03-IP地址-IP性能命令
本章节下载: 03-IP地址-IP性能命令 (181.55 KB)
1.1.2 display ip interface brief
2.1.10 ip forward-broadcast (Interface view)
2.1.11 ip forward-broadcast (System view)
display ip interface [ interface-type interface-number ]
interface-type interface-number:显示指定接口的相关信息。
【描述】
display ip interface命令用来显示三层接口的相关信息。
如果不指定参数,则显示所有三层接口的相关信息。
# 显示VLAN接口1的相关信息。
<Sysname> display ip interface vlan-interface 1
Vlan-interface1 current state : DOWN
Line protocol current state : DOWN
Internet Address is 1.1.1.1/8 Primary
Broadcast address : 1.255.255.255
The Maximum Transmit Unit : 1500 bytes
input packets : 0, bytes : 0, multicasts : 0
output packets : 0, bytes : 0, multicasts : 0
Request packet: 0
Reply packet: 0
Unknown packet: 0
TTL invalid packet number: 0
ICMP packet input number: 0
Echo reply: 0
Unreachable: 0
Source quench: 0
Routing redirect: 0
Echo request: 0
Router advert: 0
Router solicit: 0
Time exceed: 0
IP header bad: 0
Timestamp request: 0
Timestamp reply: 0
Information request: 0
Information reply: 0
Netmask request: 0
Netmask reply: 0
Unknown type: 0
DHCP packet deal mode: global
表1-1 display ip interface命令显示信息描述表
current state |
接口当前的物理状态 |
Line protocol current state |
网络层协议当前状态 |
Internet Address |
接口的IP地址,IP地址后可携带如下参数: l Primary:表示主IP地址 l Sub:表示从IP地址 |
Broadcast address |
接口所在网段的广播地址 |
The Maximum Transmit Unit |
接口的最大传输单元 |
input packets : 0, bytes : 0, multicasts : 0 output packets : 0, bytes : 0, multicasts : 0 |
接口上接收和发送的单播报文数、字节数以及组播报文数 |
ARP packet input number: 0 Request packet: 0 Reply packet: 0 Unknown packet: 0 |
接口上收到的ARP报文总数,包括: l ARP请求报文 l ARP应答报文 l 未知类型报文 |
TTL invalid packet number |
接口上收到的TTL无效的报文个数 |
ICMP packet input number: 0 Echo reply: 0 Unreachable: 0 Source quench: 0 Routing redirect: 0 Echo request: 0 Router advert: 0 Router solicit: 0 Time exceed: 0 IP header bad: 0 Timestamp request: 0 Timestamp reply: 0 Information request: 0 Information reply: 0 Netmask request: 0 Netmask reply: 0 Unknown type: 0 |
接口上收到的ICMP报文的总数,包括如下报文: l Echo应答报文 l 不可达报文 l 源站抑制报文 l 路由重定向报文 l Echo请求报文 l 路由器通告报文 l 路由器请求报文 l 超时报文 l IP报文头错误报文 l 时间戳请求报文 l 时间戳响应报文 l 信息请求报文 l 信息响应报文 l 掩码请求报文 l 掩码响应报文 l 未知类型报文 |
DHCP packet deal mode |
DHCP报文处理方式,该字段只在支持DHCP的设备上才会出现,取值可以是: l global:表示接口工作在DHCP服务器全局地址池模式 l relay:表示接口工作在DHCP中继模式 |
display ip interface brief [ interface-type [ interface-number ] ]
interface-type:显示指定类型接口的IP基本配置信息。
interface-number:显示指定接口的IP基本配置信息。
【描述】
display ip interface brief用来显示三层接口的IP基本配置信息。
如果不指定接口类型和接口编号,则显示所有三层接口的IP基本配置信息;如果只指定接口类型,不指定接口编号,则显示该类型所有三层接口的IP基本配置信息;如果同时指定接口类型和接口编号,则显示指定接口的IP基本配置信息。
相关配置可参考命令display ip interface。
# 显示VLAN接口1的基本配置信息。
<Sysname> display ip interface brief vlan-interface 1
*down: administratively down
(s): spoofing
Interface Physical Protocol IP Address
Vlan-interface1 up up 1.1.1.1
表1-2 display ip interface brief命令显示信息描述表
*down |
接口处于管理down状态,即采用shutdown命令关闭了该接口 |
(s) |
接口的欺骗属性,即接口的网络层协议状态显示是up的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立的 |
接口的名称 |
Physical |
接口的物理状态 |
Protocol |
接口的网络层协议状态 |
IP Address |
接口的IP地址(如果未配置则显示“unassigned”) |
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
ip-address:接口的IP地址,为点分十进制格式。
mask:接口IP地址相应的子网掩码,为点分十进制格式。
mask-length:子网掩码长度,即掩码中连续“1”的个数,取值范围为0~32。
sub:表示该地址为接口的从IP地址。
【描述】
ip address命令用来配置接口的IP地址。undo ip address命令用来删除接口的IP地址。
缺省情况下,没有为接口配置IP地址。
主从地址的配置关系为:
l 当配置主IP地址时,如果接口上已经有主IP地址,则新配置的地址将覆盖原有的主IP地址,成为新的主IP地址;
l 主、从IP地址可以是同一网段;
l 在删除主IP地址前必须先删除对应的所有从IP地址。
l undo ip address命令中不指定任何参数表示删除该接口的所有IP地址。
l undo ip address ip-address { mask | mask-length }表示删除主IP地址。
l undo ip address ip-address { mask | mask-length } sub表示删除指定的从IP地址。
l 当接口被配置为通过DHCP动态获取IP地址后,不能再给该接口配置从IP地址。
# 指定VLAN接口1的主IP地址为129.12.0.1,从IP地址为202.38.160.1,子网掩码都为255.255.255.0。
[Sysname-Vlan-interface1] ip address 129.12.0.1 255.255.255.0
[Sysname-Vlan-interface1] ip address 202.38.160.1 255.255.255.0 sub
display fib [ | { begin | include | exclude } string | acl acl-number | ip-prefix ip-prefix-name ]
| { begin | include | exclude } string:根据正则表达式显示缓冲区中与指定字符串相关的FIB信息。
l begin表示从第一个包含指定字符串的FIB表项开始显示。
l include表示只显示那些包含指定字符串的FIB表项。
l exclude表示只显示那些不包含指定字符串的FIB表项。
l string为1~256个字符的字符串,区分大小写。
acl acl-number:显示通过指定访问控制列表过滤的FIB信息,acl-number取值范围为2000~2999。
ip-prefix ip-prefix-name:显示通过指定前缀列表过滤的FIB信息,ip-prefix-name为1~19个字符的字符串。
【描述】
display fib命令用来显示FIB转发信息。
如果不选择参数,表示显示所有的FIB转发信息。
# 显示所有的FIB转发信息。
<Sysname> display fib
FIB Table:
Total number of Routes : 4
Flag:
U:Useable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Reject L:Generated by ARP or ESIS
Destination/Mask Nexthop Flag TimeStamp Interface Token
10.2.0.0/16 0.0.0.0 U t[1150900568] Vlan1 invalid
10.2.1.1/32 127.0.0.1 HU t[1150900568] InLoop0 invalid
127.0.0.0/8 127.0.0.1 U t[1150623094] InLoop0 invalid
127.0.0.1/32 127.0.0.1 HU t[1150623094] InLoop0 invalid
表2-1 display fib命令显示信息描述表
Total number of Routes |
FIB表中路由的总数 |
Destination/Mask |
目的地址/掩码长度 |
Nexthop |
转发的下一跳地址 |
Flag |
路由的标志: l U:表示路由可用 l G:表示网关路由 l H:表示主机路由 l B:表示黑洞路由 l D:表示动态路由 l S:表示静态路由 l R:表示是被拒绝的路由,不可用 l L:表示是由ARP或ESIS生成的路由 |
TimeStamp |
时间戳 |
转发接口 |
Token |
LSP索引号 |
# 显示通过访问控制列表2000过滤的FIB转发信息。
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.2.0.0 0.0.255.255
[Sysname-acl-basic-2000] display fib acl 2000
Route entry matched by access-list 2000:
Summary counts: 2
Flag:
# 显示从包含字符串“127”的表项开始的所有FIB表项。
<Sysname> display fib | begin 127
Flag:
# 显示通过abc0前缀列表过滤的FIB转发信息。
[Sysname] ip ip-prefix abc0 permit 10.2.0.0 16
[Sysname] display fib ip-prefix abc0
Route Entry matched by prefix-list abc0:
Summary count: 1
Flag:
display fib ip-address1 [ { mask1 | mask-length1 } [ ip-address2 { mask2 | mask-length2 } | longer ] | longer ]
ip-address1、ip-address2:目的IP地址,点分十进制格式。ip-address1和ip-address2共同确定一个地址范围,显示该地址范围内的FIB表项。
mask1、mask2:IP地址掩码。
mask-length1、mask-length2:IP地址掩码长度,即掩码中连续“1”的个数。
longer:显示与指定地址/掩码对匹配,且掩码长度大于等于用户输入掩码长度的FIB表项。如果不输入掩码,则显示与自然网段的目的地址匹配,且掩码长度大于等于自然网段掩码长度的FIB表项。
【描述】
display fib ip-address命令用来显示与指定目的IP地址匹配的FIB表项。输出信息的每一行代表一条FIB表项。
# 显示目的地址与10.1.0.0在自然掩码范围内匹配的FIB项。
<Sysname> display fib 10.1.0.0 longer
Route Entry Count: 2
Flag:
10.0.0.0/8 0.0.0.0 U t[1141140133] Vlan1 invalid
10.1.1.1/32 127.0.0.1 HU t[1141140133] InLoop0 invalid
以上显示信息的解释请参见表2-1。
display fib statistics
无
【描述】
display fib statistics命令用来显示FIB表项的统计信息。
# 显示FIB表项的统计信息。
<Sysname> display fib statistics
Route Entry Count : 2
表2-2 display fib statistics命令显示信息描述表
Route Entry Count |
FIB表项数目 |
slot slot-number:显示指定槽位的ICMP流量统计信息。slot-number为槽位号。
【描述】
display icmp statistics命令用来显示ICMP流量统计信息。
相关配置可参考命令reset ip statistics和display ip interface。
# 显示ICMP流量统计信息。
<Sysname> display icmp statistics
Input: bad formats 0 bad checksum 0
echo 5 destination unreachable 0
source quench 0 redirects 0
echo reply 10 parameter problem 0
timestamp 0 information request 0
mask requests 0 mask replies 0
time exceeded 0
Output:echo 10 destination unreachable 0
echo reply 5 parameter problem 0
timestamp 0 information reply 0
time exceeded 0
表2-3 display icmp statistics命令显示信息描述表
bad formats |
输入的格式错误报文数 |
bad checksum |
输入的校验和错误报文数 |
echo |
输入/输出的响应请求报文数 |
destination unreachable |
输入/输出的目的不可达报文数 |
source quench |
输入/输出的源站抑制报文数 |
redirects |
输入/输出的重定向报文数 |
echo reply |
输入/输出的响应应答报文数 |
parameter problem |
输入/输出的参数错误报文数 |
timestamp |
输入/输出的时间戳报文数 |
information request |
输入的信息请求报文数 |
mask requests |
输入/输出的掩码请求报文数 |
mask replies |
输入/输出的掩码应答报文数 |
information reply |
输出的信息应答报文数 |
time exceeded |
输入/输出的超时报文数 |
display ip socket [ socktype sock-type ] [ task-id socket-id ] [ slot slot-number ]
socktype sock-type:显示指定类型套接口的信息。sock-type为套接口类型,取值范围为1~3,其中1表示套接字类型为TCP、2表示套接字类型为UDP、3表示套接字类型为raw IP。
task-id:显示指定任务的套接口信息。task-id为任务号,取值范围为1~100。
socket-id:显示指定套接口的信息。socket-id为套接口号,取值范围为0~3072。
slot slot-number:显示指定槽位的套接口信息。slot-number为槽位号。
【描述】
display ip socket命令用来显示套接口信息。
# 显示所有套接口的信息。
<Sysname> display ip socket
SOCK_STREAM:
Task = VTYD(60), socketid = 1, Proto = 6,
LA = 0.0.0.0:23, FA = 0.0.0.0:0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_KEEPALIVE SO_REUSEPORT SO_SENDVPNID(3073) SO_SETKEEPALIVE,
socket state = SS_PRIV SS_ASYNC
Task = HTTP(58), socketid = 1, Proto = 6,
LA = 0.0.0.0:80, FA = 0.0.0.0:0,
socket option = SO_ACCEPTCONN SO_REUSEPORT,
socket state = SS_PRIV SS_NBIO
Task = VTYD(60), socketid = 3, Proto = 6,
LA = 192.168.0.152:23, FA = 192.168.0.208:1099,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 483, rb_cc = 0,
socket option = SO_KEEPALIVE SO_OOBINLINE SO_REUSEPORT SO_SENDVPNID(0) SO_SETKEEPALIVE,
socket state = SS_ISCONNECTED SS_PRIV SS_ASYNC
SOCK_DGRAM:
Task = AGNT(29), socketid = 1, Proto = 17,
LA = 0.0.0.0:161, FA = 0.0.0.0:0,
sndbuf = 9216, rcvbuf = 41600, sb_cc = 0, rb_cc = 0,
socket option = SO_UDPCHECKSUM SO_SENDVPNID(3073),
socket state = SS_PRIV SS_NBIO SS_ASYNC
Task = ROUT(86), socketid = 3, Proto = 17,
LA = 0.0.0.0:520, FA = 0.0.0.0:0,
sndbuf = 1024, rcvbuf = 256000, sb_cc = 0, rb_cc = 0,
socket option = SO_BROADCAST SO_REUSEPORT SO_UDPCHECKSUM SO_SETSRCADDR SO_SENDVPNID(0),
Task = RDSO(75), socketid = 1, Proto = 17,
LA = 0.0.0.0:1024, FA = 0.0.0.0:0,
socket option = SO_UDPCHECKSUM,
Task = TRAP(71), socketid = 1, Proto = 17,
LA = 0.0.0.0:1025, FA = 0.0.0.0:0,
sndbuf = 9216, rcvbuf = 0, sb_cc = 0, rb_cc = 0,
Task = RDSO(75), socketid = 2, Proto = 17,
LA = 0.0.0.0:1812, FA = 0.0.0.0:0,
SOCK_RAW:
Task = ROUT(86), socketid = 2, Proto = 65,
LA = 0.0.0.0, FA = 0.0.0.0,
sndbuf = 32767, rcvbuf = 256000, sb_cc = 0, rb_cc = 0,
socket option = 0,
Task = ROUT(86), socketid = 1, Proto = 2,
socket option = SO_SENDVPNID(0) SO_RCVVPNID(0),
表2-4 display ip socket命令显示信息描述表
SOCK_STREAM |
套接口类型为TCP |
SOCK_DGRAM |
套接口类型为UDP |
SOCK_RAW |
套接口类型为raw IP |
Task |
任务号 |
socketid |
套接口号 |
Proto |
套接口使用的协议号 |
LA |
本端地址与本端端口号 |
FA |
远端地址与远端端口号 |
sndbuf |
套接口的发送缓冲区大小 |
rcvbuf |
套接口的接收缓冲区大小 |
sb_cc |
发送缓冲区中现有的数据大小(只有TCP会缓存数据,该值才有用) |
rb_cc |
接收缓冲区中现有的数据大小 |
socket option |
套接口选项 |
socket state |
套接口状态 |
slot slot-number:显示指定槽位的IP报文统计信息。slot-number为槽位号。
【描述】
display ip statistics命令用来显示IP报文统计信息。
# 显示IP报文统计信息。
<Sysname> display ip statistics
Input: sum 92306 local 89167
bad protocol 0 bad format 0
bad checksum 0 bad options 0
Output: forwarding 415 local 80746
dropped 0 no route 0
compress fails 0
Fragment:input 0 output 0
dropped 0
fragmented 0 couldn't fragment 0
Reassembling:sum 0 timeouts 0
表2-5 display ip statistics命令显示信息描述表
Input: |
sum |
接收报文总数 |
local |
接收的目的地址是本地的报文数 |
bad protocol |
未知协议的报文数 |
bad format |
格式错误的报文数 |
bad checksum |
校验和错误的报文数 |
bad options |
选项错误的报文数 |
Output: |
forwarding |
转发的报文数 |
local |
本地发送报文数 |
dropped |
发送时丢弃的报文数 |
no route |
查不到路由的报文数 |
compress fails |
压缩失败的报文数 |
Fragment: |
input |
接收的分片报文数 |
output |
发送的分片报文数 |
dropped |
丢弃的分片报文数 |
fragmented |
分片成功的报文数 |
couldn't fragment |
分片失败的报文数 |
Reassembling: |
sum |
重组的报文总数 |
timeouts |
重组超时的分片报文数 |
display tcp statistics
无
【描述】
display tcp statistics命令用来显示TCP连接的流量统计信息。
相关配置可参考命令display tcp status,reset tcp statistics。
# 显示TCP连接的流量统计信息。
<Sysname> display tcp statistics
Received packets:
Total: 753
packets in sequence: 412 (11032 bytes)
window probe packets: 0, window update packets: 0
checksum error: 0, offset error: 0, short error: 0
duplicate packets: 4 (88 bytes), partially duplicate packets: 5 (7 bytes)
out-of-order packets: 0 (0 bytes)
packets of data after window: 0 (0 bytes)
packets received after close: 0
ACK packets: 481 (8776 bytes)
duplicate ACK packets: 7, too much ACK packets: 0
Sent packets:
Total: 665
urgent packets: 0
control packets: 5 (including 1 RST)
window probe packets: 0, window update packets: 2
data packets: 618 (8770 bytes) data packets retransmitted: 0 (0 bytes)
ACK-only packets: 40 (28 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections:0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
表2-6 display tcp statistics命令显示信息描述表
Received packets: |
Total |
接收的报文总数 |
packets in sequence |
按顺序到达的报文数,括号中为字节数 |
window probe packets |
接收的窗口探测报文数 |
window update packets |
接收的窗口更新报文数 |
checksum error |
接收的校验和错误报文数 |
offset error |
接收的偏移量错误报文数 |
short error |
接收的报文长度太短的报文数 |
duplicate packets |
接收的完全重复报文数,括号中为字节数 |
partially duplicate packets |
接收的部分重复报文数,括号中为字节数 |
out-of-order packets |
接收的顺序错乱的报文数,括号中为字节数 |
packets of data after window |
落在接收窗口外的报文数,括号中为字节数 |
packets received after close |
在连接关闭后到达的报文数 |
ACK packets |
接收的ACK确认报文数,括号中为字节数 |
duplicate ACK packets |
接收的重复的ACK确认报文数 |
too much ACK packets |
接收的确认未发送数据的ACK报文数 |
Sent packets: |
Total |
发送的报文总数 |
urgent packets |
发送的紧急数据报文数 |
control packets |
发送的控制报文数,括号中为包含的重传数据报文数 |
发送的窗口探测报文数 |
发送的窗口更新报文数 |
data packets |
发送的数据报文数,括号中为字节数 |
data packets retransmitted |
重发的数据报文数,括号中为字节数 |
ACK-only packets |
发送的ACK报文数,括号中为延迟ACK报文数 |
Retransmitted timeout |
重传定时器超时次数 |
connections dropped in retransmitted timeout |
重传次数超过限制而丢弃的连接数 |
Keepalive timeout |
存活定时器超时次数 |
keepalive probe |
发送的存活探测报文数 |
Keepalive timeout, so connections disconnected |
存活定时器超时而中断的连接数 |
Initiated connections |
发起连接次数 |
accepted connections |
接受连接次数 |
established connections |
已建立连接数 |
Closed connections |
已关闭连接数目,括号中为意外丢弃连接数(收到对端SYN之后)、主动连接失败数(收到对端SYN之前) |
Packets dropped with MD5 authentication |
MD5验证丢弃报文数 |
Packets permitted with MD5 authentication |
MD5验证通过报文数 |
display tcp status
无
【描述】
display tcp status命令用来显示所有TCP连接的状态,使用户随时监控TCP连接。
# 显示所有TCP连接状态。
<Sysname> display tcp status
*: TCP MD5 Connection
TCPCB Local Add:port Foreign Add:port State
03e37dc4 0.0.0.0:4001 0.0.0.0:0 Listening
04217174 100.0.0.204:23 100.0.0.253:65508 Established
表2-7 display tcp status命令显示信息描述表
如果某个连接前有此标识,则表示该TCP连接是采用MD5加密算法认证的连接 |
TCPCB |
TCP控制块 |
Local Add:port |
本端IP地址及端口号 |
Foreign Add:port |
对端IP地址及端口号 |
State |
TCP连接的状态 |
display udp statistics
无
【描述】
display udp statistics命令用来显示UDP流量统计信息。
相关配置可参考命令reset udp statistics。
# 显示UDP流量统计信息。
<Sysname> display udp statistics
Received packets:
Total: 0
checksum error: 0
shorter than header: 0, data length larger than packet: 0
unicast(no socket on port): 0
broadcast/multicast(no socket on port): 0
not delivered, input socket full: 0
input packets missing pcb cache: 0
Sent packets:
Total: 0
表2-8 display udp statistics命令显示信息描述表
Received packets: |
Total |
接收的UDP报文总数 |
checksum error |
校验和出错的报文数 |
shorter than header |
报文长度比报文头部短的报文数 |
data length larger than packet |
报文数据长度超过报文长度的报文数 |
unicast(no socket on port) |
端口上无socket的单播报文数 |
broadcast/multicast(no socket on port) |
端口上无socket的广播和组播报文数 |
not delivered, input socket full |
因为socket缓冲区已满而没有向上层传送的报文数 |
input packets missing pcb cache |
没有匹配PCB缓存的报文数 |
Sent packets: |
Total |
发送的UDP报文总数 |
ip forward-broadcast [ acl acl-number ]
acl acl-number:对定向广播报文应用该ACL规则号对应的过滤条件,根据过滤结果决定是否转发该定向广播报文。acl-number取值范围为2000~3999,其中2000到2999是基本ACL规则,3000到3999是高级ACL规则。
ip forward-broadcast命令用来配置允许接口转发定向广播报文。undo ip forward-broadcast命令用来禁止接口转发定向广播报文。
# 配置允许VLAN接口2转发通过ACL 2001过滤的定向广播报文。
[Sysname-Vlan-interface2] ip forward-broadcast acl 2001
无
【描述】
ip forward-broadcast命令用来配置允许设备接收定向广播报文。undo ip forward-broadcast命令用来禁止设备接收定向广播报文。
缺省情况下,禁止设备接收定向广播报文。
# 配置允许设备接收定向广播报文。
[Sysname] ip forward-broadcast
ip redirects enable
undo ip redirects
无
【描述】
ip redirects enable命令用来开启设备的ICMP重定向报文的发送功能。undo ip redirects命令用来关闭设备的ICMP重定向报文的发送功能。
缺省情况下,ICMP重定向报文发送功能处于开启状态。
# 关闭设备的ICMP重定向报文发送功能。
[Sysname] undo ip redirects
The function is disabled!
ip ttl-expires enable
undo ip ttl-expires
无
【描述】
ip ttl-expires enable命令用来开启设备的ICMP超时报文的发送功能。undo ip ttl-expires命令用来关闭设备的ICMP超时报文的发送功能。
缺省情况下,ICMP超时报文发送功能处于开启状态。
需要注意的是,关闭ICMP超时报文发送功能后,设备不会再发送“TTL超时”ICMP差错报文,但“重组超时”ICMP差错报文仍会正常发送。
# 关闭设备的ICMP超时报文发送功能。
[Sysname] undo ip ttl-expires
ip unreachables enable
undo ip unreachables
无
【描述】
ip unreachables enable命令用来开启设备的ICMP目的不可达报文的发送功能。undo ip unreachables命令用来关闭设备的ICMP目的不可达报文的发送功能。
缺省情况下,ICMP目的不可达报文发送功能处于开启状态。
需要注意的是,关闭ICMP发送目的不可达报文功能后,设备不会再发送“网络不可达”和“源站路由失败”的ICMP差错报文,但其他目的不可达报文仍会正常发送。
# 关闭设备的ICMP目的不可达报文发送功能。
[Sysname] undo ip unreachables
slot slot-number:清除指定槽位的IP报文统计信息。slot-number为槽位号。
【描述】
reset ip statistics命令用来清除IP报文统计信息。
相关配置可参考命令display ip statistics和display ip interface。
# 清除IP报文统计信息。
<Sysname> reset ip statistics
无
【描述】
reset tcp statistics命令用来清除TCP连接的流量统计信息。
相关配置可参考命令display tcp statistics。
# 清除TCP连接的流量统计信息。
<Sysname> reset tcp statistics
无
【描述】
reset udp statistics命令用来清除UDP流量统计信息。
# 清除UDP流量统计信息。
<Sysname> reset udp statistics
undo tcp timer fin-timeout
time-value:TCP finwait定时器的超时时间,取值范围为76~3600,单位为秒。
【描述】
tcp timer fin-timeout命令用来配置TCP的finwait定时器超时时间。undo tcp timer fin-timeout命令用来恢复缺省情况。
缺省情况下,TCP finwait定时器的超时时间为675秒。
需要注意的是,finwait定时器的实际超时时间由如下公式决定:
finwait定时器的实际超时时间=(配置的finwait定时器超时时间-75)+配置的synwait定时器超时时间。
相关配置可参考命令tcp timer syn-timeout,tcp window。
# 配置TCP finwait定时器的超时时间为800秒。
[Sysname] tcp timer fin-timeout 800
undo tcp timer syn-timeout
time-value:TCP synwait定时器的超时时间,取值范围为2~600,单位为秒。
【描述】
tcp timer syn-timeout命令用来配置TCP的synwait定时器超时时间。undo tcp timer syn-timeout命令用来恢复缺省情况。
缺省情况下,TCP synwait定时器的超时时间为75秒。
相关配置可参考命令tcp timer fin-timeout,tcp window。
# 配置TCP synwait定时器的超时时间为80秒。
[Sysname] tcp timer syn-timeout 80
tcp window window-size
undo tcp window
window-size:TCP连接的收发缓冲区大小,取值范围为1~32,单位为KB(千字节)。
【描述】
tcp window命令用来设置TCP连接的收发缓冲区大小。undo tcp window命令用来恢复缺省情况。
缺省情况下,TCP连接的收发缓冲区大小为8KB。
相关配置可参考命令tcp timer fin-timeout,tcp timer syn-timeout。
# 设置TCP连接的收发缓冲区大小为3KB。
[Sysname] tcp window 3
