H3C S3100-UM[S3100-SI(UM)]系列以太网交换机 命令手册-Release 22XX系列-6W101
05-IP地址-IP性能命令
本章节下载  (177.82 KB)
docurl=/cn/Service/Document_Software/Document_Center/Switches/Catalog/S3100/S3100-SI(UM)/Command/Command_Manual/H3C_S3100-SI(UM)-Release_22XX-6W101/201108/722189_30005_0.htm
05-IP地址-IP性能命令
1 IP地址配置命令
1.1  IP地址配置命令
1.1.1  display ip interface
display ip interface [ interface-type interface-number ]
【描述】
display ip interface命令用来显示三层接口的相关信息。
如果不指定参数,将显示所有三层接口的相关信息。
# 显示VLAN接口1的相关信息。
<Sysname> display ip interface Vlan-interface 1
Vlan-interface1 current state :UP
Line protocol current state :UP
Internet Address is 192.168.0.39/24 Primary
Broadcast address : 192.168.0.255
The Maximum Transmit Unit : 1500 bytes
IP packets input number: 9678, bytes: 475001, multicasts: 7
IP packets output number: 8622, bytes: 391084, multicasts: 0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
表1-1 display ip interface命令显示信息描述表
VLAN接口1当前的物理状态
链路层协议当前状态
Internet Address
接口的IP地址
Broadcast address
接口所在网段的广播地址
接口的最大传输单元
接口接收和发送的报文总数、字节数,组播报文数
接口收到的TTL无效的报文个数
    Echo reply:                               0
    Unreachable:                            0
  Source quench:                        0
  Routing redirect:                       0
    Echo request:                           0
  Router advert:                           0
  Router solicit:                            0
  Time exceed:                            0
  IP header bad:                          0
   Timestamp reply:                      0
   Netmask request:                     0
   Netmask reply:                         0
   Unknown type:                         0
接口上收到的ICMP报文的总数,包括如下报文:
l      Echo reply:Echo应答报文
l      Unreachable:不可达报文
l      Source quench:源站抑制报文
l      Routing redirect:路由重定向报文
l      Echo request :Echo请求报文
l      Router advert:路由广播报文
l      Router solicit:路由请求报文
l      Time exceed:时间超期报文
l      IP header bad :IP报文头错误报文
l      Timestamp request:时间戳请求报文
l      Timestamp reply:时间戳响应报文
l      Information request:信息请求报文
l      Information reply:信息响应报文
l      Netmask request:掩码请求报文
l      Netmask reply:掩码响应报文
l      Unknown type:未知类型报文
1.1.2  display ip interface brief
display ip interface brief [ interface-type [ interface-number ] ]
interface-type:接口类型。
interface-number:接口编号。
【描述】
display ip interface brief用来显示三层接口的基本配置信息。
l              如果不指定接口类型和接口编号,则显示所有三层接口的基本配置信息;
l              如果只指定接口类型,不指定接口编号,则显示该类型所有三层接口的基本配置信息;
l              如果同时指定接口类型和接口编号,则显示指定接口的基本配置信息。
相关配置可参考命令display ip interface
# 显示VLAN接口1的基本配置信息。
<Sysname> display ip interface brief vlan-interface 1
*down: administratively down
(l): loopback
(s): spoofing
 Interface               IP Address     Physical Protocol     Description
 Vlan-interface1         192.168.0.39    up       up           Vlan-inte...
表1-2 display ip interface brief命令显示信息描述表
*down
接口处于管理down状态,即采用shutdown命令关闭了该接口
(s)
接口的欺骗属性,即接口的链路协议状态显示是up的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立的
接口的名称
IP Address
接口的IP地址(如果未配置则显示“unassigned”)
Physical
接口的物理状态
Protocol
接口的链路层协议状态
接口的描述信息。最多可以显示12个字符,如果超过12个字符,那么只显示前9个字符
1.1.3  ip address
ip address ip-address { mask | mask-length }
undo ip address [ ip-address { mask | mask-length } ]
VLAN接口视图/LoopBack接口视图
ip-address:IP地址,点分十进制格式。
mask:接口IP地址相应的子网掩码,点分十进制格式。
mask-length:子网掩码长度,即掩码中连续“1”的个数,取值范围为0~32。
【描述】
ip address命令用来配置VLAN接口/LoopBack接口的IP地址和掩码。undo ip address命令用来删除VLAN接口/LoopBack接口的IP地址和掩码。
缺省情况下,没有为VLAN接口/LoopBack接口配置IP地址。
l          新配置的IP地址将覆盖原有的IP地址。
l          同一设备上VLAN接口和LoopBack接口的IP地址不能在同一网段。
# 配置VLAN接口1的IP地址为129.12.0.1,子网掩码为255.255.255.0。
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] ip address 129.12.0.1 255.255.255.0
2 IP性能配置命令
2.1  IP性能配置命令
2.1.1  display fib
display fib
【描述】
display fib命令用来显示转发信息表(FIB)的所有表项信息。
# 显示FIB转发信息表的所有表项信息。
<Sysname> display fib
Flag:
  U:Usable   G:Gateway    H:Host       B:Blackhole  D:Dynamic    S:Static
  R:Reject   E:Equal cost multi-path   L:Generated by ARP or ESIS
Destination/Mask   Nexthop         Flag TimeStamp     Interface
10.153.17.0/24     10.153.17.99    U    t[37]         Vlan-interface1
10.153.18.88/32    127.0.0.1       GHU  t[37]         InLoopBack0
10.153.18.0/24     10.153.18.88    U    t[37]         LoopBack0
10.153.17.99/32    127.0.0.1       GHU  t[37]         InLoopBack0
127.0.0.0/8        127.0.0.1       U    t[33]         InLoopBack0
表2-1 display fib命令显示信息描述表
Flag
标志:
l      U:表示路由可用
l      G:表示网关路由
l      H:表示本机路由
l      B:表示黑洞路由
l      D:表示动态路由
l      S:表示静态路由
l      R:表示被拒绝的路由,不可用
l      E:表示多路径等价路由
l      L:表示由ARP或ESIS生成的路由
Destination/Mask
目的地址/掩码长度
Nexthop
转发的下一跳地址
TimeStamp
时间戳
转发接口
2.1.2  display fib ip-address
display fib ip-address1 [ { mask1 | mask-length1 } [ ip-address2 { mask2 | mask-length2 } | longer ] | longer ]
ip-address1ip-address2:目的IP地址,点分十进制格式。ip-address1ip-address2共同确定一个地址范围,显示该地址范围内的FIB表项信息。
mask1mask2:子网掩码,点分十进制格式。
mask-length1、mask-length2:子网掩码长度,即掩码中连续“1”的个数,取值范围为0~32。
longer:显示与指定地址/掩码对匹配,且掩码长度大于等于用户输入掩码长度的FIB表项信息。如果不输入掩码,则显示与自然网段的目的地址匹配,且掩码长度大于等于自然网段掩码长度的FIB表项信息。
【描述】
display fib ip-address命令用来显示与指定目的IP地址匹配的转发信息表的表项信息。不指定掩码和掩码长度时,显示与指定目的IP地址最长匹配的FIB转发信息;指定掩码或掩码长度时,显示与指定目的IP地址和掩码精确匹配的FIB转发信息。
# 显示目的地址与12.158.10.0在自然掩码范围内匹配,且掩码长度大于等于8的FIB表项信息。
<Sysname> display fib 12.158.10.0 longer
  Route Entry Count: 1
Flag:
12.158.10.0/24     12.158.10.1     U    t[85391]      Vlan-interface10
# 显示目的地址在12.158.10.0/24和12.158.10.6/24范围内、掩码长度等于24的FIB表项信息。
<Sysname> display fib 12.158.10.0 255.255.255.0 12.158.10.6 255.255.255.0
Flag:
以上显示信息的解释请参见表2-1
2.1.3  display fib acl
display fib acl acl-number
acl-number:基本ACL(Access Control List,访问控制列表)序号,取值范围为2000~2999。
【描述】
display fib acl命令用来显示通过指定访问控制列表过滤的FIB表项信息。关于ACL的配置请参见“ACL”部分的介绍。
# 配置并显示访问控制列表2001。
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 211.71.75.0 0.0.0.255
[Sysname-acl-basic-2001] display acl 2001
Basic ACL  2001, 1 rule
Acl's step is 1
 rule 0 permit source 211.71.75.0 0.0.0.255
# 显示通过访问控制列表2001过滤的FIB表项信息。
<Sysname> display fib acl 2001
Route Entry matched by access-list 2001
  Summary Counts :1
Flag:
211.71.75.0/24     1.1.1.2         GSU  t[250763]     Vlan-interface2
以上显示信息的解释请参见表2-1
2.1.4  display fib |
display fib | { begin | exclude | include } regular-expression
|:用正则表达式对显示信息进行过滤。有关正则表达式的详细介绍请参见本手册“配置文件管理”模块。
begin:显示特定行及其以后的所有行,该特定行必须包含指定正则表达式。
exclude:显示不含指定正则表达式的行。
include:显示包含指定正则表达式的行。
regular-expression:正则表达式,区分大小写。
【描述】
display fib | 命令用来显示通过指定正则表达式过滤的FIB表项信息。
# 显示从包含字符串“169.254.0.0”的表项开始的所有表项信息。
<Sysname> display fib | begin 169.254.0.0
169.254.0.0/16    2.1.1.1     U       t[0]            Vlan-interface1
2.0.0.0/16        2.1.1.1     U       t[0]            Vlan-interface1
以上显示信息的解释请参见表2-1
2.1.5  display fib statistics
【描述】
display fib statistics命令用来显示FIB表项的总数目。
# 显示FIB表项的总数目。
<Sysname> display fib statistics
Route Entry Count : 8
2.1.6  display icmp statistics
【描述】
display icmp statistics命令用来显示ICMP流量统计信息。
相关配置可参考命令display ip interfacereset ip statistics
# 显示ICMP流量统计信息。
<Sysname> display icmp statistics
  Input: bad formats   0                   bad checksum            0
         echo          5                   destination unreachable 0
         source quench 0                   redirects               0
         echo reply    10                  parameter problem       0
         timestamp     0                   information request     0
         mask requests 0                   mask replies            0
         time exceeded 0
  Output:echo          10                  destination unreachable 0
         echo reply    5                   parameter problem       0
         timestamp     0                   information reply       0
         time exceeded 0
表2-2 display icmp statistics 命令显示信息描述表
Input:
bad formats
接收的格式错误报文数
bad checksum
接收的校验和错误报文数
echo
接收的响应请求报文数
接收的目的不可达报文数
source quench
接收的源站抑制报文数
redirects
接收的重定向报文数
echo reply
接收的响应应答报文数
parameter problem
接收的参数错误报文数
timestamp
接收的时间戳报文数
information request
接收的信息请求报文数
mask requests
接收的掩码请求报文数
mask replies
接收的掩码应答报文数
time exceeded
接收的超时报文数
Output:
echo
发送的响应请求报文数
发送的目的不可达报文数
source quench
发送的源站抑制报文数
redirects
发送的重定向报文数
echo reply
发送的响应应答报文数
parameter problem
发送的参数错误报文数
timestamp
发送的时间戳报文数
information reply
发送的信息应答报文数
mask requests
发送的掩码请求报文数
mask replies
发送的掩码应答报文数
time exceeded
发送的超时报文数
2.1.7  display ip socket
display ip socket [ socktype sock-type ] [ task-id socket-id ]
socktype sock-type:显示指定类型套接口的信息。sock-type为套接口类型,取值范围为1~3。其中1表示套接字类型为TCP,2表示套接字类型为UDP,3表示套接字类型为raw IP。
task-id:任务号,取值范围为1~100。
socket-id:套接口号,取值范围为0~3072。
【描述】
display ip socket命令用来显示套接口信息。
# 显示类型为TCP的套接口信息。
<Sysname> display ip socket socktype 1
SOCK_STREAM:
Task = VTYD(18), socketid = 1, Proto = 6,
LA = 0.0.0.0:23, FA = 0.0.0.0:0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_KEEPALIVE SO_SENDVPNID SO_SETKEEPALIVE,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(18), socketid = 2, Proto = 6,
LA = 10.153.17.99:23, FA = 10.153.17.56:1161,
socket option = SO_KEEPALIVE SO_OOBINLINE SO_SENDVPNID SO_SETKEEPALIVE,
socket state = SS_ISCONNECTED SS_PRIV SS_ASYNC
Task = VTYD(18), socketid = 3, Proto = 6,
LA = 10.153.17.99:23, FA = 10.153.17.82:1121,
表2-3 display ip socket命令显示信息描述表
SOCK_STREAM
套接口类型为TCP
SOCK_DGRAM
套接口类型为UDP
SOCK_RAW
套接口类型为raw IP
任务号
socketid
套接口号
Proto
该套接口使用的协议号
LA
本端地址与本端端口号
FA
远端地址与远端端口号
sndbuf
套接口的发送缓冲区大小
rcvbuf
套接口的接收缓冲区大小
sb_cc
发送缓存中现有的数据大小(只有TCP会缓存数据,该值才有用)
rb_cc
接收缓存中现有的数据大小
socket option
套接口选项
socket state
套接口状态
2.1.8  display ip statistics
【描述】
display ip statistics命令用来显示IP流量统计信息。
# 显示IP流量统计信息。
<Sysname> display ip statistics
  Input:   sum            7120             local             112
           bad protocol   0                bad format        0
           bad checksum   0                bad options       0
  Output:  forwarding     0                local             27
           dropped        0                no route          2
           compress fails 0
  Fragment:input          0                output            0
           dropped        0
           fragmented     0                couldn't fragment 0
  Reassembling:sum        0                timeouts          0
表2-4 display ip statistics命令显示信息描述表
Input:
sum
接收的报文总数
local
接收的目的地址是本地的报文数
bad protocol
协议不可达报文数
这里的协议不可达报文是指:目的地址是本机的IP地址,但IP报文头中指定的上层协议本机无法接收处理的报文。(例如在没有启动交换机的三层组播功能时,IGMP报文被认为是协议不可达报文)
bad format
报文头格式错误的IP报文数
IP报文头格式错误包括:报文头中的版本错误,IP报文头小于20字节等等
bad checksum
报文头校验和错误的报文数
bad options
报文头含有选项,但选项内容错误的IP报文数
Output:
forwarding
本机转发的IP报文数
local
本机始发的IP报文数
dropped
发送时丢弃的IP报文数
no route
查不到路由的IP报文数
compress fails
压缩失败的IP报文数
Fragment:
input
接收的分片IP报文数
output
发送的分片IP报文数
dropped
丢弃的分片IP报文数
fragmented
分片成功的IP报文数
couldn't fragment
分片失败的IP报文数
Reassembling:
sum
重组成功的IP报文数
timeouts
重组超时的IP报文数
2.1.9  display tcp statistics
【描述】
display tcp statistics命令用来显示TCP连接的流量统计信息。
相关配置可参考命令display tcp statusreset tcp statistics
# 显示TCP连接的流量统计信息。
<Sysname> display tcp statistics
Received packets:
     Total: 753
     packets in sequence: 412 (11032 bytes)
     window probe packets: 0, window update packets: 0
     checksum error: 0, offset error: 0, short error: 0
     duplicate packets: 4 (88 bytes), partially duplicate packets: 5 (7 bytes)
     out-of-order packets: 0 (0 bytes)
     packets of data after window: 0 (0 bytes)
     packets received after close: 0
     ACK packets: 481 (8776 bytes)
     duplicate ACK packets: 7, too much ACK packets: 0
Sent packets:
     Total: 665
     urgent packets: 0
     control packets: 5 (including 1 RST)
     window probe packets: 0, window update packets: 2
     data packets: 618 (8770 bytes) data packets retransmitted: 0 (0 bytes)
     ACK-only packets: 40 (28 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
表2-5 display tcp statistics显示信息描述表
Received packets
Total
接收的报文总数
packets in sequence
按顺序到达的报文数,括号中为字节数
接收的窗口探测报文数
接收的窗口更新报文数
checksum error
接收的校验和错误报文数
offset error
接收的偏移量错误报文数
short error
接收的报文长度太短的报文数
duplicate packets
接收的完全重复报文数,括号中为字节数
接收的部分重复报文数,括号中为字节数
接收的顺序错乱的报文数,括号中为字节数
落在接收窗口外的报文数,括号中为字节数
在连接关闭后到达的报文数
ACK packets
接收的ACK确认报文数,括号中为字节数
接收的重复的ACK确认报文数
接收的确认未发送数据的ACK报文数
Sent packets
Total
发送的报文总数
urgent packets
发送的紧急数据报文数
control packets
发送的控制报文数,括号中为包含的重传数据报文数
发送的窗口探测报文数
发送的窗口更新报文数
data packets
发送的数据报文数,括号中为字节数
重发的数据报文数,括号中为字节数
ACK-only packets
发送的ACK报文数,括号中为延迟ACK报文数
重传定时器超时次数
重传次数超过限制而丢弃的连接数
Keepalive timeout
存活定时器超时次数
keepalive probe
发送存活探测报文数
存活探测失败而丢弃连接数
发起连接次数
接受连接次数
已建立连接数
Closed connections
已关闭连接数目,括号中为意外丢弃连接数(收到对端SYN之后)、主动连接失败数(收到对端SYN之前)
MD5验证丢弃报文数
MD5验证通过报文数
2.1.10  display tcp status
display tcp status
【描述】
display tcp status命令用来显示全部TCP连接的状态,使用户随时监控TCP连接。
# 显示全部TCP连接状态。
<Sysname> display tcp status
 *: TCP MD5 Connection
TCPCB     Local Add:port         Foreign Add:port       State
03e37dc4  0.0.0.0:4001           0.0.0.0:0              Listening
04217174  100.0.0.204:23         100.0.0.253:65508      Established
表2-6 display tcp status命令显示信息描述表
如果某个连接前有此标识,则表示该TCP连接是采用MD5加密算法认证的连接
TCPCB
TCP控制块
Local Add:port
本地IP地址及端口号
Foreign Add:port
远端IP地址及端口号
TCP连接状态
2.1.11  display udp statistics
【描述】
display udp statistics命令用来显示UDP流量统计信息。
相关配置可参考命令reset udp statistics
# 显示UDP流量统计信息。
<Sysname> display udp statistics
Received packets:
     Total: 26320
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     no socket on port: 0
     total broadcast or multicast packets : 25006
     no socket broadcast or multicast packets: 24989
     not delivered, input socket full: 0
     input packets missing pcb cache: 1314
Sent packets:
     Total: 7187
表2-7 display udp statistics命令显示信息描述表
Received packets:
Total
接收的UDP报文总数
checksum error
校验和出错的报文数
shorter than header
报文长度比报文头短的报文数
报文数据长度超过报文长度的报文数
no socket on port
端口上无SOCKET的单播报文数
总计接收的广播或多播报文数
端口上无SOCKET的广播或多播报文数
因为SOCKET缓冲已经满而没有向上层传送的报文数
没有匹配PCB缓存的报文数
Sent packets:
Total
发送的UDP报文总数
2.1.12  icmp redirect send
icmp redirect send
undo icmp redirect send
【描述】
icmp redirect send命令用来开启设备的ICMP重定向报文的发送功能。undo icmp redirect send命令用来关闭设备的ICMP重定向报文的发送功能。
缺省情况下,ICMP重定向报文发送功能处于开启状态。
# 关闭设备的ICMP重定向报文发送功能。
[Sysname] undo icmp redirect send
2.1.13  icmp unreach send
icmp unreach send
undo icmp unreach send
【描述】
icmp unreach send命令用来开启设备的ICMP目的不可达报文的发送功能。开启该功能后,当交换机不能够给数据报找到路由时,就丢弃这个数据报,然后向发送出这个数据报的源主机发送目的不可达报文。undo icmp unreach send命令用来关闭设备的ICMP目的不可达报文的发送功能。
缺省情况下,ICMP目的不可达报文发送功能处于开启状态。
# 关闭设备的ICMP目的不可达报文发送功能。
[Sysname] undo icmp unreach send
2.1.14  reset ip statistics
reset ip statistics
【描述】
reset ip statistics命令用来清除IP统计信息。当前的IP流量统计信息可以通过display ip statistics命令查看。
# 清除IP统计信息。
<Sysname> reset ip statistics
2.1.15  reset tcp statistics
【描述】
reset tcp statistics命令用来清除TCP流量统计信息。当前的TCP流量统计信息可以通过display tcp statistics命令查看。
# 清除TCP流量统计信息。
<Sysname> reset tcp statistics
2.1.16  reset udp statistics
【描述】
reset udp statistics命令用来清除UDP流量统计信息。当前的UDP流量统计信息可以通过display udp statistics命令查看。
# 清除UDP流量统计信息。
<Sysname> reset udp statistics
2.1.17  tcp timer fin-timeout
undo tcp timer fin-timeout
time-value:TCP finwait定时器的超时时间,取值范围为76~3600,单位为秒。
【描述】
tcp timer fin-timeout命令用来配置TCP finwait定时器超时时间。undo tcp timer fin-timeout命令用来恢复缺省情况。
缺省情况下,TCP finwait定时器的超时时间为675秒。
当TCP的连接状态由FIN_WAIT_1变为FIN_WAIT_2时启动finwait定时器。若finwait定时器超时前仍未收到FIN报文,则TCP连接被终止。
相关配置可参考命令tcp timer syn-timeouttcp window
# 配置TCP finwait定时器的超时时间为800秒。
[Sysname] tcp timer fin-timeout 800
2.1.18  tcp timer syn-timeout
undo tcp timer syn-timeout
time-value:TCP synwait定时器的超时时间,取值范围为2~600,单位为秒。
【描述】
tcp timer syn-timeout命令用来设置TCP synwait定时器超时时间。undo tcp timer syn-timeout命令用来恢复缺省情况。
缺省情况下,TCP synwait定时器的值为75秒。
当发送SYN报文时,TCP启动synwait定时器,若synwait超时前未收到回应报文,则TCP连接将被终止。
相关配置可参考命令tcp timer fin-timeouttcp window
# 设置TCP synwait定时器的超时时间为80秒。
[Sysname] tcp timer syn-timeout 80
2.1.19  tcp window
tcp window window-size
undo tcp window
window-size:TCP连接的收发缓冲区大小,取值范围为1~32,单位为KB(千字节)。
【描述】
tcp window命令用来设置TCP连接的收发缓冲区大小。undo tcp window命令用来恢复缺省情况。
缺省情况下,TCP连接的收发缓冲区大小为8KB。
相关配置可参考命令tcp timer fin-timeouttcp timer syn-timeout
# 设置TCP连接的收发缓冲区大小为3KB。
[Sysname] tcp window 3
