H3C S5600系列以太网交换机 命令手册-Release 1602(V1.02)
17-组播协议命令
本章节下载 17-组播协议命令  (516.68 KB)
17-组播协议命令
  录
1 组播公共配置命令
1.1 组播公共配置命令
1.1.1 display mac-address multicast static
1.1.2 display mpm forwarding-table
1.1.3 display mpm group
1.1.4 display multicast forwarding-table
1.1.5 display multicast routing-table
1.1.6 display multicast-source-deny
1.1.7 mac-address multicast interface
1.1.8 mac-address multicast vlan
1.1.9 mtracert
1.1.10 multicast route-limit
1.1.11 multicast routing-enable
1.1.12 multicast storing-enable
1.1.13 multicast storing-packet
1.1.14 multicast-source-deny
1.1.15 reset multicast forwarding-table
1.1.16 reset multicast routing-table
1.1.17 unknown-multicast drop enable
2 IGMP配置命令
2.1 IGMP配置命
2.1.1 display igmp group
2.1.2 display igmp interface
2.1.3 igmp enable
2.1.4 igmp group-limit
2.1.5 igmp group-policy
2.1.6 igmp group-policy vlan
2.1.7 igmp host-join port
2.1.8 igmp host-join vlan
2.1.9 igmp lastmember-queryinterval
2.1.10 igmp max-response-time
2.1.11 igmp proxy
2.1.12 igmp robust-count
2.1.13 igmp timer other-querier-present
2.1.14 igmp timer query
2.1.15 igmp version
2.1.16 reset igmp group
3 PIM配置命令
3.1 PIM配置命令
3.1.1 bsr-policy
3.1.2 c-bsr
3.1.3 c-rp
3.1.4 crp-policy
3.1.5 display pim bsr-info
3.1.6 display pim interface
3.1.7 display pim neighbor
3.1.8 display pim routing-table
3.1.9 display pim rp-info
3.1.10 pim
3.1.11 pim bsr-boundary
3.1.12 pim dm
3.1.13 pim neighbor-limit
3.1.14 pim neighbor-policy
3.1.15 pim sm
3.1.16 pim timer hello
3.1.17 register-policy
3.1.18 reset pim neighbor
3.1.19 reset pim routing-table
3.1.20 spt-switch-threshold
3.1.21 source-lifetime
3.1.22 source-policy
3.1.23 static-rp
4 MSDP配置命令
4.1 MSDP配置命令
4.1.1 cache-sa-enable
4.1.2 display msdp brief
4.1.3 display msdp peer-status
4.1.4 display msdp sa-cache
4.1.5 display msdp sa-count
4.1.6 import-source
4.1.7 msdp
4.1.8 msdp-tracert
4.1.9 originating-rp
4.1.10 peer connect-interface
4.1.11 peer description
4.1.12 peer mesh-group
4.1.13 peer minimum-ttl
4.1.14 peer request-sa-enable
4.1.15 peer sa-cache-maximum
4.1.16 peer sa-policy
4.1.17 peer sa-request-policy
4.1.18 reset msdp peer
4.1.19 reset msdp sa-cache
4.1.20 reset msdp statistics
4.1.21 shutdown
4.1.22 static-rpf-peer
4.1.23 timer retry
5 IGMP Snooping配置命令
5.1 IGMP Snooping配置命令
5.1.1 display igmp-snooping configuration
5.1.2 display igmp-snooping group
5.1.3 display igmp-snooping statistics
5.1.4 igmp-snooping
5.1.5 igmp-snooping fast-leave
5.1.6 igmp-snooping general-query source-ip
5.1.7 igmp-snooping group-limit
5.1.8 igmp-snooping group-policy
5.1.9 igmp-snooping host-aging-time
5.1.10 igmp-snooping max-response-time
5.1.11 igmp-snooping nonflooding-enable
5.1.12 igmp-snooping querier
5.1.13 igmp-snooping query-interval
5.1.14 igmp-snooping router-aging-time
5.1.15 igmp-snooping version
5.1.16 igmp-snooping vlan-mapping
5.1.17 igmp host-join port
5.1.18 igmp host-join
5.1.19 multicast static-group interface
5.1.20 multicast static-group vlan
5.1.21 multicast static-router-port
5.1.22 multicast static-router-port vlan
5.1.23 reset igmp-snooping statistics
5.1.24 service-type multicast
1 组播公共配置命令
l    新增“组播数据报文存储”功能,请参见1.1.12  multicast storing-enable1.1.13  multicast storing-packet
l    新增“配置组播源生存时间”功能,请参见3.1.21  source-lifetime
l    新增“IGMPv3 Snooping相关功能”,具体请参见5.1.15  igmp-snooping version5.1.18  igmp host-join
l    新增“IGMP Snooping禁止广播”功能,具体请参见5.1.11  igmp-snooping nonflooding-enable
l    新增“静态成员端口”,具体请参见5.1.19  multicast static-group interface5.1.20  multicast static-group vlan
l    新增“静态路由器端口”,具体请参见5.1.21  multicast static-router-port5.1.22  multicast static-router-port vlan
l    新增“配置查询报文的VLAN Tag”,具体请参见5.1.16  igmp-snooping vlan-mapping
1.1  组播公共配置命令
display mac-address multicast static [ [mac-address ] vlan vlan-id ] [ count ] [ unit unit-id ]
mac-address:指定组播MAC地址,通过配置此参数可以显示指定VLAN内的该静态组播MAC地址表项信息。
vlan vlan-id:指定VLAN ID,通过配置此参数可以显示指定VLAN内的某一或所有(取决于是否指定参数mac-address)静态组播MAC地址表项信息。
count:通过配置此关键字可以显示静态组播MAC地址表项的数量。如果指定了参数vlan vlan-id,将显示该VLAN内的静态组播MAC地址表项数量;否则将显示交换机上所有的静态组播MAC地址表项数量。
unit unit-idFabric设备的Unit编号。
【描述】
display mac-address multicast static 命令用来显示交换机上的静态组播MAC地址表项信息。
有关组播MAC地址配置的相关命令请参考mac-address multicast interfacemac-address multicast vlan
# 显示VLAN 1内所有手工配置的组播MAC信息。
<Sysname> display mac-address multicast static vlan 1
MAC ADDR        VLAN ID  STATE          PORT INDEX            AGING TIME(s)
0100-0001-0001  1        Config static  GigabitEthernet1/0/1  NOAGED
                                        GigabitEthernet1/0/2
                                        GigabitEthernet1/0/3
                                        GigabitEthernet1/0/4
---  1 static mac address(es) found  ---
表1-1 display mac-address multicast static命令显示信息描述表
MAC ADDR
MAC地址
VLAN ID
MAC地址所在的VLAN ID
STATE
MAC地址的状态,只包括Config static:表示该表项是用户手工配置的静态表项
PORT INDEX
该MAC地址对应的端口,即表示发往该MAC地址的报文将从此端口发出
AGING TIME(s)
老化时间状态,静态组播MAC地址表项只能有以下状态:
NOAGED:表示该表项不会被老化
display mpm forwarding-table [ group-address ]
group-address:组播组地址,取值范围是224.0.0.0~239.255.255.255,如果配置此参数,显示信息将显示匹配(*,G)的组播转发表项端口信息,否则将显示所有组播转发表含端口信息。
【描述】
display mpm forwarding-table命令用来查看组播转发表端口信息。通过显示信息可以查看交换机上转发某组播流的入接口、出接口以及出端口信息,以便对组播端口进行管理。
相关命令可参考display multicast forwarding-table
# 显示含带端口信息的组播转发表信息。
<Sysname> display mpm forwarding-table
Total 1 entry(entries)
00001. (120.0.0.2, 225.0.0.2)
 iif Vlan-interface1200
 1 oif(s):
  Vlan-interface32
   GigabitEthernet1/0/19
Total 1 entry(entries) Listed
表1-2 display mpm forwarding-table命令显示信息描述
内容说明描述
表项总数
00001
表项序号
(S,G)即(源地址,组地址)
组播转发表的入接口是Vlan-interface1200
1 oif(s):
组播转发表有1个出接口
  Vlan-interface32
第一个出接口为Vlan-interface32,其下的出端口为GigabitEthernet1/0/19
共列出1个(S,G)表项
display mpm group [ vlan vlan-id ]
vlan vlan-id:指定VLAN ID,如果配置此参数,将显示该VLAN内的IGMP组播表项的端口信息;否则将显示所有的IGMP组播表项的端口信息。
【描述】
display mpm group命令用来显示IGMP组播表项的端口信息,以便对组播端口进行管理。
如果用户查看IGMP组播组信息可参考命令display igmp group
# 显示VLAN 1200的组播组信息。
<Sysname> display mpm group vlan 1200
  Total 1 IP Group(s).
  Total 1 MAC Group(s).
  Vlan(id):1200.
    Static Router port(s):
    Dynamic Router port(s):
                     GigabitEthernet1/0/24
    IP group(s):the following ip group(s) match to one mac group.
        IP group address:224.1.1.1
        Static host port(s):
        Dynamic host port(s):
                     GigabitEthernet1/0/22
    MAC group(s):
        MAC group address:0100-5e01-0101
        Host port(s):GigabitEthernet1/0/22
表1-3 display mpm group显示信息描述表
Total 1 IP Group(s)
IP组播组的数量
MAC组播组的数量
  Vlan(id):1200.
在VLAN 1200下存在组播组
静态路由器端口
Dynamic router port(s):
动态路由器端口
IP组播组:下列IP组播组对应同一个MAC组播组
IP group address
IP组播组地址
静态主机成员端口
动态主机成员端口
MAC group(s):
MAC组播组
MAC group address:
MAC组播组地址
Host port(s)
MAC组播组主机成员端口
display multicast forwarding-table [ group-address [ mask { mask | mask-length } ] | source-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } ]*
group-address:组播组地址,取值范围为224.0.0.0~239.255.255.255,通过配置该参数可查看指定组播组的组播转发表项。
source-address:指定组播源地址,通过配置该参数可以查看包含该指定组播源的组播转发表项。
mask:指定组播组或组播源地址的掩码,缺省值为255.255.255.255。
mask-length:指定组播组或组播源地址的掩码长度。对于组播组地址,其取值范围为4~32,缺省值为32;对于组播源地址,其取值范围为0~32,缺省值为32。
incoming-interface:查看入接口为指定接口的转发项。
interface-type interface-number:指定接口的类型和编号,通过设置此参数可查看入接口为指定接口的组播转发表项。
register:通过配置该关键字可以查看入接口为PIM-SM注册接口的组播转发表项。
【描述】
display multicast forwarding-table命令用来查看组播转发表信息。
组播转发表项直接指导着组播数据的转发,通过查看组播转发表信息可以判断组播数据是否正常转发。
相关配置可参考命令display multicast routing-table、display mpm forwarding-tablereset multicast forwarding-table
# 查看组播转发表信息。
<Sysname> display multicast forwarding-table
Multicast Forwarding Cache Table
Total 1 entry: 0 entry created by IP, 1 entry created by protocol
00001. (10.0.0.4, 225.1.1.1), iif Vlan-interface2, 0 oifs,
     Protocol Create
     Matched 122 pkts(183000 bytes), Wrong If 0 pkts
     Forwarded 122 pkts(183000 bytes)
Total 1 entry Listed
表1-4 display multicast forwarding-table显示信息描述表
组播转发表
Total 1 entries
组播转发表中匹配的(S,G)项总数
00001
表示(S,G)项的序号
表示组播转发表的(S,G)项
组播转发表的入接口 vlan-interface 2, 组播转发表没有出接口
122个匹配(s,g)表项的数据包,总共183000字节,0个匹配(s,g)表项的错误的数据包,转发了122个数据包,总共183000字节
display multicast routing-table [ group-address [ mask { mask | mask-length } ] | source-address [ mask { mask | mask-length } ] | incoming-interface { interface-type interface-number | register } ]*
group-address:指定组播组地址,取值范围为224.0.0.0~239.255.255.255,通过配置该参数可查看指定组播组的组播路由表项。
source-address:指定组播源地址,通过配置该参数可以查看包含该指定组播源的组播路由表项。
incoming-interface:通过配置该关键字可以查看入接口为指定接口的组播路由表项。
interface-type interface-number:指定接口的类型和编号,通过设置此参数可查看入接口为指定接口的组播路由表项。
register:通过配置该关键字可以查看入接口为PIM-SM注册接口的组播路由表项。
【描述】
display multicast routing-table命令用来查看组播路由表信息。
组播路由表项是进行组播数据转发的基础,通过查看组播路由表项信息可以判断是否建立了(S,G)表项,出/入接口是否正确。
相关配置可参考命令reset multicast routing-tabledisplay multicast forwarding-table
# 查看组播路由表中的路由项信息。
<Sysname> display multicast routing-table
Multicast Routing Table
Total 3 entries
(4.4.4.4, 224.2.149.17)
    Uptime: 00:15:16, Timeout in 272 sec
    Upstream interface: Vlan-interface1(4.4.4.6)
    Downstream interface list:
      Vlan-interface2(2.2.2.4), Protocol 0x1: IGMP
(4.4.4.4, 224.2.254.84)
    Downstream interface list: NULL
(4.4.4.4, 239.255.2.2)
    Uptime: 00:02:57, Timeout in 123 sec
Matched 3 entries
表1-5 display multicast routing-table显示信息描述表
组播路由表
Total 3 entries
组播路由表共3个表项
组播路由表的(s, g)
持续时间15分钟16秒,在272秒后表项超时
上游接口信息:Vlan-interface1(上游接口的IP地址:4.4.4.6)
下游接口列表:
下游接Vlan-interface2(下游接口的IP地址是2.2.2.4), 该下游接口是IGMP协议加入。
Matched 3 entries
共有3个和配置命令匹配的表项
display multicast-source-deny [ interface interface-type [ interface-number ] ]
interface-type:端口类型。
interface-number:端口编号。
【描述】
display multicast-source-deny命令用来查看端口是否处于组播源端口抑制状态。
l              如果不指定端口类型和端口号,则可以查看交换机上所有端口是否处于组播源端口抑制状态。
l              如果仅指定端口类型,则可以查看该类型各端口是否处于组播源端口抑制状态。
l              如果同时指定端口类型和端口号,则可以查看指定端口是否处于组播源端口抑制状态。
相关配置可参考命令multicast-source-deny
# 显示GigabitEthernet 1/0/1端口的组播源端口抑制状态。
<Sysname> display multicast-source-deny interface GigabitEthernet 1/0/1
GigabitEthernet1/0/1     Multicast-source-deny disabled.
以上信息表示,端口GigabitEthernet1/0/1端口的组播源端口抑制功能为关闭状态。
undo mac-address multicast [ mac-address [ interface interface-list ] vlan vlan-id ]
mac-address:组播MAC地址,形式为H-H-H。
interface-list:指定对应MAC组播组的转发端口列表,表示方式为interface-list={ interface-type interface-number [ to { interface-type interface-number } ] }&<1-10>,其中interface-type为端口类型,interface-number为端口号,它们各自的含义和取值范围请参见本书“端口基本配置”部分的命令参数说明。
vlan vlan-id:指定转发端口所在的VLAN ID,取值范围为14094
【描述】
mac-address multicast interface命令用来创建组播MAC地址表项。undo mac-address multicast interface命令用来删除组播MAC地址表项。
组播表项里面包括了组播地址、转发端口、VLAN等内容。
相关配置可参考命令display mac-address multicast static
# 在交换机上创建组播MAC地址表项,组播地址为0100-5c0a-0805,转发端口为GigabitEthernet 1/0/1,表项所属VLAN为VLAN1。
[Sysname] mac-address multicast 0100-5c0a-0805 interface GigabitEthernet 1/0/1 vlan 1
undo mac-address multicast [ [ mac-address ] vlan vlan-id ]
以太网端口视图
vlan vlan-id:指定当前端口所在的VLAN ID,取值范围为1~4094。
【描述】
mac-address multicast vlan命令用来在当前端口上创建组播MAC地址表项。undo mac-address multicast vlan命令用来删除组播MAC地址表项。
# 在交换机的GigabitEthernet 1/0/1端口上创建组播MAC地址表项,组播地址为0100-1000-1000,表项所属VLAN为VLAN1。
[Sysname] interface GigabitEthernet1/0/1
[Sysname-GigabitEthernet1/0/1] mac-address multicast 0100-1000-1000 vlan 1
1.1.9  mtracert
mtracert source-address [ group-address | last-hop-router-address group-address ]
source-address:指定一个组播流的组播源地址。
group-address:指定一个组播流的组播组地址。
last-hop-router-address:指定最后一跳路由器的地址,缺省值为当前路由器的地址。
【描述】
mtracert命令用来跟踪组播源发送的报文是怎样经过网络最终到达组播接收者。
# 跟踪组播源地址为192.168.4.1的信息。
<Sysname> mtracert 192.168.4.1
 Type Ctrl+C to quit multicast traceroute facility
 From last-hop router(192.168.2.2), trace reverse path to source 192.168.4.1 via RPF rules
 -1 192.168.2.2
   Incoming Interface Address: 192.168.2.2
   Previous-Hop Router Address: 192.168.2.1
   Input packet count on incoming interface: 0
   Output packet count on outgoing interface: 0
   Total number of packets for this source-group pair: 0
   Protocol: PIM
   Forwarding TTL: 0
   Forwarding Code: No error
 -2 192.168.2.1
   Incoming Interface Address: 192.168.3.2
   Previous-Hop Router Address: 192.168.3.1
   Protocol: PIM
   Forwarding TTL: 0
 -3 192.168.3.1
   Incoming Interface Address: 192.168.4.2
   Previous-Hop Router Address: 0.0.0.0
   Protocol: PIM
   Forwarding TTL: 0
表1-6 mtracert命令显示信息描述表
从最后一跳路由器(192.168.2.2)反向跟踪组播源192.168.4.1的路径
-1 192.168.2.2
从最后一跳路由器开始每一跳的出接口地址
Incoming interface address
入接口的IP地址
Previous-hop router address
上一跳的IP地址
入接口收到的组播报文统计
出接口发出的组播报文统计
转发的(S,G)报文统计
Protocol
运行的组播路由协议
Forwarding TTL
报文从出接口转发出去的最小TTL值
Forwarding code
转发代码
multicast route-limit limit
undo multicast route-limit
limit:组播路由表容量限制,取值范围为0~1024。
【描述】
multicast route-limit命令用来限制组播路由表容量。超过限制后,路由器将丢弃新增(S,G)的协议和数据报文。undo multicast route-limit命令用来恢复组播路由表容量限制为缺省值。
缺省情况下,组播路由表容量限制为1024。
如果在配置该命令时,路由表中的路由项已经超过配置值,原路由表中的路由项不会被删除,系统会提示用户当前的路由项数量比配置的多。
如果重复执行该命令,新的配置会覆盖原有的配置。
# 限制组播路由表的容量为100。
[Sysname] multicast route-limit 100
undo multicast routing-enable
【描述】
multicast routing-enable命令用来启动IP组播路由。undo multicast routing-enable命令用来关闭IP组播路由。
缺省情况下,没有启动IP组播路由。
# 启动IP组播路由。
[Sysname] multicast routing-enable
undo multicast storing-enable
【描述】
multicast storing-enable命令用来启动组播数据报文存储机制。undo multicast storing-enable命令用来取消组播数据报文存储机制。
组播数据报文存储机制是指在建立组播转发表项的过程中,将上送至CPU的组播数据报文缓存起来,等到组播转发表项建立好之后,再将缓存起来的数据报文按照组播转发表项转发出去。
缺省情况下,没有启动组播数据报文存储机制。
# 启动IP组播数据报文存储机制。
[Sysname] multicast storing-enable
multicast storing-packet packet-number
packet-number:每个组播转发表项最多缓存的报文个数,取值范围为10~100。
【描述】
multicast storing-packet命令用来指定最多为每个组播转发表项缓存的报文个数。
缺省情况下,为每个组播转发表项最多缓存100个报文
# 指定为每个组播组最多缓存50个报文
[Sysname] multicast storing-packet 50
multicast-source-deny [ interface interface-list ]
undo multicast-source-deny [ interface interface-list ]
系统视图、以太网端口视图
interface-list:转发端口列表,表示方式为interface-list={ interface-type interface-number [ to { interface-type interface-number } ] }&<1-10>,其中interface-type为端口类型,interface-number为端口号,它们各自的含义和取值范围请参见本书“端口基本配置”部分的命令参数说明。
【描述】
multicast-source-deny命令用来在开启组播源端口抑制功能。undo multicast-source-deny命令用来恢复组播源端口抑制功能为缺省状态。
缺省情况下,所有端口的组播源端口抑制功能处于关闭状态。
组播源端口抑制功能是在未授权的组播源端口上过滤组播报文,以防止该端口连接用户私设组播源服务器。
l              在系统视图下使用该命令时,如果不输入interface interface-list参数,则表示开启全局的组播源端口抑制特性,即在交换机所有的端口上开启该特性;如果指定了interface interface-list,则表示开启指定端口的组播源端口抑制特性。
l              在以太网端口视图下使用该命令时,不能输入interface interface-list参数,仅能够打开当前端口的组播源端口抑制特性。
# 在交换机所有端口上开启组播源端口抑制功能。
[Sysname] multicast-source-deny
# 在端口GigabitEthernet 1/0/1到GigabitEthernet 1/0/10、GigabitEthernet 1/0/12上开启组播源端口抑制功能。
[Sysname] multicast-source-deny interface GigabitEthernet 1/0/1 to GigabitEthernet 1/0/10 GigabitEthernet 1/0/12
# 在端口GigabitEthernet 1/0/13上开启组播源端口抑制功能。
[Sysname] interface GigabitEthernet 1/0/13
[Sysname-GigabitEthernet1/0/13] multicast-source-deny
reset multicast forwarding-table [ statistics ] { all | { group-address [ mask { mask | mask-length } ] | source-address [ mask { mask | mask-length  } ] | incoming-interface interface-type interface-number } * }
statistics:如果配置了该关键字,将清除指定组播转发表项的统计信息。否则,将清除指定的组播转发表项。
all:如果配置了该关键字将清除所有的组播转发表项的统计信息或转发表项,否则将根据以下各参数所指定的范围,清除相应的组播转发表项或对应转发表项的统计信息。
group-address:组播组地址,取值范围为224.0.0.0~239.255.255.255。
source-address:指定组播源地址。
mask:通过配置该关键字可指定组播组播地址或组播源地址的掩码。
incoming-interface:清除入接口为指定接口的转发表项或相应的统计信息。
【描述】
reset multicast forwarding-table命令用来清除MFC的转发项或MFC转发项的统计信息。
参数group-addresssource-address的次序可以颠倒,但必须输入合法的group-addresssource-address,否则系统会提示输入错误。
相关配置可参考命令display multicast forwarding-table
# 从MFC转发表中清除组地址为225.5.4.3的转发项。
<Sysname> reset multicast forwarding-table 225.5.4.3
# 从MFC转发表中清除组地址为225.5.4.3的转发项的统计信息。
<Sysname> reset multicast forwarding-table statistics 225.5.4.3
reset multicast routing-table { all | { group-address [ mask { maskmask-length  } ] | source-address [ mask { mask |  mask-length } ] | incoming-interface interface-type interface-number } * }
all:如果配置该关键字,将清除组播路由表中的所有路由项,否则将根据以下各参数所指定的范围,清除相应的组播路由表项。。
【描述】
reset multicast routing-table命令用来清除组播核心路由表的路由项,并删除MFC中相应的转发项。
相关配置可参考命令reset pim routing-tablereset multicast forwarding-tabledisplay multicast forwarding-table
# 从组播核心路由表中清除组地址为225.5.4.3的路由项。
<Sysname> reset multicast routing-table 225.5.4.3
undo unknown-multicast drop enable
【描述】
unknown-multicast drop enable命令启动交换机上的未知组播报文丢弃功能。undo unknown-multicast drop enable命令关闭交换机上的未知组播报文丢弃功能。
缺省情况下,未知组播丢弃功能关闭。
# 启动未知组播报文丢弃功能。
System view: return to user view with Ctrl+Z.
[Sysname] unknown-multicast drop enable
2 IGMP配置命令
2.1  IGMP配置命令
display igmp group [ group-address | interface interface-type interface-number ]
group-address:组播组地址,通过此参数可查看指定IGMP组播组的信息。
interface interface-type interface-number:指定接口的类型和编号,通过设置此参数可查看指定接口的IGMP组播组信息。
【描述】
display igmp group命令用来查看IGMP组播组信息。
如果不指定任何参数,将显示所有组播组的IGMP信息;
相关配置可参考命令igmp host-join
# 查看交换机所有接口上动态加入的组播组信息。
<Sysname> display igmp group
LoopBack0 (20.20.20.20): Total 3 IGMP Groups reported:
  Group Address      Last Reporter   Uptime      Expires
  225.1.1.1           20.20.20.20     00:02:04    00:01:15
  225.1.1.3           20.20.20.20     00:02:04    00:01:15
  225.1.1.2           20.20.20.20     00:02:04    00:01:17
表2-1 display igmp group命令显示信息描述表
Group address
组播组地址
Last Reporter
报告成为组播组成员的最后一个主机
Uptime
发现组播组以来的时间(时、分、秒)
Expires
记录将从IGMP组表中删除的预定时间(时、分、秒)
display igmp interface [ interface-type interface-number ]
interface-type interface-number:指定接口的类型和编号,通过配置该参数可查看指定接口上IGMP配置和运行信息。如果不配置该参数,将显示所有运行IGMP的接口的信息。
【描述】
display igmp interface命令用来显示接口的IGMP配置和运行信息。
# 查看接口Vlan-interface 1上的IGMP配置和运行信息。
<Sysname> display igmp interface Vlan-interface 1
Vlan-interface1 (10.153.17.99):
  IGMP is enabled
  Current IGMP version is 2
  Value of query interval for IGMP(in seconds): 60
  Value of other querier time out for IGMP(in seconds): 120
  Value of maximum query response time for IGMP(in seconds): 10
  Value of robust count for IGMP: 2
  Value of startup query interval for IGMP(in seconds): 15
  Value of last member query interval for IGMP(in seconds): 1
  Value of query timeout for IGMP version 1(in seconds): 400
  Policy to accept IGMP reports: none
  Querier for IGMP: 10.153.17.99 (this router)
  IGMP group limit is 256
  Total 1 IGMP group reported
表2-2 display igmp interface显示信息描述表
接口名(IP地址)
IGMP is enabled
IGMP已经启动,如果该接口没有启动IGMP,将没有以下的显示信息
当前接口运行的IGMP版本为2(缺省值),目前包括两个版本:
l      IGMPv1
l      IGMPv2
Value of query interval for IGMP(in seconds):60
发送IGMP通用查询报文的时间间隔(秒):60(缺省值)
Value of other querier time out for IGMP(in seconds):120
IGMP非查询器的存在时间(秒):120(缺省值)
Value of maximum query response time for IGMP(in seconds):10
IGMP通用查询的最大响应时间(秒):10(缺省值)
Value of robust count for IGMP:2
IGMP健壮系数为2(缺省值),即IGMP查询器在收到主机发送的IGMP 离开报文时,发送IGMP特定组查询报文的次数
Value of startup query interval for IGMP(in seconds):15
IGMP首次发送通用查询报文的时间间隔(秒):15(缺省值)
Value of last member query interval for IGMP(in seconds):1
IGMP查询器在收到主机发送的IGMP 离开报文时,发送IGMP特定组查询报文的时间间隔:1(缺省值)
Value of query timeout for IGMP version 1(in seconds):400
IGMP版本1中查询超时时间:400(缺省值)
Policy to accept IGMPreports:none
IGMP组播组的过滤策略,以控制对IP组播组的访问,如果没有则显示“none”,有则按照相应的策略,例如显示信息“acl 2000, only for IGMP version 1”表示只对IGMPv1的报告报文应用ACL2000的过滤策略
Querier for IGMP :10.1.0.5 (this router)
IGMP查询器:10.1.0.5(此路由器)
IGMP group limit:256
VLAN接口上加入的IGMP组的数量限制,超过限制后路由器不再处理IGMP加入报文:256(缺省值)
接口上记录的IGMP组播组数量
2.1.3  igmp enable
igmp enable
undo igmp enable
【描述】
igmp enable命令用来在接口上启动IGMP。undo igmp enable命令用来关闭接口上的IGMP。
缺省情况下,接口上没有启动IGMP。
只有先启动组播路由,此命令才能配置。配置了此命令后,才能进行其他IGMP各种功能的配置。
相关配置可参考命令multicast routing-enable
# 在Vlan-interface 10接口上启动IGMP。
[Sysname] interface Vlan-interface 10
[Sysname-Vlan-interface10] igmp enable
igmp group-limit limit
undo igmp group-limit
limit:指定接口上可以加入的IGMP组播组的数量,取值范围为0~256。
【描述】
igmp group-limit命令用来配置接口可以通过的组播组最大数量,超过限制后路由器不再处理IGMP加入报文。undo igmp group-limit命令用来恢复缺省设置。
缺省情况下,接口上可以通过的组播组最大数量为256。
重复执行该命令,新的配置将覆盖原有配置。
l    在接口配置可以通过的组播组最大数量时,如果接口已有的IGMP组播组已经达到最大值,将不允许新的组播组加入。
l    如果用户在接口上配置的IGMP组的数量为1时,采用新加入组优先的原则。即如用户将新的组播组加入接口时,系统将自动取代原有的组播组,原组播组将会自动脱离接口。
l    在接口配置可以通过的组播组最大数量时,如果接口已有的IGMP组播组比要配置的值多,系统自动删除某些已有的组播组,直到接口组播组数量符合配置的数量限制。
# 配置接口Vlan-interface10上可以通过组播组最大数量为100。
[Sysname-Vlan-interface10] igmp group-limit 100
igmp group-policy acl-number [ 1 | 2 | port interface-list ]
undo igmp group-policy [ port interface-list ]
acl-number:基本IP访问控制列表号,定义一个组播组范围。取值范围为2000~2999。
1:指定接口只接收IGMPv1的成员关系报告报文。
2:指定接口只接收IGMPv2的成员关系报告报文。如果不指定IGMP版本,则缺省使用IGMP版本2。
port:通过该端口的且符合ACL条件的IGMP报文被限制。
在LooBack接口视图下配置该命令没有port参数
【描述】
igmp group-policy命令用来在接口上设置组播组的过滤功能,以控制对指定组播组的访问。undo igmp group-policy命令用来取消该过滤功能。
缺省情况下,没有启动组播组过滤功能,即主机可以加入任一组播组。
如果不希望接口所在网络上的主机加入某些组播组并接收这些组的报文,可以使用这条命令限制接口所服务的组播组范围。
以太网端口必须属于配置此命令的VLAN接口,不能属于其他VLAN接口。
# 配置接口Vlan-interface1所在网段上的主机只能加入组播组225.1.1.1,并且该接口只接收IGMPv2的报告报文。
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 225.1.1.1 0
[Sysname-acl-basic-2000] quit
[Sysname-Vlan-interface10] igmp group-policy 2000 2
igmp group-policy acl-number vlan vlan-id
undo igmp group-policy vlan vlan-id
以太网端口视图
vlan vlan-id:指定该端口所在VLAN的ID,vlan-id为指定VLAN的编号,取值范围为1~4094。
【描述】
igmp group-policy vlan命令用来在端口上设置组播组的过滤功能,以控制对指定组播组的访问。undo igmp group-policy vlan命令用来取消该过滤功能。
如果不希望端口所在网络上的主机加入某些组播组并接收这些组的报文,可以使用这条命令限制端口所服务的组播组范围。此命令实现的功能与igmp group-policy命令相同。
需要注意的是:配置此命令的端口必须属于指定的VLAN,并且该VLAN接口启动了IGMP协议,否则配置将不起作用。
相关配置可参考命令igmp group-policyigmp host-join portigmp host-join vlan
# 配置Vlan10内的端口GigabitEthernet1/0/1下的主机只能加入到组播组225.1.1.1 。
[Sysname-GigabitEthernet1/0/1] port access vlan 10
[Sysname-GigabitEthernet1/0/1] igmp group-policy 2000 vlan 10
igmp host-join group-address port interface-list
undo igmp host-join group-address port  interface-list
group-address:组播组地址,通过配置此参数可指定模拟主机要加入的组播组地址。
port:指定该VLAN接口下启动模拟主机加入功能的端口。
【描述】
igmp host-join port命令用来在接口视图下配置IGMP模拟主机加入功能,所谓的模拟主机加入就是将指定的交换机的端口配置成为组播组的成员。undo igmp host-join port命令用来取消该配置。
缺省情况下,没有启动配置IGMP模拟主机加入功能。
# 将VLAN接口Vlan-interface10包含的以太网端口GigabitEthernet1/0/1加入组播组225.0.0.1。
[Sysname-Vlan-interface10] igmp host-join 225.0.0.1 port GigabitEthernet 1/0/1
igmp host-join group-address vlan vlan-id
undo igmp host-join group-address vlan vlan-id
以太网端口视图
【描述】
igmp host-join vlan命令用来在端口视图下配置IGMP模拟主机加入功能。undo igmp host-join vlan命令用来取消该配置。
缺省情况下,没有启动配置模拟主机加入功能。
有关模拟主机加入的概念,请参见2.1.7  igmp host-join port命令部分。
# 将VLAN10内的以太网端口GigabitEthernet 1/0/1加入组播组225.0.0.1。
[Sysname-GigabitEthernet1/0/1] igmp host-join 225.0.0.1 vlan 10
igmp lastmember-queryinterval seconds
undo igmp lastmember-queryinterval
seconds:IGMP查询器在收到主机发送的IGMP 离开报文时,发送IGMP特定组查询报文的时间间隔,取值范围为1~5秒。
【描述】
igmp lastmember-queryinterval命令用来设置IGMP查询器在收到主机发送的IGMP离开报文时,发送IGMP特定组查询报文的时间间隔。undo igmp lastmember-queryinterval命令用来恢复缺省值。
缺省情况下,IGMP查询器发送IGMP特定组查询报文的时间间隔是1秒。
相关配置可参考命令igmp robust-countdisplay igmp interface
# 在Vlan-interface 10上配置查询器最后组成员查询间隔时间为3秒。
[Sysname-Vlan-interface10] igmp lastmember-queryinterval 3
igmp max-response-time seconds
undo igmp max-response-time
seconds:IGMP查询报文中的最大响应时间,单位为秒,取值范围为1~25。
【描述】
igmp max-response-time命令用来配置IGMP查询报文中包含的最大响应时间。 undo igmp max-response-time命令用来恢复缺省值。
缺省情况下,IGMP查询报文的最大相应时间为10秒。
相关配置可参考命令display igmp interface
# 在Vlan-interface10上配置IGMP通用查询报文的最大响应时间为8秒。
[Sysname-Vlan-interface10] igmp max-response-time 8
2.1.11  igmp proxy
igmp proxy interface-type interface-number
undo igmp proxy
interface-type interface-number:指定接口的类型和编号,通过配置此参数可指定被代理接口的类型和编号。
【描述】
igmp proxy命令用来指定末梢三层交换机的一个接口作为另一个接口的IGMP代理接口。undo igmp proxy命令用来取消该配置。
缺省情况下,没有配置IGMP代理功能。
配置igmp proxy前需要先在接口上启动PIM。同一个接口不能作为两个或两个以上其它接口的IGMP代理接口。
如果为同一接口配置多次IGMP代理接口,以最后一次配置为准。
相关配置可参考命令pim neighbor-policy
# 配置三层交换机的Vlan-interface 2接口的IGMP代理接口为Vlan-interface 1。
[Sysname-Vlan-interface1] pim dm
[Sysname-Vlan-interface1] igmp enable
[Sysname- Vlan-interface1] igmp proxy vlan-interface 2
igmp robust-count robust-value
undo igmp robust-count
robust-value:IGMP健壮系数,反映IGMP查询器在收到主机发送的IGMP 离开报文时,发送IGMP特定组查询报文的次数。取值范围为2~5次。
【描述】
igmp robust-count命令用来设置IGMP查询器在收到主机发送的IGMP 离开报文时,发送IGMP特定组查询报文的次数。undo igmp robust-count命令用来恢复缺省值。
缺省情况下,IGMP查询器发送IGMP特定组查询报文的次数是2次。
相关配置可参考命令igmp lastmember-queryintervaldisplay igmp interface
# 在Vlan-interface 10接口上配置查询器健壮系数为3。
[Sysname-Vlan-interface10] igmp robust-count 3
igmp timer other-querier-present seconds
undo igmp timer other-querier-present
seconds:IGMP查询器存在时间,取值范围为1~131070秒。
【描述】
igmp timer other-querier-present命令用来设置IGMP查询器存在时间。undo igmp timer other-querier-present命令用来恢复缺省值。
缺省情况下,该值是IGMP查询消息间隔的2倍,一般为120秒。
在共享网络上,即同一网段上有多个组播路由器时,由查询器(负责在VLAN接口上定期发送查询消息,如果在有效时间内,其他非查询器收不到查询器查询消息,就认为原查询器失效,自己可以充当查询器。
在IGMP版本1中,查询器的选择由组播路由协议决定。在IGMP版本2中,共享网段上IP地址最低的路由器充当查询器。
相关配置可参考命令igmp timer querydisplay igmp interface
# 配置查询器的存活时间为300秒。
[Sysname-Vlan-interface10] igmp timer other-querier-present 300
igmp timer query seconds
undo igmp timer query
seconds:指定接口发出IGMP通用查询消息的时间间隔,取值范围为1~65535秒。
【描述】
igmp timer query命令用来配置路由器接口发送IGMP查询消息的时间间隔。undo igmp timer query命令用来恢复缺省值。
缺省情况下,路由器接口发送IGMP查询消息的时间间隔为60秒。
组播路由器每隔一段时间就发送IGMP通用查询报文,以判断网络上是否有组播组成员。可以根据网络的实际情况来修改查询时间间隔。
相关配置可参见命令igmp timer other-querier-present
# 将VLAN-interface2接口上的IGMP通用查询报文发送间隔设置为150秒。
[Sysname] interface Vlan-interface 2
[Sysname-Vlan-interface2] igmp timer query 150
2.1.15  igmp version
igmp version { 1 | 2 }
undo igmp version
1:IGMP版本1。
2:IGMP版本2。
【描述】
igmp version命令用来指定运行的IGMP版本。undo igmp version命令用来恢复缺省值。
缺省情况下,系统的缺省版本为IGMP版本2。
IGMP各版本之间不能自动转换。因此,应该配置子网上的所有路由器使用同一IGMP版本。
# 在VLAN-interface10接口上运行IGMP版本1。
[Sysname-Vlan-interface10] igmp version 1
reset igmp group { all | interface interface-type interface-number { all | group-address [ group-mask ] } }
all:前一个all表示清除所有接口上的IGMP组播组信息,后一个all则表示清除所有IGMP组播组的信息。
interface-type interface-number:指定接口类型和接口编号,通过配置此参数可清除指定接口上的IGMP组播组。
group-address:组播组地址,取值范围为224.0.0.0~239.255.255.255,通过配置此参数可清除指定的组播组。
group-mask:组播组地址的网段掩码,缺省值为255.255.255.255。
【描述】
reset igmp group命令用来删除接口上已经加入的IGMP组。删除组后,不影响该组的再次加入。
# 删除所有接口上的所有IGMP组。
<Sysname> reset igmp group all
# 删除Vlan-interface10接口上的所有IGMP组。
<Sysname> reset igmp group interface Vlan-interface10 all
# 删除Vlan-interface10接口上的组225.0.0.1。
<Sysname> reset igmp group interface Vlan-interface10 225.0.0.1
# 删除Vlan-interface10接口上范围在225.1.1.0到225.1.1.255网段之间的IGMP组。
<Sysname> reset igmp group interface Vlan-interface10 225.1.1.0 255.255.255.0
3 PIM配置命令
3.1  PIM配置命令
3.1.1  bsr-policy
bsr-policy acl-number
undo bsr-policy
PIM视图
acl-number:BSR过滤策略所使用的ACL号,取值范围为2000~2999。
【描述】
bsr-policy命令用来限定合法BSR的范围,防止BSR欺骗。undo bsr-policy命令用来恢复正常状态,不做任何范围限制,认为接收到的所有消息都是合法的。
在使用BSR机制的PIM SM网络中,任何一台路由器都可以将自己设置为C-BSR,且一旦竞争获胜就会掌管网络中RP信息的发布权。为了防止网络中合法的BSR被恶意取代,需要采取以下两方面的措施:
l              防止主机通过伪造合法BSR报文欺骗路由器,改变RP映射关系。由于BSR报文是组播报文,TTL为1,因此这种攻击通常发生在边缘路由器上。由于BSR在网络内部,主机在外部,因此通过对BSR报文进行邻居检查和RPF检查可以防止此类攻击。
l              如果网络中某台路由器被攻击者控制,或者有非法接入的路由器,攻击者可以将此路由器设置为C-BSR,并且使其在竞争中获胜,从而控制网络中RP信息的发布权。由于路由器被配置为C-BSR后会自动向全网扩散BSR消息,而BSR报文是逐跳转发的TTL为1的组播报文,因此只要其邻居路由器不接收此BSR消息,就不会影响整个网络。解决的办法就是在全网每一台路由器上配置bsr-policy,限定合法的BSR范围,如:只允许1.1.1.1/32和1.1.1.2/32作为BSR,这样路由器就不会接收和转发除此以外的其他的BSR消息,合法的BSR也不会与其竞争。
以上两种方法可以部分地保护网络中BSR的安全性。但是如果某台合法的BSR路由器被攻击者控制,还是可能导致问题。
相关rule命令中的source参数在bsr-policy命令中解析为BSR地址。
# 在路由器上配置BSR过滤策略,只允许101.1.1.1/32充当BSR,其他都是非法的。
[Sysname] pim
[Sysname-pim] bsr-policy 2000
[Sysname-pim] quit
[Sysname-acl-basic-2000] rule 0 permit source 101.1.1.1 0
3.1.2  c-bsr
c-bsr interface-type interface-number hash-mask-len [ priority ]
undo c-bsr
PIM视图
interface-type interface-number:指定接口类型和接口编号,通过配置此参数可将该接口配置成为C-BSR。该接口上必须使能了PIM-SM,该配置才能够生效。
hash-mask-len:指定计算RP的哈希掩码长度,取值范围为0~32。
priority:指定C-BSR的优先级,取值范围为0~255,缺省值为0。
【描述】
c-bsr命令用来配置某接口为C-BSR。undo c-bsr命令用来删除C-BSR的相关配置。
缺省情况下,没有配置C-BSR。
配置候选BSR时,考虑到BSR和PIM域中其他的设备需要交换大量信息,因此较高的带宽保证是必须的。
相关配置可参考命令pim sm
# 把交换机接口Vlan-interface 10 配置成C-BSR(该C-BSR的哈希掩码长度为24,优先级为2)。
[Sysname] pim
[Sysname-pim] c-bsr vlan-interface 10 24 2
3.1.3  c-rp
c-rp interface-type interface-number [ group-policy acl-number | priority priority-value ]*
undo c-rp { interface-type interface-number | all }
PIM视图
interface-type interface-number:指定接口类型和接口编号。该接口的IP地址将被通告为C-RP的地址。
group-policy:通过配置该关键字可指定该接口作为RP所服务的组播组范围。
acl-number:基本访问控制列表号,取值范围为2000~2999,它定义了一个组范围,该范围是被通告RP的服务范围。
priority priority-value:指定C-RP的优先级,取值范围为0~255,缺省值为0。该数值越大,优先级越低。
all:取消所有候选RP的配置。
【描述】
c-rp命令用来配置某接口为C-RP。undo c-rp命令用来删除C-RP的相关配置。
缺省情况下,没有配置C-RP。
配置候选RP时,应在该路由器与PIM域中的其它设备之间保留较大的通信带宽。
相关配置可参考命令c-bsr
# 配置交换机将其在PIM域中作为C-RP的消息通告给BSR。基本访问控制列表2000指定了与RP有联系的组范围,C-RP的地址指定为VLAN-interface10接口的IP地址。
[Sysname-acl-basic-2000] rule permit source 225.0.0.0 0.255.255.255
[Sysname] pim
[Sysname-pim] c-rp vlan-interface 10 group-policy 2000
3.1.4  crp-policy
crp-policy acl-number
undo crp-policy
PIM视图
acl-number:指定高级访问控制列表编号,取值范围为3000~3999。在定义该ACL时,使用rule命令中的source参数来指定C-RP的地址,destination参数来指定该C-RP所服务的组播组地址范围。
【描述】
crp-policy命令用来配置合法的C-RP地址范围及其所服务的组播组范围,以防止C-RP欺骗。undo crp-policy命令用来取消C-RP地址范围及其所服务的组播组范围的限制。
缺省情况下,C-RP地址范围及其所服务的组播组范围不受任何限制,即认为所有收到的C-RP报文都是合法的。
# 配置合法的C-RP地址范围及其所服务的组播组范围,只允许1.1.1.1/32充当C-RP,并只允许其为225.1.0.0/16范围内的组播组服务。
[Sysname] pim
[Sysname-pim] crp-policy 3000
[Sysname-pim] quit
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule 0 permit source 1.1.1.1 0 destination 225.1.0.0 0.0.255.255
【描述】
display pim bsr-info命令用来显示自举路由器(BSR)信息。
相关配置可参考命令c-bsrc-rp
# 显示BSR的信息。
<Sysname> display pim bsr-info
  Current BSR Address: 20.20.20.30
             Priority: 0
          Mask Length: 30
              Expires: 00:01:55
  Local host is BSR
表3-1 display pim bsr-info显示信息描述表
Current BSR Address
自举路由器地址
Priority
优先级
Mask Length: 30
掩码长度
Expires: 00:01:55
定时器时间
Local host is BSR
当前该设备为BSR
display pim interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号,通过配置此参数可查看指定接口的PIM信息。
【描述】
display pim interface命令用来查看接口上的PIM信息。
如果没有指定接口类型和接口编号,该命令将显示出所有接口的PIM信息。
# 显示所有接口的PIM配置信息。
<Sysname> display pim interface
PIM information of VLAN-interface 2:
  IP address of the interface is 10.10.1.20
  PIM is enabled
  PIM version is 2
  PIM mode is Sparse
  PIM query interval is 30 seconds
PIM neighbor limit is 128
  PIM neighbor policy is none
  Total 1 PIM neighbor on interface
  PIM DR(designated router) is 10.10.1.20
表3-2 display pim interface命令字段描述表
该VLAN接口的IP地址
PIM version
PIM的版本
PIM mode
VLAN接口上启动的PIM模式(密集还是稀疏)
PIM query interval
发送Hello报文的间隔
PIM neighbor limit
该VLAN接口上PIM邻居的数量限制,超过限制后路由器不加入新的邻居
PIM neighbor policy
PIM邻居过滤策略
该VLAN接口上共有一个PIM邻居
PIM DR
指定路由器
display pim neighbor [ interface interface-type interface-number ]
interface interface-type interface-number指定接口类型和接口编号,通过配置此参数可查看指定接口上的PIM邻居信息。如果不指定此参数可查看所有接口的PIM邻居信息。
【描述】
display pim neighbor命令用来查看PIM邻居信息。
# 查看所有PIM邻居的信息。
<Sysname> display pim neighbor
Neighbor Address      Interface Name       Uptime       Expires
8.8.8.6               VLAN-interface10     1637         89
表3-3 display pim neighbor命令
Neighbor Address
邻居的地址
发现邻居的VLAN接口
Uptime
发现组播组以来的时间
Expires
记录将从组表中删除的预定时间
display pim routing-table [ { { *g [ group-address [ mask { mask-length | mask } ] ] | **rp [ rp-address [ mask { mask-length | mask } ] ] } | { group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] } * } | incoming-interface { interface-type interface-number | null } | { dense-mode | sparse-mode } ] *
*g:查看(*,G)的路由项。
mask:指定组播组、组播源或RP地址的掩码,缺省值为255.255.255.255。
mask-length:指定组播组、组播源或RP地址的掩码长度,取值范围为0~32,缺省值为32 。
**rp:查看(*, *, rp) 的路由项。
rp-address:汇聚点的地址。
group-address:指定组播组地址,取值范围为224.0.0.0~239.255.255.255。
incoming-interface:查看入接口为指定接口的路由项。
interface-type interface-number:指定接口类型和接口编号,若接口类型为null,即表示查看没有入接口的路由项。
dense-mode:密集组播模式。
sparse-mode:稀疏组播模式。
【描述】
display pim routing-table命令用来显示PIM组播路由表信息。
显示的PIM组播路由表信息包括SPT与RPF信息。
# 显示PIM组播路由表信息。
<Sysname> display pim routing-table
PIM-SM Routing Table
Total 1 (S,G) entry, 1 (*,G) entry, 0 (*,*,RP) entry
(*, 228.0.0.0), RP 23.12.0.1
    Protocol 0x20: PIMSM, Flag 0x3: RPT WC
    Uptime: 00:00:13, Timeout in 197 sec
    Upstream interface: Vlan-interface1, RPF neighbor: 200.1.0.1
      Vlan-interface401, Protocol 0x100: RPT, timeout in 197 sec
(196.0.0.3, 228.0.0.0)
    Protocol 0x20: PIMSM, Flag 0x4: SPT
    Uptime: 00:10:49, Timeout in 196 sec
    Upstream interface: Vlan-interface196, RPF neighbor: NULL
      Vlan-interface401, Protocol 0x100: SPT, timeout in 197 sec
Matched 1 (S,G) entry, 1 (*,G) entry, 0 (*,*,RP) entry
表3-4 display pim routing-table命令显示信息描述表
Total 1 (*, G) entry; 1 (S, G) entry,0 (*,*,RP) entry
PIM路由表中(S,G)、(*,G)和 (*,*,RP) 表项的总数
(*, 228.0.0.0)
PIM路由表中的(*,G)表项
RP
汇聚点
Protocol
PIM的模式,是PIM-SM模式还是PIM-DM模式
Flag
PIM路由表中(S,G)或(*,G)的标志:
l      SPT:表示(S,G)表项在最短路径源树上
l      RPT:表示(S,G)或者(*,G)表项在共享树上
l      WC:表示(*,G)表项
l      LOC:表示该路由器与组播源直连
Uptime
表项已存在的时间
Timeout in 197 sec
表项将在197秒后老化
Upstream interface
入接口
Upstream neighbor
上游邻居
RPF neighbor
RPF邻居:
l      对(*,G)表项来说,当本路由器是RP时,(*,G)表项的RPF邻居是NULL
l      对(S,G)表项来说,当本路由器直连源时,(S,G)表项的RPF邻居是NULL
下游接口的列表
display pim rp-info [ group-address ]
group-address:组播组地址,通过配置该参数可查看指定组播组所对应的RP信息。如果不指定该参数,将显示所有组播组对应的RP信息。
【描述】
display pim rp-info命令用来查看RP的信息,还可以查看BSR和静态RP的信息。
# 显示组播组对应的RP信息。
<Sysname> display pim rp-info
 PIM-SM RP-SET information:
    BSR is: 4.4.4.6
    Group/MaskLen: 224.0.0.0/4
      RP 4.4.4.6
        Version: 2
        Priority: 0
        Uptime: 00:39:50
        Expires: 00:01:40
表3-5 display pim rp-info显示信息描述表
内容
内容说明
RP信息集合
BSR is:
网络中BSR的IP地址
Group/MaskLen
RP所服务的组播组范围
RP
RP的IP地址
Version
PIM的版本
Priority
RP的优先级
Uptime
RP已存在的时间
Expires
RP超时的剩余时间
3.1.10  pim
pim
undo pim
【描述】
pim命令用于进入PIM视图以配置PIM的全局参数,没有启动PIM的作用。undo pim命令清除PIM全局配置参数。
# 进入PIM视图。
[Sysname] pim
[Sysname-pim]
pim bsr-boundary
undo pim bsr-boundary
【描述】
pim bsr-boundary命令用来将交换机的接口配置为BSR服务边界,即PIM-SM域的边界。undo pim bsr-boundary命令用来删除配置的BSR服务边界。
缺省情况下,交换机未配置任何BSR服务边界。
当在某接口上配置这条命令设置了BSR服务边界后,所有自举报文(Bootstrap Message)都不能穿越域边界,但其它PIM报文可以通过域边界。通过这种方法,用户可以有效地将运行PIM-SM的网络分割为多个域,每个域上使用不同的自举路由器(Bootstrap Router)。
需要注意的是:该命令并不能建立组播边界,它只是建立了一个PIM自举报文边界。
相关配置可参考命令c-bsr
# 在Vlan-interface10接口上配置BSR服务边界。
[Sysname-Vlan-interface10] pim bsr-boundary
3.1.12  pim dm
pim dm
undo pim dm
【描述】
pim dm命令用来启动PIM-DM。undo pim dm命令用来关闭PIM-DM。
缺省情况下,接口上没有启动PIM-DM。
在通常情况下,各个接口上都应启动PIM-DM。
启动PIM-DM之前,必须先启动组播路由协议。
# 在交换机的Vlan-interface10上,启动PIM-DM。
[Sysname-Vlan-interface10] pim dm
pim neighbor-limit limit
undo pim neighbor-limit
limit:VLAN接口上的PIM邻居数量上限,取值范围为0~128。
【描述】
pim neighbor-limit命令用来限制路由器接口的PIM邻居数量,超过所配置的限制后路由器不再加入新的邻居。undo pim neighbor-limit命令用来恢复缺省配置。
缺省情况下,VLAN接口的PIM邻居数量上限为128。
如果在用户配置的时候,该VLAN接口上的PIM邻居数已经超过了配置值,原有的PIM邻居不会被删除。
# 限制Vlan-interface10接口上的PIM邻居数量上限为50。
[Sysname-Vlan-interface10] pim neighbor-limit 50
pim neighbor-policy acl-number
undo pim neighbor-policy
acl-number:基本访问控制列表,取值范围为2000~2999。
【描述】
pim neighbor-policy命令用来配置路由器对当前接口的PIM邻居进行过滤。 undo pim neighbor-policy命令用来取消过滤。
在配置该过滤功能后,只有通过访问控制列表过滤的路由器才能作为当前口的PIM邻居,其他路由器不作为PIM邻居。
重复执行该命令,新的配置将会覆盖上一次的配置。
缺省情况下,不对当前接口的PIM邻居进行过滤。
# 配置Vlan-interface10把10.10.1.2作为PIM邻居,其他都不作为PIM邻居。
[Sysname-acl-basic-2000] rule permit source 10.10.1.2 0
[Sysname-acl-basic-2000] rule deny source any
[Sysname-Vlan-interface10] pim neighbor-policy 2000
3.1.15  pim sm
pim sm
undo pim sm
【描述】
pim sm命令用来启动PIM-SM。undo pim sm命令用来关闭PIM-SM。
缺省情况下,接口上没有启动PIM-SM。
在通常情况下,各个接口上都应启动PIM-SM。
启动PIM-SM之前,必须先启动组播路由协议。
# 在Vlan-interface10接口上启用PIM-SM。
[Sysname-Vlan-interface10] pim sm
pim timer hello seconds
undo pim timer hello
seconds:接口发送Hello报文的时间间隔,取值范围为1~18000秒 。
【描述】
pim timer hello命令用来配置接口发送Hello报文的时间间隔。undo pim timer hello命令用来恢复接口发送Hello报文时间间隔的缺省值。
缺省情况下,接口发送Hello报文的时间间隔为30秒。
在接口上启动PIM-SM之后,为了发现邻居,交换机将周期性地向所有支持PIM的网络设备发送Hello报文。若接口收到了Hello报文,说明该接口存在相邻的支持PIM网络设备,该接口就将该邻居加入到自己的接口邻居列表中;接口若在指定时间内未收到其邻居列表中存在邻居发来的Hello报文,则认为该邻居已离开组播组。
# 配置交换机的Vlan-interface10接口发送Hello报文的时间间隔为40秒。
[Sysname-Vlan-interface10] pim timer hello 40
register-policy acl-number
undo register-policy
PIM视图
acl-number:指定高级访问控制列表编号,取值范围为3000~3999。只有与ACL的permit语句匹配的注册报文才会被RP接受。
【描述】
register-policy命令用来配置注册报文的过滤规则。undo register-policy命令用来删除注册报文的过滤规则。
缺省情况下,没有配置注册报文的过滤规则。
# 配置RP上对注册报文的过滤规则,只允许10.10.0.0/16范围内的组播源向225.1.0.0/16范围内的组播组发送组播数据。
[Sysname] acl number 3010
[Sysname-acl-adv-3010] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3010] quit
[Sysname] pim
[Sysname-pim] register-policy 3010
reset pim neighbor { all | { neighbor-address | interface interface-type interface-number } * }
all:配置该关键字可清除所有PIM邻居。
neighbor-address:指定邻居地址。
interface interface-type interface-number:指定接口类型和接口编号,通过配置该参数可指定要清除PIM邻居的接口。
【描述】
reset pim neighbor命令用来清除PIM的邻居。
相关配置可参考命令display pim neighbor
# 清除地址为25.5.4.3的PIM邻居。
<Sysname> reset pim neighbor 25.5.4.3
reset pim routing-table { all | { group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | incoming-interface interface-type interface-number } * }
all:清除所有PIM路由项。
mask-length:指定组播组或组播源地址的掩码长度,取值范围为0~32,缺省值为32 。
incoming-interface:通过配置该关键字可清除入接口为指定接口的PIM路由项。
interface-type interface-number:指定接口类型和接口编号,若接口类型为null,则表示清除那些没有入接口的路由项。
【描述】
reset pim routing-table命令用来清除PIM的路由项。
l              如果配置此命令时,指定group-address是224.0.0.0/24,同时指定source-address是RP地址(其中组地址可以带掩码,但是二者计算的结果必须是224.0.0.0,源地址不带掩码),则表示只删除(*,*,RP)项。
l              如果配置此命令时,指定group-address是某个组地址,同时指定source-address是0(其中组地址可以带掩码,源地址不带掩码),则表示只删除(*,G)项。
执行本命令后,不仅从PIM中删除组播路由项,而且也会删除组播核心路由表和MFC中有相应的路由项或转发项。
相关配置可参考命令reset multicast routing-tablereset multicast forwarding-tabledisplay pim routing-table
# 从PIM路由表中清除组地址为225.5.4.3的路由项。
<Sysname> reset pim routing-table 225.5.4.3
spt-switch-threshold infinity [ group-policy acl-number [ order order-value ] ]
undo spt-switch-threshold [ group-policy acl-number ]
PIM视图
infinity:指定RPT永远不向SPT切换。
group-policy acl-number:与指定组策略相匹配的组播组将启用该配置。acl-number表示基本访问控制列表编号,取值范围为2000~2999。如果不指定该参数,该配置将应用于所有组播组。
order order-value:指定ACL在组策略列表中的序号。order-value的取值范围为1~现有组策略列表中的最大序号+1,但取值范围中不包括该ACL在组策略列表中的原有序号。如果已为某ACL指定了order-value,则不允许为该ACL指定相同的order-value,否则系统将报错;如果不指定该参数,则不改变该ACL在组策略列表中的序号。
【描述】
spt-switch-threshold命令用来配置从共享树永不切换到源最短路径树的参数。undo spt-switch-threshold命令用来恢复为缺省情况。
缺省情况下,设备从RPT收到第一个组播数据包后便立即向SPT切换。
l              当需要调整组策略列表中已有ACL的次序时,可以通过配置参数acl-number指定该ACL,并设置其order-value,将该ACL插入到组策略列表的order-value位置。组策略列表中已有的其他ACL保持先后排列次序不变。
l              当需要启用组策略列表中没有的ACL时,可以通过配置参数acl-number指定该ACL,并设置其order-value,将该ACL插入到组策略列表的order-value位置。如果不指定order-value,则将其插入组策略列表的尾部。
l              如果对同一组播组配置了多条该命令,则该组播组按顺序匹配到的第一个命令将生效。
l              如果建立了组播转发表项,即使有注册出接口,后续的组播数据报文也不会被封装成注册报文进行转发。所以,在可能成为RP的交换机(即静态RP或C-RP等)上,不要使用参数infinity配置永远不向SPT切换,以免导致转发失败。
# 在不可能成为RP的交换机上,配置RPT永远不向SPT切换。
[Sysname] pim
[Sysname -pim] spt-switch-threshold infinity
source-lifetime interval
undo source-lifetime
PIM视图
interval:指定组播源的生存时间,取值范围为210~31536000,单位为秒。
【描述】
source-lifetime命令用来配置组播源的生存时间。undo source-lifetime命令用来恢复缺省情况。
缺省情况下,组播源的生存时间为210秒。
只能配置PIM 路由表和组播路由表中所有(S,G)项统一的老化时间,不能配置某一个指定(S,G)项的老化时间,并且配置会改变已经存在的所有的(S,G)项的老化时间。
# 配置组播源的生存时间为3000秒。
[Sysname] pim
[Sysname-pim] source-lifetime 3000
source-policy acl-number
undo source-policy
PIM视图
acl-number:基本或高级访问控制列表,取值范围为2000~3999。
【描述】
source-policy命令用来配置路由器对接收的组播数据报文根据源(组)地址进行过滤。undo source-policy命令用来取消该配置。
l              如果配置了源地址过滤,并且配置了基本访问控制列表,则对接收的所有组播数据报文匹配源地址,未通过匹配的报文将被丢弃。
l              如果配置了源地址过滤,并且配置了高级访问控制列表,则对接收的所有组播数据报文匹配源地址和组地址,未通过匹配的报文将被丢弃。
该命令不仅过滤组播数据,还过滤注册报文中封装的组播数据。
重复执行此命令,新的配置会覆盖上一次的配置。
# 配置丢弃源为10.10.1.1的组播数据,接受其他任意源的组播数据。
[Sysname] pim
[Sysname-pim] source-policy 2000
[Sysname-pim] quit
[Sysname-acl-basic-2000] rule deny source 10.10.1.1 0
[Sysname-acl-basic-2000] rule permit source any
3.1.23  static-rp
static-rp rp-address [ acl-number ]
undo static-rp
PIM视图
rp-address:静态RP地址,必须是合法的单播IP地址。
acl-number:基本访问控制列表,用于控制静态RP所服务的组播组范围。取值范围为2000~2999。如果配置时不指定访问控制列表,则静态RP为所有组播组服务;如果指定了访问控制列表,则静态RP只为通过该列表的组播组服务。
【描述】
static-rp命令用来配置静态RP。undo static-rp命令用来取消静态RP配置。
静态RP用作动态RP的备份,以提高网络的健壮性。在BSR机制选举产生的RP有效的情况下,静态RP不起作用。PIM域内所有路由器必须同时配置该命令并且指定同一RP地址。
相关配置可参考命令display pim rp-info
# 配置10.110.0.6为静态RP,并且只为ACL 2000所定义的组播组提供服务。
[Sysname] pim
[Sysname-pim] static-rp 10.110.0.6 2000
4 MSDP配置命令
4.1  MSDP配置命令
cache-sa-enable
undo cache-sa-enable
MSDP视图
【描述】
cache-sa-enable命令用来启动SA消息缓存机制。undo cache-sa-enable命令用来取消SA消息缓存机制。
在缺省情况下,SA消息缓存机制处于开启状态。
如果SA消息缓存机制处于开启状态,那么它在收到一个新的组加入消息时,不会马上向其指定的MSDP 对等体发送SA请求消息。
相关命令可参考display msdp sa-cachereset msdp sa-cachedisplay msdp sa-count
# 关闭SA消息缓存机制。
[Sysname] msdp
[Sysname-msdp] undo cache-sa-enable
display msdp brief
【描述】
display msdp brief命令用来显示MSDP对等体状态的简要信息。
# 查看MSDP对等体状态的简要信息。
<Sysname> display msdp brief
MSDP Peer Brief Information
  Peer's Address     State   Up/Down time   AS     SA Count  Reset Count
  20.20.20.20        Up       00:00:13      100     0         0
表4-1 display msdp brief命令显示信息描述表
Peer's Address
MSDP对等体地址
MSDP对等体的状态:
l      Up:连接建立,处于会话状态
l      Listen:连接建立,本地作为服务器端,处于监听状态
l      Connect:连接未建立,本地作为客户端,处于连接状态
l      Shutdown:关闭状态
l      Down:连接失败
Up/Down time
MSDP对等体连接已建立/失败的时长
AS
MSDP对等体所在自治系统的号码,“?”表示无法获得自治系统号码
SA Count
缓存中(S,G)项的数量
Reset Count
MSDP对等体连接复位的次数
display msdp peer-status [ peer-address ]
peer-address:查看指定MSDP对等体的详细状态信息。如果不指定该参数,将显示所有MSDP对等体的详细状态信息。
【描述】
display msdp peer-status命令用来显示MSDP对等体状态的详细信息。
相关配置可参考命令peer
# 查看MSDP对等体10.110.11.11的详细信息。
<Sysname> display msdp peer-status 10.110.11.11
MSDP Peer 20.20.20.20, AS 100
  Description:
  Information about connection status:
    State: Up
    Up/down time: 14:41:08
    Resets: 0
    Connection interface: LoopBack0 (20.20.20.30)
    Number of sent/received messages: 867/947
    Number of discarded output messages: 0
    Elapsed time since last connection or counters clear: 14:42:40
  Information about (Source, Group)-based SA filtering policy:
    Import policy: none
    Export policy: none
  Information about SA-Requests:
    Policy to accept SA-Request messages: none
    Sending SA-Requests status: disable
  Minimum TTL to forward SA with encapsulated data: 0
  SAs learned from this peer: 0, SA-cache maximum for the peer: none
  Input queue size: 0, Output queue size: 0
  Counters for MSDP message:
    Count of RPF check failure: 0
    Incoming/outgoing SA messages: 0/0
    Incoming/outgoing SA requests: 0/0
    Incoming/outgoing SA responses: 0/0
    Incoming/outgoing data packets: 0/0
表4-2 display msdp peer-status命令显示信息描述表
MSDP Peer
MSDP对等体的地址
AS
MSDP对等体所在自治域的号码,“?”表示无法获得自治域号码
MSDP对等体的状态:
l      Up:连接建立,处于会话状态
l      Shutdown:关闭状态
l      Down:连接失败
Up/Down time
MSDP对等体连接建立/失败发生的时间
Resets
MSDP对等体连接复位的次数
用于与对端对等体地址建立TCP连接的接口及其IP地址
MSDP通过该连接发送和接收的消息数目
丢弃的待发送信息
最近一次清除该MSDP对等体信息时刻距现在的时间
SA消息过滤列表信息:
l      Import policy:接收指定MSDP对等体的SA消息的过滤列表
l      Export policy:转发指定MSDP对等体的SA消息的过滤列表
SA请求消息信息:
l      Policy to accept SA-Request messages:接收或转发来自指定MSDP对等体SA消息的过滤规则
l      Sending SA-Requests status:是否使能在收到一个新的组加入消息时,向其指定的MSDP对等体发送SA请求消息
封装在SA消息中的组播数据包的最小TTL值
缓存的SA消息的数量
可缓存来自指定MSDP对等体的SA消息最大数量
Input queue size
输入缓存中所缓存的数据长度
Output queue size
输出缓存中所缓存的数据长度
MSDP消息的统计数:
l      Count of RPF check failure:未通过RPF检查而被丢弃的SA消息的统计数
l      Incoming/outgoing SA messages:接收和发送的SA消息的统计数
l      Incoming/outgoing SA requests:接收和发送的SA请求消息的统计数
l      Incoming/outgoing SA responses:接收和发送的SA响应消息的统计数
l      Incoming/outgoing data packets:接收和发送的封装有组播数据的SA消息的统计数
display msdp sa-cache  [ group-address | source-address | as-number ] *
group-address:组播组地址,通过配置此参数可以查看指定组播组的对应(S,G)表项。
source-address:组播源地址,通过配置此参数可以查看指定组播源的对应(S,G)表项。
as-number:指定自治系统号码,取值范围为1~65535
【描述】
display msdp sa-cache命令用来查看MSDP缓存中的(S,G)表项信息。
l              只有配置了cache-sa-enable命令之后,执行本命令才会有相应的输出;
l              如果不指定源地址,将显示指定组所有的源信息;
l              如果不指定组地址和源地址,将显示所有SA缓存;
l              如果不指定自治域号,将显示所有自治域的相关信息。
#查看MSDP缓存中的(S,G)表项信息。
<Sysname> display msdp sa-cache
MSDP Total Source-Active Cache - 5 entries
(Source, Group)                  Origin RP       Pro   AS   Uptime   Expires
(10.10.1.2, 225.1.1.1)          10.10.10.10      ?    ?   00:00:10 00:05:50
(10.10.1.3, 225.1.1.1)          10.10.10.10      ?    ?   00:00:11 00:05:49
(10.10.1.2, 225.1.1.2)          10.10.10.10      ?    ?   00:00:11 00:05:49
(10.10.2.1, 225.1.1.2)          10.10.10.10      ?    ?   00:00:11 00:05:49
(10.10.1.2, 225.1.2.2)            10.10.10.10       ?     ?   00:00:11 00:05:49
 MSDP matched 5 entries
表4-3 display msdp sa-cache命令显示信息描述表
SA缓存中(S,G)项的总数
(Source, Group)
表示(S,G)项:(源地址,组地址)
Origin RP
生成该(S,G)项的源RP地址
Pro
源RP的自治系统号码来源于何种协议类型,“?”表示无法获得协议类型
AS
源RP的自治系统号码,“?”表示无法获得自治系统号码
Uptime
(S,G)项缓存已存在的时间
Expires
(S,G)项缓存超时剩余时间
display msdp sa-count [ as-number ]
as-number:指定自治域号码,取值范围为1~65535。
【描述】
display msdp sa-count命令用来查看SA缓存中的(S,G)表项的数量。
只有配置了cache-sa-enable命令之后,执行本命令才会有输出。
# 查看SA缓存中(S,G)表项的数量。
<Sysname> display msdp sa-count
Number of cached Source-Active entries, counted by Peer
  Peer's Address     Number of SA
  10.10.10.10        5
  Number of source and group, counted by AS
  AS     Number of source    Number of group
  100    3                    3
  Total Source-Active entries: 5
表4-4 display msdp sa-count命令显示信息描述表
按照对等体,统计缓存中(S,G)项的数量
Peer's Address
发送SA消息的MSDP对等体地址
Number of SA
来自该对等体的(S,G)项数量
按照源RP所属的自治系统,统计缓存中(S,G)项的数量
AS
Number of source
来自该自治系统的组播源的统计数
Number of group
来自该自治系统的组播组的统计数
4.1.6  import-source
import-source [ acl acl-number ]
undo import-source
MSDP视图
acl-number:基本或高级IP访问控制列表号,范围2000~3999。控制SA消息的通告,基本访问控制列表对源进行过滤,高级访问控制列表对源/组进行过滤。如果忽略该参数,将不通告任何组播源。
【描述】
import-source命令用来限制MSDP创建SA消息时,本域中的哪些(S, G)项需要被通告。undo import-source命令用来取消配置。
缺省情况下,SA消息通告域内的所有的(S, G)项。
除了可以控制SA消息的创建,还可以使用peer sa-policy importpeer sa-policy export命令过滤转发的SA消息。
# 配置MSDP对等体创建SA消息时,通告组播路由表中的特定的(S,G)项:组播源在10.10.0.0/16网段,组播组地址为225.1.0.0/16。
[Sysname] acl number 3101
[Sysname-acl-adv-3101] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3101] quit
[Sysname] msdp
[Sysname-msdp] import-source acl 3101
4.1.7  msdp
msdp
undo msdp
【描述】
msdp命令用来启动MSDP并进入MSDP视图。undo msdp命令用来清除MSDP视图下的所有配置,释放MSDP占用的资源,并恢复初始状态。
相关配置可参考命令peer
# 启动MSDP并进入MSDP视图。
[Sysname] msdp
# 清除MSDP视图下的所有配置。
[Sysname] undo msdp
4.1.8  msdp-tracert
msdp-tracert source-address group-address rp-address [ max-hops max-hops ] [ next-hop-info | sa-info | peer-info ]* [ skip-hops skip-hops ]
source-address:指定SA消息中的组播源地址。
group-address:指定SA消息中的组播组地址。
rp-address:指定产生SA消息的源RP的IP地址。
max-hops:跟踪的最大跳数,范围为1~255,缺省值为16。
next-hop-info:指定收集下一跳信息的标志位。
sa-info:指定收集SA实体信息的标志位。
peer-info:指定收集MSDP 对等体信息的标志位。
skip-hops:在收集详细信息之前忽略的跳数,范围为0~255,缺省值为0。
【描述】
msdp-tracert命令用来跟踪SA消息在网络中传递的路径,可以定位消息丢失、减少配置错误等问题,在确定SA消息的传递路径后,通过正确配置,可以避免SA消息泛滥。
# 指定跟踪的最大跳数,并收集SA和MSDP peer的详细信息。
<Sysname> msdp-tracert 10.10.1.1 225.2.2.2 20.20.20.20 max-hops 10 sa-info peer-info
MSDP tracert: press CTRL_C to break
 D-bit:  set if have this (S,G) in cache but with a different RP
 RP-bit: set if this router is an RP
 NC-bit: set if this router is not caching SA's
 C-bit:  set if this (S,G,RP) tuple is in the cache
 MSDP trace route path information:
   Router Address:  20.20.1.1
     Fixed-length response info:
       Peer Uptime: 10 minutes,  Cache Entry Uptime: 30 minutes
       D-bit: 0,  RP-bit: 1,  NC-bit: 0,  C-bit: 1
       Return Code: Reached-max-hops
     Next Hop info:
       Next-Hop Router Address: 0.0.0.0
     SA info:
       Count of SA messages received for this (S,G,RP): 0
       Count of encapsulated data packets received for this (S,G,RP):0
       SA cache entry uptime: 00:30:00 ,  SA cache entry expiry time: 00:03:32
     Peering info:
       Peering Uptime: 10 minutes,  Count of Peering Resets: 3
表4-5 msdp-tracert命令显示信息描述表
主要字段
Router Address
本地路由器与Peer-RPF邻居建立Peering会话的地址
Peer Uptime
本地路由器与Peer-RPF邻居进行Peering会话的时间,单位为分钟,最大值为255
Cache Entry Uptime
本地路由器SA缓存中(S,G,RP)项存在的时间,单位为分钟,最大值为255
D-bit: 1
在本地路由器的SA缓存中存在(S,G,RP)项,但是RP与请求消息中指定的RP不同
RP-bit: 1
本地路由器是一个RP,不一定是(S,G,RP)项中的源RP
NC-bit: 0
本地路由器启动了SA缓存
C-bit: 1
返回的原因为到达最大的跳数,其他可能取值有:
Hit-src-RP:本跳路由器即是(S,G,RP)项中的源RP
如果使用了参数next-hop-info,则显示Peer-RPF邻居地址
为跟踪此(S,G,RP)项所接收的SA消息个数
为跟踪此(S,G,RP)项所接收的数据包个数
SA缓存项存在的时间
SA缓存项将要老化掉的时间
会话重置的次数
originating-rp interface-type interface-number
undo originating-rp
MSDP视图
【描述】
originating-rp命令用来配置接口地址为SA消息的RP地址。undo originating-rp命令用来取消将接口地址配置为SA消息的RP地址。
缺省情况下,SA消息的RP地址为PIM配置的RP地址。
# 配置Vlan-interface 100接口的IP地址为SA消息的RP地址。
[Sysname] msdp
[Sysname-msdp] originating-rp Vlan-interface 100
peer peer-address connect-interface interface-type interface-number
undo peer peer-address
MSDP视图
peer-address:MSDP对等体的IP地址。
interface-type interface-number:指定接口类型和接口编号,本地路由器使用该接口的主地址作为源IP与远端MSDP对等体建立TCP连接。
【描述】
peer connect-interface命令用来配置MSDP对等体并使用指定接口与对等体进行连接。undo peer connect-interface命令用来取消配置的MSDP对等体连接。
如果本地路由器与一个MSDP对等体同时也是BGP对等体,MSDP对等体和BGP对等体应使用相同的IP地址。
相关配置可参考命令static-rpf-peer
# 把使用IP地址125.10.7.6的路由器配置为本地路由器的MSDP对等体,并使用VLAN-interface100接口与其进行连接。
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 connect-interface Vlan-interface 100
peer peer-address description text
undo peer peer-address description
MSDP视图
text:描述性文本,区分大小写,最长为80个字符
【描述】
peer description命令用来为MSDP对等体配置描述信息。undo peer description命令用来删除已配置的描述信息。
缺省情况下,MSDP对等体没有描述信息。
管理员可以通过配置描述信息方便地区分MSDP对等体。
相关配置可参考命令display msdp peer-status
# 为IP地址为125.10.7.6的MSDP对等体添加描述信息“Router CstmrA”,以指明该路由器为客户A。
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 description router CstmrA
peer peer-address mesh-group name
undo peer peer-address mesh-group
MSDP视图
peer-address:全连接组成员的MSDP对等体的IP地址。
【描述】
peer mesh-group命令用来将一个MSDP对等体加入全连接组。undo peer mesh-group命令用来取消该配置。
缺省情况下,MSDP对等体不属于任何全连接组。
# 配置地址为125.10.7.6的MSDP对等体成为名称为Grp1的全连接组的成员。
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 mesh-group Grp1
peer peer-address minimum-ttl ttl-value
undo peer peer-address minimum-ttl
MSDP视图
peer-address:应用TTL限制的MSDP对等体的IP地址。
ttl-value:TTL阈值,取值范围为0~255。
【描述】
peer minimum-ttl命令用来配置发送到指定MSDP对等体的组播数据包的最小TTL。undo peerminimum-ttl命令用来恢复缺省值。
缺省情况下,发送到MSDP对等体的组播数据包的最小TTL值为0。
相关配置可参考命令peer
# 配置封装在SA消息中组播报文的最小TTL值为10,只有TTL值大于或等于10的组播报文才能转发给MSDP对等体110.10.10.1。
[Sysname] msdp
[Sysname-msdp] peer 110.10.10.1 minimum-ttl 10
peer peer-address request-sa-enable
undo peer peer-address request-sa-enable
MSDP视图
【描述】
peer request-sa-enable命令用来启动路由器在接收到一个新的组加入消息时,向其指定的MSDP对等体发送SA请求消息。undo peer request-sa-enable命令用来取消该配置。
缺省情况下,路由器在收到新的组加入消息时,不向其MSDP对等体发送SA请求消息,而是等待下一个SA消息的到来。
相关配置可参考命令cache-sa-enable
# 配置向MSDP对等体125.10.7.6发送SA请求消息。
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 request-sa-enable
peer peer-address sa-cache-maximum sa-limit
undo peer peer-address sa-cache-maximum
MSDP视图
sa-limit:指定可缓存的(S,G)表项的最大数量 ,取值范围为1~2048。
【描述】
peer sa-cache-maximum命令用来配置可缓存从指定MSDP对等体学到的(S,G)表项的最大数量。undo peer sa-cache-maximum命令用来恢复缺省设置。
缺省情况下,可缓存从任一MSDP对等体学到的(S,G)表项的最大数量为2048。
在可能遭受DoS攻击的网络中,建议对所有MSDP对等体进行此项配置。
相关配置可参考命令display msdp sa-countdisplay msdp peer-statusdisplay msdp brief
# 配置路由器在接收到MSDP对等体(地址为125.10.7.6)的SA消息时限制产生缓存的数量为100。
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 sa-cache-maximum 100
peer peer-address sa-policy { import | export } [ acl acl-number ]
undo peer peer-address sa-policy { import | export }
MSDP视图
peer-address:指定MSDP对等体的地址。
import:表示对来自指定MSDP对等体的SA消息进行过滤。
export:表示对转发给指定MSDP对等体的SA消息进行过滤。
acl acl-number:指定高级访问控制列表编号,取值范围为3000~3999。如果不指定该参数,将过滤掉所有携带(S,G)项的SA消息。
【描述】
peer sa-policy命令用来配置接收或转发指定MSDP对等体的SA消息的过滤规则。undo peer sa-policy命令用来取消该配置。
缺省情况下,对接收或转发的消息不作过滤,即从MSDP对等体接收或转发所有的SA消息。
相关配置可参考命令peer
# 配置向MSDP对等体125.10.7.6只转发通过ACL 3100过滤的SA消息。
[Sysname] acl number 3100
[Sysname-acl-adv-3100] rule permit ip source 170.15.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-adv-3100] quit
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 sa-policy export acl 3100
peer peer-address sa-request-policy [ acl acl-number ]
undo peer peer-address sa-request-policy
MSDP视图
peer-address:MSDP对等体地址,对该MSDP对等体发出的SA请求消息进行过滤。
acl-number:基本IP访问控制列表号,描述组播组地址,取值范围为2000~2999。如果不指定访问控制列表,则忽略所有SA请求消息。
【描述】
peer sa-request-policy命令用来限制路由器从MSDP对等体接收的SA请求消息。undo peer sa-request-policy命令用来取消该限制。
缺省情况下,路由器接收来自该MSDP对等体的所有SA请求消息。
如果没有指定访问控制列表,则忽略所有SA请求。如果指定了访问控制列表,只处理符合该列表的组的SA请求消息,其他的被忽略。
相关配置可参考命令peer
# 配置过滤SA请求消息的访问控制列表,SA消息来自MSDP对等体175.58.6.5,来自组地址范围225.1.1.0/24 的SA请求消息被接收,其它的则被忽略。
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname-acl-basic-2001] quit
[Sysname] msdp
[Sysname-msdp] peer 175.58.6.5 sa-request-policy acl 2001
reset msdp peer peer-address
【描述】
reset msdp peer命令用来重置与指定MSDP对等体的TCP连接,并清除指定MSDP对等体的所有统计信息。
相关配置可参考命令peer
# 重置与MSDP对等体125.10.7.6的TCP连接和统计信息。
<Sysname> reset msdp peer 125.10.7.6
reset msdp sa-cache [ group-address ]
group-address:组地址,匹配该地址的(S,G)缓存项从SA缓存中删除。如果不指定组播组地址,则清除所有SA缓存项。
【描述】
reset msdp sa-cache命令用来清除MSDP的SA缓存项。
相关配置可参考命令cache-sa-enabledisplay msdp sa-cache
# 从SA缓存中清除组地址为225.5.4.3的缓存项。
<Sysname> reset msdp sa-cache 225.5.4.3
reset msdp statistics [ peer-address ]
peer-address:清除指定MSDP对等体的统计信息。如果不指定该参数,则清除所有MSDP对等体的统计信息。
【描述】
reset msdp statistics命令用来在不重置MSDP对等体的情况下清除一个或多个MSDP对等体的统计信息。
相关命令可参考reset msdp peer
# 清除MSDP对等体125.10.7.6的统计信息。
<Sysname> reset msdp statistics 125.10.7.6
4.1.21  shutdown
shutdown peer-address
undo shutdown peer-address
MSDP视图
【描述】
shutdown命令用来关闭指定MSDP对等体。undo shutdown命令用来恢复对等体连接。
缺省情况下,不关闭MSDP对等体。
相关配置可参考命令peer
# 配置关闭MSDP对等体125.10.7.6。
[Sysname] msdp
[Sysname-msdp] shutdown 125.10.7.6
static-rpf-peer peer-address [ rp-policy ip-prefix-name ]
undo static-rpf-peer peer-address
MSDP视图
peer-address:接收SA消息的静态RPF对等体地址。
ip-prefix-name:基于RP地址的过滤策略,对SA消息中的RP进行过滤。ip-prefix-name表示地址前缀列表的名称,取值范围为1~19个字符。
【描述】
static-rpf-peer命令来配置静态RPF对等体。undo static-rpf-peer命令用来取消静态RPF对等体。
缺省情况下,没有静态RPF对等体。
如果命令peer只配置了一个MSDP对等体,则这个MSDP对等体将被作为静态RPF对等体。当同时配置多个静态RPF对等体时,必须遵守如下两种配置方法:
l              都使用rp-policy参数:多个静态RPF对等体同时起作用,并按照所配置的前缀列表对SA消息中的RP进行过滤,只接收RP地址通过过滤的SA消息。如果同时配置了多个使用相同rp-policy参数的静态RPF对等体,则从其中一个对等体接收到的SA消息会向其他对等体转发。
l              都不使用rp-policy参数:按照配置的先后顺序,只有第一个连接状态是UP的静态RPF对等体是激活的,接收来自该对等体所有的SA消息,从其它静态RPF对等体接收到的SA消息将被丢弃。如果这个激活的静态RPF对等体失效(如配置取消或连接断开),仍然按照配置的先后顺序,重新选择第一个连接状态是UP的静态RPF对等体作为激活的静态RPF对等体。
相关配置可参考命令peerip ip-prefix
# 配置静态RPF对等体。
[Sysname] ip ip-prefix list1 permit 130.10.0.0 16 greater-equal 16 less-equal 32
[Sysname] msdp
[Sysname-msdp] peer 130.10.7.6 connect-interface Vlan-interface 100
[Sysname-msdp] static-rpf-peer 130.10.7.6 rp-policy list1
4.1.23  timer retry
timer retry seconds
undo timer retry
MSDP视图
seconds:表示建立MSDP对等体连接的重试周期,取值范围为1~60,单位为秒。
【描述】
timer retry命令用来配置建立MSDP对等体连接的重试周期。undo timer retry命令用来恢复缺省值。
缺省情况下,建立MSDP对等体连接的重试周期为30秒。
相关配置可参考命令peer connect-interface
# 配置连接请求重试周期为60秒。
[Sysname] msdp
[Sysname-msdp] timer retry 60
5 IGMP Snooping配置命令
【描述】
display igmp-snooping configuration命令用来查询IGMP Snooping的配置信息。
如果当前交换机没有启动IGMP Snooping,将显示IGMP Snooping没有启动的信息。
如果交换机启动了IGMP Snooping,显示的IGMP Snooping的配置信息包括:
l              IGMP Snooping已经启动
l              路由器端口老化时间
l              最大响应查询时间
l              成员端口老化时间
l              是否启动了IGMP Snooping禁止广播功能
相关配置可参考命令igmp-snoopingigmp-snooping router-aging-timeigmp-snooping max-response-timeigmp-snooping host-aging-timeigmp-snooping nonflooding-enable
# 显示交换机的IGMP Snooping的配置情况。
<Sysname> display igmp-snooping configuration
  Enable IGMP Snooping.
  The router port timeout is 105 second(s).
  The max response timeout is 10 second(s).
  The host port timeout is 260 second(s).
  Enable IGMP Snooping Non-Flooding.
上述信息表示:IGMP Snooping已经启动,路由器端口老化时间为105秒,最大响应查询时间为10秒,成员端口老化时间为260秒、已经启动了IGMP Snooping禁止广播功能。
display igmp-snooping group [ vlan vlan-id ]
vlan vlan-id:指定VLAN的编号,取值范围为1~4094,通过配置此参数可以查看指定VLAN内IGMP Snooping组播组的信息。如果不指定此参数,将显示所有VLAN下的IGMP Snooping组播组信息。
【描述】
display igmp-snooping group命令用来查看IGMP Snooping组播组的信息。
相关配置可参考命令igmp-snoopingigmp host-joinmulticast static-group vlanmulticast static-group interfacemulticast static-group vlanmulticast static-router-portmulticast static-router-port vlan
# 查看VLAN100下IGMP Snooping组播组信息。
<Sysname> display igmp-snooping group vlan 100
  Vlan(id):100.
                     GigabitEthernet1/0/11
        IP group address:228.0.0.1
                     GigabitEthernet1/0/23
                     GigabitEthernet1/0/10
MAC group(s):
        MAC group address:0100-5c00-0001
        Host port(s): GigabitEthernet1/0/10       GigabitEthernet1/0/23
表5-1 display igmp-snooping group显示字段描述表
所有VLAN下的IP组播组总数
所有VLAN下的MAC组播组总数
Vlan(id):
指定VLAN下的组播组信息
该VLAN下的IP组播组总数
该VLAN下的MAC组播组总数
静态路由器端口
动态路由器端口
静态成员端口
动态成员端口
IP group address:
IP组播组地址
MAC group(s):
MAC组播组
MAC group address:
MAC组播组地址
Host port(s)
主机成员端口
【描述】
display igmp-snooping statistics命令用来查看IGMP Snooping的统计信息。
显示的IGMP Snooping的统计信息包括:
l              收到IGMP通用查询报文个数;
l              收到IGMP特定组查询报文个数;
l              收到IGMPv1报告报文个数;
l              收到IGMPv2报告报文个数;
l              收到IGMP离开报文个数;
l              收到IGMP错误报文个数;
l              发送IGMP特定组查询报文个数。
当启动IGMP V3 Snooping IGMP V3的报告报文会统计到IGMP V2报文的统计项中。
# 显示IGMP Snooping的统计信息。
<Sysname> display igmp-snooping statistics
Received IGMP general query packet(s) number:1.
Received IGMP specific query packet(s) number:0.
Received IGMP V1 report packet(s) number:0.
Received IGMP V2 report packet(s) number:3.
Received IGMP leave packet(s) number:0.
Received error IGMP packet(s) number:0.
Sent IGMP specific query packet(s) number:0.
上述信息表示IGMP Snooping收到:
l              1个IGMP通用查询报文
l              0个IGMP特定组查询报文
l              0个IGMPv1的报告报文
l              3个IGMPv2的报告报文
l              0个IGMP离开报文
l              0个IGMP错误报文
IGMP Snooping发送:
l              0个IGMP特定组查询报文
5.1.4  igmp-snooping
igmp-snooping { enable | disable }
系统视图、VLAN视图
enable:开启IGMP Snooping功能。
disable:关闭IGMP Snooping功能。
【描述】
igmp-snooping enable命令用来开启IGMP Snooping功能。igmp-snooping disable命令用来关闭IGMP Snooping功能。
缺省情况下,交换机关闭IGMP Snooping功能。
l    二、三层组播协议可以同时运行在交换机上,但是在同一个VLAN和该VLAN对应的虚接口上不能同时运行二层和三层组播协议。
l    在启动指定VLAN的IGMP Snooping前,应首先在系统视图下启动全局IGMP Snooping功能,否则将无法配置成功。
l    如果在某VLAN内同时启动了IGMP Snooping和VLAN VPN,有可能会造成IGMP查询报文不能够通过VLAN,可以通过配置查询报文的VLAN Tag解决,详细情况请参见“5.1.16  igmp-snooping vlan-mapping”。
# 打开交换机的IGMP Snooping功能。
[Sysname] igmp-snooping enable
Enable IGMP Snooping ok.
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
系统视图、以太网端口视图
vlan-list:VLAN列表,表示多个VLAN,表示方式为vlan-list = { vlan-id [ to vlan-id ] } & < 1-10 >。其中vlan-id为 VLAN的VLAN ID,取值范围为1~4094。&<1-10>表示前面的参数最多可以重复输10次。
【描述】
igmp-snooping fast-leave命令用来启动端口从组播组中快速删除功能。端口从组播组中快速删除是指当交换机从某端口收到主机发送的离开某组播组的IGMP离开组报文时,直接把该端口从对应转发表项的出端口列表中删除。undo igmp-snooping fast-leave命令用来取消该配置。
缺省情况下,关闭端口从组播组中快速删除的功能。
l    端口从组播组中快速删除功能只能在客户端支持IGMP V2或V3时生效。
l    当在系统视图下的配置时,如果没有指定VLAN,则交换机的所有端口都启动快速删除功能;如果指定了VLAN,则该VLAN内的所有端口都启动快速删除功能。
l    当在以太网端口视图下时,如果没有指定VLAN,则无论该端口属于哪个VLAN,该端口都启动快速删除功能;如果指定了VLAN,配置只对指定VLAN内的该端口有效。
l    当快速离开与未知组播报文丢弃或禁止广播功能同时开启的情况下,如果某个端口下有多个用户,一个用户快速离开,可能会造成同一组播组中其它用户的组播业务中断。
# 在端口GigabitEthernet1/0/1下启动快速删除组播组功能。
[Sysname-GigabitEthernet1/0/1] igmp-snooping fast-leave
igmp-snooping general-query source-ip { current-interface | ip-address }
undo igmp-snooping general-query source-ip
VLAN视图
current-interface:指定当前VLAN接口的IP地址作为IGMP通用查询报文的源IP地址。如果当前VLAN的接口没有IP地址,则采用缺省的IP地址0.0.0.0作为IGMP通用查询报文的源IP地址。
ip-address:指定任意合法IP地址作为发送IGMP通用查询报文时的源IP地址。
【描述】
igmp-snooping general-query source-ip命令用来配置IGMP通用查询报文的源IP地址。undo igmp-snooping general-query source-ip命令用来恢复缺省情况。
本命令只在启动了IGMP Snooping查询器功能后才有效,否则不会发送通用查询报文。
缺省情况下,交换机发送通用查询报文的源IP地址为0.0.0.0。
相关配置可参考命令igmp-snooping querierigmp-snooping query-interval
# 配置交换机在VLAN 3上发送通用查询报文的源IP地址为2.2.2.2。
System view, return to user view with Ctrl+Z.
[Sysname] vlan 3
[Sysname-vlan3] igmp-snooping enable
[Sysname-vlan3] igmp-snooping querier
[Sysname-vlan3] igmp-snooping general-query source-ip 2.2.2.2
igmp-snooping group-limit limit [ vlan vlan-list ] [ overflow-replace ]
undo igmp-snooping group-limit [ vlan vlan-list ]
以太网端口视图
limit:允许端口加入的组播组最大数量,取值范围为1~256。
overflow-replace:允许新加入的组播组替换掉原有的组播组,替换规则是优先替换组播组地址中IP地址最小的组播组。
vlan-listVLAN列表,vlan-list{ vlan-id [ to vlan-id ] }&<1-10>。&<1-10>表示前面的参数最多可以输入10次。VLAN ID取值范围为1~4094。
【描述】
igmp-snooping group-limit命令用来限制每个端口上允许通过的组播组最大数量。undo igmp-snooping group-limit命令用来恢复到缺省设置。
如果配置时不指定VLAN,则包括当前端口的所有VLAN都生效;如果指定了VLAN,则只有当该端口属于指定VLAN时,该配置对这个端口才有效。
推荐用户在配置时指定VLAN参数,以避免消耗更多的内存。
缺省情况下,交换机每个端口上允许通过的组播组最大数量为256。
l    为了避免因组播组数量过多引起网络流量过大或导致设备的处理能力下降,可以限定交换机通过的最大组播组数量。
l    当组播组数量超过限定值时,交换机会根据组播组建立的先后顺序删除最先的建立的多余组播组,此时被删除的组播组内一些正被转发的组播流会被当成未知组播报文在本VLAN内广播,导致一段时间内非成员端口也会收到组播流。为了避免上述情况的发生,请打开未知组播报文丢弃功能或IGMP Snooping禁止广播功能。
l    关键字overflow-replace不适用IGMPv3 Snooping,即当配置了IGMPv3 Snooping后,即使配置了关键字overflow-replace当组播组数量达到最大值后,也不会用新的组播组代替已经建立的组播组。
# 配置端口GigabitEthernet1/0/1上允许通过的组播组数量最大为200。
[Sysname-GigabitEthernet1/0/1] igmp-snooping group-limit 200
igmp-snooping group-policy acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
系统视图、以太网端口视图
acl-number:基本访问控制列表号,取值范围为2000~2999。
【描述】
igmp-snooping group-policy命令用来配置IGMP Snooping Filter过滤规则。undo igmp-snooping group-policy命令用来取消该过滤规则。
缺省情况下,交换机未配置IGMP Snooping Filter过滤规则。
用户配置的ACL规则为一个组播地址或者组播地址范围(224.0.0.1~239.255.255.255):
l              当配置的规则为permit时,则端口能够加入permit的ACL范围内的组,在permit范围外的组不能够加入。
l              当配置的规则为deny,并且没有配置permit的ACL时,端口不能加入deny范围内的组播地址,且deny范围外的组播地址也不能够加入。
l    一个端口可属于多个VLAN,端口所属每个VLAN只能配置一个ACL规则。
l    在配置此命令时,如果用户没有配置ACL规则,则会过滤掉所有组播组。
l    由于绝大多数的设备采用广播方式处理未知组播报文,因此,为了确保组播数据流不会被当成未知组播送到被过滤的端口,该功能一般都和未知组播丢弃功能组合使用。
l    当在系统视图下的配置时,如果没有指定VLAN,则交换机的所有端口都启动组播过滤功能;如果指定了VLAN,则该VLAN内的所有端口都启动组播过滤功能。
l    当在以太网端口视图下配置时,如果没有指定VLAN,则在所有VLAN内都启动了组播过滤功能,且只对启动IGMP Snooping的VLAN生效;如果指定了VLAN,配置只对指定VLAN内的该端口有效。
# 配置过滤规则ACL 2000:限制用户只能点播225.0.0.0~225.255.255.255范围内的组播组。
l              配置ACL规则
l              创建VLAN 2,并将端口GigabitEthernet 1/0/1加入VLAN 2。
[Sysname] vlan 2
[Sysname-vlan2] port GigabitEthernet 1/0/1
[Sysname-vlan2] quit
l              配置对端口GigabitEthernet 1/0/1下VLAN 2只能加入符合ACL 2000的IGMP组播组
[Sysname-GigabitEthernet1/0/1] igmp-snooping group-policy 2000 vlan 2
# 配置过滤规则2001,对用户限制不能点播225.0.0.0~225.0.0.255范围内的组播,范围外的组播可以点播。
l              配置ACL规则
[Sysname-acl-basic-2001] rule deny source 225.0.0.0 0.0.0.255
[Sysname-acl-basic-2001] rule permit source any
l              创建VLAN 2,并将端口GigabitEthernet 1/0/2加入VLAN 2。
[Sysname] vlan 2
[Sysname-vlan2] port GigabitEthernet 1/0/2
l              配置对端口GigabitEthernet 1/0/2下VLAN 2只能加入符合ACL 2001的IGMP组播组
[Sysname] interface GigabitEthernet 1/0/2
[Sysname-GigabitEthernet1/0/2] igmp-snooping group-policy 2001 vlan 2
igmp-snooping host-aging-time seconds
undo igmp-snooping host-aging-time
seconds:组播组成员端口的老化时间,取值范围为200~1000,单位为秒。
【描述】
igmp-snooping host-aging-time命令用来设置组播组成员端口的老化时间。undo igmp-snooping host-aging-time命令用来恢复缺省值。
缺省情况下,组播组成员端口老化时间为260秒。
设置组播组的成员老化时间,用来控制组播组成员的刷新频率。在组成员频繁变化的环境下,相应的要把老化时间设置的短一些,反之亦然。
可以通过命令display igmp-snooping configuration查看当前的成员端口老化时间。
# 把老化时间设置为300秒。
[Sysname] igmp-snooping host-aging-time 300
igmp-snooping max-response-time seconds
undo igmp-snooping max-response-time
seconds:IGMP通用查询报文的最大响应查询时间,取值范围为1~25,单位为秒。
【描述】
igmp-snooping max-response-time命令用来配置IGMP通用查询报文的最大响应时间。undo igmp-snooping max-response-time命令用来恢复缺省值。
缺省情况下,IGMP通用查询报文的最大响应时间为10秒。
合理设置最大响应时间,可以使主机快速响应查询信息,查询器也就能快速地掌握组播组成员的存在状况。
可以通过命令display igmp-snooping configuration查看当前IGMP通用查询报文的最大响应时间。
# 设置IGMP Snooping报文的响应时间为15秒。
[Sysname] igmp-snooping max-response-time 15
undo igmp-snooping nonflooding-enable
【描述】
igmp-snooping nonflooding-enable 命令用于启动IGMP Snooping禁止广播功能。undo igmp-snooping nonflooding-enable用于关闭IGMP Snooping禁止广播功能。
缺省情况下,没有启动IGMP Snooping禁止广播功能。
IGMP Snooping禁止广播功能与未知组播报文丢弃功能的区别就在于:前者将未知的组播数据报文向路由器端口转发,而后者则会直接丢弃未知组播数据报文。
必须在全局开启IGMP Snooping的情况下,才允许配置该命令。 在全局关闭IGMP Snooping情况下,该配置也相应被删除。
l    如果已经配置了未知组播报文丢弃功能或IRF Fabric功能,则不能配置IGMP Snooping禁止广播功能。
l    IGMP Snooping禁止广播功能与组播源端口抑制功能不能同时生效,如果开启IGMP Snooping禁止广播功能并且在端口上启动了组播源端口抑制功能则只有组播源端口抑制功能生效,而IGMP Snooping禁止广播功能不起作用,从该端口收到的组播数据将被丢弃。
相关的配置可参考unknown-multicast drop enable、multicast-source-denydisplay multicast-source-deny
# 全局开启IGMP Snooping,并且在没启动未知组播报文丢弃和配置堆叠口的情况下,启动IGMP Snooping禁止广播功能。
[Sysname] igmp-snooping nonflooding-enable
5.1.12  igmp-snooping querier
undo igmp-snooping querier
VLAN视图
【描述】
igmp-snooping querier命令用来开启当前VLAN内的IGMP Snooping查询器功能。undo igmp-snooping querier命令用来恢复缺省情况。
缺省情况下, 没有启动IGMP Snooping查询器功能。
在启动IGMP Snooping查询器之前,首先要在全局和指定VLAN内启动IGMP Snooping。
相关配置可参考命令igmp-snooping enableigmp-snooping query-intervaligmp-snooping general-query source-ip
# 在VLAN 3内启动的IGMP Snooping查询器功能。
[Sysname] vlan 3
5.1.13  igmp-snooping query-interval
igmp-snooping query-interval seconds
undo igmp-snooping query-interval
VLAN视图
seconds:发送通用查询报文的时间间隔,取值范围为1~300,单位为秒。
【描述】
igmp-snooping query-interval命令用来配置发送IGMP通用查询报文的时间间隔。undo igmp-snooping query-interval命令用来恢复缺省情况。
缺省情况下,发送IGMP通用查询报文的时间间隔为60秒。
本命令只在启动IGMP Snooping查询器功能后才有效,否则不会发送通用查询报文。
配置的发送IGMP通用查询报文的时间间隔必须大于IGMP通用查询报文的最大响应时间。
相关配置可参考命令igmp-snooping enableigmp-snooping querierigmp-snooping max-response-time igmp-snooping general-query source-ip
#在VLAN 3上发送IGMP通用查询报文的时间间隔为100秒。
[Sysname] vlan 3
[Sysname-vlan3] igmp-snooping query-interval 100
5.1.14  igmp-snooping router-aging-time
igmp-snooping router-aging-time seconds
undo igmp-snooping router-aging-time
seconds:路由器端口的存在间隔,取值范围为1~1000,单位为秒。
【描述】
igmp-snooping router-aging-time命令用来配置IGMP Snooping路由器端口老化时间。undo igmp-snooping router-aging-time命令用来恢复缺省值。
缺省情况下,路由器端口的老化时间为105秒。
定时器时长应设置为网络上使用的通用查询时间间隔的2.5倍左右。
相关配置可参考命令igmp-snooping max-response-timeigmp-snooping
# 设置IGMP Snooping路由器端口老化时间为500秒。
[Sysname] igmp-snooping router-aging-time 500
5.1.15  igmp-snooping version
igmp-snooping version version-number
undo igmp-snooping version
VLAN 视图
version-number:表示IGMP Snooping的版本号,取值范围为2~3,缺省值为2。
【描述】
igmp-snooping version 命令用来在当前VLAN中配置 IGMP Snooping 版本。
undo igmp-snooping version命令用来恢复缺省情况。
配置IGMP Snooping版本前,首先要在指定VLAN内启动IGMP Snooping。
# 在VLAN100内配置IGMP Snooping 为版本3。
Enable IGMP-Snooping ok.
[Sysname] vlan 100
[Sysname -vlan100] igmp-snooping enable
[Sysname -vlan100] igmp-snooping version 3
igmp-snooping vlan-mapping vlan vlan-id
undo igmp-snooping vlan-mapping
vlan-id :指定VLAN的编号,取值范围为14094
【描述】
igmp-snooping vlan-mapping vlan命令用来设置在指定VLAN内转发/发送IGMP通用查询报文和特定组查询报文。undo igmp-snooping vlan-mapping命令用来恢复缺省情况。
缺省情况下,不改变转发/发送IGMP通用查询报文和特定组查询报文所在的VLAN。
# 配置在VLAN2内 转发/发送IGMP通用查询报文和特定组查询报文。
[Sysname] igmp-snooping vlan-mapping vlan 2
5.1.17  igmp host-join port
igmp host-join group-address [ source-ip source-address ] port interface-list
undo igmp host-join group-address [ source-ip source-address ] port  interface-list
VLAN接口视图
source-address:组播源地址,通过配置此参数可指定模拟主机要加入的组播源地址。只有VLAN内使能IGMPv3 Snooping 时,该参数才有效。
【描述】
igmp host-join port命令用来配置当前VLAN内端口的IGMP Snooping模拟主机加入组播组或组播源组功能。undo igmp host-join port命令用来取消该配置。
缺省情况下,没有配置模拟主机加入功能。
与静态成员端口不同是配置了模拟主机加入功能的端口会作为动态成员端口而参与动态成员端口的老化过程。
相关配置可参考命令igmp-snooping enablemulticast static-group interfacemulticast static-group vlan
l    配置IGMP Snooping模拟主机加入功能前,应该先在当前接口对应的VLAN下启动IGMP Snooping功能。
l    有关模拟主机加入的概念,请参见2.1.7  igmp host-join port命令部分。
[Sysname] vlan 10
[Sysname-vlan10] igmp-snooping enable
[Sysname-vlan10] quit
5.1.18  igmp host-join
igmp host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp host-join group-address [ source-ip source-address ] vlan vlan-id
以太网端口视图
source-address组播源地址,通过配置此参数可指定模拟主机要加入的组播组地址。只有VLAN内使能IGMPv3 Snooping 时,该参数才有效。
vlan vlan-id端口所属的VLAN。vlan-id为指定VLAN的ID号,取值范围为1~4094。
【描述】
igmp host-join 命令用来配置当前端口的IGMP Snooping模拟主机加入组播组或组播源组的功能。
undo igmp host-join 命令用来取消当前端口作的IGMP Snooping模拟主机加入功能。
与静态成员端口不同的是配置了模拟主机加入功能的端口会作为动态成员端口而参与动态成员端口的老化过程。
l    配置IGMP Snooping模拟主机加入功能前,应该先在VLAN视图下启动IGMP Snooping功能;
l    当前端口必须属于指定VLAN,否则配置不会生效。
# 在GigabitEthernet 1/0/1配置模拟主机加入组播源为1.1.1.1的组播组225.0.0.1。
[Sysname]igmp-snooping enable
[Sysname]vlan 1
[Sysname-vlan1]igmp-snooping enable
[Sysname-vlan1]igmp-snooping version 3
[Sysname-vlan1]quit
[Sysname -GigabitEthernet 1/0/1] igmp host-join 225.0.0.1 source-ip 1.1.1.1 vlan 10
5.1.19  multicast static-group interface
multicast static-group group-address interface interface-list
undo multicast static-group group-address interface interface-list
VLAN接口视图
group-address:静态加入的组播组地址,取值范围为224.0.0.0~239.255.255.255。
interface-list:以太网端口列表,表示多个以太网端口,表示方式为interface-list = { interface-number [ to interface-number ] } & < 1-10 >。其中,interface-number为单个以太网端口编号。
【描述】
multicast static-group interface命令用来启动指定端口为静态成员端口。undo multicast static-group interface命令用来关闭静态成员端口功能。
缺省情况下,静态成员端口功能处于关闭状态。
该命令配置的是二层组播的静态成员端口,不支持三层组播的静态成员端口。
# 在Vlan-interface1上启动以太网端口GigabitEthernet 1/0/1到GigabitEthernet 1/0/3静态加入组播组的功能,要加入的组播组为225.0.0.1。
[Sysname-Vlan-interface1] multicast static-group 225.0.0.1 interface GigabitEthernet 1/0/1 to GigabitEthernet 1/0/3
5.1.20  multicast static-group vlan
multicast static-group group-address vlan vlan-id
undo multicast static-group group-address vlan vlan-id
以太网端口视图
vlan-id:指定以太网端口所属的VLAN。vlan-id为指定VLAN的编号,取值范围为1~4094。
【描述】
multicast static-group vlan命令用来将当前端口配置成指定组播组的静态成员端口,并指定该静态成员端口所属的VLAN。undo multicast static-group vlan 命令用来恢复缺省配置。
缺省情况下,当前端口不是任何组播组的静态成员端口。
配置当前端口为某组播组的静态成员端口时,当前端口是否属于组播VLAN及指定VLAN(当前端口作为静态成员端口时所属的VLAN)中是否已经加入了当前端口,将共同决定配置是否生效及生效的范围:
l              若当前端口不属于组播VLAN,且指定VLAN中未加入该端口,则配置无法生效。
l              若当前端口不属于组播VLAN,且指定VLAN中已加入该端口,则配置将只在指定VLAN中生效。
l              若当前端口属于组播VLAN,无论指定VLAN中是否已加入该端口,配置都只在组播VLAN中生效。
# 在GigabitEthernet1/0/1上启动静态加入组播组的功能,该以太网端口属于VLAN2,要加入的组播组为225.0.0.1。
[Sysname]interface GigabitEthernet 1/0/1
[Sysname-GigabitEthernet1/0/1] multicast static-group 225.0.0.1 vlan 2
5.1.21  multicast static-router-port
multicast static-router-port interface-type interface-number
undo multicast static-router-port interface-type interface-number
VLAN视图
interface-type interface-number:指定接口的类型和编号。
【描述】
multicast static-router-port命令用来启动指定端口为静态路由器端口。undo multicast static-router-port命令用来关闭静态路由器端口功能。
缺省情况下,静态路由器端口功能处于关闭状态。
# 在VLAN10上启动以太网端口GigabitEthernet1/0/1的静态路由器端口功能。
[Sysname] vlan 10
[Sysname-vlan10] multicast static-router-port GigabitEthernet1/0/1
5.1.22  multicast static-router-port vlan
multicast static-router-port vlan vlan-id
undo multicast static-router-port vlan vlan-id
以太网端口视图
vlan-id:指定VLAN的编号,取值范围为1~4094。
【描述】
multicast static-router-port vlan命令用来将当前端口配置成静态路由器端口,并指定该静态路由器端口所属的VLAN。undo multicast static-router-port vlan命令用来恢复缺省配置。
缺省情况下,当前端口不是静态路由器端口。
配置当前端口为静态路由器端口时,当前端口是否属于组播VLAN及指定VLAN(当前端口作为静态成员端口时所属的VLAN)中是否已经加入了当前端口,将共同决定配置是否生效及生效的范围:
# 在以太网端口GigabitEthernet1/0/1启动静态路由器端口功能,该以太网端口属于VLAN10。
[Sysname-GigabitEthernet 1/0/1] multicast static-router-port vlan 10
5.1.23  reset igmp-snooping statistics
【描述】
reset igmp-snooping statistics命令用来清除IGMP Snooping统计信息。
# 清除IGMP Snooping统计信息。
<Sysname> reset igmp-snooping statistics
5.1.24  service-type multicast
undo service-type multicast
VLAN视图
【描述】
service-type multicast命令用来将当前VLAN配置为组播VLAN。undo service-type multicast命令用来取消当前VLAN的组播VLAN配置。
缺省情况下,所有VLAN都不是组播VLAN。
通过配置组播VLAN,并将相应的交换机端口加入到组播VLAN内,同时启动IGMP Snooping功能,可以使不同VLAN内的用户共用一个组播VLAN,组播流只是在组播VLAN内进行传输,从而节省了带宽。由于组播VLAN与用户VLAN完全隔离,因此安全也得以保证。
l    一个端口只可以属于一个组播VLAN。
l    与用户终端相连的端口类型只能够为Hybrid。
l    组播成员端口必须与路由器端口属于同一个组播VLAN,否则无法接收到组播数据报文。
l    当路由器端口加入某个组播VLAN,该路由器端口必须配置成Trunk端口或者是允许组播VLAN报文带Tag发送的Hybrid端口,否则在此组播VLAN内的所有的组播成员端口都无法接收到组播数据报文。
l    如果组播成员端口需要接收由路由器端口转发的组播数据报文,但此组播路由器端口不属于任何组播VLAN,则组播成员端口需要从组播VLAN内删除,否则无法接收组播数据报文。
# 配置VLAN 2为组播VLAN。
[Sysname] vlan 2
[Sysname-vlan2] service-type multicast
