H3C S2000-EA系列以太网交换机 命令手册-Release 2211(V1.01)
47-PoE-PoE Profile命令
本章节下载  (158.13 KB)
1 PoE配置命令
1.1  PoE配置命令
1.1.1  display poe interface
display poe interface [ interface-type interface-number ]
interface-type interface-number:端口类型和端口编号。
【描述】
display poe interface命令用来显示端口的供电状态
l              指定interface-type interface-number参数时,该命令用来显示指定端口的供电状态;
l              不带interface-type interface-number参数时,该命令用来显示所有端口的供电状态。
# 显示端口Ethernet1/0/10的供电状态。
<Sysname> display poe interface Ethernet1/0/10
Port power enabled           :enable
Port power ON/OFF            :on
Port power status            :Standard PD was detected
Port power mode              :signal
Port PD class                :0
port power priority          :low
Port max power               :15400 mW
Port current power           :460 mW
Port peak power              :552 mW
Port average power           :547 mW
Port current                 :10 mA
Port voltage                 :51 V
表1-1 display poe interface显示信息描述表
Port power enabled
端口上已开启远程供电功能
Port power ON/OFF
端口电源开启/关闭
Port power status
端口供电状态:
user command set port to off:用户关闭端口供电
Standard PD was detected:检测到一个标准PD
Legacy PD was detected:检测到一个非标准PD
detection is in process:正在检测PD
Port power mode
端口供电方式:
signal:信号线供电方式
Port PD class
端口供电功率等级
Port power priority
端口供电优先级:
critical:最高
high:高
low:低
Port max power
端口最大可用功率
Port current power
端口当前功率
Port average power
端口平均功率
Port peak power
端口峰值功率
Port current
端口当前电流
Port voltage
端口当前电压
# 显示所有端口的供电状态。
       PORT INDEX      POWER ENABLE   MODE  PRIORITY       STATUS
 Ethernet1/0/1          off  disable signal  low      user command set port to off
 Ethernet1/0/2          off  disable signal  low      user command set port to off
 Ethernet1/0/3          off  disable signal  low      user command set port to off
 Ethernet1/0/4          off  disable signal  low      user command set port to off
 Ethernet1/0/5          off  disable signal  low      user command set port to off
 Ethernet1/0/6          off  disable signal  low      user command set port to off
<略>
表1-2 display poe interface显示信息描述表
PORT INDEX
端口索引
POWER
端口电源状态:on/off
ENABLE
端口PoE使能状态:enable/disable
MODE
端口供电方式:
signal:信号线供电方式
spare:空闲线供电方式
PRIORITY
端口供电优先级:
critical:最高
high:高
low:低
STATUS
端口供电状态:
1.1.2  display poe interface power
display poe interface power [ interface-type interface-number ]
【描述】
display poe interface power命令用来显示设备指定端口的供电功率信息。如果不指定端口参数,则显示设备所有端口的供电功率信息。
# 显示端口Ethernet1/0/10的供电功率信息。
<Sysname> display poe interface power Ethernet1/0/10
Port power                   :12400 mW
# 显示所有端口的供电功率信息。
       PORT INDEX       POWER (mW)                PORT INDEX      POWER (mW)
 Ethernet1/0/1           0                  Ethernet1/0/2           0
 Ethernet1/0/3           0                  Ethernet1/0/4           0
 Ethernet1/0/5           0                  Ethernet1/0/6           0
 Ethernet1/0/7           0                  Ethernet1/0/8           0
 Ethernet1/0/9           0                  Ethernet1/0/10          12400
<略>
1.1.3  display poe powersupply
无
【描述】
display poe powersupply命令用来显示PSE电源设备的参数。
# 显示电源设备的参数。
<Sysname> display poe powersupply
Unit 1
PSE ID                      :0
PSE Legacy Detection        :disable
PSE Total Power Consumption :0 mW
PSE Available Power         :370000 mW
PSE Peak Value              :0 mW
PSE Average Value           :0 mW
PSE Software Version        :501
PSE Hardware Version        :000
PSE CPLD Version            :001
PSE Power-Management mode   :auto
表1-3 display poe powersupply显示信息描述表
PSE ID
电源设备号
检测非标准PD使能开关
电源设备当前消耗功率
PSE Available Power
电源设备当前剩余可用功率
Power Peak Value
电源设备峰值消耗功率
Power Average Value
电源设备平均消耗功率
Power Software Version
电源设备软件版本号
Power Hardware Version
电源设备硬件版本号
PSE CPLD Version
电源设备软件序列号
电源设备过载时端口供电管理方式
auto表示采用自动方式,即基于端口供电优先级的供电管理方式
manual表示采用手动的端口供电管理方式
1.1.4  display poe temperature-protection
无
【描述】
display poe temperature-protection命令用来显示设备PoE过温保护功能设置状态。
相关命令可参考poe temperature-protection enable。
# 显示设备PoE过温保护功能设置状态。
<Sysname> display poe temperature-protection
The temperature protection is enabled.
1.1.5  poe enable
poe enable
undo poe enable
以太网端口视图
无
【描述】
poe enable命令用来开启端口远程供电功能。undo poe enable命令用来关闭端口远程供电功能。
缺省情况下,端口的远程供电功能处于关闭状态。
通过命令display poe interface可以查看端口上是否开启PoE功能。
# 开启端口Ethernet1/0/3的远程供电功能。
[Sysname] interface Ethernet 1/0/3
[Sysname-Ethernet1/0/3] poe enable
1.1.6  poe legacy enable
poe legacy enable
undo poe legacy enable
无
【描述】
poe legacy enable命令用来开启PD设备兼容性检测功能。undo poe legacy enable命令用来关闭PD设备兼容性检测功能。
符合IEEE 802.3af协议标准的PD设备为标准PD设备。
缺省情况下,PD设备兼容性检测功能处于关闭状态。
#开启PD设备兼容性检测功能。
[Sysname] poe legacy enable
Legacy detection is enabled
1.1.7  poe max-power
poe max-power max-power
undo poe max-power
以太网端口视图
max-power:为端口分配的最大功率,取值范围100~15400,单位为毫瓦。
【描述】
poe max-power命令用来配置当前端口的最大供电功率。undo poe max-power用来恢复当前端口最大供电功率为缺省值。
缺省情况下,端口的最大供电功率为15400毫瓦。
需要注意的是,设置功率大小的最小调整单位是1毫瓦。考虑到瞬时峰值功率的影响,实际可用的最大功率比设置的要多5%左右的额度。
通过命令display poe interface和display poe interface power可以查看端口上的供电功率信息。
# 配置端口Ethernet1/0/3的最大供电功率为15000毫瓦。
[Sysname-Ethernet1/0/3] poe max-power 15000
1.1.8  poe mode
poe mode { signal | spare }
undo poe mode
以太网端口视图
signal:端口供电方式为采用信号线供电。
spare:端口供电方式为采用空闲线供电。
【描述】
poe mode命令用来配置当前端口供电的方式。undo poe mode用来恢复当前端口供电的方式为缺省值。
缺省情况下,端口采用信号线供电方式。
需要注意的是,当前本系列交换机中的PoE机型暂不支持空闲线供电方式。
# 配置端口Ethernet 1/0/3的供电方式为信号线供电方式。
[Sysname-Ethernet1/0/3] poe mode signal
1.1.9  poe power-management
poe power-management { auto | manual }
undo poe power-management
auto:采用自动方式,即基于端口供电优先级的供电管理方式。
manual:采用手动的端口供电管理方式。
【描述】
poe power-management命令用来配置电源设备过载时,端口供电的管理方式。undo poe power-management命令用来恢复端口供电的管理方式为缺省情况。
缺省情况下,端口供电的管理方式为自动方式。
可以通过命令poe priority设置端口供电优先级。
# 配置端口供电管理方式为自动方式,即基于端口供电优先级。
[Sysname] poe power-management auto
Auto Power Management is enabled
1.1.10  poe priority
poe priority { critical | high | low }
undo poe priority
以太网端口视图
critical:配置端口供电优先级为最高。
high:配置端口供电优先级为高。
low:配置端口供电优先级为低。
【描述】
poe priority命令用来配置端口供电的优先级。undo poe priority命令用来恢复配置端口供电优先级为缺省值。
缺省情况下,端口的供电优先级为low。
端口供电优先级与端口供电管理方式配合使用,用于决策当整机剩余功率过小时,如何为新加入的PD分配PoE供电功率。
(1)        端口供电管理方式为手动方式:
若整机剩余功率小于15W,设备拒绝给新加入的PD设备供电。
(2)        端口供电管理方式为自动方式:
l              若整机剩余功率小于15W,有优先级高的端口插上PD时,要将优先级最低的端口组中端口号最大的端口禁止供电,使优先级低的端口释放一部分功率,供给新加入的PD。
l              若整机剩余功率小于15W,且没有优先级更低的端口,新插上PD的端口不能供电。
# 配置端口Ethernet 1/0/3的供电优先级为最高。
[Sysname-Ethernet1/0/3] poe priority critical
1.1.11  poe temperature-protection
undo poe temperature-protection enable
无
【描述】
poe temperature-protection enable命令用来开启设备PoE过温保护功能。undo poe temperature-protection enable命令用来关闭设备PoE过温保护功能。
PoE过温保护功能是指:
l              当设备内部温度超过65摄氏度时,设备进行自我保护,关闭所有端口的PoE供电功能;
l              当设备内部温度低于60摄氏度时,设备恢复所有端口的PoE供电功能。
缺省情况下,设备PoE过温保护功能处于开启状态。
可以通过命令display poe temperature-protection查看设备的PoE过温保护是否开启。
# 关闭设备PoE过温保护功能。
[Sysname] undo poe temperature-protection enable
The temperature protection is disabled.
1.1.12  poe update
poe update { refresh | full } filename
refresh:电源设备中存在可用的处理软件时使用refresh升级模式。refresh升级模式是在PSE中原有处理软件的基础上对其进行升级更新。
full:电源设备中的处理软件被损坏时使用full升级模式。full升级模式是将PSE中原有损坏处理软件彻底删除,重新装入。
filename:升级文件的名称,长度为1~64个字符,文件扩展名为.s19。
【描述】
poe update命令用来对电源设备的处理软件进行在线升级。
l          full模式的升级方式是在用refresh模式升级出现异常的情况下使用的,其它情况下,请使用refresh模式进行升级。
l          PSE处理软件被损坏的情况下(表现为所有的PoE命令执行不成功),请用full模式进行升级,使软件恢复。
l          如果在PSE处理软件的在线升级过程中因意外而中断(例如发生错误导致设备重启),重启后用full方式升级失败时,请将设备断电重启后再用full方式升级即可成功。升级后再手动重启设备,才能使原来的PoE配置恢复作用。
# 在线升级电源设备的处理软件。
[Sysname] poe update refresh 0400_001.S19
Update PoE  board successfully
2 PoE Profile配置命令
2.1  PoE Profile配置命令
2.1.1  apply poe-profile
系统视图下命令如下:
apply poe-profile profile-name interface interface-type interface-number [ to interface-type interface-number ]
undo apply poe-profile profile-name interface interface-type interface-number [ to interface-type interface-number ]
以太网端口视图下命令如下:
系统视图/以太网端口视图
profile-name:PoE Profile名称,为1~15个字符的字符串,以英文字母[a-z,A-Z]开始,并且不能为保留关键字all、interface、user、undo、mode。
interface-type interface-number:端口类型和端口编号。通过配置该参数可以在系统视图下指定应用该PoE Profile的端口
【描述】
apply poe-profile命令用来在指定的以太网端口上应用已经存在的PoE Profile的配置。undo apply poe-profile命令用来取消应用在指定以太网端口上的PoE Profile配置。
每个以太网端口上只能应用一个PoE Profile。
PoE Profile是一组配置的集合,一个PoE Profile中可以设置多个PoE特性。使用apply poe-profile命令将PoE Profile应用到端口时,有些配置可以成功应用,有些配置不能成功应用。在本系列交换机中的PoE机型上应用PoE Profile配置时遵循如下规则:
l          使用apply poe-profile命令将PoE Profile应用到某端口时,只要PoE Profile中有一个PoE特性被正确应用,则应用PoE Profile的操作成功。使用display current-configuration命令查询时就会显示此PoE Profile被该端口正确应用。
l          若PoE Profile中有一个或多个PoE特性未被端口正确应用,则设备会明确的提示该PoE Profile中哪个PoE特性在哪个端口上未被正确应用。
l          使用display current-configuration命令查询时可以显示端口应用了哪个PoE Profile,但是不能显示PoE Profile下的哪些PoE特性应用成功。
# 将已存在的PoE Profile(profile-test)的配置,应用到设备以太网端口Ethernet1/0/1~Ethernet1/0/9上。
[Sysname] apply poe-profile profile-test interface Ethernet1/0/1 to Ethernet1/0/9
2.1.2  display poe-profile
display poe-profile { all-profile | interface interface-type interface-number | name profile-name }
all-profile:显示所有的PoE Profile。
profile-name:显示指定名字的PoE profile。
【描述】
display poe-profile命令用来显示设备上已经创建的PoE Profile的详细配置信息。
# 显示名称为profile-test的PoE Profile的详细配置信息。
[Sysname] display poe-profile name profile-test
Poe-profile: profile-test, 3 action
poe enable
poe max-power 5000
2.1.3  poe-profile
undo poe-profile profile-name
【描述】
poe-profile命令用来创建一个PoE Profile并进入其视图(若该PoE Profile已创建,则直接进入其视图)。undo poe-profile命令用来删除已经创建的PoE Profile。
在PoE Profile模式下可以配置PoE的下列特性:
poe enable
本系列交换机中的PoE机型上最多可配100个PoE Profile。
# 创建一个名称为profile-test的PoE Profile。
[Sysname] poe-profile profile-test
