5.19
  Alarm thresholds:
           Temp(°C)   Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   50         3.55        1.44      -10.00         5.00
    Low    30         3.01        1.01      -30.00         0.00
表1-19 display transceiver diagnosis显示信息描述表
接口插入的光模块的数字诊断信息
当前的诊断参数
Temp.(°C)
数字诊断参数——温度,单位为°C,精确到1°C
Voltage(V)
数字诊断参数——电压,单位为V,精确到0.01V
Bias(mA)
数字诊断参数——偏置电流,单位为mA,精确到0.01mA
RX power(dBm)
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm
TX power(dBm)
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm
Alarm thresholds
告警门限
High
高告警门限
Low
低告警门限
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
interface-type interface-number:显示接口上插入的可插拔接口模块的主要特征参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet3/0/3上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface gigabitethernet 3/0/3
GigabitEthernet3/0/3 transceiver information:
  Transceiver Type              : 1000_BASE_SX_SFP
  Connector Type                : LC
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 550(50um),270(62.5um)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C
  Ordering Name                 : SFP-GE-SX-MM850
表1-20 display transceiver interface命令显示信息描述表
可插拔接口模块信息
Transceiver Type
可插拔接口模块的物理型号
Connector Type
可插拔接口模块的连接器类型,其中:
·     光纤连接器包括SC(SC Connector,NTT公司推出的拔插锁紧式光纤连接器)、LC(LC Connector,Lucent公司推出的1.25mm/RJ45锁紧式光纤连接器)两种类型
·     其他连接器包括RJ-45、CX4等类型
Wavelength(nm)
·     光模块:显示发送激光中心波长,单位nm;对于支持多条不同波长光路的模块(例如10GBASE-LX4模块),各个波长值之间用逗号分隔
·     电模块:显示为“N/A”
Transfer Distance(xx)
传输距离,xx为传输距离的单位,对于单模模块xx为km,对于其他模块xx为m。当模块支持多种传输介质时,各个传输距离值之间用逗号分隔。距离值后面括号里包含对应的“传输介质”。下面是各个介质的名称:
·     9um:表示9/125um单模光纤
·     50um:表示50/125um多模光纤
·     62.5um:表示62.5/125um多模光纤
·     TP:表示双绞线
·     CX4:表示CX4电缆
对数字诊断功能的支持情况,其中:
·     YES:表示支持数字诊断
·     NO:表示不支持数字诊断
Vendor Name
模块生产或定制厂商名称
Ordering Name
可插拔接口模块的对外型号
display transceiver manuinfo命令用于显示可插拔接口模块的部分电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet3/0/4上插入的可插拔接口模块的部分电子标签信息。
<Sysname> display transceiver manuinfo interface gigabitethernet 3/0/4
GigabitEthernet3/0/4 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2012-09-01
  Vendor Name          : H3C
表1-21 display transceiver manuinfo命令显示信息描述表
Manu. Serial Number
在生产过程中生成的序列号
Manufacturing Date
写入电子标签的日期
Vendor Name
厂商名称
display version命令用来显示系统版本信息。
display version
# 查看系统版本信息。
<Sysname> display version
H3C Comware Software, Version 7.1.045, Release 7174
H3C CR16008 uptime is 0 weeks, 0 days, 0 hours, 31 minutes
Last reboot reason : Power on
Boot image: cfa0:/CR16000-CMW710-BOOT-R7174.bin
Boot image version: 7.1.045, Release 7174
  Compiled Mar 04 2015 14:13:37
System image: cfa0:/CR16000-CMW710-SYSTEM-R7174.bin
System image version: 7.1.045, Release 7174
CR-MRP-I 2/0:  uptime is 0 weeks, 0 days, 0 hours, 31 minutes
3456    Mbytes SDRAM
1024    Kbytes NVRAM Memory
Type     : CR-MRP-I
BootRom  : 2.19
PCB      : Ver.B
Board Cpu:
  Number of Cpld: 2
  Cpld 0:
    SoftWare  : 003
---- More ----
fan auto-control-mode命令用来配置风扇的工作模式。
undo fan auto-control-mode命令用来恢复缺省情况。
独立运行模式:
fan auto-control-mode { low-temperature | silence }
IRF模式:
fan auto-control-mode chassis chassis-number { low-temperature | silence }
undo fan auto-control-mode chassis chassis-number
风扇工作在低温模式。
low-temperature:配置风扇工作在低温模式。该模式下风扇转速较高,以便优先保证单板在较低的温度下工作。
silence:配置设备工作在静音模式。该模式下风扇转速较低、噪音较小,但是单板温度比低温模式略高。在对噪音比较敏感的场合推荐使用此模式。
# 配置风扇工作在静音模式。(独立运行模式)
[Sysname] fan auto-control-mode silence
# 配置IRF中成员设备2的风扇工作在静音模式。(IRF模式)
[Sysname] fan auto-control-mode chassis 2 silence
forward-path-detection enable命令用来开启转发通道自动检测功能。
undo forward-path-detection enable命令用来关闭转发通道自动检测功能。
转发通道自动检测功能处于开启状态。
转发通道自动检测功能可以检测设备中的数据转发通道是否正常。如果不正常,会打印日志信息提醒用户。
# 开启转发通道自动检测功能。
[Sysname] forward-path-detection enable
hardware-failure-detection命令用来配置当系统检测到硬件故障时自动采取的修复操作。
undo hardware-failure-detection命令用来恢复缺省情况。
hardware-failure-detection { board | chip | forwarding } { off | isolate | reset | warning }
undo hardware-failure-detection { board | chip | forwarding }
当系统检测到器件(chip)、单板(board)和转发(forwarding)的硬件故障时,修复操作均为warning。
board:对单板故障进行在线检测,包括控制通道检测和单板状态快速检测。
chip:对器件故障进行在线检测,包括单板上各种器件(比如芯片、电容、电阻等)的检测。
forwarding:对转发层面的故障进行在线检测,包括业务自动检测和其他转发相关的检测。
off:检测到故障时,设备不进行任何操作。
isolate:检测到故障时,设备会自动关闭端口、隔离单板、禁止单板加载或给单板下电,从而尽量减小故障的影响。
reset:检测到故障时,设备会自动重启器件/单板以尝试修复故障。
warning:检测到故障时,设备发送Trap信息,不会修复故障。
设备启动后,系统会持续自动检测器件、单板和转发的硬件故障。
# 配置系统检测到器件故障时自动告警。
[Sysname] hardware-failure-detection chip warning
# 配置系统检测到单板故障时自动重启。
[Sysname] hardware-failure-detection board reset
hardware-failure-protection aggregation命令用来开启针对聚合组的硬件故障保护功能。
undo hardware-failure-protection aggregation命令用来关闭针对聚合组的硬件故障保护功能。
针对聚合组的硬件故障保护功能处于关闭状态。
只有配置hardware-failure-detection forwarding isolate命令后,该命令才生效。
置该命令后,当系统检测到硬件故障时,会按顺序遵循如下原则处理:
(1)     如果聚合组成员端口配置undo hardware-failure-protection auto-down命令,而且该端口不是聚合组中最后一个UP状态的端口,则该端口会被自动关闭;
(2)     如果聚合组成员端口配置undo hardware-failure-protection auto-down命令,而该端口是聚合组中最后一个UP状态的端口,则该端口不会被关闭;
(3)     如果聚合组成员端口配置了hardware-failure-protection auto-down命令,则不管该端口是不是聚合组中最后一个UP状态的端口,该端口都会被关闭。
出现以下任意一种情况时,hardware-failure-protection aggregation命令会对聚合组中的该成员端口失效:
·     端口下配置了以太网接口环回测试功能,即loopback { external | internal }命令;
·     端口下配置了以太网接口的强制开启功能,即port up-mode命令;
·     该端口配置为IRF物理端口。
# 开启针对聚合组的硬件故障保护功能。
[Sysname] hardware-failure-protection aggregation
·     hardware-failure-detection
·     hardware-failure-protection auto-down
hardware-failure-protection auto-down命令用来开启针对端口的硬件故障保护功能。
undo hardware-failure-protection auto-down命令用来关闭针对端口的硬件故障保护功能。
端口的硬件故障保护功能处于开启状态。
以太网接口视图
配置了hardware-failure-detection forwarding isolate后,本命令才会生效。
在端口上配置该命令前,请确保该端口存在备份的链路,以免造成业务中断。
在端口上配置hardware-failure-protection auto-down命令后,当系统检测到硬件故障时,会自动关闭该端口。此时使用display interface命令可看到该端口状态为Protect DOWN。端口硬件故障解除后,请在接口下执行undo shutdown命令来恢复端口状态。
出现以下任意一种情况时,hardware-failure-protection aggregation命令会对该端口失效:
·     该端口配置为IRF物理端口。
# 对端口配置硬件故障保护。
[Sysname] interface GigabitEthernet 7/0/47
[Sysname-GigabitEthernet7/0/47] hardware-failure-protection auto-down
1.1.46  header
header命令用来设置欢迎信息。
undo header命令用来关闭欢迎信息。
header { incoming | legal | login | motd | shell } text
undo header { incoming | legal | login | motd | shell }
incoming:设置Modem登录用户登录进入用户视图时的欢迎信息。如果要求认证,则欢迎信息在通过认证后输出。
legal:设置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:设置登录验证时的欢迎信息。
motd:设置登录终端界面前的欢迎信息。
shell:设置非Modem登录用户登录进入用户视图时的欢迎信息。
text:输入欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 先后配置incominglegalloginmotdshell欢迎信息,并验证配置效果。
[Sysname] header incoming
Welcome to incoming(header incoming)%
[Sysname] header legal
Welcome to legal (header legal)%
[Sysname] header login
Welcome to login(header login)%
[Sysname] header motd
Welcome to motd(header motd)%
[Sysname] header shell
Welcome to shell(header shell)%
本例中,“%”为text的起始/结束字符,在显示文本后输入“%”表示文本结束,退出header命令。作为起始与结束字符,“%”不会成为所设置欢迎信息的一部分。
采用Telnet方式远程登录设备,测试以上设置(只有设置了登录认证之后,才会显示login欢迎信息)。
* Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
 Press Y or ENTER to continue, N to exit.
Login authentication
Password:
1.1.47  job
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
没有为Schedule分配Job。
Schedule视图
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
·     scheduler job
·     scheduler schedule
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复空闲内存告警的门限值。
独立运行模式:
memory-threshold [ slot slot-number ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number ]
IRF模式:
memory-threshold [ chassis chassis-number slot slot-number ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ chassis chassis-number slot slot-number ]
一级告警门限为96MB,二级告警门限为64MB,三级告警门限为48MB,系统恢复到正常的内存门限为128MB。
minor minor-value:一级告警门限,单位为兆字节(MB),取值范围0~3398;minor-value应小于等于normal-value;为0则表示关闭该级门限告警功能。
severe severe-value:二级告警门限,单位为兆字节(MB),取值范围0~3398;severe-value必须小于等于minor-value;为0则表示关闭该级门限告警功能。
critical critical-value:三级告警门限,单位为兆字节(MB),取值范围0~3398;critical-value必须小于等于severe-value;为0则表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小,单位为兆字节(MB),取值范围0~3398;normal-value小于等于实际内存大小。
slot slot-number:表示单板所在的槽位号,不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板,不指定该参数时,表示全局主用主控板。(IRF模式)
系统实时监控系统剩余空闲内存大小,当条件达到时,就产生相应的告警/告警解除通知,以便通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
设备支持一级、二级、三级告警门限,关于这些告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
# 一级、二级、三级告警门限分别为64MB、48MB、32MB,当系统剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
独立运行模式:
monitor cpu-usage enable [ slot slot-number]
undo monitor cpu-usage enable [ slot slot-number]
IRF模式:
monitor cpu-usage enable [ chassis chassis-number slot slot-number ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number ]
CPU利用率历史记录功能处于开启状态。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板,不指定表示全局主用主控板。(IRF模式)
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
·     display cpu-usage
·     display cpu-usage configuration
·     display cpu-usage history
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
独立运行模式:
monitor cpu-usage interval interval-value [ slot slot-number]
IRF模式:
monitor cpu-usage interval interval-value [ chassis chassis-number slot slot-number ]
CPU利用率历史记录采样周期为1分钟。
interval-value:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
·     display cpu-usage
power-supply off命令用来强制给指定单板断电。
独立运行模式:
power-supply off slot slot-number
IRF模式:
power-supply off chassis chassis-number slot slot-number
【缺省级别】
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。(IRF模式)
指定的单板不能为主控板或交换网板。
如果设备电量不足,且某些接口板处于空闲状态或者连接的为非关键网络节点时,可以手工停止给这些接口板供电,以便节约电能保证给重要接口板供电。
在IRF中,当成员设备上处于up状态的IRF物理端口都位于同一接口板上时,则不允许强制给该接口板断电,以免导致IRF分裂。(IRF模式)
# 强制给9号槽位的单板断电。(独立运行模式)
<Sysname> power-supply off slot 9
# 强制给成员设备1的3号单板的单板断电。(IRF模式)
<Sysname> power-supply off chassis 1 slot 3
power-supply on命令用来手工给指定单板供电。
独立运行模式:
power-supply on slot slot-number
IRF模式中:
power-supply on chassis chassis-number slot slot-number
【缺省级别】
指定的单板不能为主控板或交换网板。
# 手工给9号槽位的单板供电。(独立运行模式)
<Sysname> power-supply on slot 9
# 手工给成员设备1的3号单板的单板供电。(IRF模式)
<Sysname> power-supply on chassis 1 slot 3
power-supply led-blink命令用来配置设备上交流电源模块运行指示灯的闪烁时间长度和闪烁延迟时间,用户可以通过指示灯的闪烁确定交流电源模块ID与电源模块实物的对应关系。
独立运行模式:
power-supply led-blink [ module id ] [ blink-time value ] [ delay-time value ]
IRF模式:
power-supply led-blink chassis chassis-number [ module id ] [ blink-time value ] [ delay-time value ]
module id:交流电源模块ID。
blink-time value:交流电源模块运行指示灯连续闪烁时间长度,取值范围为1~10,缺省值为3,单位为秒。
delay-time value:交流电源模块运行指示灯闪烁延迟时间,取值范围0~30,缺省值为0,单位为秒。配置延迟时间后,运行指示灯将在命令下达后延迟value秒开始闪烁,便于用户观察;如果用户没有配置延迟时间,运行指示灯将会在命令下达后立即开始闪烁。
chassis chassis-number:表示指定成员设备在IRF中的成员编号,可使用display device命令查看。
当用户没有指定交流电源模块ID时,将按照交流电源模块ID从小到大的顺序依次闪烁运行指示灯。
本命令仅适用于型号为PSE9000的交流电源框(电源框型号可通过display power-supply命令查询)。
# 配置ID为2的交流电源模块在命令下达10秒后运行指示灯闪烁5秒。
[Sysname] power-supply led-blink module 2 blink-time 5 delay-time 10
power-supply module new-id命令用来给指定交流电源模块分配新的模块ID。
独立运行模式:
power-supply module old-id-list new-id new-id-list
IRF模式:
power-supply module chassis chassis-number old-id-list new-id new-id-list
old-id-list:原交流电源模块ID列表,可以连续输入多个,以空格分隔。
new-id-list:新交流电源模块ID列表,可以连续输入多个,以空格分隔。
power-supply module new-id命令用来给指定交流电源模块分配新的模块ID。old-id-listnew-id-list之间按先后顺序一一对应,即old-id-list中的第一个ID更新为new-id-list中的第一个ID,old-id-list中的第二个ID更新为new-id-list中的第二个ID,以此类推。
·     每个交流电源模块只能分配一个ID,多个交流电源模块不能使用同一ID。推荐将交流电源模块ID号配置为与槽位号一致。
·     本命令仅适用于型号为PSE9000的交流电源框(电源框型号可通过display power-supply命令查询)。
# 原ID分别为2和3的交流电源模块的ID改为3和2。
[Sysname] power-supply module 2 3 new-id 3 2
power-supply policy enable命令用来启用电源管理功能。
undo power-supply policy enable命令用来关闭电源管理功能。
独立运行模式:
IRF模式:
power-supply policy chassis chassis-number enable
undo power-supply policy chassis chassis-number enable
电源管理功能处于使能状态。
【缺省级别】
chassis chassis-number: 表示设备在IRF中的成员编号。(IRF模式)
# 启用电源管理功能。(独立运行模式)
[Sysname] power-supply policy enable
# 启用成员设备1的电源管理功能。(IRF模式)
[Sysname] power-supply policy chassis 1 enable
power-supply policy redundant命令用来配置冗余电源模块数。
undo power-supply policy redundant命令用来恢复缺省情况。
独立运行模式:
power-supply policy redundant module-count
IRF模式:
power-supply policy chassis chassis-number redundant module-count
undo power-supply policy chassis chassis-number redundant
设备上配置的冗余电源模块数为1。
【缺省级别】
module-count:表示冗余电源模块数目,不同设备上的取值范围不同,用户可以通过帮助信息来获取设备支持的取值范围,但是该范围的上限是系统支持的最大冗余模块数,根据设备安插的接口板的数量和耗电量不同,用户实际能够设置的值会小于等于系统支持的最大冗余模块数。
只有在使能电源管理功能后,冗余电源配置才会生效。
配置冗余电源后,您可以使用display power-supply verbose命令实时监控设备当前的冗余功率使用情况是否符合冗余电源功率保留策略,并决定是否增加电源模块。当System power redundant(actual)显示值<配置的冗余电源模块数×电源模块额定功率时,说明冗余功率已经启用,您可以考虑增加电源模块以保持期望的冗余功率。
# 配置电源冗余模块数为3。(独立运行模式)
[Sysname] power-supply policy redundant 3
# 配置成员设备1的电源冗余模块数为3。(IRF模式)
[Sysname] power-supply policy chassis 1 redundant 3
·     display power-supply
1.1.57  reboot
reboot命令用来重启指定单板或整个设备。(独立运行模式)
reboot命令用来重启指定成员设备或所有成员设备。(IRF模式)
独立运行模式:
IRF模式:
force:强制重启。不指定该参数时,重启设备,系统会做一些保护性检查(如启动文件是否存在,是否正在写磁盘等),如检查不通过则退出处理,不会重启设备;指定该参数时,系统将不进行任何检查,直接执行重启操作。
(1)     独立运行模式:
·     不指定slot参数,会导致整个设备重启。
·     指定slot参数,会重启指定单板。
·     重新启动可能会导致业务中断,请谨慎使用该命令。
·     如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
·     如果设备在准备重启时,用户正在进行文件操作,为了安全起见,系统将不会执行此次重启操作。
·     使用force参数时系统在重启时不会做任何保护性措施。重启后,可能出现文件系统损坏的严重问题,请谨慎使用该参数。建议在系统故障、无法正常重启时,才使用该参数。
(2)     IRF模式:
·     不指定chassisslot参数,则会重启所有成员设备。
·     只指定chassis不指定slot参数,则会重启IRF中指定的成员设备。
·     同时指定chassisslot参数,则会重启IRF中指定的单板。
·     使用force参数时,系统在重启时不会做任何保护性措施。重启后,可能出现文件系统损坏的严重问题,请谨慎使用该参数。建议在系统故障、无法正常重启时,才使用该参数。
# 当配置没有变化时,重启设备。
<Sysname> reboot
Now rebooting, please wait...
# 当配置有变化时,重启设备,并选择保存配置文件。
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to flash successfully.
# 当配置有变化时,重启设备,但不保存配置文件。
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:n
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
# 重启接口板(接口板所在的槽位号为2)。(独立运行模式)
<Sysname> reboot slot 2
.......DONE!
This command will reboot the specified slot, Continue? [Y/N]:y
# 强制重启接口板(接口板所在的槽位号为2)。
<Sysname> reboot slot 2 force
# 重启成员设备2。(IRF模式)
<Sysname> reboot chassis 2
.......DONE!
This command will reboot the specified chassis, Continue? [Y/N]:y
# 强制重启成员设备2。
<Sysname> reboot chassis 2 force
# 重启成员设备2上的2号接口板。(IRF模式)
<Sysname> reboot chassis 2 slot 2
.......DONE!
# 强制重启成员设备2上的2号接口板。
<Sysname> reboot chassis 2 slot 2 force
1.1.58  restore factory-default
restore factory-default命令用来将设备恢复到出厂状态。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。执行该命令后,设备将只保留“.bin”软件包、MAC地址、电子标签等维持设备正常工作必需的信息,其它文件和参数均恢复到出厂状态,例如,设备存储介质根目录下的所有配置文件(即后缀为“.cfg”的文件)将被清除,设备在使用过程中生成的日志信息(即/logfile下的“.log”文件以及logbuffer中的信息)、Trap信息、Debug信息将被清除,Boot ROM菜单中各选项的值将恢复到缺省值等。因此,请谨慎使用该命令。
需要注意的是,执行该命令后,需手工重启设备才能使该命令生效。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
·     reboot
1.1.59  reset scheduler logfile
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
·     display scheduler logfile
1.1.60  scheduler job
scheduler job命令用来创建Job并进入Job视图。如果Job已创建,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
没有创建Job。
【缺省级别】
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
·     command
1.1.61  scheduler logfile size
scheduler logfile size命令用来设置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户设置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 设置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
1.1.62  scheduler reboot at
scheduler reboot at命令用来指定设备重启的具体时间和日期。
undo scheduler reboot命令用来取消重启时间的设置。
没有指定设备重启的具体时间和日期。
time:设备重启的时间,格式为HH:MMHH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     YYYY的取值范围为2000~2035;
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
如果没有指定date参数,并且:
·     设置的时间点在当前时间之后,则设备将在当天的该时间点重启;
·     设置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot atscheduler reboot delay命令,最新配置生效。
需要注意的是,该命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
# 假设系统的当前时间为2015年6月6日11:43,设置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
1.1.63  scheduler reboot delay
scheduler reboot delay命令用来配置重启设备的延迟时间。
undo scheduler reboot命令用来取消延时重启配置。
scheduler reboot delay time
没有配置重启设备的延迟时间。
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
·     使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2015年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
1.1.64  scheduler schedule
scheduler schedule命令用来创建Schedule并进入相应的Schedule视图。如果Schedule已创建,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
没有创建Schedule。
schedule-name:Schedule的名字,为1~47个字符的字符串,区分大小写。
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1)     使用scheduler job命令创建Job。
(2)     在Job视图下,使用command命令配置需要执行的命令。
(3)     使用scheduler schedule命令创建Schedule
(4)     在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5)     在Schedule视图下,使用time attime once或者time repeating命令来配置任务执行的时间。一个Schedule下只能设置一个执行时间。
# 创建名为saveconfig的Schedule。
·     job
·     time at
·     time once
·     time interval
1.1.65  shutdown-interval
shutdown-interval命令用来设定定时检测的时间间隔。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval time
定时检测的时间间隔为30秒。
time:定时检测的时间间隔,取值范围为1~300,单位为秒。
某些协议模块在特定情况下会自动关闭某个端口,比如当使能了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。同时,系统会启动一个检测定时器,如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,协议模块则自动激活该端口,令其恢复到真实的物理状态。
需要注意的是,如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。若T<T1,则被关闭的端口会再经过T1-T时间后被恢复;若T>=T1,则被关闭的端口会立即恢复。例如当前time设置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 设定定时检测时间间隔为100秒。
[Sysname] shutdown-interval 100
1.1.66  sysname
sysname命令用来设置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备的名称为H3C。
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 设置设备的名称为R2000。
[Sysname] sysname R2000
[R2000]
1.1.67  system-working-mode
system-working-mode命令用来配置系统工作模式。
undo system-working-mode命令用来恢复缺省情况。
system-working-mode { advance | bridgee | routee | standard | grand }
设备工作在advance模式。
advance:将系统工作模式设置为高级模式。
bridgee:将系统工作模式设置为增强L2模式。
routee:将系统工作模式设置为增强L3模式。
standard:将系统工作模式设置为标准模式。
grand:将系统工作模式设置为完美模式。
不同的系统工作模式支持的单板类型不同,详见表1-22
如果设备中所配置的业务板均为以下种类的单板:RC、RB类单板,为使单板达到最佳性能,建议配置系统工作模式为grand模式。
表1-22 单板类型与系统工作模式对应关系
单板类型
系统工作模式
EB类单板
EC类单板
EF类单板
FD/FG类单板
OAA单板
(LST1NSM2C1)
OAA单板(除LST1NSM2C1)
standard模式
bridgee模式
routee模式
advance模式
grand模式
“√”代表可启动;“×”代表不可启动。
不同模式下设备支持的特性不同,或者相同的特性支持的规格不同,请根据实际需要配置。
要使修改的系统工作模式生效,必须重启设备。
# 将系统工作模式配置为高级模式。
[Sysname] system-working-mode advance
Do you want to change the system working mode? [Y/N]:Y
The system working mode is changed, please save the configuration and reboot the
 system to make it effective!
·     reboot
1.1.68  temperature-limit
temperature-limit命令用于设置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
独立运行模式:
temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
IRF模式:
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number
slot slot-number:配置指定单板上温度传感器的温度门限。slot-number表示单板所在的槽位号。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
inflow:配置入风传感器的温度门限。入风传感器一般置于入风口附近,监测环境温度。
outflow:配置出风传感器的温度门限。出风传感器一般置于出风口附近,监测设备温度。
sensor-number:温度传感器的编号,取值为从1开始的正整数,每一个数字对应设备(单板)上的一个温度传感器。
lowlimit:低温告警门限,单位为摄氏度。
warninglimit:一般级(Warning)高温告警门限,单位为摄氏度,但必须大于低温告警门限。
alarmlimit:严重级(Alarm)高温告警门限,单位为摄氏度,但必须大于一般级高温告警门限。
如果温度低于低温告警门限,系统会生成日志信息和告警信息提示用户;如果温度高于Warning高温门限,系统会生成日志信息和告警信息提示用户;如果温度高于Alarm高温门限,系统一方面通过反复打印日志信息和告警信息提示用户,另一方面还会通过设备面板上的指示灯来告警。
配置时,需要注意的是:
·     高温告警门限必须大于低温告警门限;
·     Alarm高温告警门限必须大于Warning高温告警门限。
温度传感器各种告警阈值的取值范围和缺省情况与设备及单板的具体型号相关,请见表1-23表1-25
表1-23 CR16004设备部分单板温度传感器告警阈值表
单板型号
温度传感器
低温告警阈值(℃)
一般级高温告警阈值(℃)
严重级高温告警阈值(℃)
CR-MRP-I/CR-MRP-II
入风传感器
-20~0,缺省值为-10
28~65,缺省值为55
70~90,缺省值为80
出风传感器
-15~5,缺省值为-5
50~70,缺省值为60
75~95,缺省值为85
1号热点传感器
-15~5,缺省值为-5
50~70,缺省值为60
75~95,缺省值为85
CR-SPC-GP48LEF
入风传感器
-20~0,缺省值为-10
28~70,缺省值为60
70~90,缺省值为80
出风传感器
-15~5,缺省值为-5
50~70,缺省值为60
70~90,缺省值为80
1号热点传感器
-20~0,缺省值为-10
50~70,缺省值为60
65~85,缺省值为75
CR-SPC-XP40RB/CR-SPC-XP40RC
入风传感器
-15~5,缺省值为-5
28~70,缺省值为60
60~80,缺省值为70
出风传感器
-10~10,缺省值为0
65~85,缺省值为75
75~95,缺省值为85
1号热点传感器
-10~10,缺省值为0
65~85,缺省值为75
75~95,缺省值为85
2号热点传感器
-10~10,缺省值为0
70~90,缺省值为80
80~100,缺省值为90
3号热点传感器
-10~10,缺省值为0
75~95,缺省值为85
85~105,缺省值为95
4号热点传感器
-10~10,缺省值为0
75~95,缺省值为85
85~105,缺省值为95
CR-SPC-CP4RC
入风传感器
-15~5,缺省值为-5
28~70,缺省值为60
55~75,缺省值为65
出风传感器
-10~10,缺省值为0
60~80,缺省值为70
65~85,缺省值为75
1号热点传感器
-10~10,缺省值为0
70~90,缺省值为80
75~95,缺省值为85
2号热点传感器
-10~10,缺省值为0
70~90,缺省值为80
75~95,缺省值为85
3号热点传感器
-10~10,缺省值为0
75~95,缺省值为85
80~100,缺省值为90
表1-24 CR16008设备部分单板温度传感器告警阈值表
单板型号
温度传感器
低温告警阈值(℃)
一般级高温告警阈值(℃)
严重级高温告警阈值(℃)
CR-MRP-I/CR-MRP-II
入风传感器
-35~-15,缺省值为-25
28~80,缺省值为70
70~90,缺省值为80
出风传感器
-25~-5,缺省值为-15
60~80,缺省值为70
75~95,缺省值为85
1号热点传感器
-25~-5,缺省值为-15
65~85,缺省值为75
75~95,缺省值为85
CR-SPC-GP48LEF
入风传感器
-25~-5,缺省值为-15
28~75,缺省值为65
70~90,缺省值为80
出风传感器
-15~5,缺省值为-5
60~80,缺省值为70
70~90,缺省值为80
1号热点传感器
-25~-5,缺省值为-15
55~75,缺省值为65
65~85,缺省值为75
CR-SF08E
入风传感器
-20~0,缺省值为-10
28~75,缺省值为65
65~85,缺省值为75
出风传感器
-15~5,缺省值为-5
60~80,缺省值为70
70~90,缺省值为80
1号热点传感器
-10~10,缺省值为0
60~80,缺省值为70
70~90,缺省值为80
入风传感器
-20~0,缺省值为-10
28~65,缺省值为55
55~75,缺省值为65
出风传感器
-10~10,缺省值为0
60~80,缺省值为70
70~90,缺省值为80
1号热点传感器
-10~10,缺省值为0
60~80,缺省值为70
70~90,缺省值为80
2号热点传感器
-10~10,缺省值为0
65~85,缺省值为75
75~95,缺省值为85
3号热点传感器
-10~10,缺省值为0
75~95,缺省值为85
85~105,缺省值为95
4号热点传感器
-10~10,缺省值为0
75~95,缺省值为85
85~105,缺省值为95
CR-SPC-CP4RC
入风传感器
-20~0,缺省值为-10
28~70,缺省值为60
60~80,缺省值为70
出风传感器
-10~10,缺省值为0
55~75,缺省值为65
65~85,缺省值为75
1号热点传感器
-10~10,缺省值为0
65~85,缺省值为75
75~95,缺省值为85
2号热点传感器
-10~10,缺省值为0
65~85,缺省值为75
75~95,缺省值为85
3号热点传感器
-10~10,缺省值为0
70~90,缺省值为80
80~100,缺省值为90
表1-25 CR16018设备部分单板温度传感器告警阈值表
单板型号
温度传感器
低温告警阈值(℃)
一般级高温告警阈值(℃)
严重级高温告警阈值(℃)
CR-MRP-I/CR-MRP-II
入风传感器
-35~-15,缺省值为-25
28~80,缺省值为70
75~95,缺省值为85
出风传感器
-30~-10,缺省值为-20
70~90,缺省值为80
75~95,缺省值为85
1号热点传感器
-30~-10,缺省值为-20
75~95,缺省值为85
80~100,缺省值为90
CR-SPC-GP48LEF
入风传感器
-30~-10,缺省值为-20
28~80,缺省值为70
70~90,缺省值为80
出风传感器
-20~0,缺省值为-10
70~90,缺省值为80
80~100,缺省值为90
1号热点传感器
-25~-5,缺省值为-15
70~90,缺省值为80
80~100,缺省值为90
CR-SF18E
入风传感器
-15~5,缺省值为-5
28~80,缺省值为70
70~90,缺省值为80
出风传感器
-10~10,缺省值为0
70~90,缺省值为80
80~100,缺省值为90
1号热点传感器
-10~10,缺省值为0
65~85,缺省值为75
75~95,缺省值为85
2号热点传感器
-10~10,缺省值为0
60~80,缺省值为70
70~90,缺省值为80
3号热点传感器
-10~10,缺省值为0
65~85,缺省值为75
75~95,缺省值为85
入风传感器
-20~0,缺省值为-10
28~75,缺省值为65
65~85,缺省值为75
出风传感器
-10~10,缺省值为0
65~85,缺省值为75
75~95,缺省值为85
1号热点传感器
-10~10,缺省值为0
70~90,缺省值为80
80~100,缺省值为90
2号热点传感器
-10~10,缺省值为0
70~90,缺省值为80
80~100,缺省值为90
3号热点传感器
-10~10,缺省值为0
80~100,缺省值为90
90~110,缺省值为100
4号热点传感器
-10~10,缺省值为0
85~105,缺省值为95
95~115,缺省值为105
CR-SPC-CP4RC
入风传感器
-20~0,缺省值为-10
28~70,缺省值为60
60~80,缺省值为70
出风传感器
-10~10,缺省值为0
55~75,缺省值为65
65~85,缺省值为75
1号热点传感器
-10~10,缺省值为0
65~85,缺省值为75
75~95,缺省值为85
2号热点传感器
-10~10,缺省值为0
65~85,缺省值为75
75~95,缺省值为85
3号热点传感器
-10~10,缺省值为0
70~90,缺省值为80
80~100,缺省值为90
# 配置0号单板上入风方向1号温度传感器,低温门限为-10摄氏度,Warning级高温门限为70摄氏度,Alarm级高温门限为100摄氏度。(独立运行模式)
[sysname] temperature-limit slot 0 inflow 1 -10 70 100
# 配置1号成员设备0号单板上入风方向1号温度传感器,低温门限为-10摄氏度,Warning级高温门限为70摄氏度,Alarm级高温门限为100摄氏度。(IRF模式)
[sysname] temperature-limit chassis 1 slot 0 inflow 1 -10 70 100
1.1.69  time at
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
没有为Schedule配置执行时间。
Schedule视图
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time attime oncetime repeating命令时,最新配置生效。
# 配置2015年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
1.1.70  time once
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
没有为Schedule配置执行时间。
Schedule视图
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:MonTueWedThuFriSatSun,&<1-7>表示前面的参数最多可以输入7次。设置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
1.1.71  time repeating
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval-time
undo time
没有配置重复执行Schedule的时间。
Schedule视图
time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
interval interval-time:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
·     使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:MonTueWedThuFriSatSun,&<1-7>表示前面的参数最多可以输入7次。设置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval-time表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
1.1.72  transceiver phony-alarm-disable
transceiver phony-alarm-disable命令用来关闭可插拔模块告警信息开关。
undo transceiver phony-alarm-disable命令用来恢复缺省情况。
可插拔模块告警信息开关处于开启状态。
当设备上插入的光模块的生产或定制厂商不是H3C时,设备会不停打印Trap和Log信息提醒用户,要求用户更换成H3C的光模块,以便管理和维护光模块。而H3C早期销售的光模块,可能没有记录厂商信息,但为了保护用户投资,这样的光模块还需要能继续正常使用。此时,可以关闭可插拔模块告警信息开关,停止输出相关告警信息。
# 关闭可插拔模块告警信息开关。
[Sysname] transceiver phony-alarm-disable
1.1.73  usb disable
usb disable命令用来关闭设备上所有的USB接口。
undo usb disable命令用来打开设备上所有的USB接口。
usb disable
undo usb disable
设备上所有的USB接口处于开启状态。
在执行usb disable命令前,请先使用umount命令卸载所有USB分区,否则命令执行失败。有关umount命令的详细介绍,请参见“基础配置命令参考”中的“文件系统管理”。
用户可通过USB口进行文件的上传和下载。
缺省状态下USB口处于开启状态,用户可根据需要关闭USB口。
# 关闭USB接口,请先umount所有USB分区(以USB存在2个分区为例)。
<Sysname> umount usba0:
<Sysname> umount usba1:
[Sysname] usb disable
# 打开USB接口。
[Sysname] undo usb disable
