42-附录
本章节下载 (208.21 KB)
# A B C D E F G H I L M N O P Q R S T U V W X Z
| 缩略语 | 英语解释 | 中文解释 |
| A Return | ||
| AAL5 | ATM Adaptation Layer 5 | ATM适配层5 |
| ABR | Area Border Router | 区域边界路由器 |
| AC | Access Controller | 接入控制器 |
| AC | Access Category | 接入类 |
| ACCM | Async-Control-Character-Map | 异步控制字符映射表 |
| ACFC | Address-and-Control-Field-Compression | 地址控制字段压缩 |
| ACFP | Application Control Forwarding Protocol | 应用控制转发协议 |
| ACL | Access Control List | 访问控制列表 |
| ACS | Auto-Configuration Server | 自动配置服务器 |
| AD | Active Directory | 活动目录 |
| ADPCM | Adaptive Differential Pulse Code Modulation | 自适应差分脉冲编码调制 |
| ADSL | Asymmetric Digital Subscriber Line | 不对称数字用户线 |
| AES | Advanced Encryption Standard | 高级加密标准 |
| AFT | Address Family Translation | 地址族转换 |
| AFTR | Address Family Transition Router | 地址族转换路由器 |
| AH | Authentication Header | 认证头 |
| AIFSN | Arbitration Inter Frame Spacing Number | 仲裁帧间隙数 |
| AIS | Alarm Indication Signal | 告警指示信号 |
| ALG | Application Level Gateway | 应用层网关 |
| AM | Analog Modem | 模拟调制解调器 |
| AMI | Alternate Mark Inversion | 交替传号反转 |
| ANSI | American National Standard Institute | 美国国家标准协会 |
| AP | Access Point | 接入点 |
| APP | Application Protocol | 应用协议 |
| APPN | Advanced Peer-to-Peer Networking | 高级对等网络 |
| ARP | Address Resolution Protocol | 地址解析协议 |
| AS | Autonomous System | 自治系统 |
| AS | Authentication Server | 认证服务器 |
| ASBR | Autonomous System Boundary Router | 自治系统边界路由器 |
| ASM | Any-Source Multicast | 任意信源组播 |
| ASPF | Application Specific Packet Filter | 基于应用层状态的包过滤 |
| ATD | Attribute Discovery | 属性发现 |
| ATM | Asynchronous Transfer Mode | 异步传输模式 |
| AU | Administration Unit | 管理单元 |
| AV | Anti-Virus | 防病毒 |
| AVF | Active Virtual Forwarder | 处于Active状态的虚拟转发器 |
| AVP | Attribute Value Pair | 属性值对 |
| B Return | ||
| B8ZS | Bipolar 8 zeros substitution | 双极性8zero替换码 |
| BAS | Broadband Access Server | 宽带接入服务器 |
| BC | Boundary Clock | 边界时钟 |
| BC | Bandwidth Constraint | 带宽约束 |
| BCB | Backbone Core Bridge | 骨干网核心网桥 |
| BDI | Backward Defect Indication | 反向缺陷通告 |
| BDR | Backup Designated Router | 备份指定路由器 |
| BEB | Backbone Edge Bridge | 骨干网边缘网桥 |
| BFD | Bidirectional Forwarding Detection | 双向转发检测 |
| BGP | Border Gateway Protocol | 边界网关协议 |
| BIMS | Branch Intelligent Management System | 分支网点智能管理系统 |
| B-MAC | Backbone MAC | 骨干网MAC |
| BMC | Best Master Clock | 最佳主时钟 |
| BOOTP | Bootstrap Protocol | 自举协议 |
| BPDU | Bridge Protocol Data Unit | 桥协议数据单元 |
| BQ | Bandwidth Queuing | 带宽队列 |
| BSB | Blockade State Block | 阻塞状态块 |
| BSR | Bootstrap Router | 自举路由器 |
| BSS | Basic Service Set | 基本服务集 |
| BT | BitTorrent | 比特洪流 |
| B-VLAN | Backbone VLAN | 骨干网VLAN |
| C Return | ||
| CA | Certificate Authority | 证书颁发机构 |
| CAC | Connect Admission Control | 连接准入控制 |
| CAMS | Comprehensive Access Management Server | 综合访问管理服务器 |
| CAPWAP | Controlling and Provisioning of Wireless Access Point | 无线接入点控制与供应 |
| CAR | Committed Access Rate | 承诺访问速率 |
| CBQ | Class Based Queuing | 基于类的队列 |
| CBR | Constant Bit Rate | 确定比特率 |
| CBS | Committed Burst Size | 承诺突发尺寸 |
| C-BSR | Candidate-BSR | 候选BSR |
| CBT | Core-Based Tree | 有核树 |
| CBWFQ | Class Based Weighted Fair Queuing | 基于类的加权公平队列 |
| CC | Continuity Check | 连续性检测 |
| CCC | Circuit Cross Connect | 电路交叉连接 |
| CCM | Continuity Check Message | 连续性检测报文 |
| CDP | Cisco Discovery Protocol | 思科发现协议 |
| CE | Customer Edge | 用户边缘 |
| CEE | Converged Enhanced Ethernet | 汇聚增强型以太网 |
| CEM Class | Circuit Emulation Class | 电路仿真类 |
| CESOPSN | Circuit Emulation Services over PSN | 分组交换网络上传输电路仿真服务 |
| CFD | Connectivity Fault Detection | 连通错误检测 |
| CFI | Canonical Format Indicator | 标准格式指示位 |
| CFM | Connectivity Fault Management | 连通错误管理 |
| CHAP | Challenge Handshake Authentication Protocol | 质询握手验证协议 |
| CIDR | Classless Inter-Domain Routing | 无类域间路由 |
| CIR | Committed Information Rate | 承诺信息速率 |
| CIST | Common and Internal Spanning Tree | 公共和内部生成树 |
| CO | Central Office | 中心局 |
| COPS | Common Open Policy Service | 公共开放策略服务 |
| CPE | Customer Premises Equipment | 用户侧设备 |
| CPS | Certification Practice Statement | 证书惯例声明 |
| CPTone | Call Progress Tone | 呼叫进程音 |
| CR | Constraint-based Routing | 基于约束的路由 |
| CRC4 | Cyclic Redundancy Check 4 | 4阶循环冗余校验 |
| CRL | Certificate Revocation List | 证书废除列表 |
| CR-LDP | Constraint-based Routed Label Distribution Protocol | 基于约束路由的LDP |
| CR-LSP | Constraint-based Routed Label Switched Paths | 基于约束路由的LSP |
| C-RP | Candidate-RP | 候选RP |
| CSNP | Complete SNP | 全时序报文 |
| CSPF | Constraint-based Shortest Path First | 基于约束的最短路径优先 |
| CST | Common Spanning Tree | 公共生成树 |
| CT | Class Type | 服务类型 |
| CTR | Counter mode | 计数器模式 |
| CV | Connectivity Verification | 连通性检测 |
| CWMP | CPE WAN Management Protocol | CPE广域网管理协议 |
| D Return | ||
| DAD | Duplicate Address Detection | 重复地址检测 |
| DAR | Deeper Application Recognition | 深度应用识别 |
| DCBX | Data Center Bridging Exchange Protocol | 数据中心桥能力交换协议 |
| DCC | Dial Control Center | 拨号控制中心 |
| DCE | Date Center Ethernet | 数据中心以太网 |
| DCE | Data Circuit-terminating Equipment | 数据电路终接设备 |
| DCF | Distributed Coordination Function | 分布式协调功能 |
| DD | Database Description | 数据库描述 |
| DDN | Digital Data Network | 数字数据网 |
| DDNS | Dynamic Domain Name System | 动态域名系统 |
| DDoS | Distributed Denial of Service | 分布式拒绝服务 |
| DER | Distinguished Encoding Rules | 特异编码规则 |
| DF | Designated Forwarder | 指定转发者 |
| DH | Diffie-Hellman | 交换及密钥分发 |
| DHCP | Dynamic Host Configuration Protocol | 动态主机配置协议 |
| DHCPv6 | Dynamic Host Configuration Protocol for IPv6 | 支持IPv6的动态主机配置协议 |
| DiffServ | Differentiated Service | 区分业务模型 |
| DLCI | Data Link Connection Identifier | 数据链路关联标识符 |
| DLDP | Device Link Detection Protocol | 设备链路检测协议 |
| DLSw | Data Link Switching | 数据链路交换 |
| DM | Dense Mode | 密集模式 |
| DM | Delay Measurement | 延时测量 |
| DMM | Delay Measurement Message | 时延测量报文 |
| DMR | Delay Measurement Reply | 时延测量应答 |
| DMZ | Demilitarized Zone | 非军事区 |
| DN | Distinguished Name | 识别名 |
| DNAT | Destination NAT | 目的地址NAT |
| DNS | Domain Name System | 域名系统 |
| DoD | Downstream On Demand | 下游按需方式 |
| DoS | Denial of Service | 拒绝服务 |
| DPD | Dead Peer Detection | 对等体存活检测 |
| DR | Designated Router | 指定路由器 |
| DS | Differentiated Services | 差分服务 |
| DSA | Digital Signature Algorithm | 数字签名算法 |
| DSCP | Differentiated Services Codepoint | 差分服务编码点 |
| DS-lite | Dual Stack Lite | 轻量级双协议栈 |
| DTE | Data Terminal Equipment | 数据终端设备 |
| DTMF | Dual Tone Multi-Frequency | 双音多频 |
| DU | Downstream Unsolicited | 下游自主方式 |
| DUID | DHCP Unique Identifier | DHCP唯一标识符 |
| DUID-LL | DUID Based on Link-layer Address | 基于链路层地址的DUID |
| DVMRP | Distance Vector Multicast Routing Protocol | 距离矢量组播路由协议 |
| DVPN | Dynamic Virtual Private Network | 动态虚拟私有网络 |
| DWDM | Dense Wavelength Division Multiplexing | 密级波分复用 |
| E Return | ||
| E2ETC | End-to-End Transparent Clock | 端到端透明时钟 |
| EACL | Enhanced ACL | 增强型ACL |
| EAD | Endpoint Admission Defense | 端点准入防御 |
| EAIS | Ethernet Alarm Indication Signal | 以太网告警指示信号 |
| EAP | Extensible Authentication Protocol | 可扩展认证协议 |
| EAPOL | Extensible Authentication Protocol over LAN | 局域网上的可扩展认证协议 |
| EBS | Excess Burst Size | 超出突发尺寸 |
| ECDSA | Elliptic Curve Digital Signature Algorithm | 椭圆曲线数字签名算法 |
| ECM | Error Correction Mode | 误码纠错模式 |
| ECWmax | Exponent form of CWmax | 最大竞争窗口指数形式 |
| ECWmin | Exponent form of CWmin | 最小竞争窗口指数形式 |
| EDCA | Enhanced Distributed Channel Access | 增强的分布式信道访问 |
| EGP | Exterior Gateway Protocol | 外部网关协议 |
| End-Of-RIB | End of Routing-Information-Base | 路由信息库结束 |
| ENUM | Telephone Number Mapping | 电话号码映射 |
| ERT | Export Route-target | 引出路由标识 |
| ESF | Extended Super Frame | 扩展超帧 |
| ESP | Encapsulating Security Payload | 封装安全载荷 |
| ESS | Extended Service Set | 扩展服务集 |
| ETS | Enhanced Transmission Selection | 增强传输选择 |
| ETSI | European Telecommunications Standards Institute | 欧洲电信标准协会 |
| F Return | ||
| FC | Fibre Channel | 光纤通道 |
| FCoE | Fibre Channel over Ethernet | 以太网光纤通道 |
| FEC | Forwarding Equivalence Class | 转发等价类 |
| FFD | Fast Failure Detection | 快速缺陷检测 |
| FIB | Forwarding Information Base | 转发信息库 |
| FIFO | First In First Out | 先入先出 |
| FIP | FCoE Initialization Protocol | FCoE初始化协议 |
| FQDN | Fully Qualified Domain Name | 完全合格域名 |
| FRR | Fast Reroute | 快速重路由 |
| FSK | Frequency Shift Keying | 频移键控 |
| FTN | FEC to NHLFE map | FEC到NHLFE表项的映射 |
| FTP | File Transfer Protocol | 文件传输协议 |
| G Return | ||
| GARP | Generic Attribute Registration Protocol | 通用属性注册协议 |
| GBIC | Gigabit Interface Converter | 千兆以太网接口转换器 |
| GI | Guard Interval | 保护间隔 |
| GNS | Get Nearest Server | 请求最近的服务器 |
| GPS | Global Positioning System | 全球定位系统 |
| GR | Graceful Restart | 平滑重启 |
| GRE | Generic Routing Encapsulation | 通用路由封装 |
| GTK | Group Temporal Key | 群组临时密钥 |
| GTP | GPRS Tunneling Protocol | GPRS隧道协议 |
| GTS | Generic Traffic Shaping | 通用流量整形 |
| GTSM | Generalized TTL Security Mechanism | 通用TTL安全保护机制 |
| GVRP | GARP VLAN Registration Protocol | GARP VLAN注册协议 |
| H Return | ||
| HABP | HW Bypass Protocol | HW旁路认证协议 |
| HDB3 | High-density Bipolar 3 | 3阶高密度双极性码 |
| HDLC | High-level Data Link Control | 高级数据链路控制 |
| HGMP | HW Group Management Protocol | HW组管理协议 |
| HGMPv2 | HW Group Management Protocol version 2 | HW组管理协议版本2 |
| HQoS | Hierarchical Quality of Service | 分层QoS |
| HTTP | Hypertext Transfer Protocol | 超文本传输协议 |
| HTTPS | Hypertext Transfer Protocol Secure | 超文本传输协议的安全版本 |
| H-VPLS | Hierarchy of VPLS | 分层VPLS |
| HWTACACS | HW Terminal Access Controller Access Control System | HW终端访问控制器控制系统协议 |
| I Return | ||
| IA | Identity Association | 标识联盟 |
| IACTP | Inter Access Controller Tunneling Protocol | 接入控制器间隧道协议 |
| IAD | Integrated Access Device | 综合接入设备 |
| IANA | Internet Assigned Numbers Authority | 互联网编号分配委员会 |
| IBGP | Internal Border Gateway Protocol | 内部边界网关协议 |
| ICMP | Internet Control Message Protocol | 互联网控制报文协议 |
| ICMPv6 | Internet Control Message Protocol for IPv6 | IPv6互联网控制消息协议 |
| ICPIF | Calculated Planning Impairment Factor | 计算计划损伤元素 |
| ID | Direct Inward Dialing | 直接内部呼叫 |
| IDS | Intrusion Detection System | 入侵检测系统 |
| IE | Information Element | 信息元素 |
| IEEE | Institute of Electrical and Electronics Engineers | 电气和电子工程师学会 |
| IETF | Internet Engineering Task Force | 互联网工程任务组 |
| IGMP | Internet Group Management Protocol | 互联网组管理协议 |
| IGMP Snooping | Internet Group Management Protocol Snooping | 互联网组管理协议窥探 |
| IGP | Interior Gateway Protocol | 内部网关协议 |
| IKE | Internet Key Exchange | 互联网密钥交换 |
| ILM | Incoming Label Map | 入标签映射 |
| ILS | Internet Locator Service | 互联网定位服务 |
| IM | Instant Messaging | 即时消息服务 |
| IMA | Inverse Multiplexing for ATM | ATM反向复用 |
| IMSI | International Mobile Subscriber Identification Number | 国际移动用户标识 |
| InARP | Inverse Address Resolution Protocol | 逆向地址解析协议 |
| IntServ | Integrated Service | 综合业务模型 |
| IPC | Inter-process Communication | 进程间通信 |
| IPHC | IP Header Compression | IP报文头压缩 |
| IPng | IP Next Generation | 下一代互联网 |
| IPS | Intrusion Prevention System | 入侵防御系统 |
| IPsec | IP Security | IP安全 |
| IPTA | IP Terminal Access | IP终端接入 |
| IPv6 | Internet Protocol Version 6 | 互联网协议版本6 |
| IPX | Internetwork Packet Exchange | 网际报文交换 |
| IRDP | ICMP Router Discovery Protocol | ICMP路由器发现协议 |
| IRF | Intelligent Resilient Framework | 智能弹性架构 |
| ISAKMP | Internet Security Association and Key Management Protocol | 互联网安全联盟和密钥管理协议 |
| ISATAP | Intra-Site Automatic Tunnel Addressing Protocol | 站点内自动隧道寻址协议 |
| ISDN | Integrated Services Digital Network | 综合业务数字网 |
| I-SID | Backbone Service Instance Identifier | 骨干网服务实例编号 |
| IS-IS | Intermediate System-to-Intermediate System | 中间系统到中间系统 |
| ISP | Internet Service Provider | 互联网服务提供商 |
| ISPF | Incremental Shortest Path First | 增量最短路径优先 |
| ISSU | In-Service Software Upgrade | 不中断业务升级 |
| IST | Internal Spanning Tree | 内部生成树 |
| ITSP | Internet Telephone Service Provider | 互联网电话运营商 |
| IVR | Interactive Voice Response | 交互式语音应答 |
| L Return | ||
| L2F | Layer 2 Forwarding | 二层转发 |
| L2TP | Layer 2 Tunneling Protocol | 二层隧道协议 |
| LAC | L2TP Access Concentrator | L2TP访问集中器 |
| LACP | Link Aggregation Control Protocol | 链路聚合控制协议 |
| LACPDU | Link Aggregation Control Protocol Data Unit | 链路聚合控制协议数据单元 |
| LAN | Local Area Network | 局域网 |
| LB | Load Balance | 负载均衡 |
| LBM | Loopback Message | 环回报文 |
| LBR | Loopback Reply | 环回应答 |
| LC | Logic Channel | 逻辑信道 |
| LCI | Logic Channel Identifier | 逻辑信道号 |
| LCP | Link Control Protocol | 链路控制协议 |
| LDAP | Lightweight Directory Access Protocol | 轻量级目录访问协议 |
| LDP | Label Distribution Protocol | 标签分发协议 |
| LER | Label Edge Router | 标签边缘路由器 |
| LFI | Link Fragmentation and Interleaving | 链路分片与交叉 |
| LFIB | Label Forwarding Information Base | 标签转发表 |
| LLDP | Link Layer Discovery Protocol | 链路层发现协议 |
| LLDPDU | Link Layer Discovery Protocol Data Unit | 链路层发现协议数据单元 |
| LLDP-MED | Media Endpoint Discovery | 媒体终端发现 |
| LLQ | Low Latency Queuing | 低延迟队列 |
| LM | Loss Measurement | 丢包测量 |
| LMI | Local Management Interface | 本地管理接口 |
| LMM | Loss Measurement Message | 丢包测量报文 |
| LMR | Loss Measurement Reply | 丢包测量应答 |
| LNS | L2TP Network Server | L2TP网络服务器 |
| LOCV | Loss of Connectivity Verification defect | 连通性检测缺陷 |
| LR | Line Rate | 物理接口限速 |
| LSA | Link State Advertisement | 链路状态通告 |
| LSAck | Link State Acknowledgment | 链路状态确认 |
| LSDB | Link State Database | 链路状态数据库 |
| LSP | Label Switched Path | 标签交换路径 |
| LSR | Link State Request | 链路状态请求 |
| LSR | Label Switching Router | 标签交换路由器 |
| LSU | Link State Update | 链路状态更新 |
| LTM | Linktrace Message | 链路跟踪报文 |
| LTR | Linktrace Reply | 链路跟踪应答 |
| LVF | Listening Virtual Forwarder | 处于Listening状态的虚拟转发器 |
| M Return | ||
| MA | Maintenance Association | 维护集 |
| MAC | Media Access Control | 媒体访问控制 |
| MAC | Message Authentication Code | 消息验证码 |
| MAD | Multi-Active Detection | 多Active检测 |
| MAM | Maximum Allocation Model | 最大分配模型 |
| MAN | Metropolitan Area Network | 城域网 |
| MBGP | Multicast BGP | 组播BGP |
| MCE | Multi-VPN-instance Customer Edge | 多实例用户网络边界设备 |
| MCS | Modulation and Coding Scheme | 调制与编码策略 |
| MD | Maintenance Domain | 维护域 |
| MD | Multicast Domain | 组播域 |
| MDI | Medium Dependent Interface | 介质相关接口 |
| MEP | Maintenance association End Point | 维护端点 |
| MIB | Management Information Base | 管理信息库 |
| MIC | Message Integrity Check | 信息完整性校验 |
| MIP | Maintenance association Intermediate Point | 维护中间点 |
| MLD | Multicast Listener Discovery Protocol | 组播侦听者发现协议 |
| MLD Snooping | Multicast Listener Discovery Snooping | 组播侦听者发现协议窥探 |
| MLSP | Mobile Link Switch Protocol | 移动链路切换协议 |
| MOS | Mean Opinion Scores | 平均意见得分 |
| MP | Maintenance Point | 维护点 |
| MP-BGP | Multiprotocol Border Gateway Protocol | 多协议边界网关协议 |
| MPLS | Multiprotocol Label Switching | 多协议标签交换 |
| MPLS TE | Multiprotocol Label Switching Traffic Engineering | 多协议标记交换流量工程 |
| MPLS-TP | MPLS Transport Profile | MPLS传输技术架构 |
| MSDP | Multicast Source Discovery Protocol | 组播源发现协议 |
| MSTI | Multiple Spanning Tree Instance | 多生成树实例 |
| MSTP | Multiple Spanning Tree Protocol | 多生成树协议 |
| MTBF | Mean Time Between Failures | 平均故障间隔时间 |
| MTR | Multi-Topology Routing | 多拓扑路由 |
| MTTR | Mean Time to Repair | 平均修复时间 |
| MTU | Maximum Transmission Unit | 最大传输单元 |
| MU | Mobile Unit | 移动设备 |
| N Return | ||
| NAPT | Network Address Port Translation | 网络地址端口转换 |
| NAPT-PT | Network Address Port Translation-Protocol Translation | 附带协议转换的网络地址端口转换 |
| NAS | Network Access Server | 网络接入服务器 |
| NAT | Network Address Translation | 网络地址转换 |
| NAT-PT | Network Address Translation-Protocol Translation | 附带协议转换的网络地址转换 |
| NBMA | Non-Broadcast Multi-Access | 非广播多路访问 |
| NCP | Network Control Protocol | 网络控制协议 |
| ND | Neighbor Discovery | 邻居发现 |
| NDA | NetStream Data Analyzer | 网络流数据分析 |
| NDE | NetStream Data Exporter | 网络流数据输出 |
| NDP | Neighbor Discover Protocol | 邻居发现协议 |
| NET | Network Entity Title | 网络实体名称 |
| NETCONF | Network Configuration Protocol | 网络配置协议 |
| NHLFE | Next Hop Label Forwarding Entry | 下一跳标签转发项 |
| NLPID | Network Layer Protocol Identifier | 网络层协议标识符 |
| NLRI | Network Layer Reachability Information | 网络层可达性信息 |
| NMS | Network Management System | 网络管理系统 |
| NNI | Network-to-Network Interface | 网间网接口 |
| NQA | Network Quality Analyzer | 网络质量分析 |
| nrt_VBR | Nonreal-time Variable Bit Rate | 非实时可变比特率 |
| NSC | NetStream Collector | 网络流数据收集 |
| NSF | Non-Standard Facilities | 非标准能力 |
| NSR | Nonstop Routing | 不间断路由 |
| NTDP | Neighbor Topology Discover Protocol | 邻居拓扑发现协议 |
| NTP | Network Time Protocol | 网络时间协议 |
| O Return | ||
| OAA | Open Application Architecture | 开放应用架构 |
| OAMPDU | OAM Protocol Data Units | OAM协议数据单元 |
| OAP | Open Application Platform | 开放应用平台 |
| OC | Optical Carrier | 光载波 |
| OC | Ordinary Clock | 普通时钟 |
| OID | Object Identifier | 对象标识符 |
| ORF | Outbound Route Filtering | 输出路由过滤 |
| OSPF | Open Shortest Path First | 开放最短路径优先 |
| OUI | Organizationally Unique Identifier | 全球统一标识符 |
| P Return | ||
| P2MP | Point-to-MultiPoint | 点到多点 |
| P2P | Point-to-Point | 点到点 |
| P2P | Peer-to-Peer | 对等 |
| P2P | PW to PW | PW到PW |
| P2P | Point to Point | 点到点 |
| P2PTC | Peer-to-Peer Transparent Clock | 点到点透明时钟 |
| PAGP | Port Aggregation Protocol | 端口聚合协议 |
| PAM | Port to Application Map | 应用协议端口映射 |
| PAP | Password Authentication Protocol | 密码验证协议 |
| PAT | Port Address Translation | 端口地址转换 |
| PBB | Provider Backbone Bridge | 运营商骨干网桥 |
| PBBN | Provider Backbone Bridge Network | 运营商骨干桥接网 |
| PBN | Provider Bridge Network | 运营商桥接网 |
| PCM | Pulse Code Modulation | 脉冲编码调制 |
| PCR | Peak Cell Rate | 峰值信元速率 |
| PD | Powered Device | 受电设备 |
| PD | Prefix Delegation | 前缀授权 |
| PDH | Plesiochronous Digital Hierarchy | 准同步数字体系 |
| PDP | Policy Decision Point | 策略决策者 |
| PDU | Protocol Data Unit | 协议数据单元 |
| PE | Provider Edge | 服务提供商网络边缘 |
| PE-agg | PE Aggregation | 聚合PE |
| PEAP-GTC | Protected Extensible Authentication Protocol-Microsoft Generic Token Card | 受保护的扩展认证协议-通用令牌卡 |
| PEAP-MSCHAPv2 | Protected Extensible Authentication Protocol-Microsoft Challenge Handshake Authentication Protocol v2 | 受保护的扩展认证协议-Microsoft质询握手身份验证协议版本2 |
| PEP | Policy Enforcement Point | 策略执行者 |
| PFC | Protocol-Field-Compression | 协议字段压缩 |
| PFC | Priority-based Flow Control | 基于优先级的流量控制 |
| PFS | Perfect Forward Secrecy | 完善的前向安全性 |
| PHP | Penultimate Hop Popping | 倒数第二跳弹出 |
| PI | Power Interface | 电源接口 |
| PIM | Protocol Independent Multicast | 协议无关组播 |
| PIM Snooping | Protocol Independent Multicast Snooping | 协议无关组播窥探 |
| PKCS | Public Key Cryptography Standards | 公共密钥加密标准 |
| PKI | Public Key Infrastructure | 公钥基础设施 |
| PMK | Pairwise Master Key | 成对主密钥 |
| PMTU | Path MTU | 路径MTU |
| PoE | Power over Ethernet | 以太网供电 |
| POH | Path Overhead | 通道开销字节 |
| POP3 | Post Office Protocol, Version 3 | 邮局协议的第3个版本 |
| POS | Point of Sale | 销售点 |
| PPP | Point-to-Point Protocol | 点到点协议 |
| PPPoE | Point-to-Point Protocol over Ethernet | 点到点以太网承载协议 |
| PPTP | Point-to-Point Tunneling Protocol | 点到点隧道协议 |
| PRL | Preferred Roming List | 优先漫游列表 |
| PS | Protection Switching | 保护倒换 |
| PSB | Path State Block | 路径状态块 |
| PSC | Protection State Coordination | 保护状态调整 |
| PSE | Power Sourcing Equipment | 供电设备 |
| PSK | Pre-Shared Key | 预共享密钥 |
| PSNP | Partial SNP | 部分时序报文 |
| PSTN | Public Switched Telephone Network | 公共电话交换网 |
| PTP | Precision Time Protocol | 精确时间协议 |
| PTY | Pseudo-Terminals | 伪终端 |
| PVC | Permanent Virtual Circuit | 永久虚电路 |
| PVST | Per VLAN Spanning Tree | 每VLAN生成树 |
| PXE | Preboot eXecution Environment | 预启动执行环境 |
| Q Return | ||
| QoS | Quality of Service | 服务质量 |
| QPPB | QoS Policy Propagation Through the Border Gateway Protocol | 通过BGP传播QoS策略 |
| R Return | ||
| RA | Router Advertisement | 路由器通告 |
| RA | Registration Authority | 注册机构 |
| RADIUS | Remote Authentication Dial-In User Service | 远程认证拨号用户服务 |
| RD | Route Distinguisher | 路由标识符 |
| RDI | Remote Defect Indication | 远程故障指示 |
| RDM | Russian Dolls Model | 俄罗斯套娃模型 |
| RED | Random Early Detection | 随机早期检测 |
| RFID | Radio Frequency Identification | 射频识别 |
| RIP | Routing Information Protocol | 路由信息协议 |
| RIP-2 | Routing Information Protocol version 2 | 路由信息协议版本2 |
| RLSN | Remote Link Status Notification | 远程链路状态通告 |
| RMON | Remote Network Monitoring | 远程网络监视 |
| RP | Rendezvous Point | 汇集点 |
| RPA | Rendezvous Point Address | 汇集点地址 |
| RPF | Reverse Path Forwarding | 逆向路径转发 |
| RPL | Rendezvous Point Link | 汇集点链路 |
| RPR | Resilient Packet Ring | 弹性分组环 |
| RPT | Rendezvous Point Tree | 共享树 |
| RR | Router Renumber | 路由器重编号 |
| RRPP | Rapid Ring Protection Protocol | 快速环网保护协议 |
| RS | Router Solicitation | 路由器请求 |
| RSB | Reservation State Block | 预留状态块 |
| RSH | Remote Shell | 远程外壳 |
| RSN | Robust Security Network | 健壮安全网络 |
| RSNA | Robust Security Network Association | 健壮安全网络连接 |
| RSTP | Rapid Spanning Tree Protocol | 快速生成树协议 |
| RSVP | Resource Reservation Protocol | 资源预留协议 |
| rt_VBR | Real-time Variable Bit Rate | 实时可变比特率 |
| RTC | Remote Terminal Connection | 远程终端连接 |
| RTCP | Real-Time Transport Control Protocol | 实时传输控制协议 |
| RTP | Real-Time Transport Protocol | 实时传输协议 |
| RTS | Request to Send | 发送请求 |
| RTSP | Real Time Streaming Protocol | 实时流协议 |
| S Return | ||
| SA | Security Association | 安全联盟 |
| SA | Source Active | 信源有效 |
| SABM | Set Asynchronous Balanced Mode | 置异步平衡模式 |
| SAN | Storage Area Networks | 存储网络 |
| SAP | Service Advertising Protocol | 服务公告协议 |
| SATOP | Structure-Agnostic TDM over Packet | 分组网络上传输非结构化的TDM数据 |
| SAVI | Source Address Validation | 源地址有效性验证 |
| SBM | Subnetwork Bandwidth Management | 子网带宽管理 |
| SCCP | Skinny Client Control Protocol | 瘦小客户端控制协议 |
| SCEP | Simple Certificate Enrollment Protocol | 简单证书注册协议 |
| SCFF | Single Choke Fairness Frame | 公平算法帧 |
| SDH | Synchronous Digital Hierarchy | 同步数字系列 |
| SDLC | Synchronous Data Link Control | 同步数据链路控制 |
| SDP | Session Description Protocol | 会话描述协议 |
| SDU | Service Data Unit | 协议数据单元 |
| SF | Super Frame | 超帧 |
| sFlow | Sampled Flow | 采样流 |
| SFM | Source-Filtered Multicast | 信源过滤组播 |
| SFP | Small Form-factor Pluggable | 小封装可热插拔 |
| SFTP | Secure FTP | 安全的FTP |
| SIP | Session Initiation Protocol | 会话初始协议 |
| SIPS | SIP secure | 安全SIP |
| SLA | Service Level Agreement | 服务等级协定 |
| SLAAC-Only | Stateless Address Autoconfiguration | 无状态地址自动配置 |
| SLIP | Serial Line Internet Protocol | 串行线路互联网协议 |
| SM | Sparse Mode | 稀疏模式 |
| SMTP | Simple Mail Transfer Protocol | 简单邮件传输协议 |
| SNA | System Network Architecture | 系统网络结构体系 |
| SNAP | Subnetwork Access Protocol | 子网访问协议 |
| SNMP | Simple Network Management Protocol | 简单网络管理协议 |
| SNPA | Subnetwork Point of Attachment | 子网连接点 |
| SNR | Signal-to-Noise Ratio | 信噪比 |
| SONET | Synchronous Optical Network | 同步光网络 |
| SOO | Site of Origin | 路由源 |
| SP | Service Provider | 服务提供商 |
| SP | Strict Priority | 严格优先级 |
| SPCS | Stored Program Control Switching System | 程控交换机 |
| SPE | Superstratum PE or Sevice Provider-end PE | 上层PE或运营商侧PE |
| SPF | Shortest Path First | 最短路径优先 |
| SPI | Security Parameter Index | 安全参数索引 |
| SPID | Service Profile Identification | 业务轮廓标识 |
| SPT | Shortest Path Tree | 最短路径树 |
| SQL | Structured Query Language | 结构化查询语言 |
| SRTP | Secure Real-time Transport Protocol | 安全RTP协议 |
| SSH | Secure Shell | 安全外壳 |
| SSID | Service Set Identifier | 服务集标识符 |
| SSL | Secure Sockets Layer | 安全套接字层 |
| SSM | Source-Specific Multicast | 指定信源组播 |
| SSM | Synchronization Status Marker | 同步状态信息 |
| SSP | Switch-to-Switch Protocol | 交换机到交换机协议 |
| ST | Shared Tree | 共享树 |
| STP | Spanning Tree Protocol | 生成树协议 |
| SVC | Static Virtual Circuit | 静态虚拟电路 |
| SVC | Switched Virtual Circuit | 交换虚电路 |
| SVP | Spectralink Voice Priority | Spectralink语音优先级 |
| T Return | ||
| TA | Terminal Adapter | 终端适配器 |
| TC | Topology Checksum | 拓扑校验和 |
| TC | Transparent Clock | 透明时钟 |
| TCI | Tag Control Information | 标签控制信息 |
| TCN BPDU | Topology Change Notification BPDU | 拓扑变化通知BPDU |
| TDM | Time Division Multiplexing | 时分复用 |
| TE | Traffic Engineering | 流量工程 |
| TEDB | TE DataBase | 流量工程数据库 |
| TFTP | Trivial File Transfer Protocol | 简单文件传输协议 |
| TLS | Transport Layer Security | 传输层安全 |
| TLS | Transparent LAN Service | 透明局域网服务 |
| ToS | Type of Service | 服务类型 |
| TP | Topology Protection | 拓扑保护 |
| TPDU | Transport Protocol Data Unit | 传输协议数据单元 |
| TPID | Tag Protocol Identifier | 标签协议标识符 |
| TRIP | Triggered RIP | 触发路由信息协议 |
| TS | Traffic Shaping | 流量整形 |
| TST | Test | 比特错误测试 |
| TTL | Time to Live | 生存时间 |
| TTY | True Type Terminal | 实体类型终端 |
| TU | Tributary Unit | 支路单元 |
| TXOPLimit | Transmission Opportunity Limit | 传输机会限制 |
| U Return | ||
| UA | Unnumbered Acknowledge | 无编号确认 |
| U-APSD | Unscheduled automatic power-save delivery | 非调度自动节能发送 |
| UBR | Unspecified Bit Rate | 不确定比特率 |
| UDLD | Uni-directional Link Direction | 单向链路检测 |
| UNI | User Network Interface | 用户网络接口 |
| URL | Uniform Resource Locator | 统一资源定位符 |
| URPF | Unicast Reverse Path Forwarding | 单播反向路径转发 |
| USM | User-Based Security Model | 基于用户的安全模型 |
| UTC | Coordinated Universal Time | 国际协调时间 |
| V Return | ||
| VAD | Voice Activity Detection | 静音检测 |
| VAM | VPN Address Management | VPN地址管理 |
| VC | Virtual Circuit | 虚电路 |
| VC | Virtual Container | 虚容器 |
| VCC | Virtual Circuit Connection | 虚电路连接 |
| VCN | Virtual Circuit Number | 虚电路号 |
| VE | Virtual Ethernet | 虚拟以太网 |
| VE-Bridge | Virtual Ethernet Bridge | 二层虚拟以太网 |
| VF Owner | Virtual Forwarder Owner | 虚拟转发器拥有者 |
| VLAN | Virtual Local Area Network | 虚拟局域网 |
| VoD | Video on Demand | 视频点播 |
| VoIP | Voice over IP | 在IP上传送语音 |
| VP | Virtual Path | 虚路径 |
| VPC | Virtual Path Connection | 虚路径连接 |
| VPDN | Virtual Private Dial-up Network | 虚拟专用拨号网络 |
| VPLS | Virtual Private LAN Service | 虚拟专用局域网服务 |
| VPN | Virtual Private Network | 虚拟专用网络 |
| VRRP | Virtual Router Redundancy Protocol | 虚拟路由器冗余协议 |
| VSAN | Virtual Storage Area Network | 虚拟SAN |
| VSI | Virtual Switch Instance | 虚拟交换实例 |
| VT | Virtual-template | 虚拟接口模板 |
| VTP | VLAN Trunking Protocol | VLAN中继协议 |
| VTY | Virtual Type Terminal | 虚拟类型终端 |
| W Return | ||
| WAI | WLAN Authentication Infrastructure | 无线局域网鉴别基础结构 |
| WAN | Wide Area Network | 广域网 |
| WAPI | WLAN Authentication and Privacy Infrastructure | 无线局域网鉴别与保密基础结构 |
| WDS | Wireless Distribution System | 无线分布式系统 |
| WEP | Wired Equivalent Privacy | 有线等效加密 |
| WFQ | Weighted Fair Queuing | 加权公平队列 |
| WIDS | Wireless Intrusion Detection System | 无线入侵检测系统 |
| WiNet | Wisdom Network | 智能网络 |
| WINS | Windows Internet Naming Service | Windows互联网名称服务 |
| WLAN | Wireless Local Area Network | 无线局域网 |
| WMM | Wi-Fi Multimedia | Wi-Fi多媒体 |
| WPA | Wi-Fi Protected Access | Wi-Fi保护访问 |
| WPI | WLAN Privacy Infrastructure | 无线局域网保密基础结构 |
| WRED | Weighted Random Early Detection | 加权随机早期检测 |
| WRR | Weighted Round Robin | 加权轮询 |
| WWN | World Wide Name | 全球名字 |
| WWW | World Wide Web | 万维网 |
| X Return | ||
| XENPAK | 10-Gigabit Ethernet Transceiver Package | 万兆以太网接口收发器集合封装 |
| XFP | 10-Gigabit small Form-factor Pluggable | 万兆以太网接口小封装可热插拔 |
| XML | Extensible Markup Language | 扩展标记语言 |
| Z Return | ||
| ZBR | Zone Border Router | 区域边界路由器 |
