43-附录
本章节下载 (101.77 KB)
本命令索引包括手册中所出现的全部命令,按字母序排列,左边为命令行,右边为该命令所在的功能模块和页码。
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
| access-limit | 17-AAA命令 | 1-1 |
| accounting | 17-AAA命令 | 1-1 |
| accounting domain | 21-DHCP命令 | 1-1 |
| accounting lan-access | 17-AAA命令 | 1-2 |
| accounting login | 17-AAA命令 | 1-3 |
| accounting optional | 17-AAA命令 | 1-4 |
| accounting optional | 17-AAA命令 | 1-30 |
| accounting start-mode | 17-AAA命令 | 1-31 |
| accounting-on enable | 17-AAA命令 | 1-32 |
| acl | 01-登录交换机命令 | 2-1 |
| acl | 22-ACL命令 | 1-1 |
| active region-configuration | 14-MSTP命令 | 1-1 |
| add-member | 25-Stack-Cluster命令 | 2-12 |
| administrator-address | 25-Stack-Cluster命令 | 2-13 |
| adv-factor | 34-HWPing命令 | 1-1 |
| am user-bind | 11-端口安全-端口绑定命令 | 2-1 |
| apply qos-profile | 23-QoS-QoS Profile命令 | 2-1 |
| arp anti-attack valid-check enable | 38-ARP和IP攻击防御命令 | 1 |
| arp check enable | 20-ARP命令 | 1-1 |
| arp detection enable | 20-ARP命令 | 1-1 |
| arp detection trust | 20-ARP命令 | 1-2 |
| arp filter binding | 38-ARP和IP攻击防御命令 | 2 |
| arp filter source | 38-ARP和IP攻击防御命令 | 1 |
| arp max-learning-num | 38-ARP和IP攻击防御命令 | 2 |
| arp protective-down recover enable | 20-ARP命令 | 1-2 |
| arp protective-down recover interval | 20-ARP命令 | 1-3 |
| arp rate-limit | 20-ARP命令 | 1-4 |
| arp rate-limit enable | 20-ARP命令 | 1-4 |
| arp restricted-forwarding enable | 20-ARP命令 | 1-5 |
| arp static | 20-ARP命令 | 1-5 |
| arp timer aging | 20-ARP命令 | 1-6 |
| ascii | 30-FTP-SFTP-TFTP命令 | 1-5 |
| attribute | 17-AAA命令 | 1-5 |
| attribute | 40-PKI命令 | 1-1 |
| attribute-ignore | 17-AAA命令 | 1-33 |
| authentication | 17-AAA命令 | 1-6 |
| authentication lan-access | 17-AAA命令 | 1-7 |
| authentication login | 17-AAA命令 | 1-7 |
| authentication super | 17-AAA命令 | 1-8 |
| authentication-mode | 01-登录交换机命令 | 1-1 |
| authorization | 17-AAA命令 | 1-9 |
| authorization login | 17-AAA命令 | 1-10 |
| authorization vlan | 17-AAA命令 | 1-11 |
| auto-build | 25-Stack-Cluster命令 | 2-13 |
| auto-execute command | 01-登录交换机命令 | 1-2 |
| bims-server | 21-DHCP命令 | 1-1 |
| binary | 30-FTP-SFTP-TFTP命令 | 1-5 |
| black-list | 25-Stack-Cluster命令 | 2-34 |
| boot attribute-switch | 29-文件系统管理命令 | 1-13 |
| boot boot-loader | 29-文件系统管理命令 | 1-14 |
| boot boot-loader | 32-系统维护与调试命令 | 3-1 |
| boot boot-loader backup-attribute | 29-文件系统管理命令 | 1-14 |
| boot bootrom | 32-系统维护与调试命令 | 3-1 |
| boot web-package | 29-文件系统管理命令 | 1-15 |
| bpdu-drop any | 14-MSTP命令 | 1-1 |
| broadcast-suppression | 08-端口基本配置命令 | 1-1 |
| build | 25-Stack-Cluster命令 | 2-15 |
| burst-mode enable | 23-QoS-QoS Profile命令 | 1-1 |
| bye | 30-FTP-SFTP-TFTP命令 | 1-6 |
| bye | 30-FTP-SFTP-TFTP命令 | 1-19 |
| ca identifier | 40-PKI命令 | 1-2 |
| calling-station-id mode | 17-AAA命令 | 1-34 |
| cd | 29-文件系统管理命令 | 1-1 |
| cd | 30-FTP-SFTP-TFTP命令 | 1-6 |
| cd | 30-FTP-SFTP-TFTP命令 | 1-20 |
| cdup | 30-FTP-SFTP-TFTP命令 | 1-7 |
| cdup | 30-FTP-SFTP-TFTP命令 | 1-20 |
| certificate request entity | 40-PKI命令 | 1-2 |
| certificate request from | 40-PKI命令 | 1-3 |
| certificate request mode | 40-PKI命令 | 1-3 |
| certificate request polling | 40-PKI命令 | 1-4 |
| certificate request url | 40-PKI命令 | 1-5 |
| check region-configuration | 14-MSTP命令 | 1-2 |
| ciphersuite | 41-SSL命令 | 1-1 |
| client-verify enable | 41-SSL命令 | 1-1 |
| clock datetime | 32-系统维护与调试命令 | 1-1 |
| clock summer-time | 32-系统维护与调试命令 | 1-1 |
| clock timezone | 32-系统维护与调试命令 | 1-2 |
| close | 30-FTP-SFTP-TFTP命令 | 1-7 |
| close-mode wait | 41-SSL命令 | 1-2 |
| cluster | 25-Stack-Cluster命令 | 2-16 |
| cluster enable | 25-Stack-Cluster命令 | 2-17 |
| cluster switch-to | 25-Stack-Cluster命令 | 2-18 |
| cluster-mac | 25-Stack-Cluster命令 | 2-18 |
| cluster-mac syn-interval | 25-Stack-Cluster命令 | 2-19 |
| command-alias enable | 32-系统维护与调试命令 | 1-9 |
| command-alias mapping | 32-系统维护与调试命令 | 1-10 |
| command-privilege level | 01-登录交换机命令 | 3-1 |
| common-name | 40-PKI命令 | 1-5 |
| copy | 29-文件系统管理命令 | 1-2 |
| copy configuration | 08-端口基本配置命令 | 1-2 |
| copyright-info enable | 01-登录交换机命令 | 1-3 |
| count | 34-HWPing命令 | 1-1 |
| country | 40-PKI命令 | 1-6 |
| crl check | 40-PKI命令 | 1-6 |
| crl update-period | 40-PKI命令 | 1-7 |
| crl url | 40-PKI命令 | 1-7 |
| cut connection | 17-AAA命令 | 1-11 |
| databits | 01-登录交换机命令 | 1-3 |
| datafill | 34-HWPing命令 | 1-2 |
| data-flow-format | 17-AAA命令 | 1-34 |
| data-flow-format | 17-AAA命令 | 1-61 |
| datasize | 34-HWPing命令 | 1-3 |
| debugging | 32-系统维护与调试命令 | 1-7 |
| delete | 29-文件系统管理命令 | 1-2 |
| delete | 30-FTP-SFTP-TFTP命令 | 1-8 |
| delete | 30-FTP-SFTP-TFTP命令 | 1-21 |
| delete static-routes all | 04-配置管理VLAN命令 | 1-1 |
| delete-member | 25-Stack-Cluster命令 | 2-20 |
| description | 03-VLAN命令 | 1-1 |
| description | 08-端口基本配置命令 | 1-4 |
| description | 22-ACL命令 | 1-2 |
| description | 34-HWPing命令 | 1-4 |
| destination-ip | 34-HWPing命令 | 1-4 |
| destination-port | 34-HWPing命令 | 1-5 |
| dhcp enable | 21-DHCP命令 | 1-2 |
| dhcp protective-down recover enable | 21-DHCP命令 | 3-1 |
| dhcp protective-down recover interval | 21-DHCP命令 | 3-1 |
| dhcp rate-limit | 21-DHCP命令 | 3-2 |
| dhcp rate-limit enable | 21-DHCP命令 | 3-2 |
| dhcp select global | 21-DHCP命令 | 1-3 |
| dhcp select interface | 21-DHCP命令 | 1-4 |
| dhcp server bims-server | 21-DHCP命令 | 1-5 |
| dhcp server detect | 21-DHCP命令 | 1-6 |
| dhcp server dns-list | 21-DHCP命令 | 1-7 |
| dhcp server domain-name | 21-DHCP命令 | 1-7 |
| dhcp server expired | 21-DHCP命令 | 1-8 |
| dhcp server forbidden-ip | 21-DHCP命令 | 1-9 |
| dhcp server ip-pool | 21-DHCP命令 | 1-10 |
| dhcp server nbns-list | 21-DHCP命令 | 1-11 |
| dhcp server netbios-type | 21-DHCP命令 | 1-12 |
| dhcp server option | 21-DHCP命令 | 1-13 |
| dhcp server ping | 21-DHCP命令 | 1-14 |
| dhcp server relay information enable | 21-DHCP命令 | 1-14 |
| dhcp server static-bind | 21-DHCP命令 | 1-15 |
| dhcp server voice-config | 21-DHCP命令 | 1-16 |
| dhcp-snooping | 21-DHCP命令 | 2-1 |
| dhcp-snooping information enable | 21-DHCP命令 | 2-1 |
| dhcp-snooping information format | 21-DHCP命令 | 2-2 |
| dhcp-snooping information packet-format | 21-DHCP命令 | 2-2 |
| dhcp-snooping information remote-id | 21-DHCP命令 | 2-3 |
| dhcp-snooping information strategy | 21-DHCP命令 | 2-3 |
| dhcp-snooping information vlan circuit-id | 21-DHCP命令 | 2-4 |
| dhcp-snooping information vlan remote-id | 21-DHCP命令 | 2-5 |
| dhcp-snooping trust | 21-DHCP命令 | 2-6 |
| dir | 29-文件系统管理命令 | 1-4 |
| dir | 30-FTP-SFTP-TFTP命令 | 1-8 |
| dir | 30-FTP-SFTP-TFTP命令 | 1-21 |
| disconnect | 30-FTP-SFTP-TFTP命令 | 1-9 |
| display acl | 22-ACL命令 | 1-3 |
| display acl remaining entry | 22-ACL命令 | 1-3 |
| display am user-bind | 11-端口安全-端口绑定命令 | 2-2 |
| display arp | 20-ARP命令 | 1-6 |
| display arp | | 20-ARP命令 | 1-8 |
| display arp count | 20-ARP命令 | 1-8 |
| display arp detection statistics interface | 20-ARP命令 | 1-9 |
| display arp timer aging | 20-ARP命令 | 1-10 |
| display boot-loader | 29-文件系统管理命令 | 1-15 |
| display boot-loader | 32-系统维护与调试命令 | 3-2 |
| display bootp client | 21-DHCP命令 | 4-3 |
| display brief interface | 08-端口基本配置命令 | 1-4 |
| display channel | 31-信息中心命令 | 1-1 |
| display clock | 32-系统维护与调试命令 | 1-5 |
| display cluster | 25-Stack-Cluster命令 | 2-21 |
| display cluster base-members | 25-Stack-Cluster命令 | 2-35 |
| display cluster base-topology | 25-Stack-Cluster命令 | 2-36 |
| display cluster black-list | 25-Stack-Cluster命令 | 2-37 |
| display cluster candidates | 25-Stack-Cluster命令 | 2-22 |
| display cluster current-topology | 25-Stack-Cluster命令 | 2-39 |
| display cluster members | 25-Stack-Cluster命令 | 2-23 |
| display command-alias | 32-系统维护与调试命令 | 1-11 |
| display connection | 17-AAA命令 | 1-12 |
| display cpu | 32-系统维护与调试命令 | 3-2 |
| display current-configuration | 02-配置文件管理命令 | 1-1 |
| display current-configuration vlan | 02-配置文件管理命令 | 1-5 |
| display debugging | 32-系统维护与调试命令 | 1-6 |
| display device | 32-系统维护与调试命令 | 3-3 |
| display dhcp client | 21-DHCP命令 | 4-1 |
| display dhcp server conflict | 21-DHCP命令 | 1-17 |
| display dhcp server expired | 21-DHCP命令 | 1-18 |
| display dhcp server free-ip | 21-DHCP命令 | 1-19 |
| display dhcp server ip-in-use | 21-DHCP命令 | 1-19 |
| display dhcp server statistics | 21-DHCP命令 | 1-20 |
| display dhcp server tree | 21-DHCP命令 | 1-22 |
| display dhcp-snooping | 21-DHCP命令 | 2-7 |
| display dhcp-snooping trust | 21-DHCP命令 | 2-7 |
| display diagnostic-information | 32-系统维护与调试命令 | 1-8 |
| display dldp | 12-DLDP命令 | 1-1 |
| display dns domain | 36-域名解析命令 | 1-1 |
| display dns dynamic-host | 36-域名解析命令 | 1-1 |
| display dns ipv6 dynamic-host | 35-IPv6管理命令 | 1-1 |
| display dns server | 36-域名解析命令 | 1-2 |
| display domain | 17-AAA命令 | 1-14 |
| display dot1x | 16-802.1x及System-Guard命令 | 1-1 |
| display fib | 05-IP地址-IP性能命令 | 2-1 |
| display fib | | 05-IP地址-IP性能命令 | 2-3 |
| display fib acl | 05-IP地址-IP性能命令 | 2-3 |
| display fib ip-address | 05-IP地址-IP性能命令 | 2-2 |
| display fib statistics | 05-IP地址-IP性能命令 | 2-4 |
| display ftp-server | 30-FTP-SFTP-TFTP命令 | 1-1 |
| display ftp-user | 30-FTP-SFTP-TFTP命令 | 1-2 |
| display garp statistics | 07-GVRP命令 | 1-1 |
| display garp timer | 07-GVRP命令 | 1-2 |
| display gvrp statistics | 07-GVRP命令 | 1-5 |
| display gvrp status | 07-GVRP命令 | 1-6 |
| display habp | 16-802.1x及System-Guard命令 | 2-1 |
| display habp table | 16-802.1x及System-Guard命令 | 2-1 |
| display habp traffic | 16-802.1x及System-Guard命令 | 2-2 |
| display history-command | 01-登录交换机命令 | 3-3 |
| display hwping | 34-HWPing命令 | 1-6 |
| display hwping statistics | 34-HWPing命令 | 1-11 |
| display hwtacacs | 17-AAA命令 | 1-61 |
| display icmp statistics | 05-IP地址-IP性能命令 | 2-4 |
| display igmp-snooping configuration | 15-组播协议命令 | 1-1 |
| display igmp-snooping group | 15-组播协议命令 | 1-1 |
| display igmp-snooping statistics | 15-组播协议命令 | 1-3 |
| display info-center | 31-信息中心命令 | 1-1 |
| display interface | 08-端口基本配置命令 | 1-6 |
| display interface Vlan-interface | 03-VLAN命令 | 1-2 |
| display interface Vlan-interface | 04-配置管理VLAN命令 | 1-1 |
| display ip host | 36-域名解析命令 | 1-3 |
| display ip https | 42-HTTPS命令 | 1-1 |
| display ip interface | 04-配置管理VLAN命令 | 1-2 |
| display ip interface | 05-IP地址-IP性能命令 | 1-1 |
| display ip interface brief | 04-配置管理VLAN命令 | 1-4 |
| display ip interface brief | 05-IP地址-IP性能命令 | 1-2 |
| display ip routing-table | 04-配置管理VLAN命令 | 1-5 |
| display ip routing-table acl | 04-配置管理VLAN命令 | 1-5 |
| display ip routing-table ip-address | 04-配置管理VLAN命令 | 1-7 |
| display ip routing-table ip-address1 ip-address2 | 04-配置管理VLAN命令 | 1-8 |
| display ip routing-table protocol | 04-配置管理VLAN命令 | 1-9 |
| display ip routing-table radix | 04-配置管理VLAN命令 | 1-10 |
| display ip routing-table statistics | 04-配置管理VLAN命令 | 1-11 |
| display ip routing-table verbose | 04-配置管理VLAN命令 | 1-11 |
| display ip socket | 05-IP地址-IP性能命令 | 2-6 |
| display ip source static binding | 21-DHCP命令 | 2-8 |
| display ip statistics | 05-IP地址-IP性能命令 | 2-7 |
| display ipv6 fib | 35-IPv6管理命令 | 1-2 |
| display ipv6 host | 35-IPv6管理命令 | 1-3 |
| display ipv6 interface | 35-IPv6管理命令 | 1-4 |
| display ipv6 neighbors | 35-IPv6管理命令 | 1-6 |
| display ipv6 neighbors count | 35-IPv6管理命令 | 1-7 |
| display ipv6 route-table | 35-IPv6管理命令 | 1-8 |
| display ipv6 socket | 35-IPv6管理命令 | 1-9 |
| display ipv6 statistics | 35-IPv6管理命令 | 1-11 |
| display isolate port | 10-端口隔离命令 | 1-1 |
| display job | 32-系统维护与调试命令 | 17 |
| display lacp system-id | 09-端口汇聚命令 | 1-4 |
| display link-aggregation interface | 09-端口汇聚命令 | 1-1 |
| display link-aggregation summary | 09-端口汇聚命令 | 1-2 |
| display link-aggregation verbose | 09-端口汇聚命令 | 1-3 |
| display link-delay | 08-端口基本配置命令 | 1-9 |
| display lldp local-information | 39-LLDP命令 | 1-1 |
| display lldp neighbor-information | 39-LLDP命令 | 1-4 |
| display lldp statistics | 39-LLDP命令 | 1-8 |
| display lldp status | 39-LLDP命令 | 1-9 |
| display lldp tlv-config | 39-LLDP命令 | 1-11 |
| display local-server statistics | 17-AAA命令 | 1-35 |
| display local-user | 17-AAA命令 | 1-15 |
| display logbuffer | 31-信息中心命令 | 1-2 |
| display logbuffer summary | 31-信息中心命令 | 1-3 |
| display loopback-detection | 08-端口基本配置命令 | 1-10 |
| display mac-address | 13-MAC地址转发表管理命令 | 1-1 |
| display mac-address aging-time | 13-MAC地址转发表管理命令 | 1-1 |
| display mac-address multicast static | 15-组播协议命令 | 2-1 |
| display mac-address security | 11-端口安全-端口绑定命令 | 1-1 |
| display mac-authentication | 18-MAC地址认证命令 | 1-1 |
| display mac-vlan | 03-VLAN命令 | 1-13 |
| display mac-vlan interface | 03-VLAN命令 | 1-14 |
| display memory | 32-系统维护与调试命令 | 3-4 |
| display mirroring-group | 24-镜像命令 | 1-1 |
| display monitor-link group | 37-Smart Link-Monitor Link命令 | 2-1 |
| display multicast-source-deny | 15-组播协议命令 | 2-2 |
| display ndp | 25-Stack-Cluster命令 | 2-1 |
| display ntdp | 25-Stack-Cluster命令 | 2-5 |
| display ntdp device-list | 25-Stack-Cluster命令 | 2-6 |
| display ntdp single-device mac-address | 25-Stack-Cluster命令 | 2-37 |
| display ntp-service sessions | 27-NTP命令 | 1-1 |
| display ntp-service status | 27-NTP命令 | 1-2 |
| display ntp-service trace | 27-NTP命令 | 1-3 |
| display packet-filter | 22-ACL命令 | 1-4 |
| display pki certificate | 40-PKI命令 | 1-8 |
| display pki certificate access-control-policy | 40-PKI命令 | 1-9 |
| display pki certificate attribute-group | 40-PKI命令 | 1-10 |
| display pki crl domain | 40-PKI命令 | 1-11 |
| display port | 03-VLAN命令 | 1-7 |
| display port combo | 08-端口基本配置命令 | 1-10 |
| display port vlan-vpn | 33-VLAN-VPN命令 | 1-1 |
| display port-mac | 13-MAC地址转发表管理命令 | 1-3 |
| display port-security | 11-端口安全-端口绑定命令 | 1-2 |
| display priority-trust | 23-QoS-QoS Profile命令 | 1-1 |
| display public-key local | 28-SSH命令 | 1-1 |
| display public-key peer | 28-SSH命令 | 1-2 |
| display qos cos-local-precedence-map | 23-QoS-QoS Profile命令 | 1-2 |
| display qos dscp-local-precedence-map | 23-QoS-QoS Profile命令 | 1-2 |
| display qos-global | 23-QoS-QoS Profile命令 | 1-4 |
| display qos-interface all | 23-QoS-QoS Profile命令 | 1-5 |
| display qos-interface line-rate | 23-QoS-QoS Profile命令 | 1-6 |
| display qos-interface mirrored-to | 23-QoS-QoS Profile命令 | 1-6 |
| display qos-interface traffic-limit | 23-QoS-QoS Profile命令 | 1-7 |
| display qos-interface traffic-priority | 23-QoS-QoS Profile命令 | 1-8 |
| display qos-interface traffic-redirect | 23-QoS-QoS Profile命令 | 1-8 |
| display qos-interface traffic-statistic | 23-QoS-QoS Profile命令 | 1-9 |
| display qos-profile | 23-QoS-QoS Profile命令 | 2-2 |
| display qos-vlan | 23-QoS-QoS Profile命令 | 1-10 |
| display queue-scheduler | 23-QoS-QoS Profile命令 | 1-11 |
| display radius scheme | 17-AAA命令 | 1-36 |
| display radius statistics | 17-AAA命令 | 1-38 |
| display rmon alarm | 26-SNMP-RMON命令 | 2-1 |
| display rmon event | 26-SNMP-RMON命令 | 2-2 |
| display rmon eventlog | 26-SNMP-RMON命令 | 2-3 |
| display rmon history | 26-SNMP-RMON命令 | 2-4 |
| display rmon prialarm | 26-SNMP-RMON命令 | 2-5 |
| display rmon statistics | 26-SNMP-RMON命令 | 2-6 |
| display rsa local-key-pair public | 28-SSH命令 | 1-4 |
| display rsa peer-public-key | 28-SSH命令 | 1-5 |
| display saved-configuration | 02-配置文件管理命令 | 1-5 |
| display schedule reboot | 32-系统维护与调试命令 | 3-5 |
| display smart-link flush | 37-Smart Link-Monitor Link命令 | 1-1 |
| display smart-link group | 37-Smart Link-Monitor Link命令 | 1-2 |
| display snmp-agent | 26-SNMP-RMON命令 | 1-1 |
| display snmp-agent community | 26-SNMP-RMON命令 | 1-1 |
| display snmp-agent group | 26-SNMP-RMON命令 | 1-2 |
| display snmp-agent mib-view | 26-SNMP-RMON命令 | 1-3 |
| display snmp-agent statistics | 26-SNMP-RMON命令 | 1-5 |
| display snmp-agent sys-info | 26-SNMP-RMON命令 | 1-6 |
| display snmp-agent trap-list | 26-SNMP-RMON命令 | 1-7 |
| display snmp-agent usm-user | 26-SNMP-RMON命令 | 1-8 |
| display ssh server | 28-SSH命令 | 1-6 |
| display ssh server-info | 28-SSH命令 | 1-7 |
| display ssh user-information | 28-SSH命令 | 1-8 |
| display ssl client-policy | 41-SSL命令 | 1-3 |
| display ssl server-policy | 41-SSL命令 | 1-3 |
| display stacking | 25-Stack-Cluster命令 | 1-1 |
| display startup | 02-配置文件管理命令 | 1-8 |
| display stop-accounting-buffer | 17-AAA命令 | 1-39 |
| display stop-accounting-buffer | 17-AAA命令 | 1-62 |
| display storm-constrain | 08-端口基本配置命令 | 1-11 |
| display stp | 14-MSTP命令 | 1-3 |
| display stp abnormalport | 14-MSTP命令 | 1-7 |
| display stp portdown | 14-MSTP命令 | 1-7 |
| display stp region-configuration | 14-MSTP命令 | 1-8 |
| display stp root | 14-MSTP命令 | 1-9 |
| display system-guard attack-record | 16-802.1x及System-Guard命令 | 3-1 |
| display system-guard state | 16-802.1x及System-Guard命令 | 3-1 |
| display tcp ipv6 statistics | 35-IPv6管理命令 | 1-13 |
| display tcp ipv6 status | 35-IPv6管理命令 | 1-16 |
| display tcp statistics | 05-IP地址-IP性能命令 | 2-8 |
| display tcp status | 05-IP地址-IP性能命令 | 2-11 |
| display this | 02-配置文件管理命令 | 1-9 |
| display time-range | 22-ACL命令 | 1-5 |
| display transceiver alarm interface | 32-系统维护与调试命令 | 3-5 |
| display transceiver diagnosis interface | 32-系统维护与调试命令 | 3-8 |
| display transceiver interface | 32-系统维护与调试命令 | 3-8 |
| display transceiver manuinfo interface | 32-系统维护与调试命令 | 3-10 |
| display trapbuffer | 31-信息中心命令 | 1-4 |
| display udp ipv6 statistics | 35-IPv6管理命令 | 1-16 |
| display udp statistics | 05-IP地址-IP性能命令 | 2-11 |
| display unit | 08-端口基本配置命令 | 1-12 |
| display user-interface | 01-登录交换机命令 | 1-4 |
| display users | 01-登录交换机命令 | 1-6 |
| display version | 32-系统维护与调试命令 | 1-6 |
| display vlan | 03-VLAN命令 | 1-3 |
| display vlan | 06-Voice VLAN命令 | 1-3 |
| display voice vlan error-info | 06-Voice VLAN命令 | 1-1 |
| display voice vlan oui | 06-Voice VLAN命令 | 1-1 |
| display voice vlan status | 06-Voice VLAN命令 | 1-2 |
| display web package | 29-文件系统管理命令 | 1-16 |
| display web users | 01-登录交换机命令 | 1-7 |
| display web-authentication configuration | 19-Web认证命令 | 1-1 |
| display web-authentication connection | 19-Web认证命令 | 1-2 |
| dldp | 12-DLDP命令 | 1-2 |
| dldp authentication-mode | 12-DLDP命令 | 1-3 |
| dldp delaydown-timer | 12-DLDP命令 | 1-7 |
| dldp interval | 12-DLDP命令 | 1-4 |
| dldp reset | 12-DLDP命令 | 1-5 |
| dldp unidirectional-shutdown | 12-DLDP命令 | 1-5 |
| dldp work-mode | 12-DLDP命令 | 1-6 |
| dns domain | 36-域名解析命令 | 1-4 |
| dns resolve | 36-域名解析命令 | 1-4 |
| dns resolve-target | 34-HWPing命令 | 1-14 |
| dns server | 36-域名解析命令 | 1-5 |
| dns server ipv6 | 35-IPv6管理命令 | 1-17 |
| dns-list | 21-DHCP命令 | 1-23 |
| dns-server | 34-HWPing命令 | 1-13 |
| domain | 17-AAA命令 | 1-16 |
| domain delimiter | 17-AAA命令 | 1-17 |
| domain-name | 21-DHCP命令 | 1-24 |
| dot1x | 16-802.1x及System-Guard命令 | 1-4 |
| dot1x authentication-method | 16-802.1x及System-Guard命令 | 1-5 |
| dot1x dhcp-launch | 16-802.1x及System-Guard命令 | 1-5 |
| dot1x guest-vlan | 16-802.1x及System-Guard命令 | 1-6 |
| dot1x handshake | 16-802.1x及System-Guard命令 | 1-7 |
| dot1x handshake secure | 16-802.1x及System-Guard命令 | 1-8 |
| dot1x mandatory-domain | 16-802.1x及System-Guard命令 | 1-8 |
| dot1x max-user | 16-802.1x及System-Guard命令 | 1-9 |
| dot1x port-control | 16-802.1x及System-Guard命令 | 1-10 |
| dot1x port-method | 16-802.1x及System-Guard命令 | 1-10 |
| dot1x quiet-period | 16-802.1x及System-Guard命令 | 1-11 |
| dot1x re-authenticate | 16-802.1x及System-Guard命令 | 1-13 |
| dot1x retry | 16-802.1x及System-Guard命令 | 1-12 |
| dot1x retry-version-max | 16-802.1x及System-Guard命令 | 1-13 |
| dot1x supp-proxy-check | 16-802.1x及System-Guard命令 | 1-14 |
| dot1x timer | 16-802.1x及System-Guard命令 | 1-15 |
| dot1x timer reauth-period | 16-802.1x及System-Guard命令 | 1-17 |
| dot1x version-check | 16-802.1x及System-Guard命令 | 1-17 |
| duplex | 08-端口基本配置命令 | 1-13 |
| enable log updown | 08-端口基本配置命令 | 1-14 |
| enable snmp trap updown | 26-SNMP-RMON命令 | 1-9 |
| execute | 29-文件系统管理命令 | 1-5 |
| exit | 30-FTP-SFTP-TFTP命令 | 1-22 |
| expired | 21-DHCP命令 | 1-24 |
| file prompt | 29-文件系统管理命令 | 1-6 |
| filename | 34-HWPing命令 | 1-15 |
| filesize | 34-HWPing命令 | 1-15 |
| fixdisk | 29-文件系统管理命令 | 1-6 |
| flow-control | 08-端口基本配置命令 | 1-14 |
| flow-interval | 08-端口基本配置命令 | 1-15 |
| flush enable control-vlan | 37-Smart Link-Monitor Link命令 | 1-2 |
| format | 29-文件系统管理命令 | 1-7 |
| fqdn | 40-PKI命令 | 1-12 |
| free user-interface | 01-登录交换机命令 | 1-7 |
| free web-users | 01-登录交换机命令 | 2-1 |
| frequency | 34-HWPing命令 | 1-16 |
| ftp | 30-FTP-SFTP-TFTP命令 | 1-10 |
| ftp cluster | 25-Stack-Cluster命令 | 2-25 |
| ftp disconnect | 30-FTP-SFTP-TFTP命令 | 1-2 |
| ftp server enable | 30-FTP-SFTP-TFTP命令 | 1-3 |
| ftp timeout | 30-FTP-SFTP-TFTP命令 | 1-4 |
| ftp-operation | 34-HWPing命令 | 1-17 |
| ftp-server | 25-Stack-Cluster命令 | 2-26 |
| garp timer | 07-GVRP命令 | 1-3 |
| garp timer leaveall | 07-GVRP命令 | 1-4 |
| gateway-list | 21-DHCP命令 | 1-25 |
| get | 30-FTP-SFTP-TFTP命令 | 1-10 |
| get | 30-FTP-SFTP-TFTP命令 | 1-23 |
| gratuitous-arp-learning enable | 20-ARP命令 | 1-10 |
| gvrp | 07-GVRP命令 | 1-6 |
| gvrp registration | 07-GVRP命令 | 1-7 |
| habp enable | 16-802.1x及System-Guard命令 | 2-3 |
| habp server vlan | 16-802.1x及System-Guard命令 | 2-3 |
| habp timer | 16-802.1x及System-Guard命令 | 2-4 |
| handshake timeout | 41-SSL命令 | 1-4 |
| header | 01-登录交换机命令 | 1-8 |
| help | 30-FTP-SFTP-TFTP命令 | 1-23 |
| history keep-time | 34-HWPing命令 | 1-17 |
| history-command max-size | 01-登录交换机命令 | 1-10 |
| history-record enable | 34-HWPing命令 | 1-18 |
| history-records | 34-HWPing命令 | 1-18 |
| holdtime | 25-Stack-Cluster命令 | 2-27 |
| http-operation | 34-HWPing命令 | 1-19 |
| http-string | 34-HWPing命令 | 1-19 |
| hwping | 34-HWPing命令 | 1-20 |
| hwping-agent clear | 34-HWPing命令 | 1-21 |
| hwping-agent enable | 34-HWPing命令 | 1-21 |
| hwping-agent max-requests | 34-HWPing命令 | 1-22 |
| hwping-server enable | 34-HWPing命令 | 1-35 |
| hwping-server tcpconnect | 34-HWPing命令 | 1-35 |
| hwping-server udpecho | 34-HWPing命令 | 1-36 |
| hwtacacs nas-ip | 17-AAA命令 | 1-63 |
| hwtacacs scheme | 17-AAA命令 | 1-63 |
| icmp redirect send | 05-IP地址-IP性能命令 | 2-12 |
| icmp unreach send | 05-IP地址-IP性能命令 | 2-13 |
| idle-cut | 17-AAA命令 | 1-18 |
| idle-timeout | 01-登录交换机命令 | 1-10 |
| igmp host-join | 15-组播协议命令 | 1-14 |
| igmp-snooping | 15-组播协议命令 | 1-4 |
| igmp-snooping access-policy | 15-组播协议命令 | 1-4 |
| igmp-snooping fast-leave | 15-组播协议命令 | 1-5 |
| igmp-snooping general-query source-ip | 15-组播协议命令 | 1-6 |
| igmp-snooping group-limit | 15-组播协议命令 | 1-7 |
| igmp-snooping group-policy | 15-组播协议命令 | 1-7 |
| igmp-snooping host-aging-time | 15-组播协议命令 | 1-9 |
| igmp-snooping nonflooding-enable | 15-组播协议命令 | 1-9 |
| igmp-snooping querier | 15-组播协议命令 | 1-10 |
| igmp-snooping query-interval | 15-组播协议命令 | 1-11 |
| igmp-snooping router-aging-time | 15-组播协议命令 | 1-11 |
| igmp-snooping special-query source-ip | 15-组播协议命令 | 1-12 |
| igmp-snooping version | 15-组播协议命令 | 1-13 |
| igmp-snooping vlan-mapping | 15-组播协议命令 | 1-13 |
| info-center channel name | 31-信息中心命令 | 1-5 |
| info-center console channel | 31-信息中心命令 | 1-5 |
| info-center enable | 31-信息中心命令 | 1-6 |
| info-center logbuffer | 31-信息中心命令 | 1-7 |
| info-center loghost | 31-信息中心命令 | 1-7 |
| info-center loghost source | 31-信息中心命令 | 1-8 |
| info-center monitor channel | 31-信息中心命令 | 1-9 |
| info-center snmp channel | 31-信息中心命令 | 1-9 |
| info-center source | 31-信息中心命令 | 1-10 |
| info-center synchronous | 31-信息中心命令 | 1-12 |
| info-center timestamp | 31-信息中心命令 | 1-13 |
| info-center timestamp loghost | 31-信息中心命令 | 1-13 |
| info-center timestamp utc | 31-信息中心命令 | 1-14 |
| info-center trapbuffer | 31-信息中心命令 | 1-15 |
| instance | 14-MSTP命令 | 1-10 |
| interface | 08-端口基本配置命令 | 1-16 |
| interface Vlan-interface | 03-VLAN命令 | 1-4 |
| interface Vlan-interface | 04-配置管理VLAN命令 | 1-12 |
| ip (Pki Entity view) | 40-PKI命令 | 1-13 |
| ip address | 04-配置管理VLAN命令 | 1-13 |
| ip address | 05-IP地址-IP性能命令 | 1-3 |
| ip address bootp-alloc | 21-DHCP命令 | 4-3 |
| ip address dhcp-alloc | 21-DHCP命令 | 4-2 |
| ip check dot1x enable | 38-ARP和IP攻击防御命令 | 4 |
| ip check source ip-address | 21-DHCP命令 | 2-8 |
| ip host | 36-域名解析命令 | 1-5 |
| ip http acl | 01-登录交换机命令 | 2-2 |
| ip http shutdown | 01-登录交换机命令 | 1-11 |
| ip https acl | 42-HTTPS命令 | 1-1 |
| ip https certificate access-control-policy | 42-HTTPS命令 | 1-2 |
| ip https enable | 42-HTTPS命令 | 1-3 |
| ip https ssl-server-policy | 42-HTTPS命令 | 1-3 |
| ip route-static | 04-配置管理VLAN命令 | 1-13 |
| ip source static binding | 21-DHCP命令 | 2-9 |
| ip source static import dot1x | 38-ARP和IP攻击防御命令 | 3 |
| ip-pool | 25-Stack-Cluster命令 | 2-27 |
| ipv6 address | 35-IPv6管理命令 | 1-18 |
| ipv6 address auto link-local | 35-IPv6管理命令 | 1-18 |
| ipv6 address eui-64 | 35-IPv6管理命令 | 1-19 |
| ipv6 address link-local | 35-IPv6管理命令 | 1-20 |
| ipv6 host | 35-IPv6管理命令 | 1-21 |
| ipv6 icmp-error | 35-IPv6管理命令 | 1-21 |
| ipv6 nd dad attempts | 35-IPv6管理命令 | 1-22 |
| ipv6 nd hop-limit | 35-IPv6管理命令 | 1-22 |
| ipv6 nd ns retrans-timer | 35-IPv6管理命令 | 1-23 |
| ipv6 nd nud reachable-time | 35-IPv6管理命令 | 1-23 |
| ipv6 neighbor | 35-IPv6管理命令 | 1-24 |
| ipv6 neighbors max-learning-num | 35-IPv6管理命令 | 1-25 |
| ipv6 route-static | 35-IPv6管理命令 | 1-25 |
| jitter-interval | 34-HWPing命令 | 1-22 |
| jitter-packetnum | 34-HWPing命令 | 1-23 |
| key | 17-AAA命令 | 1-40 |
| key | 17-AAA命令 | 1-64 |
| lacp enable | 09-端口汇聚命令 | 1-4 |
| lacp port-priority | 09-端口汇聚命令 | 1-5 |
| lacp system-priority | 09-端口汇聚命令 | 1-5 |
| lcd | 30-FTP-SFTP-TFTP命令 | 1-11 |
| ldap-server | 40-PKI命令 | 1-13 |
| level | 17-AAA命令 | 1-19 |
| line-rate | 23-QoS-QoS Profile命令 | 1-11 |
| link-aggregation group | 37-Smart Link-Monitor Link命令 | 1-3 |
| link-aggregation group | 37-Smart Link-Monitor Link命令 | 2-1 |
| link-aggregation group description | 09-端口汇聚命令 | 1-6 |
| link-aggregation group mode | 09-端口汇聚命令 | 1-7 |
| link-delay | 08-端口基本配置命令 | 1-16 |
| lldp admin-status | 39-LLDP命令 | 1-13 |
| lldp check-change-interval | 39-LLDP命令 | 1-13 |
| lldp compliance admin-status cdp | 39-LLDP命令 | 1-14 |
| lldp compliance cdp | 39-LLDP命令 | 1-14 |
| lldp enable | 39-LLDP命令 | 1-15 |
| lldp encapsulation snap | 39-LLDP命令 | 1-15 |
| lldp fast-count | 39-LLDP命令 | 1-16 |
| lldp hold-multiplier | 39-LLDP命令 | 1-16 |
| lldp management-address-tlv | 39-LLDP命令 | 1-17 |
| lldp notification remote-change enable | 39-LLDP命令 | 1-18 |
| lldp timer notification-interval | 39-LLDP命令 | 1-18 |
| lldp timer reinit-delay | 39-LLDP命令 | 1-19 |
| lldp timer tx-delay | 39-LLDP命令 | 1-19 |
| lldp timer tx-interval | 39-LLDP命令 | 1-20 |
| lldp tlv-enable | 39-LLDP命令 | 1-20 |
| locality | 40-PKI命令 | 1-14 |
| local-server | 17-AAA命令 | 1-41 |
| local-server nas-ip | 17-AAA命令 | 1-42 |
| local-user | 17-AAA命令 | 1-19 |
| local-user password-display-mode | 17-AAA命令 | 1-20 |
| lock | 01-登录交换机命令 | 1-12 |
| logging-host | 25-Stack-Cluster命令 | 2-28 |
| loopback | 08-端口基本配置命令 | 1-17 |
| loopback-detection control enable | 08-端口基本配置命令 | 1-17 |
| loopback-detection enable | 08-端口基本配置命令 | 1-18 |
| loopback-detection interface-list enable | 08-端口基本配置命令 | 1-19 |
| loopback-detection interval-time | 08-端口基本配置命令 | 1-20 |
| loopback-detection per-vlan enable | 08-端口基本配置命令 | 1-20 |
| loopback-detection shutdown enable | 08-端口基本配置命令 | 1-21 |
| ls | 30-FTP-SFTP-TFTP命令 | 1-11 |
| ls | 30-FTP-SFTP-TFTP命令 | 1-24 |
| mac-address | 13-MAC地址转发表管理命令 | 1-3 |
| mac-address max-mac-count | 13-MAC地址转发表管理命令 | 1-5 |
| mac-address multicast interface | 15-组播协议命令 | 2-2 |
| mac-address multicast vlan | 15-组播协议命令 | 2-3 |
| mac-address security | 11-端口安全-端口绑定命令 | 1-5 |
| mac-address timer | 13-MAC地址转发表管理命令 | 1-5 |
| mac-authentication | 18-MAC地址认证命令 | 1-3 |
| mac-authentication authmode usernameasmacaddress | 18-MAC地址认证命令 | 1-4 |
| mac-authentication authmode usernamefixed | 18-MAC地址认证命令 | 1-5 |
| mac-authentication authpassword | 18-MAC地址认证命令 | 1-5 |
| mac-authentication authusername | 18-MAC地址认证命令 | 1-6 |
| mac-authentication domain | 18-MAC地址认证命令 | 1-6 |
| mac-authentication guest-vlan | 18-MAC地址认证命令 | 1-9 |
| mac-authentication interface | 18-MAC地址认证命令 | 1-3 |
| mac-authentication max-auth-num | 18-MAC地址认证命令 | 1-11 |
| mac-authentication timer | 18-MAC地址认证命令 | 1-7 |
| mac-authentication timer guest-vlan-reauth | 18-MAC地址认证命令 | 1-11 |
| mac-authentication timer offline-detect | 18-MAC地址认证命令 | 1-8 |
| mac-authenticiaon intrusion-mode block-mac | 18-MAC地址认证命令 | 1-10 |
| mac-vlan enable | 03-VLAN命令 | 1-14 |
| mac-vlan mac-address | 03-VLAN命令 | 1-15 |
| management-vlan | 04-配置管理VLAN命令 | 1-14 |
| management-vlan | 25-Stack-Cluster命令 | 2-29 |
| mdi | 08-端口基本配置命令 | 1-22 |
| messenger | 17-AAA命令 | 1-21 |
| mirrored-to | 23-QoS-QoS Profile命令 | 1-12 |
| mirrored-to vlan | 23-QoS-QoS Profile命令 | 1-13 |
| mirroring-group | 24-镜像命令 | 1-2 |
| mirroring-group mirroring-port | 24-镜像命令 | 1-3 |
| mirroring-group monitor-port | 24-镜像命令 | 1-3 |
| mirroring-group reflector-port | 24-镜像命令 | 1-4 |
| mirroring-group remote-probe vlan | 24-镜像命令 | 1-5 |
| mirroring-port | 24-镜像命令 | 1-5 |
| mkdir | 29-文件系统管理命令 | 1-7 |
| mkdir | 30-FTP-SFTP-TFTP命令 | 1-12 |
| mkdir | 30-FTP-SFTP-TFTP命令 | 1-24 |
| monitor-link group | 37-Smart Link-Monitor Link命令 | 2-2 |
| monitor-port | 24-镜像命令 | 1-6 |
| more | 29-文件系统管理命令 | 1-8 |
| move | 29-文件系统管理命令 | 1-9 |
| multicast static-group interface | 15-组播协议命令 | 1-14 |
| multicast static-group vlan | 15-组播协议命令 | 1-15 |
| multicast static-router-port | 15-组播协议命令 | 1-16 |
| multicast static-router-port vlan | 15-组播协议命令 | 1-16 |
| multicast-source-deny | 15-组播协议命令 | 2-3 |
| multicast-suppression | 08-端口基本配置命令 | 1-22 |
| name | 03-VLAN命令 | 1-5 |
| name | 17-AAA命令 | 1-22 |
| nas-ip | 17-AAA命令 | 1-65 |
| nbns-list | 21-DHCP命令 | 1-25 |
| ndp enable | 25-Stack-Cluster命令 | 2-2 |
| ndp timer aging | 25-Stack-Cluster命令 | 2-3 |
| ndp timer hello | 25-Stack-Cluster命令 | 2-4 |
| netbios-type | 21-DHCP命令 | 1-26 |
| network | 21-DHCP命令 | 1-27 |
| nslookup type | 36-域名解析命令 | 1-6 |
| ntdp enable | 25-Stack-Cluster命令 | 2-8 |
| ntdp explore | 25-Stack-Cluster命令 | 2-9 |
| ntdp hop | 25-Stack-Cluster命令 | 2-9 |
| ntdp timer | 25-Stack-Cluster命令 | 2-10 |
| ntdp timer hop-delay | 25-Stack-Cluster命令 | 2-10 |
| ntdp timer port-delay | 25-Stack-Cluster命令 | 2-11 |
| ntp-service access | 27-NTP命令 | 1-4 |
| ntp-service authentication enable | 27-NTP命令 | 1-5 |
| ntp-service authentication-keyid | 27-NTP命令 | 1-5 |
| ntp-service broadcast-client | 27-NTP命令 | 1-6 |
| ntp-service broadcast-server | 27-NTP命令 | 1-7 |
| ntp-service in-interface disable | 27-NTP命令 | 1-7 |
| ntp-service max-dynamic-sessions | 27-NTP命令 | 1-8 |
| ntp-service multicast-client | 27-NTP命令 | 1-8 |
| ntp-service multicast-server | 27-NTP命令 | 1-9 |
| ntp-service reliable authentication-keyid | 27-NTP命令 | 1-9 |
| ntp-service source-interface | 27-NTP命令 | 1-10 |
| ntp-service unicast-peer | 27-NTP命令 | 1-11 |
| ntp-service unicast-server | 27-NTP命令 | 1-12 |
| open | 30-FTP-SFTP-TFTP命令 | 1-13 |
| option | 21-DHCP命令 | 1-27 |
| organization | 40-PKI命令 | 1-14 |
| organization-unit | 40-PKI命令 | 1-15 |
| packet-filter | 22-ACL命令 | 1-6 |
| packet-filter | 23-QoS-QoS Profile命令 | 2-3 |
| packet-filter vlan | 22-ACL命令 | 1-7 |
| parity | 01-登录交换机命令 | 1-12 |
| passive | 30-FTP-SFTP-TFTP命令 | 1-14 |
| password | 17-AAA命令 | 1-22 |
| password | 34-HWPing命令 | 1-24 |
| peer-public-key end | 28-SSH命令 | 1-9 |
| ping | 32-系统维护与调试命令 | 2-1 |
| ping ipv6 | 35-IPv6管理命令 | 2-1 |
| pki certificate access-control-policy | 40-PKI命令 | 1-15 |
| pki certificate attribute-group | 40-PKI命令 | 1-16 |
| pki delete-certificate | 40-PKI命令 | 1-16 |
| pki domain | 40-PKI命令 | 1-17 |
| pki entity | 40-PKI命令 | 1-17 |
| pki import-certificate | 40-PKI命令 | 1-18 |
| pki request-certificate domain | 40-PKI命令 | 1-19 |
| pki retrieval-certificate | 40-PKI命令 | 1-19 |
| pki retrieval-crl domain | 40-PKI命令 | 1-20 |
| pki validate-certificate | 40-PKI命令 | 1-20 |
| pki-domain | 41-SSL命令 | 1-5 |
| port | 03-VLAN命令 | 1-8 |
| port | 37-Smart Link-Monitor Link命令 | 1-4 |
| port | 37-Smart Link-Monitor Link命令 | 2-3 |
| port access vlan | 03-VLAN命令 | 1-8 |
| port auto-power-down | 32-系统维护与调试命令 | 3-10 |
| port hybrid pvid vlan | 03-VLAN命令 | 1-9 |
| port hybrid vlan | 03-VLAN命令 | 1-10 |
| port isolate | 10-端口隔离命令 | 1-1 |
| port link-aggregation group | 09-端口汇聚命令 | 1-7 |
| port link-type | 03-VLAN命令 | 1-10 |
| port monitor-link group | 37-Smart Link-Monitor Link命令 | 2-4 |
| port smart-link group | 37-Smart Link-Monitor Link命令 | 1-4 |
| port trunk permit vlan | 03-VLAN命令 | 1-11 |
| port trunk pvid vlan | 03-VLAN命令 | 1-12 |
| port-mac | 13-MAC地址转发表管理命令 | 1-6 |
| port-security authorization ignore | 11-端口安全-端口绑定命令 | 1-6 |
| port-security enable | 11-端口安全-端口绑定命令 | 1-6 |
| port-security guest-vlan | 11-端口安全-端口绑定命令 | 1-7 |
| port-security intrusion-mode | 11-端口安全-端口绑定命令 | 1-8 |
| port-security max-mac-count | 11-端口安全-端口绑定命令 | 1-10 |
| port-security ntk-mode | 11-端口安全-端口绑定命令 | 1-11 |
| port-security oui | 11-端口安全-端口绑定命令 | 1-12 |
| port-security port-mode | 11-端口安全-端口绑定命令 | 1-13 |
| port-security timer autolearn | 11-端口安全-端口绑定命令 | 1-15 |
| port-security timer disableport | 11-端口安全-端口绑定命令 | 1-16 |
| port-security timer guest-vlan-reauth | 11-端口安全-端口绑定命令 | 1-16 |
| port-security trap | 11-端口安全-端口绑定命令 | 1-17 |
| prefer-cipher | 41-SSL命令 | 1-6 |
| primary accounting | 17-AAA命令 | 1-43 |
| primary accounting | 17-AAA命令 | 1-65 |
| primary authentication | 17-AAA命令 | 1-44 |
| primary authentication | 17-AAA命令 | 1-66 |
| primary authorization | 17-AAA命令 | 1-67 |
| priority | 23-QoS-QoS Profile命令 | 1-14 |
| priority trust | 23-QoS-QoS Profile命令 | 1-15 |
| priority-trust | 23-QoS-QoS Profile命令 | 1-16 |
| probe-failtimes | 34-HWPing命令 | 1-24 |
| protocol inbound | 01-登录交换机命令 | 1-13 |
| protocol inbound | 28-SSH命令 | 1-9 |
| public-key local create | 28-SSH命令 | 1-10 |
| public-key local destroy | 28-SSH命令 | 1-12 |
| public-key local export dsa | 28-SSH命令 | 1-14 |
| public-key local export rsa | 28-SSH命令 | 1-13 |
| public-key peer | 28-SSH命令 | 1-16 |
| public-key peer import sshkey | 28-SSH命令 | 1-16 |
| public-key-code begin | 28-SSH命令 | 1-17 |
| public-key-code end | 28-SSH命令 | 1-18 |
| put | 30-FTP-SFTP-TFTP命令 | 1-14 |
| put | 30-FTP-SFTP-TFTP命令 | 1-25 |
| pwd | 29-文件系统管理命令 | 1-10 |
| pwd | 30-FTP-SFTP-TFTP命令 | 1-15 |
| pwd | 30-FTP-SFTP-TFTP命令 | 1-25 |
| qos cos-local-precedence-map | 23-QoS-QoS Profile命令 | 1-17 |
| qos dscp-local-precedence-map | 23-QoS-QoS Profile命令 | 1-18 |
| qos-profile | 23-QoS-QoS Profile命令 | 2-4 |
| qos-profile port-based | 23-QoS-QoS Profile命令 | 2-4 |
| queue-scheduler | 23-QoS-QoS Profile命令 | 1-20 |
| quit | 30-FTP-SFTP-TFTP命令 | 1-15 |
| quit | 30-FTP-SFTP-TFTP命令 | 1-26 |
| quit | 32-系统维护与调试命令 | 1-3 |
| radius client | 17-AAA命令 | 1-45 |
| radius nas-ip | 17-AAA命令 | 1-46 |
| radius scheme | 17-AAA命令 | 1-47 |
| radius trap | 17-AAA命令 | 1-48 |
| radius-scheme | 17-AAA命令 | 1-23 |
| reboot | 32-系统维护与调试命令 | 3-11 |
| reboot member | 25-Stack-Cluster命令 | 2-30 |
| region-name | 14-MSTP命令 | 1-10 |
| remotehelp | 30-FTP-SFTP-TFTP命令 | 1-16 |
| remote-probe vlan enable | 24-镜像命令 | 1-7 |
| remove | 30-FTP-SFTP-TFTP命令 | 1-26 |
| rename | 29-文件系统管理命令 | 1-10 |
| rename | 30-FTP-SFTP-TFTP命令 | 1-16 |
| rename | 30-FTP-SFTP-TFTP命令 | 1-27 |
| reset arp | 20-ARP命令 | 1-11 |
| reset counters interface | 08-端口基本配置命令 | 1-23 |
| reset dhcp server conflict | 21-DHCP命令 | 1-28 |
| reset dhcp server ip-in-use | 21-DHCP命令 | 1-28 |
| reset dhcp server statistics | 21-DHCP命令 | 1-29 |
| reset dhcp-snooping | 21-DHCP命令 | 2-10 |
| reset dns dynamic-host | 36-域名解析命令 | 1-7 |
| reset dns ipv6 dynamic-host | 35-IPv6管理命令 | 1-26 |
| reset dot1x statistics | 16-802.1x及System-Guard命令 | 1-18 |
| reset garp statistics | 07-GVRP命令 | 1-5 |
| reset hwtacacs statistics | 17-AAA命令 | 1-68 |
| reset igmp-snooping statistics | 15-组播协议命令 | 1-17 |
| reset ip routing-table statistics protocol | 04-配置管理VLAN命令 | 1-15 |
| reset ip statistics | 05-IP地址-IP性能命令 | 2-13 |
| reset ipv6 neighbors | 35-IPv6管理命令 | 1-26 |
| reset ipv6 statistics | 35-IPv6管理命令 | 1-27 |
| reset lacp statistics | 09-端口汇聚命令 | 1-8 |
| reset logbuffer | 31-信息中心命令 | 1-15 |
| reset mac-authentication | 18-MAC地址认证命令 | 1-8 |
| reset ndp statistics | 25-Stack-Cluster命令 | 2-4 |
| reset radius statistics | 17-AAA命令 | 1-48 |
| reset recycle-bin | 29-文件系统管理命令 | 1-10 |
| reset saved-configuration | 02-配置文件管理命令 | 1-10 |
| reset smart-link packets counter | 37-Smart Link-Monitor Link命令 | 1-5 |
| reset stop-accounting-buffer | 17-AAA命令 | 1-49 |
| reset stop-accounting-buffer | 17-AAA命令 | 1-68 |
| reset stp | 14-MSTP命令 | 1-11 |
| reset tcp ipv6 statistics | 35-IPv6管理命令 | 1-27 |
| reset tcp statistics | 05-IP地址-IP性能命令 | 2-14 |
| reset traffic-limit | 23-QoS-QoS Profile命令 | 1-21 |
| reset traffic-limit vlan | 23-QoS-QoS Profile命令 | 1-22 |
| reset traffic-statistic | 23-QoS-QoS Profile命令 | 1-22 |
| reset traffic-statistic vlan | 23-QoS-QoS Profile命令 | 1-23 |
| reset trapbuffer | 31-信息中心命令 | 1-16 |
| reset udp ipv6 statistics | 35-IPv6管理命令 | 1-28 |
| reset udp statistics | 05-IP地址-IP性能命令 | 2-14 |
| retry | 17-AAA命令 | 1-49 |
| retry realtime-accounting | 17-AAA命令 | 1-50 |
| retry stop-accounting | 17-AAA命令 | 1-51 |
| retry stop-accounting | 17-AAA命令 | 1-69 |
| return | 32-系统维护与调试命令 | 1-4 |
| revision-level | 14-MSTP命令 | 1-12 |
| rmdir | 29-文件系统管理命令 | 1-12 |
| rmdir | 30-FTP-SFTP-TFTP命令 | 1-17 |
| rmdir | 30-FTP-SFTP-TFTP命令 | 1-27 |
| rmon alarm | 26-SNMP-RMON命令 | 2-7 |
| rmon event | 26-SNMP-RMON命令 | 2-9 |
| rmon history | 26-SNMP-RMON命令 | 2-10 |
| rmon prialarm | 26-SNMP-RMON命令 | 2-10 |
| rmon statistics | 26-SNMP-RMON命令 | 2-12 |
| root-certificate fingerprint | 40-PKI命令 | 1-21 |
| rsa local-key-pair create | 28-SSH命令 | 1-18 |
| rsa local-key-pair destroy | 28-SSH命令 | 1-20 |
| rsa peer-public-key | 28-SSH命令 | 1-21 |
| rsa peer-public-key import sshkey | 28-SSH命令 | 1-21 |
| rule (Pki Cert Acp view) | 40-PKI命令 | 1-22 |
| rule comment | 22-ACL命令 | 1-17 |
| rule(二层ACL) | 22-ACL命令 | 1-15 |
| rule(高级ACL) | 22-ACL命令 | 1-10 |
| rule(基本ACL) | 22-ACL命令 | 1-8 |
| save | 02-配置文件管理命令 | 1-10 |
| schedule reboot at | 32-系统维护与调试命令 | 3-12 |
| schedule reboot delay | 32-系统维护与调试命令 | 3-13 |
| schedule reboot regularity | 32-系统维护与调试命令 | 3-14 |
| scheme | 17-AAA命令 | 1-24 |
| scheme lan-access | 17-AAA命令 | 1-25 |
| scheme login | 17-AAA命令 | 1-26 |
| screen-length | 01-登录交换机命令 | 1-14 |
| secondary accounting | 17-AAA命令 | 1-52 |
| secondary accounting | 17-AAA命令 | 1-69 |
| secondary authentication | 17-AAA命令 | 1-53 |
| secondary authentication | 17-AAA命令 | 1-70 |
| secondary authorization | 17-AAA命令 | 1-70 |
| self-service-url | 17-AAA命令 | 1-27 |
| send | 01-登录交换机命令 | 1-14 |
| sendpacket passroute | 34-HWPing命令 | 1-25 |
| send-trap | 34-HWPing命令 | 1-25 |
| server-type | 17-AAA命令 | 1-54 |
| service-type | 01-登录交换机命令 | 1-15 |
| service-type | 17-AAA命令 | 1-27 |
| service-type multicast | 15-组播协议命令 | 1-17 |
| session | 41-SSL命令 | 1-6 |
| set authentication password | 01-登录交换机命令 | 1-16 |
| sftp | 30-FTP-SFTP-TFTP命令 | 1-28 |
| sftp server enable | 30-FTP-SFTP-TFTP命令 | 1-18 |
| sftp timeout | 30-FTP-SFTP-TFTP命令 | 1-19 |
| shell | 01-登录交换机命令 | 1-17 |
| shutdown | 03-VLAN命令 | 1-5 |
| shutdown | 08-端口基本配置命令 | 1-24 |
| smart-link flush enable control-vlan | 37-Smart Link-Monitor Link命令 | 1-5 |
| smart-link group | 37-Smart Link-Monitor Link命令 | 1-6 |
| smart-link group | 37-Smart Link-Monitor Link命令 | 2-4 |
| snmp-agent | 26-SNMP-RMON命令 | 1-10 |
| snmp-agent calculate-password | 26-SNMP-RMON命令 | 1-10 |
| snmp-agent community | 01-登录交换机命令 | 2-2 |
| snmp-agent community | 26-SNMP-RMON命令 | 1-11 |
| snmp-agent group | 01-登录交换机命令 | 2-3 |
| snmp-agent group | 26-SNMP-RMON命令 | 1-12 |
| snmp-agent local-engineid | 26-SNMP-RMON命令 | 1-14 |
| snmp-agent log | 26-SNMP-RMON命令 | 1-14 |
| snmp-agent mib-view | 26-SNMP-RMON命令 | 1-15 |
| snmp-agent packet max-size | 26-SNMP-RMON命令 | 1-17 |
| snmp-agent sys-info | 26-SNMP-RMON命令 | 1-17 |
| snmp-agent target-host | 26-SNMP-RMON命令 | 1-18 |
| snmp-agent trap enable | 26-SNMP-RMON命令 | 1-19 |
| snmp-agent trap ifmib | 26-SNMP-RMON命令 | 1-20 |
| snmp-agent trap life | 26-SNMP-RMON命令 | 1-21 |
| snmp-agent trap queue-size | 26-SNMP-RMON命令 | 1-21 |
| snmp-agent trap source | 26-SNMP-RMON命令 | 1-22 |
| snmp-agent usm-user | 01-登录交换机命令 | 2-4 |
| snmp-agent usm-user { v1 | v2c } | 26-SNMP-RMON命令 | 1-23 |
| snmp-agent usm-user v3 | 26-SNMP-RMON命令 | 1-24 |
| snmp-host | 25-Stack-Cluster命令 | 2-31 |
| source-interface | 34-HWPing命令 | 1-26 |
| source-ip | 34-HWPing命令 | 1-27 |
| source-port | 34-HWPing命令 | 1-27 |
| speed | 01-登录交换机命令 | 1-18 |
| speed | 08-端口基本配置命令 | 1-24 |
| speed auto | 08-端口基本配置命令 | 1-25 |
| ssh authentication-type default | 28-SSH命令 | 1-22 |
| ssh client assign | 28-SSH命令 | 1-23 |
| ssh client first-time enable | 28-SSH命令 | 1-24 |
| ssh server authentication-retries | 28-SSH命令 | 1-25 |
| ssh server compatible-ssh1x enable | 28-SSH命令 | 1-25 |
| ssh server rekey-interval | 28-SSH命令 | 1-26 |
| ssh server timeout | 28-SSH命令 | 1-26 |
| ssh user | 28-SSH命令 | 1-27 |
| ssh user assign | 28-SSH命令 | 1-28 |
| ssh user authentication-type | 28-SSH命令 | 1-29 |
| ssh user service-type | 28-SSH命令 | 1-30 |
| ssh2 | 28-SSH命令 | 1-31 |
| ssl client-policy | 41-SSL命令 | 1-7 |
| ssl server-policy | 41-SSL命令 | 1-8 |
| stacking | 25-Stack-Cluster命令 | 1-3 |
| stacking enable | 25-Stack-Cluster命令 | 1-3 |
| stacking ip-pool | 25-Stack-Cluster命令 | 1-4 |
| stack-port enable | 25-Stack-Cluster命令 | 1-2 |
| startup bootrom-access enable | 29-文件系统管理命令 | 1-16 |
| startup saved-configuration | 02-配置文件管理命令 | 1-12 |
| state | 17-AAA命令 | 1-28 |
| state | 40-PKI命令 | 1-22 |
| state primary | 17-AAA命令 | 1-54 |
| state secondary | 17-AAA命令 | 1-55 |
| static-bind client-identifier | 21-DHCP命令 | 1-29 |
| static-bind ip-address | 21-DHCP命令 | 1-30 |
| static-bind mac-address | 21-DHCP命令 | 1-31 |
| statistics | 34-HWPing命令 | 1-28 |
| statistics keep-time | 34-HWPing命令 | 1-29 |
| stop-accounting-buffer enable | 17-AAA命令 | 1-56 |
| stopbits | 01-登录交换机命令 | 1-18 |
| storm-constrain | 08-端口基本配置命令 | 1-25 |
| storm-constrain control | 08-端口基本配置命令 | 1-26 |
| storm-constrain enable | 08-端口基本配置命令 | 1-27 |
| storm-constrain interval | 08-端口基本配置命令 | 1-27 |
| stp | 14-MSTP命令 | 1-12 |
| stp bpdu-protection | 14-MSTP命令 | 1-14 |
| stp bridge-diameter | 14-MSTP命令 | 1-14 |
| stp compliance | 14-MSTP命令 | 1-15 |
| stp config-digest-snooping | 14-MSTP命令 | 1-16 |
| stp cost | 14-MSTP命令 | 1-18 |
| stp dot1d-trap | 14-MSTP命令 | 1-19 |
| stp edged-port | 14-MSTP命令 | 1-20 |
| stp loop-protection | 14-MSTP命令 | 1-22 |
| stp max-hops | 14-MSTP命令 | 1-23 |
| stp mcheck | 14-MSTP命令 | 1-24 |
| stp mode | 14-MSTP命令 | 1-25 |
| stp no-agreement-check | 14-MSTP命令 | 1-25 |
| stp pathcost-standard | 14-MSTP命令 | 1-27 |
| stp point-to-point | 14-MSTP命令 | 1-28 |
| stp port priority | 14-MSTP命令 | 1-29 |
| stp portlog | 14-MSTP命令 | 1-30 |
| stp portlog all | 14-MSTP命令 | 1-31 |
| stp priority | 14-MSTP命令 | 1-31 |
| stp region-configuration | 14-MSTP命令 | 1-32 |
| stp root primary | 14-MSTP命令 | 1-33 |
| stp root secondary | 14-MSTP命令 | 1-34 |
| stp root-protection | 14-MSTP命令 | 1-35 |
| stp tc-protection | 14-MSTP命令 | 1-36 |
| stp tc-protection threshold | 14-MSTP命令 | 1-37 |
| stp timer forward-delay | 14-MSTP命令 | 1-37 |
| stp timer hello | 14-MSTP命令 | 1-38 |
| stp timer max-age | 14-MSTP命令 | 1-39 |
| stp timer-factor | 14-MSTP命令 | 1-40 |
| stp transmit-limit | 14-MSTP命令 | 1-40 |
| super | 01-登录交换机命令 | 3-4 |
| super authentication-mode | 01-登录交换机命令 | 3-5 |
| super password | 01-登录交换机命令 | 3-5 |
| sysname | 32-系统维护与调试命令 | 1-4 |
| system-guard detect-threshold | 16-802.1x及System-Guard命令 | 3-2 |
| system-guard enable | 16-802.1x及System-Guard命令 | 3-3 |
| system-guard permit | 16-802.1x及System-Guard命令 | 3-3 |
| system-guard timer-interval | 16-802.1x及System-Guard命令 | 3-4 |
| system-monitor enable | 32-系统维护与调试命令 | 3-14 |
| system-view | 32-系统维护与调试命令 | 1-5 |
| tcp ipv6 timer fin-timeout | 35-IPv6管理命令 | 1-28 |
| tcp ipv6 timer syn-timeout | 35-IPv6管理命令 | 1-28 |
| tcp ipv6 window | 35-IPv6管理命令 | 1-29 |
| tcp timer fin-timeout | 05-IP地址-IP性能命令 | 2-15 |
| tcp timer syn-timeout | 05-IP地址-IP性能命令 | 2-15 |
| tcp window | 05-IP地址-IP性能命令 | 2-16 |
| telnet | 01-登录交换机命令 | 1-19 |
| telnet ipv6 | 01-登录交换机命令 | 1-20 |
| telnet ipv6 | 35-IPv6管理命令 | 2-2 |
| terminal debugging | 31-信息中心命令 | 1-16 |
| terminal debugging | 32-系统维护与调试命令 | 1-9 |
| terminal logging | 31-信息中心命令 | 1-17 |
| terminal monitor | 31-信息中心命令 | 1-17 |
| terminal trapping | 31-信息中心命令 | 1-18 |
| test-enable | 34-HWPing命令 | 1-31 |
| test-failtimes | 34-HWPing命令 | 1-32 |
| test-time begin | 34-HWPing命令 | 1-29 |
| test-type | 34-HWPing命令 | 1-30 |
| tftp { ascii | binary } | 30-FTP-SFTP-TFTP命令 | 2-1 |
| tftp get | 25-Stack-Cluster命令 | 2-32 |
| tftp get | 30-FTP-SFTP-TFTP命令 | 2-1 |
| tftp ipv6 | 35-IPv6管理命令 | 2-3 |
| tftp put | 25-Stack-Cluster命令 | 2-32 |
| tftp put | 30-FTP-SFTP-TFTP命令 | 2-2 |
| tftp-server | 25-Stack-Cluster命令 | 2-33 |
| tftp-server acl | 30-FTP-SFTP-TFTP命令 | 2-3 |
| time at | 32-系统维护与调试命令 | 18 |
| time delay | 32-系统维护与调试命令 | 19 |
| timeout | 34-HWPing命令 | 1-32 |
| timer | 17-AAA命令 | 1-57 |
| timer | 25-Stack-Cluster命令 | 2-34 |
| timer quiet | 17-AAA命令 | 1-57 |
| timer quiet | 17-AAA命令 | 1-71 |
| timer realtime-accounting | 17-AAA命令 | 1-58 |
| timer realtime-accounting | 17-AAA命令 | 1-72 |
| timer response-timeout | 17-AAA命令 | 1-59 |
| timer response-timeout | 17-AAA命令 | 1-73 |
| time-range | 22-ACL命令 | 1-18 |
| topology accept | 25-Stack-Cluster命令 | 2-40 |
| topology restore-from | 25-Stack-Cluster命令 | 2-41 |
| topology save-to | 25-Stack-Cluster命令 | 2-41 |
| tos | 34-HWPing命令 | 1-33 |
| tracemac | 25-Stack-Cluster命令 | 2-29 |
| tracert | 32-系统维护与调试命令 | 2-2 |
| tracert ipv6 | 35-IPv6管理命令 | 2-4 |
| traffic-limit | 23-QoS-QoS Profile命令 | 1-23 |
| traffic-limit | 23-QoS-QoS Profile命令 | 2-5 |
| traffic-limit vlan | 23-QoS-QoS Profile命令 | 1-24 |
| traffic-priority | 23-QoS-QoS Profile命令 | 1-25 |
| traffic-priority | 23-QoS-QoS Profile命令 | 2-6 |
| traffic-priority vlan | 23-QoS-QoS Profile命令 | 1-26 |
| traffic-redirect | 23-QoS-QoS Profile命令 | 1-27 |
| traffic-redirect vlan | 23-QoS-QoS Profile命令 | 1-28 |
| traffic-statistic | 23-QoS-QoS Profile命令 | 1-29 |
| traffic-statistic vlan | 23-QoS-QoS Profile命令 | 1-30 |
| ttl | 34-HWPing命令 | 1-33 |
| undelete | 29-文件系统管理命令 | 1-13 |
| unknown-multicast drop enable | 15-组播协议命令 | 2-4 |
| user | 30-FTP-SFTP-TFTP命令 | 1-17 |
| user privilege level | 01-登录交换机命令 | 1-21 |
| user-interface | 01-登录交换机命令 | 1-20 |
| username | 34-HWPing命令 | 1-34 |
| user-name-format | 17-AAA命令 | 1-60 |
| user-name-format | 17-AAA命令 | 1-73 |
| verbose | 30-FTP-SFTP-TFTP命令 | 1-18 |
| version | 41-SSL命令 | 1-8 |
| view | 32-系统维护与调试命令 | 20 |
| virtual-cable-test | 08-端口基本配置命令 | 1-28 |
| vlan | 03-VLAN命令 | 1-6 |
| vlan-assignment-mode | 17-AAA命令 | 1-29 |
| vlan-mapping modulo | 14-MSTP命令 | 1-41 |
| vlan-vpn enable | 33-VLAN-VPN命令 | 1-1 |
| vlan-vpn tunnel | 14-MSTP命令 | 1-42 |
| voice vlan | 06-Voice VLAN命令 | 1-3 |
| voice vlan aging | 06-Voice VLAN命令 | 1-4 |
| voice vlan enable | 06-Voice VLAN命令 | 1-5 |
| voice vlan legacy | 06-Voice VLAN命令 | 1-6 |
| voice vlan mac-address | 06-Voice VLAN命令 | 1-6 |
| voice vlan mode | 06-Voice VLAN命令 | 1-7 |
| voice vlan security enable | 06-Voice VLAN命令 | 1-8 |
| voice-config | 21-DHCP命令 | 1-31 |
| web-authentication customize | 19-Web认证命令 | 1-3 |
| web-authentication cut connection | 19-Web认证命令 | 1-5 |
| web-authentication domain | 19-Web认证命令 | 1-6 |
| web-authentication enable | 19-Web认证命令 | 1-6 |
| web-authentication free-ip | 19-Web认证命令 | 1-7 |
| web-authentication free-user interface | 19-Web认证命令 | 1-8 |
| web-authentication max-connection | 19-Web认证命令 | 1-9 |
| web-authentication move-mode | 19-Web认证命令 | 1-9 |
| web-authentication protocol | 19-Web认证命令 | 1-10 |
| web-authentication select method | 19-Web认证命令 | 1-11 |
| web-authentication timer idle-cut | 19-Web认证命令 | 1-12 |
| web-authentication timer max-online | 19-Web认证命令 | 1-12 |
| web-authentication web-proxy port | 19-Web认证命令 | 1-13 |
| web-authentication web-server | 19-Web认证命令 | 1-14 |
| xmodem get | 32-系统维护与调试命令 | 3-15 |
